[U-Boot] [PATCH] OMAP5432: do not apply 5430 non-essential pad-confs to 5432
Some of the non-essential 5432 pads have a different purpose compared to 5430, so do not apply the 5430 non-essential pads configuration to 5432. Essential pad confs are common and can/shall be shared.
Signed-off-by: Sebastien Jan s-jan@ti.com --- board/ti/omap5_evm/evm.c | 18 ++++++++++++------ 1 file changed, 12 insertions(+), 6 deletions(-)
diff --git a/board/ti/omap5_evm/evm.c b/board/ti/omap5_evm/evm.c index c8dfdf8..e488fa5 100644 --- a/board/ti/omap5_evm/evm.c +++ b/board/ti/omap5_evm/evm.c @@ -82,13 +82,19 @@ void set_muxconf_regs_essential(void)
void set_muxconf_regs_non_essential(void) { - do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_non_essential, - sizeof(core_padconf_array_non_essential) / - sizeof(struct pad_conf_entry)); + u32 omap_rev = omap_revision();
- do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_non_essential, - sizeof(wkup_padconf_array_non_essential) / - sizeof(struct pad_conf_entry)); + if (omap_rev == OMAP5430_ES1_0) { + do_set_mux(CONTROL_PADCONF_CORE, + core_padconf_array_non_essential, + sizeof(core_padconf_array_non_essential) / + sizeof(struct pad_conf_entry)); + + do_set_mux(CONTROL_PADCONF_WKUP, + wkup_padconf_array_non_essential, + sizeof(wkup_padconf_array_non_essential) / + sizeof(struct pad_conf_entry)); + } }
#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_GENERIC_MMC)
One of the things that's been discussed before is that enabling "non-essential" things can lead to PM problems later in the kernel, so should we be enabling anything U-Boot doesn't really need, ever, in these cases?
Yes, in fact non- essential muxes/clocks/dplls should never be enabled in the bootloader. But today the kernel up to OMAP5430 based boards are dependent upon these settings. But atleast for 5432 by removing this, we can force things to be fixed in the kernel. Also we should remove these non essential stuff for all. I will send a patch to remove this for OMAP4/5 as well.
Thanks, Sricharan
Sebastien Jan
Sricharan R
