[U-Boot] [PATCH] M28EVK: Fix build if CONFIG_CMD_NAND not selected
Signed-off-by: Marek Vasut marek.vasut@gmail.com Cc: Wolfgang Denk wd@denx.de Cc: Stefano Babic sbabic@denx.de --- include/configs/m28evk.h | 4 +++- 1 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 39c841f..dcea878 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -140,6 +140,7 @@ /* * NAND */ +#define CONFIG_ENV_SIZE (16 * 1024) #ifdef CONFIG_CMD_NAND #define CONFIG_NAND_MXS #define CONFIG_APBH_DMA @@ -150,7 +151,6 @@
/* Environment is in NAND */ #define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_RANGE (512 * 1024) @@ -173,6 +173,8 @@ "512k(redundant-environment)," \ "4m(kernel)," \ "-(filesystem)" +#else +#define CONFIG_ENV_IS_NOWHERE #endif
- NAND
BUMP
Hi Marek,
Couldn't you use CONFIG_ENV_IS_IN_MMC instead of CONFIG_ENV_IS_NOWHERE here?
Regards,
Fabio Estevam
Hi Marek,
- NAND
We decided to not have env elsewhere until env-in-multiple-locations patch is in place.
M
Regards,
Fabio Estevam
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
