[U-Boot] [PATCH] do_bootd: unify duplicate prototypes
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/hush.c | 4 ---- common/main.c | 2 -- include/command.h | 3 +++ 3 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/common/hush.c b/common/hush.c index 4dd9513..2482506 100644 --- a/common/hush.c +++ b/common/hush.c @@ -93,8 +93,6 @@ #include <common.h> /* readline */ #include <hush.h> #include <command.h> /* find_cmd */ -/*cmd_boot.c*/ -extern int do_bootd (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); /* do_bootd */ #endif #ifndef __U_BOOT__ #include <ctype.h> /* isalpha, isdigit */ @@ -1681,8 +1679,6 @@ static int run_pipe_real(struct pipe *pi) } else { int rcode; #if defined(CONFIG_CMD_BOOTD) - extern int do_bootd (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); - /* avoid "bootd" recursion */ if (cmdtp->cmd == do_bootd) { if (flag & CMD_FLAG_BOOTD) { diff --git a/common/main.c b/common/main.c index d97ccd7..bbb208b 100644 --- a/common/main.c +++ b/common/main.c @@ -54,8 +54,6 @@ void show_boot_progress (int val) __attribute__((weak, alias("__show_boot_progre extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); /* for do_reset() prototype */ #endif
-extern int do_bootd (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); - #if defined(CONFIG_UPDATE_TFTP) void update_tftp (void); #endif /* CONFIG_UPDATE_TFTP */ diff --git a/include/command.h b/include/command.h index 7cebf8a..72eab9d 100644 --- a/include/command.h +++ b/include/command.h @@ -95,6 +95,9 @@ extern int cmd_auto_complete(const char *const prompt, char *buf, int *np, int * extern int cmd_get_data_size(char* arg, int default_size); #endif
+#ifdef CONFIG_CMD_BOOTD +extern int do_bootd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); +#endif extern int do_bootm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
#endif /* __ASSEMBLY__ */
Dear Mike Frysinger,
Applied to "next" branch, thanks.
Mike Frysinger
