[PATCH 1/1] test: py: test_shell_run() with CONFIG_HUSH_PARSER=n
The hush parser not enabled for some boards, e.g. sipeed_maix_bitm_defconfig.
With CONFIG_HUSH_PARSER=n a double quotation mark is not interpreted as the beginning of a string. Use a single quotation mark instead.
Furthermore without the hush parser variables have to be referenced as ${varname}. Add the missing braces.
Reported-by: Sean Anderson seanga2@gmail.com Fixes: 8b86c609b860 ("test/py: add test of basic shell functionality") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- test/py/tests/test_shell_basics.py | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/test/py/tests/test_shell_basics.py b/test/py/tests/test_shell_basics.py index f54f7b7425..68a3f892f6 100644 --- a/test/py/tests/test_shell_basics.py +++ b/test/py/tests/test_shell_basics.py @@ -34,11 +34,11 @@ def test_shell_semicolon_three(u_boot_console): def test_shell_run(u_boot_console): """Test the "run" shell command."""
- u_boot_console.run_command('setenv foo "setenv monty 1; setenv python 2"') + u_boot_console.run_command('setenv foo 'setenv monty 1; setenv python 2'') u_boot_console.run_command('run foo') - response = u_boot_console.run_command('echo $monty') + response = u_boot_console.run_command('echo ${monty}') assert response.strip() == '1' - response = u_boot_console.run_command('echo $python') + response = u_boot_console.run_command('echo ${python}') assert response.strip() == '2' u_boot_console.run_command('setenv foo') u_boot_console.run_command('setenv monty') -- 2.27.0
