[U-Boot] [PATCH] x86: Fix regression build issue of coreboot-x86_defconfig
Commit bd328eb "Clean all defconfigs with savedefconfig" accidentally removed 'CONFIG_VENDOR_COREBOOT=y' from configs/coreboot-x86_defconfig. This commit reverts the change.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
configs/coreboot-x86_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 66f94d0..799853f 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VENDOR_COREBOOT=y CONFIG_TARGET_COREBOOT=y CONFIG_OF_CONTROL=y CONFIG_DM_PCI=y
Hi Simon,
diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 66f94d0..799853f 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VENDOR_COREBOOT=y CONFIG_TARGET_COREBOOT=y CONFIG_OF_CONTROL=y CONFIG_DM_PCI=y --
Please apply this patch after commit http://git.denx.de/?p=u-boot/u-boot-x86.git;a=commit;h=3506805839e14a67b0971... and before commit http://git.denx.de/?p=u-boot/u-boot-x86.git;a=commit;h=05cab1d6da2a84911fa0e.... I've verified the build with buildman on a new 'testing' branch with insertion of this patch.
Regards, Bin
Hi Bin,
On Wed, May 27, 2015 at 11:01 AM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
This should be squashed as part of http://git.denx.de/?p=u-boot/u-boot-x86.git;a=commit;h=05cab1d6da2a84911fa0e...
You need to remember to run savedefconfig when changing Kconfig or defconfig.
Cheers, -Joe
Hi Joe,
On Thu, May 28, 2015 at 12:13 AM, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Bin,
Hi Simon,
I still don't get it. commit 65c4ac0 introduced 'CONFIG_VENDOR_COREBOOT=y' and was applied before your commit bd328eb to clean up the defconfig. I suspect there was something wrong with 'savedefconfig'?
Regards, Bin
Hi Bin,
On Wed, May 27, 2015 at 11:21 AM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Joe,
Hi Bin,
Hi Simon,
No, savedefconfig is doing exactly what it should. Before your patch, CONFIG_VENDOR_COREBOOT was the default, explicitly in the Kconfig. Therefore savedefconfig sees it as redundant to specify that in the defconfig as well, so it removed it. When you change that explicit default to something else, it is up to you to change the defconfigs of the old and new default boards.
Your other option is to stop defining a default in the Kconfig and instead mark the choice as "optional" (like I did for many other selections like this that had no default explicitly - Kconfig otherwise treats the first entry as default in that case) in which case all defconfigs must have a specified vendor.
Cheers, -Joe
On 27 May 2015 at 10:27, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Bin,
Hi Joe,
Hi Bin,
Hi Simon,
OK I've squashed that in and pushed to u-boot-x86/testing. If it looks OK I'll pull it into master.
Hi Simon,
Hi Bin,
Hi Joe,
Hi Bin,
Hi Simon,
It should also include removing the (now) redundant CONFIG_VENDOR_EMULATION from that defconfig. That is best done by running savedefconfig on that defconfig after applying the "x86: Make QEMU the default vendor" patch.
Bin, are you in the middle of this?
Cheers, -Joe
Hi Joe,
On Thu, May 28, 2015 at 7:51 AM, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Simon,
Hi Bin,
Hi Joe,
Hi Bin,
Hi Simon,
On Wed, May 27, 2015 at 11:55 PM, Bin Meng bmeng.cn@gmail.com wrote: > Commit bd328eb "Clean all defconfigs with savedefconfig" accidentally > removed 'CONFIG_VENDOR_COREBOOT=y' from configs/coreboot-x86_defconfig. > This commit reverts the change. > > Signed-off-by: Bin Meng bmeng.cn@gmail.com > --- > > configs/coreboot-x86_defconfig | 1 + > 1 file changed, 1 insertion(+) > > diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig > index 66f94d0..799853f 100644 > --- a/configs/coreboot-x86_defconfig > +++ b/configs/coreboot-x86_defconfig > @@ -1,4 +1,5 @@ > CONFIG_X86=y > +CONFIG_VENDOR_COREBOOT=y > CONFIG_TARGET_COREBOOT=y > CONFIG_OF_CONTROL=y > CONFIG_DM_PCI=y > --
Thanks for the explanation. Now it is clear to me.
Yes, now we should remove CONFIG_VENDOR_EMULATION from configs/qemu-x86_defconfig. But if removing this, I feel this is inconsistent with other x86 boards' defconfig. Is this really a must-have to replace the defconfig with the one generated by 'savedefconfig'? If so, can we make it part of checkpatch.pl so that each time we submit the patch which contains modifications to the defconfig we can make sure the file is clean?
Regards, Bin
Hi Simon,
Hi Bin,
Hi Joe,
Hi Bin,
Hi Simon,
It looks OK. Another thing, I noticed this patch [1] is not in the testing branch. Did you apply it to somewhere else?
[1] http://patchwork.ozlabs.org/patch/472988/
Regards, Bin
HI Bin,
On May 27, 2015 8:41 PM, "Bin Meng" bmeng.cn@gmail.com wrote:
Hi Simon,
wrote:
Hi Bin,
Hi Joe,
Hi Bin,
wrote:
Hi Simon,
accidentally
and before commit
http://git.denx.de/?p=u-boot/u-boot-x86.git;a=commit;h=05cab1d6da2a84911fa0e... .
with
defconfig.
I was worried that it was submitted after the merge window and affects other code.
Regards, Bin
Hi Simon,
On Thu, May 28, 2015 at 10:55 AM, Simon Glass sjg@chromium.org wrote:
HI Bin,
Hi Simon,
Hi Bin,
Hi Joe,
Hi Bin,
On Wed, May 27, 2015 at 11:01 AM, Bin Meng bmeng.cn@gmail.com wrote: > Hi Simon, > > On Wed, May 27, 2015 at 11:55 PM, Bin Meng bmeng.cn@gmail.com > wrote: >> Commit bd328eb "Clean all defconfigs with savedefconfig" >> accidentally >> removed 'CONFIG_VENDOR_COREBOOT=y' from >> configs/coreboot-x86_defconfig. >> This commit reverts the change. >> >> Signed-off-by: Bin Meng bmeng.cn@gmail.com >> --- >> >> configs/coreboot-x86_defconfig | 1 + >> 1 file changed, 1 insertion(+) >> >> diff --git a/configs/coreboot-x86_defconfig >> b/configs/coreboot-x86_defconfig >> index 66f94d0..799853f 100644 >> --- a/configs/coreboot-x86_defconfig >> +++ b/configs/coreboot-x86_defconfig >> @@ -1,4 +1,5 @@ >> CONFIG_X86=y >> +CONFIG_VENDOR_COREBOOT=y >> CONFIG_TARGET_COREBOOT=y >> CONFIG_OF_CONTROL=y >> CONFIG_DM_PCI=y >> -- > > Please apply this patch after commit > > http://git.denx.de/?p=u-boot/u-boot-x86.git;a=commit;h=3506805839e14a67b0971... > and before commit > > http://git.denx.de/?p=u-boot/u-boot-x86.git;a=commit;h=05cab1d6da2a84911fa0e.... > I've verified the build with buildman on a new 'testing' branch > with > insertion of this patch.
OK, understood. But I think it is safe to remove given no board is using it.
Regards, Bin
Hi Simon, Hi Joe,
Hi Bin,
Hi Joe,
Hi Bin,
Hi Simon,
I just found u-boot.rom created from u-boot-x86/testing branch does not have working network any more on QEMU. It is working on the u-boot-x86/master branch.
=> set serverip 10.10.0.100;set ipaddr 10.10.0.108;set netmask 255.255.255.0;set gatewayip 10.10.0.100 => run ramboot *** ERROR: `serverip' not set *** ERROR: `serverip' not set
But 'print' says the env indeed has the 'serverip'. I think there should be something in the upstream that caused this after the u-boot-x86/testing branch rebase. Do you know where might be the problem?
Regards, Bin
Hi Bin,
This looks very similar to an issue that got patched on the i.MX6 yesterday by Stefano which said:
commit fd3056337e6fcc140f400e11edd33f6f1cb37de1 "Use env callbacks for net variables" has a side effect on i.MX6 boards because they do not set CONFIG_NET: the ip address results not set, but it is stored in the environment."
Might be something to check...
Regards,
Andy.
Hi Bin,
On 28 May 2015 at 09:05, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon, Hi Joe,
Hi Bin,
Hi Joe,
Hi Bin,
Hi Simon,
I'll hold off pushing to master for now.
Hi Simon,
On Fri, May 29, 2015 at 7:24 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon, Hi Joe,
Hi Bin,
Hi Joe,
Hi Bin,
On Wed, May 27, 2015 at 11:01 AM, Bin Meng bmeng.cn@gmail.com wrote: > Hi Simon, > > On Wed, May 27, 2015 at 11:55 PM, Bin Meng bmeng.cn@gmail.com wrote: >> Commit bd328eb "Clean all defconfigs with savedefconfig" accidentally >> removed 'CONFIG_VENDOR_COREBOOT=y' from configs/coreboot-x86_defconfig. >> This commit reverts the change. >> >> Signed-off-by: Bin Meng bmeng.cn@gmail.com >> --- >> >> configs/coreboot-x86_defconfig | 1 + >> 1 file changed, 1 insertion(+) >> >> diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig >> index 66f94d0..799853f 100644 >> --- a/configs/coreboot-x86_defconfig >> +++ b/configs/coreboot-x86_defconfig >> @@ -1,4 +1,5 @@ >> CONFIG_X86=y >> +CONFIG_VENDOR_COREBOOT=y >> CONFIG_TARGET_COREBOOT=y >> CONFIG_OF_CONTROL=y >> CONFIG_DM_PCI=y >> -- > > Please apply this patch after commit > http://git.denx.de/?p=u-boot/u-boot-x86.git;a=commit;h=3506805839e14a67b0971... > and before commit > http://git.denx.de/?p=u-boot/u-boot-x86.git;a=commit;h=05cab1d6da2a84911fa0e.... > I've verified the build with buildman on a new 'testing' branch with > insertion of this patch.
You may need to wait for Joe to submit a patch to fix this networking issue. Please see http://u-boot.10912.n7.nabble.com/PATCH-imx-missing-CONFIG-NET-after-consoli... for the discussion.
Regards, Bin
Andy Pont
Bin Meng
Joe Hershberger
