[PATCH v2] arm64: versal-net: Detect and display bootmode
Read boodmode register using versal_net_get_bootmode() in board_late_init and prepare corresponding distro boot command sequence based on it.
versal_net_get_bootmode() will be changed to use smc calls later, but for now directly reads the register.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@amd.com ---
Changes in v2: - Remove check for mmc/sdhci node enabled or not in EMMC bootmode - Remove check for sdhci node enabled or not in SD0 and SD1 bootmode
.../mach-versal-net/include/mach/hardware.h | 21 ++++ board/xilinx/versal-net/board.c | 114 ++++++++++++++++++ 2 files changed, 135 insertions(+)
diff --git a/arch/arm/mach-versal-net/include/mach/hardware.h b/arch/arm/mach-versal-net/include/mach/hardware.h index c5e4e22040..89b84a2efc 100644 --- a/arch/arm/mach-versal-net/include/mach/hardware.h +++ b/arch/arm/mach-versal-net/include/mach/hardware.h @@ -27,7 +27,13 @@ struct iou_scntrs_regs { u32 base_frequency_id_register; /* 0x20 */ };
+struct crp_regs { + u32 reserved0[128]; + u32 boot_mode_usr; /* 0x200 */ +}; + #define VERSAL_NET_CRL_APB_BASEADDR 0xEB5E0000 +#define VERSAL_NET_CRP_BASEADDR 0xF1260000 #define VERSAL_NET_IOU_SCNTR_SECURE 0xEC920000
#define CRL_APB_TIMESTAMP_REF_CTRL_CLKACT_BIT BIT(25) @@ -36,6 +42,7 @@ struct iou_scntrs_regs { #define IOU_SCNTRS_CONTROL_EN 1
#define crlapb_base ((struct crlapb_regs *)VERSAL_NET_CRL_APB_BASEADDR) +#define crp_base ((struct crp_regs *)VERSAL_NET_CRP_BASEADDR) #define iou_scntr_secure ((struct iou_scntrs_regs *)VERSAL_NET_IOU_SCNTR_SECURE)
#define PMC_TAP 0xF11A0000 @@ -49,6 +56,20 @@ struct iou_scntrs_regs { # define PLATFORM_VERSION_MASK GENMASK(31, 28) #define PMC_TAP_USERCODE (PMC_TAP + 0x8)
+/* Bootmode setting values */ +#define BOOT_MODES_MASK 0x0000000F +#define QSPI_MODE_24BIT 0x00000001 +#define QSPI_MODE_32BIT 0x00000002 +#define SD_MODE 0x00000003 /* sd 0 */ +#define SD_MODE1 0x00000005 /* sd 1 */ +#define EMMC_MODE 0x00000006 +#define USB_MODE 0x00000007 +#define OSPI_MODE 0x00000008 +#define SD1_LSHFT_MODE 0x0000000E /* SD1 Level shifter */ +#define JTAG_MODE 0x00000000 +#define BOOT_MODE_USE_ALT 0x100 +#define BOOT_MODE_ALT_SHIFT 12 + enum versal_net_platform { VERSAL_NET_SILICON = 0, VERSAL_NET_SPP = 1, diff --git a/board/xilinx/versal-net/board.c b/board/xilinx/versal-net/board.c index 6724c7290f..6595d6f3e8 100644 --- a/board/xilinx/versal-net/board.c +++ b/board/xilinx/versal-net/board.c @@ -10,6 +10,7 @@ #include <cpu_func.h> #include <fdtdec.h> #include <init.h> +#include <env_internal.h> #include <log.h> #include <malloc.h> #include <time.h> @@ -165,8 +166,32 @@ int board_early_init_r(void) return 0; }
+static u8 versal_net_get_bootmode(void) +{ + u8 bootmode; + u32 reg = 0; + + reg = readl(&crp_base->boot_mode_usr); + + if (reg >> BOOT_MODE_ALT_SHIFT) + reg >>= BOOT_MODE_ALT_SHIFT; + + bootmode = reg & BOOT_MODES_MASK; + + return bootmode; +} + int board_late_init(void) { + u8 bootmode; + struct udevice *dev; + int bootseq = -1; + int bootseq_len = 0; + int env_targets_len = 0; + const char *mode; + char *new_targets; + char *env_targets; + if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { debug("Saved variables - Skipping\n"); return 0; @@ -175,6 +200,95 @@ int board_late_init(void) if (!IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG)) return 0;
+ bootmode = versal_net_get_bootmode(); + + puts("Bootmode: "); + switch (bootmode) { + case USB_MODE: + puts("USB_MODE\n"); + mode = "usb_dfu0 usb_dfu1"; + break; + case JTAG_MODE: + puts("JTAG_MODE\n"); + mode = "jtag pxe dhcp"; + break; + case QSPI_MODE_24BIT: + puts("QSPI_MODE_24\n"); + mode = "xspi0"; + break; + case QSPI_MODE_32BIT: + puts("QSPI_MODE_32\n"); + mode = "xspi0"; + break; + case OSPI_MODE: + puts("OSPI_MODE\n"); + mode = "xspi0"; + break; + case EMMC_MODE: + puts("EMMC_MODE\n"); + mode = "mmc"; + bootseq = dev_seq(dev); + break; + case SD_MODE: + puts("SD_MODE\n"); + if (uclass_get_device_by_name(UCLASS_MMC, + "mmc@f1040000", &dev)) { + puts("Boot from SD0 but without SD0 enabled!\n"); + return -1; + } + debug("mmc0 device found at %p, seq %d\n", dev, dev_seq(dev)); + + mode = "mmc"; + bootseq = dev_seq(dev); + break; + case SD1_LSHFT_MODE: + puts("LVL_SHFT_"); + fallthrough; + case SD_MODE1: + puts("SD_MODE1\n"); + if (uclass_get_device_by_name(UCLASS_MMC, + "mmc@f1050000", &dev)) { + puts("Boot from SD1 but without SD1 enabled!\n"); + return -1; + } + debug("mmc1 device found at %p, seq %d\n", dev, dev_seq(dev)); + + mode = "mmc"; + bootseq = dev_seq(dev); + break; + default: + mode = ""; + printf("Invalid Boot Mode:0x%x\n", bootmode); + break; + } + + if (bootseq >= 0) { + bootseq_len = snprintf(NULL, 0, "%i", bootseq); + debug("Bootseq len: %x\n", bootseq_len); + } + + /* + * One terminating char + one byte for space between mode + * and default boot_targets + */ + env_targets = env_get("boot_targets"); + if (env_targets) + env_targets_len = strlen(env_targets); + + new_targets = calloc(1, strlen(mode) + env_targets_len + 2 + + bootseq_len); + if (!new_targets) + return -ENOMEM; + + if (bootseq >= 0) + sprintf(new_targets, "%s%x %s", mode, bootseq, + env_targets ? env_targets : ""); + else + sprintf(new_targets, "%s %s", mode, + env_targets ? env_targets : ""); + + env_set("boot_targets", new_targets); + return board_late_init_xilinx(); }
Changes in v2:
+struct crp_regs {
- u32 reserved0[128];
- u32 boot_mode_usr; /* 0x200 */
- #define VERSAL_NET_CRL_APB_BASEADDR 0xEB5E0000
- enum versal_net_platform { VERSAL_NET_SILICON = 0, VERSAL_NET_SPP = 1,
- u8 bootmode;
- u32 reg = 0;
- reg = readl(&crp_base->boot_mode_usr);
- if (reg >> BOOT_MODE_ALT_SHIFT)
- bootmode = reg & BOOT_MODES_MASK;
- return bootmode;
- int board_late_init(void) {
- u8 bootmode;
- struct udevice *dev;
- int bootseq = -1;
- int bootseq_len = 0;
- int env_targets_len = 0;
- const char *mode;
- char *new_targets;
- char *env_targets;
- if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { debug("Saved variables - Skipping\n"); return 0;
- bootmode = versal_net_get_bootmode();
- puts("Bootmode: ");
- switch (bootmode) {
- case USB_MODE:
puts("USB_MODE\n");
break;
- case JTAG_MODE:
break;
- case QSPI_MODE_24BIT:
mode = "xspi0";
break;
- case QSPI_MODE_32BIT:
mode = "xspi0";
break;
- case OSPI_MODE:
mode = "xspi0";
break;
- case EMMC_MODE:
mode = "mmc";
break;
- case SD_MODE:
puts("SD_MODE\n");
return -1;
mode = "mmc";
break;
- case SD1_LSHFT_MODE:
puts("LVL_SHFT_");
fallthrough;
- case SD_MODE1:
puts("SD_MODE1\n");
return -1;
mode = "mmc";
break;
- default:
mode = "";
break;
- if (bootseq >= 0) {
- env_targets = env_get("boot_targets");
- if (env_targets)
- new_targets = calloc(1, strlen(mode) + env_targets_len + 2 +
bootseq_len);
- if (!new_targets)
return -ENOMEM;
- if (bootseq >= 0)
- else
- env_set("boot_targets", new_targets);
- return board_late_init_xilinx(); }
Applied. M
Ashok Reddy Soma
Michal Simek
