[PATCH] mmc: msm_sdhci: fix vendor_spec_cap0 registers
The addresses were mistakenly swapped. Put them right.
Reported-by: Sumit Garg sumit.garg@linaro.org Fixes: a737d8962cae ("mmc: msm_sdhci: correct vendor_spec_cap0 register for v5") Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/mmc/msm_sdhci.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/msm_sdhci.c b/drivers/mmc/msm_sdhci.c index 2144772ac325..5e9d66526a83 100644 --- a/drivers/mmc/msm_sdhci.c +++ b/drivers/mmc/msm_sdhci.c @@ -255,15 +255,15 @@ static int msm_sdc_bind(struct udevice *dev)
static const struct msm_sdhc_variant_info msm_sdhc_mci_var = { .mci_removed = false,
- .core_vendor_spec_capabilities0 = 0x21c, + .core_vendor_spec_capabilities0 = 0x11c, };
static const struct msm_sdhc_variant_info msm_sdhc_v5_var = { .mci_removed = true,
- .core_vendor_spec_capabilities0 = 0x11c, + .core_vendor_spec_capabilities0 = 0x21c, };
static const struct udevice_id msm_mmc_ids[] = { { .compatible = "qcom,sdhci-msm-v4", .data = (ulong)&msm_sdhc_mci_var },
Applied, thanks!
[1/1] mmc: msm_sdhci: fix vendor_spec_cap0 registers commit: f09537bdd940c051b851c235e8906f1ba83233d1
Caleb Connolly
