[U-Boot] [PATCH 0/7] arm64: versal: Enable several features
time is coming up and more and more features are validated and enabled on this platform. This patches enable things which are already in mainline.
Thanks, Michal
Michal Simek (2): arm64: versal: Enable LIBFDT_OVERLAY arm64: versal: Enable USB driver support
Siva Durga Prasad Paladugu (5): arm64: versal: Enable CLK command arm64: versal: Increase SYS_MALLOC_F_LEN arm64: versal: Update boot delay to perform autoboot arm64: versal: Enable bit stream loading support for versal platform. arm64: versal: Enable UHS support
configs/xilinx_versal_virt_defconfig | 33 ++++++++++++++++++++++++++-- 1 file changed, 31 insertions(+), 2 deletions(-)
Enable device tree overlay to build all dtbs for Versal with -@ flag to enable applying overlays.
configs/xilinx_versal_virt_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index f5ce8a0a1e88..2c6c17481368 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -70,4 +70,5 @@ CONFIG_PL01X_SERIAL=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FAT_WRITE=y +CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y
This patch adds usb host and device mode support for Xilinx Versal virtual platform. By default USB host functionality is enabled. To use in usb device mode, set dr_mode property in DT to peripheral.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
configs/xilinx_versal_virt_defconfig | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 2c6c17481368..348ea17cf109 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -17,12 +17,14 @@ CONFIG_SYS_PROMPT="Versal> " CONFIG_CMD_BOOTMENU=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_DFU=y CONFIG_CMD_DM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y +CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_MII=y @@ -44,9 +46,11 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_CLK_VERSAL=y +CONFIG_DFU_RAM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_CADENCE=y +CONFIG_MISC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_DM_SPI_FLASH=y @@ -69,6 +73,23 @@ CONFIG_ZYNQ_GEM=y CONFIG_PL01X_SERIAL=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03FD +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_FUNCTION_THOR=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Enables clock command for dumping clocks.
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 348ea17cf109..ebee6d61e6b9 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_PROMPT="Versal> " CONFIG_CMD_BOOTMENU=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y CONFIG_CMD_DM=y # CONFIG_CMD_FLASH is not set
This patch increases SYS_MALLOC_F_LEN as the versal clock driver needs to be probed before relocation itself inorder to get required clocks before relocation.
configs/xilinx_versal_virt_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index ebee6d61e6b9..5300a27f6d41 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_VERSAL=y CONFIG_SYS_TEXT_BASE=0x8000000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SYS_MALLOC_F_LEN=0x100000 CONFIG_COUNTER_FREQUENCY=62500000 CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y
Update boot delay to 5 for performing autoboot.
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 5300a27f6d41..548024006869 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -7,7 +7,7 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set -CONFIG_BOOTDELAY=-1 +CONFIG_BOOTDELAY=5 CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set
This patch enables bitstream loading support for Versal platform.
configs/xilinx_versal_virt_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 548024006869..940f1539b6f8 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -48,6 +48,8 @@ CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_CLK_VERSAL=y CONFIG_DFU_RAM=y +CONFIG_FPGA_XILINX=y +CONFIG_FPGA_VERSALPL=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_CADENCE=y
This patch enables UHS support for Versal platforms.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
configs/xilinx_versal_virt_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 940f1539b6f8..1717039dc0d1 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -54,8 +54,12 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_CADENCE=y CONFIG_MISC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_ZYNQ_SDHCI_MIN_FREQ=100000 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y
po 14. 10. 2019 v 13:04 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
Thanks, Michal
-- 2.17.1
Applied all. M
Michal Simek
Michal Simek
