[PATCH 0/3] clk: imx8mn: miscellaneous cleanups and bug fixes
This series is a backport of the linux seris [1]. Like that series, this one was also tested on the BSH SystemMaster (SMM) S2 board.
[1] https://lore.kernel.org/all/20221117113637.1978703-1-dario.binacchi@amarulas...
Dario Binacchi (3): clk: imx8mn: rename vpu_pll to m7_alt_pll clk: imx: rename video_pll1 to video_pll clk: imx8mn: fix imx8mn_enet_phy_sels clocks list
drivers/clk/imx/clk-imx8mn.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
[backport from linux commit a429c60baefd95ab43a2ce7f25d5b2d7a2e431df]
The IMX8MN platform does not have any video processing unit (VPU), and indeed in the reference manual (document IMX8MNRM Rev 2, 07/2022) there is no occurrence of its pll. From an analysis of the code and the RM itself, I think vpu pll is used instead of m7 alternate pll, probably for copy and paste of code taken from modules of similar architectures.
Signed-off-by: Dario Binacchi dario.binacchi@amarulasolutions.com ---
drivers/clk/imx/clk-imx8mn.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/imx/clk-imx8mn.c b/drivers/clk/imx/clk-imx8mn.c index 35e0d935d390..86fe30ae6662 100644 --- a/drivers/clk/imx/clk-imx8mn.c +++ b/drivers/clk/imx/clk-imx8mn.c @@ -83,7 +83,7 @@ static const char *imx8mn_i2c3_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_ static const char *imx8mn_i2c4_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", "sys_pll3_out", "audio_pll1_out", "video_pll1_out", "audio_pll2_out", "sys_pll1_133m", };
-static const char *imx8mn_wdog_sels[] = {"clock-osc-24m", "sys_pll1_133m", "sys_pll1_160m", "vpu_pll_out", +static const char *imx8mn_wdog_sels[] = {"clock-osc-24m", "sys_pll1_133m", "sys_pll1_160m", "m7_alt_pll", "sys_pll2_125m", "sys_pll3_out", "sys_pll1_80m", "sys_pll2_166m", };
static const char *imx8mn_usdhc3_sels[] = {"clock-osc-24m", "sys_pll1_400m", "sys_pll1_800m", "sys_pll2_500m",
Acked-by: Sean Anderson seanga2@gmail.com
[backport from linux commit bedcf9d1dcf88ed38731f0ac9620e5a421e1e9d6]
Unlike audio_pll1 and audio_pll2, there is no video_pll2. Further, the name used in the RM is video_pll. So, let's rename "video_pll1" to "video_pll" to be consistent with the RM and avoid misunderstandings.
No functional changes intended.
drivers/clk/imx/clk-imx8mn.c | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/clk/imx/clk-imx8mn.c b/drivers/clk/imx/clk-imx8mn.c index 86fe30ae6662..a2c7c63ef74d 100644 --- a/drivers/clk/imx/clk-imx8mn.c +++ b/drivers/clk/imx/clk-imx8mn.c @@ -28,20 +28,20 @@ static const char *imx8mn_a53_sels[] = {"clock-osc-24m", "arm_pll_out", "sys_pll "sys_pll1_800m", "sys_pll1_400m", "audio_pll1_out", "sys_pll3_out", };
static const char *imx8mn_ahb_sels[] = {"clock-osc-24m", "sys_pll1_133m", "sys_pll1_800m", "sys_pll1_400m", - "sys_pll2_125m", "sys_pll3_out", "audio_pll1_out", "video_pll1_out", }; + "sys_pll2_125m", "sys_pll3_out", "audio_pll1_out", "video_pll_out", };
static const char *imx8mn_enet_axi_sels[] = {"clock-osc-24m", "sys_pll1_266m", "sys_pll1_800m", "sys_pll2_250m", - "sys_pll2_200m", "audio_pll1_out", "video_pll1_out", "sys_pll3_out", }; + "sys_pll2_200m", "audio_pll1_out", "video_pll_out", "sys_pll3_out", };
#ifndef CONFIG_SPL_BUILD static const char *imx8mn_enet_ref_sels[] = {"clock-osc-24m", "sys_pll2_125m", "sys_pll2_50m", "sys_pll2_100m", - "sys_pll1_160m", "audio_pll1_out", "video_pll1_out", "clk_ext4", }; + "sys_pll1_160m", "audio_pll1_out", "video_pll_out", "clk_ext4", };
static const char *imx8mn_enet_timer_sels[] = {"clock-osc-24m", "sys_pll2_100m", "audio_pll1_out", "clk_ext1", "clk_ext2", - "clk_ext3", "clk_ext4", "video_pll1_out", }; + "clk_ext3", "clk_ext4", "video_pll_out", };
static const char *imx8mn_enet_phy_sels[] = {"clock-osc-24m", "sys_pll2_50m", "sys_pll2_125m", "sys_pll2_200m", - "sys_pll2_500m", "video_pll1_out", "audio_pll2_out", }; + "sys_pll2_500m", "video_pll_out", "audio_pll2_out", }; #endif
static const char *imx8mn_nand_usdhc_sels[] = {"clock-osc-24m", "sys_pll1_266m", "sys_pll1_800m", "sys_pll2_200m", @@ -72,16 +72,16 @@ static const char *imx8mn_ecspi3_sels[] = {"osc_24m", "sys_pll2_200m", "sys_pll1 #endif
static const char *imx8mn_i2c1_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", "sys_pll3_out", "audio_pll1_out", - "video_pll1_out", "audio_pll2_out", "sys_pll1_133m", }; + "video_pll_out", "audio_pll2_out", "sys_pll1_133m", };
static const char *imx8mn_i2c2_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", "sys_pll3_out", "audio_pll1_out", - "video_pll1_out", "audio_pll2_out", "sys_pll1_133m", }; + "video_pll_out", "audio_pll2_out", "sys_pll1_133m", };
static const char *imx8mn_i2c3_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", "sys_pll3_out", "audio_pll1_out", - "video_pll1_out", "audio_pll2_out", "sys_pll1_133m", }; + "video_pll_out", "audio_pll2_out", "sys_pll1_133m", };
static const char *imx8mn_i2c4_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", "sys_pll3_out", "audio_pll1_out", - "video_pll1_out", "audio_pll2_out", "sys_pll1_133m", }; + "video_pll_out", "audio_pll2_out", "sys_pll1_133m", };
static const char *imx8mn_wdog_sels[] = {"clock-osc-24m", "sys_pll1_133m", "sys_pll1_160m", "m7_alt_pll", "sys_pll2_125m", "sys_pll3_out", "sys_pll1_80m", "sys_pll2_166m", }; @@ -94,7 +94,7 @@ static const char *imx8mn_qspi_sels[] = {"clock-osc-24m", "sys_pll1_400m", "sys_
static const char * const imx8mn_nand_sels[] = {"osc_24m", "sys_pll2_500m", "audio_pll1_out", "sys_pll1_400m", "audio_pll2_out", "sys_pll3_out", - "sys_pll2_250m", "video_pll1_out", }; + "sys_pll2_250m", "video_pll_out", };
static const char * const imx8mn_usb_core_sels[] = {"clock-osc-24m", "sys_pll1_100m", "sys_pll1_40m", "sys_pll2_100m", "sys_pll2_200m", "clk_ext2",
#endif
[backport from linux commit 2626cf67f20b28446dfc3a5b9493dd535cdb747b]
According to the "Clock Root" table of the reference manual (document IMX8MNRM Rev 2, 07/2022):
Clock Root offset Source Select (CCM_TARGET_ROOTn[MUX]) ... ... ... ENET_PHY_REF_CLK_ROOT 0xAA80 000 - 24M_REF_CLK 001 - SYSTEM_PLL2_DIV20 010 - SYSTEM_PLL2_DIV8 011 - SYSTEM_PLL2_DIV5 100 - SYSTEM_PLL2_DIV2 101 - AUDIO_PLL1_CLK 110 - VIDEO_PLL_CLK 111 - AUDIO_PLL2_CLK ... ... ...
while the imx8mn_enet_phy_sels list didn't contained audio_pll1_out for source select bits 101b.
diff --git a/drivers/clk/imx/clk-imx8mn.c b/drivers/clk/imx/clk-imx8mn.c index a2c7c63ef74d..692823e74b88 100644 --- a/drivers/clk/imx/clk-imx8mn.c +++ b/drivers/clk/imx/clk-imx8mn.c @@ -41,7 +41,7 @@ static const char *imx8mn_enet_timer_sels[] = {"clock-osc-24m", "sys_pll2_100m", "clk_ext3", "clk_ext4", "video_pll_out", };
static const char *imx8mn_enet_phy_sels[] = {"clock-osc-24m", "sys_pll2_50m", "sys_pll2_125m", "sys_pll2_200m", - "sys_pll2_500m", "video_pll_out", "audio_pll2_out", }; + "sys_pll2_500m", "audio_pll1_out", "video_pll_out", "audio_pll2_out", }; #endif
#endif
Applied, thanks!
[1/3] clk: imx8mn: rename vpu_pll to m7_alt_pll commit: 3724850d606e41c4e9014af20905742a477e6951 [2/3] clk: imx: rename video_pll1 to video_pll commit: 7b0ac6ac8b16c7ba4d90817938b34dcd60133248 [3/3] clk: imx8mn: fix imx8mn_enet_phy_sels clocks list commit: 67f46e29d2006ac56faa5a5ed70e43b317094d23
Dario Binacchi
Sean Anderson
