[U-Boot] [PATCH] fastboot: check for alias when looking up partition by name
Implement an alias name check for devices where GPT limitations prevent user-friendly partition names such as "boot", "system" and "cache". Or, where the actual partition name doesn't match a standard partition name used commonly with fastboot.
To set an alias, add an environment setting as follows: fastboot_partition_alias_<alias partition name>=<actual partition name>
Example: fastboot_partition_alias_boot=LNX
Signed-off-by: Michael Scott michael.scott@linaro.org Cc: Steve Rae srae@broadcom.com Cc: Lukasz Majewski l.majewski@samsung.com --- common/fb_mmc.c | 26 ++++++++++++++++++++++++-- doc/README.android-fastboot | 9 +++++++++ 2 files changed, 33 insertions(+), 2 deletions(-)
diff --git a/common/fb_mmc.c b/common/fb_mmc.c index 75899e4..0c48cf9 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -33,6 +33,28 @@ void fastboot_okay(const char *s) strncat(response_str, s, RESPONSE_LEN - 4 - 1); }
+static int get_partition_info_efi_by_name_or_alias(block_dev_desc_t *dev_desc, + const char *name, disk_partition_t *info) +{ + int ret; + + ret = get_partition_info_efi_by_name(dev_desc, name, info); + if (ret) { + /* strlen("fastboot_partition_alias_") + 32(part_name) + 1 */ + char env_alias_name[25 + 32 + 1]; + char *aliased_part_name; + + /* check for alias */ + strcpy(env_alias_name, "fastboot_partition_alias_"); + strncat(env_alias_name, name, 32); + aliased_part_name = getenv(env_alias_name); + if (aliased_part_name != NULL) + ret = get_partition_info_efi_by_name(dev_desc, + aliased_part_name, info); + } + return ret; +} + static void write_raw_image(block_dev_desc_t *dev_desc, disk_partition_t *info, const char *part_name, void *buffer, unsigned int download_bytes) @@ -98,7 +120,7 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, printf("........ success\n"); fastboot_okay(""); return; - } else if (get_partition_info_efi_by_name(dev_desc, cmd, &info)) { + } else if (get_partition_info_efi_by_name_or_alias(dev_desc, cmd, &info)) { error("cannot find partition: '%s'\n", cmd); fastboot_fail("cannot find partition"); return; @@ -136,7 +158,7 @@ void fb_mmc_erase(const char *cmd, char *response) return; }
- ret = get_partition_info_efi_by_name(dev_desc, cmd, &info); + ret = get_partition_info_efi_by_name_or_alias(dev_desc, cmd, &info); if (ret) { error("cannot find partition: '%s'", cmd); fastboot_fail("cannot find partition"); diff --git a/doc/README.android-fastboot b/doc/README.android-fastboot index 5526a43..04411e9 100644 --- a/doc/README.android-fastboot +++ b/doc/README.android-fastboot @@ -50,6 +50,15 @@ buffer should be as large as possible for a platform. The location of the buffer and size are set with CONFIG_USB_FASTBOOT_BUF_ADDR and CONFIG_USB_FASTBOOT_BUF_SIZE.
+Fastboot partition aliases can also be defined for devices where GPT +limitations prevent user-friendly partition names such as "boot", "system" +and "cache". Or, where the actual partition name doesn't match a standard +partition name used commonly with fastboot. Current implentation checks +aliases when accessing partitions by name (flash_write and erase functions). +To define a partition alias add an environment variable similar to: +fastboot_partition_alias_<alias partition name>=<actual partition name> +Example: fastboot_partition_alias_boot=LNX + In Action ========= Enter into fastboot by executing the fastboot command in u-boot and you
- int ret;
- ret = get_partition_info_efi_by_name(dev_desc, name, info);
- if (ret) {
- return ret;
- static void write_raw_image(block_dev_desc_t *dev_desc, disk_partition_t *info, const char *part_name, void *buffer, unsigned int download_bytes)
- } else if (get_partition_info_efi_by_name_or_alias(dev_desc, cmd, &info)) { error("cannot find partition: '%s'\n", cmd); fastboot_fail("cannot find partition"); return;
- ret = get_partition_info_efi_by_name_or_alias(dev_desc, cmd, &info); if (ret) { error("cannot find partition: '%s'", cmd); fastboot_fail("cannot find partition");
+Fastboot partition aliases can also be defined for devices where GPT +limitations prevent user-friendly partition names such as "boot", "system" +and "cache". Or, where the actual partition name doesn't match a standard +partition name used commonly with fastboot. Current implentation checks +aliases when accessing partitions by name (flash_write andThere's already a driver
for DWC2 in drivers/usb/gadget/s3c_udc_otg.c . This driver should really be properly renamed though ;-/ erase functions).
In Action
An interesting feature (which seems unnecessary to me...) However, Acked-by: Steve Rae srae@broadcom.com
- int ret;
- if (ret) {
- return ret;
Hi Steve,
I'm a bit confused with the mention of drivers/usb/gadget/s3c_udc_otg.c and how it relates back this patch. I'm willing to make any corrections you would like, but may need some clarification.
In Action
Enter into fastboot by executing the fastboot command in u-boot andyou
A bit of background:
We are using fastboot support on Nvidia Jetson-TK1 platform where a GPT limitation sets partition names to 3 letters.
IE: LNX = boot, APP = system and UDA = userdata.
To present a "normal" fastboot experience to users, we use this patch.
Thank you for the Ack!
- int ret;
- if (ret) {
- return ret;
Hi Steve,
Sorry -- I corrupted this (finger trouble!) - please ignore
In Action
OK -- then this patch makes much more sense! - so when the user performs "mmc part", (I'm assuming it will list the "3 letter names"), then they perform "fastboot flash LNX boot.bin" (which makes sense to me....) - or they can setup these aliases and perform "fastboot flash boot boot.bin" (I would probably stick with the former myself...) Thanks, Steve
Hi Steve,
- int ret;
- if (ret) {
1 */
- return ret;
&info)) {
Hi Steve,
In Action
Enter into fastboot by executing the fastboot command in u-bootand you
Are there more comments for this patch?
Hi Lukasz,
On 15-03-20 12:50 AM, Lukasz Majewski wrote:
Hi Steve,
[... snip ...]
No - the feature is OK (personally - I would use the names that match what "mmc part" displays; so I don't think that I would create any aliases....)
Hi Steve,
Hi Lukasz,
Hi Steve,
[... snip ...]
Applied to u-boot-dfu tree. Thanks!
Lukasz Majewski
Michael Scott
Steve Rae
