[U-Boot] [PATCH 1/1] efi_selftest: memory leak testing manage protocols
Remove memory leak in efi_selftest_manageprotocols.c.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- .../efi_selftest_manageprotocols.c | 21 +++++++++++++++++-- 1 file changed, 19 insertions(+), 2 deletions(-)
diff --git a/lib/efi_selftest/efi_selftest_manageprotocols.c b/lib/efi_selftest/efi_selftest_manageprotocols.c index 44b8da3ba5..b09e4cdcfa 100644 --- a/lib/efi_selftest/efi_selftest_manageprotocols.c +++ b/lib/efi_selftest/efi_selftest_manageprotocols.c @@ -179,7 +179,12 @@ static int execute(void) efi_st_error("LocateHandleBuffer failed to locate new handle\n"); return EFI_ST_FAILURE; } - boottime->set_mem(buffer, sizeof(efi_handle_t) * buffer_size, 0); + /* Release buffer */ + ret = boottime->free_pool(buffer); + if (ret != EFI_SUCCESS) { + efi_st_error("FreePool failed\n"); + return EFI_ST_FAILURE; + }
/* * Test error handling in UninstallMultipleProtocols @@ -221,6 +226,7 @@ static int execute(void) efi_st_error("LocateHandleBuffer failed to locate new handle\n"); return EFI_ST_FAILURE; } + /* Clear the buffer, we are reusing it it the next step. */ boottime->set_mem(buffer, sizeof(efi_handle_t) * buffer_size, 0);
/* @@ -248,7 +254,12 @@ static int execute(void) efi_st_error("LocateHandle failed to locate new handles\n"); return EFI_ST_FAILURE; } - boottime->set_mem(buffer, sizeof(efi_handle_t) * buffer_size, 0); + /* Release buffer */ + ret = boottime->free_pool(buffer); + if (ret != EFI_SUCCESS) { + efi_st_error("FreePool failed\n"); + return EFI_ST_FAILURE; + }
/* * Test LocateProtocol @@ -319,6 +330,12 @@ static int execute(void) efi_st_error("Failed to get protocols per handle\n"); return EFI_ST_FAILURE; } + /* Release buffer */ + ret = boottime->free_pool(prot_buffer); + if (ret != EFI_SUCCESS) { + efi_st_error("FreePool failed\n"); + return EFI_ST_FAILURE; + }
/* * Uninstall remaining protocols
