[U-Boot] Please pull u-boot-x86.git
Hi Tom,
Great to see the previous lot made it in. Here is the next x86 series.
The following changes since commit 2536850d7cd90bdb75bf3ff86838f913392b68db:
Prepare v2013.04-rc1 (2013-03-04 16:29:17 -0500)
git://git.denx.de/u-boot-x86.git master
for you to fetch changes up to fc959081d41aab2d6f4614c5fb3dd1b77ffcdcf4:
x86: Enable CONFIG_OF_CONTROL on coreboot (2013-03-04 15:57:52 -0800)
---------------------------------------------------------------- Simon Glass (9): x86: Add function to get top of usable ram x86: Add basic cache operations x86: Permit bootstage and timer data to be used prior to relocation x86: Add an __end symbol to signal the end of the U-Boot binary x86: Rearrange the output input to remove BSS x86: Support relocation of FDT on start-up x86: Add error checking to x86 relocation code x86: Adjust link device tree include file x86: Enable CONFIG_OF_CONTROL on coreboot
arch/x86/cpu/coreboot/coreboot.c | 15 +++++------- arch/x86/cpu/coreboot/sdram.c | 18 +++----------- arch/x86/cpu/cpu.c | 23 +++++++++++++++++ arch/x86/cpu/interrupts.c | 7 +++--- arch/x86/cpu/u-boot.lds | 21 ++++++++++------ arch/x86/include/asm/global_data.h | 4 +++ arch/x86/include/asm/init_helpers.h | 2 ++ arch/x86/include/asm/relocate.h | 1 + arch/x86/include/asm/u-boot-x86.h | 1 + arch/x86/lib/board.c | 3 +++ arch/x86/lib/init_helpers.c | 49 ++++++++++++++++++++++++++++--------- arch/x86/lib/init_wrappers.c | 1 + arch/x86/lib/relocate.c | 37 ++++++++++++++++++++++++++-- arch/x86/lib/timer.c | 9 +++---- board/chromebook-x86/dts/link.dts | 2 +- include/configs/coreboot.h | 6 +++++ 16 files changed, 146 insertions(+), 53 deletions(-)
On Mon, Mar 04, 2013 at 04:01:52PM -0800, Simon Glass wrote:
Hi Tom,
