[U-Boot] [PATCH v2] arm: ls1021a: improve the core frequency to 1.2GHZ
Change core clock to 1.2GHz in the configurations for SD and NAND boot.
Signed-off-by: Yuan Yao yao.yuan@nxp.com --- Changed in v2: Updated the commit message. --- board/freescale/ls1021aqds/ls102xa_rcw_nand.cfg | 2 +- board/freescale/ls1021aqds/ls102xa_rcw_sd_ifc.cfg | 4 ++-- board/freescale/ls1021aqds/ls102xa_rcw_sd_qspi.cfg | 4 ++-- board/freescale/ls1021atwr/ls102xa_rcw_sd_ifc.cfg | 2 +- board/freescale/ls1021atwr/ls102xa_rcw_sd_qspi.cfg | 2 +- 5 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/board/freescale/ls1021aqds/ls102xa_rcw_nand.cfg b/board/freescale/ls1021aqds/ls102xa_rcw_nand.cfg index 222c71d..d76e913 100644 --- a/board/freescale/ls1021aqds/ls102xa_rcw_nand.cfg +++ b/board/freescale/ls1021aqds/ls102xa_rcw_nand.cfg @@ -1,7 +1,7 @@ #PBL preamble and RCW header aa55aa55 01ee0100 # serdes protocol -0608000a 00000000 00000000 00000000 +0608000c 00000000 00000000 00000000 60000000 00407900 e0106a00 21046000 00000000 00000000 00000000 00038000 00000000 001b7200 00000000 00000000 diff --git a/board/freescale/ls1021aqds/ls102xa_rcw_sd_ifc.cfg b/board/freescale/ls1021aqds/ls102xa_rcw_sd_ifc.cfg index 9d99bd8..f0cf9c2 100644 --- a/board/freescale/ls1021aqds/ls102xa_rcw_sd_ifc.cfg +++ b/board/freescale/ls1021aqds/ls102xa_rcw_sd_ifc.cfg @@ -2,13 +2,13 @@ aa55aa55 01ee0100
#enable IFC, disable QSPI and DSPI -0608000a 00000000 00000000 00000000 +0608000c 00000000 00000000 00000000 60000000 00407900 60040a00 21046000 00000000 00000000 00000000 00038000 00000000 001b7200 00000000 00000000
#disable IFC, enable QSPI and DSPI -#0608000a 00000000 00000000 00000000 +#0608000c 00000000 00000000 00000000 #60000000 00407900 60040a00 21046000 #00000000 00000000 00000000 00038000 #20024800 001b7200 00000000 00000000 diff --git a/board/freescale/ls1021aqds/ls102xa_rcw_sd_qspi.cfg b/board/freescale/ls1021aqds/ls102xa_rcw_sd_qspi.cfg index 2bd398c..10cc4a9 100644 --- a/board/freescale/ls1021aqds/ls102xa_rcw_sd_qspi.cfg +++ b/board/freescale/ls1021aqds/ls102xa_rcw_sd_qspi.cfg @@ -2,13 +2,13 @@ aa55aa55 01ee0100
#enable IFC, disable QSPI and DSPI -#0608000a 00000000 00000000 00000000 +#0608000c 00000000 00000000 00000000 #60000000 00407900 60040a00 21046000 #00000000 00000000 00000000 00038000 #00000000 001b7200 00000000 00000000
#disable IFC, enable QSPI and DSPI -0608000a 00000000 00000000 00000000 +0608000c 00000000 00000000 00000000 60000000 00407900 60040a00 21046000 00000000 00000000 00000000 00038000 20024800 001b7200 00000000 00000000 diff --git a/board/freescale/ls1021atwr/ls102xa_rcw_sd_ifc.cfg b/board/freescale/ls1021atwr/ls102xa_rcw_sd_ifc.cfg index 205606f..f94997d 100644 --- a/board/freescale/ls1021atwr/ls102xa_rcw_sd_ifc.cfg +++ b/board/freescale/ls1021atwr/ls102xa_rcw_sd_ifc.cfg @@ -2,7 +2,7 @@ aa55aa55 01ee0100
#enable IFC, disable QSPI and DSPI -0608000a 00000000 00000000 00000000 +0608000c 00000000 00000000 00000000 30000000 00007900 60040a00 21046000 00000000 00000000 00000000 20000000 00080000 881b7340 00000000 00000000 diff --git a/board/freescale/ls1021atwr/ls102xa_rcw_sd_qspi.cfg b/board/freescale/ls1021atwr/ls102xa_rcw_sd_qspi.cfg index 6767e09..541b604 100644 --- a/board/freescale/ls1021atwr/ls102xa_rcw_sd_qspi.cfg +++ b/board/freescale/ls1021atwr/ls102xa_rcw_sd_qspi.cfg @@ -2,7 +2,7 @@ aa55aa55 01ee0100
#disable IFC, enable QSPI and DSPI -0608000a 00000000 00000000 00000000 +0608000c 00000000 00000000 00000000 30000000 00007900 60040a00 21046000 00000000 00000000 00000000 20000000 20024800 881b7340 00000000 00000000
Applied to fsl-qoriq, awaiting upstream. Thanks.
York
york sun
Yuan Yao
