[PATCH v2 00/57] dm: Add programatic generation of ACPI tables (part D)
Note: This is part D of this effort. With this, Coral includes all required ACPI tables.
At present on x86 U-Boot supports creating ACPI (Advanced Configuration and Power Interface) tables using the Intel ACPI Source Language (ASL) compiler.
This is good enough for basic operation but some devices need to add their information dynamically at runtime. An example is a device that needs to report its enable GPIO. This is described in the device tree, so we want to add code in the driver to convert that device-tree description into an ACPI description for use on Linux.
This series adds support for generation of ACPI tables and fragments by devices. The core support is built into driver model.
Several files are brought over from coreboot to do the actual generation.
As an example of using this new feature, chromebook_coral is updated to write out a wide array of ACPI tables including DSDT and SSDT.
This initial version of the series lays out the general approach. More work is needed to figure out the difference between CONFIG_ACPIGEN and CONFIG_GENERATE_ACPI_TABLE with respect to what is built.
Changes in v2: - Add new patch to allow more space for U-Boot on link - Add new patch to move include of bitops out of ACPI region - Rebase to master - add new patch to fix polarity type in acpi_dp_add_gpio()
Changes in v1: - Add NHLT audio support - Add NHLT information - Add comments - Add more comments and rename cpu_get_bus_clock to cpu_get_bus_clock_khz() - Add new patch with coral audio descriptor files - Add support for NHLT table - Adjust implementation to match new ACPI GPIO generation - Capitalise ACPI_OPS_PTR - Don't build for SPL - Drop unnecessary callbacks - Fix i2c PCI addresses - Handle table generation without callbacks - Move ASL_REVISION define into this patch - Move acpi_create_dbg2() into generic code - Move the acpi.h header file to this commit - Move this code into an x86-specific file - Put this code in an x86-specific place and update commit message - Rename acpi-probed to linux,probed - Rename cpi,hid-desc-reg-offset to hid-desc-addr - Split PCT and PTC tables into a separate patch - Support hid-over-i2c separately as well - UIse hid-over-i2 compatible string - Update ACPI ordering to include multiple CPUs - Update commit message - Update commit message with a comma - Update for acpi_device_write_i2c_dev() return-value change - Use OEM_TABLE_ID instead of ACPI_TABLE_CREATOR - Use SHIFT and MASK for defines - Use acpi,ddn instead of acpi,desc - Use this file in APL - Use updated acpi_device_write_dsm_i2c_hid() function
Simon Glass (57): x86: acpi: Add cros_ec tables x86: acpi: Add base asl files for common x86 devices x86: acpi: apl: Add asl files for Apollo Lake x86: acpi: Add DPTF asl files x86: apl: Correct PCIE_ECAM_BASE x86: Add a config for the systemagent PCIEX regions size x86: Add a common global NVS structure x86: acpi: Support external GNVS tables x86: acpi: Expand the GNVS x86: coral: Add ACPI tables for coral acpi: Add support for writing a _PRW acpi: Add support for conditions and return values acpi: Support generating a multi-function _DSM for devices dm: acpi: Use correct GPIO polarity type in acpi_dp_add_gpio() x86: link: Allow more space for U-Boot i2c: Add a generic driver to generate ACPI info x86: Add wake sources for the acpi_gpe driver x86: apl: Support writing the IntelGraphicsMem table x86: acpi: Add a common routine to write WiFi info x86: Add some definitions for SMM x86: apl: Add power-management definitions x86: apl: Update iomap for ACPI x86: Add a few common Intel CPU functions x86: acpi: Support generation of the HPET table x86: acpi: Support generation of the DBG2 table acpi: Add support for generating processor tables x86: acpi: Add PCT and PTC tables acpi: Add more support for generating processor tables x86: acpi: Add common Intel ACPI tables x86: Support Atom SoCs using SWSMISCI rather than the SWSCI x86: acpi: Add support for additional Intel tables x86: apl: Allow reading hostbridge base addresses p2sb: Add some definitions used for ACPI x86: apl: Generate required ACPI tables x86: apl: Add support for hostbridge ACPI generation x86: apl: Generate CPU tables x86: apl: Generate ACPI table for LPC x86: apl: Drop unnecessary code in PMC driver tpm: cr50: Add ACPI support x86: fsp: Update the FSP API with the end-firmware method x86: cpu: Report address width from cpu_get_info() x86: Sort the MTRR table x86: Notify the FSP of the 'end firmware' event x86: Correct the assembly guard in e820.h x86: Add a header guard to asm/acpi_table.h x86: Correct handling of MADT table CPUs acpi: tpm: Add a TPM2 table acpi: tpm: Add a TPM1 table x86: acpi: Set the log category for x86 table generation x86: coral: Add audio descriptor files x86: apl: Check low-level init in FSP-S pre-init x86: fsp: Add more debugging for silicon init x86: fsp: Show FSP-S or FSP-M address in fsp_get_header() acpi: Use defines for field lengths x86: Add a way to add to the e820 memory table x86: Move include of bitops out of ACPI region x86: coral: Update config and device tree for ACPI
arch/x86/Kconfig | 47 ++ arch/x86/cpu/apollolake/Kconfig | 4 + arch/x86/cpu/apollolake/Makefile | 1 + arch/x86/cpu/apollolake/acpi.c | 211 ++++++ arch/x86/cpu/apollolake/cpu.c | 77 +++ arch/x86/cpu/apollolake/fsp_s.c | 2 + arch/x86/cpu/apollolake/hostbridge.c | 244 ++++++- arch/x86/cpu/apollolake/lpc.c | 18 + arch/x86/cpu/apollolake/pmc.c | 8 +- arch/x86/cpu/cpu.c | 15 + arch/x86/cpu/i386/cpu.c | 23 + arch/x86/cpu/intel_common/Makefile | 7 + arch/x86/cpu/intel_common/acpi.c | 377 ++++++++++ arch/x86/cpu/intel_common/cpu.c | 79 +++ arch/x86/cpu/intel_common/generic_wifi.c | 120 ++++ arch/x86/cpu/intel_common/intel_opregion.c | 168 +++++ arch/x86/cpu/mtrr.c | 12 + arch/x86/cpu/x86_64/cpu.c | 5 + arch/x86/dts/chromebook_coral.dts | 224 +++++- arch/x86/include/asm/acpi/chromeos.asl | 108 +++ arch/x86/include/asm/acpi/cpu.asl | 25 + arch/x86/include/asm/acpi/cros_ec/ac.asl | 22 + arch/x86/include/asm/acpi/cros_ec/als.asl | 56 ++ arch/x86/include/asm/acpi/cros_ec/battery.asl | 411 +++++++++++ arch/x86/include/asm/acpi/cros_ec/cros_ec.asl | 57 ++ arch/x86/include/asm/acpi/cros_ec/ec.asl | 557 +++++++++++++++ arch/x86/include/asm/acpi/cros_ec/emem.asl | 53 ++ .../asm/acpi/cros_ec/keyboard_backlight.asl | 52 ++ arch/x86/include/asm/acpi/cros_ec/pd.asl | 15 + arch/x86/include/asm/acpi/cros_ec/superio.asl | 159 +++++ arch/x86/include/asm/acpi/cros_ec/tbmc.asl | 23 + arch/x86/include/asm/acpi/cros_gnvs.asl | 29 + arch/x86/include/asm/acpi/dptf/charger.asl | 65 ++ arch/x86/include/asm/acpi/dptf/cpu.asl | 186 +++++ arch/x86/include/asm/acpi/dptf/dptf.asl | 121 ++++ arch/x86/include/asm/acpi/dptf/fan.asl | 57 ++ arch/x86/include/asm/acpi/dptf/thermal.asl | 521 ++++++++++++++ arch/x86/include/asm/acpi/global_nvs.h | 5 +- arch/x86/include/asm/acpi/lpc.asl | 141 ++++ arch/x86/include/asm/acpi/pci_osc.asl | 21 + arch/x86/include/asm/acpi/pcr.asl | 80 +++ arch/x86/include/asm/acpi/ramoops.asl | 32 + arch/x86/include/asm/acpi/sleepstates.asl | 12 +- arch/x86/include/asm/acpi_table.h | 162 +++++ arch/x86/include/asm/acpigen.h | 35 + arch/x86/include/asm/arch-apollolake/acpi.h | 18 + .../include/asm/arch-apollolake/acpi/dptf.asl | 35 + .../asm/arch-apollolake/acpi/globalnvs.asl | 41 ++ .../include/asm/arch-apollolake/acpi/gpio.asl | 191 ++++++ .../asm/arch-apollolake/acpi/gpiolib.asl | 109 +++ .../include/asm/arch-apollolake/acpi/lpss.asl | 105 +++ .../asm/arch-apollolake/acpi/northbridge.asl | 120 ++++ .../asm/arch-apollolake/acpi/pch_hda.asl | 77 +++ .../asm/arch-apollolake/acpi/pci_irqs.asl | 52 ++ .../include/asm/arch-apollolake/acpi/pcie.asl | 22 + .../asm/arch-apollolake/acpi/pcie_port.asl | 113 +++ .../asm/arch-apollolake/acpi/platform.asl | 10 + .../asm/arch-apollolake/acpi/pmc_ipc.asl | 49 ++ .../include/asm/arch-apollolake/acpi/scs.asl | 173 +++++ .../asm/arch-apollolake/acpi/soc_int.asl | 50 ++ .../asm/arch-apollolake/acpi/southbridge.asl | 34 + .../include/asm/arch-apollolake/acpi/xhci.asl | 33 + .../arch-apollolake/acpi/xhci_apl_ports.asl | 23 + .../arch-apollolake/acpi/xhci_glk_ports.asl | 24 + .../include/asm/arch-apollolake/global_nvs.h | 23 +- arch/x86/include/asm/arch-apollolake/gpe.h | 135 ++++ arch/x86/include/asm/arch-apollolake/gpio.h | 3 + arch/x86/include/asm/arch-apollolake/iomap.h | 16 + arch/x86/include/asm/arch-apollolake/pm.h | 40 +- .../include/asm/arch-apollolake/systemagent.h | 31 + arch/x86/include/asm/cpu.h | 9 + arch/x86/include/asm/cpu_common.h | 56 ++ arch/x86/include/asm/e820.h | 3 +- arch/x86/include/asm/fsp/fsp_api.h | 15 +- arch/x86/include/asm/intel_acpi.h | 52 ++ arch/x86/include/asm/intel_gnvs.h | 44 ++ arch/x86/include/asm/intel_opregion.h | 247 +++++++ arch/x86/include/asm/smm.h | 27 + arch/x86/lib/Makefile | 1 + arch/x86/lib/acpi_table.c | 390 ++++++++++- arch/x86/lib/acpigen.c | 96 +++ arch/x86/lib/fsp/fsp_common.c | 16 + arch/x86/lib/fsp/fsp_dram.c | 17 + arch/x86/lib/fsp/fsp_graphics.c | 32 + arch/x86/lib/fsp2/fsp_silicon_init.c | 4 +- arch/x86/lib/fsp2/fsp_support.c | 22 +- board/google/chromebook_coral/Kconfig | 2 +- board/google/chromebook_coral/Makefile | 1 + .../chromebook_coral/baseboard_dptf.asl | 71 ++ board/google/chromebook_coral/coral.c | 135 ++++ .../chromebook_coral/dialog-2ch-48khz-24b.dat | Bin 0 -> 100 bytes .../chromebook_coral/dmic-1ch-48khz-16b.dat | Bin 0 -> 3048 bytes .../chromebook_coral/dmic-2ch-48khz-16b.dat | Bin 0 -> 3048 bytes .../chromebook_coral/dmic-4ch-48khz-16b.dat | Bin 0 -> 3048 bytes board/google/chromebook_coral/dsdt.asl | 60 ++ .../max98357-render-2ch-48khz-24b.dat | Bin 0 -> 116 bytes .../google/chromebook_coral/variant_dptf.asl | 6 + board/google/chromebook_coral/variant_ec.h | 75 ++ board/google/chromebook_coral/variant_gpio.h | 63 ++ configs/chromebook_coral_defconfig | 13 +- configs/chromebook_link_defconfig | 2 +- doc/device-tree-bindings/chosen.txt | 18 + doc/device-tree-bindings/device.txt | 3 + doc/device-tree-bindings/i2c/generic-acpi.txt | 42 ++ drivers/core/Kconfig | 9 + drivers/i2c/Makefile | 3 + drivers/i2c/acpi_i2c.c | 226 ++++++ drivers/i2c/acpi_i2c.h | 15 + drivers/i2c/i2c-uclass.c | 17 + drivers/sound/max98357a.c | 2 +- drivers/tpm/cr50_i2c.c | 55 ++ include/acpi/acpi_device.h | 69 ++ include/acpi/acpi_dp.h | 2 +- include/acpi/acpi_s3.h | 4 + include/acpi/acpi_table.h | 140 +++- include/acpi/acpigen.h | 415 +++++++++++ include/bloblist.h | 8 + include/i2c.h | 23 + include/p2sb.h | 8 + include/power/acpi_pmc.h | 4 +- lib/acpi/acpi_device.c | 43 ++ lib/acpi/acpi_dp.c | 4 +- lib/acpi/acpi_table.c | 64 ++ lib/acpi/acpigen.c | 354 ++++++++++ test/dm/acpi_dp.c | 4 +- test/dm/acpigen.c | 647 ++++++++++++++++++ 126 files changed, 9696 insertions(+), 116 deletions(-) create mode 100644 arch/x86/cpu/apollolake/acpi.c create mode 100644 arch/x86/cpu/intel_common/acpi.c create mode 100644 arch/x86/cpu/intel_common/generic_wifi.c create mode 100644 arch/x86/cpu/intel_common/intel_opregion.c create mode 100644 arch/x86/include/asm/acpi/chromeos.asl create mode 100644 arch/x86/include/asm/acpi/cpu.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/ac.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/als.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/battery.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/cros_ec.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/ec.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/emem.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/keyboard_backlight.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/pd.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/superio.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/tbmc.asl create mode 100644 arch/x86/include/asm/acpi/cros_gnvs.asl create mode 100644 arch/x86/include/asm/acpi/dptf/charger.asl create mode 100644 arch/x86/include/asm/acpi/dptf/cpu.asl create mode 100644 arch/x86/include/asm/acpi/dptf/dptf.asl create mode 100644 arch/x86/include/asm/acpi/dptf/fan.asl create mode 100644 arch/x86/include/asm/acpi/dptf/thermal.asl create mode 100644 arch/x86/include/asm/acpi/lpc.asl create mode 100644 arch/x86/include/asm/acpi/pci_osc.asl create mode 100644 arch/x86/include/asm/acpi/pcr.asl create mode 100644 arch/x86/include/asm/acpi/ramoops.asl create mode 100644 arch/x86/include/asm/acpigen.h create mode 100644 arch/x86/include/asm/arch-apollolake/acpi.h create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/dptf.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/globalnvs.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/gpio.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/gpiolib.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/lpss.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/northbridge.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/pch_hda.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/pci_irqs.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/pcie.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/pcie_port.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/platform.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/pmc_ipc.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/scs.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/soc_int.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/southbridge.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/xhci.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/xhci_apl_ports.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/xhci_glk_ports.asl create mode 100644 arch/x86/include/asm/arch-apollolake/gpe.h create mode 100644 arch/x86/include/asm/intel_acpi.h create mode 100644 arch/x86/include/asm/intel_gnvs.h create mode 100644 arch/x86/include/asm/intel_opregion.h create mode 100644 arch/x86/include/asm/smm.h create mode 100644 arch/x86/lib/acpigen.c create mode 100644 board/google/chromebook_coral/baseboard_dptf.asl create mode 100644 board/google/chromebook_coral/dialog-2ch-48khz-24b.dat create mode 100644 board/google/chromebook_coral/dmic-1ch-48khz-16b.dat create mode 100644 board/google/chromebook_coral/dmic-2ch-48khz-16b.dat create mode 100644 board/google/chromebook_coral/dmic-4ch-48khz-16b.dat create mode 100644 board/google/chromebook_coral/dsdt.asl create mode 100644 board/google/chromebook_coral/max98357-render-2ch-48khz-24b.dat create mode 100644 board/google/chromebook_coral/variant_dptf.asl create mode 100644 board/google/chromebook_coral/variant_ec.h create mode 100644 board/google/chromebook_coral/variant_gpio.h create mode 100644 doc/device-tree-bindings/i2c/generic-acpi.txt create mode 100644 drivers/i2c/acpi_i2c.c create mode 100644 drivers/i2c/acpi_i2c.h
Add ASL files for the Chrome OS EC, taken from coreboot.
(no changes since v1)
arch/x86/include/asm/acpi/cros_ec/ac.asl | 22 + arch/x86/include/asm/acpi/cros_ec/als.asl | 56 ++ arch/x86/include/asm/acpi/cros_ec/battery.asl | 411 +++++++++++++ arch/x86/include/asm/acpi/cros_ec/cros_ec.asl | 57 ++ arch/x86/include/asm/acpi/cros_ec/ec.asl | 557 ++++++++++++++++++ arch/x86/include/asm/acpi/cros_ec/emem.asl | 53 ++ .../asm/acpi/cros_ec/keyboard_backlight.asl | 52 ++ arch/x86/include/asm/acpi/cros_ec/pd.asl | 15 + arch/x86/include/asm/acpi/cros_ec/superio.asl | 159 +++++ arch/x86/include/asm/acpi/cros_ec/tbmc.asl | 23 + 10 files changed, 1405 insertions(+) create mode 100644 arch/x86/include/asm/acpi/cros_ec/ac.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/als.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/battery.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/cros_ec.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/ec.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/emem.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/keyboard_backlight.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/pd.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/superio.asl create mode 100644 arch/x86/include/asm/acpi/cros_ec/tbmc.asl
diff --git a/arch/x86/include/asm/acpi/cros_ec/ac.asl b/arch/x86/include/asm/acpi/cros_ec/ac.asl new file mode 100644 index 00000000000..80e0ebd3ad5 --- /dev/null +++ b/arch/x86/include/asm/acpi/cros_ec/ac.asl @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2012 The Chromium OS Authors. All rights reserved. + */ + +// Scope (EC0) + +Device (AC) +{ + Name (_HID, "ACPI0003") + Name (_PCL, Package () { _SB }) + + Method (_PSR) + { + Return (ACEX) + } + + Method (_STA) + { + Return (0x0F) + } +} diff --git a/arch/x86/include/asm/acpi/cros_ec/als.asl b/arch/x86/include/asm/acpi/cros_ec/als.asl new file mode 100644 index 00000000000..f3d40f889c8 --- /dev/null +++ b/arch/x86/include/asm/acpi/cros_ec/als.asl @@ -0,0 +1,56 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2014 Google Inc. + */ + +Device (ALS) +{ + Name (_HID, "ACPI0008") + Name (_UID, 1) + + Method (_STA, 0, NotSerialized) + { + Return (0xF) + } + + /* + * Returns the current ambient light illuminance reading in lux + * + * 0: Reading is below the range of sensitivity of the sensor + * -1: Reading is above the range or sensitivity of the sensor + */ + Method (_ALI, 0, NotSerialized) + { + Return (^^ALS0) + } + + /* + * Returns a recommended polling frequency in tenths of seconds + * + * 0: No need to poll, async notifications will indicate changes + */ + Name (_ALP, 10) + + /* + * Returns a package of packages where each tuple consists of a pair + * of integers mapping ambient light illuminance to display brightness. + * + * {<display luminance adjustment>, <ambient light illuminance>} + * + * Ambient light illuminance values are specified in lux. + * + * Display luminance adjustment values are relative percentages where + * 100 is no (0%) display brightness adjustment. Values <100 indicate + * negative adjustment (dimming) and values >100 indicate positive + * adjustment (brightening). + * + * This is currently unused by the Linux kernel ACPI ALS driver but + * is required by the ACPI specification so just define a basic two + * point response curve. + */ + Name (_ALR, Package () + { + Package () { 70, 30 }, // Min { -30% adjust at 30 lux } + Package () { 150, 1000 } // Max { +50% adjust at 1000 lux } + }) +} diff --git a/arch/x86/include/asm/acpi/cros_ec/battery.asl b/arch/x86/include/asm/acpi/cros_ec/battery.asl new file mode 100644 index 00000000000..f106088231e --- /dev/null +++ b/arch/x86/include/asm/acpi/cros_ec/battery.asl @@ -0,0 +1,411 @@ +/*/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2011 The Chromium OS Authors. All rights reserved. + */ + +// Scope (EC0) + +/* Mutex for EC battery index interface */ +Mutex (BATM, 0) + +// Wait for desired battery index to be presented in shared memory +// Arg0 = battery index +// Returns Zero on success, One on error. +Method (BTSW, 1) +{ +#ifdef EC_ENABLE_SECOND_BATTERY_DEVICE + If (LEqual (BTIX, Arg0)) { + Return (Zero) + } + If (LGreaterEqual (Arg0, BTCN)) { + Return (One) + } + Store (Arg0, _SB.PCI0.LPCB.EC0.BTID) + Store (5, Local0) // Timeout 5 msec + While (LNotEqual (BTIX, Arg0)) + { + Sleep (1) + Decrement (Local0) + If (LEqual (Local0, Zero)) + { + Return (One) + } + } +#else + If (LNotEqual (0, Arg0)) { + Return (One) + } +#endif + Return (Zero) +} + +// _STA implementation. +// Arg0 = battery index +Method (BSTA, 1, Serialized) +{ + If (Acquire (^BATM, 1000)) { + Return (Zero) + } + + If (And(Not(BTSW (Arg0)), BTEX)) { + Store (0x1F, Local0) + } Else { + Store (0x0F, Local0) + } + + Release (^BATM) + Return (Local0) +} + +// _BIF implementation. +// Arg0 = battery index +// Arg1 = PBIF +Method (BBIF, 2, Serialized) +{ + If (Acquire (^BATM, 1000)) { + Return (Arg1) + } + + If (BTSW (Arg0)) { + Release (^BATM) + Return (Arg1) + } + // Last Full Charge Capacity + Store (BTDF, Index (Arg1, 2)) + + // Design Voltage + Store (BTDV, Index (Arg1, 4)) + + // Design Capacity + Store (BTDA, Local0) + Store (Local0, Index (Arg1, 1)) + + // Design Capacity of Warning + Divide (Multiply (Local0, DWRN), 100, , Local2) + Store (Local2, Index (Arg1, 5)) + + // Design Capacity of Low + Divide (Multiply (Local0, DLOW), 100, , Local2) + Store (Local2, Index (Arg1, 6)) + + // Get battery info from mainboard + Store (ToString(Concatenate(BMOD, 0x00)), Index (Arg1, 9)) + Store (ToString(Concatenate(BSER, 0x00)), Index (Arg1, 10)) + Store (ToString(Concatenate(BMFG, 0x00)), Index (Arg1, 12)) + + Release (^BATM) + Return (Arg1) +} + +// _BIX implementation. +// Arg0 = battery index +// Arg1 = PBIX +Method (BBIX, 2, Serialized) +{ + If (Acquire (^BATM, 1000)) { + Return (Arg1) + } + + If (BTSW (Arg0)) { + Release (^BATM) + Return (Arg1) + } + // Last Full Charge Capacity + Store (BTDF, Index (Arg1, 3)) + + // Design Voltage + Store (BTDV, Index (Arg1, 5)) + + // Design Capacity + Store (BTDA, Local0) + Store (Local0, Index (Arg1, 2)) + + // Design Capacity of Warning + Divide (Multiply (Local0, DWRN), 100, , Local2) + Store (Local2, Index (Arg1, 6)) + + // Design Capacity of Low + Divide (Multiply (Local0, DLOW), 100, , Local2) + Store (Local2, Index (Arg1, 7)) + + // Cycle Count + Store (BTCC, Index (Arg1, 8)) + + // Get battery info from mainboard + Store (ToString(Concatenate(BMOD, 0x00)), Index (Arg1, 16)) + Store (ToString(Concatenate(BSER, 0x00)), Index (Arg1, 17)) + Store (ToString(Concatenate(BMFG, 0x00)), Index (Arg1, 19)) + + Release (^BATM) + Return (Arg1) +} + +// _BST implementation. +// Arg0 = battery index +// Arg1 = PBST +// Arg2 = BSTP +// Arg3 = BFWK +Method (BBST, 4, Serialized) +{ + If (Acquire (^BATM, 1000)) { + Return (Arg1) + } + + If (BTSW (Arg0)) { + Release (^BATM) + Return (Arg1) + } + // + // 0: BATTERY STATE + // + // bit 0 = discharging + // bit 1 = charging + // bit 2 = critical level + // + Store (Zero, Local1) + + // Check if AC is present + If (ACEX) { + If (BFCG) { + Store (0x02, Local1) + } ElseIf (BFDC) { + Store (0x01, Local1) + } + } Else { + // Always discharging when on battery power + Store (0x01, Local1) + } + + // Check for critical battery level + If (BFCR) { + Or (Local1, 0x04, Local1) + } + Store (Local1, Index (Arg1, 0)) + + // Notify if battery state has changed since last time + If (LNotEqual (Local1, DeRefOf (Arg2))) { + Store (Local1, Arg2) + If (LEqual(Arg0, 0)) { + Notify (BAT0, 0x80) + } +#ifdef EC_ENABLE_SECOND_BATTERY_DEVICE + Else { + Notify (BAT1, 0x80) + } +#endif + } + + // + // 1: BATTERY PRESENT RATE + // + Store (BTPR, Index (Arg1, 1)) + + // + // 2: BATTERY REMAINING CAPACITY + // + Store (BTRA, Local1) + If (LAnd (Arg3, LAnd (ACEX, LNot (LAnd (BFDC, BFCG))))) { + // On AC power and battery is neither charging + // nor discharging. Linux expects a full battery + // to report same capacity as last full charge. + // https://bugzilla.kernel.org/show_bug.cgi?id=12632 + Store (BTDF, Local2) + + // See if within ~6% of full + ShiftRight (Local2, 4, Local3) + If (LAnd (LGreater (Local1, Subtract (Local2, Local3)), + LLess (Local1, Add (Local2, Local3)))) + { + Store (Local2, Local1) + } + } + Store (Local1, Index (Arg1, 2)) + + // + // 3: BATTERY PRESENT VOLTAGE + // + Store (BTVO, Index (Arg1, 3)) + + Release (^BATM) + Return (Arg1) +} + +Device (BAT0) +{ + Name (_HID, EISAID ("PNP0C0A")) + Name (_UID, 1) + Name (_PCL, Package () { _SB }) + + Name (PBIF, Package () { + 0x00000001, // 0x00: Power Unit: mAh + 0xFFFFFFFF, // 0x01: Design Capacity + 0xFFFFFFFF, // 0x02: Last Full Charge Capacity + 0x00000001, // 0x03: Battery Technology: Rechargeable + 0xFFFFFFFF, // 0x04: Design Voltage + 0x00000003, // 0x05: Design Capacity of Warning + 0xFFFFFFFF, // 0x06: Design Capacity of Low + 0x00000001, // 0x07: Capacity Granularity 1 + 0x00000001, // 0x08: Capacity Granularity 2 + "", // 0x09: Model Number + "", // 0x0a: Serial Number + "LION", // 0x0b: Battery Type + "" // 0x0c: OEM Information + }) + + Name (PBIX, Package () { + 0x00000000, // 0x00: Revision + 0x00000001, // 0x01: Power Unit: mAh + 0xFFFFFFFF, // 0x02: Design Capacity + 0xFFFFFFFF, // 0x03: Last Full Charge Capacity + 0x00000001, // 0x04: Battery Technology: Rechargeable + 0xFFFFFFFF, // 0x05: Design Voltage + 0x00000003, // 0x06: Design Capacity of Warning + 0xFFFFFFFF, // 0x07: Design Capacity of Low + 0x00000000, // 0x08: Cycle Count + 0x00018000, // 0x09: Measurement Accuracy (98.3%?) + 0x000001F4, // 0x0a: Max Sampling Time (500ms) + 0x0000000a, // 0x0b: Min Sampling Time (10ms) + 0xFFFFFFFF, // 0x0c: Max Averaging Interval + 0xFFFFFFFF, // 0x0d: Min Averaging Interval + 0x00000001, // 0x0e: Capacity Granularity 1 + 0x00000001, // 0x0f: Capacity Granularity 2 + "", // 0x10 Model Number + "", // 0x11: Serial Number + "LION", // 0x12: Battery Type + "" // 0x13: OEM Information + }) + + Name (PBST, Package () { + 0x00000000, // 0x00: Battery State + 0xFFFFFFFF, // 0x01: Battery Present Rate + 0xFFFFFFFF, // 0x02: Battery Remaining Capacity + 0xFFFFFFFF, // 0x03: Battery Present Voltage + }) + Name (BSTP, Zero) + + // Workaround for full battery status, disabled by default + Name (BFWK, Zero) + + // Method to enable full battery workaround + Method (BFWE) + { + Store (One, BFWK) + } + + // Method to disable full battery workaround + Method (BFWD) + { + Store (Zero, BFWK) + } + + Method (_STA, 0, Serialized) + { + Return (BSTA (0)) + } + + Method (_BIF, 0, Serialized) + { + Return (BBIF (0, PBIF)) + } + + Method (_BIX, 0, Serialized) + { + Return (BBIX (0, PBIX)) + } + + Method (_BST, 0, Serialized) + { + Return (BBST (0, PBST, RefOf (BSTP), BFWK)) + } +} + +#ifdef EC_ENABLE_SECOND_BATTERY_DEVICE +Device (BAT1) +{ + Name (_HID, EISAID ("PNP0C0A")) + Name (_UID, 1) + Name (_PCL, Package () { _SB }) + + Name (PBIF, Package () { + 0x00000001, // 0x00: Power Unit: mAh + 0xFFFFFFFF, // 0x01: Design Capacity + 0xFFFFFFFF, // 0x02: Last Full Charge Capacity + 0x00000001, // 0x03: Battery Technology: Rechargeable + 0xFFFFFFFF, // 0x04: Design Voltage + 0x00000003, // 0x05: Design Capacity of Warning + 0xFFFFFFFF, // 0x06: Design Capacity of Low + 0x00000001, // 0x07: Capacity Granularity 1 + 0x00000001, // 0x08: Capacity Granularity 2 + "", // 0x09: Model Number + "", // 0x0a: Serial Number + "LION", // 0x0b: Battery Type + "" // 0x0c: OEM Information + }) + + Name (PBIX, Package () { + 0x00000000, // 0x00: Revision + 0x00000001, // 0x01: Power Unit: mAh + 0xFFFFFFFF, // 0x02: Design Capacity + 0xFFFFFFFF, // 0x03: Last Full Charge Capacity + 0x00000001, // 0x04: Battery Technology: Rechargeable + 0xFFFFFFFF, // 0x05: Design Voltage + 0x00000003, // 0x06: Design Capacity of Warning + 0xFFFFFFFF, // 0x07: Design Capacity of Low + 0x00000000, // 0x08: Cycle Count + 0x00018000, // 0x09: Measurement Accuracy (98.3%?) + 0x000001F4, // 0x0a: Max Sampling Time (500ms) + 0x0000000a, // 0x0b: Min Sampling Time (10ms) + 0xFFFFFFFF, // 0x0c: Max Averaging Interval + 0xFFFFFFFF, // 0x0d: Min Averaging Interval + 0x00000001, // 0x0e: Capacity Granularity 1 + 0x00000001, // 0x0f: Capacity Granularity 2 + "", // 0x10 Model Number + "", // 0x11: Serial Number + "LION", // 0x12: Battery Type + "" // 0x13: OEM Information + }) + + Name (PBST, Package () { + 0x00000000, // 0x00: Battery State + 0xFFFFFFFF, // 0x01: Battery Present Rate + 0xFFFFFFFF, // 0x02: Battery Remaining Capacity + 0xFFFFFFFF, // 0x03: Battery Present Voltage + }) + Name (BSTP, Zero) + + // Workaround for full battery status, disabled by default + Name (BFWK, Zero) + + // Method to enable full battery workaround + Method (BFWE) + { + Store (One, BFWK) + } + + // Method to disable full battery workaround + Method (BFWD) + { + Store (Zero, BFWK) + } + + Method (_STA, 0, Serialized) + { + Return (BSTA (1)) + } + + Method (_BIF, 0, Serialized) + { + Return (BBIF (1, PBIF)) + } + + Method (_BIX, 0, Serialized) + { + Return (BBIX (1, PBIX)) + } + + Method (_BST, 0, Serialized) + { + Return (BBST (1, PBST, RefOf (BSTP), BFWK)) + } +} +#endif diff --git a/arch/x86/include/asm/acpi/cros_ec/cros_ec.asl b/arch/x86/include/asm/acpi/cros_ec/cros_ec.asl new file mode 100644 index 00000000000..9f50185b70f --- /dev/null +++ b/arch/x86/include/asm/acpi/cros_ec/cros_ec.asl @@ -0,0 +1,57 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2016 Google Inc. + */ + +Device (CREC) +{ + Name (_HID, "GOOG0004") + Name (_UID, 1) + Name (_DDN, "EC Command Device") +#ifdef EC_ENABLE_WAKE_PIN + Name (_PRW, Package () { EC_ENABLE_WAKE_PIN, 0x5 }) +#endif + +#ifdef EC_ENABLE_SYNC_IRQ + Name (_CRS, ResourceTemplate () + { + Interrupt (ResourceConsumer, Level, ActiveLow, Exclusive) + { + EC_SYNC_IRQ + } + }) +#endif + +#ifdef EC_ENABLE_SYNC_IRQ_GPIO + Name (_CRS, ResourceTemplate () + { + GpioInt (Level, ActiveLow, Exclusive, PullDefault, 0x0000, + "\_SB.GPIO", 0x00, ResourceConsumer, ,) + { + EC_SYNC_IRQ + } + }) +#endif + +#ifdef EC_ENABLE_MKBP_DEVICE + Device (CKSC) + { + Name (_HID, "GOOG0007") + Name (_UID, 1) + Name (_DDN, "EC MKBP Device") + } +#endif + +#ifdef EC_ENABLE_CBAS_DEVICE + Device (CBAS) + { + Name (_HID, "GOOG000B") + Name (_UID, 1) + Name (_DDN, "EC Base Switch Device") + } +#endif + Method(_STA, 0) + { + Return (0xB) + } +} diff --git a/arch/x86/include/asm/acpi/cros_ec/ec.asl b/arch/x86/include/asm/acpi/cros_ec/ec.asl new file mode 100644 index 00000000000..03f57f25a29 --- /dev/null +++ b/arch/x86/include/asm/acpi/cros_ec/ec.asl @@ -0,0 +1,557 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2012 The Chromium OS Authors. All rights reserved. + */ + +/* + * The mainboard must define a PNOT method to handle power + * state notifications and Notify CPU device objects to + * re-evaluate their _PPC and _CST tables. + */ + +// Mainboard specific throttle handler +#ifdef DPTF_ENABLE_CHARGER +External (_SB.DPTF.TCHG, DeviceObj) +#endif + + +Device (EC0) +{ + Name (_HID, EISAID ("PNP0C09")) + Name (_UID, 1) + Name (_GPE, EC_SCI_GPI) + Name (TOFS, EC_TEMP_SENSOR_OFFSET) + Name (TNCA, EC_TEMP_SENSOR_NOT_CALIBRATED) + Name (TNOP, EC_TEMP_SENSOR_NOT_POWERED) + Name (TBAD, EC_TEMP_SENSOR_ERROR) + Name (TNPR, EC_TEMP_SENSOR_NOT_PRESENT) + Name (DWRN, 15) // Battery capacity warning at 15% + Name (DLOW, 10) // Battery capacity low at 10% + + OperationRegion (ERAM, EmbeddedControl, 0x00, EC_ACPI_MEM_MAPPED_BEGIN) + Field (ERAM, ByteAcc, Lock, Preserve) + { + Offset (0x00), + RAMV, 8, // EC RAM Version + TSTB, 8, // Test Byte + TSTC, 8, // Complement of Test Byte + KBLV, 8, // Keyboard Backlight value + FAND, 8, // Set Fan Duty Cycle + PATI, 8, // Programmable Auxiliary Trip Sensor ID + PATT, 8, // Programmable Auxiliary Trip Threshold + PATC, 8, // Programmable Auxiliary Trip Commit + CHGL, 8, // Charger Current Limit + TBMD, 1, // Tablet mode + DDPN, 3, // Device DPTF Profile Number + // DFUD must be 0 for the other 31 values to be valid + Offset (0x0a), + DFUD, 1, // Device Features Undefined + FLSH, 1, // Flash commands present + PFAN, 1, // PWM Fan control present + KBLE, 1, // Keyboard Backlight present + LTBR, 1, // Lightbar present + LEDC, 1, // LED control + MTNS, 1, // Motion sensors present + KEYB, 1, // EC is keyboard controller + PSTR, 1, // Persistent storage + P80P, 1, // EC serves I/O Port 80h + THRM, 1, // EC supports thermal management + SBKL, 1, // Screen backlight switch present + WIFI, 1, // WIFI switch present + HOST, 1, // EC monitors host events (eg SCI, SMI) + GPIO, 1, // EC provides GPIO commands + I2CB, 1, // EC provides I2C controller access + CHRG, 1, // EC provides commands for charger control + BATT, 1, // Simply Battery support + SBAT, 1, // Smart Battery support + HANG, 1, // EC can detect host hang + PMUI, 1, // Power Information + DSEC, 1, // another EC exists downstream + UPDC, 1, // supports USB Power Delivery + UMUX, 1, // supports USB Mux + MSFF, 1, // Motion Sense has FIFO + TVST, 1, // supports temporary secure vstore + TCMV, 1, // USB Type C Muxing is virtual (host assisted) + RTCD, 1, // EC provides an RTC device + FPRD, 1, // EC provides a fingerprint reader device + TPAD, 1, // EC provides a touchpad device + RWSG, 1, // EC has RWSIG task enabled + DEVE, 1, // EC supports device events + // make sure we're within our space envelope + Offset (0x0e), + Offset (0x12), + BTID, 8, // Battery index that host wants to read + USPP, 8, // USB Port Power +} + +#if IS_ENABLED(CONFIG_EC_GOOGLE_CHROMEEC_ACPI_MEMMAP) + OperationRegion (EMEM, EmbeddedControl, + EC_ACPI_MEM_MAPPED_BEGIN, EC_ACPI_MEM_MAPPED_SIZE) + Field (EMEM, ByteAcc, Lock, Preserve) +#else + OperationRegion (EMEM, SystemIO, EC_LPC_ADDR_MEMMAP, EC_MEMMAP_SIZE) + Field (EMEM, ByteAcc, NoLock, Preserve) +#endif + { + #include "emem.asl" + } + +#ifdef EC_ENABLE_LID_SWITCH + /* LID Switch */ + Device (LID0) + { + Name (_HID, EisaId ("PNP0C0D")) + Method (_LID, 0) + { + Return (^^LIDS) + } + +#ifdef EC_ENABLE_WAKE_PIN + Name (_PRW, Package () { EC_ENABLE_WAKE_PIN, 0x5 }) +#endif + } +#endif + + Method (TINS, 1, Serialized) + { + Switch (ToInteger (Arg0)) + { + Case (0) { Return (TIN0) } + Case (1) { Return (TIN1) } + Case (2) { Return (TIN2) } + Case (3) { Return (TIN3) } + Case (4) { Return (TIN4) } + Case (5) { Return (TIN5) } + Case (6) { Return (TIN6) } + Case (7) { Return (TIN7) } + Case (8) { Return (TIN8) } + Case (9) { Return (TIN9) } + Default { Return (TIN0) } + } + } + + Method (_CRS, 0, Serialized) + { + Name (ECMD, ResourceTemplate() + { + IO (Decode16, + EC_LPC_ADDR_ACPI_DATA, + EC_LPC_ADDR_ACPI_DATA, + 0, 1) + IO (Decode16, + EC_LPC_ADDR_ACPI_CMD, + EC_LPC_ADDR_ACPI_CMD, + 0, 1) + }) + Return (ECMD) + } + + Method (_REG, 2, NotSerialized) + { + // Initialize AC power state + Store (ACEX, \PWRS) + + // Initialize LID switch state + Store (LIDS, \LIDS) + } + + /* Read requested temperature and check against EC error values */ + Method (TSRD, 1, Serialized) + { + Store (_SB.PCI0.LPCB.EC0.TINS (Arg0), Local0) + + /* Check for sensor not calibrated */ + If (LEqual (Local0, _SB.PCI0.LPCB.EC0.TNCA)) { + Return (Zero) + } + + /* Check for sensor not present */ + If (LEqual (Local0, _SB.PCI0.LPCB.EC0.TNPR)) { + Return (Zero) + } + + /* Check for sensor not powered */ + If (LEqual (Local0, _SB.PCI0.LPCB.EC0.TNOP)) { + Return (Zero) + } + + /* Check for sensor bad reading */ + If (LEqual (Local0, _SB.PCI0.LPCB.EC0.TBAD)) { + Return (Zero) + } + + /* Adjust by offset to get Kelvin */ + Add (_SB.PCI0.LPCB.EC0.TOFS, Local0, Local0) + + /* Convert to 1/10 Kelvin */ + Multiply (Local0, 10, Local0) + + Return (Local0) + } + + // Lid Closed Event + Method (_Q01, 0, NotSerialized) + { + Store ("EC: LID CLOSE", Debug) + Store (LIDS, \LIDS) +#ifdef EC_ENABLE_LID_SWITCH + Notify (LID0, 0x80) +#endif + } + + // Lid Open Event + Method (_Q02, 0, NotSerialized) + { + Store ("EC: LID OPEN", Debug) + Store (LIDS, \LIDS) + Notify (CREC, 0x2) +#ifdef EC_ENABLE_LID_SWITCH + Notify (LID0, 0x80) +#endif + } + + // Power Button + Method (_Q03, 0, NotSerialized) + { + Store ("EC: POWER BUTTON", Debug) + } + + // AC Connected + Method (_Q04, 0, NotSerialized) + { + Store ("EC: AC CONNECTED", Debug) + Store (ACEX, \PWRS) + Notify (AC, 0x80) +#ifdef DPTF_ENABLE_CHARGER + If (CondRefOf (_SB.DPTF.TCHG)) { + Notify (_SB.DPTF.TCHG, 0x80) + } +#endif + \PNOT () + } + + // AC Disconnected + Method (_Q05, 0, NotSerialized) + { + Store ("EC: AC DISCONNECTED", Debug) + Store (ACEX, \PWRS) + Notify (AC, 0x80) +#ifdef DPTF_ENABLE_CHARGER + If (CondRefOf (_SB.DPTF.TCHG)) { + Notify (_SB.DPTF.TCHG, 0x80) + } +#endif + \PNOT () + } + + // Battery Low Event + Method (_Q06, 0, NotSerialized) + { + Store ("EC: BATTERY LOW", Debug) + Notify (BAT0, 0x80) + } + + // Battery Critical Event + Method (_Q07, 0, NotSerialized) + { + Store ("EC: BATTERY CRITICAL", Debug) + Notify (BAT0, 0x80) + } + + // Battery Info Event + Method (_Q08, 0, NotSerialized) + { + Store ("EC: BATTERY INFO", Debug) + Notify (BAT0, 0x81) +#ifdef EC_ENABLE_SECOND_BATTERY_DEVICE + If (CondRefOf (BAT1)) { + Notify (BAT1, 0x81) + } +#endif + } + + // Thermal Overload Event + Method (_Q0A, 0, NotSerialized) + { + Store ("EC: THERMAL OVERLOAD", Debug) + Notify (_TZ, 0x80) + } + + // Thermal Event + Method (_Q0B, 0, NotSerialized) + { + Store ("EC: THERMAL", Debug) + Notify (_TZ, 0x80) + } + + // USB Charger + Method (_Q0C, 0, NotSerialized) + { + Store ("EC: USB CHARGER", Debug) + } + + // Key Pressed + Method (_Q0D, 0, NotSerialized) + { + Store ("EC: KEY PRESSED", Debug) + Notify (CREC, 0x2) + } + + // Thermal Shutdown Imminent + Method (_Q10, 0, NotSerialized) + { + Store ("EC: THERMAL SHUTDOWN", Debug) + Notify (_TZ, 0x80) + } + + // Battery Shutdown Imminent + Method (_Q11, 0, NotSerialized) + { + Store ("EC: BATTERY SHUTDOWN", Debug) + Notify (BAT0, 0x80) + } + + // Throttle Start + Method (_Q12, 0, NotSerialized) + { +#ifdef EC_ENABLE_THROTTLING_HANDLER + Store ("EC: THROTTLE START", Debug) + _TZ.THRT (1) +#endif + } + + // Throttle Stop + Method (_Q13, 0, NotSerialized) + { +#ifdef EC_ENABLE_THROTTLING_HANDLER + Store ("EC: THROTTLE STOP", Debug) + _TZ.THRT (0) +#endif + } + +#ifdef EC_ENABLE_PD_MCU_DEVICE + // PD event + Method (_Q16, 0, NotSerialized) + { + Store ("EC: GOT PD EVENT", Debug) + Notify (ECPD, 0x80) + } +#endif + + // Battery Status + Method (_Q17, 0, NotSerialized) + { + Store ("EC: BATTERY STATUS", Debug) + Notify (BAT0, 0x80) +#ifdef EC_ENABLE_SECOND_BATTERY_DEVICE + If (CondRefOf (BAT1)) { + Notify (BAT1, 0x80) + } +#endif + } + + // MKBP interrupt. + Method (_Q1B, 0, NotSerialized) + { + Store ("EC: MKBP", Debug) + Notify (CREC, 0x80) + } + + // TABLET mode switch Event + Method (_Q1D, 0, NotSerialized) + { + Store ("EC: TABLET mode switch Event", Debug) + Notify (CREC, 0x2) +#ifdef EC_ENABLE_MULTIPLE_DPTF_PROFILES + _SB.DPTF.TPET() +#endif +#ifdef EC_ENABLE_TBMC_DEVICE + Notify (TBMC, 0x80) +#endif + } + + /* + * Dynamic Platform Thermal Framework support + */ + + /* Mutex for EC PAT interface */ + Mutex (PATM, 1) + + /* + * Set Aux Trip Point 0 + * Arg0 = Temp Sensor ID + * Arg1 = Value to set + */ + Method (PAT0, 2, Serialized) + { + If (Acquire (^PATM, 1000)) { + Return (0) + } + + /* Set sensor ID */ + Store (ToInteger (Arg0), ^PATI) + + /* Temperature is passed in 1/10 Kelvin */ + Divide (ToInteger (Arg1), 10, , Local1) + + /* Adjust by EC temperature offset */ + Subtract (Local1, ^TOFS, ^PATT) + + /* Set commit value with SELECT=0 and ENABLE=1 */ + Store (0x02, ^PATC) + + Release (^PATM) + Return (1) + } + + /* + * Set Aux Trip Point 1 + * Arg0 = Temp Sensor ID + * Arg1 = Value to set + */ + Method (PAT1, 2, Serialized) + { + If (Acquire (^PATM, 1000)) { + Return (0) + } + + /* Set sensor ID */ + Store (ToInteger (Arg0), ^PATI) + + /* Temperature is passed in 1/10 Kelvin */ + Divide (ToInteger (Arg1), 10, , Local1) + + /* Adjust by EC temperature offset */ + Subtract (Local1, ^TOFS, ^PATT) + + /* Set commit value with SELECT=1 and ENABLE=1 */ + Store (0x03, ^PATC) + + Release (^PATM) + Return (1) + } + + /* Disable Aux Trip Points + * Arg0 = Temp Sensor ID + */ + Method (PATD, 1, Serialized) + { + If (Acquire (^PATM, 1000)) { + Return (0) + } + + Store (ToInteger (Arg0), ^PATI) + Store (0x00, ^PATT) + + /* Disable PAT0 */ + Store (0x00, ^PATC) + + /* Disable PAT1 */ + Store (0x01, ^PATC) + + Release (^PATM) + Return (1) + } + + /* + * Thermal Threshold Event + */ + Method (_Q09, 0, NotSerialized) + { + If (LNot(Acquire (^PATM, 1000))) { + /* Read sensor ID for event */ + Store (^PATI, Local0) + + /* When sensor ID returns 0xFF then no more events */ + While (LNotEqual (Local0, EC_TEMP_SENSOR_NOT_PRESENT)) + { +#ifdef HAVE_THERM_EVENT_HANDLER + _SB.DPTF.TEVT (Local0) +#endif + + /* Keep reaading sensor ID for event */ + Store (^PATI, Local0) + } + + Release (^PATM) + } + } + + /* + * Set Charger Current Limit + * Arg0 = Current Limit in 64mA steps + */ + Method (CHGS, 1, Serialized) + { + Store (ToInteger (Arg0), ^CHGL) + } + + /* + * Disable Charger Current Limit + */ + Method (CHGD, 0, Serialized) + { + Store (0xFF, ^CHGL) + } + + /* Read current Tablet mode */ + Method (RCTM, 0, NotSerialized) + { + Return (^TBMD) + } + + /* Read current Device DPTF Profile Number */ + Method (RCDP, 0, NotSerialized) + { + /* + * DDPN = 0 is reserved for backwards compatibility. + * If DDPN == 0 use TBMD to load appropriate DPTF table. + */ + If (LEqual (^DDPN, 0)) { + Return (^TBMD) + } Else { + Subtract (^DDPN, 1, Local0) + Return (Local0) + } + } + +#if IS_ENABLED(CONFIG_EC_GOOGLE_CHROMEEC_ACPI_USB_PORT_POWER) + /* + * Enable USB Port Power + * Arg0 = USB port ID + */ + Method (UPPS, 1, Serialized) + { + Or (USPP, ShiftLeft (1, Arg0), USPP) + } + + /* + * Disable USB Port Power + * Arg0 = USB port ID + */ + Method (UPPC, 1, Serialized) + { + And (USPP, Not (ShiftLeft (1, Arg0)), USPP) + } +#endif + + #include "ac.asl" + #include "battery.asl" + #include "cros_ec.asl" + +#ifdef EC_ENABLE_ALS_DEVICE + #include "als.asl" +#endif + +#ifdef EC_ENABLE_KEYBOARD_BACKLIGHT + #include "keyboard_backlight.asl" +#endif + +#ifdef EC_ENABLE_PD_MCU_DEVICE + #include "pd.asl" +#endif + +#ifdef EC_ENABLE_TBMC_DEVICE + #include "tbmc.asl" +#endif +} diff --git a/arch/x86/include/asm/acpi/cros_ec/emem.asl b/arch/x86/include/asm/acpi/cros_ec/emem.asl new file mode 100644 index 00000000000..681ca1c9ded --- /dev/null +++ b/arch/x86/include/asm/acpi/cros_ec/emem.asl @@ -0,0 +1,53 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2015 The Chromium OS Authors. All rights reserved. + */ + +/* + * EMEM data may be accessed through port 62/66 or through LPC at 900h. + */ + +Offset (0x00), +TIN0, 8, // Temperature 0 +TIN1, 8, // Temperature 1 +TIN2, 8, // Temperature 2 +TIN3, 8, // Temperature 3 +TIN4, 8, // Temperature 4 +TIN5, 8, // Temperature 5 +TIN6, 8, // Temperature 6 +TIN7, 8, // Temperature 7 +TIN8, 8, // Temperature 8 +TIN9, 8, // Temperature 9 +Offset (0x10), +FAN0, 16, // Fan Speed 0 +Offset (0x24), +BTVR, 8, // Battery structure version +Offset (0x30), +LIDS, 1, // Lid Switch State +PBTN, 1, // Power Button Pressed +WPDI, 1, // Write Protect Disabled +RECK, 1, // Keyboard Initiated Recovery +RECD, 1, // Dedicated Recovery Mode +Offset (0x40), +BTVO, 32, // Battery Present Voltage +BTPR, 32, // Battery Present Rate +BTRA, 32, // Battery Remaining Capacity +ACEX, 1, // AC Present +BTEX, 1, // Battery Present +BFDC, 1, // Battery Discharging +BFCG, 1, // Battery Charging +BFCR, 1, // Battery Level Critical +Offset (0x4d), +BTCN, 8, // Battery Count +BTIX, 8, // Battery index +Offset (0x50), +BTDA, 32, // Battery Design Capacity +BTDV, 32, // Battery Design Voltage +BTDF, 32, // Battery Last Full Charge Capacity +BTCC, 32, // Battery Cycle Count +BMFG, 64, // Battery Manufacturer String +BMOD, 64, // Battery Model String +BSER, 64, // Battery Serial String +BTYP, 64, // Battery Type String +Offset (0x80), +ALS0, 16, // ALS reading 0 in lux diff --git a/arch/x86/include/asm/acpi/cros_ec/keyboard_backlight.asl b/arch/x86/include/asm/acpi/cros_ec/keyboard_backlight.asl new file mode 100644 index 00000000000..e6edd9680c2 --- /dev/null +++ b/arch/x86/include/asm/acpi/cros_ec/keyboard_backlight.asl @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2015 Google Inc. + */ + +Scope (_SB) +{ + /* + * Chrome EC Keyboard Backlight interface + */ + Device (KBLT) + { + Name (_HID, "GOOG0002") + Name (_UID, 1) + + /* Ask EC if we even have a backlight + * Return 0xf (present, enabled, show in UI, functioning) or 0 + * + * With older EC codebases that don't support the Device + * Features bitfield, this reports the keyboard backlight as + * enabled since reads to undefined addresses in EC address + * space return 0xff and so KBLE will be 1. + */ + Method (_STA, 0, NotSerialized) + { + /* If query is unsupported, but this code is compiled + * in, assume the backlight exists physically. + */ + If (LEqual (1, _SB.PCI0.LPCB.EC0.DFUD)) { + Return (0xf) + } + /* If EC reports that backlight exists, trust it */ + If (LEqual (1, _SB.PCI0.LPCB.EC0.KBLE)) { + Return (0xf) + } + /* Otherwise: no device -> disable */ + Return (0) + } + + /* Read current backlight value */ + Method (KBQC, 0, NotSerialized) + { + Return (_SB.PCI0.LPCB.EC0.KBLV) + } + + /* Write new backlight value */ + Method (KBCM, 1, NotSerialized) + { + Store (Arg0, _SB.PCI0.LPCB.EC0.KBLV) + } + } +} diff --git a/arch/x86/include/asm/acpi/cros_ec/pd.asl b/arch/x86/include/asm/acpi/cros_ec/pd.asl new file mode 100644 index 00000000000..e55fde347c2 --- /dev/null +++ b/arch/x86/include/asm/acpi/cros_ec/pd.asl @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2014 Google Inc. + */ + +Device (ECPD) +{ + Name (_HID, "GOOG0003") + Name (_UID, 1) + Name (_DDN, "EC PD Device") + Method(_STA, 0) + { + Return (0xB) + } +} diff --git a/arch/x86/include/asm/acpi/cros_ec/superio.asl b/arch/x86/include/asm/acpi/cros_ec/superio.asl new file mode 100644 index 00000000000..7ddab1e3cf1 --- /dev/null +++ b/arch/x86/include/asm/acpi/cros_ec/superio.asl @@ -0,0 +1,159 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2012 The ChromiumOS Authors. All rights reserved. + */ + +/* + * Chrome OS Embedded Controller interface + * + * Constants that should be defined: + * + * SIO_EC_MEMMAP_ENABLE : Enable EC LPC memory map resources + * EC_LPC_ADDR_MEMMAP : Base address of memory map range + * EC_MEMMAP_SIZE : Size of memory map range + * + * SIO_EC_HOST_ENABLE : Enable EC host command interface resources + * EC_LPC_ADDR_HOST_DATA : EC host command interface data port + * EC_LPC_ADDR_HOST_CMD : EC host command interface command port + * EC_HOST_CMD_REGION0 : EC host command buffer + * EC_HOST_CMD_REGION1 : EC host command buffer + * EC_HOST_CMD_REGION_SIZE : EC host command buffer size + */ + +// Scope is _SB.PCI0.LPCB + +Device (SIO) { + Name (_UID, 0) + Name (_ADR, 0) + +#ifdef SIO_EC_MEMMAP_ENABLE + Device (ECMM) { + Name (_HID, EISAID ("PNP0C02")) + Name (_UID, 4) + + Method (_STA, 0, NotSerialized) { + Return (0x0F) + } + + Name (_CRS, ResourceTemplate () + { + IO (Decode16, EC_LPC_ADDR_MEMMAP, EC_LPC_ADDR_MEMMAP, + 0x08, EC_MEMMAP_SIZE) + }) + + Name (_PRS, ResourceTemplate () + { + IO (Decode16, EC_LPC_ADDR_MEMMAP, EC_LPC_ADDR_MEMMAP, + 0x08, EC_MEMMAP_SIZE) + }) + } +#endif + +#ifdef SIO_EC_HOST_ENABLE + Device (ECUI) { + Name (_HID, EISAID ("PNP0C02")) + Name (_UID, 3) + + Method (_STA, 0, NotSerialized) { + Return (0x0F) + } + + Name (_CRS, ResourceTemplate () + { + IO (Decode16, + EC_LPC_ADDR_HOST_DATA, EC_LPC_ADDR_HOST_DATA, + 0x01, 0x01) + IO (Decode16, + EC_LPC_ADDR_HOST_CMD, EC_LPC_ADDR_HOST_CMD, + 0x01, 0x01) + IO (Decode16, + EC_HOST_CMD_REGION0, EC_HOST_CMD_REGION0, 0x08, + EC_HOST_CMD_REGION_SIZE) + IO (Decode16, + EC_HOST_CMD_REGION1, EC_HOST_CMD_REGION1, 0x08, + EC_HOST_CMD_REGION_SIZE) + }) + + Name (_PRS, ResourceTemplate () + { + StartDependentFn (0, 0) { + IO (Decode16, EC_LPC_ADDR_HOST_DATA, + EC_LPC_ADDR_HOST_DATA, 0x01, 0x01) + IO (Decode16, EC_LPC_ADDR_HOST_CMD, + EC_LPC_ADDR_HOST_CMD, 0x01, 0x01) + IO (Decode16, + EC_HOST_CMD_REGION0, EC_HOST_CMD_REGION0, + 0x08, EC_HOST_CMD_REGION_SIZE) + IO (Decode16, + EC_HOST_CMD_REGION1, EC_HOST_CMD_REGION1, + 0x08, EC_HOST_CMD_REGION_SIZE) + } + EndDependentFn () + }) + } +#endif + +#ifdef SIO_EC_ENABLE_COM1 + Device (COM1) { + Name (_HID, EISAID ("PNP0501")) + Name (_UID, 1) + + Method (_STA, 0, NotSerialized) { + Return (0x0F) + } + + Name (_CRS, ResourceTemplate () + { + IO (Decode16, 0x03F8, 0x3F8, 0x08, 0x08) + IRQNoFlags () {4} + }) + + Name (_PRS, ResourceTemplate () + { + StartDependentFn (0, 0) { + IO (Decode16, 0x03F8, 0x3F8, 0x08, 0x08) + IRQNoFlags () {4} + } + EndDependentFn () + }) + } +#endif +} + +#ifdef SIO_EC_ENABLE_PS2K +Device (PS2K) // Keyboard +{ + Name (_UID, 0) + Name (_HID, "GOOG000A") + Name (_CID, Package() { EISAID("PNP0303"), EISAID("PNP030B") } ) + + Method (_STA, 0, NotSerialized) { + Return (0x0F) + } + + Name (_CRS, ResourceTemplate() + { + IO (Decode16, 0x60, 0x60, 0x01, 0x01) + IO (Decode16, 0x64, 0x64, 0x01, 0x01) +#ifdef SIO_EC_PS2K_IRQ + SIO_EC_PS2K_IRQ +#else + IRQ (Edge, ActiveHigh, Exclusive) {1} +#endif + }) + + Name (_PRS, ResourceTemplate() + { + StartDependentFn (0, 0) { + IO (Decode16, 0x60, 0x60, 0x01, 0x01) + IO (Decode16, 0x64, 0x64, 0x01, 0x01) +#ifdef SIO_EC_PS2K_IRQ + SIO_EC_PS2K_IRQ +#else + IRQ (Edge, ActiveHigh, Exclusive) {1} +#endif + } + EndDependentFn () + }) +} +#endif diff --git a/arch/x86/include/asm/acpi/cros_ec/tbmc.asl b/arch/x86/include/asm/acpi/cros_ec/tbmc.asl new file mode 100644 index 00000000000..bfe38d668ed --- /dev/null +++ b/arch/x86/include/asm/acpi/cros_ec/tbmc.asl @@ -0,0 +1,23 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2017 Google Inc. + */ + +Device (TBMC) +{ + Name (_HID, "GOOG0006") + Name (_UID, 1) + Name (_DDN, "Tablet Motion Control") + Method (TBMC) + { + If (LEqual (^^RCTM, One)) { + Return (0x1) + } Else { + Return (0x0) + } + } + Method(_STA, 0) + { + Return (0xB) + } +}
Add common x86 ASL files, taken from coreboot.
arch/x86/include/asm/acpi/chromeos.asl | 108 +++++++++++++++++ arch/x86/include/asm/acpi/cpu.asl | 25 ++++ arch/x86/include/asm/acpi/cros_gnvs.asl | 29 +++++ arch/x86/include/asm/acpi/lpc.asl | 141 ++++++++++++++++++++++ arch/x86/include/asm/acpi/pci_osc.asl | 21 ++++ arch/x86/include/asm/acpi/pcr.asl | 80 ++++++++++++ arch/x86/include/asm/acpi/ramoops.asl | 32 +++++ arch/x86/include/asm/acpi/sleepstates.asl | 12 +- 8 files changed, 443 insertions(+), 5 deletions(-) create mode 100644 arch/x86/include/asm/acpi/chromeos.asl create mode 100644 arch/x86/include/asm/acpi/cpu.asl create mode 100644 arch/x86/include/asm/acpi/cros_gnvs.asl create mode 100644 arch/x86/include/asm/acpi/lpc.asl create mode 100644 arch/x86/include/asm/acpi/pci_osc.asl create mode 100644 arch/x86/include/asm/acpi/pcr.asl create mode 100644 arch/x86/include/asm/acpi/ramoops.asl
diff --git a/arch/x86/include/asm/acpi/chromeos.asl b/arch/x86/include/asm/acpi/chromeos.asl new file mode 100644 index 00000000000..2a0fd33265d --- /dev/null +++ b/arch/x86/include/asm/acpi/chromeos.asl @@ -0,0 +1,108 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2011 The ChromiumOS Authors. All rights reserved. + */ + +#ifdef CONFIG_CHROMEOS + +#define CONFIG_VBOOT_VBNV_OFFSET 0x26 + +#include <asm/acpi/vbnv_layout.h> + +/* GPIO package generated at run time. */ +External (OIPG) + +Device (CRHW) +{ + Name(_HID, EISAID("GGL0001")) + + Method(_STA, 0, Serialized) + { + Return (0xb) + } + + Method(CHSW, 0, Serialized) + { + Name (WSHC, Package() { VBT3 }) + Return (WSHC) + } + + Method(FWID, 0, Serialized) + { + Name (DIW1, "") + ToString(VBT5, 63, DIW1) + Name (DIWF, Package() { DIW1 }) + Return(DIWF) + } + + Method(FRID, 0, Serialized) + { + Name (DIR1, "") + ToString(VBT6, 63, DIR1) + Name (DIRF, Package() { DIR1 }) + Return (DIRF) + } + + Method(HWID, 0, Serialized) + { + Name (DIW0, "") + ToString(VBT4, 255, DIW0) + Name (DIWH, Package() { DIW0 }) + Return (DIWH) + } + + Method(BINF, 0, Serialized) + { + Name (FNIB, Package() { VBT0, VBT1, VBT2, VBT7, VBT8 }) + Return (FNIB) + } + + Method(GPIO, 0, Serialized) + { + Return (OIPG) + + } + + Method(VBNV, 0, Serialized) + { + Name(VNBV, Package() { + // See src/vendorcode/google/chromeos/Kconfig + // for the definition of these: + CONFIG_VBOOT_VBNV_OFFSET, + VBOOT_VBNV_BLOCK_SIZE + }) + Return(VNBV) + } + + Method(VDAT, 0, Serialized) + { + Name(TAD0,"") + ToBuffer(CHVD, TAD0) + Name (TADV, Package() { TAD0 }) + Return (TADV) + } + + Method(FMAP, 0, Serialized) + { + Name(PAMF, Package() { VBT9 }) + Return(PAMF) + } + + Method(MECK, 0, Serialized) + { + Name(HASH, Package() { MEHH }) + Return(HASH) + } + + Method(MLST, 0, Serialized) + { + Name(TSLM, Package() { "CHSW", "FWID", "HWID", "FRID", "BINF", + "GPIO", "VBNV", "VDAT", "FMAP", "MECK" + }) + Return (TSLM) + } +} + +#include "ramoops.asl" + +#endif diff --git a/arch/x86/include/asm/acpi/cpu.asl b/arch/x86/include/asm/acpi/cpu.asl new file mode 100644 index 00000000000..b20b3572f2b --- /dev/null +++ b/arch/x86/include/asm/acpi/cpu.asl @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2019 Google LLC + */ + +/* These come from the dynamically created CPU SSDT */ +External (_PR.CNOT, MethodObj) + +/* Notify OS to re-read CPU tables */ +Method (PNOT) +{ + _PR.CNOT (0x81) +} + +/* Notify OS to re-read CPU _PPC limit */ +Method (PPCN) +{ + _PR.CNOT (0x80) +} + +/* Notify OS to re-read Throttle Limit tables */ +Method (TNOT) +{ + _PR.CNOT (0x82) +} diff --git a/arch/x86/include/asm/acpi/cros_gnvs.asl b/arch/x86/include/asm/acpi/cros_gnvs.asl new file mode 100644 index 00000000000..c20b64565e0 --- /dev/null +++ b/arch/x86/include/asm/acpi/cros_gnvs.asl @@ -0,0 +1,29 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2019 Google LLC + */ + +/* This is the ChromeOS specific ACPI information needed by + * the mainboard's chromeos.asl + */ + +VBT0, 32, // 0x000 - Boot Reason +VBT1, 32, // 0x004 - Active Main Firmware +VBT2, 32, // 0x008 - Active EC Firmware +VBT3, 16, // 0x00c - CHSW +VBT4, 2048, // 0x00e - HWID +VBT5, 512, // 0x10e - FWID +VBT6, 512, // 0x14e - FRID +VBT7, 32, // 0x18e - active main firmware type +VBT8, 32, // 0x192 - Recovery Reason +VBT9, 32, // 0x196 - FMAP base address +CHVD, 24576, // 0x19a - VDAT space filled by verified boot +VBTA, 32, // 0xd9a - pointer to smbios FWID +MEHH, 256, // 0xd9e - Management Engine Hash +RMOB, 32, // 0xdbe - RAM oops base address +RMOL, 32, // 0xdc2 - RAM oops length +ROVP, 32, // 0xdc6 - pointer to RO_VPD +ROVL, 32, // 0xdca - size of RO_VPD +RWVP, 32, // 0xdce - pointer to RW_VPD +RWVL, 32, // 0xdd2 - size of RW_VPD + // 0xdd6 diff --git a/arch/x86/include/asm/acpi/lpc.asl b/arch/x86/include/asm/acpi/lpc.asl new file mode 100644 index 00000000000..18cc78b3e14 --- /dev/null +++ b/arch/x86/include/asm/acpi/lpc.asl @@ -0,0 +1,141 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2007-2009 coresystems GmbH + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2015 Intel Corporation. + */ + +/* Intel LPC/eSPI Bus Device - 0:1f.0 */ +#include <asm/arch/iomap.h> + +Device (LPCB) +{ + Name (_ADR, 0x001f0000) + Name (_DDN, "LPC Bus Device") + + /* DMA Controller */ + Device (DMAC) + { + Name (_HID, EISAID("PNP0200")) + Name (_CRS, ResourceTemplate() + { + IO (Decode16, 0x00, 0x00, 0x01, 0x20) + IO (Decode16, 0x81, 0x81, 0x01, 0x11) + IO (Decode16, 0x93, 0x93, 0x01, 0x0d) + IO (Decode16, 0xc0, 0xc0, 0x01, 0x20) + DMA (Compatibility, NotBusMaster, Transfer8_16) { 4 } + }) + } + + /* Firmware Hub */ + Device (FWH) + { + Name (_HID, EISAID ("INT0800")) + Name (_DDN, "Firmware Hub") + Name (_CRS, ResourceTemplate () + { + Memory32Fixed (ReadOnly, 0xff000000, 0x01000000) + }) + } + + /* High Precision Event Timer */ + Device (HPET) + { + Name (_HID, EISAID ("PNP0103")) + Name (_CID, 0x010CD041) + Name (_DDN, "High Precision Event Timer") + Name (_CRS, ResourceTemplate () + { + Memory32Fixed (ReadWrite, HPET_BASE_ADDRESS, 0x400) + }) + Method (_STA, 0) + { + Return (0xF) + } + } + + /* FPU */ + Device(MATH) + { + Name (_HID, EISAID("PNP0C04")) + Name (_CRS, ResourceTemplate() + { + IO (Decode16, 0xf0, 0xf0, 0x01, 0x01) + IRQNoFlags() { 13 } + }) + } + + /* AT Interrupt Controller */ + Device (PIC) + { + Name (_HID, EISAID ("PNP0000")) + Name (_DDN, "8259 Interrupt Controller") + Name (_CRS, ResourceTemplate() + { + IO (Decode16, 0x20, 0x20, 0x01, 0x02) + IO (Decode16, 0x24, 0x24, 0x01, 0x02) + IO (Decode16, 0x28, 0x28, 0x01, 0x02) + IO (Decode16, 0x2c, 0x2c, 0x01, 0x02) + IO (Decode16, 0x30, 0x30, 0x01, 0x02) + IO (Decode16, 0x34, 0x34, 0x01, 0x02) + IO (Decode16, 0x38, 0x38, 0x01, 0x02) + IO (Decode16, 0x3c, 0x3c, 0x01, 0x02) + IO (Decode16, 0xa0, 0xa0, 0x01, 0x02) + IO (Decode16, 0xa4, 0xa4, 0x01, 0x02) + IO (Decode16, 0xa8, 0xa8, 0x01, 0x02) + IO (Decode16, 0xac, 0xac, 0x01, 0x02) + IO (Decode16, 0xb0, 0xb0, 0x01, 0x02) + IO (Decode16, 0xb4, 0xb4, 0x01, 0x02) + IO (Decode16, 0xb8, 0xb8, 0x01, 0x02) + IO (Decode16, 0xbc, 0xbc, 0x01, 0x02) + IO (Decode16, 0x4d0, 0x4d0, 0x01, 0x02) + IRQNoFlags () { 2 } + }) + } + + /* LPC device: Resource consumption */ + Device (LDRC) + { + Name (_HID, EISAID ("PNP0C02")) + Name (_UID, 2) + Name (_DDN, "Legacy Device Resources") + Name (_CRS, ResourceTemplate () + { + IO (Decode16, 0x2e, 0x2e, 0x1, 0x02) // First SuperIO + IO (Decode16, 0x4e, 0x4e, 0x1, 0x02) // Second SuperIO + IO (Decode16, 0x61, 0x61, 0x1, 0x01) // NMI Status + IO (Decode16, 0x63, 0x63, 0x1, 0x01) // CPU Reserved + IO (Decode16, 0x65, 0x65, 0x1, 0x01) // CPU Reserved + IO (Decode16, 0x67, 0x67, 0x1, 0x01) // CPU Reserved + IO (Decode16, 0x80, 0x80, 0x1, 0x01) // Port 80 Post + IO (Decode16, 0x92, 0x92, 0x1, 0x01) // CPU Reserved + IO (Decode16, 0xb2, 0xb2, 0x1, 0x02) // SWSMI + IO (Decode16, ACPI_BASE_ADDRESS, ACPI_BASE_ADDRESS, + 0x1, 0xff) + }) + } + + /* Real Time Clock Device */ + Device (RTC) + { + Name (_HID, EISAID ("PNP0B00")) + Name (_DDN, "Real Time Clock") + Name (_CRS, ResourceTemplate () + { + IO (Decode16, 0x70, 0x70, 1, 8) + }) + } + + /* Timer */ + Device (TIMR) + { + Name (_HID, EISAID ("PNP0100")) + Name (_DDN, "8254 Timer") + Name (_CRS, ResourceTemplate () + { + IO (Decode16, 0x40, 0x40, 0x01, 0x04) + IO (Decode16, 0x50, 0x50, 0x10, 0x04) + IRQNoFlags () {0} + }) + } +} diff --git a/arch/x86/include/asm/acpi/pci_osc.asl b/arch/x86/include/asm/acpi/pci_osc.asl new file mode 100644 index 00000000000..864556fa831 --- /dev/null +++ b/arch/x86/include/asm/acpi/pci_osc.asl @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Intel Corp. + */ + +#define PCI_OSC_UUID "33DB4D5B-1FF7-401C-9657-7441C03DD766" + +Scope (_SB.PCI0) { + Method (_OSC, 4) { + /* Check for proper GUID */ + If (LEqual (Arg0, ToUUID (PCI_OSC_UUID))) { + /* Let OS control everything */ + Return (Arg3) + } Else { + /* Unrecognized UUID */ + CreateDWordField (Arg3, 0, CDW1) + Or (CDW1, 4, CDW1) + Return (Arg3) + } + } +} diff --git a/arch/x86/include/asm/acpi/pcr.asl b/arch/x86/include/asm/acpi/pcr.asl new file mode 100644 index 00000000000..f66737b89c1 --- /dev/null +++ b/arch/x86/include/asm/acpi/pcr.asl @@ -0,0 +1,80 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2015 Google Inc. + * Copyright (C) 2018 Intel Corporation. + */ + +#include <intelblocks/pcr.h> + +/* + * Calculate PCR register base at specified PID + * Arg0 - PCR Port ID + */ +Method (PCRB, 1, NotSerialized) +{ + Return (Add (IOMAP_P2SB_BAR, + ShiftLeft (Arg0, PCR_PORTID_SHIFT))) +} + +/* + * Read a PCR register at specified PID and offset + * Arg0 - PCR Port ID + * Arg1 - Register Offset + */ +Method (PCRR, 2, Serialized) +{ + OperationRegion (PCRD, SystemMemory, Add (PCRB (Arg0), Arg1), 4) + Field (PCRD, DWordAcc, NoLock, Preserve) + { + DATA, 32 + } + Return (DATA) +} + +/* + * AND a value with PCR register at specified PID and offset + * Arg0 - PCR Port ID + * Arg1 - Register Offset + * Arg2 - Value to AND + */ +Method (PCRA, 3, Serialized) +{ + OperationRegion (PCRD, SystemMemory, Add (PCRB (Arg0), Arg1), 4) + Field (PCRD, DWordAcc, NoLock, Preserve) + { + DATA, 32 + } + And (DATA, Arg2, DATA) + + /* + * After every write one needs to read an innocuous register + * to ensure the writes are completed for certain ports. This is done + * for all ports so that the callers don't need the per-port knowledge + * for each transaction. + */ + PCRR (Arg0, Arg1) +} + +/* + * OR a value with PCR register at specified PID and offset + * Arg0 - PCR Port ID + * Arg1 - Register Offset + * Arg2 - Value to OR + */ +Method (PCRO, 3, Serialized) +{ + OperationRegion (PCRD, SystemMemory, Add (PCRB (Arg0), Arg1), 4) + Field (PCRD, DWordAcc, NoLock, Preserve) + { + DATA, 32 + } + Or (DATA, Arg2, DATA) + + /* + * After every write one needs to read an innocuous register + * to ensure the writes are completed for certain ports. This is done + * for all ports so that the callers don't need the per-port knowledge + * for each transaction. + */ + PCRR (Arg0, Arg1) +} diff --git a/arch/x86/include/asm/acpi/ramoops.asl b/arch/x86/include/asm/acpi/ramoops.asl new file mode 100644 index 00000000000..55939e1aa33 --- /dev/null +++ b/arch/x86/include/asm/acpi/ramoops.asl @@ -0,0 +1,32 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2014 Google Inc. + */ + +Scope (_SB) +{ + Device(RMOP) + { + Name (_HID, "GOOG9999") + Name (_CID, "GOOG9999") + Name (_UID, 1) + + Name (RBUF, ResourceTemplate() + { + Memory32Fixed (ReadWrite, 0, 0, MRES) + }) + + Method (_CRS) + { + CreateDwordField (^RBUF, ^MRES._BAS, RBAS) + CreateDwordField (^RBUF, ^MRES._LEN, RLEN) + Store (\RMOB, RBAS) + Store (\RMOL, RLEN) + Return (^RBUF) + } + Method(_STA, 0) + { + Return (0xB) + } + } +} diff --git a/arch/x86/include/asm/acpi/sleepstates.asl b/arch/x86/include/asm/acpi/sleepstates.asl index 32e16a2c2f5..31aa69a5704 100644 --- a/arch/x86/include/asm/acpi/sleepstates.asl +++ b/arch/x86/include/asm/acpi/sleepstates.asl @@ -6,9 +6,11 @@ * Modified from coreboot src/soc/intel/baytrail/acpi/sleepstates.asl */
-Name(_S0, Package() {0x0, 0x0, 0x0, 0x0}) -#ifdef CONFIG_HAVE_ACPI_RESUME -Name(_S3, Package() {0x5, 0x0, 0x0, 0x0}) +Name(_S0, Package(){0x0,0x0,0x0,0x0}) +#if !IS_ENABLED(CONFIG_HAVE_ACPI_RESUME) +Name(_S1, Package(){0x1,0x0,0x0,0x0}) +#else +Name(_S3, Package(){0x5,0x0,0x0,0x0}) #endif -Name(_S4, Package() {0x6, 0x0, 0x0, 0x0}) -Name(_S5, Package() {0x7, 0x0, 0x0, 0x0}) +Name(_S4, Package(){0x6,0x0,0x0,0x0}) +Name(_S5, Package(){0x7,0x0,0x0,0x0})
Add Apollo Lake ASL files, taken from coreboot.
.../include/asm/arch-apollolake/acpi/dptf.asl | 35 ++++ .../asm/arch-apollolake/acpi/globalnvs.asl | 41 ++++ .../include/asm/arch-apollolake/acpi/gpio.asl | 191 ++++++++++++++++++ .../asm/arch-apollolake/acpi/gpiolib.asl | 109 ++++++++++ .../include/asm/arch-apollolake/acpi/lpss.asl | 105 ++++++++++ .../asm/arch-apollolake/acpi/northbridge.asl | 120 +++++++++++ .../asm/arch-apollolake/acpi/pch_hda.asl | 77 +++++++ .../asm/arch-apollolake/acpi/pci_irqs.asl | 52 +++++ .../include/asm/arch-apollolake/acpi/pcie.asl | 22 ++ .../asm/arch-apollolake/acpi/pcie_port.asl | 113 +++++++++++ .../asm/arch-apollolake/acpi/platform.asl | 10 + .../asm/arch-apollolake/acpi/pmc_ipc.asl | 49 +++++ .../include/asm/arch-apollolake/acpi/scs.asl | 173 ++++++++++++++++ .../asm/arch-apollolake/acpi/soc_int.asl | 50 +++++ .../asm/arch-apollolake/acpi/southbridge.asl | 34 ++++ .../include/asm/arch-apollolake/acpi/xhci.asl | 33 +++ .../arch-apollolake/acpi/xhci_apl_ports.asl | 23 +++ .../arch-apollolake/acpi/xhci_glk_ports.asl | 24 +++ 18 files changed, 1261 insertions(+) create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/dptf.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/globalnvs.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/gpio.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/gpiolib.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/lpss.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/northbridge.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/pch_hda.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/pci_irqs.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/pcie.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/pcie_port.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/platform.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/pmc_ipc.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/scs.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/soc_int.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/southbridge.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/xhci.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/xhci_apl_ports.asl create mode 100644 arch/x86/include/asm/arch-apollolake/acpi/xhci_glk_ports.asl
diff --git a/arch/x86/include/asm/arch-apollolake/acpi/dptf.asl b/arch/x86/include/asm/arch-apollolake/acpi/dptf.asl new file mode 100644 index 00000000000..4c50bb45c0f --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/dptf.asl @@ -0,0 +1,35 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Intel Corporation. + */ + +#define DPTF_CPU_DEVICE TCPU +#define DPTF_CPU_ADDR 0x00000001 + +#ifndef DPTF_CPU_PASSIVE +#define DPTF_CPU_PASSIVE 80 +#endif + +#ifndef DPTF_CPU_CRITICAL +#define DPTF_CPU_CRITICAL 90 +#endif + +#ifndef DPTF_CPU_ACTIVE_AC0 +#define DPTF_CPU_ACTIVE_AC0 90 +#endif + +#ifndef DPTF_CPU_ACTIVE_AC1 +#define DPTF_CPU_ACTIVE_AC1 80 +#endif + +#ifndef DPTF_CPU_ACTIVE_AC2 +#define DPTF_CPU_ACTIVE_AC2 70 +#endif + +#ifndef DPTF_CPU_ACTIVE_AC3 +#define DPTF_CPU_ACTIVE_AC3 60 +#endif + +#ifndef DPTF_CPU_ACTIVE_AC4 +#define DPTF_CPU_ACTIVE_AC4 50 +#endif diff --git a/arch/x86/include/asm/arch-apollolake/acpi/globalnvs.asl b/arch/x86/include/asm/arch-apollolake/acpi/globalnvs.asl new file mode 100644 index 00000000000..7854f7e1c5d --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/globalnvs.asl @@ -0,0 +1,41 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Intel Corp. + * (Written by Alexandru Gagniuc alexandrux.gagniuc@intel.com for Intel Corp.) + */ + +/* + * NOTE: The layout of the GNVS structure below must match the layout in + * soc/intel/apollolake/include/soc/nvs.h !!! + * + */ + +External (NVSA) + +OperationRegion (GNVS, SystemMemory, NVSA, ACPI_GNVS_SIZE) +Field (GNVS, ByteAcc, NoLock, Preserve) +{ + /* Miscellaneous */ + Offset (0x00), + PCNT, 8, // 0x00 - Processor Count + PPCM, 8, // 0x01 - Max PPC State + LIDS, 8, // 0x02 - LID State + PWRS, 8, // 0x03 - AC Power State + DPTE, 8, // 0x04 - Enable DPTF + CBMC, 32, // 0x05 - 0x08 - coreboot Memory Console + PM1I, 64, // 0x09 - 0x10 - System Wake Source - PM1 Index + GPEI, 64, // 0x11 - 0x18 - GPE Wake Source + NHLA, 64, // 0x19 - 0x20 - NHLT Address + NHLL, 32, // 0x21 - 0x24 - NHLT Length + PRT0, 32, // 0x25 - 0x28 - PERST_0 Address + SCDP, 8, // 0x29 - SD_CD GPIO portid + SCDO, 8, // 0x2A - GPIO pad offset relative to the community + UIOR, 8, // 0x2B - UART debug controller init on S3 resume + EPCS, 8, // 0x2C - SGX Enabled status + EMNA, 64, // 0x2D - 0x34 EPC base address + ELNG, 64, // 0x35 - 0x3C EPC Length + + /* ChromeOS stuff (0x100 -> 0xfff, size 0xeff) */ + Offset (0x100), + #include <asm/acpi/cros_gnvs.asl> +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi/gpio.asl b/arch/x86/include/asm/arch-apollolake/acpi/gpio.asl new file mode 100644 index 00000000000..b0f892166b5 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/gpio.asl @@ -0,0 +1,191 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Intel Corp. + * (Written by Lance Zhao lijian.zhao@intel.com for Intel Corp.) + */ +#include <asm/arch/gpio.h> +#include <asm/intel_pinctrl_defs.h> +// #include <intelblocks/pcr.h> +// #include <soc/pcr_ids.h> +#include <asm/arch/iomap.h> +#include <p2sb.h> +#include "gpiolib.asl" + +scope (_SB) { + + Device (GPO0) + { + Name (_HID, GPIO_COMM_NAME) + Name (_CID, GPIO_COMM_NAME) + Name (_DDN, GPIO_COMM_0_DESC) + Name (_UID, 1) + + Name (RBUF, ResourceTemplate () + { + Memory32Fixed (ReadWrite, 0, 0x4000, RMEM) + Interrupt (ResourceConsumer, Level, ActiveLow, Shared, , , ) + { + GPIO_BANK_INT + } + }) + + Method (_CRS, 0x0, NotSerialized) + { + CreateDwordField (^RBUF, ^RMEM._BAS, RBAS) + ShiftLeft (GPIO_COMM0_PID, PCR_PORTID_SHIFT, Local0) + Or (IOMAP_P2SB_BAR, Local0, RBAS) + Return (^RBUF) + } + + Method (_STA, 0x0, NotSerialized) + { + Return(0xf) + } + } + + Device (GPO1) + { + Name (_HID, GPIO_COMM_NAME) + Name (_CID, GPIO_COMM_NAME) + Name (_DDN, GPIO_COMM_1_DESC) + Name (_UID, 2) + + Name (RBUF, ResourceTemplate () + { + Memory32Fixed (ReadWrite, 0, 0x4000, RMEM) + Interrupt (ResourceConsumer, Level, ActiveLow, Shared, , , ) + { + GPIO_BANK_INT + } + }) + + Method (_CRS, 0x0, NotSerialized) + { + CreateDwordField (^RBUF, ^RMEM._BAS, RBAS) + ShiftLeft (GPIO_COMM1_PID, PCR_PORTID_SHIFT, Local0) + Or (IOMAP_P2SB_BAR, Local0, RBAS) + Return (^RBUF) + } + + Method (_STA, 0x0, NotSerialized) + { + Return(0xf) + } + } + + Device (GPO2) + { + Name (_HID, GPIO_COMM_NAME) + Name (_CID, GPIO_COMM_NAME) + Name (_DDN, GPIO_COMM_2_DESC) + Name (_UID, 3) + + Name (RBUF, ResourceTemplate () + { + Memory32Fixed (ReadWrite, 0, 0x4000, RMEM) + Interrupt (ResourceConsumer, Level, ActiveLow, Shared, , , ) + { + GPIO_BANK_INT + } + }) + + Method (_CRS, 0x0, NotSerialized) + { + CreateDwordField (^RBUF, ^RMEM._BAS, RBAS) + ShiftLeft (GPIO_COMM2_PID, PCR_PORTID_SHIFT, Local0) + Or (IOMAP_P2SB_BAR, Local0, RBAS) + Return (^RBUF) + } + + Method (_STA, 0x0, NotSerialized) + { + Return(0xf) + } + } + + Device (GPO3) + { + Name (_HID, GPIO_COMM_NAME) + Name (_CID, GPIO_COMM_NAME) + Name (_DDN, GPIO_COMM_3_DESC) + Name (_UID, 4) + + Name (RBUF, ResourceTemplate () + { + Memory32Fixed (ReadWrite, 0, 0x4000, RMEM) + Interrupt (ResourceConsumer, Level, ActiveLow, Shared, , , ) + { + GPIO_BANK_INT + } + }) + + Method (_CRS, 0x0, NotSerialized) + { + CreateDwordField (^RBUF, ^RMEM._BAS, RBAS) + ShiftLeft (GPIO_COMM3_PID, PCR_PORTID_SHIFT, Local0) + Or (IOMAP_P2SB_BAR, Local0, RBAS) + Return (^RBUF) + } + + Method (_STA, 0x0, NotSerialized) + { + Return(0xf) + } + } + + Scope(_SB.PCI0) { + /* PERST Assertion + * Note: PERST is Active High + */ + Method (PRAS, 0x1, Serialized) + { + /* + * Assert PERST + * local1 - to toggle Tx pin of Dw0 + * local2 - Address of PERST + */ + Store (Arg0, Local2) + Store (_SB.GPC0 (Local2), Local1) + Or (Local1, PAD_CFG0_TX_STATE, Local1) + _SB.SPC0 (Local2, Local1) + } + + /* PERST DE-Assertion */ + Method (PRDA, 0x1, Serialized) + { + /* + * De-assert PERST + * local1 - to toggle Tx pin of Dw0 + * local2 - Address of PERST + */ + Store (Arg0, Local2) + Store (_SB.GPC0 (Local2), Local1) + And (Local1, Not (PAD_CFG0_TX_STATE), Local1) + _SB.SPC0 (Local2, Local1) + } + } + + /* + * Sleep button device ASL code. We are using this device to + * add the _PRW method for a dummy wake event to kernel so that + * before going to sleep kernel does not clear bit 15 in ACPI + * gpe0a enable register which is actually the GPIO_TIER1_SCI_EN bit. + */ + Device (SLP) + { + Name (_HID, EisaId ("PNP0C0E")) + + Name (_PRW, Package() { GPE0A_GPIO_TIER1_SCI_STS, 0x3 }) + } +} + +Scope(_GPE) +{ + /* + * Dummy method for the Tier 1 GPIO SCI enable bit. When kernel reads + * _L0F in scope GPE it sets bit for gpio_tier1_sci_en in ACPI enable + * register at 0x430. For APL ACPI enable register DW0 i.e., ACPI + * GPE0a_EN at 0x430 is reserved. + */ + Method(_L0F, 0) {} +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi/gpiolib.asl b/arch/x86/include/asm/arch-apollolake/acpi/gpiolib.asl new file mode 100644 index 00000000000..0eb808dc195 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/gpiolib.asl @@ -0,0 +1,109 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Intel Corporation. + */ + +Scope (_SB) +{ + /* Get Pad Configuration DW0 register value */ + Method (GPC0, 0x1, Serialized) + { + /* Arg0 - GPIO DW0 address */ + Store (Arg0, Local0) + OperationRegion (PDW0, SystemMemory, Local0, 4) + Field (PDW0, AnyAcc, NoLock, Preserve) { + TEMP, 32 + } + Return (TEMP) + } + + /* Set Pad Configuration DW0 register value */ + Method (SPC0, 0x2, Serialized) + { + /* Arg0 - GPIO DW0 address */ + /* Arg1 - Value for DW0 register */ + Store (Arg0, Local0) + OperationRegion (PDW0, SystemMemory, Local0, 4) + Field (PDW0, AnyAcc, NoLock, Preserve) { + TEMP,32 + } + Store (Arg1, TEMP) + } + + /* Get Pad Configuration DW1 register value */ + Method (GPC1, 0x1, Serialized) + { + /* Arg0 - GPIO DW0 address */ + Store (Add (Arg0, 0x4), Local0) + OperationRegion (PDW1, SystemMemory, Local0, 4) + Field (PDW1, AnyAcc, NoLock, Preserve) { + TEMP, 32 + } + Return (TEMP) + } + + /* Set Pad Configuration DW1 register value */ + Method (SPC1, 0x2, Serialized) + { + /* Arg0 - GPIO DW0 address */ + /* Arg1 - Value for DW1 register */ + Store (Add (Arg0, 0x4), Local0) + OperationRegion (PDW1, SystemMemory, Local0, 4) + Field(PDW1, AnyAcc, NoLock, Preserve) { + TEMP,32 + } + Store (Arg1, TEMP) + } + + /* Get DW0 address of a given pad */ + Method (GDW0, 0x2, Serialized) + { + /* Arg0 - GPIO portid */ + /* Arg1 - GPIO pad offset relative to the community */ + Store (0, Local1) + Or( Or (ShiftLeft (Arg0, 16), IOMAP_P2SB_BAR), + Local1, Local1) + Or( Add (PAD_CFG_BASE, Multiply (Arg1, Multiply ( + GPIO_NUM_PAD_CFG_REGS, 4))), Local1, Local1) + Return (Local1) + } + + /* Calculate HOSTSW_REG address */ + Method (CHSA, 0x1, Serialized) + { + /* Arg0 - GPIO pad offset relative to the community */ + Add (HOSTSW_OWN_REG_0, Multiply (Divide (Arg0, 32), 4), Local1) + Return (Local1) + } + + /* Get Host ownership register of GPIO Community */ + Method (GHO, 0x2, Serialized) + { + /* Arg0 - GPIO portid */ + /* Arg1 - GPIO pad offset relative to the community */ + Store (CHSA (Arg1), Local1) + + OperationRegion (SHO0, SystemMemory, Or ( Or + (IOMAP_P2SB_BAR, ShiftLeft (Arg0, 16)), Local1), 4) + Field (SHO0, AnyAcc, NoLock, Preserve) { + TEMP, 32 + } + Return (TEMP) + } + + /* Set Host ownership register of GPIO Community */ + Method (SHO, 0x3, Serialized) + { + /* Arg0 - GPIO portid */ + /* Arg1 - GPIO pad offset relative to the community */ + /* Arg2 - Value for Host own register */ + Store (CHSA (Arg1), Local1) + + OperationRegion (SHO0, SystemMemory, Or ( Or + (IOMAP_P2SB_BAR, ShiftLeft (Arg0, 16)), Local1), 4) + Field (SHO0, AnyAcc, NoLock, Preserve) { + TEMP, 32 + } + Store (Arg2, TEMP) + } +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi/lpss.asl b/arch/x86/include/asm/arch-apollolake/acpi/lpss.asl new file mode 100644 index 00000000000..bc3eabba603 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/lpss.asl @@ -0,0 +1,105 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Intel Corp. + * (Written by Lance Zhao lijian.zhao@intel.com for Intel Corp.) + */ + +scope (_SB.PCI0) { + + /* LPIO1 PWM */ + Device(PWM) { + Name (_ADR, 0x001A0000) + Name (_DDN, "Intel(R) PWM Controller") + } + + /* LPIO1 HS-UART #1 */ + Device(URT1) { + Name (_ADR, 0x00180000) + Name (_DDN, "Intel(R) HS-UART Controller #1") + } + + /* LPIO1 HS-UART #2 */ + Device(URT2) { + Name (_ADR, 0x00180001) + Name (_DDN, "Intel(R) HS-UART Controller #2") + } + + /* LPIO1 HS-UART #3 */ + Device(URT3) { + Name (_ADR, 0x00180002) + Name (_DDN, "Intel(R) HS-UART Controller #3") + } + + /* LPIO1 HS-UART #4 */ + Device(URT4) { + Name (_ADR, 0x00180003) + Name (_DDN, "Intel(R) HS-UART Controller #4") + } + + /* LPIO1 SPI */ + Device(SPI1) { + Name (_ADR, 0x00190000) + Name (_DDN, "Intel(R) SPI Controller #1") + } + + /* LPIO1 SPI #2 */ + Device(SPI2) { + Name (_ADR, 0x00190001) + Name (_DDN, "Intel(R) SPI Controller #2") + } + + /* LPIO1 SPI #3 */ + Device(SPI3) { + Name (_ADR, 0x00190002) + Name (_DDN, "Intel(R) SPI Controller #3") + } + + + /* LPIO2 I2C #0 */ + Device(I2C0) { + Name (_ADR, 0x00160000) + Name (_DDN, "Intel(R) I2C Controller #0") + } + + /* LPIO2 I2C #1 */ + Device(I2C1) { + Name (_ADR, 0x00160001) + Name (_DDN, "Intel(R) I2C Controller #1") + } + + /* LPIO2 I2C #2 */ + Device(I2C2) { + Name (_ADR, 0x00160002) + Name (_DDN, "Intel(R) I2C Controller #2") + } + + /* LPIO2 I2C #3 */ + Device(I2C3) { + Name (_ADR, 0x00160003) + Name (_DDN, "Intel(R) I2C Controller #3") + } + + /* LPIO2 I2C #4 */ + Device(I2C4) { + Name (_ADR, 0x00170000) + Name (_DDN, "Intel(R) I2C Controller #4") + } + + /* LPIO2 I2C #5 */ + Device(I2C5) { + Name (_ADR, 0x00170001) + Name (_DDN, "Intel(R) I2C Controller #5") + } + + /* LPIO2 I2C #6 */ + Device(I2C6) { + Name (_ADR, 0x00170002) + Name (_DDN, "Intel(R) I2C Controller #6") + } + + /* LPIO2 I2C #7 */ + Device(I2C7) { + Name (_ADR, 0x00170003) + Name (_DDN, "Intel(R) I2C Controller #7") + } +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi/northbridge.asl b/arch/x86/include/asm/arch-apollolake/acpi/northbridge.asl new file mode 100644 index 00000000000..ff5657abd06 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/northbridge.asl @@ -0,0 +1,120 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Intel Corp. + * (Written by Lance Zhao lijian.zhao@intel.com for Intel Corp.) + */ + + Name(_HID, EISAID("PNP0A08")) /* PCIe */ + Name(_CID, EISAID("PNP0A03")) /* PCI */ + Name(_BBN, 0) + +Device (MCHC) +{ + Name (_ADR, 0x00000000) /*Dev0 Func0 */ + + OperationRegion (MCHP, PCI_Config, 0x00, 0x100) + Field (MCHP, DWordAcc, NoLock, Preserve) + { + Offset(0x60), + MCNF, 32, /* PCI MMCONF base */ + Offset (0xA8), + TUUD, 64, /* Top of Upper Used Memory */ + Offset(0xB4), + BGSM, 32, /* Base of Graphics Stolen Memory */ + Offset(0xBC), + TLUD, 32, /* Top of Low Useable DRAM */ + } +} +Name (MCRS, ResourceTemplate() +{ + /* Bus Numbers */ + WordBusNumber (ResourceProducer, MinFixed, MaxFixed, PosDecode, + 0x0000, 0x0000, 0x00ff, 0x0000, 0x0100,,,) + + /* IO Region 0 */ + DWordIO (ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, + 0x0000, 0x0000, 0x0cf7, 0x0000, 0x0cf8,,,) + + /* PCI Config Space */ + Io (Decode16, 0x0cf8, 0x0cf8, 0x0001, 0x0008) + + /* IO Region 1 */ + DWordIO (ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, + 0x0000, 0x01000, 0xffff, 0x0000, 0xf000,,,) + + /* VGA memory (0xa0000-0xbffff) */ + DWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000a0000, 0x000bffff, 0x00000000, + 0x00020000,,,) + + /* Data and GFX stolen memory */ + DWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x3be00000, 0x3fffffff, 0x00000000, + 0x04200000,,, STOM) + + /* + * PCI MMIO Region (TOLUD - PCI extended base MMCONF) + * This assumes that MMCONF is placed after PCI config space, + * and that no resources are allocated after the MMCONF region. + * This works, sicne MMCONF is hardcoded to 0xe00000000. + */ + DWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, + NonCacheable, ReadWrite, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000,,, PM01) + + /* PCI Memory Region (TOUUD - (TOUUD + ABOVE_4G_MMIO_SIZE)) */ + QWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, + NonCacheable, ReadWrite, + 0x00000000, 0x10000, 0x1ffff, 0x00000000, + 0x10000,,, PM02) +}) + +/* Current Resource Settings */ +Method (_CRS, 0, Serialized) +{ + + /* Find PCI resource area in MCRS */ + CreateDwordField (MCRS, ^PM01._MIN, PMIN) + CreateDwordField (MCRS, ^PM01._MAX, PMAX) + CreateDwordField (MCRS, ^PM01._LEN, PLEN) + + /* Read C-Unit PCI CFG Reg. 0xBC for TOLUD (shadow from B-Unit) */ + And(^MCHC.TLUD, 0xFFF00000, PMIN) + /* Read MMCONF base */ + And(^MCHC.MCNF, 0xF0000000, PMAX) + + /* Calculate PCI MMIO Length */ + Add(Subtract(PMAX, PMIN), 1, PLEN) + + /* Find GFX resource area in GCRS */ + CreateDwordField(MCRS, ^STOM._MIN, GMIN) + CreateDwordField(MCRS, ^STOM._MAX, GMAX) + CreateDwordField(MCRS, ^STOM._LEN, GLEN) + + /* Read BGSM */ + And(^MCHC.BGSM, 0xFFF00000, GMIN) + + /* Read TOLUD */ + And(^MCHC.TLUD, 0xFFF00000, GMAX) + Decrement(GMAX) + Add(Subtract(GMAX, GMIN), 1, GLEN) + + /* Patch PM02 range based on Memory Size */ + CreateQwordField (MCRS, ^PM02._MIN, MMIN) + CreateQwordField (MCRS, ^PM02._MAX, MMAX) + CreateQwordField (MCRS, ^PM02._LEN, MLEN) + + Store (^MCHC.TUUD, Local0) + + If (LLessEqual (Local0, 0x1000000000)) + { + Store (0, MMIN) + Store (0, MLEN) + } + Subtract (Add (MMIN, MLEN), 1, MMAX) + + Return (MCRS) +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi/pch_hda.asl b/arch/x86/include/asm/arch-apollolake/acpi/pch_hda.asl new file mode 100644 index 00000000000..cc3b7a769da --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/pch_hda.asl @@ -0,0 +1,77 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Intel Corporation. + * Copyright (C) 2016 Google Inc. + * + */ + +/* Audio Controller - Device 14, Function 0 */ + +Device (HDAS) +{ + Name (_ADR, 0x000E0000) + Name (_DDN, "Audio Controller") + Name (UUID, ToUUID("A69F886E-6CEB-4594-A41F-7B5DCE24C553")) + + /* Device is D3 wake capable */ + Name (_S0W, 3) + + /* NHLT Table Address populated from GNVS values */ + Name (NBUF, ResourceTemplate() { + QWordMemory (ResourceConsumer, PosDecode, MinFixed, + MaxFixed, Cacheable, ReadOnly, + 0, 0, 0, 0, 1,,, NHLT, AddressRangeACPI) + } + ) + + /* can wake up from S3 state */ + Name (_PRW, Package() { GPE0A_AVS_PME_STS, 3 }) + + /* + * Device Specific Method + * Arg0 - UUID + * Arg1 - Revision + * Arg2 - Function Index + */ + Method (_DSM, 4) { + If (LEqual (Arg0, ^UUID)) { + /* + * Function 0: Function Support Query + * Returns a bitmask of functions supported. + */ + If (LEqual (Arg2, Zero)) { + /* + * NHLT Query only supported for revision 1 and + * if NHLT address and length are set in NVS. + */ + If (LAnd (LEqual (Arg1, One), + LAnd (LNotEqual (NHLA, Zero), + LNotEqual (NHLL, Zero)))) { + Return (Buffer (One) { 0x03 }) + } + Else { + Return (Buffer (One) { 0x01 }) + } + } + + /* + * Function 1: Query NHLT memory address used by + * Intel Offload Engine Driver to discover any non-HDA + * devices that are supported by the DSP. + * + * Returns a pointer to NHLT table in memory. + */ + If (LEqual (Arg2, One)) { + CreateQWordField (NBUF, ^NHLT._MIN, NBAS) + CreateQWordField (NBUF, ^NHLT._MAX, NMAS) + CreateQWordField (NBUF, ^NHLT._LEN, NLEN) + Store (NHLA, NBAS) + Store (NHLA, NMAS) + Store (NHLL, NLEN) + Return (NBUF) + } + } + + Return (Buffer (One) { 0x00 }) + } +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi/pci_irqs.asl b/arch/x86/include/asm/arch-apollolake/acpi/pci_irqs.asl new file mode 100644 index 00000000000..21a1ca9ff9c --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/pci_irqs.asl @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Intel Corp. + * (Written by Lance Zhao lijian.zhao@intel.com for Intel Corp.) + */ + +#include "soc_int.asl" + +Method(_PRT) +{ + Return(Package() { + + Package(){0x0000FFFF, 0, 0, NPK_INT}, + Package(){0x0000FFFF, 1, 0, PUNIT_INT}, + Package(){0x0002FFFF, 0, 0, GEN_INT}, + Package(){0x0003FFFF, 0, 0, IUNIT_INT}, + Package(){0x000DFFFF, 1, 0, PMC_INT}, + Package(){0x000EFFFF, 0, 0, AUDIO_INT}, + Package(){0x000FFFFF, 0, 0, CSE_INT}, + Package(){0x0011FFFF, 0, 0, ISH_INT}, + Package(){0x0012FFFF, 0, 0, SATA_INT}, + Package(){0x0013FFFF, 0, 0, PIRQA_INT}, + Package(){0x0013FFFF, 1, 0, PIRQB_INT}, + Package(){0x0013FFFF, 2, 0, PIRQC_INT}, + Package(){0x0013FFFF, 3, 0, PIRQD_INT}, + Package(){0x0014FFFF, 0, 0, PIRQB_INT}, + Package(){0x0014FFFF, 1, 0, PIRQC_INT}, + Package(){0x0014FFFF, 2, 0, PIRQD_INT}, + Package(){0x0014FFFF, 3, 0, PIRQA_INT}, + Package(){0x0015FFFF, 0, 0, XHCI_INT}, + Package(){0x0015FFFF, 1, 0, XDCI_INT}, + Package(){0x0016FFFF, 0, 0, I2C0_INT}, + Package(){0x0016FFFF, 1, 0, I2C1_INT}, + Package(){0x0016FFFF, 2, 0, I2C2_INT}, + Package(){0x0016FFFF, 3, 0, I2C3_INT}, + Package(){0x0017FFFF, 0, 0, I2C4_INT}, + Package(){0x0017FFFF, 1, 0, I2C5_INT}, + Package(){0x0017FFFF, 2, 0, I2C6_INT}, + Package(){0x0017FFFF, 3, 0, I2C7_INT}, + Package(){0x0018FFFF, 0, 0, UART0_INT}, + Package(){0x0018FFFF, 1, 0, UART1_INT}, + Package(){0x0018FFFF, 2, 0, UART2_INT}, + Package(){0x0018FFFF, 3, 0, UART3_INT}, + Package(){0x0019FFFF, 0, 0, SPI0_INT}, + Package(){0x0019FFFF, 1, 0, SPI1_INT}, + Package(){0x0019FFFF, 2, 0, SPI2_INT}, + Package(){0x001BFFFF, 0, 0, SDCARD_INT}, + Package(){0x001CFFFF, 0, 0, EMMC_INT}, + Package(){0x001EFFFF, 0, 0, SDIO_INT}, + Package(){0x001FFFFF, 1, 0, SMBUS_INT}, + }) +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi/pcie.asl b/arch/x86/include/asm/arch-apollolake/acpi/pcie.asl new file mode 100644 index 00000000000..ecff59ab1c7 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/pcie.asl @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Intel Corporation + */ + +/* PCIe Ports */ + +Device (RP01) +{ + Name (_ADR, 0x00140000) + Name (_DDN, "PCIe-B 0") + + #include "pcie_port.asl" +} + +Device (RP03) +{ + Name (_ADR, 0x00130000) + Name (_DDN, "PCIe-A 0") + + #include "pcie_port.asl" +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi/pcie_port.asl b/arch/x86/include/asm/arch-apollolake/acpi/pcie_port.asl new file mode 100644 index 00000000000..12a08b4aa89 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/pcie_port.asl @@ -0,0 +1,113 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Intel Corporation + */ + +/* Include in each PCIe Root Port device */ + +/* lowest D-state supported by + * PCIe root port during S0 state + */ +Name (_S0W, 4) + +Name (PDST, 0) /* present Detect status */ + +/* Dynamic Opregion needed to access registers + * when the controller is in D3 cold + */ +OperationRegion (PX01, PCI_Config, 0x00, 0xFF) +Field (PX01, AnyAcc, NoLock, Preserve) +{ + Offset(0x5A), + , 6, + PDS, 1, /* 6, Presence detect Change */ + Offset(0xE2), /* RPPGEN - Root Port Power Gating Enable */ + , 2, + L23E, 1, /* 2, L23_Rdy Entry Request (L23ER) */ + L23R, 1, /* 3, L23_Rdy to Detect Transition (L23R2DT) */ + Offset(0xF4), /* BLKPLLEN */ + , 10, + BPLL, 1, +} + +OperationRegion (PX02, PCI_Config, 0x338, 0x4) +Field (PX02, AnyAcc, NoLock, Preserve) +{ + , 26, + BDQA, 1 /* BLKDQDA */ +} + +PowerResource (PXP, 0, 0) +{ + /* Define the PowerResource for PCIe slot */ + Method (_STA, 0, Serialized) + { + Store (PDS, PDST) + If (LEqual (PDS, 1)) { + Return (0xf) + } Else { + Return (0) + } + } + + Method (_ON, 0, Serialized) + { + If (LAnd (LEqual (PDST, 1), LNotEqual (\PRT0, 0))) { + /* Enter this condition if device + * is connected + */ + + /* De-assert PERST */ + _SB.PCI0.PRDA (\PRT0) + + Store (0, BDQA) /* Set BLKDQDA to 0 */ + Store (0, BPLL) /* Set BLKPLLEN to 0 */ + + /* Set L23_Rdy to Detect Transition + * (L23R2DT) + */ + Store (1, L23R) + Sleep (16) + Store (0, Local0) + + /* Delay for transition Detect + * and link to train + */ + While (L23R) { + If (Lgreater (Local0, 4)) { + Break + } + Sleep (16) + Increment (Local0) + } + } /* End PDS condition check */ + } + + Method (_OFF, 0, Serialized) + { + /* Set L23_Rdy Entry Request (L23ER) */ + If (LAnd (LEqual (PDST, 1), LNotEqual (\PRT0, 0))) { + /* enter this condition if device + * is connected + */ + Store (1, L23E) + Sleep (16) + Store (0, Local0) + While (L23E) { + If (Lgreater (Local0, 4)) { + Break + } + Sleep (16) + Increment (Local0) + } + Store (1, BDQA) /* Set BLKDQDA to 1 */ + Store (1, BPLL) /* Set BLKPLLEN to 1 */ + + /* Assert PERST */ + _SB.PCI0.PRAS (\PRT0) + } /* End PDS condition check */ + } /* End of Method_OFF */ +} /* End PXP */ + +Name(_PR0, Package() { PXP }) +Name(_PR3, Package() { PXP }) diff --git a/arch/x86/include/asm/arch-apollolake/acpi/platform.asl b/arch/x86/include/asm/arch-apollolake/acpi/platform.asl new file mode 100644 index 00000000000..b631a9fb38a --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/platform.asl @@ -0,0 +1,10 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2007-2009 coresystems GmbH + * Copyright (C) 2012 Google Inc. + * Copyright (C) 2016 Intel Corp + */ + +/* Enable ACPI _SWS methods */ +#include <soc/intel/common/acpi/acpi_wake_source.asl> +#include <soc/intel/common/acpi/platform.asl> diff --git a/arch/x86/include/asm/arch-apollolake/acpi/pmc_ipc.asl b/arch/x86/include/asm/arch-apollolake/acpi/pmc_ipc.asl new file mode 100644 index 00000000000..4a592833cc0 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/pmc_ipc.asl @@ -0,0 +1,49 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Intel Corp. + */ + +#include <asm/arch/iomap.h> + +#define MAILBOX_DATA 0x7080 +#define MAILBOX_INTF 0x7084 +#define PMIO_LENGTH 0x80 +#define PMIO_LIMIT 0x480 + +scope (_SB) { + Device (IPC1) + { + Name (_HID, "INT34D2") + Name (_CID, "INT34D2") + Name (_DDN, "Intel(R) IPC1 Controller") + Name (RBUF, ResourceTemplate () + { + Memory32Fixed (ReadWrite, 0x0, 0x2000, IBAR) + Memory32Fixed (ReadWrite, 0x0, 0x4, MDAT) + Memory32Fixed (ReadWrite, 0x0, 0x4, MINF) + IO (Decode16, IOMAP_ACPI_BASE, PMIO_LIMIT, + 0x04, PMIO_LENGTH) + Memory32Fixed (ReadWrite, 0x0, 0x2000, SBAR) + Interrupt (ResourceConsumer, Level, ActiveLow, Exclusive, , , ) + { + PMC_INT + } + }) + + Method (_CRS, 0x0, NotSerialized) + { + CreateDwordField (^RBUF, ^IBAR._BAS, IBAS) + Store (PMC_BAR0, IBAS) + + CreateDwordField (^RBUF, ^MDAT._BAS, MDBA) + Store (MCH_BASE_ADDRESS + MAILBOX_DATA, MDBA) + CreateDwordField (^RBUF, ^MINF._BAS, MIBA) + Store (MCH_BASE_ADDRESS + MAILBOX_INTF, MIBA) + + CreateDwordField (^RBUF, ^SBAR._BAS, SBAS) + Store (SRAM_BASE_0, SBAS) + + Return (^RBUF) + } + } +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi/scs.asl b/arch/x86/include/asm/arch-apollolake/acpi/scs.asl new file mode 100644 index 00000000000..7d61861ea1f --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/scs.asl @@ -0,0 +1,173 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Intel Corporation. + */ + +Scope (_SB.PCI0) { + /* 0xD6- is the port address */ + /* 0x600- is the dynamic clock gating control register offset (GENR) */ + OperationRegion (SBMM, SystemMemory, + Or ( Or (IOMAP_P2SB_BAR, + ShiftLeft(0xD6, PCR_PORTID_SHIFT)), 0x0600), 0x18) + Field (SBMM, DWordAcc, NoLock, Preserve) + { + GENR, 32, + Offset (0x08), + , 5, /* bit[5] represents Force Card Detect SD Card */ + GRR3, 1, /* GPPRVRW3 for SD Card detect Bypass. It's active high */ + } + + /* SCC power gate control method, this method must be serialized as + * multiple device will control the GENR register + * + * Arguments: (2) + * Arg0: 0-AND 1-OR + * Arg1: Value + */ + Method (SCPG, 2, Serialized) + { + if (LEqual(Arg0, 0x1)) { + Or (^GENR, Arg1, ^GENR) + } ElseIf (LEqual(Arg0, 0x0)){ + And (^GENR, Arg1, ^GENR) + } + } + + /* eMMC */ + Device (SDHA) { + Name (_ADR, 0x001C0000) + Name (_DDN, "Intel(R) eMMC Controller - 80865ACC") + Name (UUID, ToUUID ("E5C937D0-3553-4D7A-9117-EA4D19C3434D")) + + /* + * Device Specific Method + * Arg0 - UUID + * Arg1 - Revision + * Arg2 - Function Index + */ + Method (_DSM, 4) + { + If (LEqual (Arg0, ^UUID)) { + /* + * Function 9: Device Readiness Durations + * Returns a package of five integers covering + * various device related delays in PCIe Base Spec. + */ + If (LEqual (Arg2, 9)) { + /* + * Function 9 support for revision 3. + * ECN link for function definitions + * [https://pcisig.com/sites/default/files/ + * specification_documents/ + * ECN_fw_latency_optimization_final.pdf] + */ + If (LEqual (Arg1, 3)) { + /* + * Integer 0: FW reset time. + * Integer 1: FW data link up time. + * Integer 2: FW functional level reset + * time. + * Integer 3: FW D3 hot to D0 time. + * Integer 4: FW VF enable time. + * set ACPI constant Ones for elements + * where overriding the default value + * is not desired. + */ + Return (Package (5) {0, Ones, Ones, + Ones, Ones}) + } + } + } + Return (Buffer() { 0x00 }) + } + + Method (_PS0, 0, NotSerialized) + { + /* Clear clock gate + * Clear bit 6 and 0 + */ + ^^SCPG(0,0xFFFFFFBE) + /* Sleep 2 ms */ + Sleep (2) + } + + Method (_PS3, 0, NotSerialized) + { + /* Enable power gate + * Restore clock gate + * Restore bit 6 and 0 + */ + ^^SCPG(1,0x00000041) + } + + Device (CARD) + { + Name (_ADR, 0x00000008) + Method (_RMV, 0, NotSerialized) + { + Return (0) + } + } + } /* Device (SDHA) */ + + /* SD CARD */ + Device (SDCD) + { + Name (_ADR, 0x001B0000) + Name (_S0W, 4) /* _S0W: S0 Device Wake State */ + Name (SCD0, 0) /* Store SD_CD DW0 address */ + + /* Set the host ownership of sdcard cd during kernel boot */ + Method (_INI, 0) + { + /* Check SDCard CD port is valid */ + If (LAnd (LNotEqual (\SCDP, 0), LNotEqual (\SCDO, 0) )) + { + /* Store DW0 address of SD_CD */ + Store (GDW0 (\SCDP, \SCDO), SCD0) + /* Get the current SD_CD ownership */ + Store (_SB.GHO (\SCDP, \SCDO), Local0) + /* Set host ownership as GPIO in HOSTSW_OWN reg */ + Or (Local0, ShiftLeft (1, Mod (\SCDO, 32)), Local0) + _SB.SHO (\SCDP, \SCDO, Local0) + } + } + + Method (_PS0, 0, NotSerialized) + { + /* Check SDCard CD port is valid */ + If (LAnd (LNotEqual (\SCDP, 0), LNotEqual (\SCDO, 0) )) + { + /* Store DW0 into local0 to get rxstate of GPIO */ + Store (_SB.GPC0 (SCD0), Local0) + /* Extract rxstate [bit 1] of sdcard card detect pin */ + And (Local0, PAD_CFG0_RX_STATE, Local0) + /* If the sdcard is present, rxstate is low. + * If sdcard is not present, rxstate is High. + * Write the inverted value of rxstate to GRR3. + */ + If (LEqual (Local0, 0)) { + Store (1, ^^GRR3) + } Else { + Store (0, ^^GRR3) + } + Sleep (2) + } + } + + Method (_PS3, 0, NotSerialized) + { + /* Clear GRR3 to Power Gate SD Controller */ + Store (0, ^^GRR3) + } + + Device (CARD) + { + Name (_ADR, 0x00000008) + Method (_RMV, 0, NotSerialized) + { + Return (1) + } + } + } /* Device (SDCD) */ +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi/soc_int.asl b/arch/x86/include/asm/arch-apollolake/acpi/soc_int.asl new file mode 100644 index 00000000000..df2fafb7f67 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/soc_int.asl @@ -0,0 +1,50 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Intel Corp. + * (Written by Lance Zhao lijian.zhao@intel.com for Intel Corp.) + */ + +#ifndef _SOC_INT_DEFINE_ASL_ +#define _SOC_INT_DEFINE_ASL_ + +#define SDCARD_INT 3 /* Need to be shared by PMC and SCC only*/ +#define UART0_INT 4 /* Need to be shared by PMC and SCC only*/ +#define UART1_INT 5 /* Need to be shared by PMC and SCC only*/ +#define UART2_INT 6 /* Need to be shared by PMC and SCC only*/ +#define UART3_INT 7 /* Need to be shared by PMC and SCC only*/ +#define XDCI_INT 13 /* Need to be shared by PMC and SCC only*/ +#define GPIO_BANK_INT 14 +#define NPK_INT 16 +#define PIRQA_INT 16 +#define PIRQB_INT 17 +#define PIRQC_INT 18 +#define SATA_INT 19 +#define GEN_INT 19 +#define PIRQD_INT 19 +#define XHCI_INT 17 /* Need to be shared by PMC and SCC only*/ +#define SMBUS_INT 20 /* PIRQE */ +#define CSE_INT 20 /* PIRQE */ +#define IUNIT_INT 21 /* PIRQF */ +#define PIRQF_INT 21 +#define PIRQG_INT 22 +#define PUNIT_INT 24 +#define AUDIO_INT 25 +#define ISH_INT 26 +#define I2C0_INT 27 +#define I2C1_INT 28 +#define I2C2_INT 29 +#define I2C3_INT 30 +#define I2C4_INT 31 +#define I2C5_INT 32 +#define I2C6_INT 33 +#define I2C7_INT 34 +#define SPI0_INT 35 +#define SPI1_INT 36 +#define SPI2_INT 37 +#define UFS_INT 38 +#define EMMC_INT 39 +#define PMC_INT 40 +#define SDIO_INT 42 +#define CNVI_INT 44 + +#endif /* _SOC_INT_DEFINE_ASL_ */ diff --git a/arch/x86/include/asm/arch-apollolake/acpi/southbridge.asl b/arch/x86/include/asm/arch-apollolake/acpi/southbridge.asl new file mode 100644 index 00000000000..08290194f60 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/southbridge.asl @@ -0,0 +1,34 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Intel Corp. + * (Written by Lance Zhao lijian.zhao@intel.com for Intel Corp.) + */ + +#include <p2sb.h> +#include <asm/arch/gpe.h> + +/* PCIE device */ +#include "pcie.asl" + +/* LPSS device */ +#include "lpss.asl" + +/* PCI IRQ assignment */ +#include "pci_irqs.asl" + +/* GPIO controller */ +#include "gpio.asl" + +#include "xhci.asl" + +/* LPC */ +#include <asm/acpi/lpc.asl> + +/* eMMC */ +#include "scs.asl" + +/* PMC IPC controller */ +#include "pmc_ipc.asl" + +/* PCI _OSC */ +#include <asm/acpi/pci_osc.asl> diff --git a/arch/x86/include/asm/arch-apollolake/acpi/xhci.asl b/arch/x86/include/asm/arch-apollolake/acpi/xhci.asl new file mode 100644 index 00000000000..6333126c3fd --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/xhci.asl @@ -0,0 +1,33 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Intel Corporation. + */ + +/* XHCI Controller 0:15.0 */ +Device (XHCI) { + Name (_ADR, 0x00150000) /* Device 21, Function 0 */ + + Name (_S3D, 3) /* D3 supported in S3 */ + Name (_S0W, 3) /* D3 can wake device in S0 */ + Name (_S3W, 3) /* D3 can wake system from S3 */ + + /* Declare XHCI GPE status and enable bits are bit 13 */ + Name (_PRW, Package() { GPE0A_XHCI_PME_STS, 3 }) + + Method (_STA, 0) + { + Return (0xF) + } + + Device (RHUB) + { + /* Root Hub */ + Name (_ADR, Zero) + +#if IS_ENABLED(CONFIG_SOC_INTEL_GLK) +#include "xhci_glk_ports.asl" +#else +#include "xhci_apl_ports.asl" +#endif + } +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi/xhci_apl_ports.asl b/arch/x86/include/asm/arch-apollolake/acpi/xhci_apl_ports.asl new file mode 100644 index 00000000000..3ab7d18fc84 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/xhci_apl_ports.asl @@ -0,0 +1,23 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 Google LLC. + * Copyright 2019 Intel Corp. + */ + +/* USB2 */ +Device (HS01) { Name (_ADR, 1) } +Device (HS02) { Name (_ADR, 2) } +Device (HS03) { Name (_ADR, 3) } +Device (HS04) { Name (_ADR, 4) } +Device (HS05) { Name (_ADR, 5) } +Device (HS06) { Name (_ADR, 6) } +Device (HS07) { Name (_ADR, 7) } +Device (HS08) { Name (_ADR, 8) } + +/* USB3 */ +Device (SS01) { Name (_ADR, 9) } +Device (SS02) { Name (_ADR, 10) } +Device (SS03) { Name (_ADR, 11) } +Device (SS04) { Name (_ADR, 12) } +Device (SS05) { Name (_ADR, 13) } +Device (SS06) { Name (_ADR, 14) } diff --git a/arch/x86/include/asm/arch-apollolake/acpi/xhci_glk_ports.asl b/arch/x86/include/asm/arch-apollolake/acpi/xhci_glk_ports.asl new file mode 100644 index 00000000000..192267221fc --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi/xhci_glk_ports.asl @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 Google LLC. + * Copyright 2019 Intel Corp. + */ + +/* USB2 */ +Device (HS01) { Name (_ADR, 1) } +Device (HS02) { Name (_ADR, 2) } +Device (HS03) { Name (_ADR, 3) } +Device (HS04) { Name (_ADR, 4) } +Device (HS05) { Name (_ADR, 5) } +Device (HS06) { Name (_ADR, 6) } +Device (HS07) { Name (_ADR, 7) } +Device (HS08) { Name (_ADR, 8) } +Device (HS09) { Name (_ADR, 9) } + +/* USB3 */ +Device (SS01) { Name (_ADR, 10) } +Device (SS02) { Name (_ADR, 11) } +Device (SS03) { Name (_ADR, 12) } +Device (SS04) { Name (_ADR, 13) } +Device (SS05) { Name (_ADR, 14) } +Device (SS06) { Name (_ADR, 15) }
Add common DPTF (Intel Dynamic Performance and Thermal Framework) files, taken from coreboot.
(no changes since v1)
arch/x86/include/asm/acpi/dptf/charger.asl | 65 +++ arch/x86/include/asm/acpi/dptf/cpu.asl | 186 ++++++++ arch/x86/include/asm/acpi/dptf/dptf.asl | 121 +++++ arch/x86/include/asm/acpi/dptf/fan.asl | 57 +++ arch/x86/include/asm/acpi/dptf/thermal.asl | 521 +++++++++++++++++++++ 5 files changed, 950 insertions(+) create mode 100644 arch/x86/include/asm/acpi/dptf/charger.asl create mode 100644 arch/x86/include/asm/acpi/dptf/cpu.asl create mode 100644 arch/x86/include/asm/acpi/dptf/dptf.asl create mode 100644 arch/x86/include/asm/acpi/dptf/fan.asl create mode 100644 arch/x86/include/asm/acpi/dptf/thermal.asl
diff --git a/arch/x86/include/asm/acpi/dptf/charger.asl b/arch/x86/include/asm/acpi/dptf/charger.asl new file mode 100644 index 00000000000..7f4a7ecd36e --- /dev/null +++ b/arch/x86/include/asm/acpi/dptf/charger.asl @@ -0,0 +1,65 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2016 Intel Corporation. + */ + +Device (TCHG) +{ + Name (_HID, "INT3403") + Name (_UID, 0) + Name (PTYP, 0x0B) + Name (_STR, Unicode("Battery Charger")) + + Method (_STA) + { + If (LEqual (\DPTE, One)) { + Return (0xF) + } Else { + Return (0x0) + } + } + + /* Return charger performance states defined by mainboard */ + Method (PPSS) + { + Return (_SB.CHPS) + } + + /* Return maximum charger current limit */ + Method (PPPC) + { + /* Convert size of PPSS table to index */ + Store (SizeOf (_SB.CHPS), Local0) + Decrement (Local0) + + /* Check if charging is disabled (AC removed) */ + If (LEqual (_SB.PCI0.LPCB.EC0.ACEX, Zero)) { + /* Return last power state */ + Return (Local0) + } Else { + /* Return highest power state */ + Return (0) + } + + Return (0) + } + + /* Set charger current limit */ + Method (SPPC, 1) + { + /* Retrieve Control (index 4) for specified PPSS level */ + Store (DeRefOf (Index (DeRefOf (Index + (_SB.CHPS, ToInteger (Arg0))), 4)), Local0) + + /* Pass Control value to EC to limit charging */ + _SB.PCI0.LPCB.EC0.CHGS (Local0) + } + + /* Initialize charger participant */ + Method (INIT) + { + /* Disable charge limit */ + _SB.PCI0.LPCB.EC0.CHGD () + } +} diff --git a/arch/x86/include/asm/acpi/dptf/cpu.asl b/arch/x86/include/asm/acpi/dptf/cpu.asl new file mode 100644 index 00000000000..f77d3538386 --- /dev/null +++ b/arch/x86/include/asm/acpi/dptf/cpu.asl @@ -0,0 +1,186 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2016 Intel Corporation. + */ + +External (_PR.CP00._PSS, PkgObj) +External (_PR.CP00._TSS, PkgObj) +External (_PR.CP00._TPC, MethodObj) +External (_PR.CP00._PTC, PkgObj) +External (_PR.CP00._TSD, PkgObj) +External (_SB.MPDL, IntObj) + +Device (DPTF_CPU_DEVICE) +{ + Name(_ADR, DPTF_CPU_ADDR) + + Method (_STA) + { + If (LEqual (\DPTE, One)) { + Return (0xF) + } Else { + Return (0x0) + } + } + + /* + * Processor Throttling Controls + */ + + Method (_TSS) + { + If (CondRefOf (_PR.CP00._TSS)) { + Return (_PR.CP00._TSS) + } Else { + Return (Package () + { + Package () { 0, 0, 0, 0, 0 } + }) + } + } + + Method (_TPC) + { + If (CondRefOf (_PR.CP00._TPC)) { + Return (_PR.CP00._TPC) + } Else { + Return (0) + } + } + + Method (_PTC) + { + If (CondRefOf (_PR.CP00._PTC)) { + Return (_PR.CP00._PTC) + } Else { + Return (Package () + { + Buffer () { 0 }, + Buffer () { 0 } + }) + } + } + + Method (_TSD) + { + If (CondRefOf (_PR.CP00._TSD)) { + Return (_PR.CP00._TSD) + } Else { + Return (Package () + { + Package () { 5, 0, 0, 0, 0 } + }) + } + } + + Method (_TDL) + { + If (CondRefOf (_PR.CP00._TSS)) { + Store (SizeOf (_PR.CP00._TSS), Local0) + Decrement (Local0) + Return (Local0) + } Else { + Return (0) + } + } + + /* + * Processor Performance Control + */ + + Method (_PPC) + { + Return (0) + } + + Method (SPPC, 1) + { + Store (Arg0, \PPCM) + + /* Notify OS to re-read _PPC limit on each CPU */ + \PPCN () + } + + Method (_PSS) + { + If (CondRefOf (_PR.CP00._PSS)) { + Return (_PR.CP00._PSS) + } Else { + Return (Package () + { + Package () { 0, 0, 0, 0, 0, 0 } + }) + } + } + + + Method (_PDL) + { + /* Check for mainboard specific _PDL override */ + If (CondRefOf (_SB.MPDL)) { + Return (_SB.MPDL) + } ElseIf (CondRefOf (_PR.CP00._PSS)) { + Store (SizeOf (_PR.CP00._PSS), Local0) + Decrement (Local0) + Return (Local0) + } Else { + Return (0) + } + } + + /* Return PPCC table defined by mainboard */ + Method (PPCC) + { + Return (_SB.MPPC) + } + +#ifdef DPTF_CPU_CRITICAL + Method (_CRT) + { + Return (_SB.DPTF.CTOK (DPTF_CPU_CRITICAL)) + } +#endif + +#ifdef DPTF_CPU_PASSIVE + Method (_PSV) + { + Return (_SB.DPTF.CTOK (DPTF_CPU_PASSIVE)) + } +#endif + +#ifdef DPTF_CPU_ACTIVE_AC0 + Method (_AC0) + { + Return (_SB.DPTF.CTOK (DPTF_CPU_ACTIVE_AC0)) + } +#endif + +#ifdef DPTF_CPU_ACTIVE_AC1 + Method (_AC1) + { + Return (_SB.DPTF.CTOK (DPTF_CPU_ACTIVE_AC1)) + } +#endif + +#ifdef DPTF_CPU_ACTIVE_AC2 + Method (_AC2) + { + Return (_SB.DPTF.CTOK (DPTF_CPU_ACTIVE_AC2)) + } +#endif + +#ifdef DPTF_CPU_ACTIVE_AC3 + Method (_AC3) + { + Return (_SB.DPTF.CTOK (DPTF_CPU_ACTIVE_AC3)) + } +#endif + +#ifdef DPTF_CPU_ACTIVE_AC4 + Method (_AC4) + { + Return (_SB.DPTF.CTOK (DPTF_CPU_ACTIVE_AC4)) + } +#endif +} diff --git a/arch/x86/include/asm/acpi/dptf/dptf.asl b/arch/x86/include/asm/acpi/dptf/dptf.asl new file mode 100644 index 00000000000..5f958d200b7 --- /dev/null +++ b/arch/x86/include/asm/acpi/dptf/dptf.asl @@ -0,0 +1,121 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2016 Intel Corporation. + */ + +Device (DPTF) +{ + Name (_HID, EISAID ("INT3400")) + Name (_UID, 0) + + Name (IDSP, Package() + { + /* DPPM Passive Policy 1.0 */ + ToUUID ("42A441D6-AE6A-462B-A84B-4A8CE79027D3"), + + /* DPPM Critical Policy */ + ToUUID ("97C68AE7-15FA-499c-B8C9-5DA81D606E0A"), + + /* DPPM Cooling Policy */ + ToUUID ("16CAF1B7-DD38-40ED-B1C1-1B8A1913D531"), + +#ifdef DPTF_ENABLE_FAN_CONTROL + /* DPPM Active Policy */ + ToUUID ("3A95C389-E4B8-4629-A526-C52C88626BAE"), +#endif + }) + + Method (_STA) + { + If (LEqual (\DPTE, One)) { + Return (0xF) + } Else { + Return (0x0) + } + } + + /* + * Arg0: Buffer containing UUID + * Arg1: Integer containing Revision ID of buffer format + * Arg2: Integer containing count of entries in Arg3 + * Arg3: Buffer containing list of DWORD capabilities + * Return: Buffer containing list of DWORD capabilities + */ + Method (_OSC, 4, Serialized) + { + /* Check for Passive Policy UUID */ + If (LEqual (DeRefOf (Index (IDSP, 0)), Arg0)) { + /* Initialize Thermal Devices */ + ^TINI () + +#ifdef DPTF_ENABLE_CHARGER + /* Initialize Charger Device */ + ^TCHG.INIT () +#endif + } + + Return (Arg3) + } + + /* Priority based _TRT */ + Name (TRTR, 1) + + Method (_TRT) + { + Return (_SB.DTRT) + } + +#ifdef DPTF_ENABLE_FAN_CONTROL + /* _ART : Active Cooling Relationship Table */ + Method (_ART) + { + Return (_SB.DART) + } +#endif + + /* Convert from Degrees C to 1/10 Kelvin for ACPI */ + Method (CTOK, 1) { + /* 10th of Degrees C */ + Multiply (Arg0, 10, Local0) + + /* Convert to Kelvin */ + Add (Local0, 2732, Local0) + + Return (Local0) + } + + /* Convert from 1/10 Kelvin to Degrees C for ACPI */ + Method (KTOC, 1) { + If (LLessEqual (Arg0, 2732)) { + Return (0) + } + + /* Convert to Celsius */ + Subtract (Arg0, 2732, Local0) + + /* Convert from 10th of degrees */ + Divide (Local0, 10,, Local0) + + Return (Local0) + } + + /* Include Thermal Participants */ + #include "thermal.asl" + +#ifdef DPTF_ENABLE_CHARGER + /* Include Charger Participant */ + #include "charger.asl" +#endif + +#ifdef DPTF_ENABLE_FAN_CONTROL + /* Include Fan Participant */ + #include "fan.asl" +#endif + +} + +Scope (_SB.PCI0) +{ + #include "cpu.asl" +} diff --git a/arch/x86/include/asm/acpi/dptf/fan.asl b/arch/x86/include/asm/acpi/dptf/fan.asl new file mode 100644 index 00000000000..aa4aa129119 --- /dev/null +++ b/arch/x86/include/asm/acpi/dptf/fan.asl @@ -0,0 +1,57 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Intel Corporation. + */ + +Device (TFN1) +{ + Name (_HID, "INT3404") + Name (_UID, 0) + Name (_STR, Unicode("Fan Control")) + + /* _FIF: Fan Information */ + Name (_FIF, Package () + { + 0, // Revision + 1, // Fine Grained Control + 2, // Step Size + 0 // No Low Speed Notification + }) + + /* Return Fan Performance States defined by mainboard */ + Method (_FPS) + { + Return (_SB.DFPS) + } + + Name (TFST, Package () + { + 0, // Revision + 0x00, // Control + 0x00 // Speed + }) + + /* _FST: Fan current Status */ + Method (_FST, 0, Serialized,,PkgObj) + { + /* Fill in TFST with current control. */ + Store (_SB.PCI0.LPCB.EC0.FAND, Index (TFST, 1)) + Return (TFST) + } + + /* _FSL: Fan Speed Level */ + Method (_FSL, 1, Serialized) + { + Store (Arg0, _SB.PCI0.LPCB.EC0.FAND) + } + + Method (_STA) + { + If (LEqual (\DPTE, One)) + { + Return (0xF) + } Else { + Return (0x0) + } + } +} diff --git a/arch/x86/include/asm/acpi/dptf/thermal.asl b/arch/x86/include/asm/acpi/dptf/thermal.asl new file mode 100644 index 00000000000..4c3c8db8f23 --- /dev/null +++ b/arch/x86/include/asm/acpi/dptf/thermal.asl @@ -0,0 +1,521 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2016 Intel Corporation. + */ + +/* Thermal Threshold Event Handler */ +#define HAVE_THERM_EVENT_HANDLER +Method (TEVT, 1, NotSerialized) +{ + Store (ToInteger (Arg0), Local0) + +#ifdef DPTF_TSR0_SENSOR_ID + If (LEqual (Local0, DPTF_TSR0_SENSOR_ID)) { + Notify (^TSR0, 0x90) + } +#endif +#ifdef DPTF_TSR1_SENSOR_ID + If (LEqual (Local0, DPTF_TSR1_SENSOR_ID)) { + Notify (^TSR1, 0x90) + } +#endif +#ifdef DPTF_TSR2_SENSOR_ID + If (LEqual (Local0, DPTF_TSR2_SENSOR_ID)) { + Notify (^TSR2, 0x90) + } +#endif +#ifdef DPTF_TSR3_SENSOR_ID + If (LEqual (Local0, DPTF_TSR3_SENSOR_ID)) { + Notify (^TSR3, 0x90) + } +#endif +} + +/* Thermal device initialization - Disable Aux Trip Points */ +Method (TINI) +{ +#ifdef DPTF_TSR0_SENSOR_ID + ^TSR0.PATD () +#endif +#ifdef DPTF_TSR1_SENSOR_ID + ^TSR1.PATD () +#endif +#ifdef DPTF_TSR2_SENSOR_ID + ^TSR2.PATD () +#endif +#ifdef DPTF_TSR3_SENSOR_ID + ^TSR3.PATD () +#endif +} + +/* Thermal Trip Points Change Event Handler */ +Method (TPET) +{ +#ifdef DPTF_TSR0_SENSOR_ID + Notify (^TSR0, 0x81) +#endif +#ifdef DPTF_TSR1_SENSOR_ID + Notify (^TSR1, 0x81) +#endif +#ifdef DPTF_TSR2_SENSOR_ID + Notify (^TSR2, 0x81) +#endif +#ifdef DPTF_TSR3_SENSOR_ID + Notify (^TSR3, 0x81) +#endif +} + +/* + * Method to return trip temperature value depending upon the device mode. + * Arg0 --> Value to return when device is in tablet mode + * Arg1 --> Value to return when device is not in tablet mode. + */ +Method (DTRP, 2, Serialized) +{ +#ifdef EC_ENABLE_MULTIPLE_DPTF_PROFILES + If (LEqual (_SB.PCI0.LPCB.EC0.RCDP, One)) { + Return (CTOK (Arg0)) + } Else { +#endif + Return (CTOK (Arg1)) +#ifdef EC_ENABLE_MULTIPLE_DPTF_PROFILES + } +#endif +} + +#ifdef DPTF_TSR0_SENSOR_ID + +#ifndef DPTF_TSR0_TABLET_PASSIVE +#define DPTF_TSR0_TABLET_PASSIVE DPTF_TSR0_PASSIVE +#endif +#ifndef DPTF_TSR0_TABLET_CRITICAL +#define DPTF_TSR0_TABLET_CRITICAL DPTF_TSR0_CRITICAL +#endif + +Device (TSR0) +{ + Name (_HID, EISAID ("INT3403")) + Name (_UID, 1) + Name (PTYP, 0x03) + Name (TMPI, DPTF_TSR0_SENSOR_ID) + Name (_STR, Unicode (DPTF_TSR0_SENSOR_NAME)) + Name (GTSH, 20) /* 2 degree hysteresis */ + + Method (_STA) + { + If (LEqual (\DPTE, One)) { + Return (0xF) + } Else { + Return (0x0) + } + } + + Method (_TMP, 0, Serialized) + { + Return (_SB.PCI0.LPCB.EC0.TSRD (TMPI)) + } + + Method (_PSV) + { + Return (DTRP (DPTF_TSR0_TABLET_PASSIVE, DPTF_TSR0_PASSIVE)) + } + + Method (_CRT) + { + Return (DTRP (DPTF_TSR0_TABLET_CRITICAL, DPTF_TSR0_CRITICAL)) + } + + Name (PATC, 2) + + /* Set Aux Trip Point */ + Method (PAT0, 1, Serialized) + { + _SB.PCI0.LPCB.EC0.PAT0 (TMPI, Arg0) + } + + /* Set Aux Trip Point */ + Method (PAT1, 1, Serialized) + { + _SB.PCI0.LPCB.EC0.PAT1 (TMPI, Arg0) + } + + /* Disable Aux Trip Point */ + Method (PATD, 0, Serialized) + { + _SB.PCI0.LPCB.EC0.PATD (TMPI) + } + +#ifdef DPTF_ENABLE_FAN_CONTROL +#ifdef DPTF_TSR0_ACTIVE_AC0 + Method (_AC0) + { + Return (_SB.DPTF.CTOK (DPTF_TSR0_ACTIVE_AC0)) + } +#endif +#ifdef DPTF_TSR0_ACTIVE_AC1 + Method (_AC1) + { + Return (_SB.DPTF.CTOK (DPTF_TSR0_ACTIVE_AC1)) + } +#endif +#ifdef DPTF_TSR0_ACTIVE_AC2 + Method (_AC2) + { + Return (_SB.DPTF.CTOK (DPTF_TSR0_ACTIVE_AC2)) + } +#endif +#ifdef DPTF_TSR0_ACTIVE_AC3 + Method (_AC3) + { + Return (_SB.DPTF.CTOK (DPTF_TSR0_ACTIVE_AC3)) + } +#endif +#ifdef DPTF_TSR0_ACTIVE_AC4 + Method (_AC4) + { + Return (_SB.DPTF.CTOK (DPTF_TSR0_ACTIVE_AC4)) + } +#endif +#ifdef DPTF_TSR0_ACTIVE_AC5 + Method (_AC5) + { + Return (_SB.DPTF.CTOK (DPTF_TSR0_ACTIVE_AC5)) + } +#endif +#ifdef DPTF_TSR0_ACTIVE_AC6 + Method (_AC6) + { + Return (_SB.DPTF.CTOK (DPTF_TSR0_ACTIVE_AC6)) + } +#endif +#endif +} +#endif + +#ifdef DPTF_TSR1_SENSOR_ID + +#ifndef DPTF_TSR1_TABLET_PASSIVE +#define DPTF_TSR1_TABLET_PASSIVE DPTF_TSR1_PASSIVE +#endif +#ifndef DPTF_TSR1_TABLET_CRITICAL +#define DPTF_TSR1_TABLET_CRITICAL DPTF_TSR1_CRITICAL +#endif + +Device (TSR1) +{ + Name (_HID, EISAID ("INT3403")) + Name (_UID, 2) + Name (PTYP, 0x03) + Name (TMPI, DPTF_TSR1_SENSOR_ID) + Name (_STR, Unicode (DPTF_TSR1_SENSOR_NAME)) + Name (GTSH, 20) /* 2 degree hysteresis */ + + Method (_STA) + { + If (LEqual (\DPTE, One)) { + Return (0xF) + } Else { + Return (0x0) + } + } + + Method (_TMP, 0, Serialized) + { + Return (_SB.PCI0.LPCB.EC0.TSRD (TMPI)) + } + + Method (_PSV) + { + Return (DTRP (DPTF_TSR1_TABLET_PASSIVE, DPTF_TSR1_PASSIVE)) + } + + Method (_CRT) + { + Return (DTRP (DPTF_TSR1_TABLET_CRITICAL, DPTF_TSR1_CRITICAL)) + } + + Name (PATC, 2) + + /* Set Aux Trip Point */ + Method (PAT0, 1, Serialized) + { + _SB.PCI0.LPCB.EC0.PAT0 (TMPI, Arg0) + } + + /* Set Aux Trip Point */ + Method (PAT1, 1, Serialized) + { + _SB.PCI0.LPCB.EC0.PAT1 (TMPI, Arg0) + } + + /* Disable Aux Trip Point */ + Method (PATD, 0, Serialized) + { + _SB.PCI0.LPCB.EC0.PATD (TMPI) + } + +#ifdef DPTF_ENABLE_FAN_CONTROL +#ifdef DPTF_TSR1_ACTIVE_AC0 + Method (_AC0) + { + Return (_SB.DPTF.CTOK (DPTF_TSR1_ACTIVE_AC0)) + } +#endif +#ifdef DPTF_TSR1_ACTIVE_AC1 + Method (_AC1) + { + Return (_SB.DPTF.CTOK (DPTF_TSR1_ACTIVE_AC1)) + } +#endif +#ifdef DPTF_TSR1_ACTIVE_AC2 + Method (_AC2) + { + Return (_SB.DPTF.CTOK (DPTF_TSR1_ACTIVE_AC2)) + } +#endif +#ifdef DPTF_TSR1_ACTIVE_AC3 + Method (_AC3) + { + Return (_SB.DPTF.CTOK (DPTF_TSR1_ACTIVE_AC3)) + } +#endif +#ifdef DPTF_TSR1_ACTIVE_AC4 + Method (_AC4) + { + Return (_SB.DPTF.CTOK (DPTF_TSR1_ACTIVE_AC4)) + } +#endif +#ifdef DPTF_TSR1_ACTIVE_AC5 + Method (_AC5) + { + Return (_SB.DPTF.CTOK (DPTF_TSR1_ACTIVE_AC5)) + } +#endif +#ifdef DPTF_TSR1_ACTIVE_AC6 + Method (_AC6) + { + Return (_SB.DPTF.CTOK (DPTF_TSR1_ACTIVE_AC6)) + } +#endif +#endif +} +#endif + +#ifdef DPTF_TSR2_SENSOR_ID + +#ifndef DPTF_TSR2_TABLET_PASSIVE +#define DPTF_TSR2_TABLET_PASSIVE DPTF_TSR2_PASSIVE +#endif +#ifndef DPTF_TSR2_TABLET_CRITICAL +#define DPTF_TSR2_TABLET_CRITICAL DPTF_TSR2_CRITICAL +#endif + +Device (TSR2) +{ + Name (_HID, EISAID ("INT3403")) + Name (_UID, 3) + Name (PTYP, 0x03) + Name (TMPI, DPTF_TSR2_SENSOR_ID) + Name (_STR, Unicode (DPTF_TSR2_SENSOR_NAME)) + Name (GTSH, 20) /* 2 degree hysteresis */ + + Method (_STA) + { + If (LEqual (\DPTE, One)) { + Return (0xF) + } Else { + Return (0x0) + } + } + + Method (_TMP, 0, Serialized) + { + Return (_SB.PCI0.LPCB.EC0.TSRD (TMPI)) + } + + Method (_PSV) + { + Return (DTRP (DPTF_TSR2_TABLET_PASSIVE, DPTF_TSR2_PASSIVE)) + } + + Method (_CRT) + { + Return (DTRP (DPTF_TSR2_TABLET_CRITICAL, DPTF_TSR2_CRITICAL)) + } + + Name (PATC, 2) + + /* Set Aux Trip Point */ + Method (PAT0, 1, Serialized) + { + _SB.PCI0.LPCB.EC0.PAT0 (TMPI, Arg0) + } + + /* Set Aux Trip Point */ + Method (PAT1, 1, Serialized) + { + _SB.PCI0.LPCB.EC0.PAT1 (TMPI, Arg0) + } + + /* Disable Aux Trip Point */ + Method (PATD, 0, Serialized) + { + _SB.PCI0.LPCB.EC0.PATD (TMPI) + } + +#ifdef DPTF_ENABLE_FAN_CONTROL +#ifdef DPTF_TSR2_ACTIVE_AC0 + Method (_AC0) + { + Return (_SB.DPTF.CTOK (DPTF_TSR2_ACTIVE_AC0)) + } +#endif +#ifdef DPTF_TSR2_ACTIVE_AC1 + Method (_AC1) + { + Return (_SB.DPTF.CTOK (DPTF_TSR2_ACTIVE_AC1)) + } +#endif +#ifdef DPTF_TSR2_ACTIVE_AC2 + Method (_AC2) + { + Return (_SB.DPTF.CTOK (DPTF_TSR2_ACTIVE_AC2)) + } +#endif +#ifdef DPTF_TSR2_ACTIVE_AC3 + Method (_AC3) + { + Return (_SB.DPTF.CTOK (DPTF_TSR2_ACTIVE_AC3)) + } +#endif +#ifdef DPTF_TSR2_ACTIVE_AC4 + Method (_AC4) + { + Return (_SB.DPTF.CTOK (DPTF_TSR2_ACTIVE_AC4)) + } +#endif +#ifdef DPTF_TSR2_ACTIVE_AC5 + Method (_AC5) + { + Return (_SB.DPTF.CTOK (DPTF_TSR2_ACTIVE_AC5)) + } +#endif +#ifdef DPTF_TSR2_ACTIVE_AC6 + Method (_AC6) + { + Return (_SB.DPTF.CTOK (DPTF_TSR2_ACTIVE_AC6)) + } +#endif +#endif +} +#endif + +#ifdef DPTF_TSR3_SENSOR_ID + +#ifndef DPTF_TSR3_TABLET_PASSIVE +#define DPTF_TSR3_TABLET_PASSIVE DPTF_TSR3_PASSIVE +#endif +#ifndef DPTF_TSR3_TABLET_CRITICAL +#define DPTF_TSR3_TABLET_CRITICAL DPTF_TSR3_CRITICAL +#endif + +Device (TSR3) +{ + Name (_HID, EISAID ("INT3403")) + Name (_UID, 4) + Name (PTYP, 0x03) + Name (TMPI, DPTF_TSR3_SENSOR_ID) + Name (_STR, Unicode (DPTF_TSR3_SENSOR_NAME)) + Name (GTSH, 20) /* 2 degree hysteresis */ + + Method (_STA) + { + If (LEqual (\DPTE, One)) { + Return (0xF) + } Else { + Return (0x0) + } + } + + Method (_TMP, 0, Serialized) + { + Return (_SB.PCI0.LPCB.EC0.TSRD (TMPI)) + } + + Method (_PSV) + { + Return (DTRP (DPTF_TSR3_TABLET_PASSIVE, DPTF_TSR3_PASSIVE)) + } + + Method (_CRT) + { + Return (DTRP (DPTF_TSR3_TABLET_CRITICAL, DPTF_TSR3_CRITICAL)) + } + + Name (PATC, 2) + + /* Set Aux Trip Point */ + Method (PAT0, 1, Serialized) + { + _SB.PCI0.LPCB.EC0.PAT0 (TMPI, Arg0) + } + + /* Set Aux Trip Point */ + Method (PAT1, 1, Serialized) + { + _SB.PCI0.LPCB.EC0.PAT1 (TMPI, Arg0) + } + + /* Disable Aux Trip Point */ + Method (PATD, 0, Serialized) + { + _SB.PCI0.LPCB.EC0.PATD (TMPI) + } + +#ifdef DPTF_ENABLE_FAN_CONTROL +#ifdef DPTF_TSR3_ACTIVE_AC0 + Method (_AC0) + { + Return (_SB.DPTF.CTOK (DPTF_TSR3_ACTIVE_AC0)) + } +#endif +#ifdef DPTF_TSR3_ACTIVE_AC1 + Method (_AC1) + { + Return (_SB.DPTF.CTOK (DPTF_TSR3_ACTIVE_AC1)) + } +#endif +#ifdef DPTF_TSR3_ACTIVE_AC2 + Method (_AC2) + { + Return (_SB.DPTF.CTOK (DPTF_TSR3_ACTIVE_AC2)) + } +#endif +#ifdef DPTF_TSR3_ACTIVE_AC3 + Method (_AC3) + { + Return (_SB.DPTF.CTOK (DPTF_TSR3_ACTIVE_AC3)) + } +#endif +#ifdef DPTF_TSR3_ACTIVE_AC4 + Method (_AC4) + { + Return (_SB.DPTF.CTOK (DPTF_TSR3_ACTIVE_AC4)) + } +#endif +#ifdef DPTF_TSR3_ACTIVE_AC5 + Method (_AC5) + { + Return (_SB.DPTF.CTOK (DPTF_TSR3_ACTIVE_AC5)) + } +#endif +#ifdef DPTF_TSR3_ACTIVE_AC6 + Method (_AC6) + { + Return (_SB.DPTF.CTOK (DPTF_TSR3_ACTIVE_AC6)) + } +#endif +#endif +} +#endif
This value is incorrect and causes problems booting Linux. Fix it.
board/google/chromebook_coral/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/google/chromebook_coral/Kconfig b/board/google/chromebook_coral/Kconfig index 940bee89b0b..f744b4c00cb 100644 --- a/board/google/chromebook_coral/Kconfig +++ b/board/google/chromebook_coral/Kconfig @@ -22,7 +22,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select BOARD_ROMSIZE_KB_16384
config PCIE_ECAM_BASE - default 0xf0000000 + default 0xe0000000
config EARLY_POST_CROS_EC bool "Enable early post to Chrome OS EC"
Add a way to specify the required size for this region. This is used when generating ACPI tables.
arch/x86/Kconfig | 18 ++++++++++++++++++ arch/x86/cpu/apollolake/Kconfig | 1 + 2 files changed, 19 insertions(+)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index a34b108fffa..9ac6a5a1ae5 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -973,4 +973,22 @@ config TPL_ACPI_GPE
See https://queue.acm.org/blogposting.cfm?id=18977 for more info
+config SA_PCIEX_LENGTH + hex + default 0x10000000 if (PCIEX_LENGTH_256MB) + default 0x8000000 if (PCIEX_LENGTH_128MB) + default 0x4000000 if (PCIEX_LENGTH_64MB) + default 0x10000000 + help + This option allows you to select length of PCIEX region. + +config PCIEX_LENGTH_256MB + bool + +config PCIEX_LENGTH_128MB + bool + +config PCIEX_LENGTH_64MB + bool + endmenu diff --git a/arch/x86/cpu/apollolake/Kconfig b/arch/x86/cpu/apollolake/Kconfig index 99d4e105c25..37d6289ee41 100644 --- a/arch/x86/cpu/apollolake/Kconfig +++ b/arch/x86/cpu/apollolake/Kconfig @@ -13,6 +13,7 @@ config INTEL_APOLLOLAKE select TPL_X86_TSC_TIMER_NATIVE select SPL_PCH_SUPPORT select TPL_PCH_SUPPORT + select PCIEX_LENGTH_256MB select PCH_SUPPORT select P2SB select SMP_AP_WORK
Add the definition of this structure common to Intel devices. It includes some optional Chrome OS pieces which are used when vboot is integrated.
Drop the APL version as it is basically the same.
Changes in v1: - Use this file in APL
.../include/asm/arch-apollolake/global_nvs.h | 23 +--------- arch/x86/include/asm/intel_gnvs.h | 43 +++++++++++++++++++ 2 files changed, 44 insertions(+), 22 deletions(-) create mode 100644 arch/x86/include/asm/intel_gnvs.h
diff --git a/arch/x86/include/asm/arch-apollolake/global_nvs.h b/arch/x86/include/asm/arch-apollolake/global_nvs.h index fe62194b02e..ef8eb228dbe 100644 --- a/arch/x86/include/asm/arch-apollolake/global_nvs.h +++ b/arch/x86/include/asm/arch-apollolake/global_nvs.h @@ -10,27 +10,6 @@ #ifndef _GLOBAL_NVS_H_ #define _GLOBAL_NVS_H_
-struct __packed acpi_global_nvs { - /* Miscellaneous */ - u8 pcnt; /* 0x00 - Processor Count */ - u8 ppcm; /* 0x01 - Max PPC State */ - u8 lids; /* 0x02 - LID State */ - u8 pwrs; /* 0x03 - AC Power State */ - u8 dpte; /* 0x04 - Enable DPTF */ - u32 cbmc; /* 0x05 - 0x08 - U-Boot Console */ - u64 pm1i; /* 0x09 - 0x10 - System Wake Source - PM1 Index */ - u64 gpei; /* 0x11 - 0x18 - GPE Wake Source */ - u64 nhla; /* 0x19 - 0x20 - NHLT Address */ - u32 nhll; /* 0x21 - 0x24 - NHLT Length */ - u32 prt0; /* 0x25 - 0x28 - PERST_0 Address */ - u8 scdp; /* 0x29 - SD_CD GPIO portid */ - u8 scdo; /* 0x2a - GPIO pad offset relative to the community */ - u8 uior; /* 0x2b - UART debug controller init on S3 resume */ - u8 ecps; /* 0x2c - SGX Enabled status */ - u64 emna; /* 0x2d - 0x34 EPC base address */ - u64 elng; /* 0x35 - 0x3c EPC Length */ - u8 unused1[0x100 - 0x3d]; /* Pad out to 256 bytes */ - u8 unused2[0x1000 - 0x100]; /* Pad out to 4096 bytes */ -}; +#include <asm/intel_gnvs.h>
#endif /* _GLOBAL_NVS_H_ */ diff --git a/arch/x86/include/asm/intel_gnvs.h b/arch/x86/include/asm/intel_gnvs.h new file mode 100644 index 00000000000..e2d479d4f32 --- /dev/null +++ b/arch/x86/include/asm/intel_gnvs.h @@ -0,0 +1,43 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2019 Intel Corporation. + * + * Taken from coreboot intelblocks/nvs.h + * Copyright 2019 Google LLC + */ + +#ifndef _INTEL_GNVS_H_ +#define _INTEL_GNVS_H_ + +struct __packed acpi_global_nvs { + /* Miscellaneous */ + u8 pcnt; /* 0x00 - Processor Count */ + u8 ppcm; /* 0x01 - Max PPC State */ + u8 lids; /* 0x02 - LID State */ + u8 pwrs; /* 0x03 - AC Power State */ + u8 dpte; /* 0x04 - Enable DPTF */ + u32 cbmc; /* 0x05 - 0x08 - coreboot Memory Console */ + u64 pm1i; /* 0x09 - 0x10 - System Wake Source - PM1 Index */ + u64 gpei; /* 0x11 - 0x18 - GPE Wake Source */ + u64 nhla; /* 0x19 - 0x20 - NHLT Address */ + u32 nhll; /* 0x21 - 0x24 - NHLT Length */ + u32 prt0; /* 0x25 - 0x28 - PERST_0 Address */ + u8 scdp; /* 0x29 - SD_CD GPIO portid */ + u8 scdo; /* 0x2a - GPIO pad offset relative to the community */ + u8 uior; /* 0x2b - UART debug controller init on S3 resume */ + u8 ecps; /* 0x2c - SGX Enabled status */ + u64 emna; /* 0x2d - 0x34 EPC base address */ + u64 elng; /* 0x35 - 0x3C EPC Length */ + u8 unused1[0x100 - 0x3d]; /* Pad out to 256 bytes */ +#ifdef CONFIG_CHROMEOS + /* ChromeOS-specific (0x100 - 0xfff) */ + struct chromeos_acpi chromeos; +#else + u8 unused2[0x1000 - 0x100]; /* Pad out to 4096 bytes */ +#endif +}; +#ifdef CONFIG_CHROMEOS +check_member(acpi_global_nvs, chromeos, GNVS_CHROMEOS_ACPI_OFFSET); +#endif + +#endif /* _INTEL_GNVS_H_ */
At present U-Boot puts a magic number in the ASL for the GNVS table and searches for it later.
Add a Kconfig option to use a different approach, where the ASL files declare the table as an external symbol. U-Boot can then put it wherever it likes, without any magic numbers or searching.
arch/x86/Kconfig | 7 +++++ arch/x86/cpu/apollolake/Kconfig | 1 + arch/x86/include/asm/acpi/global_nvs.h | 3 ++ arch/x86/lib/acpi_table.c | 42 ++++++++++++++------------ 4 files changed, 33 insertions(+), 20 deletions(-)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 9ac6a5a1ae5..a8bbf761db6 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -785,6 +785,13 @@ config GENERATE_ACPI_TABLE by the operating system. It defines platform-independent interfaces for configuration and power management monitoring.
+config ACPI_GNVS_EXTERNAL + bool + help + Put the GNVS (Global Non-Volatile Sleeping) table separate from the + DSDT and add a pointer to the table from the DSDT. This allows + U-Boot to better control the address of the GNVS. + endmenu
config HAVE_ACPI_RESUME diff --git a/arch/x86/cpu/apollolake/Kconfig b/arch/x86/cpu/apollolake/Kconfig index 37d6289ee41..16ac2b3f504 100644 --- a/arch/x86/cpu/apollolake/Kconfig +++ b/arch/x86/cpu/apollolake/Kconfig @@ -17,6 +17,7 @@ config INTEL_APOLLOLAKE select PCH_SUPPORT select P2SB select SMP_AP_WORK + select ACPI_GNVS_EXTERNAL imply ENABLE_MRC_CACHE imply AHCI_PCI imply SCSI diff --git a/arch/x86/include/asm/acpi/global_nvs.h b/arch/x86/include/asm/acpi/global_nvs.h index d56d35ca533..a552cf6374f 100644 --- a/arch/x86/include/asm/acpi/global_nvs.h +++ b/arch/x86/include/asm/acpi/global_nvs.h @@ -11,6 +11,9 @@ * ACPI_GNVS_SIZE. They are to be used in platform's global_nvs.asl file * to declare the GNVS OperationRegion, as well as write_acpi_tables() * for the GNVS address runtime fix up. + * + * If using CONFIG_ACPI_GNVS_EXTERNAL, we don't need to locate the GNVS in + * DSDT, since it is created by code, so ACPI_GNVS_ADDR is unused. */ #define ACPI_GNVS_ADDR 0xdeadbeef #define ACPI_GNVS_SIZE 0x100 diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 3a93fedfc3e..942b2334eab 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -428,17 +428,30 @@ ulong write_acpi_tables(ulong start_addr) dsdt->length - sizeof(struct acpi_table_header));
acpi_inc_align(ctx, dsdt->length - sizeof(struct acpi_table_header)); + dsdt->length = ctx->current - (void *)dsdt;
- /* Pack GNVS into the ACPI table area */ - for (i = 0; i < dsdt->length; i++) { - u32 *gnvs = (u32 *)((u32)dsdt + i); - if (*gnvs == ACPI_GNVS_ADDR) { - ulong addr = (ulong)map_to_sysmem(ctx->current); - - debug("Fix up global NVS in DSDT to %#08lx\n", addr); - *gnvs = addr; - break; + if (!IS_ENABLED(CONFIG_ACPI_GNVS_EXTERNAL)) { + /* Pack GNVS into the ACPI table area */ + for (i = 0; i < dsdt->length; i++) { + u32 *gnvs = (u32 *)((u32)dsdt + i); + + if (*gnvs == ACPI_GNVS_ADDR) { + *gnvs = map_to_sysmem(ctx->current); + debug("Fix up global NVS in DSDT to %#08x\n", + *gnvs); + break; + } } + + /* + * Fill in platform-specific global NVS variables. If this fails + * we cannot return the error but this should only happen while + * debugging. + */ + addr = acpi_create_gnvs(ctx->current); + if (IS_ERR_VALUE(addr)) + printf("Error: Gailed to create GNVS\n"); + acpi_inc_align(ctx, sizeof(struct acpi_global_nvs)); }
/* @@ -446,20 +459,9 @@ ulong write_acpi_tables(ulong start_addr) * the GNVS address. Set the checksum to zero since it is part of the * region being checksummed. */ - dsdt->length = ctx->current - (void *)dsdt; dsdt->checksum = 0; dsdt->checksum = table_compute_checksum((void *)dsdt, dsdt->length);
- /* - * Fill in platform-specific global NVS variables. If this fails we - * cannot return the error but this should only happen while debugging. - */ - addr = acpi_create_gnvs(ctx->current); - if (IS_ERR_VALUE(addr)) - printf("Error: Failed to create GNVS\n"); - - acpi_inc_align(ctx, sizeof(struct acpi_global_nvs)); - debug("ACPI: * FADT\n"); fadt = ctx->current; acpi_inc_align(ctx, sizeof(struct acpi_fadt));
Hi Simon, Bin,
-----"Simon Glass" sjg@chromium.org schrieb: -----
Betreff: [PATCH v2 08/57] x86: acpi: Support external GNVS tables
[snip]
[snip]
While testing the latest series of ACPI patches I saw strange behavior when booting Linux. Sometimes it would boot, sometimes it would hang, sometimes it would boot but show ACPI-related errors in dmesg.
Debugging showed that the reason is that the calculated length of the DSDT in the above code includes any additional bytes that were added for alignment, and those are not initialized. I gues the Linux ACPI implementation tries to decode those, and then something crashes.
Changing the above two lines to the following
acpi_inc(ctx, dsdt->length - sizeof(struct acpi_table_header)); dsdt->length = ctx->current - (void *)dsdt; acpi_align(ctx);
fixes the issue for me.
But the issue already exists in the previous code. Would it be better to send a patch which applies to the currrent master, or on top of the ACPI series?
regards, Wolfgang
Hi Wolfgang,
On Fri, 4 Sep 2020 at 08:16, Wolfgang Wallner wolfgang.wallner@br-automation.com wrote:
Hi Simon, Bin,
[snip]
[snip]
I think to the current master would be better. I have seen that problem so thank you for figuring it out!
Regards, SImon
Expand this to 4KB so that it is possible to add custom information to it. On Chromebooks this is used to pass verified-boot information.
arch/x86/include/asm/acpi/global_nvs.h | 2 +- arch/x86/include/asm/intel_gnvs.h | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/x86/include/asm/acpi/global_nvs.h b/arch/x86/include/asm/acpi/global_nvs.h index a552cf6374f..46383629cc5 100644 --- a/arch/x86/include/asm/acpi/global_nvs.h +++ b/arch/x86/include/asm/acpi/global_nvs.h @@ -16,6 +16,6 @@ * DSDT, since it is created by code, so ACPI_GNVS_ADDR is unused. */ #define ACPI_GNVS_ADDR 0xdeadbeef -#define ACPI_GNVS_SIZE 0x100 +#define ACPI_GNVS_SIZE 0x1000
#endif /* _ACPI_GNVS_H_ */ diff --git a/arch/x86/include/asm/intel_gnvs.h b/arch/x86/include/asm/intel_gnvs.h index e2d479d4f32..c1e9d65779f 100644 --- a/arch/x86/include/asm/intel_gnvs.h +++ b/arch/x86/include/asm/intel_gnvs.h @@ -36,6 +36,7 @@ struct __packed acpi_global_nvs { u8 unused2[0x1000 - 0x100]; /* Pad out to 4096 bytes */ #endif }; + #ifdef CONFIG_CHROMEOS check_member(acpi_global_nvs, chromeos, GNVS_CHROMEOS_ACPI_OFFSET); #endif
This device has a large set of ACPI tables. Bring these in from coreboot so that full functionality is available (apart from SMI).
Changes in v1: - Add NHLT audio support - Capitalise ACPI_OPS_PTR - Use OEM_TABLE_ID instead of ACPI_TABLE_CREATOR
board/google/chromebook_coral/Makefile | 1 + .../chromebook_coral/baseboard_dptf.asl | 71 +++++++++ board/google/chromebook_coral/coral.c | 135 ++++++++++++++++++ board/google/chromebook_coral/dsdt.asl | 60 ++++++++ .../google/chromebook_coral/variant_dptf.asl | 6 + board/google/chromebook_coral/variant_ec.h | 75 ++++++++++ board/google/chromebook_coral/variant_gpio.h | 63 ++++++++ include/bloblist.h | 5 + 8 files changed, 416 insertions(+) create mode 100644 board/google/chromebook_coral/baseboard_dptf.asl create mode 100644 board/google/chromebook_coral/dsdt.asl create mode 100644 board/google/chromebook_coral/variant_dptf.asl create mode 100644 board/google/chromebook_coral/variant_ec.h create mode 100644 board/google/chromebook_coral/variant_gpio.h
diff --git a/board/google/chromebook_coral/Makefile b/board/google/chromebook_coral/Makefile index 6a27ce3da1b..f7a0ca6cc0a 100644 --- a/board/google/chromebook_coral/Makefile +++ b/board/google/chromebook_coral/Makefile @@ -3,3 +3,4 @@ # Copyright 2019 Google LLC
obj-y += coral.o +obj-$(CONFIG_GENERATE_ACPI_TABLE) += dsdt.o diff --git a/board/google/chromebook_coral/baseboard_dptf.asl b/board/google/chromebook_coral/baseboard_dptf.asl new file mode 100644 index 00000000000..5da963a6705 --- /dev/null +++ b/board/google/chromebook_coral/baseboard_dptf.asl @@ -0,0 +1,71 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2015 Intel Corporation. + */ + +#define DPTF_CPU_PASSIVE 95 +#define DPTF_CPU_CRITICAL 105 + +#define DPTF_TSR0_SENSOR_ID 0 +#define DPTF_TSR0_SENSOR_NAME "Battery" +#define DPTF_TSR0_PASSIVE 120 +#define DPTF_TSR0_CRITICAL 125 + +#define DPTF_TSR1_SENSOR_ID 1 +#define DPTF_TSR1_SENSOR_NAME "Ambient" +#define DPTF_TSR1_PASSIVE 46 +#define DPTF_TSR1_CRITICAL 75 + +#define DPTF_TSR2_SENSOR_ID 2 +#define DPTF_TSR2_SENSOR_NAME "Charger" +#define DPTF_TSR2_PASSIVE 58 +#define DPTF_TSR2_CRITICAL 90 + +#define DPTF_ENABLE_CHARGER + +/* Charger performance states, board-specific values from charger and EC */ +Name (CHPS, Package () { + Package () { 0, 0, 0, 0, 255, 0xBB8, "mA", 0 }, /* 3A (MAX) */ + Package () { 0, 0, 0, 0, 24, 0x600, "mA", 0 }, /* 1.5A */ + Package () { 0, 0, 0, 0, 16, 0x400, "mA", 0 }, /* 1.0A */ + Package () { 0, 0, 0, 0, 8, 0x200, "mA", 0 }, /* 0.5A */ + Package () { 0, 0, 0, 0, 0, 0x000, "mA", 0 }, /* 0.0A */ +}) + +Name (DTRT, Package () { + /* CPU Throttle Effect on CPU */ + Package () { _SB.PCI0.TCPU, _SB.PCI0.TCPU, 100, 100, 0, 0, 0, 0 }, + + /* CPU Effect on Temp Sensor 0 */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR0, 100, 1200, 0, 0, 0, 0 }, + +#ifdef DPTF_ENABLE_CHARGER + /* Charger Effect on Temp Sensor 2 */ + Package () { _SB.DPTF.TCHG, _SB.DPTF.TSR2, 200, 300, 0, 0, 0, 0 }, +#endif + + /* CPU Effect on Temp Sensor 1 */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR1, 100, 150, 0, 0, 0, 0 }, +}) + +Name (MPPC, Package () +{ + 0x2, /* Revision */ + Package () { /* Power Limit 1 */ + 0, /* PowerLimitIndex, 0 for Power Limit 1 */ + 3000, /* PowerLimitMinimum */ + 12000, /* PowerLimitMaximum */ + 1000, /* TimeWindowMinimum */ + 1000, /* TimeWindowMaximum */ + 200 /* StepSize */ + }, + Package () { /* Power Limit 2 */ + 1, /* PowerLimitIndex, 1 for Power Limit 2 */ + 8000, /* PowerLimitMinimum */ + 15000, /* PowerLimitMaximum */ + 1000, /* TimeWindowMinimum */ + 1000, /* TimeWindowMaximum */ + 1000 /* StepSize */ + } +}) diff --git a/board/google/chromebook_coral/coral.c b/board/google/chromebook_coral/coral.c index 12d4fe63cb0..0699cf35107 100644 --- a/board/google/chromebook_coral/coral.c +++ b/board/google/chromebook_coral/coral.c @@ -4,7 +4,24 @@ */
#include <common.h> +#include <bloblist.h> #include <command.h> +#include <dm.h> +#include <log.h> +#include <acpi/acpigen.h> +#include <asm-generic/gpio.h> +#include <asm/acpi_nhlt.h> +#include <asm/intel_gnvs.h> +#include <asm/intel_pinctrl.h> +#include <dm/acpi.h> +#include "variant_gpio.h" + +struct cros_gpio_info { + const char *linux_name; + enum cros_gpio_t type; + int gpio_num; + int flags; +};
int arch_misc_init(void) { @@ -18,3 +35,121 @@ int board_run_command(const char *cmdline)
return 0; } + +int chromeos_get_gpio(const struct udevice *dev, const char *prop, + enum cros_gpio_t type, struct cros_gpio_info *info) +{ + struct udevice *pinctrl; + struct gpio_desc desc; + int ret; + + ret = gpio_request_by_name((struct udevice *)dev, prop, 0, &desc, 0); + if (ret == -ENOTBLK) + info->gpio_num = CROS_GPIO_VIRTUAL; + else if (ret) + return log_msg_ret("gpio", ret); + else + info->gpio_num = desc.offset; + info->linux_name = dev_read_string(desc.dev, "linux-name"); + if (!info->linux_name) + return log_msg_ret("linux-name", -ENOENT); + info->type = type; + /* Get ACPI pin from GPIO library if available */ + if (info->gpio_num != CROS_GPIO_VIRTUAL) { + pinctrl = dev_get_parent(desc.dev); + info->gpio_num = intel_pinctrl_get_acpi_pin(pinctrl, + info->gpio_num); + } + info->flags = desc.flags & GPIOD_ACTIVE_LOW ? CROS_GPIO_ACTIVE_LOW : + CROS_GPIO_ACTIVE_HIGH; + + return 0; +} + +static int chromeos_acpi_gpio_generate(const struct udevice *dev, + struct acpi_ctx *ctx) +{ + struct cros_gpio_info info[3]; + int count, i; + int ret; + + count = 3; + ret = chromeos_get_gpio(dev, "recovery-gpios", CROS_GPIO_REC, &info[0]); + if (ret) + return log_msg_ret("rec", ret); + ret = chromeos_get_gpio(dev, "write-protect-gpios", CROS_GPIO_WP, + &info[1]); + if (ret) + return log_msg_ret("rec", ret); + ret = chromeos_get_gpio(dev, "phase-enforce-gpios", CROS_GPIO_PE, + &info[2]); + if (ret) + return log_msg_ret("rec", ret); + acpigen_write_scope(ctx, "\"); + acpigen_write_name(ctx, "OIPG"); + acpigen_write_package(ctx, count); + for (i = 0; i < count; i++) { + acpigen_write_package(ctx, 4); + acpigen_write_integer(ctx, info[i].type); + acpigen_write_integer(ctx, info[i].flags); + acpigen_write_integer(ctx, info[i].gpio_num); + acpigen_write_string(ctx, info[i].linux_name); + acpigen_pop_len(ctx); + } + + acpigen_pop_len(ctx); + acpigen_pop_len(ctx); + + return 0; +} + +static int coral_write_acpi_tables(const struct udevice *dev, + struct acpi_ctx *ctx) +{ + struct acpi_global_nvs *gnvs; + struct nhlt *nhlt; + const char *oem_id = "coral"; + const char *oem_table_id = "coral"; + u32 oem_revision = 2; + int ret; + + gnvs = bloblist_find(BLOBLISTT_ACPI_GNVS, sizeof(*gnvs)); + if (!gnvs) + return log_msg_ret("bloblist", -ENOENT); + + nhlt = nhlt_init(); + if (!nhlt) + return -ENOMEM; + + ret = acpi_setup_nhlt(ctx, nhlt); + if (ret) + return log_msg_ret("setup", ret); + + /* Update NHLT GNVS Data */ + gnvs->nhla = (uintptr_t)ctx->current; + gnvs->nhll = nhlt_current_size(nhlt); + + ret = nhlt_serialise_oem_overrides(ctx, nhlt, oem_id, oem_table_id, + oem_revision); + if (ret) + return log_msg_ret("serialise", ret); + + return 0; +} + +struct acpi_ops coral_acpi_ops = { + .write_tables = coral_write_acpi_tables, + .inject_dsdt = chromeos_acpi_gpio_generate, +}; + +static const struct udevice_id coral_ids[] = { + { .compatible = "google,coral" }, + { } +}; + +U_BOOT_DRIVER(coral_drv) = { + .name = "coral", + .id = UCLASS_BOARD, + .of_match = coral_ids, + ACPI_OPS_PTR(&coral_acpi_ops) +}; diff --git a/board/google/chromebook_coral/dsdt.asl b/board/google/chromebook_coral/dsdt.asl new file mode 100644 index 00000000000..b51e0b05005 --- /dev/null +++ b/board/google/chromebook_coral/dsdt.asl @@ -0,0 +1,60 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2016 Google Inc. + */ + +#include "variant_ec.h" +#include "variant_gpio.h" +#include <acpi/acpi_table.h> +#include <asm/acpi/global_nvs.h> + +DefinitionBlock( + "dsdt.aml", + "DSDT", + 0x02, // DSDT revision: ACPI v2.0 and up + OEM_ID, + OEM_TABLE_ID, + 0x20110725 // OEM revision +) +{ + /* global NVS and variables */ + #include <asm/arch/acpi/globalnvs.asl> + + /* CPU */ + #include <asm/acpi/cpu.asl> + + Scope (_SB) { + Device (PCI0) + { + #include <asm/arch/acpi/northbridge.asl> + #include <asm/arch/acpi/southbridge.asl> + #include <asm/arch/acpi/pch_hda.asl> + } + } + + /* Chrome OS specific */ + #include <asm/acpi/chromeos.asl> + + /* Chipset specific sleep states */ + #include <asm/acpi/sleepstates.asl> + + /* Chrome OS Embedded Controller */ + Scope (_SB.PCI0.LPCB) + { + /* ACPI code for EC SuperIO functions */ + #include <asm/acpi/cros_ec/superio.asl> + /* ACPI code for EC functions */ + #include <asm/acpi/cros_ec/ec.asl> + } + + /* Dynamic Platform Thermal Framework */ + Scope (_SB) + { + /* Per board variant specific definitions. */ + #include "variant_dptf.asl" + /* Include soc specific DPTF changes */ + #include <asm/arch/acpi/dptf.asl> + /* Include common dptf ASL files */ + #include <asm/acpi/dptf/dptf.asl> + } +} diff --git a/board/google/chromebook_coral/variant_dptf.asl b/board/google/chromebook_coral/variant_dptf.asl new file mode 100644 index 00000000000..943ebeaac26 --- /dev/null +++ b/board/google/chromebook_coral/variant_dptf.asl @@ -0,0 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2016 Google Inc. + */ + +#include "baseboard_dptf.asl" diff --git a/board/google/chromebook_coral/variant_ec.h b/board/google/chromebook_coral/variant_ec.h new file mode 100644 index 00000000000..7d5e1a674cf --- /dev/null +++ b/board/google/chromebook_coral/variant_ec.h @@ -0,0 +1,75 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2019 Google LLC +/* + * Taken from coreboot file of the same name + */ + +#ifndef VARIANT_EC_H +#define VARIANT_EC_H + +#include "variant_gpio.h" +#include <ec_commands.h> + +#define MAINBOARD_EC_SCI_EVENTS \ + (EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_CLOSED) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_OPEN) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_AC_CONNECTED) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_AC_DISCONNECTED) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_LOW) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_CRITICAL) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_STATUS) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_THERMAL_THRESHOLD) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_THROTTLE_START) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_THROTTLE_STOP) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_USB_CHARGER) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_MKBP) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_PD_MCU) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_MODE_CHANGE)) + +#define MAINBOARD_EC_SMI_EVENTS \ + (EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_CLOSED)) + +/* EC can wake from S5 with lid or power button */ +#define MAINBOARD_EC_S5_WAKE_EVENTS \ + (EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_OPEN) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_POWER_BUTTON)) + +/* EC can wake from S3 with lid or power button or key press */ +#define MAINBOARD_EC_S3_WAKE_EVENTS \ + (MAINBOARD_EC_S5_WAKE_EVENTS |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_KEY_PRESSED)) + +#define MAINBOARD_EC_S0IX_WAKE_EVENTS (MAINBOARD_EC_S3_WAKE_EVENTS) + +/* Log EC wake events plus EC shutdown events */ +#define MAINBOARD_EC_LOG_EVENTS \ + (EC_HOST_EVENT_MASK(EC_HOST_EVENT_THERMAL_SHUTDOWN) | \ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_SHUTDOWN) | \ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_PANIC)) + +/* + * ACPI related definitions for ASL code. + */ + +/* Enable EC backed ALS device in ACPI */ +#define EC_ENABLE_ALS_DEVICE + +/* Enable EC backed PD MCU device in ACPI */ +#define EC_ENABLE_PD_MCU_DEVICE + +/* Enable LID switch and provide wake pin for EC */ +#define EC_ENABLE_LID_SWITCH +#define EC_ENABLE_WAKE_PIN GPE_EC_WAKE + +#define EC_ENABLE_TBMC_DEVICE + +#define SIO_EC_MEMMAP_ENABLE /* EC Memory Map Resources */ +#define SIO_EC_HOST_ENABLE /* EC Host Interface Resources */ +#define SIO_EC_ENABLE_PS2K /* Enable PS/2 Keyboard */ + +/* Enable EC backed Keyboard Backlight in ACPI */ +#define EC_ENABLE_KEYBOARD_BACKLIGHT + +#endif diff --git a/board/google/chromebook_coral/variant_gpio.h b/board/google/chromebook_coral/variant_gpio.h new file mode 100644 index 00000000000..f516d88be5c --- /dev/null +++ b/board/google/chromebook_coral/variant_gpio.h @@ -0,0 +1,63 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2019 Google LLC + * + * Taken from coreboot file of the same name + */ + +#ifndef BASEBOARD_GPIO_H +#define BASEBOARD_GPIO_H + +#include <asm/arch/gpio.h> +#include <ec_commands.h> + +/* + * GPIO_11 for SCI is routed to GPE0_DW1 and maps to group GPIO_GPE_N_31_0 + * which is North community + */ +#define EC_SCI_GPI GPE0_DW1_11 + +/* EC SMI */ +#define EC_SMI_GPI GPIO_49 + +/* + * On lidopen/lidclose GPIO_22 from North Community gets toggled and + * is used in _PRW to wake up device from sleep. GPIO_22 maps to + * group GPIO_GPE_N_31_0 and the pad is configured as SCI with + * EDGE_SINGLE and INVERT. + */ +#define GPE_EC_WAKE GPE0_DW1_22 + +/* Write Protect and indication if EC is in RW code. */ +#define GPIO_PCH_WP GPIO_75 +#define GPIO_EC_IN_RW GPIO_41 +/* Determine if board is in final shipping mode. */ +#define GPIO_SHIP_MODE GPIO_10 + +/* Memory SKU GPIOs. */ +#define MEM_CONFIG3 GPIO_45 +#define MEM_CONFIG2 GPIO_38 +#define MEM_CONFIG1 GPIO_102 +#define MEM_CONFIG0 GPIO_101 + +/* DMIC_CONFIG_PIN: High for 1-DMIC and low for 4-DMIC's */ +#define DMIC_CONFIG_PIN GPIO_17 + +#ifndef __ASSEMBLY__ + +enum cros_gpio_t { + CROS_GPIO_REC = 1, /* Recovery */ + + /* Developer; * deprecated (chromium:942901) */ + CROS_GPIO_DEPRECATED_DEV = 2, + CROS_GPIO_WP = 3, /* Write Protect */ + CROS_GPIO_PE = 4, /* Phase enforcement for final product */ + + CROS_GPIO_ACTIVE_LOW = 0, + CROS_GPIO_ACTIVE_HIGH = 1, + + CROS_GPIO_VIRTUAL = -1, +}; +#endif + +#endif /* BASEBOARD_GPIO_H */ diff --git a/include/bloblist.h b/include/bloblist.h index 609ac421d66..bbe0a35d5a2 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -27,6 +27,11 @@ enum bloblist_tag_t { BLOBLISTT_SPL_HANDOFF, /* Hand-off info from SPL */ BLOBLISTT_VBOOT_CTX, /* Chromium OS verified boot context */ BLOBLISTT_VBOOT_HANDOFF, /* Chromium OS internal handoff info */ + /* + * Advanced Configuration and Power Interface Global Non-Volatile + * Sleeping table. This forms part of the ACPI tables passed to Linux. + */ + BLOBLISTT_ACPI_GNVS, };
A 'Power Resource for Wake' list the resources a device depends on for wake. Add a function to generate this.
include/acpi/acpigen.h | 10 ++++++++++ lib/acpi/acpigen.c | 10 ++++++++++ test/dm/acpigen.c | 30 ++++++++++++++++++++++++++++++ 3 files changed, 50 insertions(+)
diff --git a/include/acpi/acpigen.h b/include/acpi/acpigen.h index 228ac9c404b..a9b70123c0a 100644 --- a/include/acpi/acpigen.h +++ b/include/acpi/acpigen.h @@ -563,4 +563,14 @@ int acpigen_set_enable_tx_gpio(struct acpi_ctx *ctx, u32 tx_state_val, const char *dw0_read, const char *dw0_write, struct acpi_gpio *gpio, bool enable);
+/** + * acpigen_write_prw() - Write a power resource for wake (_PRW) + * + * @ctx: ACPI context pointer + * @wake: GPE that wakes up the device + * @level: Deepest power system sleeping state that can be entered while still + * providing wake functionality + */ +void acpigen_write_prw(struct acpi_ctx *ctx, uint wake, uint level); + #endif diff --git a/lib/acpi/acpigen.c b/lib/acpi/acpigen.c index c609ef4daa4..527de89b1e1 100644 --- a/lib/acpi/acpigen.c +++ b/lib/acpi/acpigen.c @@ -426,6 +426,16 @@ void acpigen_write_register_resource(struct acpi_ctx *ctx, acpigen_write_resourcetemplate_footer(ctx); }
+void acpigen_write_prw(struct acpi_ctx *ctx, uint wake, uint level) +{ + /* Name (_PRW, Package () { wake, level } */ + acpigen_write_name(ctx, "_PRW"); + acpigen_write_package(ctx, 2); + acpigen_write_integer(ctx, wake); + acpigen_write_integer(ctx, level); + acpigen_pop_len(ctx); +} + /* * ToUUID(uuid) * diff --git a/test/dm/acpigen.c b/test/dm/acpigen.c index 1b2767e732d..16ae7025856 100644 --- a/test/dm/acpigen.c +++ b/test/dm/acpigen.c @@ -1097,3 +1097,33 @@ static int dm_test_acpi_write_name(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_acpi_write_name, 0); + +/* Test emitting a string */ +static int dm_test_acpi_write_prw(struct unit_test_state *uts) +{ + struct acpi_ctx *ctx; + u8 *ptr; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_prw(ctx, 5, 3); + ut_asserteq(NAME_OP, *ptr++); + + ut_asserteq_strn("_PRW", (char *)ptr); + ptr += 4; + ut_asserteq(PACKAGE_OP, *ptr++); + ut_asserteq(8, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq(2, *ptr++); + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(5, *ptr++); + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(3, *ptr++); + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_prw, 0);
Add functions to support generating ACPI code for condition checks and return values.
include/acpi/acpigen.h | 93 ++++++++++++++++++++++++++++++++++++++++++ lib/acpi/acpigen.c | 68 ++++++++++++++++++++++++++++++ test/dm/acpigen.c | 93 +++++++++++++++++++++++++++++++++++++++++- 3 files changed, 253 insertions(+), 1 deletion(-)
diff --git a/include/acpi/acpigen.h b/include/acpi/acpigen.h index a9b70123c0a..fa9409e3528 100644 --- a/include/acpi/acpigen.h +++ b/include/acpi/acpigen.h @@ -52,12 +52,24 @@ enum { LOCAL5_OP = 0x65, LOCAL6_OP = 0x66, LOCAL7_OP = 0x67, + ARG0_OP = 0x68, + ARG1_OP = 0x69, + ARG2_OP = 0x6a, + ARG3_OP = 0x6b, + ARG4_OP = 0x6c, + ARG5_OP = 0x6d, + ARG6_OP = 0x6e, STORE_OP = 0x70, AND_OP = 0x7b, OR_OP = 0x7d, NOT_OP = 0x80, DEVICE_OP = 0x82, POWER_RES_OP = 0x84, + LEQUAL_OP = 0x93, + TO_BUFFER_OP = 0x96, + TO_INTEGER_OP = 0x99, + IF_OP = 0xa0, + ELSE_OP = 0xa1, RETURN_OP = 0xa4, };
@@ -573,4 +585,85 @@ int acpigen_set_enable_tx_gpio(struct acpi_ctx *ctx, u32 tx_state_val, */ void acpigen_write_prw(struct acpi_ctx *ctx, uint wake, uint level);
+/** + * acpigen_write_if() - Write an If block + * + * This requires a call to acpigen_pop_len() to complete the block + * + * @ctx: ACPI context pointer + */ +void acpigen_write_if(struct acpi_ctx *ctx); + +/** + * acpigen_write_if_lequal_op_int() - Write comparison between op and integer + * + * Generates ACPI code for checking if operand1 and operand2 are equal + * + * If (Lequal (op, val)) + * + * @ctx: ACPI context pointer + * @op: Operand to check + * @val: Value to check against + */ +void acpigen_write_if_lequal_op_int(struct acpi_ctx *ctx, uint op, u64 val); + +/** + * acpigen_write_else() - Write an Ef block + * + * This requires a call to acpigen_pop_len() to complete the block + * + * @ctx: ACPI context pointer + */ +void acpigen_write_else(struct acpi_ctx *ctx); + +/** + * acpigen_write_to_buffer() - Write a ToBuffer operation + * + * E.g.: to generate: ToBuffer (Arg0, Local0) + * use acpigen_write_to_buffer(ctx, ARG0_OP, LOCAL0_OP) + * + * @ctx: ACPI context pointer + * @src: Source argument + * @dst: Destination argument + */ +void acpigen_write_to_buffer(struct acpi_ctx *ctx, uint src, uint dst); + +/** + * acpigen_write_to_integer() - Write a ToInteger operation + * + * E.g.: to generate: ToInteger (Arg0, Local0) + * use acpigen_write_to_integer(ctx, ARG0_OP, LOCAL0_OP) + * + * @ctx: ACPI context pointer + * @src: Source argument + * @dst: Destination argument + */ +void acpigen_write_to_integer(struct acpi_ctx *ctx, uint src, uint dst); + +/** + * acpigen_write_return_byte_buffer() - Write a return of a byte buffer + * + * @ctx: ACPI context pointer + * @arr: Array of bytes to return + * @size: Number of bytes + */ +void acpigen_write_return_byte_buffer(struct acpi_ctx *ctx, u8 *arr, + size_t size); + +/** + * acpigen_write_return_singleton_buffer() - Write a return of a 1-byte buffer + * + * @ctx: ACPI context pointer + * @arg: Byte to return + */ +void acpigen_write_return_singleton_buffer(struct acpi_ctx *ctx, uint arg); + +/** + * acpigen_write_return_byte() - Write a return of a byte + * + * @ctx: ACPI context pointer + * @arg: Byte to return + */ +void acpigen_write_return_byte(struct acpi_ctx *ctx, uint arg); + #endif diff --git a/lib/acpi/acpigen.c b/lib/acpi/acpigen.c index 527de89b1e1..2518bf83dda 100644 --- a/lib/acpi/acpigen.c +++ b/lib/acpi/acpigen.c @@ -541,6 +541,74 @@ void acpigen_write_debug_string(struct acpi_ctx *ctx, const char *str) acpigen_emit_ext_op(ctx, DEBUG_OP); }
+void acpigen_write_if(struct acpi_ctx *ctx) +{ + acpigen_emit_byte(ctx, IF_OP); + acpigen_write_len_f(ctx); +} + +void acpigen_write_if_lequal_op_int(struct acpi_ctx *ctx, uint op, u64 val) +{ + acpigen_write_if(ctx); + acpigen_emit_byte(ctx, LEQUAL_OP); + acpigen_emit_byte(ctx, op); + acpigen_write_integer(ctx, val); +} + +void acpigen_write_else(struct acpi_ctx *ctx) +{ + acpigen_emit_byte(ctx, ELSE_OP); + acpigen_write_len_f(ctx); +} + +void acpigen_write_to_buffer(struct acpi_ctx *ctx, uint src, uint dst) +{ + acpigen_emit_byte(ctx, TO_BUFFER_OP); + acpigen_emit_byte(ctx, src); + acpigen_emit_byte(ctx, dst); +} + +void acpigen_write_to_integer(struct acpi_ctx *ctx, uint src, uint dst) +{ + acpigen_emit_byte(ctx, TO_INTEGER_OP); + acpigen_emit_byte(ctx, src); + acpigen_emit_byte(ctx, dst); +} + +void acpigen_write_byte_buffer(struct acpi_ctx *ctx, u8 *arr, size_t size) +{ + size_t i; + + acpigen_emit_byte(ctx, BUFFER_OP); + acpigen_write_len_f(ctx); + acpigen_write_integer(ctx, size); + + for (i = 0; i < size; i++) + acpigen_emit_byte(ctx, arr[i]); + + acpigen_pop_len(ctx); +} + +void acpigen_write_return_byte_buffer(struct acpi_ctx *ctx, u8 *arr, + size_t size) +{ + acpigen_emit_byte(ctx, RETURN_OP); + acpigen_write_byte_buffer(ctx, arr, size); +} + +void acpigen_write_return_singleton_buffer(struct acpi_ctx *ctx, uint arg) +{ + u8 buf = arg; + + acpigen_write_return_byte_buffer(ctx, &buf, 1); +} + +void acpigen_write_return_byte(struct acpi_ctx *ctx, uint arg) +{ + acpigen_emit_byte(ctx, RETURN_OP); + acpigen_write_byte(ctx, arg); +} + /** * acpigen_get_dw0_in_local5() - Generate code to put dw0 cfg0 in local5 * diff --git a/test/dm/acpigen.c b/test/dm/acpigen.c index 16ae7025856..cce19f11209 100644 --- a/test/dm/acpigen.c +++ b/test/dm/acpigen.c @@ -1098,7 +1098,7 @@ static int dm_test_acpi_write_name(struct unit_test_state *uts) } DM_TEST(dm_test_acpi_write_name, 0);
-/* Test emitting a string */ +/* Test emitting a _PRW component */ static int dm_test_acpi_write_prw(struct unit_test_state *uts) { struct acpi_ctx *ctx; @@ -1127,3 +1127,94 @@ static int dm_test_acpi_write_prw(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_acpi_write_prw, 0); + +/* Test emitting writing conditionals */ +static int dm_test_acpi_write_cond(struct unit_test_state *uts) +{ + struct acpi_ctx *ctx; + u8 *ptr; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_if(ctx); + acpigen_pop_len(ctx); + ut_asserteq(IF_OP, *ptr++); + ut_asserteq(3, acpi_test_get_length(ptr)); + ptr += 3; + + acpigen_write_else(ctx); + acpigen_pop_len(ctx); + ut_asserteq(ELSE_OP, *ptr++); + ut_asserteq(3, acpi_test_get_length(ptr)); + ptr += 3; + + acpigen_write_if_lequal_op_int(ctx, LOCAL1_OP, 5); + acpigen_pop_len(ctx); + ut_asserteq(IF_OP, *ptr++); + ut_asserteq(7, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq(LEQUAL_OP, *ptr++); + ut_asserteq(LOCAL1_OP, *ptr++); + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(5, *ptr++); + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_cond, 0); + +/* Test emitting writing return values and ToBuffer/ToInteger */ +static int dm_test_acpi_write_return(struct unit_test_state *uts) +{ + int len = sizeof(TEST_STRING); + struct acpi_ctx *ctx; + u8 *ptr; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_to_buffer(ctx, ARG0_OP, LOCAL0_OP); + ut_asserteq(TO_BUFFER_OP, *ptr++); + ut_asserteq(ARG0_OP, *ptr++); + ut_asserteq(LOCAL0_OP, *ptr++); + + acpigen_write_to_integer(ctx, ARG0_OP, LOCAL0_OP); + ut_asserteq(TO_INTEGER_OP, *ptr++); + ut_asserteq(ARG0_OP, *ptr++); + ut_asserteq(LOCAL0_OP, *ptr++); + + acpigen_write_return_byte_buffer(ctx, (u8 *)TEST_STRING, len); + ut_asserteq(RETURN_OP, *ptr++); + ut_asserteq(BUFFER_OP, *ptr++); + ut_asserteq(5 + len, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(len, *ptr++); + ut_asserteq_mem(TEST_STRING, ptr, len); + ptr += len; + + acpigen_write_return_singleton_buffer(ctx, 123); + len = 1; + ut_asserteq(RETURN_OP, *ptr++); + ut_asserteq(BUFFER_OP, *ptr++); + ut_asserteq(4 + len, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq(ONE_OP, *ptr++); + ut_asserteq(123, *ptr++); + + acpigen_write_return_byte(ctx, 43); + ut_asserteq(RETURN_OP, *ptr++); + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(43, *ptr++); + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_return, 0);
Add a function to generate ACPI code for a _DSM method for a device. This includes functions for starting and ending each part of the _DSM.
include/acpi/acpi_device.h | 14 +++++ include/acpi/acpigen.h | 99 +++++++++++++++++++++++++++++ lib/acpi/acpi_device.c | 43 +++++++++++++ lib/acpi/acpigen.c | 54 ++++++++++++++++ test/dm/acpigen.c | 126 +++++++++++++++++++++++++++++++++++++ 5 files changed, 336 insertions(+)
diff --git a/include/acpi/acpi_device.h b/include/acpi/acpi_device.h index 11461e168d3..a5b12217820 100644 --- a/include/acpi/acpi_device.h +++ b/include/acpi/acpi_device.h @@ -28,6 +28,9 @@ struct udevice; /* Length of a full path to an ACPI device */ #define ACPI_PATH_MAX 30
+/* UUID for an I2C _DSM method */ +#define ACPI_DSM_I2C_HID_UUID "3cdff6f7-4267-4555-ad05-b30a3d8938de" + /* Values that can be returned for ACPI device _STA method */ enum acpi_dev_status { ACPI_DSTATUS_PRESENT = BIT(0), @@ -319,6 +322,17 @@ int acpi_device_write_gpio_desc(struct acpi_ctx *ctx, int acpi_device_write_interrupt_or_gpio(struct acpi_ctx *ctx, struct udevice *dev, const char *prop);
+/** + * acpi_device_write_dsm_i2c_hid() - Write a device-specific method for HID + * + * This writes a DSM for an I2C Human-Interface Device based on the config + * provided + * + * @hid_desc_reg_offset: HID register offset + */ +int acpi_device_write_dsm_i2c_hid(struct acpi_ctx *ctx, + int hid_desc_reg_offset); + /** * acpi_device_write_i2c_dev() - Write an I2C device to ACPI * diff --git a/include/acpi/acpigen.h b/include/acpi/acpigen.h index fa9409e3528..34b3115bc9c 100644 --- a/include/acpi/acpigen.h +++ b/include/acpi/acpigen.h @@ -666,4 +666,103 @@ void acpigen_write_return_singleton_buffer(struct acpi_ctx *ctx, uint arg); */ void acpigen_write_return_byte(struct acpi_ctx *ctx, uint arg);
+/** + * acpigen_write_dsm_start() - Start a _DSM method + * + * Generate ACPI AML code to start the _DSM method. + * + * The functions need to be called in the correct sequence as below. + * + * Within the <generate-code-here> region, Local0 and Local1 must be are left + * untouched, but Local2-Local7 can be used + * + * Arguments passed into _DSM method: + * Arg0 = UUID + * Arg1 = Revision + * Arg2 = Function index + * Arg3 = Function-specific arguments + * + * AML code generated looks like this: + * Method (_DSM, 4, Serialized) { -- acpigen_write_dsm_start) + * ToBuffer (Arg0, Local0) + * If (LEqual (Local0, ToUUID(uuid))) { -- acpigen_write_dsm_uuid_start + * ToInteger (Arg2, Local1) + * If (LEqual (Local1, 0)) { -- acpigen_write_dsm_uuid_start_cond + * <generate-code-here> + * } -- acpigen_write_dsm_uuid_end_cond + * ... + * If (LEqual (Local1, n)) { -- acpigen_write_dsm_uuid_start_cond + * <generate-code-here> + * } -- acpigen_write_dsm_uuid_end_cond + * Return (Buffer (One) { 0x0 }) + * } -- acpigen_write_dsm_uuid_end + * ... + * If (LEqual (Local0, ToUUID(uuidn))) { + * ... + * } + * Return (Buffer (One) { 0x0 }) -- acpigen_write_dsm_end + * } + * + * @ctx: ACPI context pointer + */ +void acpigen_write_dsm_start(struct acpi_ctx *ctx); + +/** + * acpigen_write_dsm_uuid_start() - Start a new UUID block + * + * This starts generation of code to handle a particular UUID: + * + * If (LEqual (Local0, ToUUID(uuid))) { + * ToInteger (Arg2, Local1) + * + * @ctx: ACPI context pointer + */ +int acpigen_write_dsm_uuid_start(struct acpi_ctx *ctx, const char *uuid); + +/** + * acpigen_write_dsm_uuid_start_cond() - Start a new condition block + * + * This starts generation of condition-checking code to handle a particular + * function: + * + * If (LEqual (Local1, i)) + * + * @ctx: ACPI context pointer + */ +void acpigen_write_dsm_uuid_start_cond(struct acpi_ctx *ctx, int seq); + +/** + * acpigen_write_dsm_uuid_end_cond() - Start a new condition block + * + * This ends generation of condition-checking code to handle a particular + * function: + * + * } + * + * @ctx: ACPI context pointer + */ +void acpigen_write_dsm_uuid_end_cond(struct acpi_ctx *ctx); + +/** + * acpigen_write_dsm_uuid_end() - End a UUID block + * + * This ends generation of code to handle a particular UUID: + * + * Return (Buffer (One) { 0x0 }) + * + * @ctx: ACPI context pointer + */ +void acpigen_write_dsm_uuid_end(struct acpi_ctx *ctx); + +/** + * acpigen_write_dsm_end() - End a _DSM method + * + * This ends generates of the _DSM block: + * + * Return (Buffer (One) { 0x0 }) + * + * @ctx: ACPI context pointer + */ +void acpigen_write_dsm_end(struct acpi_ctx *ctx); + #endif diff --git a/lib/acpi/acpi_device.c b/lib/acpi/acpi_device.c index 3c75b6d9629..8248664a10a 100644 --- a/lib/acpi/acpi_device.c +++ b/lib/acpi/acpi_device.c @@ -487,6 +487,49 @@ int acpi_device_add_power_res(struct acpi_ctx *ctx, u32 tx_state_val, return 0; }
+int acpi_device_write_dsm_i2c_hid(struct acpi_ctx *ctx, + int hid_desc_reg_offset) +{ + int ret; + + acpigen_write_dsm_start(ctx); + ret = acpigen_write_dsm_uuid_start(ctx, ACPI_DSM_I2C_HID_UUID); + if (ret) + return log_ret(ret); + + acpigen_write_dsm_uuid_start_cond(ctx, 0); + /* ToInteger (Arg1, Local2) */ + acpigen_write_to_integer(ctx, ARG1_OP, LOCAL2_OP); + /* If (LEqual (Local2, 0x0)) */ + acpigen_write_if_lequal_op_int(ctx, LOCAL2_OP, 0x0); + /* Return (Buffer (One) { 0x1f }) */ + acpigen_write_return_singleton_buffer(ctx, 0x1f); + acpigen_pop_len(ctx); /* Pop : If */ + /* Else */ + acpigen_write_else(ctx); + /* If (LEqual (Local2, 0x1)) */ + acpigen_write_if_lequal_op_int(ctx, LOCAL2_OP, 0x1); + /* Return (Buffer (One) { 0x3f }) */ + acpigen_write_return_singleton_buffer(ctx, 0x3f); + acpigen_pop_len(ctx); /* Pop : If */ + /* Else */ + acpigen_write_else(ctx); + /* Return (Buffer (One) { 0x0 }) */ + acpigen_write_return_singleton_buffer(ctx, 0x0); + acpigen_pop_len(ctx); /* Pop : Else */ + acpigen_pop_len(ctx); /* Pop : Else */ + acpigen_write_dsm_uuid_end_cond(ctx); + + acpigen_write_dsm_uuid_start_cond(ctx, 1); + acpigen_write_return_byte(ctx, hid_desc_reg_offset); + acpigen_write_dsm_uuid_end_cond(ctx); + + acpigen_write_dsm_uuid_end(ctx); + acpigen_write_dsm_end(ctx); + + return 0; +} + /* ACPI 6.3 section 6.4.3.8.2.1 - I2cSerialBus() */ static void acpi_device_write_i2c(struct acpi_ctx *ctx, const struct acpi_i2c *i2c) diff --git a/lib/acpi/acpigen.c b/lib/acpi/acpigen.c index 2518bf83dda..d859f378413 100644 --- a/lib/acpi/acpigen.c +++ b/lib/acpi/acpigen.c @@ -609,6 +609,60 @@ void acpigen_write_return_byte(struct acpi_ctx *ctx, uint arg) acpigen_write_byte(ctx, arg); }
+void acpigen_write_dsm_start(struct acpi_ctx *ctx) +{ + /* Method (_DSM, 4, Serialized) */ + acpigen_write_method_serialized(ctx, "_DSM", 4); + + /* ToBuffer (Arg0, Local0) */ + acpigen_write_to_buffer(ctx, ARG0_OP, LOCAL0_OP); +} + +int acpigen_write_dsm_uuid_start(struct acpi_ctx *ctx, const char *uuid) +{ + int ret; + + /* If (LEqual (Local0, ToUUID(uuid))) */ + acpigen_write_if(ctx); + acpigen_emit_byte(ctx, LEQUAL_OP); + acpigen_emit_byte(ctx, LOCAL0_OP); + ret = acpigen_write_uuid(ctx, uuid); + if (ret) + return log_msg_ret("uuid", ret); + + /* ToInteger (Arg2, Local1) */ + acpigen_write_to_integer(ctx, ARG2_OP, LOCAL1_OP); + + return 0; +} + +void acpigen_write_dsm_uuid_start_cond(struct acpi_ctx *ctx, int seq) +{ + /* If (LEqual (Local1, i)) */ + acpigen_write_if_lequal_op_int(ctx, LOCAL1_OP, seq); +} + +void acpigen_write_dsm_uuid_end_cond(struct acpi_ctx *ctx) +{ + acpigen_pop_len(ctx); /* If */ +} + +void acpigen_write_dsm_uuid_end(struct acpi_ctx *ctx) +{ + /* Default case: Return (Buffer (One) { 0x0 }) */ + acpigen_write_return_singleton_buffer(ctx, 0x0); + + acpigen_pop_len(ctx); /* If (LEqual (Local0, ToUUID(uuid))) */ +} + +void acpigen_write_dsm_end(struct acpi_ctx *ctx) +{ + /* Return (Buffer (One) { 0x0 }) */ + acpigen_write_return_singleton_buffer(ctx, 0x0); + + acpigen_pop_len(ctx); /* Method _DSM */ +} + /** * acpigen_get_dw0_in_local5() - Generate code to put dw0 cfg0 in local5 * diff --git a/test/dm/acpigen.c b/test/dm/acpigen.c index cce19f11209..381fcb97022 100644 --- a/test/dm/acpigen.c +++ b/test/dm/acpigen.c @@ -10,6 +10,7 @@ #include <dm.h> #include <irq.h> #include <malloc.h> +#include <uuid.h> #include <acpi/acpigen.h> #include <acpi/acpi_device.h> #include <acpi/acpi_table.h> @@ -1218,3 +1219,128 @@ static int dm_test_acpi_write_return(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_acpi_write_return, 0); + +/* Test emitting a DSM for an I2C HID */ +static int dm_test_acpi_write_i2c_dsm(struct unit_test_state *uts) +{ + char uuid_str[UUID_STR_LEN + 1]; + const int reg_offset = 0x20; + struct acpi_ctx *ctx; + u8 *ptr; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + ut_assertok(acpi_device_write_dsm_i2c_hid(ctx, reg_offset)); + + /* acpigen_write_dsm_start() */ + ut_asserteq(METHOD_OP, *ptr++); + ut_asserteq(0x78, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq_strn("_DSM", (char *)ptr); + ptr += 4; + ut_asserteq(ACPI_METHOD_SERIALIZED_MASK | 4, *ptr++); + + ut_asserteq(TO_BUFFER_OP, *ptr++); + ut_asserteq(ARG0_OP, *ptr++); + ut_asserteq(LOCAL0_OP, *ptr++); + + /* acpigen_write_dsm_uuid_start() */ + ut_asserteq(IF_OP, *ptr++); + ut_asserteq(0x65, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq(LEQUAL_OP, *ptr++); + ut_asserteq(LOCAL0_OP, *ptr++); + + ut_asserteq(BUFFER_OP, *ptr++); + ut_asserteq(UUID_BIN_LEN + 6, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq(WORD_PREFIX, *ptr++); + ut_asserteq(UUID_BIN_LEN, get_unaligned((u16 *)ptr)); + ptr += 2; + uuid_bin_to_str(ptr, uuid_str, UUID_STR_FORMAT_GUID); + ut_asserteq_str(ACPI_DSM_I2C_HID_UUID, uuid_str); + ptr += UUID_BIN_LEN; + + ut_asserteq(TO_INTEGER_OP, *ptr++); + ut_asserteq(ARG2_OP, *ptr++); + ut_asserteq(LOCAL1_OP, *ptr++); + + /* acpigen_write_dsm_uuid_start_cond() */ + ut_asserteq(IF_OP, *ptr++); + ut_asserteq(0x34, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq(LEQUAL_OP, *ptr++); + ut_asserteq(LOCAL1_OP, *ptr++); + ut_asserteq(ZERO_OP, *ptr++); + + /* + * See code from acpi_device_write_dsm_i2c_hid(). We don't check every + * piece + */ + ut_asserteq(TO_INTEGER_OP, *ptr++); + ut_asserteq(ARG1_OP, *ptr++); + ut_asserteq(LOCAL2_OP, *ptr++); + + ut_asserteq(IF_OP, *ptr++); + ut_asserteq(0xd, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq(LEQUAL_OP, *ptr++); + ut_asserteq(LOCAL2_OP, *ptr++); + ut_asserteq(ZERO_OP, *ptr++); /* function 0 */ + + ut_asserteq(RETURN_OP, *ptr++); + ut_asserteq(BUFFER_OP, *ptr++); + ptr += 5; + + ut_asserteq(ELSE_OP, *ptr++); + ptr += 3; + + ut_asserteq(IF_OP, *ptr++); + ut_asserteq(0xd, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq(LEQUAL_OP, *ptr++); + ut_asserteq(LOCAL2_OP, *ptr++); + ut_asserteq(ONE_OP, *ptr++); + + ut_asserteq(RETURN_OP, *ptr++); + ut_asserteq(BUFFER_OP, *ptr++); + ptr += 5; + + ut_asserteq(ELSE_OP, *ptr++); + ptr += 3; + + ut_asserteq(RETURN_OP, *ptr++); + ut_asserteq(BUFFER_OP, *ptr++); + ptr += 5; + + /* acpigen_write_dsm_uuid_start_cond() */ + ut_asserteq(IF_OP, *ptr++); + ut_asserteq(9, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq(LEQUAL_OP, *ptr++); + ut_asserteq(LOCAL1_OP, *ptr++); + ut_asserteq(ONE_OP, *ptr++); /* function 1 */ + + ut_asserteq(RETURN_OP, *ptr++); + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(reg_offset, *ptr++); + + /* acpigen_write_dsm_uuid_end() */ + ut_asserteq(RETURN_OP, *ptr++); + ut_asserteq(BUFFER_OP, *ptr++); + ptr += 5; + + /* acpigen_write_dsm_end */ + ut_asserteq(RETURN_OP, *ptr++); + ut_asserteq(BUFFER_OP, *ptr++); + ptr += 5; + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_i2c_dsm, 0); +
This function currently accepts the IRQ-polarity type. Fix it to use the GPIO type instead.
Changes in v2: - add new patch to fix polarity type in acpi_dp_add_gpio()
drivers/sound/max98357a.c | 2 +- include/acpi/acpi_dp.h | 2 +- lib/acpi/acpi_dp.c | 4 ++-- test/dm/acpi_dp.c | 4 ++-- 4 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/sound/max98357a.c b/drivers/sound/max98357a.c index 841bc6ef682..827262d235c 100644 --- a/drivers/sound/max98357a.c +++ b/drivers/sound/max98357a.c @@ -81,7 +81,7 @@ static int max98357a_acpi_fill_ssdt(const struct udevice *dev, dp = acpi_dp_new_table("_DSD"); acpi_dp_add_gpio(dp, "sdmode-gpio", path, 0, 0, priv->sdmode_gpio.flags & GPIOD_ACTIVE_LOW ? - ACPI_IRQ_ACTIVE_LOW : ACPI_IRQ_ACTIVE_HIGH); + ACPI_GPIO_ACTIVE_LOW : ACPI_GPIO_ACTIVE_HIGH); acpi_dp_add_integer(dp, "sdmode-delay", dev_read_u32_default(dev, "sdmode-delay", 0)); acpi_dp_write(ctx, dp); diff --git a/include/acpi/acpi_dp.h b/include/acpi/acpi_dp.h index 0b514bce59c..5e539b1d218 100644 --- a/include/acpi/acpi_dp.h +++ b/include/acpi/acpi_dp.h @@ -221,7 +221,7 @@ struct acpi_dp *acpi_dp_add_child(struct acpi_dp *dp, const char *name, */ struct acpi_dp *acpi_dp_add_gpio(struct acpi_dp *dp, const char *name, const char *ref, int index, int pin, - enum acpi_irq_polarity polarity); + enum acpi_gpio_polarity polarity);
/** * acpi_dp_write() - Write Device Property hierarchy and clean up resources diff --git a/lib/acpi/acpi_dp.c b/lib/acpi/acpi_dp.c index 579cab47715..7e3e3259d8d 100644 --- a/lib/acpi/acpi_dp.c +++ b/lib/acpi/acpi_dp.c @@ -324,7 +324,7 @@ struct acpi_dp *acpi_dp_add_integer_array(struct acpi_dp *dp, const char *name,
struct acpi_dp *acpi_dp_add_gpio(struct acpi_dp *dp, const char *name, const char *ref, int index, int pin, - enum acpi_irq_polarity polarity) + enum acpi_gpio_polarity polarity) { struct acpi_dp *gpio;
@@ -336,7 +336,7 @@ struct acpi_dp *acpi_dp_add_gpio(struct acpi_dp *dp, const char *name, if (!acpi_dp_add_reference(gpio, NULL, ref) || !acpi_dp_add_integer(gpio, NULL, index) || !acpi_dp_add_integer(gpio, NULL, pin) || - !acpi_dp_add_integer(gpio, NULL, polarity == ACPI_IRQ_ACTIVE_LOW)) + !acpi_dp_add_integer(gpio, NULL, polarity == ACPI_GPIO_ACTIVE_LOW)) return NULL;
if (!acpi_dp_add_array(dp, gpio)) diff --git a/test/dm/acpi_dp.c b/test/dm/acpi_dp.c index e0fa61263c8..44bcabda6bc 100644 --- a/test/dm/acpi_dp.c +++ b/test/dm/acpi_dp.c @@ -398,9 +398,9 @@ static int dm_test_acpi_dp_gpio(struct unit_test_state *uts)
/* Try a few different parameters */ ut_assertnonnull(acpi_dp_add_gpio(dp, "reset", TEST_REF, 0x23, 0x24, - ACPI_IRQ_ACTIVE_HIGH)); + ACPI_GPIO_ACTIVE_HIGH)); ut_assertnonnull(acpi_dp_add_gpio(dp, "allow", TEST_REF, 0, 0, - ACPI_IRQ_ACTIVE_LOW)); + ACPI_GPIO_ACTIVE_LOW));
ptr = acpigen_get_current(ctx); ut_assertok(acpi_dp_write(ctx, dp));
The extra ACPI code increases U-Boot above it current size limit. Move the start earlier to provide space.
Changes in v2: - Add new patch to allow more space for U-Boot on link
configs/chromebook_link_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 82485a5a3f7..c59a7f3c994 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -1,5 +1,5 @@ CONFIG_X86=y -CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_SYS_TEXT_BASE=0xFFEF0000 CONFIG_SYS_MALLOC_F_LEN=0x2400 CONFIG_NR_DRAM_BANKS=8 CONFIG_ENV_SIZE=0x1000
Many I2C devices produce roughly the same ACPI data with just things like the GPIO/interrupt information being different.
This can be handled by a generic driver along with some information in the device tree.
Add a generic i2c driver for this purpose.
(no changes since v1)
Changes in v1: - Adjust implementation to match new ACPI GPIO generation - Capitalise ACPI_OPS_PTR - Rename acpi-probed to linux,probed - Support hid-over-i2c separately as well - Use acpi,ddn instead of acpi,desc - Use updated acpi_device_write_dsm_i2c_hid() function
doc/device-tree-bindings/i2c/generic-acpi.txt | 42 ++++ drivers/i2c/Makefile | 3 + drivers/i2c/acpi_i2c.c | 226 ++++++++++++++++++ drivers/i2c/acpi_i2c.h | 15 ++ drivers/i2c/i2c-uclass.c | 17 ++ include/acpi/acpi_device.h | 55 +++++ include/i2c.h | 23 ++ 7 files changed, 381 insertions(+) create mode 100644 doc/device-tree-bindings/i2c/generic-acpi.txt create mode 100644 drivers/i2c/acpi_i2c.c create mode 100644 drivers/i2c/acpi_i2c.h
diff --git a/doc/device-tree-bindings/i2c/generic-acpi.txt b/doc/device-tree-bindings/i2c/generic-acpi.txt new file mode 100644 index 00000000000..f6fc1614ecf --- /dev/null +++ b/doc/device-tree-bindings/i2c/generic-acpi.txt @@ -0,0 +1,42 @@ +I2C generic device +================== + +This is used only to generate ACPI tables for an I2C device. + +Required properties : + + - compatible : "i2c-chip"; + - reg : I2C chip address + - acpi,hid : HID name for the device + +Optional properies in addition to device.txt: + + - reset-gpios : GPIO used to assert reset to the device + - irq-gpios : GPIO used for interrupt (if Interrupt is not used) + - stop-gpios : GPIO used to stop the device + - interrupts-extended : Interrupt to use for the device + - reset-delay-ms : Delay after de-asserting reset, in ms + - reset-off-delay-ms : Delay after asserting reset (during power off) + - enable-delay-ms : Delay after asserting enable + - enable-off-delay-m s: Delay after de-asserting enable (during power off) + - stop-delay-ms : Delay after de-aserting stop + - stop-off-delay-ms : Delay after asserting stop (during power off) + - hid-descr-addr : HID register offset (for Human Interface Devices) + +Example +------- + + elan-touchscreen@10 { + compatible = "i2c-chip"; + reg = <0x10>; + acpi,hid = "ELAN0001"; + acpi,ddn = "ELAN Touchscreen"; + interrupts-extended = <&acpi_gpe GPIO_21_IRQ + IRQ_TYPE_EDGE_FALLING>; + linux,probed; + reset-gpios = <&gpio_n GPIO_36 GPIO_ACTIVE_HIGH>; + reset-delay-ms = <20>; + enable-gpios = <&gpio_n GPIO_152 GPIO_ACTIVE_HIGH>; + enable-delay-ms = <1>; + acpi,has-power-resource; + }; diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index f7b27864488..bd248cbf52b 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -3,6 +3,9 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. obj-$(CONFIG_DM_I2C) += i2c-uclass.o +ifdef CONFIG_ACPIGEN +obj-$(CONFIG_DM_I2C) += acpi_i2c.o +endif obj-$(CONFIG_DM_I2C_GPIO) += i2c-gpio.o obj-$(CONFIG_$(SPL_)I2C_CROS_EC_TUNNEL) += cros_ec_tunnel.o obj-$(CONFIG_$(SPL_)I2C_CROS_EC_LDO) += cros_ec_ldo.o diff --git a/drivers/i2c/acpi_i2c.c b/drivers/i2c/acpi_i2c.c new file mode 100644 index 00000000000..57d29683cbf --- /dev/null +++ b/drivers/i2c/acpi_i2c.c @@ -0,0 +1,226 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 Google LLC + */ + +#include <common.h> +#include <dm.h> +#include <i2c.h> +#include <log.h> +#include <acpi/acpi_device.h> +#include <acpi/acpigen.h> +#include <acpi/acpi_dp.h> +#ifdef CONFIG_X86 +#include <asm/intel_pinctrl_defs.h> +#endif +#include <asm-generic/gpio.h> +#include <dm/acpi.h> + +static bool acpi_i2c_add_gpios_to_crs(struct acpi_i2c_priv *priv) +{ + /* + * Return false if: + * 1. Request to explicitly disable export of GPIOs in CRS, or + * 2. Both reset and enable GPIOs are not provided. + */ + if (priv->disable_gpio_export_in_crs || + (!dm_gpio_is_valid(&priv->reset_gpio) && + !dm_gpio_is_valid(&priv->enable_gpio))) + return false; + + return true; +} + +static int acpi_i2c_write_gpio(struct acpi_ctx *ctx, struct gpio_desc *gpio, + int *curindex) +{ + int ret; + + if (!dm_gpio_is_valid(gpio)) + return -ENOENT; + + acpi_device_write_gpio_desc(ctx, gpio); + ret = *curindex; + (*curindex)++; + + return ret; +} + +int acpi_i2c_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx) +{ + int reset_gpio_index = -1, enable_gpio_index = -1, irq_gpio_index = -1; + enum i2c_device_t type = dev_get_driver_data(dev); + struct acpi_i2c_priv *priv = dev_get_priv(dev); + struct acpi_dp *dsd = NULL; + char scope[ACPI_PATH_MAX]; + char name[ACPI_NAME_MAX]; + int tx_state_val; + int curindex = 0; + int ret; + +#ifdef CONFIG_X86 + tx_state_val = PAD_CFG0_TX_STATE; +#elif defined(CONFIG_SANDBOX) + tx_state_val = BIT(7); /* test value */ +#else +#error "Not supported on this architecture" +#endif + ret = acpi_get_name(dev, name); + if (ret) + return log_msg_ret("name", ret); + ret = acpi_device_scope(dev, scope, sizeof(scope)); + if (ret) + return log_msg_ret("scope", ret); + + /* Device */ + acpigen_write_scope(ctx, scope); + acpigen_write_device(ctx, name); + acpigen_write_name_string(ctx, "_HID", priv->hid); + if (type == I2C_DEVICE_HID_OVER_I2C) + acpigen_write_name_string(ctx, "_CID", "PNP0C50"); + acpigen_write_name_integer(ctx, "_UID", priv->uid); + acpigen_write_name_string(ctx, "_DDN", priv->desc); + acpigen_write_sta(ctx, acpi_device_status(dev)); + + /* Resources */ + acpigen_write_name(ctx, "_CRS"); + acpigen_write_resourcetemplate_header(ctx); + acpi_device_write_i2c_dev(ctx, dev); + + /* Use either Interrupt() or GpioInt() */ + if (dm_gpio_is_valid(&priv->irq_gpio)) { + irq_gpio_index = acpi_i2c_write_gpio(ctx, &priv->irq_gpio, + &curindex); + } else { + ret = acpi_device_write_interrupt_irq(ctx, &priv->irq); + if (ret < 0) + return log_msg_ret("irq", ret); + } + + if (acpi_i2c_add_gpios_to_crs(priv)) { + reset_gpio_index = acpi_i2c_write_gpio(ctx, &priv->reset_gpio, + &curindex); + enable_gpio_index = acpi_i2c_write_gpio(ctx, &priv->enable_gpio, + &curindex); + } + acpigen_write_resourcetemplate_footer(ctx); + + /* Wake capabilities */ + if (priv->wake) { + acpigen_write_name_integer(ctx, "_S0W", 4); + acpigen_write_prw(ctx, priv->wake, 3); + } + + /* DSD */ + if (priv->probed || priv->property_count || priv->compat_string || + reset_gpio_index >= 0 || enable_gpio_index >= 0 || + irq_gpio_index >= 0) { + char path[ACPI_PATH_MAX]; + + ret = acpi_device_path(dev, path, sizeof(path)); + if (ret) + return log_msg_ret("path", ret); + + dsd = acpi_dp_new_table("_DSD"); + if (priv->compat_string) + acpi_dp_add_string(dsd, "compatible", + priv->compat_string); + if (priv->probed) + acpi_dp_add_integer(dsd, "linux,probed", 1); + if (irq_gpio_index >= 0) + acpi_dp_add_gpio(dsd, "irq-gpios", path, + irq_gpio_index, 0, + priv->irq_gpio.flags & + GPIOD_ACTIVE_LOW ? + ACPI_GPIO_ACTIVE_LOW : 0); + if (reset_gpio_index >= 0) + acpi_dp_add_gpio(dsd, "reset-gpios", path, + reset_gpio_index, 0, + priv->reset_gpio.flags & + GPIOD_ACTIVE_LOW ? + ACPI_GPIO_ACTIVE_LOW : 0); + if (enable_gpio_index >= 0) + acpi_dp_add_gpio(dsd, "enable-gpios", path, + enable_gpio_index, 0, + priv->enable_gpio.flags & + GPIOD_ACTIVE_LOW ? + ACPI_GPIO_ACTIVE_LOW : 0); + /* Generic property list is not supported */ + acpi_dp_write(ctx, dsd); + } + + /* Power Resource */ + if (priv->has_power_resource) { + ret = acpi_device_add_power_res(ctx, tx_state_val, + "\_SB.GPC0", "\_SB.SPC0", + &priv->reset_gpio, priv->reset_delay_ms, + priv->reset_off_delay_ms, &priv->enable_gpio, + priv->enable_delay_ms, priv->enable_off_delay_ms, + &priv->stop_gpio, priv->stop_delay_ms, + priv->stop_off_delay_ms); + if (ret) + return log_msg_ret("power", ret); + } + if (priv->hid_desc_reg_offset) { + ret = acpi_device_write_dsm_i2c_hid(ctx, + priv->hid_desc_reg_offset); + if (ret) + return log_msg_ret("dsm", ret); + } + + acpigen_pop_len(ctx); /* Device */ + acpigen_pop_len(ctx); /* Scope */ + + return 0; +} + +int acpi_i2c_ofdata_to_platdata(struct udevice *dev) +{ + struct acpi_i2c_priv *priv = dev_get_priv(dev); + + gpio_request_by_name(dev, "reset-gpios", 0, &priv->reset_gpio, + GPIOD_IS_OUT); + gpio_request_by_name(dev, "enable-gpios", 0, &priv->enable_gpio, + GPIOD_IS_OUT); + gpio_request_by_name(dev, "irq-gpios", 0, &priv->irq_gpio, GPIOD_IS_IN); + gpio_request_by_name(dev, "stop-gpios", 0, &priv->stop_gpio, + GPIOD_IS_OUT); + irq_get_by_index(dev, 0, &priv->irq); + priv->hid = dev_read_string(dev, "acpi,hid"); + if (!priv->hid) + return log_msg_ret("hid", -EINVAL); + dev_read_u32(dev, "acpi,uid", &priv->uid); + priv->desc = dev_read_string(dev, "acpi,ddn"); + dev_read_u32(dev, "acpi,wake", &priv->wake); + priv->probed = dev_read_bool(dev, "linux,probed"); + priv->compat_string = dev_read_string(dev, "acpi,compatible"); + priv->has_power_resource = dev_read_bool(dev, + "acpi,has-power-resource"); + dev_read_u32(dev, "hid-descr-addr", &priv->hid_desc_reg_offset); + dev_read_u32(dev, "reset-delay-ms", &priv->reset_delay_ms); + dev_read_u32(dev, "reset-off-delay-ms", &priv->reset_off_delay_ms); + dev_read_u32(dev, "enable-delay-ms", &priv->enable_delay_ms); + dev_read_u32(dev, "enable-off-delay-ms", &priv->enable_off_delay_ms); + dev_read_u32(dev, "stop-delay-ms", &priv->stop_delay_ms); + dev_read_u32(dev, "stop-off-delay-ms", &priv->stop_off_delay_ms); + + return 0; +} + +/* Use name specified in priv or build one from I2C address */ +static int acpi_i2c_get_name(const struct udevice *dev, char *out_name) +{ + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + struct acpi_i2c_priv *priv = dev_get_priv(dev); + + snprintf(out_name, ACPI_NAME_MAX, + priv->hid_desc_reg_offset ? "H%03X" : "D%03X", + chip->chip_addr); + + return 0; +} + +struct acpi_ops acpi_i2c_ops = { + .fill_ssdt = acpi_i2c_fill_ssdt, + .get_name = acpi_i2c_get_name, +}; diff --git a/drivers/i2c/acpi_i2c.h b/drivers/i2c/acpi_i2c.h new file mode 100644 index 00000000000..1f4be296016 --- /dev/null +++ b/drivers/i2c/acpi_i2c.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 Google LLC + */ + +#ifndef __ACPI_I2C_H +#define __ACPI_I2C_H + +#include <dm/acpi.h> + +extern struct acpi_ops acpi_i2c_ops; + +int acpi_i2c_ofdata_to_platdata(struct udevice *dev); + +#endif diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index 2373aa2ea4c..5c4626b0442 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -9,6 +9,8 @@ #include <i2c.h> #include <log.h> #include <malloc.h> +#include <acpi/acpi_device.h> +#include <dm/acpi.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/pinctrl.h> @@ -16,6 +18,7 @@ #include <asm/gpio.h> #endif #include <linux/delay.h> +#include "acpi_i2c.h"
#define I2C_MAX_OFFSET_LEN 4
@@ -749,7 +752,21 @@ UCLASS_DRIVER(i2c_generic) = { .name = "i2c_generic", };
+static const struct udevice_id generic_chip_i2c_ids[] = { + { .compatible = "i2c-chip", .data = I2C_DEVICE_GENERIC }, +#if CONFIG_IS_ENABLED(ACPIGEN) + { .compatible = "hid-over-i2c", .data = I2C_DEVICE_HID_OVER_I2C }, +#endif + { } +}; + U_BOOT_DRIVER(i2c_generic_chip_drv) = { .name = "i2c_generic_chip_drv", .id = UCLASS_I2C_GENERIC, + .of_match = generic_chip_i2c_ids, +#if CONFIG_IS_ENABLED(ACPIGEN) + .ofdata_to_platdata = acpi_i2c_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct acpi_i2c_priv), +#endif + ACPI_OPS_PTR(&acpi_i2c_ops) }; diff --git a/include/acpi/acpi_device.h b/include/acpi/acpi_device.h index a5b12217820..1b838fcb857 100644 --- a/include/acpi/acpi_device.h +++ b/include/acpi/acpi_device.h @@ -10,7 +10,9 @@ #define __ACPI_DEVICE_H
#include <i2c.h> +#include <irq.h> #include <spi.h> +#include <asm-generic/gpio.h> #include <linux/bitops.h>
struct acpi_ctx; @@ -235,6 +237,59 @@ struct acpi_spi { const char *resource; };
+/** + * struct acpi_i2c_priv - Information read from device tree + * + * This is used by devices which want to specify various pieces of ACPI + * information, including power control. It allows a generic function to + * generate the information for ACPI, based on device-tree properties. + * + * @disable_gpio_export_in_crs: Don't export GPIOs in the CRS + * @reset_gpio: GPIO used to assert reset to the device + * @enable_gpio: GPIO used to enable the device + * @stop_gpio: GPIO used to stop the device + * @irq_gpio: GPIO used for interrupt (if @irq is not used) + * @irq: IRQ used for interrupt (if @irq_gpio is not used) + * @hid: _HID value for device (required) + * @uid: _UID value for device + * @desc: _DDN value for device + * @wake: Wake event, e.g. GPE0_DW1_15; 0 if none + * @property_count: Number of other DSD properties (currently always 0) + * @probed: true set set 'linux,probed' property + * @compat_string: Device tree compatible string to report through ACPI + * @has_power_resource: true if this device has a power resource + * @reset_delay_ms: Delay after de-asserting reset, in ms + * @reset_off_delay_ms: Delay after asserting reset (during power off) + * @enable_delay_ms: Delay after asserting enable + * @enable_off_delay_ms: Delay after de-asserting enable (during power off) + * @stop_delay_ms: Delay after de-aserting stop + * @stop_off_delay_ms: Delay after asserting stop (during power off) + * @hid_desc_reg_offset: HID register offset (for Human Interface Devices) + */ +struct acpi_i2c_priv { + bool disable_gpio_export_in_crs; + struct gpio_desc reset_gpio; + struct gpio_desc enable_gpio; + struct gpio_desc irq_gpio; + struct gpio_desc stop_gpio; + struct irq irq; + const char *hid; + u32 uid; + const char *desc; + u32 wake; + u32 property_count; + bool probed; + const char *compat_string; + bool has_power_resource; + u32 reset_delay_ms; + u32 reset_off_delay_ms; + u32 enable_delay_ms; + u32 enable_off_delay_ms; + u32 stop_delay_ms; + u32 stop_off_delay_ms; + u32 hid_desc_reg_offset; +}; + /** * acpi_device_path() - Get the full path to an ACPI device * diff --git a/include/i2c.h b/include/i2c.h index 1d792db454a..880aa8032b7 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -58,6 +58,12 @@ enum i2c_address_mode { I2C_MODE_10_BIT };
+/** enum i2c_device_t - Types of I2C devices, used for compatible strings */ +enum i2c_device_t { + I2C_DEVICE_GENERIC, + I2C_DEVICE_HID_OVER_I2C, +}; + struct udevice; /** * struct dm_i2c_chip - information about an i2c chip @@ -558,6 +564,23 @@ int i2c_emul_find(struct udevice *dev, struct udevice **emulp); */ struct udevice *i2c_emul_get_device(struct udevice *emul);
+/* ACPI operations for generic I2C devices */ +extern struct acpi_ops i2c_acpi_ops; + +/** + * acpi_i2c_ofdata_to_platdata() - Read properties intended for ACPI + * + * This reads the generic I2C properties from the device tree, so that these + * can be used to create ACPI information for the device. + * + * See the i2c/generic-acpi.txt binding file for information about the + * properties. + * + * @dev: I2C device to process + * @return 0 if OK, -EINVAL if acpi,hid is not present + */ +int acpi_i2c_ofdata_to_platdata(struct udevice *dev); + #ifndef CONFIG_DM_I2C
Hello Simon,
Am 30.08.2020 um 01:31 schrieb Simon Glass:
Changes in v1:
typo s/m s/ms
Beside of the typo, you can add my
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
typo s/m s/ms
It's rather space on a wrong position.
Some devices can wake the system from sleep, e.g opening the lid on a clamshell or moving a USB mouse.
Add a wake to specify this for USB devices and add the settings for Apollo Lake.
arch/x86/include/asm/arch-apollolake/gpe.h | 135 ++++++++++++++++++++ arch/x86/include/asm/arch-apollolake/gpio.h | 3 + doc/device-tree-bindings/device.txt | 3 + 3 files changed, 141 insertions(+) create mode 100644 arch/x86/include/asm/arch-apollolake/gpe.h
diff --git a/arch/x86/include/asm/arch-apollolake/gpe.h b/arch/x86/include/asm/arch-apollolake/gpe.h new file mode 100644 index 00000000000..f5792960bee --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/gpe.h @@ -0,0 +1,135 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2016 Intel Corporation + * Copyright 2020 Google LLC + * + * Taken from coreboot apl gpe.h + */ + +#ifndef _ASM_ARCH_GPE_H_ +#define _ASM_ARCH_GPE_H_ + +/* bit position in GPE0a_STS register */ +#define GPE0A_PCIE_SCI_STS 0 +#define GPE0A_SWGPE_STS 2 +#define GPE0A_PCIE_WAKE0_STS 3 +#define GPE0A_PUNIT_SCI_STS 4 +#define GPE0A_PCIE_WAKE1_STS 6 +#define GPE0A_PCIE_WAKE2_STS 7 +#define GPE0A_PCIE_WAKE3_STS 8 +#define GPE0A_PCIE_GPE_STS 9 +#define GPE0A_BATLOW_STS 10 +#define GPE0A_CSE_PME_STS 11 +#define GPE0A_XDCI_PME_STS 12 +#define GPE0A_XHCI_PME_STS 13 +#define GPE0A_AVS_PME_STS 14 +#define GPE0A_GPIO_TIER1_SCI_STS 15 +#define GPE0A_SMB_WAK_STS 16 +#define GPE0A_SATA_PME_STS 17 +#define GPE0A_CNVI_PME_STS 18 + +/* Group DW0 is reserved in Apollolake */ + +/* GPE_63_32 */ +#define GPE0_DW1_00 32 +#define GPE0_DW1_01 33 +#define GPE0_DW1_02 34 +#define GPE0_DW1_03 36 +#define GPE0_DW1_04 36 +#define GPE0_DW1_05 37 +#define GPE0_DW1_06 38 +#define GPE0_DW1_07 39 +#define GPE0_DW1_08 40 +#define GPE0_DW1_09 41 +#define GPE0_DW1_10 42 +#define GPE0_DW1_11 43 +#define GPE0_DW1_12 44 +#define GPE0_DW1_13 45 +#define GPE0_DW1_14 46 +#define GPE0_DW1_15 47 +#define GPE0_DW1_16 48 +#define GPE0_DW1_17 49 +#define GPE0_DW1_18 50 +#define GPE0_DW1_19 51 +#define GPE0_DW1_20 52 +#define GPE0_DW1_21 53 +#define GPE0_DW1_22 54 +#define GPE0_DW1_23 55 +#define GPE0_DW1_24 56 +#define GPE0_DW1_25 57 +#define GPE0_DW1_26 58 +#define GPE0_DW1_27 59 +#define GPE0_DW1_28 60 +#define GPE0_DW1_29 61 +#define GPE0_DW1_30 62 +#define GPE0_DW1_31 63 +/* GPE_95_64 */ +#define GPE0_DW2_00 64 +#define GPE0_DW2_01 65 +#define GPE0_DW2_02 66 +#define GPE0_DW2_03 67 +#define GPE0_DW2_04 68 +#define GPE0_DW2_05 69 +#define GPE0_DW2_06 70 +#define GPE0_DW2_07 71 +#define GPE0_DW2_08 72 +#define GPE0_DW2_09 73 +#define GPE0_DW2_10 74 +#define GPE0_DW2_11 75 +#define GPE0_DW2_12 76 +#define GPE0_DW2_13 77 +#define GPE0_DW2_14 78 +#define GPE0_DW2_15 79 +#define GPE0_DW2_16 80 +#define GPE0_DW2_17 81 +#define GPE0_DW2_18 82 +#define GPE0_DW2_19 83 +#define GPE0_DW2_20 84 +#define GPE0_DW2_21 85 +#define GPE0_DW2_22 86 +#define GPE0_DW2_23 87 +#define GPE0_DW2_24 88 +#define GPE0_DW2_25 89 +#define GPE0_DW2_26 90 +#define GPE0_DW2_27 91 +#define GPE0_DW2_28 92 +#define GPE0_DW2_29 93 +#define GPE0_DW2_30 94 +#define GPE0_DW2_31 95 +/* GPE_127_96 */ +#define GPE0_DW3_00 96 +#define GPE0_DW3_01 97 +#define GPE0_DW3_02 98 +#define GPE0_DW3_03 99 +#define GPE0_DW3_04 100 +#define GPE0_DW3_05 101 +#define GPE0_DW3_06 102 +#define GPE0_DW3_07 103 +#define GPE0_DW3_08 104 +#define GPE0_DW3_09 105 +#define GPE0_DW3_10 106 +#define GPE0_DW3_11 107 +#define GPE0_DW3_12 108 +#define GPE0_DW3_13 109 +#define GPE0_DW3_14 110 +#define GPE0_DW3_15 111 +#define GPE0_DW3_16 112 +#define GPE0_DW3_17 113 +#define GPE0_DW3_18 114 +#define GPE0_DW3_19 115 +#define GPE0_DW3_20 116 +#define GPE0_DW3_21 117 +#define GPE0_DW3_22 118 +#define GPE0_DW3_23 119 +#define GPE0_DW3_24 120 +#define GPE0_DW3_25 121 +#define GPE0_DW3_26 122 +#define GPE0_DW3_27 123 +#define GPE0_DW3_28 124 +#define GPE0_DW3_29 125 +#define GPE0_DW3_30 126 +#define GPE0_DW3_31 127 + +#define GPE_MAX GPE0_DW3_31 + +#endif diff --git a/arch/x86/include/asm/arch-apollolake/gpio.h b/arch/x86/include/asm/arch-apollolake/gpio.h index 10879c168ec..ab5860c0fd0 100644 --- a/arch/x86/include/asm/arch-apollolake/gpio.h +++ b/arch/x86/include/asm/arch-apollolake/gpio.h @@ -482,4 +482,7 @@ #define GPIO_72_IRQ 0x65 #define GPIO_73_IRQ 0x66
+/* This is needed by ACPI */ +#define GPIO_NUM_PAD_CFG_REGS 2 /* DW0, DW1 */ + #endif /* _ASM_ARCH_GPIO_H_ */ diff --git a/doc/device-tree-bindings/device.txt b/doc/device-tree-bindings/device.txt index 2a5736c5981..73ce2a3b5b5 100644 --- a/doc/device-tree-bindings/device.txt +++ b/doc/device-tree-bindings/device.txt @@ -22,6 +22,8 @@ the acpi,compatible property. - acpi,name : Provides the ACPI name for a device, which is a string consisting of four alphanumeric character (upper case) - acpi,uid : _UID value for device + - acpi,wake : Provides the GPE used to detect a request from a device to wake + from sleep - linux,probed : Tells U-Boot to add 'linux,probed' to the ACPI tables so that Linux will only load the driver if the device can be detected (e.g. on I2C bus). Note that this is an out-of-tree Linux feature. @@ -46,6 +48,7 @@ pcie-a0@14,0 { compatible = "intel,generic-wifi"; acpi,ddn = "Intel WiFi"; acpi,name = "WF00"; + acpi,wake = <GPE0_DW3_00>; interrupts-extended = <&acpi_gpe 0x3c 0>; }; };
This table is needed by the Linux graphics driver to handle graphics correctly. Write it to ACPI.
Changes in v1: - Capitalise ACPI_OPS_PTR - Don't build for SPL
arch/x86/Kconfig | 8 + arch/x86/cpu/apollolake/Kconfig | 1 + arch/x86/cpu/intel_common/Makefile | 4 + arch/x86/cpu/intel_common/intel_opregion.c | 168 ++++++++++++++ arch/x86/include/asm/intel_opregion.h | 247 +++++++++++++++++++++ arch/x86/lib/fsp/fsp_graphics.c | 32 +++ include/bloblist.h | 1 + 7 files changed, 461 insertions(+) create mode 100644 arch/x86/cpu/intel_common/intel_opregion.c create mode 100644 arch/x86/include/asm/intel_opregion.h
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index a8bbf761db6..3e8199329c2 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -998,4 +998,12 @@ config PCIEX_LENGTH_128MB config PCIEX_LENGTH_64MB bool
+config INTEL_GMA_ACPI + bool "Generate ACPI table for Intel GMA graphics" + help + The Intel GMA graphics driver in Linux expects an ACPI table + which describes the layout of the registers and the display + connected to the device. Enable this option to create this + table so that graphics works correctly. + endmenu diff --git a/arch/x86/cpu/apollolake/Kconfig b/arch/x86/cpu/apollolake/Kconfig index 16ac2b3f504..319f12684b7 100644 --- a/arch/x86/cpu/apollolake/Kconfig +++ b/arch/x86/cpu/apollolake/Kconfig @@ -48,6 +48,7 @@ config INTEL_APOLLOLAKE imply CMD_CLK imply CLK_INTEL imply ACPI_GPE + imply INTEL_GMA_ACPI
if INTEL_APOLLOLAKE
diff --git a/arch/x86/cpu/intel_common/Makefile b/arch/x86/cpu/intel_common/Makefile index 374803b8760..207d5413965 100644 --- a/arch/x86/cpu/intel_common/Makefile +++ b/arch/x86/cpu/intel_common/Makefile @@ -9,6 +9,10 @@ obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += report_platform.o obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += mrc.o endif
+ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_INTEL_GMA_ACPI) += intel_opregion.o +endif + ifdef CONFIG_INTEL_CAR_CQOS obj-$(CONFIG_TPL_BUILD) += car2.o ifndef CONFIG_SPL_BUILD diff --git a/arch/x86/cpu/intel_common/intel_opregion.c b/arch/x86/cpu/intel_common/intel_opregion.c new file mode 100644 index 00000000000..4e6c64d9aaa --- /dev/null +++ b/arch/x86/cpu/intel_common/intel_opregion.c @@ -0,0 +1,168 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Writing IntelGraphicsMem table for ACPI + * + * Copyright 2019 Google LLC + * Modified from coreboot src/soc/intel/gma/opregion.c + */ + +#include <common.h> +#include <binman.h> +#include <bloblist.h> +#include <dm.h> +#include <spi_flash.h> +#include <asm/intel_opregion.h> + +static char vbt_data[8 << 10]; + +static int locate_vbt(char **vbtp, int *sizep) +{ + struct binman_entry vbt; + struct udevice *dev; + u32 vbtsig = 0; + int size; + int ret; + + ret = binman_entry_find("intel-vbt", &vbt); + if (ret) + return log_msg_ret("find VBT", ret); + ret = uclass_first_device_err(UCLASS_SPI_FLASH, &dev); + if (ret) + return log_msg_ret("find flash", ret); + size = vbt.size; + if (size > sizeof(vbt_data)) + return log_msg_ret("vbt", -E2BIG); + ret = spi_flash_read_dm(dev, vbt.image_pos, size, vbt_data); + if (ret) + return log_msg_ret("read", ret); + + memcpy(&vbtsig, vbt_data, sizeof(vbtsig)); + if (vbtsig != VBT_SIGNATURE) { + log_err("Missing/invalid signature in VBT data file!\n"); + return -EINVAL; + } + + log_info("Found a VBT of %u bytes\n", size); + *sizep = size; + *vbtp = vbt_data; + + return 0; +} + +/* Write ASLS PCI register and prepare SWSCI register */ +static int intel_gma_opregion_register(struct udevice *dev, ulong opregion) +{ + int sci_reg; + + if (!device_active(dev)) + return -ENOENT; + + /* + * Intel BIOS Specification + * Chapter 5.3.7 "Initialise Hardware State" + */ + dm_pci_write_config32(dev, ASLS, opregion); + + /* + * Atom-based platforms use a combined SMI/SCI register, + * whereas non-Atom platforms use a separate SCI register + */ + if (IS_ENABLED(CONFIG_INTEL_GMA_SWSMISCI)) + sci_reg = SWSMISCI; + else + sci_reg = SWSCI; + + /* + * Intel's Windows driver relies on this: + * Intel BIOS Specification + * Chapter 5.4 "ASL Software SCI Handler" + */ + dm_pci_clrset_config16(dev, sci_reg, GSSCIE, SMISCISEL); + + return 0; +} + +int intel_gma_init_igd_opregion(struct udevice *dev, + struct igd_opregion *opregion) +{ + struct optionrom_vbt *vbt = NULL; + char *vbt_buf; + int vbt_size; + int ret; + + ret = locate_vbt(&vbt_buf, &vbt_size); + if (ret) { + log_err("GMA: VBT couldn't be found\n"); + return log_msg_ret("find vbt", ret); + } + vbt = (struct optionrom_vbt *)vbt_buf; + + memset(opregion, '\0', sizeof(struct igd_opregion)); + + memcpy(&opregion->header.signature, IGD_OPREGION_SIGNATURE, + sizeof(opregion->header.signature)); + memcpy(opregion->header.vbios_version, vbt->coreblock_biosbuild, + ARRAY_SIZE(vbt->coreblock_biosbuild)); + /* Extended VBT support */ + if (vbt->hdr_vbt_size > sizeof(opregion->vbt.gvd1)) { + struct optionrom_vbt *ext_vbt; + + ret = bloblist_ensure_size(BLOBLISTT_INTEL_VBT, + vbt->hdr_vbt_size, + (void **)&ext_vbt); + if (ret) { + log_err("GMA: Unable to add Ext VBT to bloblist\n"); + return log_msg_ret("blob", ret); + } + + memcpy(ext_vbt, vbt, vbt->hdr_vbt_size); + opregion->mailbox3.rvda = (uintptr_t)ext_vbt; + opregion->mailbox3.rvds = vbt->hdr_vbt_size; + } else { + /* Raw VBT size which can fit in gvd1 */ + printf("copy to %p\n", opregion->vbt.gvd1); + memcpy(opregion->vbt.gvd1, vbt, vbt->hdr_vbt_size); + } + + /* 8kb */ + opregion->header.size = sizeof(struct igd_opregion) / 1024; + + /* + * Left-shift version field to accommodate Intel Windows driver quirk + * when not using a VBIOS. + * Required for Legacy boot + NGI, UEFI + NGI, and UEFI + GOP driver. + * + * No adverse effects when using VBIOS or booting Linux. + */ + opregion->header.version = IGD_OPREGION_VERSION << 24; + + /* We just assume we're mobile for now */ + opregion->header.mailboxes = MAILBOXES_MOBILE; + + /* Initialise Mailbox 1 */ + opregion->mailbox1.clid = 1; + + /* Initialise Mailbox 3 */ + opregion->mailbox3.bclp = IGD_BACKLIGHT_BRIGHTNESS; + opregion->mailbox3.pfit = IGD_FIELD_VALID | IGD_PFIT_STRETCH; + opregion->mailbox3.pcft = 0; /* should be (IMON << 1) & 0x3e */ + opregion->mailbox3.cblv = IGD_FIELD_VALID | IGD_INITIAL_BRIGHTNESS; + opregion->mailbox3.bclm[0] = IGD_WORD_FIELD_VALID + 0x0000; + opregion->mailbox3.bclm[1] = IGD_WORD_FIELD_VALID + 0x0a19; + opregion->mailbox3.bclm[2] = IGD_WORD_FIELD_VALID + 0x1433; + opregion->mailbox3.bclm[3] = IGD_WORD_FIELD_VALID + 0x1e4c; + opregion->mailbox3.bclm[4] = IGD_WORD_FIELD_VALID + 0x2866; + opregion->mailbox3.bclm[5] = IGD_WORD_FIELD_VALID + 0x327f; + opregion->mailbox3.bclm[6] = IGD_WORD_FIELD_VALID + 0x3c99; + opregion->mailbox3.bclm[7] = IGD_WORD_FIELD_VALID + 0x46b2; + opregion->mailbox3.bclm[8] = IGD_WORD_FIELD_VALID + 0x50cc; + opregion->mailbox3.bclm[9] = IGD_WORD_FIELD_VALID + 0x5ae5; + opregion->mailbox3.bclm[10] = IGD_WORD_FIELD_VALID + 0x64ff; + + /* Write ASLS PCI register and prepare SWSCI register */ + ret = intel_gma_opregion_register(dev, (ulong)opregion); + if (ret) + return log_msg_ret("write asls", ret); + + return 0; +} diff --git a/arch/x86/include/asm/intel_opregion.h b/arch/x86/include/asm/intel_opregion.h new file mode 100644 index 00000000000..fb3e38617e4 --- /dev/null +++ b/arch/x86/include/asm/intel_opregion.h @@ -0,0 +1,247 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Writing IntelGraphicsMem table for ACPI + * + * Copyright 2019 Google LLC + * Modified from coreboot src/soc/intel/gma/opregion.h + */ + +#ifndef _ASM_INTEL_OPREGION_H_ +#define _ASM_INTEL_OPREGION_H_ + +#define VBT_SIGNATURE 0x54425624 + +/* IGD PCI Configuration register */ +#define ASLS 0xfc /* OpRegion Base */ +#define SWSCI 0xe8 /* SWSCI Register */ +#define SWSMISCI 0xe0 /* SWSMISCI Register */ +#define GSSCIE BIT(0) /* SCI Event trigger */ +#define SMISCISEL BIT(15) /* Select SMI or SCI event source */ + +/* mailbox 0: header */ +struct __packed opregion_header { + u8 signature[16]; /* Offset 0 OpRegion signature */ + u32 size; /* Offset 16 OpRegion size */ + u32 version; /* Offset 20 OpRegion structure version */ + u8 sbios_version[32]; /* Offset 24 System BIOS build version */ + u8 vbios_version[16]; /* Offset 56 Video BIOS build version */ + u8 driver_version[16]; /* Offset 72 Graphic drvr build version */ + u32 mailboxes; /* Offset 88 Mailboxes supported */ + u32 dmod; /* Offset 92 Driver Model */ + u32 pcon; /* Offset 96 Platform Capabilities */ + u16 dver[16]; /* Offset 100 GOP Version */ + u8 reserved[124]; /* Offset 132 Reserved */ +}; + +#define IGD_OPREGION_SIGNATURE "IntelGraphicsMem" +#define IGD_OPREGION_VERSION 2 + +#define IGD_MBOX1 BIT(0) +#define IGD_MBOX2 BIT(1) +#define IGD_MBOX3 BIT(2) +#define IGD_MBOX4 BIT(3) +#define IGD_MBOX5 BIT(4) + +#define MAILBOXES_MOBILE (IGD_MBOX1 | IGD_MBOX2 | IGD_MBOX3 | \ + IGD_MBOX4 | IGD_MBOX5) +#define MAILBOXES_DESKTOP (IGD_MBOX2 | IGD_MBOX4) + +#define SBIOS_VERSION_SIZE 32 + +/* mailbox 1: public ACPI methods */ +struct __packed opregion_mailbox1 { + u32 drdy; /* Offset 0 Driver readiness */ + u32 csts; /* Offset 4 Status */ + u32 cevt; /* Offset 8 Current event */ + u8 reserved[20]; /* Offset 12 Reserved */ + u32 didl; /* Offset 32 Supported display device 1 */ + u32 ddl2; /* Offset 36 Supported display device 2 */ + u32 ddl3; /* Offset 40 Supported display device 3 */ + u32 ddl4; /* Offset 44 Supported display device 4 */ + u32 ddl5; /* Offset 48 Supported display device 5 */ + u32 ddl6; /* Offset 52 Supported display device 6 */ + u32 ddl7; /* Offset 56 Supported display device 7 */ + u32 ddl8; /* Offset 60 Supported display device 8 */ + u32 cpdl; /* Offset 64 Currently present display device 1 */ + u32 cpl2; /* Offset 68 Currently present display device 2 */ + u32 cpl3; /* Offset 72 Currently present display device 3 */ + u32 cpl4; /* Offset 76 Currently present display device 4 */ + u32 cpl5; /* Offset 80 Currently present display device 5 */ + u32 cpl6; /* Offset 84 Currently present display device 6 */ + u32 cpl7; /* Offset 88 Currently present display device 7 */ + u32 cpl8; /* Offset 92 Currently present display device 8 */ + u32 cadl; /* Offset 96 Currently active display device 1 */ + u32 cal2; /* Offset 100 Currently active display device 2 */ + u32 cal3; /* Offset 104 Currently active display device 3 */ + u32 cal4; /* Offset 108 Currently active display device 4 */ + u32 cal5; /* Offset 112 Currently active display device 5 */ + u32 cal6; /* Offset 116 Currently active display device 6 */ + u32 cal7; /* Offset 120 Currently active display device 7 */ + u32 cal8; /* Offset 124 Currently active display device 8 */ + u32 nadl; /* Offset 128 Next active device 1 */ + u32 ndl2; /* Offset 132 Next active device 2 */ + u32 ndl3; /* Offset 136 Next active device 3 */ + u32 ndl4; /* Offset 140 Next active device 4 */ + u32 ndl5; /* Offset 144 Next active device 5 */ + u32 ndl6; /* Offset 148 Next active device 6 */ + u32 ndl7; /* Offset 152 Next active device 7 */ + u32 ndl8; /* Offset 156 Next active device 8 */ + u32 aslp; /* Offset 160 ASL sleep timeout */ + u32 tidx; /* Offset 164 Toggle table index */ + u32 chpd; /* Offset 168 Current hot plug enable indicator */ + u32 clid; /* Offset 172 Current lid state indicator */ + u32 cdck; /* Offset 176 Current docking state indicator */ + u32 sxsw; /* Offset 180 Display Switch notification on Sx State + * resume + */ + u32 evts; /* Offset 184 Events supported by ASL */ + u32 cnot; /* Offset 188 Current OS Notification */ + u32 nrdy; /* Offset 192 Reasons for DRDY = 0 */ + u32 ddl9; /* Offset 196 Extended Supported display device 1 */ + u32 dd10; /* Offset 200 Extended Supported display device 2 */ + u32 dd11; /* Offset 204 Extended Supported display device 3 */ + u32 dd12; /* Offset 208 Extended Supported display device 4 */ + u32 dd13; /* Offset 212 Extended Supported display device 5 */ + u32 dd14; /* Offset 216 Extended Supported display device 6 */ + u32 dd15; /* Offset 220 Extended Supported display device 7 */ + u32 cpl9; /* Offset 224 Extended Currently present device 1 */ + u32 cp10; /* Offset 228 Extended Currently present device 2 */ + u32 cp11; /* Offset 232 Extended Currently present device 3 */ + u32 cp12; /* Offset 236 Extended Currently present device 4 */ + u32 cp13; /* Offset 240 Extended Currently present device 5 */ + u32 cp14; /* Offset 244 Extended Currently present device 6 */ + u32 cp15; /* Offset 248 Extended Currently present device 7 */ + u8 reserved2[4]; /* Offset 252 Reserved 4 bytes */ +}; + +/* mailbox 2: software sci interface */ +struct __packed opregion_mailbox2 { + u32 scic; /* Offset 0 Software SCI function number parameters */ + u32 parm; /* Offset 4 Software SCI function number parameters */ + u32 dslp; /* Offset 8 Driver sleep timeout */ + u8 reserved[244]; /* Offset 12 Reserved */ +}; + +/* mailbox 3: power conservation */ +struct __packed opregion_mailbox3 { + u32 ardy; /* Offset 0 Driver readiness */ + u32 aslc; /* Offset 4 ASLE interrupt command / status */ + u32 tche; /* Offset 8 Technology enabled indicator */ + u32 alsi; /* Offset 12 Current ALS illuminance reading */ + u32 bclp; /* Offset 16 Backlight britness to set */ + u32 pfit; /* Offset 20 Panel fitting Request */ + u32 cblv; /* Offset 24 Brightness Current State */ + /* Offset 28 Backlight Brightness Level Duty Cycle Mapping Table */ + u16 bclm[20]; + u32 cpfm; /* Offset 68 Panel Fitting Current Mode */ + u32 epfm; /* Offset 72 Enabled Panel Fitting Modes */ + u8 plut[74]; /* Offset 76 Panel Look Up Table */ + /* Offset 150 PWM Frequency and Minimum Brightness */ + u32 pfmb; + u32 ccdv; /* Offset 154 Color Correction Default Values */ + u32 pcft; /* Offset 158 Power Conservation Features */ + u32 srot; /* Offset 162 Supported Rotation angle */ + u32 iuer; /* Offset 166 Intel Ultrabook Event Register */ + u64 fdsp; /* Offset 170 FFS Display Physical address */ + u32 fdss; /* Offset 178 FFS Display Size */ + u32 stat; /* Offset 182 State Indicator */ + /* + * Offset 186 (Igd opregion offset 0x3BAh) + * Physical address of Raw VBT data + */ + u64 rvda; + /* Offset 194 (Igd opregion offset 0x3C2h) Size of Raw VBT data */ + u32 rvds; + u8 reserved[58]; /* Offset 198 Reserved */ +}; + +#define IGD_BACKLIGHT_BRIGHTNESS 0xff +#define IGD_INITIAL_BRIGHTNESS 0x64 + +#define IGD_FIELD_VALID BIT(31) +#define IGD_WORD_FIELD_VALID BIT(15) +#define IGD_PFIT_STRETCH 6 + +/* mailbox 4: vbt */ +struct __packed opregion_vbt { + u8 gvd1[6 << 10]; +}; + +/* Mailbox 5: BIOS to Driver Notification Extension */ +struct __packed opregion_mailbox5 { + u32 phed; /* Offset 7168 Panel Header */ + u8 bddc[256]; /* Offset 7172 Panel EDID */ + u8 reserved[764]; /* Offset 7428 764 bytes */ +}; + +/* IGD OpRegion */ +struct __packed igd_opregion { + struct opregion_header header; + struct opregion_mailbox1 mailbox1; + struct opregion_mailbox2 mailbox2; + struct opregion_mailbox3 mailbox3; + struct opregion_vbt vbt; + struct opregion_mailbox5 mailbox5; +}; + +/* Intel Video BIOS (Option ROM) */ +struct __packed optionrom_header { + u16 signature; + u8 size; + u8 reserved[21]; + u16 pcir_offset; + u16 vbt_offset; +}; + +#define OPROM_SIGNATURE 0xaa55 + +struct __packed optionrom_pcir { + u32 signature; + u16 vendor; + u16 device; + u16 reserved1; + u16 length; + u8 revision; + u8 classcode[3]; + u16 imagelength; + u16 coderevision; + u8 codetype; + u8 indicator; + u16 reserved2; +}; + +struct __packed optionrom_vbt { + u8 hdr_signature[20]; + u16 hdr_version; + u16 hdr_size; + u16 hdr_vbt_size; + u8 hdr_vbt_checksum; + u8 hdr_reserved; + u32 hdr_vbt_datablock; + u32 hdr_aim[4]; + u8 datahdr_signature[16]; + u16 datahdr_version; + u16 datahdr_size; + u16 datahdr_datablocksize; + u8 coreblock_id; + u16 coreblock_size; + u16 coreblock_biossize; + u8 coreblock_biostype; + u8 coreblock_releasestatus; + u8 coreblock_hwsupported; + u8 coreblock_integratedhw; + u8 coreblock_biosbuild[4]; + u8 coreblock_biossignon[155]; +}; + +/** + * intel_gma_init_igd_opregion() - Initialise IGD OpRegion + * + * This is called from ACPI code and OS drivers + * + * @return 0 if OK, -ve on error + */ +int intel_gma_init_igd_opregion(struct udevice *dev, + struct igd_opregion *opregion); + +#endif /* _ASM_INTEL_OPREGION_H_ */ diff --git a/arch/x86/lib/fsp/fsp_graphics.c b/arch/x86/lib/fsp/fsp_graphics.c index e8c1e07af1c..858d7942fed 100644 --- a/arch/x86/lib/fsp/fsp_graphics.c +++ b/arch/x86/lib/fsp/fsp_graphics.c @@ -3,14 +3,19 @@ * Copyright (C) 2017, Bin Meng bmeng.cn@gmail.com */
+#define LOG_CATEGORY UCLASS_VIDEO + #include <common.h> #include <dm.h> #include <init.h> #include <log.h> #include <vbe.h> #include <video.h> +#include <acpi/acpi_table.h> #include <asm/fsp/fsp_support.h> +#include <asm/intel_opregion.h> #include <asm/mtrr.h> +#include <dm/acpi.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -127,6 +132,32 @@ static int fsp_video_bind(struct udevice *dev) return 0; }
+#ifdef CONFIG_INTEL_GMA_ACPI +static int fsp_video_acpi_write_tables(const struct udevice *dev, + struct acpi_ctx *ctx) +{ + struct igd_opregion *opregion; + int ret; + + printf("ACPI: * IGD OpRegion\n"); + opregion = (struct igd_opregion *)ctx->current; + + ret = intel_gma_init_igd_opregion((struct udevice *)dev, opregion); + if (ret) + return ret; + + acpi_inc_align(ctx, sizeof(struct igd_opregion)); + + return 0; +} +#endif + +struct acpi_ops fsp_video_acpi_ops = { +#ifdef CONFIG_INTEL_GMA_ACPI + .write_tables = fsp_video_acpi_write_tables, +#endif +}; + static const struct udevice_id fsp_video_ids[] = { { .compatible = "fsp-fb" }, { } @@ -139,6 +170,7 @@ U_BOOT_DRIVER(fsp_video) = { .bind = fsp_video_bind, .probe = fsp_video_probe, .flags = DM_FLAG_PRE_RELOC, + ACPI_OPS_PTR(&fsp_video_acpi_ops) };
static struct pci_device_id fsp_video_supported[] = { diff --git a/include/bloblist.h b/include/bloblist.h index bbe0a35d5a2..7d8480548e0 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -32,6 +32,7 @@ enum bloblist_tag_t { * Sleeping table. This forms part of the ACPI tables passed to Linux. */ BLOBLISTT_ACPI_GNVS, + BLOBLISTT_INTEL_VBT, /* Intel Video-BIOS table */ };
Intel WiFi chips can use a common routine to write the information needed by linux. Add an implementation of this.
Enable it for coral.
Changes in v1: - Capitalise ACPI_OPS_PTR - Use acpi,ddn instead of acpi,desc
arch/x86/Kconfig | 8 ++ arch/x86/cpu/intel_common/Makefile | 1 + arch/x86/cpu/intel_common/generic_wifi.c | 120 +++++++++++++++++++++++ configs/chromebook_coral_defconfig | 1 + 4 files changed, 130 insertions(+) create mode 100644 arch/x86/cpu/intel_common/generic_wifi.c
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 3e8199329c2..1e5c72d6b39 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -1006,4 +1006,12 @@ config INTEL_GMA_ACPI connected to the device. Enable this option to create this table so that graphics works correctly.
+config INTEL_GENERIC_WIFI + bool "Enable generation of ACPI tables for Intel WiFi" + help + Select this option to provide code to a build generic WiFi ACPI table + for Intel WiFi devices. This is not a WiFi driver and offers no + network functionality. It is only here to generate the ACPI tables + required by Linux. + endmenu diff --git a/arch/x86/cpu/intel_common/Makefile b/arch/x86/cpu/intel_common/Makefile index 207d5413965..f1d1513a981 100644 --- a/arch/x86/cpu/intel_common/Makefile +++ b/arch/x86/cpu/intel_common/Makefile @@ -24,6 +24,7 @@ obj-y += cpu.o obj-y += fast_spi.o obj-y += lpc.o obj-y += lpss.o +obj-$(CONFIG_INTEL_GENERIC_WIFI) += generic_wifi.o ifndef CONFIG_TARGET_EFI_APP obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += microcode.o ifndef CONFIG_$(SPL_)X86_64 diff --git a/arch/x86/cpu/intel_common/generic_wifi.c b/arch/x86/cpu/intel_common/generic_wifi.c new file mode 100644 index 00000000000..61ec5391b09 --- /dev/null +++ b/arch/x86/cpu/intel_common/generic_wifi.c @@ -0,0 +1,120 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Generic WiFi ACPI info + * + * Copyright 2019 Google LLC + * Modified from coreboot src/drivers/wifi/generic.c + */ + +#include <common.h> +#include <log.h> +#include <acpi/acpigen.h> +#include <acpi/acpi_device.h> +#include <dm.h> +#include <dm/acpi.h> + +/* WRDS Spec Revision */ +#define WRDS_REVISION 0x0 + +/* EWRD Spec Revision */ +#define EWRD_REVISION 0x0 + +/* WRDS Domain type */ +#define WRDS_DOMAIN_TYPE_WIFI 0x7 + +/* EWRD Domain type */ +#define EWRD_DOMAIN_TYPE_WIFI 0x7 + +/* WGDS Domain type */ +#define WGDS_DOMAIN_TYPE_WIFI 0x7 + +/* + * WIFI ACPI NAME = "WF" + hex value of last 8 bits of dev_path_encode + '\0' + * The above representation returns unique and consistent name every time + * generate_wifi_acpi_name is invoked. The last 8 bits of dev_path_encode is + * chosen since it contains the bus address of the device. + */ +#define WIFI_ACPI_NAME_MAX_LEN 5 + +/** + * struct generic_wifi_config - Data structure to contain common wifi config + * @wake: Wake pin for ACPI _PRW + * @maxsleep: Maximum sleep state to wake from + */ +struct generic_wifi_config { + unsigned int wake; + unsigned int maxsleep; +}; + +static int generic_wifi_fill_ssdt(struct acpi_ctx *ctx, + const struct udevice *dev, + const struct generic_wifi_config *config) +{ + char name[ACPI_NAME_MAX]; + char path[ACPI_PATH_MAX]; + pci_dev_t bdf; + u32 address; + int ret; + + ret = acpi_device_path(dev_get_parent(dev), path, sizeof(path)); + if (ret) + return log_msg_ret("path", ret); + ret = acpi_get_name(dev, name); + if (ret) + return log_msg_ret("name", ret); + + /* Device */ + acpigen_write_scope(ctx, path); + acpigen_write_device(ctx, name); + acpigen_write_name_integer(ctx, "_UID", 0); + acpigen_write_name_string(ctx, "_DDN", + dev_read_string(dev, "acpi,ddn")); + + /* Address */ + bdf = dm_pci_get_bdf(dev); + address = (PCI_DEV(bdf) << 16) | PCI_FUNC(bdf); + acpigen_write_name_dword(ctx, "_ADR", address); + + /* Wake capabilities */ + if (config) + acpigen_write_prw(ctx, config->wake, config->maxsleep); + + acpigen_pop_len(ctx); /* Device */ + acpigen_pop_len(ctx); /* Scope */ + + return 0; +} + +static int intel_wifi_acpi_fill_ssdt(const struct udevice *dev, + struct acpi_ctx *ctx) +{ + struct generic_wifi_config config; + bool have_config; + int ret; + + ret = dev_read_u32(dev, "acpi,wake", &config.wake); + have_config = !ret; + /* By default, all intel wifi chips wake from S3 */ + config.maxsleep = 3; + ret = generic_wifi_fill_ssdt(ctx, dev, have_config ? &config : NULL); + if (ret) + return log_msg_ret("wifi", ret); + + return 0; +} + +struct acpi_ops wifi_acpi_ops = { + .fill_ssdt = intel_wifi_acpi_fill_ssdt, +}; + +static const struct udevice_id intel_wifi_ids[] = { + { .compatible = "intel,generic-wifi" }, + { } +}; + +U_BOOT_DRIVER(intel_wifi) = { + .name = "intel_wifi", + .id = UCLASS_MISC, + .of_match = intel_wifi_ids, + ACPI_OPS_PTR(&wifi_acpi_ops) +}; diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index e1d0749239b..c9006e2f934 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -18,6 +18,7 @@ CONFIG_HAVE_ACPI_RESUME=y CONFIG_INTEL_CAR_CQOS=y CONFIG_X86_OFFSET_U_BOOT=0xffe00000 CONFIG_X86_OFFSET_SPL=0xffe80000 +CONFIG_INTEL_GENERIC_WIFI=y CONFIG_BOOTSTAGE=y CONFIG_SPL_BOOTSTAGE=y CONFIG_TPL_BOOTSTAGE=y
U-Boot does not support SMM (System Management Mode) at present, but needs a few definitions to correctly set up the ACPI table. Add these.
arch/x86/include/asm/smm.h | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+) create mode 100644 arch/x86/include/asm/smm.h
diff --git a/arch/x86/include/asm/smm.h b/arch/x86/include/asm/smm.h new file mode 100644 index 00000000000..1e539fda067 --- /dev/null +++ b/arch/x86/include/asm/smm.h @@ -0,0 +1,27 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * SMM definitions (U-Boot does not support SMM itself) + * + * Copyright (C) 2008-2009 coresystems GmbH + * Copyright 2019 Google LLC + * + * Modified from coreboot smm.h + */ + +#ifndef _ASM_SMM_H +#define _ASM_SMM_H + +#define APM_CNT 0xb2 +#define APM_CNT_CST_CONTROL 0x85 +#define APM_CNT_PST_CONTROL 0x80 +#define APM_CNT_ACPI_DISABLE 0x1e +#define APM_CNT_ACPI_ENABLE 0xe1 +#define APM_CNT_MBI_UPDATE 0xeb +#define APM_CNT_GNVS_UPDATE 0xea +#define APM_CNT_FINALIZE 0xcb +#define APM_CNT_LEGACY 0xcc +#define APM_CNT_SMMSTORE 0xed +#define APM_CNT_ELOG_GSMI 0xef +#define APM_STS 0xb3 + +#endif /* _ASM_SMM_H */
Add SCI and power-state definitions required by ACPI tables. Fix the license to match the original source file.
Als update the guard on acpi_pmc.h to avoid an error when buiding ASL.
Changes in v1: - Use SHIFT and MASK for defines
arch/x86/include/asm/arch-apollolake/pm.h | 40 ++++++++++++++++++++++- include/power/acpi_pmc.h | 4 +-- 2 files changed, 41 insertions(+), 3 deletions(-)
diff --git a/arch/x86/include/asm/arch-apollolake/pm.h b/arch/x86/include/asm/arch-apollolake/pm.h index 6718290c4fe..9a8d971e910 100644 --- a/arch/x86/include/asm/arch-apollolake/pm.h +++ b/arch/x86/include/asm/arch-apollolake/pm.h @@ -1,12 +1,15 @@ -/* SPDX-License-Identifier: GPL-2.0 */ +/* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright (C) 2015-2016 Intel Corp. * (Written by Lance Zhao lijian.zhao@intel.com for Intel Corp.) + * Copyright 2019 Google LLC */
#ifndef _ASM_ARCH_PM_H #define _ASM_ARCH_PM_H
+#include <power/acpi_pmc.h> + #define PMC_GPE_SW_31_0 0 #define PMC_GPE_SW_63_32 1 #define PMC_GPE_NW_31_0 3 @@ -16,4 +19,39 @@ #define PMC_GPE_N_63_32 7 #define PMC_GPE_W_31_0 9
+#define IRQ_REG 0x106c +#define SCI_IRQ_SHIFT 24 +#define SCI_IRQ_MASK (0xff << SCI_IRQ_SHIFT) +#define SCIS_IRQ9 9 +#define SCIS_IRQ10 10 +#define SCIS_IRQ11 11 +#define SCIS_IRQ20 20 +#define SCIS_IRQ21 21 +#define SCIS_IRQ22 22 +#define SCIS_IRQ23 23 + +/* P-state configuration */ +#define PSS_MAX_ENTRIES 8 +#define PSS_RATIO_STEP 2 +#define PSS_LATENCY_TRANSITION 10 +#define PSS_LATENCY_BUSMASTER 10 + +#ifndef __ASSEMBLY__ +/* Track power state from reset to log events */ +struct __packed chipset_power_state { + u16 pm1_sts; + u16 pm1_en; + u32 pm1_cnt; + u32 gpe0_sts[GPE0_REG_MAX]; + u32 gpe0_en[GPE0_REG_MAX]; + u16 tco1_sts; + u16 tco2_sts; + u32 prsts; + u32 gen_pmcon1; + u32 gen_pmcon2; + u32 gen_pmcon3; + u32 prev_sleep_state; +}; +#endif /* !__ASSEMBLY__ */ + #endif diff --git a/include/power/acpi_pmc.h b/include/power/acpi_pmc.h index 5fbf7451369..222288b71a4 100644 --- a/include/power/acpi_pmc.h +++ b/include/power/acpi_pmc.h @@ -6,7 +6,7 @@ #ifndef __ACPI_PMC_H #define __ACPI_PMC_H
-#ifndef __ACPI__ +#ifndef __ASSEMBLY__
enum { GPE0_REG_MAX = 4, @@ -194,6 +194,6 @@ void pmc_dump_info(struct udevice *dev); */ int pmc_gpe_init(struct udevice *dev);
-#endif /* !__ACPI__ */ +#endif /* !__ASSEMBLY__ */
#endif
Add some more definitions to the iomap. These will be used by ACPI-generation code as well as the device tree.
arch/x86/include/asm/arch-apollolake/iomap.h | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/x86/include/asm/arch-apollolake/iomap.h b/arch/x86/include/asm/arch-apollolake/iomap.h index 4ce10170558..21c5f33021a 100644 --- a/arch/x86/include/asm/arch-apollolake/iomap.h +++ b/arch/x86/include/asm/arch-apollolake/iomap.h @@ -11,11 +11,27 @@
/* Put p2sb at 0xd0000000 in TPL */ #define IOMAP_P2SB_BAR 0xd0000000 +#define IOMAP_P2SB_SIZE 0x10000000
#define IOMAP_SPI_BASE 0xfe010000
#define IOMAP_ACPI_BASE 0x400 #define IOMAP_ACPI_SIZE 0x100 +#define ACPI_BASE_ADDRESS IOMAP_ACPI_BASE + +#define PMC_BAR0 0xfe042000 + +#define MCH_BASE_ADDRESS 0xfed10000 +#define MCH_SIZE 0x8000 + +#ifdef __ACPI__ +#define HPET_BASE_ADDRESS 0xfed00000 + +#define SRAM_BASE_0 0xfe900000 +#define SRAM_SIZE_0 (8 * KiB) +#define SRAM_BASE_2 0xfe902000 +#define SRAM_SIZE_2 (4 * KiB) +#endif
/* * Use UART2. To use UART1 you need to set '2' to '1', change device tree serial
Add functions to query CPU information, needed for ACPI.
Changes in v1: - Add more comments and rename cpu_get_bus_clock to cpu_get_bus_clock_khz()
arch/x86/cpu/intel_common/cpu.c | 64 +++++++++++++++++++++++++++++++ arch/x86/include/asm/cpu_common.h | 49 +++++++++++++++++++++++ include/acpi/acpigen.h | 12 ++++++ 3 files changed, 125 insertions(+)
diff --git a/arch/x86/cpu/intel_common/cpu.c b/arch/x86/cpu/intel_common/cpu.c index 509730aea96..cb4ef84013a 100644 --- a/arch/x86/cpu/intel_common/cpu.c +++ b/arch/x86/cpu/intel_common/cpu.c @@ -12,6 +12,7 @@ #include <dm.h> #include <errno.h> #include <log.h> +#include <acpi/acpigen.h> #include <asm/cpu.h> #include <asm/cpu_common.h> #include <asm/intel_regs.h> @@ -227,3 +228,66 @@ void cpu_set_eist(bool eist_status) msr.lo &= ~MISC_ENABLE_ENHANCED_SPEEDSTEP; msr_write(MSR_IA32_MISC_ENABLE, msr); } + +int cpu_get_coord_type(void) +{ + return HW_ALL; +} + +int cpu_get_min_ratio(void) +{ + msr_t msr; + + /* Get bus ratio limits and calculate clock speeds */ + msr = msr_read(MSR_PLATFORM_INFO); + + return (msr.hi >> 8) & 0xff; /* Max Efficiency Ratio */ +} + +int cpu_get_max_ratio(void) +{ + u32 ratio_max; + msr_t msr; + + if (cpu_config_tdp_levels()) { + /* Set max ratio to nominal TDP ratio */ + msr = msr_read(MSR_CONFIG_TDP_NOMINAL); + ratio_max = msr.lo & 0xff; + } else { + msr = msr_read(MSR_PLATFORM_INFO); + /* Max Non-Turbo Ratio */ + ratio_max = (msr.lo >> 8) & 0xff; + } + + return ratio_max; +} + +int cpu_get_bus_clock_khz(void) +{ + /* + * CPU bus clock is set by default here to 100MHz. This function returns + * the bus clock in KHz. + */ + return INTEL_BCLK_MHZ * 1000; +} + +int cpu_get_power_max(void) +{ + int power_unit; + msr_t msr; + + msr = msr_read(MSR_PKG_POWER_SKU_UNIT); + power_unit = 2 << ((msr.lo & 0xf) - 1); + msr = msr_read(MSR_PKG_POWER_SKU); + + return (msr.lo & 0x7fff) * 1000 / power_unit; +} + +int cpu_get_max_turbo_ratio(void) +{ + msr_t msr; + + msr = msr_read(MSR_TURBO_RATIO_LIMIT); + + return msr.lo & 0xff; +} diff --git a/arch/x86/include/asm/cpu_common.h b/arch/x86/include/asm/cpu_common.h index cdd99a90b76..a7b7112d417 100644 --- a/arch/x86/include/asm/cpu_common.h +++ b/arch/x86/include/asm/cpu_common.h @@ -128,4 +128,53 @@ void cpu_set_eist(bool eist_status); */ void cpu_set_p_state_to_turbo_ratio(void);
+/** + * cpu_get_coord_type() - Get the type of coordination for P-State transition + * + * See ACPI spec v6.3 section 8.4.6.5 _PSD (P-State Dependency) + * + * @return HW_ALL (always) + */ +int cpu_get_coord_type(void); + +/** + * cpu_get_min_ratio() - get minimum support frequency ratio for CPU + * + * @return minimum ratio + */ +int cpu_get_min_ratio(void); + +/** + * cpu_get_max_ratio() - get nominal TDP ration or max non-turbo ratio + * + * If a nominal TDP ratio is available, it is returned. Otherwise this returns + * the maximum non-turbo frequency ratio for this processor + * + * @return max ratio + */ +int cpu_get_max_ratio(void); + +/** + * cpu_get_bus_clock_khz() - Get the bus clock frequency in KHz + * + * This is the value the clock ratio is multiplied with + * + * @return bus-block frequency in KHz + */ +int cpu_get_bus_clock_khz(void); + +/** + * cpu_get_power_max() - Get maximum CPU TDP + * + * @return maximum CPU TDP (Thermal-design power) in mW + */ +int cpu_get_power_max(void); + +/** + * cpu_get_max_turbo_ratio() - Get maximum turbo ratio + * + * @return maximum ratio + */ +int cpu_get_max_turbo_ratio(void); + #endif diff --git a/include/acpi/acpigen.h b/include/acpi/acpigen.h index 34b3115bc9c..c412898169e 100644 --- a/include/acpi/acpigen.h +++ b/include/acpi/acpigen.h @@ -73,6 +73,18 @@ enum { RETURN_OP = 0xa4, };
+/** + * enum psd_coord - Coordination types for P-states + * + * The type of coordination that exists (hardware) or is required (software) as + * a result of the underlying hardware dependency + */ +enum psd_coord { + SW_ALL = 0xfc, + SW_ANY = 0xfd, + HW_ALL = 0xfe +}; + /** * acpigen_get_current() - Get the current ACPI code output pointer *
Add an implementation of the HPET (High Precision Event Timer) ACPI table. Since this is x86-specific, put it in an x86-specific file
Changes in v1: - Put this code in an x86-specific place and update commit message
arch/x86/include/asm/acpi_table.h | 10 ++++++ arch/x86/lib/acpi_table.c | 59 +++++++++++++++++++++++++++++++ include/acpi/acpi_table.h | 31 +++++++++++----- 3 files changed, 91 insertions(+), 9 deletions(-)
diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index 733085c1785..7047ee6c772 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -36,6 +36,16 @@ int acpi_create_mcfg_mmconfig(struct acpi_mcfg_mmconfig *mmconfig, u32 base, u32 acpi_fill_mcfg(u32 current); u32 acpi_fill_csrt(u32 current);
+/** + * acpi_write_hpet() - Write out a HPET table + * + * Write out the table for High-Precision Event Timers + * + * @ctx: Current ACPI context + * @return 0 if OK, -ve on error + */ +int acpi_write_hpet(struct acpi_ctx *ctx); + /** * acpi_create_gnvs() - Create a GNVS (Global Non Volatile Storage) table * diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 942b2334eab..e1900ffe42f 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -516,3 +516,62 @@ ulong acpi_get_rsdp_addr(void) { return acpi_rsdp_addr; } + +/** + * acpi_write_hpet() - Write out a HPET table + * + * Write out the table for High-Precision Event Timers + * + * @hpet: Place to put HPET table + */ +static int acpi_create_hpet(struct acpi_hpet *hpet) +{ + struct acpi_table_header *header = &hpet->header; + struct acpi_gen_regaddr *addr = &hpet->addr; + + /* + * See IA-PC HPET (High Precision Event Timers) Specification v1.0a + * https://www.intel.com/content/dam/www/public/us/en/documents/technical-speci... + */ + memset((void *)hpet, '\0', sizeof(struct acpi_hpet)); + + /* Fill out header fields. */ + acpi_fill_header(header, "HPET"); + + header->aslc_revision = ASL_REVISION; + header->length = sizeof(struct acpi_hpet); + header->revision = acpi_get_table_revision(ACPITAB_HPET); + + /* Fill out HPET address */ + addr->space_id = 0; /* Memory */ + addr->bit_width = 64; + addr->bit_offset = 0; + addr->addrl = CONFIG_HPET_ADDRESS & 0xffffffff; + addr->addrh = ((unsigned long long)CONFIG_HPET_ADDRESS) >> 32; + + hpet->id = *(u32 *)CONFIG_HPET_ADDRESS; + hpet->number = 0; + hpet->min_tick = 0; /* HPET_MIN_TICKS */ + + header->checksum = table_compute_checksum(hpet, + sizeof(struct acpi_hpet)); + + return 0; +} + +int acpi_write_hpet(struct acpi_ctx *ctx) +{ + struct acpi_hpet *hpet; + int ret; + + log_debug("ACPI: * HPET\n"); + + hpet = ctx->current; + acpi_inc_align(ctx, sizeof(struct acpi_hpet)); + acpi_create_hpet(hpet); + ret = acpi_add_table(ctx, hpet); + if (ret) + return log_msg_ret("add", ret); + + return 0; +} diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index fe9b29f3f82..f8140446a59 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -20,6 +20,9 @@ #define OEM_TABLE_ID "U-BOOTBL" /* U-Boot Table */ #define ASLC_ID "INTL" /* Intel ASL Compiler */
+/* TODO(sjg@chromium.org): Figure out how to get compiler revision */ +#define ASL_REVISION 0 + #define ACPI_RSDP_REV_ACPI_1_0 0 #define ACPI_RSDP_REV_ACPI_2_0 2
@@ -56,6 +59,15 @@ struct __packed acpi_table_header { u32 aslc_revision; /* ASL compiler revision number */ };
+struct acpi_gen_regaddr { + u8 space_id; /* Address space ID */ + u8 bit_width; /* Register size in bits */ + u8 bit_offset; /* Register bit offset */ + u8 access_size; /* Access size */ + u32 addrl; /* Register address, low 32 bits */ + u32 addrh; /* Register address, high 32 bits */ +}; + /* A maximum number of 32 ACPI tables ought to be enough for now */ #define MAX_ACPI_TABLES 32
@@ -71,6 +83,16 @@ struct acpi_xsdt { u64 entry[MAX_ACPI_TABLES]; };
+/* HPET timers */ +struct __packed acpi_hpet { + struct acpi_table_header header; + u32 id; + struct acpi_gen_regaddr addr; + u8 number; + u16 min_tick; + u8 attributes; +}; + /* FADT Preferred Power Management Profile */ enum acpi_pm_profile { ACPI_PM_UNSPECIFIED = 0, @@ -138,15 +160,6 @@ enum acpi_address_space_size { ACPI_ACCESS_SIZE_QWORD_ACCESS };
-struct acpi_gen_regaddr { - u8 space_id; /* Address space ID */ - u8 bit_width; /* Register size in bits */ - u8 bit_offset; /* Register bit offset */ - u8 access_size; /* Access size */ - u32 addrl; /* Register address, low 32 bits */ - u32 addrh; /* Register address, high 32 bits */ -}; - /* FADT (Fixed ACPI Description Table) */ struct __packed acpi_fadt { struct acpi_table_header header;
Add an implementation of the DBG2 (Debug Port Table 2) ACPI table. Adjust one of the header includes to be in the correct order, before adding more.
Note that the DBG2 table is generic but the PCI UART is x86-specific at present since it assumes an ns16550 UART. It can be generalised later if necessary.
Changes in v1: - Move ASL_REVISION define into this patch - Move acpi_create_dbg2() into generic code - Update commit message
arch/x86/include/asm/acpi_table.h | 11 ++++++ arch/x86/lib/acpi_table.c | 41 ++++++++++++++++++++ include/acpi/acpi_table.h | 40 +++++++++++++++++++ lib/acpi/acpi_table.c | 64 +++++++++++++++++++++++++++++++ 4 files changed, 156 insertions(+)
diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index 7047ee6c772..1b7ff509516 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -46,6 +46,17 @@ u32 acpi_fill_csrt(u32 current); */ int acpi_write_hpet(struct acpi_ctx *ctx);
+/** + * acpi_write_dbg2_pci_uart() - Write out a DBG2 table + * + * @ctx: Current ACPI context + * @dev: Debug UART device to describe + * @access_size: Access size for UART (e.g. ACPI_ACCESS_SIZE_DWORD_ACCESS) + * @return 0 if OK, -ve on error + */ +int acpi_write_dbg2_pci_uart(struct acpi_ctx *ctx, struct udevice *dev, + uint access_size); + /** * acpi_create_gnvs() - Create a GNVS (Global Non Volatile Storage) table * diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index e1900ffe42f..28a27103342 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -15,6 +15,7 @@ #include <serial.h> #include <version.h> #include <acpi/acpigen.h> +#include <acpi/acpi_device.h> #include <acpi/acpi_table.h> #include <asm/acpi/global_nvs.h> #include <asm/ioapic.h> @@ -575,3 +576,43 @@ int acpi_write_hpet(struct acpi_ctx *ctx)
return 0; } + +int acpi_write_dbg2_pci_uart(struct acpi_ctx *ctx, struct udevice *dev, + uint access_size) +{ + struct acpi_dbg2_header *dbg2 = ctx->current; + char path[ACPI_PATH_MAX]; + struct acpi_gen_regaddr address; + phys_addr_t addr; + int ret; + + if (!device_active(dev)) { + log_info("Device not enabled\n"); + return -EACCES; + } + /* + * PCI devices don't remember their resource allocation information in + * U-Boot at present. We assume that MMIO is used for the UART and that + * the address space is 32 bytes: ns16550 uses 8 registers of up to + * 32-bits each. This is only for debugging so it is not a big deal. + */ + addr = dm_pci_read_bar32(dev, 0); + printf("UART addr %lx\n", (ulong)addr); + + memset(&address, '\0', sizeof(address)); + address.space_id = ACPI_ADDRESS_SPACE_MEMORY; + address.addrl = (uint32_t)addr; + address.addrh = (uint32_t)((addr >> 32) & 0xffffffff); + address.access_size = access_size; + + ret = acpi_device_path(dev, path, sizeof(path)); + if (ret) + return log_msg_ret("path", ret); + acpi_create_dbg2(dbg2, ACPI_DBG2_SERIAL_PORT, + ACPI_DBG2_16550_COMPATIBLE, &address, 0x1000, path); + + acpi_inc_align(ctx, dbg2->header.length); + acpi_add_table(ctx, dbg2); + + return 0; +} diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index f8140446a59..c826a797f5b 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -448,6 +448,29 @@ struct __packed acpi_dmar {
#define ACPI_DBG2_UNKNOWN 0x00FF
+/* DBG2: Microsoft Debug Port Table 2 header */ +struct __packed acpi_dbg2_header { + struct acpi_table_header header; + u32 devices_offset; + u32 devices_count; +}; + +/* DBG2: Microsoft Debug Port Table 2 device entry */ +struct __packed acpi_dbg2_device { + u8 revision; + u16 length; + u8 address_count; + u16 namespace_string_length; + u16 namespace_string_offset; + u16 oem_data_length; + u16 oem_data_offset; + u16 port_type; + u16 port_subtype; + u8 reserved[2]; + u16 base_address_offset; + u16 address_size_offset; +}; + /* SPCR (Serial Port Console Redirection table) */ struct __packed acpi_spcr { struct acpi_table_header header; @@ -522,6 +545,23 @@ int acpi_get_table_revision(enum acpi_tables table); */ int acpi_create_dmar(struct acpi_dmar *dmar, enum dmar_flags flags);
+/** + * acpi_create_dbg2() - Create a DBG2 table + * + * This table describes how to access the debug UART + * + * @dbg2: Place to put information + * @port_type: Serial port type (see ACPI_DBG2_...) + * @port_subtype: Serial port sub-type (see ACPI_DBG2_...) + * @address: ACPI address of port + * @address_size: Size of address space + * @device_path: Path of device (created using acpi_device_path()) + */ +void acpi_create_dbg2(struct acpi_dbg2_header *dbg2, + int port_type, int port_subtype, + struct acpi_gen_regaddr *address, uint32_t address_size, + const char *device_path); + /** * acpi_fill_header() - Set up a new table header * diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index acc55e7fad6..908d8903893 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -264,3 +264,67 @@ void acpi_setup_base_tables(struct acpi_ctx *ctx, void *start) */ acpi_align64(ctx); } + +void acpi_create_dbg2(struct acpi_dbg2_header *dbg2, + int port_type, int port_subtype, + struct acpi_gen_regaddr *address, u32 address_size, + const char *device_path) +{ + uintptr_t current; + struct acpi_dbg2_device *device; + u32 *dbg2_addr_size; + struct acpi_table_header *header; + size_t path_len; + const char *path; + char *namespace; + + /* Fill out header fields. */ + current = (uintptr_t)dbg2; + memset(dbg2, '\0', sizeof(struct acpi_dbg2_header)); + header = &dbg2->header; + + header->revision = acpi_get_table_revision(ACPITAB_DBG2); + acpi_fill_header(header, "DBG2"); + header->aslc_revision = ASL_REVISION; + + /* One debug device defined */ + dbg2->devices_offset = sizeof(struct acpi_dbg2_header); + dbg2->devices_count = 1; + current += sizeof(struct acpi_dbg2_header); + + /* Device comes after the header */ + device = (struct acpi_dbg2_device *)current; + memset(device, 0, sizeof(struct acpi_dbg2_device)); + current += sizeof(struct acpi_dbg2_device); + + device->revision = 0; + device->address_count = 1; + device->port_type = port_type; + device->port_subtype = port_subtype; + + /* Base Address comes after device structure */ + memcpy((void *)current, address, sizeof(struct acpi_gen_regaddr)); + device->base_address_offset = current - (uintptr_t)device; + current += sizeof(struct acpi_gen_regaddr); + + /* Address Size comes after address structure */ + dbg2_addr_size = (uint32_t *)current; + device->address_size_offset = current - (uintptr_t)device; + *dbg2_addr_size = address_size; + current += sizeof(uint32_t); + + /* Namespace string comes last, use '.' if not provided */ + path = device_path ? : "."; + /* Namespace string length includes NULL terminator */ + path_len = strlen(path) + 1; + namespace = (char *)current; + device->namespace_string_length = path_len; + device->namespace_string_offset = current - (uintptr_t)device; + strncpy(namespace, path, path_len); + current += path_len; + + /* Update structure lengths and checksum */ + device->length = current - (uintptr_t)device; + header->length = current - (uintptr_t)dbg2; + header->checksum = table_compute_checksum(dbg2, header->length); +}
ACPI has a number of CPU-related tables. Add utility functions to write out the basic packages.
(no changes since v1)
include/acpi/acpigen.h | 39 +++++++++++++++ lib/acpi/acpigen.c | 55 +++++++++++++++++++++ test/dm/acpigen.c | 106 +++++++++++++++++++++++++++++++++++++++++ 3 files changed, 200 insertions(+)
diff --git a/include/acpi/acpigen.h b/include/acpi/acpigen.h index c412898169e..3a2c6339d5e 100644 --- a/include/acpi/acpigen.h +++ b/include/acpi/acpigen.h @@ -64,7 +64,9 @@ enum { OR_OP = 0x7d, NOT_OP = 0x80, DEVICE_OP = 0x82, + PROCESSOR_OP = 0x83, POWER_RES_OP = 0x84, + NOTIFY_OP = 0x86, LEQUAL_OP = 0x93, TO_BUFFER_OP = 0x96, TO_INTEGER_OP = 0x99, @@ -777,4 +779,41 @@ void acpigen_write_dsm_uuid_end(struct acpi_ctx *ctx); */ void acpigen_write_dsm_end(struct acpi_ctx *ctx);
+/** + * acpigen_write_processor() - Write a Processor package + * + * This emits a Processor package header with the required information. The + * caller must complete the information and call acpigen_pop_len() at the end + * + * @ctx: ACPI context pointer + * @cpuindex: CPU number + * @pblock_addr: PBlk system IO address + * @pblock_len: PBlk length + */ +void acpigen_write_processor(struct acpi_ctx *ctx, uint cpuindex, + u32 pblock_addr, uint pblock_len); + +/** + * acpigen_write_processor_package() - Write a package containing the processors + * + * The package containins the name of each processor in the SoC + * + * @ctx: ACPI context pointer + * @name: Package name (.e.g "PPKG") + * @first_core: Number of the first core (e.g. 0) + * @core_count: Number of cores (e.g. 4) + */ +void acpigen_write_processor_package(struct acpi_ctx *ctx, const char *name, + uint first_core, uint core_count); + +/** + * acpigen_write_processor_cnot() - Write a processor notification method + * + * This writes a method that notifies all CPU cores + * + * @ctx: ACPI context pointer + * @num_cores: Number of CPU cores + */ +void acpigen_write_processor_cnot(struct acpi_ctx *ctx, const uint num_cores); + #endif diff --git a/lib/acpi/acpigen.c b/lib/acpi/acpigen.c index d859f378413..b9985075cde 100644 --- a/lib/acpi/acpigen.c +++ b/lib/acpi/acpigen.c @@ -17,6 +17,9 @@ #include <acpi/acpi_table.h> #include <dm/acpi.h>
+/* CPU path format */ +#define ACPI_CPU_STRING "\_PR.CP%02d" + u8 *acpigen_get_current(struct acpi_ctx *ctx) { return ctx->current; @@ -340,6 +343,58 @@ void acpigen_write_method_serialized(struct acpi_ctx *ctx, const char *name, ACPI_METHOD_SERIALIZED_MASK); }
+void acpigen_write_processor(struct acpi_ctx *ctx, uint cpuindex, + u32 pblock_addr, uint pblock_len) +{ + /* + * Processor (_PR.CPnn, cpuindex, pblock_addr, pblock_len) + * { + */ + char pscope[16]; + + acpigen_emit_ext_op(ctx, PROCESSOR_OP); + acpigen_write_len_f(ctx); + + snprintf(pscope, sizeof(pscope), ACPI_CPU_STRING, cpuindex); + acpigen_emit_namestring(ctx, pscope); + acpigen_emit_byte(ctx, cpuindex); + acpigen_emit_dword(ctx, pblock_addr); + acpigen_emit_byte(ctx, pblock_len); +} + +void acpigen_write_processor_package(struct acpi_ctx *ctx, + const char *const name, + const uint first_core, + const uint core_count) +{ + uint i; + char pscope[16]; + + acpigen_write_name(ctx, name); + acpigen_write_package(ctx, core_count); + for (i = first_core; i < first_core + core_count; ++i) { + snprintf(pscope, sizeof(pscope), ACPI_CPU_STRING, i); + acpigen_emit_namestring(ctx, pscope); + } + acpigen_pop_len(ctx); +} + +void acpigen_write_processor_cnot(struct acpi_ctx *ctx, const uint num_cores) +{ + int core_id; + + acpigen_write_method(ctx, "\_PR.CNOT", 1); + for (core_id = 0; core_id < num_cores; core_id++) { + char buffer[30]; + + snprintf(buffer, sizeof(buffer), ACPI_CPU_STRING, core_id); + acpigen_emit_byte(ctx, NOTIFY_OP); + acpigen_emit_namestring(ctx, buffer); + acpigen_emit_byte(ctx, ARG0_OP); + } + acpigen_pop_len(ctx); +} + void acpigen_write_device(struct acpi_ctx *ctx, const char *name) { acpigen_emit_ext_op(ctx, DEVICE_OP); diff --git a/test/dm/acpigen.c b/test/dm/acpigen.c index 381fcb97022..74b7e23aab3 100644 --- a/test/dm/acpigen.c +++ b/test/dm/acpigen.c @@ -1344,3 +1344,109 @@ static int dm_test_acpi_write_i2c_dsm(struct unit_test_state *uts) } DM_TEST(dm_test_acpi_write_i2c_dsm, 0);
+/* Test emitting a processor */ +static int dm_test_acpi_write_processor(struct unit_test_state *uts) +{ + const int cpuindex = 6; + const u32 pblock_addr = 0x12345600; + const u32 pblock_len = 0x60; + struct acpi_ctx *ctx; + u8 *ptr; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_processor(ctx, cpuindex, pblock_addr, pblock_len); + acpigen_pop_len(ctx); + + ut_asserteq(EXT_OP_PREFIX, *ptr++); + ut_asserteq(PROCESSOR_OP, *ptr++); + ut_asserteq(0x13, acpi_test_get_length(ptr)); + ptr += 3; + ut_asserteq_strn("\._PR_CP06", (char *)ptr); + ptr += 10; + ut_asserteq(cpuindex, *ptr++); + ut_asserteq(pblock_addr, get_unaligned((u32 *)ptr)); + ptr += 4; + ut_asserteq(pblock_len, *ptr++); + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_processor, 0); + +/* Test emitting a processor package */ +static int dm_test_acpi_write_processor_package(struct unit_test_state *uts) +{ + const int core_count = 3; + struct acpi_ctx *ctx; + u8 *ptr; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_processor_package(ctx, "XCPU", 0, core_count); + + ut_asserteq(NAME_OP, *ptr++); + ut_asserteq_strn("XCPU", (char *)ptr); + ptr += 4; + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(core_count, *ptr++); + + ut_asserteq_strn("\._PR_CP00", (char *)ptr); + ptr += 10; + ut_asserteq_strn("\._PR_CP01", (char *)ptr); + ptr += 10; + ut_asserteq_strn("\._PR_CP02", (char *)ptr); + ptr += 10; + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_processor_package, 0); + +/* Test emitting a processor notification package */ +static int dm_test_acpi_write_processor_cnot(struct unit_test_state *uts) +{ + const int core_count = 3; + struct acpi_ctx *ctx; + u8 *ptr; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_processor_cnot(ctx, core_count); + + ut_asserteq(METHOD_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq_strn("\._PR_CNOT", (char *)ptr); + ptr += 10; + ut_asserteq(1, *ptr++); + + ut_asserteq(NOTIFY_OP, *ptr++); + ut_asserteq_strn("\._PR_CP00", (char *)ptr); + ptr += 10; + ut_asserteq(ARG0_OP, *ptr++); + ut_asserteq(NOTIFY_OP, *ptr++); + ut_asserteq_strn("\._PR_CP01", (char *)ptr); + ptr += 10; + ut_asserteq(ARG0_OP, *ptr++); + ut_asserteq(NOTIFY_OP, *ptr++); + ut_asserteq_strn("\._PR_CP02", (char *)ptr); + ptr += 10; + ut_asserteq(ARG0_OP, *ptr++); + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_processor_cnot, 0);
These are needed for the CPU tables. Add them into an x86-specific file since we do not support them on sandbox, or include tests.
Changes in v1: - Split PCT and PTC tables into a separate patch
arch/x86/include/asm/acpigen.h | 35 +++++++++++++ arch/x86/lib/Makefile | 2 +- arch/x86/lib/acpigen.c | 96 ++++++++++++++++++++++++++++++++++ 3 files changed, 132 insertions(+), 1 deletion(-) create mode 100644 arch/x86/include/asm/acpigen.h create mode 100644 arch/x86/lib/acpigen.c
diff --git a/arch/x86/include/asm/acpigen.h b/arch/x86/include/asm/acpigen.h new file mode 100644 index 00000000000..c531dd61d53 --- /dev/null +++ b/arch/x86/include/asm/acpigen.h @@ -0,0 +1,35 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Generation of x86-specific ACPI tables + * + * Copyright 2020 Google LLC + */ + +#ifndef __ASM_ACPIGEN_H__ +#define __ASM_ACPIGEN_H__ + +struct acpi_ctx; + +/** + * acpigen_write_empty_pct() - Write an empty PCT + * + * See ACPI v6.3 section 8.4.6.1: _PCT (Performance Control) + * + * This writes an empty table so that CPU performance works as expected + * + * @ctx: ACPI context pointer + */ +void acpigen_write_empty_pct(struct acpi_ctx *ctx); + +/** + * acpigen_write_empty_ptc() - Write an empty PTC + * + * See ACPI v6.3 section 8.4.5.1: _PTC (Processor Throttling Control) + * + * This writes an empty table so that CPU performance works as expected + * + * @ctx: ACPI context pointer + */ +void acpigen_write_empty_ptc(struct acpi_ctx *ctx); + +#endif /* __ASM_ACPI_H__ */ diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index 1185a88c27c..f04d275dd9a 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -38,7 +38,7 @@ obj-y += sfi.o obj-y += acpi.o obj-$(CONFIG_HAVE_ACPI_RESUME) += acpi_s3.o ifndef CONFIG_QEMU -obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi_table.o +obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi_table.o acpigen.o endif obj-y += tables.o ifndef CONFIG_SPL_BUILD diff --git a/arch/x86/lib/acpigen.c b/arch/x86/lib/acpigen.c new file mode 100644 index 00000000000..ea2ec2a9083 --- /dev/null +++ b/arch/x86/lib/acpigen.c @@ -0,0 +1,96 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Google LLC + */ + +#include <common.h> +#include <acpi/acpigen.h> +#include <acpi/acpi_table.h> +#include <asm/acpigen.h> + +void acpigen_write_empty_pct(struct acpi_ctx *ctx) +{ + /* + * Name (_PCT, Package (0x02) + * { + * ResourceTemplate () + * { + * Register (FFixedHW, + * 0x00, // Bit Width + * 0x00, // Bit Offset + * 0x0000000000000000, // Address + * ,) + * }, + * + * ResourceTemplate () + * { + * Register (FFixedHW, + * 0x00, // Bit Width + * 0x00, // Bit Offset + * 0x0000000000000000, // Address + * ,) + * } + * }) + */ + static char stream[] = { + /* 00000030 "0._PCT.," */ + 0x08, 0x5f, 0x50, 0x43, 0x54, 0x12, 0x2c, + /* 00000038 "........" */ + 0x02, 0x11, 0x14, 0x0a, 0x11, 0x82, 0x0c, 0x00, + /* 00000040 "........" */ + 0x7f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 00000048 "....y..." */ + 0x00, 0x00, 0x00, 0x00, 0x79, 0x00, 0x11, 0x14, + /* 00000050 "........" */ + 0x0a, 0x11, 0x82, 0x0c, 0x00, 0x7f, 0x00, 0x00, + /* 00000058 "........" */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x79, 0x00 + }; + acpigen_emit_stream(ctx, stream, ARRAY_SIZE(stream)); +} + +void acpigen_write_empty_ptc(struct acpi_ctx *ctx) +{ + /* + * Name (_PTC, Package (0x02) + * { + * ResourceTemplate () + * { + * Register (FFixedHW, + * 0x00, // Bit Width + * 0x00, // Bit Offset + * 0x0000000000000000, // Address + * ,) + * }, + * + * ResourceTemplate () + * { + * Register (FFixedHW, + * 0x00, // Bit Width + * 0x00, // Bit Offset + * 0x0000000000000000, // Address + * ,) + * } + * }) + */ + struct acpi_gen_regaddr addr = { + .space_id = ACPI_ADDRESS_SPACE_FIXED, + .bit_width = 0, + .bit_offset = 0, + .access_size = 0, + .addrl = 0, + .addrh = 0, + }; + + acpigen_write_name(ctx, "_PTC"); + acpigen_write_package(ctx, 2); + + /* ControlRegister */ + acpigen_write_register_resource(ctx, &addr); + + /* StatusRegister */ + acpigen_write_register_resource(ctx, &addr); + + acpigen_pop_len(ctx); +}
This adds tables relating to P-States and C-States.
include/acpi/acpigen.h | 162 +++++++++++++++++++++++ lib/acpi/acpigen.c | 167 +++++++++++++++++++++++ test/dm/acpigen.c | 294 +++++++++++++++++++++++++++++++++++++++++ 3 files changed, 623 insertions(+)
diff --git a/include/acpi/acpigen.h b/include/acpi/acpigen.h index 3a2c6339d5e..976f4dbb9af 100644 --- a/include/acpi/acpigen.h +++ b/include/acpi/acpigen.h @@ -10,8 +10,10 @@ #ifndef __ACPI_ACPIGEN_H #define __ACPI_ACPIGEN_H
+#include <acpi/acpi_table.h> #include <linux/types.h>
+struct acpi_cstate; struct acpi_ctx; struct acpi_gen_regaddr; struct acpi_gpio; @@ -87,6 +89,53 @@ enum psd_coord { HW_ALL = 0xfe };
+/** + * enum csd_coord - Coordination types for C-states + * + * The type of coordination that exists (hardware) or is required (software) as + * a result of the underlying hardware dependency + */ +enum csd_coord { + CSD_HW_ALL = 0xfe, +}; + +/** + * struct acpi_cstate - Information about a C-State + * + * @ctype: C State type (1=C1, 2=C2, 3=C3) + * @latency: Worst-case latency to enter and exit the C State (in uS) + * @power: Average power consumption of the processor when in this C-State (mW) + * @resource: Register to read to place the processor in this state + */ +struct acpi_cstate { + uint ctype; + uint latency; + uint power; + struct acpi_gen_regaddr resource; +}; + +/** + * struct acpi_tstate - Information about a Throttling Supported State + * + * See ACPI v6.3 section 8.4.5.2: _TSS (Throttling Supported States) + * + * @percent: Percent of the core CPU operating frequency that will be + * available when this throttling state is invoked + * @power: Throttling state’s maximum power dissipation (mw) + * @latency: Worst-case latency (uS) that the CPU is unavailable during a + * transition from any throttling state to this throttling state + * @control: Value to be written to the Processor Control Register + * (THROTTLE_CTRL) to initiate a transition to this throttling state + * @status: Value in THROTTLE_STATUS when in this state + */ +struct acpi_tstate { + uint percent; + uint power; + uint latency; + uint control; + uint status; +}; + /** * acpigen_get_current() - Get the current ACPI code output pointer * @@ -816,4 +865,117 @@ void acpigen_write_processor_package(struct acpi_ctx *ctx, const char *name, */ void acpigen_write_processor_cnot(struct acpi_ctx *ctx, const uint num_cores);
+/** + * acpigen_write_ppc() - generates a function returning max P-states + * + * @ctx: ACPI context pointer + * @num_pstates: Number of pstates to return + */ +void acpigen_write_ppc(struct acpi_ctx *ctx, uint num_pstates); + +/** + * acpigen_write_ppc() - generates a function returning PPCM + * + * This returns the maximum number of supported P-states, as saved in the + * variable PPCM + * + * @ctx: ACPI context pointer + */ +void acpigen_write_ppc_nvs(struct acpi_ctx *ctx); + +/** + * acpigen_write_tpc() - Write a _TPC method that returns the TPC limit + * + * @ctx: ACPI context pointer + * @gnvs_tpc_limit: Variable that holds the TPC limit + */ +void acpigen_write_tpc(struct acpi_ctx *ctx, const char *gnvs_tpc_limit); + +/** + * acpigen_write_pss_package() - Write a PSS package + * + * See ACPI v6.3 section 8.4.6: Processor Performance Control + * + * @ctx: ACPI context pointer + * @corefreq: CPU core frequency in MHz + * @translat: worst-case latency in uS that the CPU is unavailable during a + * transition from any performance state to this performance state + * @busmlat: worst-case latency in microseconds that Bus Masters are prevented + * from accessing memory during a transition from any performance state to + * this performance state + * @control: Value to write to PERF_CTRL to move to this performance state + * @status: Expected PERF_STATUS value when in this state + */ +void acpigen_write_pss_package(struct acpi_ctx *ctx, uint corefreq, uint power, + uint translat, uint busmlat, uint control, + uint status); + +/** + * acpigen_write_psd_package() - Write a PSD package + * + * Writes a P-State dependency package + * + * See ACPI v6.3 section 8.4.6.5: _PSD (P-State Dependency) + * + * @ctx: ACPI context pointer + * @domain: Dependency domain number to which this P state entry belongs + * @numprocs: Number of processors belonging to the domain for this logical + * processor’s P-states + * @coordtype: Coordination type + */ +void acpigen_write_psd_package(struct acpi_ctx *ctx, uint domain, uint numprocs, + enum psd_coord coordtype); + +/** + * acpigen_write_cst_package() - Write a _CST package + * + * See ACPI v6.3 section 8.4.2.1: _CST (C States) + * + * @ctx: ACPI context pointer + * @entry: Array of entries + * @nentries; Number of entries + */ +void acpigen_write_cst_package(struct acpi_ctx *ctx, + const struct acpi_cstate *entry, int nentries); + +/** + * acpigen_write_csd_package() - Write a _CSD Package + * + * See ACPI v6.3 section 8.4.2.2: _CSD (C-State Dependency) + * + * @ctx: ACPI context pointer + * @domain: dependency domain number to which this C state entry belongs + * @numprocs: number of processors belonging to the domain for the particular + * C-state + * @coordtype: Co-ordination type + * @index: Index of the C-State entry in the _CST object for which the + * dependency applies + */ +void acpigen_write_csd_package(struct acpi_ctx *ctx, uint domain, uint numprocs, + enum csd_coord coordtype, uint index); + +/** + * acpigen_write_tss_package() - Write a _TSS package + * + * @ctx: ACPI context pointer + * @entry: Entries to write + * @nentries: Number of entries to write + */ +void acpigen_write_tss_package(struct acpi_ctx *ctx, + struct acpi_tstate *entry, int nentries); + +/** + * acpigen_write_tsd_package() - Write a _TSD package + * + * See ACPI v6.3 section 8.4.5.4: _TSD (T-State Dependency) + * + * @ctx: ACPI context pointer + * @domain: dependency domain number to which this T state entry belongs + * @numprocs: Number of processors belonging to the domain for this logical + * processor’s T-states + * @coordtype: Coordination type + */ +void acpigen_write_tsd_package(struct acpi_ctx *ctx, uint domain, uint numprocs, + enum psd_coord coordtype); + #endif diff --git a/lib/acpi/acpigen.c b/lib/acpi/acpigen.c index b9985075cde..e395226e3de 100644 --- a/lib/acpi/acpigen.c +++ b/lib/acpi/acpigen.c @@ -481,6 +481,53 @@ void acpigen_write_register_resource(struct acpi_ctx *ctx, acpigen_write_resourcetemplate_footer(ctx); }
+void acpigen_write_ppc(struct acpi_ctx *ctx, uint num_pstates) +{ + /* + * Method (_PPC, 0, NotSerialized) + * { + * Return (num_pstates) + * } + */ + acpigen_write_method(ctx, "_PPC", 0); + acpigen_emit_byte(ctx, RETURN_OP); + acpigen_write_byte(ctx, num_pstates); + acpigen_pop_len(ctx); +} + +/* + * Generates a func with max supported P-states saved + * in the variable PPCM. + */ +void acpigen_write_ppc_nvs(struct acpi_ctx *ctx) +{ + /* + * Method (_PPC, 0, NotSerialized) + * { + * Return (PPCM) + * } + */ + acpigen_write_method(ctx, "_PPC", 0); + acpigen_emit_byte(ctx, RETURN_OP); + acpigen_emit_namestring(ctx, "PPCM"); + acpigen_pop_len(ctx); +} + +void acpigen_write_tpc(struct acpi_ctx *ctx, const char *gnvs_tpc_limit) +{ + /* + * // Sample _TPC method + * Method (_TPC, 0, NotSerialized) + * { + * Return (\TLVL) + * } + */ + acpigen_write_method(ctx, "_TPC", 0); + acpigen_emit_byte(ctx, RETURN_OP); + acpigen_emit_namestring(ctx, gnvs_tpc_limit); + acpigen_pop_len(ctx); +} + void acpigen_write_prw(struct acpi_ctx *ctx, uint wake, uint level) { /* Name (_PRW, Package () { wake, level } */ @@ -491,6 +538,126 @@ void acpigen_write_prw(struct acpi_ctx *ctx, uint wake, uint level) acpigen_pop_len(ctx); }
+void acpigen_write_pss_package(struct acpi_ctx *ctx, u32 core_freq, u32 power, + u32 trans_lat, u32 busm_lat, u32 control, + u32 status) +{ + acpigen_write_package(ctx, 6); + acpigen_write_dword(ctx, core_freq); + acpigen_write_dword(ctx, power); + acpigen_write_dword(ctx, trans_lat); + acpigen_write_dword(ctx, busm_lat); + acpigen_write_dword(ctx, control); + acpigen_write_dword(ctx, status); + acpigen_pop_len(ctx); + + log_debug("PSS: %uMHz power %u control 0x%x status 0x%x\n", + core_freq, power, control, status); +} + +void acpigen_write_psd_package(struct acpi_ctx *ctx, uint domain, uint numprocs, + enum psd_coord coordtype) +{ + acpigen_write_name(ctx, "_PSD"); + acpigen_write_package(ctx, 1); + acpigen_write_package(ctx, 5); + acpigen_write_byte(ctx, 5); // 5 values + acpigen_write_byte(ctx, 0); // revision 0 + acpigen_write_dword(ctx, domain); + acpigen_write_dword(ctx, coordtype); + acpigen_write_dword(ctx, numprocs); + acpigen_pop_len(ctx); + acpigen_pop_len(ctx); +} + +static void acpigen_write_cst_package_entry(struct acpi_ctx *ctx, + const struct acpi_cstate *cstate) +{ + acpigen_write_package(ctx, 4); + acpigen_write_register_resource(ctx, &cstate->resource); + acpigen_write_dword(ctx, cstate->ctype); + acpigen_write_dword(ctx, cstate->latency); + acpigen_write_dword(ctx, cstate->power); + acpigen_pop_len(ctx); +} + +void acpigen_write_cst_package(struct acpi_ctx *ctx, + const struct acpi_cstate *cstate, int nentries) +{ + int i; + + acpigen_write_name(ctx, "_CST"); + acpigen_write_package(ctx, nentries + 1); + acpigen_write_dword(ctx, nentries); + + for (i = 0; i < nentries; i++) + acpigen_write_cst_package_entry(ctx, cstate + i); + + acpigen_pop_len(ctx); +} + +void acpigen_write_csd_package(struct acpi_ctx *ctx, uint domain, uint numprocs, + enum csd_coord coordtype, uint index) +{ + acpigen_write_name(ctx, "_CSD"); + acpigen_write_package(ctx, 1); + acpigen_write_package(ctx, 6); + acpigen_write_byte(ctx, 6); // 6 values + acpigen_write_byte(ctx, 0); // revision 0 + acpigen_write_dword(ctx, domain); + acpigen_write_dword(ctx, coordtype); + acpigen_write_dword(ctx, numprocs); + acpigen_write_dword(ctx, index); + acpigen_pop_len(ctx); + acpigen_pop_len(ctx); +} + +void acpigen_write_tss_package(struct acpi_ctx *ctx, + struct acpi_tstate *entry, int nentries) +{ + /* + * Sample _TSS package with 100% and 50% duty cycles + * Name (_TSS, Package (0x02) + * { + * Package(){100, 1000, 0, 0x00, 0) + * Package(){50, 520, 0, 0x18, 0) + * }) + */ + struct acpi_tstate *tstate = entry; + int i; + + acpigen_write_name(ctx, "_TSS"); + acpigen_write_package(ctx, nentries); + + for (i = 0; i < nentries; i++) { + acpigen_write_package(ctx, 5); + acpigen_write_dword(ctx, tstate->percent); + acpigen_write_dword(ctx, tstate->power); + acpigen_write_dword(ctx, tstate->latency); + acpigen_write_dword(ctx, tstate->control); + acpigen_write_dword(ctx, tstate->status); + acpigen_pop_len(ctx); + tstate++; + } + + acpigen_pop_len(ctx); +} + +void acpigen_write_tsd_package(struct acpi_ctx *ctx, u32 domain, u32 numprocs, + enum psd_coord coordtype) +{ + acpigen_write_name(ctx, "_TSD"); + acpigen_write_package(ctx, 1); + acpigen_write_package(ctx, 5); + acpigen_write_byte(ctx, 5); // 5 values + acpigen_write_byte(ctx, 0); // revision 0 + acpigen_write_dword(ctx, domain); + acpigen_write_dword(ctx, coordtype); + acpigen_write_dword(ctx, numprocs); + acpigen_pop_len(ctx); + acpigen_pop_len(ctx); +} + /* * ToUUID(uuid) * diff --git a/test/dm/acpigen.c b/test/dm/acpigen.c index 74b7e23aab3..3ec2743af9f 100644 --- a/test/dm/acpigen.c +++ b/test/dm/acpigen.c @@ -1450,3 +1450,297 @@ static int dm_test_acpi_write_processor_cnot(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_acpi_write_processor_cnot, 0); + +/* Test acpigen_write_tpc */ +static int dm_test_acpi_write_tpc(struct unit_test_state *uts) +{ + struct acpi_ctx *ctx; + u8 *ptr; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_tpc(ctx, "\TLVL"); + + ut_asserteq(METHOD_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq_strn("_TPC", (char *)ptr); + ptr += 4; + ut_asserteq(0, *ptr++); + ut_asserteq(RETURN_OP, *ptr++); + ut_asserteq_strn("\TLVL", (char *)ptr); + ptr += 5; + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_tpc, 0); + +/* Test acpigen_write_pss_package(), etc. */ +static int dm_test_acpi_write_pss_psd(struct unit_test_state *uts) +{ + struct acpi_ctx *ctx; + u8 *ptr; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_pss_package(ctx, 1, 2, 3, 4, 5, 6); + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(6, *ptr++); + + ut_asserteq(DWORD_PREFIX, *ptr++); + ut_asserteq(1, get_unaligned((u32 *)ptr)); + ptr += 5; + + ut_asserteq(2, get_unaligned((u32 *)ptr)); + ptr += 5; + + ut_asserteq(3, get_unaligned((u32 *)ptr)); + ptr += 5; + + ut_asserteq(4, get_unaligned((u32 *)ptr)); + ptr += 5; + + ut_asserteq(5, get_unaligned((u32 *)ptr)); + ptr += 5; + + ut_asserteq(6, get_unaligned((u32 *)ptr)); + ptr += 4; + + acpigen_write_psd_package(ctx, 6, 7, HW_ALL); + ut_asserteq(NAME_OP, *ptr++); + ut_asserteq_strn("_PSD", (char *)ptr); + ptr += 4; + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(1, *ptr++); + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(5, *ptr++); + + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(5, *ptr++); + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(0, *ptr++); + + ut_asserteq(DWORD_PREFIX, *ptr++); + ut_asserteq(6, get_unaligned((u32 *)ptr)); + ptr += 5; + + ut_asserteq(HW_ALL, get_unaligned((u32 *)ptr)); + ptr += 5; + + ut_asserteq(7, get_unaligned((u32 *)ptr)); + ptr += 4; + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_pss_psd, 0); + +/* Test acpi_write_cst_package() */ +static int dm_test_acpi_write_cst(struct unit_test_state *uts) +{ + static struct acpi_cstate cstate_map[] = { + { + /* C1 */ + .ctype = 1, /* ACPI C1 */ + .latency = 1, + .power = 1000, + .resource = { + .space_id = ACPI_ADDRESS_SPACE_FIXED, + }, + }, { + .ctype = 2, /* ACPI C2 */ + .latency = 50, + .power = 10, + .resource = { + .space_id = ACPI_ADDRESS_SPACE_IO, + .bit_width = 8, + .addrl = 0x415, + }, + }, + }; + int nentries = ARRAY_SIZE(cstate_map); + struct acpi_ctx *ctx; + u8 *ptr; + int i; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_cst_package(ctx, cstate_map, nentries); + + ut_asserteq(NAME_OP, *ptr++); + ut_asserteq_strn("_CST", (char *)ptr); + ptr += 4; + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(nentries + 1, *ptr++); + ut_asserteq(DWORD_PREFIX, *ptr++); + ut_asserteq(nentries, get_unaligned((u32 *)ptr)); + ptr += 4; + + for (i = 0; i < nentries; i++) { + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(4, *ptr++); + ut_asserteq(BUFFER_OP, *ptr++); + ptr += 0x17; + ut_asserteq(DWORD_PREFIX, *ptr++); + ut_asserteq(cstate_map[i].ctype, get_unaligned((u32 *)ptr)); + ptr += 5; + ut_asserteq(cstate_map[i].latency, get_unaligned((u32 *)ptr)); + ptr += 5; + ut_asserteq(cstate_map[i].power, get_unaligned((u32 *)ptr)); + ptr += 4; + } + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_cst, 0); + +/* Test acpi_write_cst_package() */ +static int dm_test_acpi_write_csd(struct unit_test_state *uts) +{ + struct acpi_ctx *ctx; + u8 *ptr; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_csd_package(ctx, 12, 34, CSD_HW_ALL, 56); + + ut_asserteq(NAME_OP, *ptr++); + ut_asserteq_strn("_CSD", (char *)ptr); + ptr += 4; + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(1, *ptr++); + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(6, *ptr++); + + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(6, *ptr++); + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(0, *ptr++); + ut_asserteq(DWORD_PREFIX, *ptr++); + ut_asserteq(12, get_unaligned((u32 *)ptr)); + ptr += 5; + ut_asserteq(CSD_HW_ALL, get_unaligned((u32 *)ptr)); + ptr += 5; + ut_asserteq(34, get_unaligned((u32 *)ptr)); + ptr += 5; + ut_asserteq(56, get_unaligned((u32 *)ptr)); + ptr += 4; + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_csd, 0); + +/* Test acpigen_write_tss_package() */ +static int dm_test_acpi_write_tss(struct unit_test_state *uts) +{ + static struct acpi_tstate tstate_list[] = { + { 1, 2, 3, 4, 5, }, + { 6, 7, 8, 9, 10, }, + }; + int nentries = ARRAY_SIZE(tstate_list); + struct acpi_ctx *ctx; + u8 *ptr; + int i; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_tss_package(ctx, tstate_list, nentries); + + ut_asserteq(NAME_OP, *ptr++); + ut_asserteq_strn("_TSS", (char *)ptr); + ptr += 4; + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(nentries, *ptr++); + + for (i = 0; i < nentries; i++) { + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(5, *ptr++); + ut_asserteq(DWORD_PREFIX, *ptr++); + ut_asserteq(tstate_list[i].percent, get_unaligned((u32 *)ptr)); + ptr += 5; + ut_asserteq(tstate_list[i].power, get_unaligned((u32 *)ptr)); + ptr += 5; + ut_asserteq(tstate_list[i].latency, get_unaligned((u32 *)ptr)); + ptr += 5; + ut_asserteq(tstate_list[i].control, get_unaligned((u32 *)ptr)); + ptr += 5; + ut_asserteq(tstate_list[i].status, get_unaligned((u32 *)ptr)); + ptr += 4; + } + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_tss, 0); + +/* Test acpigen_write_tsd_package() */ +static int dm_test_acpi_write_tsd_package(struct unit_test_state *uts) +{ + struct acpi_ctx *ctx; + u8 *ptr; + + ut_assertok(alloc_context(&ctx)); + + ptr = acpigen_get_current(ctx); + acpigen_write_tsd_package(ctx, 12, 34, HW_ALL); + + ut_asserteq(NAME_OP, *ptr++); + ut_asserteq_strn("_TSD", (char *)ptr); + ptr += 4; + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(1, *ptr++); + ut_asserteq(PACKAGE_OP, *ptr++); + ptr += 3; /* skip length */ + ut_asserteq(5, *ptr++); + + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(5, *ptr++); + ut_asserteq(BYTE_PREFIX, *ptr++); + ut_asserteq(0, *ptr++); + ut_asserteq(DWORD_PREFIX, *ptr++); + ut_asserteq(12, get_unaligned((u32 *)ptr)); + ptr += 5; + ut_asserteq(CSD_HW_ALL, get_unaligned((u32 *)ptr)); + ptr += 5; + ut_asserteq(34, get_unaligned((u32 *)ptr)); + ptr += 4; + + ut_asserteq_ptr(ptr, ctx->current); + + free_context(&ctx); + + return 0; +} +DM_TEST(dm_test_acpi_write_tsd_package, 0);
Add various tables that are common to Intel CPUs. These functions can be used by arch-specific CPU code.
arch/x86/cpu/intel_common/Makefile | 2 + arch/x86/cpu/intel_common/acpi.c | 377 +++++++++++++++++++++++++++++ arch/x86/cpu/intel_common/cpu.c | 14 ++ arch/x86/include/asm/acpi_table.h | 22 ++ arch/x86/include/asm/cpu_common.h | 7 + arch/x86/include/asm/intel_acpi.h | 52 ++++ drivers/core/Kconfig | 9 + 7 files changed, 483 insertions(+) create mode 100644 arch/x86/cpu/intel_common/acpi.c create mode 100644 arch/x86/include/asm/intel_acpi.h
diff --git a/arch/x86/cpu/intel_common/Makefile b/arch/x86/cpu/intel_common/Makefile index f1d1513a981..4a5cf17e41d 100644 --- a/arch/x86/cpu/intel_common/Makefile +++ b/arch/x86/cpu/intel_common/Makefile @@ -2,6 +2,8 @@ # # Copyright (c) 2016 Google, Inc
+obj-$(CONFIG_INTEL_ACPIGEN) += acpi.o + ifdef CONFIG_HAVE_MRC obj-$(CONFIG_$(SPL_TPL_)X86_16BIT_INIT) += car.o obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += me_status.o diff --git a/arch/x86/cpu/intel_common/acpi.c b/arch/x86/cpu/intel_common/acpi.c new file mode 100644 index 00000000000..a4d5fbd38a7 --- /dev/null +++ b/arch/x86/cpu/intel_common/acpi.c @@ -0,0 +1,377 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Generic Intel ACPI table generation + * + * Copyright (C) 2017 Intel Corp. + * Copyright 2019 Google LLC + * + * Modified from coreboot src/soc/intel/common/block/acpi.c + */ + +#include <common.h> +#include <bloblist.h> +#include <cpu.h> +#include <dm.h> +#include <acpi/acpigen.h> +#include <asm/acpigen.h> +#include <asm/acpi_table.h> +#include <asm/cpu.h> +#include <asm/cpu_common.h> +#include <asm/intel_acpi.h> +#include <asm/ioapic.h> +#include <asm/mpspec.h> +#include <asm/smm.h> +#include <asm/turbo.h> +#include <asm/intel_gnvs.h> +#include <asm/arch/iomap.h> +#include <asm/arch/pm.h> +#include <asm/arch/systemagent.h> +#include <dm/acpi.h> +#include <linux/err.h> +#include <power/acpi_pmc.h> + +u32 acpi_fill_mcfg(u32 current) +{ + /* PCI Segment Group 0, Start Bus Number 0, End Bus Number is 255 */ + current += acpi_create_mcfg_mmconfig((void *)current, + CONFIG_MMCONF_BASE_ADDRESS, 0, 0, + (CONFIG_SA_PCIEX_LENGTH >> 20) + - 1); + return current; +} + +static int acpi_sci_irq(void) +{ + int sci_irq = 9; + uint scis; + int ret; + + ret = arch_read_sci_irq_select(); + if (IS_ERR_VALUE(ret)) + return log_msg_ret("sci_irq", ret); + scis = ret; + scis &= SCI_IRQ_MASK; + scis >>= SCI_IRQ_SHIFT; + + /* Determine how SCI is routed. */ + switch (scis) { + case SCIS_IRQ9: + case SCIS_IRQ10: + case SCIS_IRQ11: + sci_irq = scis - SCIS_IRQ9 + 9; + break; + case SCIS_IRQ20: + case SCIS_IRQ21: + case SCIS_IRQ22: + case SCIS_IRQ23: + sci_irq = scis - SCIS_IRQ20 + 20; + break; + default: + log_warning("Invalid SCI route! Defaulting to IRQ9\n"); + sci_irq = 9; + break; + } + + log_debug("SCI is IRQ%d\n", sci_irq); + + return sci_irq; +} + +static unsigned long acpi_madt_irq_overrides(unsigned long current) +{ + int sci = acpi_sci_irq(); + u16 flags = MP_IRQ_TRIGGER_LEVEL; + + if (sci < 0) + return log_msg_ret("sci irq", sci); + + /* INT_SRC_OVR */ + current += acpi_create_madt_irqoverride((void *)current, 0, 0, 2, 0); + + flags |= arch_madt_sci_irq_polarity(sci); + + /* SCI */ + current += + acpi_create_madt_irqoverride((void *)current, 0, sci, sci, flags); + + return current; +} + +u32 acpi_fill_madt(u32 current) +{ + /* Local APICs */ + current += acpi_create_madt_lapics(current); + + /* IOAPIC */ + current += acpi_create_madt_ioapic((void *)current, 2, IO_APIC_ADDR, 0); + + return acpi_madt_irq_overrides(current); +} + +void intel_acpi_fill_fadt(struct acpi_fadt *fadt) +{ + const u16 pmbase = IOMAP_ACPI_BASE; + + /* Use ACPI 3.0 revision. */ + fadt->header.revision = acpi_get_table_revision(ACPITAB_FADT); + + fadt->sci_int = acpi_sci_irq(); + fadt->smi_cmd = APM_CNT; + fadt->acpi_enable = APM_CNT_ACPI_ENABLE; + fadt->acpi_disable = APM_CNT_ACPI_DISABLE; + fadt->s4bios_req = 0x0; + fadt->pstate_cnt = 0; + + fadt->pm1a_evt_blk = pmbase + PM1_STS; + fadt->pm1b_evt_blk = 0x0; + fadt->pm1a_cnt_blk = pmbase + PM1_CNT; + fadt->pm1b_cnt_blk = 0x0; + + fadt->gpe0_blk = pmbase + GPE0_STS; + + fadt->pm1_evt_len = 4; + fadt->pm1_cnt_len = 2; + + /* GPE0 STS/EN pairs each 32 bits wide. */ + fadt->gpe0_blk_len = 2 * GPE0_REG_MAX * sizeof(uint32_t); + + fadt->flush_size = 0x400; /* twice of cache size */ + fadt->flush_stride = 0x10; /* Cache line width */ + fadt->duty_offset = 1; + fadt->day_alrm = 0xd; + + fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | + ACPI_FADT_C2_MP_SUPPORTED | ACPI_FADT_SLEEP_BUTTON | + ACPI_FADT_RESET_REGISTER | ACPI_FADT_SEALED_CASE | + ACPI_FADT_S4_RTC_WAKE | ACPI_FADT_PLATFORM_CLOCK; + + fadt->reset_reg.space_id = 1; + fadt->reset_reg.bit_width = 8; + fadt->reset_reg.addrl = IO_PORT_RESET; + fadt->reset_value = RST_CPU | SYS_RST; + + fadt->x_pm1a_evt_blk.space_id = 1; + fadt->x_pm1a_evt_blk.bit_width = fadt->pm1_evt_len * 8; + fadt->x_pm1a_evt_blk.addrl = pmbase + PM1_STS; + + fadt->x_pm1b_evt_blk.space_id = 1; + + fadt->x_pm1a_cnt_blk.space_id = 1; + fadt->x_pm1a_cnt_blk.bit_width = fadt->pm1_cnt_len * 8; + fadt->x_pm1a_cnt_blk.addrl = pmbase + PM1_CNT; + + fadt->x_pm1b_cnt_blk.space_id = 1; + + fadt->x_gpe1_blk.space_id = 1; +} + +int intel_southbridge_write_acpi_tables(const struct udevice *dev, + struct acpi_ctx *ctx) +{ + int ret; + + ret = acpi_write_dbg2_pci_uart(ctx, gd->cur_serial_dev, + ACPI_ACCESS_SIZE_DWORD_ACCESS); + if (ret) + return log_msg_ret("dbg2", ret); + + ret = acpi_write_hpet(ctx); + if (ret) + return log_msg_ret("hpet", ret); + + return 0; +} + +__weak u32 acpi_fill_soc_wake(u32 generic_pm1_en, + const struct chipset_power_state *ps) +{ + return generic_pm1_en; +} + +__weak int acpi_create_gnvs(struct acpi_global_nvs *gnvs) +{ + return 0; +} + +int southbridge_inject_dsdt(const struct udevice *dev, struct acpi_ctx *ctx) +{ + struct acpi_global_nvs *gnvs; + int ret; + + ret = bloblist_ensure_size(BLOBLISTT_ACPI_GNVS, sizeof(*gnvs), + (void **)&gnvs); + if (ret) + return log_msg_ret("bloblist", ret); + memset(gnvs, '\0', sizeof(*gnvs)); + + ret = acpi_create_gnvs(gnvs); + if (ret) + return log_msg_ret("gnvs", ret); + + /* + * TODO(sjg@chromum.org): tell SMI about it + * smm_setup_structures(gnvs, NULL, NULL); + */ + + /* Add it to DSDT */ + acpigen_write_scope(ctx, "\"); + acpigen_write_name_dword(ctx, "NVSA", (uintptr_t)gnvs); + acpigen_pop_len(ctx); + + return 0; +} + +static int calculate_power(int tdp, int p1_ratio, int ratio) +{ + u32 m; + u32 power; + + /* + * M = ((1.1 - ((p1_ratio - ratio) * 0.00625)) / 1.1) ^ 2 + * + * Power = (ratio / p1_ratio) * m * tdp + */ + + m = (110000 - ((p1_ratio - ratio) * 625)) / 11; + m = (m * m) / 1000; + + power = ((ratio * 100000 / p1_ratio) / 100); + power *= (m / 100) * (tdp / 1000); + power /= 1000; + + return power; +} + +void generate_p_state_entries(struct acpi_ctx *ctx, int core, + int cores_per_package) +{ + int ratio_min, ratio_max, ratio_turbo, ratio_step; + int coord_type, power_max, num_entries; + int ratio, power, clock, clock_max; + bool turbo; + + coord_type = cpu_get_coord_type(); + ratio_min = cpu_get_min_ratio(); + ratio_max = cpu_get_max_ratio(); + clock_max = (ratio_max * cpu_get_bus_clock_khz()) / 1000; + turbo = (turbo_get_state() == TURBO_ENABLED); + + /* Calculate CPU TDP in mW */ + power_max = cpu_get_power_max(); + + /* Write _PCT indicating use of FFixedHW */ + acpigen_write_empty_pct(ctx); + + /* Write _PPC with no limit on supported P-state */ + acpigen_write_ppc_nvs(ctx); + /* Write PSD indicating configured coordination type */ + acpigen_write_psd_package(ctx, core, 1, coord_type); + + /* Add P-state entries in _PSS table */ + acpigen_write_name(ctx, "_PSS"); + + /* Determine ratio points */ + ratio_step = PSS_RATIO_STEP; + do { + num_entries = ((ratio_max - ratio_min) / ratio_step) + 1; + if (((ratio_max - ratio_min) % ratio_step) > 0) + num_entries += 1; + if (turbo) + num_entries += 1; + if (num_entries > PSS_MAX_ENTRIES) + ratio_step += 1; + } while (num_entries > PSS_MAX_ENTRIES); + + /* _PSS package count depends on Turbo */ + acpigen_write_package(ctx, num_entries); + + /* P[T] is Turbo state if enabled */ + if (turbo) { + ratio_turbo = cpu_get_max_turbo_ratio(); + + /* Add entry for Turbo ratio */ + acpigen_write_pss_package(ctx, clock_max + 1, /* MHz */ + power_max, /* mW */ + PSS_LATENCY_TRANSITION,/* lat1 */ + PSS_LATENCY_BUSMASTER,/* lat2 */ + ratio_turbo << 8, /* control */ + ratio_turbo << 8); /* status */ + num_entries -= 1; + } + + /* First regular entry is max non-turbo ratio */ + acpigen_write_pss_package(ctx, clock_max, /* MHz */ + power_max, /* mW */ + PSS_LATENCY_TRANSITION,/* lat1 */ + PSS_LATENCY_BUSMASTER,/* lat2 */ + ratio_max << 8, /* control */ + ratio_max << 8); /* status */ + num_entries -= 1; + + /* Generate the remaining entries */ + for (ratio = ratio_min + ((num_entries - 1) * ratio_step); + ratio >= ratio_min; ratio -= ratio_step) { + /* Calculate power at this ratio */ + power = calculate_power(power_max, ratio_max, ratio); + clock = (ratio * cpu_get_bus_clock_khz()) / 1000; + + acpigen_write_pss_package(ctx, clock, /* MHz */ + power, /* mW */ + PSS_LATENCY_TRANSITION,/* lat1 */ + PSS_LATENCY_BUSMASTER,/* lat2 */ + ratio << 8, /* control */ + ratio << 8); /* status */ + } + /* Fix package length */ + acpigen_pop_len(ctx); +} + +void generate_t_state_entries(struct acpi_ctx *ctx, int core, + int cores_per_package, struct acpi_tstate *entry, + int nentries) +{ + if (!nentries) + return; + + /* Indicate SW_ALL coordination for T-states */ + acpigen_write_tsd_package(ctx, core, cores_per_package, SW_ALL); + + /* Indicate FixedHW so OS will use MSR */ + acpigen_write_empty_ptc(ctx); + + /* Set NVS controlled T-state limit */ + acpigen_write_tpc(ctx, "\TLVL"); + + /* Write TSS table for MSR access */ + acpigen_write_tss_package(ctx, entry, nentries); +} + +int acpi_generate_cpu_header(struct acpi_ctx *ctx, int core_id, + const struct acpi_cstate *c_state_map, + int num_cstates) +{ + bool is_first = !core_id; + + /* Generate processor _PR.CPUx */ + acpigen_write_processor(ctx, core_id, is_first ? ACPI_BASE_ADDRESS : 0, + is_first ? 6 : 0); + + /* Generate C-state tables */ + acpigen_write_cst_package(ctx, c_state_map, num_cstates); + + return 0; +} + +int acpi_generate_cpu_package_final(struct acpi_ctx *ctx, int cores_per_package) +{ + /* + * PPKG is usually used for thermal management of the first and only + * package + */ + acpigen_write_processor_package(ctx, "PPKG", 0, cores_per_package); + + /* Add a method to notify processor nodes */ + acpigen_write_processor_cnot(ctx, cores_per_package); + + return 0; +} diff --git a/arch/x86/cpu/intel_common/cpu.c b/arch/x86/cpu/intel_common/cpu.c index cb4ef84013a..d8a3d60ae72 100644 --- a/arch/x86/cpu/intel_common/cpu.c +++ b/arch/x86/cpu/intel_common/cpu.c @@ -291,3 +291,17 @@ int cpu_get_max_turbo_ratio(void)
return msr.lo & 0xff; } + +int cpu_get_cores_per_package(void) +{ + struct cpuid_result result; + int cores = 1; + + if (gd->arch.x86_vendor != X86_VENDOR_INTEL) + return 1; + + result = cpuid_ext(0xb, 1); + cores = result.ebx & 0xff; + + return cores; +} diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index 1b7ff509516..3245e447813 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -76,4 +76,26 @@ ulong write_acpi_tables(ulong start); */ ulong acpi_get_rsdp_addr(void);
+/** + * arch_read_sci_irq_select() - Read the system-control interrupt number + * + * @returns value of IRQ register in the PMC + */ +int arch_read_sci_irq_select(void); + +/** + * arch_write_sci_irq_select() - Set the system-control interrupt number + * + * @scis: New value for IRQ register in the PMC + */ +int arch_write_sci_irq_select(uint scis); + +/** + * arch_madt_sci_irq_polarity() - Return the priority to use for the MADT + * + * @sci: System-control interrupt number + * @return priority to use (MP_IRQ_POLARITY_...) + */ +int arch_madt_sci_irq_polarity(int sci); + #endif /* __ASM_ACPI_TABLE_H__ */ diff --git a/arch/x86/include/asm/cpu_common.h b/arch/x86/include/asm/cpu_common.h index a7b7112d417..48f56c2aad9 100644 --- a/arch/x86/include/asm/cpu_common.h +++ b/arch/x86/include/asm/cpu_common.h @@ -177,4 +177,11 @@ int cpu_get_power_max(void); */ int cpu_get_max_turbo_ratio(void);
+/** + * cpu_get_cores_per_package() - Get the number of CPU cores in each package + * + * @return number of cores + */ +int cpu_get_cores_per_package(void); + #endif diff --git a/arch/x86/include/asm/intel_acpi.h b/arch/x86/include/asm/intel_acpi.h new file mode 100644 index 00000000000..a5781f1af45 --- /dev/null +++ b/arch/x86/include/asm/intel_acpi.h @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + */ + +#ifndef __ASM_INTEL_ACPI_H__ +#define __ASM_INTEL_ACPI_H__ + +struct acpi_cstate; +struct acpi_ctx; +struct acpi_tstate; +struct udevice; + +/** + * acpi_generate_cpu_header() - Start generating an ACPI CPU entry + * + * Generates the ACPI information for a CPU. After this, the caller should + * generate_p_state_entries(), generate_t_state_entries and then + * acpigen_pop_len() to close off this package. + * + * @ctx: ACPI context pointer + * @core_id: CPU core number, as numbered by the SoC + * @c_state_map: Information about each C state + * @num_cstates: Number of entries in @c_state_map + * @return 0 if OK, -ve on error + */ +int acpi_generate_cpu_header(struct acpi_ctx *ctx, int core_id, + const struct acpi_cstate *c_state_map, + int num_cstates); + +/** + * acpi_generate_cpu_package_final() - Write out the CPU PPKG entry + * + * This writes information about the CPUs in the package + * + * @ctx: ACPI context pointer + * @cores_per_package: Number of CPU cores in each package in the SoC + */ +int acpi_generate_cpu_package_final(struct acpi_ctx *ctx, + int cores_per_package); + +void generate_p_state_entries(struct acpi_ctx *ctx, int core, + int cores_per_package); +void generate_t_state_entries(struct acpi_ctx *ctx, int core, + int cores_per_package, struct acpi_tstate *entry, + int nentries); +int southbridge_inject_dsdt(const struct udevice *dev, struct acpi_ctx *ctx); + +int intel_southbridge_write_acpi_tables(const struct udevice *dev, + struct acpi_ctx *ctx); + +#endif /* __ASM_INTEL_ACPI_H__ */ diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index 00d1d80dc38..1ca5d66141b 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -277,4 +277,13 @@ config ACPIGEN things like generating device-specific tables and returning the ACPI name of a device.
+config INTEL_ACPIGEN + bool "Support ACPI table generation for Intel SoCs" + depends on ACPIGEN + help + This option adds some functions used for programatic generation of + ACPI tables on Intel SoCs. This provides features for writing CPU + information such as P states and T stages. Also included is a way + to create a GNVS table and set it up. + endmenu
Some Atom SoCs use SWSMISCI for SMI control. Add a Kconfig to select this. It is used on Apollo Lake.
arch/x86/Kconfig | 6 ++++++ arch/x86/cpu/apollolake/Kconfig | 1 + 2 files changed, 7 insertions(+)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 1e5c72d6b39..3adb8391925 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -1014,4 +1014,10 @@ config INTEL_GENERIC_WIFI network functionality. It is only here to generate the ACPI tables required by Linux.
+config INTEL_GMA_SWSMISCI + bool + help + Select this option for Atom-based platforms which use the SWSMISCI + register (0xe0) rather than the SWSCI register (0xe8). + endmenu diff --git a/arch/x86/cpu/apollolake/Kconfig b/arch/x86/cpu/apollolake/Kconfig index 319f12684b7..35a425cd1bc 100644 --- a/arch/x86/cpu/apollolake/Kconfig +++ b/arch/x86/cpu/apollolake/Kconfig @@ -17,6 +17,7 @@ config INTEL_APOLLOLAKE select PCH_SUPPORT select P2SB select SMP_AP_WORK + select INTEL_GMA_SWSMISCI select ACPI_GNVS_EXTERNAL imply ENABLE_MRC_CACHE imply AHCI_PCI
Apollo Lake needs to generate a few more table types used on Intel SoCs. Add support for these into the x86 ACPI code.
Changes in v1: - Move this code into an x86-specific file - Update commit message - Use OEM_TABLE_ID instead of ACPI_TABLE_CREATOR
arch/x86/include/asm/acpi_table.h | 115 ++++++++++++++++++++++++++++++ arch/x86/lib/acpi_table.c | 111 ++++++++++++++++++++++++++++ include/acpi/acpi_table.h | 43 +++++++++++ 3 files changed, 269 insertions(+)
diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index 3245e447813..faf31730730 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -98,4 +98,119 @@ int arch_write_sci_irq_select(uint scis); */ int arch_madt_sci_irq_polarity(int sci);
+/** + * acpi_create_dmar_drhd() - Create a table for DMA remapping with the IOMMU + * + * See here for the specification + * https://software.intel.com/sites/default/files/managed/c5/15/vt-directed-io-... + * + * @ctx: ACPI context pointer + * @flags: (DRHD_INCLUDE_...) + * @segment: PCI segment asscociated with this unit + * @bar: Base address of remapping hardware register-set for this unit + */ +void acpi_create_dmar_drhd(struct acpi_ctx *ctx, uint flags, uint segment, + u64 bar); + +/** + * acpi_create_dmar_rmrr() - Set up an RMRR + * + * This sets up a Reserved-Memory Region Reporting structure, used to allow + * DMA to regions used by devices that the BIOS controls. + * + * @ctx: ACPI context pointer + * @segment: PCI segment asscociated with this unit + * @bar: Base address of mapping + * @limit: End address of mapping + */ +void acpi_create_dmar_rmrr(struct acpi_ctx *ctx, uint segment, u64 bar, + u64 limit); + +/** + * acpi_dmar_drhd_fixup() - Set the length of an DRHD + * + * This sets the DRHD length field based on the current ctx->current + * + * @ctx: ACPI context pointer + * @base: Address of the start of the DRHD + */ +void acpi_dmar_drhd_fixup(struct acpi_ctx *ctx, void *base); + +/** + * acpi_dmar_rmrr_fixup() - Set the length of an RMRR + * + * This sets the RMRR length field based on the current ctx->current + * + * @ctx: ACPI context pointer + * @base: Address of the start of the RMRR + */ +void acpi_dmar_rmrr_fixup(struct acpi_ctx *ctx, void *base); + +/** + * acpi_create_dmar_ds_pci() - Set up a DMAR scope for a PCI device + * + * @ctx: ACPI context pointer + * @bdf: PCI device to add + * @return length of mapping in bytes + */ +int acpi_create_dmar_ds_pci(struct acpi_ctx *ctx, pci_dev_t bdf); + +/** + * acpi_create_dmar_ds_pci_br() - Set up a DMAR scope for a PCI bridge + * + * This is used to provide a mapping for a PCI bridge + * + * @ctx: ACPI context pointer + * @bdf: PCI device to add + * @return length of mapping in bytes + */ +int acpi_create_dmar_ds_pci_br(struct acpi_ctx *ctx, pci_dev_t bdf); + +/** + * acpi_create_dmar_ds_ioapic() - Set up a DMAR scope for an IOAPIC device + * + * @ctx: ACPI context pointer + * @enumeration_id: Enumeration ID (typically 2) + * @bdf: PCI device to add + * @return length of mapping in bytes + */ +int acpi_create_dmar_ds_ioapic(struct acpi_ctx *ctx, uint enumeration_id, + pci_dev_t bdf); + +/** + * acpi_create_dmar_ds_msi_hpet() - Set up a DMAR scope for an HPET + * + * Sets up a scope for a High-Precision Event Timer that supports + * Message-Signalled Interrupts + * + * @ctx: ACPI context pointer + * @enumeration_id: Enumeration ID (typically 0) + * @bdf: PCI device to add + * @return length of mapping in bytes + */ +int acpi_create_dmar_ds_msi_hpet(struct acpi_ctx *ctx, uint enumeration_id, + pci_dev_t bdf); + +/** + * acpi_fadt_common() - Handle common parts of filling out an FADT + * + * This sets up the Fixed ACPI Description Table + * + * @fadt: Pointer to place to put FADT + * @facs: Pointer to the FACS + * @dsdt: Pointer to the DSDT + */ +void acpi_fadt_common(struct acpi_fadt *fadt, struct acpi_facs *facs, + void *dsdt); + +/** + * intel_acpi_fill_fadt() - Set up the contents of the FADT + * + * This sets up parts of the Fixed ACPI Description Table that are common to + * Intel chips + * + * @fadt: Pointer to place to put FADT + */ +void intel_acpi_fill_fadt(struct acpi_fadt *fadt); + #endif /* __ASM_ACPI_TABLE_H__ */ diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 28a27103342..b0cc1f123e2 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -616,3 +616,114 @@ int acpi_write_dbg2_pci_uart(struct acpi_ctx *ctx, struct udevice *dev,
return 0; } + +void acpi_fadt_common(struct acpi_fadt *fadt, struct acpi_facs *facs, + void *dsdt) +{ + struct acpi_table_header *header = &fadt->header; + + memset((void *)fadt, '\0', sizeof(struct acpi_fadt)); + + acpi_fill_header(header, "FACP"); + header->length = sizeof(struct acpi_fadt); + header->revision = 4; + memcpy(header->oem_id, OEM_ID, 6); + memcpy(header->oem_table_id, OEM_TABLE_ID, 8); + memcpy(header->aslc_id, ASLC_ID, 4); + header->aslc_revision = 1; + + fadt->firmware_ctrl = (unsigned long)facs; + fadt->dsdt = (unsigned long)dsdt; + + fadt->x_firmware_ctl_l = (unsigned long)facs; + fadt->x_firmware_ctl_h = 0; + fadt->x_dsdt_l = (unsigned long)dsdt; + fadt->x_dsdt_h = 0; + + fadt->preferred_pm_profile = ACPI_PM_MOBILE; + + /* Use ACPI 3.0 revision */ + fadt->header.revision = 4; +} + +void acpi_create_dmar_drhd(struct acpi_ctx *ctx, uint flags, uint segment, + u64 bar) +{ + struct dmar_entry *drhd = ctx->current; + + memset(drhd, '\0', sizeof(*drhd)); + drhd->type = DMAR_DRHD; + drhd->length = sizeof(*drhd); /* will be fixed up later */ + drhd->flags = flags; + drhd->segment = segment; + drhd->bar = bar; + acpi_inc(ctx, drhd->length); +} + +void acpi_create_dmar_rmrr(struct acpi_ctx *ctx, uint segment, u64 bar, + u64 limit) +{ + struct dmar_rmrr_entry *rmrr = ctx->current; + + memset(rmrr, '\0', sizeof(*rmrr)); + rmrr->type = DMAR_RMRR; + rmrr->length = sizeof(*rmrr); /* will be fixed up later */ + rmrr->segment = segment; + rmrr->bar = bar; + rmrr->limit = limit; + acpi_inc(ctx, rmrr->length); +} + +void acpi_dmar_drhd_fixup(struct acpi_ctx *ctx, void *base) +{ + struct dmar_entry *drhd = base; + + drhd->length = ctx->current - base; +} + +void acpi_dmar_rmrr_fixup(struct acpi_ctx *ctx, void *base) +{ + struct dmar_rmrr_entry *rmrr = base; + + rmrr->length = ctx->current - base; +} + +static int acpi_create_dmar_ds(struct acpi_ctx *ctx, enum dev_scope_type type, + uint enumeration_id, pci_dev_t bdf) +{ + /* we don't support longer paths yet */ + const size_t dev_scope_length = sizeof(struct dev_scope) + 2; + struct dev_scope *ds = ctx->current; + + memset(ds, '\0', dev_scope_length); + ds->type = type; + ds->length = dev_scope_length; + ds->enumeration = enumeration_id; + ds->start_bus = PCI_BUS(bdf); + ds->path[0].dev = PCI_DEV(bdf); + ds->path[0].fn = PCI_FUNC(bdf); + + return ds->length; +} + +int acpi_create_dmar_ds_pci_br(struct acpi_ctx *ctx, pci_dev_t bdf) +{ + return acpi_create_dmar_ds(ctx, SCOPE_PCI_SUB, 0, bdf); +} + +int acpi_create_dmar_ds_pci(struct acpi_ctx *ctx, pci_dev_t bdf) +{ + return acpi_create_dmar_ds(ctx, SCOPE_PCI_ENDPOINT, 0, bdf); +} + +int acpi_create_dmar_ds_ioapic(struct acpi_ctx *ctx, uint enumeration_id, + pci_dev_t bdf) +{ + return acpi_create_dmar_ds(ctx, SCOPE_IOAPIC, enumeration_id, bdf); +} + +int acpi_create_dmar_ds_msi_hpet(struct acpi_ctx *ctx, uint enumeration_id, + pci_dev_t bdf) +{ + return acpi_create_dmar_ds(ctx, SCOPE_MSI_HPET, enumeration_id, bdf); +} diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index c826a797f5b..a2e510cf56e 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -377,6 +377,49 @@ struct acpi_csrt_shared_info { u32 max_block_size; };
+/* Port types for ACPI _UPC object */ +enum acpi_upc_type { + UPC_TYPE_A, + UPC_TYPE_MINI_AB, + UPC_TYPE_EXPRESSCARD, + UPC_TYPE_USB3_A, + UPC_TYPE_USB3_B, + UPC_TYPE_USB3_MICRO_B, + UPC_TYPE_USB3_MICRO_AB, + UPC_TYPE_USB3_POWER_B, + UPC_TYPE_C_USB2_ONLY, + UPC_TYPE_C_USB2_SS_SWITCH, + UPC_TYPE_C_USB2_SS, + UPC_TYPE_PROPRIETARY = 0xff, + /* + * The following types are not directly defined in the ACPI + * spec but are used by coreboot to identify a USB device type. + */ + UPC_TYPE_INTERNAL = 0xff, + UPC_TYPE_UNUSED, + UPC_TYPE_HUB +}; + +enum dev_scope_type { + SCOPE_PCI_ENDPOINT = 1, + SCOPE_PCI_SUB = 2, + SCOPE_IOAPIC = 3, + SCOPE_MSI_HPET = 4, + SCOPE_ACPI_NAMESPACE_DEVICE = 5 +}; + +struct __packed dev_scope { + u8 type; + u8 length; + u8 reserved[2]; + u8 enumeration; + u8 start_bus; + struct { + u8 dev; + u8 fn; + } __packed path[0]; +}; + enum dmar_type { DMAR_DRHD = 0, DMAR_RMRR = 1,
Add a few functions to permit reading of various useful base addresses provided by the hostbridge.
Changes in v1: - Add comments
arch/x86/cpu/apollolake/hostbridge.c | 27 ++++++++++++++++ .../include/asm/arch-apollolake/systemagent.h | 31 +++++++++++++++++++ 2 files changed, 58 insertions(+)
diff --git a/arch/x86/cpu/apollolake/hostbridge.c b/arch/x86/cpu/apollolake/hostbridge.c index cb46ec6c0bb..056f7e57a9a 100644 --- a/arch/x86/cpu/apollolake/hostbridge.c +++ b/arch/x86/cpu/apollolake/hostbridge.c @@ -40,7 +40,9 @@ enum {
PCIEXBAR_PCIEXBAREN = 1 << 0,
+ BGSM = 0xb4, /* Base GTT Stolen Memory */ TSEG = 0xb8, /* TSEG base */ + TOLUD = 0xbc, };
static int apl_hostbridge_early_init_pinctrl(struct udevice *dev) @@ -165,6 +167,31 @@ static int apl_hostbridge_probe(struct udevice *dev) return 0; }
+static ulong sa_read_reg(struct udevice *dev, int reg) +{ + u32 val; + + /* All regions concerned for have 1 MiB alignment */ + dm_pci_read_config32(dev, BGSM, &val); + + return ALIGN_DOWN(val, 1 << 20); +} + +ulong sa_get_tolud_base(struct udevice *dev) +{ + return sa_read_reg(dev, TOLUD); +} + +ulong sa_get_gsm_base(struct udevice *dev) +{ + return sa_read_reg(dev, BGSM); +} + +ulong sa_get_tseg_base(struct udevice *dev) +{ + return sa_read_reg(dev, TSEG); +} + static const struct udevice_id apl_hostbridge_ids[] = { { .compatible = "intel,apl-hostbridge" }, { } diff --git a/arch/x86/include/asm/arch-apollolake/systemagent.h b/arch/x86/include/asm/arch-apollolake/systemagent.h index 9e7bd62751a..788a63d7999 100644 --- a/arch/x86/include/asm/arch-apollolake/systemagent.h +++ b/arch/x86/include/asm/arch-apollolake/systemagent.h @@ -35,4 +35,35 @@ */ void enable_bios_reset_cpl(void);
+/** + * sa_get_tolud_base() - Get the TOLUD base address + * + * This returns the Top Of Low Useable DRAM, marking the top of usable DRAM + * below 4GB + * + * @dev: hostbridge device + * @return TOLUD address + */ +ulong sa_get_tolud_base(struct udevice *dev); + +/** + * sa_get_gsm_base() - Get the GSM base address + * + * This returns the base of GTT Stolen Memory, marking the start of memory used + * for Graphics Translation Tables. + * + * @dev: hostbridge device + * @return GSM address + */ +ulong sa_get_gsm_base(struct udevice *dev); + +/** + * sa_get_tseg_base() - Get the TSEG base address + * + * This returns the top address of DRAM available below 4GB + * + * @return TSEG base + */ +ulong sa_get_tseg_base(struct udevice *dev); + #endif
Allow this header to be included in ASL files by adding a header guard and a few definitions that are needed.
include/p2sb.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/p2sb.h b/include/p2sb.h index 93e1155dca6..a25170e3d11 100644 --- a/include/p2sb.h +++ b/include/p2sb.h @@ -10,6 +10,12 @@ /* Port Id lives in bits 23:16 and register offset lives in 15:0 of address */ #define PCR_PORTID_SHIFT 16
+#if !defined(__ACPI__) + +/* These registers contain IOAPIC and HPET devfn */ +#define PCH_P2SB_IBDF 0x6c +#define PCH_P2SB_HBDF 0x70 + /** * struct p2sb_child_platdata - Information about each child of a p2sb device * @@ -164,4 +170,6 @@ int p2sb_get_port_id(struct udevice *dev); */ void *pcr_reg_address(struct udevice *dev, uint offset);
+#endif /* !__ACPI__ */ + #endif
Add support for generating various ACPI tables for Apollo Lake. Add a few S3 definitions that are needed.
Changes in v1: - Drop unnecessary callbacks
arch/x86/cpu/apollolake/Makefile | 1 + arch/x86/cpu/apollolake/acpi.c | 211 ++++++++++++++++++++ arch/x86/include/asm/arch-apollolake/acpi.h | 18 ++ include/acpi/acpi_s3.h | 4 + 4 files changed, 234 insertions(+) create mode 100644 arch/x86/cpu/apollolake/acpi.c create mode 100644 arch/x86/include/asm/arch-apollolake/acpi.h
diff --git a/arch/x86/cpu/apollolake/Makefile b/arch/x86/cpu/apollolake/Makefile index 3aa2a556765..2ddf4af62c5 100644 --- a/arch/x86/cpu/apollolake/Makefile +++ b/arch/x86/cpu/apollolake/Makefile @@ -16,6 +16,7 @@ obj-y += fsp_m.o endif endif ifndef CONFIG_SPL_BUILD +obj-y += acpi.o obj-y += fsp_s.o endif
diff --git a/arch/x86/cpu/apollolake/acpi.c b/arch/x86/cpu/apollolake/acpi.c new file mode 100644 index 00000000000..69b544f0d98 --- /dev/null +++ b/arch/x86/cpu/apollolake/acpi.c @@ -0,0 +1,211 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Intel Corp. + * Copyright (C) 2017-2019 Siemens AG + * (Written by Lance Zhao lijian.zhao@intel.com for Intel Corp.) + * Copyright 2019 Google LLC + * + * Modified from coreboot apollolake/acpi.c + */ + +#define LOG_CATEGORY LOGC_ACPI + +#include <common.h> +#include <cpu.h> +#include <dm.h> +#include <log.h> +#include <p2sb.h> +#include <pci.h> +#include <acpi/acpigen.h> +#include <acpi/acpi_s3.h> +#include <asm/acpi_table.h> +#include <asm/cpu_common.h> +#include <asm/intel_acpi.h> +#include <asm/intel_gnvs.h> +#include <asm/intel_pinctrl.h> +#include <asm/intel_pinctrl_defs.h> +#include <asm/intel_regs.h> +#include <asm/io.h> +#include <asm/mpspec.h> +#include <asm/tables.h> +#include <asm/arch/iomap.h> +#include <asm/arch/gpio.h> +#include <asm/arch/pm.h> +#include <asm/arch/systemagent.h> +#include <dm/acpi.h> +#include <dm/uclass-internal.h> +#include <power/acpi_pmc.h> + +int arch_read_sci_irq_select(void) +{ + struct acpi_pmc_upriv *upriv; + struct udevice *dev; + int ret; + + ret = uclass_first_device_err(UCLASS_ACPI_PMC, &dev); + if (ret) + return log_msg_ret("pmc", ret); + upriv = dev_get_uclass_priv(dev); + + return readl(upriv->pmc_bar0 + IRQ_REG); +} + +int arch_write_sci_irq_select(uint scis) +{ + struct acpi_pmc_upriv *upriv; + struct udevice *dev; + int ret; + + ret = uclass_first_device_err(UCLASS_ACPI_PMC, &dev); + if (ret) + return log_msg_ret("pmc", ret); + upriv = dev_get_uclass_priv(dev); + writel(scis, upriv->pmc_bar0 + IRQ_REG); + + return 0; +} + +int acpi_create_gnvs(struct acpi_global_nvs *gnvs) +{ + struct udevice *cpu; + int ret; + + /* Clear out GNV */ + memset(gnvs, '\0', sizeof(*gnvs)); + + /* TODO(sjg@chromium.org): Add the console log to gnvs->cbmc */ + +#ifdef CONFIG_CHROMEOS + /* Initialise Verified Boot data */ + chromeos_init_acpi(&gnvs->chromeos); + gnvs->chromeos.vbt2 = ACTIVE_ECFW_RO; +#endif + /* Set unknown wake source */ + gnvs->pm1i = ~0ULL; + + /* CPU core count */ + gnvs->pcnt = 1; + ret = uclass_find_first_device(UCLASS_CPU, &cpu); + if (cpu) { + ret = cpu_get_count(cpu); + if (ret > 0) + gnvs->pcnt = ret; + } + + return 0; +} + +uint32_t acpi_fill_soc_wake(uint32_t generic_pm1_en) +{ + /* + * WAK_STS bit is set when the system is in one of the sleep states + * (via the SLP_EN bit) and an enabled wake event occurs. Upon setting + * this bit, the PMC will transition the system to the ON state and + * can only be set by hardware and can only be cleared by writing a one + * to this bit position. + */ + generic_pm1_en |= WAK_STS | RTC_EN | PWRBTN_EN; + + return generic_pm1_en; +} + +int arch_madt_sci_irq_polarity(int sci) +{ + return MP_IRQ_POLARITY_LOW; +} + +void fill_fadt(struct acpi_fadt *fadt) +{ + fadt->pm_tmr_blk = IOMAP_ACPI_BASE + PM1_TMR; + + fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; + fadt->p_lvl3_lat = ACPI_FADT_C3_NOT_SUPPORTED; + + fadt->pm_tmr_len = 4; + fadt->duty_width = 3; + + fadt->iapc_boot_arch = ACPI_FADT_LEGACY_DEVICES | ACPI_FADT_8042; + + fadt->x_pm_tmr_blk.space_id = 1; + fadt->x_pm_tmr_blk.bit_width = fadt->pm_tmr_len * 8; + fadt->x_pm_tmr_blk.addrl = IOMAP_ACPI_BASE + PM1_TMR; +} + +void acpi_create_fadt(struct acpi_fadt *fadt, struct acpi_facs *facs, + void *dsdt) +{ + struct acpi_table_header *header = &fadt->header; + + acpi_fadt_common(fadt, facs, dsdt); + intel_acpi_fill_fadt(fadt); + fill_fadt(fadt); + header->checksum = table_compute_checksum(fadt, header->length); +} + +int apl_acpi_fill_dmar(struct acpi_ctx *ctx) +{ + struct udevice *dev, *sa_dev; + u64 gfxvtbar = readq(MCHBAR_REG(GFXVTBAR)) & VTBAR_MASK; + u64 defvtbar = readq(MCHBAR_REG(DEFVTBAR)) & VTBAR_MASK; + bool gfxvten = readl(MCHBAR_REG(GFXVTBAR)) & VTBAR_ENABLED; + bool defvten = readl(MCHBAR_REG(DEFVTBAR)) & VTBAR_ENABLED; + void *tmp; + int ret; + + uclass_find_first_device(UCLASS_VIDEO, &dev); + ret = uclass_first_device_err(UCLASS_NORTHBRIDGE, &sa_dev); + if (ret) + return log_msg_ret("no sa", ret); + + /* IGD has to be enabled, GFXVTBAR set and enabled */ + if (dev && device_active(dev) && gfxvtbar && gfxvten) { + tmp = ctx->current; + + acpi_create_dmar_drhd(ctx, 0, 0, gfxvtbar); + ret = acpi_create_dmar_ds_pci(ctx, PCI_BDF(0, 2, 0)); + if (ret) + return log_msg_ret("ds_pci", ret); + acpi_dmar_drhd_fixup(ctx, tmp); + + /* Add RMRR entry */ + tmp = ctx->current; + acpi_create_dmar_rmrr(ctx->current, 0, sa_get_gsm_base(sa_dev), + sa_get_tolud_base(sa_dev) - 1); + acpi_create_dmar_ds_pci(ctx->current, PCI_BDF(0, 2, 0)); + acpi_dmar_rmrr_fixup(ctx, tmp); + } + + /* DEFVTBAR has to be set and enabled */ + if (defvtbar && defvten) { + struct udevice *p2sb_dev; + u16 ibdf, hbdf; + uint ioapic, hpet; + int ret; + + tmp = ctx->current; + /* + * P2SB may already be hidden. There's no clear rule, when. + * It is needed to get bus, device and function for IOAPIC and + * HPET device which is stored in P2SB device. So unhide it to + * get the info and hide it again when done. + * + * TODO(sjg@chromium.org): p2sb_unhide() ? + */ + ret = uclass_first_device_err(UCLASS_P2SB, &p2sb_dev); + if (ret) + return log_msg_ret("p2sb", ret); + + dm_pci_read_config16(p2sb_dev, PCH_P2SB_IBDF, &ibdf); + ioapic = PCI_TO_BDF(ibdf); + dm_pci_read_config16(p2sb_dev, PCH_P2SB_HBDF, &hbdf); + hpet = PCI_TO_BDF(hbdf); + /* TODO(sjg@chromium.org): p2sb_hide() ? */ + + acpi_create_dmar_drhd(ctx, DRHD_INCLUDE_PCI_ALL, 0, defvtbar); + acpi_create_dmar_ds_ioapic(ctx, 2, ioapic); + acpi_create_dmar_ds_msi_hpet(ctx, 0, hpet); + acpi_dmar_drhd_fixup(tmp, ctx->current); + } + + return 0; +} diff --git a/arch/x86/include/asm/arch-apollolake/acpi.h b/arch/x86/include/asm/arch-apollolake/acpi.h new file mode 100644 index 00000000000..ed852feee03 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/acpi.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2019 Google LLC + */ + +#ifndef _ASM_ARCH_ACPI_H +#define _ASM_ARCH_ACPI_H + +struct acpi_ctx; + +/** + * apl_acpi_fill_dmar() - Set up the DMAR for APL + * + * @ctx: ACPI context pointer + */ +int apl_acpi_fill_dmar(struct acpi_ctx *ctx); + +#endif /* _ASM_ARCH_CPU_H */ diff --git a/include/acpi/acpi_s3.h b/include/acpi/acpi_s3.h index baa848dcd15..847139baa0c 100644 --- a/include/acpi/acpi_s3.h +++ b/include/acpi/acpi_s3.h @@ -28,6 +28,10 @@ #define SLP_TYP_S4 6 #define SLP_TYP_S5 7
+/* PM1_STS register */ +#define RTC_EN BIT(10) +#define PWRBTN_EN BIT(8) + /* Memory size reserved for S3 resume */ #define S3_RESERVE_SIZE 0x1000
Support generating a DMAR table and add a few helper routines as well. Also set up NHLT so that audio works.
(no changes since v1)
Changes in v1: - Add support for NHLT table - Capitalise ACPI_OPS_PTR - Move the acpi.h header file to this commit - Update commit message
arch/x86/cpu/apollolake/hostbridge.c | 221 +++++++++++++++++++++++++-- 1 file changed, 212 insertions(+), 9 deletions(-)
diff --git a/arch/x86/cpu/apollolake/hostbridge.c b/arch/x86/cpu/apollolake/hostbridge.c index 056f7e57a9a..cf60fd8b021 100644 --- a/arch/x86/cpu/apollolake/hostbridge.c +++ b/arch/x86/cpu/apollolake/hostbridge.c @@ -1,17 +1,45 @@ // SPDX-License-Identifier: GPL-2.0 /* * Copyright 2019 Google LLC + * Copyright (C) 2015 - 2017 Intel Corp. + * Copyright (C) 2017 - 2019 Siemens AG + * (Written by Alexandru Gagniuc alexandrux.gagniuc@intel.com for Intel Corp.) + * (Written by Andrey Petrov andrey.petrov@intel.com for Intel Corp.) + * + * Portions from coreboot soc/intel/apollolake/chip.c */
+#define LOG_CATEGORY UCLASS_NORTHBRIDGE + #include <common.h> #include <dm.h> #include <dt-structs.h> #include <log.h> #include <spl.h> +#include <tables_csum.h> +#include <acpi/acpi_table.h> +#include <asm/acpi_nhlt.h> #include <asm/intel_pinctrl.h> #include <asm/intel_regs.h> +#include <asm/io.h> #include <asm/pci.h> +#include <asm/arch/acpi.h> #include <asm/arch/systemagent.h> +#include <dt-bindings/sound/nhlt.h> +#include <dm/acpi.h> + +enum { + PCIEXBAR = 0x60, + PCIEXBAR_LENGTH_256MB = 0, + PCIEXBAR_LENGTH_128MB, + PCIEXBAR_LENGTH_64MB, + + PCIEXBAR_PCIEXBAREN = 1 << 0, + + BGSM = 0xb4, /* Base GTT Stolen Memory */ + TSEG = 0xb8, /* TSEG base */ + TOLUD = 0xbc, +};
/** * struct apl_hostbridge_platdata - platform data for hostbridge @@ -32,17 +60,100 @@ struct apl_hostbridge_platdata { pci_dev_t bdf; };
-enum { - PCIEXBAR = 0x60, - PCIEXBAR_LENGTH_256MB = 0, - PCIEXBAR_LENGTH_128MB, - PCIEXBAR_LENGTH_64MB, +static const struct nhlt_format_config dmic_1ch_formats[] = { + /* 48 KHz 16-bits per sample. */ + { + .num_channels = 1, + .sample_freq_khz = 48, + .container_bits_per_sample = 16, + .valid_bits_per_sample = 16, + .settings_file = "dmic-1ch-48khz-16b.dat", + }, +};
- PCIEXBAR_PCIEXBAREN = 1 << 0, +static const struct nhlt_dmic_array_config dmic_1ch_mic_config = { + .tdm_config = { + .config_type = NHLT_TDM_MIC_ARRAY, + }, + .array_type = NHLT_MIC_ARRAY_VENDOR_DEFINED, +};
- BGSM = 0xb4, /* Base GTT Stolen Memory */ - TSEG = 0xb8, /* TSEG base */ - TOLUD = 0xbc, +static const struct nhlt_endp_descriptor dmic_1ch_descriptors[] = { + { + .link = NHLT_LINK_PDM, + .device = NHLT_PDM_DEV, + .direction = NHLT_DIR_CAPTURE, + .vid = NHLT_VID, + .did = NHLT_DID_DMIC, + .cfg = &dmic_1ch_mic_config, + .cfg_size = sizeof(dmic_1ch_mic_config), + .formats = dmic_1ch_formats, + .num_formats = ARRAY_SIZE(dmic_1ch_formats), + }, +}; + +static const struct nhlt_format_config dmic_2ch_formats[] = { + /* 48 KHz 16-bits per sample. */ + { + .num_channels = 2, + .sample_freq_khz = 48, + .container_bits_per_sample = 16, + .valid_bits_per_sample = 16, + .settings_file = "dmic-2ch-48khz-16b.dat", + }, +}; + +static const struct nhlt_dmic_array_config dmic_2ch_mic_config = { + .tdm_config = { + .config_type = NHLT_TDM_MIC_ARRAY, + }, + .array_type = NHLT_MIC_ARRAY_2CH_SMALL, +}; + +static const struct nhlt_endp_descriptor dmic_2ch_descriptors[] = { + { + .link = NHLT_LINK_PDM, + .device = NHLT_PDM_DEV, + .direction = NHLT_DIR_CAPTURE, + .vid = NHLT_VID, + .did = NHLT_DID_DMIC, + .cfg = &dmic_2ch_mic_config, + .cfg_size = sizeof(dmic_2ch_mic_config), + .formats = dmic_2ch_formats, + .num_formats = ARRAY_SIZE(dmic_2ch_formats), + }, +}; + +static const struct nhlt_format_config dmic_4ch_formats[] = { + /* 48 KHz 16-bits per sample. */ + { + .num_channels = 4, + .sample_freq_khz = 48, + .container_bits_per_sample = 16, + .valid_bits_per_sample = 16, + .settings_file = "dmic-4ch-48khz-16b.dat", + }, +}; + +static const struct nhlt_dmic_array_config dmic_4ch_mic_config = { + .tdm_config = { + .config_type = NHLT_TDM_MIC_ARRAY, + }, + .array_type = NHLT_MIC_ARRAY_4CH_L_SHAPED, +}; + +static const struct nhlt_endp_descriptor dmic_4ch_descriptors[] = { + { + .link = NHLT_LINK_PDM, + .device = NHLT_PDM_DEV, + .direction = NHLT_DIR_CAPTURE, + .vid = NHLT_VID, + .did = NHLT_DID_DMIC, + .cfg = &dmic_4ch_mic_config, + .cfg_size = sizeof(dmic_4ch_mic_config), + .formats = dmic_4ch_formats, + .num_formats = ARRAY_SIZE(dmic_4ch_formats), + }, };
static int apl_hostbridge_early_init_pinctrl(struct udevice *dev) @@ -167,6 +278,87 @@ static int apl_hostbridge_probe(struct udevice *dev) return 0; }
+static int apl_acpi_hb_get_name(const struct udevice *dev, char *out_name) +{ + return acpi_copy_name(out_name, "RHUB"); +} + +#ifdef CONFIG_GENERATE_ACPI_TABLE +static int apl_acpi_hb_write_tables(const struct udevice *dev, + struct acpi_ctx *ctx) +{ + struct acpi_table_header *header; + struct acpi_dmar *dmar; + u32 val; + + /* + * Create DMAR table only if virtualization is enabled. Due to some + * constraints on Apollo Lake SoC (some stepping affected), VTD could + * not be enabled together with IPU. Doing so will override and disable + * VTD while leaving CAPID0_A still reporting that VTD is available. + * As in this case FSP will lock VTD to disabled state, we need to make + * sure that DMAR table generation only happens when at least DEFVTBAR + * is enabled. Otherwise the DMAR header will be generated while the + * content of the table will be missing. + */ + dm_pci_read_config32(dev, CAPID0_A, &val); + if ((val & VTD_DISABLE) || + !(readl(MCHBAR_REG(DEFVTBAR)) & VTBAR_ENABLED)) + return 0; + + log_debug("ACPI: * DMAR\n"); + dmar = (struct acpi_dmar *)ctx->current; + header = &dmar->header; + acpi_create_dmar(dmar, DMAR_INTR_REMAP); + ctx->current += sizeof(struct acpi_dmar); + apl_acpi_fill_dmar(ctx); + + /* (Re)calculate length and checksum */ + header->length = ctx->current - (void *)dmar; + header->checksum = table_compute_checksum((void *)dmar, header->length); + + acpi_align(ctx); + acpi_add_table(ctx, dmar); + acpi_align(ctx); + + return 0; +} +#endif + +static int apl_acpi_setup_nhlt(const struct udevice *dev, struct acpi_ctx *ctx) +{ + struct nhlt *nhlt = ctx->nhlt; + u32 channels; + ofnode node; + + node = ofnode_find_subnode(dev_ofnode(dev), "nhlt"); + if (ofnode_read_u32(node, "intel,dmic-channels", &channels)) + return log_msg_ret("channels", -EINVAL); + switch (channels) { + case 1: + return nhlt_add_endpoints(nhlt, dmic_1ch_descriptors, + ARRAY_SIZE(dmic_1ch_descriptors)); + case 2: + return nhlt_add_endpoints(nhlt, dmic_2ch_descriptors, + ARRAY_SIZE(dmic_2ch_descriptors)); + case 4: + return nhlt_add_endpoints(nhlt, dmic_4ch_descriptors, + ARRAY_SIZE(dmic_4ch_descriptors)); + } + + return log_msg_ret("channels", -EINVAL); +} + +static int apl_hostbridge_remove(struct udevice *dev) +{ + /* + * TODO(sjg@chromium.org): Consider adding code from coreboot's + * platform_fsp_notify_status() + */ + + return 0; +} + static ulong sa_read_reg(struct udevice *dev, int reg) { u32 val; @@ -192,6 +384,14 @@ ulong sa_get_tseg_base(struct udevice *dev) return sa_read_reg(dev, TSEG); }
+struct acpi_ops apl_hostbridge_acpi_ops = { + .get_name = apl_acpi_hb_get_name, +#ifdef CONFIG_GENERATE_ACPI_TABLE + .write_tables = apl_acpi_hb_write_tables, +#endif + .setup_nhlt = apl_acpi_setup_nhlt, +}; + static const struct udevice_id apl_hostbridge_ids[] = { { .compatible = "intel,apl-hostbridge" }, { } @@ -203,5 +403,8 @@ U_BOOT_DRIVER(apl_hostbridge_drv) = { .of_match = apl_hostbridge_ids, .ofdata_to_platdata = apl_hostbridge_ofdata_to_platdata, .probe = apl_hostbridge_probe, + .remove = apl_hostbridge_remove, .platdata_auto_alloc_size = sizeof(struct apl_hostbridge_platdata), + ACPI_OPS_PTR(&apl_hostbridge_acpi_ops) + .flags = DM_FLAG_OS_PREPARE, };
Add ACPI generation to the APL CPU driver.
Changes in v1: - Capitalise ACPI_OPS_PTR - Handle table generation without callbacks
arch/x86/cpu/apollolake/cpu.c | 77 ++++++++++++++++++++++++++++++ arch/x86/lib/Makefile | 3 +- configs/chromebook_coral_defconfig | 1 + 3 files changed, 80 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/apollolake/cpu.c b/arch/x86/cpu/apollolake/cpu.c index 0a6d2ad7a4a..8da2e64e226 100644 --- a/arch/x86/cpu/apollolake/cpu.c +++ b/arch/x86/cpu/apollolake/cpu.c @@ -6,14 +6,90 @@ #include <common.h> #include <cpu.h> #include <dm.h> +#include <log.h> +#include <acpi/acpigen.h> +#include <acpi/acpi_table.h> #include <asm/cpu_common.h> #include <asm/cpu_x86.h> +#include <asm/intel_acpi.h> +#include <asm/msr.h> +#include <dm/acpi.h> + +#define CSTATE_RES(address_space, width, offset, address) \ + { \ + .space_id = address_space, \ + .bit_width = width, \ + .bit_offset = offset, \ + .addrl = address, \ + } + +static struct acpi_cstate cstate_map[] = { + { + /* C1 */ + .ctype = 1, /* ACPI C1 */ + .latency = 1, + .power = 1000, + .resource = { + .space_id = ACPI_ADDRESS_SPACE_FIXED, + }, + }, { + .ctype = 2, /* ACPI C2 */ + .latency = 50, + .power = 10, + .resource = { + .space_id = ACPI_ADDRESS_SPACE_IO, + .bit_width = 8, + .addrl = 0x415, + }, + }, { + .ctype = 3, /* ACPI C3 */ + .latency = 150, + .power = 10, + .resource = { + .space_id = ACPI_ADDRESS_SPACE_IO, + .bit_width = 8, + .addrl = 0x419, + }, + }, +};
static int apl_get_info(const struct udevice *dev, struct cpu_info *info) { return cpu_intel_get_info(info, INTEL_BCLK_MHZ); }
+static int acpi_cpu_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx) +{ + uint core_id = dev->req_seq; + int cores_per_package; + int ret; + + cores_per_package = cpu_get_cores_per_package(); + ret = acpi_generate_cpu_header(ctx, core_id, cstate_map, + ARRAY_SIZE(cstate_map)); + + /* Generate P-state tables */ + generate_p_state_entries(ctx, core_id, cores_per_package); + + /* Generate T-state tables */ + generate_t_state_entries(ctx, core_id, cores_per_package, NULL, 0); + + acpigen_pop_len(ctx); + + if (device_is_last_sibling(dev)) { + ret = acpi_generate_cpu_package_final(ctx, cores_per_package); + + if (ret) + return ret; + } + + return 0; +} + +struct acpi_ops apl_cpu_acpi_ops = { + .fill_ssdt = acpi_cpu_fill_ssdt, +}; + static const struct cpu_ops cpu_x86_apl_ops = { .get_desc = cpu_x86_get_desc, .get_info = apl_get_info, @@ -32,5 +108,6 @@ U_BOOT_DRIVER(cpu_x86_apl_drv) = { .of_match = cpu_x86_apl_ids, .bind = cpu_x86_bind, .ops = &cpu_x86_apl_ops, + ACPI_OPS_PTR(&apl_cpu_acpi_ops) .flags = DM_FLAG_PRE_RELOC, }; diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index f04d275dd9a..1bcbb49a61f 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -38,7 +38,8 @@ obj-y += sfi.o obj-y += acpi.o obj-$(CONFIG_HAVE_ACPI_RESUME) += acpi_s3.o ifndef CONFIG_QEMU -obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi_table.o acpigen.o +obj-y += acpigen.o +obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi_table.o endif obj-y += tables.o ifndef CONFIG_SPL_BUILD diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index c9006e2f934..ef4dabbe26e 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -72,6 +72,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y +CONFIG_INTEL_ACPIGEN=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y
Add an ACPI table for the LPC on Apollo Lake.
arch/x86/cpu/apollolake/lpc.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/x86/cpu/apollolake/lpc.c b/arch/x86/cpu/apollolake/lpc.c index b81a458f2eb..a29832c879a 100644 --- a/arch/x86/cpu/apollolake/lpc.c +++ b/arch/x86/cpu/apollolake/lpc.c @@ -9,10 +9,14 @@ #include <dm.h> #include <log.h> #include <spl.h> +#include <acpi/acpi_table.h> +#include <asm/cpu_common.h> +#include <asm/intel_acpi.h> #include <asm/lpc_common.h> #include <asm/pci.h> #include <asm/arch/iomap.h> #include <asm/arch/lpc.h> +#include <dm/acpi.h> #include <linux/log2.h>
void lpc_enable_fixed_io_ranges(uint io_enables) @@ -110,6 +114,19 @@ void lpc_io_setup_comm_a_b(void) lpc_enable_fixed_io_ranges(com_enable); }
+static int apl_acpi_lpc_get_name(const struct udevice *dev, char *out_name) +{ + return acpi_copy_name(out_name, "LPCB"); +} + +struct acpi_ops apl_lpc_acpi_ops = { + .get_name = apl_acpi_lpc_get_name, +#ifdef CONFIG_GENERATE_ACPI_TABLE + .write_tables = intel_southbridge_write_acpi_tables, +#endif + .inject_dsdt = southbridge_inject_dsdt, +}; + static const struct udevice_id apl_lpc_ids[] = { { .compatible = "intel,apl-lpc" }, { } @@ -120,4 +137,5 @@ U_BOOT_DRIVER(apl_lpc_drv) = { .name = "intel_apl_lpc", .id = UCLASS_LPC, .of_match = apl_lpc_ids, + ACPI_OPS_PTR(&apl_lpc_acpi_ops) };
We don't have CONFIG_PCI in TPL but it is present in SPL, etc. So this code is not needed. Drop it, and fix a code-style nit just above.
arch/x86/cpu/apollolake/pmc.c | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/arch/x86/cpu/apollolake/pmc.c b/arch/x86/cpu/apollolake/pmc.c index 192dec7109a..576d0187570 100644 --- a/arch/x86/cpu/apollolake/pmc.c +++ b/arch/x86/cpu/apollolake/pmc.c @@ -118,7 +118,8 @@ int apl_pmc_ofdata_to_uc_platdata(struct udevice *dev) int size; int ret;
- ret = dev_read_u32_array(dev, "early-regs", base, ARRAY_SIZE(base)); + ret = dev_read_u32_array(dev, "early-regs", base, + ARRAY_SIZE(base)); if (ret) return log_msg_ret("Missing/short early-regs", ret); if (spl_phase() == PHASE_TPL) { @@ -133,11 +134,6 @@ int apl_pmc_ofdata_to_uc_platdata(struct udevice *dev) } upriv->acpi_base = base[4];
- /* Since PCI is not enabled, we must get the BDF manually */ - plat->bdf = pci_get_devfn(dev); - if (plat->bdf < 0) - return log_msg_ret("Cannot get PMC PCI address", plat->bdf); - /* Get the dwX values for pmc gpe settings */ size = dev_read_size(dev, "gpe0-dw"); if (size < 0)
Generate ACPI information for this device so that Linux can use it correctly.
Changes in v1: - Capitalise ACPI_OPS_PTR - Update for acpi_device_write_i2c_dev() return-value change - Use acpi,ddn instead of acpi,desc
drivers/tpm/cr50_i2c.c | 55 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 55 insertions(+)
diff --git a/drivers/tpm/cr50_i2c.c b/drivers/tpm/cr50_i2c.c index 1942c07c605..64831a42232 100644 --- a/drivers/tpm/cr50_i2c.c +++ b/drivers/tpm/cr50_i2c.c @@ -14,11 +14,14 @@ #include <log.h> #include <spl.h> #include <tpm-v2.h> +#include <acpi/acpigen.h> +#include <acpi/acpi_device.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/iomap.h> #include <asm/arch/pm.h> #include <linux/delay.h> +#include <dm/acpi.h>
enum { TIMEOUT_INIT_MS = 30000, /* Very long timeout for TPM init */ @@ -581,6 +584,53 @@ static int cr50_i2c_cleanup(struct udevice *dev) return 0; }
+static int cr50_acpi_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx) +{ + char scope[ACPI_PATH_MAX]; + char name[ACPI_NAME_MAX]; + const char *hid; + int ret; + + ret = acpi_device_scope(dev, scope, sizeof(scope)); + if (ret) + return log_msg_ret("scope", ret); + ret = acpi_get_name(dev, name); + if (ret) + return log_msg_ret("name", ret); + + hid = dev_read_string(dev, "acpi,hid"); + if (!hid) + return log_msg_ret("hid", ret); + + /* Device */ + acpigen_write_scope(ctx, scope); + acpigen_write_device(ctx, name); + acpigen_write_name_string(ctx, "_HID", hid); + acpigen_write_name_integer(ctx, "_UID", + dev_read_u32_default(dev, "acpi,uid", 0)); + acpigen_write_name_string(ctx, "_DDN", + dev_read_string(dev, "acpi,ddn")); + acpigen_write_sta(ctx, acpi_device_status(dev)); + + /* Resources */ + acpigen_write_name(ctx, "_CRS"); + acpigen_write_resourcetemplate_header(ctx); + ret = acpi_device_write_i2c_dev(ctx, dev); + if (ret < 0) + return log_msg_ret("i2c", ret); + ret = acpi_device_write_interrupt_or_gpio(ctx, (struct udevice *)dev, + "ready-gpios"); + if (ret < 0) + return log_msg_ret("irq_gpio", ret); + + acpigen_write_resourcetemplate_footer(ctx); + + acpigen_pop_len(ctx); /* Device */ + acpigen_pop_len(ctx); /* Scope */ + + return 0; +} + enum { TPM_TIMEOUT_MS = 5, SHORT_TIMEOUT_MS = 750, @@ -653,6 +703,10 @@ static int cr50_i2c_probe(struct udevice *dev) return 0; }
+struct acpi_ops cr50_acpi_ops = { + .fill_ssdt = cr50_acpi_fill_ssdt, +}; + static const struct tpm_ops cr50_i2c_ops = { .open = cr50_i2c_open, .get_desc = cr50_i2c_get_desc, @@ -675,5 +729,6 @@ U_BOOT_DRIVER(cr50_i2c) = { .probe = cr50_i2c_probe, .remove = cr50_i2c_cleanup, .priv_auto_alloc_size = sizeof(struct cr50_priv), + ACPI_OPS_PTR(&cr50_acpi_ops) .flags = DM_FLAG_OS_PREPARE, };
This new method is intended to be called when UEFI shuts down the 'boot services', i.e. any lingering code in the boot loader that might be used by the OS.
Add a definition for this new method and update the comments a little.
arch/x86/include/asm/fsp/fsp_api.h | 15 ++++++++++++--- 1 file changed, 12 insertions(+), 3 deletions(-)
diff --git a/arch/x86/include/asm/fsp/fsp_api.h b/arch/x86/include/asm/fsp/fsp_api.h index 4941e2d74f0..3a9b61903c0 100644 --- a/arch/x86/include/asm/fsp/fsp_api.h +++ b/arch/x86/include/asm/fsp/fsp_api.h @@ -10,9 +10,18 @@
enum fsp_phase { /* Notification code for post PCI enuermation */ - INIT_PHASE_PCI = 0x20, - /* Notification code before transferring control to the payload */ - INIT_PHASE_BOOT = 0x40 + INIT_PHASE_PCI = 0x20, + /* + * Notification code before transferring control to the payload. + * This is issued at the end of init before starting main(), i.e. + * the command line / boot script. + */ + INIT_PHASE_BOOT = 0x40, + /* + * Notification code before existing boot services. This is issued + * just before removing devices and booting the kernel. + */ + INIT_PHASE_END_FIRMWARE = 0xf0, };
struct fsp_notify_params {
Add support for this new field in the common code used by most x86 CPU drivers.
arch/x86/cpu/i386/cpu.c | 23 +++++++++++++++++++++++ arch/x86/cpu/intel_common/cpu.c | 1 + arch/x86/cpu/x86_64/cpu.c | 5 +++++ arch/x86/include/asm/cpu.h | 9 +++++++++ 4 files changed, 38 insertions(+)
diff --git a/arch/x86/cpu/i386/cpu.c b/arch/x86/cpu/i386/cpu.c index 8f342dd06e2..7517b756f43 100644 --- a/arch/x86/cpu/i386/cpu.c +++ b/arch/x86/cpu/i386/cpu.c @@ -34,6 +34,10 @@
DECLARE_GLOBAL_DATA_PTR;
+#define CPUID_FEATURE_PAE BIT(6) +#define CPUID_FEATURE_PSE36 BIT(17) +#define CPUID_FEAURE_HTT BIT(28) + /* * Constructor for a conventional segment GDT (or LDT) entry * This is a macro so it can be used in initialisers @@ -388,6 +392,25 @@ static void setup_identity(void) } }
+static uint cpu_cpuid_extended_level(void) +{ + return cpuid_eax(0x80000000); +} + +int cpu_phys_address_size(void) +{ + if (!has_cpuid()) + return 32; + + if (cpu_cpuid_extended_level() >= 0x80000008) + return cpuid_eax(0x80000008) & 0xff; + + if (cpuid_edx(1) & (CPUID_FEATURE_PAE | CPUID_FEATURE_PSE36)) + return 36; + + return 32; +} + /* Don't allow PCI region 3 to use memory in the 2-4GB memory hole */ static void setup_pci_ram_top(void) { diff --git a/arch/x86/cpu/intel_common/cpu.c b/arch/x86/cpu/intel_common/cpu.c index d8a3d60ae72..39aa0f63c65 100644 --- a/arch/x86/cpu/intel_common/cpu.c +++ b/arch/x86/cpu/intel_common/cpu.c @@ -127,6 +127,7 @@ int cpu_intel_get_info(struct cpu_info *info, int bclk) info->cpu_freq = ((msr.lo >> 8) & 0xff) * bclk * 1000000; info->features = 1 << CPU_FEAT_L1_CACHE | 1 << CPU_FEAT_MMU | 1 << CPU_FEAT_UCODE | 1 << CPU_FEAT_DEVICE_ID; + info->address_width = cpu_phys_address_size();
return 0; } diff --git a/arch/x86/cpu/x86_64/cpu.c b/arch/x86/cpu/x86_64/cpu.c index 1b4d3971b04..90a766c3c57 100644 --- a/arch/x86/cpu/x86_64/cpu.c +++ b/arch/x86/cpu/x86_64/cpu.c @@ -70,3 +70,8 @@ int x86_cpu_reinit_f(void) { return 0; } + +int cpu_phys_address_size(void) +{ + return CONFIG_CPU_ADDR_BITS; +} diff --git a/arch/x86/include/asm/cpu.h b/arch/x86/include/asm/cpu.h index 21a05dab7de..5b001bbee21 100644 --- a/arch/x86/include/asm/cpu.h +++ b/arch/x86/include/asm/cpu.h @@ -288,4 +288,13 @@ u32 cpu_get_family_model(void); */ u32 cpu_get_stepping(void);
+/** + * cpu_phys_address_size() - Get the physical address size in bits + * + * This is 32 for older CPUs but newer ones may support 36. + * + * @return address size (typically 32 or 36) + */ +int cpu_phys_address_size(void); + #endif
At present the MTRR registers are programmed with the list the U-Boot builds up in the same order. In some cases this list may be out of order. It looks better in Linux to have the registers in order, so sort them,
arch/x86/cpu/mtrr.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/x86/cpu/mtrr.c b/arch/x86/cpu/mtrr.c index 2468d88a80a..08fa80f8bc7 100644 --- a/arch/x86/cpu/mtrr.c +++ b/arch/x86/cpu/mtrr.c @@ -19,6 +19,7 @@ #include <common.h> #include <cpu_func.h> #include <log.h> +#include <sort.h> #include <asm/cache.h> #include <asm/io.h> #include <asm/mp.h> @@ -124,6 +125,16 @@ static int mtrr_copy_to_aps(void) return 0; }
+static int h_comp_mtrr(const void *p1, const void *p2) +{ + const struct mtrr_request *req1 = p1; + const struct mtrr_request *req2 = p2; + + s64 diff = req1->start - req2->start; + + return diff < 0 ? -1 : diff > 0 ? 1 : 0; +} + int mtrr_commit(bool do_caches) { struct mtrr_request *req = gd->arch.mtrr_req; @@ -139,6 +150,7 @@ int mtrr_commit(bool do_caches) debug("open\n"); mtrr_open(&state, do_caches); debug("open done\n"); + qsort(req, gd->arch.mtrr_req_count, sizeof(*req), h_comp_mtrr); for (i = 0; i < gd->arch.mtrr_req_count; i++, req++) set_var_mtrr(i, req->type, req->start, req->size);
Send this notification when U-Boot is about to boot into Linux, as requested by the FSP.
Currently this causes a crash with the APL FSP, so leave it disabled for now.
arch/x86/cpu/cpu.c | 15 +++++++++++++++ arch/x86/lib/fsp/fsp_common.c | 16 ++++++++++++++++ 2 files changed, 31 insertions(+)
diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index 69c14189d1f..f8692753963 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -189,6 +189,14 @@ __weak void board_final_init(void) { }
+/* + * Implement a weak default function for boards that need to do some final + * processing before booting the OS. + */ +__weak void board_final_cleanup(void) +{ +} + int last_stage_init(void) { struct acpi_fadt __maybe_unused *fadt; @@ -218,6 +226,13 @@ int last_stage_init(void) } }
+ /* + * TODO(sjg@chromium.org): Move this to bootm_announce_and_cleanup() + * once APL FSP-S at 0x200000 does not overlap with the bzimage at + * 0x100000. + */ + board_final_cleanup(); + return 0; } #endif diff --git a/arch/x86/lib/fsp/fsp_common.c b/arch/x86/lib/fsp/fsp_common.c index ea529547254..4061fa244c4 100644 --- a/arch/x86/lib/fsp/fsp_common.c +++ b/arch/x86/lib/fsp/fsp_common.c @@ -60,6 +60,22 @@ void board_final_init(void) debug("OK\n"); }
+void board_final_cleanup(void) +{ + u32 status; + + /* TODO(sjg@chromium.org): This causes Linux to crash */ + return; + + /* call into FspNotify */ + debug("Calling into FSP (notify phase INIT_PHASE_END_FIRMWARE): "); + status = fsp_notify(NULL, INIT_PHASE_END_FIRMWARE); + if (status) + debug("fail, error code %x\n", status); + else + debug("OK\n"); +} + int fsp_save_s3_stack(void) { struct udevice *dev;
This is currently in the wrong place, so including the file in the device tree fails. Fix it.
Changes in v1: - Update commit message with a comma
arch/x86/include/asm/e820.h | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/x86/include/asm/e820.h b/arch/x86/include/asm/e820.h index 9d29f82f972..87af0f492ec 100644 --- a/arch/x86/include/asm/e820.h +++ b/arch/x86/include/asm/e820.h @@ -21,10 +21,9 @@ struct e820_entry { #define ISA_START_ADDRESS 0xa0000 #define ISA_END_ADDRESS 0x100000
-#endif /* __ASSEMBLY__ */ - /* Implementation defined function to install an e820 map */ unsigned int install_e820_map(unsigned int max_entries, struct e820_entry *); +#endif /* __ASSEMBLY__ */
#endif /* _ASM_X86_E820_H */
This file cannot currently be included in ASL files. Add a header guard to permit this.
arch/x86/include/asm/acpi_table.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index faf31730730..1b49ccadc0c 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -9,6 +9,8 @@ #ifndef __ASM_ACPI_TABLE_H__ #define __ASM_ACPI_TABLE_H__
+#ifndef __ACPI__ + struct acpi_facs; struct acpi_fadt; struct acpi_global_nvs; @@ -213,4 +215,6 @@ void acpi_fadt_common(struct acpi_fadt *fadt, struct acpi_facs *facs, */ void intel_acpi_fill_fadt(struct acpi_fadt *fadt);
+#endif /* !__ACPI__ */ + #endif /* __ASM_ACPI_TABLE_H__ */
At present if hyperthreading is disabled the CPU numbering is not sequential. Fix this.
arch/x86/lib/acpi_table.c | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index b0cc1f123e2..667059b5ace 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -66,14 +66,17 @@ int acpi_create_madt_lapics(u32 current) { struct udevice *dev; int total_length = 0; + int cpu_num = 0;
for (uclass_find_first_device(UCLASS_CPU, &dev); dev; uclass_find_next_device(&dev)) { struct cpu_platdata *plat = dev_get_parent_platdata(dev); - int length = acpi_create_madt_lapic( - (struct acpi_madt_lapic *)current, - plat->cpu_id, plat->cpu_id); + int length; + + length = acpi_create_madt_lapic( + (struct acpi_madt_lapic *)current, cpu_num++, + plat->cpu_id); current += length; total_length += length; }
This provides information about a v2 TPM in the system. Generate this table if the TPM is present.
arch/x86/lib/acpi_table.c | 74 +++++++++++++++++++++++++++++++++++++++ include/acpi/acpi_table.h | 11 ++++++ include/bloblist.h | 1 + 3 files changed, 86 insertions(+)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 667059b5ace..9b13880f996 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <bloblist.h> #include <cpu.h> #include <dm.h> #include <log.h> @@ -214,6 +215,64 @@ static void acpi_create_mcfg(struct acpi_mcfg *mcfg) header->checksum = table_compute_checksum((void *)mcfg, header->length); }
+static int get_tpm2_log(void **ptrp, int *sizep) +{ + const int tpm2_default_log_len = 0x10000; + int size; + int ret; + + *sizep = 0; + size = tpm2_default_log_len; + ret = bloblist_ensure_size_ret(BLOBLISTT_TPM2_TCG_LOG, &size, ptrp); + if (ret) + return log_msg_ret("blob", ret); + *sizep = size; + + return 0; +} + +static int acpi_create_tpm2(struct acpi_tpm2 *tpm2) +{ + struct acpi_table_header *header = &tpm2->header; + int tpm2_log_len; + void *lasa; + int ret; + + memset((void *)tpm2, 0, sizeof(struct acpi_tpm2)); + + /* + * Some payloads like SeaBIOS depend on log area to use TPM2. + * Get the memory size and address of TPM2 log area or initialize it. + */ + ret = get_tpm2_log(&lasa, &tpm2_log_len); + if (ret) + return ret; + + /* Fill out header fields. */ + acpi_fill_header(header, "TPM2"); + memcpy(header->aslc_id, ASLC_ID, 4); + + header->length = sizeof(struct acpi_tpm2); + header->revision = acpi_get_table_revision(ACPITAB_TPM2); + + /* Hard to detect for coreboot. Just set it to 0 */ + tpm2->platform_class = 0; + + /* Must be set to 0 for FIFO-interface support */ + tpm2->control_area = 0; + tpm2->start_method = 6; + memset(tpm2->msp, 0, sizeof(tpm2->msp)); + + /* Fill the log area size and start address fields. */ + tpm2->laml = tpm2_log_len; + tpm2->lasa = (uintptr_t)lasa; + + /* Calculate checksum. */ + header->checksum = table_compute_checksum((void *)tpm2, header->length); + + return 0; +} + __weak u32 acpi_fill_csrt(u32 current) { return 0; @@ -486,6 +545,21 @@ ulong write_acpi_tables(ulong start_addr) acpi_inc_align(ctx, mcfg->header.length); acpi_add_table(ctx, mcfg);
+ if (IS_ENABLED(CONFIG_TPM_V2)) { + struct acpi_tpm2 *tpm2; + int ret; + + debug("ACPI: * TPM2\n"); + tpm2 = (struct acpi_tpm2 *)ctx->current; + ret = acpi_create_tpm2(tpm2); + if (!ret) { + acpi_inc_align(ctx, tpm2->header.length); + acpi_add_table(ctx, tpm2); + } else { + log_warning("TPM2 table creation failed\n"); + } + } + debug("ACPI: * MADT\n"); madt = ctx->current; acpi_create_madt(madt); diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index a2e510cf56e..c7ee8b55da4 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -93,6 +93,17 @@ struct __packed acpi_hpet { u8 attributes; };
+struct __packed acpi_tpm2 { + struct acpi_table_header header; + u16 platform_class; + u8 reserved[2]; + u64 control_area; + u32 start_method; + u8 msp[12]; + u32 laml; + u64 lasa; +}; + /* FADT Preferred Power Management Profile */ enum acpi_pm_profile { ACPI_PM_UNSPECIFIED = 0, diff --git a/include/bloblist.h b/include/bloblist.h index 7d8480548e0..dc7d80bd851 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -33,6 +33,7 @@ enum bloblist_tag_t { */ BLOBLISTT_ACPI_GNVS, BLOBLISTT_INTEL_VBT, /* Intel Video-BIOS table */ + BLOBLISTT_TPM2_TCG_LOG, /* TPM v2 log space */ };
This provides information about a v1 TPM in the system. Generate this table if the TPM is present.
Add a required new bloblist type and correct the header order of one header file.
arch/x86/lib/acpi_table.c | 54 ++++++++++++++++++++++++++++++++++++++- include/acpi/acpi_table.h | 7 +++++ include/bloblist.h | 1 + 3 files changed, 61 insertions(+), 1 deletion(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 9b13880f996..a3db94b8318 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -215,6 +215,47 @@ static void acpi_create_mcfg(struct acpi_mcfg *mcfg) header->checksum = table_compute_checksum((void *)mcfg, header->length); }
+/** + * acpi_create_tcpa() - Create a TCPA table + * + * @tcpa: Pointer to place to put table + * + * Trusted Computing Platform Alliance Capabilities Table + * TCPA PC Specific Implementation SpecificationTCPA is defined in the PCI + * Firmware Specification 3.0 + */ +static int acpi_create_tcpa(struct acpi_tcpa *tcpa) +{ + struct acpi_table_header *header = &tcpa->header; + u32 current = (u32)tcpa + sizeof(struct acpi_tcpa); + int size = 0x10000; /* Use this as the default size */ + void *log; + int ret; + + if (!CONFIG_IS_ENABLED(BLOBLIST)) + return -ENXIO; + memset(tcpa, '\0', sizeof(struct acpi_tcpa)); + + /* Fill out header fields */ + acpi_fill_header(header, "TCPA"); + header->length = sizeof(struct acpi_tcpa); + header->revision = 1; + + ret = bloblist_ensure_size_ret(BLOBLISTT_TCPA_LOG, &size, &log); + if (ret) + return log_msg_ret("blob", ret); + + tcpa->platform_class = 0; + tcpa->laml = size; + tcpa->lasa = (ulong)log; + + /* (Re)calculate length and checksum */ + header->length = current - (u32)tcpa; + header->checksum = table_compute_checksum((void *)tcpa, header->length); + + return 0; +} + static int get_tpm2_log(void **ptrp, int *sizep) { const int tpm2_default_log_len = 0x10000; @@ -455,11 +496,13 @@ ulong write_acpi_tables(ulong start_addr) struct acpi_fadt *fadt; struct acpi_table_header *ssdt; struct acpi_mcfg *mcfg; + struct acpi_tcpa *tcpa; struct acpi_madt *madt; struct acpi_csrt *csrt; struct acpi_spcr *spcr; void *start; ulong addr; + int ret; int i;
start = map_sysmem(start_addr, 0); @@ -547,7 +590,6 @@ ulong write_acpi_tables(ulong start_addr)
if (IS_ENABLED(CONFIG_TPM_V2)) { struct acpi_tpm2 *tpm2; - int ret;
debug("ACPI: * TPM2\n"); tpm2 = (struct acpi_tpm2 *)ctx->current; @@ -566,6 +608,16 @@ ulong write_acpi_tables(ulong start_addr) acpi_inc_align(ctx, madt->header.length); acpi_add_table(ctx, madt);
+ debug("ACPI: * TCPA\n"); + tcpa = (struct acpi_tcpa *)ctx->current; + ret = acpi_create_tcpa(tcpa); + if (ret) { + log_warning("Failed to create TCPA table (err=%d)\n", ret); + } else { + acpi_inc_align(ctx, tcpa->header.length); + acpi_add_table(ctx, tcpa); + } + debug("ACPI: * CSRT\n"); csrt = ctx->current; if (!acpi_create_csrt(csrt)) { diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index c7ee8b55da4..9fba6536f50 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -104,6 +104,13 @@ struct __packed acpi_tpm2 { u64 lasa; };
+struct __packed acpi_tcpa { + struct acpi_table_header header; + u16 platform_class; + u32 laml; + u64 lasa; +}; + /* FADT Preferred Power Management Profile */ enum acpi_pm_profile { ACPI_PM_UNSPECIFIED = 0, diff --git a/include/bloblist.h b/include/bloblist.h index dc7d80bd851..5784c2226e7 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -34,6 +34,7 @@ enum bloblist_tag_t { BLOBLISTT_ACPI_GNVS, BLOBLISTT_INTEL_VBT, /* Intel Video-BIOS table */ BLOBLISTT_TPM2_TCG_LOG, /* TPM v2 log space */ + BLOBLISTT_TCPA_LOG, /* TPM log space */ };
This file doesn't currently have a log category. Add one so that items are logged correctly.
arch/x86/lib/acpi_table.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index a3db94b8318..faab9d9de3c 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -6,6 +6,8 @@ * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com */
+#define LOG_CATEGORY LOGC_ACPI + #include <common.h> #include <bloblist.h> #include <cpu.h>
Add files describing the various audio configurations supported on coral. These are passed to Linux in the ACPI tables.
Changes in v1: - Add new patch with coral audio descriptor files
.../chromebook_coral/dialog-2ch-48khz-24b.dat | Bin 0 -> 100 bytes .../chromebook_coral/dmic-1ch-48khz-16b.dat | Bin 0 -> 3048 bytes .../chromebook_coral/dmic-2ch-48khz-16b.dat | Bin 0 -> 3048 bytes .../chromebook_coral/dmic-4ch-48khz-16b.dat | Bin 0 -> 3048 bytes .../max98357-render-2ch-48khz-24b.dat | Bin 0 -> 116 bytes 5 files changed, 0 insertions(+), 0 deletions(-) create mode 100644 board/google/chromebook_coral/dialog-2ch-48khz-24b.dat create mode 100644 board/google/chromebook_coral/dmic-1ch-48khz-16b.dat create mode 100644 board/google/chromebook_coral/dmic-2ch-48khz-16b.dat create mode 100644 board/google/chromebook_coral/dmic-4ch-48khz-16b.dat create mode 100644 board/google/chromebook_coral/max98357-render-2ch-48khz-24b.dat
diff --git a/board/google/chromebook_coral/dialog-2ch-48khz-24b.dat b/board/google/chromebook_coral/dialog-2ch-48khz-24b.dat new file mode 100644 index 0000000000000000000000000000000000000000..46c0efbd0adc0883564cf8404503fa1de7c4cc33 GIT binary patch literal 100 zcmZQzU|?WnWOx?=qy_%}|8E4u0zd*AHfO)k$iPr=0H_oQW->7YNf2go01_a;&(5v@ Oq?n-iKR*Kl2m=7w%Nqy)
literal 0 HcmV?d00001
diff --git a/board/google/chromebook_coral/dmic-1ch-48khz-16b.dat b/board/google/chromebook_coral/dmic-1ch-48khz-16b.dat new file mode 100644 index 0000000000000000000000000000000000000000..6a7f2cef4efea7707f4b2c57f8278962a53ca7c6 GIT binary patch literal 3048 zcmeH{?Q5207{-tL@yX`Po^x&`v;5##(}YE((R^uH$tuM#U0<xw`e19QX~tH4S!ser zHDiG`qA$;!h!vv2kkDSuj9ylRh1M!Z(N?HATPkin{f=b}_8$b#4Hwsay`9&29_R18 z5=lifa=D^hE=M=?jbiTKb{)Oj#jjN3{FjXWZ(_JF;<r)B@WhBeulFREjF=rBF5q_q z$JcOKZCZLFB~8kOP7H>sSgT?D0{yFuU;8_>nsFU%595k~&|1!xVg3wf4xSI4XZ~IM zY{u4OjJKW(t!KS{tklW=ulhpU*;^6P0DDUQ2)*1Nn#uTKoNYK0YV8eWFO^=pQd-I0 z4}N0qY^Y_5bg&qWj)y9{Lw%E^wyUN7lcDKfgf?OCmRV9IYAydL)XScJf;e}r)beHM z_<>LtHcFRDi~kJm&4%vc{(=XH`x@!#_Ru|Vg*Gmfvh@Vbnf|8G{n+blmX?-D->)O4 zH$$VJl0M!jjcp6PSQ~mDKQ23r7WiB~BXsLF{Ogc5(^4Bk^9w>ZRG{tTL``=~SDnmg zurf6H6Y0@A5+#R1Z$FvQsz*ZaEJxIJi5l+<J$|-OZ!8Io=}c66V@g%TxwE=Z`&Jg} z6n3hbM`>?&TJ00kYFn1loqbYfo;15a!WEU$kY3-SV;wC^4jai)*M(3w`PqrCb?Cnu z-N%ueZKp#E>F1))64vIi?^({Zz{h*!^?B@OX@mUtGB?0ljy;FTbFjaL)_~n=?l?vm zi`chi3{v96cKT_IbNDl#GdKMen##Rh+}Dl|6POzhTN(DP&q!axLp@yF#@WTp-;CWU z_;>nu_@Pywf=TY%%G!ZK7@i25S4b-e`a#bAjDK6O`+864As8zDG4#wYp%1xl8mxSC zxzt)N9i1+1nkwyrrya1`0Z(Pe(EM{a`!v*ZB(#V7W)b)G<Z$;~_SB#UIv?U}E37WU z{&)LBb9RJg!^G~6(3&6Mx<op%K)Sa9cAt|@G%<$1Uy126SlhP({mVnkibKE636*em z^X=$7G12}DiPj!XX(r;oGCr+URq3JLW6yit`@G-heBO3!&vtF!_xL{F>-+78{jp#6 z&wkop`)&UnhvRWvj?ZyAUdQeDt%LQjF4o67Sug8m{j8()w650II$Lk+ZvCAH=fin% zew-)g%XxGDoJZ%=d3AoBXXo2_cmB<Rc`z5|!<?8Gb7OwYk$Ey#=F6O!H*;tH%%OQS zm*&%)npbmce$BCYHrM9coSS!ZZ~k2et_RnJ>%(>8dU4&jeq2YcC)bth%XQ{@bKSZA pT!*+YRF|&Lq3`1RF6@u|2r>V@!&m-&&%f{a_dWl<|KHyCe*hgO-4Xx*
diff --git a/board/google/chromebook_coral/dmic-2ch-48khz-16b.dat b/board/google/chromebook_coral/dmic-2ch-48khz-16b.dat new file mode 100644 index 0000000000000000000000000000000000000000..71d7648202154b6e8116dcf99cb7336f92731ac9 GIT binary patch literal 3048 zcmeH{?Q7O$6vw~6dv`V;cAq_zX!*jirU{EmqxsOXl2wXfy54A^^}^Or(~PZpv(f~M zYQ_R>L~rgn5i3N4A)!6_7(J{A3$0a-qODMKwp84@`+R3_g#LoKZ@Bi`bzSE=*E!$w zIaea7cxo<JoXh3-4F3vPyEJa%>mel!jnim<3P$+v<-Zc9O_!`L-}rat{odq?|J?K9 zT*f*sS;b{_Y3b>dG(HzPITWg9ua^1CeBWUH=HH=}%<CDum{$&lR&%x-_h&hC;6msE z>mLwj3%;IYzWID;E&C0lq%Q2g>JM$jwlbtaY|8!!y*3b<#{98jsqt*6tuK_lQhN1T zX*sqZ|HRt4Q0qkLKq)$$2vzlj`o~M{*GmJZLQ}p7ZNT3h)1@lZT6!?lhs^*<oWD_O z{W5f7U#J@&;}%H^{tWHThVJA3!iUNG2I;wu&;##=*3Xl&4J6H(f#%Rd`0Hws7L`li zuOX**LL;7)4zHI+wTE7*3w=Z!R~<nMVy>7Px^oNhbxIo<sdb?_g`rz2(RM<j=KH1V zPGvMy6`Jsg^u#@hl0%{Qp2=v%<DvJLBI=q%O%H~iI#;B(7luZ5C91nMrE2orUQ?t! z%ZqdxKh-S-+TD{@M@d@ki&MI{U&_puW)w<<0y@OV_!b@O8Ch!BM2)&HhI**ac66;r z|CQ)In%ZnR6Pm|&7Wyn?Z#H%>aIO_TKBTTM;Wx_|;{QI@2HDGDbA&nv_O*;g{MK;C zanhKN-KLR9Nf2B4PG+7Xo;jSk?XS=z?(OEj4q_-_Z47K>uv?pvzJ`YexVVe63s}D$ zzY~e?%<u5Ss5uRj+_#y%eMK-l7B;VumXY)$oc)>jHsSZJ-q52kRQhA+`Cmf&xo<M8 zd~>zbRv{gmB5jx??SQ9ku-XYv<;T(db2$4n)O$3vi~FXN_s!IB=PYb$(F2_iakdRs z=i~poy`h=gLNj1uXJ=^D4{%*39i1yJX@uPurIXFf;qO;+`V7|gEJOc_(Bjh2Z!<$> zoZWagI*(1X_hO>e$5NVx_^*#iYejW>`0KgXy>C0)`<&0)kNw%N{reu@=X-s><8VBV z%keo*$LqKqzw>ZD&dd2ZPv`5roxgRk9@fSBSSRac-K?K=w4T=0`dVk}ZQZTE>)?90 zF0PO3<a)VouAl4Zdb+Nzuj}l3yY8;PIWQ0A!hDz$^I~qyk2x|==E{7TGxKKd%%3?l zkLJ>Rnp5*?Zq2VbHqYkTe4BIgZtl&$`@sF+zHooIPuwr=8~2a<$o=HLa(}tc+;8qX n_n-Ta5Qh8G{YeP<_ub5)SN?s^zwi0?Jw5#1=im4L$NT;ddMe!=
diff --git a/board/google/chromebook_coral/dmic-4ch-48khz-16b.dat b/board/google/chromebook_coral/dmic-4ch-48khz-16b.dat new file mode 100644 index 0000000000000000000000000000000000000000..142ab353f3736f110f30e9befbd72f7e8ae4264b GIT binary patch literal 3048 zcmeH{?Q7O$6vw~6dv`V;cAq_zX!*jirU{F1M)RR%C94#}biJ`c>xHeMrWsrHW~B)h z)r<w&5Z~N$B0V4)3<>Sg%;;f7Sg5UX6m5l?v!&wJ-RC=dBlH)<eZ#fiuIoD2xz72X z&$$vw#nri7aW0qRGx957?b4{`>mel!P0(0>3P$<w<-Zc9&6lh$-}rat{l4Ui|J?K9 ze8ze%S<PkjY3ZqyG%*)CIUK5Cua5ake77;*{<^9IHq=9NRCHJmNS{aMZ&yb!v; z`g_FLimxY_Z#f@Y$A04&sT=#R2SPirtqf@ho3cMbuMUQ0Fn_dIYC0Qg?+<0KlwP@3 zT7m6{Ke2W$)HYc<Sc(oOLRGz?fr(Pb_0r&}(6lc@8}WDBOsNXBmVF%R$7YZu&fh4t zeHA)!Ak>482}`6!e}?vEL-%lh;X~wogY;}?=)Si@8x}~}Mv~^tU`yyh{B^fVOUkA1 z*OJp)p;6CBpKOrEbc9~64}Cx!R~<$RVy>tT-M*Fhx};5v)cVl8!q82XXgeuU%e~Td zr!pF@3QhV{di<_L$)V6YPiM69vCzBA5Or;$<_AJgo-5Lui$kNk6V>0GQVn_Tsx8vK z6-7FYpPJSJ?d?sgvm~vKr77J#AZ6xCvkE0b0Ucswe20z=j4U;5rbay%L%q~z7rHi} z|0;AJOKrBE2`%6|2YnW^Hy69-IoAds?^D+o@tb7~^M5~UL+s_SIZT}c`#MGwervho z7-=lTZu4lQB#0e+r!vnG&pgiD@>ggI_x5mKCoz<;HV(Ej*saS*-@rp7T-?FgMXcY7 z-^s*x=6CpE)SiY(?%TrNfg%_l51ZFW%SrlS&i+h%oALWbU+57SD*Z9^+%KVzxNj<~ ze0#OjULhTwCT*M|y$(-1VYLgM%8#M>7jX7jsP9N<5BJR^@9ETV_Z)2M&;y+hakd>+ z7vlf;{?P25p;<7oyDPN%2e>Yij?9<tZ-U(yq?0Yo;qO;+`W)8wEl2-~(9+V-Z?i*X zoZWOMI*(7Z|6-ywM^l=C_^*viYh_J(<m<WDy>C0)`<&0)kNw%N{reu@=X-s><8VBV z%keo*$LqKqzw>ZD&dd2ZPv`5roxgRk9@fSBSSRac-K?K=w4T=0`dVk}ZQZTE>)?90 zF0PO3<a)VouAl4Zdb+Nzuj}l3yY8;PIWQ0A!hDz$^I~qyk2x|==E{7TGxKKd%%3?l zkLJ>Rnp5*?Zq2VbHqYkTe4BIgZtl&$`@sF+zHooIPuwr=8~2a<$o=HLa(}tc+;8qX n_n-Ta5Jvja{YeP<_ub5)SN?s^zwi0?Jw5W?=im4L$NT;dsY=};
diff --git a/board/google/chromebook_coral/max98357-render-2ch-48khz-24b.dat b/board/google/chromebook_coral/max98357-render-2ch-48khz-24b.dat new file mode 100644 index 0000000000000000000000000000000000000000..b0b5b9ba648c4546f98e15e42356a5fc4af6bb27 GIT binary patch literal 116 zcmZQzU|?WnWOx?=qy_%}|BnyXGahJUU??~MR0;$VT+Bccgqa+G1PJi6vnv28CMf>T R&%gk}Aix2{5<r{+!~hE!AMpSH
If U-Boot is not running FSP-S it should not do the pre-init either. Add a condition to handle this.
arch/x86/cpu/apollolake/fsp_s.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/x86/cpu/apollolake/fsp_s.c b/arch/x86/cpu/apollolake/fsp_s.c index e54b0ac1047..715ceab6ac7 100644 --- a/arch/x86/cpu/apollolake/fsp_s.c +++ b/arch/x86/cpu/apollolake/fsp_s.c @@ -157,6 +157,8 @@ int arch_fsps_preinit(void) struct udevice *itss; int ret;
+ if (!ll_boot_init()) + return 0; ret = irq_first_device_type(X86_IRQT_ITSS, &itss); if (ret) return log_msg_ret("no itss", ret);
If locating the FSP header hangs for whatever reason it is useful to see where it got stuck. Add a debug print. Also show the address of the FSP-S entry point as a sanity check.
arch/x86/lib/fsp2/fsp_silicon_init.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/x86/lib/fsp2/fsp_silicon_init.c b/arch/x86/lib/fsp2/fsp_silicon_init.c index 0f221a864fb..ead3493de82 100644 --- a/arch/x86/lib/fsp2/fsp_silicon_init.c +++ b/arch/x86/lib/fsp2/fsp_silicon_init.c @@ -26,8 +26,10 @@ int fsp_silicon_init(bool s3wake, bool use_spi_flash) struct binman_entry entry; struct udevice *dev; ulong rom_offset = 0; + u32 init_addr; int ret;
+ log_debug("Locating FSP\n"); ret = fsp_locate_fsp(FSP_S, &entry, use_spi_flash, &dev, &hdr, &rom_offset); if (ret) @@ -44,7 +46,7 @@ int fsp_silicon_init(bool s3wake, bool use_spi_flash) ret = fsps_update_config(dev, rom_offset, &upd); if (ret) return log_msg_ret("Could not setup config", ret); - log_debug("Silicon init..."); + log_debug("Silicon init @ %x...", init_addr); bootstage_start(BOOTSTAGE_ID_ACCUM_FSP_S, "fsp-s"); func = (fsp_silicon_init_func)(hdr->img_base + hdr->fsp_silicon_init); ret = func(&upd);
At present this function only supports FSP-M but it is also used to read FSP-S, in which case FSP-M may be zero. Add support for showing whichever address is present in the FSP binary.
Also change the debug() statements to log_debug() while here.
arch/x86/lib/fsp2/fsp_support.c | 22 ++++++++++++++-------- 1 file changed, 14 insertions(+), 8 deletions(-)
diff --git a/arch/x86/lib/fsp2/fsp_support.c b/arch/x86/lib/fsp2/fsp_support.c index 3f2ca840dc9..f220ef498b0 100644 --- a/arch/x86/lib/fsp2/fsp_support.c +++ b/arch/x86/lib/fsp2/fsp_support.c @@ -35,7 +35,8 @@ int fsp_get_header(ulong offset, ulong size, bool use_spi_flash, * * You are in a maze of twisty little headers all alike. */ - debug("offset=%x buf=%x\n", (uint)offset, (uint)buf); + log_debug("offset=%x buf=%x, use_spi_flash=%d\n", (uint)offset, + (uint)buf, use_spi_flash); if (use_spi_flash) { ret = uclass_first_device_err(UCLASS_SPI_FLASH, &dev); if (ret) @@ -52,16 +53,16 @@ int fsp_get_header(ulong offset, ulong size, bool use_spi_flash, fv = ptr;
/* Check the FV signature, _FVH */ - debug("offset=%x sign=%x\n", (uint)offset, (uint)fv->sign); + log_debug("offset=%x sign=%x\n", (uint)offset, (uint)fv->sign); if (fv->sign != EFI_FVH_SIGNATURE) return log_msg_ret("Base FV signature", -EINVAL);
/* Go to the end of the FV header and align the address */ - debug("fv->ext_hdr_off = %x\n", fv->ext_hdr_off); + log_debug("fv->ext_hdr_off = %x\n", fv->ext_hdr_off); ptr += fv->ext_hdr_off; exhdr = ptr; ptr += ALIGN(exhdr->ext_hdr_size, 8); - debug("ptr=%x\n", ptr - (void *)buf); + log_debug("ptr=%x\n", ptr - (void *)buf);
/* Check the FFS GUID */ file_hdr = ptr; @@ -71,7 +72,7 @@ int fsp_get_header(ulong offset, ulong size, bool use_spi_flash, ptr = file_hdr + 1;
raw = ptr; - debug("raw->type = %x\n", raw->type); + log_debug("raw->type = %x\n", raw->type); if (raw->type != EFI_SECTION_RAW) return log_msg_ret("Section type not RAW", -ENOEXEC);
@@ -80,13 +81,18 @@ int fsp_get_header(ulong offset, ulong size, bool use_spi_flash, fsp = ptr;
/* Check the FSPH header */ - debug("fsp %x\n", (uint)fsp); + log_debug("fsp %x, fsp-buf=%x, si=%x\n", (uint)fsp, ptr - (void *)buf, + (void *)&fsp->fsp_silicon_init - (void *)buf); if (fsp->sign != EFI_FSPH_SIGNATURE) return log_msg_ret("Base FSPH signature", -EACCES);
base = (void *)fsp->img_base; - debug("Image base %x\n", (uint)base); - debug("Image addr %x\n", (uint)fsp->fsp_mem_init); + log_debug("image base %x\n", (uint)base); + if (fsp->fsp_mem_init) + log_debug("mem_init offset %x\n", (uint)fsp->fsp_mem_init); + else if (fsp->fsp_silicon_init) + log_debug("silicon_init offset %x\n", + (uint)fsp->fsp_silicon_init); if (use_spi_flash) { ret = spi_flash_read_dm(dev, offset, size, base); if (ret)
A few fields have an open-coded length. Use the defines for this purpose instead.
include/acpi/acpi_table.h | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 9fba6536f50..3a243bf19ce 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -13,6 +13,7 @@ #ifndef __ACPI_TABLE_H__ #define __ACPI_TABLE_H__
+#include <dm/acpi.h> #include <linux/bitops.h>
#define RSDP_SIG "RSD PTR " /* RSDP pointer signature */ @@ -48,7 +49,7 @@ struct acpi_rsdp {
/* Generic ACPI header, provided by (almost) all tables */ struct __packed acpi_table_header { - char signature[4]; /* ACPI signature (4 ASCII characters) */ + char signature[ACPI_NAME_LEN]; /* ACPI signature (4 ASCII chars) */ u32 length; /* Table length in bytes (incl. header) */ u8 revision; /* Table version (not ACPI version!) */ volatile u8 checksum; /* To make sum of entire table == 0 */ @@ -263,7 +264,7 @@ struct __packed acpi_fadt {
/* FACS (Firmware ACPI Control Structure) */ struct acpi_facs { - char signature[4]; /* "FACS" */ + char signature[ACPI_NAME_LEN]; /* "FACS" */ u32 length; /* Length in bytes (>= 64) */ u32 hardware_signature; /* Hardware signature */ u32 firmware_waking_vector; /* Firmware waking vector */
Some boards want to reserve extra regions of memory. Add a 'chosen' property to support this.
arch/x86/lib/fsp/fsp_dram.c | 17 +++++++++++++++++ doc/device-tree-bindings/chosen.txt | 18 ++++++++++++++++++ 2 files changed, 35 insertions(+)
diff --git a/arch/x86/lib/fsp/fsp_dram.c b/arch/x86/lib/fsp/fsp_dram.c index faa819fab4b..a76497d4e01 100644 --- a/arch/x86/lib/fsp/fsp_dram.c +++ b/arch/x86/lib/fsp/fsp_dram.c @@ -12,6 +12,7 @@ #include <asm/mrccache.h> #include <asm/mtrr.h> #include <asm/post.h> +#include <dm/ofnode.h>
@@ -92,6 +93,8 @@ unsigned int install_e820_map(unsigned int max_entries, unsigned int num_entries = 0; const struct hob_header *hdr; struct hob_res_desc *res_desc; + const fdt64_t *prop; + int size;
hdr = gd->arch.hob_list;
@@ -133,6 +136,20 @@ unsigned int install_e820_map(unsigned int max_entries, num_entries++; }
+ prop = ofnode_read_chosen_prop("e820-entries", &size); + if (prop) { + int count = size / (sizeof(u64) * 3); + int i; + + if (num_entries + count >= max_entries) + return -ENOSPC; + for (i = 0; i < count; i++, num_entries++, prop += 3) { + entries[num_entries].addr = fdt64_to_cpu(prop[0]); + entries[num_entries].size = fdt64_to_cpu(prop[1]); + entries[num_entries].type = fdt64_to_cpu(prop[2]); + } + } + return num_entries; }
diff --git a/doc/device-tree-bindings/chosen.txt b/doc/device-tree-bindings/chosen.txt index d4dfc05847b..e5ba6720ce1 100644 --- a/doc/device-tree-bindings/chosen.txt +++ b/doc/device-tree-bindings/chosen.txt @@ -143,3 +143,21 @@ This provides the ordering to use when writing device data to the ACPI SSDT node to add. The ACPI information is written in this order.
If the ordering does not include all nodes, an error is generated. + +e820-entries +------------ + +This provides a way to add entries to the e820 table which tells the OS about +the memory map. The property contains three sets of 64-bit values: + + address - Start address of region + size - Size of region + flags - Flags (E820_...) + +Example: + +chosen { + e820-entries = /bits/ 64 < + IOMAP_P2SB_BAR IOMAP P2SB_SIZE E820_RESERVED + MCH_BASE_ADDRESS MCH_SIZE E820_RESERVED>; +};
At present linux/bitops.h is included in ACPI code. This is not needed and can cause a problem in fls64.h since BITS_PER_LONG is not defined. Move the #include into the part not used by ACPI.
Changes in v2: - Add new patch to move include of bitops out of ACPI region
include/acpi/acpi_table.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 3a243bf19ce..abbca6530db 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -14,7 +14,6 @@ #define __ACPI_TABLE_H__
#include <dm/acpi.h> -#include <linux/bitops.h>
#define RSDP_SIG "RSD PTR " /* RSDP pointer signature */ #define OEM_ID "U-BOOT" /* U-Boot */ @@ -29,6 +28,8 @@
+#include <linux/bitops.h> + struct acpi_ctx;
Enable new features and provide require device-tree config so that U-Boot produces the correct ACPI tables on Coral.
Changes in v2: - Rebase to master
Changes in v1: - Add NHLT information - Fix i2c PCI addresses - Rename acpi-probed to linux,probed - Rename cpi,hid-desc-reg-offset to hid-desc-addr - UIse hid-over-i2 compatible string - Update ACPI ordering to include multiple CPUs - Use acpi,ddn instead of acpi,desc
arch/x86/dts/chromebook_coral.dts | 224 +++++++++++++++++++++++++++-- configs/chromebook_coral_defconfig | 11 +- 2 files changed, 220 insertions(+), 15 deletions(-)
diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index a17a9c28003..8c08259b001 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -15,14 +15,20 @@ #include "flashmap-16mb-rw.dtsi" #endif
+#include <dt-bindings/clock/intel-clock.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/x86-irq.h> +#include <asm/e820.h> #include <asm/intel_pinctrl_defs.h> #include <asm/arch-apollolake/cpu.h> +#include <asm/arch-apollolake/gpe.h> #include <asm/arch-apollolake/gpio.h> #include <asm/arch-apollolake/iomap.h> #include <asm/arch-apollolake/pm.h> #include <dt-bindings/clock/intel-clock.h> #include <asm/arch-apollolake/fsp/fsp_m_upd.h> #include <asm/arch-apollolake/fsp/fsp_s_upd.h> +#include <dt-bindings/sound/nhlt.h>
/ { model = "Google Coral"; @@ -40,6 +46,14 @@ i2c5 = &i2c_5; i2c6 = &i2c_6; i2c7 = &i2c_7; + mmc1 = &sdmmc; + }; + + board: board { + compatible = "google,coral"; + recovery-gpios = <&gpio_nw (-1) GPIO_ACTIVE_LOW>; + write-protect-gpios = <&gpio_nw GPIO_75 GPIO_ACTIVE_HIGH>; + phase-enforce-gpios = <&gpio_n GPIO_10 GPIO_ACTIVE_HIGH>; };
config { @@ -48,6 +62,15 @@
chosen { stdout-path = &serial; + e820-entries = /bits/ 64 < + IOMAP_P2SB_BAR IOMAP_P2SB_SIZE E820_RESERVED + MCH_BASE_ADDRESS MCH_SIZE E820_RESERVED>; + u-boot,acpi-ssdt-order = <&cpu_0 &cpu_1 &cpu_2 &cpu_3 + &i2c_0 &i2c_1 &i2c_2 &i2c_3 &i2c_4 &i2c_5 + &sdmmc &maxim_codec &wifi &da_codec &tpm + &elan_touchscreen &raydium_touchscreen + &elan_touchpad &synaptics_touchpad &wacom_digitizer>; + u-boot,acpi-dsdt-order = <&board &lpc>; };
clk: clock { @@ -60,7 +83,7 @@ #address-cells = <1>; #size-cells = <0>;
- cpu@0 { + cpu_0: cpu@0 { u-boot,dm-pre-reloc; device_type = "cpu"; compatible = "intel,apl-cpu"; @@ -68,21 +91,21 @@ intel,apic-id = <0>; };
- cpu@1 { + cpu_1: cpu@1 { device_type = "cpu"; compatible = "intel,apl-cpu"; reg = <1>; intel,apic-id = <2>; };
- cpu@2 { + cpu_2: cpu@2 { device_type = "cpu"; compatible = "intel,apl-cpu"; reg = <2>; intel,apic-id = <4>; };
- cpu@3 { + cpu_3: cpu@3 { device_type = "cpu"; compatible = "intel,apl-cpu"; reg = <3>; @@ -128,6 +151,10 @@ */ fsp_s: fsp-s { }; + + nhlt { + intel,dmic-channels = <4>; + }; };
punit@0,1 { @@ -136,21 +163,29 @@ compatible = "intel,apl-punit"; };
+ gma@2,0 { + reg = <0x00001000 0 0 0 0>; + compatible = "vesa-fb"; + }; + p2sb: p2sb@d,0 { u-boot,dm-pre-reloc; reg = <0x02006810 0 0 0 0>; compatible = "intel,p2sb"; early-regs = <IOMAP_P2SB_BAR 0x100000>; + pci,no-autoconfig;
n { compatible = "intel,apl-pinctrl"; u-boot,dm-pre-reloc; intel,p2sb-port-id = <PID_GPIO_N>; + acpi,path = "\_SB.GPO0"; gpio_n: gpio-n { compatible = "intel,gpio"; u-boot,dm-pre-reloc; gpio-controller; #gpio-cells = <2>; + linux-name = "INT3452:00"; }; };
@@ -159,11 +194,13 @@ compatible = "intel,apl-pinctrl"; intel,p2sb-port-id = <PID_GPIO_NW>; #gpio-cells = <2>; + acpi,path = "\_SB.GPO1"; gpio_nw: gpio-nw { compatible = "intel,gpio"; u-boot,dm-pre-reloc; gpio-controller; #gpio-cells = <2>; + linux-name = "INT3452:01"; }; };
@@ -172,11 +209,13 @@ compatible = "intel,apl-pinctrl"; intel,p2sb-port-id = <PID_GPIO_W>; #gpio-cells = <2>; + acpi,path = "\_SB.GPO2"; gpio_w: gpio-w { compatible = "intel,gpio"; u-boot,dm-pre-reloc; gpio-controller; #gpio-cells = <2>; + linux-name = "INT3452:02"; }; };
@@ -185,11 +224,13 @@ compatible = "intel,apl-pinctrl"; intel,p2sb-port-id = <PID_GPIO_SW>; #gpio-cells = <2>; + acpi,path = "\_SB.GPO3"; gpio_sw: gpio-sw { compatible = "intel,gpio"; u-boot,dm-pre-reloc; gpio-controller; #gpio-cells = <2>; + linux-name = "INT3452:03"; }; };
@@ -238,6 +279,24 @@ gpe0-en = <0x30>; };
+ audio@e,0 { + reg = <0x7000 0 0 0 0>; + compatible = "simple-bus"; + acpi,name = "HDAS"; + i2s { + compatible = "fred"; + }; + maxim_codec: maxim-codec { + compatible = "maxim,max98357a"; + acpi,ddn = "Maxim Integrated 98357A Amplifier"; + sdmode-gpios = <&gpio_n GPIO_76 GPIO_ACTIVE_HIGH>; + sdmode-delay = <5>; + acpi,name = "MAXM"; + acpi,hid = "MX98357A"; + acpi,audio-link = <AUDIO_LINK_SSP5>; + }; + }; + spi: fast-spi@d,2 { u-boot,dm-pre-reloc; reg = <0x02006a10 0 0 0 0>; @@ -267,19 +326,63 @@ }; };
+ /* WiFi */ + pcie-a0@14,0 { + reg = <0x0000a000 0 0 0 0>; + acpi,name = "RP01"; + wifi: wifi { + compatible = "intel,generic-wifi"; + acpi,ddn = "Intel WiFi"; + acpi,name = "WF00"; + acpi,wake = <GPE0_DW3_00>; + interrupts-extended = <&acpi_gpe 0x3c 0>; + }; + }; + i2c_0: i2c2@16,0 { compatible = "intel,apl-i2c"; reg = <0x0200b010 0 0 0 0>; clocks = <&clk CLK_I2C>; i2c-scl-rising-time-ns = <104>; i2c-scl-falling-time-ns = <52>; + clock-frequency = <400000>; + i2c,speeds = <100000 400000 1000000>; + #address-cells = <1>; + #size-cells = <0>; + da_codec: da-codec { + reg = <0x1a>; + compatible = "dlg,da7219"; + interrupts-extended = <&acpi_gpe GPIO_116_IRQ + (IRQ_TYPE_LEVEL_LOW | X86_IRQ_TYPE_SHARED)>; + acpi,name = "DLG7"; + acpi,ddn = "Dialog Semiconductor DA7219 Audio Codec"; + acpi,audio-link = <AUDIO_LINK_SSP1>; + dlg,micbias-lvl = <2600>; + dlg,mic-amp-in-sel = "diff"; + da7219_aad { + dlg,btn-cfg = <50>; + dlg,mic-det-thr = <500>; + dlg,jack-ins-deb = <20>; + dlg,jack-det-rate = "32ms_64ms"; + dlg,jack-rem-deb = <1>; + dlg,a-d-btn-thr = <0xa>; + dlg,d-b-btn-thr = <0x16>; + dlg,b-c-btn-thr = <0x21>; + dlg,c-mic-btn-thr = <0x3e>; + dlg,btn-avg = <4>; + dlg,adc-1bit-rpt = <1>; + }; + }; };
i2c_1: i2c2@16,1 { compatible = "intel,apl-i2c"; reg = <0x0200b110 0 0 0 0>; clocks = <&clk CLK_I2C>; - status = "disabled"; + clock-frequency = <400000>; + i2c,speeds = <100000 400000 1000000 3400000>; + i2c-scl-rising-time-ns = <52>; + i2c-scl-falling-time-ns = <52>; };
i2c_2: i2c2@16,2 { @@ -288,53 +391,130 @@ #address-cells = <1>; #size-cells = <0>; clock-frequency = <400000>; + i2c,speeds = <100000 400000 1000000>; clocks = <&clk CLK_I2C>; i2c-scl-rising-time-ns = <57>; i2c-scl-falling-time-ns = <28>; - tpm@50 { + tpm: tpm@50 { reg = <0x50>; compatible = "google,cr50"; u-boot,i2c-offset-len = <0>; ready-gpios = <&gpio_n 28 GPIO_ACTIVE_LOW>; - interrupts-extended = <&acpi_gpe 0x3c 0>; + interrupts-extended = <&acpi_gpe GPIO_28_IRQ + IRQ_TYPE_EDGE_FALLING>; + acpi,hid = "GOOG0005"; + acpi,ddn = "I2C TPM"; + acpi,name = "TPMI"; }; };
i2c_3: i2c2@16,3 { compatible = "intel,apl-i2c"; - reg = <0x0200b110 0 0 0 0>; + reg = <0x0200b310 0 0 0 0>; + #address-cells = <1>; + #size-cells = <0>; clocks = <&clk CLK_I2C>; i2c-scl-rising-time-ns = <76>; i2c-scl-falling-time-ns = <164>; + clock-frequency = <400000>; + i2c,speeds = <100000 400000>; + elan_touchscreen: elan-touchscreen@10 { + compatible = "i2c-chip"; + reg = <0x10>; + acpi,hid = "ELAN0001"; + acpi,ddn = "ELAN Touchscreen"; + interrupts-extended = <&acpi_gpe GPIO_21_IRQ + IRQ_TYPE_EDGE_FALLING>; + linux,probed; + reset-gpios = <&gpio_n GPIO_36 GPIO_ACTIVE_HIGH>; + reset-delay-ms = <20>; + enable-gpios = <&gpio_n GPIO_152 GPIO_ACTIVE_HIGH>; + enable-delay-ms = <1>; + acpi,has-power-resource; + }; + + raydium_touchscreen: raydium-touchscreen@39 { + compatible = "i2c-chip"; + reg = <0x39>; + acpi,hid = "RAYD0001"; + acpi,ddn = "Raydium Touchscreen"; + interrupts-extended = <&acpi_gpe GPIO_21_IRQ + IRQ_TYPE_EDGE_FALLING>; + linux,probed; + reset-gpios = <&gpio_n GPIO_36 GPIO_ACTIVE_HIGH>; + reset-delay-ms = <1>; + enable-gpios = <&gpio_n GPIO_152 GPIO_ACTIVE_HIGH>; + enable-delay-ms = <50>; + acpi,has-power-resource; + }; };
i2c_4: i2c2@17,0 { compatible = "intel,apl-i2c"; - reg = <0x0200b110 0 0 0 0>; + reg = <0x0200b810 0 0 0 0>; + #address-cells = <1>; + #size-cells = <0>; clocks = <&clk CLK_I2C>; i2c-sda-hold-time-ns = <350>; i2c-scl-rising-time-ns = <114>; i2c-scl-falling-time-ns = <164>; + clock-frequency = <400000>; + i2c,speeds = <100000 400000>; + elan_touchpad: elan-touchpad@15 { + compatible = "i2c-chip"; + reg = <0x15>; + u-boot,i2c-offset-len = <0>; + acpi,hid = "ELAN0000"; + acpi,ddn = "ELAN Touchpad"; + interrupts-extended = <&acpi_gpe GPIO_18_IRQ + IRQ_TYPE_EDGE_FALLING>; + acpi,wake = <GPE0_DW1_15>; + linux,probed; + }; + synaptics_touchpad: synaptics-touchpad@2c { + compatible = "hid-over-i2c"; + reg = <0x2c>; + acpi,hid = "PNP0C50"; + acpi,ddn = "Synaptics Touchpad"; + interrupts-extended = <&acpi_gpe GPIO_18_IRQ + IRQ_TYPE_EDGE_FALLING>; + acpi,wake = <GPE0_DW1_15>; + linux,probed; + hid-descr-addr = <0x20>; + }; };
i2c_5: i2c2@17,1 { compatible = "intel,apl-i2c"; - reg = <0x0200b110 0 0 0 0>; + reg = <0x0200b910 0 0 0 0>; + #address-cells = <1>; + #size-cells = <0>; clocks = <&clk CLK_I2C>; i2c-scl-rising-time-ns = <76>; i2c-scl-falling-time-ns = <164>; + clock-frequency = <400000>; + i2c,speeds = <100000 400000 1000000>; + wacom_digitizer: wacom-digitizer@9 { + compatible = "hid-over-i2c"; + reg = <0x9>; + acpi,hid = "WCOM50C1"; + acpi,ddn = "WCOM Digitizer"; + interrupts-extended = <&acpi_gpe GPIO_13_IRQ + (IRQ_TYPE_LEVEL_LOW | X86_IRQ_TYPE_SHARED)>; + hid-descr-addr = <0x1>; + }; };
i2c_6: i2c2@17,2 { compatible = "intel,apl-i2c"; - reg = <0x0200b110 0 0 0 0>; + reg = <0x0200ba10 0 0 0 0>; clocks = <&clk CLK_I2C>; status = "disabled"; };
i2c_7: i2c2@17,3 { compatible = "intel,apl-i2c"; - reg = <0x0200b110 0 0 0 0>; + reg = <0x0200bb10 0 0 0 0>; clocks = <&clk CLK_I2C>; status = "disabled"; }; @@ -347,6 +527,15 @@ reg-shift = <2>; clock-frequency = <1843200>; current-speed = <115200>; + acpi,name = "URT3"; + pci,no-autoconfig; + }; + + sdmmc: sdmmc@1b,0 { + reg = <0x0000d800 0 0 0 0>; + compatible = "intel,apl-sd"; + cd-gpios = <&gpio_n GPIO_177 GPIO_ACTIVE_LOW>; + acpi,name = "SDCD"; };
pch: pch@1f,0 { @@ -356,7 +545,7 @@ #address-cells = <1>; #size-cells = <1>;
- lpc { + lpc: lpc { compatible = "intel,apl-lpc"; #address-cells = <1>; #size-cells = <0>; @@ -600,6 +789,11 @@ fsps,emmc-rx-cmd-data-cntl1 = <0x00181717>; fsps,emmc-rx-cmd-data-cntl2 = <0x10008>;
+ /* Enable Audio Clock and Power gating */ + fsps,hd-audio-clk-gate = <1>; + fsps,hd-audio-pwr-gate = <1>; + fsps,bios-cfg-lock-down = <1>; + /* Enable WiFi */ fsps,pcie-root-port-en = [01 00 00 00 00 00]; fsps,pcie-rp-hot-plug = [00 00 00 00 00 00]; @@ -611,6 +805,10 @@ fsps,port-usb20-per-port-pe-txi-set = [07 07 06 06 07 07 07 01]; fsps,port-usb20-per-port-txi-set = [00 02 00 00 00 00 00 03];
+ fsps,lpss-s0ix-enable = <1>; + fsps,usb-otg = <0>; + fsps,monitor-mwait-enable = <0>; + /* * TODO(sjg@chromium.org): Move this to the I2C nodes * Intel Common SoC Config diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index ef4dabbe26e..af0397ff1f4 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x3d00 CONFIG_NR_DRAM_BANKS=8 CONFIG_SPL_DM_SPI=y CONFIG_SPL_TEXT_BASE=0xfef10000 +CONFIG_MAX_CPUS=8 CONFIG_SPL_SYS_MALLOC_F_LEN=0xf000 CONFIG_BOOTSTAGE_STASH_ADDR=0xfef00000 CONFIG_DEBUG_UART_BOARD_INIT=y @@ -14,9 +15,10 @@ CONFIG_VENDOR_GOOGLE=y CONFIG_TARGET_CHROMEBOOK_CORAL=y CONFIG_DEBUG_UART=y CONFIG_FSP_VERSION2=y +CONFIG_GENERATE_ACPI_TABLE=y CONFIG_HAVE_ACPI_RESUME=y CONFIG_INTEL_CAR_CQOS=y -CONFIG_X86_OFFSET_U_BOOT=0xffe00000 +CONFIG_X86_OFFSET_U_BOOT=0xffd00000 CONFIG_X86_OFFSET_SPL=0xffe80000 CONFIG_INTEL_GENERIC_WIFI=y CONFIG_BOOTSTAGE=y @@ -26,13 +28,14 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_SPL_BOOTSTAGE_RECORD_COUNT=10 CONFIG_BOOTSTAGE_STASH=y CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/sdb3 init=/sbin/init rootwait ro earlyprintk console=tty0 console=ttyS0,115200" +CONFIG_BOOTARGS="console=ttyS2,115200n8 cros_legacy loglevel=9 init=/sbin/init oops=panic panic=-1 root=PARTUUID=35c775e7-3735-d745-93e5-d9e0238f7ed0/PARTNROFF=1 rootwait rw noinitrd vt.global_cursor_default=0 add_efi_memmap boot=local noresume noswap i915.modeset=1 nmi_watchdog=panic,lapic disablevmx=off" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_LOG=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_LAST_STAGE_INIT=y CONFIG_BLOBLIST=y # CONFIG_TPL_BLOBLIST is not set +CONFIG_BLOBLIST_SIZE=0x30000 CONFIG_BLOBLIST_ADDR=0x100000 CONFIG_HANDOFF=y CONFIG_TPL_SYS_MALLOC_SIMPLE=y @@ -74,8 +77,10 @@ CONFIG_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_INTEL_ACPIGEN=y CONFIG_CPU=y +CONFIG_BOARD=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y +CONFIG_MISC=y CONFIG_TPL_MISC=y CONFIG_CROS_EC=y CONFIG_CROS_EC_LPC=y @@ -87,7 +92,9 @@ CONFIG_PINCTRL=y CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_SOUND=y +CONFIG_SOUND_DA7219=y CONFIG_SOUND_I8254=y +CONFIG_SOUND_MAX98357A=y CONFIG_SOUND_RT5677=y CONFIG_SPI=y CONFIG_ICH_SPI=y
Andy Shevchenko
Heiko Schocher
Wolfgang Wallner
