[PATCH u-boot-marvell v2 0/6] A3720 PCIe enhancements
Hello Stefan,
Pali has worked on some more enhancements for Armada 3720 PCIe driver (Aardvark).
The main change is adding support for accessing configuration space of the PCI Bridge on the PCIe Root Port. Linux does something similar with pci-bridge-emul.
Marek
Changes since v1: - fix mistake in the documentation change in the last patch
Marek Behún (2): arm: a37xx: pci: Cosmetic change arm: a37xx: pci: Update private structure documentation
Pali Rohár (4): arm: a37xx: pci: Fix pcie_advk_link_up() arm: a37xx: pci: Add support for accessing PCI Bridge on root bus arm: a37xx: pci: Do not automatically enable bus mastering on PCI Bridge arm: a37xx: pci: Handle propagation of CRSSVE bit from PCIe Root Port
drivers/pci/pci-aardvark.c | 199 +++++++++++++++++++++++++++++-------- include/pci.h | 4 + 2 files changed, 163 insertions(+), 40 deletions(-)
Aardvark reports Disabled and Hot Reset LTSSM states as values >= 0x20. Link is not up in these states, so fix pcie_advk_link_up() function.
Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Marek Behún marek.behun@nic.cz --- drivers/pci/pci-aardvark.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/pci/pci-aardvark.c b/drivers/pci/pci-aardvark.c index cf6e30f936..741e0431e1 100644 --- a/drivers/pci/pci-aardvark.c +++ b/drivers/pci/pci-aardvark.c @@ -145,6 +145,7 @@ #define LTSSM_SHIFT 24 #define LTSSM_MASK 0x3f #define LTSSM_L0 0x10 +#define LTSSM_DISABLED 0x20 #define VENDOR_ID_REG (LMI_BASE_ADDR + 0x44)
/* PCIe core controller registers */ @@ -569,7 +570,7 @@ static int pcie_advk_link_up(struct pcie_advk *pcie)
val = advk_readl(pcie, CFG_REG); ltssm_state = (val >> LTSSM_SHIFT) & LTSSM_MASK; - return ltssm_state >= LTSSM_L0; + return ltssm_state >= LTSSM_L0 && ltssm_state < LTSSM_DISABLED; }
Thanks, Stefan
Viele Grüße, Stefan
Aardvark does not have a real PCIe Root Port device on the root bus. Instead it has PCIe registers of PCIe Root Port device mapped in internal Aardvark memory space starting at offset 0xc0.
The PCIe Root Port itself is normally available as a PCI Bridge device on the root bus with bus number zero. Aardvark instead has the configuration registers of this PCI Bridge at offset 0x00 of Aardvark's memory space, but the class code of this device is Mass Storage Controller (0x010400), instead of PCI Bridge (0x600400), which causes U-Boot to fail to recognize it as a P2P Bridge
Add a hook into the pcie_advk_read_config() / pcie_advk_write_config() functions to redirect access for root bus from PIO transfer to this internal Aardvark memory space. This will allow U-Boot to access configuration space of this PCI Bridge which represents PCIe Root Port.
Redirect access to PCI Bridge registers in range 0x10 - 0x34 to driver's internal buffer (cfgcache[]). This is because at those addresses Aardvark has different registers, incompatible with config space of a PCI Bridge.
Redirect access to PCI Bridge register PCI_ROM_ADDRESS1 (0x38) to Aardvark internal address for that register (0x30).
When reading PCI Bridge register PCI_HEADER_TYPE, set it explicitly to value Type 1 (PCI_HEADER_TYPE_BRIDGE) as PCI Bridge must be of Type 1.
When writing to PCI_PRIMARY_BUS or PCI_SECONDARY_BUS registers on this PCI Bridge, correctly update driver's first_busno and sec_busno variables, so that pcie_advk_addr_valid() function can check if address of any device behind the root bus is valid and that PIO transfers are started with correct config type (1 vs 0), which is required for accessing devices behind some PCI bridge after the root bus.
U-Boot's PCI_PNP code sets primary and secondary bus numbers as relative to the configured bus number of the root bus. This is done so that U-Boot can support multiple PCIe host bridges or multiple root port buses, when internal bus numbers are different.
Now that root bus is available, update code in pcie_advk_read_config() and pcie_advk_write_config() functions to correctly calculate real Aardvark bus number of the target device from U-Boot's bus number as: busno = PCI_BUS(bdf) - dev_seq(bus)
Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Marek Behún marek.behun@nic.cz --- drivers/pci/pci-aardvark.c | 143 ++++++++++++++++++++++++++++++++----- 1 file changed, 124 insertions(+), 19 deletions(-)
diff --git a/drivers/pci/pci-aardvark.c b/drivers/pci/pci-aardvark.c index 741e0431e1..692210ded9 100644 --- a/drivers/pci/pci-aardvark.c +++ b/drivers/pci/pci-aardvark.c @@ -39,6 +39,8 @@ #define PCIE_CORE_CMD_IO_ACCESS_EN BIT(0) #define PCIE_CORE_CMD_MEM_ACCESS_EN BIT(1) #define PCIE_CORE_CMD_MEM_IO_REQ_EN BIT(2) +#define PCIE_CORE_DEV_REV_REG 0x8 +#define PCIE_CORE_EXP_ROM_BAR_REG 0x30 #define PCIE_CORE_DEV_CTRL_STATS_REG 0xc8 #define PCIE_CORE_DEV_CTRL_STATS_RELAX_ORDER_DISABLE (0 << 4) #define PCIE_CORE_DEV_CTRL_STATS_SNOOP_DISABLE (0 << 11) @@ -163,7 +165,7 @@ #define PCIE_CONFIG_WR_TYPE1 0xb
/* PCI_BDF shifts 8bit, so we need extra 4bit shift */ -#define PCIE_BDF(dev) (dev << 4) +#define PCIE_BDF(b, d, f) (PCI_BDF(b, d, f) << 4) #define PCIE_CONF_BUS(bus) (((bus) & 0xff) << 20) #define PCIE_CONF_DEV(dev) (((dev) & 0x1f) << 15) #define PCIE_CONF_FUNC(fun) (((fun) & 0x7) << 12) @@ -188,13 +190,17 @@ * first_busno stores the bus number of the PCIe root-port * number which may vary depending on the PCIe setup * (PEX switches etc). + * @sec_busno: sec_busno stores the bus number for the device behind + * the PCIe root-port * @device: The pointer to PCI uclass device. */ struct pcie_advk { void *base; int first_busno; + int sec_busno; struct udevice *dev; struct gpio_desc reset_gpio; + u32 cfgcache[0x34 - 0x10]; };
static inline void advk_writel(struct pcie_advk *pcie, uint val, uint reg) @@ -210,22 +216,30 @@ static inline uint advk_readl(struct pcie_advk *pcie, uint reg) /** * pcie_advk_addr_valid() - Check for valid bus address * + * @pcie: Pointer to the PCI bus + * @busno: Bus number of PCI device + * @dev: Device number of PCI device + * @func: Function number of PCI device * @bdf: The PCI device to access - * @first_busno: Bus number of the PCIe controller root complex * - * Return: 1 on valid, 0 on invalid + * Return: true on valid, false on invalid */ -static int pcie_advk_addr_valid(pci_dev_t bdf, int first_busno) +static bool pcie_advk_addr_valid(struct pcie_advk *pcie, + int busno, u8 dev, u8 func) { + /* On the primary (local) bus there is only one PCI Bridge */ + if (busno == pcie->first_busno && (dev != 0 || func != 0)) + return false; + /* - * In PCIE-E only a single device (0) can exist - * on the local bus. Beyound the local bus, there might be - * a Switch and everything is possible. + * In PCI-E only a single device (0) can exist on the secondary bus. + * Beyond the secondary bus, there might be a Switch and anything is + * possible. */ - if ((PCI_BUS(bdf) == first_busno) && (PCI_DEV(bdf) > 0)) - return 0; + if (busno == pcie->sec_busno && dev != 0) + return false;
- return 1; + return true; }
/** @@ -355,20 +369,55 @@ static int pcie_advk_read_config(const struct udevice *bus, pci_dev_t bdf, enum pci_size_t size) { struct pcie_advk *pcie = dev_get_priv(bus); + int busno = PCI_BUS(bdf) - dev_seq(bus); int retry_count; bool allow_crs; + ulong data; uint reg; int ret;
dev_dbg(pcie->dev, "PCIE CFG read: (b,d,f)=(%2d,%2d,%2d) ", PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf));
- if (!pcie_advk_addr_valid(bdf, pcie->first_busno)) { + if (!pcie_advk_addr_valid(pcie, busno, PCI_DEV(bdf), PCI_FUNC(bdf))) { dev_dbg(pcie->dev, "- out of range\n"); *valuep = pci_get_ff(size); return 0; }
+ /* + * The configuration space of the PCI Bridge on primary (local) bus is + * not accessible via PIO transfers like all other PCIe devices. PCI + * Bridge config registers are available directly in Aardvark memory + * space starting at offset zero. Moreover PCI Bridge registers in the + * range 0x10 - 0x34 are not available and register 0x38 (Expansion ROM + * Base Address) is at offset 0x30. + * We therefore read configuration space content of the primary PCI + * Bridge from our virtual cache. + */ + if (busno == pcie->first_busno) { + if (offset >= 0x10 && offset < 0x34) + data = pcie->cfgcache[(offset - 0x10) / 4]; + else if ((offset & ~3) == PCI_ROM_ADDRESS1) + data = advk_readl(pcie, PCIE_CORE_EXP_ROM_BAR_REG); + else + data = advk_readl(pcie, offset & ~3); + + if ((offset & ~3) == (PCI_HEADER_TYPE & ~3)) { + /* + * Change Header Type of PCI Bridge device to Type 1 + * (0x01, used by PCI Bridges) because hardwired value + * is Type 0 (0x00, used by Endpoint devices). + */ + data &= ~0x00ff0000; + data |= PCI_HEADER_TYPE_BRIDGE << 16; + } + + *valuep = pci_conv_32_to_size(data, offset, size); + + return 0; + } + /* * Returning fabricated CRS value (0xFFFF0001) by PCIe Root Complex to * OS is allowed only for 4-byte PCI_VENDOR_ID config read request and @@ -396,14 +445,14 @@ static int pcie_advk_read_config(const struct udevice *bus, pci_dev_t bdf, /* Program the control register */ reg = advk_readl(pcie, PIO_CTRL); reg &= ~PIO_CTRL_TYPE_MASK; - if (PCI_BUS(bdf) == pcie->first_busno) + if (busno == pcie->sec_busno) reg |= PCIE_CONFIG_RD_TYPE0; else reg |= PCIE_CONFIG_RD_TYPE1; advk_writel(pcie, reg, PIO_CTRL);
/* Program the address registers */ - reg = PCIE_BDF(bdf) | PCIE_CONF_REG(offset); + reg = PCIE_BDF(busno, PCI_DEV(bdf), PCI_FUNC(bdf)) | PCIE_CONF_REG(offset); advk_writel(pcie, reg, PIO_ADDR_LS); advk_writel(pcie, 0, PIO_ADDR_MS);
@@ -491,7 +540,9 @@ static int pcie_advk_write_config(struct udevice *bus, pci_dev_t bdf, enum pci_size_t size) { struct pcie_advk *pcie = dev_get_priv(bus); + int busno = PCI_BUS(bdf) - dev_seq(bus); int retry_count; + ulong data; uint reg; int ret;
@@ -500,11 +551,41 @@ static int pcie_advk_write_config(struct udevice *bus, pci_dev_t bdf, dev_dbg(pcie->dev, "(addr,size,val)=(0x%04x, %d, 0x%08lx)\n", offset, size, value);
- if (!pcie_advk_addr_valid(bdf, pcie->first_busno)) { + if (!pcie_advk_addr_valid(pcie, busno, PCI_DEV(bdf), PCI_FUNC(bdf))) { dev_dbg(pcie->dev, "- out of range\n"); return 0; }
+ /* + * As explained in pcie_advk_read_config(), for the configuration + * space of the primary PCI Bridge, we write the content into virtual + * cache. + */ + if (busno == pcie->first_busno) { + if (offset >= 0x10 && offset < 0x34) { + data = pcie->cfgcache[(offset - 0x10) / 4]; + data = pci_conv_size_to_32(data, value, offset, size); + pcie->cfgcache[(offset - 0x10) / 4] = data; + } else if ((offset & ~3) == PCI_ROM_ADDRESS1) { + data = advk_readl(pcie, PCIE_CORE_EXP_ROM_BAR_REG); + data = pci_conv_size_to_32(data, value, offset, size); + advk_writel(pcie, data, PCIE_CORE_EXP_ROM_BAR_REG); + } else { + data = advk_readl(pcie, offset & ~3); + data = pci_conv_size_to_32(data, value, offset, size); + advk_writel(pcie, data, offset & ~3); + } + + if (offset == PCI_PRIMARY_BUS) + pcie->first_busno = data & 0xff; + + if (offset == PCI_SECONDARY_BUS || + (offset == PCI_PRIMARY_BUS && size != PCI_SIZE_8)) + pcie->sec_busno = (data >> 8) & 0xff; + + return 0; + } + if (advk_readl(pcie, PIO_START)) { dev_err(pcie->dev, "Previous PIO read/write transfer is still running\n"); @@ -514,14 +595,14 @@ static int pcie_advk_write_config(struct udevice *bus, pci_dev_t bdf, /* Program the control register */ reg = advk_readl(pcie, PIO_CTRL); reg &= ~PIO_CTRL_TYPE_MASK; - if (PCI_BUS(bdf) == pcie->first_busno) + if (busno == pcie->sec_busno) reg |= PCIE_CONFIG_WR_TYPE0; else reg |= PCIE_CONFIG_WR_TYPE1; advk_writel(pcie, reg, PIO_CTRL);
/* Program the address registers */ - reg = PCIE_BDF(bdf) | PCIE_CONF_REG(offset); + reg = PCIE_BDF(busno, PCI_DEV(bdf), PCI_FUNC(bdf)) | PCIE_CONF_REG(offset); advk_writel(pcie, reg, PIO_ADDR_LS); advk_writel(pcie, 0, PIO_ADDR_MS); dev_dbg(pcie->dev, "\tPIO req. - addr = 0x%08x\n", reg); @@ -590,14 +671,14 @@ static int pcie_advk_wait_for_link(struct pcie_advk *pcie) /* check if the link is up or not */ for (retries = 0; retries < LINK_MAX_RETRIES; retries++) { if (pcie_advk_link_up(pcie)) { - printf("PCIE-%d: Link up\n", pcie->first_busno); + printf("PCIe: Link up\n"); return 0; }
udelay(LINK_WAIT_TIMEOUT); }
- printf("PCIE-%d: Link down\n", pcie->first_busno); + printf("PCIe: Link down\n");
return -ETIMEDOUT; } @@ -716,6 +797,25 @@ static int pcie_advk_setup_hw(struct pcie_advk *pcie) */ advk_writel(pcie, 0x11ab11ab, VENDOR_ID_REG);
+ /* + * Change Class Code of PCI Bridge device to PCI Bridge (0x600400), + * because default value is Mass Storage Controller (0x010400), causing + * U-Boot to fail to recognize it as P2P Bridge. + * + * Note that this Aardvark PCI Bridge does not have a compliant Type 1 + * Configuration Space and it even cannot be accessed via Aardvark's + * PCI config space access method. Something like config space is + * available in internal Aardvark registers starting at offset 0x0 + * and is reported as Type 0. In range 0x10 - 0x34 it has totally + * different registers. So our driver reports Header Type as Type 1 and + * for the above mentioned range redirects access to the virtual + * cfgcache[] buffer, which avoids changing internal Aardvark registers. + */ + reg = advk_readl(pcie, PCIE_CORE_DEV_REV_REG); + reg &= ~0xffffff00; + reg |= (PCI_CLASS_BRIDGE_PCI << 8) << 8; + advk_writel(pcie, reg, PCIE_CORE_DEV_REV_REG); + /* Set Advanced Error Capabilities and Control PF0 register */ reg = PCIE_CORE_ERR_CAPCTL_ECRC_CHK_TX | PCIE_CORE_ERR_CAPCTL_ECRC_CHK_TX_EN | @@ -857,9 +957,14 @@ static int pcie_advk_probe(struct udevice *dev) dev_warn(dev, "PCIE Reset on GPIO support is missing\n"); }
- pcie->first_busno = dev_seq(dev); pcie->dev = pci_get_controller(dev);
+ /* PCI Bridge support 32-bit I/O and 64-bit prefetch mem addressing */ + pcie->cfgcache[(PCI_IO_BASE - 0x10) / 4] = + PCI_IO_RANGE_TYPE_32 | (PCI_IO_RANGE_TYPE_32 << 8); + pcie->cfgcache[(PCI_PREF_MEMORY_BASE - 0x10) / 4] = + PCI_PREF_RANGE_TYPE_64 | (PCI_PREF_RANGE_TYPE_64 << 16); + return pcie_advk_setup_hw(pcie); }
else
^^ There is a small mistake. Header Type is 7-bit value. Upper 8th bit indicates if device is multifunction. So correct mask should be:
data &= ~0x007f0000;
- Returning fabricated CRS value (0xFFFF0001) by PCIe Root Complex to
- OS is allowed only for 4-byte PCI_VENDOR_ID config read request and
else
I'll try to get to these (and other) patches today and will fix this while applying.
Thanks, Stefan
Viele Grüße, Stefan
Thanks, Stefan
(PEX switches etc).
- @sec_busno: sec_busno stores the bus number for the device behind
the PCIe root-port
- @device: The pointer to PCI uclass device.
- pcie_advk_addr_valid() - Check for valid bus address
- @pcie: Pointer to the PCI bus
- @busno: Bus number of PCI device
- @dev: Device number of PCI device
- @func: Function number of PCI device
- @bdf: The PCI device to access
- @first_busno: Bus number of the PCIe controller root complex
- Return: 1 on valid, 0 on invalid
- Return: true on valid, false on invalid
{int busno, u8 dev, u8 func)
- /* On the primary (local) bus there is only one PCI Bridge */
- if (busno == pcie->first_busno && (dev != 0 || func != 0))
return false;
*/* possible.
- if (busno == pcie->sec_busno && dev != 0)
return false;
- return 1;
return true; }
else
- reg = PCIE_BDF(busno, PCI_DEV(bdf), PCI_FUNC(bdf)) | PCIE_CONF_REG(offset); advk_writel(pcie, reg, PIO_ADDR_LS); advk_writel(pcie, 0, PIO_ADDR_MS);
- int busno = PCI_BUS(bdf) - dev_seq(bus); int retry_count;
- ulong data; uint reg; int ret;
* cache.
} else {
- reg = PCIE_BDF(busno, PCI_DEV(bdf), PCI_FUNC(bdf)) | PCIE_CONF_REG(offset); advk_writel(pcie, reg, PIO_ADDR_LS); advk_writel(pcie, 0, PIO_ADDR_MS); dev_dbg(pcie->dev, "\tPIO req. - addr = 0x%08x\n", reg);
- reg = advk_readl(pcie, PCIE_CORE_DEV_REV_REG);
- reg &= ~0xffffff00;
- reg |= (PCI_CLASS_BRIDGE_PCI << 8) << 8;
- advk_writel(pcie, reg, PCIE_CORE_DEV_REV_REG);
- /* Set Advanced Error Capabilities and Control PF0 register */ reg = PCIE_CORE_ERR_CAPCTL_ECRC_CHK_TX | PCIE_CORE_ERR_CAPCTL_ECRC_CHK_TX_EN |
- /* PCI Bridge support 32-bit I/O and 64-bit prefetch mem addressing */
- pcie->cfgcache[(PCI_IO_BASE - 0x10) / 4] =
- pcie->cfgcache[(PCI_PREF_MEMORY_BASE - 0x10) / 4] =
- return pcie_advk_setup_hw(pcie); }
Viele Grüße, Stefan
Now that PCI Bridge is working for the PCIe Root Port, U-Boot's PCI_PNP code automatically enables memory access and bus mastering when needed.
We do not need to enable it when setting the HW up.
Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Marek Behún marek.behun@nic.cz --- drivers/pci/pci-aardvark.c | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/drivers/pci/pci-aardvark.c b/drivers/pci/pci-aardvark.c index 692210ded9..8c025dc45d 100644 --- a/drivers/pci/pci-aardvark.c +++ b/drivers/pci/pci-aardvark.c @@ -910,12 +910,6 @@ static int pcie_advk_setup_hw(struct pcie_advk *pcie) if (pcie_advk_wait_for_link(pcie)) return -ENXIO;
- reg = advk_readl(pcie, PCIE_CORE_CMD_STATUS_REG); - reg |= PCIE_CORE_CMD_MEM_ACCESS_EN | - PCIE_CORE_CMD_IO_ACCESS_EN | - PCIE_CORE_CMD_MEM_IO_REQ_EN; - advk_writel(pcie, reg, PCIE_CORE_CMD_STATUS_REG); - return 0; }
Thanks, Stefan
- return 0; }
Viele Grüße, Stefan
Now that PCI Bridge (PCIe Root Port) for Aardvark is emulated in U-Boot, add support for handling and propagation of CRSSVE bit.
When CRSSVE bit is unset (default), driver has to reissue config read/write request on CRS response.
CRSSVE bit is supported only when CRSVIS bit is provided in read-only Root Capabilities register. So manually inject this CRSVIS bit into read response for that register.
Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Marek Behún marek.behun@nic.cz --- drivers/pci/pci-aardvark.c | 26 ++++++++++++++++++++++---- include/pci.h | 4 ++++ 2 files changed, 26 insertions(+), 4 deletions(-)
diff --git a/drivers/pci/pci-aardvark.c b/drivers/pci/pci-aardvark.c index 8c025dc45d..53e9e23d4a 100644 --- a/drivers/pci/pci-aardvark.c +++ b/drivers/pci/pci-aardvark.c @@ -41,6 +41,7 @@ #define PCIE_CORE_CMD_MEM_IO_REQ_EN BIT(2) #define PCIE_CORE_DEV_REV_REG 0x8 #define PCIE_CORE_EXP_ROM_BAR_REG 0x30 +#define PCIE_CORE_PCIEXP_CAP_OFF 0xc0 #define PCIE_CORE_DEV_CTRL_STATS_REG 0xc8 #define PCIE_CORE_DEV_CTRL_STATS_RELAX_ORDER_DISABLE (0 << 4) #define PCIE_CORE_DEV_CTRL_STATS_SNOOP_DISABLE (0 << 11) @@ -201,6 +202,7 @@ struct pcie_advk { struct udevice *dev; struct gpio_desc reset_gpio; u32 cfgcache[0x34 - 0x10]; + bool cfgcrssve; };
static inline void advk_writel(struct pcie_advk *pcie, uint val, uint reg) @@ -413,6 +415,18 @@ static int pcie_advk_read_config(const struct udevice *bus, pci_dev_t bdf, data |= PCI_HEADER_TYPE_BRIDGE << 16; }
+ if ((offset & ~3) == PCIE_CORE_PCIEXP_CAP_OFF + PCI_EXP_RTCTL) { + /* CRSSVE bit is stored only in cache */ + if (pcie->cfgcrssve) + data |= PCI_EXP_RTCTL_CRSSVE; + } + + if ((offset & ~3) == PCIE_CORE_PCIEXP_CAP_OFF + + (PCI_EXP_RTCAP & ~3)) { + /* CRS is emulated below, so set CRSVIS capability */ + data |= PCI_EXP_RTCAP_CRSVIS << 16; + } + *valuep = pci_conv_32_to_size(data, offset, size);
return 0; @@ -423,13 +437,14 @@ static int pcie_advk_read_config(const struct udevice *bus, pci_dev_t bdf, * OS is allowed only for 4-byte PCI_VENDOR_ID config read request and * only when CRSSVE bit in Root Port PCIe device is enabled. In all * other error PCIe Root Complex must return all-ones. - * Aardvark HW does not have Root Port PCIe device and U-Boot does not - * implement emulation of this device. + * * U-Boot currently does not support handling of CRS return value for * PCI_VENDOR_ID config read request and also does not set CRSSVE bit. - * Therefore disable returning CRS response for now. + * So it means that pcie->cfgcrssve is false. But the code is prepared + * for returning CRS, so that if U-Boot does support CRS in the future, + * it will work for Aardvark. */ - allow_crs = false; + allow_crs = pcie->cfgcrssve;
if (advk_readl(pcie, PIO_START)) { dev_err(pcie->dev, @@ -583,6 +598,9 @@ static int pcie_advk_write_config(struct udevice *bus, pci_dev_t bdf, (offset == PCI_PRIMARY_BUS && size != PCI_SIZE_8)) pcie->sec_busno = (data >> 8) & 0xff;
+ if ((offset & ~3) == PCIE_CORE_PCIEXP_CAP_OFF + PCI_EXP_RTCTL) + pcie->cfgcrssve = data & PCI_EXP_RTCTL_CRSSVE; + return 0; }
diff --git a/include/pci.h b/include/pci.h index 0fc22adffd..69eafeb4b9 100644 --- a/include/pci.h +++ b/include/pci.h @@ -495,6 +495,10 @@ #define PCI_EXP_LNKSTA_DLLLA 0x2000 /* Data Link Layer Link Active */ #define PCI_EXP_SLTCAP 20 /* Slot Capabilities */ #define PCI_EXP_SLTCAP_PSN 0xfff80000 /* Physical Slot Number */ +#define PCI_EXP_RTCTL 28 /* Root Control */ +#define PCI_EXP_RTCTL_CRSSVE 0x0010 /* CRS Software Visibility Enable */ +#define PCI_EXP_RTCAP 30 /* Root Capabilities */ +#define PCI_EXP_RTCAP_CRSVIS 0x0001 /* CRS Software Visibility capability */ #define PCI_EXP_DEVCAP2 36 /* Device Capabilities 2 */ #define PCI_EXP_DEVCAP2_ARI 0x00000020 /* ARI Forwarding Supported */ #define PCI_EXP_DEVCTL2 40 /* Device Control 2 */
Thanks, Stefan
bool cfgcrssve; };
- U-Boot currently does not support handling of CRS return value for
- PCI_VENDOR_ID config read request and also does not set CRSSVE bit.
*/* it will work for Aardvark.
- return 0; }
Viele Grüße, Stefan
Update indentation in driver's private structure.
Signed-off-by: Marek Behún marek.behun@nic.cz --- drivers/pci/pci-aardvark.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/pci/pci-aardvark.c b/drivers/pci/pci-aardvark.c index 53e9e23d4a..b4f350ca2c 100644 --- a/drivers/pci/pci-aardvark.c +++ b/drivers/pci/pci-aardvark.c @@ -196,13 +196,13 @@ * @device: The pointer to PCI uclass device. */ struct pcie_advk { - void *base; - int first_busno; - int sec_busno; - struct udevice *dev; - struct gpio_desc reset_gpio; - u32 cfgcache[0x34 - 0x10]; - bool cfgcrssve; + void *base; + int first_busno; + int sec_busno; + struct udevice *dev; + struct gpio_desc reset_gpio; + u32 cfgcache[0x34 - 0x10]; + bool cfgcrssve; };
Thanks, Stefan
- void *base;
- int first_busno;
- int sec_busno;
- bool cfgcrssve;
void *base;
int first_busno;
int sec_busno;
bool cfgcrssve; };
Viele Grüße, Stefan
There were several changes for this structure but the documentation was not changed at the time. Fix this.
Signed-off-by: Marek Behún marek.behun@nic.cz --- drivers/pci/pci-aardvark.c | 17 +++++++++-------- 1 file changed, 9 insertions(+), 8 deletions(-)
diff --git a/drivers/pci/pci-aardvark.c b/drivers/pci/pci-aardvark.c index b4f350ca2c..414872ed35 100644 --- a/drivers/pci/pci-aardvark.c +++ b/drivers/pci/pci-aardvark.c @@ -186,14 +186,15 @@ /** * struct pcie_advk - Advk PCIe controller state * - * @reg_base: The base address of the register space. - * @first_busno: This driver supports multiple PCIe controllers. - * first_busno stores the bus number of the PCIe root-port - * number which may vary depending on the PCIe setup - * (PEX switches etc). - * @sec_busno: sec_busno stores the bus number for the device behind - * the PCIe root-port - * @device: The pointer to PCI uclass device. + * @base: The base address of the register space. + * @first_busno: Bus number of the PCIe root-port. + * This may vary depending on the PCIe setup. + * @sec_busno: Bus number for the device behind the PCIe root-port. + * @dev: The pointer to PCI uclass device. + * @reset_gpio: GPIO descriptor for PERST. + * @cfgcache: Buffer for emulation of PCIe Root Port's PCI Bridge registers + * that are not available on Aardvark. + * @cfgcrssve: For CRSSVE emulation. */ struct pcie_advk { void *base;
Thanks, Stefan
- struct pcie_advk - Advk PCIe controller state
- @reg_base: The base address of the register space.
- @first_busno: This driver supports multiple PCIe controllers.
(PEX switches etc).
the PCIe root-port
- @base: The base address of the register space.
- @first_busno: Bus number of the PCIe root-port.
- @sec_busno: Bus number for the device behind the PCIe root-port.
- @dev: The pointer to PCI uclass device.
- @reset_gpio: GPIO descriptor for PERST.
- @cfgcache: Buffer for emulation of PCIe Root Port's PCI Bridge registers
- @cfgcrssve: For CRSSVE emulation.
Viele Grüße, Stefan
Hello Stefan,
Marek
Changes since v1:
Applied to u-boot-marvell/master
Thanks, Stefan
Marek Behún
Pali Rohár
Stefan Roese
