[U-Boot] [PATCH V2 01/12] arm: dts: imx7: sync with Linux
Sync with Linux commit 308ac756("Merge tag 'gpio-v4.11-3'").
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefan Agner stefan.agner@toradex.com Cc: Stefano Babic sbabic@denx.de ---
V2: remove imx7.dtsi
arch/arm/dts/imx7-colibri.dts | 10 +- arch/arm/dts/imx7.dtsi | 194 ------- arch/arm/dts/imx7d-pinfunc.h | 111 ++-- arch/arm/dts/imx7d.dtsi | 140 +++++ arch/arm/dts/imx7s.dtsi | 999 ++++++++++++++++++++++++++++++++ include/dt-bindings/clock/imx7d-clock.h | 454 +++++++++++++++ 6 files changed, 1657 insertions(+), 251 deletions(-) delete mode 100644 arch/arm/dts/imx7.dtsi create mode 100644 arch/arm/dts/imx7d.dtsi create mode 100644 arch/arm/dts/imx7s.dtsi create mode 100644 include/dt-bindings/clock/imx7d-clock.h
diff --git a/arch/arm/dts/imx7-colibri.dts b/arch/arm/dts/imx7-colibri.dts index cbef5d5..f6c2105 100644 --- a/arch/arm/dts/imx7-colibri.dts +++ b/arch/arm/dts/imx7-colibri.dts @@ -6,7 +6,7 @@
/dts-v1/; #include <dt-bindings/gpio/gpio.h> -#include "imx7.dtsi" +#include "imx7d.dtsi"
/ { model = "Toradex Colibri iMX7S/D"; @@ -83,15 +83,15 @@ &iomuxc_lpsr { pinctrl_i2c1: i2c1-grp { fsl,pins = < - MX7D_PAD_GPIO1_IO05__I2C1_SDA 0x4000007f - MX7D_PAD_GPIO1_IO04__I2C1_SCL 0x4000007f + MX7D_PAD_LPSR_GPIO1_IO05__I2C1_SDA 0x4000007f + MX7D_PAD_LPSR_GPIO1_IO04__I2C1_SCL 0x4000007f >; };
pinctrl_i2c1_gpio: i2c1-gpio-grp { fsl,pins = < - MX7D_PAD_GPIO1_IO05__GPIO1_IO5 0x4000007f - MX7D_PAD_GPIO1_IO04__GPIO1_IO4 0x4000007f + MX7D_PAD_LPSR_GPIO1_IO05__GPIO1_IO5 0x4000007f + MX7D_PAD_LPSR_GPIO1_IO04__GPIO1_IO4 0x4000007f >; }; }; diff --git a/arch/arm/dts/imx7.dtsi b/arch/arm/dts/imx7.dtsi deleted file mode 100644 index 755cc46..0000000 --- a/arch/arm/dts/imx7.dtsi +++ /dev/null @@ -1,194 +0,0 @@ -/* - * Copyright 2016 Toradex AG - * - * SPDX-License-Identifier: GPL-2.0+ or X11 - */ -#include "imx7d-pinfunc.h" -#include "skeleton.dtsi" - -/ { - aliases { - gpio0 = &gpio1; - gpio1 = &gpio2; - gpio2 = &gpio3; - gpio3 = &gpio4; - gpio4 = &gpio5; - gpio5 = &gpio6; - gpio6 = &gpio7; - i2c0 = &i2c1; - i2c1 = &i2c2; - i2c2 = &i2c3; - i2c3 = &i2c4; - serial0 = &uart1; - serial1 = &uart2; - serial2 = &uart3; - serial3 = &uart4; - serial4 = &uart5; - serial5 = &uart6; - serial6 = &uart7; - }; - - soc { - #address-cells = <1>; - #size-cells = <1>; - compatible = "simple-bus"; - ranges; - - aips1: aips-bus@30000000 { - compatible = "fsl,aips-bus", "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x30000000 0x400000>; - ranges; - - gpio1: gpio@30200000 { - compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; - reg = <0x30200000 0x10000>; - gpio-controller; - #gpio-cells = <2>; - }; - - gpio2: gpio@30210000 { - compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; - reg = <0x30210000 0x10000>; - gpio-controller; - #gpio-cells = <2>; - }; - - gpio3: gpio@30220000 { - compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; - reg = <0x30220000 0x10000>; - gpio-controller; - #gpio-cells = <2>; - }; - - gpio4: gpio@30230000 { - compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; - reg = <0x30230000 0x10000>; - gpio-controller; - #gpio-cells = <2>; - }; - - gpio5: gpio@30240000 { - compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; - reg = <0x30240000 0x10000>; - gpio-controller; - #gpio-cells = <2>; - }; - - gpio6: gpio@30250000 { - compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; - reg = <0x30250000 0x10000>; - gpio-controller; - #gpio-cells = <2>; - }; - - gpio7: gpio@30260000 { - compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; - reg = <0x30260000 0x10000>; - gpio-controller; - #gpio-cells = <2>; - }; - - iomuxc_lpsr: iomuxc-lpsr@302c0000 { - compatible = "fsl,imx7d-iomuxc-lpsr"; - reg = <0x302c0000 0x10000>; - fsl,input-sel = <&iomuxc>; - }; - - iomuxc: iomuxc@30330000 { - compatible = "fsl,imx7d-iomuxc"; - reg = <0x30330000 0x10000>; - }; - }; - - aips3: aips-bus@30800000 { - compatible = "fsl,aips-bus", "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x30800000 0x400000>; - ranges; - - uart1: serial@30860000 { - compatible = "fsl,imx7d-uart", - "fsl,imx6q-uart"; - reg = <0x30860000 0x10000>; - status = "disabled"; - }; - - uart2: serial@30890000 { - compatible = "fsl,imx7d-uart", - "fsl,imx6q-uart"; - reg = <0x30890000 0x10000>; - status = "disabled"; - }; - - uart3: serial@30880000 { - compatible = "fsl,imx7d-uart", - "fsl,imx6q-uart"; - reg = <0x30880000 0x10000>; - status = "disabled"; - }; - - i2c1: i2c@30a20000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx7d-i2c", "fsl,imx21-i2c"; - reg = <0x30a20000 0x10000>; - status = "disabled"; - }; - - i2c2: i2c@30a30000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx7d-i2c", "fsl,imx21-i2c"; - reg = <0x30a30000 0x10000>; - status = "disabled"; - }; - - i2c3: i2c@30a40000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx7d-i2c", "fsl,imx21-i2c"; - reg = <0x30a40000 0x10000>; - status = "disabled"; - }; - - i2c4: i2c@30a50000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx7d-i2c", "fsl,imx21-i2c"; - reg = <0x30a50000 0x10000>; - status = "disabled"; - }; - - uart4: serial@30a60000 { - compatible = "fsl,imx7d-uart", - "fsl,imx6q-uart"; - reg = <0x30a60000 0x10000>; - status = "disabled"; - }; - - uart5: serial@30a70000 { - compatible = "fsl,imx7d-uart", - "fsl,imx6q-uart"; - reg = <0x30a70000 0x10000>; - status = "disabled"; - }; - - uart6: serial@30a80000 { - compatible = "fsl,imx7d-uart", - "fsl,imx6q-uart"; - reg = <0x30a80000 0x10000>; - status = "disabled"; - }; - - uart7: serial@30a90000 { - compatible = "fsl,imx7d-uart", - "fsl,imx6q-uart"; - reg = <0x30a90000 0x10000>; - status = "disabled"; - }; - }; - }; -}; diff --git a/arch/arm/dts/imx7d-pinfunc.h b/arch/arm/dts/imx7d-pinfunc.h index 32d2464..f6f7e78 100644 --- a/arch/arm/dts/imx7d-pinfunc.h +++ b/arch/arm/dts/imx7d-pinfunc.h @@ -1,7 +1,10 @@ /* * Copyright (C) 2014-2015 Freescale Semiconductor, Inc. * - * SPDX-License-Identifier: GPL-2.0+ + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * */
#ifndef __DTS_IMX7D_PINFUNC_H @@ -12,57 +15,61 @@ * <mux_reg conf_reg input_reg mux_mode input_val> */
-#define MX7D_PAD_GPIO1_IO00__GPIO1_IO0 0x0000 0x0030 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO00__PWM4_OUT 0x0000 0x0030 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO00__WDOD1_WDOG_ANY 0x0000 0x0030 0x0000 0x2 0x0 -#define MX7D_PAD_GPIO1_IO00__WDOD1_WDOG_B 0x0000 0x0030 0x0000 0x3 0x0 -#define MX7D_PAD_GPIO1_IO00__WDOD1_WDOG__RST_B_DEB 0x0000 0x0030 0x0000 0x4 0x0 -#define MX7D_PAD_GPIO1_IO01__GPIO1_IO1 0x0004 0x0034 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO01__PWM1_OUT 0x0004 0x0034 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO01__CCM_ENET_REF_CLK3 0x0004 0x0034 0x0000 0x2 0x0 -#define MX7D_PAD_GPIO1_IO01__SAI1_MCLK 0x0004 0x0034 0x0000 0x3 0x0 -#define MX7D_PAD_GPIO1_IO01__ANATOP_24M_OUT 0x0004 0x0034 0x0000 0x4 0x0 -#define MX7D_PAD_GPIO1_IO01__OBSERVE0_OUT 0x0004 0x0034 0x0000 0x6 0x0 -#define MX7D_PAD_GPIO1_IO02__GPIO1_IO2 0x0008 0x0038 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO02__PWM2_OUT 0x0008 0x0038 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO02__CCM_ENET_REF_CLK1 0x0008 0x0038 0x0564 0x2 0x3 -#define MX7D_PAD_GPIO1_IO02__SAI2_MCLK 0x0008 0x0038 0x0000 0x3 0x0 -#define MX7D_PAD_GPIO1_IO02__CCM_CLKO1 0x0008 0x0038 0x0000 0x5 0x0 -#define MX7D_PAD_GPIO1_IO02__OBSERVE1_OUT 0x0008 0x0038 0x0000 0x6 0x0 -#define MX7D_PAD_GPIO1_IO02__USB_OTG1_ID 0x0008 0x0038 0x0734 0x7 0x3 -#define MX7D_PAD_GPIO1_IO03__GPIO1_IO3 0x000C 0x003C 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO03__PWM3_OUT 0x000C 0x003C 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO03__CCM_ENET_REF_CLK2 0x000C 0x003C 0x0570 0x2 0x3 -#define MX7D_PAD_GPIO1_IO03__SAI3_MCLK 0x000C 0x003C 0x0000 0x3 0x0 -#define MX7D_PAD_GPIO1_IO03__CCM_CLKO2 0x000C 0x003C 0x0000 0x5 0x0 -#define MX7D_PAD_GPIO1_IO03__OBSERVE2_OUT 0x000C 0x003C 0x0000 0x6 0x0 -#define MX7D_PAD_GPIO1_IO03__USB_OTG2_ID 0x000C 0x003C 0x0730 0x7 0x3 -#define MX7D_PAD_GPIO1_IO04__GPIO1_IO4 0x0010 0x0040 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO04__USB_OTG1_OC 0x0010 0x0040 0x072C 0x1 0x1 -#define MX7D_PAD_GPIO1_IO04__FLEXTIMER1_CH4 0x0010 0x0040 0x0594 0x2 0x1 -#define MX7D_PAD_GPIO1_IO04__UART5_CTS_B 0x0010 0x0040 0x0710 0x3 0x4 -#define MX7D_PAD_GPIO1_IO04__I2C1_SCL 0x0010 0x0040 0x05D4 0x4 0x2 -#define MX7D_PAD_GPIO1_IO04__OBSERVE3_OUT 0x0010 0x0040 0x0000 0x6 0x0 -#define MX7D_PAD_GPIO1_IO05__GPIO1_IO5 0x0014 0x0044 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO05__USB_OTG1_PWR 0x0014 0x0044 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO05__FLEXTIMER1_CH5 0x0014 0x0044 0x0598 0x2 0x1 -#define MX7D_PAD_GPIO1_IO05__UART5_RTS_B 0x0014 0x0044 0x0710 0x3 0x5 -#define MX7D_PAD_GPIO1_IO05__I2C1_SDA 0x0014 0x0044 0x05D8 0x4 0x2 -#define MX7D_PAD_GPIO1_IO05__OBSERVE4_OUT 0x0014 0x0044 0x0000 0x6 0x0 -#define MX7D_PAD_GPIO1_IO06__GPIO1_IO6 0x0018 0x0048 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO06__USB_OTG2_OC 0x0018 0x0048 0x0728 0x1 0x1 -#define MX7D_PAD_GPIO1_IO06__FLEXTIMER1_CH6 0x0018 0x0048 0x059C 0x2 0x1 -#define MX7D_PAD_GPIO1_IO06__UART5_RX_DATA 0x0018 0x0048 0x0714 0x3 0x4 -#define MX7D_PAD_GPIO1_IO06__I2C2_SCL 0x0018 0x0048 0x05DC 0x4 0x2 -#define MX7D_PAD_GPIO1_IO06__CCM_WAIT 0x0018 0x0048 0x0000 0x5 0x0 -#define MX7D_PAD_GPIO1_IO06__KPP_ROW4 0x0018 0x0048 0x0624 0x6 0x1 -#define MX7D_PAD_GPIO1_IO07__GPIO1_IO7 0x001C 0x004C 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO07__USB_OTG2_PWR 0x001C 0x004C 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO07__FLEXTIMER1_CH7 0x001C 0x004C 0x05A0 0x2 0x1 -#define MX7D_PAD_GPIO1_IO07__UART5_TX_DATA 0x001C 0x004C 0x0714 0x3 0x5 -#define MX7D_PAD_GPIO1_IO07__I2C2_SDA 0x001C 0x004C 0x05E0 0x4 0x2 -#define MX7D_PAD_GPIO1_IO07__CCM_STOP 0x001C 0x004C 0x0000 0x5 0x0 -#define MX7D_PAD_GPIO1_IO07__KPP_COL4 0x001C 0x004C 0x0604 0x6 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO00__GPIO1_IO0 0x0000 0x0030 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO00__PWM4_OUT 0x0000 0x0030 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO00__WDOD1_WDOG_ANY 0x0000 0x0030 0x0000 0x2 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO00__WDOD1_WDOG_B 0x0000 0x0030 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO00__WDOD1_WDOG__RST_B_DEB 0x0000 0x0030 0x0000 0x4 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__GPIO1_IO1 0x0004 0x0034 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__PWM1_OUT 0x0004 0x0034 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__CCM_ENET_REF_CLK3 0x0004 0x0034 0x0000 0x2 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__SAI1_MCLK 0x0004 0x0034 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__ANATOP_24M_OUT 0x0004 0x0034 0x0000 0x4 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__OBSERVE0_OUT 0x0004 0x0034 0x0000 0x6 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__GPIO1_IO2 0x0008 0x0038 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__PWM2_OUT 0x0008 0x0038 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__CCM_ENET_REF_CLK1 0x0008 0x0038 0x0564 0x2 0x3 +#define MX7D_PAD_LPSR_GPIO1_IO02__SAI2_MCLK 0x0008 0x0038 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__CCM_CLKO1 0x0008 0x0038 0x0000 0x5 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__OBSERVE1_OUT 0x0008 0x0038 0x0000 0x6 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__USB_OTG1_ID 0x0008 0x0038 0x0734 0x7 0x3 +#define MX7D_PAD_LPSR_GPIO1_IO03__GPIO1_IO3 0x000C 0x003C 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO03__PWM3_OUT 0x000C 0x003C 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO03__CCM_ENET_REF_CLK2 0x000C 0x003C 0x0570 0x2 0x3 +#define MX7D_PAD_LPSR_GPIO1_IO03__SAI3_MCLK 0x000C 0x003C 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO03__CCM_CLKO2 0x000C 0x003C 0x0000 0x5 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO03__OBSERVE2_OUT 0x000C 0x003C 0x0000 0x6 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO03__USB_OTG2_ID 0x000C 0x003C 0x0730 0x7 0x3 +#define MX7D_PAD_LPSR_GPIO1_IO04__GPIO1_IO4 0x0010 0x0040 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO04__USB_OTG1_OC 0x0010 0x0040 0x072C 0x1 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO04__FLEXTIMER1_CH4 0x0010 0x0040 0x0594 0x2 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO04__UART5_DCE_CTS 0x0010 0x0040 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO04__UART5_DTE_RTS 0x0010 0x0040 0x0710 0x3 0x4 +#define MX7D_PAD_LPSR_GPIO1_IO04__I2C1_SCL 0x0010 0x0040 0x05D4 0x4 0x2 +#define MX7D_PAD_LPSR_GPIO1_IO04__OBSERVE3_OUT 0x0010 0x0040 0x0000 0x6 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO05__GPIO1_IO5 0x0014 0x0044 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO05__USB_OTG1_PWR 0x0014 0x0044 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO05__FLEXTIMER1_CH5 0x0014 0x0044 0x0598 0x2 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO05__UART5_DCE_RTS 0x0014 0x0044 0x0710 0x3 0x5 +#define MX7D_PAD_LPSR_GPIO1_IO05__UART5_DTE_CTS 0x0014 0x0044 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO05__I2C1_SDA 0x0014 0x0044 0x05D8 0x4 0x2 +#define MX7D_PAD_LPSR_GPIO1_IO05__OBSERVE4_OUT 0x0014 0x0044 0x0000 0x6 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO06__GPIO1_IO6 0x0018 0x0048 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO06__USB_OTG2_OC 0x0018 0x0048 0x0728 0x1 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO06__FLEXTIMER1_CH6 0x0018 0x0048 0x059C 0x2 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO06__UART5_DCE_RX 0x0018 0x0048 0x0714 0x3 0x4 +#define MX7D_PAD_LPSR_GPIO1_IO06__UART5_DTE_TX 0x0018 0x0048 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO06__I2C2_SCL 0x0018 0x0048 0x05DC 0x4 0x2 +#define MX7D_PAD_LPSR_GPIO1_IO06__CCM_WAIT 0x0018 0x0048 0x0000 0x5 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO06__KPP_ROW4 0x0018 0x0048 0x0624 0x6 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO07__GPIO1_IO7 0x001C 0x004C 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO07__USB_OTG2_PWR 0x001C 0x004C 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO07__FLEXTIMER1_CH7 0x001C 0x004C 0x05A0 0x2 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO07__UART5_DCE_TX 0x001C 0x004C 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO07__UART5_DTE_RX 0x001C 0x004C 0x0714 0x3 0x5 +#define MX7D_PAD_LPSR_GPIO1_IO07__I2C2_SDA 0x001C 0x004C 0x05E0 0x4 0x2 +#define MX7D_PAD_LPSR_GPIO1_IO07__CCM_STOP 0x001C 0x004C 0x0000 0x5 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO07__KPP_COL4 0x001C 0x004C 0x0604 0x6 0x1 #define MX7D_PAD_GPIO1_IO08__GPIO1_IO8 0x0014 0x026C 0x0000 0x0 0x0 #define MX7D_PAD_GPIO1_IO08__SD1_VSELECT 0x0014 0x026C 0x0000 0x1 0x0 #define MX7D_PAD_GPIO1_IO08__WDOG1_WDOG_B 0x0014 0x026C 0x0000 0x2 0x0 diff --git a/arch/arm/dts/imx7d.dtsi b/arch/arm/dts/imx7d.dtsi new file mode 100644 index 0000000..f6dee41 --- /dev/null +++ b/arch/arm/dts/imx7d.dtsi @@ -0,0 +1,140 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * Copyright 2016 Toradex AG + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include "imx7s.dtsi" + +/ { + cpus { + cpu0: cpu@0 { + operating-points = < + /* KHz uV */ + 996000 1075000 + 792000 975000 + >; + clock-frequency = <996000000>; + }; + + cpu1: cpu@1 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <1>; + clock-frequency = <996000000>; + }; + }; + + soc { + etm@3007d000 { + compatible = "arm,coresight-etm3x", "arm,primecell"; + reg = <0x3007d000 0x1000>; + + /* + * System will hang if added nosmp in kernel command line + * without arm,primecell-periphid because amba bus try to + * read id and core1 power off at this time. + */ + arm,primecell-periphid = <0xbb956>; + cpu = <&cpu1>; + clocks = <&clks IMX7D_MAIN_AXI_ROOT_CLK>; + clock-names = "apb_pclk"; + + port { + etm1_out_port: endpoint { + remote-endpoint = <&ca_funnel_in_port1>; + }; + }; + }; + }; +}; + +&aips3 { + usbotg2: usb@30b20000 { + compatible = "fsl,imx7d-usb", "fsl,imx27-usb"; + reg = <0x30b20000 0x200>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_USB_CTRL_CLK>; + fsl,usbphy = <&usbphynop2>; + fsl,usbmisc = <&usbmisc2 0>; + phy-clkgate-delay-us = <400>; + status = "disabled"; + }; + + usbmisc2: usbmisc@30b20200 { + #index-cells = <1>; + compatible = "fsl,imx7d-usbmisc", "fsl,imx6q-usbmisc"; + reg = <0x30b20200 0x200>; + }; + + usbphynop2: usbphynop2 { + compatible = "usb-nop-xceiv"; + clocks = <&clks IMX7D_USB_PHY2_CLK>; + clock-names = "main_clk"; + }; + + fec2: ethernet@30bf0000 { + compatible = "fsl,imx7d-fec", "fsl,imx6sx-fec"; + reg = <0x30bf0000 0x10000>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_ENET_AXI_ROOT_CLK>, + <&clks IMX7D_ENET_AXI_ROOT_CLK>, + <&clks IMX7D_ENET2_TIME_ROOT_CLK>, + <&clks IMX7D_PLL_ENET_MAIN_125M_CLK>, + <&clks IMX7D_ENET_PHY_REF_ROOT_CLK>; + clock-names = "ipg", "ahb", "ptp", + "enet_clk_ref", "enet_out"; + fsl,num-tx-queues=<3>; + fsl,num-rx-queues=<3>; + status = "disabled"; + }; +}; + +&ca_funnel_ports { + port@1 { + reg = <1>; + ca_funnel_in_port1: endpoint { + slave-mode; + remote-endpoint = <&etm1_out_port>; + }; + }; +}; diff --git a/arch/arm/dts/imx7s.dtsi b/arch/arm/dts/imx7s.dtsi new file mode 100644 index 0000000..a7d48e7 --- /dev/null +++ b/arch/arm/dts/imx7s.dtsi @@ -0,0 +1,999 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * Copyright 2016 Toradex AG + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include <dt-bindings/clock/imx7d-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include "imx7d-pinfunc.h" + +/ { + #address-cells = <1>; + #size-cells = <1>; + /* + * The decompressor and also some bootloaders rely on a + * pre-existing /chosen node to be available to insert the + * command line and merge other ATAGS info. + * Also for U-Boot there must be a pre-existing /memory node. + */ + chosen {}; + memory { device_type = "memory"; reg = <0 0>; }; + + aliases { + gpio0 = &gpio1; + gpio1 = &gpio2; + gpio2 = &gpio3; + gpio3 = &gpio4; + gpio4 = &gpio5; + gpio5 = &gpio6; + gpio6 = &gpio7; + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + i2c3 = &i2c4; + mmc0 = &usdhc1; + mmc1 = &usdhc2; + mmc2 = &usdhc3; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + serial3 = &uart4; + serial4 = &uart5; + serial5 = &uart6; + serial6 = &uart7; + spi0 = &ecspi1; + spi1 = &ecspi2; + spi2 = &ecspi3; + spi3 = &ecspi4; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@0 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <0>; + clock-frequency = <792000000>; + clock-latency = <61036>; /* two CLK32 periods */ + clocks = <&clks IMX7D_CLK_ARM>; + }; + }; + + ckil: clock-cki { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "ckil"; + }; + + osc: clock-osc { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + clock-output-names = "osc"; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + interrupt-parent = <&intc>; + ranges; + + funnel@30041000 { + compatible = "arm,coresight-funnel", "arm,primecell"; + reg = <0x30041000 0x1000>; + clocks = <&clks IMX7D_MAIN_AXI_ROOT_CLK>; + clock-names = "apb_pclk"; + + ca_funnel_ports: ports { + #address-cells = <1>; + #size-cells = <0>; + + /* funnel input ports */ + port@0 { + reg = <0>; + ca_funnel_in_port0: endpoint { + slave-mode; + remote-endpoint = <&etm0_out_port>; + }; + }; + + /* funnel output port */ + port@2 { + reg = <0>; + ca_funnel_out_port0: endpoint { + remote-endpoint = <&hugo_funnel_in_port0>; + }; + }; + + /* the other input ports are not connect to anything */ + }; + }; + + etm@3007c000 { + compatible = "arm,coresight-etm3x", "arm,primecell"; + reg = <0x3007c000 0x1000>; + cpu = <&cpu0>; + clocks = <&clks IMX7D_MAIN_AXI_ROOT_CLK>; + clock-names = "apb_pclk"; + + port { + etm0_out_port: endpoint { + remote-endpoint = <&ca_funnel_in_port0>; + }; + }; + }; + + funnel@30083000 { + compatible = "arm,coresight-funnel", "arm,primecell"; + reg = <0x30083000 0x1000>; + clocks = <&clks IMX7D_MAIN_AXI_ROOT_CLK>; + clock-names = "apb_pclk"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + /* funnel input ports */ + port@0 { + reg = <0>; + hugo_funnel_in_port0: endpoint { + slave-mode; + remote-endpoint = <&ca_funnel_out_port0>; + }; + }; + + port@1 { + reg = <1>; + hugo_funnel_in_port1: endpoint { + slave-mode; /* M4 input */ + }; + }; + + port@2 { + reg = <0>; + hugo_funnel_out_port0: endpoint { + remote-endpoint = <&etf_in_port>; + }; + }; + + /* the other input ports are not connect to anything */ + }; + }; + + etf@30084000 { + compatible = "arm,coresight-tmc", "arm,primecell"; + reg = <0x30084000 0x1000>; + clocks = <&clks IMX7D_MAIN_AXI_ROOT_CLK>; + clock-names = "apb_pclk"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + etf_in_port: endpoint { + slave-mode; + remote-endpoint = <&hugo_funnel_out_port0>; + }; + }; + + port@1 { + reg = <0>; + etf_out_port: endpoint { + remote-endpoint = <&replicator_in_port0>; + }; + }; + }; + }; + + etr@30086000 { + compatible = "arm,coresight-tmc", "arm,primecell"; + reg = <0x30086000 0x1000>; + clocks = <&clks IMX7D_MAIN_AXI_ROOT_CLK>; + clock-names = "apb_pclk"; + + port { + etr_in_port: endpoint { + slave-mode; + remote-endpoint = <&replicator_out_port1>; + }; + }; + }; + + tpiu@30087000 { + compatible = "arm,coresight-tpiu", "arm,primecell"; + reg = <0x30087000 0x1000>; + clocks = <&clks IMX7D_MAIN_AXI_ROOT_CLK>; + clock-names = "apb_pclk"; + + port { + tpiu_in_port: endpoint { + slave-mode; + remote-endpoint = <&replicator_out_port1>; + }; + }; + }; + + replicator { + /* + * non-configurable replicators don't show up on the + * AMBA bus. As such no need to add "arm,primecell" + */ + compatible = "arm,coresight-replicator"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + /* replicator output ports */ + port@0 { + reg = <0>; + replicator_out_port0: endpoint { + remote-endpoint = <&tpiu_in_port>; + }; + }; + + port@1 { + reg = <1>; + replicator_out_port1: endpoint { + remote-endpoint = <&etr_in_port>; + }; + }; + + /* replicator input port */ + port@2 { + reg = <0>; + replicator_in_port0: endpoint { + slave-mode; + remote-endpoint = <&etf_out_port>; + }; + }; + }; + }; + + intc: interrupt-controller@31001000 { + compatible = "arm,cortex-a7-gic"; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x31001000 0x1000>, + <0x31002000 0x2000>, + <0x31004000 0x2000>, + <0x31006000 0x2000>; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + }; + + aips1: aips-bus@30000000 { + compatible = "fsl,aips-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x30000000 0x400000>; + ranges; + + gpio1: gpio@30200000 { + compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; + reg = <0x30200000 0x10000>; + interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>, /* GPIO1_INT15_0 */ + <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; /* GPIO1_INT31_16 */ + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc_lpsr 0 0 8>, <&iomuxc 8 5 8>; + }; + + gpio2: gpio@30210000 { + compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; + reg = <0x30210000 0x10000>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 13 32>; + }; + + gpio3: gpio@30220000 { + compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; + reg = <0x30220000 0x10000>; + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 45 29>; + }; + + gpio4: gpio@30230000 { + compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; + reg = <0x30230000 0x10000>; + interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 74 24>; + }; + + gpio5: gpio@30240000 { + compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; + reg = <0x30240000 0x10000>; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 98 18>; + }; + + gpio6: gpio@30250000 { + compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; + reg = <0x30250000 0x10000>; + interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 116 23>; + }; + + gpio7: gpio@30260000 { + compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio"; + reg = <0x30260000 0x10000>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 139 16>; + }; + + wdog1: wdog@30280000 { + compatible = "fsl,imx7d-wdt", "fsl,imx21-wdt"; + reg = <0x30280000 0x10000>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_WDOG1_ROOT_CLK>; + }; + + wdog2: wdog@30290000 { + compatible = "fsl,imx7d-wdt", "fsl,imx21-wdt"; + reg = <0x30290000 0x10000>; + interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_WDOG2_ROOT_CLK>; + status = "disabled"; + }; + + wdog3: wdog@302a0000 { + compatible = "fsl,imx7d-wdt", "fsl,imx21-wdt"; + reg = <0x302a0000 0x10000>; + interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_WDOG3_ROOT_CLK>; + status = "disabled"; + }; + + wdog4: wdog@302b0000 { + compatible = "fsl,imx7d-wdt", "fsl,imx21-wdt"; + reg = <0x302b0000 0x10000>; + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_WDOG4_ROOT_CLK>; + status = "disabled"; + }; + + iomuxc_lpsr: iomuxc-lpsr@302c0000 { + compatible = "fsl,imx7d-iomuxc-lpsr"; + reg = <0x302c0000 0x10000>; + fsl,input-sel = <&iomuxc>; + }; + + gpt1: gpt@302d0000 { + compatible = "fsl,imx7d-gpt", "fsl,imx6sx-gpt"; + reg = <0x302d0000 0x10000>; + interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_GPT1_ROOT_CLK>; + clock-names = "ipg", "per"; + }; + + gpt2: gpt@302e0000 { + compatible = "fsl,imx7d-gpt", "fsl,imx6sx-gpt"; + reg = <0x302e0000 0x10000>; + interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_GPT2_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + gpt3: gpt@302f0000 { + compatible = "fsl,imx7d-gpt", "fsl,imx6sx-gpt"; + reg = <0x302f0000 0x10000>; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_GPT3_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + gpt4: gpt@30300000 { + compatible = "fsl,imx7d-gpt", "fsl,imx6sx-gpt"; + reg = <0x30300000 0x10000>; + interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_GPT4_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + iomuxc: iomuxc@30330000 { + compatible = "fsl,imx7d-iomuxc"; + reg = <0x30330000 0x10000>; + }; + + gpr: iomuxc-gpr@30340000 { + compatible = "fsl,imx7d-iomuxc-gpr", "syscon"; + reg = <0x30340000 0x10000>; + }; + + ocotp: ocotp-ctrl@30350000 { + compatible = "fsl,imx7d-ocotp", "syscon"; + reg = <0x30350000 0x10000>; + clocks = <&clks IMX7D_OCOTP_CLK>; + }; + + anatop: anatop@30360000 { + compatible = "fsl,imx7d-anatop", "fsl,imx6q-anatop", + "syscon", "simple-bus"; + reg = <0x30360000 0x10000>; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; + + reg_1p0d: regulator-vdd1p0d { + compatible = "fsl,anatop-regulator"; + regulator-name = "vdd1p0d"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1200000>; + anatop-reg-offset = <0x210>; + anatop-vol-bit-shift = <8>; + anatop-vol-bit-width = <5>; + anatop-min-bit-val = <8>; + anatop-min-voltage = <800000>; + anatop-max-voltage = <1200000>; + }; + }; + + snvs: snvs@30370000 { + compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd"; + reg = <0x30370000 0x10000>; + + snvs_rtc: snvs-rtc-lp { + compatible = "fsl,sec-v4.0-mon-rtc-lp"; + regmap = <&snvs>; + offset = <0x34>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + }; + + snvs_poweroff: snvs-poweroff { + compatible = "syscon-poweroff"; + regmap = <&snvs>; + offset = <0x38>; + mask = <0x60>; + }; + + snvs_pwrkey: snvs-powerkey { + compatible = "fsl,sec-v4.0-pwrkey"; + regmap = <&snvs>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + linux,keycode = <KEY_POWER>; + wakeup-source; + }; + }; + + clks: ccm@30380000 { + compatible = "fsl,imx7d-ccm"; + reg = <0x30380000 0x10000>; + interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + #clock-cells = <1>; + clocks = <&ckil>, <&osc>; + clock-names = "ckil", "osc"; + }; + + src: src@30390000 { + compatible = "fsl,imx7d-src", "fsl,imx51-src", "syscon"; + reg = <0x30390000 0x10000>; + interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; + #reset-cells = <1>; + }; + }; + + aips2: aips-bus@30400000 { + compatible = "fsl,aips-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x30400000 0x400000>; + ranges; + + adc1: adc@30610000 { + compatible = "fsl,imx7d-adc"; + reg = <0x30610000 0x10000>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_ADC_ROOT_CLK>; + clock-names = "adc"; + status = "disabled"; + }; + + adc2: adc@30620000 { + compatible = "fsl,imx7d-adc"; + reg = <0x30620000 0x10000>; + interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_ADC_ROOT_CLK>; + clock-names = "adc"; + status = "disabled"; + }; + + ecspi4: ecspi@30630000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-ecspi", "fsl,imx51-ecspi"; + reg = <0x30630000 0x10000>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_ECSPI4_ROOT_CLK>, + <&clks IMX7D_ECSPI4_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + pwm1: pwm@30660000 { + compatible = "fsl,imx7d-pwm", "fsl,imx27-pwm"; + reg = <0x30660000 0x10000>; + interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_PWM1_ROOT_CLK>, + <&clks IMX7D_PWM1_ROOT_CLK>; + clock-names = "ipg", "per"; + #pwm-cells = <2>; + status = "disabled"; + }; + + pwm2: pwm@30670000 { + compatible = "fsl,imx7d-pwm", "fsl,imx27-pwm"; + reg = <0x30670000 0x10000>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_PWM2_ROOT_CLK>, + <&clks IMX7D_PWM2_ROOT_CLK>; + clock-names = "ipg", "per"; + #pwm-cells = <2>; + status = "disabled"; + }; + + pwm3: pwm@30680000 { + compatible = "fsl,imx7d-pwm", "fsl,imx27-pwm"; + reg = <0x30680000 0x10000>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_PWM3_ROOT_CLK>, + <&clks IMX7D_PWM3_ROOT_CLK>; + clock-names = "ipg", "per"; + #pwm-cells = <2>; + status = "disabled"; + }; + + pwm4: pwm@30690000 { + compatible = "fsl,imx7d-pwm", "fsl,imx27-pwm"; + reg = <0x30690000 0x10000>; + interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_PWM4_ROOT_CLK>, + <&clks IMX7D_PWM4_ROOT_CLK>; + clock-names = "ipg", "per"; + #pwm-cells = <2>; + status = "disabled"; + }; + + lcdif: lcdif@30730000 { + compatible = "fsl,imx7d-lcdif", "fsl,imx28-lcdif"; + reg = <0x30730000 0x10000>; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_LCDIF_PIXEL_ROOT_CLK>, + <&clks IMX7D_LCDIF_PIXEL_ROOT_CLK>; + clock-names = "pix", "axi"; + status = "disabled"; + }; + }; + + aips3: aips-bus@30800000 { + compatible = "fsl,aips-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x30800000 0x400000>; + ranges; + + ecspi1: ecspi@30820000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-ecspi", "fsl,imx51-ecspi"; + reg = <0x30820000 0x10000>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_ECSPI1_ROOT_CLK>, + <&clks IMX7D_ECSPI1_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + ecspi2: ecspi@30830000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-ecspi", "fsl,imx51-ecspi"; + reg = <0x30830000 0x10000>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_ECSPI2_ROOT_CLK>, + <&clks IMX7D_ECSPI2_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + ecspi3: ecspi@30840000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-ecspi", "fsl,imx51-ecspi"; + reg = <0x30840000 0x10000>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_ECSPI3_ROOT_CLK>, + <&clks IMX7D_ECSPI3_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + uart1: serial@30860000 { + compatible = "fsl,imx7d-uart", + "fsl,imx6q-uart"; + reg = <0x30860000 0x10000>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_UART1_ROOT_CLK>, + <&clks IMX7D_UART1_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + uart2: serial@30890000 { + compatible = "fsl,imx7d-uart", + "fsl,imx6q-uart"; + reg = <0x30890000 0x10000>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_UART2_ROOT_CLK>, + <&clks IMX7D_UART2_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + uart3: serial@30880000 { + compatible = "fsl,imx7d-uart", + "fsl,imx6q-uart"; + reg = <0x30880000 0x10000>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_UART3_ROOT_CLK>, + <&clks IMX7D_UART3_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + sai1: sai@308a0000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx7d-sai", "fsl,imx6sx-sai"; + reg = <0x308a0000 0x10000>; + interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_SAI1_IPG_CLK>, + <&clks IMX7D_SAI1_ROOT_CLK>, + <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_CLK_DUMMY>; + clock-names = "bus", "mclk1", "mclk2", "mclk3"; + dma-names = "rx", "tx"; + dmas = <&sdma 8 24 0>, <&sdma 9 24 0>; + status = "disabled"; + }; + + sai2: sai@308b0000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx7d-sai", "fsl,imx6sx-sai"; + reg = <0x308b0000 0x10000>; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_SAI2_IPG_CLK>, + <&clks IMX7D_SAI2_ROOT_CLK>, + <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_CLK_DUMMY>; + clock-names = "bus", "mclk1", "mclk2", "mclk3"; + dma-names = "rx", "tx"; + dmas = <&sdma 10 24 0>, <&sdma 11 24 0>; + status = "disabled"; + }; + + sai3: sai@308c0000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx7d-sai", "fsl,imx6sx-sai"; + reg = <0x308c0000 0x10000>; + interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_SAI3_IPG_CLK>, + <&clks IMX7D_SAI3_ROOT_CLK>, + <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_CLK_DUMMY>; + clock-names = "bus", "mclk1", "mclk2", "mclk3"; + dma-names = "rx", "tx"; + dmas = <&sdma 12 24 0>, <&sdma 13 24 0>; + status = "disabled"; + }; + + flexcan1: can@30a00000 { + compatible = "fsl,imx7d-flexcan", "fsl,imx6q-flexcan"; + reg = <0x30a00000 0x10000>; + interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_CAN1_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + flexcan2: can@30a10000 { + compatible = "fsl,imx7d-flexcan", "fsl,imx6q-flexcan"; + reg = <0x30a10000 0x10000>; + interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_CAN2_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + i2c1: i2c@30a20000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-i2c", "fsl,imx21-i2c"; + reg = <0x30a20000 0x10000>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_I2C1_ROOT_CLK>; + status = "disabled"; + }; + + i2c2: i2c@30a30000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-i2c", "fsl,imx21-i2c"; + reg = <0x30a30000 0x10000>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_I2C2_ROOT_CLK>; + status = "disabled"; + }; + + i2c3: i2c@30a40000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-i2c", "fsl,imx21-i2c"; + reg = <0x30a40000 0x10000>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_I2C3_ROOT_CLK>; + status = "disabled"; + }; + + i2c4: i2c@30a50000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-i2c", "fsl,imx21-i2c"; + reg = <0x30a50000 0x10000>; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_I2C4_ROOT_CLK>; + status = "disabled"; + }; + + uart4: serial@30a60000 { + compatible = "fsl,imx7d-uart", + "fsl,imx6q-uart"; + reg = <0x30a60000 0x10000>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_UART4_ROOT_CLK>, + <&clks IMX7D_UART4_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + uart5: serial@30a70000 { + compatible = "fsl,imx7d-uart", + "fsl,imx6q-uart"; + reg = <0x30a70000 0x10000>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_UART5_ROOT_CLK>, + <&clks IMX7D_UART5_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + uart6: serial@30a80000 { + compatible = "fsl,imx7d-uart", + "fsl,imx6q-uart"; + reg = <0x30a80000 0x10000>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_UART6_ROOT_CLK>, + <&clks IMX7D_UART6_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + uart7: serial@30a90000 { + compatible = "fsl,imx7d-uart", + "fsl,imx6q-uart"; + reg = <0x30a90000 0x10000>; + interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_UART7_ROOT_CLK>, + <&clks IMX7D_UART7_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + usbotg1: usb@30b10000 { + compatible = "fsl,imx7d-usb", "fsl,imx27-usb"; + reg = <0x30b10000 0x200>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_USB_CTRL_CLK>; + fsl,usbphy = <&usbphynop1>; + fsl,usbmisc = <&usbmisc1 0>; + phy-clkgate-delay-us = <400>; + status = "disabled"; + }; + + usbh: usb@30b30000 { + compatible = "fsl,imx7d-usb", "fsl,imx27-usb"; + reg = <0x30b30000 0x200>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_USB_CTRL_CLK>; + fsl,usbphy = <&usbphynop3>; + fsl,usbmisc = <&usbmisc3 0>; + phy_type = "hsic"; + dr_mode = "host"; + phy-clkgate-delay-us = <400>; + status = "disabled"; + }; + + usbmisc1: usbmisc@30b10200 { + #index-cells = <1>; + compatible = "fsl,imx7d-usbmisc", "fsl,imx6q-usbmisc"; + reg = <0x30b10200 0x200>; + }; + + usbmisc3: usbmisc@30b30200 { + #index-cells = <1>; + compatible = "fsl,imx7d-usbmisc", "fsl,imx6q-usbmisc"; + reg = <0x30b30200 0x200>; + }; + + usbphynop1: usbphynop1 { + compatible = "usb-nop-xceiv"; + clocks = <&clks IMX7D_USB_PHY1_CLK>; + clock-names = "main_clk"; + }; + + usbphynop3: usbphynop3 { + compatible = "usb-nop-xceiv"; + clocks = <&clks IMX7D_USB_HSIC_ROOT_CLK>; + clock-names = "main_clk"; + }; + + usdhc1: usdhc@30b40000 { + compatible = "fsl,imx7d-usdhc", "fsl,imx6sl-usdhc"; + reg = <0x30b40000 0x10000>; + interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_USDHC1_ROOT_CLK>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + usdhc2: usdhc@30b50000 { + compatible = "fsl,imx7d-usdhc", "fsl,imx6sl-usdhc"; + reg = <0x30b50000 0x10000>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_USDHC2_ROOT_CLK>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + usdhc3: usdhc@30b60000 { + compatible = "fsl,imx7d-usdhc", "fsl,imx6sl-usdhc"; + reg = <0x30b60000 0x10000>; + interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_USDHC3_ROOT_CLK>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + sdma: sdma@30bd0000 { + compatible = "fsl,imx7d-sdma", "fsl,imx35-sdma"; + reg = <0x30bd0000 0x10000>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_SDMA_CORE_CLK>, + <&clks IMX7D_AHB_CHANNEL_ROOT_CLK>; + clock-names = "ipg", "ahb"; + #dma-cells = <3>; + fsl,sdma-ram-script-name = "imx/sdma/sdma-imx7d.bin"; + }; + + fec1: ethernet@30be0000 { + compatible = "fsl,imx7d-fec", "fsl,imx6sx-fec"; + reg = <0x30be0000 0x10000>; + interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_ENET_AXI_ROOT_CLK>, + <&clks IMX7D_ENET_AXI_ROOT_CLK>, + <&clks IMX7D_ENET1_TIME_ROOT_CLK>, + <&clks IMX7D_PLL_ENET_MAIN_125M_CLK>, + <&clks IMX7D_ENET_PHY_REF_ROOT_CLK>; + clock-names = "ipg", "ahb", "ptp", + "enet_clk_ref", "enet_out"; + fsl,num-tx-queues=<3>; + fsl,num-rx-queues=<3>; + status = "disabled"; + }; + }; + }; +}; diff --git a/include/dt-bindings/clock/imx7d-clock.h b/include/dt-bindings/clock/imx7d-clock.h new file mode 100644 index 0000000..a7a1a50 --- /dev/null +++ b/include/dt-bindings/clock/imx7d-clock.h @@ -0,0 +1,454 @@ +/* + * Copyright (C) 2014-2015 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + */ + +#ifndef __DT_BINDINGS_CLOCK_IMX7D_H +#define __DT_BINDINGS_CLOCK_IMX7D_H + +#define IMX7D_OSC_24M_CLK 0 +#define IMX7D_PLL_ARM_MAIN 1 +#define IMX7D_PLL_ARM_MAIN_CLK 2 +#define IMX7D_PLL_ARM_MAIN_SRC 3 +#define IMX7D_PLL_ARM_MAIN_BYPASS 4 +#define IMX7D_PLL_SYS_MAIN 5 +#define IMX7D_PLL_SYS_MAIN_CLK 6 +#define IMX7D_PLL_SYS_MAIN_SRC 7 +#define IMX7D_PLL_SYS_MAIN_BYPASS 8 +#define IMX7D_PLL_SYS_MAIN_480M 9 +#define IMX7D_PLL_SYS_MAIN_240M 10 +#define IMX7D_PLL_SYS_MAIN_120M 11 +#define IMX7D_PLL_SYS_MAIN_480M_CLK 12 +#define IMX7D_PLL_SYS_MAIN_240M_CLK 13 +#define IMX7D_PLL_SYS_MAIN_120M_CLK 14 +#define IMX7D_PLL_SYS_PFD0_392M_CLK 15 +#define IMX7D_PLL_SYS_PFD0_196M 16 +#define IMX7D_PLL_SYS_PFD0_196M_CLK 17 +#define IMX7D_PLL_SYS_PFD1_332M_CLK 18 +#define IMX7D_PLL_SYS_PFD1_166M 19 +#define IMX7D_PLL_SYS_PFD1_166M_CLK 20 +#define IMX7D_PLL_SYS_PFD2_270M_CLK 21 +#define IMX7D_PLL_SYS_PFD2_135M 22 +#define IMX7D_PLL_SYS_PFD2_135M_CLK 23 +#define IMX7D_PLL_SYS_PFD3_CLK 24 +#define IMX7D_PLL_SYS_PFD4_CLK 25 +#define IMX7D_PLL_SYS_PFD5_CLK 26 +#define IMX7D_PLL_SYS_PFD6_CLK 27 +#define IMX7D_PLL_SYS_PFD7_CLK 28 +#define IMX7D_PLL_ENET_MAIN 29 +#define IMX7D_PLL_ENET_MAIN_CLK 30 +#define IMX7D_PLL_ENET_MAIN_SRC 31 +#define IMX7D_PLL_ENET_MAIN_BYPASS 32 +#define IMX7D_PLL_ENET_MAIN_500M 33 +#define IMX7D_PLL_ENET_MAIN_250M 34 +#define IMX7D_PLL_ENET_MAIN_125M 35 +#define IMX7D_PLL_ENET_MAIN_100M 36 +#define IMX7D_PLL_ENET_MAIN_50M 37 +#define IMX7D_PLL_ENET_MAIN_40M 38 +#define IMX7D_PLL_ENET_MAIN_25M 39 +#define IMX7D_PLL_ENET_MAIN_500M_CLK 40 +#define IMX7D_PLL_ENET_MAIN_250M_CLK 41 +#define IMX7D_PLL_ENET_MAIN_125M_CLK 42 +#define IMX7D_PLL_ENET_MAIN_100M_CLK 43 +#define IMX7D_PLL_ENET_MAIN_50M_CLK 44 +#define IMX7D_PLL_ENET_MAIN_40M_CLK 45 +#define IMX7D_PLL_ENET_MAIN_25M_CLK 46 +#define IMX7D_PLL_DRAM_MAIN 47 +#define IMX7D_PLL_DRAM_MAIN_CLK 48 +#define IMX7D_PLL_DRAM_MAIN_SRC 49 +#define IMX7D_PLL_DRAM_MAIN_BYPASS 50 +#define IMX7D_PLL_DRAM_MAIN_533M 51 +#define IMX7D_PLL_DRAM_MAIN_533M_CLK 52 +#define IMX7D_PLL_AUDIO_MAIN 53 +#define IMX7D_PLL_AUDIO_MAIN_CLK 54 +#define IMX7D_PLL_AUDIO_MAIN_SRC 55 +#define IMX7D_PLL_AUDIO_MAIN_BYPASS 56 +#define IMX7D_PLL_VIDEO_MAIN_CLK 57 +#define IMX7D_PLL_VIDEO_MAIN 58 +#define IMX7D_PLL_VIDEO_MAIN_SRC 59 +#define IMX7D_PLL_VIDEO_MAIN_BYPASS 60 +#define IMX7D_USB_MAIN_480M_CLK 61 +#define IMX7D_ARM_A7_ROOT_CLK 62 +#define IMX7D_ARM_A7_ROOT_SRC 63 +#define IMX7D_ARM_A7_ROOT_CG 64 +#define IMX7D_ARM_A7_ROOT_DIV 65 +#define IMX7D_ARM_M4_ROOT_CLK 66 +#define IMX7D_ARM_M4_ROOT_SRC 67 +#define IMX7D_ARM_M4_ROOT_CG 68 +#define IMX7D_ARM_M4_ROOT_DIV 69 +#define IMX7D_ARM_M0_ROOT_CLK 70 +#define IMX7D_ARM_M0_ROOT_SRC 71 +#define IMX7D_ARM_M0_ROOT_CG 72 +#define IMX7D_ARM_M0_ROOT_DIV 73 +#define IMX7D_MAIN_AXI_ROOT_CLK 74 +#define IMX7D_MAIN_AXI_ROOT_SRC 75 +#define IMX7D_MAIN_AXI_ROOT_CG 76 +#define IMX7D_MAIN_AXI_ROOT_DIV 77 +#define IMX7D_DISP_AXI_ROOT_CLK 78 +#define IMX7D_DISP_AXI_ROOT_SRC 79 +#define IMX7D_DISP_AXI_ROOT_CG 80 +#define IMX7D_DISP_AXI_ROOT_DIV 81 +#define IMX7D_ENET_AXI_ROOT_CLK 82 +#define IMX7D_ENET_AXI_ROOT_SRC 83 +#define IMX7D_ENET_AXI_ROOT_CG 84 +#define IMX7D_ENET_AXI_ROOT_DIV 85 +#define IMX7D_NAND_USDHC_BUS_ROOT_CLK 86 +#define IMX7D_NAND_USDHC_BUS_ROOT_SRC 87 +#define IMX7D_NAND_USDHC_BUS_ROOT_CG 88 +#define IMX7D_NAND_USDHC_BUS_ROOT_DIV 89 +#define IMX7D_AHB_CHANNEL_ROOT_CLK 90 +#define IMX7D_AHB_CHANNEL_ROOT_SRC 91 +#define IMX7D_AHB_CHANNEL_ROOT_CG 92 +#define IMX7D_AHB_CHANNEL_ROOT_DIV 93 +#define IMX7D_DRAM_PHYM_ROOT_CLK 94 +#define IMX7D_DRAM_PHYM_ROOT_SRC 95 +#define IMX7D_DRAM_PHYM_ROOT_CG 96 +#define IMX7D_DRAM_PHYM_ROOT_DIV 97 +#define IMX7D_DRAM_ROOT_CLK 98 +#define IMX7D_DRAM_ROOT_SRC 99 +#define IMX7D_DRAM_ROOT_CG 100 +#define IMX7D_DRAM_ROOT_DIV 101 +#define IMX7D_DRAM_PHYM_ALT_ROOT_CLK 102 +#define IMX7D_DRAM_PHYM_ALT_ROOT_SRC 103 +#define IMX7D_DRAM_PHYM_ALT_ROOT_CG 104 +#define IMX7D_DRAM_PHYM_ALT_ROOT_DIV 105 +#define IMX7D_DRAM_ALT_ROOT_CLK 106 +#define IMX7D_DRAM_ALT_ROOT_SRC 107 +#define IMX7D_DRAM_ALT_ROOT_CG 108 +#define IMX7D_DRAM_ALT_ROOT_DIV 109 +#define IMX7D_USB_HSIC_ROOT_CLK 110 +#define IMX7D_USB_HSIC_ROOT_SRC 111 +#define IMX7D_USB_HSIC_ROOT_CG 112 +#define IMX7D_USB_HSIC_ROOT_DIV 113 +#define IMX7D_PCIE_CTRL_ROOT_CLK 114 +#define IMX7D_PCIE_CTRL_ROOT_SRC 115 +#define IMX7D_PCIE_CTRL_ROOT_CG 116 +#define IMX7D_PCIE_CTRL_ROOT_DIV 117 +#define IMX7D_PCIE_PHY_ROOT_CLK 118 +#define IMX7D_PCIE_PHY_ROOT_SRC 119 +#define IMX7D_PCIE_PHY_ROOT_CG 120 +#define IMX7D_PCIE_PHY_ROOT_DIV 121 +#define IMX7D_EPDC_PIXEL_ROOT_CLK 122 +#define IMX7D_EPDC_PIXEL_ROOT_SRC 123 +#define IMX7D_EPDC_PIXEL_ROOT_CG 124 +#define IMX7D_EPDC_PIXEL_ROOT_DIV 125 +#define IMX7D_LCDIF_PIXEL_ROOT_CLK 126 +#define IMX7D_LCDIF_PIXEL_ROOT_SRC 127 +#define IMX7D_LCDIF_PIXEL_ROOT_CG 128 +#define IMX7D_LCDIF_PIXEL_ROOT_DIV 129 +#define IMX7D_MIPI_DSI_ROOT_CLK 130 +#define IMX7D_MIPI_DSI_ROOT_SRC 131 +#define IMX7D_MIPI_DSI_ROOT_CG 132 +#define IMX7D_MIPI_DSI_ROOT_DIV 133 +#define IMX7D_MIPI_CSI_ROOT_CLK 134 +#define IMX7D_MIPI_CSI_ROOT_SRC 135 +#define IMX7D_MIPI_CSI_ROOT_CG 136 +#define IMX7D_MIPI_CSI_ROOT_DIV 137 +#define IMX7D_MIPI_DPHY_ROOT_CLK 138 +#define IMX7D_MIPI_DPHY_ROOT_SRC 139 +#define IMX7D_MIPI_DPHY_ROOT_CG 140 +#define IMX7D_MIPI_DPHY_ROOT_DIV 141 +#define IMX7D_SAI1_ROOT_CLK 142 +#define IMX7D_SAI1_ROOT_SRC 143 +#define IMX7D_SAI1_ROOT_CG 144 +#define IMX7D_SAI1_ROOT_DIV 145 +#define IMX7D_SAI2_ROOT_CLK 146 +#define IMX7D_SAI2_ROOT_SRC 147 +#define IMX7D_SAI2_ROOT_CG 148 +#define IMX7D_SAI2_ROOT_DIV 149 +#define IMX7D_SAI3_ROOT_CLK 150 +#define IMX7D_SAI3_ROOT_SRC 151 +#define IMX7D_SAI3_ROOT_CG 152 +#define IMX7D_SAI3_ROOT_DIV 153 +#define IMX7D_SPDIF_ROOT_CLK 154 +#define IMX7D_SPDIF_ROOT_SRC 155 +#define IMX7D_SPDIF_ROOT_CG 156 +#define IMX7D_SPDIF_ROOT_DIV 157 +#define IMX7D_ENET1_REF_ROOT_CLK 158 +#define IMX7D_ENET1_REF_ROOT_SRC 159 +#define IMX7D_ENET1_REF_ROOT_CG 160 +#define IMX7D_ENET1_REF_ROOT_DIV 161 +#define IMX7D_ENET1_TIME_ROOT_CLK 162 +#define IMX7D_ENET1_TIME_ROOT_SRC 163 +#define IMX7D_ENET1_TIME_ROOT_CG 164 +#define IMX7D_ENET1_TIME_ROOT_DIV 165 +#define IMX7D_ENET2_REF_ROOT_CLK 166 +#define IMX7D_ENET2_REF_ROOT_SRC 167 +#define IMX7D_ENET2_REF_ROOT_CG 168 +#define IMX7D_ENET2_REF_ROOT_DIV 169 +#define IMX7D_ENET2_TIME_ROOT_CLK 170 +#define IMX7D_ENET2_TIME_ROOT_SRC 171 +#define IMX7D_ENET2_TIME_ROOT_CG 172 +#define IMX7D_ENET2_TIME_ROOT_DIV 173 +#define IMX7D_ENET_PHY_REF_ROOT_CLK 174 +#define IMX7D_ENET_PHY_REF_ROOT_SRC 175 +#define IMX7D_ENET_PHY_REF_ROOT_CG 176 +#define IMX7D_ENET_PHY_REF_ROOT_DIV 177 +#define IMX7D_EIM_ROOT_CLK 178 +#define IMX7D_EIM_ROOT_SRC 179 +#define IMX7D_EIM_ROOT_CG 180 +#define IMX7D_EIM_ROOT_DIV 181 +#define IMX7D_NAND_ROOT_CLK 182 +#define IMX7D_NAND_ROOT_SRC 183 +#define IMX7D_NAND_ROOT_CG 184 +#define IMX7D_NAND_ROOT_DIV 185 +#define IMX7D_QSPI_ROOT_CLK 186 +#define IMX7D_QSPI_ROOT_SRC 187 +#define IMX7D_QSPI_ROOT_CG 188 +#define IMX7D_QSPI_ROOT_DIV 189 +#define IMX7D_USDHC1_ROOT_CLK 190 +#define IMX7D_USDHC1_ROOT_SRC 191 +#define IMX7D_USDHC1_ROOT_CG 192 +#define IMX7D_USDHC1_ROOT_DIV 193 +#define IMX7D_USDHC2_ROOT_CLK 194 +#define IMX7D_USDHC2_ROOT_SRC 195 +#define IMX7D_USDHC2_ROOT_CG 196 +#define IMX7D_USDHC2_ROOT_DIV 197 +#define IMX7D_USDHC3_ROOT_CLK 198 +#define IMX7D_USDHC3_ROOT_SRC 199 +#define IMX7D_USDHC3_ROOT_CG 200 +#define IMX7D_USDHC3_ROOT_DIV 201 +#define IMX7D_CAN1_ROOT_CLK 202 +#define IMX7D_CAN1_ROOT_SRC 203 +#define IMX7D_CAN1_ROOT_CG 204 +#define IMX7D_CAN1_ROOT_DIV 205 +#define IMX7D_CAN2_ROOT_CLK 206 +#define IMX7D_CAN2_ROOT_SRC 207 +#define IMX7D_CAN2_ROOT_CG 208 +#define IMX7D_CAN2_ROOT_DIV 209 +#define IMX7D_I2C1_ROOT_CLK 210 +#define IMX7D_I2C1_ROOT_SRC 211 +#define IMX7D_I2C1_ROOT_CG 212 +#define IMX7D_I2C1_ROOT_DIV 213 +#define IMX7D_I2C2_ROOT_CLK 214 +#define IMX7D_I2C2_ROOT_SRC 215 +#define IMX7D_I2C2_ROOT_CG 216 +#define IMX7D_I2C2_ROOT_DIV 217 +#define IMX7D_I2C3_ROOT_CLK 218 +#define IMX7D_I2C3_ROOT_SRC 219 +#define IMX7D_I2C3_ROOT_CG 220 +#define IMX7D_I2C3_ROOT_DIV 221 +#define IMX7D_I2C4_ROOT_CLK 222 +#define IMX7D_I2C4_ROOT_SRC 223 +#define IMX7D_I2C4_ROOT_CG 224 +#define IMX7D_I2C4_ROOT_DIV 225 +#define IMX7D_UART1_ROOT_CLK 226 +#define IMX7D_UART1_ROOT_SRC 227 +#define IMX7D_UART1_ROOT_CG 228 +#define IMX7D_UART1_ROOT_DIV 229 +#define IMX7D_UART2_ROOT_CLK 230 +#define IMX7D_UART2_ROOT_SRC 231 +#define IMX7D_UART2_ROOT_CG 232 +#define IMX7D_UART2_ROOT_DIV 233 +#define IMX7D_UART3_ROOT_CLK 234 +#define IMX7D_UART3_ROOT_SRC 235 +#define IMX7D_UART3_ROOT_CG 236 +#define IMX7D_UART3_ROOT_DIV 237 +#define IMX7D_UART4_ROOT_CLK 238 +#define IMX7D_UART4_ROOT_SRC 239 +#define IMX7D_UART4_ROOT_CG 240 +#define IMX7D_UART4_ROOT_DIV 241 +#define IMX7D_UART5_ROOT_CLK 242 +#define IMX7D_UART5_ROOT_SRC 243 +#define IMX7D_UART5_ROOT_CG 244 +#define IMX7D_UART5_ROOT_DIV 245 +#define IMX7D_UART6_ROOT_CLK 246 +#define IMX7D_UART6_ROOT_SRC 247 +#define IMX7D_UART6_ROOT_CG 248 +#define IMX7D_UART6_ROOT_DIV 249 +#define IMX7D_UART7_ROOT_CLK 250 +#define IMX7D_UART7_ROOT_SRC 251 +#define IMX7D_UART7_ROOT_CG 252 +#define IMX7D_UART7_ROOT_DIV 253 +#define IMX7D_ECSPI1_ROOT_CLK 254 +#define IMX7D_ECSPI1_ROOT_SRC 255 +#define IMX7D_ECSPI1_ROOT_CG 256 +#define IMX7D_ECSPI1_ROOT_DIV 257 +#define IMX7D_ECSPI2_ROOT_CLK 258 +#define IMX7D_ECSPI2_ROOT_SRC 259 +#define IMX7D_ECSPI2_ROOT_CG 260 +#define IMX7D_ECSPI2_ROOT_DIV 261 +#define IMX7D_ECSPI3_ROOT_CLK 262 +#define IMX7D_ECSPI3_ROOT_SRC 263 +#define IMX7D_ECSPI3_ROOT_CG 264 +#define IMX7D_ECSPI3_ROOT_DIV 265 +#define IMX7D_ECSPI4_ROOT_CLK 266 +#define IMX7D_ECSPI4_ROOT_SRC 267 +#define IMX7D_ECSPI4_ROOT_CG 268 +#define IMX7D_ECSPI4_ROOT_DIV 269 +#define IMX7D_PWM1_ROOT_CLK 270 +#define IMX7D_PWM1_ROOT_SRC 271 +#define IMX7D_PWM1_ROOT_CG 272 +#define IMX7D_PWM1_ROOT_DIV 273 +#define IMX7D_PWM2_ROOT_CLK 274 +#define IMX7D_PWM2_ROOT_SRC 275 +#define IMX7D_PWM2_ROOT_CG 276 +#define IMX7D_PWM2_ROOT_DIV 277 +#define IMX7D_PWM3_ROOT_CLK 278 +#define IMX7D_PWM3_ROOT_SRC 279 +#define IMX7D_PWM3_ROOT_CG 280 +#define IMX7D_PWM3_ROOT_DIV 281 +#define IMX7D_PWM4_ROOT_CLK 282 +#define IMX7D_PWM4_ROOT_SRC 283 +#define IMX7D_PWM4_ROOT_CG 284 +#define IMX7D_PWM4_ROOT_DIV 285 +#define IMX7D_FLEXTIMER1_ROOT_CLK 286 +#define IMX7D_FLEXTIMER1_ROOT_SRC 287 +#define IMX7D_FLEXTIMER1_ROOT_CG 288 +#define IMX7D_FLEXTIMER1_ROOT_DIV 289 +#define IMX7D_FLEXTIMER2_ROOT_CLK 290 +#define IMX7D_FLEXTIMER2_ROOT_SRC 291 +#define IMX7D_FLEXTIMER2_ROOT_CG 292 +#define IMX7D_FLEXTIMER2_ROOT_DIV 293 +#define IMX7D_SIM1_ROOT_CLK 294 +#define IMX7D_SIM1_ROOT_SRC 295 +#define IMX7D_SIM1_ROOT_CG 296 +#define IMX7D_SIM1_ROOT_DIV 297 +#define IMX7D_SIM2_ROOT_CLK 298 +#define IMX7D_SIM2_ROOT_SRC 299 +#define IMX7D_SIM2_ROOT_CG 300 +#define IMX7D_SIM2_ROOT_DIV 301 +#define IMX7D_GPT1_ROOT_CLK 302 +#define IMX7D_GPT1_ROOT_SRC 303 +#define IMX7D_GPT1_ROOT_CG 304 +#define IMX7D_GPT1_ROOT_DIV 305 +#define IMX7D_GPT2_ROOT_CLK 306 +#define IMX7D_GPT2_ROOT_SRC 307 +#define IMX7D_GPT2_ROOT_CG 308 +#define IMX7D_GPT2_ROOT_DIV 309 +#define IMX7D_GPT3_ROOT_CLK 310 +#define IMX7D_GPT3_ROOT_SRC 311 +#define IMX7D_GPT3_ROOT_CG 312 +#define IMX7D_GPT3_ROOT_DIV 313 +#define IMX7D_GPT4_ROOT_CLK 314 +#define IMX7D_GPT4_ROOT_SRC 315 +#define IMX7D_GPT4_ROOT_CG 316 +#define IMX7D_GPT4_ROOT_DIV 317 +#define IMX7D_TRACE_ROOT_CLK 318 +#define IMX7D_TRACE_ROOT_SRC 319 +#define IMX7D_TRACE_ROOT_CG 320 +#define IMX7D_TRACE_ROOT_DIV 321 +#define IMX7D_WDOG1_ROOT_CLK 322 +#define IMX7D_WDOG_ROOT_SRC 323 +#define IMX7D_WDOG_ROOT_CG 324 +#define IMX7D_WDOG_ROOT_DIV 325 +#define IMX7D_CSI_MCLK_ROOT_CLK 326 +#define IMX7D_CSI_MCLK_ROOT_SRC 327 +#define IMX7D_CSI_MCLK_ROOT_CG 328 +#define IMX7D_CSI_MCLK_ROOT_DIV 329 +#define IMX7D_AUDIO_MCLK_ROOT_CLK 330 +#define IMX7D_AUDIO_MCLK_ROOT_SRC 331 +#define IMX7D_AUDIO_MCLK_ROOT_CG 332 +#define IMX7D_AUDIO_MCLK_ROOT_DIV 333 +#define IMX7D_WRCLK_ROOT_CLK 334 +#define IMX7D_WRCLK_ROOT_SRC 335 +#define IMX7D_WRCLK_ROOT_CG 336 +#define IMX7D_WRCLK_ROOT_DIV 337 +#define IMX7D_CLKO1_ROOT_SRC 338 +#define IMX7D_CLKO1_ROOT_CG 339 +#define IMX7D_CLKO1_ROOT_DIV 340 +#define IMX7D_CLKO2_ROOT_SRC 341 +#define IMX7D_CLKO2_ROOT_CG 342 +#define IMX7D_CLKO2_ROOT_DIV 343 +#define IMX7D_MAIN_AXI_ROOT_PRE_DIV 344 +#define IMX7D_DISP_AXI_ROOT_PRE_DIV 345 +#define IMX7D_ENET_AXI_ROOT_PRE_DIV 346 +#define IMX7D_NAND_USDHC_BUS_ROOT_PRE_DIV 347 +#define IMX7D_AHB_CHANNEL_ROOT_PRE_DIV 348 +#define IMX7D_USB_HSIC_ROOT_PRE_DIV 349 +#define IMX7D_PCIE_CTRL_ROOT_PRE_DIV 350 +#define IMX7D_PCIE_PHY_ROOT_PRE_DIV 351 +#define IMX7D_EPDC_PIXEL_ROOT_PRE_DIV 352 +#define IMX7D_LCDIF_PIXEL_ROOT_PRE_DIV 353 +#define IMX7D_MIPI_DSI_ROOT_PRE_DIV 354 +#define IMX7D_MIPI_CSI_ROOT_PRE_DIV 355 +#define IMX7D_MIPI_DPHY_ROOT_PRE_DIV 356 +#define IMX7D_SAI1_ROOT_PRE_DIV 357 +#define IMX7D_SAI2_ROOT_PRE_DIV 358 +#define IMX7D_SAI3_ROOT_PRE_DIV 359 +#define IMX7D_SPDIF_ROOT_PRE_DIV 360 +#define IMX7D_ENET1_REF_ROOT_PRE_DIV 361 +#define IMX7D_ENET1_TIME_ROOT_PRE_DIV 362 +#define IMX7D_ENET2_REF_ROOT_PRE_DIV 363 +#define IMX7D_ENET2_TIME_ROOT_PRE_DIV 364 +#define IMX7D_ENET_PHY_REF_ROOT_PRE_DIV 365 +#define IMX7D_EIM_ROOT_PRE_DIV 366 +#define IMX7D_NAND_ROOT_PRE_DIV 367 +#define IMX7D_QSPI_ROOT_PRE_DIV 368 +#define IMX7D_USDHC1_ROOT_PRE_DIV 369 +#define IMX7D_USDHC2_ROOT_PRE_DIV 370 +#define IMX7D_USDHC3_ROOT_PRE_DIV 371 +#define IMX7D_CAN1_ROOT_PRE_DIV 372 +#define IMX7D_CAN2_ROOT_PRE_DIV 373 +#define IMX7D_I2C1_ROOT_PRE_DIV 374 +#define IMX7D_I2C2_ROOT_PRE_DIV 375 +#define IMX7D_I2C3_ROOT_PRE_DIV 376 +#define IMX7D_I2C4_ROOT_PRE_DIV 377 +#define IMX7D_UART1_ROOT_PRE_DIV 378 +#define IMX7D_UART2_ROOT_PRE_DIV 379 +#define IMX7D_UART3_ROOT_PRE_DIV 380 +#define IMX7D_UART4_ROOT_PRE_DIV 381 +#define IMX7D_UART5_ROOT_PRE_DIV 382 +#define IMX7D_UART6_ROOT_PRE_DIV 383 +#define IMX7D_UART7_ROOT_PRE_DIV 384 +#define IMX7D_ECSPI1_ROOT_PRE_DIV 385 +#define IMX7D_ECSPI2_ROOT_PRE_DIV 386 +#define IMX7D_ECSPI3_ROOT_PRE_DIV 387 +#define IMX7D_ECSPI4_ROOT_PRE_DIV 388 +#define IMX7D_PWM1_ROOT_PRE_DIV 389 +#define IMX7D_PWM2_ROOT_PRE_DIV 390 +#define IMX7D_PWM3_ROOT_PRE_DIV 391 +#define IMX7D_PWM4_ROOT_PRE_DIV 392 +#define IMX7D_FLEXTIMER1_ROOT_PRE_DIV 393 +#define IMX7D_FLEXTIMER2_ROOT_PRE_DIV 394 +#define IMX7D_SIM1_ROOT_PRE_DIV 395 +#define IMX7D_SIM2_ROOT_PRE_DIV 396 +#define IMX7D_GPT1_ROOT_PRE_DIV 397 +#define IMX7D_GPT2_ROOT_PRE_DIV 398 +#define IMX7D_GPT3_ROOT_PRE_DIV 399 +#define IMX7D_GPT4_ROOT_PRE_DIV 400 +#define IMX7D_TRACE_ROOT_PRE_DIV 401 +#define IMX7D_WDOG_ROOT_PRE_DIV 402 +#define IMX7D_CSI_MCLK_ROOT_PRE_DIV 403 +#define IMX7D_AUDIO_MCLK_ROOT_PRE_DIV 404 +#define IMX7D_WRCLK_ROOT_PRE_DIV 405 +#define IMX7D_CLKO1_ROOT_PRE_DIV 406 +#define IMX7D_CLKO2_ROOT_PRE_DIV 407 +#define IMX7D_DRAM_PHYM_ALT_ROOT_PRE_DIV 408 +#define IMX7D_DRAM_ALT_ROOT_PRE_DIV 409 +#define IMX7D_LVDS1_IN_CLK 410 +#define IMX7D_LVDS1_OUT_SEL 411 +#define IMX7D_LVDS1_OUT_CLK 412 +#define IMX7D_CLK_DUMMY 413 +#define IMX7D_GPT_3M_CLK 414 +#define IMX7D_OCRAM_CLK 415 +#define IMX7D_OCRAM_S_CLK 416 +#define IMX7D_WDOG2_ROOT_CLK 417 +#define IMX7D_WDOG3_ROOT_CLK 418 +#define IMX7D_WDOG4_ROOT_CLK 419 +#define IMX7D_SDMA_CORE_CLK 420 +#define IMX7D_USB1_MAIN_480M_CLK 421 +#define IMX7D_USB_CTRL_CLK 422 +#define IMX7D_USB_PHY1_CLK 423 +#define IMX7D_USB_PHY2_CLK 424 +#define IMX7D_IPG_ROOT_CLK 425 +#define IMX7D_SAI1_IPG_CLK 426 +#define IMX7D_SAI2_IPG_CLK 427 +#define IMX7D_SAI3_IPG_CLK 428 +#define IMX7D_PLL_AUDIO_TEST_DIV 429 +#define IMX7D_PLL_AUDIO_POST_DIV 430 +#define IMX7D_PLL_VIDEO_TEST_DIV 431 +#define IMX7D_PLL_VIDEO_POST_DIV 432 +#define IMX7D_MU_ROOT_CLK 433 +#define IMX7D_SEMA4_HS_ROOT_CLK 434 +#define IMX7D_PLL_DRAM_TEST_DIV 435 +#define IMX7D_ADC_ROOT_CLK 436 +#define IMX7D_CLK_ARM 437 +#define IMX7D_CKIL 438 +#define IMX7D_OCOTP_CLK 439 +#define IMX7D_CLK_END 440 +#endif /* __DT_BINDINGS_CLOCK_IMX7D_H */
Add basic dts for i.MX7D-SDB board.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de ---
V2: Drop dts file from NXP vendor tree.
arch/arm/dts/Makefile | 3 ++- arch/arm/dts/imx7d-sdb.dts | 19 +++++++++++++++++++ configs/mx7dsabresd_defconfig | 3 ++- 3 files changed, 23 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/imx7d-sdb.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 8187f65..d4eaf35 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -325,7 +325,8 @@ dtb-$(CONFIG_MX6) += imx6ull-14x14-evk.dtb \ imx6ul-isiot-nand.dtb \ imx6ul-opos6uldev.dtb
-dtb-$(CONFIG_MX7) += imx7-colibri.dtb +dtb-$(CONFIG_MX7) += imx7-colibri.dtb \ + imx7d-sdb.dtb
dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-evk.dtb
diff --git a/arch/arm/dts/imx7d-sdb.dts b/arch/arm/dts/imx7d-sdb.dts new file mode 100644 index 0000000..0378897 --- /dev/null +++ b/arch/arm/dts/imx7d-sdb.dts @@ -0,0 +1,19 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +#include "imx7d.dtsi" + +/ { + model = "Freescale i.MX7 SabreSD Board"; + compatible = "fsl,imx7d-sdb", "fsl,imx7d"; + + memory { + reg = <0x80000000 0x80000000>; + }; + +}; diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index 9541e12..5bdc638 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_MX7DSABRESD=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_VIDEO=y +CONFIG_DEFAULT_DEVICE_TREE="imx7d-sdb" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -32,6 +33,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_USB=y @@ -44,4 +46,3 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 -CONFIG_OF_LIBFDT=y
Add spi gpio node for 74LV595.
V2: New
arch/arm/dts/imx7d-sdb.dts | 35 +++++++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/arch/arm/dts/imx7d-sdb.dts b/arch/arm/dts/imx7d-sdb.dts index 0378897..3b8f1cb 100644 --- a/arch/arm/dts/imx7d-sdb.dts +++ b/arch/arm/dts/imx7d-sdb.dts @@ -16,4 +16,39 @@ reg = <0x80000000 0x80000000>; };
+ spi4 { + compatible = "spi-gpio"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spi1>; + status = "okay"; + gpio-sck = <&gpio1 13 0>; + gpio-mosi = <&gpio1 9 0>; + cs-gpios = <&gpio1 12 0>; + num-chipselects = <1>; + #address-cells = <1>; + #size-cells = <0>; + + gpio_spi: gpio_spi@0 { + compatible = "fairchild,74hc595"; + gpio-controller; + #gpio-cells = <2>; + reg = <0>; + registers-number = <1>; + registers-default = /bits/ 8 <0x74>; /* Enable PERI_3V3, SENSOR_RST_B and HDMI_RST*/ + spi-max-frequency = <100000>; + }; + }; +}; + +&iomuxc { + imx7d-sdb { + pinctrl_spi1: spi1grp { + fsl,pins = < + MX7D_PAD_GPIO1_IO09__GPIO1_IO9 0x59 + MX7D_PAD_GPIO1_IO12__GPIO1_IO12 0x59 + MX7D_PAD_GPIO1_IO13__GPIO1_IO13 0x59 + >; + }; + }; + };
Add regulator node for usb and mmc.
V2: New
arch/arm/dts/imx7d-sdb.dts | 36 ++++++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/arch/arm/dts/imx7d-sdb.dts b/arch/arm/dts/imx7d-sdb.dts index 3b8f1cb..df9dfb9 100644 --- a/arch/arm/dts/imx7d-sdb.dts +++ b/arch/arm/dts/imx7d-sdb.dts @@ -38,6 +38,42 @@ spi-max-frequency = <100000>; }; }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_usb_otg1_vbus: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "usb_otg1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 5 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_usb_otg2_vbus: regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "usb_otg2_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 7 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_sd1_vmmc: regulator@3 { + compatible = "regulator-fixed"; + regulator-name = "VDD_SD1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio5 2 GPIO_ACTIVE_HIGH>; + startup-delay-us = <200000>; + enable-active-high; + }; + }; };
&iomuxc {
Add i2c support.
V2: New
arch/arm/dts/imx7d-sdb.dts | 146 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 146 insertions(+)
diff --git a/arch/arm/dts/imx7d-sdb.dts b/arch/arm/dts/imx7d-sdb.dts index df9dfb9..7fab6f2 100644 --- a/arch/arm/dts/imx7d-sdb.dts +++ b/arch/arm/dts/imx7d-sdb.dts @@ -85,6 +85,152 @@ MX7D_PAD_GPIO1_IO13__GPIO1_IO13 0x59 >; }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX7D_PAD_I2C1_SDA__I2C1_SDA 0x4000007f + MX7D_PAD_I2C1_SCL__I2C1_SCL 0x4000007f + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX7D_PAD_I2C2_SDA__I2C2_SDA 0x4000007f + MX7D_PAD_I2C2_SCL__I2C2_SCL 0x4000007f + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX7D_PAD_I2C3_SDA__I2C3_SDA 0x4000007f + MX7D_PAD_I2C3_SCL__I2C3_SCL 0x4000007f + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX7D_PAD_SAI1_RX_BCLK__I2C4_SDA 0x4000007f + MX7D_PAD_SAI1_RX_SYNC__I2C4_SCL 0x4000007f + >; + }; }; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + pmic: pfuze3000@08 { + compatible = "fsl,pfuze3000"; + reg = <0x08>; + + regulators { + sw1a_reg: sw1a { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + /* use sw1c_reg to align with pfuze100/pfuze200 */ + sw1c_reg: sw1b { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1475000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw2_reg: sw2 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1850000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3a_reg: sw3 { + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1650000>; + regulator-boot-on; + regulator-always-on; + }; + + swbst_reg: swbst { + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + vgen1_reg: vldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen2_reg: vldo2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + regulator-always-on; + }; + + vgen3_reg: vccsd { + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen4_reg: v33 { + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen5_reg: vldo3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen6_reg: vldo4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; +};
+&i2c4 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; };
Add usdhc support
Signed-off-by: Peng Fan peng.fan@nxp.com ---
V2: New
arch/arm/dts/imx7d-sdb.dts | 73 ++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 73 insertions(+)
diff --git a/arch/arm/dts/imx7d-sdb.dts b/arch/arm/dts/imx7d-sdb.dts index 7fab6f2..85b83c3 100644 --- a/arch/arm/dts/imx7d-sdb.dts +++ b/arch/arm/dts/imx7d-sdb.dts @@ -113,6 +113,55 @@ MX7D_PAD_SAI1_RX_SYNC__I2C4_SCL 0x4000007f >; }; + + pinctrl_usdhc1_gpio: usdhc1_gpiogrp { + fsl,pins = < + MX7D_PAD_SD1_CD_B__GPIO5_IO0 0x59 /* CD */ + MX7D_PAD_SD1_WP__GPIO5_IO1 0x59 /* WP */ + MX7D_PAD_SD1_RESET_B__GPIO5_IO2 0x59 /* vmmc */ + MX7D_PAD_GPIO1_IO08__SD1_VSELECT 0x59 /* VSELECT */ + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX7D_PAD_SD1_CMD__SD1_CMD 0x59 + MX7D_PAD_SD1_CLK__SD1_CLK 0x19 + MX7D_PAD_SD1_DATA0__SD1_DATA0 0x59 + MX7D_PAD_SD1_DATA1__SD1_DATA1 0x59 + MX7D_PAD_SD1_DATA2__SD1_DATA2 0x59 + MX7D_PAD_SD1_DATA3__SD1_DATA3 0x59 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX7D_PAD_SD2_CMD__SD2_CMD 0x59 + MX7D_PAD_SD2_CLK__SD2_CLK 0x19 + MX7D_PAD_SD2_DATA0__SD2_DATA0 0x59 + MX7D_PAD_SD2_DATA1__SD2_DATA1 0x59 + MX7D_PAD_SD2_DATA2__SD2_DATA2 0x59 + MX7D_PAD_SD2_DATA3__SD2_DATA3 0x59 + MX7D_PAD_ECSPI2_MOSI__GPIO4_IO21 0x19 /* WL_REG_ON */ + MX7D_PAD_ECSPI2_SCLK__GPIO4_IO20 0x19 /* WL_HOST_WAKE */ + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX7D_PAD_SD3_CMD__SD3_CMD 0x59 + MX7D_PAD_SD3_CLK__SD3_CLK 0x19 + MX7D_PAD_SD3_DATA0__SD3_DATA0 0x59 + MX7D_PAD_SD3_DATA1__SD3_DATA1 0x59 + MX7D_PAD_SD3_DATA2__SD3_DATA2 0x59 + MX7D_PAD_SD3_DATA3__SD3_DATA3 0x59 + MX7D_PAD_SD3_DATA4__SD3_DATA4 0x59 + MX7D_PAD_SD3_DATA5__SD3_DATA5 0x59 + MX7D_PAD_SD3_DATA6__SD3_DATA6 0x59 + MX7D_PAD_SD3_DATA7__SD3_DATA7 0x59 + MX7D_PAD_SD3_STROBE__SD3_STROBE 0x19 + >; + }; }; };
@@ -234,3 +283,27 @@ pinctrl-0 = <&pinctrl_i2c4>; status = "okay"; }; + +&usdhc1 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>, <&pinctrl_usdhc1_gpio>; + cd-gpios = <&gpio5 0 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio5 1 GPIO_ACTIVE_HIGH>; + vmmc-supply = <®_sd1_vmmc>; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>; + non-removable; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + bus-width = <8>; + non-removable; + status = "okay"; +};
Add the Kconfig entry for SOFT_SPI which uses gpio to simulate the SPI signals. We use it for accessing 74x164 on some i.MX boards.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Jagan Teki jagan@openedev.com Cc: Stefano Babic sbabic@denx.de ---
V2: None
drivers/spi/Kconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index f3f7dbe..bef864f 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -197,6 +197,12 @@ config OMAP3_SPI
endif # if DM_SPI
+config SOFT_SPI + bool "Soft SPI driver" + help + Enable Soft SPI driver. This driver is to use GPIO simulate + the SPI protocol. + config FSL_ESPI bool "Freescale eSPI driver" help
V2: None
endif # if DM_SPI
+config SOFT_SPI
Did you move this for dm-driven file? since we've two files with same config
help
the SPI protocol.
If possible please write few lines about this
thanks!
V2: None
endif # if DM_SPI
+config SOFT_SPI
This config is for dm and non-dm both.
help
the SPI protocol.
I understand this two line help message will trigger check patch warning, but I think this is clear to tell user what this option is.
Thanks, Peng.
thanks!
Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Make oe-pins optional because some boards have fixed it to enable.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Stefano Babic sbabic@denx.de ---
V2: None
drivers/gpio/74x164_gpio.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/gpio/74x164_gpio.c b/drivers/gpio/74x164_gpio.c index 750eedf..53a639a 100644 --- a/drivers/gpio/74x164_gpio.c +++ b/drivers/gpio/74x164_gpio.c @@ -156,8 +156,7 @@ static int gen_74x164_probe(struct udevice *dev) ret = gpio_request_by_name(dev, "oe-gpios", 0, &priv->oe, GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); if (ret) { - dev_err(dev, "No oe-pins property\n"); - goto free_buf; + dev_dbg(dev, "No oe-pins property\n"); }
uc_priv->bank_name = str;
V2: None
Enable more DM drivers. The imx I2C/MMC DM drivers needs DM_GPIO enabled. The 74x164 drivers needs SOFT_SPI and DM_GPIO enabled. So needs to enable them together.
V2: None
board/freescale/mx7dsabresd/mx7dsabresd.c | 288 ++---------------------------- configs/mx7dsabresd_defconfig | 21 +++ include/configs/mx7dsabresd.h | 11 -- 3 files changed, 37 insertions(+), 283 deletions(-)
diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index 6ccdd4b..d6ba364 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -31,17 +31,11 @@ DECLARE_GLOBAL_DATA_PTR; #define UART_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | \ PAD_CTL_PUS_PU100KOHM | PAD_CTL_HYS)
-#define USDHC_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ - PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU47KOHM) - #define ENET_PAD_CTRL (PAD_CTL_PUS_PU100KOHM | PAD_CTL_DSE_3P3V_49OHM) #define ENET_PAD_CTRL_MII (PAD_CTL_DSE_3P3V_32OHM)
#define ENET_RX_PAD_CTRL (PAD_CTL_PUS_PU100KOHM | PAD_CTL_DSE_3P3V_49OHM)
-#define I2C_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ - PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU100KOHM) - #define LCD_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_PUS_PU100KOHM | \ PAD_CTL_DSE_3P3V_49OHM)
@@ -54,23 +48,8 @@ DECLARE_GLOBAL_DATA_PTR; (PAD_CTL_HYS | PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_SRE_FAST)
#define NAND_PAD_READY0_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_PUS_PU5KOHM) -#ifdef CONFIG_SYS_I2C_MXC -#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) -/* I2C1 for PMIC */ -static struct i2c_pads_info i2c_pad_info1 = { - .scl = { - .i2c_mode = MX7D_PAD_I2C1_SCL__I2C1_SCL | PC, - .gpio_mode = MX7D_PAD_I2C1_SCL__GPIO4_IO8 | PC, - .gp = IMX_GPIO_NR(4, 8), - }, - .sda = { - .i2c_mode = MX7D_PAD_I2C1_SDA__I2C1_SDA | PC, - .gpio_mode = MX7D_PAD_I2C1_SDA__GPIO4_IO9 | PC, - .gp = IMX_GPIO_NR(4, 9), - }, -}; -#endif
+#ifdef CONFIG_MXC_SPI static iomux_v3_cfg_t const ecspi3_pads[] = { MX7D_PAD_SAI2_RX_DATA__ECSPI3_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), MX7D_PAD_SAI2_TX_SYNC__ECSPI3_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), @@ -87,6 +66,7 @@ static void setup_spi(void) { imx_iomux_v3_setup_multiple_pads(ecspi3_pads, ARRAY_SIZE(ecspi3_pads)); } +#endif
int dram_init(void) { @@ -104,34 +84,6 @@ static iomux_v3_cfg_t const uart1_pads[] = { MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), };
-static iomux_v3_cfg_t const usdhc1_pads[] = { - MX7D_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD1_DATA0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD1_DATA1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD1_DATA2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD1_DATA3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - - MX7D_PAD_SD1_CD_B__GPIO5_IO0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD1_RESET_B__GPIO5_IO2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), -}; - -static iomux_v3_cfg_t const usdhc3_emmc_pads[] = { - MX7D_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_STROBE__SD3_STROBE | MUX_PAD_CTRL(USDHC_PAD_CTRL), - - MX7D_PAD_SD3_RESET_B__GPIO6_IO11 | MUX_PAD_CTRL(USDHC_PAD_CTRL), -}; - static iomux_v3_cfg_t const usb_otg1_pads[] = { MX7D_PAD_GPIO1_IO05__USB_OTG1_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), }; @@ -140,94 +92,6 @@ static iomux_v3_cfg_t const usb_otg2_pads[] = { MX7D_PAD_UART3_CTS_B__USB_OTG2_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), };
-#define IOX_SDI IMX_GPIO_NR(1, 9) -#define IOX_STCP IMX_GPIO_NR(1, 12) -#define IOX_SHCP IMX_GPIO_NR(1, 13) - -static iomux_v3_cfg_t const iox_pads[] = { - /* IOX_SDI */ - MX7D_PAD_GPIO1_IO09__GPIO1_IO9 | MUX_PAD_CTRL(NO_PAD_CTRL), - /* IOX_STCP */ - MX7D_PAD_GPIO1_IO12__GPIO1_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL), - /* IOX_SHCP */ - MX7D_PAD_GPIO1_IO13__GPIO1_IO13 | MUX_PAD_CTRL(NO_PAD_CTRL), -}; - -/* - * PCIE_DIS_B --> Q0 - * PCIE_RST_B --> Q1 - * HDMI_RST_B --> Q2 - * PERI_RST_B --> Q3 - * SENSOR_RST_B --> Q4 - * ENET_RST_B --> Q5 - * PERI_3V3_EN --> Q6 - * LCD_PWR_EN --> Q7 - */ -enum qn { - PCIE_DIS_B, - PCIE_RST_B, - HDMI_RST_B, - PERI_RST_B, - SENSOR_RST_B, - ENET_RST_B, - PERI_3V3_EN, - LCD_PWR_EN, -}; - -enum qn_func { - qn_reset, - qn_enable, - qn_disable, -}; - -enum qn_level { - qn_low = 0, - qn_high = 1, -}; - -static enum qn_level seq[3][2] = { - {0, 1}, {1, 1}, {0, 0} -}; - -static enum qn_func qn_output[8] = { - qn_disable, qn_reset, qn_reset, qn_reset, qn_reset, qn_reset, qn_enable, - qn_disable -}; - -static void iox74lv_init(void) -{ - int i; - - for (i = 7; i >= 0; i--) { - gpio_direction_output(IOX_SHCP, 0); - gpio_direction_output(IOX_SDI, seq[qn_output[i]][0]); - udelay(500); - gpio_direction_output(IOX_SHCP, 1); - udelay(500); - } - - gpio_direction_output(IOX_STCP, 0); - udelay(500); - /* - * shift register will be output to pins - */ - gpio_direction_output(IOX_STCP, 1); - - for (i = 7; i >= 0; i--) { - gpio_direction_output(IOX_SHCP, 0); - gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); - udelay(500); - gpio_direction_output(IOX_SHCP, 1); - udelay(500); - } - gpio_direction_output(IOX_STCP, 0); - udelay(500); - /* - * shift register will be output to pins - */ - gpio_direction_output(IOX_STCP, 1); -}; - #ifdef CONFIG_NAND_MXS static iomux_v3_cfg_t const gpmi_pads[] = { MX7D_PAD_SD3_DATA0__NAND_DATA00 | MUX_PAD_CTRL(NAND_PAD_CTRL), @@ -306,11 +170,13 @@ static int setup_lcd(void) imx_iomux_v3_setup_multiple_pads(pwm_pads, ARRAY_SIZE(pwm_pads));
/* Reset LCD */ + gpio_request(IMX_GPIO_NR(3, 4), "lcd reset"); gpio_direction_output(IMX_GPIO_NR(3, 4) , 0); udelay(500); gpio_direction_output(IMX_GPIO_NR(3, 4) , 1);
/* Set Brightness to high */ + gpio_request(IMX_GPIO_NR(1, 1), "lcd backlight"); gpio_direction_output(IMX_GPIO_NR(1, 1) , 1);
return 0; @@ -346,17 +212,6 @@ static void setup_iomux_uart(void) imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); }
-#ifdef CONFIG_FSL_ESDHC - -#define USDHC1_CD_GPIO IMX_GPIO_NR(5, 0) -#define USDHC1_PWR_GPIO IMX_GPIO_NR(5, 2) -#define USDHC3_PWR_GPIO IMX_GPIO_NR(6, 11) - -static struct fsl_esdhc_cfg usdhc_cfg[3] = { - {USDHC1_BASE_ADDR, 0, 4}, - {USDHC3_BASE_ADDR}, -}; - int board_mmc_get_env_dev(int devno) { if (devno == 2) @@ -365,7 +220,7 @@ int board_mmc_get_env_dev(int devno) return devno; }
-static int mmc_map_to_kernel_blk(int dev_no) +int mmc_map_to_kernel_blk(int dev_no) { if (dev_no == 1) dev_no++; @@ -373,102 +228,6 @@ static int mmc_map_to_kernel_blk(int dev_no) return dev_no; }
-int board_mmc_getcd(struct mmc *mmc) -{ - struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; - int ret = 0; - - switch (cfg->esdhc_base) { - case USDHC1_BASE_ADDR: - ret = !gpio_get_value(USDHC1_CD_GPIO); - break; - case USDHC3_BASE_ADDR: - ret = 1; /* Assume uSDHC3 emmc is always present */ - break; - } - - return ret; -} - -int board_mmc_init(bd_t *bis) -{ - int i, ret; - /* - * According to the board_mmc_init() the following map is done: - * (U-Boot device node) (Physical Port) - * mmc0 USDHC1 - * mmc2 USDHC3 (eMMC) - */ - for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { - switch (i) { - case 0: - imx_iomux_v3_setup_multiple_pads( - usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); - gpio_request(USDHC1_CD_GPIO, "usdhc1_cd"); - gpio_direction_input(USDHC1_CD_GPIO); - gpio_request(USDHC1_PWR_GPIO, "usdhc1_pwr"); - gpio_direction_output(USDHC1_PWR_GPIO, 0); - udelay(500); - gpio_direction_output(USDHC1_PWR_GPIO, 1); - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); - break; - case 1: - imx_iomux_v3_setup_multiple_pads( - usdhc3_emmc_pads, ARRAY_SIZE(usdhc3_emmc_pads)); - gpio_request(USDHC3_PWR_GPIO, "usdhc3_pwr"); - gpio_direction_output(USDHC3_PWR_GPIO, 0); - udelay(500); - gpio_direction_output(USDHC3_PWR_GPIO, 1); - usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - break; - default: - printf("Warning: you configured more USDHC controllers" - "(%d) than supported by the board\n", i + 1); - return -EINVAL; - } - - ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); - if (ret) - return ret; - } - - return 0; -} - -static int check_mmc_autodetect(void) -{ - char *autodetect_str = getenv("mmcautodetect"); - - if ((autodetect_str != NULL) && - (strcmp(autodetect_str, "yes") == 0)) { - return 1; - } - - return 0; -} - -static void mmc_late_init(void) -{ - char cmd[32]; - char mmcblk[32]; - u32 dev_no = mmc_get_env_dev(); - - if (!check_mmc_autodetect()) - return; - - setenv_ulong("mmcdev", dev_no); - - /* Set mmcblk env */ - sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", - mmc_map_to_kernel_blk(dev_no)); - setenv("mmcroot", mmcblk); - - sprintf(cmd, "mmc dev %d", dev_no); - run_command(cmd, 0); -} - -#endif - #ifdef CONFIG_FEC_MXC int board_eth_init(bd_t *bis) { @@ -539,7 +298,6 @@ int board_early_init_f(void) { setup_iomux_uart();
- setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); imx_iomux_v3_setup_multiple_pads(usb_otg1_pads, ARRAY_SIZE(usb_otg1_pads)); imx_iomux_v3_setup_multiple_pads(usb_otg2_pads, @@ -553,10 +311,6 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- imx_iomux_v3_setup_multiple_pads(iox_pads, ARRAY_SIZE(iox_pads)); - - iox74lv_init(); - #ifdef CONFIG_FEC_MXC setup_fec(); #endif @@ -580,29 +334,23 @@ int board_init(void) return 0; }
-#ifdef CONFIG_POWER -#define I2C_PMIC 0 +#ifdef CONFIG_DM_PMIC int power_init_board(void) { - struct pmic *p; - int ret; - unsigned int reg, rev_id; + struct udevice *dev; + int ret, dev_id, rev_id;
- ret = power_pfuze3000_init(I2C_PMIC); - if (ret) + ret = pmic_get("pfuze3000", &dev); + if (ret == -ENODEV) + return 0; + if (ret != 0) return ret;
- p = pmic_get("PFUZE3000"); - ret = pmic_probe(p); - if (ret) - return ret; - - pmic_reg_read(p, PFUZE3000_DEVICEID, ®); - pmic_reg_read(p, PFUZE3000_REVID, &rev_id); - printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", reg, rev_id); + dev_id = pmic_reg_read(dev, PFUZE3000_DEVICEID); + rev_id = pmic_reg_read(dev, PFUZE3000_REVID); + printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", dev_id, rev_id);
- /* disable Low Power Mode during standby mode */ - pmic_reg_write(p, PFUZE3000_LDOGCTL, 0x1); + pmic_clrsetbits(dev, PFUZE3000_LDOGCTL, 0, 1);
return 0; } @@ -612,10 +360,6 @@ int board_late_init(void) { struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR;
-#ifdef CONFIG_ENV_IS_IN_MMC - mmc_late_init(); -#endif - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads));
set_wdog_reset(wdog); diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index 5bdc638..7ab65dc 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -29,13 +29,33 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +# CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y +CONFIG_DM_GPIO=y +CONFIG_DM_74X164=y +CONFIG_DM_I2C=y +CONFIG_DM_MMC=y +# CONFIG_DM_MMC_OPS is not set +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SPI=y +CONFIG_SOFT_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y @@ -46,3 +66,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_ERRNO_STR=y diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 81d769f..840a220 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -34,20 +34,12 @@ /* MMC Config*/ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
-/* PMIC */ -#define CONFIG_POWER -#define CONFIG_POWER_I2C -#define CONFIG_POWER_PFUZE3000 -#define CONFIG_POWER_PFUZE3000_I2C_ADDR 0x08 - #undef CONFIG_BOOTM_NETBSD #undef CONFIG_BOOTM_PLAN9 #undef CONFIG_BOOTM_RTEMS
/* I2C configs */ -#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ #define CONFIG_SYS_I2C_SPEED 100000
#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ @@ -197,9 +189,6 @@ #define CONFIG_ENV_SIZE SZ_8K #define CONFIG_ENV_IS_IN_MMC
-/* MXC SPI driver support */ -#define CONFIG_MXC_SPI - /* * If want to use nand, define CONFIG_NAND_MXS and rework board * to support nand, since emmc has pin conflicts with nand
Hi Peng,
V2: None
This does not patch mx7dsabresd_secure_defconfig, that results then broken. I have just fixed in my local branch and I send a patch for it (I can just test build).
Regards, Stefano
Reset ENET_RST_B to make ENET function stable. Since DM_GPIO enabled, we use "gpio_spi@0_5" which corresponds to ENET_RST_B.
V2: None
board/freescale/mx7dsabresd/mx7dsabresd.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index d6ba364..f7a5f0d 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -232,6 +232,23 @@ int mmc_map_to_kernel_blk(int dev_no) int board_eth_init(bd_t *bis) { int ret; + unsigned int gpio; + + ret = gpio_lookup_name("gpio_spi@0_5", NULL, NULL, &gpio); + if (ret) { + printf("GPIO: 'gpio_spi@0_5' not found\n"); + return -ENODEV; + } + + ret = gpio_request(gpio, "fec_rst"); + if (ret && ret != -EBUSY) { + printf("gpio: requesting pin %u failed\n", gpio); + return ret; + } + + gpio_direction_output(gpio, 0); + udelay(500); + gpio_direction_output(gpio, 1);
setup_iomux_fec();
Switch to use DM USB.
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/mx7dsabresd/mx7dsabresd.c | 25 ------------------------- configs/mx7dsabresd_defconfig | 1 + include/configs/mx7dsabresd.h | 3 --- 3 files changed, 1 insertion(+), 28 deletions(-)
diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index f7a5f0d..ecea5a5 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -23,8 +23,6 @@ #include <i2c.h> #include <asm/imx-common/mxc_i2c.h> #include <asm/arch/crm_regs.h> -#include <usb.h> -#include <usb/ehci-ci.h>
@@ -84,14 +82,6 @@ static iomux_v3_cfg_t const uart1_pads[] = { MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), };
-static iomux_v3_cfg_t const usb_otg1_pads[] = { - MX7D_PAD_GPIO1_IO05__USB_OTG1_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), -}; - -static iomux_v3_cfg_t const usb_otg2_pads[] = { - MX7D_PAD_UART3_CTS_B__USB_OTG2_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), -}; - #ifdef CONFIG_NAND_MXS static iomux_v3_cfg_t const gpmi_pads[] = { MX7D_PAD_SD3_DATA0__NAND_DATA00 | MUX_PAD_CTRL(NAND_PAD_CTRL), @@ -315,11 +305,6 @@ int board_early_init_f(void) { setup_iomux_uart();
- imx_iomux_v3_setup_multiple_pads(usb_otg1_pads, - ARRAY_SIZE(usb_otg1_pads)); - imx_iomux_v3_setup_multiple_pads(usb_otg2_pads, - ARRAY_SIZE(usb_otg2_pads)); - return 0; }
@@ -403,13 +388,3 @@ int checkboard(void)
return 0; } - -#ifdef CONFIG_USB_EHCI_MX7 -int board_usb_phy_mode(int port) -{ - if (port == 0) - return USB_INIT_DEVICE; - else - return USB_INIT_HOST; -} -#endif diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index 7ab65dc..2405dd1 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -57,6 +57,7 @@ CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SPI=y CONFIG_SOFT_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_STORAGE=y diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 840a220..41a6006 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -221,12 +221,9 @@ #define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC1 */
/* USB Configs */ -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_MAX_CONTROLLER_COUNT 2
#define CONFIG_IMX_THERMAL
Add board revision check
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/mx7dsabresd/mx7dsabresd.c | 59 ++++++++++++++++++++++++++++++- 1 file changed, 58 insertions(+), 1 deletion(-)
diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index ecea5a5..07392fa 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -82,6 +82,48 @@ static iomux_v3_cfg_t const uart1_pads[] = { MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), };
+#define BOARD_REV_C 0x300 +#define BOARD_REV_B 0x200 +#define BOARD_REV_A 0x100 + +static int mx7sabre_rev(void) +{ + /* + * Get Board ID information from OCOTP_GP1[15:8] + * i.MX7D SDB RevA: 0x41 + * i.MX7D SDB RevB: 0x42 + */ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[14]; + int reg = readl(&bank->fuse_regs[0]); + int ret; + + if (reg != 0) { + switch (reg >> 8 & 0x0F) { + case 0x3: + ret = BOARD_REV_C; + break; + case 0x02: + ret = BOARD_REV_B; + break; + case 0x01: + default: + ret = BOARD_REV_A; + break; + } + } else { + /* If the gp1 fuse is not burn, we have to use TO rev for the board rev */ + if (is_soc_rev(CHIP_REV_1_0)) + ret = BOARD_REV_A; + else if (is_soc_rev(CHIP_REV_1_1)) + ret = BOARD_REV_B; + else + ret = BOARD_REV_C; + } + + return ret; +} + #ifdef CONFIG_NAND_MXS static iomux_v3_cfg_t const gpmi_pads[] = { MX7D_PAD_SD3_DATA0__NAND_DATA00 | MUX_PAD_CTRL(NAND_PAD_CTRL), @@ -377,14 +419,29 @@ int board_late_init(void)
int checkboard(void) { + int rev = mx7sabre_rev(); char *mode; + char *revname;
if (IS_ENABLED(CONFIG_ARMV7_BOOT_SEC_DEFAULT)) mode = "secure"; else mode = "non-secure";
- printf("Board: i.MX7D SABRESD in %s mode\n", mode); + switch (rev) { + case BOARD_REV_C: + revname = "C"; + break; + case BOARD_REV_B: + revname = "B"; + break; + case BOARD_REV_A: + default: + revname = "A"; + break; + } + + printf("Board: i.MX7D SABRESD Rev%s in %s mode\n", revname, mode);
return 0; }
Isn't this versioning scheme shared with other NXP boards? If so, it would be better to put this in common code.
Hi Fabio,
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: Monday, April 17, 2017 11:00 PM To: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de; U-Boot-Denx u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH V2 12/12] imx: mx7dsabresd: add board revision check
I prefer to keep the code here. There are board revision fuse for the boards from NXP, but this is not always true, I think.
Thanks, Peng.
Hi Peng,
On 18/04/2017 02:54, Peng Fan wrote:
Hi Fabio,
Anyway, there is "quite" same code for mx6 sabre:
static int mx6sabre_rev(void) { /* * Get Board ID information from OCOTP_GP1[15:8] * i.MX6Q ARD RevA: 0x01 * i.MX6Q ARD RevB: 0x02 */ struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; struct fuse_bank *bank = &ocotp->bank[4]; struct fuse_bank4_regs *fuse = (struct fuse_bank4_regs *)bank->fuse_regs; int reg = readl(&fuse->gp1); int ret;
switch (reg >> 8 & 0x0F) { case 0x02: ret = BOARD_REV_B; break; case 0x01: default:
And the version number is simple an integer and we do not need to add defines - if we simply returns the read value (1,2,3,..), the code works even with future versions. Are you sure that this is not at least "sabre common code " ?
Regards, Stefano
Hi Stefano,
-----Original Message----- From: Stefano Babic [mailto:sbabic@denx.de] Sent: Thursday, May 11, 2017 7:33 PM To: Peng Fan peng.fan@nxp.com; Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de; U-Boot-Denx u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH V2 12/12] imx: mx7dsabresd: add board revision check
Hi Peng,
Hi Fabio,
Could I use a follow up patch to move the revision check to a common place? I would not send a whole V3 patch set if no more comments.
Thanks, Peng.
Regards, Stefano
========= DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de ============================================================ =========
Hi Peng,
Hi Fabio,
Patches 1..11 are free of comments. I am merging them and I will send PR to Tom for inclusion after my build test. I will just let this last one out.
Regards, Stefano
-----Original Message----- From: Stefano Babic [mailto:sbabic@denx.de] Sent: Thursday, May 18, 2017 4:20 PM To: Peng Fan peng.fan@nxp.com; Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de; U-Boot-Denx u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH V2 12/12] imx: mx7dsabresd: add board revision check
Hi Peng,
Hi Stefano,
Hi Fabio,
It is ok for me to let this out. Thanks.
Thanks, Peng.
Regards, Stefano
ok - just check with patch I send today to fix the "secure" variant, then I could insert this to my PR.
Thanks, Stefano
Sync with Linux commit 308ac756("Merge tag 'gpio-v4.11-3'").
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefan Agner stefan.agner@toradex.com Cc: Stefano Babic sbabic@denx.de
V2: remove imx7.dtsi
Reviewed-by: Stefano Babic sbabic@denx.de
Regards, Stefano
arch/arm/dts/imx7-colibri.dts | 10 +- arch/arm/dts/imx7.dtsi | 194 ------- arch/arm/dts/imx7d-pinfunc.h | 111 ++-- arch/arm/dts/imx7d.dtsi | 140 +++++ arch/arm/dts/imx7s.dtsi | 999 ++++++++++++++++++++++++++++++++ include/dt-bindings/clock/imx7d-clock.h | 454 +++++++++++++++ 6 files changed, 1657 insertions(+), 251 deletions(-) delete mode 100644 arch/arm/dts/imx7.dtsi create mode 100644 arch/arm/dts/imx7d.dtsi create mode 100644 arch/arm/dts/imx7s.dtsi create mode 100644 include/dt-bindings/clock/imx7d-clock.h
diff --git a/arch/arm/dts/imx7-colibri.dts b/arch/arm/dts/imx7-colibri.dts index cbef5d5..f6c2105 100644 --- a/arch/arm/dts/imx7-colibri.dts +++ b/arch/arm/dts/imx7-colibri.dts @@ -6,7 +6,7 @@
/dts-v1/; #include <dt-bindings/gpio/gpio.h> -#include "imx7.dtsi" +#include "imx7d.dtsi"
/ { model = "Toradex Colibri iMX7S/D"; @@ -83,15 +83,15 @@ &iomuxc_lpsr { pinctrl_i2c1: i2c1-grp { fsl,pins = <
MX7D_PAD_GPIO1_IO05__I2C1_SDA 0x4000007f
MX7D_PAD_GPIO1_IO04__I2C1_SCL 0x4000007f
MX7D_PAD_LPSR_GPIO1_IO05__I2C1_SDA 0x4000007f
MX7D_PAD_LPSR_GPIO1_IO04__I2C1_SCL 0x4000007f
pinctrl_i2c1_gpio: i2c1-gpio-grp { fsl,pins = <
MX7D_PAD_GPIO1_IO05__GPIO1_IO5 0x4000007f
MX7D_PAD_GPIO1_IO04__GPIO1_IO4 0x4000007f
MX7D_PAD_LPSR_GPIO1_IO05__GPIO1_IO5 0x4000007f
MX7D_PAD_LPSR_GPIO1_IO04__GPIO1_IO4 0x4000007f
;};}; diff --git a/arch/arm/dts/imx7.dtsi b/arch/arm/dts/imx7.dtsi deleted file mode 100644 index 755cc46..0000000 --- a/arch/arm/dts/imx7.dtsi +++ /dev/null @@ -1,194 +0,0 @@ -/*
- Copyright 2016 Toradex AG
- SPDX-License-Identifier: GPL-2.0+ or X11
-#include "imx7d-pinfunc.h" -#include "skeleton.dtsi"
- aliases {
gpio0 = &gpio1;
gpio1 = &gpio2;
gpio2 = &gpio3;
gpio3 = &gpio4;
gpio4 = &gpio5;
gpio5 = &gpio6;
gpio6 = &gpio7;
i2c0 = &i2c1;
i2c1 = &i2c2;
i2c2 = &i2c3;
i2c3 = &i2c4;
serial0 = &uart1;
serial1 = &uart2;
serial2 = &uart3;
serial3 = &uart4;
serial4 = &uart5;
serial5 = &uart6;
serial6 = &uart7;
- soc {
#size-cells = <1>;
ranges;
aips1: aips-bus@30000000 {
compatible = "fsl,aips-bus", "simple-bus";
#size-cells = <1>;
reg = <0x30000000 0x400000>;
ranges;
gpio1: gpio@30200000 {
compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio";
reg = <0x30200000 0x10000>;
gpio-controller;
#gpio-cells = <2>;
gpio2: gpio@30210000 {
reg = <0x30210000 0x10000>;
gpio-controller;
#gpio-cells = <2>;
gpio3: gpio@30220000 {
reg = <0x30220000 0x10000>;
gpio-controller;
#gpio-cells = <2>;
gpio4: gpio@30230000 {
reg = <0x30230000 0x10000>;
gpio-controller;
#gpio-cells = <2>;
gpio5: gpio@30240000 {
reg = <0x30240000 0x10000>;
gpio-controller;
#gpio-cells = <2>;
gpio6: gpio@30250000 {
reg = <0x30250000 0x10000>;
gpio-controller;
#gpio-cells = <2>;
gpio7: gpio@30260000 {
reg = <0x30260000 0x10000>;
gpio-controller;
#gpio-cells = <2>;
iomuxc_lpsr: iomuxc-lpsr@302c0000 {
compatible = "fsl,imx7d-iomuxc-lpsr";
reg = <0x302c0000 0x10000>;
fsl,input-sel = <&iomuxc>;
iomuxc: iomuxc@30330000 {
compatible = "fsl,imx7d-iomuxc";
reg = <0x30330000 0x10000>;
aips3: aips-bus@30800000 {
#size-cells = <1>;
reg = <0x30800000 0x400000>;
ranges;
uart1: serial@30860000 {
"fsl,imx6q-uart";
reg = <0x30860000 0x10000>;
uart2: serial@30890000 {
"fsl,imx6q-uart";
reg = <0x30890000 0x10000>;
uart3: serial@30880000 {
"fsl,imx6q-uart";
reg = <0x30880000 0x10000>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
"fsl,imx6q-uart";
"fsl,imx6q-uart";
"fsl,imx6q-uart";
"fsl,imx6q-uart";
-}; diff --git a/arch/arm/dts/imx7d-pinfunc.h b/arch/arm/dts/imx7d-pinfunc.h index 32d2464..f6f7e78 100644 --- a/arch/arm/dts/imx7d-pinfunc.h +++ b/arch/arm/dts/imx7d-pinfunc.h @@ -1,7 +1,10 @@ /*
- Copyright (C) 2014-2015 Freescale Semiconductor, Inc.
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
#ifndef __DTS_IMX7D_PINFUNC_H @@ -12,57 +15,61 @@
<mux_reg conf_reg input_reg mux_mode input_val>
-#define MX7D_PAD_GPIO1_IO00__GPIO1_IO0 0x0000 0x0030 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO00__PWM4_OUT 0x0000 0x0030 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO00__WDOD1_WDOG_ANY 0x0000 0x0030 0x0000 0x2 0x0 -#define MX7D_PAD_GPIO1_IO00__WDOD1_WDOG_B 0x0000 0x0030 0x0000 0x3 0x0 -#define MX7D_PAD_GPIO1_IO00__WDOD1_WDOG__RST_B_DEB 0x0000 0x0030 0x0000 0x4 0x0 -#define MX7D_PAD_GPIO1_IO01__GPIO1_IO1 0x0004 0x0034 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO01__PWM1_OUT 0x0004 0x0034 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO01__CCM_ENET_REF_CLK3 0x0004 0x0034 0x0000 0x2 0x0 -#define MX7D_PAD_GPIO1_IO01__SAI1_MCLK 0x0004 0x0034 0x0000 0x3 0x0 -#define MX7D_PAD_GPIO1_IO01__ANATOP_24M_OUT 0x0004 0x0034 0x0000 0x4 0x0 -#define MX7D_PAD_GPIO1_IO01__OBSERVE0_OUT 0x0004 0x0034 0x0000 0x6 0x0 -#define MX7D_PAD_GPIO1_IO02__GPIO1_IO2 0x0008 0x0038 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO02__PWM2_OUT 0x0008 0x0038 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO02__CCM_ENET_REF_CLK1 0x0008 0x0038 0x0564 0x2 0x3 -#define MX7D_PAD_GPIO1_IO02__SAI2_MCLK 0x0008 0x0038 0x0000 0x3 0x0 -#define MX7D_PAD_GPIO1_IO02__CCM_CLKO1 0x0008 0x0038 0x0000 0x5 0x0 -#define MX7D_PAD_GPIO1_IO02__OBSERVE1_OUT 0x0008 0x0038 0x0000 0x6 0x0 -#define MX7D_PAD_GPIO1_IO02__USB_OTG1_ID 0x0008 0x0038 0x0734 0x7 0x3 -#define MX7D_PAD_GPIO1_IO03__GPIO1_IO3 0x000C 0x003C 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO03__PWM3_OUT 0x000C 0x003C 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO03__CCM_ENET_REF_CLK2 0x000C 0x003C 0x0570 0x2 0x3 -#define MX7D_PAD_GPIO1_IO03__SAI3_MCLK 0x000C 0x003C 0x0000 0x3 0x0 -#define MX7D_PAD_GPIO1_IO03__CCM_CLKO2 0x000C 0x003C 0x0000 0x5 0x0 -#define MX7D_PAD_GPIO1_IO03__OBSERVE2_OUT 0x000C 0x003C 0x0000 0x6 0x0 -#define MX7D_PAD_GPIO1_IO03__USB_OTG2_ID 0x000C 0x003C 0x0730 0x7 0x3 -#define MX7D_PAD_GPIO1_IO04__GPIO1_IO4 0x0010 0x0040 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO04__USB_OTG1_OC 0x0010 0x0040 0x072C 0x1 0x1 -#define MX7D_PAD_GPIO1_IO04__FLEXTIMER1_CH4 0x0010 0x0040 0x0594 0x2 0x1 -#define MX7D_PAD_GPIO1_IO04__UART5_CTS_B 0x0010 0x0040 0x0710 0x3 0x4 -#define MX7D_PAD_GPIO1_IO04__I2C1_SCL 0x0010 0x0040 0x05D4 0x4 0x2 -#define MX7D_PAD_GPIO1_IO04__OBSERVE3_OUT 0x0010 0x0040 0x0000 0x6 0x0 -#define MX7D_PAD_GPIO1_IO05__GPIO1_IO5 0x0014 0x0044 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO05__USB_OTG1_PWR 0x0014 0x0044 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO05__FLEXTIMER1_CH5 0x0014 0x0044 0x0598 0x2 0x1 -#define MX7D_PAD_GPIO1_IO05__UART5_RTS_B 0x0014 0x0044 0x0710 0x3 0x5 -#define MX7D_PAD_GPIO1_IO05__I2C1_SDA 0x0014 0x0044 0x05D8 0x4 0x2 -#define MX7D_PAD_GPIO1_IO05__OBSERVE4_OUT 0x0014 0x0044 0x0000 0x6 0x0 -#define MX7D_PAD_GPIO1_IO06__GPIO1_IO6 0x0018 0x0048 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO06__USB_OTG2_OC 0x0018 0x0048 0x0728 0x1 0x1 -#define MX7D_PAD_GPIO1_IO06__FLEXTIMER1_CH6 0x0018 0x0048 0x059C 0x2 0x1 -#define MX7D_PAD_GPIO1_IO06__UART5_RX_DATA 0x0018 0x0048 0x0714 0x3 0x4 -#define MX7D_PAD_GPIO1_IO06__I2C2_SCL 0x0018 0x0048 0x05DC 0x4 0x2 -#define MX7D_PAD_GPIO1_IO06__CCM_WAIT 0x0018 0x0048 0x0000 0x5 0x0 -#define MX7D_PAD_GPIO1_IO06__KPP_ROW4 0x0018 0x0048 0x0624 0x6 0x1 -#define MX7D_PAD_GPIO1_IO07__GPIO1_IO7 0x001C 0x004C 0x0000 0x0 0x0 -#define MX7D_PAD_GPIO1_IO07__USB_OTG2_PWR 0x001C 0x004C 0x0000 0x1 0x0 -#define MX7D_PAD_GPIO1_IO07__FLEXTIMER1_CH7 0x001C 0x004C 0x05A0 0x2 0x1 -#define MX7D_PAD_GPIO1_IO07__UART5_TX_DATA 0x001C 0x004C 0x0714 0x3 0x5 -#define MX7D_PAD_GPIO1_IO07__I2C2_SDA 0x001C 0x004C 0x05E0 0x4 0x2 -#define MX7D_PAD_GPIO1_IO07__CCM_STOP 0x001C 0x004C 0x0000 0x5 0x0 -#define MX7D_PAD_GPIO1_IO07__KPP_COL4 0x001C 0x004C 0x0604 0x6 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO00__GPIO1_IO0 0x0000 0x0030 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO00__PWM4_OUT 0x0000 0x0030 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO00__WDOD1_WDOG_ANY 0x0000 0x0030 0x0000 0x2 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO00__WDOD1_WDOG_B 0x0000 0x0030 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO00__WDOD1_WDOG__RST_B_DEB 0x0000 0x0030 0x0000 0x4 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__GPIO1_IO1 0x0004 0x0034 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__PWM1_OUT 0x0004 0x0034 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__CCM_ENET_REF_CLK3 0x0004 0x0034 0x0000 0x2 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__SAI1_MCLK 0x0004 0x0034 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__ANATOP_24M_OUT 0x0004 0x0034 0x0000 0x4 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO01__OBSERVE0_OUT 0x0004 0x0034 0x0000 0x6 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__GPIO1_IO2 0x0008 0x0038 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__PWM2_OUT 0x0008 0x0038 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__CCM_ENET_REF_CLK1 0x0008 0x0038 0x0564 0x2 0x3 +#define MX7D_PAD_LPSR_GPIO1_IO02__SAI2_MCLK 0x0008 0x0038 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__CCM_CLKO1 0x0008 0x0038 0x0000 0x5 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__OBSERVE1_OUT 0x0008 0x0038 0x0000 0x6 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO02__USB_OTG1_ID 0x0008 0x0038 0x0734 0x7 0x3 +#define MX7D_PAD_LPSR_GPIO1_IO03__GPIO1_IO3 0x000C 0x003C 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO03__PWM3_OUT 0x000C 0x003C 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO03__CCM_ENET_REF_CLK2 0x000C 0x003C 0x0570 0x2 0x3 +#define MX7D_PAD_LPSR_GPIO1_IO03__SAI3_MCLK 0x000C 0x003C 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO03__CCM_CLKO2 0x000C 0x003C 0x0000 0x5 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO03__OBSERVE2_OUT 0x000C 0x003C 0x0000 0x6 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO03__USB_OTG2_ID 0x000C 0x003C 0x0730 0x7 0x3 +#define MX7D_PAD_LPSR_GPIO1_IO04__GPIO1_IO4 0x0010 0x0040 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO04__USB_OTG1_OC 0x0010 0x0040 0x072C 0x1 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO04__FLEXTIMER1_CH4 0x0010 0x0040 0x0594 0x2 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO04__UART5_DCE_CTS 0x0010 0x0040 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO04__UART5_DTE_RTS 0x0010 0x0040 0x0710 0x3 0x4 +#define MX7D_PAD_LPSR_GPIO1_IO04__I2C1_SCL 0x0010 0x0040 0x05D4 0x4 0x2 +#define MX7D_PAD_LPSR_GPIO1_IO04__OBSERVE3_OUT 0x0010 0x0040 0x0000 0x6 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO05__GPIO1_IO5 0x0014 0x0044 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO05__USB_OTG1_PWR 0x0014 0x0044 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO05__FLEXTIMER1_CH5 0x0014 0x0044 0x0598 0x2 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO05__UART5_DCE_RTS 0x0014 0x0044 0x0710 0x3 0x5 +#define MX7D_PAD_LPSR_GPIO1_IO05__UART5_DTE_CTS 0x0014 0x0044 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO05__I2C1_SDA 0x0014 0x0044 0x05D8 0x4 0x2 +#define MX7D_PAD_LPSR_GPIO1_IO05__OBSERVE4_OUT 0x0014 0x0044 0x0000 0x6 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO06__GPIO1_IO6 0x0018 0x0048 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO06__USB_OTG2_OC 0x0018 0x0048 0x0728 0x1 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO06__FLEXTIMER1_CH6 0x0018 0x0048 0x059C 0x2 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO06__UART5_DCE_RX 0x0018 0x0048 0x0714 0x3 0x4 +#define MX7D_PAD_LPSR_GPIO1_IO06__UART5_DTE_TX 0x0018 0x0048 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO06__I2C2_SCL 0x0018 0x0048 0x05DC 0x4 0x2 +#define MX7D_PAD_LPSR_GPIO1_IO06__CCM_WAIT 0x0018 0x0048 0x0000 0x5 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO06__KPP_ROW4 0x0018 0x0048 0x0624 0x6 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO07__GPIO1_IO7 0x001C 0x004C 0x0000 0x0 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO07__USB_OTG2_PWR 0x001C 0x004C 0x0000 0x1 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO07__FLEXTIMER1_CH7 0x001C 0x004C 0x05A0 0x2 0x1 +#define MX7D_PAD_LPSR_GPIO1_IO07__UART5_DCE_TX 0x001C 0x004C 0x0000 0x3 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO07__UART5_DTE_RX 0x001C 0x004C 0x0714 0x3 0x5 +#define MX7D_PAD_LPSR_GPIO1_IO07__I2C2_SDA 0x001C 0x004C 0x05E0 0x4 0x2 +#define MX7D_PAD_LPSR_GPIO1_IO07__CCM_STOP 0x001C 0x004C 0x0000 0x5 0x0 +#define MX7D_PAD_LPSR_GPIO1_IO07__KPP_COL4 0x001C 0x004C 0x0604 0x6 0x1 #define MX7D_PAD_GPIO1_IO08__GPIO1_IO8 0x0014 0x026C 0x0000 0x0 0x0 #define MX7D_PAD_GPIO1_IO08__SD1_VSELECT 0x0014 0x026C 0x0000 0x1 0x0 #define MX7D_PAD_GPIO1_IO08__WDOG1_WDOG_B 0x0014 0x026C 0x0000 0x2 0x0 diff --git a/arch/arm/dts/imx7d.dtsi b/arch/arm/dts/imx7d.dtsi new file mode 100644 index 0000000..f6dee41 --- /dev/null +++ b/arch/arm/dts/imx7d.dtsi @@ -0,0 +1,140 @@ +/*
- Copyright 2015 Freescale Semiconductor, Inc.
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License as
published by the Free Software Foundation; either version 2 of the
License, or (at your option) any later version.
This file is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
obtaining a copy of this software and associated documentation
files (the "Software"), to deal in the Software without
restriction, including without limitation the rights to use,
copy, modify, merge, publish, distribute, sublicense, and/or
sell copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following
conditions:
The above copyright notice and this permission notice shall be
included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
OTHER DEALINGS IN THE SOFTWARE.
+#include "imx7s.dtsi"
- cpus {
cpu0: cpu@0 {
operating-points = <
/* KHz uV */
996000 1075000
792000 975000
clock-frequency = <996000000>;
cpu1: cpu@1 {
compatible = "arm,cortex-a7";
device_type = "cpu";
reg = <1>;
- soc {
etm@3007d000 {
compatible = "arm,coresight-etm3x", "arm,primecell";
reg = <0x3007d000 0x1000>;
* System will hang if added nosmp in kernel command line
* without arm,primecell-periphid because amba bus try to
* read id and core1 power off at this time.
arm,primecell-periphid = <0xbb956>;
cpu = <&cpu1>;
clocks = <&clks IMX7D_MAIN_AXI_ROOT_CLK>;
clock-names = "apb_pclk";
port {
etm1_out_port: endpoint {
remote-endpoint = <&ca_funnel_in_port1>;
+&aips3 {
- usbotg2: usb@30b20000 {
compatible = "fsl,imx7d-usb", "fsl,imx27-usb";
reg = <0x30b20000 0x200>;
interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_USB_CTRL_CLK>;
fsl,usbphy = <&usbphynop2>;
fsl,usbmisc = <&usbmisc2 0>;
phy-clkgate-delay-us = <400>;
status = "disabled";
- usbmisc2: usbmisc@30b20200 {
#index-cells = <1>;
compatible = "fsl,imx7d-usbmisc", "fsl,imx6q-usbmisc";
reg = <0x30b20200 0x200>;
- usbphynop2: usbphynop2 {
compatible = "usb-nop-xceiv";
clocks = <&clks IMX7D_USB_PHY2_CLK>;
clock-names = "main_clk";
- fec2: ethernet@30bf0000 {
compatible = "fsl,imx7d-fec", "fsl,imx6sx-fec";
reg = <0x30bf0000 0x10000>;
interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_ENET_AXI_ROOT_CLK>,
<&clks IMX7D_ENET2_TIME_ROOT_CLK>,
<&clks IMX7D_PLL_ENET_MAIN_125M_CLK>,
<&clks IMX7D_ENET_PHY_REF_ROOT_CLK>;
clock-names = "ipg", "ahb", "ptp",
"enet_clk_ref", "enet_out";
fsl,num-tx-queues=<3>;
fsl,num-rx-queues=<3>;
+&ca_funnel_ports {
- port@1 {
reg = <1>;
ca_funnel_in_port1: endpoint {
slave-mode;
remote-endpoint = <&etm1_out_port>;
+}; diff --git a/arch/arm/dts/imx7s.dtsi b/arch/arm/dts/imx7s.dtsi new file mode 100644 index 0000000..a7d48e7 --- /dev/null +++ b/arch/arm/dts/imx7s.dtsi @@ -0,0 +1,999 @@ +/*
- whole.
conditions:
+#include <dt-bindings/clock/imx7d-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include "imx7d-pinfunc.h"
- #address-cells = <1>;
- #size-cells = <1>;
* The decompressor and also some bootloaders rely on a
* pre-existing /chosen node to be available to insert the
* command line and merge other ATAGS info.
* Also for U-Boot there must be a pre-existing /memory node.
- chosen {};
- memory { device_type = "memory"; reg = <0 0>; };
- aliases {
gpio0 = &gpio1;
gpio1 = &gpio2;
gpio2 = &gpio3;
gpio3 = &gpio4;
gpio4 = &gpio5;
gpio5 = &gpio6;
gpio6 = &gpio7;
i2c0 = &i2c1;
i2c1 = &i2c2;
i2c2 = &i2c3;
i2c3 = &i2c4;
mmc0 = &usdhc1;
mmc1 = &usdhc2;
mmc2 = &usdhc3;
serial0 = &uart1;
serial1 = &uart2;
serial2 = &uart3;
serial3 = &uart4;
serial4 = &uart5;
serial5 = &uart6;
serial6 = &uart7;
spi0 = &ecspi1;
spi1 = &ecspi2;
spi2 = &ecspi3;
spi3 = &ecspi4;
- cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0>;
clock-frequency = <792000000>;
clock-latency = <61036>; /* two CLK32 periods */
clocks = <&clks IMX7D_CLK_ARM>;
- ckil: clock-cki {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <32768>;
clock-output-names = "ckil";
- osc: clock-osc {
#clock-cells = <0>;
clock-frequency = <24000000>;
clock-output-names = "osc";
- soc {
#size-cells = <1>;
interrupt-parent = <&intc>;
ranges;
funnel@30041000 {
compatible = "arm,coresight-funnel", "arm,primecell";
reg = <0x30041000 0x1000>;
ca_funnel_ports: ports {
#size-cells = <0>;
/* funnel input ports */
port@0 {
reg = <0>;
ca_funnel_in_port0: endpoint {
slave-mode;
remote-endpoint = <&etm0_out_port>;
/* funnel output port */
port@2 {
reg = <0>;
ca_funnel_out_port0: endpoint {
remote-endpoint = <&hugo_funnel_in_port0>;
/* the other input ports are not connect to anything */
etm@3007c000 {
reg = <0x3007c000 0x1000>;
cpu = <&cpu0>;
port {
etm0_out_port: endpoint {
remote-endpoint = <&ca_funnel_in_port0>;
funnel@30083000 {
reg = <0x30083000 0x1000>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
hugo_funnel_in_port0: endpoint {
slave-mode;
remote-endpoint = <&ca_funnel_out_port0>;
port@1 {
reg = <1>;
hugo_funnel_in_port1: endpoint {
slave-mode; /* M4 input */
port@2 {
reg = <0>;
hugo_funnel_out_port0: endpoint {
remote-endpoint = <&etf_in_port>;
etf@30084000 {
compatible = "arm,coresight-tmc", "arm,primecell";
reg = <0x30084000 0x1000>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
etf_in_port: endpoint {
slave-mode;
remote-endpoint = <&hugo_funnel_out_port0>;
port@1 {
reg = <0>;
etf_out_port: endpoint {
remote-endpoint = <&replicator_in_port0>;
etr@30086000 {
reg = <0x30086000 0x1000>;
port {
etr_in_port: endpoint {
slave-mode;
remote-endpoint = <&replicator_out_port1>;
tpiu@30087000 {
compatible = "arm,coresight-tpiu", "arm,primecell";
reg = <0x30087000 0x1000>;
port {
tpiu_in_port: endpoint {
slave-mode;
replicator {
* non-configurable replicators don't show up on the
* AMBA bus. As such no need to add "arm,primecell"
compatible = "arm,coresight-replicator";
ports {
#size-cells = <0>;
/* replicator output ports */
port@0 {
reg = <0>;
replicator_out_port0: endpoint {
remote-endpoint = <&tpiu_in_port>;
port@1 {
reg = <1>;
replicator_out_port1: endpoint {
remote-endpoint = <&etr_in_port>;
/* replicator input port */
port@2 {
reg = <0>;
replicator_in_port0: endpoint {
slave-mode;
remote-endpoint = <&etf_out_port>;
intc: interrupt-controller@31001000 {
compatible = "arm,cortex-a7-gic";
interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>;
#interrupt-cells = <3>;
interrupt-controller;
reg = <0x31001000 0x1000>,
<0x31002000 0x2000>,
<0x31004000 0x2000>,
<0x31006000 0x2000>;
timer {
compatible = "arm,armv7-timer";
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
<GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
<GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
<GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>;
#size-cells = <1>;
ranges;
interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>, /* GPIO1_INT15_0 */
<GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; /* GPIO1_INT31_16 */
gpio-controller;
#gpio-cells = <2>;
#interrupt-cells = <2>;
gpio-ranges = <&iomuxc_lpsr 0 0 8>, <&iomuxc 8 5 8>;
interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>;
gpio-controller;
#gpio-cells = <2>;
gpio-ranges = <&iomuxc 0 13 32>;
interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;
gpio-controller;
#gpio-cells = <2>;
gpio-ranges = <&iomuxc 0 45 29>;
interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>;
gpio-controller;
#gpio-cells = <2>;
gpio-ranges = <&iomuxc 0 74 24>;
interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>;
gpio-controller;
#gpio-cells = <2>;
gpio-ranges = <&iomuxc 0 98 18>;
interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>;
gpio-controller;
#gpio-cells = <2>;
gpio-ranges = <&iomuxc 0 116 23>;
interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>;
gpio-controller;
#gpio-cells = <2>;
gpio-ranges = <&iomuxc 0 139 16>;
wdog1: wdog@30280000 {
compatible = "fsl,imx7d-wdt", "fsl,imx21-wdt";
reg = <0x30280000 0x10000>;
interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_WDOG1_ROOT_CLK>;
wdog2: wdog@30290000 {
reg = <0x30290000 0x10000>;
interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_WDOG2_ROOT_CLK>;
wdog3: wdog@302a0000 {
reg = <0x302a0000 0x10000>;
interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_WDOG3_ROOT_CLK>;
wdog4: wdog@302b0000 {
reg = <0x302b0000 0x10000>;
interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_WDOG4_ROOT_CLK>;
gpt1: gpt@302d0000 {
compatible = "fsl,imx7d-gpt", "fsl,imx6sx-gpt";
reg = <0x302d0000 0x10000>;
interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_CLK_DUMMY>,
<&clks IMX7D_GPT1_ROOT_CLK>;
clock-names = "ipg", "per";
gpt2: gpt@302e0000 {
reg = <0x302e0000 0x10000>;
interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>;
<&clks IMX7D_GPT2_ROOT_CLK>;
gpt3: gpt@302f0000 {
reg = <0x302f0000 0x10000>;
interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>;
<&clks IMX7D_GPT3_ROOT_CLK>;
gpt4: gpt@30300000 {
reg = <0x30300000 0x10000>;
interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>;
<&clks IMX7D_GPT4_ROOT_CLK>;
gpr: iomuxc-gpr@30340000 {
compatible = "fsl,imx7d-iomuxc-gpr", "syscon";
reg = <0x30340000 0x10000>;
ocotp: ocotp-ctrl@30350000 {
compatible = "fsl,imx7d-ocotp", "syscon";
reg = <0x30350000 0x10000>;
clocks = <&clks IMX7D_OCOTP_CLK>;
anatop: anatop@30360000 {
compatible = "fsl,imx7d-anatop", "fsl,imx6q-anatop",
"syscon", "simple-bus";
reg = <0x30360000 0x10000>;
interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>;
reg_1p0d: regulator-vdd1p0d {
compatible = "fsl,anatop-regulator";
regulator-name = "vdd1p0d";
regulator-max-microvolt = <1200000>;
anatop-reg-offset = <0x210>;
anatop-vol-bit-shift = <8>;
anatop-vol-bit-width = <5>;
anatop-min-bit-val = <8>;
anatop-min-voltage = <800000>;
anatop-max-voltage = <1200000>;
snvs: snvs@30370000 {
compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd";
reg = <0x30370000 0x10000>;
snvs_rtc: snvs-rtc-lp {
compatible = "fsl,sec-v4.0-mon-rtc-lp";
regmap = <&snvs>;
offset = <0x34>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
snvs_poweroff: snvs-poweroff {
compatible = "syscon-poweroff";
regmap = <&snvs>;
offset = <0x38>;
mask = <0x60>;
snvs_pwrkey: snvs-powerkey {
compatible = "fsl,sec-v4.0-pwrkey";
regmap = <&snvs>;
interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
linux,keycode = <KEY_POWER>;
wakeup-source;
clks: ccm@30380000 {
compatible = "fsl,imx7d-ccm";
reg = <0x30380000 0x10000>;
interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>;
#clock-cells = <1>;
clocks = <&ckil>, <&osc>;
clock-names = "ckil", "osc";
src: src@30390000 {
compatible = "fsl,imx7d-src", "fsl,imx51-src", "syscon";
reg = <0x30390000 0x10000>;
interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>;
#reset-cells = <1>;
aips2: aips-bus@30400000 {
#size-cells = <1>;
reg = <0x30400000 0x400000>;
ranges;
adc1: adc@30610000 {
compatible = "fsl,imx7d-adc";
reg = <0x30610000 0x10000>;
interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_ADC_ROOT_CLK>;
clock-names = "adc";
adc2: adc@30620000 {
reg = <0x30620000 0x10000>;
interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>;
ecspi4: ecspi@30630000 {
#size-cells = <0>;
compatible = "fsl,imx7d-ecspi", "fsl,imx51-ecspi";
reg = <0x30630000 0x10000>;
interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_ECSPI4_ROOT_CLK>,
<&clks IMX7D_ECSPI4_ROOT_CLK>;
pwm1: pwm@30660000 {
compatible = "fsl,imx7d-pwm", "fsl,imx27-pwm";
reg = <0x30660000 0x10000>;
interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_PWM1_ROOT_CLK>,
<&clks IMX7D_PWM1_ROOT_CLK>;
#pwm-cells = <2>;
pwm2: pwm@30670000 {
reg = <0x30670000 0x10000>;
interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_PWM2_ROOT_CLK>,
<&clks IMX7D_PWM2_ROOT_CLK>;
#pwm-cells = <2>;
pwm3: pwm@30680000 {
reg = <0x30680000 0x10000>;
interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_PWM3_ROOT_CLK>,
<&clks IMX7D_PWM3_ROOT_CLK>;
#pwm-cells = <2>;
pwm4: pwm@30690000 {
reg = <0x30690000 0x10000>;
interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_PWM4_ROOT_CLK>,
<&clks IMX7D_PWM4_ROOT_CLK>;
#pwm-cells = <2>;
lcdif: lcdif@30730000 {
compatible = "fsl,imx7d-lcdif", "fsl,imx28-lcdif";
reg = <0x30730000 0x10000>;
interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_LCDIF_PIXEL_ROOT_CLK>,
<&clks IMX7D_LCDIF_PIXEL_ROOT_CLK>;
clock-names = "pix", "axi";
#size-cells = <1>;
ranges;
ecspi1: ecspi@30820000 {
#size-cells = <0>;
reg = <0x30820000 0x10000>;
interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_ECSPI1_ROOT_CLK>,
<&clks IMX7D_ECSPI1_ROOT_CLK>;
ecspi2: ecspi@30830000 {
#size-cells = <0>;
reg = <0x30830000 0x10000>;
interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_ECSPI2_ROOT_CLK>,
<&clks IMX7D_ECSPI2_ROOT_CLK>;
ecspi3: ecspi@30840000 {
#size-cells = <0>;
reg = <0x30840000 0x10000>;
interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_ECSPI3_ROOT_CLK>,
<&clks IMX7D_ECSPI3_ROOT_CLK>;
compatible = "fsl,imx7d-uart",
"fsl,imx6q-uart";
interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_UART1_ROOT_CLK>,
<&clks IMX7D_UART1_ROOT_CLK>;
"fsl,imx6q-uart";
interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_UART2_ROOT_CLK>,
<&clks IMX7D_UART2_ROOT_CLK>;
"fsl,imx6q-uart";
interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_UART3_ROOT_CLK>,
<&clks IMX7D_UART3_ROOT_CLK>;
sai1: sai@308a0000 {
#sound-dai-cells = <0>;
compatible = "fsl,imx7d-sai", "fsl,imx6sx-sai";
reg = <0x308a0000 0x10000>;
interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_SAI1_IPG_CLK>,
<&clks IMX7D_SAI1_ROOT_CLK>,
<&clks IMX7D_CLK_DUMMY>;
clock-names = "bus", "mclk1", "mclk2", "mclk3";
dma-names = "rx", "tx";
dmas = <&sdma 8 24 0>, <&sdma 9 24 0>;
sai2: sai@308b0000 {
reg = <0x308b0000 0x10000>;
interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_SAI2_IPG_CLK>,
<&clks IMX7D_SAI2_ROOT_CLK>,
dmas = <&sdma 10 24 0>, <&sdma 11 24 0>;
sai3: sai@308c0000 {
reg = <0x308c0000 0x10000>;
interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_SAI3_IPG_CLK>,
<&clks IMX7D_SAI3_ROOT_CLK>,
dmas = <&sdma 12 24 0>, <&sdma 13 24 0>;
flexcan1: can@30a00000 {
compatible = "fsl,imx7d-flexcan", "fsl,imx6q-flexcan";
reg = <0x30a00000 0x10000>;
interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>;
<&clks IMX7D_CAN1_ROOT_CLK>;
flexcan2: can@30a10000 {
reg = <0x30a10000 0x10000>;
interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>;
<&clks IMX7D_CAN2_ROOT_CLK>;
i2c1: i2c@30a20000 {
#size-cells = <0>;
compatible = "fsl,imx7d-i2c", "fsl,imx21-i2c";
reg = <0x30a20000 0x10000>;
interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_I2C1_ROOT_CLK>;
i2c2: i2c@30a30000 {
#size-cells = <0>;
reg = <0x30a30000 0x10000>;
interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_I2C2_ROOT_CLK>;
i2c3: i2c@30a40000 {
#size-cells = <0>;
reg = <0x30a40000 0x10000>;
interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_I2C3_ROOT_CLK>;
i2c4: i2c@30a50000 {
#size-cells = <0>;
reg = <0x30a50000 0x10000>;
interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_I2C4_ROOT_CLK>;
uart4: serial@30a60000 {
"fsl,imx6q-uart";
reg = <0x30a60000 0x10000>;
interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_UART4_ROOT_CLK>,
<&clks IMX7D_UART4_ROOT_CLK>;
uart5: serial@30a70000 {
"fsl,imx6q-uart";
reg = <0x30a70000 0x10000>;
interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_UART5_ROOT_CLK>,
<&clks IMX7D_UART5_ROOT_CLK>;
uart6: serial@30a80000 {
"fsl,imx6q-uart";
reg = <0x30a80000 0x10000>;
interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_UART6_ROOT_CLK>,
<&clks IMX7D_UART6_ROOT_CLK>;
uart7: serial@30a90000 {
"fsl,imx6q-uart";
reg = <0x30a90000 0x10000>;
interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_UART7_ROOT_CLK>,
<&clks IMX7D_UART7_ROOT_CLK>;
usbotg1: usb@30b10000 {
reg = <0x30b10000 0x200>;
interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>;
fsl,usbphy = <&usbphynop1>;
fsl,usbmisc = <&usbmisc1 0>;
usbh: usb@30b30000 {
reg = <0x30b30000 0x200>;
interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>;
fsl,usbphy = <&usbphynop3>;
fsl,usbmisc = <&usbmisc3 0>;
phy_type = "hsic";
dr_mode = "host";
usbmisc1: usbmisc@30b10200 {
#index-cells = <1>;
reg = <0x30b10200 0x200>;
usbmisc3: usbmisc@30b30200 {
#index-cells = <1>;
reg = <0x30b30200 0x200>;
usbphynop1: usbphynop1 {
clocks = <&clks IMX7D_USB_PHY1_CLK>;
usbphynop3: usbphynop3 {
clocks = <&clks IMX7D_USB_HSIC_ROOT_CLK>;
usdhc1: usdhc@30b40000 {
compatible = "fsl,imx7d-usdhc", "fsl,imx6sl-usdhc";
reg = <0x30b40000 0x10000>;
interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>;
<&clks IMX7D_USDHC1_ROOT_CLK>;
clock-names = "ipg", "ahb", "per";
bus-width = <4>;
usdhc2: usdhc@30b50000 {
reg = <0x30b50000 0x10000>;
interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
<&clks IMX7D_USDHC2_ROOT_CLK>;
bus-width = <4>;
usdhc3: usdhc@30b60000 {
reg = <0x30b60000 0x10000>;
interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
<&clks IMX7D_USDHC3_ROOT_CLK>;
bus-width = <4>;
sdma: sdma@30bd0000 {
compatible = "fsl,imx7d-sdma", "fsl,imx35-sdma";
reg = <0x30bd0000 0x10000>;
interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_SDMA_CORE_CLK>,
<&clks IMX7D_AHB_CHANNEL_ROOT_CLK>;
clock-names = "ipg", "ahb";
#dma-cells = <3>;
fsl,sdma-ram-script-name = "imx/sdma/sdma-imx7d.bin";
fec1: ethernet@30be0000 {
reg = <0x30be0000 0x10000>;
interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>;
<&clks IMX7D_ENET1_TIME_ROOT_CLK>,
+}; diff --git a/include/dt-bindings/clock/imx7d-clock.h b/include/dt-bindings/clock/imx7d-clock.h new file mode 100644 index 0000000..a7a1a50 --- /dev/null +++ b/include/dt-bindings/clock/imx7d-clock.h @@ -0,0 +1,454 @@ +/*
+#ifndef __DT_BINDINGS_CLOCK_IMX7D_H +#define __DT_BINDINGS_CLOCK_IMX7D_H
+#define IMX7D_OSC_24M_CLK 0 +#define IMX7D_PLL_ARM_MAIN 1 +#define IMX7D_PLL_ARM_MAIN_CLK 2 +#define IMX7D_PLL_ARM_MAIN_SRC 3 +#define IMX7D_PLL_ARM_MAIN_BYPASS 4 +#define IMX7D_PLL_SYS_MAIN 5 +#define IMX7D_PLL_SYS_MAIN_CLK 6 +#define IMX7D_PLL_SYS_MAIN_SRC 7 +#define IMX7D_PLL_SYS_MAIN_BYPASS 8 +#define IMX7D_PLL_SYS_MAIN_480M 9 +#define IMX7D_PLL_SYS_MAIN_240M 10 +#define IMX7D_PLL_SYS_MAIN_120M 11 +#define IMX7D_PLL_SYS_MAIN_480M_CLK 12 +#define IMX7D_PLL_SYS_MAIN_240M_CLK 13 +#define IMX7D_PLL_SYS_MAIN_120M_CLK 14 +#define IMX7D_PLL_SYS_PFD0_392M_CLK 15 +#define IMX7D_PLL_SYS_PFD0_196M 16 +#define IMX7D_PLL_SYS_PFD0_196M_CLK 17 +#define IMX7D_PLL_SYS_PFD1_332M_CLK 18 +#define IMX7D_PLL_SYS_PFD1_166M 19 +#define IMX7D_PLL_SYS_PFD1_166M_CLK 20 +#define IMX7D_PLL_SYS_PFD2_270M_CLK 21 +#define IMX7D_PLL_SYS_PFD2_135M 22 +#define IMX7D_PLL_SYS_PFD2_135M_CLK 23 +#define IMX7D_PLL_SYS_PFD3_CLK 24 +#define IMX7D_PLL_SYS_PFD4_CLK 25 +#define IMX7D_PLL_SYS_PFD5_CLK 26 +#define IMX7D_PLL_SYS_PFD6_CLK 27 +#define IMX7D_PLL_SYS_PFD7_CLK 28 +#define IMX7D_PLL_ENET_MAIN 29 +#define IMX7D_PLL_ENET_MAIN_CLK 30 +#define IMX7D_PLL_ENET_MAIN_SRC 31 +#define IMX7D_PLL_ENET_MAIN_BYPASS 32 +#define IMX7D_PLL_ENET_MAIN_500M 33 +#define IMX7D_PLL_ENET_MAIN_250M 34 +#define IMX7D_PLL_ENET_MAIN_125M 35 +#define IMX7D_PLL_ENET_MAIN_100M 36 +#define IMX7D_PLL_ENET_MAIN_50M 37 +#define IMX7D_PLL_ENET_MAIN_40M 38 +#define IMX7D_PLL_ENET_MAIN_25M 39 +#define IMX7D_PLL_ENET_MAIN_500M_CLK 40 +#define IMX7D_PLL_ENET_MAIN_250M_CLK 41 +#define IMX7D_PLL_ENET_MAIN_125M_CLK 42 +#define IMX7D_PLL_ENET_MAIN_100M_CLK 43 +#define IMX7D_PLL_ENET_MAIN_50M_CLK 44 +#define IMX7D_PLL_ENET_MAIN_40M_CLK 45 +#define IMX7D_PLL_ENET_MAIN_25M_CLK 46 +#define IMX7D_PLL_DRAM_MAIN 47 +#define IMX7D_PLL_DRAM_MAIN_CLK 48 +#define IMX7D_PLL_DRAM_MAIN_SRC 49 +#define IMX7D_PLL_DRAM_MAIN_BYPASS 50 +#define IMX7D_PLL_DRAM_MAIN_533M 51 +#define IMX7D_PLL_DRAM_MAIN_533M_CLK 52 +#define IMX7D_PLL_AUDIO_MAIN 53 +#define IMX7D_PLL_AUDIO_MAIN_CLK 54 +#define IMX7D_PLL_AUDIO_MAIN_SRC 55 +#define IMX7D_PLL_AUDIO_MAIN_BYPASS 56 +#define IMX7D_PLL_VIDEO_MAIN_CLK 57 +#define IMX7D_PLL_VIDEO_MAIN 58 +#define IMX7D_PLL_VIDEO_MAIN_SRC 59 +#define IMX7D_PLL_VIDEO_MAIN_BYPASS 60 +#define IMX7D_USB_MAIN_480M_CLK 61 +#define IMX7D_ARM_A7_ROOT_CLK 62 +#define IMX7D_ARM_A7_ROOT_SRC 63 +#define IMX7D_ARM_A7_ROOT_CG 64 +#define IMX7D_ARM_A7_ROOT_DIV 65 +#define IMX7D_ARM_M4_ROOT_CLK 66 +#define IMX7D_ARM_M4_ROOT_SRC 67 +#define IMX7D_ARM_M4_ROOT_CG 68 +#define IMX7D_ARM_M4_ROOT_DIV 69 +#define IMX7D_ARM_M0_ROOT_CLK 70 +#define IMX7D_ARM_M0_ROOT_SRC 71 +#define IMX7D_ARM_M0_ROOT_CG 72 +#define IMX7D_ARM_M0_ROOT_DIV 73 +#define IMX7D_MAIN_AXI_ROOT_CLK 74 +#define IMX7D_MAIN_AXI_ROOT_SRC 75 +#define IMX7D_MAIN_AXI_ROOT_CG 76 +#define IMX7D_MAIN_AXI_ROOT_DIV 77 +#define IMX7D_DISP_AXI_ROOT_CLK 78 +#define IMX7D_DISP_AXI_ROOT_SRC 79 +#define IMX7D_DISP_AXI_ROOT_CG 80 +#define IMX7D_DISP_AXI_ROOT_DIV 81 +#define IMX7D_ENET_AXI_ROOT_CLK 82 +#define IMX7D_ENET_AXI_ROOT_SRC 83 +#define IMX7D_ENET_AXI_ROOT_CG 84 +#define IMX7D_ENET_AXI_ROOT_DIV 85 +#define IMX7D_NAND_USDHC_BUS_ROOT_CLK 86 +#define IMX7D_NAND_USDHC_BUS_ROOT_SRC 87 +#define IMX7D_NAND_USDHC_BUS_ROOT_CG 88 +#define IMX7D_NAND_USDHC_BUS_ROOT_DIV 89 +#define IMX7D_AHB_CHANNEL_ROOT_CLK 90 +#define IMX7D_AHB_CHANNEL_ROOT_SRC 91 +#define IMX7D_AHB_CHANNEL_ROOT_CG 92 +#define IMX7D_AHB_CHANNEL_ROOT_DIV 93 +#define IMX7D_DRAM_PHYM_ROOT_CLK 94 +#define IMX7D_DRAM_PHYM_ROOT_SRC 95 +#define IMX7D_DRAM_PHYM_ROOT_CG 96 +#define IMX7D_DRAM_PHYM_ROOT_DIV 97 +#define IMX7D_DRAM_ROOT_CLK 98 +#define IMX7D_DRAM_ROOT_SRC 99 +#define IMX7D_DRAM_ROOT_CG 100 +#define IMX7D_DRAM_ROOT_DIV 101 +#define IMX7D_DRAM_PHYM_ALT_ROOT_CLK 102 +#define IMX7D_DRAM_PHYM_ALT_ROOT_SRC 103 +#define IMX7D_DRAM_PHYM_ALT_ROOT_CG 104 +#define IMX7D_DRAM_PHYM_ALT_ROOT_DIV 105 +#define IMX7D_DRAM_ALT_ROOT_CLK 106 +#define IMX7D_DRAM_ALT_ROOT_SRC 107 +#define IMX7D_DRAM_ALT_ROOT_CG 108 +#define IMX7D_DRAM_ALT_ROOT_DIV 109 +#define IMX7D_USB_HSIC_ROOT_CLK 110 +#define IMX7D_USB_HSIC_ROOT_SRC 111 +#define IMX7D_USB_HSIC_ROOT_CG 112 +#define IMX7D_USB_HSIC_ROOT_DIV 113 +#define IMX7D_PCIE_CTRL_ROOT_CLK 114 +#define IMX7D_PCIE_CTRL_ROOT_SRC 115 +#define IMX7D_PCIE_CTRL_ROOT_CG 116 +#define IMX7D_PCIE_CTRL_ROOT_DIV 117 +#define IMX7D_PCIE_PHY_ROOT_CLK 118 +#define IMX7D_PCIE_PHY_ROOT_SRC 119 +#define IMX7D_PCIE_PHY_ROOT_CG 120 +#define IMX7D_PCIE_PHY_ROOT_DIV 121 +#define IMX7D_EPDC_PIXEL_ROOT_CLK 122 +#define IMX7D_EPDC_PIXEL_ROOT_SRC 123 +#define IMX7D_EPDC_PIXEL_ROOT_CG 124 +#define IMX7D_EPDC_PIXEL_ROOT_DIV 125 +#define IMX7D_LCDIF_PIXEL_ROOT_CLK 126 +#define IMX7D_LCDIF_PIXEL_ROOT_SRC 127 +#define IMX7D_LCDIF_PIXEL_ROOT_CG 128 +#define IMX7D_LCDIF_PIXEL_ROOT_DIV 129 +#define IMX7D_MIPI_DSI_ROOT_CLK 130 +#define IMX7D_MIPI_DSI_ROOT_SRC 131 +#define IMX7D_MIPI_DSI_ROOT_CG 132 +#define IMX7D_MIPI_DSI_ROOT_DIV 133 +#define IMX7D_MIPI_CSI_ROOT_CLK 134 +#define IMX7D_MIPI_CSI_ROOT_SRC 135 +#define IMX7D_MIPI_CSI_ROOT_CG 136 +#define IMX7D_MIPI_CSI_ROOT_DIV 137 +#define IMX7D_MIPI_DPHY_ROOT_CLK 138 +#define IMX7D_MIPI_DPHY_ROOT_SRC 139 +#define IMX7D_MIPI_DPHY_ROOT_CG 140 +#define IMX7D_MIPI_DPHY_ROOT_DIV 141 +#define IMX7D_SAI1_ROOT_CLK 142 +#define IMX7D_SAI1_ROOT_SRC 143 +#define IMX7D_SAI1_ROOT_CG 144 +#define IMX7D_SAI1_ROOT_DIV 145 +#define IMX7D_SAI2_ROOT_CLK 146 +#define IMX7D_SAI2_ROOT_SRC 147 +#define IMX7D_SAI2_ROOT_CG 148 +#define IMX7D_SAI2_ROOT_DIV 149 +#define IMX7D_SAI3_ROOT_CLK 150 +#define IMX7D_SAI3_ROOT_SRC 151 +#define IMX7D_SAI3_ROOT_CG 152 +#define IMX7D_SAI3_ROOT_DIV 153 +#define IMX7D_SPDIF_ROOT_CLK 154 +#define IMX7D_SPDIF_ROOT_SRC 155 +#define IMX7D_SPDIF_ROOT_CG 156 +#define IMX7D_SPDIF_ROOT_DIV 157 +#define IMX7D_ENET1_REF_ROOT_CLK 158 +#define IMX7D_ENET1_REF_ROOT_SRC 159 +#define IMX7D_ENET1_REF_ROOT_CG 160 +#define IMX7D_ENET1_REF_ROOT_DIV 161 +#define IMX7D_ENET1_TIME_ROOT_CLK 162 +#define IMX7D_ENET1_TIME_ROOT_SRC 163 +#define IMX7D_ENET1_TIME_ROOT_CG 164 +#define IMX7D_ENET1_TIME_ROOT_DIV 165 +#define IMX7D_ENET2_REF_ROOT_CLK 166 +#define IMX7D_ENET2_REF_ROOT_SRC 167 +#define IMX7D_ENET2_REF_ROOT_CG 168 +#define IMX7D_ENET2_REF_ROOT_DIV 169 +#define IMX7D_ENET2_TIME_ROOT_CLK 170 +#define IMX7D_ENET2_TIME_ROOT_SRC 171 +#define IMX7D_ENET2_TIME_ROOT_CG 172 +#define IMX7D_ENET2_TIME_ROOT_DIV 173 +#define IMX7D_ENET_PHY_REF_ROOT_CLK 174 +#define IMX7D_ENET_PHY_REF_ROOT_SRC 175 +#define IMX7D_ENET_PHY_REF_ROOT_CG 176 +#define IMX7D_ENET_PHY_REF_ROOT_DIV 177 +#define IMX7D_EIM_ROOT_CLK 178 +#define IMX7D_EIM_ROOT_SRC 179 +#define IMX7D_EIM_ROOT_CG 180 +#define IMX7D_EIM_ROOT_DIV 181 +#define IMX7D_NAND_ROOT_CLK 182 +#define IMX7D_NAND_ROOT_SRC 183 +#define IMX7D_NAND_ROOT_CG 184 +#define IMX7D_NAND_ROOT_DIV 185 +#define IMX7D_QSPI_ROOT_CLK 186 +#define IMX7D_QSPI_ROOT_SRC 187 +#define IMX7D_QSPI_ROOT_CG 188 +#define IMX7D_QSPI_ROOT_DIV 189 +#define IMX7D_USDHC1_ROOT_CLK 190 +#define IMX7D_USDHC1_ROOT_SRC 191 +#define IMX7D_USDHC1_ROOT_CG 192 +#define IMX7D_USDHC1_ROOT_DIV 193 +#define IMX7D_USDHC2_ROOT_CLK 194 +#define IMX7D_USDHC2_ROOT_SRC 195 +#define IMX7D_USDHC2_ROOT_CG 196 +#define IMX7D_USDHC2_ROOT_DIV 197 +#define IMX7D_USDHC3_ROOT_CLK 198 +#define IMX7D_USDHC3_ROOT_SRC 199 +#define IMX7D_USDHC3_ROOT_CG 200 +#define IMX7D_USDHC3_ROOT_DIV 201 +#define IMX7D_CAN1_ROOT_CLK 202 +#define IMX7D_CAN1_ROOT_SRC 203 +#define IMX7D_CAN1_ROOT_CG 204 +#define IMX7D_CAN1_ROOT_DIV 205 +#define IMX7D_CAN2_ROOT_CLK 206 +#define IMX7D_CAN2_ROOT_SRC 207 +#define IMX7D_CAN2_ROOT_CG 208 +#define IMX7D_CAN2_ROOT_DIV 209 +#define IMX7D_I2C1_ROOT_CLK 210 +#define IMX7D_I2C1_ROOT_SRC 211 +#define IMX7D_I2C1_ROOT_CG 212 +#define IMX7D_I2C1_ROOT_DIV 213 +#define IMX7D_I2C2_ROOT_CLK 214 +#define IMX7D_I2C2_ROOT_SRC 215 +#define IMX7D_I2C2_ROOT_CG 216 +#define IMX7D_I2C2_ROOT_DIV 217 +#define IMX7D_I2C3_ROOT_CLK 218 +#define IMX7D_I2C3_ROOT_SRC 219 +#define IMX7D_I2C3_ROOT_CG 220 +#define IMX7D_I2C3_ROOT_DIV 221 +#define IMX7D_I2C4_ROOT_CLK 222 +#define IMX7D_I2C4_ROOT_SRC 223 +#define IMX7D_I2C4_ROOT_CG 224 +#define IMX7D_I2C4_ROOT_DIV 225 +#define IMX7D_UART1_ROOT_CLK 226 +#define IMX7D_UART1_ROOT_SRC 227 +#define IMX7D_UART1_ROOT_CG 228 +#define IMX7D_UART1_ROOT_DIV 229 +#define IMX7D_UART2_ROOT_CLK 230 +#define IMX7D_UART2_ROOT_SRC 231 +#define IMX7D_UART2_ROOT_CG 232 +#define IMX7D_UART2_ROOT_DIV 233 +#define IMX7D_UART3_ROOT_CLK 234 +#define IMX7D_UART3_ROOT_SRC 235 +#define IMX7D_UART3_ROOT_CG 236 +#define IMX7D_UART3_ROOT_DIV 237 +#define IMX7D_UART4_ROOT_CLK 238 +#define IMX7D_UART4_ROOT_SRC 239 +#define IMX7D_UART4_ROOT_CG 240 +#define IMX7D_UART4_ROOT_DIV 241 +#define IMX7D_UART5_ROOT_CLK 242 +#define IMX7D_UART5_ROOT_SRC 243 +#define IMX7D_UART5_ROOT_CG 244 +#define IMX7D_UART5_ROOT_DIV 245 +#define IMX7D_UART6_ROOT_CLK 246 +#define IMX7D_UART6_ROOT_SRC 247 +#define IMX7D_UART6_ROOT_CG 248 +#define IMX7D_UART6_ROOT_DIV 249 +#define IMX7D_UART7_ROOT_CLK 250 +#define IMX7D_UART7_ROOT_SRC 251 +#define IMX7D_UART7_ROOT_CG 252 +#define IMX7D_UART7_ROOT_DIV 253 +#define IMX7D_ECSPI1_ROOT_CLK 254 +#define IMX7D_ECSPI1_ROOT_SRC 255 +#define IMX7D_ECSPI1_ROOT_CG 256 +#define IMX7D_ECSPI1_ROOT_DIV 257 +#define IMX7D_ECSPI2_ROOT_CLK 258 +#define IMX7D_ECSPI2_ROOT_SRC 259 +#define IMX7D_ECSPI2_ROOT_CG 260 +#define IMX7D_ECSPI2_ROOT_DIV 261 +#define IMX7D_ECSPI3_ROOT_CLK 262 +#define IMX7D_ECSPI3_ROOT_SRC 263 +#define IMX7D_ECSPI3_ROOT_CG 264 +#define IMX7D_ECSPI3_ROOT_DIV 265 +#define IMX7D_ECSPI4_ROOT_CLK 266 +#define IMX7D_ECSPI4_ROOT_SRC 267 +#define IMX7D_ECSPI4_ROOT_CG 268 +#define IMX7D_ECSPI4_ROOT_DIV 269 +#define IMX7D_PWM1_ROOT_CLK 270 +#define IMX7D_PWM1_ROOT_SRC 271 +#define IMX7D_PWM1_ROOT_CG 272 +#define IMX7D_PWM1_ROOT_DIV 273 +#define IMX7D_PWM2_ROOT_CLK 274 +#define IMX7D_PWM2_ROOT_SRC 275 +#define IMX7D_PWM2_ROOT_CG 276 +#define IMX7D_PWM2_ROOT_DIV 277 +#define IMX7D_PWM3_ROOT_CLK 278 +#define IMX7D_PWM3_ROOT_SRC 279 +#define IMX7D_PWM3_ROOT_CG 280 +#define IMX7D_PWM3_ROOT_DIV 281 +#define IMX7D_PWM4_ROOT_CLK 282 +#define IMX7D_PWM4_ROOT_SRC 283 +#define IMX7D_PWM4_ROOT_CG 284 +#define IMX7D_PWM4_ROOT_DIV 285 +#define IMX7D_FLEXTIMER1_ROOT_CLK 286 +#define IMX7D_FLEXTIMER1_ROOT_SRC 287 +#define IMX7D_FLEXTIMER1_ROOT_CG 288 +#define IMX7D_FLEXTIMER1_ROOT_DIV 289 +#define IMX7D_FLEXTIMER2_ROOT_CLK 290 +#define IMX7D_FLEXTIMER2_ROOT_SRC 291 +#define IMX7D_FLEXTIMER2_ROOT_CG 292 +#define IMX7D_FLEXTIMER2_ROOT_DIV 293 +#define IMX7D_SIM1_ROOT_CLK 294 +#define IMX7D_SIM1_ROOT_SRC 295 +#define IMX7D_SIM1_ROOT_CG 296 +#define IMX7D_SIM1_ROOT_DIV 297 +#define IMX7D_SIM2_ROOT_CLK 298 +#define IMX7D_SIM2_ROOT_SRC 299 +#define IMX7D_SIM2_ROOT_CG 300 +#define IMX7D_SIM2_ROOT_DIV 301 +#define IMX7D_GPT1_ROOT_CLK 302 +#define IMX7D_GPT1_ROOT_SRC 303 +#define IMX7D_GPT1_ROOT_CG 304 +#define IMX7D_GPT1_ROOT_DIV 305 +#define IMX7D_GPT2_ROOT_CLK 306 +#define IMX7D_GPT2_ROOT_SRC 307 +#define IMX7D_GPT2_ROOT_CG 308 +#define IMX7D_GPT2_ROOT_DIV 309 +#define IMX7D_GPT3_ROOT_CLK 310 +#define IMX7D_GPT3_ROOT_SRC 311 +#define IMX7D_GPT3_ROOT_CG 312 +#define IMX7D_GPT3_ROOT_DIV 313 +#define IMX7D_GPT4_ROOT_CLK 314 +#define IMX7D_GPT4_ROOT_SRC 315 +#define IMX7D_GPT4_ROOT_CG 316 +#define IMX7D_GPT4_ROOT_DIV 317 +#define IMX7D_TRACE_ROOT_CLK 318 +#define IMX7D_TRACE_ROOT_SRC 319 +#define IMX7D_TRACE_ROOT_CG 320 +#define IMX7D_TRACE_ROOT_DIV 321 +#define IMX7D_WDOG1_ROOT_CLK 322 +#define IMX7D_WDOG_ROOT_SRC 323 +#define IMX7D_WDOG_ROOT_CG 324 +#define IMX7D_WDOG_ROOT_DIV 325 +#define IMX7D_CSI_MCLK_ROOT_CLK 326 +#define IMX7D_CSI_MCLK_ROOT_SRC 327 +#define IMX7D_CSI_MCLK_ROOT_CG 328 +#define IMX7D_CSI_MCLK_ROOT_DIV 329 +#define IMX7D_AUDIO_MCLK_ROOT_CLK 330 +#define IMX7D_AUDIO_MCLK_ROOT_SRC 331 +#define IMX7D_AUDIO_MCLK_ROOT_CG 332 +#define IMX7D_AUDIO_MCLK_ROOT_DIV 333 +#define IMX7D_WRCLK_ROOT_CLK 334 +#define IMX7D_WRCLK_ROOT_SRC 335 +#define IMX7D_WRCLK_ROOT_CG 336 +#define IMX7D_WRCLK_ROOT_DIV 337 +#define IMX7D_CLKO1_ROOT_SRC 338 +#define IMX7D_CLKO1_ROOT_CG 339 +#define IMX7D_CLKO1_ROOT_DIV 340 +#define IMX7D_CLKO2_ROOT_SRC 341 +#define IMX7D_CLKO2_ROOT_CG 342 +#define IMX7D_CLKO2_ROOT_DIV 343 +#define IMX7D_MAIN_AXI_ROOT_PRE_DIV 344 +#define IMX7D_DISP_AXI_ROOT_PRE_DIV 345 +#define IMX7D_ENET_AXI_ROOT_PRE_DIV 346 +#define IMX7D_NAND_USDHC_BUS_ROOT_PRE_DIV 347 +#define IMX7D_AHB_CHANNEL_ROOT_PRE_DIV 348 +#define IMX7D_USB_HSIC_ROOT_PRE_DIV 349 +#define IMX7D_PCIE_CTRL_ROOT_PRE_DIV 350 +#define IMX7D_PCIE_PHY_ROOT_PRE_DIV 351 +#define IMX7D_EPDC_PIXEL_ROOT_PRE_DIV 352 +#define IMX7D_LCDIF_PIXEL_ROOT_PRE_DIV 353 +#define IMX7D_MIPI_DSI_ROOT_PRE_DIV 354 +#define IMX7D_MIPI_CSI_ROOT_PRE_DIV 355 +#define IMX7D_MIPI_DPHY_ROOT_PRE_DIV 356 +#define IMX7D_SAI1_ROOT_PRE_DIV 357 +#define IMX7D_SAI2_ROOT_PRE_DIV 358 +#define IMX7D_SAI3_ROOT_PRE_DIV 359 +#define IMX7D_SPDIF_ROOT_PRE_DIV 360 +#define IMX7D_ENET1_REF_ROOT_PRE_DIV 361 +#define IMX7D_ENET1_TIME_ROOT_PRE_DIV 362 +#define IMX7D_ENET2_REF_ROOT_PRE_DIV 363 +#define IMX7D_ENET2_TIME_ROOT_PRE_DIV 364 +#define IMX7D_ENET_PHY_REF_ROOT_PRE_DIV 365 +#define IMX7D_EIM_ROOT_PRE_DIV 366 +#define IMX7D_NAND_ROOT_PRE_DIV 367 +#define IMX7D_QSPI_ROOT_PRE_DIV 368 +#define IMX7D_USDHC1_ROOT_PRE_DIV 369 +#define IMX7D_USDHC2_ROOT_PRE_DIV 370 +#define IMX7D_USDHC3_ROOT_PRE_DIV 371 +#define IMX7D_CAN1_ROOT_PRE_DIV 372 +#define IMX7D_CAN2_ROOT_PRE_DIV 373 +#define IMX7D_I2C1_ROOT_PRE_DIV 374 +#define IMX7D_I2C2_ROOT_PRE_DIV 375 +#define IMX7D_I2C3_ROOT_PRE_DIV 376 +#define IMX7D_I2C4_ROOT_PRE_DIV 377 +#define IMX7D_UART1_ROOT_PRE_DIV 378 +#define IMX7D_UART2_ROOT_PRE_DIV 379 +#define IMX7D_UART3_ROOT_PRE_DIV 380 +#define IMX7D_UART4_ROOT_PRE_DIV 381 +#define IMX7D_UART5_ROOT_PRE_DIV 382 +#define IMX7D_UART6_ROOT_PRE_DIV 383 +#define IMX7D_UART7_ROOT_PRE_DIV 384 +#define IMX7D_ECSPI1_ROOT_PRE_DIV 385 +#define IMX7D_ECSPI2_ROOT_PRE_DIV 386 +#define IMX7D_ECSPI3_ROOT_PRE_DIV 387 +#define IMX7D_ECSPI4_ROOT_PRE_DIV 388 +#define IMX7D_PWM1_ROOT_PRE_DIV 389 +#define IMX7D_PWM2_ROOT_PRE_DIV 390 +#define IMX7D_PWM3_ROOT_PRE_DIV 391 +#define IMX7D_PWM4_ROOT_PRE_DIV 392 +#define IMX7D_FLEXTIMER1_ROOT_PRE_DIV 393 +#define IMX7D_FLEXTIMER2_ROOT_PRE_DIV 394 +#define IMX7D_SIM1_ROOT_PRE_DIV 395 +#define IMX7D_SIM2_ROOT_PRE_DIV 396 +#define IMX7D_GPT1_ROOT_PRE_DIV 397 +#define IMX7D_GPT2_ROOT_PRE_DIV 398 +#define IMX7D_GPT3_ROOT_PRE_DIV 399 +#define IMX7D_GPT4_ROOT_PRE_DIV 400 +#define IMX7D_TRACE_ROOT_PRE_DIV 401 +#define IMX7D_WDOG_ROOT_PRE_DIV 402 +#define IMX7D_CSI_MCLK_ROOT_PRE_DIV 403 +#define IMX7D_AUDIO_MCLK_ROOT_PRE_DIV 404 +#define IMX7D_WRCLK_ROOT_PRE_DIV 405 +#define IMX7D_CLKO1_ROOT_PRE_DIV 406 +#define IMX7D_CLKO2_ROOT_PRE_DIV 407 +#define IMX7D_DRAM_PHYM_ALT_ROOT_PRE_DIV 408 +#define IMX7D_DRAM_ALT_ROOT_PRE_DIV 409 +#define IMX7D_LVDS1_IN_CLK 410 +#define IMX7D_LVDS1_OUT_SEL 411 +#define IMX7D_LVDS1_OUT_CLK 412 +#define IMX7D_CLK_DUMMY 413 +#define IMX7D_GPT_3M_CLK 414 +#define IMX7D_OCRAM_CLK 415 +#define IMX7D_OCRAM_S_CLK 416 +#define IMX7D_WDOG2_ROOT_CLK 417 +#define IMX7D_WDOG3_ROOT_CLK 418 +#define IMX7D_WDOG4_ROOT_CLK 419 +#define IMX7D_SDMA_CORE_CLK 420 +#define IMX7D_USB1_MAIN_480M_CLK 421 +#define IMX7D_USB_CTRL_CLK 422 +#define IMX7D_USB_PHY1_CLK 423 +#define IMX7D_USB_PHY2_CLK 424 +#define IMX7D_IPG_ROOT_CLK 425 +#define IMX7D_SAI1_IPG_CLK 426 +#define IMX7D_SAI2_IPG_CLK 427 +#define IMX7D_SAI3_IPG_CLK 428 +#define IMX7D_PLL_AUDIO_TEST_DIV 429 +#define IMX7D_PLL_AUDIO_POST_DIV 430 +#define IMX7D_PLL_VIDEO_TEST_DIV 431 +#define IMX7D_PLL_VIDEO_POST_DIV 432 +#define IMX7D_MU_ROOT_CLK 433 +#define IMX7D_SEMA4_HS_ROOT_CLK 434 +#define IMX7D_PLL_DRAM_TEST_DIV 435 +#define IMX7D_ADC_ROOT_CLK 436 +#define IMX7D_CLK_ARM 437 +#define IMX7D_CKIL 438 +#define IMX7D_OCOTP_CLK 439 +#define IMX7D_CLK_END 440 +#endif /* __DT_BINDINGS_CLOCK_IMX7D_H */
participants (6)
Fabio Estevam
Jagan Teki
Peng Fan
Peng Fan
Stefano Babic
