[U-Boot] [PATCH 0/4] Introduce lcd_console rotation.
Sometimes, for example if the display is mounted in portrait mode or even if it
mounted landscape but rotated by 180 degree, we need to rotate our content of the display respectively the framebuffer, so that user can read the messages who are printed out.
For this we introduce the feature called "CONFIG_LCD_ROTATION", this may be defined in the board-configuration if needed. After this the lcd_console will be initialized with a given rotation from "vl_rot" out of "vidinfo_t" which is provided by the board specific code.
If CONFIG_LCD_ROTATION is not defined, the console will be initialized with 0 degrees rotation - the screen behaves like the days before.
Patch 1-3 make preparations to the code. Patch 4 implements the new feature
Hannes Petermaier (4): common/lcd_console: cleanup lcd_drawchars/lcd_putc_xy common/lcd_console: ask only one-time for bg/fg-color per call common/lcd_console: move single static variables into common (static) structure common/lcd_console: introduce display/framebuffer rotation
README | 17 +++ common/lcd.c | 22 +-- common/lcd_console.c | 395 +++++++++++++++++++++++++++++++++++++------------ include/lcd.h | 1 + include/lcd_console.h | 9 +- 5 files changed, 334 insertions(+), 110 deletions(-)
From: Hannes Petermaier hannes.petermaier@br-automation.com
the capability of drawing some *str with count from lcd_drawchars is unnary. It is always called from lcd_putc_xy with one character of and count = 1.
So we simply rename lcd_drawchars into lcd_putc_xy and remove the loops inside.
Signed-off-by: Hannes Petermaier hannes.petermaier@br-automation.com Signed-off-by: Hannes Petermaier oe5hpm@oevsv.at ---
common/lcd_console.c | 23 +++++++---------------- 1 file changed, 7 insertions(+), 16 deletions(-)
diff --git a/common/lcd_console.c b/common/lcd_console.c index 8bf83b9..243b7c5 100644 --- a/common/lcd_console.c +++ b/common/lcd_console.c @@ -55,18 +55,17 @@ int lcd_get_screen_columns(void) return console_cols; }
-static void lcd_drawchars(ushort x, ushort y, uchar *str, int count) +static void lcd_putc_xy(ushort x, ushort y, char c) { uchar *dest; ushort row; int fg_color, bg_color; + int i;
dest = (uchar *)(lcd_console_address + y * lcd_line_length + x * NBITS(LCD_BPP) / 8);
for (row = 0; row < VIDEO_FONT_HEIGHT; ++row, dest += lcd_line_length) { - uchar *s = str; - int i; #if LCD_BPP == LCD_COLOR16 ushort *d = (ushort *)dest; #elif LCD_BPP == LCD_COLOR32 @@ -77,25 +76,17 @@ static void lcd_drawchars(ushort x, ushort y, uchar *str, int count)
fg_color = lcd_getfgcolor(); bg_color = lcd_getbgcolor(); - for (i = 0; i < count; ++i) { - uchar c, bits;
- c = *s++; - bits = video_fontdata[c * VIDEO_FONT_HEIGHT + row]; + uchar bits; + bits = video_fontdata[c * VIDEO_FONT_HEIGHT + row];
- for (c = 0; c < 8; ++c) { - *d++ = (bits & 0x80) ? fg_color : bg_color; - bits <<= 1; - } + for (i = 0; i < 8; ++i) { + *d++ = (bits & 0x80) ? fg_color : bg_color; + bits <<= 1; } } }
-static inline void lcd_putc_xy(ushort x, ushort y, uchar c) -{ - lcd_drawchars(x, y, &c, 1); -} - static void console_scrollup(void) { const int rows = CONFIG_CONSOLE_SCROLL_LINES;
Hi Hannes,
Acked-by: Nikita Kiryanov nikita@compulab.co.il
Don't call the lcd_getfgcolor and lcd_getbgcolor within the "draw-loop", this only wastes time.
common/lcd_console.c | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/common/lcd_console.c b/common/lcd_console.c index 243b7c5..b7dda7a 100644 --- a/common/lcd_console.c +++ b/common/lcd_console.c @@ -59,7 +59,8 @@ static void lcd_putc_xy(ushort x, ushort y, char c) { uchar *dest; ushort row; - int fg_color, bg_color; + int fg_color = lcd_getfgcolor(); + int bg_color = lcd_getbgcolor(); int i;
dest = (uchar *)(lcd_console_address + @@ -73,10 +74,6 @@ static void lcd_putc_xy(ushort x, ushort y, char c) #else uchar *d = dest; #endif - - fg_color = lcd_getfgcolor(); - bg_color = lcd_getbgcolor(); - uchar bits; bits = video_fontdata[c * VIDEO_FONT_HEIGHT + row];
Hi Hannes,
-- Regards, Nikita Kiryanov
For coming implementation of lcd_console rotation, we will need some more variables for holding information about framebuffer size, rotation, ...
For better readability we catch all them into a common structure.
common/lcd_console.c | 76 +++++++++++++++++++++++++------------------------- 1 file changed, 38 insertions(+), 38 deletions(-)
diff --git a/common/lcd_console.c b/common/lcd_console.c index b7dda7a..cac77be 100644 --- a/common/lcd_console.c +++ b/common/lcd_console.c @@ -11,48 +11,49 @@ #include <video_font.h> /* Get font data, width and height */
#define CONSOLE_ROW_SIZE (VIDEO_FONT_HEIGHT * lcd_line_length) -#define CONSOLE_ROW_FIRST lcd_console_address -#define CONSOLE_SIZE (CONSOLE_ROW_SIZE * console_rows) +#define CONSOLE_ROW_FIRST cons.lcd_address +#define CONSOLE_SIZE (CONSOLE_ROW_SIZE * cons.rows)
-static short console_curr_col; -static short console_curr_row; -static short console_cols; -static short console_rows; -static void *lcd_console_address; +struct console_t { + short curr_col, curr_row; + short cols, rows; + void *lcd_address; +}; +static struct console_t cons;
void lcd_init_console(void *address, int rows, int cols) { - console_curr_col = 0; - console_curr_row = 0; - console_cols = cols; - console_rows = rows; - lcd_console_address = address; + memset(&cons, 0, sizeof(cons)); + cons.cols = cols; + cons.rows = rows; + cons.lcd_address = address; + }
void lcd_set_col(short col) { - console_curr_col = col; + cons.curr_col = col; }
void lcd_set_row(short row) { - console_curr_row = row; + cons.curr_row = row; }
void lcd_position_cursor(unsigned col, unsigned row) { - console_curr_col = min_t(short, col, console_cols - 1); - console_curr_row = min_t(short, row, console_rows - 1); + cons.curr_col = min_t(short, col, cons.cols - 1); + cons.curr_row = min_t(short, row, cons.rows - 1); }
int lcd_get_screen_rows(void) { - return console_rows; + return cons.rows; }
int lcd_get_screen_columns(void) { - return console_cols; + return cons.cols; }
static void lcd_putc_xy(ushort x, ushort y, char c) @@ -63,7 +64,7 @@ static void lcd_putc_xy(ushort x, ushort y, char c) int bg_color = lcd_getbgcolor(); int i;
- dest = (uchar *)(lcd_console_address + + dest = (uchar *)(cons.lcd_address + y * lcd_line_length + x * NBITS(LCD_BPP) / 8);
for (row = 0; row < VIDEO_FONT_HEIGHT; ++row, dest += lcd_line_length) { @@ -91,7 +92,7 @@ static void console_scrollup(void)
/* Copy up rows ignoring those that will be overwritten */ memcpy(CONSOLE_ROW_FIRST, - lcd_console_address + CONSOLE_ROW_SIZE * rows, + cons.lcd_address + CONSOLE_ROW_SIZE * rows, CONSOLE_SIZE - CONSOLE_ROW_SIZE * rows);
/* Clear the last rows */ @@ -99,7 +100,7 @@ static void console_scrollup(void) memset(lcd_console_address + CONSOLE_SIZE - CONSOLE_ROW_SIZE * rows, bg_color, CONSOLE_ROW_SIZE * rows); #else - u32 *ppix = lcd_console_address + + u32 *ppix = cons.lcd_address + CONSOLE_SIZE - CONSOLE_ROW_SIZE * rows; u32 i; for (i = 0; @@ -109,27 +110,27 @@ static void console_scrollup(void) } #endif lcd_sync(); - console_curr_row -= rows; + cons.curr_row -= rows; }
static inline void console_back(void) { - if (--console_curr_col < 0) { - console_curr_col = console_cols - 1; - if (--console_curr_row < 0) - console_curr_row = 0; + if (--cons.curr_col < 0) { + cons.curr_col = cons.cols - 1; + if (--cons.curr_row < 0) + cons.curr_row = 0; }
- lcd_putc_xy(console_curr_col * VIDEO_FONT_WIDTH, - console_curr_row * VIDEO_FONT_HEIGHT, ' '); + lcd_putc_xy(cons.curr_col * VIDEO_FONT_WIDTH, + cons.curr_row * VIDEO_FONT_HEIGHT, ' '); }
static inline void console_newline(void) { - console_curr_col = 0; + cons.curr_col = 0;
/* Check if we need to scroll the terminal */ - if (++console_curr_row >= console_rows) + if (++cons.curr_row >= cons.rows) console_scrollup(); else lcd_sync(); @@ -145,18 +146,17 @@ void lcd_putc(const char c)
switch (c) { case '\r': - console_curr_col = 0; - + cons.curr_col = 0; return; case '\n': console_newline();
return; case '\t': /* Tab (8 chars alignment) */ - console_curr_col += 8; - console_curr_col &= ~7; + cons.curr_col += 8; + cons.curr_col &= ~7;
- if (console_curr_col >= console_cols) + if (cons.curr_col >= cons.cols) console_newline();
return; @@ -165,9 +165,9 @@ void lcd_putc(const char c)
return; default: - lcd_putc_xy(console_curr_col * VIDEO_FONT_WIDTH, - console_curr_row * VIDEO_FONT_HEIGHT, c); - if (++console_curr_col >= console_cols) + lcd_putc_xy(cons.curr_col * VIDEO_FONT_WIDTH, + cons.curr_row * VIDEO_FONT_HEIGHT, c); + if (++cons.curr_col >= cons.cols) console_newline(); } }
Hi Hannes,
- short curr_col, curr_row;
- short cols, rows;
- void *lcd_address;
Can this be void *base_address? I think that's a bit more descriptive.
Other than that, Acked-by: Nikita Kiryanov nikita@compulab.co.il
Nikita Kiryanov nikita@compulab.co.il schrieb am 15.03.2015 19:57:08:
Hi Hannes,
Hi Nikita,
- short cols, rows;
Yes, i will do some cleanup after Patch 4/4 is finished and within this action i will rename this variable to fbbase - this should be most descriptive.
many thanks and best regards, Hannes
Sometimes, for example if the display is mounted in portrait mode or even if it mounted landscape but rotated by 180 degrees, we need to rotate our content of the display respectively the framebuffer, so that user can read the messages who are printed out.
README | 17 +++ common/lcd.c | 22 ++-- common/lcd_console.c | 333 ++++++++++++++++++++++++++++++++++++++++--------- include/lcd.h | 1 + include/lcd_console.h | 9 +- 5 files changed, 309 insertions(+), 73 deletions(-)
diff --git a/README b/README index 3c4a2e6..a95b1e8 100644 --- a/README +++ b/README @@ -1933,6 +1933,23 @@ CBFS (Coreboot Filesystem) support the console jump but can help speed up operation when scrolling is slow.
+ CONFIG_LCD_ROTATION + + Sometimes, for example if the display is mounted in portrait + mode or even if it mounted landscape but rotated by 180degree, + we need to rotate our content of the display respectively the + framebuffer, so that user can read the messages who are printed + out. + For this we introduce the feature called "CONFIG_LCD_ROTATION", + this may be defined in the board-configuration if needed. After + this the lcd_console will be initialized with a given rotation + from "vl_rot" out of "vidinfo_t" which is provided by the board + specific code. + + If CONFIG_LCD_ROTATION is not defined, the console will be + initialized with 0degree rotation - the screen behaves like the + days before. + CONFIG_LCD_BMP_RLE8
Support drawing of RLE8-compressed bitmaps on the LCD. diff --git a/common/lcd.c b/common/lcd.c index f33942c..dfa4c69 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -167,7 +167,6 @@ int drv_lcd_init(void)
void lcd_clear(void) { - short console_rows, console_cols; int bg_color; char *s; ulong addr; @@ -211,16 +210,21 @@ void lcd_clear(void) } #endif #endif - /* Paint the logo and retrieve LCD base address */ - debug("[LCD] Drawing the logo...\n"); -#if defined(CONFIG_LCD_LOGO) && !defined(CONFIG_LCD_INFO_BELOW_LOGO) - console_rows = (panel_info.vl_row - BMP_LOGO_HEIGHT); - console_rows /= VIDEO_FONT_HEIGHT; + /* setup text-console */ + debug("[LCD] setting up console...\n"); +#ifdef CONFIG_LCD_ROTATION + lcd_init_console(lcd_base, + panel_info.vl_col, + panel_info.vl_row, + panel_info.vl_rot); #else - console_rows = panel_info.vl_row / VIDEO_FONT_HEIGHT; + lcd_init_console(lcd_base, + panel_info.vl_col, + panel_info.vl_row, + 0); #endif - console_cols = panel_info.vl_col / VIDEO_FONT_WIDTH; - lcd_init_console(lcd_base, console_rows, console_cols); + /* Paint the logo and retrieve LCD base address */ + debug("[LCD] Drawing the logo...\n"); if (do_splash) { s = getenv("splashimage"); if (s) { diff --git a/common/lcd_console.c b/common/lcd_console.c index cac77be..6199c9a 100644 --- a/common/lcd_console.c +++ b/common/lcd_console.c @@ -2,6 +2,7 @@ * (C) Copyright 2001-2014 * DENX Software Engineering -- wd@denx.de * Compulab Ltd - http://compulab.co.il/ + * Bernecker & Rainer Industrieelektronik GmbH - http://www.br-automation.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -10,26 +11,27 @@ #include <lcd.h> #include <video_font.h> /* Get font data, width and height */
-#define CONSOLE_ROW_SIZE (VIDEO_FONT_HEIGHT * lcd_line_length) -#define CONSOLE_ROW_FIRST cons.lcd_address -#define CONSOLE_SIZE (CONSOLE_ROW_SIZE * cons.rows) +#define PIXLBYTES (NBYTES(LCD_BPP)) + +#if LCD_BPP == LCD_COLOR16 + #define fbptr_t ushort +#elif LCD_BPP == LCD_COLOR32 + #define fbptr_t u32 +#else + #define fbptr_t uchar +#endif
struct console_t { short curr_col, curr_row; short cols, rows; void *lcd_address; + u32 lcdsizex, lcdsizey; + void (*fp_putc_xy)(ushort x, ushort y, char c); + void (*fp_console_moverow)(u32 rowdst, u32 rowsrc); + void (*fp_console_setrow)(u32 row, int clr); }; static struct console_t cons;
-void lcd_init_console(void *address, int rows, int cols) -{ - memset(&cons, 0, sizeof(cons)); - cons.cols = cols; - cons.rows = rows; - cons.lcd_address = address; - -} - void lcd_set_col(short col) { cons.curr_col = col; @@ -56,63 +58,221 @@ int lcd_get_screen_columns(void) return cons.cols; }
-static void lcd_putc_xy(ushort x, ushort y, char c) +static void lcd_putc_xy0(ushort x, ushort y, char c) { - uchar *dest; - ushort row; int fg_color = lcd_getfgcolor(); int bg_color = lcd_getbgcolor(); + int i, row; + uchar *dest = (uchar *)(cons.lcd_address + + y * cons.lcdsizex * PIXLBYTES + + x * PIXLBYTES); + + for (row = 0; row < VIDEO_FONT_HEIGHT; row++) { + fbptr_t *d = (fbptr_t *)dest; + uchar bits; + bits = video_fontdata[c * VIDEO_FONT_HEIGHT + row]; + for (i = 0; i < 8; ++i) { + *d++ = (bits & 0x80) ? fg_color : bg_color; + bits <<= 1; + } + dest += cons.lcdsizex * PIXLBYTES; + } +} + +static inline void console_setrow0(u32 row, int clr) +{ int i; + uchar *dst = (uchar *)(cons.lcd_address + + row * VIDEO_FONT_HEIGHT * + cons.lcdsizex * PIXLBYTES);
- dest = (uchar *)(cons.lcd_address + - y * lcd_line_length + x * NBITS(LCD_BPP) / 8); + fbptr_t *d = (fbptr_t *)dst; + for (i = 0; i < (VIDEO_FONT_HEIGHT * cons.lcdsizex); i++) + *d++ = clr; +}
- for (row = 0; row < VIDEO_FONT_HEIGHT; ++row, dest += lcd_line_length) { -#if LCD_BPP == LCD_COLOR16 - ushort *d = (ushort *)dest; -#elif LCD_BPP == LCD_COLOR32 - u32 *d = (u32 *)dest; -#else - uchar *d = dest; -#endif +static inline void console_moverow0(u32 rowdst, u32 rowsrc) +{ + int i; + uchar *dst = (uchar *)(cons.lcd_address + + rowdst * VIDEO_FONT_HEIGHT * + cons.lcdsizex * PIXLBYTES); + + uchar *src = (uchar *)(cons.lcd_address + + rowsrc * VIDEO_FONT_HEIGHT * + cons.lcdsizex * PIXLBYTES); + + fbptr_t *pdst = (fbptr_t *)dst; + fbptr_t *psrc = (fbptr_t *)src; + for (i = 0; i < (VIDEO_FONT_HEIGHT * cons.lcdsizex); i++) + *pdst++ = *psrc++; +} +#ifdef CONFIG_LCD_ROTATION +static void lcd_putc_xy90(ushort x, ushort y, char c) +{ + int fg_color = lcd_getfgcolor(); + int bg_color = lcd_getbgcolor(); + int i, col; + uchar *dest = (uchar *)(cons.lcd_address + + cons.lcdsizey * cons.lcdsizex * PIXLBYTES - + (x+1) * cons.lcdsizex * PIXLBYTES + + y * PIXLBYTES); + + fbptr_t *d = (fbptr_t *)dest; + uchar msk = 0x80; + uchar *pfont = video_fontdata + c * VIDEO_FONT_HEIGHT; + for (col = 0; col < VIDEO_FONT_WIDTH; ++col) { + for (i = 0; i < VIDEO_FONT_HEIGHT; ++i) + *d++ = (*(pfont + i) & msk) ? fg_color : bg_color; + msk >>= 1; + d -= (cons.lcdsizex + VIDEO_FONT_HEIGHT); + } +} + +static inline void console_setrow90(u32 row, int clr) +{ + int i, j; + uchar *dst = (uchar *)(cons.lcd_address + + row*VIDEO_FONT_HEIGHT * PIXLBYTES); + + for (j = 0; j < cons.lcdsizey; j++) { + fbptr_t *pdst = (fbptr_t *)dst; + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + *pdst++ = clr; + dst += cons.lcdsizex * PIXLBYTES; + } +} + +static inline void console_moverow90(u32 rowdst, u32 rowsrc) +{ + int i, j; + uchar *dst = (uchar *)(cons.lcd_address + + rowdst*VIDEO_FONT_HEIGHT * PIXLBYTES); + + uchar *src = (uchar *)(cons.lcd_address + + rowsrc*VIDEO_FONT_HEIGHT * PIXLBYTES); + + for (j = 0; j < cons.lcdsizey; j++) { + fbptr_t *psrc = (fbptr_t *)src; + fbptr_t *pdst = (fbptr_t *)dst; + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + *pdst++ = *psrc++; + src += cons.lcdsizex * PIXLBYTES; + dst += cons.lcdsizex * PIXLBYTES; + } +} + +static void lcd_putc_xy180(ushort x, ushort y, char c) +{ + int fg_color = lcd_getfgcolor(); + int bg_color = lcd_getbgcolor(); + int i, row; + uchar *dest = (uchar *)(cons.lcd_address + + cons.lcdsizex * PIXLBYTES + + cons.lcdsizey * cons.lcdsizex * PIXLBYTES - + y * cons.lcdsizex * PIXLBYTES - + (x+1) * PIXLBYTES); + + for (row = 0; row < VIDEO_FONT_HEIGHT; row++) { + fbptr_t *d = (fbptr_t *)dest; uchar bits; bits = video_fontdata[c * VIDEO_FONT_HEIGHT + row];
for (i = 0; i < 8; ++i) { - *d++ = (bits & 0x80) ? fg_color : bg_color; + *d-- = (bits & 0x80) ? fg_color : bg_color; bits <<= 1; } + dest -= cons.lcdsizex * PIXLBYTES; } }
-static void console_scrollup(void) +static void lcd_putc_xy270(ushort x, ushort y, char c) { - const int rows = CONFIG_CONSOLE_SCROLL_LINES; + int fg_color = lcd_getfgcolor(); int bg_color = lcd_getbgcolor(); + int col, i; + uchar *dest = (uchar *)(cons.lcd_address + + ((x+1) * cons.lcdsizex) * PIXLBYTES - + y * PIXLBYTES); + + fbptr_t *d = (fbptr_t *)dest; + uchar msk = 0x80; + uchar *pfont = video_fontdata + c * VIDEO_FONT_HEIGHT; + for (col = 0; col < VIDEO_FONT_WIDTH; ++col) { + for (i = 0; i < VIDEO_FONT_HEIGHT; ++i) + *d-- = (*(pfont + i) & msk) ? fg_color : bg_color; + msk >>= 1; + d += (cons.lcdsizex + VIDEO_FONT_HEIGHT); + } +}
- /* Copy up rows ignoring those that will be overwritten */ - memcpy(CONSOLE_ROW_FIRST, - cons.lcd_address + CONSOLE_ROW_SIZE * rows, - CONSOLE_SIZE - CONSOLE_ROW_SIZE * rows); +static inline void console_setrow270(u32 row, int clr) +{ + int i, j; + uchar *dst = (uchar *)(cons.lcd_address + + cons.lcdsizex * PIXLBYTES - + (row*VIDEO_FONT_HEIGHT+1) * PIXLBYTES); + + for (j = 0; j < cons.lcdsizey; j++) { + fbptr_t *pdst = (fbptr_t *)dst; + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + *pdst-- = clr; + dst += cons.lcdsizex * PIXLBYTES; + } +}
- /* Clear the last rows */ -#if (LCD_BPP != LCD_COLOR32) - memset(lcd_console_address + CONSOLE_SIZE - CONSOLE_ROW_SIZE * rows, - bg_color, CONSOLE_ROW_SIZE * rows); -#else - u32 *ppix = cons.lcd_address + - CONSOLE_SIZE - CONSOLE_ROW_SIZE * rows; - u32 i; - for (i = 0; - i < (CONSOLE_ROW_SIZE * rows) / NBYTES(panel_info.vl_bpix); - i++) { - *ppix++ = bg_color; +static inline void console_moverow270(u32 rowdst, u32 rowsrc) +{ + int i, j; + uchar *dst = (uchar *)(cons.lcd_address + + cons.lcdsizex * PIXLBYTES - + (rowdst*VIDEO_FONT_HEIGHT+1) * PIXLBYTES); + + uchar *src = (uchar *)(cons.lcd_address + + cons.lcdsizex * PIXLBYTES - + (rowsrc*VIDEO_FONT_HEIGHT+1) * PIXLBYTES); + + for (j = 0; j < cons.lcdsizey; j++) { + fbptr_t *psrc = (fbptr_t *)src; + fbptr_t *pdst = (fbptr_t *)dst; + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + *pdst-- = *psrc--; + src += cons.lcdsizex * PIXLBYTES; + dst += cons.lcdsizex * PIXLBYTES; } -#endif - lcd_sync(); - cons.curr_row -= rows; }
+static inline void console_setrow180(u32 row, int clr) +{ + int i; + uchar *dst = (uchar *)(cons.lcd_address + + (cons.rows-row-1) * VIDEO_FONT_HEIGHT * + cons.lcdsizex * PIXLBYTES); + + fbptr_t *d = (fbptr_t *)dst; + for (i = 0; i < (VIDEO_FONT_HEIGHT * cons.lcdsizex); i++) + *d++ = clr; +} + +static inline void console_moverow180(u32 rowdst, u32 rowsrc) +{ + int i; + uchar *dst = (uchar *)(cons.lcd_address + + (cons.rows-rowdst-1) * VIDEO_FONT_HEIGHT * + cons.lcdsizex * PIXLBYTES); + + uchar *src = (uchar *)(cons.lcd_address + + (cons.rows-rowsrc-1) * VIDEO_FONT_HEIGHT * + cons.lcdsizex * PIXLBYTES); + + fbptr_t *pdst = (fbptr_t *)dst; + fbptr_t *psrc = (fbptr_t *)src; + for (i = 0; i < (VIDEO_FONT_HEIGHT * cons.lcdsizex); i++) + *pdst++ = *psrc++; +} + +#endif /* CONFIG_LCD_ROTATION */ + static inline void console_back(void) { if (--cons.curr_col < 0) { @@ -121,26 +281,83 @@ static inline void console_back(void) cons.curr_row = 0; }
- lcd_putc_xy(cons.curr_col * VIDEO_FONT_WIDTH, - cons.curr_row * VIDEO_FONT_HEIGHT, ' '); + cons.fp_putc_xy(cons.curr_col * VIDEO_FONT_WIDTH, + cons.curr_row * VIDEO_FONT_HEIGHT, ' '); }
static inline void console_newline(void) { + const int rows = CONFIG_CONSOLE_SCROLL_LINES; + int bg_color = lcd_getbgcolor(); + int i; + cons.curr_col = 0;
/* Check if we need to scroll the terminal */ - if (++cons.curr_row >= cons.rows) - console_scrollup(); - else - lcd_sync(); + if (++cons.curr_row >= cons.rows) { + for (i = 0; i < cons.rows-rows; i++) + cons.fp_console_moverow(i, i+rows); + for (i = 0; i < rows; i++) + cons.fp_console_setrow(cons.rows-i-1, bg_color); + cons.curr_row -= rows; + } + lcd_sync(); +} + +static void console_calc_rowcol(int vl_cols, int vl_rows, short *cl, short *rw) +{ + *cl = vl_cols / VIDEO_FONT_WIDTH; +#if defined(CONFIG_LCD_LOGO) && !defined(CONFIG_LCD_INFO_BELOW_LOGO) + *rw = (vl_rows - BMP_LOGO_HEIGHT); + *rw /= VIDEO_FONT_HEIGHT; +#else + *rw = vl_rows / VIDEO_FONT_HEIGHT; +#endif +} + +void lcd_init_console(void *address, int vl_cols, int vl_rows, int vl_rot) +{ + memset(&cons, 0, sizeof(cons)); + cons.lcd_address = address; + + cons.lcdsizex = vl_cols; + cons.lcdsizey = vl_rows; + + if (vl_rot == 0) { + cons.fp_putc_xy = &lcd_putc_xy0; + cons.fp_console_moverow = &console_moverow0; + cons.fp_console_setrow = &console_setrow0; + console_calc_rowcol(vl_cols, vl_rows, &cons.cols, &cons.rows); +#ifdef CONFIG_LCD_ROTATION + } else if (vl_rot == 90) { + cons.fp_putc_xy = &lcd_putc_xy90; + cons.fp_console_moverow = &console_moverow90; + cons.fp_console_setrow = &console_setrow90; + console_calc_rowcol(vl_rows, vl_cols, &cons.cols, &cons.rows); + } else if (vl_rot == 180) { + cons.fp_putc_xy = &lcd_putc_xy180; + cons.fp_console_moverow = &console_moverow180; + cons.fp_console_setrow = &console_setrow180; + console_calc_rowcol(vl_cols, vl_rows, &cons.cols, &cons.rows); + } else if (vl_rot == 270) { + cons.fp_putc_xy = &lcd_putc_xy270; + cons.fp_console_moverow = &console_moverow270; + cons.fp_console_setrow = &console_setrow270; + console_calc_rowcol(vl_rows, vl_cols, &cons.cols, &cons.rows); +#endif + } else { + puts("lcd_init_console: invalid framebuffer rotation!\n"); + } + + debug("lcd_console: have %d/%d col/rws on scr %dx%d (%d deg rotated)\n", + cons.cols, cons.rows, cons.lcdsizex, cons.lcdsizey, vl_rot); + }
void lcd_putc(const char c) { if (!lcd_is_enabled) { serial_putc(c); - return; }
@@ -150,7 +367,6 @@ void lcd_putc(const char c) return; case '\n': console_newline(); - return; case '\t': /* Tab (8 chars alignment) */ cons.curr_col += 8; @@ -158,15 +374,13 @@ void lcd_putc(const char c)
if (cons.curr_col >= cons.cols) console_newline(); - return; case '\b': console_back(); - return; default: - lcd_putc_xy(cons.curr_col * VIDEO_FONT_WIDTH, - cons.curr_row * VIDEO_FONT_HEIGHT, c); + cons.fp_putc_xy(cons.curr_col * VIDEO_FONT_WIDTH, + cons.curr_row * VIDEO_FONT_HEIGHT, c); if (++cons.curr_col >= cons.cols) console_newline(); } @@ -176,7 +390,6 @@ void lcd_puts(const char *s) { if (!lcd_is_enabled) { serial_puts(s); - return; }
diff --git a/include/lcd.h b/include/lcd.h index f049fd3..41e0c11 100644 --- a/include/lcd.h +++ b/include/lcd.h @@ -51,6 +51,7 @@ void lcd_set_flush_dcache(int flush); typedef struct vidinfo { ushort vl_col; /* Number of columns (i.e. 160) */ ushort vl_row; /* Number of rows (i.e. 100) */ + ushort vl_rot; /* Rotation of Display (i.e. 90) */ u_char vl_bpix; /* Bits per pixel, 0 = 1 */ ushort *cmap; /* Pointer to the colormap */ void *priv; /* Pointer to driver-specific data */ diff --git a/include/lcd_console.h b/include/lcd_console.h index 429214d..2244b3f 100644 --- a/include/lcd_console.h +++ b/include/lcd_console.h @@ -16,11 +16,12 @@ * console has. * * @address: Console base address - * @rows: Number of rows in the console - * @cols: Number of columns in the console + * @vl_rows: Number of rows in the console + * @vl_cols: Number of columns in the console + * @vl_rot: Rotation of display in degree (0 - 90 - 180 - 270) counterlockwise */ -void lcd_init_console(void *address, int rows, int cols); - +/*void lcd_init_console(void *address, int rows, int cols); */ +void lcd_init_console(void *address, int vl_cols, int vl_rows, int vl_rot); /** * lcd_set_col() - Set the number of the current lcd console column *
Hi Hannes,
- /* setup text-console */
- debug("[LCD] setting up console...\n");
panel_info.vl_col,
panel_info.vl_row,
panel_info.vl_rot);
#else
panel_info.vl_col,
panel_info.vl_row,
0);
#endif
Please, don't start the #ifdef mess here... just always pass the panel_info.vl_rot.
- debug("[LCD] Drawing the logo...\n"); if (do_splash) { s = getenv("splashimage"); if (s) {
- (C) Copyright 2001-2014
- DENX Software Engineering -- wd@denx.de
- Compulab Ltd - http://compulab.co.il/
- Bernecker & Rainer Industrieelektronik GmbH - http://www.br-automation.com
- #define fbptr_t ushort
- #define fbptr_t u32
+#else
- #define fbptr_t uchar
- u32 lcdsizex, lcdsizey;
- void (*fp_putc_xy)(ushort x, ushort y, char c);
- void (*fp_console_moverow)(u32 rowdst, u32 rowsrc);
- void (*fp_console_setrow)(u32 row, int clr);
- cons.cols = cols;
- cons.rows = rows;
- uchar *dest;
- int i, row;
- uchar *dest = (uchar *)(cons.lcd_address +
x * PIXLBYTES);
- for (row = 0; row < VIDEO_FONT_HEIGHT; row++) {
uchar bits;
bits <<= 1;
- uchar *dst = (uchar *)(cons.lcd_address +
- fbptr_t *d = (fbptr_t *)dst;
- for (i = 0; i < (VIDEO_FONT_HEIGHT * cons.lcdsizex); i++)
*d++ = clr;
-#else
uchar *d = dest;
- int i;
- uchar *src = (uchar *)(cons.lcd_address +
- fbptr_t *pdst = (fbptr_t *)dst;
- fbptr_t *psrc = (fbptr_t *)src;
*pdst++ = *psrc++;
- int fg_color = lcd_getfgcolor();
- int bg_color = lcd_getbgcolor();
- int i, col;
y * PIXLBYTES);
- fbptr_t *d = (fbptr_t *)dest;
- uchar msk = 0x80;
- uchar *pfont = video_fontdata + c * VIDEO_FONT_HEIGHT;
- for (col = 0; col < VIDEO_FONT_WIDTH; ++col) {
msk >>= 1;
- int i, j;
- for (j = 0; j < cons.lcdsizey; j++) {
*pdst++ = clr;
- int i, j;
*pdst++ = *psrc++;
int i, row;
(x+1) * PIXLBYTES);
}*d-- = (bits & 0x80) ? fg_color : bg_color; bits <<= 1;
}dest -= cons.lcdsizex * PIXLBYTES;
- int fg_color = lcd_getfgcolor(); int bg_color = lcd_getbgcolor();
- int col, i;
y * PIXLBYTES);
- uchar msk = 0x80;
msk >>= 1;
- int i, j;
*pdst-- = clr;
-#else
- u32 i;
- for (i = 0;
i++) {
*ppix++ = bg_color;
- int i, j;
*pdst-- = *psrc--;
}dst += cons.lcdsizex * PIXLBYTES;
-#endif
- lcd_sync();
- int i;
*d++ = clr;
- int i;
*pdst++ = *psrc++;
Can't this whole thing go into a separate file? So, the console stuff will only define weak functions which can be overridden by the rotation functionality. This will keep the console code clean (also from ifdefs) and have the rotation functionality cleanly added by a CONFIG_ symbol, which will control the compilation for the separate file.
- cons.fp_putc_xy(cons.curr_col * VIDEO_FONT_WIDTH,
int i;
cons.curr_col = 0;
console_scrollup();
- else
lcd_sync();
- if (++cons.curr_row >= cons.rows) {
- lcd_sync();
- *cl = vl_cols / VIDEO_FONT_WIDTH;
- *rw = (vl_rows - BMP_LOGO_HEIGHT);
- *rw /= VIDEO_FONT_HEIGHT;
+#else
- *rw = vl_rows / VIDEO_FONT_HEIGHT;
+#endif +}
- cons.lcdsizex = vl_cols;
- cons.lcdsizey = vl_rows;
- if (vl_rot == 0) {
This call can be made after the if else structure and written only once.
- } else if (vl_rot == 90) {
- } else if (vl_rot == 180) {
- } else if (vl_rot == 270) {
- } else {
I would recommend extracting the whole if else ... structure into a separate function say lcd_setup_console_rot() or something and make the default one doing only the vl_rot == 0 stuff.
- debug("lcd_console: have %d/%d col/rws on scr %dx%d (%d deg rotated)\n",
- return; }
On 2015-03-12 13:26, Igor Grinberg wrote:
Hi Hannes,
Hi Igor, thanks for response.
#endif
panel_info.vl_col,
panel_info.vl_row,
#elsepanel_info.vl_rot);
panel_info.vl_col,
panel_info.vl_row,
#endif0);
This is not possible, because 'vl_rot' does'nt exist if CONFIG_LCD_ROTATION is not defined. (have a look into lcd.h). I made this to be compatible to all who have allready initialized a panel_info without vl_rot.
+#else
- void (*fp_console_setrow)(u32 row, int clr); }; static struct console_t cons;
- cons.cols = cols;
- cons.rows = rows;
- uchar *dest;
- int i, row;
x * PIXLBYTES);
uchar bits;
bits <<= 1;
*d++ = clr;
-#else
uchar *d = dest;
- int i;
*pdst++ = *psrc++;
- int i, col;
y * PIXLBYTES);
- uchar msk = 0x80;
msk >>= 1;
- int i, j;
*pdst++ = clr;
- int i, j;
*pdst++ = *psrc++;
int i, row;
(x+1) * PIXLBYTES);
} }dest -= cons.lcdsizex * PIXLBYTES;
- int col, i;
y * PIXLBYTES);
- uchar msk = 0x80;
msk >>= 1;
- int i, j;
*pdst-- = clr;
-#else
- u32 i;
- for (i = 0;
i++) {
*ppix++ = bg_color;
- int i, j;
*pdst-- = *psrc--;
-#endif
- lcd_sync();
- int i;
*d++ = clr;
- int i;
*pdst++ = *psrc++;
Might be possible, which name should we give to it ? lcd_console_rotation.c ? But how we deal with the function-pointer initialization ?
- static inline void console_back(void) { if (--cons.curr_col < 0) {
int i;
cons.curr_col = 0;
console_scrollup();
- else
lcd_sync();
- lcd_sync();
+#else
+#endif +}
No. Have a closer look to it. If display is rotated 0°/180° the calculation is not the same if display is rotated 90/270°
- } else {
Whats the use of this ? Should this also be in a separate file?
Hi Hannes,
Hi Hannes,
#endif
panel_info.vl_col,
panel_info.vl_row,
panel_info.vl_col,
panel_info.vl_row,
#endif0);
Of course I did before sending the reply... What I'm trying to say is - let it exist and default to 0 angle rotation.
This increases the mess and I think is not sensible enough. Just change the users to initialize the panel_info with vl_rot. I think also that default initialization of globals is 0, right? If so, those users that do not initialize the vl_rot explicitly, should have it initialized to 0 implicitly by compiler.
@@ -10,26 +11,27 @@ #include <lcd.h> #include <video_font.h> /* Get font data, width and height */ -#define CONSOLE_ROW_SIZE (VIDEO_FONT_HEIGHT * lcd_line_length) -#define CONSOLE_ROW_FIRST cons.lcd_address -#define CONSOLE_SIZE (CONSOLE_ROW_SIZE * cons.rows) +#define PIXLBYTES (NBYTES(LCD_BPP))
+#else
+#endif struct console_t { short curr_col, curr_row; short cols, rows; void *lcd_address;
- void (*fp_console_setrow)(u32 row, int clr); }; static struct console_t cons; -void lcd_init_console(void *address, int rows, int cols)
- cons.cols = cols;
- cons.rows = rows;
@@ -56,63 +58,221 @@ int lcd_get_screen_columns(void) return cons.cols; } -static void lcd_putc_xy(ushort x, ushort y, char c) +static void lcd_putc_xy0(ushort x, ushort y, char c) {
- uchar *dest;
- int i, row;
x * PIXLBYTES);
uchar bits;
bits <<= 1;
*d++ = clr;
-#else
uchar *d = dest;
- int i;
*pdst++ = *psrc++;
- int i, col;
y * PIXLBYTES);
- uchar msk = 0x80;
msk >>= 1;
- int i, j;
*pdst++ = clr;
- int i, j;
*pdst++ = *psrc++;
- int i, row;
(x+1) * PIXLBYTES);
fbptr_t *d = (fbptr_t *)dest; uchar bits; bits = video_fontdata[c * VIDEO_FONT_HEIGHT + row]; for (i = 0; i < 8; ++i) {
} -static void console_scrollup(void)dest -= cons.lcdsizex * PIXLBYTES; }
- int col, i;
y * PIXLBYTES);
- uchar msk = 0x80;
msk >>= 1;
- int i, j;
*pdst-- = clr;
-#else
- u32 i;
- for (i = 0;
i++) {
*ppix++ = bg_color;
- int i, j;
*pdst-- = *psrc--;
-#endif
- lcd_sync();
- cons.curr_row -= rows; } +static inline void console_setrow180(u32 row, int clr)
- int i;
*d++ = clr;
- int i;
*pdst++ = *psrc++;
Sounds good.
I think the usual method would do... You call some kind of lcd_console_init_rot() with most of the code that you currently have in lcd_init_console() that is related to rotation. If the CONFIG_LCD_ROTATION is not set, then the lcd_init_console() stub just returns the 0 rotation config.
} static inline void console_newline(void) {cons.curr_row * VIDEO_FONT_HEIGHT, ' ');
- int i;
cons.curr_col = 0; /* Check if we need to scroll the terminal */
console_scrollup();
- else
lcd_sync();
- lcd_sync();
+#else
+#endif +}
Yep. Sorry, I've missed the switch between cols and rows...
- } else {
Yes, that is how I think it will do better.
Just to explain my points: 1) make the rotation feature an integrative part of the code by always using the rotation code: if CONFIG_LCD_ROTATION is *not* set then just rotate it to 0 degrees and compile out the rest of the code. 2) make the rotation feature a bit more separate from the console code. I believe this way will make it cleaner.
Also, might it be useful to allow specifiying the angle through the CONFIG_LCD_ROTATION define? Have you considered using Kconfig for this?
Hi Hannes,
Hi Igor,
panel_info.vl_col,
panel_info.vl_row,
panel_info.vl_col,
panel_info.vl_row,
#endif0);
rotation.
Yes, thats a good idea. I will check if the compiler really initializes the global struct panel_info with zero and change this.
} +static inline void console_setrow180(u32 row, int clr) +{
- int i;
*d++ = clr;
- int i;
*pdst++ = *psrc++;
overridden
rotation
the
Sounds good.
rotation.
I just started to move rotation specific functions into own file, called lcd_console_rotation.c and ran into some trouble.
1) I need during initialization the console_calc_rowcol(...) function, which is provided by lcd.c. A possible solution might be to "un-static" it - but i am not happy with this. Another way could be to take up vl_rot into console_t structure and pass only a pointer to structure to this function and decide inside the function. But this would create a little mix between 0 degree and rotation code. Yet another idea is to have (also having pointer to console_t in call) in lcd_console_rotation also such a calc function which overrides the values calculated before.
or maybe you've another solution ?
2) I need in almost every "paint-function" the framebuffer base (cons.lcd_address) and the screen dimension. This information is stored in the static structure within lcd.c - i don't like to make this public. A possible solution could be to change all painting function to work without some global variable and pass a third argument, pointer to console_t, and take informations from there. This will consume one more register on function call, runtime is equal i think.
Whats your opinion around this ?
- make the rotation feature an integrative part of the code by always
using
rotate it
Actually (within new code) i do initialize the pointers and things around with 0 degree rotation and call afterwards the new function lcd_init_console_rot which is implemented in lcd_console_rotation.c and "__weak" in lcd_console.c which does re-initialze fps and col/row stuff.
First i thought about this to specifiy rotation angle with a value defined CONFIG_LCD_ROTATION - but this is only usefull to one of my boards (where display is rotated 180degrees). In another board i have one U-Boot for a bunch of variants (16 at this time) where all rotation angles are needed. I want to take there this information out of device-tree and write it to vl_rot.
-- Regards, Igor.
On 03/16/15 10:32, Hannes Petermaier wrote:
Hi Hannes,
Hi Igor,
panel_info.vl_col,
panel_info.vl_row,
panel_info.vl_col,
panel_info.vl_row,
#endif0);
rotation.
- int i;
*d++ = clr;
- int i;
*pdst++ = *psrc++;
overridden
rotation
the
Sounds good.
rotation.
Well, you need to perform the rows and columns calculation regardless of the rotation feature, so the console_calc_rowcol() should be there anyway. It is a "bonus" that the rotation code can use the same function (and it looks generic enough) for rows and columns calculation, so IMO, a cleaner solution would be just make it non static.
Well, since Nikita is working on refactoring the lcd.c stuff and already examined several aproaches, I think he can provide a better opinion on this. Nikita?
using
rotate it
Sounds good.
Yep. This sounds even better. Does DT have an already defined property for this? Have you considered may be using an environment variable for this?
I think that passing a pointer to console_t is the way to go. You have an object oriented design here, and that's the object oriented way of accessing the object's members from its methods.
Hi Hannes,
I second Grinberg's suggestion of a separate file and 0 degree default (also as a fallback for invalid rotation value, see below). Some additional comments:
CONFIG_LCD_ROTATION
out.
specific code.
This is enough. "the screen behaves like the days before" is vague and unnecessary (days before what?)
days before.
CONFIG_LCD_BMP_RLE8
Here you can just create the fbptr variable directly. You have a bunch of function where this recasting is avoidable.
*d++ = clr;
- } else {
This case leaves the function pointers uninitialized, which would crash the system later on. I suggest you default to 0 degree rotation both for the generic case and for the fallback behavior (with the warning message where necessary).
This is a cleanup. It should not be in this patch.
return;
Same here, and in other places...
return;
- ushort vl_rot; /* Rotation of Display (i.e. 90) */ u_char vl_bpix; /* Bits per pixel, 0 = 1 */ ushort *cmap; /* Pointer to the colormap */ void *priv; /* Pointer to driver-specific data */
- console has.
- @address: Console base address
- @rows: Number of rows in the console
- @cols: Number of columns in the console
- @vl_rows: Number of rows in the console
- @vl_cols: Number of columns in the console
- @vl_rot: Rotation of display in degree (0 - 90 - 180 - 270) counterlockwise
Please delete this comment
- lcd_set_col() - Set the number of the current lcd console column
Nikita Kiryanov nikita@compulab.co.il schrieb am 15.03.2015 19:56:31:
Hi Hannes,
Hi Nikita, many thanks for response.
(also as a
Okay - i will provide a V2 from this patch where i try to implement as sugessted, maybe we will need some V3 :-) Probably on wednesday.
unnecessary
(days before what?)
Okay - i will do so.
of
*d++ = clr;
vl_rot)
- } else {
the
for
Oh my god, i haven't seen this mess ... i will remove it during moving lcd_rotation stuff into separate file.
I will make this cleanup in a following patch, after this series has been merged.
- console has.
counterlockwise
Okay.
participants (5)
Hannes Petermaier
Hannes Petermaier
Hannes Petermaier
Igor Grinberg
Nikita Kiryanov
