[U-Boot] [PATCH RESEND v2] armv7: Disable D cache for goni target (s5p)
Disable D cache for goni target (s5p) - rationale:
1. Before change introduced in commit SHA1:c2dd0d45540397704de9b13287417d21049d34c6 the D-cache for GONI target was disabled. This change was supposed to preserve this state.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com Cc: Aneesh V aneesh@ti.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net --- Changes for v2: - Rationale for disabling D cache
include/configs/s5p_goni.h | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index d648ce8..010428b 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -74,6 +74,9 @@ /* It should define before config_cmd_default.h */ #define CONFIG_SYS_NO_FLASH 1
+/* Cache D configuration */ +#define CONFIG_SYS_DCACHE_OFF + /* Command definition */ #include <config_cmd_default.h>
On Mon, Jul 18, 2011 at 9:23 AM, Lukasz Majewski l.majewski@samsung.com wrote:
- Before change introduced in commit
I had exactly the same rationale for disabling cache on the Integrator - it used to be off now it's default on and doesn't work - but that patch was NAK:ed by Wolfgang.
BTW: what CPU is there in the S5P?
Linus Walleij
Dear Linus Walleij,
Could you please give me the link of that thread?
Thanks Minkyu Kang
On Thu, Jul 28, 2011 at 7:04 AM, Minkyu Kang promsoft@gmail.com wrote:
Dear Linus Walleij,
Me: http://marc.info/?l=u-boot&m=131066804010454&w=2
Wolfgang: http://marc.info/?l=u-boot&m=131066501332302&w=2
AFAICT the idea is that it should be possible to turn D-cache off, we have to fix it if it doesn't work. Alternatively I have to prove that the D-cache on the ARM920T cannot be safely turned off at all, i.e. if it requires that the CP15 operation be done from an onchip memory or something like that.
Anyone knows, by the way? I've really tried hard to fix this and so far gotten nowhere.
Thanks, Linus Walleij
Hi Linus,
On Friday 29 July 2011 04:04 AM, Linus Walleij wrote:
On Thu, Jul 28, 2011 at 7:04 AM, Minkyu Kangpromsoft@gmail.com wrote:
Dear Linus Walleij,
On 18 July 2011 19:35, Linus Walleijlinus.walleij@linaro.org wrote:
On Mon, Jul 18, 2011 at 9:23 AM, Lukasz Majewskil.majewski@samsung.com wrote:
I hadn't noticed this thread before. Here are my thoughts on your problem:
I think the fundamental problem is that caching was enabled for ARM without putting the cache maintenance functions in place. At a minimum, we need a few flush and invalidate functions. I worked on this for armv7, but similar things need to be done for earlier architectures if you have to enable caching. Once we have these cache maintenance functions, they need to be used in the following scenarios to avoid coherency issues.
1. Drivers using DMA: i. Flush the buffer before initiating a memory to peripheral DMA. ii. Invalidate the buffer after a peripheral to memory DMA (before MPU reads it)
2. Cleanup before Linux: Flush the entire SDRAM and disable the cache.
I think you are hit by not doing 2 properly. If you have dirty entries in the cache when Linux boots you will have coherency issues. I had faced similar issues when I had some issues in armv7 cleanup_before_linux(). I had to do an extra invalidate to solve it. Please see how this has been done for armv7 in arch/arm/cpu/armv7/cpu.c in function cleanup_before_linux().
In some other cases there are problems due to (1) above. In any case, the starting point really is to make sure that you have the required set of maintenance functions for your architecture revision. We may not need maintenance functions for each architecture revision depending on the backward compatibility of the successive revisions. I have not looked into those details though.
best regards, Aneesh
Hi Aneesh,
On 29 July 2011 15:43, Aneesh V aneesh@ti.com wrote:
Hi Linus,
Dear Linus Walleij,
In my case i am using armv7 based board. Still flushing is not happening. If i am resetting the board after issuing saveenv command, environment is not retained. IMHO in armv7 still more handling need to be done. I am using mmc as boot media.
- Drivers using DMA:
- Cleanup before Linux:
best regards, Aneesh _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Chander,
On Friday 29 July 2011 04:01 PM, Chander Kashyap wrote:
Hi Aneesh,
On 29 July 2011 15:43, Aneesh Vaneesh@ti.com wrote:
Hi Linus,
Dear Linus Walleij,
Please note that what I have provided is a means to do the flushing, the APIs, and also I have taken care of the cleanup_beofre_linux() for armv7. You still need to do some work to fix the issues in category (1) below for your platform. For instance, does your MMC driver use DMA? If yes, you may have to look into it.
Hi Aneesh, thanks for taking time for this!
No problems with this. I only use the serial port and it's working flawlessly downloading a uImage to target with caches enabled.
Yes, this is the problem. The problem is further that I've tried several variants of code and of course following the ARM920T manual on how to do this.
Actually I think the problem is really not with the cache *at all* but with the MMU. The current ARM CP15 MMU code sets up an identity mapping and it is always turned on/off in conjunction with the cache.
The moste pedantic and careful code I have does this:
+#ifdef CONFIG_ARM920T + /* Flush all cache */ + debug("FLUSH I-cache\n"); + asm volatile("mcr p15, 0, %0, c7, c5, 0" : : "r" (0)); + isb(); + debug("FLUSH D-cache\n"); + asm volatile("mcr p15, 0, %0, c7, c6, 0" : : "r" (0)); + isb(); + debug("FLUSH all cache\n"); + asm volatile("mcr p15, 0, %0, c7, c7, 0" : : "r" (0)); + isb(); + /* Flush I+D TLB */ + debug("FLUSH I+D TLB\n"); + asm volatile("mcr p15, 0, %0, c8, c7, 0" : : "r" (0)); + isb(); + /* Drain write buffer */ + debug("Drain write buffer\n"); + asm volatile("mcr p15, 0, %0, c7, c10, 4" : : "r" (0)); + isb(); +#endif
This is called in arch/arm/lib/cache.c generic CP15 code as it calls __flush_cache before it turns off the MMU.
At this point the program counter goes astray and the machine hangs :-(
It's something like removing the identity map is not good for the CPU, it gets lost. I think. (Working hopothesis.)
I think actually all ARM920T machines are broken, they have just not been tested yet.
For the old CP15 caches it's quite simple, as can be seen from Linux MM code you just invalidate all the cache: asm volatile("mcr p15, 0, %0, c7, c7, 0" : : "r" (0));
Yours, Linus Walleij
Hi Linus,
isb();
isb();
isb();
/* Flush I+D TLB */
isb();
isb();
Is it hanging when you return from the function? What is the order in which you are disabling the cache, flushing it etc. This order is important. I had faced some issues initially when I developed the code for armv7. Please see a discussion about those issues in this thread:
http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/91332/focus=91965
I am not sure if identity mapping is the issue for you. At least, it's not causing any trouble on armv7.
PC going astray may be due to restoring wrong r14, which in turn, could be due to a cache-coherency problem.
Dear Minkyu, I am not able to retain environment saved on mmc card using setenv cmd when dcahe is enabled. By disabling it it works fine.
On 28 July 2011 10:34, Minkyu Kang promsoft@gmail.com wrote:
Dear Linus Walleij,
Thanks Minkyu Kang -- from. prom. www.promsoft.net _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
participants (5)
Aneesh V
Chander Kashyap
Linus Walleij
Lukasz Majewski
Minkyu Kang
