[PATCH] net: phy: xilinx_phy: Get rid of using property xlnx, phy-type
As the xlnx,phy-type device tree property is deprecated and phy-mode is being used, so removing the code references of xlnx,phy-type.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- drivers/net/phy/xilinx_phy.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/drivers/net/phy/xilinx_phy.c b/drivers/net/phy/xilinx_phy.c index 1df639d6f4..50f1611ad5 100644 --- a/drivers/net/phy/xilinx_phy.c +++ b/drivers/net/phy/xilinx_phy.c @@ -107,10 +107,6 @@ static int xilinxphy_of_init(struct phy_device *phydev) if (!ofnode_valid(node)) return -EINVAL;
- phytype = ofnode_read_u32_default(node, "xlnx,phy-type", -1); - if (phytype == XAE_PHY_TYPE_1000BASE_X) - phydev->flags |= XAE_PHY_TYPE_1000BASE_X; - return 0; }
- return 0; }
Applied. M
diff --git a/drivers/net/phy/xilinx_phy.c b/drivers/net/phy/xilinx_phy.c index 1df639d6f4..50f1611ad5 100644 --- a/drivers/net/phy/xilinx_phy.c +++ b/drivers/net/phy/xilinx_phy.c @@ -107,10 +107,6 @@ static int xilinxphy_of_init(struct phy_device *phydev) if (!ofnode_valid(node)) return -EINVAL; - phytype = ofnode_read_u32_default(node, "xlnx,phy-type", -1); - if (phytype == XAE_PHY_TYPE_1000BASE_X) - phydev->flags |= XAE_PHY_TYPE_1000BASE_X;
return 0; }
Applied. M
Actually no. I will remove this patch from my queue. You also need to remove phytype variable. That's why please send v2 on this.
M
Michal Simek
