[U-Boot] Regarding HUSH support in uboot
Hi How do we know whether hush shell capability is supported or not in the command shell.I have enabled CONFIG_SYS_HUSH_PARSER in in config file. I am trying to write simple script like below myname=`test` if $myname=test then echo "test" else echo "failed" fi I am getting the following error "unknown command test". Can anybody please let me know if the hush shell is eanbled or not. Thanks Amruth p.v
Dear amruth vamadev,
In message CAL5DGCRuO3aYZjTDoQbgSzd6-d4KAgsO7BfvSnPhyajx3LMoOw@mail.gmail.com you wrote:
A simple test is
echo a && echo b
If you get "a && echo b" back, then hush is not active.
Wolfgang Denk Thanks for response.If I want to store those strings into variable and may be compare it or parse it for information.For example "echo a" redirected to variable like assignment. My goal is to write simple diags to test pci or serial flash using commands in the shell using script. We can issue the commands and parse the response and print useful messages to users. myvar = echo a if itest.s myvar == a then echo 'a" else echo "no a" Any idea how we can achieve this. Thanks Amruth p.v
A simple test is
echo a && echo b
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de The one who says it cannot be done should never interrupt the one who is doing it.
In message CAL5DGCQABjk_F8T2-3XLFJkmp8ZvPwH_RvAa2i_==jS+8__mpA@mail.gmail.com you wrote:
Such test code should most probably be integrated into the POST framework.
Current hush implementation does not support backticks or $(cmd) notation. You will have to chose a differnt style.
amruth vamadev
