[U-Boot-Users] Doubt on Kernel Linking
I work with MPC823FADS board.
I'm using u-boot as the bootloader in it. The RAM memroy map as seen with the "bdinfo" command in u-boot says.. 0x00000000 to 0x00800000.
I'm trying to boot linux kernel ( linux-2.4.4-2002-10-06 from DENX) on my board. By default , the kernel is build at 0xC0000000. (This memory is not mapped by u-boot).
Do I have to change the kernel linking to a address that is within, 0x00000000 and 0x00800000 ?
Rupesh
These are physical addresses.
This is a virtual address.
No. You MUST NOT change the Linux kernel, or it will break. Physical and virtual addresses are completely different beasts.
I kept the link address back at 0xc0000000. Doing mkimage , I did load address and entry address as 0x0.
On my FADS823 board, I do a download to 0x100000. And gave a bootm 0x100000.
But the system hangs after Uncompressing Kernel Image... Note: I have compared the bd_info stricture of linux and u-boot . It is the same . Also the IMMR address. I do mkimage on gzipped binary image of vmlinux.
Please advice. Rupesh
----- Original Message ----- From: "Wolfgang Denk" wd@denx.de To: "Rupesh S" rupeshs@myw.ltindia.com Cc: u-boot-users@lists.sourceforge.net Sent: Friday, May 23, 2003 5:07 AM Subject: Re: [U-Boot-Users] Doubt on Kernel Linking
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de We are Microsoft. Unix is irrelevant. Openness is futile. Prepare to be assimilated.
This SF.net email is sponsored by: ObjectStore. If flattening out C++ or Java code to make your application fit in a relational database is painful, don't do it! Check out ObjectStore. Now part of Progress Software. http://www.objectstore.net/sourceforge _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Please advice.
Attach a debugger (BDI2000 recommended).
Or reset the board and check the contents of the "log_buf" buffer (post mortem dump) - grep the address from the System.map file, and subtract 0xC0000000 to convert from virtual to physical address; the use U-Boot's "md" command.
I also enabled the DEBUG printfs in u-boot. Below attached is the log of messages I got after displaying memory of "log_buf". It gives a few "OOPS". The kernel mesages must be happening before the kernel gets hold of serial console as well, because I don't see these on my console.
:>bootm 100000 ## Booting image at 00100000 ... Image Name: Rupesh's Kernel Image Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 489707 Bytes = 478.2 kB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK ## Current stack ends at 0x0075FC18 => set upper limit to 0x0075F410 ## cmdline at 0x0075F310 ... 0x0075F310 bd address = 0x0075FFC4 memstart = 0x00000000 memsize = 0x00800000 flashstart = 0x02800000 flashsize = 0x00200000 flashoffset = 0x00080000 sramstart = 0x00000000 sramsize = 0x00000000 immr_base = 0xFF000000 bootflags = 0x00000001 intfreq = 40 MHz busfreq = 40 MHz ethaddr = 08:00:22:50:70:63 IP addr = 192.168.6.227 baudrate = 19200 bps No initrd ## Transferring control to Linux (at address 00000000) ...
/****************** Here It Hanged !!! *****************/ /***************** Below messages after RESET ************************/
U-Boot 0.3.1 (May 26 2003 - 11:20:21)
CPU: PPC823ZTnnA at 40 MHz: 2 kB I-Cache 1 kB D-Cache *** Warning: CPU Core has Silicon Bugs -- Check the Errata *** Board: FADS with db MPC823 rev ENG or PILOT DRAM: (4 MB SDRAM) 8 MB Top of RAM usable for U-Boot at: 00800000 Reserving 512k for U-Boot at: 00780000 Reserving 128k for malloc() at: 00760000 Reserving 60 Bytes for Board Info at: 0075ffc4 Reserving 44 Bytes for Global Data at: 0075ff98 Stack Pointer at: 0075ff78 New Stack Pointer is: 0075ff78 Now running in RAM - U-Boot at: 00780000 FLASH: 2 MB In: serial Out: serial Err: serial U-Boot relocated to 00780000 Net: SCC ETHERNET ### main_loop entered: bootdelay=0
### main_loop: bootcmd="<UNDEFINED>"
/********************* The location of "log_buf" *****************************************/ :>md 12eee8 0012eee8: 63657373 206f6620 62616420 61726561 cess of bad area 0012eef8: 2c207369 673a2031 310a4f6f 70733a20 , sig: 11.Oops: 0012ef08: 6b65726e 656c2061 63636573 73206f66 kernel access of 0012ef18: 20626164 20617265 612c2073 69673a20 bad area, sig: 0012ef28: 31310a4f 6f70733a 206b6572 6e656c20 11.Oops: kernel 0012ef38: 61636365 7373206f 66206261 64206172 access of bad ar 0012ef48: 65612c20 7369673a 2031310a 3c323e4b ea, sig: 11.<2>K 0012ef58: 65726e65 6c207374 61636b20 6f766572 ernel stack over 0012ef68: 666c6f77 20696e20 70726f63 65737320 flow in process 0012ef78: 63303131 37303230 2c207231 3d633031 c0117020, r1=c01 0012ef88: 31373262 300a4f6f 70733a20 6b65726e 172b0.Oops: kern 0012ef98: 656c2061 63636573 73206f66 20626164 el access of bad 0012efa8: 20617265 612c2073 69673a20 31310a4f area, sig: 11.O 0012efb8: 6f70733a 206b6572 6e656c20 61636365 ops: kernel acce 0012efc8: 7373206f 66206261 64206172 65612c20 ss of bad area, 0012efd8: 7369673a 2031310a 4f6f7073 3a206b65 sig: 11.Oops: ke :>
What could be wrong ?? Please advice.. Rupesh
----- Original Message ----- From: "Wolfgang Denk" wd@denx.de To: "Rupesh S" rupeshs@myw.ltindia.com Cc: u-boot-users@lists.sourceforge.net Sent: Friday, May 23, 2003 6:56 AM Subject: Re: [U-Boot-Users] Doubt on Kernel Linking
the
Please advice.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de If all economists were laid end to end, they would not reach a con- clusion.
I had the same problem as you in the past (8xx board locked up in linux with sig11 messages in log_buf). Since log_buf is cyclic (it assums that the latest messages are the most important), The buffer is overwritten with the sig 11 messages.
I've modified the debug code that writes to log_buf (kernel/printk.c) and instead of wrapping around, it stopped writing at the end of the buffer (sorry, no patch - its quite simply, and I didn't keep it). This way you can see You can also control the size of the log buf by changing LOG_BUF_LEN in the same file.
BTW, I've never managed to run the ELDK kernel (I was aware of clocks_in_mhz - changing it didn't help). I ended up using 2.4.20 from the linuxppc_2_4 CVS tree in www.penguinppc.org , which worked for me. OTOH, the ELDK kernel works for other people.
I'm now trying to integrate some parts of the ELDK kernel such as the 8xx LCD code in the latest kernel.
Udi
n.b. Wolfgang, did you get the u-boot patch I sent you? (RBC823 config + 8xx LCD patches)
the
Please advice.
Hi, Is there any http or ftp server in www.penguinppc.org from where I can download the linuxppc kernel ( > 2.4.18)
----- Original Message ----- From: "Udi Finkelstein" u-boot-users@udif.com To: "Rupesh S" rupeshs@myw.ltindia.com Cc: "Wolfgang Denk" wd@denx.de; u-boot-users@lists.sourceforge.net Sent: Sunday, May 25, 2003 11:50 PM Subject: Re: [U-Boot-Users] Doubt on Kernel Linking
Udi
serial
the
Please advice.
Please see:
http://www.penguinppc.org/dev/kernel.shtml
Not that I look at it again, I probably got the source using rsync, not CVS.
You can also look at http://source.mvista.com if you don't mind using the Bitkeeper client.
Udi
Udi
serial
It is
the
Please advice.
I could find another linux ppc site. http://ppckernel.org/ Please comemnt . Rupesh
----- Original Message ----- From: "Udi Finkelstein" u-boot-users@udif.com To: "Rupesh S" rupeshs@myw.ltindia.com Cc: "Udi Finkelstein" u-boot-users@udif.com; "Wolfgang Denk" wd@denx.de; u-boot-users@lists.sourceforge.net Sent: Monday, May 26, 2003 1:59 AM Subject: Re: [U-Boot-Users] Doubt on Kernel Linking
Please see:
CVS.
Udi
that
Udi
8xx LCD patches)
serial
It is
the
Please advice.
For the official kernels see http://penguinppc.org/dev/kernel.shtml
The DENX kernels are available on our CVS (modules linux-2.4 (2.4.4) and linuxppc_2_4_devel (2.4.20)), see http://www.denx.de/re/linux.html
Hwello,
I have seen exactly the same error messages on FADS boareds before (the one and only time I tried to get Linux running on such a system ever). In my case the hardware was broken.
SInce you are using an ENG or PILOT version of the hardware, too, I speculate that you have broken hardware, too. Many of the early FADS boards would fail with Linux.
Rupesh S
Udi Finkelstein
