[U-Boot] [PATCH V2] mmc:eSDHC: Workaround for data timeout issue on Txxx SoC
1. The Data timeout counter value in eSDHC_SYSCTL register is not working as it should be, so add quirks to enable this workaround to fix it to the max value 0xE.
2. For eSDHC the Block Count size each transmission should not exceed 0xFFFF blocks, Fix b_max to 0xFFFF to limit the transfer size for read and write command.
3. Add CONFIG_SYS_FSL_ERRATUM_ESDHC111 to enable its workaround.
Signed-off-by: Haijun Zhang Haijun.Zhang@freescale.com --- changes for V2 - Rewrite the comments.
arch/powerpc/include/asm/config_mpc85xx.h | 5 +++++ drivers/mmc/fsl_esdhc.c | 5 ++++- 2 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 9a20b97..df44451 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -734,6 +734,8 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_A006261 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111 +#define ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE
#elif defined(CONFIG_PPC_T2080) || defined(CONFIG_PPC_T2081) #define CONFIG_E6500 @@ -778,6 +780,9 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_SFP_VER_3_0 #define CONFIG_SYS_FSL_ISBC_VER 2 +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111 +#define ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE +
#elif defined(CONFIG_PPC_C29X) #define CONFIG_MAX_CPUS 1 diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 7b146a3..e888079 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -244,6 +244,9 @@ static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data) timeout++; #endif
+#ifdef ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE + timeout = 0xE; +#endif esdhc_clrsetbits32(®s->sysctl, SYSCTL_TIMEOUT_MASK, timeout << 16);
return 0; @@ -604,7 +607,7 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) mmc->f_min = 400000; mmc->f_max = MIN(gd->arch.sdhc_clk, 52000000);
- mmc->b_max = 0; + mmc->b_max = 0xFFFF; mmc_register(mmc);
Hi Haijun,
The patch looks good but it doesn't apply after the mmc changes I've made
I've reworked and applied it;
On Mar 18, 2014, at 11:04 AM, Haijun Zhang wrote:
- The Data timeout counter value in eSDHC_SYSCTL register is
- For eSDHC the Block Count size each transmission should not
^ this is already handled by the default value of 0xffff
- Add CONFIG_SYS_FSL_ERRATUM_ESDHC111 to enable its workaround.
changes for V2
- timeout = 0xE;
----------8<-----------------
- mmc->b_max = 0;
^ This chunk is no longer needed.
-- 1.8.5
Acked-by: Pantelis Antoniou panto@antoniou-consulting.com
Thanks a lot.
BTW, how about other patches? I saw there are patches conflict with mine now.
Regards & Thanks
-- Haijun
On 04/02/2014 06:27 PM, Pantelis Antoniou wrote:
Hi Haijun,
changes for V2
- timeout = 0xE;
- mmc->b_max = 0;
-- 1.8.5
Haijun Zhang
Pantelis Antoniou
Zhang Haijun
