[PATCH v1 1/1] rockchip: rock5b-rk3588: Enable automatic PCI enumeration
PCI enumeration is required to detect the onboard Ethernet device.
Signed-off-by: Sebastian Reichel sebastian.reichel@collabora.com --- configs/rock5b-rk3588_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index c54e13e8732c..e5b9f7d326b4 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -17,6 +17,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_PCI=y +CONFIG_PCI_INIT_R=y CONFIG_DEBUG_UART=y CONFIG_AHCI=y CONFIG_FIT=y
Hello Sebastian,
This has been added and removed before, please see
https://lore.kernel.org/all/20231104130451.111020-1-martin.roukala@mupuf.org...
this commit adds it 5b269ed404dc ("configs: rockchip: rock5b-rk3588: Enable CONFIG_PCI_INIT_R")
this commit removes it again 191ece249a96 ("rockchip: rk3588-rock-5b: Enable support for PCIe SATA cards")
Eugen
Hi Sebastian,
On 2024-10-31 19:15, Eugen Hristev wrote:
Hello Sebastian,
What use-case are you trying to solve with a forced pci enumeration?
With standard boot Ethernet should be enabled when it is needed.
However for EFI boot Ethernet maybe is not detected? Please see [1] for a possible alternative patch that I created when someone reported an issue with iPXE boot some time ago.
I did not get confirmation it fully solved the issue, from what I could test it should help get Ethernet detected during EFI boot on a ROCK 5B.
[1] https://github.com/Kwiboo/u-boot-rockchip/commit/90b6d787de0b3e6ed863440be57...
Regards, Jonas
Eugen
Ah, I should have checked the history. Sorry.
LAVA by default has a U-Boot script doing the following (IIUIC across all boards), which fails with the current setup:
setenv autoload no setenv initrd_high 0xffffffff setenv fdt_high 0xffffffff dhcp setenv serverip 192.168.201.1 tftp 0x0400000 16212093/tftp-deploy-or30pzbe/kernel/vmlinuz tftp 0xa200000 16212093/tftp-deploy-or30pzbe/ramdisk/ramdisk.cpio.gz.uboot setenv initrd_size ${filesize} tftp 0xa100000 16212093/tftp-deploy-or30pzbe/dtb/rk3588-rock-5b.dtb setenv bootargs 'console=ttyS2,1500000n8 root=/dev/nfs rw nfsroot=192.168.201.1:/var/lib/lava/dispatcher/tmp/16212093/extract-nfsrootfs-e0aw1qlf,tcp,hard,v3 rootwait ip=dhcp' booti 0x0400000 0xa200000 0xa100000
Basically it comes down to missing network support when breaking into the U-Boot shell. Also while it is obvious one needs to enumerate the PCI bus for U-Boot developers with knowledge about the Rock 5B, it's unexpected for people with less knowledge. So I think it's sensible to have a default configuration supporting network in the U-Boot shell without extra steps.
-- Sebastian
Hi Sebastian,
If you run a boot script you can easily add 'pci enum' before 'dhcp' and Ethernet will work for you LAVA script.
Unfortunately forcing a pci enumeration slow down booting from faster boot media, adding at least one second pci timeout delay and an error being logged for each unoccupied M.2 slot.
For normal use, standard boot automatically enumerate pci and Ethernet once needed, if that is not working then that is an issue to be solved.
PCI_INIT_R was rejected earlier because it forces unnecessary slower boot times on any user not booting from Ethernet.
With use of a boot script, the script should be capable/responsible to load any resources that is needed for its custom boot flow.
Regards, Jonas
-- Sebastian
On 2024-10-31 22:52, Jonas Karlman wrote:
Hi Sebastian,
Look like something like following in device-types/rk3588-rock-5b.jinja2 could work for LAVA:
{% set uboot_ipaddr_cmd = 'pci enum; dhcp' %}
Regards, Jonas
Regards, Jonas
-- Sebastian
Eugen Hristev
Jonas Karlman
Sebastian Reichel
