[U-Boot] [PATCH] DRA7: Add support for ES1.1 silicon ID code
ES1.1 silicon is a very minor variant of ES1.0. Add priliminary support for ES1.1 IDCODE change.
Signed-off-by: Nishanth Menon nm@ti.com Reviewed-by: Tom Rini trini@ti.com ---
arch/arm/cpu/armv7/omap-common/clocks-common.c | 2 +- arch/arm/cpu/armv7/omap-common/emif-common.c | 5 ++--- arch/arm/cpu/armv7/omap5/hw_data.c | 2 ++ arch/arm/cpu/armv7/omap5/hwinit.c | 3 +++ arch/arm/cpu/armv7/omap5/sdram.c | 4 ++++ arch/arm/include/asm/arch-omap5/omap.h | 1 + arch/arm/include/asm/omap_common.h | 1 + 7 files changed, 14 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/clocks-common.c b/arch/arm/cpu/armv7/omap-common/clocks-common.c index dfa3760..2883c1d 100644 --- a/arch/arm/cpu/armv7/omap-common/clocks-common.c +++ b/arch/arm/cpu/armv7/omap-common/clocks-common.c @@ -436,7 +436,7 @@ static void setup_non_essential_dplls(void) #ifdef CONFIG_SYS_OMAP_ABE_SYSCK abe_ref_clk = CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK;
- if (omap_revision() == DRA752_ES1_0) + if (is_dra7xx()) /* Select the sys clk for dpll_abe */ clrsetbits_le32((*prcm)->cm_abe_pll_sys_clksel, CM_CLKSEL_ABE_PLL_SYS_CLKSEL_MASK, diff --git a/arch/arm/cpu/armv7/omap-common/emif-common.c b/arch/arm/cpu/armv7/omap-common/emif-common.c index cd6289b..429c4be 100644 --- a/arch/arm/cpu/armv7/omap-common/emif-common.c +++ b/arch/arm/cpu/armv7/omap-common/emif-common.c @@ -179,8 +179,7 @@ void emif_update_timings(u32 base, const struct emif_regs *regs) writel(regs->temp_alert_config, &emif->emif_temp_alert_config); writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1_shdw);
- if ((omap_revision() >= OMAP5430_ES1_0) || - (omap_revision() == DRA752_ES1_0)) { + if ((omap_revision() >= OMAP5430_ES1_0) || is_dra7xx()) { writel(EMIF_L3_CONFIG_VAL_SYS_10_MPU_5_LL_0, &emif->emif_l3_config); } else if (omap_revision() >= OMAP4460_ES1_0) { @@ -309,7 +308,7 @@ static void ddr3_init(u32 base, const struct emif_regs *regs) * The same sequence should work on OMAP5432 as well. But strange that * it is not working */ - if (omap_revision() == DRA752_ES1_0) { + if (is_dra7xx()) { do_ext_phy_settings(base, regs); writel(regs->sdram_config2, &emif->emif_lpddr2_nvm_config); writel(regs->sdram_config_init, &emif->emif_sdram_config); diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index 5268a1f..e47b454 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -639,6 +639,7 @@ void hw_data_init(void) break;
case DRA752_ES1_0: + case DRA752_ES1_1: *prcm = &dra7xx_prcm; *dplls_data = &dra7xx_dplls; *omap_vcores = &dra752_volts; @@ -666,6 +667,7 @@ void get_ioregs(const struct ctrl_ioregs **regs) *regs = &ioregs_omap5432_es2; break; case DRA752_ES1_0: + case DRA752_ES1_1: *regs = &ioregs_dra7xx_es1; break;
diff --git a/arch/arm/cpu/armv7/omap5/hwinit.c b/arch/arm/cpu/armv7/omap5/hwinit.c index 5386ae0..737d23c 100644 --- a/arch/arm/cpu/armv7/omap5/hwinit.c +++ b/arch/arm/cpu/armv7/omap5/hwinit.c @@ -333,6 +333,9 @@ void init_omap_revision(void) case DRA752_CONTROL_ID_CODE_ES1_0: *omap_si_rev = DRA752_ES1_0; break; + case DRA752_CONTROL_ID_CODE_ES1_1: + *omap_si_rev = DRA752_ES1_1; + break; default: *omap_si_rev = OMAP5430_SILICON_ID_INVALID; } diff --git a/arch/arm/cpu/armv7/omap5/sdram.c b/arch/arm/cpu/armv7/omap5/sdram.c index 2e18706..16a91f9 100644 --- a/arch/arm/cpu/armv7/omap5/sdram.c +++ b/arch/arm/cpu/armv7/omap5/sdram.c @@ -245,6 +245,7 @@ static void emif_get_reg_dump_sdp(u32 emif_nr, const struct emif_regs **regs) *regs = &emif_regs_ddr3_532_mhz_1cs_es2; break; case DRA752_ES1_0: + case DRA752_ES1_1: switch (emif_nr) { case 1: *regs = &emif_1_regs_ddr3_532_mhz_1cs_dra_es1; @@ -273,6 +274,7 @@ static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs *dmm_lisa_regs = &lisa_map_4G_x_2_x_2; break; case DRA752_ES1_0: + case DRA752_ES1_1: default: *dmm_lisa_regs = &lisa_map_2G_x_2_x_2_2G_x_1_x_2; } @@ -460,6 +462,7 @@ static void emif_get_ext_phy_ctrl_const_regs(u32 emif_nr, *size = ARRAY_SIZE(ddr3_ext_phy_ctrl_const_base_es2); break; case DRA752_ES1_0: + case DRA752_ES1_1: if (emif_nr == 1) { *regs = dra_ddr3_ext_phy_ctrl_const_base_es1_emif1; *size = @@ -626,6 +629,7 @@ const struct read_write_regs *get_bug_regs(u32 *iterations) sizeof(omap5_bug_00339_regs[0]); break; case DRA752_ES1_0: + case DRA752_ES1_1: bug_00339_regs_ptr = dra_bug_00339_regs; *iterations = sizeof(dra_bug_00339_regs)/ sizeof(dra_bug_00339_regs[0]); diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index 5be2dee..19fdece 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -44,6 +44,7 @@ #define OMAP5432_CONTROL_ID_CODE_ES1_0 0x0B99802F #define OMAP5432_CONTROL_ID_CODE_ES2_0 0x1B99802F #define DRA752_CONTROL_ID_CODE_ES1_0 0x0B99002F +#define DRA752_CONTROL_ID_CODE_ES1_1 0x1B99002F
/* UART */ #define UART1_BASE (OMAP54XX_L4_PER_BASE + 0x6a000) diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index a78f990..9b1f495 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -643,6 +643,7 @@ static inline u8 is_dra7xx(void)
/* DRA7XX */ #define DRA752_ES1_0 0x07520100 +#define DRA752_ES1_1 0x07520110
/* * SRAM scratch space entries
- if (is_dra7xx()) /* Select the sys clk for dpll_abe */ clrsetbits_le32((*prcm)->cm_abe_pll_sys_clksel, CM_CLKSEL_ABE_PLL_SYS_CLKSEL_MASK,
- if ((omap_revision() >= OMAP5430_ES1_0) || is_dra7xx()) { writel(EMIF_L3_CONFIG_VAL_SYS_10_MPU_5_LL_0, &emif->emif_l3_config); } else if (omap_revision() >= OMAP4460_ES1_0) {
- if (is_dra7xx()) { do_ext_phy_settings(base, regs); writel(regs->sdram_config2, &emif->emif_lpddr2_nvm_config); writel(regs->sdram_config_init, &emif->emif_sdram_config);
case DRA752_ES1_0:
- case DRA752_ES1_1: *prcm = &dra7xx_prcm; *dplls_data = &dra7xx_dplls; *omap_vcores = &dra752_volts;
- case DRA752_ES1_1: *regs = &ioregs_dra7xx_es1; break;
- case DRA752_CONTROL_ID_CODE_ES1_1:
default: *omap_si_rev = OMAP5430_SILICON_ID_INVALID; }break;
- case DRA752_ES1_1: switch (emif_nr) { case 1: *regs = &emif_1_regs_ddr3_532_mhz_1cs_dra_es1;
- case DRA752_ES1_1: default: *dmm_lisa_regs = &lisa_map_2G_x_2_x_2_2G_x_1_x_2; }
- case DRA752_ES1_1: if (emif_nr == 1) { *regs = dra_ddr3_ext_phy_ctrl_const_base_es1_emif1; *size =
- case DRA752_ES1_1: bug_00339_regs_ptr = dra_bug_00339_regs; *iterations = sizeof(dra_bug_00339_regs)/ sizeof(dra_bug_00339_regs[0]);
- SRAM scratch space entries
Reviewed By: Sricharan R r.sricharan@ti.com
Regards, Sricharan
Applied to u-boot-ti/master, thanks!
Nishanth Menon
Sricharan R
