[U-Boot] [PATCH 1/2] arm64: zynqmp: Prepare psu_init rework
Move generic functions to common location spl.c. Function declarations are added to private header. These changes are done in connection to the fact that still files from HDF can be copied over and compilation should pass.
Depends on previous psu_init patches
--- arch/arm/cpu/armv8/zynqmp/spl.c | 55 +++++++++++++++++++++++++ arch/arm/include/asm/arch-zynqmp/psu_init_gpl.h | 25 +++++++++++ arch/arm/include/asm/arch-zynqmp/sys_proto.h | 2 - board/xilinx/zynqmp/zynqmp.c | 1 + 4 files changed, 81 insertions(+), 2 deletions(-) create mode 100644 arch/arm/include/asm/arch-zynqmp/psu_init_gpl.h
diff --git a/arch/arm/cpu/armv8/zynqmp/spl.c b/arch/arm/cpu/armv8/zynqmp/spl.c index 41ca74a2be2b..da983458a982 100644 --- a/arch/arm/cpu/armv8/zynqmp/spl.c +++ b/arch/arm/cpu/armv8/zynqmp/spl.c @@ -14,6 +14,7 @@ #include <asm/spl.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> +#include <asm/arch/psu_init_gpl.h>
void board_init_f(ulong dummy) { @@ -156,3 +157,57 @@ int board_fit_config_name_match(const char *name) return 0; } #endif + +#define PSU_MASK_POLL_TIME 1100000 + +int __maybe_unused mask_pollonvalue(unsigned long add, u32 mask, u32 value) +{ + int i = 0; + + while ((__raw_readl(add) & mask) != value) { + if (i == PSU_MASK_POLL_TIME) + return 0; + i++; + } + return 1; +} + +__weak int mask_poll(u32 add, u32 mask) +{ + int i = 0; + unsigned long addr = add; + + while (!(__raw_readl(addr) & mask)) { + if (i == PSU_MASK_POLL_TIME) + return 0; + i++; + } + return 1; +} + +__weak void mask_delay(u32 delay) +{ + udelay(delay); +} + +__weak void psu_mask_write(unsigned long offset, unsigned long mask, + unsigned long val) +{ + unsigned long regval = 0; + + regval = readl(offset); + regval &= ~(mask); + regval |= (val & mask); + writel(regval, offset); +} + +__weak void prog_reg(unsigned long addr, unsigned long mask, + unsigned long shift, unsigned long value) +{ + int rdata = 0; + + rdata = readl(addr); + rdata = rdata & (~mask); + rdata = rdata | (value << shift); + writel(rdata, addr); +} diff --git a/arch/arm/include/asm/arch-zynqmp/psu_init_gpl.h b/arch/arm/include/asm/arch-zynqmp/psu_init_gpl.h new file mode 100644 index 000000000000..29ea8ee1aa19 --- /dev/null +++ b/arch/arm/include/asm/arch-zynqmp/psu_init_gpl.h @@ -0,0 +1,25 @@ +/* + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _PSU_INIT_GPL_H_ /* prevent circular inclusions */ +#define _PSU_INIT_GPL_H_ + +#include <asm/io.h> +#include <common.h> + +int mask_pollonvalue(unsigned long add, u32 mask, u32 value); + +int mask_poll(u32 add, u32 mask); + +void mask_delay(u32 delay); + +void psu_mask_write(unsigned long offset, unsigned long mask, + unsigned long val); + +void prog_reg(unsigned long addr, unsigned long mask, + unsigned long shift, unsigned long value); + +int psu_init(void); + +#endif /* _PSU_INIT_GPL_H_ */ diff --git a/arch/arm/include/asm/arch-zynqmp/sys_proto.h b/arch/arm/include/asm/arch-zynqmp/sys_proto.h index 4dfabba80a5c..084d55a2b01f 100644 --- a/arch/arm/include/asm/arch-zynqmp/sys_proto.h +++ b/arch/arm/include/asm/arch-zynqmp/sys_proto.h @@ -33,8 +33,6 @@ enum { int zynq_board_read_rom_ethaddr(unsigned char *ethaddr); unsigned int zynqmp_get_silicon_version(void);
-int psu_init(void); - void handoff_setup(void);
void zynqmp_pmufw_version(void); diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index db557e880674..824f4ae50fe5 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -13,6 +13,7 @@ #include <asm/arch/clk.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> +#include <asm/arch/psu_init_gpl.h> #include <asm/io.h> #include <usb.h> #include <dwc3-uboot.h>
Add low level initialization for zcu102-rev1.0.
.../zynqmp/zynqmp-zcu102-rev1.0/psu_init_gpl.c | 625 +++++++++++++++++++++ 1 file changed, 625 insertions(+) create mode 100644 board/xilinx/zynqmp/zynqmp-zcu102-rev1.0/psu_init_gpl.c
diff --git a/board/xilinx/zynqmp/zynqmp-zcu102-rev1.0/psu_init_gpl.c b/board/xilinx/zynqmp/zynqmp-zcu102-rev1.0/psu_init_gpl.c new file mode 100644 index 000000000000..a351ffa0c2e9 --- /dev/null +++ b/board/xilinx/zynqmp/zynqmp-zcu102-rev1.0/psu_init_gpl.c @@ -0,0 +1,625 @@ +/* + * (c) Copyright 2015 Xilinx, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/psu_init_gpl.h> +#include <xil_io.h> + +static unsigned long psu_pll_init_data(void) +{ + psu_mask_write(0xFF5E0034, 0xFE7FEDEFU, 0x7E4B0C82U); + psu_mask_write(0xFF5E0030, 0x00717F00U, 0x00015900U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000000U); + mask_poll(0xFF5E0040, 0x00000002U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0048, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFF5E0038, 0x8000FFFFU, 0x80008E69U); + psu_mask_write(0xFF5E0024, 0xFE7FEDEFU, 0x7E4B0C82U); + psu_mask_write(0xFF5E0020, 0x00717F00U, 0x00015A00U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000000U); + mask_poll(0xFF5E0040, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0044, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0024, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A0020, 0x00717F00U, 0x00014800U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0048, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0030, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A002C, 0x00717F00U, 0x00014000U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000002U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A004C, 0x00003F00U, 0x00000200U); + psu_mask_write(0xFD1A003C, 0xFE7FEDEFU, 0x7E4B0C82U); + psu_mask_write(0xFD1A0038, 0x00717F00U, 0x00015900U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000004U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0050, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0040, 0x8000FFFFU, 0x80008E69U); + + return 1; +} + +static unsigned long psu_clock_init_data(void) +{ + psu_mask_write(0xFF5E005C, 0x063F3F07U, 0x06010C00U); + psu_mask_write(0xFF5E0060, 0x023F3F07U, 0x02010600U); + psu_mask_write(0xFF5E004C, 0x023F3F07U, 0x02031900U); + psu_mask_write(0xFF5E0068, 0x013F3F07U, 0x01010500U); + psu_mask_write(0xFF5E0070, 0x013F3F07U, 0x01010800U); + psu_mask_write(0xFF18030C, 0x00020000U, 0x00000000U); + psu_mask_write(0xFF5E0074, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0078, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0120, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0124, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0088, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0090, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E009C, 0x01003F07U, 0x01000602U); + psu_mask_write(0xFF5E00A4, 0x01003F07U, 0x01000600U); + psu_mask_write(0xFF5E00A8, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E00AC, 0x01003F07U, 0x01000F02U); + psu_mask_write(0xFF5E00B0, 0x01003F07U, 0x01000602U); + psu_mask_write(0xFF5E00B8, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E00C0, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E00C4, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E00C8, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E00CC, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01011E02U); + psu_mask_write(0xFF5E0104, 0x00000007U, 0x00000000U); + psu_mask_write(0xFF5E0128, 0x01003F07U, 0x01000F00U); + psu_mask_write(0xFD1A00A0, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A00B4, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A0070, 0x013F3F07U, 0x01010500U); + psu_mask_write(0xFD1A0074, 0x013F3F07U, 0x01013C03U); + psu_mask_write(0xFD1A007C, 0x013F3F07U, 0x01013803U); + psu_mask_write(0xFD1A0060, 0x03003F07U, 0x03000100U); + psu_mask_write(0xFD1A0068, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A0080, 0x00003F07U, 0x00000200U); + psu_mask_write(0xFD1A0084, 0x07003F07U, 0x07000100U); + psu_mask_write(0xFD1A00B8, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A00BC, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A00C0, 0x01003F07U, 0x01000203U); + psu_mask_write(0xFD1A00C4, 0x01003F07U, 0x01000502U); + psu_mask_write(0xFD1A00F8, 0x00003F07U, 0x00000200U); + psu_mask_write(0xFF180380, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD610100, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF180300, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF410050, 0x00000001U, 0x00000000U); + + return 1; +} + +static unsigned long psu_ddr_init_data(void) +{ + psu_mask_write(0xFD1A0108, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD070000, 0xE30FBE3DU, 0x41040010U); + psu_mask_write(0xFD070010, 0x8000F03FU, 0x00000030U); + psu_mask_write(0xFD070020, 0x000003F3U, 0x00000300U); + psu_mask_write(0xFD070024, 0xFFFFFFFFU, 0x00800000U); + psu_mask_write(0xFD070030, 0x0000007FU, 0x00000000U); + psu_mask_write(0xFD070034, 0x00FFFF1FU, 0x00408410U); + psu_mask_write(0xFD070050, 0x00F1F1F4U, 0x00210000U); + psu_mask_write(0xFD070054, 0x0FFF0FFFU, 0x00000000U); + psu_mask_write(0xFD070060, 0x00000073U, 0x00000001U); + psu_mask_write(0xFD070064, 0x0FFF83FFU, 0x0082808BU); + psu_mask_write(0xFD070070, 0x00000017U, 0x00000010U); + psu_mask_write(0xFD070074, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD0700C4, 0x3F000391U, 0x10000200U); + psu_mask_write(0xFD0700C8, 0x01FF1F3FU, 0x0040051FU); + psu_mask_write(0xFD0700D0, 0xC3FF0FFFU, 0x00020106U); + psu_mask_write(0xFD0700D4, 0x01FF7F0FU, 0x00020000U); + psu_mask_write(0xFD0700D8, 0x0000FF0FU, 0x00002305U); + psu_mask_write(0xFD0700DC, 0xFFFFFFFFU, 0x09300301U); + psu_mask_write(0xFD0700E0, 0xFFFFFFFFU, 0x00200200U); + psu_mask_write(0xFD0700E4, 0x00FF03FFU, 0x00210004U); + psu_mask_write(0xFD0700E8, 0xFFFFFFFFU, 0x000006C0U); + psu_mask_write(0xFD0700EC, 0xFFFF0000U, 0x08190000U); + psu_mask_write(0xFD0700F0, 0x0000003FU, 0x00000010U); + psu_mask_write(0xFD0700F4, 0x00000FFFU, 0x0000066FU); + psu_mask_write(0xFD070100, 0x7F3F7F3FU, 0x11112412U); + psu_mask_write(0xFD070104, 0x001F1F7FU, 0x0004041AU); + psu_mask_write(0xFD070108, 0x3F3F3F3FU, 0x0708060EU); + psu_mask_write(0xFD07010C, 0x3FF3F3FFU, 0x0050400CU); + psu_mask_write(0xFD070110, 0x1F0F0F1FU, 0x08030309U); + psu_mask_write(0xFD070114, 0x0F0F3F1FU, 0x06060403U); + psu_mask_write(0xFD070118, 0x0F0F000FU, 0x01010004U); + psu_mask_write(0xFD07011C, 0x00000F0FU, 0x00000606U); + psu_mask_write(0xFD070120, 0x7F7F7F7FU, 0x04040D06U); + psu_mask_write(0xFD070124, 0x40070F3FU, 0x0002020BU); + psu_mask_write(0xFD07012C, 0x7F1F031FU, 0x6F07010EU); + psu_mask_write(0xFD070130, 0x00030F1FU, 0x00020608U); + psu_mask_write(0xFD070180, 0xF7FF03FFU, 0x81000040U); + psu_mask_write(0xFD070184, 0x3FFFFFFFU, 0x02019707U); + psu_mask_write(0xFD070190, 0x1FBFBF3FU, 0x048B820BU); + psu_mask_write(0xFD070194, 0xF31F0F0FU, 0x00030304U); + psu_mask_write(0xFD070198, 0x0FF1F1F1U, 0x07000101U); + psu_mask_write(0xFD07019C, 0x000000F1U, 0x00000021U); + psu_mask_write(0xFD0701A0, 0xC3FF03FFU, 0x00400003U); + psu_mask_write(0xFD0701A4, 0x00FF00FFU, 0x004100E2U); + psu_mask_write(0xFD0701B0, 0x00000007U, 0x00000000U); + psu_mask_write(0xFD0701B4, 0x00003F3FU, 0x00000906U); + psu_mask_write(0xFD0701C0, 0x00000007U, 0x00000001U); + psu_mask_write(0xFD070200, 0x0000001FU, 0x0000001FU); + psu_mask_write(0xFD070204, 0x001F1F1FU, 0x001F0A0AU); + psu_mask_write(0xFD070208, 0x0F0F0F0FU, 0x00000000U); + psu_mask_write(0xFD07020C, 0x0F0F0F0FU, 0x00000000U); + psu_mask_write(0xFD070210, 0x00000F0FU, 0x00000F0FU); + psu_mask_write(0xFD070214, 0x0F0F0F0FU, 0x080F0808U); + psu_mask_write(0xFD070218, 0x8F0F0F0FU, 0x0F080808U); + psu_mask_write(0xFD07021C, 0x00000F0FU, 0x00000F0FU); + psu_mask_write(0xFD070220, 0x00001F1FU, 0x00000808U); + psu_mask_write(0xFD070224, 0x0F0F0F0FU, 0x08080808U); + psu_mask_write(0xFD070228, 0x0F0F0F0FU, 0x08080808U); + psu_mask_write(0xFD07022C, 0x0000000FU, 0x00000008U); + psu_mask_write(0xFD070240, 0x0F1F0F7CU, 0x06000600U); + psu_mask_write(0xFD070244, 0x00003333U, 0x00000001U); + psu_mask_write(0xFD070250, 0x7FFF3F07U, 0x01002001U); + psu_mask_write(0xFD070264, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD07026C, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD070280, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070284, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070288, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD07028C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070290, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD070294, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070300, 0x00000011U, 0x00000000U); + psu_mask_write(0xFD07030C, 0x80000033U, 0x00000000U); + psu_mask_write(0xFD070320, 0x00000001U, 0x00000000U); + psu_mask_write(0xFD070400, 0x00000111U, 0x00000001U); + psu_mask_write(0xFD070404, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070408, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070490, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070494, 0x0033000FU, 0x0020000BU); + psu_mask_write(0xFD070498, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD0704B4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0704B8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070540, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070544, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD070548, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070564, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070568, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0705F0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0705F4, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD0705F8, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070614, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070618, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706A0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0706A4, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706A8, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD0706AC, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706B0, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD0706C4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706C8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070750, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070754, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070758, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07075C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070760, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070774, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070778, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070800, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070804, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070808, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07080C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070810, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070F04, 0x000001FFU, 0x00000000U); + psu_mask_write(0xFD070F08, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD070F0C, 0x000001FFU, 0x00000010U); + psu_mask_write(0xFD070F10, 0x000000FFU, 0x0000000FU); + psu_mask_write(0xFD072190, 0x1FBFBF3FU, 0x07828002U); + psu_mask_write(0xFD1A0108, 0x0000000CU, 0x00000000U); + psu_mask_write(0xFD080010, 0xFFFFFFFFU, 0x07001E00U); + psu_mask_write(0xFD080018, 0xFFFFFFFFU, 0x00F10028U); + psu_mask_write(0xFD08001C, 0xFFFFFFFFU, 0x55AA5480U); + psu_mask_write(0xFD080024, 0xFFFFFFFFU, 0x010100F4U); + psu_mask_write(0xFD080040, 0xFFFFFFFFU, 0x0AC85610U); + psu_mask_write(0xFD080044, 0xFFFFFFFFU, 0x41980B06U); + psu_mask_write(0xFD080068, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD080090, 0xFFFFFFFFU, 0x02A04161U); + psu_mask_write(0xFD080100, 0xFFFFFFFFU, 0x0800040CU); + psu_mask_write(0xFD080110, 0xFFFFFFFFU, 0x06240F09U); + psu_mask_write(0xFD080114, 0xFFFFFFFFU, 0x28210008U); + psu_mask_write(0xFD080118, 0xFFFFFFFFU, 0x00070300U); + psu_mask_write(0xFD08011C, 0xFFFFFFFFU, 0x83000800U); + psu_mask_write(0xFD080120, 0xFFFFFFFFU, 0x01162B07U); + psu_mask_write(0xFD080124, 0xFFFFFFFFU, 0x00330F09U); + psu_mask_write(0xFD080128, 0xFFFFFFFFU, 0x00000E0FU); + psu_mask_write(0xFD080140, 0xFFFFFFFFU, 0x08400020U); + psu_mask_write(0xFD080144, 0xFFFFFFFFU, 0x00000C80U); + psu_mask_write(0xFD080150, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080154, 0xFFFFFFFFU, 0x00000200U); + psu_mask_write(0xFD080180, 0xFFFFFFFFU, 0x00000830U); + psu_mask_write(0xFD080184, 0xFFFFFFFFU, 0x00000301U); + psu_mask_write(0xFD080188, 0xFFFFFFFFU, 0x00000020U); + psu_mask_write(0xFD08018C, 0xFFFFFFFFU, 0x00000200U); + psu_mask_write(0xFD080190, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080194, 0xFFFFFFFFU, 0x000006C0U); + psu_mask_write(0xFD080198, 0xFFFFFFFFU, 0x00000819U); + psu_mask_write(0xFD0801AC, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0801B0, 0xFFFFFFFFU, 0x0000004DU); + psu_mask_write(0xFD0801B4, 0xFFFFFFFFU, 0x00000008U); + psu_mask_write(0xFD0801B8, 0xFFFFFFFFU, 0x0000004DU); + psu_mask_write(0xFD0801D8, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080200, 0xFFFFFFFFU, 0x800091C7U); + psu_mask_write(0xFD080204, 0xFFFFFFFFU, 0x00010236U); + psu_mask_write(0xFD080240, 0xFFFFFFFFU, 0x00141054U); + psu_mask_write(0xFD080250, 0xFFFFFFFFU, 0x00088000U); + psu_mask_write(0xFD080414, 0xFFFFFFFFU, 0x12341000U); + psu_mask_write(0xFD0804F4, 0xFFFFFFFFU, 0x00000005U); + psu_mask_write(0xFD080500, 0xFFFFFFFFU, 0x30000028U); + psu_mask_write(0xFD080508, 0xFFFFFFFFU, 0x0A000000U); + psu_mask_write(0xFD08050C, 0xFFFFFFFFU, 0x00000009U); + psu_mask_write(0xFD080510, 0xFFFFFFFFU, 0x0A000000U); + psu_mask_write(0xFD080520, 0xFFFFFFFFU, 0x0300B0CEU); + psu_mask_write(0xFD080528, 0xFFFFFFFFU, 0xF9032019U); + psu_mask_write(0xFD08052C, 0xFFFFFFFFU, 0x07F001E3U); + psu_mask_write(0xFD080544, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080548, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080558, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD08055C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080560, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080564, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080680, 0xFFFFFFFFU, 0x008AAA58U); + psu_mask_write(0xFD080684, 0xFFFFFFFFU, 0x000079DDU); + psu_mask_write(0xFD080694, 0xFFFFFFFFU, 0x01E10210U); + psu_mask_write(0xFD080698, 0xFFFFFFFFU, 0x01E10000U); + psu_mask_write(0xFD0806A4, 0xFFFFFFFFU, 0x00087BDBU); + psu_mask_write(0xFD080700, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080710, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080714, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080718, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080800, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080810, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080814, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080818, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080900, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080904, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080910, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080914, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080918, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080A00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080A04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080A10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080A14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080A18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080B00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080B04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080B10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080B14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080B18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080C00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080C04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080C10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080C14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080C18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080D00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080D04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080D10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080D14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080D18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080E00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080E04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080E10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080E14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080E18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080F00, 0xFFFFFFFFU, 0x40800624U); + psu_mask_write(0xFD080F04, 0xFFFFFFFFU, 0x00007F00U); + psu_mask_write(0xFD080F10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080F14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080F18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD081400, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081404, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD08141C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08142C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081430, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD081440, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081444, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD08145C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08146C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081470, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD081480, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081484, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD08149C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD0814AC, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD0814B0, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD0814C0, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD0814C4, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD0814DC, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD0814EC, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD0814F0, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD081500, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081504, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD08151C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08152C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081530, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD0817C4, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD0817DC, 0xFFFFFFFFU, 0x012643C4U); + psu_mask_write(0xFD080004, 0xFFFFFFFFU, 0x00040073U); + + return 1; +} + +static unsigned long psu_mio_init_data(void) +{ + psu_mask_write(0xFF180000, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180004, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180008, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18000C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180010, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180014, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180018, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18001C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180020, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180024, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180028, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18002C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180030, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180034, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180038, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF18003C, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF180040, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF180044, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF180048, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF18004C, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF180050, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF180054, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF180058, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18005C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180060, 0x000000FEU, 0x00000020U); + psu_mask_write(0xFF180064, 0x000000FEU, 0x00000020U); + psu_mask_write(0xFF180068, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18006C, 0x000000FEU, 0x00000018U); + psu_mask_write(0xFF180070, 0x000000FEU, 0x00000018U); + psu_mask_write(0xFF180074, 0x000000FEU, 0x00000018U); + psu_mask_write(0xFF180078, 0x000000FEU, 0x00000018U); + psu_mask_write(0xFF18007C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180080, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180084, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180088, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF18008C, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180090, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180094, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180098, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18009C, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800A0, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800A4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800A8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800AC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800B0, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800B4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800B8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800BC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C0, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800CC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800D0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800D4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800D8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800DC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800EC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800FC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180100, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180104, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180108, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18010C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180110, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180114, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180118, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18011C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180120, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180124, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180128, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18012C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180130, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF180134, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF180204, 0xFFFFFFFFU, 0x52240000U); + psu_mask_write(0xFF180208, 0xFFFFFFFFU, 0x00B03000U); + psu_mask_write(0xFF18020C, 0x00003FFFU, 0x00000FC0U); + psu_mask_write(0xFF180138, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18013C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180140, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180144, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180148, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18014C, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180154, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180158, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18015C, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180160, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180164, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180168, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180170, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180174, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180178, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF18017C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180180, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180184, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180200, 0x0000000FU, 0x00000000U); + + return 1; +} + +static unsigned long psu_peripherals_init_data(void) +{ + psu_mask_write(0xFD1A0100, 0x000F807EU, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x001A0000U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x0093C018U, 0x00000000U); + psu_mask_write(0xFF5E0230, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF180390, 0x00000004U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00000540U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000040U, 0x00000000U); + psu_mask_write(0xFF180310, 0x00008000U, 0x00000000U); + psu_mask_write(0xFF180320, 0x33800000U, 0x02800000U); + psu_mask_write(0xFF18031C, 0x7FFE0000U, 0x5DB80000U); + psu_mask_write(0xFF180358, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF180324, 0x03C00000U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000100U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000600U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00008000U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00007800U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000006U, 0x00000000U); + psu_mask_write(0xFF000034, 0x000000FFU, 0x00000005U); + psu_mask_write(0xFF000018, 0x0000FFFFU, 0x0000008FU); + psu_mask_write(0xFF000000, 0x000001FFU, 0x00000017U); + psu_mask_write(0xFF000004, 0x000003FFU, 0x00000020U); + psu_mask_write(0xFF010034, 0x000000FFU, 0x00000005U); + psu_mask_write(0xFF010018, 0x0000FFFFU, 0x0000008FU); + psu_mask_write(0xFF010000, 0x000001FFU, 0x00000017U); + psu_mask_write(0xFF010004, 0x000003FFU, 0x00000020U); + psu_mask_write(0xFF5E0238, 0x00040000U, 0x00000000U); + psu_mask_write(0xFF4B0024, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFFCA5000, 0x00001FFFU, 0x00000000U); + psu_mask_write(0xFD5C0060, 0x000F000FU, 0x00000000U); + psu_mask_write(0xFFA60040, 0x80000000U, 0x80000000U); + psu_mask_write(0xFF260020, 0xFFFFFFFFU, 0x05F5E100U); + psu_mask_write(0xFF260000, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF0A0244, 0x03FFFFFFU, 0x00000020U); + psu_mask_write(0xFF0A0248, 0x03FFFFFFU, 0x00000020U); + psu_mask_write(0xFF0A0008, 0xFFFFFFFFU, 0xFFDF0020U); + mask_delay(1); + psu_mask_write(0xFF0A0008, 0xFFFFFFFFU, 0xFFDF0000U); + mask_delay(5); + psu_mask_write(0xFF0A0008, 0xFFFFFFFFU, 0xFFDF0020U); + return 1; +} + +static unsigned long psu_afi_config(void) +{ + return 1; +} + +static unsigned long psu_ddr_phybringup_data(void) +{ + unsigned int regval = 0; + + while ((Xil_In32(0xFD080030U) & 0x0000000FU) != 0x0000000FU) + ; + prog_reg(0xFD080004U, 0x00000001U, 0x00000000U, 0x00000001U); + + while ((Xil_In32(0xFD080030U) & 0x000000FFU) != 0x0000001FU) + ; + prog_reg(0xFD070010U, 0x00000008U, 0x00000003U, 0x00000001U); + prog_reg(0xFD0701B0U, 0x00000001U, 0x00000000U, 0x00000001U); + prog_reg(0xFD070010U, 0x00000030U, 0x00000004U, 0x00000001U); + prog_reg(0xFD070010U, 0x00000001U, 0x00000000U, 0x00000000U); + prog_reg(0xFD070010U, 0x0000F000U, 0x0000000CU, 0x00000006U); + prog_reg(0xFD070014U, 0x0003FFFFU, 0x00000000U, 0x00000819U); + prog_reg(0xFD070010U, 0x80000000U, 0x0000001FU, 0x00000001U); + while ((Xil_In32(0xFD070018) & 0x1) == 1) + ; + prog_reg(0xFD070010U, 0x00000030U, 0x00000004U, 0x00000001U); + prog_reg(0xFD070010U, 0x00000001U, 0x00000000U, 0x00000000U); + prog_reg(0xFD070010U, 0x0000F000U, 0x0000000CU, 0x00000006U); + prog_reg(0xFD070014U, 0x0003FFFFU, 0x00000000U, 0x00000899U); + prog_reg(0xFD070010U, 0x80000000U, 0x0000001FU, 0x00000001U); + while ((Xil_In32(0xFD070018) & 0x1) == 1) + ; + prog_reg(0xFD070010U, 0x00000030U, 0x00000004U, 0x00000001U); + prog_reg(0xFD070010U, 0x00000001U, 0x00000000U, 0x00000000U); + prog_reg(0xFD070010U, 0x0000F000U, 0x0000000CU, 0x00000006U); + prog_reg(0xFD070014U, 0x0003FFFFU, 0x00000000U, 0x00000819U); + prog_reg(0xFD070010U, 0x80000000U, 0x0000001FU, 0x00000001U); + while ((Xil_In32(0xFD070018) & 0x1) == 1) + ; + prog_reg(0xFD070010U, 0x00000008U, 0x00000003U, 0x00000000U); + Xil_Out32(0xFD0701B0U, 0x00000001U); + Xil_Out32(0xFD070320U, 0x00000001U); + while ((Xil_In32(0xFD070004U) & 0x0000000FU) != 0x00000001U) + ; + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000001U); + Xil_Out32(0xFD080004, 0x0004FE01); + regval = Xil_In32(0xFD080030); + while (regval != 0x80000FFF) + regval = Xil_In32(0xFD080030); + + Xil_Out32(0xFD080200U, 0x100091C7U); + Xil_Out32(0xFD080018U, 0x00F01EF2U); + prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000003U); + prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000003U); + + Xil_Out32(0xFD080004, 0x00060001); + regval = Xil_In32(0xFD080030); + while ((regval & 0x80004001) != 0x80004001) + + regval = Xil_In32(0xFD080030); + + prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000000U); + prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000000U); + + Xil_Out32(0xFD080200U, 0x800091C7U); + Xil_Out32(0xFD080018U, 0x00F12302U); + + Xil_Out32(0xFD080004, 0x0000C001); + regval = Xil_In32(0xFD080030); + while ((regval & 0x80000C01) != 0x80000C01) + + regval = Xil_In32(0xFD080030); + + Xil_Out32(0xFD070180U, 0x01000040U); + Xil_Out32(0xFD070060U, 0x00000000U); + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000000U); + + return 1; +} + +static void init_peripheral(void) +{ + unsigned int tmp_regval; + + tmp_regval = Xil_In32(0xFD690040); + tmp_regval &= ~0x00000001; + Xil_Out32(0xFD690040, tmp_regval); + + tmp_regval = Xil_In32(0xFD690030); + tmp_regval &= ~0x00000001; + Xil_Out32(0xFD690030, tmp_regval); +} + +int psu_init(void) +{ + int status = 1; + + status &= psu_mio_init_data(); + status &= psu_pll_init_data(); + status &= psu_clock_init_data(); + status &= psu_ddr_init_data(); + status &= psu_ddr_phybringup_data(); + status &= psu_peripherals_init_data(); + init_peripheral(); + + status &= psu_afi_config(); + + if (status == 0) + return 1; + return 0; +}
2018-01-10 16:38 GMT+01:00 Michal Simek michal.simek@xilinx.com:
diff --git a/arch/arm/cpu/armv8/zynqmp/spl.c b/arch/arm/cpu/armv8/zynqmp/ spl.c index 41ca74a2be2b..da983458a982 100644 --- a/arch/arm/cpu/armv8/zynqmp/spl.c +++ b/arch/arm/cpu/armv8/zynqmp/spl.c @@ -14,6 +14,7 @@ #include <asm/spl.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> +#include <asm/arch/psu_init_gpl.h>
int i = 0;
i++;
return 1;
int i = 0;
i++;
return 1;
udelay(delay);
unsigned long val)
regval &= ~(mask);
int rdata = 0;
unsigned long val);
1.9.1
Will send v2 of this patch. Psu init functions should be moved to separate files as is done for zynq.
M
Michal Simek
Michal Simek
