[PATCH 0/6] Support for AC5X NAND and AT-x240 board
This series adds support for the NAND flash controller on the AC5X SoC and adds support for the Allied Telesis x240 board.
I've also included 2 unrelated changes. "arm: mvebu: Remove unused alias from RC AC5X dts" removes an unused alias from the dts. This was in the neighborhood of the x240 so I included it.
"mtd: nand: pxa3xx: Enable devbus/nand arbiter on Armada 8K" allows using the NFC and device bus at the same time. This is needed for another board (CN9130 based) that I'll hopefully get upstream in the near future. I figured I'd include it now since I was touching the NAND driver.
Chris Packham (6): arm: mvebu: ac5: Add nand-controller node arm: mvebu: ac5: Define mvebu_get_nand_clock() mtd: nand: pxa3xx: Add support for the Marvell AC5 SoC mtd: nand: pxa3xx: Enable devbus/nand arbiter on Armada 8K arm: mvebu: Add Allied Telesis x240 board arm: mvebu: Remove unused alias from RC AC5X dts
arch/arm/dts/Makefile | 3 +- arch/arm/dts/ac5-98dx25xx.dtsi | 9 ++ arch/arm/dts/ac5-98dx35xx-atl-x240.dts | 212 +++++++++++++++++++++++++ arch/arm/dts/ac5-98dx35xx-rd.dts | 1 - arch/arm/mach-mvebu/Kconfig | 7 + arch/arm/mach-mvebu/alleycat5/soc.c | 6 + board/alliedtelesis/x240/MAINTAINERS | 7 + board/alliedtelesis/x240/Makefile | 6 + board/alliedtelesis/x240/x240.c | 13 ++ configs/x240_defconfig | 87 ++++++++++ drivers/mtd/nand/raw/pxa3xx_nand.c | 20 ++- include/configs/x240.h | 37 +++++ 12 files changed, 402 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/ac5-98dx35xx-atl-x240.dts create mode 100644 board/alliedtelesis/x240/MAINTAINERS create mode 100644 board/alliedtelesis/x240/Makefile create mode 100644 board/alliedtelesis/x240/x240.c create mode 100644 configs/x240_defconfig create mode 100644 include/configs/x240.h
The AC5/AC5X SoC has a NAND flash controller. Add this to the SoC device tree.
Signed-off-by: Chris Packham judge.packham@gmail.com --- arch/arm/dts/ac5-98dx25xx.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/dts/ac5-98dx25xx.dtsi b/arch/arm/dts/ac5-98dx25xx.dtsi index 3c68355f323a..f53b4781d7fd 100644 --- a/arch/arm/dts/ac5-98dx25xx.dtsi +++ b/arch/arm/dts/ac5-98dx25xx.dtsi @@ -251,6 +251,15 @@ status = "disabled"; };
+ nand: nand-controller@805b0000 { + compatible = "marvell,mvebu-ac5-pxa3xx-nand"; + reg = <0x0 0x805b0000 0x0 0x54>; + #address-cells = <0x00000001>; + marvell,nand-enable-arbiter; + num-cs = <0x00000001>; + status = "disabled"; + }; + gic: interrupt-controller@80600000 { compatible = "arm,gic-v3"; #interrupt-cells = <3>;
The NF_CLK for the AC5 SoC runs at 400MHz. There's no strapping or gating require so just add a mvebu_get_nand_clock() that returns this value.
Signed-off-by: Chris Packham judge.packham@gmail.com --- arch/arm/mach-mvebu/alleycat5/soc.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/mach-mvebu/alleycat5/soc.c b/arch/arm/mach-mvebu/alleycat5/soc.c index dc69f46eedb2..734b0a87dd49 100644 --- a/arch/arm/mach-mvebu/alleycat5/soc.c +++ b/arch/arm/mach-mvebu/alleycat5/soc.c @@ -255,6 +255,12 @@ void soc_print_clock_info(void) printf("\tMSS %4d MHz\n", 200); }
+/* Return NAND clock in Hz */ +u32 mvebu_get_nand_clock(void) +{ + return 400 * 1000000; +} + /* * Override of __weak int mach_cpu_init(void) : * SoC/machine dependent CPU setup
The NAND flash controller (NFC) on the AC5/AC5X SoC is the same as the NFC used on other Marvell SoCs. It does have the additional restriction of only supporting SDR timing modes up to 3.
Signed-off-by: Chris Packham judge.packham@gmail.com --- drivers/mtd/nand/raw/pxa3xx_nand.c | 17 ++++++++++++++--- 1 file changed, 14 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/raw/pxa3xx_nand.c b/drivers/mtd/nand/raw/pxa3xx_nand.c index fcd1b9c63614..9dee580ab9c2 100644 --- a/drivers/mtd/nand/raw/pxa3xx_nand.c +++ b/drivers/mtd/nand/raw/pxa3xx_nand.c @@ -167,6 +167,7 @@ enum pxa3xx_nand_variant { PXA3XX_NAND_VARIANT_PXA, PXA3XX_NAND_VARIANT_ARMADA370, PXA3XX_NAND_VARIANT_ARMADA_8K, + PXA3XX_NAND_VARIANT_AC5, };
struct pxa3xx_nand_host { @@ -391,6 +392,10 @@ static const struct udevice_id pxa3xx_nand_dt_ids[] = { .compatible = "marvell,armada-8k-nand-controller", .data = PXA3XX_NAND_VARIANT_ARMADA_8K, }, + { + .compatible = "marvell,mvebu-ac5-pxa3xx-nand", + .data = PXA3XX_NAND_VARIANT_AC5, + }, {} };
@@ -505,6 +510,9 @@ static int pxa3xx_nand_init_timings(struct pxa3xx_nand_host *host) if (mode < 0) mode = 0;
+ if (info->variant == PXA3XX_NAND_VARIANT_AC5) + mode = min(mode, 3); + timings = onfi_async_timing_mode_to_sdr_timings(mode); if (IS_ERR(timings)) return PTR_ERR(timings); @@ -730,7 +738,8 @@ static irqreturn_t pxa3xx_nand_irq(struct pxa3xx_nand_info *info)
/* NDCB3 register is available in NFCv2 (Armada 370/XP SoC) */ if (info->variant == PXA3XX_NAND_VARIANT_ARMADA370 || - info->variant == PXA3XX_NAND_VARIANT_ARMADA_8K) + info->variant == PXA3XX_NAND_VARIANT_ARMADA_8K || + info->variant == PXA3XX_NAND_VARIANT_AC5) nand_writel(info, NDCB0, info->ndcb3); }
@@ -1579,7 +1588,8 @@ static int pxa3xx_nand_scan(struct mtd_info *mtd)
/* Device detection must be done with ECC disabled */ if (info->variant == PXA3XX_NAND_VARIANT_ARMADA370 || - info->variant == PXA3XX_NAND_VARIANT_ARMADA_8K) + info->variant == PXA3XX_NAND_VARIANT_ARMADA_8K || + info->variant == PXA3XX_NAND_VARIANT_AC5) nand_writel(info, NDECCCTRL, 0x0);
if (nand_scan_ident(mtd, 1, NULL)) @@ -1630,7 +1640,8 @@ static int pxa3xx_nand_scan(struct mtd_info *mtd) */ if (mtd->writesize > info->chunk_size) { if (info->variant == PXA3XX_NAND_VARIANT_ARMADA370 || - info->variant == PXA3XX_NAND_VARIANT_ARMADA_8K) { + info->variant == PXA3XX_NAND_VARIANT_ARMADA_8K || + info->variant == PXA3XX_NAND_VARIANT_AC5) { chip->cmdfunc = nand_cmdfunc_extended; } else { dev_err(mtd->dev,
The CN9130 SoC (an ARMADA 8K type) has both a NAND Flash Controller and a generic local bus controller (Device Bus Controller) that share common pins.
With a board design that incorporates both a NAND flash and uses the Device Bus (in our case for an SRAM) accessing the Device Bus device fails unless the NfArbiterEn bit is set. Setting the bit enables arbitration between the Device Bus and the NAND flash.
Since there is no obvious downside in enabling this for designs that don't require arbitration, we always enable it.
Signed-off-by: Chris Packham judge.packham@gmail.com --- drivers/mtd/nand/raw/pxa3xx_nand.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/raw/pxa3xx_nand.c b/drivers/mtd/nand/raw/pxa3xx_nand.c index 9dee580ab9c2..d502e967f92c 100644 --- a/drivers/mtd/nand/raw/pxa3xx_nand.c +++ b/drivers/mtd/nand/raw/pxa3xx_nand.c @@ -125,6 +125,7 @@ DECLARE_GLOBAL_DATA_PTR; /* System control register and bit to enable NAND on some SoCs */ #define GENCONF_SOC_DEVICE_MUX 0x208 #define GENCONF_SOC_DEVICE_MUX_NFC_EN BIT(0) +#define GENCONF_SOC_DEVICE_MUX_NFC_DEVBUS_ARB_EN BIT(27)
/* * This should be large enough to read 'ONFI' and 'JEDEC'. @@ -1739,7 +1740,7 @@ static int alloc_nand_resource(struct udevice *dev, struct pxa3xx_nand_info *inf return PTR_ERR(sysctrl_base);
regmap_read(sysctrl_base, GENCONF_SOC_DEVICE_MUX, ®); - reg |= GENCONF_SOC_DEVICE_MUX_NFC_EN; + reg |= GENCONF_SOC_DEVICE_MUX_NFC_EN | GENCONF_SOC_DEVICE_MUX_NFC_DEVBUS_ARB_EN; regmap_write(sysctrl_base, GENCONF_SOC_DEVICE_MUX, reg); }
The x240 and SE240 are a series of L2+ switches from Allied Telesis. There are a number of them in the range but as far as U-Boot is concerned all the CPU block components are the same so there's only one board defined.
Signed-off-by: Chris Packham judge.packham@gmail.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/ac5-98dx35xx-atl-x240.dts | 212 +++++++++++++++++++++++++ arch/arm/mach-mvebu/Kconfig | 7 + board/alliedtelesis/x240/MAINTAINERS | 7 + board/alliedtelesis/x240/Makefile | 6 + board/alliedtelesis/x240/x240.c | 13 ++ configs/x240_defconfig | 87 ++++++++++ include/configs/x240.h | 37 +++++ 8 files changed, 371 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/ac5-98dx35xx-atl-x240.dts create mode 100644 board/alliedtelesis/x240/MAINTAINERS create mode 100644 board/alliedtelesis/x240/Makefile create mode 100644 board/alliedtelesis/x240/x240.c create mode 100644 configs/x240_defconfig create mode 100644 include/configs/x240.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 480269fa6065..38d878a0f853 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -303,7 +303,8 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ cn9132-db-B.dtb \ cn9130-crb-A.dtb \ cn9130-crb-B.dtb \ - ac5-98dx35xx-rd.dtb + ac5-98dx35xx-rd.dtb \ + ac5-98dx35xx-atl-x240.dtb endif
dtb-$(CONFIG_ARCH_SYNQUACER) += synquacer-sc2a11-developerbox.dtb diff --git a/arch/arm/dts/ac5-98dx35xx-atl-x240.dts b/arch/arm/dts/ac5-98dx35xx-atl-x240.dts new file mode 100644 index 000000000000..820ec18b4355 --- /dev/null +++ b/arch/arm/dts/ac5-98dx35xx-atl-x240.dts @@ -0,0 +1,212 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include "ac5-98dx35xx.dtsi" + +/ { + model = "Allied Telesis x240"; + compatible = "alliedtelesis,x240", "marvell,ac5x", "marvell,ac5"; + + aliases { + serial0 = &uart0; + spiflash0 = &spiflash0; + gpio0 = &gpio0; + gpio1 = &gpio1; + spi0 = &spi0; + i2c0 = &i2c0; + usb0 = &usb0; + pinctrl0 = &pinctrl0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + boot-board { + compatible = "atl,boot-board"; + present-gpio = <&gpio1 6 GPIO_ACTIVE_HIGH>; + override-gpio = <&gpio1 2 GPIO_ACTIVE_HIGH>; + }; + + gpio-leds { + compatible = "gpio-leds"; + + fault { + label = "fault:red"; + gpios = <&system_gpio 11 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + }; +}; + +&nand { + pinctrl-names = "default"; + pinctrl-0 = <&nand_pins>; + + nand-ecc-strength = <4>; + nand-ecc-step-size = <512>; + status = "okay"; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@user { + reg = <0x00000000 0x10000000>; + label = "user"; + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + + mux@71 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nxp,pca9546"; + reg = <0x71>; + i2c-mux-idle-disconnect; + reset-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; /* MPP36 */ + status = "okay"; + + i2c@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + hwmon@2e { + compatible = "adi,adt7476"; + reg = <0x2e>; + }; + + rtc@68 { + compatible = "adi,max31331"; + reg = <0x68>; + }; + + system_gpio: gpio@27 { + compatible = "nxp,pca9555"; + gpio-controller; + #gpio-cells= <2>; + reg = <0x27>; + interrupt-parent = <&gpio0>; + interrupts = <25 IRQ_TYPE_LEVEL_LOW>; /* MPP25 */ + }; + }; + }; +}; + +&spi0 { + status = "okay"; + spiflash0: flash@0 { + compatible = "jedec,spi-nor"; + spi-max-frequency = <50000000>; + spi-tx-bus-width = <1>; /* 1-single, 2-dual, 4-quad */ + spi-rx-bus-width = <1>; /* 1-single, 2-dual, 4-quad */ + reg = <0>; + + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +&gpio0 { + phy-reset { + gpio-hog; + gpios = <19 GPIO_ACTIVE_LOW>; + output-high; + line-name = "phy-reset"; + }; + + usb-en { + gpio-hog; + gpios = <28 GPIO_ACTIVE_HIGH>; + output-high; + line-name = "usb-en"; + }; + + led-oe-n { + gpio-hog; + gpios = <23 GPIO_ACTIVE_LOW>; + output-low; + line-name = "led-oe-n"; + }; +}; + +&gpio1 { + nand-protect { + gpio-hog; + gpios = <8 GPIO_ACTIVE_LOW>; + output-low; + line-name = "nand-protect"; + }; +}; + +&pinctrl0 { + /* + * MPP Bus: MPP# + * NF_IO [0-7] + * NF_Wen [8] + * NF_ALE [9] + * NF_CLE [10] + * NF_Cen [11] + * QSPI_SCK/SPI0_SCK [12] + * QSPI_CSn/SPI0_CSn [13] + * QSPI_DIO[0]/SPI0_MOSI [14] + * QSPI_DIO[1]/SPI0_MISO [15] + * NF_Ren [16] + * NF_RBn [17] + * WD_INTn [18] + * B_B_OVRIDE_N [19] + * GREEN_SW_N [20] + * PHY_INT_N[0] [21] + * SPI_WPn [22] + * LED_OE_N [23] + * USB_PWR_FLT_N [24] + * SFP_INT_N [25] + * I2C0_SCL [26] + * I2C0_SDA [27] + * USB_EN [28] + * MONITOR_INT_N [29] + * XM1_MDC [30] + * XM1_MDIO [31] + * UA0_RXD [32] + * UA0_TXD [33] + * PHY_RST0n [34] + * TPM_INT_N [35] + * I2CMUX_RESET_N [36] + * SPI_SRAM_SEL_N [37] + * B_B_PRESENT [38] + * SPI_FLASH_SEL_N [39] + * NF_WP_N [40] + * POE_INT_N [41] + * PoE_RST_N [42] + * LED0_CLK [43] + * LED0_STB [44] + * LED0_DATA [45] + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 1 1 1 1 0xff 0xff 0 0 + 0 0 0 0 0 0 1 1 0 0 + 1 1 1 1 0 0 0 0 0 0 + 0 0 0 1 1 1 >; + + nand_pins: nand-pins { + marvell,pins = <0 1 2 3 4 5 6 7 8 9 10 11 16 17>; + marvell,function = <2>; + }; +}; diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index ac484c73f62d..5c7f4bf964af 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -202,6 +202,10 @@ config TARGET_X530 bool "Support Allied Telesis x530" select 88F6820
+config TARGET_X240 + bool "Support Allied Telesis x240" + select ALLEYCAT_5 + config TARGET_DB_XC3_24G4XG bool "Support DB-XC3-24G4XG" select 98DX3336 @@ -274,6 +278,7 @@ config SYS_BOARD default "theadorable" if TARGET_THEADORABLE default "a38x" if TARGET_CONTROLCENTERDC default "x530" if TARGET_X530 + default "x240" if TARGET_X240 default "db-xc3-24g4xg" if TARGET_DB_XC3_24G4XG default "crs3xx-98dx3236" if TARGET_CRS3XX_98DX3236 default "mvebu_alleycat-5" if TARGET_MVEBU_ALLEYCAT5 @@ -297,6 +302,7 @@ config SYS_CONFIG_NAME default "turris_mox" if TARGET_TURRIS_MOX default "controlcenterdc" if TARGET_CONTROLCENTERDC default "x530" if TARGET_X530 + default "x240" if TARGET_X240 default "db-xc3-24g4xg" if TARGET_DB_XC3_24G4XG default "crs3xx-98dx3236" if TARGET_CRS3XX_98DX3236 default "mvebu_alleycat-5" if TARGET_MVEBU_ALLEYCAT5 @@ -320,6 +326,7 @@ config SYS_VENDOR default "CZ.NIC" if TARGET_TURRIS_MOX default "gdsys" if TARGET_CONTROLCENTERDC default "alliedtelesis" if TARGET_X530 + default "alliedtelesis" if TARGET_X240 default "mikrotik" if TARGET_CRS3XX_98DX3236 default "Marvell" if TARGET_MVEBU_ALLEYCAT5
diff --git a/board/alliedtelesis/x240/MAINTAINERS b/board/alliedtelesis/x240/MAINTAINERS new file mode 100644 index 000000000000..f1f78d96167c --- /dev/null +++ b/board/alliedtelesis/x240/MAINTAINERS @@ -0,0 +1,7 @@ +X240 BOARD +M: Chris Packham chris.packham@alliedtelesis.co.nz +S: Maintained +F: board/alliedtelesis/x240/ +F: arch/arm/dts/ac5-98dx35xx-rd.dts +F: include/configs/x240.h +F: configs/x240_defconfig diff --git a/board/alliedtelesis/x240/Makefile b/board/alliedtelesis/x240/Makefile new file mode 100644 index 000000000000..7f20a47d6a76 --- /dev/null +++ b/board/alliedtelesis/x240/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2022 Allied Telesis +# + +obj-y += x240.o diff --git a/board/alliedtelesis/x240/x240.c b/board/alliedtelesis/x240/x240.c new file mode 100644 index 000000000000..0c4f8e03b859 --- /dev/null +++ b/board/alliedtelesis/x240/x240.c @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + gd->bd->bi_boot_params = CFG_SYS_SDRAM_BASE + 0x100; + + return 0; +} diff --git a/configs/x240_defconfig b/configs/x240_defconfig new file mode 100644 index 000000000000..7caaa1743ccb --- /dev/null +++ b/configs/x240_defconfig @@ -0,0 +1,87 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_TEXT_BASE=0x200000000 +CONFIG_SYS_MALLOC_LEN=0x900000 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x200FF0000 +CONFIG_TARGET_X240=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x00f80000 +CONFIG_ENV_SECT_SIZE=0x40000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="ac5-98dx35xx-atl-x240" +CONFIG_SYS_LOAD_ADDR=0x220000000 +CONFIG_DEBUG_UART=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_FIT=y +CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_CLK=y +CONFIG_CLK_MVEBU=y +CONFIG_GPIO_HOG=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +# CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_PXA3XX=y +CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_8K=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_RTC_MAX313XX=y +CONFIG_DM_SCSI=y +CONFIG_SYS_NS16550=y +CONFIG_MVEBU_A3700_SPI=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +# CONFIG_FAT_WRITE is not set diff --git a/include/configs/x240.h b/include/configs/x240.h new file mode 100644 index 000000000000..3601df588d56 --- /dev/null +++ b/include/configs/x240.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 Allied Telesis + */ + +#ifndef __X240_H_ +#define __X240_H_ + +#include <asm/arch/soc.h> + +/* additions for new ARM relocation support */ +#define CFG_SYS_SDRAM_BASE 0x200000000 + +#define CFG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ + 115200, 230400, 460800, 921600 } + +/* Default Env vars */ + +#define BOOT_TARGET_DEVICES(func) \ + func(USB, usb, 0) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +#define CFG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + "kernel_addr_r=0x202000000\0" \ + "fdt_addr_r=0x201000000\0" \ + "ramdisk_addr_r=0x206000000\0" \ + "fdtfile=marvell/" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" + +/* + * High Level Configuration Options (easy to change) + */ +#define CFG_SYS_TCLK 325000000 + +#endif /* __X240_H_ */
ac5-98dx35xx-rd.dtb
endif
+/dts-v1/;
aliases {
serial0 = &uart0;
gpio0 = &gpio0;
gpio1 = &gpio1;
spi0 = &spi0;
i2c0 = &i2c0;
usb0 = &usb0;
chosen {
boot-board {
gpio-leds {
fault {
+&nand {
status = "okay";
partitions {
#size-cells = <1>;
partition@user {
label = "user";
+&uart0 {
status = "okay";
+&usb0 {
status = "okay";
+&i2c0 {
status = "okay";
mux@71 {
#size-cells = <0>;
reg = <0x71>;
status = "okay";
i2c@1 {
#size-cells = <0>;
reg = <1>;
hwmon@2e {
reg = <0x2e>;
rtc@68 {
reg = <0x68>;
gpio-controller;
#gpio-cells= <2>;
reg = <0x27>;
+&spi0 {
status = "okay";
reg = <0>;
#size-cells = <1>;
+&gpio0 {
phy-reset {
gpio-hog;
output-high;
usb-en {
gpio-hog;
output-high;
led-oe-n {
gpio-hog;
output-low;
+&gpio1 {
nand-protect {
gpio-hog;
output-low;
+&pinctrl0 {
* MPP Bus: MPP#
* NF_IO [0-7]
* NF_Wen [8]
* NF_ALE [9]
* NF_CLE [10]
* NF_Cen [11]
* NF_Ren [16]
* NF_RBn [17]
* WD_INTn [18]
* B_B_OVRIDE_N [19]
* GREEN_SW_N [20]
* PHY_INT_N[0] [21]
* SPI_WPn [22]
* LED_OE_N [23]
* SFP_INT_N [25]
* I2C0_SCL [26]
* I2C0_SDA [27]
* USB_EN [28]
* XM1_MDC [30]
* XM1_MDIO [31]
* UA0_RXD [32]
* UA0_TXD [33]
* PHY_RST0n [34]
* TPM_INT_N [35]
* B_B_PRESENT [38]
* NF_WP_N [40]
* POE_INT_N [41]
* PoE_RST_N [42]
* LED0_CLK [43]
* LED0_STB [44]
* LED0_DATA [45]
0 0 0 0 0 0 1 1 0 0
1 1 1 1 0 0 0 0 0 0
0 0 0 1 1 1 >;
+config TARGET_X240
select ALLEYCAT_5
Oops this should have been in my debugging patch which is on the top of my pile. I'll drop it in v2.
- Copyright (C) 2022 Allied Telesis
func(USB, usb, 0) \
BOOTENV \
- High Level Configuration Options (easy to change)
2.41.0
The sar-reg0 alias was left over from an earlier iteration of the patches adding support for this board. Remove the unused alias.
Fixes: 6cc8b5db40 ("arm: mvebu: Add RD-AC5X board") Signed-off-by: Chris Packham judge.packham@gmail.com --- arch/arm/dts/ac5-98dx35xx-rd.dts | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/dts/ac5-98dx35xx-rd.dts b/arch/arm/dts/ac5-98dx35xx-rd.dts index d9f217cd4a5f..1dc85bb7ef24 100644 --- a/arch/arm/dts/ac5-98dx35xx-rd.dts +++ b/arch/arm/dts/ac5-98dx35xx-rd.dts @@ -31,7 +31,6 @@ usb0 = &usb0; usb1 = &usb1; pinctrl0 = &pinctrl0; - sar-reg0 = "/config-space/sar-reg"; };
usb1phy: usb-phy {
Chris Packham
