[U-Boot] [PATCH 1/1] dm: sysreset: x86: missing build dependency
make qemu-x86_defconfig with additional
#CONFIG_SYSRESET is not set
results in
LD u-boot lib/built-in.o: In function `efi_reset_system_boottime': lib/efi_loader/efi_runtime.c:122: undefined reference to `do_reset'
Fixes: fabb2b4c7f28 ("dm: sysreset: x86: Add a sysreset driver") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/sysreset/Kconfig | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/sysreset/Kconfig b/drivers/sysreset/Kconfig index 9b2fda4d25..a5a58e6d83 100644 --- a/drivers/sysreset/Kconfig +++ b/drivers/sysreset/Kconfig @@ -36,6 +36,12 @@ config SYSRESET_PSCI Enable PSCI SYSTEM_RESET function call. To use this, PSCI firmware must be running on your system.
+config SYSRESET_X86 + bool "Enable support for x86 processor reboot driver" + depends on X86 + help + Reboot support for generic x86 processor reset. + endif
config SYSRESET_SYSCON @@ -51,10 +57,4 @@ config SYSRESET_WATCHDOG help Reboot support for generic watchdog reset.
-config SYSRESET_X86 - bool "Enable support for x86 processor reboot driver" - depends on X86 - help - Reboot support for generic x86 processor reset. - endmenu
Hi Heinrich,
On Sun, Jul 22, 2018 at 5:48 PM, Heinrich Schuchardt xypron.glpk@gmx.de wrote:
I don't understand the changes. Why do you want to add "#CONFIG_SYSRESET is not set"?
results in
depends on X86
help
endif
depends on X86
help
endmenu
Regards, Bin
On 07/23/2018 03:51 AM, Bin Meng wrote:
Hi Heinrich,
I was astonished that a configuration file I was using suddenly was failing after your patch was merged. I analyzed the problem and found the missing dependency.
In general it should not be possible to create a configuration that cannot be built. One tool to verify this is the U-Boot randconfig target.
Best regards
Heinrich
results in
depends on X86
help
endif
depends on X86
help
endmenu
Regards, Bin
Hi Heinrich,
On Sun, Jul 29, 2018 at 5:44 AM, Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hi Heinrich,
Yes, that's the goal, however I doubt currently we achieved such goal.
Using "Fixes: fabb2b4c7f28 ("dm: sysreset: x86: Add a sysreset driver")" misleads people, as you are not using the default configuration. If we want to support such random build for sysreset, I think we should put the below driver under "if SYSRESET" too, not just x86.
41 config SYSRESET_SYSCON 42 bool "Enable support for mfd syscon reboot driver" 43 select REGMAP 44 select SYSCON 45 help 46 Reboot support for generic SYSCON mapped register reset. 47 48 config SYSRESET_WATCHDOG 49 bool "Enable support for watchdog reboot driver" 50 select WDT 51 help 52 Reboot support for generic watchdog reset. 53
Regards, Bin
Bin Meng
