[PATCH] patman: Properly document the patchwork_url setting
The "Series-patchwork-url:" tag description says that it overrides the settings file but doesn't specify the name of the setting. Elsewhere in the documentation about the "useful" settings we see a setting that sounds promising called "patchwork_server" that's actually not a valid setting. It should be "patchwork_url".
Fix these problems so the doc is right and more useful.
Signed-off-by: Douglas Anderson dianders@chromium.org ---
tools/patman/patman.rst | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/tools/patman/patman.rst b/tools/patman/patman.rst index e01355824c59..f4588c00fc11 100644 --- a/tools/patman/patman.rst +++ b/tools/patman/patman.rst @@ -144,7 +144,7 @@ patman.py. For reference, the useful ones (at the moment) shown below process_tags: False verbose: True smtp_server: /path/to/sendmail - patchwork_server: https://patchwork.ozlabs.org + patchwork_url: https://patchwork.ozlabs.org
If you want to adjust settings (or aliases) that affect just a single project you can add a section that looks like [project_settings] or @@ -248,9 +248,9 @@ Series-links: [id | version:id]...
Series-patchwork-url: url This allows specifying the Patchwork URL for a branch. This overrides - both the setting files and the command-line argument. The URL should - include the protocol and web site, with no trailing slash, for example - 'https://patchwork.ozlabs.org/project' + both the setting files ("patchwork_url") and the command-line argument. + The URL should include the protocol and web site, with no trailing slash, + for example 'https://patchwork.ozlabs.org/project'
Cover-letter: Sets the cover letter contents for the series. The first line
Douglas Anderson
