[U-Boot] [PATCH 1/1] at91: reworked support for otc570 board
After relocation rework, the meesc and otc570 board support was broken. This patch will fix the otc570 board.
Signed-off-by: Daniel Gorsulowski Daniel.Gorsulowski@esd.eu ---
This patch is based on u-boot-atmel/rework101229 branch (minus the last 5 patches) plus the 'at91: fixed at91sam9263 system file' patch in u-boot-atmel/next branch.
board/esd/otc570/config.mk | 1 - board/esd/otc570/otc570.c | 106 ++++++++++-------- boards.cfg | 3 +- include/configs/otc570.h | 265 +++++++++++++++++++++++++------------------- 4 files changed, 211 insertions(+), 164 deletions(-) delete mode 100644 board/esd/otc570/config.mk
diff --git a/board/esd/otc570/config.mk b/board/esd/otc570/config.mk deleted file mode 100644 index e554a45..0000000 --- a/board/esd/otc570/config.mk +++ /dev/null @@ -1 +0,0 @@ -CONFIG_SYS_TEXT_BASE = 0x23f00000 diff --git a/board/esd/otc570/otc570.c b/board/esd/otc570/otc570.c index 410d8b4..f025fc9 100644 --- a/board/esd/otc570/otc570.c +++ b/board/esd/otc570/otc570.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2010 + * (C) Copyright 2010-2011 * Daniel Gorsulowski daniel.gorsulowski@esd.eu * esd electronic system design gmbh <www.esd.eu> * @@ -27,7 +27,7 @@ */
#include <common.h> -#include <asm/arch/at91sam9263.h> +#include <asm/io.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> @@ -35,14 +35,14 @@ #include <asm/arch/at91_matrix.h> #include <asm/arch/at91_pio.h> #include <asm/arch/clk.h> -#include <asm/arch/hardware.h> -#include <asm/arch/io.h> -#include <atmel_lcdc.h> -#include <lcd.h> #include <netdev.h> -#ifdef CONFIG_LCD_INFO -#include <nand.h> -#include <version.h> +#ifdef CONFIG_LCD +# include <atmel_lcdc.h> +# include <lcd.h> +# ifdef CONFIG_LCD_INFO +# include <nand.h> +# include <version.h> +# endif #endif
DECLARE_GLOBAL_DATA_PTR; @@ -73,8 +73,8 @@ int get_hw_rev(void) static void otc570_nand_hw_init(void) { unsigned long csa; - at91_smc_t *smc = (at91_smc_t *) AT91_SMC0_BASE; - at91_matrix_t *matrix = (at91_matrix_t *) AT91_MATRIX_BASE; + at91_smc_t *smc = (at91_smc_t *) ATMEL_BASE_SMC0; + at91_matrix_t *matrix = (at91_matrix_t *) ATMEL_BASE_MATRIX;
/* Enable CS3 */ csa = readl(&matrix->csa[0]) | AT91_MATRIX_CSA_EBI_CS3A; @@ -93,8 +93,8 @@ static void otc570_nand_hw_init(void) &smc->cs[3].cycle); writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | AT91_SMC_MODE_EXNW_DISABLE | - AT91_SMC_MODE_DBW_8 | - AT91_SMC_MODE_TDF_CYCLE(2), + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(3), &smc->cs[3].mode);
/* Configure RDY/BSY */ @@ -108,9 +108,9 @@ static void otc570_nand_hw_init(void) #ifdef CONFIG_MACB static void otc570_macb_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; /* Enable clock */ - writel(1 << AT91SAM9263_ID_EMAC, &pmc->pcer); + writel(1 << ATMEL_ID_EMAC, &pmc->pcer); at91_macb_hw_init(); } #endif @@ -123,7 +123,7 @@ static void otc570_macb_hw_init(void) */ static void otc570_ethercat_hw_init(void) { - at91_smc_t *smc1 = (at91_smc_t *) AT91_SMC1_BASE; + at91_smc_t *smc1 = (at91_smc_t *) ATMEL_BASE_SMC1;
/* Configure SMC EBI1_CS0 for EtherCAT */ writel(AT91_SMC_SETUP_NWE(0) | AT91_SMC_SETUP_NCS_WR(0) | @@ -155,7 +155,7 @@ vidinfo_t panel_info = { .vl_sync = ATMEL_LCDC_INVLINE_INVERTED | ATMEL_LCDC_INVFRAME_INVERTED,
- .vl_bpix = 3, /* Bits per pixel, 0 = 1bit, 3 = 8bit */ + .vl_bpix = LCD_BPP,/* Bits per pixel, 0 = 1bit, 3 = 8bit */ .vl_tft = 1, /* 0 = passive, 1 = TFT */ .vl_vsync_len = 1, /* Length of vertical sync in NOL */ .vl_upper_margin = 35, /* Idle lines at the frame start */ @@ -164,22 +164,22 @@ vidinfo_t panel_info = { .vl_left_margin = 112, /* Idle cycles at the line beginning */ .vl_right_margin = 1, /* Idle cycles at the end of the line */
- .mmio = AT91SAM9263_LCDC_BASE, + .mmio = ATMEL_BASE_LCDC, };
void lcd_enable(void) { - at91_set_pio_value(AT91_PIO_PORTA, 30, 0); /* power up */ + at91_set_pio_value(AT91_PIO_PORTA, 30, 0); /* power up */ }
void lcd_disable(void) { - at91_set_pio_value(AT91_PIO_PORTA, 30, 1); /* power down */ + at91_set_pio_value(AT91_PIO_PORTA, 30, 1); /* power down */ }
static void otc570_lcd_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTC, 0, 0); /* LCDVSYNC */ at91_set_a_periph(AT91_PIO_PORTC, 1, 0); /* LCDHSYNC */ @@ -206,8 +206,7 @@ static void otc570_lcd_hw_init(void) at91_set_a_periph(AT91_PIO_PORTC, 27, 0); /* LCDD23 */ at91_set_pio_output(AT91_PIO_PORTA, 30, 1); /* PCI */
- writel(1 << AT91SAM9263_ID_LCDC, &pmc->pcer); - gd->fb_base = CONFIG_OTC570_LCD_BASE; + writel(1 << ATMEL_ID_LCDC, &pmc->pcer); }
#ifdef CONFIG_LCD_INFO @@ -225,8 +224,7 @@ void lcd_show_board_info(void) nand_size += nand_info[i].size;
lcd_printf("\n%s\n", U_BOOT_VERSION); - lcd_printf("%s CPU at %s MHz\n", CONFIG_SYS_AT91_CPU_NAME, - strmhz(temp, get_cpu_clk_rate())); + lcd_printf("CPU at %s MHz\n", strmhz(temp, get_cpu_clk_rate())); lcd_printf(" %ld MB SDRAM, %ld MB NAND\n", dram_size >> 20, nand_size >> 20 ); @@ -239,8 +237,9 @@ void lcd_show_board_info(void)
int dram_init(void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM; - gd->bd->bi_dram[0].size = get_ram_size((long *) PHYS_SDRAM, (1 << 27)); + gd->ram_size = get_ram_size( + (void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); return 0; }
@@ -248,7 +247,7 @@ int board_eth_init(bd_t *bis) { int rc = 0; #ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)AT91_EMAC_BASE, 0x00); + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC, 0x00); #endif return rc; } @@ -257,13 +256,14 @@ int checkboard(void) { char str[32];
- puts("Board: esd ARM9 HMI Panel - OTC570"); + puts("Board : esd ARM9 HMI Panel - OTC570"); if (getenv_f("serial#", str, sizeof(str)) > 0) { puts(", serial# "); puts(str); } - printf("\nHardware-revision: 1.%d\n", get_hw_rev()); - printf("Mach-type: %lu\n", gd->bd->bi_arch_number); + printf("\n"); + printf("Hardware-revision: 1.%d\n", get_hw_rev()); + printf("Mach-type : %lu\n", gd->bd->bi_arch_number); return 0; }
@@ -297,12 +297,12 @@ u32 get_board_rev(void) int misc_init_r(void) { char str[64]; - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_pio_output(AT91_PIO_PORTA, 29, 1); at91_set_a_periph(AT91_PIO_PORTA, 26, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTA, 27, 0); /* RXD0 */ - writel(1 << AT91SAM9263_ID_US0, &pmc->pcer); + writel(1 << ATMEL_ID_USART0, &pmc->pcer); /* Set USART_MODE = 1 (RS485) */ writel(1, 0xFFF8C004);
@@ -325,37 +325,49 @@ int misc_init_r(void) at91_set_pio_output(AT91_PIO_PORTA, 29, 0); } } +#ifdef CONFIG_LCD printf("Display memory address: 0x%08lX\n", gd->fb_base); +#endif
return 0; } #endif /* CONFIG_MISC_INIT_R */
-int board_init(void) +int board_early_init_f(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; - - /* Peripheral Clock Enable Register */ - writel( 1 << AT91SAM9263_ID_PIOA | - 1 << AT91SAM9263_ID_PIOB | - 1 << AT91SAM9263_ID_PIOCDE | - 1 << AT91SAM9263_ID_TWI | - 1 << AT91SAM9263_ID_SPI0 | - 1 << AT91SAM9263_ID_LCDC | - 1 << AT91SAM9263_ID_UHP, + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; + + /* enable all clocks */ + writel((1 << ATMEL_ID_PIOA) | + (1 << ATMEL_ID_PIOB) | + (1 << ATMEL_ID_PIOCDE) | + (1 << ATMEL_ID_TWI) | + (1 << ATMEL_ID_SPI0) | +#ifdef CONFIG_LCD + (1 << ATMEL_ID_LCDC) | +#endif + (1 << ATMEL_ID_UHP), &pmc->pcer);
+ at91_seriald_hw_init(); + /* arch number of OTC570-Board */ gd->bd->bi_arch_number = MACH_TYPE_OTC570;
+ return 0; +} + +int board_init(void) +{ + /* initialize ET1100 Controller */ + otc570_ethercat_hw_init(); + /* adress of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND otc570_nand_hw_init(); #endif - otc570_ethercat_hw_init(); #ifdef CONFIG_HAS_DATAFLASH at91_spi0_hw_init(1 << 0); #endif diff --git a/boards.cfg b/boards.cfg index eccbb9c..77f3fc4 100644 --- a/boards.cfg +++ b/boards.cfg @@ -85,7 +85,8 @@ top9000eval_xe arm arm926ejs top9000 emk top9000su_xe arm arm926ejs top9000 emk at91 top9000:SU9000 meesc arm arm926ejs meesc esd at91 meesc:AT91SAM9263,SYS_USE_NANDFLASH meesc_dataflash arm arm926ejs meesc esd at91 meesc:AT91SAM9263,SYS_USE_DATAFLASH -otc570 arm arm926ejs - esd at91 +otc570 arm arm926ejs otc570 esd at91 otc570:AT91SAM9263,SYS_USE_NANDFLASH +otc570_dataflash arm arm926ejs otc570 esd at91 otc570:AT91SAM9263,SYS_USE_DATAFLASH pm9261 arm arm926ejs - ronetix at91 pm9263 arm arm926ejs - ronetix at91 da830evm arm arm926ejs da8xxevm davinci davinci diff --git a/include/configs/otc570.h b/include/configs/otc570.h index ca3bf26..9ecb2b0 100644 --- a/include/configs/otc570.h +++ b/include/configs/otc570.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2010 + * (C) Copyright 2010-2011 * Daniel Gorsulowski daniel.gorsulowski@esd.eu * esd electronic system design gmbh <www.esd.eu> * @@ -31,101 +31,119 @@ #ifndef __CONFIG_H #define __CONFIG_H
-/* Common stuff */ -#define CONFIG_OTC570 1 /* Board is esd OTC570 */ -#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ -#define CONFIG_AT91SAM9263 1 /* It's an AT91SAM9263 SoC */ +/* + * SoC must be defined first, before hardware.h is included. + * In this case SoC is defined in boards.cfg. + */ +#include <asm/hardware.h> + +/* + * Warning: changing CONFIG_SYS_TEXT_BASE requires + * adapting the initial boot program. + * Since the linker has to swallow that define, we must use a pure + * hex number here! + */ +#define CONFIG_SYS_TEXT_BASE 0x20002000 + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* 32.768 kHz crystal */ #define CONFIG_SYS_AT91_MAIN_CLOCK 16000000/* 16.0 MHz crystal */ #define CONFIG_SYS_HZ 1000 /* decrementer freq */ -#define CONFIG_DISPLAY_BOARDINFO 1 -#define CONFIG_DISPLAY_CPUINFO 1 /* display cpu info and speed */ -#define CONFIG_PREBOOT /* enable preboot variable */ -#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_INITRD_TAG 1 -#define CONFIG_SERIAL_TAG 1 -#define CONFIG_REVISION_TAG 1 -#undef CONFIG_USE_IRQ /* don't need IRQ/FIQ stuff */
+/* Misc CPU related */ #define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ - #define CONFIG_ARCH_CPU_INIT +#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f() */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_SERIAL_TAG +#define CONFIG_REVISION_TAG +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_MISC_INIT_R /* Call misc_init_r */ +#undef CONFIG_USE_IRQ /* don't need IRQ/FIQ stuff */ + +#define CONFIG_DISPLAY_BOARDINFO /* call checkboard() */ +#define CONFIG_DISPLAY_CPUINFO /* display cpu info and speed */ +#define CONFIG_PREBOOT /* enable preboot variable */
/* * Hardware drivers */ -#define CONFIG_AT91_GPIO 1 + +/* required until arch/arm/include/asm/arch-at91/at91sam9263.h is reworked */ +#define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP + +/* general purpose I/O */ +#define CONFIG_AT91_GPIO
/* Console output */ -#define CONFIG_ATMEL_USART 1 -#undef CONFIG_USART0 -#undef CONFIG_USART1 -#undef CONFIG_USART2 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200, 19200, 38400, 57600, 9600}
#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK 1 +#define CONFIG_ZERO_BOOTDELAY_CHECK
/* LCD */ -#define CONFIG_LCD 1 -#define LCD_BPP LCD_COLOR8 - +#define CONFIG_LCD #undef CONFIG_SPLASH_SCREEN
-#ifndef CONFIG_SPLASH_SCREEN -#define CONFIG_LCD_LOGO 1 -#define CONFIG_LCD_INFO 1 -#undef CONFIG_LCD_INFO_BELOW_LOGO -#endif /* CONFIG_SPLASH_SCREEN */ +#ifdef CONFIG_LCD +# define LCD_BPP LCD_COLOR8 + +# ifndef CONFIG_SPLASH_SCREEN +# define CONFIG_LCD_LOGO +# define CONFIG_LCD_INFO +# undef CONFIG_LCD_INFO_BELOW_LOGO +# endif /* CONFIG_SPLASH_SCREEN */
-#undef LCD_TEST_PATTERN -#define CONFIG_SYS_WHITE_ON_BLACK 1 -#define CONFIG_ATMEL_LCD 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 -#define CONFIG_OTC570_LCD_BASE 0x23E00000 /* LCD is in SDRAM */ -#define CONFIG_CMD_BMP 1 +# undef LCD_TEST_PATTERN +# define CONFIG_SYS_WHITE_ON_BLACK +# define CONFIG_ATMEL_LCD +# define CONFIG_SYS_CONSOLE_IS_IN_ENV +# define CONFIG_OTC570_LCD_BASE (CONFIG_SYS_SDRAM_BASE + 0x03fa5000) +# define CONFIG_CMD_BMP +#endif /* CONFIG_LCD */
/* RTC and I2C stuff */ -#define CONFIG_RTC_DS1338 1 +#define CONFIG_RTC_DS1338 #define CONFIG_SYS_I2C_RTC_ADDR 0x68 #undef CONFIG_HARD_I2C -#define CONFIG_SOFT_I2C 1 +#define CONFIG_SOFT_I2C #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 0x7F
#ifdef CONFIG_SOFT_I2C -#define CONFIG_I2C_CMD_TREE 1 -#define CONFIG_I2C_MULTI_BUS 1 +# define CONFIG_I2C_CMD_TREE +# define CONFIG_I2C_MULTI_BUS /* Configure data and clock pins for pio */ -#define I2C_INIT { \ +# define I2C_INIT { \ at91_set_pio_output(AT91_PIO_PORTB, 4, 0); \ at91_set_pio_output(AT91_PIO_PORTB, 5, 0); \ } -#define I2C_SOFT_DECLARATIONS +# define I2C_SOFT_DECLARATIONS /* Configure data pin as output */ -#define I2C_ACTIVE at91_set_pio_output(AT91_PIO_PORTB, 4, 0) +# define I2C_ACTIVE at91_set_pio_output(AT91_PIO_PORTB, 4, 0) /* Configure data pin as input */ -#define I2C_TRISTATE at91_set_pio_input(AT91_PIO_PORTB, 4, 0) +# define I2C_TRISTATE at91_set_pio_input(AT91_PIO_PORTB, 4, 0) /* Read data pin */ -#define I2C_READ at91_get_pio_value(AT91_PIO_PORTB, 4) +# define I2C_READ at91_get_pio_value(AT91_PIO_PORTB, 4) /* Set data pin */ -#define I2C_SDA(bit) at91_set_pio_value(AT91_PIO_PORTB, 4, bit) +# define I2C_SDA(bit) at91_set_pio_value(AT91_PIO_PORTB, 4, bit) /* Set clock pin */ -#define I2C_SCL(bit) at91_set_pio_value(AT91_PIO_PORTB, 5, bit) -#define I2C_DELAY udelay(2) /* 1/4 I2C clock duration */ +# define I2C_SCL(bit) at91_set_pio_value(AT91_PIO_PORTB, 5, bit) +# define I2C_DELAY udelay(2) /* 1/4 I2C clock duration */ #endif /* CONFIG_SOFT_I2C */
-#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK 1 - /* * BOOTP options */ -#define CONFIG_BOOTP_BOOTFILESIZE 1 -#define CONFIG_BOOTP_BOOTPATH 1 -#define CONFIG_BOOTP_GATEWAY 1 -#define CONFIG_BOOTP_HOSTNAME 1 +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME
/* * Command line configuration. @@ -135,99 +153,116 @@ #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_IMLS
-#define CONFIG_CMD_PING 1 -#define CONFIG_CMD_DHCP 1 -#define CONFIG_CMD_NAND 1 -#define CONFIG_CMD_USB 1 -#define CONFIG_CMD_I2C 1 -#define CONFIG_CMD_DATE 1 +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NAND +#define CONFIG_CMD_USB +#define CONFIG_CMD_I2C +#define CONFIG_CMD_DATE
/* LED */ -#define CONFIG_AT91_LED 1 +#define CONFIG_AT91_LED
-/* SDRAM */ -#define CONFIG_NR_DRAM_BANKS 1 -#define PHYS_SDRAM 0x20000000 +/* + * SDRAM: 1 bank, min 32, max 128 MB + * Initialized before u-boot gets started. + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE 0x20000000 /* ATMEL_BASE_CS1 */ +#define CONFIG_SYS_SDRAM_SIZE 0x04000000 + +#define CONFIG_SYS_MEMTEST_START (CONFIG_SYS_SDRAM_BASE + 0x00100000) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x01E00000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x00100000) + +/* + * Initial stack pointer: 4k - GENERATED_GBL_DATA_SIZE in internal SRAM, + * leaving the correct space for initial global data structure above + * that address while providing maximum stack area below. + */ +#define CONFIG_SYS_INIT_SP_ADDR \ + (ATMEL_BASE_SRAM0 + 0x1000 - GENERATED_GBL_DATA_SIZE)
/* DataFlash */ -#define CONFIG_ATMEL_DATAFLASH_SPI -#define CONFIG_HAS_DATAFLASH 1 -#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) -#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 -#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ -#define AT91_SPI_CLK 15000000 -#define DATAFLASH_TCSS (0x1a << 16) -#define DATAFLASH_TCHS (0x1 << 24) +#ifdef CONFIG_SYS_USE_DATAFLASH +# define CONFIG_ATMEL_DATAFLASH_SPI +# define CONFIG_HAS_DATAFLASH +# define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) +# define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 +# define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +# define AT91_SPI_CLK 15000000 +# define DATAFLASH_TCSS (0x1a << 16) +# define DATAFLASH_TCHS (0x1 << 24) +#endif
/* NOR flash is not populated, disable it */ -#define CONFIG_SYS_NO_FLASH 1 +#define CONFIG_SYS_NO_FLASH
/* NAND flash */ #ifdef CONFIG_CMD_NAND -#define CONFIG_NAND_ATMEL -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_DBW_8 1 -/* our ALE is AD21 */ -#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) -/* our CLE is AD22 */ -#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) -#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIO_PORTD, 15 -#define CONFIG_SYS_NAND_READY_PIN AT91_PIO_PORTA, 22 -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ +# define CONFIG_NAND_ATMEL +# define CONFIG_SYS_MAX_NAND_DEVICE 1 +# define CONFIG_SYS_NAND_BASE 0x40000000 /* ATMEL_BASE_CS3 */ +# define CONFIG_SYS_NAND_DBW_8 +# define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +# define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +# define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIO_PORTD, 15 +# define CONFIG_SYS_NAND_READY_PIN AT91_PIO_PORTA, 22 +# define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #endif
/* Ethernet */ -#define CONFIG_MACB 1 -#define CONFIG_RMII 1 -#define CONFIG_NET_MULTI 1 +#define CONFIG_MACB +#define CONFIG_RMII +#define CONFIG_NET_MULTI +#define CONFIG_FIT #define CONFIG_NET_RETRY_COUNT 20 #undef CONFIG_RESET_PHY_R
/* USB */ #define CONFIG_USB_ATMEL -#define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1 -#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_USB_OHCI_NEW +#define CONFIG_DOS_PARTITION +#define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 -#define CONFIG_USB_STORAGE 1 -#define CONFIG_CMD_FAT 1 - -#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ - -#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM -#define CONFIG_SYS_MEMTEST_END 0x23e00000 - -#define CONFIG_SYS_USE_DATAFLASH 1 -#undef CONFIG_SYS_USE_NANDFLASH +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_FAT
/* CAN */ -#define CONFIG_AT91_CAN 1 +#define CONFIG_AT91_CAN
/* hw-controller addresses */ -#define CONFIG_ET1100_BASE 0x70000000 +#define CONFIG_ET1100_BASE 0x70000000 /* ATMEL_BASE_CS6 */ + +#ifdef CONFIG_SYS_USE_DATAFLASH
/* bootstrap + u-boot + env in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_DATAFLASH 1 -#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ +# define CONFIG_ENV_IS_IN_DATAFLASH +# define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ 0x8400) -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ +# define CONFIG_ENV_OFFSET 0x4200 +# define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SIZE 0x4200 +# define CONFIG_ENV_SIZE 0x4200
-#define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } +#elif CONFIG_SYS_USE_NANDFLASH + +/* bootstrap + u-boot + env + linux in nandflash */ +# define CONFIG_ENV_IS_IN_NAND 1 +# define CONFIG_ENV_OFFSET 0xC0000 +# define CONFIG_ENV_SIZE 0x20000 + +#endif
#define CONFIG_SYS_PROMPT "=> " -#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_CBSIZE 512 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_LONGHELP 1 -#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING
/* * Size of malloc() pool @@ -238,7 +273,7 @@ #define CONFIG_STACKSIZE (32 * 1024) /* regular stack */
#ifdef CONFIG_USE_IRQ -#error CONFIG_USE_IRQ not supported +# error CONFIG_USE_IRQ not supported #endif
#endif
Daniel Gorsulowski
