[U-Boot] [PATCH] mmc: use pr_* log functions
Use pr_* log functions from Linux. They can be enabled/disabled via CONFIG_LOGLEVEL.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/mmc/mmc.c | 68 +++++++++++++++++++++++++++---------------------------- 1 file changed, 34 insertions(+), 34 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 255310a..3a2e3b3 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -213,8 +213,8 @@ static int mmc_select_mode(struct mmc *mmc, enum bus_mode mode) mmc->selected_mode = mode; mmc->tran_speed = mmc_mode2freq(mmc, mode); mmc->ddr_mode = mmc_is_mode_ddr(mode); - debug("selecting mode %s (freq : %d MHz)\n", mmc_mode_name(mode), - mmc->tran_speed / 1000000); + pr_debug("selecting mode %s (freq : %d MHz)\n", mmc_mode_name(mode), + mmc->tran_speed / 1000000); return 0; }
@@ -457,7 +457,7 @@ ulong mmc_bread(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt, }
if (mmc_set_blocklen(mmc, mmc->read_bl_len)) { - debug("%s: Failed to set blocklen\n", __func__); + pr_debug("%s: Failed to set blocklen\n", __func__); return 0; }
@@ -465,7 +465,7 @@ ulong mmc_bread(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt, cur = (blocks_todo > mmc->cfg->b_max) ? mmc->cfg->b_max : blocks_todo; if (mmc_read_blocks(mmc, dst, start, cur) != cur) { - debug("%s: Failed to read blocks\n", __func__); + pr_debug("%s: Failed to read blocks\n", __func__); return 0; } blocks_todo -= cur; @@ -900,11 +900,11 @@ static int mmc_boot_part_access_chk(struct mmc *mmc, unsigned int part_num) forbidden = MMC_CAP(MMC_HS_200);
if (MMC_CAP(mmc->selected_mode) & forbidden) { - debug("selected mode (%s) is forbidden for part %d\n", - mmc_mode_name(mmc->selected_mode), part_num); + pr_debug("selected mode (%s) is forbidden for part %d\n", + mmc_mode_name(mmc->selected_mode), part_num); change = true; } else if (mmc->selected_mode != mmc->best_mode) { - debug("selected mode is not optimal\n"); + pr_debug("selected mode is not optimal\n"); change = true; }
@@ -1427,7 +1427,7 @@ retry_ssr: mmc->ssr.erase_offset = eo * 1000; } } else { - debug("Invalid Allocation Unit Size.\n"); + pr_debug("Invalid Allocation Unit Size.\n"); }
return 0; @@ -1532,18 +1532,18 @@ void mmc_dump_capabilities(const char *text, uint caps) { enum bus_mode mode;
- printf("%s: widths [", text); + pr_debug("%s: widths [", text); if (caps & MMC_MODE_8BIT) - printf("8, "); + pr_debug("8, "); if (caps & MMC_MODE_4BIT) - printf("4, "); + pr_debug("4, "); if (caps & MMC_MODE_1BIT) - printf("1, "); - printf("\b\b] modes ["); + pr_debug("1, "); + pr_debug("\b\b] modes ["); for (mode = MMC_LEGACY; mode < MMC_MODES_END; mode++) if (MMC_CAP(mode) & caps) - printf("%s, ", mmc_mode_name(mode)); - printf("\b\b]\n"); + pr_debug("%s, ", mmc_mode_name(mode)); + pr_debug("\b\b]\n"); } #endif
@@ -1577,7 +1577,7 @@ static int mmc_set_signal_voltage(struct mmc *mmc, uint signal_voltage) mmc->signal_voltage = signal_voltage; err = mmc_set_ios(mmc); if (err) - debug("unable to set voltage (err %d)\n", err); + pr_debug("unable to set voltage (err %d)\n", err);
return err; } @@ -1660,10 +1660,10 @@ static int sd_select_mode_and_width(struct mmc *mmc, uint card_caps)
for (w = widths; w < widths + ARRAY_SIZE(widths); w++) { if (*w & caps & mwt->widths) { - debug("trying mode %s width %d (at %d MHz)\n", - mmc_mode_name(mwt->mode), - bus_width(*w), - mmc_mode2freq(mmc, mwt->mode) / 1000000); + pr_debug("trying mode %s width %d (at %d MHz)\n", + mmc_mode_name(mwt->mode), + bus_width(*w), + mmc_mode2freq(mmc, mwt->mode) / 1000000);
/* configure the bus width (card + host) */ err = sd_select_bus_width(mmc, bus_width(*w)); @@ -1686,7 +1686,7 @@ static int sd_select_mode_and_width(struct mmc *mmc, uint card_caps) err = mmc_execute_tuning(mmc, mwt->tuning); if (err) { - debug("tuning failed\n"); + pr_debug("tuning failed\n"); goto error; } } @@ -1708,7 +1708,7 @@ error: } }
- printf("unable to select a mode\n"); + pr_err("unable to select a mode\n"); return -ENOTSUPP; }
@@ -1860,7 +1860,7 @@ static int mmc_select_mode_and_width(struct mmc *mmc, uint card_caps) return 0;
if (!mmc->ext_csd) { - debug("No ext_csd found!\n"); /* this should enver happen */ + pr_debug("No ext_csd found!\n"); /* this should enver happen */ return -ENOTSUPP; }
@@ -1870,10 +1870,10 @@ static int mmc_select_mode_and_width(struct mmc *mmc, uint card_caps) for_each_supported_width(card_caps & mwt->widths, mmc_is_mode_ddr(mwt->mode), ecbw) { enum mmc_voltage old_voltage; - debug("trying mode %s width %d (at %d MHz)\n", - mmc_mode_name(mwt->mode), - bus_width(ecbw->cap), - mmc_mode2freq(mmc, mwt->mode) / 1000000); + pr_debug("trying mode %s width %d (at %d MHz)\n", + mmc_mode_name(mwt->mode), + bus_width(ecbw->cap), + mmc_mode2freq(mmc, mwt->mode) / 1000000); old_voltage = mmc->signal_voltage; err = mmc_set_lowest_voltage(mmc, mwt->mode, MMC_ALL_SIGNAL_VOLTAGE); @@ -1914,7 +1914,7 @@ static int mmc_select_mode_and_width(struct mmc *mmc, uint card_caps) if (mwt->tuning) { err = mmc_execute_tuning(mmc, mwt->tuning); if (err) { - debug("tuning failed\n"); + pr_debug("tuning failed\n"); goto error; } } @@ -2396,12 +2396,12 @@ static int mmc_power_init(struct mmc *mmc) ret = device_get_supply_regulator(mmc->dev, "vmmc-supply", &mmc->vmmc_supply); if (ret) - debug("%s: No vmmc supply\n", mmc->dev->name); + pr_debug("%s: No vmmc supply\n", mmc->dev->name);
ret = device_get_supply_regulator(mmc->dev, "vqmmc-supply", &mmc->vqmmc_supply); if (ret) - debug("%s: No vqmmc supply\n", mmc->dev->name); + pr_debug("%s: No vqmmc supply\n", mmc->dev->name); #endif #else /* !CONFIG_DM_MMC */ /* @@ -2457,7 +2457,7 @@ static int mmc_power_off(struct mmc *mmc) int ret = regulator_set_enable(mmc->vmmc_supply, false);
if (ret) { - debug("Error disabling VMMC supply\n"); + pr_debug("Error disabling VMMC supply\n"); return ret; } } @@ -2505,7 +2505,7 @@ int mmc_start_init(struct mmc *mmc) if (no_card) { mmc->has_init = 0; #if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) - printf("MMC: no card present\n"); + pr_err("MMC: no card present\n"); #endif return -ENOMEDIUM; } @@ -2532,7 +2532,7 @@ int mmc_start_init(struct mmc *mmc) * to use the UHS modes, because we wouldn't be able to * recover from an error during the UHS initialization. */ - debug("Unable to do a full power cycle. Disabling the UHS modes for safety\n"); + pr_debug("Unable to do a full power cycle. Disabling the UHS modes for safety\n"); uhs_en = false; mmc->host_caps &= ~UHS_CAPS; err = mmc_power_on(mmc); @@ -2629,7 +2629,7 @@ int mmc_init(struct mmc *mmc) if (!err) err = mmc_complete_init(mmc); if (err) - printf("%s: %d, time %lu\n", __func__, err, get_timer(start)); + pr_info("%s: %d, time %lu\n", __func__, err, get_timer(start));
return err; }
On Sun, 28 Jan 2018 19:11:42 +0900 Masahiro Yamada yamada.masahiro@socionext.com wrote:
- pr_debug("selecting mode %s (freq : %d MHz)\n",
return 0;mmc->tran_speed / 1000000);
return 0; }pr_debug("%s: Failed to set blocklen\n", __func__);
__func__);
%d\n",
%d\n",
change = true; }pr_debug("selected mode is not optimal\n");
- pr_debug("%s: widths [", text); if (caps & MMC_MODE_8BIT)
printf("8, ");
if (caps & MMC_MODE_4BIT)pr_debug("8, ");
printf("4, ");
if (caps & MMC_MODE_1BIT)pr_debug("4, ");
printf("1, ");
pr_debug("1, ");
- pr_debug("\b\b] modes ["); for (mode = MMC_LEGACY; mode < MMC_MODES_END; mode++) if (MMC_CAP(mode) & caps)
- pr_debug("\b\b]\n");
} #endif
return err;
} @@ -1660,10 +1660,10 @@ static int sd_select_mode_and_width(struct mmc *mmc, uint card_caps) for (w = widths; w < widths + ARRAY_SIZE(widths); w++) { if (*w & caps & mwt->widths) {
%d MHz)\n",
bus_width(*w),
mmc_mode2freq(mmc,
(at %d MHz)\n",
bus_width(*w),
mmc_mode2freq(mmc,
mwt->mode) / 1000000); /* configure the bus width (card + host) */ err = sd_select_bus_width(mmc, bus_width(*w)); @@ -1686,7 +1686,7 @@ static int sd_select_mode_and_width(struct mmc *mmc, uint card_caps) err = mmc_execute_tuning(mmc, mwt->tuning); if (err) {
debug("tuning
failed\n");
pr_debug("tuning
- pr_err("unable to select a mode\n"); return -ENOTSUPP;
happen */
MHz)\n",
1000000);
MHz)\n",
#endif #else /* !CONFIG_DM_MMC */ /* @@ -2457,7 +2457,7 @@ static int mmc_power_off(struct mmc *mmc) int ret = regulator_set_enable(mmc->vmmc_supply, false); if (ret) {
} }pr_debug("Error disabling VMMC supply\n"); return ret;
get_timer(start));
get_timer(start)); return err; }
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- pr_debug("selecting mode %s (freq : %d MHz)\n", mmc_mode_name(m
Applied to u-boot-mmc. Thanks!
- pr_debug("selecting mode %s (freq : %d MHz)\n", mmc_mode_name(mode),
} blocks_todo -= cur;pr_debug("%s: Failed to read blocks\n", __func__); return 0;
change = true; } else if (mmc->selected_mode != mmc->best_mode) {mmc_mode_name(mmc->selected_mode), part_num);
printf("8, ");
printf("4, ");
printf("1, ");
pr_debug("1, ");
} #endif
return err;
bus_width(*w),
bus_width(*w),
mmc_mode2freq(mmc, mwt->mode) / 1000000); /* configure the bus width (card + host) */ err = sd_select_bus_width(mmc, bus_width(*w));
return -ENOTSUPP; }pr_debug("No ext_csd found!\n"); /* this should enver happen */
if (ret) {
uhs_en = false; mmc->host_caps &= ~UHS_CAPS; err = mmc_power_on(mmc);pr_debug("Unable to do a full power cycle. Disabling the UHS modes for safety\n");
return err;
Jaehoon Chung
Lukasz Majewski
Masahiro Yamada
