[U-Boot] [PATCH 1/2] ARM: kirkwood: remove automatic I2C config if DM_I2C is enabled
The mach/config.h file would helpfully define CONFIG_SYS_I2C and CONFIG_SYS_I2C_MVTWSI if CONFIG_CMD_I2C was defined by the board. This conflicts with the way DM_I2C works. As a transitional measure don't automatically define these if CONFIG_DM_I2C is defined. It should be possible to remove this once all kirkwood boards are migrated to DM.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
arch/arm/mach-kirkwood/include/mach/config.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h index 98639114dbdd..3482944c11de 100644 --- a/arch/arm/mach-kirkwood/include/mach/config.h +++ b/arch/arm/mach-kirkwood/include/mach/config.h @@ -116,7 +116,7 @@ /* * I2C related stuff */ -#ifdef CONFIG_CMD_I2C +#if defined(CONFIG_CMD_I2C) && !defined(CONFIG_DM_I2C) #ifndef CONFIG_SYS_I2C_SOFT #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MVTWSI
This is a series of line cards for Allied Telesis's SBx8100 chassis switch. The CPU block is common to the SBx81GS24a, SBx81XS6, SBx81XS16 and SBx81GT40 cards collectively referred to as SBx81LIFKW in u-boot.
Signed-off-by: Chris Packham judge.packham@gmail.com --- This is the board I've been using for testing the device tree support for kirkwood. The Ethernet arrangement is a bit complicated and doesn't currently work on u-boot#master but I can test SPI and I2C.
arch/arm/dts/kirkwood-atl-sbx81lifkw.dts | 133 ++++++++++++++ arch/arm/mach-kirkwood/Kconfig | 4 + board/alliedtelesis/SBx81LIFKW/Kconfig | 12 ++ board/alliedtelesis/SBx81LIFKW/MAINTAINERS | 7 + board/alliedtelesis/SBx81LIFKW/Makefile | 8 + board/alliedtelesis/SBx81LIFKW/kwbimage.cfg | 47 +++++ board/alliedtelesis/SBx81LIFKW/platform.S | 108 +++++++++++ board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c | 192 ++++++++++++++++++++ configs/SBx81LIFKW_defconfig | 32 ++++ include/configs/SBx81LIFKW.h | 123 +++++++++++++ 10 files changed, 666 insertions(+) create mode 100644 arch/arm/dts/kirkwood-atl-sbx81lifkw.dts create mode 100644 board/alliedtelesis/SBx81LIFKW/Kconfig create mode 100644 board/alliedtelesis/SBx81LIFKW/MAINTAINERS create mode 100644 board/alliedtelesis/SBx81LIFKW/Makefile create mode 100644 board/alliedtelesis/SBx81LIFKW/kwbimage.cfg create mode 100644 board/alliedtelesis/SBx81LIFKW/platform.S create mode 100644 board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c create mode 100644 configs/SBx81LIFKW_defconfig create mode 100644 include/configs/SBx81LIFKW.h
diff --git a/arch/arm/dts/kirkwood-atl-sbx81lifkw.dts b/arch/arm/dts/kirkwood-atl-sbx81lifkw.dts new file mode 100644 index 000000000000..e5b1efa1415a --- /dev/null +++ b/arch/arm/dts/kirkwood-atl-sbx81lifkw.dts @@ -0,0 +1,133 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "kirkwood.dtsi" +#include "kirkwood-6281.dtsi" + +/ { + model = "Allied Telesis SBx81LIFKW Board"; + compatible = "atl,SBx81LIFKW", "marvell,kirkwood-88f6281", + "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x08000000>; /* 128 MB */ + }; + + chosen { + bootargs = "console=ttyS0,115200n8 earlyprintk"; + stdout-path = &uart0; + }; + + aliases { + ethernet0 = ð0; + i2c0 = &i2c0; + spi0 = &spi0; + }; + + dsa { + compatible = "marvell,dsa"; + #address-cells = <2>; + #size-cells = <0>; + dsa,ethernet = <ð0>; + dsa,mii-bus = <&mdio>; + status = "okay"; + + switch@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1 0>; + + port@0 { + reg = <0>; + label = "internal0"; + }; + port@1 { + reg = <1>; + label = "internal1"; + }; + port@8 { + reg = <8>; + label = "internal8"; + phy-mode = "rgmii-id"; + fixed-link { + speed = <1000>; + full-duplex; + }; + }; + port@9 { + reg = <9>; + label = "internal9"; + phy-mode = "rgmii-id"; + fixed-link { + speed = <1000>; + full-duplex; + }; + }; + port@10 { + reg = <10>; + label = "cpu"; + }; + }; + }; +}; + +&spi0 { + status = "okay"; + + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,m25p128", "jedec,spi-nor", "spi-flash"; + reg = <0>; + spi-max-frequency = <50000000>; + mode = <0>; + + partition@u-boot { + reg = <0x00000000 0x00c00000>; + label = "u-boot"; + }; + partition@u-boot-env { + reg = <0x00c00000 0x00040000>; + label = "u-boot-env"; + }; + partition@unused { + reg = <0x00100000 0x00f00000>; + label = "unused"; + }; + }; +}; + +&i2c0 { + status = "okay"; + + eeprom@52 { + compatible = "atmel,24c04"; + reg = <0x52>; + }; +}; + +&uart0 { + status = "okay"; +}; + +&mdio { + status = "okay"; +}; + +ð0 { + status = "okay"; + + ethernet0-port@0 { + speed = <1000>; + duplex = <1>; + }; +}; + +&pciec { + status = "okay"; +}; + +&pcie0 { + status = "okay"; +}; diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index 2dd107a8b3bf..5a5a63cea719 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -59,6 +59,9 @@ config TARGET_NAS220 config TARGET_NSA310S bool "Zyxel NSA310S"
+config TARGET_SBx81LIFKW + bool "Allied Telesis SBx81GS24/SBx81GT40/SBx81XS6/SBx81XS16" + endchoice
config SYS_SOC @@ -81,5 +84,6 @@ source "board/Seagate/dockstar/Kconfig" source "board/Seagate/goflexhome/Kconfig" source "board/Seagate/nas220/Kconfig" source "board/zyxel/nsa310s/Kconfig" +source "board/alliedtelesis/SBx81LIFKW/Kconfig"
endif diff --git a/board/alliedtelesis/SBx81LIFKW/Kconfig b/board/alliedtelesis/SBx81LIFKW/Kconfig new file mode 100644 index 000000000000..5c2609b7f464 --- /dev/null +++ b/board/alliedtelesis/SBx81LIFKW/Kconfig @@ -0,0 +1,12 @@ +if TARGET_SBx81LIFKW + +config SYS_BOARD + default "SBx81LIFKW" + +config SYS_VENDOR + default "alliedtelesis" + +config SYS_CONFIG_NAME + default "SBx81LIFKW" + +endif diff --git a/board/alliedtelesis/SBx81LIFKW/MAINTAINERS b/board/alliedtelesis/SBx81LIFKW/MAINTAINERS new file mode 100644 index 000000000000..31ccec0e9b7e --- /dev/null +++ b/board/alliedtelesis/SBx81LIFKW/MAINTAINERS @@ -0,0 +1,7 @@ +SBx81LIFKW BOARD +M: Chris Packham chris.packham@alliedtelesis.co.nz +S: Maintained +F: board/alliedtelesis/SBx81LIFKW/ +F: include/configs/SBx81LIFKW +F: configs/SBx81LIFKW_defconfig +F: arch/arm/dts/kirkwood-atl-sbx81lifkw.dts diff --git a/board/alliedtelesis/SBx81LIFKW/Makefile b/board/alliedtelesis/SBx81LIFKW/Makefile new file mode 100644 index 000000000000..2a5a33fa0807 --- /dev/null +++ b/board/alliedtelesis/SBx81LIFKW/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2010, 2018 +# Allied Telesis <www.alliedtelesis.com> +# + +obj-y += sbx81lifkw.o +obj-y += platform.o diff --git a/board/alliedtelesis/SBx81LIFKW/kwbimage.cfg b/board/alliedtelesis/SBx81LIFKW/kwbimage.cfg new file mode 100644 index 000000000000..9726f15e28b0 --- /dev/null +++ b/board/alliedtelesis/SBx81LIFKW/kwbimage.cfg @@ -0,0 +1,47 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2018 Allied Telesis +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM spi # Boot from SPI flash + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed +DATA 0xffd100e0 0x1b1b1b1b +DATA 0xffd20134 0xffffffff +DATA 0xffd20138 0x009fffff +DATA 0xffd20154 0x00000000 +DATA 0xffd2014c 0x00000000 +DATA 0xffd20148 0x00000001 + +# Dram initalization for 1 x x16 +# DDR II Micron part number MT47H64M16HR-3 +# MClk 333MHz, Size 128MB, ECC disable +# +DATA 0xffd01400 0x43000618 +DATA 0xffd01404 0x35143000 +DATA 0xffd01408 0x11012227 +DATA 0xffd0140c 0x00000819 +DATA 0xffd01410 0x0000000d +DATA 0xffd01414 0x00000000 +DATA 0xffd01418 0x00000000 +DATA 0xffd0141c 0x00000632 +DATA 0xffd01420 0x00000040 +DATA 0xffd01424 0x0000f07f +DATA 0xffd01500 0x00000000 # SDRAM CS[0] Base address at 0x00000000 +DATA 0xffd01504 0x07FFFFF1 # SDRAM CS[0] Size 128MiB +DATA 0xffd01508 0x10000000 +DATA 0xffd0150c 0x00FFFFF4 # SDRAM CS[1] Size, window disabled +DATA 0xffd01514 0x00FFFFF8 # SDRAM CS[2] Size, window disabled +DATA 0xffd0151c 0x00FFFFFC # SDRAM CS[3] Size, window disabled +DATA 0xffd01494 0x00030000 +DATA 0xffd01498 0x00000000 +DATA 0xffd0149c 0x0000e803 +DATA 0xffd01480 0x00000001 + +# End of Header extension +DATA 0x0 0x0 diff --git a/board/alliedtelesis/SBx81LIFKW/platform.S b/board/alliedtelesis/SBx81LIFKW/platform.S new file mode 100644 index 000000000000..44ce603696af --- /dev/null +++ b/board/alliedtelesis/SBx81LIFKW/platform.S @@ -0,0 +1,108 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2010 + * Allied Telesis <www.alliedtelesis.com> + */ + +/* based (loosley) on Marvell's board/mv_feroceon/mv_kw/platform.S */ + +#include <config.h> + +platform_lowlevel_init_data: + /* AHB to Mbus Bridge + * Change CPU reg base to 0xF1000000 + * These *MUST* be first, and it hits + * both potential address to be safe + */ + .long 0xD0020080, KW_REGS_PHY_BASE + .long 0xF1020080, KW_REGS_PHY_BASE + + /* Configure RGMII-0 interface pad voltage to 1.8V */ + .long KW_REGS_PHY_BASE + 0x100E0, 0x1B1B1B1B + + .long KW_REGS_PHY_BASE + 0x20134, 0xffffffff + .long KW_REGS_PHY_BASE + 0x20138, 0x009fffff + .long KW_REGS_PHY_BASE + 0x20154, 0x00000000 + .long KW_REGS_PHY_BASE + 0x2014c, 0x00000000 + .long KW_REGS_PHY_BASE + 0x20148, 0x00000001 + + /* Dram initalization for 1 x x16 + * DDR II Micron part number MT47H64M16HR-3 + * MClk 333MHz, Size 128MB, ECC disable + */ + .long KW_REGS_PHY_BASE + 0x01400, 0x43000618 /* DDR Configuration register */ + .long KW_REGS_PHY_BASE + 0x01404, 0x35143000 /* DDR Controller Control Low */ + .long KW_REGS_PHY_BASE + 0x01408, 0x11012227 /* DDR Timing (Low) (active cycles value +1) */ + .long KW_REGS_PHY_BASE + 0x0140C, 0x00000819 /* DDR Timing (High) */ + .long KW_REGS_PHY_BASE + 0x01410, 0x0000000d /* DDR Address Control */ + .long KW_REGS_PHY_BASE + 0x01414, 0x00000000 /* DDR Open Pages Control */ + .long KW_REGS_PHY_BASE + 0x01418, 0x00000000 /* DDR Operation */ + .long KW_REGS_PHY_BASE + 0x0141C, 0x00000632 /* DDR Mode */ + .long KW_REGS_PHY_BASE + 0x01420, 0x00000040 /* DDR Extended Mode */ + .long KW_REGS_PHY_BASE + 0x01424, 0x0000f07f /* DDR Controller Control High */ + .long KW_REGS_PHY_BASE + 0x01428, 0x00063300 /* DDR2 ODT Read Timing (default values) */ + .long KW_REGS_PHY_BASE + 0x0147C, 0x00006330 /* DDR2 ODT Write Timing (default values) */ + + .long KW_REGS_PHY_BASE + 0x01500, 0x00000000 /* SDRAM CS[0] Base address at 0x00000000 */ + .long KW_REGS_PHY_BASE + 0x01504, 0x07FFFFF1 /* SDRAM CS[0] Size 128MiB */ + .long KW_REGS_PHY_BASE + 0x01508, 0x10000000 /* SDRAM CS[1] Base address */ + .long KW_REGS_PHY_BASE + 0x0150C, 0x00FFFFF4 /* SDRAM CS[1] Size, window disabled */ + .long KW_REGS_PHY_BASE + 0x01510, 0x20000000 /* SDRAM CS[2] Base address */ + .long KW_REGS_PHY_BASE + 0x01514, 0x00FFFFF8 /* SDRAM CS[2] Size, window disabled */ + .long KW_REGS_PHY_BASE + 0x01518, 0x30000000 /* SDRAM CS[3] Base address */ + .long KW_REGS_PHY_BASE + 0x0151C, 0x00FFFFFC /* SDRAM CS[3] Size, window disabled */ + + .long KW_REGS_PHY_BASE + 0x01494, 0x00030000 /* DDR ODT Control (Low) */ + .long KW_REGS_PHY_BASE + 0x01498, 0x00000000 /* DDR ODT Control (High) */ + .long KW_REGS_PHY_BASE + 0x0149C, 0x0000e803 /* CPU ODT Control */ + + .long KW_REGS_PHY_BASE + 0x01480, 0x00000001 /* DDR Initialization Control */ + + /* End of Header extension */ + .long 0x0, 0x0 + +.globl lowlevel_init + +/************************************************/ +/* lowlevel_init * +/************************************************/ + +lowlevel_init: + /* change CPU registers according to platform spec */ + adr r2, platform_lowlevel_init_data + b check_next + +reg_write: + /* TODO: This does not yet cater for BigEndian (BE) systems */ + str r1, [r0] + add r2, #8 +check_next: + ldr r0, [r2] + ldr r1, [r2, #4] + cmp r0, #0x0 + bne reg_write + + /* Change L2 cache to exist */ + ldr r1, =(KW_REGS_PHY_BASE + 0x20128) + ldr r2, [r1] + orr r2, r2, #0x18 + str r2, [r1] + + /* Read operation to make sure the L2 bit is set */ + ldr r2, [r1] + + /* invalidate L2 cache */ + mov r0, #0 + mcr p15, 1, r0, c15, c11, 0 + +#if defined(CONFIG_SPI_FLASH) + /* configure the Prescale of SPI clk Tclk = 166MHz */ + ldr r1, =(KW_REGS_PHY_BASE + 0x10604) + ldr r3, [r1] + and r3, r3, #~0x1f + orr r3, r3, #0x15 + str r3, [r1] +#endif + +done: + mov pc, lr diff --git a/board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c b/board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c new file mode 100644 index 000000000000..c2fd6304151d --- /dev/null +++ b/board/alliedtelesis/SBx81LIFKW/sbx81lifkw.c @@ -0,0 +1,192 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2010, 2018 + * Allied Telesis <www.alliedtelesis.com> + */ + +#include <common.h> +#include <linux/io.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <asm/arch/mpp.h> +#include <asm/arch/gpio.h> + +/* Note: GPIO differences between specific boards + * + * We're trying to avoid having multiple build targets for all the Kirkwood + * based boards one area where things tend to differ is GPIO usage. For the + * most part the GPIOs driven by the bootloader are similar enough in function + * that there is no harm in driving them. + * + * XZ4 XS6 XS16 GS24A GT40 GP24A GT24A + * GPIO39 - INT(<) NC MUX_RST_N(>) NC POE_DIS_N(>) NC + */ + +#define SBX81LIFKW_OE_LOW ~(BIT(31) | BIT(30) | BIT(28) | BIT(27) | \ + BIT(18) | BIT(17) | BIT(13) | BIT(12) | \ + BIT(10)) +#define SBX81LIFKW_OE_HIGH ~(BIT(0) | BIT(1) | BIT(7)) +#define SBX81LIFKW_OE_VAL_LOW (BIT(31) | BIT(30) | BIT(28) | BIT(27)) +#define SBX81LIFKW_OE_VAL_HIGH (BIT(0) | BIT(1)) + +#define MV88E6097_RESET 27 + +DECLARE_GLOBAL_DATA_PTR; + +struct led { + u32 reg; + u32 value; + u32 mask; +}; + +struct led amber_solid = { + MVEBU_GPIO0_BASE, + BIT(10), + BIT(18) | BIT(10) +}; + +struct led green_solid = { + MVEBU_GPIO0_BASE, + BIT(18) | BIT(10), + BIT(18) | BIT(10) +}; + +struct led amber_flash = { + MVEBU_GPIO0_BASE, + 0, + BIT(18) | BIT(10) +}; + +struct led green_flash = { + MVEBU_GPIO0_BASE, + BIT(18), + BIT(18) | BIT(10) +}; + +static void status_led_set(struct led *led) +{ + u32 val; + + val = readl(led->reg); + val &= ~led->mask; + val |= led->value; + writel(val, led->reg); +} + +int board_early_init_f(void) +{ + /* + * default gpio configuration + * There are maximum 64 gpios controlled through 2 sets of registers + * the below configuration configures mainly initial LED status + */ + mvebu_config_gpio(SBX81LIFKW_OE_VAL_LOW, + SBX81LIFKW_OE_VAL_HIGH, + SBX81LIFKW_OE_LOW, SBX81LIFKW_OE_HIGH); + + /* Multi-Purpose Pins Functionality configuration */ + static const u32 kwmpp_config[] = { + MPP0_SPI_SCn, + MPP1_SPI_MOSI, + MPP2_SPI_SCK, + MPP3_SPI_MISO, + MPP4_UART0_RXD, + MPP5_UART0_TXD, + MPP6_SYSRST_OUTn, + MPP7_PEX_RST_OUTn, + MPP8_TW_SDA, + MPP9_TW_SCK, + MPP10_GPO, + MPP11_GPIO, + MPP12_GPO, + MPP13_GPIO, + MPP14_GPIO, + MPP15_UART0_RTS, + MPP16_UART0_CTS, + MPP17_GPIO, + MPP18_GPO, + MPP19_GPO, + MPP20_GPIO, + MPP21_GPIO, + MPP22_GPIO, + MPP23_GPIO, + MPP24_GPIO, + MPP25_GPIO, + MPP26_GPIO, + MPP27_GPIO, + MPP28_GPIO, + MPP29_GPIO, + MPP30_GPIO, + MPP31_GPIO, + MPP32_GPIO, + MPP33_GPIO, + MPP34_GPIO, + MPP35_GPIO, + MPP36_GPIO, + MPP37_GPIO, + MPP38_GPIO, + MPP39_GPIO, + MPP40_GPIO, + MPP41_GPIO, + MPP42_GPIO, + MPP43_GPIO, + MPP44_GPIO, + MPP45_GPIO, + MPP46_GPIO, + MPP47_GPIO, + MPP48_GPIO, + MPP49_GPIO, + 0 + }; + + kirkwood_mpp_conf(kwmpp_config, NULL); + return 0; +} + +int board_init(void) +{ + /* Power-down unused subsystems. The required + * subsystems are: + * + * GE0 b0 + * PEX0 PHY b1 + * PEX0.0 b2 + * TSU b5 + * SDRAM b6 + * RUNIT b7 + */ + writel((BIT(0) | BIT(1) | BIT(2) | + BIT(5) | BIT(6) | BIT(7)), + KW_CPU_REG_BASE + 0x1c); + + /* address of boot parameters */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + status_led_set(&amber_solid); + + return 0; +} + +#ifdef CONFIG_MV88E61XX_SWITCH +/* Configure and enable Switch and PHY */ +void reset_phy(void) +{ + /* Ensure the 88e6097 gets at least 10ms Reset + */ + kw_gpio_set_value(MV88E6097_RESET, 0); + mdelay(20); + kw_gpio_set_value(MV88E6097_RESET, 1); + mdelay(20); +} +#endif + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ + status_led_set(&green_flash); + + return 0; +} +#endif diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig new file mode 100644 index 000000000000..01bbbfcc2231 --- /dev/null +++ b/configs/SBx81LIFKW_defconfig @@ -0,0 +1,32 @@ +CONFIG_ARM=y +CONFIG_KIRKWOOD=y +CONFIG_SYS_TEXT_BASE=0x00600000 +CONFIG_TARGET_SBx81LIFKW=y +CONFIG_IDENT_STRING="\nSBx81LIFKW" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-atl-sbx81lifkw" +# CONFIG_SYS_MALLOC_F is not set +CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y +CONFIG_SILENT_U_BOOT_ONLY=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_SF=y +CONFIG_CMD_DHCP=y +CONFIG_BOOTP_NTPSERVER=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_DM=y +CONFIG_DM_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +# CONFIG_MMC is not set +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI=y +CONFIG_KIRKWOOD_SPI=y diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h new file mode 100644 index 000000000000..ea85c9ee7716 --- /dev/null +++ b/include/configs/SBx81LIFKW.h @@ -0,0 +1,123 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2016 Allied Telesis <www.alliedtelesis.co.nz> + */ + +#ifndef _CONFIG_SBX81LIFKW_H +#define _CONFIG_SBX81LIFKW_H + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ +#define CONFIG_KW88F6281 1 /* SOC Name */ +#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg +#define CONFIG_BUILD_TARGET "u-boot.kwb" + +/* additions for new ARM relocation support */ +#define CONFIG_SYS_SDRAM_BASE 0x00000000 + +#define CONFIG_MD5 /* get_random_hex on krikwood needs MD5 support */ +#define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ +#define CONFIG_KIRKWOOD_PCIE_INIT /* Enable PCIE Port0 */ +#define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ +#define CONFIG_KIRKWOOD_GPIO 1 + +#define CONFIG_MISC_INIT_R /* call misc_init_r */ + +/* + * NS16550 Configuration + */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK CONFIG_SYS_TCLK +#define CONFIG_SYS_NS16550_COM1 KW_UART0_BASE + +/* + * Serial Port configuration + * The following definitions let you select what serial you want to use + * for your console driver. + */ + +#define CONFIG_CONS_INDEX 1 /*Console on UART0 */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_INITRD_TAG 1 /* enable INITRD tag */ +#define CONFIG_SETUP_MEMORY_TAGS 1 /* enable memory tag */ + +#define MTDPARTS_DEFAULT "mtdparts=spi0.0:768K(boot)ro,256K(boot-env),14M(user),1M(errlog)" +#define MTDPARTS_MTDOOPS "errlog" +#define CONFIG_DOS_PARTITION + +/* + * Environment variables configurations + */ +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 20000000 /* 20Mhz */ +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ +#define CONFIG_ENV_SIZE 0x02000 +#define CONFIG_ENV_OFFSET 0xc0000 /* env starts here - 768K */ + +/* + * U-Boot bootcode configuration + */ + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for monitor */ +#define CONFIG_SYS_MALLOC_LEN (4 << 20) /* Reserve 4.0 MB for malloc */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Mem map for Linux*/ + +/* size in bytes reserved for initial data */ + +#include <asm/arch/config.h> +/* There is no PHY directly connected so don't ask it for link status */ +#undef CONFIG_SYS_FAULT_ECHO_LINK_DOWN + +/* + * Other required minimal configurations + */ +#define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ +#define CONFIG_NR_DRAM_BANKS 4 +#define CONFIG_SYS_MEMTEST_START 0x00400000 /* 4M */ +#define CONFIG_SYS_MEMTEST_END 0x007fffff /*(_8M -1) */ +#define CONFIG_SYS_RESET_ADDRESS 0xffff0000 /* Rst Vector Adr */ + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_NETCONSOLE /* include NetConsole support */ +#define CONFIG_NET_MULTI /* specify more that one ports available */ +#define CONFIG_MII /* expose smi over miiphy interface */ +#define CONFIG_PHYLIB +#define CONFIG_MVGBE /* Enable kirkwood Gbe Controller Driver */ +#define CONFIG_MVGBE_PORTS {1, 0} /* enable a single port */ +#define CONFIG_PHY_BASE_ADR 0x01 +#define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ +#define CONFIG_RESET_PHY_R /* use reset_phy() to init switch */ +#define CONFIG_MV88E61XX_SWITCH /* Enable MV88E61XX switch driver */ +#define CONFIG_MV88E61XX_PHY_PORTS 0x303 /* Pt0,1,8,9 */ +#define CONFIG_MV88E61XX_CPU_PORT 10 /* 10(CPU) */ +#endif /* CONFIG_CMD_NET */ + +/* + * Time settings + */ +#define CONFIG_RTC_MV + +#define CONFIG_SYS_LOAD_ADDR 0x1000000 /* default location for tftp and bootm */ + +#endif /* _CONFIG_SBX81LIFKW_H */
Hi Chris,
- model = "Allied Telesis SBx81LIFKW Board";
- compatible = "atl,SBx81LIFKW", "marvell,kirkwood-88f6281",
"marvell,kirkwood";
- memory {
- chosen {
- aliases {
ethernet0 = ð0;
i2c0 = &i2c0;
spi0 = &spi0;
- dsa {
#size-cells = <0>;
status = "okay";
switch@0 {
#size-cells = <0>;
reg = <1 0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
port@8 {
reg = <8>;
fixed-link {
speed = <1000>;
full-duplex;
port@9 {
reg = <9>;
fixed-link {
speed = <1000>;
full-duplex;
port@10 {
reg = <10>;
label = "cpu";
+&spi0 {
- status = "okay";
- flash@0 {
#size-cells = <1>;
reg = <0>;
mode = <0>;
partition@u-boot {
label = "u-boot";
partition@unused {
label = "unused";
+&i2c0 {
- status = "okay";
- eeprom@52 {
reg = <0x52>;
+&uart0 {
- status = "okay";
+&mdio {
- status = "okay";
+ð0 {
- status = "okay";
- ethernet0-port@0 {
speed = <1000>;
duplex = <1>;
+&pciec {
- status = "okay";
+&pcie0 {
- status = "okay";
endchoice
config SYS_SOC
+config SYS_BOARD
+config SYS_VENDOR
- (C) Copyright 2010
- Allied Telesis <www.alliedtelesis.com>
- /* AHB to Mbus Bridge
- .long 0xD0020080, KW_REGS_PHY_BASE
- .long 0xF1020080, KW_REGS_PHY_BASE
- /* Configure RGMII-0 interface pad voltage to 1.8V */
- .long KW_REGS_PHY_BASE + 0x100E0, 0x1B1B1B1B
- .long KW_REGS_PHY_BASE + 0x20134, 0xffffffff
- .long KW_REGS_PHY_BASE + 0x20138, 0x009fffff
- .long KW_REGS_PHY_BASE + 0x20154, 0x00000000
- .long KW_REGS_PHY_BASE + 0x2014c, 0x00000000
- .long KW_REGS_PHY_BASE + 0x20148, 0x00000001
- /* Dram initalization for 1 x x16
- .long KW_REGS_PHY_BASE + 0x01400, 0x43000618 /* DDR Configuration register */
- .long KW_REGS_PHY_BASE + 0x01404, 0x35143000 /* DDR Controller Control Low */
- .long KW_REGS_PHY_BASE + 0x01408, 0x11012227 /* DDR Timing (Low) (active cycles value +1) */
- .long KW_REGS_PHY_BASE + 0x0140C, 0x00000819 /* DDR Timing (High) */
- .long KW_REGS_PHY_BASE + 0x01410, 0x0000000d /* DDR Address Control */
- .long KW_REGS_PHY_BASE + 0x01414, 0x00000000 /* DDR Open Pages Control */
- .long KW_REGS_PHY_BASE + 0x01418, 0x00000000 /* DDR Operation */
- .long KW_REGS_PHY_BASE + 0x0141C, 0x00000632 /* DDR Mode */
- .long KW_REGS_PHY_BASE + 0x01420, 0x00000040 /* DDR Extended Mode */
- .long KW_REGS_PHY_BASE + 0x01424, 0x0000f07f /* DDR Controller Control High */
- .long KW_REGS_PHY_BASE + 0x01428, 0x00063300 /* DDR2 ODT Read Timing (default values) */
- .long KW_REGS_PHY_BASE + 0x0147C, 0x00006330 /* DDR2 ODT Write Timing (default values) */
- .long KW_REGS_PHY_BASE + 0x01500, 0x00000000 /* SDRAM CS[0] Base address at 0x00000000 */
- .long KW_REGS_PHY_BASE + 0x01504, 0x07FFFFF1 /* SDRAM CS[0] Size 128MiB */
- .long KW_REGS_PHY_BASE + 0x01508, 0x10000000 /* SDRAM CS[1] Base address */
- .long KW_REGS_PHY_BASE + 0x0150C, 0x00FFFFF4 /* SDRAM CS[1] Size, window disabled */
- .long KW_REGS_PHY_BASE + 0x01510, 0x20000000 /* SDRAM CS[2] Base address */
- .long KW_REGS_PHY_BASE + 0x01514, 0x00FFFFF8 /* SDRAM CS[2] Size, window disabled */
- .long KW_REGS_PHY_BASE + 0x01518, 0x30000000 /* SDRAM CS[3] Base address */
- .long KW_REGS_PHY_BASE + 0x0151C, 0x00FFFFFC /* SDRAM CS[3] Size, window disabled */
- .long KW_REGS_PHY_BASE + 0x01494, 0x00030000 /* DDR ODT Control (Low) */
- .long KW_REGS_PHY_BASE + 0x01498, 0x00000000 /* DDR ODT Control (High) */
- .long KW_REGS_PHY_BASE + 0x0149C, 0x0000e803 /* CPU ODT Control */
- .long KW_REGS_PHY_BASE + 0x01480, 0x00000001 /* DDR Initialization Control */
- /* End of Header extension */
- .long 0x0, 0x0
My experience with Kirkwood and its code base is limited. But why do you have this DDR setup again in this .S file? Its already done in the SPI NOR header "kwbimage.cfg".
This is just a first comment - I'll do a more thorough review later.
Thanks, Stefan
Chris Packham
Stefan Roese
