[U-Boot] [PATCH] ARM: socfpga: Fix FPGA bitstream loading code
According to SoCFPGA Cyclone V datasheet rev.2018.01.26 page 175 (Chapter 5, FPGA Manager, data register) and Arria10 datasheet rev.2017.07.22 page 211 (Chapter 5.4.1.2, FPGA Manager, img_data_w register), the FPGA data register must be written with writes with non-incrementing address.
The current code increments the address in 32-byte bursts. Fix the code so it does not increment the address and writes the register repeatedly instead.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Cc: Tien Fong Chee tien.fong.chee@intel.com --- drivers/fpga/socfpga.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga.c index 685957626b..6ecea771ce 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga.c @@ -55,8 +55,7 @@ void fpgamgr_program_write(const void *rbf_data, size_t rbf_size) " cmp %2, #0\n" " beq 2f\n" "1: ldmia %0!, {r0-r7}\n" - " stmia %1!, {r0-r7}\n" - " sub %1, #32\n" + " stmia %1, {r0-r7}\n" " subs %2, #1\n" " bne 1b\n" "2: cmp %3, #0\n"
The current code increments the address in 32-byte bursts. Fix the code so it does not increment the address and writes the register repeatedly instead. > Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Cc: Tien Fong Chee tien.fong.chee@intel.com
" sub %1, #32\n"
Iirc, stmia without the "!" still stores the registers to different addresses, it just does not change %1 any more if you leave away the "!"? So this would save on opcode, but not change anything?
Uh oh, you're right. Do we have a bigger problem here then ? Or is the socfpga ignoring the bottom 5 bits of this register address ?
Well, bitsream programming works for me very well (we're loading all our FGPAs in U-Boot from a FIT image), so maybe it's the documentation that has a problem?
That could indeed be, maybe someone on the CC list can take a look into it and crosscheck it with internal docs ?
sure. let me check.
Thanks for finding.
I can't find any doc mention about "FPGA data must be written in non- incremting address", but i saw there is a description about configuration data is buffered in a 64 deep x 32 bits wide FIFO in the FPGA Manager https://www.intel.com/content/dam/www/programmable/us/en/p dfs/literature/hb/arria-10/a10_5v4.pdf (pg. 204)
Based on my understand through this register fpga_mgr_fpgamgrdata address map (0xFFCFE400-0xFFCFE7FF) on pg. 207 , the 256 bytes of FIFO buffer is mapping to above range addresses.
Thanks.
Regards, TF.
Well yes, it's a FIFO, but is the FIFO populated by writing to a single non-incrementing address or are we supposed to write to subsequent incrementing addresses ?
0xFFCFE7FF-0xFFCFE400 = 0x400 = 1024 Bytes , not 256 . Why ?
On 07.05.19 21:19, Marek Vasut wrote: > > > According to SoCFPGA Cyclone V datasheet rev.2018.01.26 > page > 175 > (Chapter 5, FPGA Manager, data register) and Arria10 > datasheet > rev.2017.07.22 page 211 (Chapter 5.4.1.2, FPGA Manager, > img_data_w > register), the FPGA data register must be written with > writes > with > non-incrementing address. > > The current code increments the address in 32-byte > bursts. > Fix the > code so it does not increment the address and writes the > register > repeatedly instead. > > Signed-off-by: Marek Vasut marex@denx.de > Cc: Chin Liang See chin.liang.see@intel.com > Cc: Dinh Nguyen dinguyen@kernel.org > Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com > Cc: Tien Fong Chee tien.fong.chee@intel.com > --- > drivers/fpga/socfpga.c | 3 +-- > 1 file changed, 1 insertion(+), 2 deletions(-) > > diff --git a/drivers/fpga/socfpga.c > b/drivers/fpga/socfpga.c > index 685957626b..6ecea771ce 100644 > --- a/drivers/fpga/socfpga.c > +++ b/drivers/fpga/socfpga.c > @@ -55,8 +55,7 @@ void fpgamgr_program_write(const void > *rbf_data, > size_t rbf_size) > " cmp %2, #0\n" > " beq 2f\n" > "1: ldmia %0!, {r0-r7}\n" > - " stmia %1!, {r0-r7}\n" > - " sub %1, #32\n" > + " stmia %1, {r0-r7}\n" Iirc, stmia without the "!" still stores the registers to different addresses, it just does not change %1 any more if you leave away the "!"? So this would save on opcode, but not change anything?
I can't find any doc mention about "FPGA data must be written in non- incremting address", but i saw there is a description about configuration data is buffered in a 64 deep x 32 bits wide FIFO in the FPGA Manager https://www.intel.com/content/dam/www/programmable/us/ en/p dfs/literature/hb/arria-10/a10_5v4.pdf (pg. 204)
Finally, i have connected all scattered dot information from few internal docs. The register fpga_mgr_fpgamgrdata is actually a space in memory, acting like a buffer for the FPGA data. Regardless of the programming mode, data input from this buffer is translated into a 32- bit wide data path used by the configuration logic.
Thanks.
On 5/7/19 9:36 PM, Simon Goldschmidt wrote: > > > > > On 07.05.19 21:19, Marek Vasut wrote: >> >> >> According to SoCFPGA Cyclone V datasheet rev.2018.01.26 >> page >> 175 >> (Chapter 5, FPGA Manager, data register) and Arria10 >> datasheet >> rev.2017.07.22 page 211 (Chapter 5.4.1.2, FPGA Manager, >> img_data_w >> register), the FPGA data register must be written with >> writes >> with >> non-incrementing address. >> >> The current code increments the address in 32-byte >> bursts. >> Fix the >> code so it does not increment the address and writes the >> register >> repeatedly instead. > >> Signed-off-by: Marek Vasut marex@denx.de >> Cc: Chin Liang See chin.liang.see@intel.com >> Cc: Dinh Nguyen dinguyen@kernel.org >> Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com >> Cc: Tien Fong Chee tien.fong.chee@intel.com >> --- >> drivers/fpga/socfpga.c | 3 +-- >> 1 file changed, 1 insertion(+), 2 deletions(-) >> >> diff --git a/drivers/fpga/socfpga.c >> b/drivers/fpga/socfpga.c >> index 685957626b..6ecea771ce 100644 >> --- a/drivers/fpga/socfpga.c >> +++ b/drivers/fpga/socfpga.c >> @@ -55,8 +55,7 @@ void fpgamgr_program_write(const void >> *rbf_data, >> size_t rbf_size) >> " cmp %2, #0\n" >> " beq 2f\n" >> "1: ldmia %0!, {r0-r7}\n" >> - " stmia %1!, {r0-r7}\n" >> - " sub %1, #32\n" >> + " stmia %1, {r0-r7}\n" > Iirc, stmia without the "!" still stores the registers to > different > addresses, it just does not change %1 any more if you leave > away the > "!"? So this would save on opcode, but not change anything? Uh oh, you're right. Do we have a bigger problem here then ? Or is the socfpga ignoring the bottom 5 bits of this register address ?
Does that mean that a write anywhere in 0xFFCFE400..0xFFCFE7FF ends up in the same register / FIFO ? Does that mean that whole address range ignores the bottom 0x3ff MSbits ? Does it matter to which address in that range the CPU writes the data or not ?
On 07.05.19 21:41, Marek Vasut wrote: > > > > On 5/7/19 9:36 PM, Simon Goldschmidt wrote: > > > > > > > > > > > > On 07.05.19 21:19, Marek Vasut wrote: > > > > > > > > > > > > According to SoCFPGA Cyclone V datasheet > > > rev.2018.01.26 > > > page > > > 175 > > > (Chapter 5, FPGA Manager, data register) and Arria10 > > > datasheet > > > rev.2017.07.22 page 211 (Chapter 5.4.1.2, FPGA > > > Manager, > > > img_data_w > > > register), the FPGA data register must be written > > > with > > > writes > > > with > > > non-incrementing address. > > > > > > The current code increments the address in 32-byte > > > bursts. > > > Fix the > > > code so it does not increment the address and writes > > > the > > > register > > > repeatedly instead. > > > > Signed-off-by: Marek Vasut marex@denx.de > > > Cc: Chin Liang See chin.liang.see@intel.com > > > Cc: Dinh Nguyen dinguyen@kernel.org > > > Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.co > > > m> > > > Cc: Tien Fong Chee tien.fong.chee@intel.com > > > --- > > > drivers/fpga/socfpga.c | 3 +-- > > > 1 file changed, 1 insertion(+), 2 deletions(-) > > > > > > diff --git a/drivers/fpga/socfpga.c > > > b/drivers/fpga/socfpga.c > > > index 685957626b..6ecea771ce 100644 > > > --- a/drivers/fpga/socfpga.c > > > +++ b/drivers/fpga/socfpga.c > > > @@ -55,8 +55,7 @@ void fpgamgr_program_write(const > > > void > > > *rbf_data, > > > size_t rbf_size) > > > " cmp %2, #0\n" > > > " beq 2f\n" > > > "1: ldmia %0!, {r0-r7}\n" > > > - " stmia %1!, {r0-r7}\n" > > > - " sub %1, #32\n" > > > + " stmia %1, {r0-r7}\n" > > Iirc, stmia without the "!" still stores the registers > > to > > different > > addresses, it just does not change %1 any more if you > > leave > > away the > > "!"? So this would save on opcode, but not change > > anything? > Uh oh, you're right. Do we have a bigger problem here > then ? > Or > is the > socfpga ignoring the bottom 5 bits of this register > address ? Well, bitsream programming works for me very well (we're loading all our FGPAs in U-Boot from a FIT image), so maybe it's the documentation that has a problem?
I can't find any doc mention about "FPGA data must be written in non- incremting address", but i saw there is a description about configuration data is buffered in a 64 deep x 32 bits wide FIFO in the FPGA Manager https://www.intel.com/content/dam/www/programmable /us/ en/p dfs/literature/hb/arria-10/a10_5v4.pdf (pg. 204)
Sorry, that's all information i have. Anyway, i have already engaged the HW engineer in the loop, and i will update you once i have more details.
Thanks.
On 5/7/19 9:43 PM, Simon Goldschmidt wrote: > > > > > > On 07.05.19 21:41, Marek Vasut wrote: >> >> >> >> On 5/7/19 9:36 PM, Simon Goldschmidt wrote: >>> >>> >>> >>> >>> >>> On 07.05.19 21:19, Marek Vasut wrote: >>>> >>>> >>>> >>>> According to SoCFPGA Cyclone V datasheet >>>> rev.2018.01.26 >>>> page >>>> 175 >>>> (Chapter 5, FPGA Manager, data register) and Arria10 >>>> datasheet >>>> rev.2017.07.22 page 211 (Chapter 5.4.1.2, FPGA >>>> Manager, >>>> img_data_w >>>> register), the FPGA data register must be written >>>> with >>>> writes >>>> with >>>> non-incrementing address. >>>> >>>> The current code increments the address in 32-byte >>>> bursts. >>>> Fix the >>>> code so it does not increment the address and writes >>>> the >>>> register >>>> repeatedly instead. > >>>> Signed-off-by: Marek Vasut marex@denx.de >>>> Cc: Chin Liang See chin.liang.see@intel.com >>>> Cc: Dinh Nguyen dinguyen@kernel.org >>>> Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.co >>>> m> >>>> Cc: Tien Fong Chee tien.fong.chee@intel.com >>>> --- >>>> drivers/fpga/socfpga.c | 3 +-- >>>> 1 file changed, 1 insertion(+), 2 deletions(-) >>>> >>>> diff --git a/drivers/fpga/socfpga.c >>>> b/drivers/fpga/socfpga.c >>>> index 685957626b..6ecea771ce 100644 >>>> --- a/drivers/fpga/socfpga.c >>>> +++ b/drivers/fpga/socfpga.c >>>> @@ -55,8 +55,7 @@ void fpgamgr_program_write(const >>>> void >>>> *rbf_data, >>>> size_t rbf_size) >>>> " cmp %2, #0\n" >>>> " beq 2f\n" >>>> "1: ldmia %0!, {r0-r7}\n" >>>> - " stmia %1!, {r0-r7}\n" >>>> - " sub %1, #32\n" >>>> + " stmia %1, {r0-r7}\n" >>> Iirc, stmia without the "!" still stores the registers >>> to >>> different >>> addresses, it just does not change %1 any more if you >>> leave >>> away the >>> "!"? So this would save on opcode, but not change >>> anything? >> Uh oh, you're right. Do we have a bigger problem here >> then ? >> Or >> is the >> socfpga ignoring the bottom 5 bits of this register >> address ? > Well, bitsream programming works for me very well (we're > loading > all our > FGPAs in U-Boot from a FIT image), so maybe it's the > documentation > that > has a problem? That could indeed be, maybe someone on the CC list can take a look into it and crosscheck it with internal docs ?
Thanks, let's wait and see ...
Marek,
Am 13.05.2019 um 15:12 schrieb Marek Vasut:
On Tue, 2019-05-07 at 21:44 +0200, Marek Vasut wrote: > > > On 5/7/19 9:43 PM, Simon Goldschmidt wrote: >> >> >> >> >> >> On 07.05.19 21:41, Marek Vasut wrote: >>> >>> >>> >>> On 5/7/19 9:36 PM, Simon Goldschmidt wrote: >>>> >>>> >>>> >>>> >>>> >>>> On 07.05.19 21:19, Marek Vasut wrote: >>>>> >>>>> >>>>> >>>>> According to SoCFPGA Cyclone V datasheet >>>>> rev.2018.01.26 >>>>> page >>>>> 175 >>>>> (Chapter 5, FPGA Manager, data register) and Arria10 >>>>> datasheet >>>>> rev.2017.07.22 page 211 (Chapter 5.4.1.2, FPGA >>>>> Manager, >>>>> img_data_w >>>>> register), the FPGA data register must be written >>>>> with >>>>> writes >>>>> with >>>>> non-incrementing address. >>>>> >>>>> The current code increments the address in 32-byte >>>>> bursts. >>>>> Fix the >>>>> code so it does not increment the address and writes >>>>> the >>>>> register >>>>> repeatedly instead. > >>>>> Signed-off-by: Marek Vasut marex@denx.de >>>>> Cc: Chin Liang See chin.liang.see@intel.com >>>>> Cc: Dinh Nguyen dinguyen@kernel.org >>>>> Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.co >>>>> m> >>>>> Cc: Tien Fong Chee tien.fong.chee@intel.com >>>>> --- >>>>> drivers/fpga/socfpga.c | 3 +-- >>>>> 1 file changed, 1 insertion(+), 2 deletions(-) >>>>> >>>>> diff --git a/drivers/fpga/socfpga.c >>>>> b/drivers/fpga/socfpga.c >>>>> index 685957626b..6ecea771ce 100644 >>>>> --- a/drivers/fpga/socfpga.c >>>>> +++ b/drivers/fpga/socfpga.c >>>>> @@ -55,8 +55,7 @@ void fpgamgr_program_write(const >>>>> void >>>>> *rbf_data, >>>>> size_t rbf_size) >>>>> " cmp %2, #0\n" >>>>> " beq 2f\n" >>>>> "1: ldmia %0!, {r0-r7}\n" >>>>> - " stmia %1!, {r0-r7}\n" >>>>> - " sub %1, #32\n" >>>>> + " stmia %1, {r0-r7}\n" >>>> Iirc, stmia without the "!" still stores the registers >>>> to >>>> different >>>> addresses, it just does not change %1 any more if you >>>> leave >>>> away the >>>> "!"? So this would save on opcode, but not change >>>> anything? >>> Uh oh, you're right. Do we have a bigger problem here >>> then ? >>> Or >>> is the >>> socfpga ignoring the bottom 5 bits of this register >>> address ? >> Well, bitsream programming works for me very well (we're >> loading >> all our >> FGPAs in U-Boot from a FIT image), so maybe it's the >> documentation >> that >> has a problem? > That could indeed be, maybe someone on the CC list can take a > look > into > it and crosscheck it with internal docs ? I can't find any doc mention about "FPGA data must be written in non- incremting address", but i saw there is a description about configuration data is buffered in a 64 deep x 32 bits wide FIFO in the FPGA Manager https://www.intel.com/content/dam/www/programmable /us/ en/p dfs/literature/hb/arria-10/a10_5v4.pdf (pg. 204)
Have you dropped this? It's assigned to me in patchwork (I'm going through the list of old items assigned to me...).
On 10/9/19 8:06 PM, Simon Goldschmidt wrote: [...]
> Based on my understand through this register > fpga_mgr_fpgamgrdata > address map (0xFFCFE400-0xFFCFE7FF) on pg. 207 , the 256 bytes > of > FIFO > buffer is mapping to above range addresses. 0xFFCFE7FF-0xFFCFE400 = 0x400 = 1024 Bytes , not 256 . Why ?
I don't know, sorry. Apparently there isn't enough information to decide whether this patch is correct or not.
Marek Vasut marex@denx.de schrieb am Mi., 9. Okt. 2019, 23:01:
>> Based on my understand through this register >> fpga_mgr_fpgamgrdata >> address map (0xFFCFE400-0xFFCFE7FF) on pg. 207 , the 256 bytes >> of >> FIFO >> buffer is mapping to above range addresses. > 0xFFCFE7FF-0xFFCFE400 = 0x400 = 1024 Bytes , not 256 . Why ? Finally, i have connected all scattered dot information from few internal docs. The register fpga_mgr_fpgamgrdata is actually a space in memory, acting like a buffer for the FPGA data. Regardless of the programming mode, data input from this buffer is translated into a 32- bit wide data path used by the configuration logic.
Right. However, since it seems to work as is, I don't think we have a real problem.
On 10/10/19 7:15 AM, Simon Goldschmidt wrote: [...]
I think the datasheet could use clarification in that aspect. But it might be way too late for that.
Hi, i think i have find the problem, but i think i doesn't have the experience for modifie that. on the file : drivers/fpga/ socfpga_gen5.c : line 161 : function <fpgamgr_program_poll_initphase> :
1. we wait fot the return of the fonction <fpgamgr_get_mode> with the value <FPGAMGRREGS_MODE_INITPHASE> or <FPGAMGRREGS_MODE_USERMODE> 2. but he never comming its always the value <FPGAMGRREGS_MODE_CFGPHASE> then we are the timing out.
Then the fpga is on configuration mode, my question is:
1. How to set him on user mode ? 2. Why the configuration is not finalised ? 3. Where i can find information for finalise it ?
I want to contribute, but im a noobies :)
real
problem.
-- Best regards, Marek Vasut _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
jérémy alcim alcim.dev@gmail.com schrieb am Fr., 29. Nov. 2019, 08:32:
- we wait fot the return of the fonction <fpgamgr_get_mode> with the
- How to set him on user mode ?
- Why the configuration is not finalised ?
- Where i can find information for finalise it ?
Most probably, the FPGA is stuck in configuration phase because the file you were trying to program is not a valid programming file. Unless I'm really mistaken, this does not have anything to do with what's discussed in this thread.
decide
real
problem.
Chee, Tien Fong
jérémy alcim
Simon Goldschmidt
