[PATCH 0/9] meson64_android: Android boot flow using abootimg
The SEI-610 and SEI-510 boards are well supported in the Android Open Source project via the yukawa [1] platform.
Their U-Boot version, despite being public [2] is not in mainline.
Android 10 and higher have significantly reworked the bootloader requirements:
* bootloader should pass slot information in case of A/B * bootloader should perform AVB verification in case it's supported * bootloader should read and apply dtb overlays from a dtbo partition
These series add support for all the above.
[1] https://android.googlesource.com/device/amlogic/yukawa [2] https://gitlab.com/baylibre/amlogic/atv/u-boot/-/tree/u-boot/v2021.07/integ
Guillaume La Roque (2): configs: meson64_android: boot android via abootimg configs: sei510/610: android bootflow via abootimg
Mattijs Korpershoek (7): configs: meson64: permit redefining SYS_MALLOC_LEN configs: meson64_android: increase SYS_MALLOC_LEN to 128M for AVB configs: meson64_android: implement AVB support configs: meson64_android: implement A/B slot support configs: meson64_android: define BOOT_CMD macro configs: sei510/sei610: reformat PARTS_default configs: sei510/sei610: don't use hard-coded gpt uuids
configs/sei510_defconfig | 5 ++ configs/sei610_defconfig | 5 ++ include/configs/meson64.h | 2 + include/configs/meson64_android.h | 139 ++++++++++++++++++++++++++++-- include/configs/sei510.h | 23 +++-- include/configs/sei610.h | 23 +++-- 6 files changed, 165 insertions(+), 32 deletions(-)
Permit redefining SYS_MALLOC_LEN for board specific configs. This is especially useful for Android with AVB, which requires a malloc length of 128M.
Signed-off-by: Guillaume La Roque glaroque@baylibre.com Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- include/configs/meson64.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/meson64.h b/include/configs/meson64.h index fb7f16d148..f9bb0240d2 100644 --- a/include/configs/meson64.h +++ b/include/configs/meson64.h @@ -32,7 +32,9 @@ #define CONFIG_CPU_ARMV8 #define CONFIG_REMAKE_ELF #define CONFIG_SYS_MAXARGS 32 +#ifndef CONFIG_SYS_MALLOC_LEN #define CONFIG_SYS_MALLOC_LEN (32 << 20) +#endif #define CONFIG_SYS_CBSIZE 1024
#define CONFIG_SYS_SDRAM_BASE 0
Acked-by: Neil Armstrong narmstrong@baylibre.com
I prefer to see these as SZ_xxx, but also what's the minimum DRAM you're going to see on a meson64 platform? And if it's 1GB or more, why not just use 128MB for everyone?
We can get down to 256MiB DRAM (very rare), but 512MiB is used on La Frite.
Neil
Hi Tom, Neil,
Neil Armstrong narmstrong@baylibre.com writes:
In that case, I think it's more reasonable to keep the change as-is. I'll send a v2 replacing (32 << 20) by SZ_32M
Do you agree ?
Mattijs
Neil
On Fri, Aug 06, 2021 at 11:24:54AM +0200, Mattijs Korpershoek wrote:
Hi Tom, Neil,
tbh, using SZ_xxx isn't a big enough issue to v2 things over.
OK, thanks.
To prepare for AVB support, increase SYS_MALLOC_LEN to 128M. This value has been found by testing the following on khadas vim3l: => avb init => avb verify
Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- include/configs/meson64_android.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/meson64_android.h b/include/configs/meson64_android.h index f9f2b26416..bc3ffb9ca5 100644 --- a/include/configs/meson64_android.h +++ b/include/configs/meson64_android.h @@ -9,6 +9,10 @@ #ifndef __MESON64_ANDROID_CONFIG_H #define __MESON64_ANDROID_CONFIG_H
+#include <linux/sizes.h> + +#define CONFIG_SYS_MALLOC_LEN SZ_128M + #ifndef BOOT_PARTITION #define BOOT_PARTITION "boot" #endif
AVB (Android Verified Boot) is well supported in U-Boot already. Add support for it in meson64_android.
This is controlled by the "force_avb" environment variable and the CONFIG_CMD_AVB option.
Signed-off-by: Guillaume La Roque glaroque@baylibre.com Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- include/configs/meson64_android.h | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/include/configs/meson64_android.h b/include/configs/meson64_android.h index bc3ffb9ca5..48a23b6e41 100644 --- a/include/configs/meson64_android.h +++ b/include/configs/meson64_android.h @@ -27,6 +27,25 @@
#ifndef RECOVERY_PARTITION #define RECOVERY_PARTITION "recovery" + +#if defined(CONFIG_CMD_AVB) +#define AVB_VERIFY_CHECK \ + "if test "${force_avb}" -eq 1; then " \ + "if run avb_verify; then " \ + "echo AVB verification OK.;" \ + "setenv bootargs "$bootargs $avb_bootargs";" \ + "else " \ + "echo AVB verification failed.;" \ + "exit; fi;" \ + "else " \ + "setenv bootargs "$bootargs androidboot.verifiedbootstate=orange";" \ + "echo Running without AVB...; "\ + "fi;" + +#define AVB_VERIFY_CMD "avb_verify=avb init ${mmcdev}; avb verify;\0" +#else +#define AVB_VERIFY_CHECK "" +#define AVB_VERIFY_CMD "" #endif
#define BOOTENV_DEV_FASTBOOT(devtypeu, devtypel, instance) \ @@ -93,6 +112,7 @@ "echo Running Recovery...;" \ "mmc dev ${mmcdev};" \ "setenv bootargs "${bootargs} androidboot.serialno=${serial#}";" \ + AVB_VERIFY_CHECK \ "part start mmc ${mmcdev} " RECOVERY_PARTITION " boot_start;" \ "part size mmc ${mmcdev} " RECOVERY_PARTITION " boot_size;" \ "if mmc read ${loadaddr} ${boot_start} ${boot_size}; then " \ @@ -111,6 +131,7 @@ "echo Loading Android " BOOT_PARTITION " partition...;" \ "mmc dev ${mmcdev};" \ "setenv bootargs ${bootargs} androidboot.serialno=${serial#};" \ + AVB_VERIFY_CHECK \ "part start mmc ${mmcdev} " BOOT_PARTITION " boot_start;" \ "part size mmc ${mmcdev} " BOOT_PARTITION " boot_size;" \ "if mmc read ${loadaddr} ${boot_start} ${boot_size}; then " \ @@ -142,6 +163,8 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "partitions=" PARTS_DEFAULT "\0" \ "mmcdev=2\0" \ + AVB_VERIFY_CMD \ + "force_avb=0\0" \ "gpio_recovery=88\0" \ "check_button=gpio input ${gpio_recovery};test $? -eq 0;\0" \ "load_logo=" PREBOOT_LOAD_LOGO "\0" \
- "if test "${force_avb}" -eq 1; then " \
"setenv bootargs \"$bootargs $avb_bootargs\";" \
"else " \
"exit; fi;" \
- "else " \
"setenv bootargs \"$bootargs androidboot.verifiedbootstate=orange\";" \
- "fi;"
"part start mmc ${mmcdev} " BOOT_PARTITION " boot_start;" \ "part size mmc ${mmcdev} " BOOT_PARTITION " boot_size;" \ "if mmc read ${loadaddr} ${boot_start} ${boot_size}; then " \AVB_VERIFY_CHECK \
- AVB_VERIFY_CMD \
- "force_avb=0\0" \ "gpio_recovery=88\0" \ "check_button=gpio input ${gpio_recovery};test $? -eq 0;\0" \ "load_logo=" PREBOOT_LOAD_LOGO "\0" \
Implement A/B slot selection using the U-Boot ab_select command.
Keep support for non A/B.
Not: We need to redefine the recovery partition label, as RecoveryOS is included in the boot image for A/B systems [1]
[1] https://source.android.com/devices/tech/ota/ab/ab_implement#recovery Signed-off-by: Guillaume La Roque glaroque@baylibre.com Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- include/configs/meson64_android.h | 55 ++++++++++++++++++++++++++----- 1 file changed, 47 insertions(+), 8 deletions(-)
diff --git a/include/configs/meson64_android.h b/include/configs/meson64_android.h index 48a23b6e41..83fa25bfb1 100644 --- a/include/configs/meson64_android.h +++ b/include/configs/meson64_android.h @@ -25,9 +25,6 @@ #define CONTROL_PARTITION "misc" #endif
-#ifndef RECOVERY_PARTITION -#define RECOVERY_PARTITION "recovery" - #if defined(CONFIG_CMD_AVB) #define AVB_VERIFY_CHECK \ "if test "${force_avb}" -eq 1; then " \ @@ -42,12 +39,48 @@ "echo Running without AVB...; "\ "fi;"
-#define AVB_VERIFY_CMD "avb_verify=avb init ${mmcdev}; avb verify;\0" +#define AVB_VERIFY_CMD "avb_verify=avb init ${mmcdev}; avb verify $slot_suffix;\0" #else #define AVB_VERIFY_CHECK "" #define AVB_VERIFY_CMD "" #endif
+#if defined(CONFIG_CMD_AB_SELECT) +#define ANDROIDBOOT_GET_CURRENT_SLOT_CMD "get_current_slot=" \ + "if part number mmc ${mmcdev} " CONTROL_PARTITION " control_part_number; " \ + "then " \ + "echo " CONTROL_PARTITION \ + " partition number:${control_part_number};" \ + "ab_select current_slot mmc ${mmcdev}:${control_part_number};" \ + "else " \ + "echo " CONTROL_PARTITION " partition not found;" \ + "fi;\0" + +#define AB_SELECT_SLOT \ + "run get_current_slot; " \ + "if test -e "${current_slot}"; " \ + "then " \ + "setenv slot_suffix _${current_slot}; " \ + "else " \ + "echo current_slot not found;" \ + "exit;" \ + "fi;" + +#define AB_SELECT_ARGS \ + "setenv bootargs_ab androidboot.slot_suffix=${slot_suffix}; " \ + "echo A/B cmdline addition: ${bootargs_ab};" \ + "setenv bootargs ${bootargs} ${bootargs_ab};" + +#define AB_BOOTARGS " androidboot.force_normal_boot=1" +#define RECOVERY_PARTITION "boot" +#else +#define AB_SELECT_SLOT "" +#define AB_SELECT_ARGS " " +#define ANDROIDBOOT_GET_CURRENT_SLOT_CMD "" +#define AB_BOOTARGS " " +#define RECOVERY_PARTITION "recovery" +#endif + #define BOOTENV_DEV_FASTBOOT(devtypeu, devtypel, instance) \ "bootcmd_fastboot=" \ "setenv run_fastboot 0;" \ @@ -112,9 +145,11 @@ "echo Running Recovery...;" \ "mmc dev ${mmcdev};" \ "setenv bootargs "${bootargs} androidboot.serialno=${serial#}";" \ + AB_SELECT_SLOT \ + AB_SELECT_ARGS \ AVB_VERIFY_CHECK \ - "part start mmc ${mmcdev} " RECOVERY_PARTITION " boot_start;" \ - "part size mmc ${mmcdev} " RECOVERY_PARTITION " boot_size;" \ + "part start mmc ${mmcdev} " RECOVERY_PARTITION "${slot_suffix} boot_start;" \ + "part size mmc ${mmcdev} " RECOVERY_PARTITION "${slot_suffix} boot_size;" \ "if mmc read ${loadaddr} ${boot_start} ${boot_size}; then " \ "echo Running Android Recovery...;" \ "bootm ${loadaddr};" \ @@ -131,10 +166,13 @@ "echo Loading Android " BOOT_PARTITION " partition...;" \ "mmc dev ${mmcdev};" \ "setenv bootargs ${bootargs} androidboot.serialno=${serial#};" \ + AB_SELECT_SLOT \ + AB_SELECT_ARGS \ AVB_VERIFY_CHECK \ - "part start mmc ${mmcdev} " BOOT_PARTITION " boot_start;" \ - "part size mmc ${mmcdev} " BOOT_PARTITION " boot_size;" \ + "part start mmc ${mmcdev} " BOOT_PARTITION "${slot_suffix} boot_start;" \ + "part size mmc ${mmcdev} " BOOT_PARTITION "${slot_suffix} boot_size;" \ "if mmc read ${loadaddr} ${boot_start} ${boot_size}; then " \ + "setenv bootargs "${bootargs} " AB_BOOTARGS "" ; " \ "echo Running Android...;" \ "bootm ${loadaddr};" \ "fi;" \ @@ -163,6 +201,7 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "partitions=" PARTS_DEFAULT "\0" \ "mmcdev=2\0" \ + ANDROIDBOOT_GET_CURRENT_SLOT_CMD \ AVB_VERIFY_CMD \ "force_avb=0\0" \ "gpio_recovery=88\0" \
- "if part number mmc ${mmcdev} " CONTROL_PARTITION " control_part_number; " \
- "then " \
- "else " \
- "fi;\0"
- "run get_current_slot; " \
- "if test -e "${current_slot}"; " \
- "then " \
- "else " \
"exit;" \
- "fi;"
- "setenv bootargs_ab androidboot.slot_suffix=${slot_suffix}; " \
- "echo A/B cmdline addition: ${bootargs_ab};" \
- "setenv bootargs ${bootargs} ${bootargs_ab};"
AB_SELECT_SLOT \
AB_SELECT_SLOT \
AVB_VERIFY_CHECK \AB_SELECT_ARGS \
"if mmc read ${loadaddr} ${boot_start} ${boot_size}; then " \"part size mmc ${mmcdev} " BOOT_PARTITION "${slot_suffix} boot_size;" \
"fi;" \"setenv bootargs \"${bootargs} " AB_BOOTARGS "\" ; " \ "echo Running Android...;" \ "bootm ${loadaddr};" \
- ANDROIDBOOT_GET_CURRENT_SLOT_CMD \ AVB_VERIFY_CMD \ "force_avb=0\0" \ "gpio_recovery=88\0" \
BOOT_CMD might be different based on CONFIG_CMD_ABOOTIMG.
To prepare for abootimg support, extract the boot command to a dedicated macro.
Signed-off-by: Guillaume La Roque glaroque@baylibre.com Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- include/configs/meson64_android.h | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/include/configs/meson64_android.h b/include/configs/meson64_android.h index 83fa25bfb1..0ce616c17e 100644 --- a/include/configs/meson64_android.h +++ b/include/configs/meson64_android.h @@ -81,6 +81,8 @@ #define RECOVERY_PARTITION "recovery" #endif
+#define BOOT_CMD "bootm ${loadaddr};" + #define BOOTENV_DEV_FASTBOOT(devtypeu, devtypel, instance) \ "bootcmd_fastboot=" \ "setenv run_fastboot 0;" \ @@ -152,7 +154,7 @@ "part size mmc ${mmcdev} " RECOVERY_PARTITION "${slot_suffix} boot_size;" \ "if mmc read ${loadaddr} ${boot_start} ${boot_size}; then " \ "echo Running Android Recovery...;" \ - "bootm ${loadaddr};" \ + BOOT_CMD \ "fi;" \ "echo Failed to boot Android...;" \ "reset;" \ @@ -174,7 +176,7 @@ "if mmc read ${loadaddr} ${boot_start} ${boot_size}; then " \ "setenv bootargs "${bootargs} " AB_BOOTARGS "" ; " \ "echo Running Android...;" \ - "bootm ${loadaddr};" \ + BOOT_CMD \ "fi;" \ "echo Failed to boot Android...;" \ "reset\0"
"fi;" \ "echo Failed to boot Android...;" \ "reset\0"BOOT_CMD \
Since Android 10, we are required to use a "dtbo" partition which includes the various device-tree overlays [1]. It's also possible to provide a "dtb" partition.
This is supported via the "abootimg" command.
On Yukawa, the assumption is that we have only a "dtbo" partition, which includes all board dtbs and their dtbos [2]
[1] https://source.android.com/devices/architecture/dto/partitions [2] https://android.googlesource.com/device/amlogic/yukawa/+/refs/heads/master/b... Signed-off-by: Guillaume La Roque glaroque@baylibre.com Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- include/configs/meson64_android.h | 57 ++++++++++++++++++++++++++++++- 1 file changed, 56 insertions(+), 1 deletion(-)
diff --git a/include/configs/meson64_android.h b/include/configs/meson64_android.h index 0ce616c17e..358e0a5c71 100644 --- a/include/configs/meson64_android.h +++ b/include/configs/meson64_android.h @@ -81,7 +81,59 @@ #define RECOVERY_PARTITION "recovery" #endif
+#if defined(CONFIG_CMD_ABOOTIMG) +/* + * Prepares complete device tree blob for current board (for Android boot). + * + * Boot image or recovery image should be loaded into $loadaddr prior to running + * these commands. The logic of these commnads is next: + * + * 1. Read correct DTB for current SoC/board from boot image in $loadaddr + * to $fdtaddr + * 2. Merge all needed DTBO for current board from 'dtbo' partition into read + * DTB + * 3. User should provide $fdtaddr as 3rd argument to 'bootm' + */ +#define PREPARE_FDT \ + "echo Preparing FDT...; " \ + "if test $board_name = sei510; then " \ + "echo " Reading DTB for sei510..."; " \ + "setenv dtb_index 0;" \ + "elif test $board_name = sei610; then " \ + "echo " Reading DTB for sei610..."; " \ + "setenv dtb_index 1;" \ + "else " \ + "echo Error: Android boot is not supported for $board_name; " \ + "exit; " \ + "fi; " \ + "abootimg get dtb --index=$dtb_index dtb_start dtb_size; " \ + "cp.b $dtb_start $fdt_addr_r $dtb_size; " \ + "fdt addr $fdt_addr_r 0x80000; " \ + "if test $board_name = sei510; then " \ + "echo " Reading DTBO for sei510..."; " \ + "setenv dtbo_index 0;" \ + "elif test $board_name = sei610; then " \ + "echo " Reading DTBO for sei610..."; " \ + "setenv dtbo_index 1;" \ + "else " \ + "echo Error: Android boot is not supported for $board_name; " \ + "exit; " \ + "fi; " \ + "part start mmc ${mmcdev} dtbo${slot_suffix} p_dtbo_start; " \ + "part size mmc ${mmcdev} dtbo${slot_suffix} p_dtbo_size; " \ + "mmc read ${dtboaddr} ${p_dtbo_start} ${p_dtbo_size}; " \ + "echo " Applying DTBOs..."; " \ + "adtimg addr $dtboaddr; " \ + "adtimg get dt --index=$dtbo_index dtbo0_addr; " \ + "fdt apply $dtbo0_addr;" \ + "setenv bootargs "$bootargs androidboot.dtbo_idx=$dtbo_index ";"\ + +#define BOOT_CMD "bootm ${loadaddr} ${loadaddr} ${fdt_addr_r};" + +#else +#define PREPARE_FDT " " #define BOOT_CMD "bootm ${loadaddr};" +#endif
#define BOOTENV_DEV_FASTBOOT(devtypeu, devtypel, instance) \ "bootcmd_fastboot=" \ @@ -153,6 +205,7 @@ "part start mmc ${mmcdev} " RECOVERY_PARTITION "${slot_suffix} boot_start;" \ "part size mmc ${mmcdev} " RECOVERY_PARTITION "${slot_suffix} boot_size;" \ "if mmc read ${loadaddr} ${boot_start} ${boot_size}; then " \ + PREPARE_FDT \ "echo Running Android Recovery...;" \ BOOT_CMD \ "fi;" \ @@ -174,6 +227,7 @@ "part start mmc ${mmcdev} " BOOT_PARTITION "${slot_suffix} boot_start;" \ "part size mmc ${mmcdev} " BOOT_PARTITION "${slot_suffix} boot_size;" \ "if mmc read ${loadaddr} ${boot_start} ${boot_size}; then " \ + PREPARE_FDT \ "setenv bootargs "${bootargs} " AB_BOOTARGS "" ; " \ "echo Running Android...;" \ BOOT_CMD \ @@ -212,7 +266,8 @@ "stdin=" STDIN_CFG "\0" \ "stdout=" STDOUT_CFG "\0" \ "stderr=" STDOUT_CFG "\0" \ - "loadaddr=0x01000000\0" \ + "dtboaddr=0x08200000\0" \ + "loadaddr=0x01080000\0" \ "fdt_addr_r=0x01000000\0" \ "scriptaddr=0x08000000\0" \ "kernel_addr_r=0x01080000\0" \
- Prepares complete device tree blob for current board (for Android boot).
- Boot image or recovery image should be loaded into $loadaddr prior to running
- these commands. The logic of these commnads is next:
- Read correct DTB for current SoC/board from boot image in $loadaddr
to $fdtaddr
- Merge all needed DTBO for current board from 'dtbo' partition into read
DTB
- User should provide $fdtaddr as 3rd argument to 'bootm'
- "echo Preparing FDT...; " \
- "if test $board_name = sei510; then " \
"echo \" Reading DTB for sei510...\"; " \
- "elif test $board_name = sei610; then " \
"echo \" Reading DTB for sei610...\"; " \
- "else " \
"exit; " \
- "fi; " \
- "abootimg get dtb --index=$dtb_index dtb_start dtb_size; " \
- "cp.b $dtb_start $fdt_addr_r $dtb_size; " \
- "fdt addr $fdt_addr_r 0x80000; " \
"echo \" Reading DTBO for sei510...\"; " \
"echo \" Reading DTBO for sei610...\"; " \
- "else " \
"exit; " \
- "fi; " \
- "part start mmc ${mmcdev} dtbo${slot_suffix} p_dtbo_start; " \
- "part size mmc ${mmcdev} dtbo${slot_suffix} p_dtbo_size; " \
- "mmc read ${dtboaddr} ${p_dtbo_start} ${p_dtbo_size}; " \
- "echo " Applying DTBOs..."; " \
- "adtimg addr $dtboaddr; " \
- "adtimg get dt --index=$dtbo_index dtbo0_addr; " \
- "fdt apply $dtbo0_addr;" \
- "setenv bootargs "$bootargs androidboot.dtbo_idx=$dtbo_index ";"\
PREPARE_FDT \ "setenv bootargs \"${bootargs} " AB_BOOTARGS "\" ; " \ "echo Running Android...;" \ BOOT_CMD \
- "dtboaddr=0x08200000\0" \
- "loadaddr=0x01080000\0" \ "fdt_addr_r=0x01000000\0" \ "scriptaddr=0x08000000\0" \ "kernel_addr_r=0x01080000\0" \
There is a mix of spaces and tabs at the leading . This makes updating theses lines harder.
Add a single space before each \ for some consistency.
Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- include/configs/sei510.h | 14 +++++++------- include/configs/sei610.h | 14 +++++++------- 2 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/include/configs/sei510.h b/include/configs/sei510.h index d37b4c6405..16a34c717d 100644 --- a/include/configs/sei510.h +++ b/include/configs/sei510.h @@ -16,14 +16,14 @@ #define USERDATA_UUID "9b976e42-5207-11e9-8f16-ff47ac594b22;" #define ROOT_UUID "ddb8c3f6-d94d-4394-b633-3134139cc2e0;"
-#define PARTS_DEFAULT \ - "uuid_disk=${uuid_gpt_disk};" \ +#define PARTS_DEFAULT \ + "uuid_disk=${uuid_gpt_disk};" \ "name=boot,size=64M,bootable,uuid=${uuid_gpt_boot};" \ - "name=logo,size=2M,uuid=" LOGO_UUID \ - "name=cache,size=256M,uuid=" CACHE_UUID \ - "name=system,size=1536M,uuid=" SYSTEM_UUID \ - "name=vendor,size=256M,uuid=" VENDOR_UUID \ - "name=userdata,size=5341M,uuid=" USERDATA_UUID \ + "name=logo,size=2M,uuid=" LOGO_UUID \ + "name=cache,size=256M,uuid=" CACHE_UUID \ + "name=system,size=1536M,uuid=" SYSTEM_UUID \ + "name=vendor,size=256M,uuid=" VENDOR_UUID \ + "name=userdata,size=5341M,uuid=" USERDATA_UUID \ "name=rootfs,size=-,uuid=" ROOT_UUID
diff --git a/include/configs/sei610.h b/include/configs/sei610.h index 9eeffdd72c..6d13fd143b 100644 --- a/include/configs/sei610.h +++ b/include/configs/sei610.h @@ -16,14 +16,14 @@ #define USERDATA_UUID "9b976e42-5207-11e9-8f16-ff47ac594b22;" #define ROOT_UUID "ddb8c3f6-d94d-4394-b633-3134139cc2e0;"
-#define PARTS_DEFAULT \ - "uuid_disk=${uuid_gpt_disk};" \ +#define PARTS_DEFAULT \ + "uuid_disk=${uuid_gpt_disk};" \ "name=boot,size=64M,bootable,uuid=${uuid_gpt_boot};" \ - "name=logo,size=2M,uuid=" LOGO_UUID \ - "name=cache,size=256M,uuid=" CACHE_UUID \ - "name=system,size=1536M,uuid=" SYSTEM_UUID \ - "name=vendor,size=256M,uuid=" VENDOR_UUID \ - "name=userdata,size=12795M,uuid=" USERDATA_UUID \ + "name=logo,size=2M,uuid=" LOGO_UUID \ + "name=cache,size=256M,uuid=" CACHE_UUID \ + "name=system,size=1536M,uuid=" SYSTEM_UUID \ + "name=vendor,size=256M,uuid=" VENDOR_UUID \ + "name=userdata,size=12795M,uuid=" USERDATA_UUID \ "name=rootfs,size=-,uuid=" ROOT_UUID
#include <configs/meson64_android.h>
- "uuid_disk=${uuid_gpt_disk};" \ "name=boot,size=64M,bootable,uuid=${uuid_gpt_boot};" \
- "name=userdata,size=5341M,uuid=" USERDATA_UUID \ "name=rootfs,size=-,uuid=" ROOT_UUID
- "name=userdata,size=12795M,uuid=" USERDATA_UUID \ "name=rootfs,size=-,uuid=" ROOT_UUID
doc/README.gpt states:
The fields 'uuid' and 'uuid_disk' are optional if CONFIG_RANDOM_UUID is enabled. A random uuid will be used if omitted or they point to an empty/ non-existent environment variable. The environment variable will be set to the generated UUID. The 'gpt guid' command reads the current value of the uuid_disk from the GPT.
Since we have CONFIG_RANDOM_UUID=y, remove the hard-coded uuids and use meaningful variable names instead.
Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- include/configs/sei510.h | 12 ++++-------- include/configs/sei610.h | 12 ++++-------- 2 files changed, 8 insertions(+), 16 deletions(-)
diff --git a/include/configs/sei510.h b/include/configs/sei510.h index 16a34c717d..5bf2668803 100644 --- a/include/configs/sei510.h +++ b/include/configs/sei510.h @@ -10,20 +10,16 @@ #define __CONFIG_H
#define LOGO_UUID "43a3305d-150f-4cc9-bd3b-38fca8693846;" -#define CACHE_UUID "99207ae6-5207-11e9-999e-6f77a3612069;" -#define SYSTEM_UUID "99f9b7ac-5207-11e9-8507-c3c037e393f3;" -#define VENDOR_UUID "9d082802-5207-11e9-954c-cbbce08ba108;" -#define USERDATA_UUID "9b976e42-5207-11e9-8f16-ff47ac594b22;" #define ROOT_UUID "ddb8c3f6-d94d-4394-b633-3134139cc2e0;"
#define PARTS_DEFAULT \ "uuid_disk=${uuid_gpt_disk};" \ "name=boot,size=64M,bootable,uuid=${uuid_gpt_boot};" \ "name=logo,size=2M,uuid=" LOGO_UUID \ - "name=cache,size=256M,uuid=" CACHE_UUID \ - "name=system,size=1536M,uuid=" SYSTEM_UUID \ - "name=vendor,size=256M,uuid=" VENDOR_UUID \ - "name=userdata,size=5341M,uuid=" USERDATA_UUID \ + "name=cache,size=256M,uuid=${uuid_gpt_cache};" \ + "name=system,size=1536M,uuid=${uuid_gpt_system};" \ + "name=vendor,size=256M,uuid=${uuid_gpt_vendor};" \ + "name=userdata,size=5341M,uuid={uuid_gpt_userdata};" \ "name=rootfs,size=-,uuid=" ROOT_UUID
diff --git a/include/configs/sei610.h b/include/configs/sei610.h index 6d13fd143b..baace75a02 100644 --- a/include/configs/sei610.h +++ b/include/configs/sei610.h @@ -10,20 +10,16 @@ #define __CONFIG_H
#define PARTS_DEFAULT \ "uuid_disk=${uuid_gpt_disk};" \ "name=boot,size=64M,bootable,uuid=${uuid_gpt_boot};" \ "name=logo,size=2M,uuid=" LOGO_UUID \ - "name=cache,size=256M,uuid=" CACHE_UUID \ - "name=system,size=1536M,uuid=" SYSTEM_UUID \ - "name=vendor,size=256M,uuid=" VENDOR_UUID \ - "name=userdata,size=12795M,uuid=" USERDATA_UUID \ + "name=cache,size=256M,uuid=${uuid_gpt_cache};" \ + "name=system,size=1536M,uuid=${uuid_gpt_system};" \ + "name=vendor,size=256M,uuid=${uuid_gpt_vendor};" \ + "name=userdata,size=12795M,uuid=${uuid_gpt_userdata};" \ "name=rootfs,size=-,uuid=" ROOT_UUID
- "name=cache,size=256M,uuid=${uuid_gpt_cache};" \
- "name=system,size=1536M,uuid=${uuid_gpt_system};" \
- "name=vendor,size=256M,uuid=${uuid_gpt_vendor};" \
- "name=userdata,size=5341M,uuid={uuid_gpt_userdata};" \ "name=rootfs,size=-,uuid=" ROOT_UUID
- "name=userdata,size=12795M,uuid=${uuid_gpt_userdata};" \ "name=rootfs,size=-,uuid=" ROOT_UUID
Activate the following Kconfig options: * AVB for Android Verified Boot support * ADTIMG for merging DTBOs * ABOOTIMG for extracting Android boot image
Also rework the partitioning tables: - add a misc partition to handle BCB messages - add a dtbo partition to store various DTBOs - add a vbmeta partition for AVB hashes - Merge vendor and system into the "super" partition
Note: avb support is disables by default. To activate it: => setenv force_avb 1; => saveenv;
Signed-off-by: Guillaume La Roque glaroque@baylibre.com Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- configs/sei510_defconfig | 5 +++++ configs/sei610_defconfig | 5 +++++ include/configs/sei510.h | 11 +++++++---- include/configs/sei610.h | 13 ++++++++----- 4 files changed, 25 insertions(+), 9 deletions(-)
diff --git a/configs/sei510_defconfig b/configs/sei510_defconfig index 74328f2fd4..8099b40b55 100644 --- a/configs/sei510_defconfig +++ b/configs/sei510_defconfig @@ -20,7 +20,10 @@ CONFIG_PREBOOT="run load_logo" # CONFIG_CONSOLE_MUX is not set # CONFIG_DISPLAY_CPUINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_AVB_VERIFY=y # CONFIG_CMD_BDI is not set +CONFIG_CMD_ADTIMG=y +CONFIG_CMD_ABOOTIMG=y # CONFIG_CMD_IMI is not set CONFIG_CMD_BCB=y CONFIG_CMD_GPIO=y @@ -32,6 +35,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_BMP=y CONFIG_CMD_REGULATOR=y +CONFIG_CMD_AVB=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -84,4 +88,5 @@ CONFIG_VIDEO_BMP_RLE8=y CONFIG_BMP_16BPP=y CONFIG_BMP_24BPP=y CONFIG_BMP_32BPP=y +CONFIG_LIBAVB=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/sei610_defconfig b/configs/sei610_defconfig index 2a6d0e5995..e11f36ac79 100644 --- a/configs/sei610_defconfig +++ b/configs/sei610_defconfig @@ -20,7 +20,10 @@ CONFIG_PREBOOT="run load_logo" # CONFIG_CONSOLE_MUX is not set # CONFIG_DISPLAY_CPUINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_AVB_VERIFY=y # CONFIG_CMD_BDI is not set +CONFIG_CMD_ADTIMG=y +CONFIG_CMD_ABOOTIMG=y # CONFIG_CMD_IMI is not set CONFIG_CMD_BCB=y CONFIG_CMD_GPIO=y @@ -32,6 +35,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_BMP=y CONFIG_CMD_REGULATOR=y +CONFIG_CMD_AVB=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -84,4 +88,5 @@ CONFIG_VIDEO_BMP_RLE8=y CONFIG_BMP_16BPP=y CONFIG_BMP_24BPP=y CONFIG_BMP_32BPP=y +CONFIG_LIBAVB=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/include/configs/sei510.h b/include/configs/sei510.h index 5bf2668803..ea91a06157 100644 --- a/include/configs/sei510.h +++ b/include/configs/sei510.h @@ -14,12 +14,15 @@
#define PARTS_DEFAULT \ "uuid_disk=${uuid_gpt_disk};" \ - "name=boot,size=64M,bootable,uuid=${uuid_gpt_boot};" \ "name=logo,size=2M,uuid=" LOGO_UUID \ + "name=misc,size=128K,uuid=${uuid_gpt_misc};" \ + "name=dtbo,size=8M,uuid=${uuid_gpt_dtbo};" \ + "name=vbmeta,size=64K,uuid=${uuid_gpt_vbmeta};" \ + "name=boot,size=32M,bootable,uuid=${uuid_gpt_boot};" \ + "name=recovery,size=32M,uuid=${uuid_gpt_recovery};" \ "name=cache,size=256M,uuid=${uuid_gpt_cache};" \ - "name=system,size=1536M,uuid=${uuid_gpt_system};" \ - "name=vendor,size=256M,uuid=${uuid_gpt_vendor};" \ - "name=userdata,size=5341M,uuid={uuid_gpt_userdata};" \ + "name=super,size=2304M,uuid=${uuid_gpt_super};" \ + "name=userdata,size=4820M,uuid=${uuid_gpt_userdata};" \ "name=rootfs,size=-,uuid=" ROOT_UUID
diff --git a/include/configs/sei610.h b/include/configs/sei610.h index baace75a02..783eece271 100644 --- a/include/configs/sei610.h +++ b/include/configs/sei610.h @@ -14,12 +14,15 @@
#define PARTS_DEFAULT \ "uuid_disk=${uuid_gpt_disk};" \ - "name=boot,size=64M,bootable,uuid=${uuid_gpt_boot};" \ - "name=logo,size=2M,uuid=" LOGO_UUID \ + "name=logo,start=512K,size=2M,uuid=" LOGO_UUID \ + "name=misc,size=512K,uuid=${uuid_gpt_misc};" \ + "name=dtbo,size=8M,uuid=${uuid_gpt_dtbo};" \ + "name=vbmeta,size=512K,uuid=${uuid_gpt_vbmeta};" \ + "name=boot,size=32M,bootable,uuid=${uuid_gpt_boot};" \ + "name=recovery,size=32M,uuid=${uuid_gpt_recovery};" \ "name=cache,size=256M,uuid=${uuid_gpt_cache};" \ - "name=system,size=1536M,uuid=${uuid_gpt_system};" \ - "name=vendor,size=256M,uuid=${uuid_gpt_vendor};" \ - "name=userdata,size=12795M,uuid=${uuid_gpt_userdata};" \ + "name=super,size=2304M,uuid=${uuid_gpt_super};" \ + "name=userdata,size=12274M,uuid=${uuid_gpt_userdata};" \ "name=rootfs,size=-,uuid=" ROOT_UUID
- AVB for Android Verified Boot support
- ADTIMG for merging DTBOs
- ABOOTIMG for extracting Android boot image
- "name=misc,size=128K,uuid=${uuid_gpt_misc};" \
- "name=dtbo,size=8M,uuid=${uuid_gpt_dtbo};" \
- "name=vbmeta,size=64K,uuid=${uuid_gpt_vbmeta};" \
- "name=boot,size=32M,bootable,uuid=${uuid_gpt_boot};" \
- "name=recovery,size=32M,uuid=${uuid_gpt_recovery};" \ "name=cache,size=256M,uuid=${uuid_gpt_cache};" \
- "name=super,size=2304M,uuid=${uuid_gpt_super};" \
- "name=userdata,size=4820M,uuid=${uuid_gpt_userdata};" \ "name=rootfs,size=-,uuid=" ROOT_UUID
- "name=logo,start=512K,size=2M,uuid=" LOGO_UUID \
- "name=misc,size=512K,uuid=${uuid_gpt_misc};" \
- "name=vbmeta,size=512K,uuid=${uuid_gpt_vbmeta};" \
- "name=userdata,size=12274M,uuid=${uuid_gpt_userdata};" \ "name=rootfs,size=-,uuid=" ROOT_UUID
- bootloader should pass slot information in case of A/B
- bootloader should perform AVB verification in case it's supported
- bootloader should read and apply dtb overlays from a dtbo partition
My high level concern with this series is that it takes what I assume is the Android-only boot path, and adds further abstractions to it, it looks like. Can we just say "Here is the Android 10 boot path" (since AVB has been around for a while) and here is the generic distro boot path for non-Android? Reading this over it looks like it becomes "Here is the Android + AVB boot path", "Here is the Androidd non-AVB boot path" and then I assume "Here is the generic distro boot path".
I'd also like to know if in general we can make some generic environment macros for "Here is Android AVB boot path", so that we don't need to duplicate this between SoCs. At the very high level, something like the generic distro boot framework, but that does Android instead.
We've been thinking about that, but the Android boot flow doesn't really leave place for other methods.
In our implementation we decided to use the distro_bootcmd helper to setup the different Android boot flow steps, it permits to have a much simpler cmd definition than the other implementation, but makes mixing with the default boot steps more complex (or maybe there is something we can use to enable/disable easily some distro BOOT_TARGET_DEVICES ?)
Neil
Hi Neil, Tom,
Not exactly. Android supports multiple combinations: - non-AVB + no-A/B (legacy, no security). This is usually used for development builds - AVB + no-A/B - AVB + A/B Here, we should be supporting all of the above using compile flags.
I agree. It would be really nice if we could have a generic "boot android" framework
TI has a ti_omap5_common.h which seems to support similar things. However, it does not support the "no-A/B" mode. In that file, we can also see board specific logic: namely the mapping between the $board_name and the dtbo index passed to "abootimg".
Google has another approach via the boot_android[1] command.
We will keep looking into this.
For now, we have mostly worked on cleaning up/syncing the downstream [1] yukawa tree in order to enable AOSP users to rebuild their U-Boot from mainline.
[1] http://patchwork.ozlabs.org/project/uboot/patch/20170402084952.5102-7-deymo@... [2] https://gitlab.com/baylibre/amlogic/atv/u-boot/-/tree/u-boot/v2021.07/integ
Neil
On Fri, Aug 06, 2021 at 05:36:41PM +0200, Mattijs Korpershoek wrote:
Hi Neil, Tom,
development builds
- AVB + no-A/B
- AVB + A/B
I guess I'm a little disappointed that there was no follow up to the question about boot_android. I would like to see the Android support made easier to work with.
Hi Neil, Tom,
development builds
- AVB + no-A/B
- AVB + A/B
We share the same disappointment, the Android boot flow is incredibly hard to implement and test. And completely changes in incompatible ways between new releases.
Neil
Applied to u-boot-amlogic
Thanks, Neil
Mattijs Korpershoek
Neil Armstrong
