[U-Boot] [PATCH 1/5] arm: include: Import unified.h from Linux kernel
Import unified.h from Linux kernel 4.4.6 , commit 0d1912303e54ed1b2a371be0bba51c384dd57326 . This header file contains macros used in libgcc functions in Linux kernel on ARM and will be needed for the libgcc sync.
Since unified.h defines the W(instr) macro, we must drop this from the macro from memcpy.S , otherwise this triggers a warning about symbol redefinition. In order to keep the changes to unified.h to the minimum, tweak arch/arm/lib/Makefile such that it defines new CONFIG_THUMB2_KERNEL macro, which is already checked by unified.h, only if Thumb build is enabled, but the target does not support Thumb2 . This way we can remove ad-hoc -DMEMSET_NO_THUMB_BUILD and -DMEMCPY_NO_THUMB_BUILD and we do not change the logic.
Signed-off-by: Marek Vasut marex@denx.de Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- arch/arm/include/asm/assembler.h | 1 + arch/arm/include/asm/unified.h | 140 +++++++++++++++++++++++++++++++++++++++ arch/arm/lib/Makefile | 6 +- arch/arm/lib/memcpy.S | 6 -- 4 files changed, 144 insertions(+), 9 deletions(-) create mode 100644 arch/arm/include/asm/unified.h
diff --git a/arch/arm/include/asm/assembler.h b/arch/arm/include/asm/assembler.h index 11b80fb..ae1e42f 100644 --- a/arch/arm/include/asm/assembler.h +++ b/arch/arm/include/asm/assembler.h @@ -15,6 +15,7 @@ */
#include <config.h> +#include <asm/unified.h>
/* * Endian independent macros for shifting bytes within registers. diff --git a/arch/arm/include/asm/unified.h b/arch/arm/include/asm/unified.h new file mode 100644 index 0000000..a91ae49 --- /dev/null +++ b/arch/arm/include/asm/unified.h @@ -0,0 +1,140 @@ +/* + * include/asm-arm/unified.h - Unified Assembler Syntax helper macros + * + * Copyright (C) 2008 ARM Limited + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#ifndef __ASM_UNIFIED_H +#define __ASM_UNIFIED_H + +#if defined(__ASSEMBLY__) && defined(CONFIG_ARM_ASM_UNIFIED) + .syntax unified +#endif + +#ifdef CONFIG_CPU_V7M +#define AR_CLASS(x...) +#define M_CLASS(x...) x +#else +#define AR_CLASS(x...) x +#define M_CLASS(x...) +#endif + +#ifdef CONFIG_THUMB2_KERNEL + +#if __GNUC__ < 4 +#error Thumb-2 kernel requires gcc >= 4 +#endif + +/* The CPSR bit describing the instruction set (Thumb) */ +#define PSR_ISETSTATE PSR_T_BIT + +#define ARM(x...) +#define THUMB(x...) x +#ifdef __ASSEMBLY__ +#define W(instr) instr.w +#else +#define WASM(instr) #instr ".w" +#endif + +#else /* !CONFIG_THUMB2_KERNEL */ + +/* The CPSR bit describing the instruction set (ARM) */ +#define PSR_ISETSTATE 0 + +#define ARM(x...) x +#define THUMB(x...) +#ifdef __ASSEMBLY__ +#define W(instr) instr +#else +#define WASM(instr) #instr +#endif + +#endif /* CONFIG_THUMB2_KERNEL */ + +#ifndef CONFIG_ARM_ASM_UNIFIED + +/* + * If the unified assembly syntax isn't used (in ARM mode), these + * macros expand to an empty string + */ +#ifdef __ASSEMBLY__ + .macro it, cond + .endm + .macro itt, cond + .endm + .macro ite, cond + .endm + .macro ittt, cond + .endm + .macro itte, cond + .endm + .macro itet, cond + .endm + .macro itee, cond + .endm + .macro itttt, cond + .endm + .macro ittte, cond + .endm + .macro ittet, cond + .endm + .macro ittee, cond + .endm + .macro itett, cond + .endm + .macro itete, cond + .endm + .macro iteet, cond + .endm + .macro iteee, cond + .endm +#else /* !__ASSEMBLY__ */ +__asm__( +" .macro it, cond\n" +" .endm\n" +" .macro itt, cond\n" +" .endm\n" +" .macro ite, cond\n" +" .endm\n" +" .macro ittt, cond\n" +" .endm\n" +" .macro itte, cond\n" +" .endm\n" +" .macro itet, cond\n" +" .endm\n" +" .macro itee, cond\n" +" .endm\n" +" .macro itttt, cond\n" +" .endm\n" +" .macro ittte, cond\n" +" .endm\n" +" .macro ittet, cond\n" +" .endm\n" +" .macro ittee, cond\n" +" .endm\n" +" .macro itett, cond\n" +" .endm\n" +" .macro itete, cond\n" +" .endm\n" +" .macro iteet, cond\n" +" .endm\n" +" .macro iteee, cond\n" +" .endm\n"); +#endif /* __ASSEMBLY__ */ + +#endif /* CONFIG_ARM_ASM_UNIFIED */ + +#endif /* !__ASM_UNIFIED_H */ diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 7a0fb58..a930744 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -80,8 +80,8 @@ CFLAGS_cache-cp15.o := -marm
AFLAGS_REMOVE_memset.o := -mthumb -mthumb-interwork AFLAGS_REMOVE_memcpy.o := -mthumb -mthumb-interwork -AFLAGS_memset.o := -DMEMSET_NO_THUMB_BUILD -AFLAGS_memcpy.o := -DMEMCPY_NO_THUMB_BUILD - +else +AFLAGS_memset.o := -DCONFIG_THUMB2_KERNEL +AFLAGS_memcpy.o := -DCONFIG_THUMB2_KERNEL endif endif diff --git a/arch/arm/lib/memcpy.S b/arch/arm/lib/memcpy.S index 7d9fc0f..00602e9 100644 --- a/arch/arm/lib/memcpy.S +++ b/arch/arm/lib/memcpy.S @@ -13,12 +13,6 @@ #include <linux/linkage.h> #include <asm/assembler.h>
-#if defined(CONFIG_SYS_THUMB_BUILD) && !defined(MEMCPY_NO_THUMB_BUILD) -#define W(instr) instr.w -#else -#define W(instr) instr -#endif - #define LDR1W_SHIFT 0 #define STR1W_SHIFT 0
Drop the underscore from the filenames of files implementing libgcc routines. There is no functional change. This change is done to make sync with Linux kernel easier.
Signed-off-by: Marek Vasut marex@denx.de Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- arch/arm/lib/Makefile | 6 +++--- arch/arm/lib/{_ashldi3.S => ashldi3.S} | 0 arch/arm/lib/{_ashrdi3.S => ashrdi3.S} | 0 arch/arm/lib/{_divsi3.S => divsi3.S} | 0 arch/arm/lib/{_lshrdi3.S => lshrdi3.S} | 0 arch/arm/lib/{_modsi3.S => modsi3.S} | 0 arch/arm/lib/{_udivsi3.S => udivsi3.S} | 0 arch/arm/lib/{_uldivmod.S => uldivmod.S} | 0 arch/arm/lib/{_umodsi3.S => umodsi3.S} | 0 9 files changed, 3 insertions(+), 3 deletions(-) rename arch/arm/lib/{_ashldi3.S => ashldi3.S} (100%) rename arch/arm/lib/{_ashrdi3.S => ashrdi3.S} (100%) rename arch/arm/lib/{_divsi3.S => divsi3.S} (100%) rename arch/arm/lib/{_lshrdi3.S => lshrdi3.S} (100%) rename arch/arm/lib/{_modsi3.S => modsi3.S} (100%) rename arch/arm/lib/{_udivsi3.S => udivsi3.S} (100%) rename arch/arm/lib/{_uldivmod.S => uldivmod.S} (100%) rename arch/arm/lib/{_umodsi3.S => umodsi3.S} (100%)
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index a930744..7cfe5ab 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -5,9 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-lib-$(CONFIG_USE_PRIVATE_LIBGCC) += _ashldi3.o _ashrdi3.o _divsi3.o \ - _lshrdi3.o _modsi3.o _udivsi3.o _umodsi3.o div0.o \ - _uldivmod.o +lib-$(CONFIG_USE_PRIVATE_LIBGCC) += ashldi3.o ashrdi3.o divsi3.o \ + lshrdi3.o modsi3.o udivsi3.o umodsi3.o div0.o \ + uldivmod.o
ifdef CONFIG_CPU_V7M obj-y += vectors_m.o crt0.o diff --git a/arch/arm/lib/_ashldi3.S b/arch/arm/lib/ashldi3.S similarity index 100% rename from arch/arm/lib/_ashldi3.S rename to arch/arm/lib/ashldi3.S diff --git a/arch/arm/lib/_ashrdi3.S b/arch/arm/lib/ashrdi3.S similarity index 100% rename from arch/arm/lib/_ashrdi3.S rename to arch/arm/lib/ashrdi3.S diff --git a/arch/arm/lib/_divsi3.S b/arch/arm/lib/divsi3.S similarity index 100% rename from arch/arm/lib/_divsi3.S rename to arch/arm/lib/divsi3.S diff --git a/arch/arm/lib/_lshrdi3.S b/arch/arm/lib/lshrdi3.S similarity index 100% rename from arch/arm/lib/_lshrdi3.S rename to arch/arm/lib/lshrdi3.S diff --git a/arch/arm/lib/_modsi3.S b/arch/arm/lib/modsi3.S similarity index 100% rename from arch/arm/lib/_modsi3.S rename to arch/arm/lib/modsi3.S diff --git a/arch/arm/lib/_udivsi3.S b/arch/arm/lib/udivsi3.S similarity index 100% rename from arch/arm/lib/_udivsi3.S rename to arch/arm/lib/udivsi3.S diff --git a/arch/arm/lib/_uldivmod.S b/arch/arm/lib/uldivmod.S similarity index 100% rename from arch/arm/lib/_uldivmod.S rename to arch/arm/lib/uldivmod.S diff --git a/arch/arm/lib/_umodsi3.S b/arch/arm/lib/umodsi3.S similarity index 100% rename from arch/arm/lib/_umodsi3.S rename to arch/arm/lib/umodsi3.S
Sync the libgcc shift operations with Linux kernel 4.4.6 , commit 0d1912303e54ed1b2a371be0bba51c384dd57326 . Syncing these three files is easy, as there is almost no change in them, except the addition of Thumb support.
Signed-off-by: Marek Vasut marex@denx.de Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- arch/arm/lib/ashldi3.S | 12 ++++++++---- arch/arm/lib/ashrdi3.S | 12 ++++++++---- arch/arm/lib/lshrdi3.S | 12 ++++++++---- 3 files changed, 24 insertions(+), 12 deletions(-)
diff --git a/arch/arm/lib/ashldi3.S b/arch/arm/lib/ashldi3.S index 9c34c21..a4f5ebb 100644 --- a/arch/arm/lib/ashldi3.S +++ b/arch/arm/lib/ashldi3.S @@ -5,6 +5,7 @@ */
#include <linux/linkage.h> +#include <asm/assembler.h>
#ifdef __ARMEB__ #define al r1 @@ -14,15 +15,18 @@ #define ah r1 #endif
-.globl __ashldi3 -__ashldi3: +ENTRY(__ashldi3) ENTRY(__aeabi_llsl)
subs r3, r2, #32 rsb ip, r2, #32 movmi ah, ah, lsl r2 movpl ah, al, lsl r3 - orrmi ah, ah, al, lsr ip + ARM( orrmi ah, ah, al, lsr ip ) + THUMB( lsrmi r3, al, ip ) + THUMB( orrmi ah, ah, r3 ) mov al, al, lsl r2 - mov pc, lr + ret lr + +ENDPROC(__ashldi3) ENDPROC(__aeabi_llsl) diff --git a/arch/arm/lib/ashrdi3.S b/arch/arm/lib/ashrdi3.S index c74fd64..c6e1ed3 100644 --- a/arch/arm/lib/ashrdi3.S +++ b/arch/arm/lib/ashrdi3.S @@ -5,6 +5,7 @@ */
-.globl __ashrdi3 -__ashrdi3: +ENTRY(__ashrdi3) ENTRY(__aeabi_lasr)
subs r3, r2, #32 rsb ip, r2, #32 movmi al, al, lsr r2 movpl al, ah, asr r3 - orrmi al, al, ah, lsl ip + ARM( orrmi al, al, ah, lsl ip ) + THUMB( lslmi r3, ah, ip ) + THUMB( orrmi al, al, r3 ) mov ah, ah, asr r2 - mov pc, lr + ret lr + +ENDPROC(__ashrdi3) ENDPROC(__aeabi_lasr) diff --git a/arch/arm/lib/lshrdi3.S b/arch/arm/lib/lshrdi3.S index 1f9b916..9c51141 100644 --- a/arch/arm/lib/lshrdi3.S +++ b/arch/arm/lib/lshrdi3.S @@ -5,6 +5,7 @@ */
-.globl __lshrdi3 -__lshrdi3: +ENTRY(__lshrdi3) ENTRY(__aeabi_llsr)
subs r3, r2, #32 rsb ip, r2, #32 movmi al, al, lsr r2 movpl al, ah, lsr r3 - orrmi al, al, ah, lsl ip + ARM( orrmi al, al, ah, lsl ip ) + THUMB( lslmi r3, ah, ip ) + THUMB( orrmi al, al, r3 ) mov ah, ah, lsr r2 - mov pc, lr + ret lr + +ENDPROC(__lshrdi3) ENDPROC(__aeabi_llsr)
Sync the libgcc 32bit division and modulo operations with Linux 4.4.6 , commit 0d1912303e54ed1b2a371be0bba51c384dd57326 . The functions in these four files are present in lib1funcs.S in Linux, so replace these files with lib1funcs.S from Linux.
Since we do not support stack unwinding, instead of importing the whole asm/unwind.h and all the baggage, this patch defines empty UNWIND() macro in lib1funcs.S . Moreover, to make all of the functions available, define CONFIG_AEABI , which is safe, because U-Boot is always compiled with ARM EABI.
Signed-off-by: Marek Vasut marex@denx.de Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- arch/arm/lib/Makefile | 5 +- arch/arm/lib/divsi3.S | 143 ------------------- arch/arm/lib/lib1funcs.S | 351 +++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/lib/modsi3.S | 99 ------------- arch/arm/lib/udivsi3.S | 95 ------------- arch/arm/lib/umodsi3.S | 90 ------------ 6 files changed, 353 insertions(+), 430 deletions(-) delete mode 100644 arch/arm/lib/divsi3.S create mode 100644 arch/arm/lib/lib1funcs.S delete mode 100644 arch/arm/lib/modsi3.S delete mode 100644 arch/arm/lib/udivsi3.S delete mode 100644 arch/arm/lib/umodsi3.S
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 7cfe5ab..dce6ff9 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -5,9 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-lib-$(CONFIG_USE_PRIVATE_LIBGCC) += ashldi3.o ashrdi3.o divsi3.o \ - lshrdi3.o modsi3.o udivsi3.o umodsi3.o div0.o \ - uldivmod.o +lib-$(CONFIG_USE_PRIVATE_LIBGCC) += ashldi3.o ashrdi3.o lshrdi3.o \ + lib1funcs.o uldivmod.o div0.o
ifdef CONFIG_CPU_V7M obj-y += vectors_m.o crt0.o diff --git a/arch/arm/lib/divsi3.S b/arch/arm/lib/divsi3.S deleted file mode 100644 index c463c68..0000000 --- a/arch/arm/lib/divsi3.S +++ /dev/null @@ -1,143 +0,0 @@ -#include <linux/linkage.h> - -.macro ARM_DIV_BODY dividend, divisor, result, curbit - -#if __LINUX_ARM_ARCH__ >= 5 - - clz \curbit, \divisor - clz \result, \dividend - sub \result, \curbit, \result - mov \curbit, #1 - mov \divisor, \divisor, lsl \result - mov \curbit, \curbit, lsl \result - mov \result, #0 - -#else - - @ Initially shift the divisor left 3 bits if possible, - @ set curbit accordingly. This allows for curbit to be located - @ at the left end of each 4 bit nibbles in the division loop - @ to save one loop in most cases. - tst \divisor, #0xe0000000 - moveq \divisor, \divisor, lsl #3 - moveq \curbit, #8 - movne \curbit, #1 - - @ Unless the divisor is very big, shift it up in multiples of - @ four bits, since this is the amount of unwinding in the main - @ division loop. Continue shifting until the divisor is - @ larger than the dividend. -1: cmp \divisor, #0x10000000 - cmplo \divisor, \dividend - movlo \divisor, \divisor, lsl #4 - movlo \curbit, \curbit, lsl #4 - blo 1b - - @ For very big divisors, we must shift it a bit at a time, or - @ we will be in danger of overflowing. -1: cmp \divisor, #0x80000000 - cmplo \divisor, \dividend - movlo \divisor, \divisor, lsl #1 - movlo \curbit, \curbit, lsl #1 - blo 1b - - mov \result, #0 - -#endif - - @ Division loop -1: cmp \dividend, \divisor - subhs \dividend, \dividend, \divisor - orrhs \result, \result, \curbit - cmp \dividend, \divisor, lsr #1 - subhs \dividend, \dividend, \divisor, lsr #1 - orrhs \result, \result, \curbit, lsr #1 - cmp \dividend, \divisor, lsr #2 - subhs \dividend, \dividend, \divisor, lsr #2 - orrhs \result, \result, \curbit, lsr #2 - cmp \dividend, \divisor, lsr #3 - subhs \dividend, \dividend, \divisor, lsr #3 - orrhs \result, \result, \curbit, lsr #3 - cmp \dividend, #0 @ Early termination? - movnes \curbit, \curbit, lsr #4 @ No, any more bits to do? - movne \divisor, \divisor, lsr #4 - bne 1b - -.endm - -.macro ARM_DIV2_ORDER divisor, order - -#if __LINUX_ARM_ARCH__ >= 5 - - clz \order, \divisor - rsb \order, \order, #31 - -#else - - cmp \divisor, #(1 << 16) - movhs \divisor, \divisor, lsr #16 - movhs \order, #16 - movlo \order, #0 - - cmp \divisor, #(1 << 8) - movhs \divisor, \divisor, lsr #8 - addhs \order, \order, #8 - - cmp \divisor, #(1 << 4) - movhs \divisor, \divisor, lsr #4 - addhs \order, \order, #4 - - cmp \divisor, #(1 << 2) - addhi \order, \order, #3 - addls \order, \order, \divisor, lsr #1 - -#endif - -.endm - - .align 5 -.globl __divsi3 -__divsi3: -ENTRY(__aeabi_idiv) - cmp r1, #0 - eor ip, r0, r1 @ save the sign of the result. - beq Ldiv0 - rsbmi r1, r1, #0 @ loops below use unsigned. - subs r2, r1, #1 @ division by 1 or -1 ? - beq 10f - movs r3, r0 - rsbmi r3, r0, #0 @ positive dividend value - cmp r3, r1 - bls 11f - tst r1, r2 @ divisor is power of 2 ? - beq 12f - - ARM_DIV_BODY r3, r1, r0, r2 - - cmp ip, #0 - rsbmi r0, r0, #0 - mov pc, lr - -10: teq ip, r0 @ same sign ? - rsbmi r0, r0, #0 - mov pc, lr - -11: movlo r0, #0 - moveq r0, ip, asr #31 - orreq r0, r0, #1 - mov pc, lr - -12: ARM_DIV2_ORDER r1, r2 - - cmp ip, #0 - mov r0, r3, lsr r2 - rsbmi r0, r0, #0 - mov pc, lr - -Ldiv0: - - str lr, [sp, #-4]! - bl __div0 - mov r0, #0 @ About as wrong as it could be. - ldr pc, [sp], #4 -ENDPROC(__aeabi_idiv) diff --git a/arch/arm/lib/lib1funcs.S b/arch/arm/lib/lib1funcs.S new file mode 100644 index 0000000..5871dbe --- /dev/null +++ b/arch/arm/lib/lib1funcs.S @@ -0,0 +1,351 @@ +/* + * linux/arch/arm/lib/lib1funcs.S: Optimized ARM division routines + * + * Author: Nicolas Pitre nico@fluxnic.net + * - contributed to gcc-3.4 on Sep 30, 2003 + * - adapted for the Linux kernel on Oct 2, 2003 + */ + +/* Copyright 1995, 1996, 1998, 1999, 2000, 2003 Free Software Foundation, Inc. + + * SPDX-License-Identifier: GPL-2.0+ + */ + + +#include <linux/linkage.h> +#include <asm/assembler.h> + +/* + * U-Boot compatibility bit, define empty UNWIND() macro as, since we + * do not support stack unwinding and define CONFIG_AEABI to make all + * of the functions available without diverging from Linux code. + */ +#ifdef __UBOOT__ +#define UNWIND(x...) +#define CONFIG_AEABI +#endif + +.macro ARM_DIV_BODY dividend, divisor, result, curbit + +#if __LINUX_ARM_ARCH__ >= 5 + + clz \curbit, \divisor + clz \result, \dividend + sub \result, \curbit, \result + mov \curbit, #1 + mov \divisor, \divisor, lsl \result + mov \curbit, \curbit, lsl \result + mov \result, #0 + +#else + + @ Initially shift the divisor left 3 bits if possible, + @ set curbit accordingly. This allows for curbit to be located + @ at the left end of each 4 bit nibbles in the division loop + @ to save one loop in most cases. + tst \divisor, #0xe0000000 + moveq \divisor, \divisor, lsl #3 + moveq \curbit, #8 + movne \curbit, #1 + + @ Unless the divisor is very big, shift it up in multiples of + @ four bits, since this is the amount of unwinding in the main + @ division loop. Continue shifting until the divisor is + @ larger than the dividend. +1: cmp \divisor, #0x10000000 + cmplo \divisor, \dividend + movlo \divisor, \divisor, lsl #4 + movlo \curbit, \curbit, lsl #4 + blo 1b + + @ For very big divisors, we must shift it a bit at a time, or + @ we will be in danger of overflowing. +1: cmp \divisor, #0x80000000 + cmplo \divisor, \dividend + movlo \divisor, \divisor, lsl #1 + movlo \curbit, \curbit, lsl #1 + blo 1b + + mov \result, #0 + +#endif + + @ Division loop +1: cmp \dividend, \divisor + subhs \dividend, \dividend, \divisor + orrhs \result, \result, \curbit + cmp \dividend, \divisor, lsr #1 + subhs \dividend, \dividend, \divisor, lsr #1 + orrhs \result, \result, \curbit, lsr #1 + cmp \dividend, \divisor, lsr #2 + subhs \dividend, \dividend, \divisor, lsr #2 + orrhs \result, \result, \curbit, lsr #2 + cmp \dividend, \divisor, lsr #3 + subhs \dividend, \dividend, \divisor, lsr #3 + orrhs \result, \result, \curbit, lsr #3 + cmp \dividend, #0 @ Early termination? + movnes \curbit, \curbit, lsr #4 @ No, any more bits to do? + movne \divisor, \divisor, lsr #4 + bne 1b + +.endm + + +.macro ARM_DIV2_ORDER divisor, order + +#if __LINUX_ARM_ARCH__ >= 5 + + clz \order, \divisor + rsb \order, \order, #31 + +#else + + cmp \divisor, #(1 << 16) + movhs \divisor, \divisor, lsr #16 + movhs \order, #16 + movlo \order, #0 + + cmp \divisor, #(1 << 8) + movhs \divisor, \divisor, lsr #8 + addhs \order, \order, #8 + + cmp \divisor, #(1 << 4) + movhs \divisor, \divisor, lsr #4 + addhs \order, \order, #4 + + cmp \divisor, #(1 << 2) + addhi \order, \order, #3 + addls \order, \order, \divisor, lsr #1 + +#endif + +.endm + + +.macro ARM_MOD_BODY dividend, divisor, order, spare + +#if __LINUX_ARM_ARCH__ >= 5 + + clz \order, \divisor + clz \spare, \dividend + sub \order, \order, \spare + mov \divisor, \divisor, lsl \order + +#else + + mov \order, #0 + + @ Unless the divisor is very big, shift it up in multiples of + @ four bits, since this is the amount of unwinding in the main + @ division loop. Continue shifting until the divisor is + @ larger than the dividend. +1: cmp \divisor, #0x10000000 + cmplo \divisor, \dividend + movlo \divisor, \divisor, lsl #4 + addlo \order, \order, #4 + blo 1b + + @ For very big divisors, we must shift it a bit at a time, or + @ we will be in danger of overflowing. +1: cmp \divisor, #0x80000000 + cmplo \divisor, \dividend + movlo \divisor, \divisor, lsl #1 + addlo \order, \order, #1 + blo 1b + +#endif + + @ Perform all needed subtractions to keep only the reminder. + @ Do comparisons in batch of 4 first. + subs \order, \order, #3 @ yes, 3 is intended here + blt 2f + +1: cmp \dividend, \divisor + subhs \dividend, \dividend, \divisor + cmp \dividend, \divisor, lsr #1 + subhs \dividend, \dividend, \divisor, lsr #1 + cmp \dividend, \divisor, lsr #2 + subhs \dividend, \dividend, \divisor, lsr #2 + cmp \dividend, \divisor, lsr #3 + subhs \dividend, \dividend, \divisor, lsr #3 + cmp \dividend, #1 + mov \divisor, \divisor, lsr #4 + subges \order, \order, #4 + bge 1b + + tst \order, #3 + teqne \dividend, #0 + beq 5f + + @ Either 1, 2 or 3 comparison/subtractions are left. +2: cmn \order, #2 + blt 4f + beq 3f + cmp \dividend, \divisor + subhs \dividend, \dividend, \divisor + mov \divisor, \divisor, lsr #1 +3: cmp \dividend, \divisor + subhs \dividend, \dividend, \divisor + mov \divisor, \divisor, lsr #1 +4: cmp \dividend, \divisor + subhs \dividend, \dividend, \divisor +5: +.endm + + +ENTRY(__udivsi3) +ENTRY(__aeabi_uidiv) +UNWIND(.fnstart) + + subs r2, r1, #1 + reteq lr + bcc Ldiv0 + cmp r0, r1 + bls 11f + tst r1, r2 + beq 12f + + ARM_DIV_BODY r0, r1, r2, r3 + + mov r0, r2 + ret lr + +11: moveq r0, #1 + movne r0, #0 + ret lr + +12: ARM_DIV2_ORDER r1, r2 + + mov r0, r0, lsr r2 + ret lr + +UNWIND(.fnend) +ENDPROC(__udivsi3) +ENDPROC(__aeabi_uidiv) + +ENTRY(__umodsi3) +UNWIND(.fnstart) + + subs r2, r1, #1 @ compare divisor with 1 + bcc Ldiv0 + cmpne r0, r1 @ compare dividend with divisor + moveq r0, #0 + tsthi r1, r2 @ see if divisor is power of 2 + andeq r0, r0, r2 + retls lr + + ARM_MOD_BODY r0, r1, r2, r3 + + ret lr + +UNWIND(.fnend) +ENDPROC(__umodsi3) + +ENTRY(__divsi3) +ENTRY(__aeabi_idiv) +UNWIND(.fnstart) + + cmp r1, #0 + eor ip, r0, r1 @ save the sign of the result. + beq Ldiv0 + rsbmi r1, r1, #0 @ loops below use unsigned. + subs r2, r1, #1 @ division by 1 or -1 ? + beq 10f + movs r3, r0 + rsbmi r3, r0, #0 @ positive dividend value + cmp r3, r1 + bls 11f + tst r1, r2 @ divisor is power of 2 ? + beq 12f + + ARM_DIV_BODY r3, r1, r0, r2 + + cmp ip, #0 + rsbmi r0, r0, #0 + ret lr + +10: teq ip, r0 @ same sign ? + rsbmi r0, r0, #0 + ret lr + +11: movlo r0, #0 + moveq r0, ip, asr #31 + orreq r0, r0, #1 + ret lr + +12: ARM_DIV2_ORDER r1, r2 + + cmp ip, #0 + mov r0, r3, lsr r2 + rsbmi r0, r0, #0 + ret lr + +UNWIND(.fnend) +ENDPROC(__divsi3) +ENDPROC(__aeabi_idiv) + +ENTRY(__modsi3) +UNWIND(.fnstart) + + cmp r1, #0 + beq Ldiv0 + rsbmi r1, r1, #0 @ loops below use unsigned. + movs ip, r0 @ preserve sign of dividend + rsbmi r0, r0, #0 @ if negative make positive + subs r2, r1, #1 @ compare divisor with 1 + cmpne r0, r1 @ compare dividend with divisor + moveq r0, #0 + tsthi r1, r2 @ see if divisor is power of 2 + andeq r0, r0, r2 + bls 10f + + ARM_MOD_BODY r0, r1, r2, r3 + +10: cmp ip, #0 + rsbmi r0, r0, #0 + ret lr + +UNWIND(.fnend) +ENDPROC(__modsi3) + +#ifdef CONFIG_AEABI + +ENTRY(__aeabi_uidivmod) +UNWIND(.fnstart) +UNWIND(.save {r0, r1, ip, lr} ) + + stmfd sp!, {r0, r1, ip, lr} + bl __aeabi_uidiv + ldmfd sp!, {r1, r2, ip, lr} + mul r3, r0, r2 + sub r1, r1, r3 + ret lr + +UNWIND(.fnend) +ENDPROC(__aeabi_uidivmod) + +ENTRY(__aeabi_idivmod) +UNWIND(.fnstart) +UNWIND(.save {r0, r1, ip, lr} ) + stmfd sp!, {r0, r1, ip, lr} + bl __aeabi_idiv + ldmfd sp!, {r1, r2, ip, lr} + mul r3, r0, r2 + sub r1, r1, r3 + ret lr + +UNWIND(.fnend) +ENDPROC(__aeabi_idivmod) + +#endif + +Ldiv0: +UNWIND(.fnstart) +UNWIND(.pad #4) +UNWIND(.save {lr}) + str lr, [sp, #-8]! + bl __div0 + mov r0, #0 @ About as wrong as it could be. + ldr pc, [sp], #8 +UNWIND(.fnend) +ENDPROC(Ldiv0) diff --git a/arch/arm/lib/modsi3.S b/arch/arm/lib/modsi3.S deleted file mode 100644 index c5e1c22..0000000 --- a/arch/arm/lib/modsi3.S +++ /dev/null @@ -1,99 +0,0 @@ -#include <linux/linkage.h> - -.macro ARM_MOD_BODY dividend, divisor, order, spare - -#if __LINUX_ARM_ARCH__ >= 5 - - clz \order, \divisor - clz \spare, \dividend - sub \order, \order, \spare - mov \divisor, \divisor, lsl \order - -#else - - mov \order, #0 - - @ Unless the divisor is very big, shift it up in multiples of - @ four bits, since this is the amount of unwinding in the main - @ division loop. Continue shifting until the divisor is - @ larger than the dividend. -1: cmp \divisor, #0x10000000 - cmplo \divisor, \dividend - movlo \divisor, \divisor, lsl #4 - addlo \order, \order, #4 - blo 1b - - @ For very big divisors, we must shift it a bit at a time, or - @ we will be in danger of overflowing. -1: cmp \divisor, #0x80000000 - cmplo \divisor, \dividend - movlo \divisor, \divisor, lsl #1 - addlo \order, \order, #1 - blo 1b - -#endif - - @ Perform all needed substractions to keep only the reminder. - @ Do comparisons in batch of 4 first. - subs \order, \order, #3 @ yes, 3 is intended here - blt 2f - -1: cmp \dividend, \divisor - subhs \dividend, \dividend, \divisor - cmp \dividend, \divisor, lsr #1 - subhs \dividend, \dividend, \divisor, lsr #1 - cmp \dividend, \divisor, lsr #2 - subhs \dividend, \dividend, \divisor, lsr #2 - cmp \dividend, \divisor, lsr #3 - subhs \dividend, \dividend, \divisor, lsr #3 - cmp \dividend, #1 - mov \divisor, \divisor, lsr #4 - subges \order, \order, #4 - bge 1b - - tst \order, #3 - teqne \dividend, #0 - beq 5f - - @ Either 1, 2 or 3 comparison/substractions are left. -2: cmn \order, #2 - blt 4f - beq 3f - cmp \dividend, \divisor - subhs \dividend, \dividend, \divisor - mov \divisor, \divisor, lsr #1 -3: cmp \dividend, \divisor - subhs \dividend, \dividend, \divisor - mov \divisor, \divisor, lsr #1 -4: cmp \dividend, \divisor - subhs \dividend, \dividend, \divisor -5: -.endm - - .align 5 -ENTRY(__modsi3) - cmp r1, #0 - beq Ldiv0 - rsbmi r1, r1, #0 @ loops below use unsigned. - movs ip, r0 @ preserve sign of dividend - rsbmi r0, r0, #0 @ if negative make positive - subs r2, r1, #1 @ compare divisor with 1 - cmpne r0, r1 @ compare dividend with divisor - moveq r0, #0 - tsthi r1, r2 @ see if divisor is power of 2 - andeq r0, r0, r2 - bls 10f - - ARM_MOD_BODY r0, r1, r2, r3 - -10: cmp ip, #0 - rsbmi r0, r0, #0 - mov pc, lr -ENDPROC(__modsi3) - -Ldiv0: - - str lr, [sp, #-4]! - bl __div0 - mov r0, #0 @ About as wrong as it could be. - ldr pc, [sp], #4 diff --git a/arch/arm/lib/udivsi3.S b/arch/arm/lib/udivsi3.S deleted file mode 100644 index 3b653be..0000000 --- a/arch/arm/lib/udivsi3.S +++ /dev/null @@ -1,95 +0,0 @@ -#include <linux/linkage.h> - -/* # 1 "libgcc1.S" */ -@ libgcc1 routines for ARM cpu. -@ Division routines, written by Richard Earnshaw, (rearnsha@armltd.co.uk) -dividend .req r0 -divisor .req r1 -result .req r2 -curbit .req r3 -/* ip .req r12 */ -/* sp .req r13 */ -/* lr .req r14 */ -/* pc .req r15 */ - .text - .globl __udivsi3 - .type __udivsi3 ,function - .globl __aeabi_uidiv - .type __aeabi_uidiv ,function - .align 0 - __udivsi3: - __aeabi_uidiv: - cmp divisor, #0 - beq Ldiv0 - mov curbit, #1 - mov result, #0 - cmp dividend, divisor - bcc Lgot_result -Loop1: - @ Unless the divisor is very big, shift it up in multiples of - @ four bits, since this is the amount of unwinding in the main - @ division loop. Continue shifting until the divisor is - @ larger than the dividend. - cmp divisor, #0x10000000 - cmpcc divisor, dividend - movcc divisor, divisor, lsl #4 - movcc curbit, curbit, lsl #4 - bcc Loop1 -Lbignum: - @ For very big divisors, we must shift it a bit at a time, or - @ we will be in danger of overflowing. - cmp divisor, #0x80000000 - cmpcc divisor, dividend - movcc divisor, divisor, lsl #1 - movcc curbit, curbit, lsl #1 - bcc Lbignum -Loop3: - @ Test for possible subtractions, and note which bits - @ are done in the result. On the final pass, this may subtract - @ too much from the dividend, but the result will be ok, since the - @ "bit" will have been shifted out at the bottom. - cmp dividend, divisor - subcs dividend, dividend, divisor - orrcs result, result, curbit - cmp dividend, divisor, lsr #1 - subcs dividend, dividend, divisor, lsr #1 - orrcs result, result, curbit, lsr #1 - cmp dividend, divisor, lsr #2 - subcs dividend, dividend, divisor, lsr #2 - orrcs result, result, curbit, lsr #2 - cmp dividend, divisor, lsr #3 - subcs dividend, dividend, divisor, lsr #3 - orrcs result, result, curbit, lsr #3 - cmp dividend, #0 @ Early termination? - movnes curbit, curbit, lsr #4 @ No, any more bits to do? - movne divisor, divisor, lsr #4 - bne Loop3 -Lgot_result: - mov r0, result - mov pc, lr -Ldiv0: - str lr, [sp, #-4]! - bl __div0 (PLT) - mov r0, #0 @ about as wrong as it could be - ldmia sp!, {pc} - .size __udivsi3 , . - __udivsi3 - -ENTRY(__aeabi_uidivmod) - - stmfd sp!, {r0, r1, ip, lr} - bl __aeabi_uidiv - ldmfd sp!, {r1, r2, ip, lr} - mul r3, r0, r2 - sub r1, r1, r3 - mov pc, lr -ENDPROC(__aeabi_uidivmod) - -ENTRY(__aeabi_idivmod) - - stmfd sp!, {r0, r1, ip, lr} - bl __aeabi_idiv - ldmfd sp!, {r1, r2, ip, lr} - mul r3, r0, r2 - sub r1, r1, r3 - mov pc, lr -ENDPROC(__aeabi_idivmod) diff --git a/arch/arm/lib/umodsi3.S b/arch/arm/lib/umodsi3.S deleted file mode 100644 index b166737..0000000 --- a/arch/arm/lib/umodsi3.S +++ /dev/null @@ -1,90 +0,0 @@ -#include <linux/linkage.h> - -/* # 1 "libgcc1.S" */ -@ libgcc1 routines for ARM cpu. -@ Division routines, written by Richard Earnshaw, (rearnsha@armltd.co.uk) -/* # 145 "libgcc1.S" */ -dividend .req r0 -divisor .req r1 -overdone .req r2 -curbit .req r3 -/* ip .req r12 */ -/* sp .req r13 */ -/* lr .req r14 */ -/* pc .req r15 */ - .text - .type __umodsi3 ,function - .align 0 - ENTRY(__umodsi3) - cmp divisor, #0 - beq Ldiv0 - mov curbit, #1 - cmp dividend, divisor - movcc pc, lr -Loop1: - @ Unless the divisor is very big, shift it up in multiples of - @ four bits, since this is the amount of unwinding in the main - @ division loop. Continue shifting until the divisor is - @ larger than the dividend. - cmp divisor, #0x10000000 - cmpcc divisor, dividend - movcc divisor, divisor, lsl #4 - movcc curbit, curbit, lsl #4 - bcc Loop1 -Lbignum: - @ For very big divisors, we must shift it a bit at a time, or - @ we will be in danger of overflowing. - cmp divisor, #0x80000000 - cmpcc divisor, dividend - movcc divisor, divisor, lsl #1 - movcc curbit, curbit, lsl #1 - bcc Lbignum -Loop3: - @ Test for possible subtractions. On the final pass, this may - @ subtract too much from the dividend, so keep track of which - @ subtractions are done, we can fix them up afterwards... - mov overdone, #0 - cmp dividend, divisor - subcs dividend, dividend, divisor - cmp dividend, divisor, lsr #1 - subcs dividend, dividend, divisor, lsr #1 - orrcs overdone, overdone, curbit, ror #1 - cmp dividend, divisor, lsr #2 - subcs dividend, dividend, divisor, lsr #2 - orrcs overdone, overdone, curbit, ror #2 - cmp dividend, divisor, lsr #3 - subcs dividend, dividend, divisor, lsr #3 - orrcs overdone, overdone, curbit, ror #3 - mov ip, curbit - cmp dividend, #0 @ Early termination? - movnes curbit, curbit, lsr #4 @ No, any more bits to do? - movne divisor, divisor, lsr #4 - bne Loop3 - @ Any subtractions that we should not have done will be recorded in - @ the top three bits of "overdone". Exactly which were not needed - @ are governed by the position of the bit, stored in ip. - @ If we terminated early, because dividend became zero, - @ then none of the below will match, since the bit in ip will not be - @ in the bottom nibble. - ands overdone, overdone, #0xe0000000 - moveq pc, lr @ No fixups needed - tst overdone, ip, ror #3 - addne dividend, dividend, divisor, lsr #3 - tst overdone, ip, ror #2 - addne dividend, dividend, divisor, lsr #2 - tst overdone, ip, ror #1 - addne dividend, dividend, divisor, lsr #1 - mov pc, lr -Ldiv0: - str lr, [sp, #-4]! - bl __div0 (PLT) - mov r0, #0 @ about as wrong as it could be - ldmia sp!, {pc} - .size __umodsi3 , . - __umodsi3 -/* # 320 "libgcc1.S" */ -/* # 421 "libgcc1.S" */ -/* # 433 "libgcc1.S" */ -/* # 456 "libgcc1.S" */ -/* # 500 "libgcc1.S" */ -/* # 580 "libgcc1.S" */ -ENDPROC(__umodsi3)
This patch decouples U-Boot binary from the toolchain on systems where private libgcc is available. Instead of pulling in functions provided by the libgcc from the toolchain, U-Boot will use it's own set of libgcc functions. These functions are usually imported from Linux kernel, which also uses it's own libgcc functions instead of the ones provided by the toolchain.
This patch solves a rather common problem. The toolchain can usually generate code for many variants of target architecture and often even different endianness. The libgcc on the other hand is usually compiled for one particular configuration and the functions provided by it may or may not be suited for use in U-Boot. This can manifest in two ways, either the U-Boot fails to compile altogether and linker will complain or, in the much worse case, the resulting U-Boot will build, but will misbehave in very subtle and hard to debug ways.
Signed-off-by: Marek Vasut marex@denx.de Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- lib/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/lib/Kconfig b/lib/Kconfig index 7a45336..2b911bc 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -14,6 +14,7 @@ config HAVE_PRIVATE_LIBGCC config USE_PRIVATE_LIBGCC bool "Use private libgcc" depends on HAVE_PRIVATE_LIBGCC + default y if HAVE_PRIVATE_LIBGCC help This option allows you to use the built-in libgcc implementation of U-Boot instead of the one privided by the compiler.
Hello Marek,
I don't think using private libgcc by default is a good idea.
U-Boot's private libgcc is not a feature of U-Boot, but a fix for some cases where a target cannot properly link with the libgcc provided by the (specific release of the) GCC toolchain in use. Using private libgcc to other cases than these does not fix or improve anything; those other cases were working and did not require any fix in this respect.
Also, libgcc is not a standalone project that can be frozen, forked or improved freely; it is an internal component of the GCC toolchain. No standard defines what libgcc is or should be, and we have no control over the 'contract' between GCC-emitted code and libgcc. The GCC project may decide to change that contract at any time, and produce a new toolchain and a new libgcc. Using our private libgcc by default will cause all targets to break for no good reason. We've already been bitten by internal GCC changes on which we were dependent; adding more such dependency is not the way to go IMO.
If we truly fear that GCC is *generally* unable to properly build our targets due to its libgcc, then we should not only "snapshot and fix" libgcc; we should "snapshot and fix" the whole GCC toolchain, to make sure we keep a consistent copy of it. I don't think that would be a viable move.
And if we don't believe that GCC is generally unable to properly build U-Boot, then we should always use it as provided unless it is provably buggy, in which case if a private libgcc is a fix, then by all means we should use it.
And whenever we find that a GCC toolchain is provably buggy, we should raise a bug, either to the toolchain provider if the issue is only with a given binary release (e.g. mismatched or badly supported endianness), or to the GCC project if the bug is inherent to GCC (e.g. generation of non-supported opcodes for a given arch/cpu).
Amicalement,
On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert ARIBAUD wrote:
Hello Marek,
This isn't true, exactly. If using clang for example everyone needs to enable this code. We're also using -fno-builtin -ffreestanding which should limit the amount of interference from the toolchain. And we get that.
Ah, but this shows part of the problem. We don't need "libgcc" as in "the thing which provides gcc'isms". We need "libgcc" as in "the thing which provides AEABI functions". Today we get these from libgcc but we run into cases where this doesn't work quite right (toolchain fun) or simply aren't available (again, clang). So I am in favour of re-syncing with this part of the kernel and mirroring the decision to always include these functions, again, like the kernel does.
Hello Tom,
Hello Marek,
You mean clang does not produce self-sustained binaries?
Not sure I'm getting what you mean. For one thing, I don't see that AEABI specifies any functions. Also, I don't see where it is established that U-Boot "needs AEABI functions". Finally, I don't see that libgcc is a standalone project aiming at providing AEABI functions.
If we are using libgcc for providing AEABI services then we are using it wrong. Its role is to support GCC-generated code.
Could you give me an example of this "need for [an] AEABI function"?
-- Tom
Amicalement,
On Wed, Mar 23, 2016 at 06:08:45PM +0100, Albert ARIBAUD wrote:
Hello Tom,
Hello Marek,
clang does not provide "libgcc", so there's no -lgcc providing all of the functions that are (today) in: _ashldi3.S _ashrdi3.S _divsi3.S _lshrdi3.S _modsi3.S _udivsi3.S _umodsi3.S div0.S _uldivmod.S which aside from __modsi3 and __umodsi3 are all __aeabi_xxx
Well, lets unpack things in the order that it matters. If we kludge the toplevel Makefile to not set CONFIG_USE_PRIVATE_LIBGCC nor link in libgcc on ARM, and build work_92105 with an arm-none-eabi GCC we start failing on: arch/arm/cpu/arm926ejs/built-in.o: In function `print_cpuinfo': /home/trini/work/u-boot/u-boot/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c:64: undefined reference to `__aeabi_uidiv' /home/trini/work/u-boot/u-boot/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c:65: undefined reference to `__aeabi_uidiv' /home/trini/work/u-boot/u-boot/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c:66: undefined reference to `__aeabi_uidiv' and fail on and on from there (I see several pages). Line 64-66 are: printf("CPU clock: %uMHz\n", get_hclk_pll_rate() / 1000000); printf("AHB bus clock: %uMHz\n", get_hclk_clk_rate() / 1000000); printf("Peripheral clock: %uMHz\n", get_periph_clk_rate() / 1000000);
So, despite being "freestanding" and requring "no builtins" we still requiring the toolchain to give us these functions separately, or just bring them ourself. Note that ARC, SH and MIPS all always follow the kernel model of just providing these bits of functionality rather than rely on getting just those things from libgcc.
See above. And yes, we're using libgcc wrong by IMHO using it at all. We don't need it and opt out of it for almost everything, except for the above.
Hello Tom,
Hello Marek,
There is also _udivmoddi4 pulled from libgcc for 64-bit division since we switched to 64-bit all around ARM. It comes from clock calculations for video, e.g. from drivers/video/ipu_common.c for i.MX6.
The problem is most of i.MX6 toolchains (including my own) are built with "-mfloat-abi=hard -mfpu=vfpv3-d16" or something similar so it fails to link with the rest of U-Boot that is unconditionally built with "-msoft-float" for unknown reason.
We should either add 64-bit functions to private libgcc so it is built and linked properly with whatever ABI are nailed down in arch/arm/config.mk or somehow allow to specify specific ABI flags in board configuration or wherever else.
I do use a hack like this
=== Cut === diff --git a/arch/arm/config.mk b/arch/arm/config.mk index 9af6c37..a96868c 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -16,8 +16,14 @@ endif LDFLAGS_FINAL += --gc-sections PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections \ -fno-common -ffixed-r9 -PLATFORM_RELFLAGS += $(call cc-option, -msoft-float) \ - $(call cc-option,-mshort-load-bytes,$(call cc-option,-malignment-traps,)) + +ifeq ($(CONFIG_SYS_HARDFP_VFP_BUILD),y) +PLATFORM_RELFLAGS += $(call cc-option,-mfloat-abi=hard,$(call cc-option,-mfpu=vfpv3-d16,)) +else +PLATFORM_RELFLAGS += $(call cc-option, -msoft-float) +endif + +PLATFORM_RELFLAGS += $(call cc-option,-mshort-load-bytes,$(call cc-option,-malignment-traps,)) === Cut ===
but this is not very nice so it won't go in the main tree for sure.
A smarter, more elegant way should be invented so the entire U-Boot could be built with ABI flags matched those used for toolchain build.
Or _ALL_ libgcc functions should be made U-Boot private so no toolchain parts are used at all.
--- ****************************************************************** * KSI@home KOI8 Net < > The impossible we do immediately. * * Las Vegas NV, USA < > Miracles require 24-hour notice. * ******************************************************************
Hello Tom,
Hello Marek,
Well, this is an example of why we both don't want libgcc ever nor do we want to overly expand what we do offer. In this case isn't it an example of something that should be using lldiv/do_div/etc?
Hello Tom,
Hello Marek,
On Sun, 20 Mar 2016 17:15:34 +0100, Marek Vasut marex@denx.de wrote: > This patch decouples U-Boot binary from the toolchain on systems where > private libgcc is available. Instead of pulling in functions provided > by the libgcc from the toolchain, U-Boot will use it's own set of libgcc > functions. These functions are usually imported from Linux kernel, which > also uses it's own libgcc functions instead of the ones provided by the > toolchain. > > This patch solves a rather common problem. The toolchain can usually > generate code for many variants of target architecture and often even > different endianness. The libgcc on the other hand is usually compiled > for one particular configuration and the functions provided by it may > or may not be suited for use in U-Boot. This can manifest in two ways, > either the U-Boot fails to compile altogether and linker will complain > or, in the much worse case, the resulting U-Boot will build, but will > misbehave in very subtle and hard to debug ways.
It is. However do_div does not help for some reason -- here is an excerpt from drivers/video/ipu_common.c (one of several places where do_div() is used) that pulls _udivmoddi4 from toolchain anyways:
=== Cut === static void ipu_pixel_clk_recalc(struct clk *clk) { u32 div; u64 final_rate = (unsigned long long)clk->parent->rate * 16;
div = __raw_readl(DI_BS_CLKGEN0(clk->id)); debug("read BS_CLKGEN0 div:%d, final_rate:%lld, prate:%ld\n", div, final_rate, clk->parent->rate);
clk->rate = 0; if (div != 0) { do_div(final_rate, div); clk->rate = final_rate; } } === Cut ===
Without the above hack this results in link failure:
=== Cut === arm-linux-gnueabi-ld.bfd: error: /opt/arm-linux-toolchain/lib/gcc/arm-linux-gnueabi/5.3.0/libgcc.a(_udivmoddi4.o) uses VFP register arguments, u-boot does not arm-linux-gnueabi-ld.bfd: failed to merge target specific data of file /opt/arm-linux-toolchain/lib/gcc/arm-linux-gnueabi/5.3.0/libgcc.a(_udivmoddi4.o) Makefile:1191: recipe for target 'u-boot' failed make: *** [u-boot] Error 1 === Cut ===
U-Boot built with "-mfloat-abi=hard -mfpu=vfpv3-d16" pulls whatever it requires from toolchain libgcc and works fine, no problems.
Hello Tom,
Hello Marek,
I haven't seen the _udivmoddi4 emitted in my tests. Linux's libgcc copy also doesn't implement the function. Which toolchain do you use and which target did you compile?
Hello Tom,
On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert ARIBAUD wrote: > Hello Marek, > > On Sun, 20 Mar 2016 17:15:34 +0100, Marek Vasut marex@denx.de wrote: >> This patch decouples U-Boot binary from the toolchain on systems where >> private libgcc is available. Instead of pulling in functions provided >> by the libgcc from the toolchain, U-Boot will use it's own set of libgcc >> functions. These functions are usually imported from Linux kernel, which >> also uses it's own libgcc functions instead of the ones provided by the >> toolchain. >> >> This patch solves a rather common problem. The toolchain can usually >> generate code for many variants of target architecture and often even >> different endianness. The libgcc on the other hand is usually compiled >> for one particular configuration and the functions provided by it may >> or may not be suited for use in U-Boot. This can manifest in two ways, >> either the U-Boot fails to compile altogether and linker will complain >> or, in the much worse case, the resulting U-Boot will build, but will >> misbehave in very subtle and hard to debug ways. > > I don't think using private libgcc by default is a good idea. > > U-Boot's private libgcc is not a feature of U-Boot, but a fix for some > cases where a target cannot properly link with the libgcc provided by > the (specific release of the) GCC toolchain in use. Using private libgcc > to other cases than these does not fix or improve anything; those > other cases were working and did not require any fix in this respect.
I'm using my own armv7hl-linux-gnueabi toolchain built for hard float. Linux arm libgcc does have arch/arm/lib/div64.S file that provides __do_div64() function that is used by do_div() from include/asm/div64.h for 32-bit ARM platform. Sure, arm64 has neither div64.h nor div64.S. We _DO_ have div64.h (that is totally different from what Linux provides) but no div64.S in arch/arm/lib.
The target is a custom board based on Freescale/NXP mx6qsabresd (I'm not ready to submit it to the main tree yet) so sabresd should produce the same result. Just have IPU enabled.
Hello Tom,
On Wed, 23 Mar 2016 09:22:38 -0400, Tom Rini trini@konsulko.com wrote: > On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert ARIBAUD wrote: >> Hello Marek, >> >> On Sun, 20 Mar 2016 17:15:34 +0100, Marek Vasut marex@denx.de >> wrote: >>> This patch decouples U-Boot binary from the toolchain on >>> systems where >>> private libgcc is available. Instead of pulling in functions >>> provided >>> by the libgcc from the toolchain, U-Boot will use it's own set >>> of libgcc >>> functions. These functions are usually imported from Linux >>> kernel, which >>> also uses it's own libgcc functions instead of the ones >>> provided by the >>> toolchain. >>> >>> This patch solves a rather common problem. The toolchain can >>> usually >>> generate code for many variants of target architecture and >>> often even >>> different endianness. The libgcc on the other hand is usually >>> compiled >>> for one particular configuration and the functions provided by >>> it may >>> or may not be suited for use in U-Boot. This can manifest in >>> two ways, >>> either the U-Boot fails to compile altogether and linker will >>> complain >>> or, in the much worse case, the resulting U-Boot will build, >>> but will >>> misbehave in very subtle and hard to debug ways. >> >> I don't think using private libgcc by default is a good idea. >> >> U-Boot's private libgcc is not a feature of U-Boot, but a fix >> for some >> cases where a target cannot properly link with the libgcc >> provided by >> the (specific release of the) GCC toolchain in use. Using >> private libgcc >> to other cases than these does not fix or improve anything; those >> other cases were working and did not require any fix in this >> respect. > > This isn't true, exactly. If using clang for example everyone > needs to > enable this code. We're also using -fno-builtin -ffreestanding > which > should limit the amount of interference from the toolchain. And > we get > that.
In that case, we should just import div64.S from Linux on arm32 and be done with it ? Since we now have all the necessary macros thanks to the first four patches in this series, that should be trivial.
What do you think? I can bake a patch real quick, so you can test it ?
Best regards, Marek Vasut
On Wed, Mar 23, 2016 at 06:08:45PM +0100, Albert ARIBAUD wrote: > Hello Tom, > > On Wed, 23 Mar 2016 09:22:38 -0400, Tom Rini trini@konsulko.com > wrote: >> On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert ARIBAUD wrote: >>> Hello Marek, >>> >>> On Sun, 20 Mar 2016 17:15:34 +0100, Marek Vasut marex@denx.de >>> wrote: >>>> This patch decouples U-Boot binary from the toolchain on >>>> systems where >>>> private libgcc is available. Instead of pulling in functions >>>> provided >>>> by the libgcc from the toolchain, U-Boot will use it's own set >>>> of libgcc >>>> functions. These functions are usually imported from Linux >>>> kernel, which >>>> also uses it's own libgcc functions instead of the ones >>>> provided by the >>>> toolchain. >>>> >>>> This patch solves a rather common problem. The toolchain can >>>> usually >>>> generate code for many variants of target architecture and >>>> often even >>>> different endianness. The libgcc on the other hand is usually >>>> compiled >>>> for one particular configuration and the functions provided by >>>> it may >>>> or may not be suited for use in U-Boot. This can manifest in >>>> two ways, >>>> either the U-Boot fails to compile altogether and linker will >>>> complain >>>> or, in the much worse case, the resulting U-Boot will build, >>>> but will >>>> misbehave in very subtle and hard to debug ways. >>> >>> I don't think using private libgcc by default is a good idea. >>> >>> U-Boot's private libgcc is not a feature of U-Boot, but a fix >>> for some >>> cases where a target cannot properly link with the libgcc >>> provided by >>> the (specific release of the) GCC toolchain in use. Using >>> private libgcc >>> to other cases than these does not fix or improve anything; those >>> other cases were working and did not require any fix in this >>> respect. >> >> This isn't true, exactly. If using clang for example everyone >> needs to >> enable this code. We're also using -fno-builtin -ffreestanding >> which >> should limit the amount of interference from the toolchain. And >> we get >> that. > > You mean clang does not produce self-sustained binaries?
Sure I'll test it, no problems. Just bake the patch :)
Import __do_div64 from Linux 4.4.6 , commit 0d1912303e54ed1b2a371be0bba51c384dd57326 on arm32. This function is for some toolchains, which generate _udivmoddi4() for 64 bit division.
Since we do not support stack unwinding, instead of importing the whole asm/unwind.h and all the baggage, this patch defines empty UNWIND() macro.
Signed-off-by: Marek Vasut marex@denx.de Cc: ksi@koi8.net Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- arch/arm/lib/Makefile | 2 +- arch/arm/lib/div64.S | 214 ++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 215 insertions(+), 1 deletion(-) create mode 100644 arch/arm/lib/div64.S
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index dce6ff9..29c2f2b 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -6,7 +6,7 @@ #
lib-$(CONFIG_USE_PRIVATE_LIBGCC) += ashldi3.o ashrdi3.o lshrdi3.o \ - lib1funcs.o uldivmod.o div0.o + lib1funcs.o uldivmod.o div0.o div64.o
ifdef CONFIG_CPU_V7M obj-y += vectors_m.o crt0.o diff --git a/arch/arm/lib/div64.S b/arch/arm/lib/div64.S new file mode 100644 index 0000000..f238bc6 --- /dev/null +++ b/arch/arm/lib/div64.S @@ -0,0 +1,214 @@ +/* + * linux/arch/arm/lib/div64.S + * + * Optimized computation of 64-bit dividend / 32-bit divisor + * + * Author: Nicolas Pitre + * Created: Oct 5, 2003 + * Copyright: Monta Vista Software, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#include <linux/linkage.h> +#include <asm/assembler.h> +#ifdef __UBOOT__ +#define UNWIND(x...) +#endif + +#ifdef __ARMEB__ +#define xh r0 +#define xl r1 +#define yh r2 +#define yl r3 +#else +#define xl r0 +#define xh r1 +#define yl r2 +#define yh r3 +#endif + +/* + * __do_div64: perform a division with 64-bit dividend and 32-bit divisor. + * + * Note: Calling convention is totally non standard for optimal code. + * This is meant to be used by do_div() from include/asm/div64.h only. + * + * Input parameters: + * xh-xl = dividend (clobbered) + * r4 = divisor (preserved) + * + * Output values: + * yh-yl = result + * xh = remainder + * + * Clobbered regs: xl, ip + */ + +ENTRY(__do_div64) +UNWIND(.fnstart) + + @ Test for easy paths first. + subs ip, r4, #1 + bls 9f @ divisor is 0 or 1 + tst ip, r4 + beq 8f @ divisor is power of 2 + + @ See if we need to handle upper 32-bit result. + cmp xh, r4 + mov yh, #0 + blo 3f + + @ Align divisor with upper part of dividend. + @ The aligned divisor is stored in yl preserving the original. + @ The bit position is stored in ip. + +#if __LINUX_ARM_ARCH__ >= 5 + + clz yl, r4 + clz ip, xh + sub yl, yl, ip + mov ip, #1 + mov ip, ip, lsl yl + mov yl, r4, lsl yl + +#else + + mov yl, r4 + mov ip, #1 +1: cmp yl, #0x80000000 + cmpcc yl, xh + movcc yl, yl, lsl #1 + movcc ip, ip, lsl #1 + bcc 1b + +#endif + + @ The division loop for needed upper bit positions. + @ Break out early if dividend reaches 0. +2: cmp xh, yl + orrcs yh, yh, ip + subcss xh, xh, yl + movnes ip, ip, lsr #1 + mov yl, yl, lsr #1 + bne 2b + + @ See if we need to handle lower 32-bit result. +3: cmp xh, #0 + mov yl, #0 + cmpeq xl, r4 + movlo xh, xl + retlo lr + + @ The division loop for lower bit positions. + @ Here we shift remainer bits leftwards rather than moving the + @ divisor for comparisons, considering the carry-out bit as well. + mov ip, #0x80000000 +4: movs xl, xl, lsl #1 + adcs xh, xh, xh + beq 6f + cmpcc xh, r4 +5: orrcs yl, yl, ip + subcs xh, xh, r4 + movs ip, ip, lsr #1 + bne 4b + ret lr + + @ The top part of remainder became zero. If carry is set + @ (the 33th bit) this is a false positive so resume the loop. + @ Otherwise, if lower part is also null then we are done. +6: bcs 5b + cmp xl, #0 + reteq lr + + @ We still have remainer bits in the low part. Bring them up. + +#if __LINUX_ARM_ARCH__ >= 5 + + clz xh, xl @ we know xh is zero here so... + add xh, xh, #1 + mov xl, xl, lsl xh + mov ip, ip, lsr xh + +#else + +7: movs xl, xl, lsl #1 + mov ip, ip, lsr #1 + bcc 7b + +#endif + + @ Current remainder is now 1. It is worthless to compare with + @ divisor at this point since divisor can not be smaller than 3 here. + @ If possible, branch for another shift in the division loop. + @ If no bit position left then we are done. + movs ip, ip, lsr #1 + mov xh, #1 + bne 4b + ret lr + +8: @ Division by a power of 2: determine what that divisor order is + @ then simply shift values around + +#if __LINUX_ARM_ARCH__ >= 5 + + clz ip, r4 + rsb ip, ip, #31 + +#else + + mov yl, r4 + cmp r4, #(1 << 16) + mov ip, #0 + movhs yl, yl, lsr #16 + movhs ip, #16 + + cmp yl, #(1 << 8) + movhs yl, yl, lsr #8 + addhs ip, ip, #8 + + cmp yl, #(1 << 4) + movhs yl, yl, lsr #4 + addhs ip, ip, #4 + + cmp yl, #(1 << 2) + addhi ip, ip, #3 + addls ip, ip, yl, lsr #1 + +#endif + + mov yh, xh, lsr ip + mov yl, xl, lsr ip + rsb ip, ip, #32 + ARM( orr yl, yl, xh, lsl ip ) + THUMB( lsl xh, xh, ip ) + THUMB( orr yl, yl, xh ) + mov xh, xl, lsl ip + mov xh, xh, lsr ip + ret lr + + @ eq -> division by 1: obvious enough... +9: moveq yl, xl + moveq yh, xh + moveq xh, #0 + reteq lr +UNWIND(.fnend) + +UNWIND(.fnstart) +UNWIND(.pad #4) +UNWIND(.save {lr}) +Ldiv0_64: + @ Division by 0: + str lr, [sp, #-8]! + bl __div0 + + @ as wrong as it could be... + mov yl, #0 + mov yh, #0 + mov xh, #0 + ldr pc, [sp], #8 + +UNWIND(.fnend) +ENDPROC(__do_div64)
> On Wed, Mar 23, 2016 at 06:08:45PM +0100, Albert ARIBAUD wrote: >> Hello Tom, >> >> On Wed, 23 Mar 2016 09:22:38 -0400, Tom Rini trini@konsulko.com >> wrote: >>> On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert ARIBAUD wrote: >>>> Hello Marek, >>>> >>>> On Sun, 20 Mar 2016 17:15:34 +0100, Marek Vasut marex@denx.de >>>> wrote: >>>>> This patch decouples U-Boot binary from the toolchain on >>>>> systems where >>>>> private libgcc is available. Instead of pulling in functions >>>>> provided >>>>> by the libgcc from the toolchain, U-Boot will use it's own set >>>>> of libgcc >>>>> functions. These functions are usually imported from Linux >>>>> kernel, which >>>>> also uses it's own libgcc functions instead of the ones >>>>> provided by the >>>>> toolchain. >>>>> >>>>> This patch solves a rather common problem. The toolchain can >>>>> usually >>>>> generate code for many variants of target architecture and >>>>> often even >>>>> different endianness. The libgcc on the other hand is usually >>>>> compiled >>>>> for one particular configuration and the functions provided by >>>>> it may >>>>> or may not be suited for use in U-Boot. This can manifest in >>>>> two ways, >>>>> either the U-Boot fails to compile altogether and linker will >>>>> complain >>>>> or, in the much worse case, the resulting U-Boot will build, >>>>> but will >>>>> misbehave in very subtle and hard to debug ways. >>>> >>>> I don't think using private libgcc by default is a good idea. >>>> >>>> U-Boot's private libgcc is not a feature of U-Boot, but a fix >>>> for some >>>> cases where a target cannot properly link with the libgcc >>>> provided by >>>> the (specific release of the) GCC toolchain in use. Using >>>> private libgcc >>>> to other cases than these does not fix or improve anything; those >>>> other cases were working and did not require any fix in this >>>> respect. >>> >>> This isn't true, exactly. If using clang for example everyone >>> needs to >>> enable this code. We're also using -fno-builtin -ffreestanding >>> which >>> should limit the amount of interference from the toolchain. And >>> we get >>> that. >> >> You mean clang does not produce self-sustained binaries? > > clang does not provide "libgcc", so there's no -lgcc providing > all of > the functions that are (today) in: > _ashldi3.S _ashrdi3.S _divsi3.S _lshrdi3.S _modsi3.S _udivsi3.S > _umodsi3.S div0.S _uldivmod.S > which aside from __modsi3 and __umodsi3 are all __aeabi_xxx
Done, give it a go please.
On Wed, Mar 23, 2016 at 04:02:07PM -0700, Sergey Kubushyn wrote: > On Wed, 23 Mar 2016, Tom Rini wrote: > >> On Wed, Mar 23, 2016 at 06:08:45PM +0100, Albert ARIBAUD wrote: >>> Hello Tom, >>> >>> On Wed, 23 Mar 2016 09:22:38 -0400, Tom Rini trini@konsulko.com >>> wrote: >>>> On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert ARIBAUD wrote: >>>>> Hello Marek, >>>>> >>>>> On Sun, 20 Mar 2016 17:15:34 +0100, Marek Vasut marex@denx.de >>>>> wrote: >>>>>> This patch decouples U-Boot binary from the toolchain on >>>>>> systems where >>>>>> private libgcc is available. Instead of pulling in functions >>>>>> provided >>>>>> by the libgcc from the toolchain, U-Boot will use it's own set >>>>>> of libgcc >>>>>> functions. These functions are usually imported from Linux >>>>>> kernel, which >>>>>> also uses it's own libgcc functions instead of the ones >>>>>> provided by the >>>>>> toolchain. >>>>>> >>>>>> This patch solves a rather common problem. The toolchain can >>>>>> usually >>>>>> generate code for many variants of target architecture and >>>>>> often even >>>>>> different endianness. The libgcc on the other hand is usually >>>>>> compiled >>>>>> for one particular configuration and the functions provided by >>>>>> it may >>>>>> or may not be suited for use in U-Boot. This can manifest in >>>>>> two ways, >>>>>> either the U-Boot fails to compile altogether and linker will >>>>>> complain >>>>>> or, in the much worse case, the resulting U-Boot will build, >>>>>> but will >>>>>> misbehave in very subtle and hard to debug ways. >>>>> >>>>> I don't think using private libgcc by default is a good idea. >>>>> >>>>> U-Boot's private libgcc is not a feature of U-Boot, but a fix >>>>> for some >>>>> cases where a target cannot properly link with the libgcc >>>>> provided by >>>>> the (specific release of the) GCC toolchain in use. Using >>>>> private libgcc >>>>> to other cases than these does not fix or improve anything; those >>>>> other cases were working and did not require any fix in this >>>>> respect. >>>> >>>> This isn't true, exactly. If using clang for example everyone >>>> needs to >>>> enable this code. We're also using -fno-builtin -ffreestanding >>>> which >>>> should limit the amount of interference from the toolchain. And >>>> we get >>>> that. >>> >>> You mean clang does not produce self-sustained binaries? >> >> clang does not provide "libgcc", so there's no -lgcc providing >> all of >> the functions that are (today) in: >> _ashldi3.S _ashrdi3.S _divsi3.S _lshrdi3.S _modsi3.S _udivsi3.S >> _umodsi3.S div0.S _uldivmod.S >> which aside from __modsi3 and __umodsi3 are all __aeabi_xxx > > There is also _udivmoddi4 pulled from libgcc for 64-bit division > since we > switched to 64-bit all around ARM. It comes from clock > calculations for > video, e.g. from drivers/video/ipu_common.c for i.MX6.
Will do first thing tomorrow morning when I'm back at my work desk. Will post the results when done.
OK, it didn't work, _udivmoddi4.o is still being pulled from libgcc. I'm analyzing it right now, will come up with more later today.
On 03/24/2016 12:08 AM, Tom Rini wrote: > On Wed, Mar 23, 2016 at 04:02:07PM -0700, Sergey Kubushyn wrote: > > On Wed, 23 Mar 2016, Tom Rini wrote: > > > > > On Wed, Mar 23, 2016 at 06:08:45PM +0100, Albert ARIBAUD > > > wrote: > > > > Hello Tom, > > > > > > > > On Wed, 23 Mar 2016 09:22:38 -0400, Tom Rini > > > > trini@konsulko.com > > > > wrote: > > > > > On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert ARIBAUD > > > > > wrote: > > > > > > Hello Marek, > > > > > > > > > > > > On Sun, 20 Mar 2016 17:15:34 +0100, Marek Vasut > > > > > > marex@denx.de > > > > > > wrote: > > > > > > > This patch decouples U-Boot binary from the > > > > > > > toolchain on > > > > > > > systems where > > > > > > > private libgcc is available. Instead of pulling in > > > > > > > functions > > > > > > > provided > > > > > > > by the libgcc from the toolchain, U-Boot will use > > > > > > > it's own set > > > > > > > of libgcc > > > > > > > functions. These functions are usually imported from > > > > > > > Linux > > > > > > > kernel, which > > > > > > > also uses it's own libgcc functions instead of the > > > > > > > ones > > > > > > > provided by the > > > > > > > toolchain. > > > > > > > > > > > > > > This patch solves a rather common problem. The > > > > > > > toolchain can > > > > > > > usually > > > > > > > generate code for many variants of target > > > > > > > architecture and > > > > > > > often even > > > > > > > different endianness. The libgcc on the other hand > > > > > > > is usually > > > > > > > compiled > > > > > > > for one particular configuration and the functions > > > > > > > provided by > > > > > > > it may > > > > > > > or may not be suited for use in U-Boot. This can > > > > > > > manifest in > > > > > > > two ways, > > > > > > > either the U-Boot fails to compile altogether and > > > > > > > linker will > > > > > > > complain > > > > > > > or, in the much worse case, the resulting U-Boot > > > > > > > will build, > > > > > > > but will > > > > > > > misbehave in very subtle and hard to debug ways. > > > > > > > > > > > > I don't think using private libgcc by default is a > > > > > > good idea. > > > > > > > > > > > > U-Boot's private libgcc is not a feature of U-Boot, > > > > > > but a fix > > > > > > for some > > > > > > cases where a target cannot properly link with the > > > > > > libgcc > > > > > > provided by > > > > > > the (specific release of the) GCC toolchain in use. > > > > > > Using > > > > > > private libgcc > > > > > > to other cases than these does not fix or improve > > > > > > anything; those > > > > > > other cases were working and did not require any fix > > > > > > in this > > > > > > respect. > > > > > > > > > > This isn't true, exactly. If using clang for example > > > > > everyone > > > > > needs to > > > > > enable this code. We're also using -fno-builtin > > > > > -ffreestanding > > > > > which > > > > > should limit the amount of interference from the > > > > > toolchain. And > > > > > we get > > > > > that. > > > > > > > > You mean clang does not produce self-sustained binaries? > > > > > > clang does not provide "libgcc", so there's no -lgcc > > > providing > > > all of > > > the functions that are (today) in: > > > _ashldi3.S _ashrdi3.S _divsi3.S _lshrdi3.S _modsi3.S > > > _udivsi3.S > > > _umodsi3.S div0.S _uldivmod.S > > > which aside from __modsi3 and __umodsi3 are all __aeabi_xxx > > > > There is also _udivmoddi4 pulled from libgcc for 64-bit > > division > > since we > > switched to 64-bit all around ARM. It comes from clock > > calculations for > > video, e.g. from drivers/video/ipu_common.c for i.MX6. > > Well, this is an example of why we both don't want libgcc ever > nor > do we > want to overly expand what we do offer. In this case isn't it > an > example of something that should be using lldiv/do_div/etc?
OK, it requires a CONFIG_USE_PRIVATE_LIBGCC defined to use private libgcc, my bad -- thought it would be automatic. Having that defined makes build fail complaining about assembly syntax in div64.S:
=== Cut === arch/arm/lib/div64.S: Assembler messages: arch/arm/lib/div64.S:185: Error: bad instruction `arm( orr r2,r2,r1,lsl ip)' arch/arm/lib/div64.S:186: Error: bad instruction `thumb( lsl r1,r1,ip)' arch/arm/lib/div64.S:187: Error: bad instruction `thumb( orr r2,r2,r1)' scripts/Makefile.build:316: recipe for target 'arch/arm/lib/div64.o' failed make[1]: *** [arch/arm/lib/div64.o] Error 1 Makefile:1214: recipe for target 'arch/arm/lib' failed make: *** [arch/arm/lib] Error 2 === Cut ===
Probably something is missing in div64.h? The Linux one is totally different. Digging in right now...
On 03/24/2016 12:47 AM, Sergey Kubushyn wrote: On Thu, 24 Mar 2016, Marek Vasut wrote: > > > > On 03/24/2016 12:08 AM, Tom Rini wrote: > > On Wed, Mar 23, 2016 at 04:02:07PM -0700, Sergey Kubushyn
wrote:
> > > On Wed, 23 Mar 2016, Tom Rini wrote: > > > > > > > > > > On Wed, Mar 23, 2016 at 06:08:45PM +0100,
Albert ARIBAUD > > > > > > > wrote:
> > > > > Hello Tom, > > > > > > > > > > > > > On Wed, 23 Mar 2016 09:22:38 -0400,
Tom Rini > > > > > > > > trini@konsulko.com
> > > > > wrote: > > > > > > On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert
ARIBAUD > > > > > > > > > wrote:
> > > > > > > Hello Marek, > > > > > > > > > > > > > > > > > On Sun, 20 Mar 2016 17:15:34
+0100, Marek Vasut > > > > > > > > > > marex@denx.de
> > > > > > > wrote: > > > > > > > > This patch decouples U-Boot binary from the > > > > > > > > toolchain on > > > > > > > > systems where > > > > > > > > private libgcc is available. Instead of
pulling in > > > > > > > > > > > functions
> > > > > > > > provided > > > > > > > > by the libgcc from the toolchain, U-Boot will
use > > > > > > > > > > > it's own set
> > > > > > > > of libgcc > > > > > > > > functions. These functions are usually
imported from > > > > > > > > > > > Linux
> > > > > > > > kernel, which > > > > > > > > also uses it's own libgcc functions instead of
the > > > > > > > > > > > ones
> > > > > > > > provided by the > > > > > > > > toolchain. > > > > > > > > > > > > > > > > > > > This patch solves a
rather common problem. The > > > > > > > > > > > toolchain can
> > > > > > > > usually > > > > > > > > generate code for many variants of target > > > > > > > > architecture and > > > > > > > > often even > > > > > > > > different endianness. The libgcc on the other
hand > > > > > > > > > > > is usually
> > > > > > > > compiled > > > > > > > > for one particular configuration and the
functions > > > > > > > > > > > provided by
> > > > > > > > it may > > > > > > > > or may not be suited for use in U-Boot. This
can > > > > > > > > > > > manifest in
> > > > > > > > two ways, > > > > > > > > either the U-Boot fails to compile altogether
and > > > > > > > > > > > linker will
> > > > > > > > complain > > > > > > > > or, in the much worse case, the resulting
U-Boot > > > > > > > > > > > will build,
> > > > > > > > but will > > > > > > > > misbehave in very subtle and hard to debug ways. > > > > > > > > > > > > > > > > > I don't think using private
libgcc by default is a > > > > > > > > > > good idea.
not a feature of U-Boot, > > > > > > > > > > but a fix
> > > > > > > for some > > > > > > > cases where a target cannot properly link with
the > > > > > > > > > > libgcc
> > > > > > > provided by > > > > > > > the (specific release of the) GCC toolchain in
use. > > > > > > > > > > Using
> > > > > > > private libgcc > > > > > > > to other cases than these does not fix or
improve > > > > > > > > > > anything; those
fix > > > > > > > > > > in this
> > > > > > > respect. > > > > > > > > > > > > > > > This isn't true, exactly. If
using clang for example > > > > > > > > > everyone
> > > > > > needs to > > > > > > enable this code. We're also using -fno-builtin > > > > > > -ffreestanding > > > > > > which > > > > > > should limit the amount of interference from the > > > > > > toolchain. And > > > > > > we get > > > > > > that. > > > > > > > > > > > > > You mean clang does not produce
there's no -lgcc > > > > > > > providing
> > > > all of > > > > the functions that are (today) in: > > > > _ashldi3.S _ashrdi3.S _divsi3.S _lshrdi3.S _modsi3.S > > > > _udivsi3.S > > > > _umodsi3.S div0.S _uldivmod.S > > > > which aside from __modsi3 and __umodsi3 are all
__aeabi_xxx
for 64-bit > > > > > > division
> > > since we > > > switched to 64-bit all around ARM. It comes from clock > > > calculations for > > > video, e.g. from drivers/video/ipu_common.c for i.MX6. > > > > > > > Well, this is an example of why we both don't
want libgcc ever > > > > > nor
> > do we > > want to overly expand what we do offer. In this case
isn't it > > > > > an
> > example of something that should be using lldiv/do_div/etc? > > > > > I haven't seen the _udivmoddi4 emitted in my tests.
Linux's libgcc > > > > copy
use > > > > and
> which target did you compile? > > > I'm using my own armv7hl-linux-gnueabi toolchain built
for hard > > > float.
have
div64.S > > > in
arch/arm/lib. > In that case, we should just import div64.S from Linux on
arm32 and be
to > > the
test it ?
Are you building the stuff with all of these 5+1 patches ?
> On 03/24/2016 12:47 AM, Sergey Kubushyn wrote: > On Thu, 24 Mar 2016, Marek Vasut wrote: >>>>> On 03/24/2016 12:08 AM, Tom Rini wrote: >>> On Wed, Mar 23, 2016 at 04:02:07PM -0700, Sergey Kubushyn
wrote:
>>>> On Wed, 23 Mar 2016, Tom Rini wrote: >>>>>>>>>>> On Wed, Mar 23, 2016 at 06:08:45PM +0100,
>>>>>> Hello Tom, >>>>>>>>>>>>>> On Wed, 23 Mar 2016 09:22:38 -0400,
>>>>>> wrote: >>>>>>> On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert
>>>>>>>> Hello Marek, >>>>>>>>>>>>>>>>>> On Sun, 20 Mar 2016 17:15:34
>>>>>>>> wrote: >>>>>>>>> This patch decouples U-Boot binary from the > >>>>>>>> toolchain on >>>>>>>>> systems where >>>>>>>>> private libgcc is available. Instead of
>>>>>>>>> provided >>>>>>>>> by the libgcc from the toolchain, U-Boot will
>>>>>>>>> of libgcc >>>>>>>>> functions. These functions are usually
>>>>>>>>> kernel, which >>>>>>>>> also uses it's own libgcc functions instead of
>>>>>>>>> provided by the >>>>>>>>> toolchain. >>>>>>>>>>>>>>>>>>>> This patch solves a
>>>>>>>>> usually >>>>>>>>> generate code for many variants of target > > >>>>>>> architecture and >>>>>>>>> often even >>>>>>>>> different endianness. The libgcc on the other
>>>>>>>>> compiled >>>>>>>>> for one particular configuration and the
>>>>>>>>> it may >>>>>>>>> or may not be suited for use in U-Boot. This
>>>>>>>>> two ways, >>>>>>>>> either the U-Boot fails to compile altogether
>>>>>>>>> complain >>>>>>>>> or, in the much worse case, the resulting
>>>>>>>>> but will >>>>>>>>> misbehave in very subtle and hard to debug ways. >>>>>>>>>>>>>>>>>> I don't think using private
>>>>>>>> for some >>>>>>>> cases where a target cannot properly link with
>>>>>>>> provided by >>>>>>>> the (specific release of the) GCC toolchain in
>>>>>>>> private libgcc >>>>>>>> to other cases than these does not fix or
>>>>>>>> respect. >>>>>>>>>>>>>>>> This isn't true, exactly. If
>>>>>>> needs to >>>>>>> enable this code. We're also using -fno-builtin > >>>>>> -ffreestanding >>>>>>> which >>>>>>> should limit the amount of interference from the > >>>>>> toolchain. And >>>>>>> we get >>>>>>> that. >>>>>>>>>>>>>> You mean clang does not produce
>>>>> all of >>>>> the functions that are (today) in: >>>>> _ashldi3.S _ashrdi3.S _divsi3.S _lshrdi3.S _modsi3.S >>>>> _udivsi3.S >>>>> _umodsi3.S div0.S _uldivmod.S >>>>> which aside from __modsi3 and __umodsi3 are all
__aeabi_xxx
>>>> since we >>>> switched to 64-bit all around ARM. It comes from clock >>>> calculations for >>>> video, e.g. from drivers/video/ipu_common.c for i.MX6. >>>>>>>> Well, this is an example of why we both don't
>>> do we >>> want to overly expand what we do offer. In this case
>>> example of something that should be using lldiv/do_div/etc? >>>>>> I haven't seen the _udivmoddi4 emitted in my tests.
use > > > > and
>> which target did you compile? >>>> I'm using my own armv7hl-linux-gnueabi toolchain built
> Linux > arm libgcc does have arch/arm/lib/div64.S file that provides > __do_div64() > function that is used by do_div() from include/asm/div64.h for > 32-bit > ARM > platform. Sure, arm64 has neither div64.h nor div64.S. We _DO_
have
> div64.h > (that is totally different from what Linux provides) but no
div64.S > > > in
> arch/arm/lib. >> In that case, we should just import div64.S from Linux on
arm32 and be
to > > the
first four patches in this series, that should be trivial. >> What do you think? I can bake a patch real quick, so you can
test it ?
Nope. Aren't those already in U-Boot master? I pulled the latest master and thought those were there. If not would you please send me those 5 patches so I wouldn't have to hunt them through archives?
On Thu, 24 Mar 2016, Marek Vasut wrote: >> On 03/24/2016 12:47 AM, Sergey Kubushyn wrote: >> On Thu, 24 Mar 2016, Marek Vasut wrote: >>>>>> On 03/24/2016 12:08 AM, Tom Rini wrote: >>>> On Wed, Mar 23, 2016 at 04:02:07PM -0700, Sergey Kubushyn
wrote:
>>>>> On Wed, 23 Mar 2016, Tom Rini wrote: >>>>>>>>>>>> On Wed, Mar 23, 2016 at 06:08:45PM +0100,
>>>>>>> Hello Tom, >>>>>>>>>>>>>>> On Wed, 23 Mar 2016 09:22:38 -0400,
>>>>>>> wrote: >>>>>>>> On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert
>>>>>>>>> Hello Marek, >>>>>>>>>>>>>>>>>>> On Sun, 20 Mar 2016 17:15:34
>>>>>>>>> wrote: >>>>>>>>>> This patch decouples U-Boot binary from the > >>>>>>>>> toolchain on >>>>>>>>>> systems where >>>>>>>>>> private libgcc is available. Instead of
>>>>>>>>>> provided >>>>>>>>>> by the libgcc from the toolchain, U-Boot will
>>>>>>>>>> of libgcc >>>>>>>>>> functions. These functions are usually
>>>>>>>>>> kernel, which >>>>>>>>>> also uses it's own libgcc functions instead of
>>>>>>>>>> provided by the >>>>>>>>>> toolchain. >>>>>>>>>>>>>>>>>>>>> This patch solves a
>>>>>>>>>> usually >>>>>>>>>> generate code for many variants of target > > >>>>>>>> architecture and >>>>>>>>>> often even >>>>>>>>>> different endianness. The libgcc on the other
>>>>>>>>>> compiled >>>>>>>>>> for one particular configuration and the
>>>>>>>>>> it may >>>>>>>>>> or may not be suited for use in U-Boot. This
>>>>>>>>>> two ways, >>>>>>>>>> either the U-Boot fails to compile altogether
>>>>>>>>>> complain >>>>>>>>>> or, in the much worse case, the resulting
>>>>>>>>>> but will >>>>>>>>>> misbehave in very subtle and hard to debug ways. >>>>>>>>>>>>>>>>>>> I don't think using private
>>>>>>>>> for some >>>>>>>>> cases where a target cannot properly link with
>>>>>>>>> provided by >>>>>>>>> the (specific release of the) GCC toolchain in
>>>>>>>>> private libgcc >>>>>>>>> to other cases than these does not fix or
>>>>>>>>> respect. >>>>>>>>>>>>>>>>> This isn't true, exactly. If
>>>>>>>> needs to >>>>>>>> enable this code. We're also using -fno-builtin > >>>>>>> -ffreestanding >>>>>>>> which >>>>>>>> should limit the amount of interference from the > >>>>>>> toolchain. And >>>>>>>> we get >>>>>>>> that. >>>>>>>>>>>>>>> You mean clang does not produce
>>>>>> all of >>>>>> the functions that are (today) in: >>>>>> _ashldi3.S _ashrdi3.S _divsi3.S _lshrdi3.S _modsi3.S >>>>>> _udivsi3.S >>>>>> _umodsi3.S div0.S _uldivmod.S >>>>>> which aside from __modsi3 and __umodsi3 are all
__aeabi_xxx
>>>>> since we >>>>> switched to 64-bit all around ARM. It comes from clock >>>>> calculations for >>>>> video, e.g. from drivers/video/ipu_common.c for i.MX6. >>>>>>>>> Well, this is an example of why we both don't
>>>> do we >>>> want to overly expand what we do offer. In this case
>>>> example of something that should be using lldiv/do_div/etc? >>>>>>> I haven't seen the _udivmoddi4 emitted in my tests.
use > > > > and
>>> which target did you compile? >>>>> I'm using my own armv7hl-linux-gnueabi toolchain built
>> Linux >> arm libgcc does have arch/arm/lib/div64.S file that provides >> __do_div64() >> function that is used by do_div() from include/asm/div64.h for >> 32-bit >> ARM >> platform. Sure, arm64 has neither div64.h nor div64.S. We _DO_
have
>> div64.h >> (that is totally different from what Linux provides) but no
div64.S > > > in
>> arch/arm/lib. >>> In that case, we should just import div64.S from Linux on
arm32 and be
to > > the
> first four patches in this series, that should be trivial. >>> What do you think? I can bake a patch real quick, so you can
test it ?
I'll send you all six off-list.
On 03/24/2016 12:54 AM, Sergey Kubushyn wrote: > On Thu, 24 Mar 2016, Marek Vasut wrote: >>> On 03/24/2016 12:47 AM, Sergey Kubushyn wrote: >>> On Thu, 24 Mar 2016, Marek Vasut wrote: >>>>>>> On 03/24/2016 12:08 AM, Tom Rini wrote: >>>>> On Wed, Mar 23, 2016 at 04:02:07PM -0700, Sergey Kubushyn wrote: >>>>>> On Wed, 23 Mar 2016, Tom Rini wrote: >>>>>>>>>>>>> On Wed, Mar 23, 2016 at 06:08:45PM +0100, Albert ARIBAUD > > > > > > > wrote: >>>>>>>> Hello Tom, >>>>>>>>>>>>>>>> On Wed, 23 Mar 2016 09:22:38 -0400, Tom Rini > > > > > > > > trini@konsulko.com >>>>>>>> wrote: >>>>>>>>> On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert ARIBAUD > > > > > > > > > wrote: >>>>>>>>>> Hello Marek, >>>>>>>>>>>>>>>>>>>> On Sun, 20 Mar 2016 17:15:34 +0100, Marek Vasut > > > > > > > > > > marex@denx.de >>>>>>>>>> wrote: >>>>>>>>>>> This patch decouples U-Boot binary from the > >>>>>>>>>> toolchain on >>>>>>>>>>> systems where >>>>>>>>>>> private libgcc is available. Instead of pulling in > > > > > > > > > > > functions >>>>>>>>>>> provided >>>>>>>>>>> by the libgcc from the toolchain, U-Boot will use > > > > > > > > > > > it's own set >>>>>>>>>>> of libgcc >>>>>>>>>>> functions. These functions are usually imported from > > > > > > > > > > > Linux >>>>>>>>>>> kernel, which >>>>>>>>>>> also uses it's own libgcc functions instead of the > > > > > > > > > > > ones >>>>>>>>>>> provided by the >>>>>>>>>>> toolchain. >>>>>>>>>>>>>>>>>>>>>> This patch solves a rather common problem. The > > > > > > > > > > > toolchain can >>>>>>>>>>> usually >>>>>>>>>>> generate code for many variants of target > > >>>>>>>>> architecture and >>>>>>>>>>> often even >>>>>>>>>>> different endianness. The libgcc on the other hand > > > > > > > > > > > is usually >>>>>>>>>>> compiled >>>>>>>>>>> for one particular configuration and the functions > > > > > > > > > > > provided by >>>>>>>>>>> it may >>>>>>>>>>> or may not be suited for use in U-Boot. This can > > > > > > > > > > > manifest in >>>>>>>>>>> two ways, >>>>>>>>>>> either the U-Boot fails to compile altogether and > > > > > > > > > > > linker will >>>>>>>>>>> complain >>>>>>>>>>> or, in the much worse case, the resulting U-Boot > > > > > > > > > > > will build, >>>>>>>>>>> but will >>>>>>>>>>> misbehave in very subtle and hard to debug ways. >>>>>>>>>>>>>>>>>>>> I don't think using private libgcc by default is a > > > > > > > > > > good idea. >>>>>>>>>>>>>>>>>>>> U-Boot's private libgcc is not a feature of U-Boot, > > > > > > > > > > but a fix >>>>>>>>>> for some >>>>>>>>>> cases where a target cannot properly link with the > > > > > > > > > > libgcc >>>>>>>>>> provided by >>>>>>>>>> the (specific release of the) GCC toolchain in use. > > > > > > > > > > Using >>>>>>>>>> private libgcc >>>>>>>>>> to other cases than these does not fix or improve > > > > > > > > > > anything; those >>>>>>>>>> other cases were working and did not require any fix > > > > > > > > > > in this >>>>>>>>>> respect. >>>>>>>>>>>>>>>>>> This isn't true, exactly. If using clang for example > > > > > > > > > everyone >>>>>>>>> needs to >>>>>>>>> enable this code. We're also using -fno-builtin > >>>>>>>> -ffreestanding >>>>>>>>> which >>>>>>>>> should limit the amount of interference from the > >>>>>>>> toolchain. And >>>>>>>>> we get >>>>>>>>> that. >>>>>>>>>>>>>>>> You mean clang does not produce self-sustained binaries? >>>>>>>>>>>>>> clang does not provide "libgcc", so there's no -lgcc > > > > > > > providing >>>>>>> all of >>>>>>> the functions that are (today) in: >>>>>>> _ashldi3.S _ashrdi3.S _divsi3.S _lshrdi3.S _modsi3.S >>>>>>> _udivsi3.S >>>>>>> _umodsi3.S div0.S _uldivmod.S >>>>>>> which aside from __modsi3 and __umodsi3 are all __aeabi_xxx >>>>>>>>>>>> There is also _udivmoddi4 pulled from libgcc for 64-bit > > > > > > division >>>>>> since we >>>>>> switched to 64-bit all around ARM. It comes from clock >>>>>> calculations for >>>>>> video, e.g. from drivers/video/ipu_common.c for i.MX6. >>>>>>>>>> Well, this is an example of why we both don't want libgcc ever > > > > > nor >>>>> do we >>>>> want to overly expand what we do offer. In this case isn't it > > > > > an >>>>> example of something that should be using lldiv/do_div/etc? >>>>>>>> I haven't seen the _udivmoddi4 emitted in my tests. Linux's libgcc > > > > copy >>>> also doesn't implement the function. Which toolchain do you use > > > > and >>>> which target did you compile? >>>>>> I'm using my own armv7hl-linux-gnueabi toolchain built for hard > > > float. >>> Linux >>> arm libgcc does have arch/arm/lib/div64.S file that provides >>> __do_div64() >>> function that is used by do_div() from include/asm/div64.h for >>> 32-bit >>> ARM >>> platform. Sure, arm64 has neither div64.h nor div64.S. We _DO_ have >>> div64.h >>> (that is totally different from what Linux provides) but no div64.S > > > in >>> arch/arm/lib. >>>> In that case, we should just import div64.S from Linux on arm32 and be >> done with it ? Since we now have all the necessary macros thanks to > > the >> first four patches in this series, that should be trivial. >>>> What do you think? I can bake a patch real quick, so you can test it ? >> Sure I'll test it, no problems. Just bake the patch :)
OK, it worked. Now it is time to push it into the official tree :)
Follow-up _series_ to re-sync our 64bit math stuff with the kernel.
> On Wed, Mar 23, 2016 at 06:08:45PM +0100, Albert ARIBAUD wrote: >> Hello Tom, >> >> On Wed, 23 Mar 2016 09:22:38 -0400, Tom Rini trini@konsulko.com >> wrote: >>> On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert ARIBAUD wrote: >>>> Hello Marek, >>>> >>>> On Sun, 20 Mar 2016 17:15:34 +0100, Marek Vasut marex@denx.de >>>> wrote: >>>>> This patch decouples U-Boot binary from the toolchain on >>>>> systems where >>>>> private libgcc is available. Instead of pulling in functions >>>>> provided >>>>> by the libgcc from the toolchain, U-Boot will use it's own set >>>>> of libgcc >>>>> functions. These functions are usually imported from Linux >>>>> kernel, which >>>>> also uses it's own libgcc functions instead of the ones >>>>> provided by the >>>>> toolchain. >>>>> >>>>> This patch solves a rather common problem. The toolchain can >>>>> usually >>>>> generate code for many variants of target architecture and >>>>> often even >>>>> different endianness. The libgcc on the other hand is usually >>>>> compiled >>>>> for one particular configuration and the functions provided by >>>>> it may >>>>> or may not be suited for use in U-Boot. This can manifest in >>>>> two ways, >>>>> either the U-Boot fails to compile altogether and linker will >>>>> complain >>>>> or, in the much worse case, the resulting U-Boot will build, >>>>> but will >>>>> misbehave in very subtle and hard to debug ways. >>>> >>>> I don't think using private libgcc by default is a good idea. >>>> >>>> U-Boot's private libgcc is not a feature of U-Boot, but a fix >>>> for some >>>> cases where a target cannot properly link with the libgcc >>>> provided by >>>> the (specific release of the) GCC toolchain in use. Using >>>> private libgcc >>>> to other cases than these does not fix or improve anything; those >>>> other cases were working and did not require any fix in this >>>> respect. >>> >>> This isn't true, exactly. If using clang for example everyone >>> needs to >>> enable this code. We're also using -fno-builtin -ffreestanding >>> which >>> should limit the amount of interference from the toolchain. And >>> we get >>> that. >> >> You mean clang does not produce self-sustained binaries? > > clang does not provide "libgcc", so there's no -lgcc providing all of > the functions that are (today) in: > _ashldi3.S _ashrdi3.S _divsi3.S _lshrdi3.S _modsi3.S _udivsi3.S > _umodsi3.S div0.S _uldivmod.S > which aside from __modsi3 and __umodsi3 are all __aeabi_xxx
Something tells me this is gonna be one patch , not a series.
Hello Tom,
Hello Tom,
Hello Marek,
(ok, that explains what you mean by AEABI functions -- those are actually not functions defined by the AEABI, but functions that the GCC folks prefixed with __aeabi.)
I do understand that clang does not provide these functions. What I want to understand is how come code compiled by clang would need them unless we introduced that dependency ourselves. clang does produce correct and self-sufficient code when using 64-bit division, right?
Here you are actively setting the conditions for the build to fail since you prevent the linker from using *any* libgcc implentation despite knowing that the generated code requires one.
Do these errors occur when you do not actively prevent any libgcc from linking? Do they occur when you do not prevent GCC's libgcc from linking?
Yes, we do require the toolchain to provide these functions, or more to the point, we need to not prevent the toolchain from building our code as it was designed to; and the toolchain was designed to generate code which refers to symbols defined in a library that must be linked with that code; and the toolchain provides that library as "libgcc". That is exactly my point: the toolchain requires *and provides* libgcc. That's an internal design-induced requirement, and users of the toolchain should not even have to meddle with it unless broken.
Again, I an fine with private libgcc as a fix to specific case of buggy toolchain releases. What I am not fine with is replacing a third party tool's mechanism with our own when this mechanism works.
And I think your view of what libgcc is is wrong. It is not something *we* use, it is something that *GCC* uses by design. And it is not something that we have a choice in using as long as we build with GCC.
We do need libgcc as long as we use GCC. The best proof is the contrived build above, which you can reproduce with *any* GCC build, cross or native, for bare metal code or for a Linux Hello World application: when we actively deprive GCC from the libgcc that it requires and provides, it won't work, exactly like when we remove gas from a car, it won't run.
-- Tom
Amicalement,
On Thu, Mar 24, 2016 at 08:50:03AM +0100, Albert ARIBAUD wrote:
Hello Tom,
Hello Tom,
Hello Marek,
No. For reference, http://infocenter.arm.com/help/topic/com.arm.doc.ihi0043d/IHI0043D_rtabi.pdf and chapter 4 is all about the support library. We are entirely in our right to do either of (a) use the compiler-provided library (b) provide our own implementation of what we need. The kernel opts for (b) and I would like us to follow that as well, consistently, rather than ad-hoc.
Hello Tom,
Hello Tom,
Hello Marek,
Second that. By having _EVERYTHING_ coming from U-Boot we are taking care of _ANY_ possible mismatch between what we are building and pre-built toolchain libraries. Soft float in ARM U-Boot and VFP hard float in most i.MX6/7 toolchains is just one of such prominent examples.
U-Boot is a standalone program not supposed to coexist with any external applications i.e. it is totally self-sufficient, not living in some kind of system environment so it makes perfect sense for it not to use _ANY_ external parts in the final binary.
Hello Sergey,
On Thu, 24 Mar 2016 18:37:52 -0700 (PDT), Sergey Kubushyn ksi@koi8.net wrote:
Granted U-Boot is standalone as a binary system component, but this binary, as the produce of GCC, is dependent on libgcc for more than simply AEABI support, hence my proposal.
Amicalement,
Hello Tom,
Hello Tom,
Hello Tom,
Hello Marek,
Kk, so you did not mean "whatever happens to be aeabi in libgcc, you meant AEABI itself.
But then what you seek is is not a custom libgcc; it is controlled AEABI support library.
I'm fine with that, since, contrary to libgcc, it has an external, stable, definition.
But that is *unrelated* to libgcc, which is not described nor intended as "AEABI support" -- libgcc exists in all architectures, even non-ARM, and provides AEABI in the ARM case by accident -- or, more to the point, by sub-optimal design IMO.
The right design for solving the problems raised by Marek is therefore to rename U-Boot's "custom libgcc" as U-Boot's "AEABI support library" and link U-Boot *first* against this AEABI support library, *then* against GCC's libgcc.
Essentially, this 'hijacks' whatever is AEABI from libgcc while not interfering with what is not AEABI (i.e. what is purely GCC/libgcc internals).
That way,
0) U-Boot gets the stable and controlled AEABI support you want;
1) GCC keeps its somewhat stable but uncontrolled internal "generated code / libgcc" interface;
2) U-Boot won't interfere with non-aeabi-related stuff in GCC+libgcc, i.e. whatever ibgcc-related but non-AEABI-related changes occur in a GCC release, we won't break them changes in non-AEABI ;
3) GCC+libgcc won't interfere with AEABI any more, i.e. whatever AEABI breakages happen in a given GCC toolchain will not break U-Boot.
4) This design works with any ARM toolchain -- which is kind of evident since it separates generic ARM EABI support from specific toolchain support.
Comments welcome.
-- Tom
Amicalement,
On Fri, 25 Mar 2016 07:37:25 +0100, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hello Tom,
That way,
Addition: this does not mean we should get rid of the private libgcc support: it can be useful in case of an issue with the non-aeabi part of libgcc.
Amicalement,
On Fri, Mar 25, 2016 at 07:37:25AM +0100, Albert ARIBAUD wrote:
Hello Tom,
Hello Tom,
Hello Tom,
On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert ARIBAUD wrote: > Hello Marek, > > On Sun, 20 Mar 2016 17:15:34 +0100, Marek Vasut marex@denx.de wrote: > > This patch decouples U-Boot binary from the toolchain on systems where > > private libgcc is available. Instead of pulling in functions provided > > by the libgcc from the toolchain, U-Boot will use it's own set of libgcc > > functions. These functions are usually imported from Linux kernel, which > > also uses it's own libgcc functions instead of the ones provided by the > > toolchain. > > > > This patch solves a rather common problem. The toolchain can usually > > generate code for many variants of target architecture and often even > > different endianness. The libgcc on the other hand is usually compiled > > for one particular configuration and the functions provided by it may > > or may not be suited for use in U-Boot. This can manifest in two ways, > > either the U-Boot fails to compile altogether and linker will complain > > or, in the much worse case, the resulting U-Boot will build, but will > > misbehave in very subtle and hard to debug ways. > > I don't think using private libgcc by default is a good idea. > > U-Boot's private libgcc is not a feature of U-Boot, but a fix for some > cases where a target cannot properly link with the libgcc provided by > the (specific release of the) GCC toolchain in use. Using private libgcc > to other cases than these does not fix or improve anything; those > other cases were working and did not require any fix in this respect.
No. It's not libgcc. We call it libgcc, but we shouldn't. We should call it lib1funcs which is part of the end result of Marek's patches. LLVM has its own library which does this. But it's not about LLVM, either.
Yes, "libgcc" often, but not always, is how U-Boot provides the architecture specific compiler support library functions. Or rather, ARM and PowerPC are the big cases where we rely on -lgcc and everywhere else simply provides the required functionality in U-Boot.
... but we don't need to link vs libgcc (or the compiler-dependent helper library), ever. We can provide all of the functions we need normally. What we need to do, and Marek's patch is fixing about half of the problem, is always provide the required functionality so that we can link ourself. Once we have Marek's patch in, only PowerPC is relying on "libgcc" for some number of functions, and once that's done we can just remove "LIBGCC" from the system.
That way,
- U-Boot gets the stable and controlled AEABI support you want;
To be clear, what I want is for U-Boot to not rely on having a specific configuration of gcc available. We do not build today with various (and correctly configured) toolchains because they are not multi-lib and we do not allow hard float. The massive number of places that tell people to "fix" this problem by just removing -msoft-float is very wrong. And we aren't going to fix that problem by jumping all over stack overflow, we're going to fix that by making it not be a problem.
The problem here is what once we do this we are never using anything from linking against libgcc, so there's no reason to.
Hello Tom,
Hello Tom,
Hello Tom,
Hello Tom,
On Wed, 23 Mar 2016 09:22:38 -0400, Tom Rini trini@konsulko.com wrote: > On Wed, Mar 23, 2016 at 01:53:35PM +0100, Albert ARIBAUD wrote: > > Hello Marek, > > > > On Sun, 20 Mar 2016 17:15:34 +0100, Marek Vasut marex@denx.de wrote: > > > This patch decouples U-Boot binary from the toolchain on systems where > > > private libgcc is available. Instead of pulling in functions provided > > > by the libgcc from the toolchain, U-Boot will use it's own set of libgcc > > > functions. These functions are usually imported from Linux kernel, which > > > also uses it's own libgcc functions instead of the ones provided by the > > > toolchain. > > > > > > This patch solves a rather common problem. The toolchain can usually > > > generate code for many variants of target architecture and often even > > > different endianness. The libgcc on the other hand is usually compiled > > > for one particular configuration and the functions provided by it may > > > or may not be suited for use in U-Boot. This can manifest in two ways, > > > either the U-Boot fails to compile altogether and linker will complain > > > or, in the much worse case, the resulting U-Boot will build, but will > > > misbehave in very subtle and hard to debug ways. > > > > I don't think using private libgcc by default is a good idea. > > > > U-Boot's private libgcc is not a feature of U-Boot, but a fix for some > > cases where a target cannot properly link with the libgcc provided by > > the (specific release of the) GCC toolchain in use. Using private libgcc > > to other cases than these does not fix or improve anything; those > > other cases were working and did not require any fix in this respect. > > This isn't true, exactly. If using clang for example everyone needs to > enable this code. We're also using -fno-builtin -ffreestanding which > should limit the amount of interference from the toolchain. And we get > that.
Well then, I don't know which lib the patch is about. AFAIK, libgcc is described in https://gcc.gnu.org/onlinedocs/gccint/Libgcc.html (which is part of "GCC internals") as follows:
"GCC provides a low-level runtime library, libgcc.a or libgcc_s.so.1 on some platforms. GCC generates calls to routines in this library automatically, whenever it needs to perform some operation that is too complicated to emit inline code for."
To me this means that libgcc provides an interface which is private to the GCC project, and the GCC folks can put in there whatever routine they want if they think it helps keeping emitted code uncomplicated, an then emit calls to this routine in the code they generate.
Do we have the same reading of this?
In that respect, LLVM is indeed no different from GCC (or any toolchain for that matter; a compiler is not bound to emit self-sufficient code and it is common practice to rely on a support library.
That does not change th fact that libgcc, as described above (and I suspect that LLVM uses the same language elements to describe its own support library) is *not* based on a standard and fixed specification, and is *not* designed as a replaceable implementation of such a spec.
I do understand that you are unhappy with some build(s) of the GCC toolchain where libgcc is either unfit for the intended target, or buggy, or both. I also think AEABI support does not belong in libgcc as it is defined in the reference above. But:
- not all builds of the same version of GCC exhibit the issue you are raising. This should at least make us consider what it is with those builds of GCC which exhibit the issue that makes their libgcc unfit for a target which it is supposed to support.
- not all targets in U-Boot are affected. This should at least make us consider that bypassing libgcc by default is not the proper approach as it "fixes a non-bug" for many targets.
Just because some arches decided to bypass libgcc does not make it the right design decision.
Yes we do as long as we use GCC, because we do not know what calls GCC might emit to some routine it provides in the corresponding libgcc. This interface between GCC-emitted code is not public. It is not controlled by us. It is controlled by GCC and by hijacking all of libgcc, we break this interface and force GCC to fail, but that's not a shortcoming of GCC, it is a shortcoming of us.
Again, this is not about functions we need. This is about fonctions the GCC project decides it needs, and decides to generate calls to in code emitted by their compiler and provide and implementation in their libgcc.
Yes, and for the routines that GCC emits calls to in the course of compiling our code, the corresponding functionality is provided by GCC's libgcc.
If we need something because GCC-emitted code calls it, then libgcc provides it.
If we need something because GCC-emitted code calls it but which our toolchain of choice does not provide in its libgcc, then it's a GCC or toolchain build issue, and I'm fine with overriding *that* thing with a custom libgcc -- which we can do without entirely bypassing the toolchain's own libgcc.
Last, if we need something which is not called by GCC-emitted code but explicitly by us, then we should provide that thing, but then there is no reason to put it in libgcc since that thing is no a way for the compiler to avoid emiggint inline code -- which is all what libgcc is about.
Or, with Marek's patch redesigned, we can keep using GCC in a proper way *and* fix exactly what needs to be fixed, for targets that need it fixed, without interfering with a third party tool's internal interfaces.
That way,
If by this you mean you do not want U-Boot not to rely on a given GCC build's defaults such as default endianness, default CPU, default arch, etc, I'm 100% with you. If you mean you want to use any ARM GCC build for any ARM target regardless of whether that build actually has support for it, then I would disagree.
As a simple example: if your ARM GCC build has compiler support for big- and little-endian, but only provides libgcc for little-endian, then I expect that GCC build to succeed in building all little-endian U-Boot ARM targets, but I don't expect it to build big-endian ones, since as a toolchain, it does not support big-endian.
So what you mean is that you're using a toolchain which only supports hard float and want to build non-hard float targets. You're using a tool which is not suited to your needs.
Agreed.
Indeed, but the solution is not to let people use inadequate toolchains. We don't hesitate to tell people not to use too old a U-Boot version; we don't hesitate to tell people not to use too old a GCC version; why hesitate in telling them not to use too inadequate a GCC version? All the more when a simple buildman command wll provide them with a working one.
That's only if you follow this proposal *and* insist on *still* replacing GCC'slibgcc entirely with our custom libgcc by default (and still assume GCC will never ever change anything to its libgcc, too).
My proposal assumes custom libgcc is only used to fix bugs in libgcc (for those versions of GCC that exhibit such bugs) or to support GCC builds when no other GCC toolchain build exists that can build a given target. No bugs and there is an easily accessible GCC build for the target? No need for private libgcc.
(also, custom libgcc should not *replace* libgcc. It should replace *those symbols* in libgcc which require replacing -- the same way that we don't entirely replace libc just because we have better versions of memmove/memcpy/memset.)
-- Tom
Amicalement,
Hi Marek,
On 20 March 2016 at 10:15, Marek Vasut marex@denx.de wrote:
Import unified.h from Linux kernel 4.4.6 , commit 0d1912303e54ed1b2a371be0bba51c384dd57326 . This header file contains macros used in libgcc functions in Linux kernel on ARM and will be needed for the libgcc sync.
Since unified.h defines the W(instr) macro, we must drop this from the macro from memcpy.S , otherwise this triggers a warning about symbol redefinition. In order to keep the changes to unified.h to the minimum, tweak arch/arm/lib/Makefile such that it defines new CONFIG_THUMB2_KERNEL macro, which is already checked by unified.h, only if Thumb build is enabled, but the target does not support Thumb2 . This way we can remove ad-hoc -DMEMSET_NO_THUMB_BUILD and -DMEMCPY_NO_THUMB_BUILD and we do not change the logic.
Signed-off-by: Marek Vasut marex@denx.de Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com
arch/arm/include/asm/assembler.h | 1 + arch/arm/include/asm/unified.h | 140 +++++++++++++++++++++++++++++++++++++++ arch/arm/lib/Makefile | 6 +- arch/arm/lib/memcpy.S | 6 -- 4 files changed, 144 insertions(+), 9 deletions(-) create mode 100644 arch/arm/include/asm/unified.h
Can we use SPDX?
diff --git a/arch/arm/include/asm/assembler.h b/arch/arm/include/asm/assembler.h index 11b80fb..ae1e42f 100644 --- a/arch/arm/include/asm/assembler.h +++ b/arch/arm/include/asm/assembler.h @@ -15,6 +15,7 @@ */
#include <config.h> +#include <asm/unified.h>
- Endian independent macros for shifting bytes within registers.
diff --git a/arch/arm/include/asm/unified.h b/arch/arm/include/asm/unified.h new file mode 100644 index 0000000..a91ae49 --- /dev/null +++ b/arch/arm/include/asm/unified.h @@ -0,0 +1,140 @@ +/*
- include/asm-arm/unified.h - Unified Assembler Syntax helper macros
- Copyright (C) 2008 ARM Limited
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
+#ifndef __ASM_UNIFIED_H +#define __ASM_UNIFIED_H
+#if defined(__ASSEMBLY__) && defined(CONFIG_ARM_ASM_UNIFIED)
.syntax unified
+#ifdef CONFIG_CPU_V7M +#define AR_CLASS(x...) +#define M_CLASS(x...) x +#else +#define AR_CLASS(x...) x +#define M_CLASS(x...) +#endif
+#ifdef CONFIG_THUMB2_KERNEL
+#if __GNUC__ < 4 +#error Thumb-2 kernel requires gcc >= 4 +#endif
+/* The CPSR bit describing the instruction set (Thumb) */ +#define PSR_ISETSTATE PSR_T_BIT
+#define ARM(x...) +#define THUMB(x...) x +#ifdef __ASSEMBLY__ +#define W(instr) instr.w +#else +#define WASM(instr) #instr ".w" +#endif
+#else /* !CONFIG_THUMB2_KERNEL */
+/* The CPSR bit describing the instruction set (ARM) */ +#define PSR_ISETSTATE 0
+#define ARM(x...) x +#define THUMB(x...) +#ifdef __ASSEMBLY__ +#define W(instr) instr +#else +#define WASM(instr) #instr +#endif
+#endif /* CONFIG_THUMB2_KERNEL */
+#ifndef CONFIG_ARM_ASM_UNIFIED
- If the unified assembly syntax isn't used (in ARM mode), these
- macros expand to an empty string
.macro it, cond
.endm
.macro itt, cond
.endm
.macro ite, cond
.endm
.macro ittt, cond
.endm
.macro itte, cond
.endm
.macro itet, cond
.endm
.macro itee, cond
.endm
.macro itttt, cond
.endm
.macro ittte, cond
.endm
.macro ittet, cond
.endm
.macro ittee, cond
.endm
.macro itett, cond
.endm
.macro itete, cond
.endm
.macro iteet, cond
.endm
.macro iteee, cond
.endm
+#else /* !__ASSEMBLY__ */ +__asm__( +" .macro it, cond\n" +" .endm\n" +" .macro itt, cond\n" +" .endm\n" +" .macro ite, cond\n" +" .endm\n" +" .macro ittt, cond\n" +" .endm\n" +" .macro itte, cond\n" +" .endm\n" +" .macro itet, cond\n" +" .endm\n" +" .macro itee, cond\n" +" .endm\n" +" .macro itttt, cond\n" +" .endm\n" +" .macro ittte, cond\n" +" .endm\n" +" .macro ittet, cond\n" +" .endm\n" +" .macro ittee, cond\n" +" .endm\n" +" .macro itett, cond\n" +" .endm\n" +" .macro itete, cond\n" +" .endm\n" +" .macro iteet, cond\n" +" .endm\n" +" .macro iteee, cond\n" +" .endm\n"); +#endif /* __ASSEMBLY__ */
+#endif /* CONFIG_ARM_ASM_UNIFIED */
+#endif /* !__ASM_UNIFIED_H */ diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 7a0fb58..a930744 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -80,8 +80,8 @@ CFLAGS_cache-cp15.o := -marm
AFLAGS_REMOVE_memset.o := -mthumb -mthumb-interwork AFLAGS_REMOVE_memcpy.o := -mthumb -mthumb-interwork -AFLAGS_memset.o := -DMEMSET_NO_THUMB_BUILD -AFLAGS_memcpy.o := -DMEMCPY_NO_THUMB_BUILD
+else +AFLAGS_memset.o := -DCONFIG_THUMB2_KERNEL +AFLAGS_memcpy.o := -DCONFIG_THUMB2_KERNEL endif endif diff --git a/arch/arm/lib/memcpy.S b/arch/arm/lib/memcpy.S index 7d9fc0f..00602e9 100644 --- a/arch/arm/lib/memcpy.S +++ b/arch/arm/lib/memcpy.S @@ -13,12 +13,6 @@ #include <linux/linkage.h> #include <asm/assembler.h>
-#if defined(CONFIG_SYS_THUMB_BUILD) && !defined(MEMCPY_NO_THUMB_BUILD) -#define W(instr) instr.w -#else -#define W(instr) instr -#endif
#define LDR1W_SHIFT 0 #define STR1W_SHIFT 0
-- 2.7.0
On 04/09/2016 08:34 PM, Simon Glass wrote:
Hi Marek,
Can we use SPDX?
Yes, done. Thanks!
participants (5)
Albert ARIBAUD
Sergey Kubushyn
