[U-Boot] Pull request: u-boot-arm/master
Hi Tom,
The following changes since commit db67801bf92f7fae6131dbc0d387131698fb9490:
Merge branch 'master' of git://git.denx.de/u-boot-nand-flash (2014-10-10 09:45:16 -0400)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to 3d420cbd355a5f09e4f113eb10579a264a8ef138:
Merge branch 'u-boot-socfpga/topic/arm/socfpga-20141010' into 'u-boot-arm/master' (2014-10-11 01:20:55 +0200)
Albert ARIBAUD (4): Merge remote-tracking branch 'u-boot-imx/master' Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master' Merge branch 'u-boot/master' into 'u-boot-arm/master' Merge branch 'u-boot-socfpga/topic/arm/socfpga-20141010' into 'u-boot-arm/master'
Andreas Bießmann (2): macb: simplify gmac initialisation sama5d3xek: run PHY's config
Andrew Ruder (2): arm: mx31: use common timer functions arm: mx35: use common timer functions
Bo Shen (1): ARM: atmel: switch at91sam9263ek to generic board
Christian Gmeiner (1): imx6: add Bachmann OT1200 board
Diego Rondini (1): nitrogen6x: config: allow boot to USB stick
Eric Nelson (23): nitrogen6x: Update DDR timings for 2G memory arrangement nitrogen6x: implement board_cfb_skip() to disable text output nitrogen6x: configure SD2 pads for SDIO on USDHC2 nitrogen6x: power-down miscellanous peripherals nitrogen6x: staticize board file nitrogen6x: prevent warnings about board_ehci* callbacks nitrogen6x: display: add qvga panel nitrogen6x: display: add support for LG-9.7 LVDS display nitrogen6x: display: add LDB-WXGA-S for SPWG 1280x800 displays nitrogen6x: display: add support for fusion 7 display nitrogen6x: display: add svga display (800x600) nitrogen6x: display: add Ampire 1024x600 panel nitrogen6x: display: add wvga-lvds panel nitrogen6x: display use I2C detect for HDMI nitrogen6x: config: add USB Mass Storage (ums) support nitrogen6x: config: add initrd_high nitrogen6x: config: expose SATA, then MMC over USB nitrogen6x: config: enable USB keyboard support nitrogen6x: config: add CONFIG_CMD_MEMTEST nitrogen6x: config: enable "i2c edid" nitrogen6x: config: disable logo nitrogen6x: config: add gpio command nitrogen6x: config: enable Android fastboot
Fabio Estevam (9): mx6sxsabresd: Staticize i2c_pad_info1 mx6qsabreauto: Staticize when possible cm_fx6: Remove CONFIG_NETMASK mx51evk: Fix CONFIG_SYS_FSL_ESDHC_ADDR mx51evk: Add generic board support mx25pdk: Fix CONFIG_SYS_FSL_ESDHC_ADDR mx25pdk: Add generic board support wandboard: Select CONFIG_CMD_FUSE mx6sxsabresd: Fix PCI reset and power GPIO assignments
Guillaume GARDET (1): imx: nitrogen6x: Make use of both uSD and SD slots to load script or kernel on Sabrelite board
Heiko Schocher (1): arm, at91: add generic board support for the taurus and corvus board
Kevin Mihelich (2): nitrogen6x: config: use FS_GENERIC load command nitrogen6x: config: enable EXT4 filesystem
Marek Vasut (12): usb: ehci: mxs: Add board-specific callbacks arm: mxs: Wait when disabling VDDMEM current limiter arm: mxs: Wait for DRAM to start arm: mxs: olinuxino: Enable USB only when needed arm: mxs: olinuxino: Fine-tune DRAM configuration arm: m28evk: Test if bootscript exists before loading it arm: m53evk: Test if bootscript exists before loading it arm: m28evk: Enable FS_GENERIC arm: m53evk: Enable FS_GENERIC arm: m28evk: Zap superfluous tab in env arm: m53evk: Zap superfluous tab in env arm: socfpga: Use EMAC1 on SoCDK
Masahiro Yamada (1): exynos: update maintainer of Snow and SMDK5420 board
Minkyu Kang (3): Revert "odroid: set MPLL clock to 880MHz" Merge branch 'master' of http://git.denx.de/u-boot-samsung Merge branch 'uboot'
Nikita Kiryanov (1): compulab: eeprom: add default eeprom bus
Nitin Garg (3): imx: ddr: Move mx6q_4x_mt41j128.cfg to mx6sabresd board imx: Support i.MX6 High Assurance Boot authentication imx6sx: Fix i.MX6SX HAB api function table offset
Nobuhiro Iwamatsu (11): arm: rmobile: lager: Fix value of CONFIG_SH_SCIF_CLK_FREQ arm: rmobile: lager: Add CONFIG_SCIF_USE_EXT_CLK arm: rmobile: koelsch: Add CONFIG_SCIF_USE_EXT_CLK arm: rmobile: koelsch: Update QoS initialization to version 0.334 arm: rmobile: alt: Update QoS initialization to version 0.11 arm: rmobile: lager: Update Qos setting to version 0.955 arm: rmobile: lager: Add Qos setting for ES2 arm: rmobile: lager: Fix CPU frequency setting arm: rmobile: Remove unnecessary initialization for l2ctlr arm: rmobile: r8a7791: Fix initialize L2 cache arm: rmobile: r8a7794: Skip initialize L2 cache
Pavel Machek (1): arm: socfpga: add MAINTAINERS entry
Peng Fan (3): imx:mx6sxsabresd: change CONFIG_SYS_FSL_ESDHC_ADDR imx:mx6qarm2: change CONFIG_SYS_FSL_ESDHC_ADDR imx:mx6slevk: change CONFIG_SYS_FSL_ESDHC_ADDR
Przemyslaw Marczak (1): odroid: clock: set aclk_cores to 200MHz
Robert Baldyga (1): armv7: s5pc1xx: improve cache handling
Robert Winkler (1): nitrogen6x: display: add support lvds jeida screen
Simon Glass (15): Exynos: Use 900MHz ARM frequency in SPL for peach_pit exynos5: Enable data cache cros_ec: power: Add a tunnelled version of the tps65090 driver cros_ec: exynos: Use the correct tps65090 driver in each case dm: exynos: Split out the cros_ec drivers exynos: dts: Add device tree node for cros_ec keyboard exynos: Rename -dt config files to -common exynos: Move common exynos settings into a common file exynos: Move common smdk5420 things to common file exynos: config: Move cros_ec and tps65090 out of smdk boards config: Move arndale to use common exynos5250 file config: Move smdkv310 to use common exynos4 file samsung: Enable device tree for s5p_goni samsung: Enable device tree for smdkc100 exynos: Enable pre-relocation malloc()
Stefan Agner (2): mtd: nand: add Freescale vf610_nfc driver arm: vf610: add NAND support for vf610twr
Stefan Roese (1): ARM: mx6: gw_ventana: Remove superfluous memset of GD in board_init_f
Stefano Babic (3): Merge branch 'master' of git://git.denx.de/u-boot-arm imx: Fix warning by building vf610twr_nand Merge branch 'master' of git://git.denx.de/u-boot-arm
Troy Kisky (4): nitrogen6x: simplify board_mmc_getcd nitrogen6x: configure SGTL5000, CSI camera clock outputs nitrogen6x: phy: add 100 us delay after phy reset nitrogen6x: config: allow more bootargs parameters
Ye.Li (6): imx: mx6qarm2: Add the kernel FDT Loading support imx: mx6qarm2: Change the mmcroot and mmcpart env value imx: mx6: Checking PLL2 PFD0 and PFD2 for periph_clk before PFD reset usb: ehci-mx6: Rename the USB register base address imx: mx6dlarm2: Add support for i.MX6DL arm2 DDR3 board imx: mx6dlarm2: Add support for i.MX6Q/DL arm2 LPDDR2 boards
MAINTAINERS | 7 + arch/arm/Kconfig | 17 +- arch/arm/cpu/arm1136/mx31/timer.c | 104 +- arch/arm/cpu/arm1136/mx35/timer.c | 83 -- arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c | 13 +- arch/arm/cpu/armv7/exynos/Kconfig | 1 + arch/arm/cpu/armv7/mx6/clock.c | 27 + arch/arm/cpu/armv7/mx6/hab.c | 169 ++- arch/arm/cpu/armv7/mx6/soc.c | 39 +- arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S | 22 +- arch/arm/cpu/armv7/s5pc1xx/Kconfig | 25 + arch/arm/cpu/armv7/s5pc1xx/cache.S | 30 - arch/arm/cpu/armv7/s5pc1xx/cache.c | 47 + arch/arm/dts/Makefile | 3 + arch/arm/dts/exynos4210-smdkv310.dts | 21 + arch/arm/dts/exynos5420-peach-pit.dts | 57 +- arch/arm/dts/s5pc1xx-goni.dts | 28 + arch/arm/dts/s5pc1xx-smdkc100.dts | 29 + arch/arm/include/asm/arch-mx31/imx-regs.h | 10 + arch/arm/include/asm/arch-mx35/imx-regs.h | 12 + arch/arm/include/asm/arch-mx6/clock.h | 1 + arch/arm/include/asm/arch-mx6/hab.h | 16 +- arch/arm/include/asm/arch-mx6/imx-regs.h | 9 +- arch/arm/include/asm/arch-s5pc1xx/periph.h | 61 + arch/arm/include/asm/arch-s5pc1xx/pinmux.h | 50 + board/atmel/sama5d3xek/sama5d3xek.c | 29 +- board/bachmann/ot1200/Kconfig | 23 + board/bachmann/ot1200/MAINTAINERS | 6 + board/bachmann/ot1200/Makefile | 9 + board/bachmann/ot1200/README | 20 + .../ddr => bachmann/ot1200}/mx6q_4x_mt41j128.cfg | 0 board/bachmann/ot1200/ot1200.c | 251 ++++ board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg | 24 +- board/boundary/nitrogen6x/nitrogen6x.c | 292 ++++- board/compulab/common/eeprom.c | 4 + board/congatec/cgtqmx6eval/imximage.cfg | 169 +++ board/freescale/mx6qarm2/MAINTAINERS | 4 + board/freescale/mx6qarm2/imximage.cfg | 189 ++- board/freescale/mx6qarm2/imximage_mx6dl.cfg | 462 +++++++ board/freescale/mx6qarm2/mx6qarm2.c | 11 +- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 16 +- board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg | 169 +++ board/freescale/mx6sxsabresd/mx6sxsabresd.c | 2 +- board/freescale/vf610twr/MAINTAINERS | 1 + board/freescale/vf610twr/vf610twr.c | 47 +- board/gateworks/gw_ventana/gw_ventana_spl.c | 7 - board/olimex/mx23_olinuxino/mx23_olinuxino.c | 46 +- board/renesas/alt/qos.c | 6 +- board/renesas/koelsch/qos.c | 41 +- board/renesas/lager/lager.c | 8 +- board/renesas/lager/qos.c | 1358 +++++++++++++++++++- board/samsung/odroid/odroid.c | 64 +- board/samsung/smdk5250/MAINTAINERS | 2 +- board/samsung/smdk5420/MAINTAINERS | 4 - configs/cgtqmx6qeval_defconfig | 2 +- configs/mx6dlarm2_defconfig | 3 + configs/mx6dlarm2_lpddr2_defconfig | 3 + configs/mx6qarm2_defconfig | 2 +- configs/mx6qarm2_lpddr2_defconfig | 3 + configs/mx6qsabresd_defconfig | 2 +- configs/ot1200_defconfig | 3 + configs/s5p_goni_defconfig | 2 + configs/smdkc100_defconfig | 2 + configs/smdkv310_defconfig | 1 + configs/vf610twr_defconfig | 2 +- configs/vf610twr_nand_defconfig | 3 + drivers/mmc/s5p_sdhci.c | 2 - drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/vf610_nfc.c | 724 +++++++++++ drivers/net/macb.c | 25 +- drivers/power/pmic/Makefile | 3 +- drivers/power/pmic/pmic_tps65090_ec.c | 218 ++++ drivers/usb/host/ehci-mx6.c | 4 +- drivers/usb/host/ehci-mxs.c | 16 + include/configs/arndale.h | 195 +-- include/configs/at91sam9263ek.h | 2 + include/configs/cm_fx6.h | 1 - include/configs/corvus.h | 2 + include/configs/{exynos4-dt.h => exynos-common.h} | 110 +- include/configs/exynos4-common.h | 68 + include/configs/{exynos5-dt.h => exynos5-common.h} | 126 +- include/configs/exynos5-dt-common.h | 35 + .../{exynos5250-dt.h => exynos5250-common.h} | 7 +- .../configs/{exynos5420.h => exynos5420-common.h} | 22 +- include/configs/koelsch.h | 1 + include/configs/lager.h | 3 +- include/configs/m28evk.h | 13 +- include/configs/m53evk.h | 13 +- include/configs/mx25pdk.h | 3 +- include/configs/mx51evk.h | 3 +- include/configs/mx6qarm2.h | 49 +- include/configs/mx6slevk.h | 2 +- include/configs/mx6sxsabresd.h | 6 +- include/configs/nitrogen6x.h | 113 +- include/configs/odroid.h | 4 +- include/configs/origen.h | 5 +- include/configs/ot1200.h | 197 +++ include/configs/peach-pit.h | 16 +- include/configs/s5p_goni.h | 9 +- include/configs/s5pc210_universal.h | 5 +- include/configs/smdk5250.h | 23 +- include/configs/smdk5420.h | 5 +- include/configs/smdkc100.h | 6 + include/configs/smdkv310.h | 61 +- include/configs/snow.h | 25 +- include/configs/socfpga_cyclone5.h | 2 +- include/configs/taurus.h | 2 + include/configs/trats.h | 6 +- include/configs/trats2.h | 6 +- include/configs/vf610twr.h | 46 +- include/configs/wandboard.h | 5 + 111 files changed, 5360 insertions(+), 1003 deletions(-) create mode 100644 arch/arm/cpu/armv7/s5pc1xx/Kconfig delete mode 100644 arch/arm/cpu/armv7/s5pc1xx/cache.S create mode 100644 arch/arm/cpu/armv7/s5pc1xx/cache.c create mode 100644 arch/arm/dts/exynos4210-smdkv310.dts create mode 100644 arch/arm/dts/s5pc1xx-goni.dts create mode 100644 arch/arm/dts/s5pc1xx-smdkc100.dts create mode 100644 arch/arm/include/asm/arch-s5pc1xx/periph.h create mode 100644 arch/arm/include/asm/arch-s5pc1xx/pinmux.h create mode 100644 board/bachmann/ot1200/Kconfig create mode 100644 board/bachmann/ot1200/MAINTAINERS create mode 100644 board/bachmann/ot1200/Makefile create mode 100644 board/bachmann/ot1200/README rename board/{freescale/imx/ddr => bachmann/ot1200}/mx6q_4x_mt41j128.cfg (100%) create mode 100644 board/bachmann/ot1200/ot1200.c create mode 100644 board/congatec/cgtqmx6eval/imximage.cfg create mode 100644 board/freescale/mx6qarm2/imximage_mx6dl.cfg create mode 100644 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg create mode 100644 configs/mx6dlarm2_defconfig create mode 100644 configs/mx6dlarm2_lpddr2_defconfig create mode 100644 configs/mx6qarm2_lpddr2_defconfig create mode 100644 configs/ot1200_defconfig create mode 100644 configs/vf610twr_nand_defconfig create mode 100644 drivers/mtd/nand/vf610_nfc.c create mode 100644 drivers/power/pmic/pmic_tps65090_ec.c rename include/configs/{exynos4-dt.h => exynos-common.h} (51%) create mode 100644 include/configs/exynos4-common.h rename include/configs/{exynos5-dt.h => exynos5-common.h} (64%) create mode 100644 include/configs/exynos5-dt-common.h rename include/configs/{exynos5250-dt.h => exynos5250-common.h} (88%) rename include/configs/{exynos5420.h => exynos5420-common.h} (71%) create mode 100644 include/configs/ot1200.h
Amicalement,
On Sat, Oct 11, 2014 at 02:38:24AM +0200, Albert ARIBAUD wrote:
Hi Tom,
- .../{exynos5250-dt.h => exynos5250-common.h} | 7
Albert ARIBAUD
