[U-Boot] [PATCH] MUSB timeout broken
The following construct (musb_hcd.c, usb_lowlevel_init)
timeout = musb_cfg.timeout; while (timeout--) if (readb(&musbr->devctl) & MUSB_DEVCTL_HM) break;
will leave timeout == -1 when the timeout is reached, hence the timeout detecting code that follows will not trigger:
/* if musb core is not in host mode, then return */ if (!timeout) return -1;
Without the patch below, doing a 'usb reset' without a device connected makes it impossible to discover connected devices later. I have not investigated why this happens since the timeout logic was broken (and correcting that fixed the issue at hand).
Changed to pre-decrement since I assume the timeout value is not *that* exact.
Thanks, Orjan
diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index 974bb31..adcf7f7 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -1114,7 +1114,7 @@ int usb_lowlevel_init(void) * should be a usb device connected. */ timeout = musb_cfg.timeout; - while (timeout--) + while (--timeout) if (readb(&musbr->devctl) & MUSB_DEVCTL_HM) break;
Dear Orjan Friberg,
Thanks for spotting and reporting.
Thanks, Orjan
while (timeout--)
Unfortunately, your patch is white space corrupted, and missing a proper Signed-off-by: line.
Please fix and repost. Thanks.
Orjan Friberg
