[U-Boot] [PATCH] arm64: zynqmp: Setup ENV_SIZE via Kconfig for mini targets
Mini targets are using different ENV_SIZE then standard one that's why defconfigs should be updated to simplify config files.
Based on: https://lists.denx.de/pipermail/u-boot/2018-July/335126.html and https://lists.denx.de/pipermail/u-boot/2018-July/335152.html
--- configs/xilinx_zynqmp_mini_emmc0_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc1_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_defconfig | 1 + configs/xilinx_zynqmp_mini_qspi_defconfig | 1 + include/configs/xilinx_zynqmp_mini.h | 1 - include/configs/xilinx_zynqmp_mini_emmc.h | 1 - include/configs/xilinx_zynqmp_mini_nand.h | 1 - include/configs/xilinx_zynqmp_mini_qspi.h | 1 - 8 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index ffb9693c10f3..65a72b7f9947 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_mini_emmc" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x10000 +CONFIG_ENV_SIZE=0x10000 # CONFIG_CMD_ZYNQMP is not set CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-emmc0" CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index edca32d28e2c..c32ba73b1f1a 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_mini_emmc" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x10000 +CONFIG_ENV_SIZE=0x10000 # CONFIG_CMD_ZYNQMP is not set CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-emmc1" CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index 4c8c2fcee6d0..3117770263df 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_mini_nand" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x10000 +CONFIG_ENV_SIZE=0x10000 # CONFIG_CMD_ZYNQMP is not set CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-nand" CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index 8b3282912404..a4bc89503001 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_mini_qspi" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0xFFFC0000 +CONFIG_ENV_SIZE=0x578 CONFIG_SYS_MEM_RSVD_FOR_MMU=y CONFIG_ZYNQMP_NO_DDR=y # CONFIG_CMD_ZYNQMP is not set diff --git a/include/configs/xilinx_zynqmp_mini.h b/include/configs/xilinx_zynqmp_mini.h index 118779a0a026..8ba91d0d1dda 100644 --- a/include/configs/xilinx_zynqmp_mini.h +++ b/include/configs/xilinx_zynqmp_mini.h @@ -17,7 +17,6 @@ /* Undef unneeded configs */ #undef CONFIG_EXTRA_ENV_SETTINGS #undef CONFIG_SYS_MALLOC_LEN -#undef CONFIG_ENV_SIZE #undef CONFIG_ZLIB #undef CONFIG_GZIP #undef CONFIG_CMD_ENV diff --git a/include/configs/xilinx_zynqmp_mini_emmc.h b/include/configs/xilinx_zynqmp_mini_emmc.h index dc81c66c641d..6531599c79d9 100644 --- a/include/configs/xilinx_zynqmp_mini_emmc.h +++ b/include/configs/xilinx_zynqmp_mini_emmc.h @@ -14,7 +14,6 @@
#define CONFIG_SYS_ICACHE_OFF #define CONFIG_NR_DRAM_BANKS 1 -#define CONFIG_ENV_SIZE 0x10000 #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MALLOC_LEN 0x800000
diff --git a/include/configs/xilinx_zynqmp_mini_nand.h b/include/configs/xilinx_zynqmp_mini_nand.h index 4434e6ab3291..00db44964847 100644 --- a/include/configs/xilinx_zynqmp_mini_nand.h +++ b/include/configs/xilinx_zynqmp_mini_nand.h @@ -16,7 +16,6 @@ #define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_SYS_SDRAM_SIZE 0x1000000 #define CONFIG_SYS_SDRAM_BASE 0x0 -#define CONFIG_ENV_SIZE 0x10000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x40000) #define CONFIG_SYS_MALLOC_LEN 0x800000
diff --git a/include/configs/xilinx_zynqmp_mini_qspi.h b/include/configs/xilinx_zynqmp_mini_qspi.h index 6fb05200ce24..229132675ee3 100644 --- a/include/configs/xilinx_zynqmp_mini_qspi.h +++ b/include/configs/xilinx_zynqmp_mini_qspi.h @@ -14,7 +14,6 @@
#define CONFIG_SYS_ICACHE_OFF #define CONFIG_NR_DRAM_BANKS 1 -#define CONFIG_ENV_SIZE 1400 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + 0x20000) #define CONFIG_SYS_MALLOC_LEN 0x2000
Michal Simek
