[U-Boot-Users] [PATCH] logic error waiting for init in virtex2/spartan2/spartan3
In the xilinx download code there is a logic error in the section where it is waiting for the init signal to go inactive.
There is a while loop which loop if init is active /or/ busy is active, instead it checks if init is active /and/ busy active. In most designs busy is never used (only needed for clocks > 50 MHz) and often not connected. If the unused busy function returns 0 (not busy) the while loop will exit early and configuration will start too soon. This behaviour is masked if the debugging code is turned on by the printf run time.
CHANGELOG
fix init wait loop exit conditions for xilinx downloads to properly handle case where busy is low Patch by Andrew Dyer amdyer@gmail.com, 18 July 2006
Signed-off-by: Andrew Dyer amdyer@gmail.com
Andrew Dyer
