[U-Boot] [PATCH] sh: add support for sh7757lcr board
The R0P7757LC0030RL board has SH7757, 256MB DDR3-SDRAM, SPI ROM, Ethernet, and more.
This patch supports the following functions: - 256MB DDR3-SDRAM - SPI ROM - Ethernet
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- arch/sh/include/asm/cpu_sh4.h | 2 + arch/sh/include/asm/cpu_sh7757.h | 263 +++++++++++++++ board/renesas/sh7757lcr/Makefile | 42 +++ board/renesas/sh7757lcr/config.mk | 28 ++ board/renesas/sh7757lcr/lowlevel_init.S | 558 +++++++++++++++++++++++++++++++ board/renesas/sh7757lcr/sh7757lcr.c | 436 ++++++++++++++++++++++++ board/renesas/sh7757lcr/spi-boot.c | 111 ++++++ board/renesas/sh7757lcr/u-boot.lds | 101 ++++++ boards.cfg | 1 + doc/README.sh7757lcr | 64 ++++ include/configs/sh7757lcr.h | 143 ++++++++ 11 files changed, 1749 insertions(+), 0 deletions(-) create mode 100644 arch/sh/include/asm/cpu_sh7757.h create mode 100644 board/renesas/sh7757lcr/Makefile create mode 100644 board/renesas/sh7757lcr/config.mk create mode 100644 board/renesas/sh7757lcr/lowlevel_init.S create mode 100644 board/renesas/sh7757lcr/sh7757lcr.c create mode 100644 board/renesas/sh7757lcr/spi-boot.c create mode 100644 board/renesas/sh7757lcr/u-boot.lds create mode 100644 doc/README.sh7757lcr create mode 100644 include/configs/sh7757lcr.h
diff --git a/arch/sh/include/asm/cpu_sh4.h b/arch/sh/include/asm/cpu_sh4.h index fdcebd6..9b29d3a 100644 --- a/arch/sh/include/asm/cpu_sh4.h +++ b/arch/sh/include/asm/cpu_sh4.h @@ -44,6 +44,8 @@ # include <asm/cpu_sh7722.h> #elif defined (CONFIG_CPU_SH7723) # include <asm/cpu_sh7723.h> +#elif defined (CONFIG_CPU_SH7757) +# include <asm/cpu_sh7757.h> #elif defined (CONFIG_CPU_SH7763) # include <asm/cpu_sh7763.h> #elif defined (CONFIG_CPU_SH7780) diff --git a/arch/sh/include/asm/cpu_sh7757.h b/arch/sh/include/asm/cpu_sh7757.h new file mode 100644 index 0000000..eb9ff5b --- /dev/null +++ b/arch/sh/include/asm/cpu_sh7757.h @@ -0,0 +1,263 @@ +/* + * Copyright (C) 2011 Renesas Solutions Corp. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#ifndef _ASM_CPU_SH7757_H_ +#define _ASM_CPU_SH7757_H_ + +#define CCR 0xFF00001C +#define WTCNT 0xFFCC0000 +#define CCR_CACHE_INIT 0x0000090b +#define CACHE_OC_NUM_WAYS 1 + +/* Exception */ +#define EXPEVT 0xff000024 +#define INTEVT 0xff000028 + +/* Watchdog */ +#define WTCSR0 0xffcc0002 +#define WRSTCSR_R 0xffcc0003 +#define WRSTCSR_W 0xffcc0002 +#define WTCSR_PREFIX 0xa500 +#define WRSTCSR_PREFIX 0x6900 +#define WRSTCSR_WOVF_PREFIX 0x9600 + + +/* SCIF */ +#define SCIF0_BASE 0xfe4b0000 /* The real name is SCIF2 */ +#define SCIF1_BASE 0xfe4c0000 /* The real name is SCIF3 */ +#define SCIF2_BASE 0xfe4d0000 /* The real name is SCIF4 */ + +/* SerMux */ +#define SMR0 0xfe470000 + +/* TMU0 */ +#define TSTR 0xFE430004 +#define TOCR 0xFE430000 +#define TSTR0 0xFE430004 +#define TCOR0 0xFE430008 +#define TCNT0 0xFE43000C +#define TCR0 0xFE430010 +#define TCOR1 0xFE430014 +#define TCNT1 0xFE430018 +#define TCR1 0xFE43001C +#define TCOR2 0xFE430020 +#define TCNT2 0xFE430024 +#define TCR2 0xFE430028 +#define TCPR2 0xFE43002C + +/* BSC */ +#define BCR 0xFE801000 +#define CS0BCR 0xFF802000 +#define CS0WCR 0xFF802008 +#define CS4BCR 0xFF802040 +#define CS4WCR 0xFF802048 +#define CS5BCR 0xFF802050 +#define CS5WCR 0xFF802058 +#define CS6BCR 0xFF802060 +#define CS6WCR 0xFF802068 + +/* DDR3IF */ +#define DDR3IF_BASE 0xfe800000 +#define DBSTATE0 (DDR3IF_BASE + 0x0008) +#define DBSTATE1 (DDR3IF_BASE + 0x000c) +#define DBACEN (DDR3IF_BASE + 0x0010) +#define DBRFEN (DDR3IF_BASE + 0x0014) +#define DBCMD (DDR3IF_BASE + 0x0018) +#define DBWAIT (DDR3IF_BASE + 0x001c) +#define DBKIND (DDR3IF_BASE + 0x0020) +#define DBCONF (DDR3IF_BASE + 0x0024) +#define DBTR0 (DDR3IF_BASE + 0x0040) +#define DBTR1 (DDR3IF_BASE + 0x0044) +#define DBTR2 (DDR3IF_BASE + 0x0048) +#define DBTR3 (DDR3IF_BASE + 0x0050) +#define DBTR4 (DDR3IF_BASE + 0x0054) +#define DBTR5 (DDR3IF_BASE + 0x0058) +#define DBTR6 (DDR3IF_BASE + 0x005c) +#define DBTR7 (DDR3IF_BASE + 0x0060) +#define DBTR8 (DDR3IF_BASE + 0x0064) +#define DBTR9 (DDR3IF_BASE + 0x0068) +#define DBTR10 (DDR3IF_BASE + 0x006c) +#define DBTR11 (DDR3IF_BASE + 0x0070) +#define DBTR12 (DDR3IF_BASE + 0x0074) +#define DBTR13 (DDR3IF_BASE + 0x0078) +#define DBTR14 (DDR3IF_BASE + 0x007c) +#define DBTR15 (DDR3IF_BASE + 0x0080) +#define DBTR16 (DDR3IF_BASE + 0x0084) +#define DBTR17 (DDR3IF_BASE + 0x0088) +#define DBTR18 (DDR3IF_BASE + 0x008c) +#define DBTR19 (DDR3IF_BASE + 0x0090) +#define DBADJ0 (DDR3IF_BASE + 0x00c0) +#define DBADJ1 (DDR3IF_BASE + 0x00c4) +#define DBADJ2 (DDR3IF_BASE + 0x00c8) +#define DBADJ3 (DDR3IF_BASE + 0x00cc) +#define DBRFCNF0 (DDR3IF_BASE + 0x00e0) +#define DBRFCNF1 (DDR3IF_BASE + 0x00e4) +#define DBRFCNF2 (DDR3IF_BASE + 0x00e8) +#define DBCALCNF (DDR3IF_BASE + 0x00f4) +#define DBRNK0 (DDR3IF_BASE + 0x0100) +#define DBPDCNT0 (DDR3IF_BASE + 0x0200) +#define DBPDCNT1 (DDR3IF_BASE + 0x0204) +#define DBPDCNT2 (DDR3IF_BASE + 0x0208) +#define DBPDCNT3 (DDR3IF_BASE + 0x020c) +#define DBPDLCK (DDR3IF_BASE + 0x0280) +#define DBPDRGA (DDR3IF_BASE + 0x0290) +#define DBPDRGD (DDR3IF_BASE + 0x02a0) +#define DBBS0CNT0 (DDR3IF_BASE + 0x0300) +#define DBBS0CNT1 (DDR3IF_BASE + 0x0304) + +/* DDR-ECC */ +#define ECD_ECDEN 0xffc1012c +#define ECD_MCR 0xfe900010 +#define ECD_SPACER 0xfe900018 +#define ECD_INTSR 0xfe900024 + +/* GPIO */ +#define GPIO_BASE 0xffec0000 +#define PACR (GPIO_BASE + 0x0000) +#define PBCR (GPIO_BASE + 0x0002) +#define PCCR (GPIO_BASE + 0x0004) +#define PDCR (GPIO_BASE + 0x0006) +#define PECR (GPIO_BASE + 0x0008) +#define PFCR (GPIO_BASE + 0x000a) +#define PGCR (GPIO_BASE + 0x000c) +#define PHCR (GPIO_BASE + 0x000e) +#define PICR (GPIO_BASE + 0x0010) +#define PJCR (GPIO_BASE + 0x0012) +#define PKCR (GPIO_BASE + 0x0014) +#define PLCR (GPIO_BASE + 0x0016) +#define PMCR (GPIO_BASE + 0x0018) +#define PNCR (GPIO_BASE + 0x001a) +#define POCR (GPIO_BASE + 0x001c) +#define PPCR (GPIO_BASE + 0x001e) +#define PQCR (GPIO_BASE + 0x0020) +#define PRCR (GPIO_BASE + 0x0022) +#define PSCR (GPIO_BASE + 0x0024) +#define PTCR (GPIO_BASE + 0x0026) +#define PUCR (GPIO_BASE + 0x0028) +#define PVCR (GPIO_BASE + 0x002a) +#define PWCR (GPIO_BASE + 0x002c) +#define PXCR (GPIO_BASE + 0x002e) +#define PYCR (GPIO_BASE + 0x0030) +#define PZCR (GPIO_BASE + 0x0032) +#define PADR (GPIO_BASE + 0x0034) +#define PBDR (GPIO_BASE + 0x0036) +#define PCDR (GPIO_BASE + 0x0038) +#define PDDR (GPIO_BASE + 0x003a) +#define PEDR (GPIO_BASE + 0x003c) +#define PFDR (GPIO_BASE + 0x003e) +#define PGDR (GPIO_BASE + 0x0040) +#define PHDR (GPIO_BASE + 0x0042) +#define PIDR (GPIO_BASE + 0x0044) +#define PJDR (GPIO_BASE + 0x0046) +#define PKDR (GPIO_BASE + 0x0048) +#define PLDR (GPIO_BASE + 0x004a) +#define PMDR (GPIO_BASE + 0x004c) +#define PNDR (GPIO_BASE + 0x004e) +#define PODR (GPIO_BASE + 0x0050) +#define PPDR (GPIO_BASE + 0x0052) +#define PQDR (GPIO_BASE + 0x0054) +#define PRDR (GPIO_BASE + 0x0056) +#define PSDR (GPIO_BASE + 0x0058) +#define PTDR (GPIO_BASE + 0x005a) +#define PUDR (GPIO_BASE + 0x005c) +#define PVDR (GPIO_BASE + 0x005e) +#define PWDR (GPIO_BASE + 0x0060) +#define PXDR (GPIO_BASE + 0x0062) +#define PYDR (GPIO_BASE + 0x0064) +#define PZDR (GPIO_BASE + 0x0066) +#define PSEL0 (GPIO_BASE + 0x0070) +#define PSEL1 (GPIO_BASE + 0x0072) +#define PSEL2 (GPIO_BASE + 0x0074) +#define PSEL3 (GPIO_BASE + 0x0076) +#define PSEL4 (GPIO_BASE + 0x0078) +#define PSEL5 (GPIO_BASE + 0x007a) +#define PSEL6 (GPIO_BASE + 0x007c) +#define PSEL7 (GPIO_BASE + 0x0082) +#define PSEL8 (GPIO_BASE + 0x0084) + +/* GETHER */ +#define GETHER_GBECONT 0xffc10100 +#define GBECONT_RMII1 0x00020000 +#define GBECONT_RMII0 0x00010000 + +/* USB1 */ +#define USB1_PORT1SEL 0xfe4f2000 +#define USB1_EHCIDATAC 0xfe4fe018 +#define USB1_OHCIDATAC 0xfe4fe118 +#define USB0_PHY_RESET 0xfe5f0000 +#define USB0_PHY_PORTSEL 0xfe5f000a +#define USB0_SUSPMODE 0xfe450102 +#define USB1_SUSPMODE 0xfe4f0102 + +/* GCTRL */ +#define GCTRL_BASE 0xffc10000 +#define GCTRL_WPROTECT (GCTRL_BASE + 0x0000) +#define GCTRL_GPLLDIV (GCTRL_BASE + 0x0004) +#define GCTRL_GRACR3 (GCTRL_BASE + 0x000c) +#define GCTRL_FCNTCR1 (GCTRL_BASE + 0x0020) +#define GCTRL_FCNTCR2 (GCTRL_BASE + 0x0024) +#define GCTRL_MSTPCR2 (GCTRL_BASE + 0x0028) +#define GCTRL_GPLL1DIV (GCTRL_BASE + 0x0030) +#define GCTRL_VCOMPSEL (GCTRL_BASE + 0x0034) +#define GCTRL_SPIBOOTCAN (GCTRL_BASE + 0x1000) + +/* PCIe */ +#define PCIE_BASE 0xffca0000 +#define PCIE_PCICONF14 (PCIE_BASE + 0x003c) +#define PCIE_MSICAP0 (PCIE_BASE + 0x0050) +#define PCIE_LAD0 (PCIE_BASE + 0x1260) +#define PCIE_LADMSK0 (PCIE_BASE + 0x1264) +#define PCIE_LAD1 (PCIE_BASE + 0x1268) +#define PCIE_LADMSK1 (PCIE_BASE + 0x126c) +#define PCIE_LAD2 (PCIE_BASE + 0x1270) +#define PCIE_LADMSK2 (PCIE_BASE + 0x1274) +#define PCIE_LAD3 (PCIE_BASE + 0x1278) +#define PCIE_LADMSK3 (PCIE_BASE + 0x127c) +#define PCIE_LAD4 (PCIE_BASE + 0x1280) +#define PCIE_LADMSK4 (PCIE_BASE + 0x1284) +#define PCIE_LAD5 (PCIE_BASE + 0x1288) +#define PCIE_LADMSK5 (PCIE_BASE + 0x128c) +#define PCIE_BARMAP0 (PCIE_BASE + 0x1420) +#define PCIE_PBICTL3 (PCIE_BASE + 0x142C) +#define PCIE_PBICTL2 (PCIE_BASE + 0x1470) +#define PCIE_BSTCTL0 (PCIE_BASE + 0x1604) +#define PCIE_ENDICTL0 (PCIE_BASE + 0x160c) +#define PCIE_ENDICTL1 (PCIE_BASE + 0x1610) + +/* PCIe-Bridge */ +#define PCIEBRG_BASE 0xffd60000 +#define PCIEBRG_CTRL_H8S (PCIEBRG_BASE + 0x00) +#define PCIEBRG_CP_ADDR (PCIEBRG_BASE + 0x10) +#define PCIEBRG_CP_DATA (PCIEBRG_BASE + 0x14) +#define PCIEBRG_CP_CTRL (PCIEBRG_BASE + 0x18) + +/* CPU version */ +#define CCN_PRR 0xff000044 +#define prr_mask(_val) ((_val >> 4) & 0xff) +#define PRR_SH7757_B0 0x10 +#define PRR_SH7757_C0 0x11 + +#define is_sh7757_b0(_val) \ +({ \ + int __ret = prr_mask(__raw_readl(CCN_PRR)) == PRR_SH7757_B0; \ + __ret; \ +}) + +#endif /* _ASM_CPU_SH7757_H_ */ diff --git a/board/renesas/sh7757lcr/Makefile b/board/renesas/sh7757lcr/Makefile new file mode 100644 index 0000000..22106fd --- /dev/null +++ b/board/renesas/sh7757lcr/Makefile @@ -0,0 +1,42 @@ +# +# Copyright (C) 2011 Yoshihiro Shimoda shimoda.yoshihiro@renesas.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := sh7757lcr.o spi-boot.o +SOBJS := lowlevel_init.o + +$(LIB): $(obj).depend $(COBJS) $(SOBJS) + $(call cmd_link_o_target, $(COBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/renesas/sh7757lcr/config.mk b/board/renesas/sh7757lcr/config.mk new file mode 100644 index 0000000..514f52a --- /dev/null +++ b/board/renesas/sh7757lcr/config.mk @@ -0,0 +1,28 @@ +# +# Copyright (C) 2007 +# Nobuhiro Iwamatsu iwamatsu@nigauri.org +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA + +# +# CONFIG_SYS_TEXT_BASE refers to image _after_ relocation. +# +# NOTE: Must match value used in u-boot.lds (in this directory). +# +LDSCRIPT = $(OBJTREE)/board/$(BOARDDIR)/u-boot.lds +#sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp + +CONFIG_SYS_TEXT_BASE = 0x8ef80000 diff --git a/board/renesas/sh7757lcr/lowlevel_init.S b/board/renesas/sh7757lcr/lowlevel_init.S new file mode 100644 index 0000000..db4bf70 --- /dev/null +++ b/board/renesas/sh7757lcr/lowlevel_init.S @@ -0,0 +1,558 @@ +/* + * Copyright (C) 2011 Renesas Solutions Corp. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/processor.h> +#include <asm/macro.h> + +.macro or32, addr, data + mov.l \addr, r1 + mov.l \data, r0 + mov.l @r1, r2 + or r2, r0 + mov.l r0, @r1 +.endm + +.macro wait_DBCMD + mov.l DBWAIT_A, r0 + mov.l @r0, r1 +.endm + + .global lowlevel_init + .section .spiboot1.text + .align 2 + +lowlevel_init: + + /*------- GPIO -------*/ + write8 PGDR_A, PGDR_D /* eMMC power off */ + + write16 PACR_A, PACR_D + write16 PBCR_A, PBCR_D + write16 PCCR_A, PCCR_D + write16 PDCR_A, PDCR_D + write16 PECR_A, PECR_D + write16 PFCR_A, PFCR_D + write16 PGCR_A, PGCR_D + write16 PHCR_A, PHCR_D + write16 PICR_A, PICR_D + write16 PJCR_A, PJCR_D + write16 PKCR_A, PKCR_D + write16 PLCR_A, PLCR_D + write16 PMCR_A, PMCR_D + write16 PNCR_A, PNCR_D + write16 POCR_A, POCR_D + write16 PQCR_A, PQCR_D + write16 PRCR_A, PRCR_D + write16 PSCR_A, PSCR_D + write16 PTCR_A, PTCR_D + write16 PUCR_A, PUCR_D + write16 PVCR_A, PVCR_D + write16 PWCR_A, PWCR_D + write16 PXCR_A, PXCR_D + write16 PYCR_A, PYCR_D + write16 PZCR_A, PZCR_D + write16 PSEL0_A, PSEL0_D + write16 PSEL1_A, PSEL1_D + write16 PSEL2_A, PSEL2_D + write16 PSEL3_A, PSEL3_D + write16 PSEL4_A, PSEL4_D + write16 PSEL5_A, PSEL5_D + write16 PSEL6_A, PSEL6_D + write16 PSEL7_A, PSEL7_D + write16 PSEL8_A, PSEL8_D + + bra exit_gpio + nop + + .align 4 + +/*------- GPIO -------*/ +PGDR_A: .long PGDR +PACR_A: .long PACR +PBCR_A: .long PBCR +PCCR_A: .long PCCR +PDCR_A: .long PDCR +PECR_A: .long PECR +PFCR_A: .long PFCR +PGCR_A: .long PGCR +PHCR_A: .long PHCR +PICR_A: .long PICR +PJCR_A: .long PJCR +PKCR_A: .long PKCR +PLCR_A: .long PLCR +PMCR_A: .long PMCR +PNCR_A: .long PNCR +POCR_A: .long POCR +PQCR_A: .long PQCR +PRCR_A: .long PRCR +PSCR_A: .long PSCR +PTCR_A: .long PTCR +PUCR_A: .long PUCR +PVCR_A: .long PVCR +PWCR_A: .long PWCR +PXCR_A: .long PXCR +PYCR_A: .long PYCR +PZCR_A: .long PZCR +PSEL0_A: .long PSEL0 +PSEL1_A: .long PSEL1 +PSEL2_A: .long PSEL2 +PSEL3_A: .long PSEL3 +PSEL4_A: .long PSEL4 +PSEL5_A: .long PSEL5 +PSEL6_A: .long PSEL6 +PSEL7_A: .long PSEL7 +PSEL8_A: .long PSEL8 + +PGDR_D: .long 0x80 +PACR_D: .long 0x0000 +PBCR_D: .long 0x0001 +PCCR_D: .long 0x0000 +PDCR_D: .long 0x0000 +PECR_D: .long 0x0000 +PFCR_D: .long 0x0000 +PGCR_D: .long 0x0000 +PHCR_D: .long 0x0000 +PICR_D: .long 0x0000 +PJCR_D: .long 0x0000 +PKCR_D: .long 0x0003 +PLCR_D: .long 0x0000 +PMCR_D: .long 0x0000 +PNCR_D: .long 0x0000 +POCR_D: .long 0x0000 +PQCR_D: .long 0xc000 +PRCR_D: .long 0x0000 +PSCR_D: .long 0x0000 +PTCR_D: .long 0x0000 +#if defined(CONFIG_SH7757_OFFSET_SPI) +PUCR_D: .long 0x0055 +#else +PUCR_D: .long 0x0000 +#endif +PVCR_D: .long 0x0000 +PWCR_D: .long 0x0000 +PXCR_D: .long 0x0000 +PYCR_D: .long 0x0000 +PZCR_D: .long 0x0000 +PSEL0_D: .long 0xfe00 +PSEL1_D: .long 0x0000 +PSEL2_D: .long 0x3000 +PSEL3_D: .long 0xff00 +PSEL4_D: .long 0x771f +PSEL5_D: .long 0x0ffc +PSEL6_D: .long 0x00ff +PSEL7_D: .long 0xfc00 +PSEL8_D: .long 0x0000 + + .align 2 + +exit_gpio: + mov #0, r14 + mova 2f, r0 + mov.l PC_MASK, r1 + tst r0, r1 + bf 2f + + bra exit_pmb + nop + + .align 2 + +/* If CPU runs on SDRAM, PC is 0x8???????. */ +PC_MASK: .long 0x20000000 + +2: + mov #1, r14 + + mov.l EXPEVT_A, r0 + mov.l @r0, r0 + mov.l EXPEVT_POWER_ON_RESET, r1 + cmp/eq r0, r1 + bt 1f + + /* + * If EXPEVT value is manual reset or tlb multipul-hit, + * initialization of DDR3IF is not necessary. + */ + bra exit_ddr + nop + +1: + /* For Core Reset */ + mov.l DBACEN_A, r0 + mov.l @r0, r0 + cmp/eq #0, r0 + bt 3f + + /* + * If DBACEN == 1(DBSC was already enabled), we have to avoid the + * initialization of DDR3-SDRAM. + */ + bra exit_ddr + nop + +3: + /*------- DDR3IF -------*/ + /* oscillation stabilization time */ + wait_timer WAIT_OSC_TIME + + /* step 3 */ + write32 DBCMD_A, DBCMD_RSTL_VAL + wait_timer WAIT_30US + + /* step 4 */ + write32 DBCMD_A, DBCMD_PDEN_VAL + + /* step 5 */ + write32 DBKIND_A, DBKIND_D + + /* step 6 */ + write32 DBCONF_A, DBCONF_D + write32 DBTR0_A, DBTR0_D + write32 DBTR1_A, DBTR1_D + write32 DBTR2_A, DBTR2_D + write32 DBTR3_A, DBTR3_D + write32 DBTR4_A, DBTR4_D + write32 DBTR5_A, DBTR5_D + write32 DBTR6_A, DBTR6_D + write32 DBTR7_A, DBTR7_D + write32 DBTR8_A, DBTR8_D + write32 DBTR9_A, DBTR9_D + write32 DBTR10_A, DBTR10_D + write32 DBTR11_A, DBTR11_D + write32 DBTR12_A, DBTR12_D + write32 DBTR13_A, DBTR13_D + write32 DBTR14_A, DBTR14_D + write32 DBTR15_A, DBTR15_D + write32 DBTR16_A, DBTR16_D + write32 DBTR17_A, DBTR17_D + write32 DBTR18_A, DBTR18_D + write32 DBTR19_A, DBTR19_D + write32 DBRNK0_A, DBRNK0_D + + /* step 7 */ + write32 DBPDCNT3_A, DBPDCNT3_D + + /* step 8 */ + write32 DBPDCNT1_A, DBPDCNT1_D + write32 DBPDCNT2_A, DBPDCNT2_D + write32 DBPDLCK_A, DBPDLCK_D + write32 DBPDRGA_A, DBPDRGA_D + write32 DBPDRGD_A, DBPDRGD_D + + /* step 9 */ + wait_timer WAIT_30US + + /* step 10 */ + write32 DBPDCNT0_A, DBPDCNT0_D + + /* step 11 */ + wait_timer WAIT_30US + wait_timer WAIT_30US + + /* step 12 */ + write32 DBCMD_A, DBCMD_WAIT_VAL + wait_DBCMD + + /* step 13 */ + write32 DBCMD_A, DBCMD_RSTH_VAL + wait_DBCMD + + /* step 14 */ + write32 DBCMD_A, DBCMD_WAIT_VAL + write32 DBCMD_A, DBCMD_WAIT_VAL + write32 DBCMD_A, DBCMD_WAIT_VAL + write32 DBCMD_A, DBCMD_WAIT_VAL + + /* step 15 */ + write32 DBCMD_A, DBCMD_PDXT_VAL + + /* step 16 */ + write32 DBCMD_A, DBCMD_MRS2_VAL + + /* step 17 */ + write32 DBCMD_A, DBCMD_MRS3_VAL + + /* step 18 */ + write32 DBCMD_A, DBCMD_MRS1_VAL + + /* step 19 */ + write32 DBCMD_A, DBCMD_MRS0_VAL + + /* step 20 */ + write32 DBCMD_A, DBCMD_ZQCL_VAL + + write32 DBCMD_A, DBCMD_REF_VAL + write32 DBCMD_A, DBCMD_REF_VAL + wait_DBCMD + + /* step 21 */ + write32 DBADJ0_A, DBADJ0_D + write32 DBADJ1_A, DBADJ1_D + write32 DBADJ2_A, DBADJ2_D + + /* step 22 */ + write32 DBRFCNF0_A, DBRFCNF0_D + write32 DBRFCNF1_A, DBRFCNF1_D + write32 DBRFCNF2_A, DBRFCNF2_D + + /* step 23 */ + write32 DBCALCNF_A, DBCALCNF_D + + /* step 24 */ + write32 DBRFEN_A, DBRFEN_D + write32 DBCMD_A, DBCMD_SRXT_VAL + + /* step 25 */ + write32 DBACEN_A, DBACEN_D + + /* step 26 */ + wait_DBCMD + + /* enable DDR-ECC */ + write32 ECD_ECDEN_A, ECD_ECDEN_D + write32 ECD_INTSR_A, ECD_INTSR_D + write32 ECD_SPACER_A, ECD_SPACER_D + write32 ECD_MCR_A, ECD_MCR_D + + bra exit_ddr + nop + + .align 4 + +EXPEVT_A: .long EXPEVT +EXPEVT_POWER_ON_RESET: .long 0x00000000 + +/*------- DDR3IF -------*/ +DBCMD_A: .long DBCMD +DBKIND_A: .long DBKIND +DBCONF_A: .long DBCONF +DBTR0_A: .long DBTR0 +DBTR1_A: .long DBTR1 +DBTR2_A: .long DBTR2 +DBTR3_A: .long DBTR3 +DBTR4_A: .long DBTR4 +DBTR5_A: .long DBTR5 +DBTR6_A: .long DBTR6 +DBTR7_A: .long DBTR7 +DBTR8_A: .long DBTR8 +DBTR9_A: .long DBTR9 +DBTR10_A: .long DBTR10 +DBTR11_A: .long DBTR11 +DBTR12_A: .long DBTR12 +DBTR13_A: .long DBTR13 +DBTR14_A: .long DBTR14 +DBTR15_A: .long DBTR15 +DBTR16_A: .long DBTR16 +DBTR17_A: .long DBTR17 +DBTR18_A: .long DBTR18 +DBTR19_A: .long DBTR19 +DBRNK0_A: .long DBRNK0 +DBPDCNT0_A: .long DBPDCNT0 +DBPDCNT1_A: .long DBPDCNT1 +DBPDCNT2_A: .long DBPDCNT2 +DBPDCNT3_A: .long DBPDCNT3 +DBPDLCK_A: .long DBPDLCK +DBPDRGA_A: .long DBPDRGA +DBPDRGD_A: .long DBPDRGD +DBADJ0_A: .long DBADJ0 +DBADJ1_A: .long DBADJ1 +DBADJ2_A: .long DBADJ2 +DBRFCNF0_A: .long DBRFCNF0 +DBRFCNF1_A: .long DBRFCNF1 +DBRFCNF2_A: .long DBRFCNF2 +DBCALCNF_A: .long DBCALCNF +DBRFEN_A: .long DBRFEN +DBACEN_A: .long DBACEN +DBWAIT_A: .long DBWAIT + +WAIT_OSC_TIME: .long 6000 +WAIT_30US: .long 13333 + +DBCMD_RSTL_VAL: .long 0x20000000 +DBCMD_PDEN_VAL: .long 0x1000d73c +DBCMD_WAIT_VAL: .long 0x0000d73c +DBCMD_RSTH_VAL: .long 0x2100d73c +DBCMD_PDXT_VAL: .long 0x110000c8 +DBCMD_MRS0_VAL: .long 0x28000930 +DBCMD_MRS1_VAL: .long 0x29000004 +DBCMD_MRS2_VAL: .long 0x2a000008 +DBCMD_MRS3_VAL: .long 0x2b000000 +DBCMD_ZQCL_VAL: .long 0x03000200 +DBCMD_REF_VAL: .long 0x0c000000 +DBCMD_SRXT_VAL: .long 0x19000000 +DBKIND_D: .long 0x00000007 +DBCONF_D: .long 0x0f030a01 +DBTR0_D: .long 0x00000007 +DBTR1_D: .long 0x00000006 +DBTR2_D: .long 0x00000000 +DBTR3_D: .long 0x00000007 +DBTR4_D: .long 0x00070007 +DBTR5_D: .long 0x0000001b +DBTR6_D: .long 0x00000014 +DBTR7_D: .long 0x00000005 +DBTR8_D: .long 0x00000015 +DBTR9_D: .long 0x00000006 +DBTR10_D: .long 0x00000008 +DBTR11_D: .long 0x00000007 +DBTR12_D: .long 0x0000000e +DBTR13_D: .long 0x00000056 +DBTR14_D: .long 0x00000006 +DBTR15_D: .long 0x00000004 +DBTR16_D: .long 0x00150002 +DBTR17_D: .long 0x000c0017 +DBTR18_D: .long 0x00000200 +DBTR19_D: .long 0x00000040 +DBRNK0_D: .long 0x00000001 +DBPDCNT0_D: .long 0x00000001 +DBPDCNT1_D: .long 0x00000001 +DBPDCNT2_D: .long 0x00000000 +DBPDCNT3_D: .long 0x00004010 +DBPDLCK_D: .long 0x0000a55a +DBPDRGA_D: .long 0x00000028 +DBPDRGD_D: .long 0x00017100 + +DBADJ0_D: .long 0x00000000 +DBADJ1_D: .long 0x00000000 +DBADJ2_D: .long 0x18061806 +DBRFCNF0_D: .long 0x000001ff +DBRFCNF1_D: .long 0x08001000 +DBRFCNF2_D: .long 0x00000000 +DBCALCNF_D: .long 0x0000ffff +DBRFEN_D: .long 0x00000001 +DBACEN_D: .long 0x00000001 + +/*------- DDR-ECC -------*/ +ECD_ECDEN_A: .long ECD_ECDEN +ECD_ECDEN_D: .long 0x00000001 +ECD_INTSR_A: .long ECD_INTSR +ECD_INTSR_D: .long 0xffffffff +ECD_SPACER_A: .long ECD_SPACER +ECD_SPACER_D: .long SH7757LCR_SDRAM_ECC_SETTING +ECD_MCR_A: .long ECD_MCR +ECD_MCR_D: .long 0x00000001 + + .align 2 +exit_ddr: + +#if defined(CONFIG_SH_32BIT) + /*------- set PMB -------*/ + write32 PASCR_A, PASCR_29BIT_D + write32 MMUCR_A, MMUCR_D + + /***************************************************************** + * ent virt phys v sz c wt + * 0 0xa0000000 0x00000000 1 128M 0 1 + * 1 0xa8000000 0x48000000 1 128M 0 1 + * 5 0x88000000 0x48000000 1 128M 1 1 + */ + write32 PMB_ADDR_SPIBOOT_A, PMB_ADDR_SPIBOOT_D + write32 PMB_DATA_SPIBOOT_A, PMB_DATA_SPIBOOT_D + write32 PMB_ADDR_DDR_C1_A, PMB_ADDR_DDR_C1_D + write32 PMB_DATA_DDR_C1_A, PMB_DATA_DDR_C1_D + write32 PMB_ADDR_DDR_N1_A, PMB_ADDR_DDR_N1_D + write32 PMB_DATA_DDR_N1_A, PMB_DATA_DDR_N1_D + + write32 PMB_ADDR_ENTRY2, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY3, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY4, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY6, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY7, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY8, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY9, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY10, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY11, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY12, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY13, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY14, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY15, PMB_ADDR_NOT_USE_D + + write32 PASCR_A, PASCR_INIT + mov.l DUMMY_ADDR, r0 + icbi @r0 +#endif /* if defined(CONFIG_SH_32BIT) */ + +exit_pmb: + /* CPU is running on ILRAM? */ + mov r14, r0 + tst #1, r0 + bt 1f + + mov.l _bss_start, r15 + mov.l _spiboot_main, r0 +100: bsrf r0 + nop + + .align 2 +_spiboot_main: .long (spiboot_main - (100b + 4)) +_bss_start: .long bss_start + +1: + + write32 CCR_A, CCR_D + + rts + nop + + .align 4 + +#if defined(CONFIG_SH_32BIT) +/*------- set PMB -------*/ +PMB_ADDR_SPIBOOT_A: .long PMB_ADDR_BASE(0) +PMB_ADDR_DDR_N1_A: .long PMB_ADDR_BASE(1) +PMB_ADDR_DDR_C1_A: .long PMB_ADDR_BASE(5) +PMB_ADDR_ENTRY2: .long PMB_ADDR_BASE(2) +PMB_ADDR_ENTRY3: .long PMB_ADDR_BASE(3) +PMB_ADDR_ENTRY4: .long PMB_ADDR_BASE(4) +PMB_ADDR_ENTRY6: .long PMB_ADDR_BASE(6) +PMB_ADDR_ENTRY7: .long PMB_ADDR_BASE(7) +PMB_ADDR_ENTRY8: .long PMB_ADDR_BASE(8) +PMB_ADDR_ENTRY9: .long PMB_ADDR_BASE(9) +PMB_ADDR_ENTRY10: .long PMB_ADDR_BASE(10) +PMB_ADDR_ENTRY11: .long PMB_ADDR_BASE(11) +PMB_ADDR_ENTRY12: .long PMB_ADDR_BASE(12) +PMB_ADDR_ENTRY13: .long PMB_ADDR_BASE(13) +PMB_ADDR_ENTRY14: .long PMB_ADDR_BASE(14) +PMB_ADDR_ENTRY15: .long PMB_ADDR_BASE(15) + +PMB_ADDR_SPIBOOT_D: .long mk_pmb_addr_val(0xa0) +PMB_ADDR_DDR_C1_D: .long mk_pmb_addr_val(0x88) +PMB_ADDR_DDR_N1_D: .long mk_pmb_addr_val(0xa8) +PMB_ADDR_NOT_USE_D: .long 0x00000000 + +PMB_DATA_SPIBOOT_A: .long PMB_DATA_BASE(0) +PMB_DATA_DDR_N1_A: .long PMB_DATA_BASE(1) +PMB_DATA_DDR_C1_A: .long PMB_DATA_BASE(5) + +/* ppn ub v s1 s0 c wt */ +PMB_DATA_SPIBOOT_D: .long mk_pmb_data_val(0x00, 0, 1, 1, 0, 0, 1) +PMB_DATA_DDR_C1_D: .long mk_pmb_data_val(0x48, 0, 1, 1, 0, 1, 1) +PMB_DATA_DDR_N1_D: .long mk_pmb_data_val(0x48, 1, 1, 1, 0, 0, 1) + +PASCR_A: .long 0xff000070 +DUMMY_ADDR: .long 0xa0000000 +PASCR_29BIT_D: .long 0x00000000 +PASCR_INIT: .long 0x80000080 +MMUCR_A: .long 0xff000010 +MMUCR_D: .long 0x00000004 /* clear ITLB */ +#endif /* CONFIG_SH_32BIT */ + +CCR_A: .long CCR +CCR_D: .long CCR_CACHE_INIT diff --git a/board/renesas/sh7757lcr/sh7757lcr.c b/board/renesas/sh7757lcr/sh7757lcr.c new file mode 100644 index 0000000..abf1135 --- /dev/null +++ b/board/renesas/sh7757lcr/sh7757lcr.c @@ -0,0 +1,436 @@ +/* + * Copyright (C) 2011 Renesas Solutions Corp. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <spi_flash.h> + +int checkboard(void) +{ + puts("BOARD: R0P7757LC0030RL board\n"); + + return 0; +} + +static void init_gctrl(void) +{ + unsigned long graofst; + + graofst = (SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_GRA_OFFSET) >> 24; + writel(graofst | 0x20000f00, GCTRL_GRACR3); +} + +static int init_pcie_bridge_from_spi(void *buf, size_t size) +{ + struct spi_flash *spi; + int ret; + unsigned long pcie_addr; + + spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3); + if (!spi) { + printf("%s: spi_flash probe error.\n", __func__); + return 1; + } + + if (is_sh7757_b0()) + pcie_addr = SH7757LCR_PCIEBRG_ADDR_B0; + else + pcie_addr = SH7757LCR_PCIEBRG_ADDR; + + ret = spi_flash_read(spi, pcie_addr, size, buf); + if (ret) { + printf("%s: spi_flash read error.\n", __func__); + spi_flash_free(spi); + return 1; + } + spi_flash_free(spi); + + return 0; +} + +static void init_pcie_bridge(void) +{ + int i; + unsigned char *data; + unsigned short tmp; + unsigned long pcie_size; + + if (!(readw(PCIEBRG_CTRL_H8S) & 0x0001)) + return; + + if (is_sh7757_b0()) + pcie_size = SH7757LCR_PCIEBRG_SIZE_B0; + else + pcie_size = SH7757LCR_PCIEBRG_SIZE; + + data = malloc(pcie_size); + if (!data) { + printf("%s: malloc error.\n", __func__); + return; + } + if (init_pcie_bridge_from_spi(data, pcie_size)) { + free(data); + return; + } + + if (data[0] == 0xff && data[1] == 0xff && data[2] == 0xff && + data[3] == 0xff) { + free(data); + printf("%s: skipped initialization\n", __func__); + return; + } + + writew(0xa501, PCIEBRG_CTRL_H8S); /* reset */ + writew(0x0000, PCIEBRG_CP_CTRL); + writew(0x0000, PCIEBRG_CP_ADDR); + + for (i = 0; i < pcie_size; i += 2) { + tmp = (data[i] << 8) | data[i + 1]; + writew(tmp, PCIEBRG_CP_DATA); + } + + writew(0xa500, PCIEBRG_CTRL_H8S); /* start */ + if (!is_sh7757_b0()) + writel(0x00000001, PCIE_PBICTL3); + + free(data); +} + +static void init_usb_phy(void) +{ + writew(0x0100, USB0_PHY_RESET); /* set reset */ + /* port0 = USB0, port1 = USB1 */ + writew(0x0002, USB0_PHY_PORTSEL); + writel(0x0001, USB1_PORT1SEL); /* port1 = Host */ + writew(0x0111, USB0_PHY_RESET); /* clear reset */ + + writew(0x4000, USB0_SUSPMODE); + writew(0x4000, USB1_SUSPMODE); + +#if defined(__LITTLE_ENDIAN) + writel(0x00000000, USB1_EHCIDATAC); + writel(0x00000000, USB1_OHCIDATAC); +#endif +} + +static void mac_string_to_hex(unsigned char *mac, char *mac_string) +{ + int i; + char *s, *e; + + s = mac_string; + for (i = 0; i < 6; i++) { + mac[i] = s ? simple_strtoul(s, &e, 16) : 0; + if (s) + s = (*e) ? e + 1 : e; + } +} + +static void set_mac_to_sh_eth_register(int channel, char *mac_string) +{ +#define SH_ETH_BASE 0xfef00000 +#define MALR(port) (SH_ETH_BASE + 0x800 * (port) + 0x01c8) +#define MAHR(port) (SH_ETH_BASE + 0x800 * (port) + 0x01c0) + unsigned char mac[6]; + unsigned long val; + + mac_string_to_hex(mac, mac_string); + + val = (mac[0] << 24) | (mac[1] << 16) | (mac[2] << 8) | mac[3]; + writel(val, MAHR(channel)); + val = (mac[4] << 8) | mac[5]; + writel(val, MALR(channel)); +} + +static void set_mac_to_sh_giga_eth_register(int channel, char *mac_string) +{ +#define SH_GIGA_ETH_BASE 0xfee00000 +#define GIGA_MALR(port) (SH_GIGA_ETH_BASE + 0x800 * (port) + 0x05c8) +#define GIGA_MAHR(port) (SH_GIGA_ETH_BASE + 0x800 * (port) + 0x05c0) + + unsigned char mac[6]; + unsigned long val; + + mac_string_to_hex(mac, mac_string); + + val = (mac[0] << 24) | (mac[1] << 16) | (mac[2] << 8) | mac[3]; + writel(val, GIGA_MAHR(channel)); + val = (mac[4] << 8) | mac[5]; + writel(val, GIGA_MALR(channel)); +} + +/***************************************************************** + * This PMB must be set on this timing. The lowlevel_init is run on + * Area 0(phys 0x00000000), so we have to map it. + * + * The new PMB table is following: + * ent virt phys v sz c wt + * 0 0xa0000000 0x40000000 1 128M 0 1 + * 1 0xa8000000 0x48000000 1 128M 0 1 + * 2 0xb0000000 0x50000000 1 128M 0 1 + * 3 0xb8000000 0x58000000 1 128M 0 1 + * 4 0x80000000 0x40000000 1 128M 1 1 + * 5 0x88000000 0x48000000 1 128M 1 1 + * 6 0x90000000 0x50000000 1 128M 1 1 + * 7 0x98000000 0x58000000 1 128M 1 1 + */ +static void set_pmb_on_board_init(void) +{ + /* clear ITLB */ + writel(0x00000004, 0xff000010); + + /* delete PMB for SPIBOOT */ + writel(0, PMB_ADDR_BASE(0)); + writel(0, PMB_DATA_BASE(0)); + + /* add PMB for SDRAM(0x40000000 - 0x47ffffff) */ + /* ppn ub v s1 s0 c wt */ + writel(mk_pmb_addr_val(0xa0), PMB_ADDR_BASE(0)); + writel(mk_pmb_data_val(0x40, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(0)); + writel(mk_pmb_addr_val(0xb0), PMB_ADDR_BASE(2)); + writel(mk_pmb_data_val(0x50, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(2)); + writel(mk_pmb_addr_val(0xb8), PMB_ADDR_BASE(3)); + writel(mk_pmb_data_val(0x58, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(3)); + writel(mk_pmb_addr_val(0x80), PMB_ADDR_BASE(4)); + writel(mk_pmb_data_val(0x40, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(4)); + writel(mk_pmb_addr_val(0x90), PMB_ADDR_BASE(6)); + writel(mk_pmb_data_val(0x50, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(6)); + writel(mk_pmb_addr_val(0x98), PMB_ADDR_BASE(7)); + writel(mk_pmb_data_val(0x58, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(7)); +} + +int board_init(void) +{ + set_pmb_on_board_init(); + + /* enable RMII's MDIO (disable GRMII's MDIO) */ + writel(0x00030000, GETHER_GBECONT); + + init_gctrl(); + init_usb_phy(); + + return 0; +} + +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gd->bd->bi_memstart = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE; + printf("DRAM: %dMB\n", CONFIG_SYS_SDRAM_SIZE / (1024 * 1024)); + printf(" Physical address\n"); + printf(" 0x%08x - 0x%08x : Accessible Space as ECC Area\n", + SH7757LCR_SDRAM_PHYS_TOP, + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_SDRAM_SIZE - 1); + printf(" 0x%08x - 0x%08x : No Access Area\n", + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_SDRAM_SIZE, + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_SDRAM_SIZE * 2 - 1); + printf(" 0x%08x - 0x%08x : Non-ECC Area for DVC/AVC\n", + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_SDRAM_ECC_SETTING * 2, + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_SDRAM_ECC_SETTING * 2 + + SH7757LCR_SDRAM_DVC_SIZE - 1); + printf(" 0x%08x - 0x%08x : Non-ECC Area for G200eR2\n", + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_GRA_OFFSET, + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_GRA_OFFSET + 0x00ffffff); + + return 0; +} + +static int get_sh_eth_mac_raw(unsigned char *buf, int size) +{ + struct spi_flash *spi; + int ret; + + spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3); + if (spi == NULL) { + printf("%s: spi_flash probe error.\n", __func__); + return 1; + } + + ret = spi_flash_read(spi, SH7757LCR_ETHERNET_MAC_BASE, size, buf); + if (ret) { + printf("%s: spi_flash read error.\n", __func__); + spi_flash_free(spi); + return 1; + } + spi_flash_free(spi); +} + +static int get_sh_eth_mac(int channel, char *mac_string, unsigned char *buf) +{ + struct spi_flash *spi; + int ret; + + memcpy(mac_string, &buf[channel * (SH7757LCR_ETHERNET_MAC_SIZE + 1)], + SH7757LCR_ETHERNET_MAC_SIZE); + mac_string[SH7757LCR_ETHERNET_MAC_SIZE] = 0x00; /* terminate */ + + return 0; +} + +static void init_ethernet_mac(void) +{ + char mac_string[64]; + char env_string[64]; + int i; + unsigned char *buf; + + buf = malloc(256); + get_sh_eth_mac_raw(buf, 256); + + /* Fast Ethernet */ + for (i = 0; i < SH7757LCR_ETHERNET_NUM_CH; i++) { + get_sh_eth_mac(i, mac_string, buf); + if (i == 0) + setenv("ethaddr", mac_string); + else { + sprintf(env_string, "eth%daddr", i); + setenv(env_string, mac_string); + } + + set_mac_to_sh_eth_register(i, mac_string); + } + + /* Gigabit Ethernet */ + for (i = 0; i < SH7757LCR_GIGA_ETHERNET_NUM_CH; i++) { + get_sh_eth_mac(i + 2, mac_string, buf); + sprintf(env_string, "eth%daddr", i + 2); + setenv(env_string, mac_string); + + set_mac_to_sh_giga_eth_register(i, mac_string); + } + + free(buf); +} + +static void init_pcie(void) +{ + writel(0x00000ff2, PCIE_LADMSK0); + writel(0x00000001, PCIE_BARMAP0); + writel(0xffcaa000, PCIE_LAD0); + writel(0x00030000, PCIE_ENDICTL0); + writel(0x00000003, PCIE_ENDICTL1); + writel(0x00000004, PCIE_PBICTL2); +} + +static void finish_spiboot(void) +{ + /* + * SH7757 B0 does not use LBSC. + * So if we set SPIBOOTCAN to 1, SH7757 can not access Area0. + * This setting is not cleared by manual reset, So we have to set it + * to 0. + */ + writel(0x00000000, GCTRL_SPIBOOTCAN); +} + +int board_late_init(void) +{ + init_ethernet_mac(); + init_pcie_bridge(); + init_pcie(); + finish_spiboot(); + + return 0; +} + +int do_sh_g200(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned long graofst; + + writel(0xfedcba98, GCTRL_WPROTECT); + graofst = (SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_GRA_OFFSET) >> 24; + writel(graofst | 0xa0000f00, GCTRL_GRACR3); + + return 0; +} + +U_BOOT_CMD( + sh_g200, 1, 1, do_sh_g200, + "enable sh-g200", + "enable SH-G200 bus (disable PCIe-G200)" +); + +int do_write_mac(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + int i, ret; + char mac_string[256]; + struct spi_flash *spi; + unsigned char *buf; + + if (argc != 5) { + buf = malloc(256); + get_sh_eth_mac_raw(buf, 256); + + /* print current MAC address */ + for (i = 0; i < 4; i++) { + get_sh_eth_mac(i, mac_string, buf); + if (i < 2) + printf(" ETHERC ch%d = %s\n", i, mac_string); + else + printf("GETHERC ch%d = %s\n", i-2, mac_string); + } + free(buf); + return 0; + } + + /* new setting */ + memset(mac_string, 0xff, sizeof(mac_string)); + sprintf(mac_string, "%s\t%s\t%s\t%s", + argv[1], argv[2], argv[3], argv[4]); + + /* write MAC data to SPI rom */ + spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3); + if (!spi) { + printf("%s: spi_flash probe error.\n", __func__); + return 1; + } + + ret = spi_flash_erase(spi, SH7757LCR_ETHERNET_MAC_BASE_SPI, + SH7757LCR_SPI_SECTOR_SIZE); + if (ret) { + printf("%s: spi_flash erase error.\n", __func__); + return 1; + } + + ret = spi_flash_write(spi, SH7757LCR_ETHERNET_MAC_BASE_SPI, + sizeof(mac_string), mac_string); + if (ret) { + printf("%s: spi_flash write error.\n", __func__); + spi_flash_free(spi); + return 1; + } + spi_flash_free(spi); + + puts("The writing of the MAC address to SPI ROM was completed.\n"); + + return 0; +} + +U_BOOT_CMD( + write_mac, 5, 1, do_write_mac, + "write MAC address for ETHERC/GETHERC", + "[ETHERC ch0] [ETHERC ch1] [GETHERC ch0] [GETHERC ch1]\n" +); diff --git a/board/renesas/sh7757lcr/spi-boot.c b/board/renesas/sh7757lcr/spi-boot.c new file mode 100644 index 0000000..44cc278 --- /dev/null +++ b/board/renesas/sh7757lcr/spi-boot.c @@ -0,0 +1,111 @@ +/* + * Copyright (C) 2011 Renesas Solutions Corp. + * + * This file is subject to the terms and conditions of the GNU Lesser + * General Public License. See the file "COPYING.LIB" in the main + * directory of this archive for more details. + */ + +#include <common.h> + +#define CONFIG_RAM_BOOT_PHYS 0x4ef80000 +#if defined(CONFIG_SH7757_OFFSET_SPI) +#define CONFIG_SPI_ADDR 0x00010000 +#else +#define CONFIG_SPI_ADDR 0x00000000 +#endif +#define CONFIG_SPI_LENGTH 0x00030000 +#define CONFIG_RAM_BOOT 0x8ef80000 + +#define SPIWDMADR 0xFE001018 +#define SPIWDMCNTR 0xFE001020 +#define SPIDMCOR 0xFE001028 +#define SPIDMINTSR 0xFE001188 +#define SPIDMINTMR 0xFE001190 + +#define SPIDMINTSR_DMEND 0x00000004 + +#define TBR 0xFE002000 +#define RBR 0xFE002000 + +#define CR1 0xFE002008 +#define CR2 0xFE002010 +#define CR3 0xFE002018 +#define CR4 0xFE002020 + +/* CR1 */ +#define SPI_TBE 0x80 +#define SPI_TBF 0x40 +#define SPI_RBE 0x20 +#define SPI_RBF 0x10 +#define SPI_PFONRD 0x08 +#define SPI_SSDB 0x04 +#define SPI_SSD 0x02 +#define SPI_SSA 0x01 + +/* CR2 */ +#define SPI_RSTF 0x80 +#define SPI_LOOPBK 0x40 +#define SPI_CPOL 0x20 +#define SPI_CPHA 0x10 +#define SPI_L1M0 0x08 + +/* CR4 */ +#define SPI_TBEI 0x80 +#define SPI_TBFI 0x40 +#define SPI_RBEI 0x20 +#define SPI_RBFI 0x10 +#define SPI_SSS 0x01 + +#define spi_write(val, addr) (*(volatile unsigned long *)(addr)) = val +#define spi_read(addr) (*(volatile unsigned long *)(addr)) + +/* M25P80 */ +#define M25_READ 0x03 + +#define __uses_spiboot2 __attribute__((section(".spiboot2.text"))) +static void __uses_spiboot2 spi_reset(void) +{ + spi_write(0xfe, CR1); + + spi_write(0, SPIDMCOR); + spi_write(0x00, CR1); + + spi_write(spi_read(CR2) | SPI_RSTF, CR2); /* fifo reset */ + spi_write(spi_read(CR2) & ~SPI_RSTF, CR2); +} + +static void __uses_spiboot2 spi_read_flash(void *buf, unsigned long addr, + unsigned long len) +{ + volatile unsigned long i; + + spi_write(M25_READ, TBR); + spi_write((addr >> 16) & 0xFF, TBR); + spi_write((addr >> 8) & 0xFF, TBR); + spi_write(addr & 0xFF, TBR); + + spi_write(SPIDMINTSR_DMEND, SPIDMINTSR); + spi_write(buf, SPIWDMADR); + spi_write(len & 0xFFFFFFE0, SPIWDMCNTR); + spi_write(1, SPIDMCOR); + + spi_write(0xff, CR3); + spi_write(spi_read(CR1) | SPI_SSDB, CR1); + spi_write(spi_read(CR1) | SPI_SSA, CR1); + + while (!(spi_read(SPIDMINTSR) & SPIDMINTSR_DMEND)) + ; +} + +void __uses_spiboot2 spiboot_main(void) +{ + void (*_start)(void) = CONFIG_SYS_TEXT_BASE; + + spi_reset(); + spi_read_flash((void *)CONFIG_RAM_BOOT_PHYS, CONFIG_SPI_ADDR, + CONFIG_SPI_LENGTH); + + _start(); +} + diff --git a/board/renesas/sh7757lcr/u-boot.lds b/board/renesas/sh7757lcr/u-boot.lds new file mode 100644 index 0000000..6255649 --- /dev/null +++ b/board/renesas/sh7757lcr/u-boot.lds @@ -0,0 +1,101 @@ +/* + * Copyright (C) 2007 + * Nobuhiro Iwamatsu iwamatsu@nigauri.org + * + * Copyright (C) 2008-2009 + * Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") +OUTPUT_ARCH(sh) +ENTRY(_start) + +SECTIONS +{ + /* + * entry and reloct_dst will be provided via ldflags + */ + . = .; + + PROVIDE (_ftext = .); + PROVIDE (_fcode = .); + PROVIDE (_start = .); + + .text : + { + arch/sh/cpu/sh4/start.o (.text) + *(.spiboot1.text) + *(.spiboot2.text) + . = ALIGN(8192); + common/env_embedded.o (.ppcenv) + . = ALIGN(8192); + common/env_embedded.o (.ppcenvr) + . = ALIGN(8192); + *(.text) + . = ALIGN(4); + } =0xFF + PROVIDE (_ecode = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + . = ALIGN(4); + } + PROVIDE (_etext = .); + + + PROVIDE (_fdata = .); + .data : + { + *(.data) + . = ALIGN(4); + } + PROVIDE (_edata = .); + + PROVIDE (_fgot = .); + .got : + { + *(.got) + . = ALIGN(4); + } + PROVIDE (_egot = .); + + PROVIDE (__u_boot_cmd_start = .); + .u_boot_cmd : + { + *(.u_boot_cmd) + . = ALIGN(4); + } + PROVIDE (__u_boot_cmd_end = .); + + PROVIDE (reloc_dst_end = .); + /* _reloc_dst_end = .; */ + + PROVIDE (bss_start = .); + PROVIDE (__bss_start = .); + .bss (NOLOAD) : + { + *(.bss) + . = ALIGN(4); + } + PROVIDE (bss_end = .); + + PROVIDE (_end = .); +} diff --git a/boards.cfg b/boards.cfg index 0574bb2..417ed1d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -752,6 +752,7 @@ ms7750se sh sh4 ms7750se - ap325rxa sh sh4 ap325rxa renesas - r2dplus sh sh4 r2dplus renesas - r7780mp sh sh4 r7780mp renesas - +sh7757lcr sh sh4 sh7757lcr renesas - sh7763rdp sh sh4 sh7763rdp renesas - sh7785lcr sh sh4 sh7785lcr renesas - sh7785lcr_32bit sh sh4 sh7785lcr renesas - sh7785lcr:SH_32BIT=1 diff --git a/doc/README.sh7757lcr b/doc/README.sh7757lcr new file mode 100644 index 0000000..cae14e0 --- /dev/null +++ b/doc/README.sh7757lcr @@ -0,0 +1,64 @@ +======================================== +Renesas R0P7757LC0030RL board +======================================== + +This board specification: +========================= + +The R0P7757LC0030RL(board config name:sh7757lcr) has the following device: + + - SH7757 (SH-4A) + - DDR3-SDRAM 256MB (with ECC) + - SPI ROM 8MB + - 2D Graphic controller + - Ethernet controller + + +configuration for This board: +============================= + +You can select the configuration as follows: + + - make sh7785lcr_config + + +This board specific command: +============================ + +This board has the following its specific command: + + - sh_g200 + - write_mac + + +1. sh_g200 + +If we run this command, SH4 can control the G200. +The default setting is that SH4 cannot control the G200. + + +2. write_mac + +You can write MAC address to SPI ROM. + + Usage 1) Write MAC address + + write_mac [ETHERC ch0] [ETHERC ch1] [GETHERC ch0] [GETHERC ch1] + + For example) + => write_mac 00:00:87:6c:21:80 00:00:87:6c:21:81 00:00:87:6c:21:82 00:00:87:6c:21:83 + *) We have to input the command as a single line + (without carriage return) + *) We have to reset after input the command. + + Usage 2) Show current data + + write_mac + + For example) + => write_mac + ETHERC ch0 = 00:00:87:6c:21:80 + ETHERC ch1 = 00:00:87:6c:21:81 + GETHERC ch0 = 00:00:87:6c:21:82 + GETHERC ch1 = 00:00:87:6c:21:83 + diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h new file mode 100644 index 0000000..c9dca42 --- /dev/null +++ b/include/configs/sh7757lcr.h @@ -0,0 +1,143 @@ +/* + * Configuation settings for the sh7757lcr board + * + * Copyright (C) 2011 Renesas Solutions Corp. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __SH7757LCR_H +#define __SH7757LCR_H + +#undef DEBUG +#define CONFIG_SH 1 +#define CONFIG_SH4A 1 +#define CONFIG_SH_32BIT 1 +#define CONFIG_CPU_SH7757 1 +#define CONFIG_SH7757LCR 1 + +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_NFS +#define CONFIG_CMD_DFL +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_SF +#define CONFIG_CMD_RUN +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_MD5SUM +#define CONFIG_MD5 +#define CONFIG_CMD_LOADS + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp" + +#define CONFIG_VERSION_VARIABLE +#undef CONFIG_SHOW_BOOT_PROGRESS + +/* MEMORY */ +#define SH7757LCR_SDRAM_BASE (0x80000000) +#define SH7757LCR_SDRAM_SIZE (240 * 1024 * 1024) +#define SH7757LCR_SDRAM_ECC_SETTING 0x0f000000 /* 240MByte */ +#define SH7757LCR_SDRAM_DVC_SIZE (16 * 1024 * 1024) + +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE 512 +#define CONFIG_SYS_BAUDRATE_TABLE { 115200 } + +/* SCIF */ +#define CONFIG_SCIF_CONSOLE 1 +#define CONFIG_CONS_SCIF2 1 +#undef CONFIG_SYS_CONSOLE_INFO_QUIET +#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE + +#define CONFIG_SYS_MEMTEST_START (SH7757LCR_SDRAM_BASE) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ + 224 * 1024 * 1024) +#undef CONFIG_SYS_ALT_MEMTEST +#undef CONFIG_SYS_MEMTEST_SCRATCH +#undef CONFIG_SYS_LOADS_BAUD_CHANGE + +#define CONFIG_SYS_SDRAM_BASE (SH7757LCR_SDRAM_BASE) +#define CONFIG_SYS_SDRAM_SIZE (SH7757LCR_SDRAM_SIZE) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + \ + (128 + 16) * 1024 * 1024) + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) +#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) + +/* FLASH */ +#define CONFIG_SYS_NO_FLASH + +/* Ether */ +#define CONFIG_NET_MULTI 1 +#define CONFIG_SH_ETHER 1 +#define CONFIG_SH_ETHER_USE_PORT 0 +#define CONFIG_SH_ETHER_PHY_ADDR 1 +#define CONFIG_SH_ETHER_CACHE_WRITEBACK 1 + +#define SH7757LCR_ETHERNET_MAC_BASE_SPI 0x000b0000 +#define SH7757LCR_SPI_SECTOR_SIZE (64 * 1024) +#define SH7757LCR_ETHERNET_MAC_BASE SH7757LCR_ETHERNET_MAC_BASE_SPI +#define SH7757LCR_ETHERNET_MAC_SIZE 17 +#define SH7757LCR_ETHERNET_NUM_CH 2 +#define BOARD_LATE_INIT 1 + +/* Gigabit Ether */ +#define SH7757LCR_GIGA_ETHERNET_NUM_CH 2 + +/* SPI */ +#define CONFIG_SH_SPI 1 +#define CONFIG_SH_SPI_BASE 0xfe002000 +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO 1 + +/* SH7757 board */ +#define SH7757LCR_SDRAM_PHYS_TOP 0x40000000 +#define SH7757LCR_GRA_OFFSET 0x1f000000 +#define SH7757LCR_PCIEBRG_ADDR_B0 0x000a0000 +#define SH7757LCR_PCIEBRG_SIZE_B0 (64 * 1024) +#define SH7757LCR_PCIEBRG_ADDR 0x00090000 +#define SH7757LCR_PCIEBRG_SIZE (96 * 1024) + +/* ENV setting */ +#define CONFIG_ENV_IS_EMBEDDED +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SECT_SIZE (64 * 1024) +#define CONFIG_ENV_ADDR (0x00080000) +#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE) +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netboot=bootp; bootm\0" + +/* Board Clock */ +#define CONFIG_SYS_CLK_FREQ 48000000 +#define CONFIG_SYS_TMU_CLK_DIV 4 +#define CONFIG_SYS_HZ 1000 +#endif /* __SH7757LCR_H */
- 256MB DDR3-SDRAM
- SPI ROM
- Ethernet
- Copyright (C) 2011 Renesas Solutions Corp.
- MA 02111-1307 USA
- int __ret = prr_mask(__raw_readl(CCN_PRR)) == PRR_SH7757_B0; \
- __ret; \
- $(call cmd_link_o_target, $(COBJS) $(SOBJS))
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj).depend
Is this nesseary?
Please move this to config file of board.
- MA 02111-1307 USA
- mov.l \addr, r1
- mov.l \data, r0
- mov.l @r1, r2
- or r2, r0
- mov.l r0, @r1
+.endm
+.macro wait_DBCMD
- mov.l DBWAIT_A, r0
- mov.l @r0, r1
+.endm
- .global lowlevel_init
- .section .spiboot1.text
- .align 2
+lowlevel_init:
- /*------- GPIO -------*/
- write8 PGDR_A, PGDR_D /* eMMC power off */
- write16 PACR_A, PACR_D
- write16 PBCR_A, PBCR_D
- write16 PCCR_A, PCCR_D
- write16 PDCR_A, PDCR_D
- write16 PECR_A, PECR_D
- write16 PFCR_A, PFCR_D
- write16 PGCR_A, PGCR_D
- write16 PHCR_A, PHCR_D
- write16 PICR_A, PICR_D
- write16 PJCR_A, PJCR_D
- write16 PKCR_A, PKCR_D
- write16 PLCR_A, PLCR_D
- write16 PMCR_A, PMCR_D
- write16 PNCR_A, PNCR_D
- write16 POCR_A, POCR_D
- write16 PQCR_A, PQCR_D
- write16 PRCR_A, PRCR_D
- write16 PSCR_A, PSCR_D
- write16 PTCR_A, PTCR_D
- write16 PUCR_A, PUCR_D
- write16 PVCR_A, PVCR_D
- write16 PWCR_A, PWCR_D
- write16 PXCR_A, PXCR_D
- write16 PYCR_A, PYCR_D
- write16 PZCR_A, PZCR_D
- write16 PSEL0_A, PSEL0_D
- write16 PSEL1_A, PSEL1_D
- write16 PSEL2_A, PSEL2_D
- write16 PSEL3_A, PSEL3_D
- write16 PSEL4_A, PSEL4_D
- write16 PSEL5_A, PSEL5_D
- write16 PSEL6_A, PSEL6_D
- write16 PSEL7_A, PSEL7_D
- write16 PSEL8_A, PSEL8_D
- bra exit_gpio
- nop
- .align 4
- .align 2
+exit_gpio:
- mov #0, r14
- mova 2f, r0
- mov.l PC_MASK, r1
- tst r0, r1
- bf 2f
- bra exit_pmb
- nop
- .align 2
+2:
- mov #1, r14
- mov.l EXPEVT_A, r0
- mov.l @r0, r0
- mov.l EXPEVT_POWER_ON_RESET, r1
- cmp/eq r0, r1
- bt 1f
- bra exit_ddr
- nop
+1:
- /* For Core Reset */
- mov.l DBACEN_A, r0
- mov.l @r0, r0
- cmp/eq #0, r0
- bt 3f
- bra exit_ddr
- nop
+3:
- /*------- DDR3IF -------*/
- /* oscillation stabilization time */
- wait_timer WAIT_OSC_TIME
- /* step 3 */
- write32 DBCMD_A, DBCMD_RSTL_VAL
- wait_timer WAIT_30US
- /* step 4 */
- write32 DBCMD_A, DBCMD_PDEN_VAL
- /* step 5 */
- write32 DBKIND_A, DBKIND_D
- /* step 6 */
- write32 DBCONF_A, DBCONF_D
- write32 DBTR0_A, DBTR0_D
- write32 DBTR1_A, DBTR1_D
- write32 DBTR2_A, DBTR2_D
- write32 DBTR3_A, DBTR3_D
- write32 DBTR4_A, DBTR4_D
- write32 DBTR5_A, DBTR5_D
- write32 DBTR6_A, DBTR6_D
- write32 DBTR7_A, DBTR7_D
- write32 DBTR8_A, DBTR8_D
- write32 DBTR9_A, DBTR9_D
- write32 DBTR10_A, DBTR10_D
- write32 DBTR11_A, DBTR11_D
- write32 DBTR12_A, DBTR12_D
- write32 DBTR13_A, DBTR13_D
- write32 DBTR14_A, DBTR14_D
- write32 DBTR15_A, DBTR15_D
- write32 DBTR16_A, DBTR16_D
- write32 DBTR17_A, DBTR17_D
- write32 DBTR18_A, DBTR18_D
- write32 DBTR19_A, DBTR19_D
- write32 DBRNK0_A, DBRNK0_D
- /* step 7 */
- write32 DBPDCNT3_A, DBPDCNT3_D
- /* step 8 */
- write32 DBPDCNT1_A, DBPDCNT1_D
- write32 DBPDCNT2_A, DBPDCNT2_D
- write32 DBPDLCK_A, DBPDLCK_D
- write32 DBPDRGA_A, DBPDRGA_D
- write32 DBPDRGD_A, DBPDRGD_D
- /* step 9 */
- /* step 10 */
- write32 DBPDCNT0_A, DBPDCNT0_D
- /* step 11 */
- /* step 12 */
- write32 DBCMD_A, DBCMD_WAIT_VAL
- wait_DBCMD
- /* step 13 */
- write32 DBCMD_A, DBCMD_RSTH_VAL
- wait_DBCMD
- /* step 14 */
- /* step 15 */
- write32 DBCMD_A, DBCMD_PDXT_VAL
- /* step 16 */
- write32 DBCMD_A, DBCMD_MRS2_VAL
- /* step 17 */
- write32 DBCMD_A, DBCMD_MRS3_VAL
- /* step 18 */
- write32 DBCMD_A, DBCMD_MRS1_VAL
- /* step 19 */
- write32 DBCMD_A, DBCMD_MRS0_VAL
- /* step 20 */
- write32 DBCMD_A, DBCMD_ZQCL_VAL
- write32 DBCMD_A, DBCMD_REF_VAL
- wait_DBCMD
- /* step 21 */
- write32 DBADJ0_A, DBADJ0_D
- write32 DBADJ1_A, DBADJ1_D
- write32 DBADJ2_A, DBADJ2_D
- /* step 22 */
- write32 DBRFCNF0_A, DBRFCNF0_D
- write32 DBRFCNF1_A, DBRFCNF1_D
- write32 DBRFCNF2_A, DBRFCNF2_D
- /* step 23 */
- write32 DBCALCNF_A, DBCALCNF_D
- /* step 24 */
- write32 DBRFEN_A, DBRFEN_D
- write32 DBCMD_A, DBCMD_SRXT_VAL
- /* step 25 */
- write32 DBACEN_A, DBACEN_D
- /* step 26 */
- wait_DBCMD
- /* enable DDR-ECC */
- write32 ECD_ECDEN_A, ECD_ECDEN_D
- write32 ECD_INTSR_A, ECD_INTSR_D
- write32 ECD_SPACER_A, ECD_SPACER_D
- write32 ECD_MCR_A, ECD_MCR_D
- bra exit_ddr
- nop
- .align 4
- .align 2
+exit_ddr:
- /*------- set PMB -------*/
- write32 PASCR_A, PASCR_29BIT_D
- write32 MMUCR_A, MMUCR_D
- write32 PMB_ADDR_SPIBOOT_A, PMB_ADDR_SPIBOOT_D
- write32 PMB_DATA_SPIBOOT_A, PMB_DATA_SPIBOOT_D
- write32 PMB_ADDR_DDR_C1_A, PMB_ADDR_DDR_C1_D
- write32 PMB_DATA_DDR_C1_A, PMB_DATA_DDR_C1_D
- write32 PMB_ADDR_DDR_N1_A, PMB_ADDR_DDR_N1_D
- write32 PMB_DATA_DDR_N1_A, PMB_DATA_DDR_N1_D
- write32 PMB_ADDR_ENTRY2, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY3, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY4, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY6, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY7, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY8, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY9, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY10, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY11, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY12, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY13, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY14, PMB_ADDR_NOT_USE_D
- write32 PMB_ADDR_ENTRY15, PMB_ADDR_NOT_USE_D
- write32 PASCR_A, PASCR_INIT
- mov.l DUMMY_ADDR, r0
- icbi @r0
+exit_pmb:
- /* CPU is running on ILRAM? */
- mov r14, r0
- tst #1, r0
- bt 1f
- mov.l _bss_start, r15
- mov.l _spiboot_main, r0
+100: bsrf r0
- nop
- .align 2
+1:
- write32 CCR_A, CCR_D
- rts
nop
- .align 4
- project.
- MA 02111-1307 USA
- puts("BOARD: R0P7757LC0030RL board\n");
- unsigned long graofst;
- graofst = (SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_GRA_OFFSET) >> 24;
- writel(graofst | 0x20000f00, GCTRL_GRACR3);
- struct spi_flash *spi;
- int ret;
- unsigned long pcie_addr;
- spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3);
- if (!spi) {
return 1;
- if (is_sh7757_b0())
- else
- ret = spi_flash_read(spi, pcie_addr, size, buf);
- if (ret) {
return 1;
- spi_flash_free(spi);
- int i;
- unsigned char *data;
- unsigned short tmp;
- unsigned long pcie_size;
- if (!(readw(PCIEBRG_CTRL_H8S) & 0x0001))
return;
- else
- data = malloc(pcie_size);
- if (!data) {
return;
- if (init_pcie_bridge_from_spi(data, pcie_size)) {
free(data);
return;
- if (data[0] == 0xff && data[1] == 0xff && data[2] == 0xff &&
data[3] == 0xff) {
free(data);
return;
- writew(0xa501, PCIEBRG_CTRL_H8S); /* reset */
- writew(0x0000, PCIEBRG_CP_CTRL);
- writew(0x0000, PCIEBRG_CP_ADDR);
- for (i = 0; i < pcie_size; i += 2) {
- writew(0xa500, PCIEBRG_CTRL_H8S); /* start */
- if (!is_sh7757_b0())
- free(data);
- writew(0x0100, USB0_PHY_RESET); /* set reset */
- /* port0 = USB0, port1 = USB1 */
- writew(0x0002, USB0_PHY_PORTSEL);
- writel(0x0001, USB1_PORT1SEL); /* port1 = Host */
- writew(0x0111, USB0_PHY_RESET); /* clear reset */
- writew(0x4000, USB0_SUSPMODE);
- writew(0x4000, USB1_SUSPMODE);
- writel(0x00000000, USB1_EHCIDATAC);
- writel(0x00000000, USB1_OHCIDATAC);
+#endif +}
- int i;
- char *s, *e;
- s = mac_string;
- for (i = 0; i < 6; i++) {
if (s)
Please use eth_parse_enetaddr.
- unsigned char mac[6];
- unsigned long val;
- mac_string_to_hex(mac, mac_string);
- val = (mac[0] << 24) | (mac[1] << 16) | (mac[2] << 8) | mac[3];
- writel(val, MAHR(channel));
- val = (mac[4] << 8) | mac[5];
- writel(val, MALR(channel));
- writel(val, GIGA_MAHR(channel));
- writel(val, GIGA_MALR(channel));
- This PMB must be set on this timing. The lowlevel_init is run on
- Area 0(phys 0x00000000), so we have to map it.
- The new PMB table is following:
- ent virt phys v sz c wt
- 0 0xa0000000 0x40000000 1 128M 0 1
- 1 0xa8000000 0x48000000 1 128M 0 1
- 2 0xb0000000 0x50000000 1 128M 0 1
- 3 0xb8000000 0x58000000 1 128M 0 1
- 4 0x80000000 0x40000000 1 128M 1 1
- 5 0x88000000 0x48000000 1 128M 1 1
- 6 0x90000000 0x50000000 1 128M 1 1
- 7 0x98000000 0x58000000 1 128M 1 1
- /* clear ITLB */
- writel(0x00000004, 0xff000010);
- /* delete PMB for SPIBOOT */
- writel(0, PMB_ADDR_BASE(0));
- writel(0, PMB_DATA_BASE(0));
- /* add PMB for SDRAM(0x40000000 - 0x47ffffff) */
- /* ppn ub v s1 s0 c wt */
- writel(mk_pmb_addr_val(0xa0), PMB_ADDR_BASE(0));
- writel(mk_pmb_data_val(0x40, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(0));
- writel(mk_pmb_addr_val(0xb0), PMB_ADDR_BASE(2));
- writel(mk_pmb_data_val(0x50, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(2));
- writel(mk_pmb_addr_val(0xb8), PMB_ADDR_BASE(3));
- writel(mk_pmb_data_val(0x58, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(3));
- writel(mk_pmb_addr_val(0x80), PMB_ADDR_BASE(4));
- writel(mk_pmb_data_val(0x40, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(4));
- writel(mk_pmb_addr_val(0x90), PMB_ADDR_BASE(6));
- writel(mk_pmb_data_val(0x50, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(6));
- writel(mk_pmb_addr_val(0x98), PMB_ADDR_BASE(7));
- writel(mk_pmb_data_val(0x58, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(7));
- set_pmb_on_board_init();
- /* enable RMII's MDIO (disable GRMII's MDIO) */
- writel(0x00030000, GETHER_GBECONT);
- init_gctrl();
- init_usb_phy();
- DECLARE_GLOBAL_DATA_PTR;
- gd->bd->bi_memstart = CONFIG_SYS_SDRAM_BASE;
- gd->bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE;
- printf("DRAM: %dMB\n", CONFIG_SYS_SDRAM_SIZE / (1024 * 1024));
- printf(" Physical address\n");
- printf(" 0x%08x - 0x%08x : Accessible Space as ECC Area\n",
- printf(" 0x%08x - 0x%08x : No Access Area\n",
- printf(" 0x%08x - 0x%08x : Non-ECC Area for DVC/AVC\n",
- printf(" 0x%08x - 0x%08x : Non-ECC Area for G200eR2\n",
- int ret;
- if (spi == NULL) {
return 1;
- ret = spi_flash_read(spi, SH7757LCR_ETHERNET_MAC_BASE, size, buf);
- if (ret) {
return 1;
- int ret;
- memcpy(mac_string, &buf[channel * (SH7757LCR_ETHERNET_MAC_SIZE + 1)],
- mac_string[SH7757LCR_ETHERNET_MAC_SIZE] = 0x00; /* terminate */
- char mac_string[64];
- char env_string[64];
- int i;
- unsigned char *buf;
- buf = malloc(256);
Please add NULL check.
- get_sh_eth_mac_raw(buf, 256);
- /* Fast Ethernet */
- for (i = 0; i < SH7757LCR_ETHERNET_NUM_CH; i++) {
if (i == 0)
else {
- /* Gigabit Ethernet */
- for (i = 0; i < SH7757LCR_GIGA_ETHERNET_NUM_CH; i++) {
I think that you should use i + SH7757LCR_ETHERNET_NUM_CH.
- free(buf);
- writel(0x00000ff2, PCIE_LADMSK0);
- writel(0x00000001, PCIE_BARMAP0);
- writel(0xffcaa000, PCIE_LAD0);
- writel(0x00030000, PCIE_ENDICTL0);
- writel(0x00000003, PCIE_ENDICTL1);
- writel(0x00000004, PCIE_PBICTL2);
* to 0.
- writel(0x00000000, GCTRL_SPIBOOTCAN);
- init_ethernet_mac();
- init_pcie_bridge();
- init_pcie();
- finish_spiboot();
- writel(0xfedcba98, GCTRL_WPROTECT);
- writel(graofst | 0xa0000f00, GCTRL_GRACR3);
+U_BOOT_CMD(
- sh_g200, 1, 1, do_sh_g200,
- "enable sh-g200",
- "enable SH-G200 bus (disable PCIe-G200)"
- int i, ret;
- char mac_string[256];
- if (argc != 5) {
buf = malloc(256);
please add NULL check.
if (i < 2)
else
free(buf);
- /* new setting */
- memset(mac_string, 0xff, sizeof(mac_string));
- sprintf(mac_string, "%s\t%s\t%s\t%s",
- /* write MAC data to SPI rom */
- if (!spi) {
return 1;
- ret = spi_flash_erase(spi, SH7757LCR_ETHERNET_MAC_BASE_SPI,
- if (ret) {
return 1;
- ret = spi_flash_write(spi, SH7757LCR_ETHERNET_MAC_BASE_SPI,
- if (ret) {
return 1;
- puts("The writing of the MAC address to SPI ROM was completed.\n");
+U_BOOT_CMD(
- write_mac, 5, 1, do_write_mac,
- "write MAC address for ETHERC/GETHERC",
- "[ETHERC ch0] [ETHERC ch1] [GETHERC ch0] [GETHERC ch1]\n"
- This file is subject to the terms and conditions of the GNU Lesser
- General Public License. See the file "COPYING.LIB" in the main
- directory of this archive for more details.
- spi_write(0xfe, CR1);
- spi_write(0, SPIDMCOR);
- spi_write(0x00, CR1);
- spi_write(spi_read(CR2) | SPI_RSTF, CR2); /* fifo reset */
- spi_write(spi_read(CR2) & ~SPI_RSTF, CR2);
unsigned long len)
- volatile unsigned long i;
- spi_write(M25_READ, TBR);
- spi_write((addr >> 16) & 0xFF, TBR);
- spi_write((addr >> 8) & 0xFF, TBR);
- spi_write(addr & 0xFF, TBR);
- spi_write(SPIDMINTSR_DMEND, SPIDMINTSR);
- spi_write(buf, SPIWDMADR);
- spi_write(len & 0xFFFFFFE0, SPIWDMCNTR);
- spi_write(1, SPIDMCOR);
- spi_write(0xff, CR3);
- spi_write(spi_read(CR1) | SPI_SSDB, CR1);
- spi_write(spi_read(CR1) | SPI_SSA, CR1);
- while (!(spi_read(SPIDMINTSR) & SPIDMINTSR_DMEND))
- void (*_start)(void) = CONFIG_SYS_TEXT_BASE;
- spi_reset();
- spi_read_flash((void *)CONFIG_RAM_BOOT_PHYS, CONFIG_SPI_ADDR,
CONFIG_SPI_LENGTH);
- _start();
- Copyright (C) 2007
- Nobuhiro Iwamatsu iwamatsu@nigauri.org
- Copyright (C) 2008-2009
- Yoshihiro Shimoda shimoda.yoshihiro@renesas.com
Please update your copyright.
- project.
- MA 02111-1307 USA
+SECTIONS +{
- PROVIDE (_ftext = .);
- PROVIDE (_fcode = .);
- PROVIDE (_start = .);
- .text :
*(.spiboot1.text)
*(.spiboot2.text)
. = ALIGN(8192);
. = ALIGN(8192);
. = ALIGN(8192);
*(.text)
. = ALIGN(4);
- } =0xFF
- PROVIDE (_ecode = .);
- .rodata :
. = ALIGN(4);
- PROVIDE (_etext = .);
- PROVIDE (_fdata = .);
- .data :
*(.data)
. = ALIGN(4);
- PROVIDE (_edata = .);
- PROVIDE (_fgot = .);
- .got :
*(.got)
. = ALIGN(4);
- PROVIDE (_egot = .);
- PROVIDE (__u_boot_cmd_start = .);
- .u_boot_cmd :
*(.u_boot_cmd)
. = ALIGN(4);
- PROVIDE (__u_boot_cmd_end = .);
- PROVIDE (reloc_dst_end = .);
- /* _reloc_dst_end = .; */
- PROVIDE (bss_start = .);
- PROVIDE (__bss_start = .);
- .bss (NOLOAD) :
*(.bss)
. = ALIGN(4);
- PROVIDE (bss_end = .);
- PROVIDE (_end = .);
- SH7757 (SH-4A)
- SPI ROM 8MB
- sh_g200
- write_mac
+1. sh_g200
+2. write_mac
- Usage 1) Write MAC address
- write_mac [ETHERC ch0] [ETHERC ch1] [GETHERC ch0] [GETHERC ch1]
- For example)
- Usage 2) Show current data
- write_mac
- For example)
=> write_mac
- Configuation settings for the sh7757lcr board
- project.
- MA 02111-1307 USA
224 * 1024 * 1024)
1.7.1
Hi, Iwamatsu-san,
Thank you for your review!
Is this nesseary?
The "#sinclude" is not nessesary. I will remove it. However the "LDSCRIPT" is necessary on this board because the LSI needs the top of address when booting.
I will move it.
- int i;
- char *s, *e;
- s = mac_string;
if (s)
Oh, I didn't know that function. I will replace it.
- int i;
OK, I will add it.
Thank you. I will modify it.
- int i, ret;
- if (argc != 5) {
buf = malloc(256);
I will modify it.
OK, I will update it.
Best regards, Yoshihiro Shimoda
Dear Yoshihiro Shimoda,
In message 4D3547B8.6020705@renesas.com you wrote:
Is this nesseary?
Please ditch the whole config.mk file and define LDSCRIPT in your board config file.
Dear Wolfgang Denk,
Is this nesseary?
Oh, I didn't know the "CONFIG_SYS_LDSCRIPT" option. I will ditch and modify the board config file.
Dear Nobuhiro Iwamatsu,
The R0P7757LC0030RL board has SH7757, 256MB DDR3-SDRAM, SPI ROM, Ethernet, and more.
This patch supports the following functions:
- 256MB DDR3-SDRAM
- SPI ROM
- Ethernet
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com
~ 400 lines of full quote deleted.
Is this nesseary?
Could you please only quote the lines you are referring to?
It is difficult to find your comments when you quote the whole, long patch.
Thanks.
- 256MB DDR3-SDRAM
- SPI ROM
- Ethernet
arch/sh/include/asm/cpu_sh4.h | 2 + arch/sh/include/asm/cpu_sh7757.h | 263 +++++++++++++++ board/renesas/sh7757lcr/Makefile | 42 +++ board/renesas/sh7757lcr/config.mk | 28 ++ board/renesas/sh7757lcr/lowlevel_init.S | 558 +++++++++++++++++++++++++++++++ board/renesas/sh7757lcr/sh7757lcr.c | 436 ++++++++++++++++++++++++ board/renesas/sh7757lcr/spi-boot.c | 111 ++++++ board/renesas/sh7757lcr/u-boot.lds | 101 ++++++ boards.cfg | 1 + doc/README.sh7757lcr | 64 ++++ include/configs/sh7757lcr.h | 143 ++++++++ 11 files changed, 1749 insertions(+), 0 deletions(-) create mode 100644 arch/sh/include/asm/cpu_sh7757.h create mode 100644 board/renesas/sh7757lcr/Makefile create mode 100644 board/renesas/sh7757lcr/config.mk create mode 100644 board/renesas/sh7757lcr/lowlevel_init.S create mode 100644 board/renesas/sh7757lcr/sh7757lcr.c create mode 100644 board/renesas/sh7757lcr/spi-boot.c create mode 100644 board/renesas/sh7757lcr/u-boot.lds create mode 100644 doc/README.sh7757lcr create mode 100644 include/configs/sh7757lcr.h
Entry to MAINTAINERS missing.
+/* TMU0 */ +#define TSTR 0xFE430004 +#define TOCR 0xFE430000 +#define TSTR0 0xFE430004 +#define TCOR0 0xFE430008 +#define TCNT0 0xFE43000C +#define TCR0 0xFE430010 +#define TCOR1 0xFE430014 +#define TCNT1 0xFE430018 +#define TCR1 0xFE43001C +#define TCOR2 0xFE430020 +#define TCNT2 0xFE430024 +#define TCR2 0xFE430028 +#define TCPR2 0xFE43002C
Please use C structs to describe hardware registers.
+/* DDR3IF */ +#define DDR3IF_BASE 0xfe800000 +#define DBSTATE0 (DDR3IF_BASE + 0x0008) +#define DBSTATE1 (DDR3IF_BASE + 0x000c) +#define DBACEN (DDR3IF_BASE + 0x0010) +#define DBRFEN (DDR3IF_BASE + 0x0014) +#define DBCMD (DDR3IF_BASE + 0x0018) +#define DBWAIT (DDR3IF_BASE + 0x001c) +#define DBKIND (DDR3IF_BASE + 0x0020) +#define DBCONF (DDR3IF_BASE + 0x0024) +#define DBTR0 (DDR3IF_BASE + 0x0040) +#define DBTR1 (DDR3IF_BASE + 0x0044) +#define DBTR2 (DDR3IF_BASE + 0x0048) +#define DBTR3 (DDR3IF_BASE + 0x0050) +#define DBTR4 (DDR3IF_BASE + 0x0054) +#define DBTR5 (DDR3IF_BASE + 0x0058) +#define DBTR6 (DDR3IF_BASE + 0x005c) +#define DBTR7 (DDR3IF_BASE + 0x0060) +#define DBTR8 (DDR3IF_BASE + 0x0064) +#define DBTR9 (DDR3IF_BASE + 0x0068) +#define DBTR10 (DDR3IF_BASE + 0x006c) +#define DBTR11 (DDR3IF_BASE + 0x0070) +#define DBTR12 (DDR3IF_BASE + 0x0074) +#define DBTR13 (DDR3IF_BASE + 0x0078) +#define DBTR14 (DDR3IF_BASE + 0x007c) +#define DBTR15 (DDR3IF_BASE + 0x0080) +#define DBTR16 (DDR3IF_BASE + 0x0084) +#define DBTR17 (DDR3IF_BASE + 0x0088) +#define DBTR18 (DDR3IF_BASE + 0x008c) +#define DBTR19 (DDR3IF_BASE + 0x0090) +#define DBADJ0 (DDR3IF_BASE + 0x00c0) +#define DBADJ1 (DDR3IF_BASE + 0x00c4) +#define DBADJ2 (DDR3IF_BASE + 0x00c8) +#define DBADJ3 (DDR3IF_BASE + 0x00cc) +#define DBRFCNF0 (DDR3IF_BASE + 0x00e0) +#define DBRFCNF1 (DDR3IF_BASE + 0x00e4) +#define DBRFCNF2 (DDR3IF_BASE + 0x00e8) +#define DBCALCNF (DDR3IF_BASE + 0x00f4) +#define DBRNK0 (DDR3IF_BASE + 0x0100) +#define DBPDCNT0 (DDR3IF_BASE + 0x0200) +#define DBPDCNT1 (DDR3IF_BASE + 0x0204) +#define DBPDCNT2 (DDR3IF_BASE + 0x0208) +#define DBPDCNT3 (DDR3IF_BASE + 0x020c) +#define DBPDLCK (DDR3IF_BASE + 0x0280) +#define DBPDRGA (DDR3IF_BASE + 0x0290) +#define DBPDRGD (DDR3IF_BASE + 0x02a0) +#define DBBS0CNT0 (DDR3IF_BASE + 0x0300) +#define DBBS0CNT1 (DDR3IF_BASE + 0x0304)
We don't allow base address + offset notation to access hardware registers. Please use C structs instead.
Please fix globally. Thanks.
Dear Wolfgang Denk,
Thank you for your review.
Sorry, I will modify the MAINTAINERS.
The current code in arch/lib/sh/time.c doesn't use C structs. Should I also modify the code?
They are used in assembler code (lowlevel_init.S). Do we use C structs in assembler code using GCC? At the moment, I don't know about it. So I will study GCC...
2011/1/19 Wolfgang Denk wd@denx.de:
This patch supports the following functions: - 256MB DDR3-SDRAM - SPI ROM - Ethernet
Some IP of SH is different every CPU. When we made structure to summarize these in, time suffers from a test and thinks that it is it for the cause of the bug.
I recommend a method using address it, and to read/write of register.
These macro was used in assembler. It will be difficult to use these as a structure, I think.
Best regards, Nobuhiro
Nobuhiro Iwamatsu
Yoshihiro Shimoda
