Pull request for UEFI sub-system for efi-2021-04-rc1
Dear Tom,
The following changes since commit ee6726be4f0dccb612f0193c62ca149164c8a5af:
Merge tag 'ti-v2021.04-rc1' of https://gitlab.denx.de/u-boot/custodians/u-boot-ti (2021-01-12 09:32:48 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2021-04-rc1
for you to fetch changes up to 8e70f1cb3f2c18d574b087d4fc1d79e68ce98fa9:
efi_selftest: dtbdump support EFI_DT_FIXUP_PROTOCOL (2021-01-13 02:38:01 +0100)
Gitlab showed no problems: https://gitlab.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/5854
---------------------------------------------------------------- Pull request for UEFI sub-system for efi-2021-04-rc1
In the UEFI sub-system:
* implement non-blocking file services * print boot device and file path in helloworld.efi * improve detection of boot device * correct argument handling in efivar.py * implement EFI_DT_FIXUP_PROTOCOL
Bug fixes:
* adjust conitrace command for low baud rates * check that FIT images are valid FDTs
---------------------------------------------------------------- Heinrich Schuchardt (16): efi_loader: implement non-blocking file services tools: efivar.py without arguments tools: efivar.py: incorrect indentation tools: efivar.py should check GUID when deleting tools: efivar.py unused variable efi_loader: simplify running helloworld.efi efi_loader: print boot device and file path in helloworld efi_loader: carve out efi_check_pe() image-fit: fit_check_format check for valid FDT efi_loader: setting boot device efi_loader: move efi_(u)intn_t to efi.h efi_loader: typedef efi_string_t text output protocol efi_loader: remove outdated TODO in efi_memory.c cmd: conitrace: increase wait for next key efi_loader: implement EFI_DT_FIXUP_PROTOCOL efi_selftest: dtbdump support EFI_DT_FIXUP_PROTOCOL
cmd/bootefi.c | 234 +++++++++++----------------- cmd/conitrace.c | 4 +- cmd/efidebug.c | 5 + common/image-fit.c | 6 + doc/uefi/uefi.rst | 11 +- fs/fs.c | 3 +- include/efi.h | 5 + include/efi_api.h | 34 ++-- include/efi_dt_fixup.h | 39 +++++ include/efi_loader.h | 10 +- lib/efi_loader/Makefile | 3 + lib/efi_loader/efi_console.c | 6 +- lib/efi_loader/efi_dt_fixup.c | 160 +++++++++++++++++++ lib/efi_loader/efi_file.c | 317 ++++++++++++++++++++++++++++++++------ lib/efi_loader/efi_image_loader.c | 80 ++++++---- lib/efi_loader/efi_memory.c | 2 - lib/efi_loader/efi_root_node.c | 6 + lib/efi_loader/helloworld.c | 167 ++++++++++++++++---- lib/efi_selftest/dtbdump.c | 310 ++++++++++++++++++++++++++++++++----- net/tftp.c | 9 +- tools/efivar.py | 39 ++--- 21 files changed, 1096 insertions(+), 354 deletions(-) create mode 100644 include/efi_dt_fixup.h create mode 100644 lib/efi_loader/efi_dt_fixup.c
On Wed, Jan 13, 2021 at 07:43:56PM +0100, Heinrich Schuchardt wrote:
Dear Tom,
But! This got me to look a little harder at things and even if we have a platform where we disable ext4/fat write support, there's no change in the EFI side of the code. Is this something we can do anything about? If so, is it worthwhile or likely to really only change a few boards and I'm just grasping at straws, so to speak, on the question of "Can we do anything to reduce EFI code size" ?
Dear Tom,
I assume you already have disabled: CONFIG_EFI_DEVICE_PATH_TO_TEXT CONFIG_EFI_LOADER_HII CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2
Could you, please, give me an example config to work on?
Best regards
Heinrich
