[U-Boot] [PATCH 1/2] defconfigs: dra7xx_hs_evm: Move OPTEE load address to avoid overlaps
Move the OPTEE load address to 0xbdb00000 in order to avoid overlap with the memory regions used in radio and RVC usecases.
Signed-off-by: Misael Lopez Cruz misael.lopez@ti.com Signed-off-by: Andrew F. Davis afd@ti.com --- configs/dra7xx_hs_evm_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index f3a9c68008..e238c39c0c 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -3,7 +3,7 @@ CONFIG_OMAP54XX=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TI_SECURE_DEVICE=y CONFIG_TARGET_DRA7XX_EVM=y -CONFIG_TI_SECURE_EMIF_REGION_START=0xbe000000 +CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE=0x01c00000 # CONFIG_SPL_NAND_SUPPORT is not set
Signed-off-by: Andrew F. Davis afd@ti.com --- configs/am57xx_hs_evm_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 956e39f1f8..138017d0d1 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -3,7 +3,7 @@ CONFIG_OMAP54XX=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TI_SECURE_DEVICE=y CONFIG_TARGET_AM57XX_EVM=y -CONFIG_TI_SECURE_EMIF_REGION_START=0xbe000000 +CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE=0x01c00000 # CONFIG_SPL_NAND_SUPPORT is not set
Andrew F. Davis
