[U-Boot] Pull request v2: nand flash
v2: Amended the resync commit due to include/mtd/mtd-abi.h being missing (it was present locally as an uncommitted file, which is why I didn't see build failures).
The following changes since commit 8bcb6f43e98ffc76e998349e0ec32a0e359160d4:
Update MAINTAINERS file for sandbox (2013-05-17 17:04:39 -0400)
git://git.denx.de/u-boot-nand-flash.git master
for you to fetch changes up to dfe64e2c89731a3f9950d7acd8681b68df2bae03:
mtd: resync with Linux-3.7.1 (2013-05-31 17:12:03 -0500)
---------------------------------------------------------------- Harvey Chapman (1): nand: adjust erase/read/write partition/chip size for bad blocks
Prabhakar Kushwaha (1): nand/fsl_ifc: Convert to self-init
Scott Wood (1): nand/fsl_elbc: detect page size at runtime
Sergey Lapin (1): mtd: resync with Linux-3.7.1
htbegin (2): mtd: nand: fix the partial page write condition mtd: nand: use ssize_t instead of size_t to prevent infinite loop
board/ait/cam_enc_4xx/cam_enc_4xx.c | 12 +- common/cmd_nand.c | 53 +- common/cmd_onenand.c | 30 +- common/env_onenand.c | 6 +- drivers/mtd/Makefile | 4 +- drivers/mtd/cfi_mtd.c | 12 +- drivers/mtd/mtdconcat.c | 98 +-- drivers/mtd/mtdcore.c | 191 ++++ drivers/mtd/mtdpart.c | 158 ++-- drivers/mtd/nand/atmel_nand.c | 17 +- drivers/mtd/nand/bfin_nand.c | 2 + drivers/mtd/nand/davinci_nand.c | 4 +- drivers/mtd/nand/diskonchip.c | 13 +- drivers/mtd/nand/fsl_elbc_nand.c | 56 +- drivers/mtd/nand/fsl_ifc_nand.c | 62 +- drivers/mtd/nand/fsmc_nand.c | 5 +- drivers/mtd/nand/jz4740_nand.c | 1 + drivers/mtd/nand/mpc5121_nfc.c | 2 +- drivers/mtd/nand/mxc_nand.c | 25 +- drivers/mtd/nand/mxs_nand.c | 34 +- drivers/mtd/nand/nand_base.c | 1658 ++++++++++++++++++++--------------- drivers/mtd/nand/nand_bbt.c | 822 ++++++++--------- drivers/mtd/nand/nand_ids.c | 14 +- drivers/mtd/nand/nand_util.c | 26 +- drivers/mtd/nand/ndfc.c | 1 + drivers/mtd/nand/nomadik.c | 1 + drivers/mtd/nand/omap_gpmc.c | 6 +- drivers/mtd/nand/s3c2410_nand.c | 1 + drivers/mtd/nand/tegra_nand.c | 27 +- drivers/mtd/nand/tegra_nand.h | 2 +- drivers/mtd/onenand/onenand_base.c | 82 +- drivers/mtd/onenand/onenand_bbt.c | 6 +- drivers/mtd/ubi/build.c | 2 +- drivers/mtd/ubi/eba.c | 2 +- drivers/mtd/ubi/io.c | 12 +- drivers/mtd/ubi/kapi.c | 2 +- drivers/mtd/ubi/misc.c | 2 +- drivers/mtd/ubi/vtbl.c | 2 +- fs/yaffs2/yaffs_mtdif.c | 18 +- fs/yaffs2/yaffs_mtdif2.c | 14 +- include/configs/P1022DS.h | 2 - include/linux/mtd/bbm.h | 49 +- include/linux/mtd/mtd.h | 203 +++-- include/linux/mtd/nand.h | 173 ++-- include/linux/string.h | 3 + include/{linux => }/mtd/mtd-abi.h | 53 +- include/nand.h | 11 +- lib/string.c | 59 ++ 48 files changed, 2307 insertions(+), 1731 deletions(-) rename include/{linux => }/mtd/mtd-abi.h (65%)
Scott Wood
