[PATCH v4 0/3] riscv: Fix build against binutils 2.38
Binutils 2.37 and 2.38 are based on different revisions of the "RISC-V Unprivileged Specification" and there fore require different -march parameters for GCC.
We support both 32bit and 64bit RISC-V boards. Buildman uses a 64bit toolchain for both which leads to build failures with -march=rv32imac_zicsr_zifencei.
The first patch install the riscv32 toolchain in the Docker image. Only after rebuilding and uploading the Docker image we can proceed with the other patches.
The next patch let's buildman choose the correct tool chain.
The final patch which has already been posted previously corrects the -march parameter for binutils 2.38+.
v4: remove riscv toolchain-alias in Docker image
Alexandre Ghiti (1): riscv: Fix build against binutils 2.38
Heinrich Schuchardt (2): docker: install riscv32 toolchain buildman: differentiate between riscv32, riscv64
arch/riscv/Makefile | 11 ++++++++++- tools/buildman/boards.py | 11 +++++++++++ tools/docker/Dockerfile | 2 +- 3 files changed, 22 insertions(+), 2 deletions(-)
For building riscv32 targets we should use the riscv32 toolchain. Add it to the Docker image.
Drop the riscv toolchain-alias as we do not need it in future.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v4: drop riscv toolchain-alias v3: new patch --- tools/docker/Dockerfile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index d3292e752a..cbd837ad4e 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -24,6 +24,7 @@ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/11.1.0/... | tar -C /opt -xJ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/11.1.0/... | tar -C /opt -xJ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/11.1.0/... | tar -C /opt -xJ +RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/11.1.0/... | tar -C /opt -xJ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/11.1.0/... | tar -C /opt -xJ
# Manually install other toolchains @@ -217,6 +218,5 @@ RUN /bin/echo -e "kernelorg = /opt/gcc-11.1.0-nolibc/*" >> ~/.buildman RUN /bin/echo -e "arc = /opt/arc_gnu_2021.03_prebuilt_uclibc_le_archs_linux_install" >> ~/.buildman RUN /bin/echo -e "\n[toolchain-prefix]\nxtensa = /opt/2020.07/xtensa-dc233c-elf/bin/xtensa-dc233c-elf-" >> ~/.buildman; RUN /bin/echo -e "\n[toolchain-alias]\nsh = sh2" >> ~/.buildman -RUN /bin/echo -e "\nriscv = riscv64" >> ~/.buildman RUN /bin/echo -e "\nsandbox = x86_64" >> ~/.buildman RUN /bin/echo -e "\nx86 = i386" >> ~/.buildman;
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Rick Chen rick@andestech.com
riscv32 needs a different toolchain than riscv64
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v4: no change v3: new patch --- tools/buildman/boards.py | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/tools/buildman/boards.py b/tools/buildman/boards.py index 8a0971aa40..cdc4d9ffd2 100644 --- a/tools/buildman/boards.py +++ b/tools/buildman/boards.py @@ -263,6 +263,17 @@ class KconfigScanner: if params['arch'] == 'arm' and params['cpu'] == 'armv8': params['arch'] = 'aarch64'
+ # fix-up for riscv + if params['arch'] == 'riscv': + try: + value = self._conf.syms.get('ARCH_RV32I').str_value + except: + value = '' + if value == 'y': + params['arch'] = 'riscv32' + else: + params['arch'] = 'riscv64' + return params
Hi Heinrich,
On Mon, 3 Oct 2022 at 10:08, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
# fix-up for riscv
try:
except:
value = ''
if value == 'y':
else:
return params
I think I understand this better. Can we detect a boards.cfg file which needs updating? Or perhaps the existing output_is_new() function is good enough?
Regards.
Simon
On 10/3/22 18:44, Simon Glass wrote:
Hi Heinrich,
# fix-up for riscv
try:
except:
value = ''
if value == 'y':
else:
return params
output_is_new() only checks the change date of files called *_defconfig, Kconfig*, MAINTAINERS. You could check the date of file boards.py too.
Best regards
Heinrich
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Rick Chen rick@andestech.com
From: Alexandre Ghiti alexandre.ghiti@canonical.com
The following description is copied from the equivalent patch for the Linux Kernel proposed by Aurelien Jarno:
From version 2.38, binutils default to ISA spec version 20191213. This
means that the csr read/write (csrr*/csrw*) instructions and fence.i instruction has separated from the `I` extension, become two standalone extensions: Zicsr and Zifencei. As the kernel uses those instruction, this causes the following build failure:
arch/riscv/cpu/mtrap.S: Assembler messages: arch/riscv/cpu/mtrap.S:65: Error: unrecognized opcode `csrr a0,scause' arch/riscv/cpu/mtrap.S:66: Error: unrecognized opcode `csrr a1,sepc' arch/riscv/cpu/mtrap.S:67: Error: unrecognized opcode `csrr a2,stval' arch/riscv/cpu/mtrap.S:70: Error: unrecognized opcode `csrw sepc,a0'
Signed-off-by: Alexandre Ghiti alexandre.ghiti@canonical.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Tested-by: Heiko Stuebner heiko@sntech.de Tested-by: Christian Stewart christian@paral.in Reviewed-by: Rick Chen rick@andestech.com --- v4: no change v3: no change --- arch/riscv/Makefile | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/Makefile b/arch/riscv/Makefile index 0b80eb8d86..53d1194ffb 100644 --- a/arch/riscv/Makefile +++ b/arch/riscv/Makefile @@ -24,7 +24,16 @@ ifeq ($(CONFIG_CMODEL_MEDANY),y) CMODEL = medany endif
-ARCH_FLAGS = -march=$(ARCH_BASE)$(ARCH_A)$(ARCH_C) -mabi=$(ABI) \ +RISCV_MARCH = $(ARCH_BASE)$(ARCH_A)$(ARCH_C) + +# Newer binutils versions default to ISA spec version 20191213 which moves some +# instructions from the I extension to the Zicsr and Zifencei extensions. +toolchain-need-zicsr-zifencei := $(call cc-option-yn, -mabi=$(ABI) -march=$(RISCV_MARCH)_zicsr_zifencei) +ifeq ($(toolchain-need-zicsr-zifencei),y) + RISCV_MARCH := $(RISCV_MARCH)_zicsr_zifencei +endif + +ARCH_FLAGS = -march=$(RISCV_MARCH) -mabi=$(ABI) \ -mcmodel=$(CMODEL)
PLATFORM_CPPFLAGS += $(ARCH_FLAGS)
