[U-Boot] [PATCH 1/2] sunxi: VBUS detection function fixup in g_dnl_board_usb_cable_connected
sunxi_usbc_vbus_detect was renamed to sunxi_usb_phy_vbus_detect but g_dnl_board_usb_cable_connected was still using the old name, breaking the build when USB gadget is enabled.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- board/sunxi/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 4c51468..5f79cc1 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -476,7 +476,7 @@ static struct musb_hdrc_platform_data musb_plat = { #ifdef CONFIG_USB_GADGET int g_dnl_board_usb_cable_connected(void) { - return sunxi_usbc_vbus_detect(0); + return sunxi_usb_phy_vbus_detect(0); } #endif
Sunxi platforms use ARM Cortex A8, A7 and A15 (unsupported yet) CPU cores, which all have 64 bytes cache line size.
This is required to e.g. enable USB gadget.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- include/configs/sunxi-common.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 723067e..3e4e26b 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -66,6 +66,9 @@ # define CONFIG_SYS_NS16550_COM5 SUNXI_R_UART_BASE #endif
+/* CPU */ +#define CONFIG_SYS_CACHELINE_SIZE 64 + /* DRAM Base */ #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define CONFIG_SYS_INIT_RAM_ADDR 0x0
Thanks for these 2 fixes, I've added both to my personal tree. I'll send a pull-req to get these into u-boot/master soon.
Regards,
Hans
- return sunxi_usb_phy_vbus_detect(0); } #endif
Hans de Goede
Paul Kocialkowski
