[PATCH 0/2] J721E/J7200 postdiv clk parenting/data fixes
Hi Lokesh,
The following patches fix the clock parenting of couple of post-divider PLL output clocks for Main PLL0 and PLL1 on both J721E and J7200 SoCs. The Main PLL1 register values are also fixed up (they were pointing to PLL0 atm).
These PLL POSTDIV clocks are in sequence and the last POSTDIV clock acts as input clock for certain HSDIV output clocks. So, the fixes only correct the parents and their rates, and none of the child clock rates are affected.
Boot tested and verified the clock rates on both J721E and J7200 EVMs.
regards Suman
Suman Anna (2): arm: mach-k3: j721e: Fix clk-data parenting for postdiv PLL clocks arm: mach-k3: j7200: Fix clk-data parenting for postdiv PLL clocks
arch/arm/mach-k3/j7200/clk-data.c | 8 ++++---- arch/arm/mach-k3/j721e/clk-data.c | 8 ++++---- 2 files changed, 8 insertions(+), 8 deletions(-)
The TI K3 Fractional PLLs use two programmable POSTDIV1 and POSTDIV2 divisors to generate the final FOUTPOSTDIV clock. These are in sequence with POSTDIV2 following the POSTDIV1 clock. The current J721E clock data has the POSTDIV2 clock as the parent for the POSTDIV1 clock, which is opposite of the actual implementation. Fix the data by simply adjusting the register bit-shifts.
The Main PLL1 POSTDIV clocks were also defined incorrectly using Main PLL0 register values, fix these as well.
Fixes: 277729eaf373 ("arm: mach-k3: Add platform data for j721e and j7200") Signed-off-by: Suman Anna s-anna@ti.com --- arch/arm/mach-k3/j721e/clk-data.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-k3/j721e/clk-data.c b/arch/arm/mach-k3/j721e/clk-data.c index 953ac457130b..ff9262d7bcee 100644 --- a/arch/arm/mach-k3/j721e/clk-data.c +++ b/arch/arm/mach-k3/j721e/clk-data.c @@ -463,8 +463,8 @@ static const struct clk_data clk_list[] = { CLK_MUX("wkup_fref_clksel_out0", wkup_fref_clksel_out0_parents, 2, 0x43008050, 8, 1, 0), CLK_MUX("main_pll_hfosc_sel_out1", main_pll_hfosc_sel_out1_parents, 2, 0x43008084, 0, 1, 0), CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_main_1_foutvcop_clk", "main_pll_hfosc_sel_out1", 0x681000, 0, 1920000000), - CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x680038, 24, 3, 0), - CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x681038, 16, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x681038, 24, 3, 0), CLK_PLL("pllfrac2_ssmod_16fft_mcu_0_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d00000, 0), CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d01000, 0, 2400000000), CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d02000, 0, 2000000000), @@ -523,8 +523,8 @@ static const struct clk_data clk_list[] = { CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout3_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d0208c, 0, 7, 0), CLK_FIXED_RATE("j7_wakeup_16ff_wkup_0_wkup_rcosc_32k_clk", 32000, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_0_foutvcop_clk", "main_pll_hfosc_sel_out0", 0x680000, 0), - CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 24, 3, 0), - CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 16, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 24, 3, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_13_foutvcop_clk", "main_pll_hfosc_sel_out13", 0x68d000, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_14_foutvcop_clk", "main_pll_hfosc_sel_out14", 0x68e000, 0), CLK_PLL("pllfrac2_ssmod_16fft_main_16_foutvcop_clk", "main_pll_hfosc_sel_out16", 0x690000, 0),
The TI K3 Fractional PLLs use two programmable POSTDIV1 and POSTDIV2 divisors to generate the final FOUTPOSTDIV clock. These are in sequence with POSTDIV2 following the POSTDIV1 clock. The current J7200 clock data has the POSTDIV2 clock as the parent for the POSTDIV1 clock, which is opposite of the actual implementation. Fix the data by simply adjusting the register bit-shifts.
Fixes: 277729eaf373 ("arm: mach-k3: Add platform data for j721e and j7200") Signed-off-by: Suman Anna s-anna@ti.com --- arch/arm/mach-k3/j7200/clk-data.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-k3/j7200/clk-data.c b/arch/arm/mach-k3/j7200/clk-data.c index 93c067079ab6..49145bbfc8cd 100644 --- a/arch/arm/mach-k3/j7200/clk-data.c +++ b/arch/arm/mach-k3/j7200/clk-data.c @@ -319,8 +319,8 @@ static const struct clk_data clk_list[] = { CLK_MUX("wkup_fref_clksel_out0", wkup_fref_clksel_out0_parents, 2, 0x43008050, 8, 1, 0), CLK_MUX("main_pll_hfosc_sel_out1", main_pll_hfosc_sel_out1_parents, 2, 0x43008084, 0, 1, 0), CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_main_1_foutvcop_clk", "main_pll_hfosc_sel_out1", 0x681000, 0, 1920000000), - CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x680038, 24, 3, 0), - CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681038, 16, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x681038, 24, 3, 0), CLK_PLL("pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d00000, 0), CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d01000, 0, 2400000000), CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d02000, 0, 2000000000), @@ -360,8 +360,8 @@ static const struct clk_data clk_list[] = { CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout2_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02088, 0, 7, 0), CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout3_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d0208c, 0, 7, 0), CLK_PLL("pllfracf_ssmod_16fft_main_0_foutvcop_clk", "main_pll_hfosc_sel_out0", 0x680000, 0), - CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 24, 3, 0), - CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 16, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 24, 3, 0), CLK_PLL("pllfracf_ssmod_16fft_main_12_foutvcop_clk", "main_pll_hfosc_sel_out12", 0x68c000, 0), CLK_PLL("pllfracf_ssmod_16fft_main_14_foutvcop_clk", "main_pll_hfosc_sel_out14", 0x68e000, 0), CLK_PLL("pllfracf_ssmod_16fft_main_2_foutvcop_clk", "main_pll_hfosc_sel_out2", 0x682000, 0),
Suman Anna
