[U-Boot] [PATCH] dm: ofnode: query correct property in livetree ofnode_get_addr_size
The livetree codepath of ofnode_get_addr_size always used the "reg" property for of_get_property. Use the property parameter of the function call instead and check the return value if the property exists. Otherwise return FDT_ADDR_T_NONE.
This was discoverd while using SPI NOR with livetree. spi_flash_decode_fdt checks for memory-map and will not fail with livetree even if the property does not exist.
Signed-off-by: Klaus Goger klaus.goger@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
drivers/core/ofnode.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index c6ca13fabf..0030ab962e 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -468,8 +468,10 @@ fdt_addr_t ofnode_get_addr_size(ofnode node, const char *property, int na, ns; int psize; const struct device_node *np = ofnode_to_np(node); - const __be32 *prop = of_get_property(np, "reg", &psize); + const __be32 *prop = of_get_property(np, property, &psize);
+ if (!prop) + return FDT_ADDR_T_NONE; na = of_n_addr_cells(np); ns = of_n_addr_cells(np); *sizep = of_read_number(prop + na, ns);
On 20 September 2017 at 05:50, Klaus Goger klaus.goger@theobroma-systems.com wrote:
Applied to u-boot-dm thanks!
Klaus Goger
sjg@google.com
