[U-Boot] [PATCHv2 1/5] smart-gateway-mt7688: Rework build time check for overwriting factory data
The board file has a build time check to ensure that we do not have the redundant environment overwriting the factory data. However, using the symbol CONFIG_ENV_SIZE_REDUND isn't strictly needed as that is always the same as CONFIG_ENV_SIZE. Use CONFIG_ENV_SIZE instead so that we can later drop CONFIG_ENV_SIZE_REDUND.
Cc: Stefan Roese sr@denx.de Signed-off-by: Tom Rini trini@konsulko.com --- Changes in v2: - As pointed out by Stefan's review, I should address the usage of ENV_SIZE_REDUND here first and remove it second. --- board/gardena/smart-gateway-mt7688/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/gardena/smart-gateway-mt7688/board.c b/board/gardena/smart-gateway-mt7688/board.c index bd494c84fc80..e9ffd42a8a68 100644 --- a/board/gardena/smart-gateway-mt7688/board.c +++ b/board/gardena/smart-gateway-mt7688/board.c @@ -18,7 +18,7 @@
#define FACTORY_DATA_OFFS 0xc0000 #define FACTORY_DATA_SECT_SIZE 0x10000 -#if ((CONFIG_ENV_OFFSET_REDUND + CONFIG_ENV_SIZE_REDUND) > FACTORY_DATA_OFFS) +#if ((CONFIG_ENV_OFFSET_REDUND + CONFIG_ENV_SIZE) > FACTORY_DATA_OFFS) #error "U-Boot image with environment too big (overlapping with factory-data)!" #endif #define FACTORY_DATA_USER_OFFS 0x140
We have CONFIG_ENV_SIZE_IS_REDUND but don't really use it. We have one board where we can simply multiple CONFIG_ENV_SIZE by two for the same result. The other place where we could but were not previously using this is for where env_internal.h checks for if we should set ENV_IS_EMBEDDED. This seems like the most likely use, historically, of the variable, but it was not used. Add logic to check for this now.
Cc: Wolfgang Denk wd@denx.de Cc: Joe Hershberger joe.hershberger@ni.com Signed-off-by: Tom Rini trini@konsulko.com --- env/Kconfig | 7 ------- env/flash.c | 5 ----- env/mmc.c | 5 ----- env/nand.c | 5 ----- env/sata.c | 2 +- include/configs/MPC8308RDB.h | 1 - include/configs/MPC8313ERDB_NAND.h | 1 - include/configs/MPC8349EMDS.h | 1 - include/configs/MPC8349EMDS_SDRAM.h | 1 - include/configs/MigoR.h | 1 - include/configs/TQM834x.h | 1 - include/configs/UCP1020.h | 2 -- include/configs/am335x_shc.h | 1 - include/configs/apf27.h | 1 - include/configs/apx4devkit.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/bk4r1.h | 1 - include/configs/blanche.h | 1 - include/configs/caddy2.h | 1 - include/configs/condor.h | 1 - include/configs/dh_imx6.h | 1 - include/configs/display5.h | 1 - include/configs/draco.h | 1 - include/configs/eagle.h | 1 - include/configs/edb93xx.h | 1 - include/configs/etamin.h | 1 - include/configs/flea3.h | 1 - include/configs/gardena-smart-gateway-mt7688.h | 1 - include/configs/gazerbeam.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/hrcon.h | 1 - include/configs/ids8313.h | 1 - include/configs/imx27lite-common.h | 1 - include/configs/km/km-mpc83xx.h | 1 - include/configs/km/km_arm.h | 1 - include/configs/kp_imx53.h | 1 - include/configs/m53menlo.h | 1 - include/configs/mccmon6.h | 1 - include/configs/mpc8308_p1m.h | 1 - include/configs/mx28evk.h | 1 - include/configs/mx35pdk.h | 1 - include/configs/novena.h | 1 - include/configs/pcm052.h | 1 - include/configs/pcm058.h | 1 - include/configs/pfla02.h | 1 - include/configs/platinum.h | 1 - include/configs/rastaban.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/sbc8349.h | 1 - include/configs/sh7752evb.h | 1 - include/configs/sh7753evb.h | 1 - include/configs/sh7757lcr.h | 1 - include/configs/sh7763rdp.h | 1 - include/configs/sksimx6.h | 1 - include/configs/socfpga_vining_fpga.h | 1 - include/configs/socrates.h | 1 - include/configs/strider.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/thuban.h | 1 - include/configs/titanium.h | 1 - include/configs/vcoreiii.h | 1 - include/configs/vct.h | 1 - include/configs/ve8313.h | 1 - include/configs/vining_2000.h | 1 - include/configs/vme8349.h | 1 - include/configs/woodburn_common.h | 1 - include/configs/x600.h | 1 - include/env_internal.h | 7 +++++-- scripts/config_whitelist.txt | 1 - tools/envcrc.c | 3 --- 71 files changed, 6 insertions(+), 93 deletions(-)
diff --git a/env/Kconfig b/env/Kconfig index 337787051df8..0b97af42b1c8 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -132,7 +132,6 @@ config ENV_IS_IN_FLASH RAM, your target system will be dead.
CONFIG_ENV_ADDR_REDUND - CONFIG_ENV_SIZE_REDUND
These settings describe a second storage area used to hold a redundant copy of the environment data, so that there is @@ -195,12 +194,6 @@ config ENV_IS_IN_MMC This value is also in units of bytes, but must also be aligned to an MMC sector boundary.
- CONFIG_ENV_SIZE_REDUND (optional): - - This value need not be set, even when CONFIG_ENV_OFFSET_REDUND is - set. If this value is set, it must be set to the same value as - CONFIG_ENV_SIZE. - config ENV_IS_IN_NAND bool "Environment in a NAND device" depends on !CHAIN_OF_TRUST diff --git a/env/flash.c b/env/flash.c index 231a5fdf24d0..b94ed2b04f8d 100644 --- a/env/flash.c +++ b/env/flash.c @@ -28,11 +28,6 @@ DECLARE_GLOBAL_DATA_PTR; # endif #endif
-#if defined(CONFIG_ENV_SIZE_REDUND) && \ - (CONFIG_ENV_SIZE_REDUND < CONFIG_ENV_SIZE) -#error CONFIG_ENV_SIZE_REDUND should not be less then CONFIG_ENV_SIZE -#endif - /* TODO(sjg@chromium.org): Figure out all these special cases */ #if (!defined(CONFIG_MICROBLAZE) && !defined(CONFIG_ARCH_ZYNQ) && \ !defined(CONFIG_TARGET_MCCMON6) && !defined(CONFIG_TARGET_X600) && \ diff --git a/env/mmc.c b/env/mmc.c index 9f1878def13a..fee9f0674edc 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -22,11 +22,6 @@ #define __STR(X) #X #define STR(X) __STR(X)
-#if defined(CONFIG_ENV_SIZE_REDUND) && \ - (CONFIG_ENV_SIZE_REDUND != CONFIG_ENV_SIZE) -#error CONFIG_ENV_SIZE_REDUND should be the same as CONFIG_ENV_SIZE -#endif - DECLARE_GLOBAL_DATA_PTR;
#if !defined(CONFIG_ENV_OFFSET) diff --git a/env/nand.c b/env/nand.c index 9f3dc635cf1f..e631bf2fdab5 100644 --- a/env/nand.c +++ b/env/nand.c @@ -31,11 +31,6 @@ #error CONFIG_ENV_OFFSET_REDUND must have CONFIG_CMD_SAVEENV & CONFIG_CMD_NAND #endif
-#if defined(CONFIG_ENV_SIZE_REDUND) && \ - (CONFIG_ENV_SIZE_REDUND != CONFIG_ENV_SIZE) -#error CONFIG_ENV_SIZE_REDUND should be the same as CONFIG_ENV_SIZE -#endif - #ifndef CONFIG_ENV_RANGE #define CONFIG_ENV_RANGE CONFIG_ENV_SIZE #endif diff --git a/env/sata.c b/env/sata.c index 93697100815d..8bfcc94306d3 100644 --- a/env/sata.c +++ b/env/sata.c @@ -16,7 +16,7 @@ #include <sata.h> #include <search.h>
-#if defined(CONFIG_ENV_SIZE_REDUND) || defined(CONFIG_ENV_OFFSET_REDUND) +#if defined(CONFIG_ENV_OFFSET_REDUND) #error ENV REDUND not supported #endif
diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 85d7ff6c5214..e4a51d2d27e2 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -253,7 +253,6 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8313ERDB_NAND.h b/include/configs/MPC8313ERDB_NAND.h index 4153d609be4a..fb09c2630f9c 100644 --- a/include/configs/MPC8313ERDB_NAND.h +++ b/include/configs/MPC8313ERDB_NAND.h @@ -300,7 +300,6 @@ #define CONFIG_ENV_OFFSET (512 * 1024) #define CONFIG_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_RANGE (CONFIG_ENV_SECT_SIZE * 4) #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE)
diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 7352e34b9c97..10293bd5f1b5 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -276,7 +276,6 @@
/* Address and size of Redundant Environment Sector */ #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#else #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) diff --git a/include/configs/MPC8349EMDS_SDRAM.h b/include/configs/MPC8349EMDS_SDRAM.h index 2ae1069e4f8a..0193a6bfb736 100644 --- a/include/configs/MPC8349EMDS_SDRAM.h +++ b/include/configs/MPC8349EMDS_SDRAM.h @@ -331,7 +331,6 @@
#else #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index 64172f36194e..fab355e1f2a4 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -83,7 +83,6 @@ #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) /* Offset of env Flash sector relative to CONFIG_SYS_FLASH_BASE */ #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR - CONFIG_SYS_FLASH_BASE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE)
/* Board Clock */ #define CONFIG_SYS_CLK_FREQ 33333333 diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 9bf5d9d3fd6b..c8537e03139e 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -191,7 +191,6 @@ #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) for env */ #define CONFIG_ENV_SIZE 0x8000 /* 32K max size */ #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 40080f512b53..b2778a93c984 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -388,7 +388,6 @@ #if defined(CONFIG_SYS_REDUNDAND_ENVIRONMENT) /* Address and size of Redundant Environment Sector */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #endif
#elif defined(CONFIG_RAMBOOT_SDCARD) @@ -408,7 +407,6 @@ #if defined(CONFIG_SYS_REDUNDAND_ENVIRONMENT) /* Address and size of Redundant Environment Sector */ #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #endif
#endif diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index f4a000f0200d..b34e48cb454e 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -51,7 +51,6 @@ #define CONFIG_HSMMC2_8BIT
#define CONFIG_ENV_OFFSET_REDUND 0x9000 /* 36 kB */ -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
#ifndef CONFIG_SHC_ICT /* diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 044ce4467e58..16a257406321 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -71,7 +71,6 @@ #define CONFIG_ENV_RANGE 0X00080000 /* 512kB */ #define CONFIG_ENV_OFFSET_REDUND \ (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) /* +512kB */ -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE /* 512kB */ #define CONFIG_FIRMWARE_OFFSET 0x00200000 #define CONFIG_FIRMWARE_SIZE 0x00080000 /* 512kB */ #define CONFIG_KERNEL_OFFSET 0x00300000 diff --git a/include/configs/apx4devkit.h b/include/configs/apx4devkit.h index 09de1c06ef67..66b616c80bb1 100644 --- a/include/configs/apx4devkit.h +++ b/include/configs/apx4devkit.h @@ -35,7 +35,6 @@ #if defined(CONFIG_CMD_NAND) && defined(CONFIG_ENV_IS_IN_NAND) #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE (128 * 1024) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_RANGE (384 * 1024) #define CONFIG_ENV_OFFSET 0x120000 #define CONFIG_ENV_OFFSET_REDUND \ diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index c3ccceedca97..dc611da035f4 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -75,7 +75,6 @@ CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE)
/* SH Ether */ #define CONFIG_SH_ETHER_USE_PORT 0 diff --git a/include/configs/bk4r1.h b/include/configs/bk4r1.h index 285e28b535e4..2575a0de3f93 100644 --- a/include/configs/bk4r1.h +++ b/include/configs/bk4r1.h @@ -263,7 +263,6 @@ #define CONFIG_ENV_SECT_SIZE (SZ_128K) #define CONFIG_ENV_SIZE (SZ_8K) #define CONFIG_ENV_OFFSET 0x200000 -#define CONFIG_ENV_SIZE_REDUND (SZ_8K) #define CONFIG_ENV_OFFSET_REDUND 0x220000 #endif
diff --git a/include/configs/blanche.h b/include/configs/blanche.h index 8774bde331b4..7f4a204a3959 100644 --- a/include/configs/blanche.h +++ b/include/configs/blanche.h @@ -59,7 +59,6 @@ #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_SYS_MONITOR_LEN) #endif
#endif /* __BLANCHE_H */ diff --git a/include/configs/caddy2.h b/include/configs/caddy2.h index 89deeac4e7de..2c4f2c5b730b 100644 --- a/include/configs/caddy2.h +++ b/include/configs/caddy2.h @@ -205,7 +205,6 @@
#else #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) diff --git a/include/configs/condor.h b/include/configs/condor.h index e3c146e8244d..c84d127f49f6 100644 --- a/include/configs/condor.h +++ b/include/configs/condor.h @@ -16,7 +16,6 @@ #define CONFIG_BITBANGMII_MULTI
/* Environment compatibility */ -#undef CONFIG_ENV_SIZE_REDUND #undef CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_SECT_SIZE (256 * 1024) #define CONFIG_ENV_OFFSET 0x700000 diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index d4bd88f5114b..66a1b980eee9 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -144,7 +144,6 @@ #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_OFFSET_REDUND \ (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #endif
#endif /* __DH_IMX6_CONFIG_H */ diff --git a/include/configs/display5.h b/include/configs/display5.h index 7b171489e381..b353cffbfcc2 100644 --- a/include/configs/display5.h +++ b/include/configs/display5.h @@ -354,7 +354,6 @@ #define CONFIG_ENV_SECT_SIZE (SZ_64K) #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #endif
#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) diff --git a/include/configs/draco.h b/include/configs/draco.h index ffeb3982b556..e566ccef2a19 100644 --- a/include/configs/draco.h +++ b/include/configs/draco.h @@ -42,7 +42,6 @@
/* Define own nand partitions */ #define CONFIG_ENV_OFFSET_REDUND 0x2E0000 -#define CONFIG_ENV_SIZE_REDUND 0x2000 #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/eagle.h b/include/configs/eagle.h index f0e4bcaa29df..5f2fe42d2eb0 100644 --- a/include/configs/eagle.h +++ b/include/configs/eagle.h @@ -16,7 +16,6 @@ #define CONFIG_BITBANGMII_MULTI
/* Environment compatibility */ -#undef CONFIG_ENV_SIZE_REDUND #undef CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_SECT_SIZE (256 * 1024) #define CONFIG_ENV_OFFSET 0x700000 diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index 84cbcdda93ca..6526a83141f1 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -183,7 +183,6 @@ #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE)
#define CONFIG_USB_OHCI_NEW #define CONFIG_USB_OHCI_EP93XX diff --git a/include/configs/etamin.h b/include/configs/etamin.h index 726f8a500f9d..8e09f73a887f 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -112,7 +112,6 @@
/* Define own nand partitions */ #define CONFIG_ENV_OFFSET_REDUND 0xB80000 -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 4cd823fa363e..4b8b2dc4ad65 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -117,7 +117,6 @@
#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index 94c5b8daf349..cfa7d1c674a0 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -43,7 +43,6 @@ #define CONFIG_ENV_SECT_SIZE (64 << 10) #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
/* * Environment is right behind U-Boot in flash. Make sure U-Boot diff --git a/include/configs/gazerbeam.h b/include/configs/gazerbeam.h index 0ff48287ace2..8c01097245ed 100644 --- a/include/configs/gazerbeam.h +++ b/include/configs/gazerbeam.h @@ -60,7 +60,6 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
#define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index e543061bff6d..8b0f4d4d9019 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -163,7 +163,6 @@ #define CONFIG_ENV_SECT_SIZE (128 * SZ_1K) #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + (512 * SZ_1K)) - #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) #define CONFIG_ENV_OFFSET (512 * SZ_1K) #define CONFIG_ENV_SECT_SIZE (64 * SZ_1K) diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index 8fb321178fa1..cd59b840e9f9 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -357,7 +357,6 @@ void fpga_control_clear(unsigned int bus, int pin); #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #else #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #endif diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index 43cb14c14e5c..71063653fadc 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -227,7 +227,6 @@ + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SIZE 0x20000 #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#define CONFIG_NETDEV eth1 #define CONFIG_HOSTNAME "ids8313" diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index 730e874c9f02..a2d0ade0151f 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -98,7 +98,6 @@ #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE /* Address and size of Redundant Environment Sector */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
/* * Ethernet diff --git a/include/configs/km/km-mpc83xx.h b/include/configs/km/km-mpc83xx.h index c06143c68b55..a9899fe4591e 100644 --- a/include/configs/km/km-mpc83xx.h +++ b/include/configs/km/km-mpc83xx.h @@ -117,7 +117,6 @@ /* Address and size of Redundant Environment Sector */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#else /* CFG_SYS_RAMBOOT */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 64c968b63ba4..63fa6675ff92 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -155,7 +155,6 @@ int get_scl(void); #define CONFIG_ENV_SIZE (0x2000 - CONFIG_ENV_OFFSET) #define CONFIG_I2C_ENV_EEPROM_BUS 5 /* I2C2 (Mux-Port 5) */ #define CONFIG_ENV_OFFSET_REDUND 0x2000 /* no bracets! */ -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) #endif
#define KM_FLASH_GPIO_PIN 16 diff --git a/include/configs/kp_imx53.h b/include/configs/kp_imx53.h index ff564b27ec83..85224c3f46ae 100644 --- a/include/configs/kp_imx53.h +++ b/include/configs/kp_imx53.h @@ -99,7 +99,6 @@ /* environment organization */ #define CONFIG_ENV_OFFSET (SZ_1M) #define CONFIG_ENV_SIZE (SZ_8K) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0
diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 113e84456d38..701bf2a597ba 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -72,7 +72,6 @@ #define CONFIG_MXC_NAND_HWECC
/* Environment is in NAND */ -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_RANGE (4 * CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_OFFSET (8 * CONFIG_ENV_SECT_SIZE) /* 1 MiB */ diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index c75519c1958f..50afc7c60808 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -252,6 +252,5 @@ #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000)
#define CONFIG_ENV_ADDR_REDUND (CONFIG_SYS_FLASH_BASE + 0x60000) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
#endif /* __CONFIG_H * */ diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index 3ce4b705b707..5a8546838fe3 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -232,7 +232,6 @@ #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 2fad2c7a8492..7e7637ebecd8 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -34,7 +34,6 @@
/* Environment is in NAND */ #if defined(CONFIG_CMD_NAND) && defined(CONFIG_ENV_IS_IN_NAND) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_RANGE (512 * 1024) #define CONFIG_ENV_OFFSET 0x300000 diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index e153dfb19922..4ec36193c0b2 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -133,7 +133,6 @@
#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/novena.h b/include/configs/novena.h index cdc437c4925f..fff2396e98f2 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -28,7 +28,6 @@ #ifdef CONFIG_CMD_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_OFFSET (512 * 1024) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_OFFSET_REDUND \ (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #endif diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index fb8f3c8609c0..b68d205bfb3a 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -178,7 +178,6 @@ #define CONFIG_ENV_SECT_SIZE (SZ_128K) #define CONFIG_ENV_SIZE (SZ_8K) #define CONFIG_ENV_OFFSET 0xA0000 -#define CONFIG_ENV_SIZE_REDUND (SZ_8K) #define CONFIG_ENV_OFFSET_REDUND 0xC0000 #endif
diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index b9f5ad326082..6c4a619433b6 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -78,7 +78,6 @@ #define CONFIG_ENV_SECT_SIZE (64 * SZ_1K) #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
#ifdef CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (0x1E0000) diff --git a/include/configs/pfla02.h b/include/configs/pfla02.h index 9a169351a3a0..a4d0e4898a48 100644 --- a/include/configs/pfla02.h +++ b/include/configs/pfla02.h @@ -79,7 +79,6 @@ #define CONFIG_ENV_SECT_SIZE (64 * SZ_1K) #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
#ifdef CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (0x1E0000) diff --git a/include/configs/platinum.h b/include/configs/platinum.h index 1b57e9931f67..58e590a1fd3b 100644 --- a/include/configs/platinum.h +++ b/include/configs/platinum.h @@ -78,7 +78,6 @@ #define CONFIG_ENV_SECT_SIZE (128 << 10) #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + (512 << 10)) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
#else /* CONFIG_CMD_NAND */
diff --git a/include/configs/rastaban.h b/include/configs/rastaban.h index c69535aa6dcb..c34b68a374f7 100644 --- a/include/configs/rastaban.h +++ b/include/configs/rastaban.h @@ -47,7 +47,6 @@
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index e940a8b70a3b..3a763336ed17 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -43,7 +43,6 @@ #define CONFIG_ENV_SECT_SIZE (256 * 1024) #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_SYS_MONITOR_LEN)
/* SF MTD */ #ifdef CONFIG_SPL_BUILD diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index 95bd97c0ec3a..0f7a00f95782 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -54,7 +54,6 @@ #define CONFIG_ENV_OVERWRITE #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#define CONFIG_EXTRA_ENV_SETTINGS \ "bootm_size=0x10000000\0" diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index d2053cc0597a..01d480288578 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -229,7 +229,6 @@
#else #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index cd7f51c7ced0..02c5143491a6 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -67,7 +67,6 @@ #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE) #define CONFIG_EXTRA_ENV_SETTINGS \ "netboot=bootp; bootm\0"
diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index 6b00bd7d906a..ae76254589b3 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -67,7 +67,6 @@ #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE) #define CONFIG_EXTRA_ENV_SETTINGS \ "netboot=bootp; bootm\0"
diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index f1955a16b927..04b6879644b7 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -79,7 +79,6 @@ #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE) #define CONFIG_EXTRA_ENV_SETTINGS \ "netboot=bootp; bootm\0"
diff --git a/include/configs/sh7763rdp.h b/include/configs/sh7763rdp.h index 10961b14bae9..620cf5af5009 100644 --- a/include/configs/sh7763rdp.h +++ b/include/configs/sh7763rdp.h @@ -60,7 +60,6 @@ #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + (1 * CONFIG_ENV_SECT_SIZE)) /* Offset of env Flash sector relative to CONFIG_SYS_FLASH_BASE */ #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR - CONFIG_SYS_FLASH_BASE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_ADDR_REDUND (CONFIG_SYS_FLASH_BASE + (2 * CONFIG_ENV_SECT_SIZE))
/* Clock */ diff --git a/include/configs/sksimx6.h b/include/configs/sksimx6.h index e1a7d724c161..b2ca7b1a7257 100644 --- a/include/configs/sksimx6.h +++ b/include/configs/sksimx6.h @@ -58,7 +58,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
/* Default environment */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/socfpga_vining_fpga.h b/include/configs/socfpga_vining_fpga.h index abde883487e8..5cc12419a692 100644 --- a/include/configs/socfpga_vining_fpga.h +++ b/include/configs/socfpga_vining_fpga.h @@ -195,7 +195,6 @@ "fi\0" \ "socfpga_legacy_reset_compat=1\0"
-#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_OFFSET 0x100000 #define CONFIG_ENV_OFFSET_REDUND \ diff --git a/include/configs/socrates.h b/include/configs/socrates.h index a03005902fa8..f5f3316b9030 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -192,7 +192,6 @@ CONFIG_ENV_SECT_SIZE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x4000 #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/strider.h b/include/configs/strider.h index e3d64e52aa13..d270d8a2dd4f 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -390,7 +390,6 @@ void fpga_control_clear(unsigned int bus, int pin); #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #else #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #endif diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 121de2bd2452..69819da492fd 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -114,7 +114,6 @@ #define CONFIG_ENV_ADDR 0x180000 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ 2 * CONFIG_SYS_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 diff --git a/include/configs/thuban.h b/include/configs/thuban.h index 569df9e4d8d7..954b063e293a 100644 --- a/include/configs/thuban.h +++ b/include/configs/thuban.h @@ -40,7 +40,6 @@
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/titanium.h b/include/configs/titanium.h index c24d657dba7d..64ec06da8599 100644 --- a/include/configs/titanium.h +++ b/include/configs/titanium.h @@ -149,7 +149,6 @@ #define CONFIG_ENV_SECT_SIZE (128 << 10) #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + (512 << 10)) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h index 7ed952435937..6ff68cd6a085 100644 --- a/include/configs/vcoreiii.h +++ b/include/configs/vcoreiii.h @@ -30,7 +30,6 @@ #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_SECT_SIZE (256 * 1024)
-#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE)
#endif diff --git a/include/configs/vct.h b/include/configs/vct.h index 571071593a12..890f347b4395 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -134,7 +134,6 @@
/* Address and size of Redundant Environment Sector */ #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) #endif /* CONFIG_ENV_IS_IN_FLASH */ #endif /* CONFIG_VCT_NOR */
diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 66f771d818f1..2608b2b23220 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -202,7 +202,6 @@ /* Address and size of Redundant Environment Sector */ #define CONFIG_ENV_OFFSET_REDUND \ (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index 33f06c00b1d8..6672930fb39c 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -88,7 +88,6 @@ #define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_ENV_SIZE SZ_8K #define CONFIG_ENV_OFFSET_REDUND (9 * SZ_64K) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
#ifdef CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC4 eMMC */ diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index a4f2af4962de..74e8d3925bf2 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -205,7 +205,6 @@
#else #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index 5ad3dab51c4a..d7c4a6f1f4d8 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -124,7 +124,6 @@
#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/x600.h b/include/configs/x600.h index d4bbdcdb1340..f6779213a896 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -93,7 +93,6 @@ #define CONFIG_ENV_SIZE 0x02000 #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + \ CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
/* Miscellaneous configurable options */ #define CONFIG_BOOT_PARAMS_ADDR 0x00000100 diff --git a/include/env_internal.h b/include/env_internal.h index d520e6a55b5c..b8158c0e0bc5 100644 --- a/include/env_internal.h +++ b/include/env_internal.h @@ -50,8 +50,11 @@ # else # error "Both CONFIG_ENV_SECT_SIZE and CONFIG_ENV_SIZE undefined" # endif -# if defined(CONFIG_ENV_ADDR_REDUND) && !defined(CONFIG_ENV_SIZE_REDUND) -# define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +# if defined(CONFIG_ENV_ADDR_REDUND) && \ + ((CONFIG_ENV_ADDR >= CONFIG_SYS_MONITOR_BASE) && \ + (CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SIZE) <= \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN)) +# define ENV_IS_EMBEDDED # endif # if (CONFIG_ENV_ADDR >= CONFIG_SYS_MONITOR_BASE) && \ (CONFIG_ENV_ADDR + CONFIG_ENV_SIZE) <= \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b680c554c15a..d73e433cffb1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -454,7 +454,6 @@ CONFIG_ENV_SETTINGS_NAND_V2 CONFIG_ENV_SETTINGS_V1 CONFIG_ENV_SETTINGS_V2 CONFIG_ENV_SIZE_FLEX -CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SROM_BANK CONFIG_ENV_TOTAL_SIZE CONFIG_ENV_UBIFS_OPTION diff --git a/tools/envcrc.c b/tools/envcrc.c index 95776828289e..4b3b828af0fd 100644 --- a/tools/envcrc.c +++ b/tools/envcrc.c @@ -33,9 +33,6 @@ # ifndef CONFIG_ENV_SIZE # define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE # endif -# if defined(CONFIG_ENV_ADDR_REDUND) && !defined(CONFIG_ENV_SIZE_REDUND) -# define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE -# endif # if (CONFIG_ENV_ADDR >= CONFIG_SYS_MONITOR_BASE) && \ ((CONFIG_ENV_ADDR + CONFIG_ENV_SIZE) <= (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN)) # define ENV_IS_EMBEDDED
Cc: Wolfgang Denk wd@denx.de Cc: Joe Hershberger joe.hershberger@ni.com Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com
These functions can only be built and used when we have ENV_IS_IN_SPI_FLASH, use that as a guard.
Reviewed-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Tom Rini trini@konsulko.com --- Changes in v2: - Update commit message, add reviewed-by --- board/freescale/ls1043aqds/ls1043aqds.c | 2 +- board/freescale/ls1046aqds/ls1046aqds.c | 2 +- board/freescale/ls1088a/ls1088a.c | 2 ++ 3 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/freescale/ls1043aqds/ls1043aqds.c b/board/freescale/ls1043aqds/ls1043aqds.c index 45f006dab720..8c96b962b788 100644 --- a/board/freescale/ls1043aqds/ls1043aqds.c +++ b/board/freescale/ls1043aqds/ls1043aqds.c @@ -525,7 +525,7 @@ u16 flash_read16(void *addr) return (((val) >> 8) & 0x00ff) | (((val) << 8) & 0xff00); }
-#ifdef CONFIG_TFABOOT +#if defined(CONFIG_TFABOOT) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) void *env_sf_get_env_addr(void) { return (void *)(CONFIG_SYS_FSL_QSPI_BASE + CONFIG_ENV_OFFSET); diff --git a/board/freescale/ls1046aqds/ls1046aqds.c b/board/freescale/ls1046aqds/ls1046aqds.c index 6a51dcd64913..aac5d9aa848f 100644 --- a/board/freescale/ls1046aqds/ls1046aqds.c +++ b/board/freescale/ls1046aqds/ls1046aqds.c @@ -482,7 +482,7 @@ u16 flash_read16(void *addr) return (((val) >> 8) & 0x00ff) | (((val) << 8) & 0xff00); }
-#ifdef CONFIG_TFABOOT +#if defined(CONFIG_TFABOOT) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) void *env_sf_get_env_addr(void) { return (void *)(CONFIG_SYS_FSL_QSPI_BASE + CONFIG_ENV_OFFSET); diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index f1592982a348..4ecf6dce6855 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -1008,8 +1008,10 @@ int is_flash_available(void) } #endif
+#ifdef CONFIG_ENV_IS_IN_SPI_FLASH void *env_sf_get_env_addr(void) { return (void *)(CONFIG_SYS_FSL_QSPI_BASE + CONFIG_ENV_OFFSET); } #endif +#endif
We can only configure and set the environment in SPL when we have a particular environment location set that is not "nowhere" like it is in SECURE_BOOT designs. Update the code to reflect that.
Cc: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Tom Rini trini@konsulko.com --- Changes in v2: - Rework the guard to be if env is nand/mmc/spi, redo commit message. --- board/freescale/t104xrdb/spl.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/freescale/t104xrdb/spl.c b/board/freescale/t104xrdb/spl.c index 7b0eb8edf51d..7df371df4df5 100644 --- a/board/freescale/t104xrdb/spl.c +++ b/board/freescale/t104xrdb/spl.c @@ -106,6 +106,8 @@ void board_init_r(gd_t *gd, ulong dest_addr) #endif
/* relocate environment function pointers etc. */ +#if defined(CONFIG_ENV_IS_IN_NAND) || defined(CONFIG_ENV_IS_IN_MMC) || \ + defined(CONFIG_ENV_IS_IN_SPI_FLASH) #ifdef CONFIG_SPL_NAND_BOOT nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, (uchar *)CONFIG_ENV_ADDR); @@ -120,6 +122,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) #endif gd->env_addr = (ulong)(CONFIG_ENV_ADDR); gd->env_valid = ENV_VALID; +#endif
i2c_init_all();
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: Tuesday, November 19, 2019 6:32 AM To: u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com Subject: [PATCHv2 4/5] T1042RDB_PI_NAND_SECURE_BOOT: Guard t104xrdb SPL env code
Changes in v2:
- defined(CONFIG_ENV_IS_IN_SPI_FLASH)
i2c_init_all();
-- 2.17.1
Cc: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Priyanka Jain priyanka.jain@nxp.com
- In ARMv8 NXP Layerscape platforms we also need to make use of CONFIG_SYS_RELOC_GD_ENV_ADDR now, do so. - On ENV_IS_IN_REMOTE, CONFIG_ENV_OFFSET is never used, drop the define to 0. - Add Kconfig entry for ENV_ADDR. - Make ENV_ADDR / ENV_OFFSET depend on the env locations that use it. - Add ENV_xxx_REDUND options that depend on their primary option and SYS_REDUNDAND_ENVIRONMENT - On a number of PowerPC platforms, use SPL_ENV_ADDR not CONFIG_ENV_ADDR for the pre-main-U-Boot environment location. - On ENV_IS_IN_SPI_FLASH, check not for CONFIG_ENV_ADDR being set but rather it being non-zero, as it will now be zero by default. - Rework the env_offset absolute in env/embedded.o to not use CONFIG_ENV_OFFSET as it was the only use of ENV_OFFSET within ENV_IS_IN_FLASH. - Migrate all platforms.
Cc: Wolfgang Denk wd@denx.de Cc: Joe Hershberger joe.hershberger@ni.com Cc: Patrick Delaunay patrick.delaunay@st.com Cc: uboot-stm32@st-md-mailman.stormreply.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 2 +- board/freescale/b4860qds/spl.c | 4 +- board/freescale/c29xpcie/spl.c | 4 +- board/freescale/p1010rdb/spl.c | 4 +- board/freescale/p1022ds/spl.c | 4 +- board/freescale/p1_p2_rdb_pc/spl.c | 4 +- board/freescale/t102xqds/spl.c | 8 +-- board/freescale/t102xrdb/spl.c | 8 +-- board/freescale/t104xrdb/spl.c | 8 +-- board/freescale/t208xqds/spl.c | 8 +-- board/freescale/t208xrdb/spl.c | 8 +-- board/freescale/t4qds/spl.c | 6 +-- board/freescale/t4rdb/spl.c | 4 +- configs/10m50_defconfig | 3 ++ configs/3c120_defconfig | 3 ++ configs/B4420QDS_NAND_defconfig | 2 + configs/B4420QDS_SPIFLASH_defconfig | 3 ++ configs/B4420QDS_defconfig | 3 ++ configs/B4860QDS_NAND_defconfig | 2 + configs/B4860QDS_SECURE_BOOT_defconfig | 1 + configs/B4860QDS_SPIFLASH_defconfig | 3 ++ configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 2 + configs/B4860QDS_defconfig | 3 ++ configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 2 + configs/BSC9131RDB_NAND_defconfig | 2 + .../BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 3 ++ configs/BSC9131RDB_SPIFLASH_defconfig | 3 ++ ...BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 2 + ...BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 2 + .../BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 3 ++ .../BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 3 ++ ...C9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 2 + ...C9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 2 + ...132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 3 ++ ...132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 3 ++ configs/C29XPCIE_NAND_defconfig | 2 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 3 ++ configs/C29XPCIE_defconfig | 3 ++ configs/Cyrus_P5020_defconfig | 2 + configs/Cyrus_P5040_defconfig | 2 + configs/M5208EVBE_defconfig | 3 ++ configs/M52277EVB_defconfig | 3 ++ configs/M52277EVB_stmicro_defconfig | 3 ++ configs/M5235EVB_Flash32_defconfig | 3 ++ configs/M5235EVB_defconfig | 3 ++ configs/M5249EVB_defconfig | 3 ++ configs/M5253DEMO_defconfig | 3 ++ configs/M5272C3_defconfig | 3 ++ configs/M5275EVB_defconfig | 3 ++ configs/M5282EVB_defconfig | 3 ++ configs/M53017EVB_defconfig | 3 ++ configs/M5329AFEE_defconfig | 3 ++ configs/M5329BFEE_defconfig | 3 ++ configs/M5373EVB_defconfig | 3 ++ configs/M54418TWR_defconfig | 3 ++ configs/M54418TWR_nand_mii_defconfig | 1 + configs/M54418TWR_nand_rmii_defconfig | 1 + configs/M54418TWR_nand_rmii_lowfreq_defconfig | 1 + configs/M54418TWR_serial_mii_defconfig | 3 ++ configs/M54418TWR_serial_rmii_defconfig | 3 ++ configs/M54451EVB_defconfig | 3 ++ configs/M54451EVB_stmicro_defconfig | 3 ++ configs/M54455EVB_a66_defconfig | 3 ++ configs/M54455EVB_defconfig | 3 ++ configs/M54455EVB_i66_defconfig | 3 ++ configs/M54455EVB_intel_defconfig | 3 ++ configs/M54455EVB_stm33_defconfig | 3 ++ configs/M5475AFE_defconfig | 3 ++ configs/M5475BFE_defconfig | 3 ++ configs/M5475CFE_defconfig | 3 ++ configs/M5475DFE_defconfig | 3 ++ configs/M5475EFE_defconfig | 3 ++ configs/M5475FFE_defconfig | 3 ++ configs/M5475GFE_defconfig | 3 ++ configs/M5485AFE_defconfig | 3 ++ configs/M5485BFE_defconfig | 3 ++ configs/M5485CFE_defconfig | 3 ++ configs/M5485DFE_defconfig | 3 ++ configs/M5485EFE_defconfig | 3 ++ configs/M5485FFE_defconfig | 3 ++ configs/M5485GFE_defconfig | 3 ++ configs/M5485HFE_defconfig | 3 ++ configs/MCR3000_defconfig | 3 ++ configs/MPC8308RDB_defconfig | 4 ++ configs/MPC8313ERDB_33_defconfig | 3 ++ configs/MPC8313ERDB_66_defconfig | 3 ++ configs/MPC8313ERDB_NAND_33_defconfig | 3 ++ configs/MPC8313ERDB_NAND_66_defconfig | 3 ++ configs/MPC8315ERDB_defconfig | 3 ++ configs/MPC8323ERDB_defconfig | 3 ++ configs/MPC832XEMDS_ATM_defconfig | 3 ++ configs/MPC832XEMDS_HOST_33_defconfig | 3 ++ configs/MPC832XEMDS_HOST_66_defconfig | 3 ++ configs/MPC832XEMDS_SLAVE_defconfig | 3 ++ configs/MPC832XEMDS_defconfig | 3 ++ configs/MPC8349EMDS_PCI64_defconfig | 4 ++ configs/MPC8349EMDS_SDRAM_defconfig | 4 ++ configs/MPC8349EMDS_SLAVE_defconfig | 4 ++ configs/MPC8349EMDS_defconfig | 4 ++ configs/MPC8349ITXGP_defconfig | 3 ++ configs/MPC8349ITX_LOWBOOT_defconfig | 3 ++ configs/MPC8349ITX_defconfig | 3 ++ configs/MPC837XEMDS_HOST_defconfig | 3 ++ configs/MPC837XEMDS_SLAVE_defconfig | 3 ++ configs/MPC837XEMDS_defconfig | 3 ++ configs/MPC837XERDB_SLAVE_defconfig | 3 ++ configs/MPC837XERDB_defconfig | 3 ++ configs/MPC8536DS_36BIT_defconfig | 3 ++ configs/MPC8536DS_SDCARD_defconfig | 2 + configs/MPC8536DS_SPIFLASH_defconfig | 3 ++ configs/MPC8536DS_defconfig | 3 ++ configs/MPC8541CDS_defconfig | 3 ++ configs/MPC8541CDS_legacy_defconfig | 3 ++ configs/MPC8544DS_defconfig | 3 ++ configs/MPC8548CDS_36BIT_defconfig | 3 ++ configs/MPC8548CDS_defconfig | 3 ++ configs/MPC8548CDS_legacy_defconfig | 3 ++ configs/MPC8555CDS_defconfig | 3 ++ configs/MPC8555CDS_legacy_defconfig | 3 ++ configs/MPC8568MDS_defconfig | 3 ++ configs/MPC8569MDS_ATM_defconfig | 3 ++ configs/MPC8569MDS_defconfig | 3 ++ configs/MPC8572DS_36BIT_defconfig | 3 ++ configs/MPC8572DS_defconfig | 3 ++ configs/MPC8610HPCD_defconfig | 3 ++ configs/MPC8641HPCN_36BIT_defconfig | 3 ++ configs/MPC8641HPCN_defconfig | 3 ++ configs/MigoR_defconfig | 3 ++ .../P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 + .../P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 3 ++ configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 2 + ...010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 3 ++ configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 2 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 3 ++ configs/P1010RDB-PA_SDCARD_defconfig | 2 + .../P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 3 ++ .../P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 + .../P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 3 ++ configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 2 + ...010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 3 ++ configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 2 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 3 ++ configs/P1010RDB-PB_SDCARD_defconfig | 2 + .../P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 3 ++ configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 2 + configs/P1020MBG-PC_36BIT_defconfig | 3 ++ configs/P1020MBG-PC_SDCARD_defconfig | 2 + configs/P1020MBG-PC_defconfig | 3 ++ configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 2 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 3 ++ configs/P1020RDB-PC_36BIT_defconfig | 3 ++ configs/P1020RDB-PC_NAND_defconfig | 2 + configs/P1020RDB-PC_SDCARD_defconfig | 2 + configs/P1020RDB-PC_SPIFLASH_defconfig | 3 ++ configs/P1020RDB-PC_defconfig | 3 ++ configs/P1020RDB-PD_NAND_defconfig | 2 + configs/P1020RDB-PD_SDCARD_defconfig | 2 + configs/P1020RDB-PD_SPIFLASH_defconfig | 3 ++ configs/P1020RDB-PD_defconfig | 3 ++ configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 2 + configs/P1020UTM-PC_36BIT_defconfig | 3 ++ configs/P1020UTM-PC_SDCARD_defconfig | 2 + configs/P1020UTM-PC_defconfig | 3 ++ configs/P1021RDB-PC_36BIT_NAND_defconfig | 2 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 2 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 3 ++ configs/P1021RDB-PC_36BIT_defconfig | 3 ++ configs/P1021RDB-PC_NAND_defconfig | 2 + configs/P1021RDB-PC_SDCARD_defconfig | 2 + configs/P1021RDB-PC_SPIFLASH_defconfig | 3 ++ configs/P1021RDB-PC_defconfig | 3 ++ configs/P1022DS_36BIT_NAND_defconfig | 2 + configs/P1022DS_36BIT_SDCARD_defconfig | 2 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 3 ++ configs/P1022DS_36BIT_defconfig | 3 ++ configs/P1022DS_NAND_defconfig | 2 + configs/P1022DS_SDCARD_defconfig | 2 + configs/P1022DS_SPIFLASH_defconfig | 3 ++ configs/P1022DS_defconfig | 3 ++ configs/P1023RDB_defconfig | 3 ++ configs/P1024RDB_36BIT_defconfig | 3 ++ configs/P1024RDB_NAND_defconfig | 2 + configs/P1024RDB_SDCARD_defconfig | 2 + configs/P1024RDB_SPIFLASH_defconfig | 3 ++ configs/P1024RDB_defconfig | 3 ++ configs/P1025RDB_36BIT_defconfig | 3 ++ configs/P1025RDB_NAND_defconfig | 2 + configs/P1025RDB_SDCARD_defconfig | 2 + configs/P1025RDB_SPIFLASH_defconfig | 3 ++ configs/P1025RDB_defconfig | 3 ++ configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 2 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 3 ++ configs/P2020RDB-PC_36BIT_defconfig | 3 ++ configs/P2020RDB-PC_NAND_defconfig | 2 + configs/P2020RDB-PC_SDCARD_defconfig | 2 + configs/P2020RDB-PC_SPIFLASH_defconfig | 3 ++ configs/P2020RDB-PC_defconfig | 3 ++ configs/P2041RDB_NAND_defconfig | 2 + configs/P2041RDB_SDCARD_defconfig | 2 + configs/P2041RDB_SECURE_BOOT_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 3 ++ configs/P2041RDB_SRIO_PCIE_BOOT_defconfig | 2 + configs/P2041RDB_defconfig | 3 ++ configs/P3041DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P3041DS_NAND_defconfig | 2 + configs/P3041DS_SDCARD_defconfig | 2 + configs/P3041DS_SECURE_BOOT_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 3 ++ configs/P3041DS_SRIO_PCIE_BOOT_defconfig | 2 + configs/P3041DS_defconfig | 3 ++ configs/P4080DS_SDCARD_defconfig | 2 + configs/P4080DS_SECURE_BOOT_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 3 ++ configs/P4080DS_SRIO_PCIE_BOOT_defconfig | 2 + configs/P4080DS_defconfig | 3 ++ configs/P5020DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5020DS_NAND_defconfig | 2 + configs/P5020DS_SDCARD_defconfig | 2 + configs/P5020DS_SECURE_BOOT_defconfig | 1 + configs/P5020DS_SPIFLASH_defconfig | 3 ++ configs/P5020DS_SRIO_PCIE_BOOT_defconfig | 2 + configs/P5020DS_defconfig | 3 ++ configs/P5040DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5040DS_NAND_defconfig | 2 + configs/P5040DS_SDCARD_defconfig | 2 + configs/P5040DS_SECURE_BOOT_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 3 ++ configs/P5040DS_defconfig | 3 ++ configs/SBx81LIFKW_defconfig | 3 ++ configs/SBx81LIFXCAT_defconfig | 3 ++ configs/T1023RDB_NAND_defconfig | 2 + configs/T1023RDB_SDCARD_defconfig | 2 + configs/T1023RDB_SECURE_BOOT_defconfig | 1 + configs/T1023RDB_SPIFLASH_defconfig | 4 ++ configs/T1023RDB_defconfig | 3 ++ configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 3 ++ configs/T1024QDS_NAND_defconfig | 2 + configs/T1024QDS_SDCARD_defconfig | 2 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 4 ++ configs/T1024QDS_defconfig | 3 ++ configs/T1024RDB_NAND_defconfig | 2 + configs/T1024RDB_SDCARD_defconfig | 2 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 4 ++ configs/T1024RDB_defconfig | 3 ++ configs/T1040D4RDB_NAND_defconfig | 2 + configs/T1040D4RDB_SDCARD_defconfig | 2 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 4 ++ configs/T1040D4RDB_defconfig | 3 ++ configs/T1040QDS_DDR4_defconfig | 3 ++ configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 3 ++ configs/T1040RDB_NAND_defconfig | 2 + configs/T1040RDB_SDCARD_defconfig | 2 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 4 ++ configs/T1040RDB_defconfig | 3 ++ configs/T1042D4RDB_NAND_defconfig | 2 + configs/T1042D4RDB_SDCARD_defconfig | 2 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 4 ++ configs/T1042D4RDB_defconfig | 3 ++ .../T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 2 + configs/T1042RDB_PI_SDCARD_defconfig | 2 + configs/T1042RDB_PI_SPIFLASH_defconfig | 4 ++ configs/T1042RDB_PI_defconfig | 3 ++ configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_defconfig | 3 ++ configs/T2080QDS_NAND_defconfig | 2 + configs/T2080QDS_SDCARD_defconfig | 2 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 4 ++ configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 2 + configs/T2080QDS_defconfig | 3 ++ configs/T2080RDB_NAND_defconfig | 2 + configs/T2080RDB_SDCARD_defconfig | 2 + configs/T2080RDB_SECURE_BOOT_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 4 ++ configs/T2080RDB_SRIO_PCIE_BOOT_defconfig | 2 + configs/T2080RDB_defconfig | 3 ++ configs/T2081QDS_NAND_defconfig | 2 + configs/T2081QDS_SDCARD_defconfig | 2 + configs/T2081QDS_SPIFLASH_defconfig | 4 ++ configs/T2081QDS_SRIO_PCIE_BOOT_defconfig | 2 + configs/T2081QDS_defconfig | 3 ++ configs/T4160QDS_NAND_defconfig | 2 + configs/T4160QDS_SDCARD_defconfig | 2 + configs/T4160QDS_SECURE_BOOT_defconfig | 1 + configs/T4160QDS_defconfig | 3 ++ configs/T4160RDB_defconfig | 3 ++ configs/T4240QDS_NAND_defconfig | 2 + configs/T4240QDS_SDCARD_defconfig | 2 + configs/T4240QDS_SECURE_BOOT_defconfig | 1 + configs/T4240QDS_SRIO_PCIE_BOOT_defconfig | 2 + configs/T4240QDS_defconfig | 3 ++ configs/T4240RDB_SDCARD_defconfig | 2 + configs/T4240RDB_defconfig | 3 ++ configs/TQM834x_defconfig | 4 ++ configs/TWR-P1025_defconfig | 3 ++ configs/UCP1020_defconfig | 3 ++ configs/adp-ae3xx_defconfig | 3 ++ configs/adp-ag101p_defconfig | 3 ++ configs/ae350_rv32_defconfig | 1 + configs/ae350_rv32_xip_defconfig | 1 + configs/ae350_rv64_defconfig | 1 + configs/ae350_rv64_xip_defconfig | 1 + configs/alt_defconfig | 4 ++ configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_guardian_defconfig | 2 +- configs/am335x_shc_defconfig | 1 + configs/am335x_shc_ict_defconfig | 1 + configs/am335x_shc_netboot_defconfig | 1 + configs/am335x_shc_sdboot_defconfig | 1 + configs/am335x_sl50_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/am57xx_hs_evm_usb_defconfig | 1 + configs/am65x_evm_a53_defconfig | 3 ++ configs/am65x_evm_r5_defconfig | 1 + configs/am65x_hs_evm_a53_defconfig | 1 + configs/am65x_hs_evm_r5_defconfig | 1 + configs/amcore_defconfig | 3 ++ configs/ap121_defconfig | 3 ++ configs/ap143_defconfig | 3 ++ configs/ap152_defconfig | 3 ++ configs/apalis-imx8qm_defconfig | 2 + configs/apalis-tk1_defconfig | 2 + configs/apalis_imx6_defconfig | 2 + configs/apalis_t30_defconfig | 2 + configs/apf27_defconfig | 3 ++ configs/apx4devkit_defconfig | 3 ++ configs/aristainetos2_defconfig | 4 ++ configs/aristainetos2b_defconfig | 4 ++ configs/aristainetos_defconfig | 4 ++ configs/armadillo-800eva_defconfig | 3 ++ configs/arndale_defconfig | 2 + configs/aspenite_defconfig | 1 + configs/astro_mcf5373l_defconfig | 3 ++ configs/at91rm9200ek_defconfig | 2 +- configs/at91rm9200ek_ram_defconfig | 2 +- configs/at91sam9260ek_nandflash_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 3 +- configs/at91sam9263ek_norflash_defconfig | 3 +- configs/at91sam9g10ek_nandflash_defconfig | 1 + .../at91sam9g20ek_2mmc_nandflash_defconfig | 1 + configs/at91sam9g20ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9xeek_nandflash_defconfig | 1 + configs/axm_defconfig | 1 + configs/bayleybay_defconfig | 3 ++ configs/bcm11130_defconfig | 2 + configs/bcm11130_nand_defconfig | 2 + configs/bcm23550_w1d_defconfig | 2 + configs/bcm28155_ap_defconfig | 2 + configs/bcm28155_w1d_defconfig | 2 + configs/bcm7260_defconfig | 3 ++ configs/bcm7445_defconfig | 4 ++ configs/bcm911360_entphn-ns_defconfig | 1 + configs/bcm911360_entphn_defconfig | 1 + configs/bcm911360k_defconfig | 1 + configs/bcm958300k-ns_defconfig | 1 + configs/bcm958300k_defconfig | 1 + configs/bcm958305k_defconfig | 1 + configs/bcm958622hr_defconfig | 1 + configs/bcm958712k_defconfig | 1 + configs/bcm963158_ram_defconfig | 1 + configs/bcm968380gerg_ram_defconfig | 1 + configs/bcm968580xref_ram_defconfig | 1 + configs/beaver_defconfig | 2 + configs/bg0900_defconfig | 1 + configs/bk4r1_defconfig | 3 ++ configs/blanche_defconfig | 4 ++ configs/boston32r2_defconfig | 3 ++ configs/boston32r2el_defconfig | 3 ++ configs/boston32r6_defconfig | 3 ++ configs/boston32r6el_defconfig | 3 ++ configs/boston64r2_defconfig | 3 ++ configs/boston64r2el_defconfig | 3 ++ configs/boston64r6_defconfig | 3 ++ configs/boston64r6el_defconfig | 3 ++ configs/brppt1_mmc_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brppt2_defconfig | 3 ++ configs/brsmarc1_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/bubblegum_96_defconfig | 1 + configs/caddy2_defconfig | 4 ++ configs/cardhu_defconfig | 2 + configs/cei-tk1-som_defconfig | 2 + configs/cgtqmx6eval_defconfig | 3 ++ configs/cherryhill_defconfig | 3 ++ configs/chiliboard_defconfig | 1 + configs/chromebook_bob_defconfig | 1 + configs/chromebook_link64_defconfig | 3 ++ configs/chromebook_link_defconfig | 3 ++ configs/chromebook_samus_defconfig | 3 ++ configs/chromebook_samus_tpl_defconfig | 3 ++ configs/chromebox_panther_defconfig | 3 ++ configs/ci20_mmc_defconfig | 2 + configs/cl-som-imx7_defconfig | 3 ++ configs/clearfog_defconfig | 2 + configs/clearfog_gt_8k_defconfig | 3 ++ configs/cm_fx6_defconfig | 3 ++ configs/cm_t43_defconfig | 2 +- configs/cm_t54_defconfig | 3 +- configs/cobra5272_defconfig | 3 ++ configs/colibri-imx6ull_defconfig | 2 + configs/colibri-imx8qxp_defconfig | 2 + configs/colibri_imx6_defconfig | 2 + configs/colibri_imx7_defconfig | 2 + configs/colibri_imx7_emmc_defconfig | 2 + configs/colibri_pxa270_defconfig | 3 ++ configs/colibri_t20_defconfig | 2 + configs/colibri_t30_defconfig | 2 + configs/colibri_vf_defconfig | 2 + configs/comtrend_ar5315u_ram_defconfig | 1 + configs/comtrend_ar5387un_ram_defconfig | 1 + configs/comtrend_ct5361_ram_defconfig | 1 + configs/comtrend_vr3032u_ram_defconfig | 1 + configs/comtrend_wap5813n_ram_defconfig | 1 + ...-qeval20-qa3-e3845-internal-uart_defconfig | 3 ++ configs/conga-qeval20-qa3-e3845_defconfig | 3 ++ ...trolcenterd_36BIT_SDCARD_DEVELOP_defconfig | 2 + configs/controlcenterd_36BIT_SDCARD_defconfig | 2 + ...ntrolcenterd_TRAILBLAZER_DEVELOP_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_defconfig | 1 + configs/controlcenterdc_defconfig | 3 ++ configs/coreboot_defconfig | 1 + configs/corvus_defconfig | 1 + configs/cougarcanyon2_defconfig | 3 ++ configs/crownbay_defconfig | 3 ++ configs/crs305-1g-4s_defconfig | 3 ++ configs/d2net_v2_defconfig | 4 ++ configs/da850evm_defconfig | 3 ++ configs/da850evm_direct_nor_defconfig | 3 ++ configs/da850evm_nand_defconfig | 2 + configs/dalmore_defconfig | 2 + configs/db-88f6281-bp-nand_defconfig | 3 ++ configs/db-88f6281-bp-spi_defconfig | 3 ++ configs/db-88f6720_defconfig | 3 ++ configs/db-88f6820-amc_defconfig | 3 ++ configs/db-88f6820-gp_defconfig | 3 ++ configs/db-mv784mp-gp_defconfig | 3 ++ configs/db-xc3-24g4xg_defconfig | 3 ++ configs/devkit3250_defconfig | 2 + configs/dfi-bt700-q7x-151_defconfig | 3 ++ configs/dh_imx6_defconfig | 4 ++ configs/display5_defconfig | 4 ++ configs/display5_factory_defconfig | 4 ++ configs/dms-ba16-1g_defconfig | 3 ++ configs/dms-ba16_defconfig | 3 ++ configs/dns325_defconfig | 2 + configs/dockstar_defconfig | 2 + configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/dra7xx_hs_evm_usb_defconfig | 1 + configs/draco_defconfig | 1 + configs/dragonboard410c_defconfig | 2 + configs/dragonboard820c_defconfig | 1 + configs/dreamplug_defconfig | 4 ++ configs/ds109_defconfig | 4 ++ configs/ds414_defconfig | 3 ++ configs/durian_defconfig | 1 + configs/e2220-1170_defconfig | 2 + configs/eb_cpu5282_defconfig | 3 ++ configs/eb_cpu5282_internal_defconfig | 3 ++ configs/edb9315a_defconfig | 4 ++ configs/edison_defconfig | 3 ++ configs/edminiv2_defconfig | 3 ++ configs/efi-x86_app_defconfig | 1 + configs/efi-x86_payload32_defconfig | 1 + configs/efi-x86_payload64_defconfig | 1 + configs/elgin-rv1108_defconfig | 1 + configs/espresso7420_defconfig | 1 + configs/etamin_defconfig | 1 + configs/evb-ast2500_defconfig | 1 + configs/evb-px5_defconfig | 1 + configs/evb-rk3128_defconfig | 1 + configs/evb-rk3229_defconfig | 1 + configs/evb-rk3288_defconfig | 1 + configs/evb-rk3328_defconfig | 1 + configs/evb-rk3399_defconfig | 1 + configs/ficus-rk3399_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/firefly-rk3399_defconfig | 1 + configs/flea3_defconfig | 4 ++ configs/galileo_defconfig | 3 ++ ...gardena-smart-gateway-mt7688-ram_defconfig | 4 ++ .../gardena-smart-gateway-mt7688_defconfig | 4 ++ configs/gazerbeam_defconfig | 4 ++ configs/ge_bx50v3_defconfig | 3 ++ configs/goflexhome_defconfig | 2 + configs/gose_defconfig | 4 ++ configs/gplugd_defconfig | 1 + configs/grpeach_defconfig | 3 ++ configs/guruplug_defconfig | 2 + configs/gwventana_emmc_defconfig | 3 ++ configs/gwventana_gw5904_defconfig | 3 ++ configs/gwventana_nand_defconfig | 3 ++ configs/harmony_defconfig | 2 + configs/helios4_defconfig | 2 + configs/highbank_defconfig | 2 + configs/hikey960_defconfig | 1 + configs/hikey_defconfig | 2 + configs/hrcon_defconfig | 4 ++ configs/hrcon_dh_defconfig | 4 ++ configs/huawei_hg556a_ram_defconfig | 1 + configs/ib62x0_defconfig | 2 + configs/iconnect_defconfig | 2 + configs/ids8313_defconfig | 4 ++ configs/imgtec_xilfpga_defconfig | 1 + configs/imx6dl_icore_nand_defconfig | 2 + configs/imx6dl_mamoj_defconfig | 2 + configs/imx6q_icore_nand_defconfig | 2 + configs/imx6q_logic_defconfig | 2 + configs/imx6qdl_icore_mipi_defconfig | 2 + configs/imx6qdl_icore_mmc_defconfig | 2 + configs/imx6qdl_icore_nand_defconfig | 2 + configs/imx6qdl_icore_rqs_defconfig | 2 + configs/imx6ul_geam_mmc_defconfig | 2 + configs/imx6ul_geam_nand_defconfig | 2 + configs/imx6ul_isiot_emmc_defconfig | 2 + configs/imx6ul_isiot_nand_defconfig | 2 + configs/imx8mm_evk_defconfig | 2 + configs/imx8mn_ddr4_evk_defconfig | 2 + configs/imx8mq_evk_defconfig | 2 + configs/imx8qm_mek_defconfig | 2 + configs/imx8qm_rom7720_a1_4G_defconfig | 2 + configs/imx8qxp_mek_defconfig | 2 + configs/inetspace_v2_defconfig | 4 ++ configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/integratorcp_cm1136_defconfig | 3 ++ configs/integratorcp_cm920t_defconfig | 3 ++ configs/integratorcp_cm926ejs_defconfig | 3 ++ configs/integratorcp_cm946es_defconfig | 3 ++ configs/j721e_evm_a72_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 + configs/jetson-tk1_defconfig | 2 + configs/k2e_evm_defconfig | 2 + configs/k2e_hs_evm_defconfig | 2 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 2 + configs/k2hk_hs_evm_defconfig | 2 + configs/k2l_evm_defconfig | 2 + configs/k2l_hs_evm_defconfig | 2 + configs/khadas-edge-captain-rk3399_defconfig | 1 + configs/khadas-edge-rk3399_defconfig | 1 + configs/khadas-edge-v-rk3399_defconfig | 1 + configs/khadas-vim2_defconfig | 1 + configs/khadas-vim3_defconfig | 1 + configs/khadas-vim_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 3 ++ configs/km_kirkwood_defconfig | 3 ++ configs/km_kirkwood_pci_defconfig | 3 ++ configs/kmcoge4_defconfig | 4 ++ configs/kmcoge5ne_defconfig | 4 ++ configs/kmcoge5un_defconfig | 4 ++ configs/kmeter1_defconfig | 4 ++ configs/kmnusa_defconfig | 4 ++ configs/kmopti2_defconfig | 4 ++ configs/kmsugp1_defconfig | 4 ++ configs/kmsupx5_defconfig | 4 ++ configs/kmsuv31_defconfig | 4 ++ configs/kmtegr1_defconfig | 4 ++ configs/kmtepr2_defconfig | 4 ++ configs/koelsch_defconfig | 4 ++ configs/kp_imx53_defconfig | 3 ++ configs/kp_imx6q_tpc_defconfig | 3 ++ configs/kylin-rk3036_defconfig | 1 + configs/kzm9g_defconfig | 3 ++ configs/lager_defconfig | 4 ++ configs/leez-rk3399_defconfig | 1 + configs/legoev3_defconfig | 1 + configs/libretech-ac_defconfig | 3 ++ configs/libretech-cc_defconfig | 1 + configs/linkit-smart-7688-ram_defconfig | 3 ++ configs/linkit-smart-7688_defconfig | 3 ++ configs/lion-rk3368_defconfig | 1 + configs/liteboard_defconfig | 2 + configs/ls1012a2g5rdb_qspi_defconfig | 3 ++ configs/ls1012a2g5rdb_tfa_defconfig | 3 ++ configs/ls1012afrdm_qspi_defconfig | 3 ++ configs/ls1012afrdm_tfa_defconfig | 3 ++ .../ls1012afrwy_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012afrwy_qspi_defconfig | 4 ++ configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012afrwy_tfa_defconfig | 4 ++ configs/ls1012aqds_qspi_defconfig | 3 ++ configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012aqds_tfa_defconfig | 3 ++ configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_qspi_defconfig | 4 ++ configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_tfa_defconfig | 4 ++ configs/ls1021aiot_qspi_defconfig | 3 ++ configs/ls1021aiot_sdcard_defconfig | 2 + configs/ls1021aqds_ddr4_nor_defconfig | 3 ++ configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 3 ++ configs/ls1021aqds_nand_defconfig | 2 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 3 ++ configs/ls1021aqds_nor_lpuart_defconfig | 3 ++ configs/ls1021aqds_qspi_defconfig | 3 ++ configs/ls1021aqds_sdcard_ifc_defconfig | 2 + configs/ls1021aqds_sdcard_qspi_defconfig | 2 + configs/ls1021atsn_qspi_defconfig | 3 ++ configs/ls1021atsn_sdcard_defconfig | 2 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 3 ++ configs/ls1021atwr_nor_lpuart_defconfig | 3 ++ configs/ls1021atwr_qspi_defconfig | 3 ++ ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 2 + configs/ls1021atwr_sdcard_qspi_defconfig | 2 + configs/ls1028aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1028aqds_tfa_defconfig | 4 ++ configs/ls1028ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1028ardb_tfa_defconfig | 4 ++ configs/ls1043aqds_defconfig | 3 ++ configs/ls1043aqds_lpuart_defconfig | 3 ++ configs/ls1043aqds_nand_defconfig | 2 + configs/ls1043aqds_nor_ddr3_defconfig | 3 ++ configs/ls1043aqds_qspi_defconfig | 3 ++ configs/ls1043aqds_sdcard_ifc_defconfig | 2 + configs/ls1043aqds_sdcard_qspi_defconfig | 2 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 4 ++ configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 3 ++ configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 2 + .../ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 2 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 4 ++ configs/ls1046afrwy_tfa_defconfig | 4 ++ configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 3 ++ configs/ls1046aqds_lpuart_defconfig | 3 ++ configs/ls1046aqds_nand_defconfig | 2 + configs/ls1046aqds_qspi_defconfig | 3 ++ configs/ls1046aqds_sdcard_ifc_defconfig | 2 + configs/ls1046aqds_sdcard_qspi_defconfig | 2 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 4 ++ configs/ls1046ardb_emmc_defconfig | 2 + configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_qspi_defconfig | 3 ++ configs/ls1046ardb_qspi_spl_defconfig | 3 ++ .../ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_sdcard_defconfig | 2 + configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 4 ++ configs/ls1088aqds_defconfig | 3 ++ configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088aqds_qspi_defconfig | 4 ++ configs/ls1088aqds_sdcard_ifc_defconfig | 2 + configs/ls1088aqds_sdcard_qspi_defconfig | 2 + configs/ls1088aqds_tfa_defconfig | 4 ++ configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_qspi_defconfig | 4 ++ ...1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_sdcard_qspi_defconfig | 2 + configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_tfa_defconfig | 4 ++ configs/ls2080a_emu_defconfig | 1 + configs/ls2080a_simu_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 3 ++ configs/ls2080aqds_nand_defconfig | 2 + configs/ls2080aqds_qspi_defconfig | 3 ++ configs/ls2080aqds_sdcard_defconfig | 2 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 3 ++ configs/ls2080ardb_nand_defconfig | 2 + configs/ls2081ardb_defconfig | 3 ++ configs/ls2088aqds_tfa_defconfig | 4 ++ configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_qspi_defconfig | 3 ++ configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 4 ++ configs/lschlv2_defconfig | 3 ++ configs/lsxhl_defconfig | 3 ++ configs/lx2160aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160aqds_tfa_defconfig | 2 + configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160ardb_tfa_defconfig | 2 + configs/m53menlo_defconfig | 3 ++ configs/malta64_defconfig | 3 ++ configs/malta64el_defconfig | 3 ++ configs/malta_defconfig | 3 ++ configs/maltael_defconfig | 3 ++ configs/marsboard_defconfig | 3 ++ configs/maxbcm_defconfig | 3 ++ configs/mccmon6_nor_defconfig | 4 ++ configs/mccmon6_sd_defconfig | 4 ++ configs/medcom-wide_defconfig | 2 + configs/meerkat96_defconfig | 2 + configs/mgcoge3un_defconfig | 3 ++ configs/microblaze-generic_defconfig | 1 + configs/microchip_mpfs_icicle_defconfig | 1 + configs/minnowmax_defconfig | 3 ++ configs/miqi-rk3288_defconfig | 1 + configs/mpc8308_p1m_defconfig | 4 ++ configs/mscc_jr2_defconfig | 4 ++ configs/mscc_luton_defconfig | 4 ++ configs/mscc_ocelot_defconfig | 4 ++ configs/mscc_serval_defconfig | 4 ++ configs/mscc_servalt_defconfig | 4 ++ configs/mt7623n_bpir2_defconfig | 2 + configs/mt7629_rfb_defconfig | 1 + configs/mvebu_db-88f3720_defconfig | 3 ++ configs/mvebu_db_armada8k_defconfig | 3 ++ configs/mvebu_espressobin-88f3720_defconfig | 3 ++ configs/mvebu_mcbin-88f8040_defconfig | 3 ++ configs/mx23_olinuxino_defconfig | 2 + configs/mx23evk_defconfig | 2 + configs/mx25pdk_defconfig | 2 + configs/mx28evk_auart_console_defconfig | 2 + configs/mx28evk_defconfig | 2 + configs/mx28evk_nand_defconfig | 3 ++ configs/mx28evk_spi_defconfig | 1 + configs/mx31pdk_defconfig | 3 ++ configs/mx35pdk_defconfig | 4 ++ configs/mx51evk_defconfig | 2 + configs/mx53ard_defconfig | 2 + configs/mx53cx9020_defconfig | 2 + configs/mx53evk_defconfig | 2 + configs/mx53loco_defconfig | 2 + configs/mx53ppd_defconfig | 2 + configs/mx53smd_defconfig | 2 + configs/mx6cuboxi_defconfig | 2 + configs/mx6dlarm2_defconfig | 2 + configs/mx6dlarm2_lpddr2_defconfig | 2 + configs/mx6memcal_defconfig | 1 + configs/mx6qarm2_defconfig | 2 + configs/mx6qarm2_lpddr2_defconfig | 2 + configs/mx6qsabrelite_defconfig | 2 + configs/mx6sabreauto_defconfig | 2 + configs/mx6sabresd_defconfig | 2 + configs/mx6slevk_defconfig | 2 + configs/mx6slevk_spinor_defconfig | 3 ++ configs/mx6slevk_spl_defconfig | 2 + configs/mx6sllevk_defconfig | 2 + configs/mx6sllevk_plugin_defconfig | 2 + configs/mx6sxsabreauto_defconfig | 2 + configs/mx6sxsabresd_defconfig | 2 + configs/mx6sxsabresd_spl_defconfig | 2 + configs/mx6ul_14x14_evk_defconfig | 2 + configs/mx6ul_9x9_evk_defconfig | 2 + configs/mx6ull_14x14_evk_defconfig | 2 + configs/mx6ull_14x14_evk_plugin_defconfig | 2 + configs/mx6ulz_14x14_evk_defconfig | 2 + configs/mx7dsabresd_defconfig | 2 + configs/mx7dsabresd_qspi_defconfig | 2 + configs/mx7ulp_evk_defconfig | 2 + configs/mx7ulp_evk_plugin_defconfig | 2 + configs/nanopc-t4-rk3399_defconfig | 1 + configs/nanopi-k2_defconfig | 1 + configs/nanopi-m4-rk3399_defconfig | 1 + configs/nanopi-neo4-rk3399_defconfig | 1 + configs/nas220_defconfig | 2 + configs/net2big_v2_defconfig | 4 ++ configs/netgear_cg3100d_ram_defconfig | 1 + configs/netgear_dgnd3700v2_ram_defconfig | 1 + configs/netspace_lite_v2_defconfig | 4 ++ configs/netspace_max_v2_defconfig | 4 ++ configs/netspace_mini_v2_defconfig | 4 ++ configs/netspace_v2_defconfig | 4 ++ configs/nitrogen6dl2g_defconfig | 3 ++ configs/nitrogen6dl_defconfig | 3 ++ configs/nitrogen6q2g_defconfig | 3 ++ configs/nitrogen6q_defconfig | 3 ++ configs/nitrogen6s1g_defconfig | 3 ++ configs/nitrogen6s_defconfig | 3 ++ configs/novena_defconfig | 3 ++ configs/nsa310s_defconfig | 2 + configs/nyan-big_defconfig | 2 + configs/odroid-c2_defconfig | 1 + configs/odroid-n2_defconfig | 1 + configs/odroid-xu3_defconfig | 2 + configs/odroid_defconfig | 2 + configs/omap5_uevm_defconfig | 1 + configs/omapl138_lcdk_defconfig | 2 + configs/openrd_base_defconfig | 2 + configs/openrd_client_defconfig | 2 + configs/openrd_ultimate_defconfig | 2 + configs/opos6uldev_defconfig | 3 ++ configs/orangepi-rk3399_defconfig | 1 + configs/origen_defconfig | 2 + configs/ot1200_defconfig | 3 ++ configs/ot1200_spl_defconfig | 3 ++ configs/p200_defconfig | 1 + configs/p201_defconfig | 1 + configs/p212_defconfig | 1 + configs/p2371-0000_defconfig | 2 + configs/p2371-2180_defconfig | 2 + configs/p2571_defconfig | 2 + configs/p2771-0000-000_defconfig | 2 + configs/p2771-0000-500_defconfig | 2 + configs/paz00_defconfig | 2 + configs/pcm052_defconfig | 3 ++ configs/pcm058_defconfig | 4 ++ configs/peach-pi_defconfig | 3 ++ configs/peach-pit_defconfig | 3 ++ configs/pfla02_defconfig | 4 ++ configs/phycore-am335x-r2-wega_defconfig | 2 +- configs/phycore-rk3288_defconfig | 1 + configs/phycore_pcl063_defconfig | 1 + configs/phycore_pcl063_ull_defconfig | 1 + configs/pic32mzdask_defconfig | 1 + configs/pico-dwarf-imx6ul_defconfig | 2 + configs/pico-dwarf-imx7d_defconfig | 2 + configs/pico-hobbit-imx6ul_defconfig | 2 + configs/pico-hobbit-imx7d_defconfig | 2 + configs/pico-imx6_defconfig | 2 + configs/pico-imx6ul_defconfig | 2 + configs/pico-imx7d_bl33_defconfig | 2 + configs/pico-imx7d_defconfig | 2 + configs/pico-nymph-imx7d_defconfig | 2 + configs/pico-pi-imx6ul_defconfig | 2 + configs/pico-pi-imx7d_defconfig | 2 + configs/platinum_picon_defconfig | 3 ++ configs/platinum_titanium_defconfig | 3 ++ configs/plutux_defconfig | 2 + configs/pm9261_defconfig | 2 +- configs/pm9263_defconfig | 2 +- configs/pm9g45_defconfig | 1 + configs/pogo_e02_defconfig | 2 + configs/poplar_defconfig | 2 + configs/popmetal-rk3288_defconfig | 1 + configs/porter_defconfig | 4 ++ configs/puma-rk3399_defconfig | 1 + configs/pumpkin_defconfig | 1 + configs/qemu-ppce500_defconfig | 1 + configs/qemu-riscv32_defconfig | 1 + configs/qemu-riscv32_smode_defconfig | 1 + configs/qemu-riscv32_spl_defconfig | 1 + configs/qemu-riscv64_defconfig | 1 + configs/qemu-riscv64_smode_defconfig | 1 + configs/qemu-riscv64_spl_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu_arm64_defconfig | 3 ++ configs/qemu_arm_defconfig | 3 ++ configs/qemu_mips64_defconfig | 3 ++ configs/qemu_mips64el_defconfig | 3 ++ configs/qemu_mips_defconfig | 3 ++ configs/qemu_mipsel_defconfig | 3 ++ configs/r2dplus_defconfig | 3 ++ configs/r7780mp_defconfig | 3 ++ configs/r8a7795_salvator-x_defconfig | 2 + configs/r8a7795_ulcb_defconfig | 2 + configs/r8a77965_salvator-x_defconfig | 2 + configs/r8a77965_ulcb_defconfig | 2 + configs/r8a7796_salvator-x_defconfig | 2 + configs/r8a7796_ulcb_defconfig | 2 + configs/r8a77970_eagle_defconfig | 3 ++ configs/r8a77980_condor_defconfig | 3 ++ configs/r8a77990_ebisu_defconfig | 2 + configs/r8a77995_draak_defconfig | 2 + configs/rastaban_defconfig | 1 + configs/riotboard_defconfig | 2 + configs/riotboard_spl_defconfig | 2 + configs/roc-rk3399-pc_defconfig | 1 + configs/rock-pi-4-rk3399_defconfig | 1 + configs/rock2_defconfig | 1 + configs/rock64-rk3328_defconfig | 1 + configs/rock960-rk3399_defconfig | 1 + configs/rock_defconfig | 1 + configs/rockpro64-rk3399_defconfig | 1 + configs/rpi_0_w_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_b_plus_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_4_32b_defconfig | 1 + configs/rpi_4_defconfig | 1 + configs/rpi_defconfig | 1 + configs/s32v234evb_defconfig | 2 + configs/s400_defconfig | 1 + configs/s5p_goni_defconfig | 2 + configs/s5pc210_universal_defconfig | 2 + configs/sagem_f@st1704_ram_defconfig | 1 + configs/sam9x60ek_nandflash_defconfig | 1 + configs/sama5d2_ptc_ek_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/sbc8349_PCI_33_defconfig | 4 ++ configs/sbc8349_PCI_66_defconfig | 4 ++ configs/sbc8349_defconfig | 4 ++ configs/sbc8548_PCI_33_PCIE_defconfig | 3 ++ configs/sbc8548_PCI_33_defconfig | 3 ++ configs/sbc8548_PCI_66_PCIE_defconfig | 3 ++ configs/sbc8548_PCI_66_defconfig | 3 ++ configs/sbc8548_defconfig | 3 ++ configs/sbc8641d_defconfig | 3 ++ configs/sc_sps_1_defconfig | 2 + configs/seaboard_defconfig | 2 + configs/secomx6quq7_defconfig | 2 + configs/sei510_defconfig | 2 + configs/sei610_defconfig | 2 + configs/sfr_nb4-ser_ram_defconfig | 1 + configs/sh7752evb_defconfig | 1 + configs/sh7753evb_defconfig | 1 + configs/sh7757lcr_defconfig | 1 + configs/sh7763rdp_defconfig | 4 ++ configs/sheevaplug_defconfig | 2 + configs/sifive_fu540_defconfig | 1 + configs/silk_defconfig | 4 ++ configs/sksimx6_defconfig | 3 ++ configs/slimbootloader_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/smdk5250_defconfig | 3 ++ configs/smdk5420_defconfig | 3 ++ configs/smdkc100_defconfig | 2 + configs/smdkv310_defconfig | 2 + configs/snow_defconfig | 3 ++ configs/socfpga_arria10_defconfig | 2 + configs/socfpga_arria5_defconfig | 2 + configs/socfpga_cyclone5_defconfig | 2 + configs/socfpga_dbm_soc1_defconfig | 2 + configs/socfpga_de0_nano_soc_defconfig | 2 + configs/socfpga_de10_nano_defconfig | 2 + configs/socfpga_de1_soc_defconfig | 2 + configs/socfpga_is1_defconfig | 3 ++ configs/socfpga_mcvevk_defconfig | 2 + configs/socfpga_sockit_defconfig | 2 + configs/socfpga_socrates_defconfig | 2 + configs/socfpga_sr1500_defconfig | 4 ++ configs/socfpga_stratix10_defconfig | 2 + configs/socfpga_vining_fpga_defconfig | 4 ++ configs/socrates_defconfig | 4 ++ configs/som-db5800-som-6867_defconfig | 3 ++ configs/spear300_defconfig | 3 ++ configs/spear300_nand_defconfig | 2 + configs/spear300_usbtty_defconfig | 3 ++ configs/spear300_usbtty_nand_defconfig | 2 + configs/spear310_defconfig | 3 ++ configs/spear310_nand_defconfig | 2 + configs/spear310_pnor_defconfig | 3 ++ configs/spear310_usbtty_defconfig | 3 ++ configs/spear310_usbtty_nand_defconfig | 2 + configs/spear310_usbtty_pnor_defconfig | 3 ++ configs/spear320_defconfig | 3 ++ configs/spear320_nand_defconfig | 2 + configs/spear320_pnor_defconfig | 3 ++ configs/spear320_usbtty_defconfig | 3 ++ configs/spear320_usbtty_nand_defconfig | 2 + configs/spear320_usbtty_pnor_defconfig | 3 ++ configs/spear600_defconfig | 3 ++ configs/spear600_nand_defconfig | 2 + configs/spear600_usbtty_defconfig | 3 ++ configs/spear600_usbtty_nand_defconfig | 2 + configs/spring_defconfig | 3 ++ configs/stih410-b2260_defconfig | 1 + configs/stm32f429-discovery_defconfig | 3 ++ configs/stm32f429-evaluation_defconfig | 1 + configs/stm32f469-discovery_defconfig | 1 + configs/stm32f746-disco_defconfig | 1 + configs/stm32f769-disco_defconfig | 1 + configs/stm32h743-disco_defconfig | 1 + configs/stm32h743-eval_defconfig | 1 + configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_optee_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + configs/stmark2_defconfig | 3 ++ configs/stout_defconfig | 4 ++ configs/strider_con_defconfig | 4 ++ configs/strider_con_dp_defconfig | 4 ++ configs/strider_cpu_defconfig | 4 ++ configs/strider_cpu_dp_defconfig | 4 ++ configs/stv0991_defconfig | 4 ++ configs/suvd3_defconfig | 4 ++ configs/taurus_defconfig | 1 + configs/tbs2910_defconfig | 2 + configs/tec-ng_defconfig | 2 + configs/tec_defconfig | 2 + ...able-x86-conga-qa3-e3845-pcie-x4_defconfig | 4 ++ .../theadorable-x86-conga-qa3-e3845_defconfig | 4 ++ configs/theadorable-x86-dfi-bt700_defconfig | 4 ++ configs/theadorable_debug_defconfig | 3 ++ configs/thuban_defconfig | 1 + configs/thunderx_88xx_defconfig | 1 + configs/ti816x_evm_defconfig | 3 +- configs/tinker-rk3288_defconfig | 1 + configs/titanium_defconfig | 3 ++ configs/tools-only_defconfig | 1 + configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/tplink_wdr4300_defconfig | 1 + configs/tqma6dl_mba6_mmc_defconfig | 2 + configs/tqma6dl_mba6_spi_defconfig | 4 ++ configs/tqma6q_mba6_mmc_defconfig | 2 + configs/tqma6q_mba6_spi_defconfig | 4 ++ configs/tqma6s_mba6_mmc_defconfig | 2 + configs/tqma6s_mba6_spi_defconfig | 4 ++ configs/tqma6s_wru4_mmc_defconfig | 2 + configs/trats2_defconfig | 2 + configs/trats_defconfig | 2 + configs/tricorder_defconfig | 1 + configs/trimslice_defconfig | 3 ++ configs/ts4600_defconfig | 2 + configs/ts4800_defconfig | 2 + configs/tuge1_defconfig | 4 ++ configs/turris_mox_defconfig | 3 ++ configs/turris_omnia_defconfig | 3 ++ configs/tuxx1_defconfig | 4 ++ configs/u200_defconfig | 1 + configs/uDPU_defconfig | 3 ++ configs/udoo_defconfig | 2 + configs/udoo_neo_defconfig | 2 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_v7_defconfig | 1 + configs/uniphier_v8_defconfig | 1 + configs/usbarmory_defconfig | 2 + configs/variscite_dart6ul_defconfig | 1 + configs/vct_platinum_defconfig | 4 ++ configs/vct_platinum_onenand_defconfig | 2 + configs/vct_platinum_onenand_small_defconfig | 2 + configs/vct_platinum_small_defconfig | 4 ++ configs/vct_platinumavc_defconfig | 4 ++ configs/vct_platinumavc_onenand_defconfig | 2 + .../vct_platinumavc_onenand_small_defconfig | 2 + configs/vct_platinumavc_small_defconfig | 4 ++ configs/vct_premium_defconfig | 4 ++ configs/vct_premium_onenand_defconfig | 2 + configs/vct_premium_onenand_small_defconfig | 2 + configs/vct_premium_small_defconfig | 4 ++ configs/ve8313_defconfig | 4 ++ configs/venice2_defconfig | 2 + configs/ventana_defconfig | 2 + configs/vexpress_aemv8a_juno_defconfig | 3 ++ configs/vexpress_aemv8a_semi_defconfig | 3 ++ configs/vexpress_ca15_tc2_defconfig | 3 ++ configs/vexpress_ca5x2_defconfig | 3 ++ configs/vexpress_ca9x4_defconfig | 3 ++ configs/vf610twr_defconfig | 2 + configs/vf610twr_nand_defconfig | 2 + configs/vining_2000_defconfig | 3 ++ configs/vme8349_defconfig | 4 ++ configs/vyasa-rk3288_defconfig | 1 + configs/wandboard_defconfig | 2 + configs/warp7_bl33_defconfig | 2 + configs/warp7_defconfig | 2 + configs/warp_defconfig | 2 + configs/wb45n_defconfig | 3 +- configs/wb50n_defconfig | 1 + configs/woodburn_defconfig | 4 ++ configs/woodburn_sd_defconfig | 4 ++ configs/work_92105_defconfig | 3 ++ configs/x530_defconfig | 4 ++ configs/x600_defconfig | 4 ++ configs/xfi3_defconfig | 1 + configs/xilinx_zynqmp_r5_defconfig | 1 + configs/xpedite517x_defconfig | 3 ++ configs/xpedite520x_defconfig | 3 ++ configs/xpedite537x_defconfig | 3 ++ configs/xpedite550x_defconfig | 3 ++ configs/xpress_defconfig | 2 + configs/xpress_spl_defconfig | 2 + configs/xtfpga_defconfig | 3 ++ configs/zc5202_defconfig | 2 + configs/zc5601_defconfig | 2 + configs/zmx25_defconfig | 3 ++ configs/zynq_zc770_xm012_defconfig | 1 + env/Kconfig | 32 +++++++++--- env/embedded.c | 2 +- env/mmc.c | 4 -- env/remote.c | 4 -- env/sf.c | 6 +-- include/configs/10m50_devboard.h | 2 - include/configs/3c120_devboard.h | 2 - include/configs/B4860QDS.h | 21 +------- include/configs/BSC9131RDB.h | 8 --- include/configs/BSC9132QDS.h | 14 ----- include/configs/C29XPCIE.h | 14 +---- include/configs/M5208EVBE.h | 3 -- include/configs/M52277EVB.h | 6 --- include/configs/M5235EVB.h | 10 ---- include/configs/M5249EVB.h | 4 -- include/configs/M5253DEMO.h | 7 --- include/configs/M5272C3.h | 7 --- include/configs/M5275EVB.h | 7 --- include/configs/M5282EVB.h | 2 - include/configs/M53017EVB.h | 3 -- include/configs/M5329EVB.h | 2 - include/configs/M5373EVB.h | 2 - include/configs/M54418TWR.h | 14 ----- include/configs/M54451EVB.h | 9 ---- include/configs/M54455EVB.h | 9 ---- include/configs/M5475EVB.h | 2 - include/configs/M5485EVB.h | 2 - include/configs/MCR3000.h | 2 - include/configs/MPC8308RDB.h | 5 -- include/configs/MPC8313ERDB_NAND.h | 6 +-- include/configs/MPC8313ERDB_NOR.h | 8 --- include/configs/MPC8315ERDB.h | 9 ---- include/configs/MPC8323ERDB.h | 9 ---- include/configs/MPC832XEMDS.h | 9 ---- include/configs/MPC8349EMDS.h | 10 ---- include/configs/MPC8349EMDS_SDRAM.h | 10 ---- include/configs/MPC8349ITX.h | 10 ---- include/configs/MPC837XEMDS.h | 9 ---- include/configs/MPC837XERDB.h | 9 ---- include/configs/MPC8536DS.h | 11 ---- include/configs/MPC8540ADS.h | 8 --- include/configs/MPC8541CDS.h | 3 -- include/configs/MPC8544DS.h | 7 --- include/configs/MPC8548CDS.h | 7 --- include/configs/MPC8555CDS.h | 3 -- include/configs/MPC8560ADS.h | 8 --- include/configs/MPC8568MDS.h | 3 -- include/configs/MPC8569MDS.h | 6 --- include/configs/MPC8572DS.h | 12 ----- include/configs/MPC8610HPCD.h | 8 --- include/configs/MPC8641HPCN.h | 8 --- include/configs/MigoR.h | 4 -- include/configs/P1010RDB.h | 18 +------ include/configs/P1022DS.h | 22 ++------ include/configs/P1023RDB.h | 4 -- include/configs/P2041RDB.h | 18 ------- include/configs/SBx81LIFKW.h | 3 -- include/configs/SBx81LIFXCAT.h | 3 -- include/configs/T102xQDS.h | 21 +------- include/configs/T102xRDB.h | 29 +---------- include/configs/T1040QDS.h | 15 ------ include/configs/T104xRDB.h | 15 +----- include/configs/T208xQDS.h | 21 +------- include/configs/T208xRDB.h | 21 +------- include/configs/T4240QDS.h | 17 ------ include/configs/T4240RDB.h | 18 +------ include/configs/TQM834x.h | 5 -- include/configs/UCP1020.h | 40 +------------- include/configs/adp-ae3xx.h | 3 -- include/configs/adp-ag101p.h | 3 -- include/configs/advantech_dms-ba16.h | 4 -- include/configs/am335x_evm.h | 12 ----- include/configs/am335x_shc.h | 4 -- include/configs/am335x_sl50.h | 2 - include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 4 -- include/configs/am57xx_evm.h | 1 - include/configs/am65x_evm.h | 5 -- include/configs/amcore.h | 5 -- include/configs/ap121.h | 4 -- include/configs/ap143.h | 4 -- include/configs/ap152.h | 3 -- include/configs/apalis-imx8.h | 3 -- include/configs/apalis-tk1.h | 2 - include/configs/apalis_imx6.h | 3 -- include/configs/apalis_t30.h | 2 - include/configs/apf27.h | 4 -- include/configs/apx4devkit.h | 7 --- include/configs/aristainetos-common.h | 4 -- include/configs/armadillo-800eva.h | 5 -- include/configs/arndale.h | 2 - include/configs/aspenite.h | 1 - include/configs/astro_mcf5373l.h | 4 -- include/configs/at91-sama5_common.h | 1 - include/configs/at91rm9200ek.h | 2 - include/configs/at91sam9260ek.h | 11 ---- include/configs/at91sam9261ek.h | 9 ---- include/configs/at91sam9263ek.h | 9 ---- include/configs/at91sam9m10g45ek.h | 4 -- include/configs/at91sam9n12ek.h | 9 ---- include/configs/at91sam9rlek.h | 7 --- include/configs/at91sam9x5ek.h | 1 - include/configs/ax25-ae350.h | 2 - include/configs/bav335x.h | 13 ----- include/configs/bayleybay.h | 2 - include/configs/bcm23550_w1d.h | 2 - include/configs/bcm28155_ap.h | 2 - include/configs/bcm7260.h | 1 - include/configs/bcm7445.h | 2 - include/configs/bcm_ep_board.h | 2 - include/configs/bcm_northstar2.h | 2 - include/configs/bcmstb.h | 2 - include/configs/beaver.h | 1 - include/configs/bg0900.h | 1 - include/configs/bk4r1.h | 7 --- include/configs/blanche.h | 8 --- include/configs/boston.h | 9 ---- include/configs/broadcom_bcm963158.h | 1 - include/configs/broadcom_bcm968380gerg.h | 2 - include/configs/broadcom_bcm968580xref.h | 1 - include/configs/brppt1.h | 5 -- include/configs/brppt2.h | 3 -- include/configs/brsmarc1.h | 2 - include/configs/brxre1.h | 3 -- include/configs/bubblegum_96.h | 2 - include/configs/caddy2.h | 9 ---- include/configs/cardhu.h | 1 - include/configs/cei-tk1-som.h | 1 - include/configs/cgtqmx6eval.h | 8 --- include/configs/cherryhill.h | 2 - include/configs/chiliboard.h | 2 - include/configs/chromebook_link.h | 3 -- include/configs/chromebook_samus.h | 3 -- include/configs/ci20.h | 2 - include/configs/cl-som-imx7.h | 3 -- include/configs/clearfog.h | 4 -- include/configs/cm_fx6.h | 3 -- include/configs/cm_t335.h | 1 - include/configs/cm_t35.h | 2 - include/configs/cm_t54.h | 5 -- include/configs/cobra5272.h | 8 --- include/configs/colibri-imx6ull.h | 6 --- include/configs/colibri-imx8x.h | 3 -- include/configs/colibri_imx6.h | 3 -- include/configs/colibri_imx7.h | 7 --- include/configs/colibri_pxa270.h | 4 -- include/configs/colibri_t20.h | 3 -- include/configs/colibri_t30.h | 2 - include/configs/colibri_vf.h | 2 - include/configs/comtrend_ar5315u.h | 1 - include/configs/comtrend_ar5387un.h | 1 - include/configs/comtrend_ct5361.h | 1 - include/configs/comtrend_vr3032u.h | 2 - include/configs/comtrend_wap5813n.h | 1 - include/configs/condor.h | 3 -- include/configs/conga-qeval20-qa3-e3845.h | 3 -- include/configs/controlcenterd.h | 6 --- include/configs/controlcenterdc.h | 3 -- include/configs/corenet_ds.h | 17 ------ include/configs/corvus.h | 1 - include/configs/cougarcanyon2.h | 2 - include/configs/crownbay.h | 2 - include/configs/crs305-1g-4s.h | 3 -- include/configs/cyrus.h | 2 - include/configs/da850evm.h | 15 ------ include/configs/dalmore.h | 1 - include/configs/dart_6ul.h | 4 -- include/configs/db-88f6281-bp.h | 3 -- include/configs/db-88f6720.h | 3 -- include/configs/db-88f6820-amc.h | 3 -- include/configs/db-88f6820-gp.h | 3 -- include/configs/db-mv784mp-gp.h | 3 -- include/configs/db-xc3-24g4xg.h | 3 -- include/configs/devkit3250.h | 2 - include/configs/dfi-bt700.h | 3 -- include/configs/dh_imx6.h | 8 --- include/configs/display5.h | 5 -- include/configs/dns325.h | 7 --- include/configs/dockstar.h | 6 --- include/configs/dra7xx_evm.h | 12 ----- include/configs/draak.h | 1 - include/configs/draco.h | 1 - include/configs/dragonboard410c.h | 1 - include/configs/dragonboard820c.h | 2 - include/configs/dreamplug.h | 6 --- include/configs/ds109.h | 6 --- include/configs/ds414.h | 3 -- include/configs/durian.h | 1 - include/configs/e2220-1170.h | 1 - include/configs/eagle.h | 3 -- include/configs/eb_cpu5282.h | 3 -- include/configs/ebisu.h | 1 - include/configs/edb93xx.h | 13 ----- include/configs/edison.h | 3 -- include/configs/edminiv2.h | 3 -- include/configs/el6x_common.h | 3 -- include/configs/embestmx6boards.h | 4 -- include/configs/etamin.h | 3 -- include/configs/ethernut5.h | 1 - include/configs/evb_ast2500.h | 2 - include/configs/exynos5-common.h | 5 -- include/configs/exynos5-dt-common.h | 1 - include/configs/exynos7420-common.h | 1 - include/configs/flea3.h | 7 --- include/configs/galileo.h | 2 - .../configs/gardena-smart-gateway-mt7688.h | 5 -- include/configs/gazerbeam.h | 5 -- include/configs/ge_bx50v3.h | 3 -- include/configs/goflexhome.h | 6 --- include/configs/gplugd.h | 1 - include/configs/grpeach.h | 3 -- include/configs/guruplug.h | 5 -- include/configs/gw_ventana.h | 12 ----- include/configs/harmony.h | 1 - include/configs/helios4.h | 7 --- include/configs/highbank.h | 2 - include/configs/hikey.h | 1 - include/configs/hikey960.h | 4 -- include/configs/hrcon.h | 9 ---- include/configs/huawei_hg556a.h | 1 - include/configs/ib62x0.h | 5 -- include/configs/iconnect.h | 5 -- include/configs/ids8313.h | 4 -- include/configs/imgtec_xilfpga.h | 1 - include/configs/imx27lite-common.h | 2 - include/configs/imx6-engicam.h | 5 -- include/configs/imx6_logic.h | 3 -- include/configs/imx6dl-mamoj.h | 4 -- include/configs/imx8mm_evk.h | 4 -- include/configs/imx8mn_evk.h | 4 -- include/configs/imx8mq_evk.h | 2 - include/configs/imx8qm_mek.h | 2 - include/configs/imx8qm_rom7720.h | 4 -- include/configs/imx8qxp_mek.h | 2 - include/configs/integratorap.h | 1 - include/configs/integratorcp.h | 6 --- include/configs/j721e_evm.h | 2 - include/configs/jetson-tk1.h | 1 - include/configs/k2e_evm.h | 3 -- include/configs/k2g_evm.h | 2 - include/configs/k2hk_evm.h | 3 -- include/configs/k2l_evm.h | 3 -- include/configs/km/km-mpc83xx.h | 15 ------ include/configs/km/km-powerpc.h | 2 - include/configs/km/km_arm.h | 8 --- include/configs/kmp204x.h | 4 -- include/configs/kmtegr1.h | 3 -- include/configs/kp_imx53.h | 3 -- include/configs/kp_imx6q_tpc.h | 3 -- include/configs/kzm9g.h | 3 -- include/configs/lacie_kw.h | 4 -- include/configs/legoev3.h | 2 - include/configs/libretech-ac.h | 3 -- include/configs/linkit-smart-7688.h | 3 -- include/configs/liteboard.h | 2 - include/configs/ls1012a_common.h | 8 --- include/configs/ls1012afrwy.h | 8 --- include/configs/ls1012ardb.h | 2 - include/configs/ls1021aiot.h | 6 --- include/configs/ls1021aqds.h | 13 ----- include/configs/ls1021atsn.h | 6 --- include/configs/ls1021atwr.h | 10 ---- include/configs/ls1028a_common.h | 4 -- include/configs/ls1028aqds.h | 1 - include/configs/ls1028ardb.h | 1 - include/configs/ls1043aqds.h | 17 ------ include/configs/ls1043ardb.h | 13 ----- include/configs/ls1046afrwy.h | 5 -- include/configs/ls1046aqds.h | 17 ------ include/configs/ls1046ardb.h | 10 ---- include/configs/ls1088a_common.h | 3 -- include/configs/ls1088aqds.h | 14 ----- include/configs/ls1088ardb.h | 13 ----- include/configs/ls2080a_common.h | 8 --- include/configs/ls2080a_emu.h | 1 - include/configs/ls2080a_simu.h | 1 - include/configs/ls2080aqds.h | 16 ------ include/configs/ls2080ardb.h | 17 ------ include/configs/lsxl.h | 4 -- include/configs/lx2160a_common.h | 5 -- include/configs/m53menlo.h | 7 +-- include/configs/malta.h | 4 -- include/configs/maxbcm.h | 3 -- include/configs/mccmon6.h | 5 -- include/configs/medcom-wide.h | 1 - include/configs/meerkat96.h | 2 - include/configs/meesc.h | 5 -- include/configs/meson64.h | 3 -- include/configs/meson64_android.h | 2 - include/configs/microblaze-generic.h | 15 ------ include/configs/microchip_mpfs_icicle.h | 1 - include/configs/minnowmax.h | 3 -- include/configs/mpc8308_p1m.h | 5 -- include/configs/mt7623.h | 2 - include/configs/mt7629.h | 1 - include/configs/mvebu_armada-37xx.h | 3 -- include/configs/mvebu_armada-8k.h | 4 -- include/configs/mx23_olinuxino.h | 2 - include/configs/mx23evk.h | 2 - include/configs/mx25pdk.h | 2 - include/configs/mx28evk.h | 15 ------ include/configs/mx31pdk.h | 3 -- include/configs/mx35pdk.h | 11 ---- include/configs/mx51evk.h | 2 - include/configs/mx53ard.h | 2 - include/configs/mx53cx9020.h | 2 - include/configs/mx53evk.h | 2 - include/configs/mx53loco.h | 2 - include/configs/mx53ppd.h | 2 - include/configs/mx53smd.h | 2 - include/configs/mx6cuboxi.h | 2 - include/configs/mx6memcal.h | 2 - include/configs/mx6qarm2.h | 2 - include/configs/mx6sabre_common.h | 5 -- include/configs/mx6slevk.h | 8 --- include/configs/mx6sllevk.h | 3 -- include/configs/mx6sxsabreauto.h | 3 -- include/configs/mx6sxsabresd.h | 3 -- include/configs/mx6ul_14x14_evk.h | 2 - include/configs/mx6ullevk.h | 3 -- include/configs/mx7dsabresd.h | 2 - include/configs/mx7ulp_evk.h | 3 -- include/configs/nas220.h | 6 --- include/configs/netgear_cg3100d.h | 1 - include/configs/netgear_dgnd3700v2.h | 1 - include/configs/nitrogen6x.h | 5 -- include/configs/novena.h | 4 -- include/configs/nsa310s.h | 5 -- include/configs/nyan-big.h | 1 - include/configs/odroid.h | 2 - include/configs/odroid_xu3.h | 5 -- include/configs/omap3_beagle.h | 1 - include/configs/omap3_cairo.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omap3_overo.h | 2 - include/configs/omap3_pandora.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/omap4_sdp4430.h | 1 - include/configs/omap5_uevm.h | 1 - include/configs/omapl138_lcdk.h | 9 ---- include/configs/openrd.h | 5 -- include/configs/opos6uldev.h | 3 -- include/configs/origen.h | 2 - include/configs/ot1200.h | 3 -- include/configs/p1_p2_rdb_pc.h | 22 ++------ include/configs/p1_twr.h | 8 --- include/configs/p2371-0000.h | 1 - include/configs/p2371-2180.h | 1 - include/configs/p2571.h | 1 - include/configs/p2771-0000.h | 1 - include/configs/paz00.h | 1 - include/configs/pcl063.h | 3 -- include/configs/pcl063_ull.h | 4 -- include/configs/pcm052.h | 10 ---- include/configs/pcm058.h | 10 ---- include/configs/pdu001.h | 1 - include/configs/pengwyn.h | 2 - include/configs/pfla02.h | 10 ---- include/configs/pic32mzdask.h | 1 - include/configs/pico-imx6.h | 2 - include/configs/pico-imx6ul.h | 2 - include/configs/pico-imx7d.h | 2 - include/configs/picosam9g45.h | 1 - include/configs/platinum.h | 6 --- include/configs/plutux.h | 1 - include/configs/pm9261.h | 9 ---- include/configs/pm9263.h | 9 ---- include/configs/pm9g45.h | 4 -- include/configs/pogo_e02.h | 6 --- include/configs/poplar.h | 2 - include/configs/puma_rk3399.h | 2 - include/configs/pumpkin.h | 1 - include/configs/qemu-arm.h | 2 - include/configs/qemu-mips.h | 2 - include/configs/qemu-mips64.h | 2 - include/configs/qemu-ppce500.h | 1 - include/configs/qemu-riscv.h | 1 - include/configs/qemu-x86.h | 3 -- include/configs/r2dplus.h | 4 -- include/configs/r7780mp.h | 3 -- include/configs/rastaban.h | 1 - include/configs/rcar-gen2-common.h | 4 -- include/configs/rcar-gen3-common.h | 2 - include/configs/rpi.h | 1 - include/configs/s32v234evb.h | 2 - include/configs/s5p_goni.h | 2 - include/configs/s5pc210_universal.h | 2 - include/configs/sagem_f@st1704.h | 1 - include/configs/salvator-x.h | 1 - include/configs/sam9x60ek.h | 1 - include/configs/sandbox.h | 2 - include/configs/sansa_fuze_plus.h | 1 - include/configs/sbc8349.h | 9 ---- include/configs/sbc8548.h | 14 ----- include/configs/sbc8641d.h | 3 -- include/configs/sc_sps_1.h | 2 - include/configs/seaboard.h | 1 - include/configs/secomx6quq7.h | 2 - include/configs/sfr_nb4_ser.h | 1 - include/configs/sh7752evb.h | 4 -- include/configs/sh7753evb.h | 4 -- include/configs/sh7757lcr.h | 4 -- include/configs/sh7763rdp.h | 5 -- include/configs/sheevaplug.h | 6 --- include/configs/siemens-am33x-common.h | 4 -- include/configs/sifive-fu540.h | 1 - include/configs/sksimx6.h | 4 -- include/configs/smartweb.h | 1 - include/configs/smdkc100.h | 3 -- include/configs/smdkv310.h | 2 - include/configs/socfpga_common.h | 10 +--- include/configs/socfpga_sr1500.h | 4 -- include/configs/socfpga_stratix10_socdk.h | 9 ---- include/configs/socfpga_vining_fpga.h | 5 -- include/configs/socrates.h | 5 -- include/configs/som-db5800-som-6867.h | 3 -- include/configs/spear-common.h | 7 --- include/configs/stih410-b2260.h | 3 -- include/configs/stm32f429-discovery.h | 4 -- include/configs/stm32f429-evaluation.h | 4 -- include/configs/stm32f469-discovery.h | 4 -- include/configs/stm32f746-disco.h | 2 - include/configs/stm32h743-disco.h | 2 - include/configs/stm32h743-eval.h | 2 - include/configs/stmark2.h | 3 -- include/configs/strider.h | 9 ---- include/configs/stv0991.h | 5 -- include/configs/t4qds.h | 4 +- include/configs/tam3517-common.h | 4 -- include/configs/tao3530.h | 1 - include/configs/taurus.h | 1 - include/configs/tbs2910.h | 2 - include/configs/tec-ng.h | 1 - include/configs/tec.h | 1 - include/configs/tegra-common.h | 1 - include/configs/theadorable-x86-common.h | 6 --- include/configs/theadorable.h | 3 -- include/configs/thuban.h | 1 - include/configs/thunderx_88xx.h | 1 - include/configs/ti816x_evm.h | 3 -- include/configs/titanium.h | 6 --- include/configs/topic_miami.h | 4 -- include/configs/tplink_wdr4300.h | 2 - include/configs/tqma6.h | 7 --- include/configs/trats.h | 2 - include/configs/trats2.h | 2 - include/configs/tricorder.h | 1 - include/configs/trimslice.h | 2 - include/configs/ts4600.h | 2 - include/configs/ts4800.h | 2 - include/configs/turris_mox.h | 3 -- include/configs/turris_omnia.h | 3 -- include/configs/udoo.h | 2 - include/configs/udoo_neo.h | 2 - include/configs/ulcb.h | 1 - include/configs/uniphier.h | 4 -- include/configs/usbarmory.h | 2 - include/configs/vcoreiii.h | 9 ---- include/configs/vct.h | 7 --- include/configs/ve8313.h | 6 --- include/configs/venice2.h | 1 - include/configs/ventana.h | 1 - include/configs/vexpress_aemv8a.h | 5 -- include/configs/vexpress_common.h | 6 --- include/configs/vf610twr.h | 6 --- include/configs/vinco.h | 5 -- include/configs/vining_2000.h | 4 -- include/configs/vme8349.h | 9 ---- include/configs/wandboard.h | 2 - include/configs/warp.h | 2 - include/configs/warp7.h | 2 - include/configs/wb45n.h | 3 -- include/configs/wb50n.h | 1 - include/configs/woodburn_common.h | 7 --- include/configs/work_92105.h | 5 -- include/configs/x530.h | 4 -- include/configs/x600.h | 6 --- include/configs/x86-chromebook.h | 5 -- include/configs/x86-common.h | 1 - include/configs/xfi3.h | 1 - include/configs/xilinx_zynqmp_r5.h | 2 - include/configs/xpedite517x.h | 3 -- include/configs/xpedite520x.h | 3 -- include/configs/xpedite537x.h | 3 -- include/configs/xpedite550x.h | 3 -- include/configs/xpress.h | 2 - include/configs/xtfpga.h | 2 - include/configs/zmx25.h | 4 -- include/env_internal.h | 52 ------------------- scripts/config_whitelist.txt | 3 -- 1605 files changed, 2597 insertions(+), 2331 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index f0df88c565ab..adfa51b6be0d 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -844,7 +844,7 @@ int board_late_init(void) * check if gd->env_addr is default_environment; then setenv bootcmd * and mcinitcmd. */ -#if !defined(CONFIG_ENV_ADDR) || defined(ENV_IS_EMBEDDED) +#ifdef CONFIG_SYS_RELOC_GD_ENV_ADDR if (gd->env_addr == (ulong)&default_environment[0]) { #else if (gd->env_addr + gd->reloc_off == (ulong)&default_environment[0]) { diff --git a/board/freescale/b4860qds/spl.c b/board/freescale/b4860qds/spl.c index 6dfc0c73eca9..06ea8775044a 100644 --- a/board/freescale/b4860qds/spl.c +++ b/board/freescale/b4860qds/spl.c @@ -100,8 +100,8 @@ void board_init_r(gd_t *gd, ulong dest_addr) #else /* relocate environment function pointers etc. */ nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, - (uchar *)CONFIG_ENV_ADDR); - gd->env_addr = (ulong)(CONFIG_ENV_ADDR); + (uchar *)SPL_ENV_ADDR); + gd->env_addr = (ulong)(SPL_ENV_ADDR); gd->env_valid = ENV_VALID; #endif
diff --git a/board/freescale/c29xpcie/spl.c b/board/freescale/c29xpcie/spl.c index 29040962cf1b..9a2385b978c5 100644 --- a/board/freescale/c29xpcie/spl.c +++ b/board/freescale/c29xpcie/spl.c @@ -61,8 +61,8 @@ void board_init_r(gd_t *gd, ulong dest_addr)
i2c_init_all(); diff --git a/board/freescale/p1010rdb/spl.c b/board/freescale/p1010rdb/spl.c index 8f050b3947d1..cb489140c030 100644 --- a/board/freescale/p1010rdb/spl.c +++ b/board/freescale/p1010rdb/spl.c @@ -86,8 +86,8 @@ void board_init_r(gd_t *gd, ulong dest_addr) /* relocate environment function pointers etc. */ #ifdef CONFIG_SPL_NAND_BOOT nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, - (uchar *)CONFIG_ENV_ADDR); - gd->env_addr = (ulong)(CONFIG_ENV_ADDR); + (uchar *)SPL_ENV_ADDR); + gd->env_addr = (ulong)(SPL_ENV_ADDR); gd->env_valid = ENV_VALID; #else env_relocate(); diff --git a/board/freescale/p1022ds/spl.c b/board/freescale/p1022ds/spl.c index 06273f1d20e6..8d2c1388ec3f 100644 --- a/board/freescale/p1022ds/spl.c +++ b/board/freescale/p1022ds/spl.c @@ -98,9 +98,9 @@ void board_init_r(gd_t *gd, ulong dest_addr) /* relocate environment function pointers etc. */ #ifdef CONFIG_SPL_NAND_BOOT nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, - (uchar *)CONFIG_ENV_ADDR); + (uchar *)SPL_ENV_ADDR);
- gd->env_addr = (ulong)(CONFIG_ENV_ADDR); + gd->env_addr = (ulong)(SPL_ENV_ADDR); gd->env_valid = ENV_VALID; #else env_relocate(); diff --git a/board/freescale/p1_p2_rdb_pc/spl.c b/board/freescale/p1_p2_rdb_pc/spl.c index dbf9f739b28f..908f4bc96f50 100644 --- a/board/freescale/p1_p2_rdb_pc/spl.c +++ b/board/freescale/p1_p2_rdb_pc/spl.c @@ -91,8 +91,8 @@ void board_init_r(gd_t *gd, ulong dest_addr) /* relocate environment function pointers etc. */ #ifdef CONFIG_SPL_NAND_BOOT nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, - (uchar *)CONFIG_ENV_ADDR); - gd->env_addr = (ulong)(CONFIG_ENV_ADDR); + (uchar *)SPL_ENV_ADDR); + gd->env_addr = (ulong)(SPL_ENV_ADDR); gd->env_valid = ENV_VALID; #else env_relocate(); diff --git a/board/freescale/t102xqds/spl.c b/board/freescale/t102xqds/spl.c index 3008f0919f17..7a499a559fbd 100644 --- a/board/freescale/t102xqds/spl.c +++ b/board/freescale/t102xqds/spl.c @@ -125,19 +125,19 @@ void board_init_r(gd_t *gd, ulong dest_addr)
#ifdef CONFIG_SPL_NAND_BOOT nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, - (uchar *)CONFIG_ENV_ADDR); + (uchar *)SPL_ENV_ADDR); #endif #ifdef CONFIG_SPL_MMC_BOOT mmc_initialize(bd); mmc_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, - (uchar *)CONFIG_ENV_ADDR); + (uchar *)SPL_ENV_ADDR); #endif #ifdef CONFIG_SPL_SPI_BOOT fsl_spi_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, - (uchar *)CONFIG_ENV_ADDR); + (uchar *)SPL_ENV_ADDR); #endif
i2c_init_all(); diff --git a/board/freescale/t102xrdb/spl.c b/board/freescale/t102xrdb/spl.c index 029e3d212ca6..c579be1cb253 100644 --- a/board/freescale/t102xrdb/spl.c +++ b/board/freescale/t102xrdb/spl.c @@ -112,19 +112,19 @@ void board_init_r(gd_t *gd, ulong dest_addr)
i2c_init_all(); diff --git a/board/freescale/t104xrdb/spl.c b/board/freescale/t104xrdb/spl.c index 7df371df4df5..2d1342fb99d7 100644 --- a/board/freescale/t104xrdb/spl.c +++ b/board/freescale/t104xrdb/spl.c @@ -110,17 +110,17 @@ void board_init_r(gd_t *gd, ulong dest_addr) defined(CONFIG_ENV_IS_IN_SPI_FLASH) #ifdef CONFIG_SPL_NAND_BOOT nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, - (uchar *)CONFIG_ENV_ADDR); + (uchar *)SPL_ENV_ADDR); #endif #ifdef CONFIG_SPL_MMC_BOOT mmc_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, - (uchar *)CONFIG_ENV_ADDR); + (uchar *)SPL_ENV_ADDR); #endif #ifdef CONFIG_SPL_SPI_BOOT fsl_spi_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, - (uchar *)CONFIG_ENV_ADDR); + (uchar *)SPL_ENV_ADDR); #endif - gd->env_addr = (ulong)(CONFIG_ENV_ADDR); + gd->env_addr = (ulong)(SPL_ENV_ADDR); gd->env_valid = ENV_VALID; #endif
diff --git a/board/freescale/t208xqds/spl.c b/board/freescale/t208xqds/spl.c index 9695dfc2e2ed..f0499ad7e542 100644 --- a/board/freescale/t208xqds/spl.c +++ b/board/freescale/t208xqds/spl.c @@ -111,19 +111,19 @@ void board_init_r(gd_t *gd, ulong dest_addr)
i2c_init_all(); diff --git a/board/freescale/t208xrdb/spl.c b/board/freescale/t208xrdb/spl.c index ca7d6a28e052..d7ca0dd6db29 100644 --- a/board/freescale/t208xrdb/spl.c +++ b/board/freescale/t208xrdb/spl.c @@ -81,19 +81,19 @@ void board_init_r(gd_t *gd, ulong dest_addr)
i2c_init_all(); diff --git a/board/freescale/t4qds/spl.c b/board/freescale/t4qds/spl.c index 7666fe7556dc..df81205e88da 100644 --- a/board/freescale/t4qds/spl.c +++ b/board/freescale/t4qds/spl.c @@ -120,15 +120,15 @@ void board_init_r(gd_t *gd, ulong dest_addr)
i2c_init_all(); diff --git a/board/freescale/t4rdb/spl.c b/board/freescale/t4rdb/spl.c index a19558bd6be1..ec3978a70aa7 100644 --- a/board/freescale/t4rdb/spl.c +++ b/board/freescale/t4rdb/spl.c @@ -84,9 +84,9 @@ void board_init_r(gd_t *gd, ulong dest_addr)
i2c_init_all(); diff --git a/configs/10m50_defconfig b/configs/10m50_defconfig index 119cbcd354a0..138bb5235406 100644 --- a/configs/10m50_defconfig +++ b/configs/10m50_defconfig @@ -1,6 +1,8 @@ CONFIG_NIOS2=y CONFIG_SYS_CONFIG_NAME="10m50_devboard" +CONFIG_ENV_SIZE=0x10000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_FIT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y @@ -18,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DEFAULT_DEVICE_TREE="10m50_devboard" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xF4080000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_GPIO=y CONFIG_ALTERA_PIO=y diff --git a/configs/3c120_defconfig b/configs/3c120_defconfig index 42a032f1e76f..08758ca17e29 100644 --- a/configs/3c120_defconfig +++ b/configs/3c120_defconfig @@ -1,6 +1,8 @@ CONFIG_NIOS2=y CONFIG_SYS_CONFIG_NAME="3c120_devboard" +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_FIT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y @@ -18,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DEFAULT_DEVICE_TREE="3c120_devboard" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xE2880000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_GPIO=y CONFIG_ALTERA_PIO=y diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index 863389e884a9..13475ba4501a 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x140000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_B4420QDS=y diff --git a/configs/B4420QDS_SPIFLASH_defconfig b/configs/B4420QDS_SPIFLASH_defconfig index fbb359a7cc18..37723e8788e1 100644 --- a/configs/B4420QDS_SPIFLASH_defconfig +++ b/configs/B4420QDS_SPIFLASH_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_B4420QDS=y CONFIG_FIT=y diff --git a/configs/B4420QDS_defconfig b/configs/B4420QDS_defconfig index c94444f42cbc..aa1b1f400ef5 100644 --- a/configs/B4420QDS_defconfig +++ b/configs/B4420QDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_B4420QDS=y CONFIG_FIT=y @@ -22,6 +24,7 @@ CONFIG_CMD_DATE=y CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index b1922c1d32c8..0c7aa18dca78 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x140000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_B4860QDS=y diff --git a/configs/B4860QDS_SECURE_BOOT_defconfig b/configs/B4860QDS_SECURE_BOOT_defconfig index 9ddcc0edbd02..739516ed723d 100644 --- a/configs/B4860QDS_SECURE_BOOT_defconfig +++ b/configs/B4860QDS_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_B4860QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/B4860QDS_SPIFLASH_defconfig b/configs/B4860QDS_SPIFLASH_defconfig index cedf4c940c1f..1aa0c65fef20 100644 --- a/configs/B4860QDS_SPIFLASH_defconfig +++ b/configs/B4860QDS_SPIFLASH_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_B4860QDS=y CONFIG_FIT=y diff --git a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig index 412a7d49f166..2b8cc49ec239 100644 --- a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_B4860QDS=y CONFIG_FIT=y @@ -23,6 +24,7 @@ CONFIG_CMD_DATE=y CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_REMOTE=y +CONFIG_ENV_ADDR=0xFFE20000 CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/B4860QDS_defconfig b/configs/B4860QDS_defconfig index 2df7196ef360..b4993d4f35c0 100644 --- a/configs/B4860QDS_defconfig +++ b/configs/B4860QDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_B4860QDS=y CONFIG_FIT=y @@ -22,6 +24,7 @@ CONFIG_CMD_DATE=y CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index 3fd5b17a7e76..8d45903dd16e 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x00201000 CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_BSC9131RDB=y diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index abaa57ded19d..99cada8cc76d 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x00201000 CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_BSC9131RDB=y diff --git a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig index 7e27adcbec69..603d752bcd5e 100644 --- a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9131RDB=y CONFIG_FIT=y diff --git a/configs/BSC9131RDB_SPIFLASH_defconfig b/configs/BSC9131RDB_SPIFLASH_defconfig index c6a4b3232c96..9f4541ebfa0d 100644 --- a/configs/BSC9131RDB_SPIFLASH_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9131RDB=y CONFIG_FIT=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig index febb1bfb499d..f89ce3a54f51 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index dabf5f311cf3..db62a7ed07a8 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x00201000 CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig index d2f9ae9365ef..532024ce9137 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index 2959c7e9adc5..e23c71b2c054 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x00201000 CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig index cade39d7e2b4..9296218fa710 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x8FF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig index a16838c49a4a..8fc2bdd30b02 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x8FF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y CONFIG_FIT=y @@ -26,6 +28,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x8FF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig index 1ea17b58c322..362cbec73bb9 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x8FF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig index e56be3fda02b..1419dcadc362 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x8FF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y CONFIG_FIT=y @@ -26,6 +28,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x8FF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig index 0bc855a80967..1b72d490e98e 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig index afac604b402e..66375cab942e 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y CONFIG_FIT=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig index b5faee59df37..bdc56fca9dc8 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig index 50ebb14f704d..f26a49a4a443 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y CONFIG_FIT=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig index 07c07c75d3a1..28068f755170 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig index c40f726dbfd7..83d79100dc66 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y CONFIG_FIT=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig index bfe80147ae71..c78017c9a136 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig index 08e4d681ce46..38bf15a7026f 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_BSC9132QDS=y CONFIG_FIT=y diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index d2c7836e179b..a64ee9fe6300 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x100000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_C29XPCIE=y diff --git a/configs/C29XPCIE_NOR_SECBOOT_defconfig b/configs/C29XPCIE_NOR_SECBOOT_defconfig index 50ba06f6a6d4..604d8dd0938e 100644 --- a/configs/C29XPCIE_NOR_SECBOOT_defconfig +++ b/configs/C29XPCIE_NOR_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_C29XPCIE=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig index fbaa2cf7c65d..01ad74b4b73d 100644 --- a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig +++ b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_C29XPCIE=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/C29XPCIE_SPIFLASH_defconfig b/configs/C29XPCIE_SPIFLASH_defconfig index 097dc0188c86..d7c4096a330f 100644 --- a/configs/C29XPCIE_SPIFLASH_defconfig +++ b/configs/C29XPCIE_SPIFLASH_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_C29XPCIE=y CONFIG_FIT=y diff --git a/configs/C29XPCIE_defconfig b/configs/C29XPCIE_defconfig index ac525e8e9282..3c0ae78e975d 100644 --- a/configs/C29XPCIE_defconfig +++ b/configs/C29XPCIE_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_C29XPCIE=y CONFIG_FIT=y @@ -19,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/Cyrus_P5020_defconfig b/configs/Cyrus_P5020_defconfig index 016ec03cfcc0..eb2b0f86f3a2 100644 --- a/configs/Cyrus_P5020_defconfig +++ b/configs/Cyrus_P5020_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xCF400 CONFIG_MPC85xx=y CONFIG_TARGET_CYRUS_P5020=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set diff --git a/configs/Cyrus_P5040_defconfig b/configs/Cyrus_P5040_defconfig index d1c359b60483..10ca467faa6f 100644 --- a/configs/Cyrus_P5040_defconfig +++ b/configs/Cyrus_P5040_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xCF400 CONFIG_MPC85xx=y CONFIG_TARGET_CYRUS_P5040=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set diff --git a/configs/M5208EVBE_defconfig b/configs/M5208EVBE_defconfig index 8f5990a63c17..0b015ff83f93 100644 --- a/configs/M5208EVBE_defconfig +++ b/configs/M5208EVBE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x0 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TARGET_M5208EVBE=y CONFIG_BOOTDELAY=1 # CONFIG_DISPLAY_BOARDINFO is not set @@ -13,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5208EVBE" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x2000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/M52277EVB_defconfig b/configs/M52277EVB_defconfig index 55f6fb9c9086..d2e40245785c 100644 --- a/configs/M52277EVB_defconfig +++ b/configs/M52277EVB_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x0 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_SECT_SIZE=0x8000 CONFIG_TARGET_M52277EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SPANSION_BOOT" CONFIG_BOOTDELAY=3 @@ -17,6 +19,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_JFFS2=y CONFIG_DEFAULT_DEVICE_TREE="M52277EVB" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x40000 # CONFIG_NET is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/M52277EVB_stmicro_defconfig b/configs/M52277EVB_stmicro_defconfig index c689eaacacb3..1a89934c25ff 100644 --- a/configs/M52277EVB_stmicro_defconfig +++ b/configs/M52277EVB_stmicro_defconfig @@ -1,5 +1,8 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x43E00000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x30000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M52277EVB=y CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_STMICRO_BOOT" CONFIG_BOOTDELAY=3 diff --git a/configs/M5235EVB_Flash32_defconfig b/configs/M5235EVB_Flash32_defconfig index 80ceb978aa21..3c79ff0542ed 100644 --- a/configs/M5235EVB_Flash32_defconfig +++ b/configs/M5235EVB_Flash32_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFFC00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TARGET_M5235EVB=y CONFIG_SYS_EXTRA_OPTIONS="NORFLASH_PS32BIT" CONFIG_BOOTDELAY=1 @@ -18,6 +20,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5235EVB_Flash32" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFE04000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/M5235EVB_defconfig b/configs/M5235EVB_defconfig index 2fa977555ce9..347782cecf84 100644 --- a/configs/M5235EVB_defconfig +++ b/configs/M5235EVB_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFFE00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TARGET_M5235EVB=y CONFIG_BOOTDELAY=1 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +20,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5235EVB" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFE04000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/M5249EVB_defconfig b/configs/M5249EVB_defconfig index e074169aa4d8..39c4976e0df0 100644 --- a/configs/M5249EVB_defconfig +++ b/configs/M5249EVB_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFFE00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TARGET_M5249EVB=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -11,6 +13,7 @@ CONFIG_MX_CYCLIC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5249EVB" +CONFIG_ENV_ADDR=0xFFE04000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/M5253DEMO_defconfig b/configs/M5253DEMO_defconfig index 77e2d2b226bf..84a24844fe21 100644 --- a/configs/M5253DEMO_defconfig +++ b/configs/M5253DEMO_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_TARGET_M5253DEMO=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set @@ -14,5 +16,6 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_MAC_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="M5253DEMO" +CONFIG_ENV_ADDR=0xFF804000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/M5272C3_defconfig b/configs/M5272C3_defconfig index eaf43b4db2d8..afd5c44b1092 100644 --- a/configs/M5272C3_defconfig +++ b/configs/M5272C3_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFFE00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TARGET_M5272C3=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set @@ -14,6 +16,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5272C3" +CONFIG_ENV_ADDR=0xFFE04000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/M5275EVB_defconfig b/configs/M5275EVB_defconfig index 246b1b01d0f9..d4f6d427a18c 100644 --- a/configs/M5275EVB_defconfig +++ b/configs/M5275EVB_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFFE00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TARGET_M5275EVB=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set @@ -16,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5275EVB" +CONFIG_ENV_ADDR=0xFFE04000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/M5282EVB_defconfig b/configs/M5282EVB_defconfig index d9694896eea4..bbf394dcdef3 100644 --- a/configs/M5282EVB_defconfig +++ b/configs/M5282EVB_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFFE00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TARGET_M5282EVB=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set @@ -14,6 +16,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5282EVB" +CONFIG_ENV_ADDR=0xFFE04000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/M53017EVB_defconfig b/configs/M53017EVB_defconfig index 92dfd0256dd2..bf467bb8e92d 100644 --- a/configs/M53017EVB_defconfig +++ b/configs/M53017EVB_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x0 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_SECT_SIZE=0x8000 CONFIG_TARGET_M53017EVB=y CONFIG_BOOTDELAY=1 CONFIG_USE_BOOTARGS=y @@ -16,6 +18,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="M53017EVB" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x40000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5329AFEE_defconfig b/configs/M5329AFEE_defconfig index 35403d1eeeca..9191dc0515a3 100644 --- a/configs/M5329AFEE_defconfig +++ b/configs/M5329AFEE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x0 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TARGET_M5329EVB=y CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=0" CONFIG_BOOTDELAY=1 @@ -16,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="M5329AFEE" +CONFIG_ENV_ADDR=0x4000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/M5329BFEE_defconfig b/configs/M5329BFEE_defconfig index 2d98dbe732c8..e9d460f69835 100644 --- a/configs/M5329BFEE_defconfig +++ b/configs/M5329BFEE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x0 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TARGET_M5329EVB=y CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=16" CONFIG_BOOTDELAY=1 @@ -16,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="M5329BFEE" +CONFIG_ENV_ADDR=0x4000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/M5373EVB_defconfig b/configs/M5373EVB_defconfig index 00c33b151817..8ba76718060c 100644 --- a/configs/M5373EVB_defconfig +++ b/configs/M5373EVB_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x0 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TARGET_M5373EVB=y CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=16" CONFIG_BOOTDELAY=1 @@ -16,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="M5373EVB" +CONFIG_ENV_ADDR=0x4000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/M54418TWR_defconfig b/configs/M54418TWR_defconfig index 49abfed5c6ed..783c6f073e02 100644 --- a/configs/M54418TWR_defconfig +++ b/configs/M54418TWR_defconfig @@ -1,5 +1,8 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x47E00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x40000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M54418TWR=y CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_SERIAL_BOOT,SYS_INPUT_CLKSRC=50000000" CONFIG_USE_BOOTARGS=y diff --git a/configs/M54418TWR_nand_mii_defconfig b/configs/M54418TWR_nand_mii_defconfig index dd650c3eb943..1688d4063a10 100644 --- a/configs/M54418TWR_nand_mii_defconfig +++ b/configs/M54418TWR_nand_mii_defconfig @@ -1,5 +1,6 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x47E00000 +CONFIG_ENV_SIZE=0x20000 CONFIG_TARGET_M54418TWR=y CONFIG_SYS_EXTRA_OPTIONS="SYS_NAND_BOOT,SYS_INPUT_CLKSRC=25000000" CONFIG_USE_BOOTARGS=y diff --git a/configs/M54418TWR_nand_rmii_defconfig b/configs/M54418TWR_nand_rmii_defconfig index 32a2b6068469..87e38261bada 100644 --- a/configs/M54418TWR_nand_rmii_defconfig +++ b/configs/M54418TWR_nand_rmii_defconfig @@ -1,5 +1,6 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x47E00000 +CONFIG_ENV_SIZE=0x20000 CONFIG_TARGET_M54418TWR=y CONFIG_SYS_EXTRA_OPTIONS="SYS_NAND_BOOT,SYS_INPUT_CLKSRC=50000000" CONFIG_USE_BOOTARGS=y diff --git a/configs/M54418TWR_nand_rmii_lowfreq_defconfig b/configs/M54418TWR_nand_rmii_lowfreq_defconfig index c20c0703807f..d196e4c18709 100644 --- a/configs/M54418TWR_nand_rmii_lowfreq_defconfig +++ b/configs/M54418TWR_nand_rmii_lowfreq_defconfig @@ -1,5 +1,6 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x47E00000 +CONFIG_ENV_SIZE=0x20000 CONFIG_TARGET_M54418TWR=y CONFIG_SYS_EXTRA_OPTIONS="SYS_NAND_BOOT,LOW_MCFCLK,SYS_INPUT_CLKSRC=50000000" CONFIG_USE_BOOTARGS=y diff --git a/configs/M54418TWR_serial_mii_defconfig b/configs/M54418TWR_serial_mii_defconfig index d6eda311d0cb..7d88778b8d46 100644 --- a/configs/M54418TWR_serial_mii_defconfig +++ b/configs/M54418TWR_serial_mii_defconfig @@ -1,5 +1,8 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x47E00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x40000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M54418TWR=y CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_SERIAL_BOOT,SYS_INPUT_CLKSRC=25000000" CONFIG_USE_BOOTARGS=y diff --git a/configs/M54418TWR_serial_rmii_defconfig b/configs/M54418TWR_serial_rmii_defconfig index cb2b36f4b3bd..079c9175bd79 100644 --- a/configs/M54418TWR_serial_rmii_defconfig +++ b/configs/M54418TWR_serial_rmii_defconfig @@ -1,5 +1,8 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x47E00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x40000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M54418TWR=y CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_SERIAL_BOOT,SYS_INPUT_CLKSRC=50000000" CONFIG_USE_BOOTARGS=y diff --git a/configs/M54451EVB_defconfig b/configs/M54451EVB_defconfig index f0bd93f2d9db..26471de8fd6c 100644 --- a/configs/M54451EVB_defconfig +++ b/configs/M54451EVB_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x0 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_M54451EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_INPUT_CLKSRC=24000000" CONFIG_BOOTDELAY=1 @@ -22,6 +24,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="M54451EVB" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x40000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54451EVB_stmicro_defconfig b/configs/M54451EVB_stmicro_defconfig index d5a9a9f5ab0e..16cc02ad87a5 100644 --- a/configs/M54451EVB_stmicro_defconfig +++ b/configs/M54451EVB_stmicro_defconfig @@ -1,5 +1,8 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x47E00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x20000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M54451EVB=y CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_STMICRO_BOOT,SYS_INPUT_CLKSRC=24000000" CONFIG_BOOTDELAY=1 diff --git a/configs/M54455EVB_a66_defconfig b/configs/M54455EVB_a66_defconfig index ca403083f795..997164ca1518 100644 --- a/configs/M54455EVB_a66_defconfig +++ b/configs/M54455EVB_a66_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M54455EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_ATMEL_BOOT,SYS_INPUT_CLKSRC=66666666" CONFIG_BOOTDELAY=1 @@ -26,6 +28,7 @@ CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="M54455EVB_a66" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x4040000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54455EVB_defconfig b/configs/M54455EVB_defconfig index 3ca2d7379758..d782c4bcd0c8 100644 --- a/configs/M54455EVB_defconfig +++ b/configs/M54455EVB_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M54455EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_ATMEL_BOOT,SYS_INPUT_CLKSRC=33333333" CONFIG_BOOTDELAY=1 @@ -27,6 +29,7 @@ CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="M54455EVB" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x4040000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54455EVB_i66_defconfig b/configs/M54455EVB_i66_defconfig index 20abcd80ab80..5311b19d9792 100644 --- a/configs/M54455EVB_i66_defconfig +++ b/configs/M54455EVB_i66_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x0 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_M54455EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_INTEL_BOOT,SYS_INPUT_CLKSRC=66666666" CONFIG_BOOTDELAY=1 @@ -26,6 +28,7 @@ CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="M54455EVB_i66" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x40000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54455EVB_intel_defconfig b/configs/M54455EVB_intel_defconfig index a17e4fab2524..4039093fcd03 100644 --- a/configs/M54455EVB_intel_defconfig +++ b/configs/M54455EVB_intel_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x0 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_M54455EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_INTEL_BOOT,SYS_INPUT_CLKSRC=33333333" CONFIG_BOOTDELAY=1 @@ -26,6 +28,7 @@ CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="M54455EVB_intel" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x40000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54455EVB_stm33_defconfig b/configs/M54455EVB_stm33_defconfig index 440218531601..09a273ecc06a 100644 --- a/configs/M54455EVB_stm33_defconfig +++ b/configs/M54455EVB_stm33_defconfig @@ -1,5 +1,8 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x4FE00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x30000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M54455EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_STMICRO_BOOT,CF_SBF,SYS_INPUT_CLKSRC=33333333" CONFIG_BOOTDELAY=1 diff --git a/configs/M5475AFE_defconfig b/configs/M5475AFE_defconfig index 368f73e9dd66..dcb100ad2104 100644 --- a/configs/M5475AFE_defconfig +++ b/configs/M5475AFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475AFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475BFE_defconfig b/configs/M5475BFE_defconfig index d44b0b267fd3..d1a5a6c97c1f 100644 --- a/configs/M5475BFE_defconfig +++ b/configs/M5475BFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475BFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475CFE_defconfig b/configs/M5475CFE_defconfig index 108ef978a65f..bf2eb8f8c110 100644 --- a/configs/M5475CFE_defconfig +++ b/configs/M5475CFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475CFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475DFE_defconfig b/configs/M5475DFE_defconfig index 9325db5ba67e..424e7f23dddd 100644 --- a/configs/M5475DFE_defconfig +++ b/configs/M5475DFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475DFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475EFE_defconfig b/configs/M5475EFE_defconfig index 6873f1500c91..7e947c66acfc 100644 --- a/configs/M5475EFE_defconfig +++ b/configs/M5475EFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475EFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475FFE_defconfig b/configs/M5475FFE_defconfig index a98e804c4149..a12b62ac1f92 100644 --- a/configs/M5475FFE_defconfig +++ b/configs/M5475FFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475FFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475GFE_defconfig b/configs/M5475GFE_defconfig index ed7574380145..594b0c0a987b 100644 --- a/configs/M5475GFE_defconfig +++ b/configs/M5475GFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=4,SYS_DRAMSZ=64" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475GFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485AFE_defconfig b/configs/M5485AFE_defconfig index 8f94ac99a174..ab96ba775888 100644 --- a/configs/M5485AFE_defconfig +++ b/configs/M5485AFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485AFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485BFE_defconfig b/configs/M5485BFE_defconfig index 96bd5200dad9..0a7c2bffb0ab 100644 --- a/configs/M5485BFE_defconfig +++ b/configs/M5485BFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485BFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485CFE_defconfig b/configs/M5485CFE_defconfig index 148be33d5a5b..84f8ebae7d69 100644 --- a/configs/M5485CFE_defconfig +++ b/configs/M5485CFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485CFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485DFE_defconfig b/configs/M5485DFE_defconfig index 5facb0733da8..25d54630aedf 100644 --- a/configs/M5485DFE_defconfig +++ b/configs/M5485DFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485DFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485EFE_defconfig b/configs/M5485EFE_defconfig index ece3e115ea34..de82703c8f3d 100644 --- a/configs/M5485EFE_defconfig +++ b/configs/M5485EFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485EFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485FFE_defconfig b/configs/M5485FFE_defconfig index c2a2d926d657..c9101033422f 100644 --- a/configs/M5485FFE_defconfig +++ b/configs/M5485FFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485FFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485GFE_defconfig b/configs/M5485GFE_defconfig index 9cf620242ae7..c7f47703e11c 100644 --- a/configs/M5485GFE_defconfig +++ b/configs/M5485GFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=4,SYS_DRAMSZ=64" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485GFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485HFE_defconfig b/configs/M5485HFE_defconfig index e6c9225ea9f2..4b03ee009439 100644 --- a/configs/M5485HFE_defconfig +++ b/configs/M5485HFE_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO" CONFIG_BOOTDELAY=1 @@ -15,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485HFE" +CONFIG_ENV_ADDR=0xFF840000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/MCR3000_defconfig b/configs/MCR3000_defconfig index 8ce5c55b536f..8bc6d1c9bdd4 100644 --- a/configs/MCR3000_defconfig +++ b/configs/MCR3000_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_MPC8xx=y CONFIG_SYS_IMMR=0xFF000000 CONFIG_TARGET_MCR3000=y @@ -67,6 +69,7 @@ CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="mcr3000" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x4004000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y # CONFIG_MMC is not set diff --git a/configs/MPC8308RDB_defconfig b/configs/MPC8308RDB_defconfig index 55ecf758863c..dc9ebb8f5cc4 100644 --- a/configs/MPC8308RDB_defconfig +++ b/configs/MPC8308RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_CLK_FREQ=33333333 CONFIG_MPC83xx=y CONFIG_TARGET_MPC8308RDB=y @@ -127,6 +129,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE080000 +CONFIG_ENV_ADDR_REDUND=0xFE090000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8313ERDB_33_defconfig b/configs/MPC8313ERDB_33_defconfig index 9b58860e08af..121959b2722e 100644 --- a/configs/MPC8313ERDB_33_defconfig +++ b/configs/MPC8313ERDB_33_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_CLK_FREQ=33333333 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -143,6 +145,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=e2800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(kernel),-(fs)" +CONFIG_ENV_ADDR=0xFE080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8313ERDB_66_defconfig b/configs/MPC8313ERDB_66_defconfig index 98fcda1de29a..c0f89bc61432 100644 --- a/configs/MPC8313ERDB_66_defconfig +++ b/configs/MPC8313ERDB_66_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_CLK_FREQ=66666667 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -142,6 +144,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=e2800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(kernel),-(fs)" +CONFIG_ENV_ADDR=0xFE080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index 744f8f6ace6c..170bc39809f0 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x00100000 CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_SPL=y CONFIG_SYS_CLK_FREQ=33333333 CONFIG_MPC83xx=y @@ -151,6 +153,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(ker # CONFIG_ENV_IS_IN_FLASH is not set CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x90000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index 4c53104c68fc..c2a3267d471e 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x00100000 CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_SPL=y CONFIG_SYS_CLK_FREQ=66666667 CONFIG_MPC83xx=y @@ -150,6 +152,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(ker # CONFIG_ENV_IS_IN_FLASH is not set CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x90000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8315ERDB_defconfig b/configs/MPC8315ERDB_defconfig index 2a550bc98b9f..c232e495dedc 100644 --- a/configs/MPC8315ERDB_defconfig +++ b/configs/MPC8315ERDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_CLK_FREQ=66666667 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -127,6 +129,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=e0600000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=e0600000.flash:512k(uboot),128k(env),6m@1m(kernel),-(fs)" +CONFIG_ENV_ADDR=0xFE080000 CONFIG_FSL_SATA=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8323ERDB_defconfig b/configs/MPC8323ERDB_defconfig index 349d611086ea..fd31046e4e2d 100644 --- a/configs/MPC8323ERDB_defconfig +++ b/configs/MPC8323ERDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66666667 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -101,6 +103,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_ENV_ADDR=0xFE080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC832XEMDS_ATM_defconfig b/configs/MPC832XEMDS_ATM_defconfig index 3eda9a4deb98..c1b323f9fe41 100644 --- a/configs/MPC832XEMDS_ATM_defconfig +++ b/configs/MPC832XEMDS_ATM_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -126,6 +128,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_ENV_ADDR=0xFE080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC832XEMDS_HOST_33_defconfig b/configs/MPC832XEMDS_HOST_33_defconfig index ede3b8a0e4c0..17a142bf8244 100644 --- a/configs/MPC832XEMDS_HOST_33_defconfig +++ b/configs/MPC832XEMDS_HOST_33_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -147,6 +149,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_ENV_ADDR=0xFE080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC832XEMDS_HOST_66_defconfig b/configs/MPC832XEMDS_HOST_66_defconfig index 370a9141c9c3..5eca9b26696a 100644 --- a/configs/MPC832XEMDS_HOST_66_defconfig +++ b/configs/MPC832XEMDS_HOST_66_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -147,6 +149,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_ENV_ADDR=0xFE080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC832XEMDS_SLAVE_defconfig b/configs/MPC832XEMDS_SLAVE_defconfig index 5b1c8f89b604..498d87935467 100644 --- a/configs/MPC832XEMDS_SLAVE_defconfig +++ b/configs/MPC832XEMDS_SLAVE_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -144,6 +146,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_ENV_ADDR=0xFE080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC832XEMDS_defconfig b/configs/MPC832XEMDS_defconfig index 34fbe53f727f..53bec936a799 100644 --- a/configs/MPC832XEMDS_defconfig +++ b/configs/MPC832XEMDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -125,6 +127,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_ENV_ADDR=0xFE080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8349EMDS_PCI64_defconfig b/configs/MPC8349EMDS_PCI64_defconfig index 873fabc60bc7..fd4e6ece4387 100644 --- a/configs/MPC8349EMDS_PCI64_defconfig +++ b/configs/MPC8349EMDS_PCI64_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -94,6 +96,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE080000 +CONFIG_ENV_ADDR_REDUND=0xFE0A0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8349EMDS_SDRAM_defconfig b/configs/MPC8349EMDS_SDRAM_defconfig index ed7445ca98c2..1a618930c8ba 100644 --- a/configs/MPC8349EMDS_SDRAM_defconfig +++ b/configs/MPC8349EMDS_SDRAM_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -103,6 +105,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE080000 +CONFIG_ENV_ADDR_REDUND=0xFE0A0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8349EMDS_SLAVE_defconfig b/configs/MPC8349EMDS_SLAVE_defconfig index c39c36208792..1351d9621317 100644 --- a/configs/MPC8349EMDS_SLAVE_defconfig +++ b/configs/MPC8349EMDS_SLAVE_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66666666 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -94,6 +96,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE080000 +CONFIG_ENV_ADDR_REDUND=0xFE0A0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8349EMDS_defconfig b/configs/MPC8349EMDS_defconfig index 87e041944cfc..5a8692fceb5f 100644 --- a/configs/MPC8349EMDS_defconfig +++ b/configs/MPC8349EMDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -95,6 +97,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE080000 +CONFIG_ENV_ADDR_REDUND=0xFE0A0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8349ITXGP_defconfig b/configs/MPC8349ITXGP_defconfig index b4cf8c33d050..c4d41c63a891 100644 --- a/configs/MPC8349ITXGP_defconfig +++ b/configs/MPC8349ITXGP_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_CLK_FREQ=66666666 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -164,6 +166,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y +CONFIG_ENV_ADDR=0xFE080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8349ITX_LOWBOOT_defconfig b/configs/MPC8349ITX_LOWBOOT_defconfig index fbfeda57cfae..d5e253b0a658 100644 --- a/configs/MPC8349ITX_LOWBOOT_defconfig +++ b/configs/MPC8349ITX_LOWBOOT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_CLK_FREQ=66666666 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -168,6 +170,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_ADDR=0xFE080000 CONFIG_SATA_SIL3114=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8349ITX_defconfig b/configs/MPC8349ITX_defconfig index e9a8bb1836de..0517fc6ad40a 100644 --- a/configs/MPC8349ITX_defconfig +++ b/configs/MPC8349ITX_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFEF00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_CLK_FREQ=66666666 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -167,6 +169,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_ADDR=0xFEF80000 CONFIG_SATA_SIL3114=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC837XEMDS_HOST_defconfig b/configs/MPC837XEMDS_HOST_defconfig index 7b69f5b44f3a..a7aa5a261c5e 100644 --- a/configs/MPC837XEMDS_HOST_defconfig +++ b/configs/MPC837XEMDS_HOST_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -161,6 +163,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_ADDR=0xFE080000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC837XEMDS_SLAVE_defconfig b/configs/MPC837XEMDS_SLAVE_defconfig index 17ccb40ac5dd..c33aae0ea6d5 100644 --- a/configs/MPC837XEMDS_SLAVE_defconfig +++ b/configs/MPC837XEMDS_SLAVE_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_TARGET_MPC837XEMDS=y @@ -119,6 +121,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_ADDR=0xFE080000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/MPC837XEMDS_defconfig b/configs/MPC837XEMDS_defconfig index 47125e27bc04..3fd3a394932f 100644 --- a/configs/MPC837XEMDS_defconfig +++ b/configs/MPC837XEMDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -139,6 +141,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_ADDR=0xFE080000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC837XERDB_SLAVE_defconfig b/configs/MPC837XERDB_SLAVE_defconfig index 4dcaed23e3b1..39c50960bb24 100644 --- a/configs/MPC837XERDB_SLAVE_defconfig +++ b/configs/MPC837XERDB_SLAVE_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_CLK_FREQ=66666667 CONFIG_MPC83xx=y CONFIG_TARGET_MPC837XERDB=y @@ -117,6 +119,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_ADDR=0xFE080000 CONFIG_FSL_SATA=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index 738e75ac36c0..fd8335ee4ef1 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_CLK_FREQ=66666667 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -158,6 +160,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_ADDR=0xFE080000 CONFIG_FSL_SATA=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index 428586a48690..871a141e4824 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8536DS=y @@ -25,6 +27,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_SYS_FSL_DDR2=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index d8f6a516ec0d..b7d026394531 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xf8f40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8536DS=y diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index fb223890c03d..b0b1040cda89 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xf8f40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xF0000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8536DS=y diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index 01863a443cbd..f10a0891a883 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8536DS=y @@ -24,6 +26,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_SYS_FSL_DDR2=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8541CDS_defconfig b/configs/MPC8541CDS_defconfig index 3307dbbb481d..7017f7f5c875 100644 --- a/configs/MPC8541CDS_defconfig +++ b/configs/MPC8541CDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8541CDS=y @@ -16,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFC0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8541CDS_legacy_defconfig b/configs/MPC8541CDS_legacy_defconfig index bef89171ea5c..a62d3663b51a 100644 --- a/configs/MPC8541CDS_legacy_defconfig +++ b/configs/MPC8541CDS_legacy_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8541CDS=y @@ -17,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFC0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index a77f8f14cd16..fb1ed08adb7b 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8544DS=y @@ -20,6 +22,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFF70000 CONFIG_SCSI_AHCI=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index 1c3762497846..a8700100e168 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8548CDS=y @@ -19,6 +21,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="mpc8548cds_36b" +CONFIG_ENV_ADDR=0xFFF60000 CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index ef82aa8c2b54..42c31d423782 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8548CDS=y @@ -18,6 +20,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="mpc8548cds" +CONFIG_ENV_ADDR=0xFFF60000 CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index e36fcf8435c4..263f24c17962 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8548CDS=y @@ -18,6 +20,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="mpc8548cds" +CONFIG_ENV_ADDR=0xFFF60000 CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8555CDS_defconfig b/configs/MPC8555CDS_defconfig index f5fcd81f1195..b6391751076e 100644 --- a/configs/MPC8555CDS_defconfig +++ b/configs/MPC8555CDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8555CDS=y @@ -16,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFC0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8555CDS_legacy_defconfig b/configs/MPC8555CDS_legacy_defconfig index 7887bccb6443..51710bbdbe7b 100644 --- a/configs/MPC8555CDS_legacy_defconfig +++ b/configs/MPC8555CDS_legacy_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8555CDS=y @@ -17,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFC0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8568MDS_defconfig b/configs/MPC8568MDS_defconfig index 190b0b89dfab..24bc0d582d25 100644 --- a/configs/MPC8568MDS_defconfig +++ b/configs/MPC8568MDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8568MDS=y @@ -18,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFF60000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8569MDS_ATM_defconfig b/configs/MPC8569MDS_ATM_defconfig index 08e17bf5f252..8d7cc64a2201 100644 --- a/configs/MPC8569MDS_ATM_defconfig +++ b/configs/MPC8569MDS_ATM_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8569MDS=y @@ -23,6 +25,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFF60000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8569MDS_defconfig b/configs/MPC8569MDS_defconfig index f1b4a7befd91..7517b4d56822 100644 --- a/configs/MPC8569MDS_defconfig +++ b/configs/MPC8569MDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8569MDS=y @@ -22,6 +24,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFF60000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index 3f02171737ba..6faf32e00a73 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_MPC8572DS=y CONFIG_PHYS_64BIT=y @@ -22,6 +24,7 @@ CONFIG_CMD_PING=y CONFIG_MP=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_SCSI_AHCI=y CONFIG_SYS_FSL_DDR2=y # CONFIG_MMC is not set diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index acb4af4b3de6..b4e88ef2ec66 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_MPC8572DS=y CONFIG_FIT=y @@ -21,6 +23,7 @@ CONFIG_CMD_PING=y CONFIG_MP=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_SCSI_AHCI=y CONFIG_SYS_FSL_DDR2=y # CONFIG_MMC is not set diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 80ea441aa338..987982341164 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC86xx=y CONFIG_HIGH_BATS=y CONFIG_TARGET_MPC8610HPCD=y @@ -20,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_ADDR=0xFFF80000 CONFIG_SCSI_AHCI=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index 81901f7a28b0..249cddac36d2 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xeff00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC86xx=y CONFIG_HIGH_BATS=y CONFIG_TARGET_MPC8641HPCN=y @@ -19,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_ADDR=0xEFF80000 CONFIG_SCSI_AHCI=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index 497d398c834f..f87c61696644 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xeff00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC86xx=y CONFIG_HIGH_BATS=y CONFIG_TARGET_MPC8641HPCN=y @@ -19,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_ADDR=0xEFF80000 CONFIG_SCSI_AHCI=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/MigoR_defconfig b/configs/MigoR_defconfig index b261a92e03c3..54012a39a60f 100644 --- a/configs/MigoR_defconfig +++ b/configs/MigoR_defconfig @@ -1,5 +1,7 @@ CONFIG_SH=y CONFIG_SYS_TEXT_BASE=0x8FFC0000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_MIGOR=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -23,6 +25,7 @@ CONFIG_CMD_SDRAM=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xA0020000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig index 17fa25f37a4f..11856f67a751 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index dfa64d132636..305787335cd1 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig index 99e8b4058034..851840f4e4db 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 10a2eff357c0..3b3484dc7911 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y CONFIG_PHYS_64BIT=y @@ -25,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index aa96237e5963..34b95bbeebb3 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig index 7d39e670daeb..10a8424af7d5 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index eaf5bfe6e9e5..1edfbfb348c9 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig index 96eb27cdb57b..0532a9c7b18f 100644 --- a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index cd4f258c7f1b..177a2ca8f38d 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y diff --git a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig index 7b58ee80d2da..ba4bcdf98a70 100644 --- a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 47c5cca91c49..9bcf41cc603b 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y CONFIG_FIT=y @@ -24,6 +26,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index d5a18093a328..0d5fe5dd3f83 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y diff --git a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig index d1dca08ab83e..f289a342dee8 100644 --- a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index 71aea8a6e88e..6012f88bf35c 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig index f304be67a919..1ad079bc89ed 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 622db5fbc223..a28ab0417941 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig index 4c7f46460969..ebbd76e60d5f 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 9ea5d83e922c..35daf2cb900a 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y CONFIG_PHYS_64BIT=y @@ -25,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 12ca80bae490..2f408d546e0c 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig index 01084fef9438..e85aacc06778 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index f857023fca3e..f538a5029bde 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig index 844e4a088dfe..154cbd434409 100644 --- a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 33fd5fca4431..11ff356201c3 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y diff --git a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig index bcfb589095a5..6775aba6f2c7 100644 --- a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 4178800a3a01..9ad9f955a3b6 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y CONFIG_FIT=y @@ -24,6 +26,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 982305bf1bb1..cd5ccc882b50 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y diff --git a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig index 9420619b18b5..5386633cdcb0 100644 --- a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 3de5feda3882..033719559dac 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig index 71cf213041ba..222dbf034d82 100644 --- a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1020MBG-PC_36BIT_defconfig b/configs/P1020MBG-PC_36BIT_defconfig index 63cc1b6b7729..5fd1870ce5c0 100644 --- a/configs/P1020MBG-PC_36BIT_defconfig +++ b/configs/P1020MBG-PC_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020MBG=y @@ -27,6 +29,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1020MBG-PC_SDCARD_defconfig b/configs/P1020MBG-PC_SDCARD_defconfig index 44f77421c920..c48e463f2994 100644 --- a/configs/P1020MBG-PC_SDCARD_defconfig +++ b/configs/P1020MBG-PC_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1020MBG-PC_defconfig b/configs/P1020MBG-PC_defconfig index f0a479aca8d4..c8a324d0a9e8 100644 --- a/configs/P1020MBG-PC_defconfig +++ b/configs/P1020MBG-PC_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020MBG=y @@ -26,6 +28,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 2fc6e83a3470..c5fad3ebc2f3 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index f7532151f2af..4230a494993e 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index d47c291425d3..888f9e98fbd7 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 9ce12c564791..454a7991b1da 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PC=y @@ -30,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc_36b" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 8e0345be79aa..1bf070971bd1 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 43a48bad7c7d..601c7dccb09e 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 38c7b04bd9ee..c9de7bc56c60 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 9158fefdfddd..605c9257cc90 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PC=y @@ -29,6 +31,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index a1f2ac63f17d..8cebc3ce8f0d 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index fba8dfbd19a7..2bd17ec32653 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index fc90cf5a29dc..a5255a3a96f6 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index a29f811450f8..ea3e26cf4fb1 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PD=y @@ -32,6 +34,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ec000000.nor:128k(dtb),6016k(kernel),57088k(fs CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pd" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig index a5213d709987..069a1d317621 100644 --- a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1020UTM-PC_36BIT_defconfig b/configs/P1020UTM-PC_36BIT_defconfig index 4fe2a9228a62..df9ae199a45c 100644 --- a/configs/P1020UTM-PC_36BIT_defconfig +++ b/configs/P1020UTM-PC_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020UTM=y @@ -27,6 +29,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1020UTM-PC_SDCARD_defconfig b/configs/P1020UTM-PC_SDCARD_defconfig index 4f8c82b44e93..a6b3e0ca99a0 100644 --- a/configs/P1020UTM-PC_SDCARD_defconfig +++ b/configs/P1020UTM-PC_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1020UTM-PC_defconfig b/configs/P1020UTM-PC_defconfig index dbe1879d886f..2ec53742eddd 100644 --- a/configs/P1020UTM-PC_defconfig +++ b/configs/P1020UTM-PC_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020UTM=y @@ -26,6 +28,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index 8a929f11eebe..8cc533ca1d09 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig index 1b66deb4072f..40b06d207d80 100644 --- a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig index 581e37e9cdd4..74b3472cca78 100644 --- a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1021RDB-PC_36BIT_defconfig b/configs/P1021RDB-PC_36BIT_defconfig index 273435a6b462..01ae3e494aee 100644 --- a/configs/P1021RDB-PC_36BIT_defconfig +++ b/configs/P1021RDB-PC_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1021RDB=y @@ -31,6 +33,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=fef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index 3795668bd852..aeac3b60f9dc 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1021RDB-PC_SDCARD_defconfig b/configs/P1021RDB-PC_SDCARD_defconfig index 1be333c5b45c..6d4dfc02132b 100644 --- a/configs/P1021RDB-PC_SDCARD_defconfig +++ b/configs/P1021RDB-PC_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1021RDB-PC_SPIFLASH_defconfig b/configs/P1021RDB-PC_SPIFLASH_defconfig index 0ae8a7f91f1f..3dc5ca8ffc83 100644 --- a/configs/P1021RDB-PC_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_SPIFLASH_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1021RDB-PC_defconfig b/configs/P1021RDB-PC_defconfig index 9671af1d86d4..373c4f0fa6dd 100644 --- a/configs/P1021RDB-PC_defconfig +++ b/configs/P1021RDB-PC_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1021RDB=y @@ -30,6 +32,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=ef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index cfdb0fbf18d3..013af8743722 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1022DS=y diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index 8bb5285488ba..6b400cdcfb06 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1022DS=y diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index 8b5a67552650..b4aa22281387 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1022DS_36BIT_defconfig b/configs/P1022DS_36BIT_defconfig index 44c950ed13e7..c1b4b77cacf3 100644 --- a/configs/P1022DS_36BIT_defconfig +++ b/configs/P1022DS_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P1022DS=y CONFIG_PHYS_64BIT=y @@ -29,6 +31,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index 982ac00bebf5..eb7a34b7cd0c 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1022DS=y diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index 7b3e98304ae8..fec645a8efb6 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1022DS=y diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index 206dda0017ec..f478dc8c4c02 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1022DS_defconfig b/configs/P1022DS_defconfig index 42c47f732a4b..4a2bd8ca779c 100644 --- a/configs/P1022DS_defconfig +++ b/configs/P1022DS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P1022DS=y CONFIG_FIT=y @@ -28,6 +30,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=e8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=e8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1023RDB_defconfig b/configs/P1023RDB_defconfig index ee2aee4a322b..9c2d90e8def7 100644 --- a/configs/P1023RDB_defconfig +++ b/configs/P1023RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1023RDB=y @@ -27,6 +29,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1024RDB_36BIT_defconfig b/configs/P1024RDB_36BIT_defconfig index 577d9e863a62..2541fd14cf56 100644 --- a/configs/P1024RDB_36BIT_defconfig +++ b/configs/P1024RDB_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1024RDB=y @@ -27,6 +29,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1024RDB_NAND_defconfig b/configs/P1024RDB_NAND_defconfig index b3e8a4ce6109..2a8233b1c587 100644 --- a/configs/P1024RDB_NAND_defconfig +++ b/configs/P1024RDB_NAND_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1024RDB_SDCARD_defconfig b/configs/P1024RDB_SDCARD_defconfig index bbd0bd8e3e71..7e38adf5833e 100644 --- a/configs/P1024RDB_SDCARD_defconfig +++ b/configs/P1024RDB_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1024RDB_SPIFLASH_defconfig b/configs/P1024RDB_SPIFLASH_defconfig index 398b9491253d..4c29e4a2da05 100644 --- a/configs/P1024RDB_SPIFLASH_defconfig +++ b/configs/P1024RDB_SPIFLASH_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1024RDB_defconfig b/configs/P1024RDB_defconfig index 694a2e9eacc6..88c79c9e0df5 100644 --- a/configs/P1024RDB_defconfig +++ b/configs/P1024RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1024RDB=y @@ -26,6 +28,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1025RDB_36BIT_defconfig b/configs/P1025RDB_36BIT_defconfig index e2407e3ae8d7..0b475d679104 100644 --- a/configs/P1025RDB_36BIT_defconfig +++ b/configs/P1025RDB_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1025RDB=y @@ -29,6 +31,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index 51b12233ea1a..71c58d892327 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1025RDB_SDCARD_defconfig b/configs/P1025RDB_SDCARD_defconfig index 9f4debf1fc8e..d09eb782d1df 100644 --- a/configs/P1025RDB_SDCARD_defconfig +++ b/configs/P1025RDB_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P1025RDB_SPIFLASH_defconfig b/configs/P1025RDB_SPIFLASH_defconfig index d12348bb311f..d78bb54fc207 100644 --- a/configs/P1025RDB_SPIFLASH_defconfig +++ b/configs/P1025RDB_SPIFLASH_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P1025RDB_defconfig b/configs/P1025RDB_defconfig index a22f1a10da08..4d8711bbb1da 100644 --- a/configs/P1025RDB_defconfig +++ b/configs/P1025RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1025RDB=y @@ -28,6 +30,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 5a4f5822edcf..8d54a0f0c1de 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 73222c9e5ee0..770e497d5113 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 8cb2afc47b4e..3e9a841828df 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index c99c25f83590..243f4e108af7 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P2020RDB=y @@ -34,6 +36,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fef000000.nor:256k(vsc7385-firmware),256k(dtb) CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc_36b" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 965172515113..c4050b8da724 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 7768fd14c9b0..94458c9d14df 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 6e3a3c6e1e2d..19807d45f48c 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index a0a69ca22f54..ebd6d76d8ff0 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P2020RDB=y @@ -33,6 +35,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb), CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 9c86ded023d0..889cc60fe0bd 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_MPC85xx=y CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 96240f1ac5a6..a09a0b8aa1cb 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xCF400 CONFIG_MPC85xx=y CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/P2041RDB_SECURE_BOOT_defconfig b/configs/P2041RDB_SECURE_BOOT_defconfig index 5c13d29258f2..eace75ecb542 100644 --- a/configs/P2041RDB_SECURE_BOOT_defconfig +++ b/configs/P2041RDB_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P2041RDB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index db8108025259..9dc89848e11d 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig index 4161d10c27ef..5c06ac75219f 100644 --- a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P2041RDB=y CONFIG_FIT=y @@ -24,6 +25,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_REMOTE=y +CONFIG_ENV_ADDR=0xFFE20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index e757330510e8..b51a12048268 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -26,6 +28,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p2041rdb" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y diff --git a/configs/P3041DS_NAND_SECURE_BOOT_defconfig b/configs/P3041DS_NAND_SECURE_BOOT_defconfig index ce1f79c1ec57..fb9d2606bbb2 100644 --- a/configs/P3041DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P3041DS_NAND_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P3041DS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 542d947f4f19..04c6a11e9a34 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_MPC85xx=y CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index 2cb4688a9a99..32c85d38e060 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xCF400 CONFIG_MPC85xx=y CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/P3041DS_SECURE_BOOT_defconfig b/configs/P3041DS_SECURE_BOOT_defconfig index 1ba0194feaa7..c180f35db329 100644 --- a/configs/P3041DS_SECURE_BOOT_defconfig +++ b/configs/P3041DS_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P3041DS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index b45118cbc3f7..c3752a60ee41 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig index efb759d470a8..cf9e2dd32fc4 100644 --- a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P3041DS=y CONFIG_FIT=y @@ -24,6 +25,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_REMOTE=y +CONFIG_ENV_ADDR=0xFFE20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 96297df0df9e..0757ece1522a 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -26,6 +28,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p3041ds" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index 86455da09f3c..e8209fab6c57 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xCF400 CONFIG_MPC85xx=y CONFIG_TARGET_P4080DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/P4080DS_SECURE_BOOT_defconfig b/configs/P4080DS_SECURE_BOOT_defconfig index 4f5ad98cd15d..281bba123f97 100644 --- a/configs/P4080DS_SECURE_BOOT_defconfig +++ b/configs/P4080DS_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P4080DS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index 2344198379d6..2d0cb4614537 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_P4080DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig index 095b21f95b59..2ee3d1090696 100644 --- a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P4080DS=y CONFIG_FIT=y @@ -24,6 +25,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_REMOTE=y +CONFIG_ENV_ADDR=0xFFE20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index a9a90e499885..801f56026a02 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P4080DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -26,6 +28,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p4080ds" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y diff --git a/configs/P5020DS_NAND_SECURE_BOOT_defconfig b/configs/P5020DS_NAND_SECURE_BOOT_defconfig index 8c07d0f55a24..183296867857 100644 --- a/configs/P5020DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5020DS_NAND_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P5020DS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P5020DS_NAND_defconfig b/configs/P5020DS_NAND_defconfig index 4ae3e177f51c..cbb1263e18f6 100644 --- a/configs/P5020DS_NAND_defconfig +++ b/configs/P5020DS_NAND_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_MPC85xx=y CONFIG_TARGET_P5020DS=y CONFIG_FIT=y diff --git a/configs/P5020DS_SDCARD_defconfig b/configs/P5020DS_SDCARD_defconfig index 829c6aa70486..43e5b9c3dfe4 100644 --- a/configs/P5020DS_SDCARD_defconfig +++ b/configs/P5020DS_SDCARD_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xCF400 CONFIG_MPC85xx=y CONFIG_TARGET_P5020DS=y CONFIG_FIT=y diff --git a/configs/P5020DS_SECURE_BOOT_defconfig b/configs/P5020DS_SECURE_BOOT_defconfig index 26cc310b8c98..326bb06967ba 100644 --- a/configs/P5020DS_SECURE_BOOT_defconfig +++ b/configs/P5020DS_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P5020DS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P5020DS_SPIFLASH_defconfig b/configs/P5020DS_SPIFLASH_defconfig index 008ed33fbf33..b82f28480a84 100644 --- a/configs/P5020DS_SPIFLASH_defconfig +++ b/configs/P5020DS_SPIFLASH_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_P5020DS=y CONFIG_FIT=y diff --git a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig index 79de46e41528..ce80ef9bc987 100644 --- a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P5020DS=y CONFIG_FIT=y @@ -25,6 +26,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_REMOTE=y +CONFIG_ENV_ADDR=0xFFE20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/P5020DS_defconfig b/configs/P5020DS_defconfig index df43d13f7ca8..2c116cf90f96 100644 --- a/configs/P5020DS_defconfig +++ b/configs/P5020DS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P5020DS=y CONFIG_FIT=y @@ -24,6 +26,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P5040DS_NAND_SECURE_BOOT_defconfig b/configs/P5040DS_NAND_SECURE_BOOT_defconfig index b268a9fa10d5..be287317fd4e 100644 --- a/configs/P5040DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5040DS_NAND_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P5040DS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index bf58aba7a1d2..465fc371f5ce 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_MPC85xx=y CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index 51b8197ef802..711d97221c0e 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xCF400 CONFIG_MPC85xx=y CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/P5040DS_SECURE_BOOT_defconfig b/configs/P5040DS_SECURE_BOOT_defconfig index a6e6f191ccba..bae759e4bc52 100644 --- a/configs/P5040DS_SECURE_BOOT_defconfig +++ b/configs/P5040DS_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_P5040DS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index adf61e3fb663..2b96bca1a9e6 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -1,5 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index f922521e7fed..bb9e5d86a144 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -27,6 +29,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p5040ds" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index 73f8cfb608de..61dc1e87528f 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -4,6 +4,9 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x00600000 CONFIG_TARGET_SBx81LIFKW=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_IDENT_STRING="\nSBx81LIFKW" # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index 094d4c65b3e3..bda5e7f06d9a 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -4,6 +4,9 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x00600000 CONFIG_TARGET_SBx81LIFXCAT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_IDENT_STRING="\nSBx81LIFXCAT" # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index 1902197f5b16..f82d396d560f 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x140000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1023RDB=y diff --git a/configs/T1023RDB_SDCARD_defconfig b/configs/T1023RDB_SDCARD_defconfig index 8f1caae06698..120cf8c9780a 100644 --- a/configs/T1023RDB_SDCARD_defconfig +++ b/configs/T1023RDB_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1023RDB=y diff --git a/configs/T1023RDB_SECURE_BOOT_defconfig b/configs/T1023RDB_SECURE_BOOT_defconfig index 865b7a9cbf3a..980ea5072bf6 100644 --- a/configs/T1023RDB_SECURE_BOOT_defconfig +++ b/configs/T1023RDB_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T1023RDB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1023RDB_SPIFLASH_defconfig b/configs/T1023RDB_SPIFLASH_defconfig index 49df3528b9b2..a4ea7dde5a07 100644 --- a/configs/T1023RDB_SPIFLASH_defconfig +++ b/configs/T1023RDB_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y @@ -44,6 +47,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.1" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:1m(uboot),5m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xFFFC9000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1023RDB_defconfig b/configs/T1023RDB_defconfig index cadc16a2b05c..c2443034e978 100644 --- a/configs/T1023RDB_defconfig +++ b/configs/T1023RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T1023RDB=y CONFIG_FIT=y @@ -29,6 +31,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.1" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:1m(uboot),5m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index 09f0979a9230..dc4f94af9536 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T1024QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index 6a61ddff88e7..265bf372041d 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T1024QDS=y CONFIG_FIT=y @@ -30,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index cf010f1c997a..1267a76482ee 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x140000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1024QDS=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index df896b3b5649..27239cc19fab 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1024QDS=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index 949a33e2a6dc..32f88ea5130a 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T1024QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 1a0915b90da0..5b91d7f8d79c 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y @@ -45,6 +48,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xFFFC9000 CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index af0eb46f8406..93da3a79ef37 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T1024QDS=y CONFIG_FIT=y @@ -30,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index af65615f7d3d..d9fe82acadc6 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 43817bedf209..8412eb1bece1 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index 93abcf34660a..cc4d12f8e644 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 9ffd5d62303f..cbb992cb2fac 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y @@ -47,6 +50,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t1024rdb" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xFFFC9000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index 08a622544449..2b40f5d1c099 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -33,6 +35,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t1024rdb" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index ab5a9b73c0e5..fce47588bb95 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1040D4RDB=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index edbedf841b68..9cf68f8be483 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1040D4RDB=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index e59f8d736ed7..03266d4ec394 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T1040D4RDB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index 1f08ee8e8039..98b4717aaa3c 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y @@ -43,6 +46,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xFFFC9000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index 8d7427d310c7..ba32893bef4c 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T1040D4RDB=y CONFIG_FIT=y @@ -28,6 +30,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 9aa552379f74..0181de22c33c 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T1040QDS=y CONFIG_FIT=y @@ -31,6 +33,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index e411274a9d4c..b0e830711a0e 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T1040QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 5901ca51f148..59e47645b855 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T1040QDS=y CONFIG_FIT=y @@ -31,6 +33,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index c00c85038465..a70581e0dce9 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1040RDB=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index 369b08d4efca..99c528e10525 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1040RDB=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index 376d52d2cbba..41c598ad2764 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T1040RDB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index a19d506c6035..23922cdc29ad 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y @@ -43,6 +46,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xFFFC9000 CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index 9ef146bed050..d8d2e4a35551 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T1040RDB=y CONFIG_FIT=y @@ -28,6 +30,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 2fcd9e194032..5ea869abf7e0 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 04372fd26a1c..4dca49cb39a0 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index 55541be9758a..93129fa45b7d 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 2c869cdbd093..4aeb63eac1ee 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y @@ -46,6 +49,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t1042d4rdb" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xFFFC9000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 5d8a25f2b5ac..ad976961a990 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -32,6 +34,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t1042d4rdb" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index e11757d3f0ac..6296dc605ba5 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NXP_ESBC=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1042RDB_PI=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index a32fa4c64651..c83b12952e9e 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1042RDB_PI=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index ad145b65d483..ed5123c3f008 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1042RDB_PI=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 120fc14d1f34..5677234f7fa5 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y @@ -45,6 +48,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xFFFC9000 CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index 7aeac6020344..b59e6bf17f45 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T1042RDB_PI=y CONFIG_FIT=y @@ -30,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index fc9144a03df9..29862687345d 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T1042RDB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index 6378c95efc98..fc20e6b37624 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T1042RDB=y CONFIG_FIT=y @@ -27,6 +29,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 4d80baead6fd..44f0e6c9b6c8 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x140000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 786f154e71ce..e41c005a04b2 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 3e1b3686eac4..f7f59a7a9d15 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 066a83b727e4..56d6c241e372 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y @@ -43,6 +46,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xFFFC9000 CONFIG_DM=y CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index f4bebee1473a..a1cef08b6ec8 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -27,6 +28,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_ENV_IS_IN_REMOTE=y +CONFIG_ENV_ADDR=0xFFE20000 CONFIG_DM=y CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index e22542fd8c90..7d7179d4fcdc 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -29,6 +31,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 692d01cbbd87..3d4e0eb397fb 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 247cc314b088..1a3a6a37334e 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y diff --git a/configs/T2080RDB_SECURE_BOOT_defconfig b/configs/T2080RDB_SECURE_BOOT_defconfig index 71f07438c11e..5c256f8261ec 100644 --- a/configs/T2080RDB_SECURE_BOOT_defconfig +++ b/configs/T2080RDB_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 1370e16d68ca..01723c63d00e 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y @@ -44,6 +47,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t2080rdb" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xFFFC9000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y diff --git a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig index ab071abc4752..d29c147ece15 100644 --- a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y CONFIG_FIT=y @@ -25,6 +26,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_CMD_IRQ is not set CONFIG_ENV_IS_IN_REMOTE=y +CONFIG_ENV_ADDR=0xFFE20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index bc4a02663f90..71a95599d11a 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -30,6 +32,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t2080rdb" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y diff --git a/configs/T2081QDS_NAND_defconfig b/configs/T2081QDS_NAND_defconfig index f793e2a72a3d..72bb8f9be764 100644 --- a/configs/T2081QDS_NAND_defconfig +++ b/configs/T2081QDS_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x140000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2081QDS=y diff --git a/configs/T2081QDS_SDCARD_defconfig b/configs/T2081QDS_SDCARD_defconfig index 7d4c147b95ea..ef477d760352 100644 --- a/configs/T2081QDS_SDCARD_defconfig +++ b/configs/T2081QDS_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2081QDS=y diff --git a/configs/T2081QDS_SPIFLASH_defconfig b/configs/T2081QDS_SPIFLASH_defconfig index eb752cd99c70..55718265ed99 100644 --- a/configs/T2081QDS_SPIFLASH_defconfig +++ b/configs/T2081QDS_SPIFLASH_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y @@ -40,6 +43,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:1m(uboot),5m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xFFFC9000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig index 5dfb4f2ab212..5f8ee398a88e 100644 --- a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T2081QDS=y CONFIG_FIT=y @@ -23,6 +24,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_REMOTE=y +CONFIG_ENV_ADDR=0xFFE20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/T2081QDS_defconfig b/configs/T2081QDS_defconfig index 306d8b79d845..cecf93cb2552 100644 --- a/configs/T2081QDS_defconfig +++ b/configs/T2081QDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T2081QDS=y CONFIG_FIT=y @@ -25,6 +27,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:1m(uboot),5m(kernel),128k(dtb),-(user)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T4160QDS_NAND_defconfig b/configs/T4160QDS_NAND_defconfig index 1a47bbc5dbbe..1bdd43bc581f 100644 --- a/configs/T4160QDS_NAND_defconfig +++ b/configs/T4160QDS_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x140000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T4160QDS=y diff --git a/configs/T4160QDS_SDCARD_defconfig b/configs/T4160QDS_SDCARD_defconfig index f04c34dc5ea6..e9f0760bc1e9 100644 --- a/configs/T4160QDS_SDCARD_defconfig +++ b/configs/T4160QDS_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T4160QDS=y diff --git a/configs/T4160QDS_SECURE_BOOT_defconfig b/configs/T4160QDS_SECURE_BOOT_defconfig index c71880e213b0..0042424539d0 100644 --- a/configs/T4160QDS_SECURE_BOOT_defconfig +++ b/configs/T4160QDS_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T4160QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T4160QDS_defconfig b/configs/T4160QDS_defconfig index 50970fc79588..d4668402ac1b 100644 --- a/configs/T4160QDS_defconfig +++ b/configs/T4160QDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T4160QDS=y CONFIG_FIT=y @@ -22,6 +24,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T4160RDB_defconfig b/configs/T4160RDB_defconfig index 077961de62e1..986539ad8454 100644 --- a/configs/T4160RDB_defconfig +++ b/configs/T4160RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T4160RDB=y CONFIG_FIT=y @@ -22,6 +24,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T4240QDS_NAND_defconfig b/configs/T4240QDS_NAND_defconfig index 031cdc205e35..00b369cede44 100644 --- a/configs/T4240QDS_NAND_defconfig +++ b/configs/T4240QDS_NAND_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x140000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T4240QDS=y diff --git a/configs/T4240QDS_SDCARD_defconfig b/configs/T4240QDS_SDCARD_defconfig index 579d4f42b6f4..b12e3e21f390 100644 --- a/configs/T4240QDS_SDCARD_defconfig +++ b/configs/T4240QDS_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T4240QDS=y diff --git a/configs/T4240QDS_SECURE_BOOT_defconfig b/configs/T4240QDS_SECURE_BOOT_defconfig index 3f6ad233d3e6..046686bd7ec6 100644 --- a/configs/T4240QDS_SECURE_BOOT_defconfig +++ b/configs/T4240QDS_SECURE_BOOT_defconfig @@ -1,6 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T4240QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig index 3eb07017d115..217378ec5043 100644 --- a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y CONFIG_TARGET_T4240QDS=y CONFIG_FIT=y @@ -23,6 +24,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_REMOTE=y +CONFIG_ENV_ADDR=0xFFE20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/T4240QDS_defconfig b/configs/T4240QDS_defconfig index c9f541c0ef63..bd24b4891dcb 100644 --- a/configs/T4240QDS_defconfig +++ b/configs/T4240QDS_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T4240QDS=y CONFIG_FIT=y @@ -22,6 +24,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index df308d4fbcb5..b5d306171044 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T4240RDB=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 9cf2c6afa6c6..0e926df4fad7 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_T4240RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -25,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t4240rdb" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y diff --git a/configs/TQM834x_defconfig b/configs/TQM834x_defconfig index f7d7d58af426..4a28327357d0 100644 --- a/configs/TQM834x_defconfig +++ b/configs/TQM834x_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x80000000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66666000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -139,6 +141,8 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=TQM834x-0" CONFIG_MTDPARTS_DEFAULT="mtdparts=TQM834x-0:256k(u-boot),256k(env),1m(kernel),2m(initrd),-(user);" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0x80060000 +CONFIG_ENV_ADDR_REDUND=0x80080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y diff --git a/configs/TWR-P1025_defconfig b/configs/TWR-P1025_defconfig index 53f66c714d8c..686e52348af5 100644 --- a/configs/TWR-P1025_defconfig +++ b/configs/TWR-P1025_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF40000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1_TWR=y @@ -30,6 +32,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=ec000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=ec000000.nor:256k(vsc7385-firmware),256k(dtb),5632k(kernel),57856k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEFF20000 CONFIG_SATA_SIL3114=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index 128f10fa5d05..71a0b2cf4bc4 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xEFF80000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y CONFIG_TARGET_UCP1020=y CONFIG_FIT=y @@ -32,6 +34,7 @@ CONFIG_CMD_CRAMFS=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xEC0C0000 # CONFIG_SATA_SIL is not set # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/adp-ae3xx_defconfig b/configs/adp-ae3xx_defconfig index 1d6efb3bcc69..2ea0609e9a9d 100644 --- a/configs/adp-ae3xx_defconfig +++ b/configs/adp-ae3xx_defconfig @@ -1,6 +1,9 @@ CONFIG_NDS32=y CONFIG_SYS_TEXT_BASE=0x4A000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x140000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_TARGET_ADP_AE3XX=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index c91f13d0eea3..9dd960c8e316 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -1,6 +1,8 @@ CONFIG_NDS32=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_ADP_AG101P=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 @@ -18,6 +20,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ag101p" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x80140000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_MMC=y diff --git a/configs/ae350_rv32_defconfig b/configs/ae350_rv32_defconfig index 02769ab32def..fdf3bdb958ec 100644 --- a/configs/ae350_rv32_defconfig +++ b/configs/ae350_rv32_defconfig @@ -1,6 +1,7 @@ CONFIG_RISCV=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_TARGET_AX25_AE350=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/ae350_rv32_xip_defconfig b/configs/ae350_rv32_xip_defconfig index 385d86ac0900..8ca2b8017c36 100644 --- a/configs/ae350_rv32_xip_defconfig +++ b/configs/ae350_rv32_xip_defconfig @@ -1,6 +1,7 @@ CONFIG_RISCV=y CONFIG_SYS_TEXT_BASE=0x80000000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_TARGET_AX25_AE350=y CONFIG_XIP=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ae350_rv64_defconfig b/configs/ae350_rv64_defconfig index e21b24793e6e..dcce3d20c7d1 100644 --- a/configs/ae350_rv64_defconfig +++ b/configs/ae350_rv64_defconfig @@ -1,6 +1,7 @@ CONFIG_RISCV=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_TARGET_AX25_AE350=y CONFIG_ARCH_RV64I=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ae350_rv64_xip_defconfig b/configs/ae350_rv64_xip_defconfig index 1439a218a0bc..4544828b6283 100644 --- a/configs/ae350_rv64_xip_defconfig +++ b/configs/ae350_rv64_xip_defconfig @@ -1,6 +1,7 @@ CONFIG_RISCV=y CONFIG_SYS_TEXT_BASE=0x80000000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_TARGET_AX25_AE350=y CONFIG_ARCH_RV64I=y CONFIG_XIP=y diff --git a/configs/alt_defconfig b/configs/alt_defconfig index a0535533fb0b..f5b68e5c001d 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -12,9 +12,12 @@ CONFIG_ARCH_RMOBILE_BOARD_STRING="Alt" CONFIG_R8A7794=y CONFIG_TARGET_ALT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0xe6300000 @@ -54,6 +57,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7794-alt-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xC0000 CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 329e2a83106c..ce3b2ae68f56 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-boneblack" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x280000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y # CONFIG_SPL_BLK is not set diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index ea6fd2d97703..f4f0a63fcebc 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -8,7 +8,7 @@ CONFIG_AM33XX=y CONFIG_TARGET_AM335X_GUARDIAN=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y -CONFIG_ENV_SIZE=0x040000 +CONFIG_ENV_SIZE=0x40000 CONFIG_SPL=y CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 3bf3400376f0..5e8b2511fbf0 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -44,6 +44,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x9000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_MMC=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 98bbf831a29a..38cceb173c7f 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -45,6 +45,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x9000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_MMC=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index b3f0086d5464..2c85f9567a73 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -46,6 +46,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x9000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_MMC=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index 4579bfd94210..52ad497604c3 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -45,6 +45,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x9000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_MMC=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index b7f1810783d5..71686b7a4fb0 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -43,6 +43,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-sl50" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x20000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_BOOTCOUNT_LIMIT=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index c901aced18d0..6934cb58d749 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -33,6 +33,7 @@ CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x120000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 784751227024..a8ae4952552b 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -41,6 +41,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am572x-idk" CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk am574x-idk" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x280000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 11054f585f78..b3abbba0f92b 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -43,6 +43,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15" CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk am574x-idk" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x280000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index 150ad85f915a..260391b270eb 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -48,6 +48,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15" CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk am574x-idk" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x280000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index ead9fdc397e0..a5f8cf9aba39 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -8,6 +8,8 @@ CONFIG_TARGET_AM654_A53_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x680000 CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL_FS_FAT=y @@ -46,6 +48,7 @@ CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x6A0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index 17cf18adf909..8ead2388831b 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -10,6 +10,7 @@ CONFIG_TARGET_AM654_R5_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL_FS_FAT=y diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig index 70e93eb41f0f..ca635dd95255 100644 --- a/configs/am65x_hs_evm_a53_defconfig +++ b/configs/am65x_hs_evm_a53_defconfig @@ -9,6 +9,7 @@ CONFIG_TARGET_AM654_A53_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL_FS_FAT=y diff --git a/configs/am65x_hs_evm_r5_defconfig b/configs/am65x_hs_evm_r5_defconfig index 53d554a8bdad..aafbfb23bb41 100644 --- a/configs/am65x_hs_evm_r5_defconfig +++ b/configs/am65x_hs_evm_r5_defconfig @@ -10,6 +10,7 @@ CONFIG_TARGET_AM654_R5_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL_FS_FAT=y diff --git a/configs/amcore_defconfig b/configs/amcore_defconfig index d68d5223c1c6..78e2d1da05d5 100644 --- a/configs/amcore_defconfig +++ b/configs/amcore_defconfig @@ -1,6 +1,8 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFFC00000 CONFIG_SYS_MALLOC_F_LEN=0x800 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_TARGET_AMCORE=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -19,6 +21,7 @@ CONFIG_CMD_TIMER=y CONFIG_CMD_DIAG=y CONFIG_DEFAULT_DEVICE_TREE="amcore" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFC1F000 # CONFIG_NET is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/ap121_defconfig b/configs/ap121_defconfig index cc6d46c56dc6..d65854179361 100644 --- a/configs/ap121_defconfig +++ b/configs/ap121_defconfig @@ -1,9 +1,12 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9F000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x40000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xb8020000 CONFIG_DEBUG_UART_CLOCK=25000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ARCH_ATH79=y CONFIG_DEBUG_UART=y CONFIG_BOOTDELAY=3 diff --git a/configs/ap143_defconfig b/configs/ap143_defconfig index 58352ebd5e41..5b6da7b85f2a 100644 --- a/configs/ap143_defconfig +++ b/configs/ap143_defconfig @@ -1,9 +1,12 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9F000000 CONFIG_SYS_MALLOC_F_LEN=0x800 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x40000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xb8020000 CONFIG_DEBUG_UART_CLOCK=25000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ARCH_ATH79=y CONFIG_TARGET_AP143=y CONFIG_DEBUG_UART=y diff --git a/configs/ap152_defconfig b/configs/ap152_defconfig index 817ebcfcd88c..76181eb5bcc6 100644 --- a/configs/ap152_defconfig +++ b/configs/ap152_defconfig @@ -1,9 +1,12 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9F000000 CONFIG_SYS_MALLOC_F_LEN=0x800 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x40000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xb8020000 CONFIG_DEBUG_UART_CLOCK=25000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ARCH_ATH79=y CONFIG_TARGET_AP152=y CONFIG_DEBUG_UART=y diff --git a/configs/apalis-imx8qm_defconfig b/configs/apalis-imx8qm_defconfig index eb7d40c79c06..85ef2df13ed1 100644 --- a/configs/apalis-imx8qm_defconfig +++ b/configs/apalis-imx8qm_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_IMX8=y CONFIG_SYS_TEXT_BASE=0x80020000 CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_APALIS_IMX8=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 CONFIG_NR_DRAM_BANKS=3 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index 3d982e00be11..d01c7e3e36c9 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA124=y CONFIG_TARGET_APALIS_TK1=y diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index fb0100e9f236..92a249f317df 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_APALIS_IMX6=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_CMD_HDMIDETECT=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index bb276ca93ef0..554e6194a484 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA30=y CONFIG_TARGET_APALIS_T30=y diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index e1f92778e659..21ada4735618 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -3,6 +3,8 @@ CONFIG_ARM=y CONFIG_TARGET_APF27=y CONFIG_SYS_TEXT_BASE=0xA0000800 CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_IDENT_STRING=" apf27 patch 3.10" @@ -40,6 +42,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand.0:1M(u-boot)ro,512K(env),512K(env2),5 CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index 3660b679e1a9..1843bc1f40fe 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_APX4DEVKIT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x120000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 @@ -32,6 +34,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:128k(bootstrap),1024k(boot),768k(env CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index b5f46dbd6746..0c8958d57b2c 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_ARISTAINETOS2=y +CONFIG_ENV_SIZE=0x3000 +CONFIG_ENV_OFFSET=0xD0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 @@ -36,6 +39,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xE0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_FSL_USDHC=y CONFIG_NAND=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 283b5408eece..c387009465b4 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_ARISTAINETOS2B=y +CONFIG_ENV_SIZE=0x3000 +CONFIG_ENV_OFFSET=0xD0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 @@ -36,6 +39,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xE0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_FSL_USDHC=y CONFIG_NAND=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index ae5b1de1220c..a2baee764b2d 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_ARISTAINETOS=y +CONFIG_ENV_SIZE=0x3000 +CONFIG_ENV_OFFSET=0xD0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" CONFIG_BOOTDELAY=3 @@ -36,6 +39,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xE0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_FSL_USDHC=y CONFIG_NAND=y diff --git a/configs/armadillo-800eva_defconfig b/configs/armadillo-800eva_defconfig index 6eefabd8b684..c6fd9c033178 100644 --- a/configs/armadillo-800eva_defconfig +++ b/configs/armadillo-800eva_defconfig @@ -7,7 +7,9 @@ CONFIG_SYS_TEXT_BASE=0xE80C0000 CONFIG_ARCH_RMOBILE_BOARD_STRING="Armadillo-800EVA Board" CONFIG_R8A7740=y CONFIG_TARGET_ARMADILLO_800EVA=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_CMDLINE_EDITING is not set @@ -33,6 +35,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x40000 # CONFIG_MMC is not set CONFIG_SH_ETHER=y CONFIG_SCIF_CONSOLE=y diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index 3464a671059a..987b0fcd909e 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_ARNDALE=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x86200 CONFIG_NR_DRAM_BANKS=8 CONFIG_SPL=y CONFIG_IDENT_STRING=" for ARNDALE" diff --git a/configs/aspenite_defconfig b/configs/aspenite_defconfig index 835a7981e51a..43b0b88e0c13 100644 --- a/configs/aspenite_defconfig +++ b/configs/aspenite_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_ASPENITE=y CONFIG_SYS_TEXT_BASE=0x600000 +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nMarvell-Aspenite DB" CONFIG_BOOTDELAY=3 diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index 126b50c9b68e..da7332e0a12e 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_SECT_SIZE=0x8000 CONFIG_TARGET_ASTRO_MCF5373L=y CONFIG_BOOTDELAY=1 CONFIG_USE_BOOTARGS=y @@ -17,6 +19,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_CMD_JFFS2=y CONFIG_DEFAULT_DEVICE_TREE="astro_mcf5373l" +CONFIG_ENV_ADDR=0x1FF8000 # CONFIG_NET is not set CONFIG_FPGA_ALTERA=y CONFIG_FPGA_CYCLON2=y diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index 834457cb99fc..19c85aa4eb47 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -4,7 +4,6 @@ CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x10000000 CONFIG_TARGET_AT91RM9200EK=y CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_BOOTDELAY=3 @@ -22,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x10040000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index 93171912bc3b..e8eb3d30fee5 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -4,7 +4,6 @@ CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_TARGET_AT91RM9200EK=y CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT" @@ -23,6 +22,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x10040000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 5dd719e20a6b..f5c021f13650 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -30,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 9af60ce5a194..089120431ec4 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -30,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 550d9427f21d..a825e4abef89 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -34,6 +34,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 5253e63f6452..4bd24782cdf8 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_TEXT_BASE=0x0000000 CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x7e0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 @@ -35,6 +34,8 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0x107E0000 +CONFIG_ENV_ADDR_REDUND=0x107D0000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index a008368f6673..5d292c0bb57e 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_TEXT_BASE=0x21F00000 CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x7e0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 @@ -35,6 +34,8 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0x107E0000 +CONFIG_ENV_ADDR_REDUND=0x107D0000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 23abe50585eb..69fca8375753 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -30,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 020bb51e28c0..acf6d6cbb12f 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -31,6 +31,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek_2mmc" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 91b3a6cd557c..e3dbdb391267 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -30,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 66327d012ad3..c6ec113b0dc2 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9m10g45ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 6671f1881446..f48ca112f678 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9n12ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index dc80c84f10d8..800e9bb286f1 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -31,6 +31,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9rlek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set CONFIG_DM=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index fba256c91517..325e5c8d2adc 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -34,6 +34,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g35ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 2d11ba01b601..97aa2ec3505a 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -30,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 1c5bf39f2804..98d0e200bc32 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -51,6 +51,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20-taurus" CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM=y CONFIG_BLK=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 9328637dadc5..f2cce97ef849 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -1,6 +1,9 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x6FF000 CONFIG_NR_DRAM_BANKS=8 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_INTEL=y CONFIG_TARGET_BAYLEYBAY=y CONFIG_INTERNAL_UART=y diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index 06009c6887d6..d843ad093020 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_TEXT_BASE=0xae000000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x2340000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="SYS_MMC_ENV_DEV=0" CONFIG_MISC_INIT_R=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index 556538728f3e..cde16eae0a53 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_TEXT_BASE=0xae000000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x2340000 CONFIG_NR_DRAM_BANKS=1 CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm23550_w1d_defconfig b/configs/bcm23550_w1d_defconfig index aa90227583c0..2b03964f7dcb 100644 --- a/configs/bcm23550_w1d_defconfig +++ b/configs/bcm23550_w1d_defconfig @@ -4,6 +4,8 @@ CONFIG_SYS_DCACHE_OFF=y CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM23550_W1D=y CONFIG_SYS_TEXT_BASE=0x9f000000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x2340000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_MISC_INIT_R=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index 4bd8d2a0863a..f8fcac747d98 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_TEXT_BASE=0xae000000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x2340000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_MISC_INIT_R=y diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index 06fc357b5141..a3a0f680d125 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_TEXT_BASE=0xae000000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x2340000 CONFIG_NR_DRAM_BANKS=1 CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm7260_defconfig b/configs/bcm7260_defconfig index 5b194b93e898..47f0a7d488c1 100644 --- a/configs/bcm7260_defconfig +++ b/configs/bcm7260_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_BCMSTB=y CONFIG_SYS_TEXT_BASE=0x10100000 CONFIG_TARGET_BCM7260=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x814800 CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y @@ -14,6 +16,7 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_PRIOR_STAGE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x824800 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y diff --git a/configs/bcm7445_defconfig b/configs/bcm7445_defconfig index 35eee69e15ae..2450d247caa6 100644 --- a/configs/bcm7445_defconfig +++ b/configs/bcm7445_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_BCMSTB=y CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_BCM7445=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x1E0000 CONFIG_NR_DRAM_BANKS=3 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTDELAY=1 @@ -15,6 +18,7 @@ CONFIG_CMD_SPI=y CONFIG_OF_PRIOR_STAGE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x1F0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y diff --git a/configs/bcm911360_entphn-ns_defconfig b/configs/bcm911360_entphn-ns_defconfig index 340039a906d3..45707edb8579 100644 --- a/configs/bcm911360_entphn-ns_defconfig +++ b/configs/bcm911360_entphn-ns_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000,ARMV7_NONSEC" CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm911360_entphn_defconfig b/configs/bcm911360_entphn_defconfig index 5e4a960c09c9..2156d5640172 100644 --- a/configs/bcm911360_entphn_defconfig +++ b/configs/bcm911360_entphn_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000" CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm911360k_defconfig b/configs/bcm911360k_defconfig index 092e2c978ba9..02fa526a4330 100644 --- a/configs/bcm911360k_defconfig +++ b/configs/bcm911360k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm958300k-ns_defconfig b/configs/bcm958300k-ns_defconfig index 866cf5340ab9..73c8966cce14 100644 --- a/configs/bcm958300k-ns_defconfig +++ b/configs/bcm958300k-ns_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000,ARMV7_NONSEC" CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm958300k_defconfig b/configs/bcm958300k_defconfig index 092e2c978ba9..02fa526a4330 100644 --- a/configs/bcm958300k_defconfig +++ b/configs/bcm958300k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm958305k_defconfig b/configs/bcm958305k_defconfig index 092e2c978ba9..02fa526a4330 100644 --- a/configs/bcm958305k_defconfig +++ b/configs/bcm958305k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm958622hr_defconfig b/configs/bcm958622hr_defconfig index 7bf9cd4abd1b..f7861ebbec62 100644 --- a/configs/bcm958622hr_defconfig +++ b/configs/bcm958622hr_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMNSP=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x01000000" CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm958712k_defconfig b/configs/bcm958712k_defconfig index 3b584fc13613..2425c3149aa6 100644 --- a/configs/bcm958712k_defconfig +++ b/configs/bcm958712k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMNS2=y CONFIG_SYS_TEXT_BASE=0x85000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" Broadcom Northstar 2" CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index c02521445eca..81df312895c8 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -3,6 +3,7 @@ CONFIG_ARM=y CONFIG_ARCH_BCM63158=y CONFIG_SYS_TEXT_BASE=0x10000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_BCM963158=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/bcm968380gerg_ram_defconfig b/configs/bcm968380gerg_ram_defconfig index 477b9b04a62c..b9689ce56d71 100644 --- a/configs/bcm968380gerg_ram_defconfig +++ b/configs/bcm968380gerg_ram_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6838=y diff --git a/configs/bcm968580xref_ram_defconfig b/configs/bcm968580xref_ram_defconfig index 76ee3f32432b..001e8d89abd5 100644 --- a/configs/bcm968580xref_ram_defconfig +++ b/configs/bcm968580xref_ram_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_BCM6858=y CONFIG_SYS_TEXT_BASE=0x10000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_BCM968580XREF=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 20c3b8270b41..5351b530e226 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA30=y CONFIG_TARGET_BEAVER=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 98fe71a21a1d..e8f3b5f26e75 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_BG0900=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index aea740d04d33..67efe61140dd 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 CONFIG_SYS_MALLOC_F_LEN=0x800 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x200000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_SYS_BOOTCOUNT_ADDR=0x4006e02c @@ -33,6 +35,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="vf610-bk4r1" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x220000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index 58ee355db4c0..65171de3ea82 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_ARCH_RMOBILE_BOARD_STRING="Blanche" CONFIG_R8A7792=y CONFIG_TARGET_BLANCHE=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y @@ -36,6 +39,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7792-blanche-u-boot" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x40000 CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/boston32r2_defconfig b/configs/boston32r2_defconfig index 3d8d97252c43..3904d0f0f924 100644 --- a/configs/boston32r2_defconfig +++ b/configs/boston32r2_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9FC00000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_BOSTON=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set @@ -25,6 +27,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_MTD=y diff --git a/configs/boston32r2el_defconfig b/configs/boston32r2el_defconfig index 6650211b48fc..8974e71e87fc 100644 --- a/configs/boston32r2el_defconfig +++ b/configs/boston32r2el_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9FC00000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_BOSTON=y CONFIG_SYS_LITTLE_ENDIAN=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set @@ -26,6 +28,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_MTD=y diff --git a/configs/boston32r6_defconfig b/configs/boston32r6_defconfig index b916460f058e..0724423f4fac 100644 --- a/configs/boston32r6_defconfig +++ b/configs/boston32r6_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9FC00000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_BOSTON=y CONFIG_CPU_MIPS32_R6=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set @@ -26,6 +28,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_MTD=y diff --git a/configs/boston32r6el_defconfig b/configs/boston32r6el_defconfig index 6bf0027e698a..5d316d77c265 100644 --- a/configs/boston32r6el_defconfig +++ b/configs/boston32r6el_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9FC00000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_BOSTON=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_CPU_MIPS32_R6=y @@ -27,6 +29,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_MTD=y diff --git a/configs/boston64r2_defconfig b/configs/boston64r2_defconfig index 250a70da9030..09aa97874d00 100644 --- a/configs/boston64r2_defconfig +++ b/configs/boston64r2_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xFFFFFFFF9FC00000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_BOSTON=y CONFIG_CPU_MIPS64_R2=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set @@ -26,6 +28,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_MTD=y diff --git a/configs/boston64r2el_defconfig b/configs/boston64r2el_defconfig index 84c4e5372b91..d48083d923ec 100644 --- a/configs/boston64r2el_defconfig +++ b/configs/boston64r2el_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xFFFFFFFF9FC00000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_BOSTON=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_CPU_MIPS64_R2=y @@ -27,6 +29,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_MTD=y diff --git a/configs/boston64r6_defconfig b/configs/boston64r6_defconfig index 133a0a9115bd..140817f49131 100644 --- a/configs/boston64r6_defconfig +++ b/configs/boston64r6_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xFFFFFFFF9FC00000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_BOSTON=y CONFIG_CPU_MIPS64_R6=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set @@ -26,6 +28,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_MTD=y diff --git a/configs/boston64r6el_defconfig b/configs/boston64r6el_defconfig index 8c97dca774e5..9c99a92ff204 100644 --- a/configs/boston64r6el_defconfig +++ b/configs/boston64r6el_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xFFFFFFFF9FC00000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_BOSTON=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_CPU_MIPS64_R6=y @@ -27,6 +29,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_MTD=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 5fa59301d1e5..b1e65194b197 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -67,6 +67,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am335x-brppt1-mmc" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupt-controller interrupt-cells dma-names dmas " CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x50000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 36d0006a331c..495ecca857b3 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -73,6 +73,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am335x-brppt1-spi" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupt-controller interrupt-cells dma-names dmas " CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x30000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/brppt2_defconfig b/configs/brppt2_defconfig index 70d7dd466f76..e67b7265923e 100644 --- a/configs/brppt2_defconfig +++ b/configs/brppt2_defconfig @@ -10,10 +10,13 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x1000 CONFIG_TARGET_BRPPT2=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_SYS_BOOTCOUNT_ADDR=0x020CC068 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y # CONFIG_CMD_BMODE is not set diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index 466c7e95ce8a..2a29a112d0e3 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -72,6 +72,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-brsmarc1" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x30000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 9544240982ac..3ebcb3339397 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -66,6 +66,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am335x-brxre1" CONFIG_OF_SPL_REMOVE_PROPS="" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x50000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y diff --git a/configs/bubblegum_96_defconfig b/configs/bubblegum_96_defconfig index a5454a892c9a..a13464c7ae03 100644 --- a/configs/bubblegum_96_defconfig +++ b/configs/bubblegum_96_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_OWL=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_TARGET_BUBBLEGUM_96=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="\nBubblegum-96" CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/caddy2_defconfig b/configs/caddy2_defconfig index 0760986f40a5..3c542c5d44ed 100644 --- a/configs/caddy2_defconfig +++ b/configs/caddy2_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -107,6 +109,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFFFC0000 +CONFIG_ENV_ADDR_REDUND=0xFFFE0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 9161f93e1937..729440864466 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA30=y CONFIG_TARGET_CARDHU=y diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index b98d3496bc30..7642b1985ab0 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA124=y CONFIG_TARGET_CEI_TK1_SOM=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 98e3c8bfeb37..f1eb3a4b2b58 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -7,8 +7,11 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_CGTQMX6EVAL=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/cherryhill_defconfig b/configs/cherryhill_defconfig index 3ec5d3e01076..5c292e83f428 100644 --- a/configs/cherryhill_defconfig +++ b/configs/cherryhill_defconfig @@ -1,8 +1,11 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFE00000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x5F0000 CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_VENDOR_INTEL=y CONFIG_TARGET_CHERRYHILL=y CONFIG_DEBUG_UART=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 9f592c94079f..56db948cab58 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -36,6 +36,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-chiliboard" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x22000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_GPIO=y diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index ec51d711a5a2..bc0498987565 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -6,6 +6,7 @@ CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_BOOT_MODE_REG=0 CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 # CONFIG_SPL_MMC_SUPPORT is not set +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_TARGET_CHROMEBOOK_BOB=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff1a0000 diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 89fffa587b07..b5c7c541c953 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -1,9 +1,12 @@ CONFIG_X86=y CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_X86_RUN_64BIT=y CONFIG_VENDOR_GOOGLE=y CONFIG_TARGET_CHROMEBOOK_LINK64=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index cdf51794e6b0..7273fcb3c5ef 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -1,10 +1,13 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 CONFIG_SYS_MALLOC_F_LEN=0x2400 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_GOOGLE=y CONFIG_TARGET_CHROMEBOOK_LINK=y CONFIG_DEBUG_UART=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 68cbd5d4ef95..8227fee72c56 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -1,10 +1,13 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFE00000 CONFIG_SYS_MALLOC_F_LEN=0x1d00 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_GOOGLE=y CONFIG_TARGET_CHROMEBOOK_SAMUS=y CONFIG_DEBUG_UART=y diff --git a/configs/chromebook_samus_tpl_defconfig b/configs/chromebook_samus_tpl_defconfig index a3bd44c830d7..df1eed898627 100644 --- a/configs/chromebook_samus_tpl_defconfig +++ b/configs/chromebook_samus_tpl_defconfig @@ -1,10 +1,13 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xffed0000 CONFIG_SYS_MALLOC_F_LEN=0x1a00 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_GOOGLE=y CONFIG_TARGET_CHROMEBOOK_SAMUS_TPL=y CONFIG_DEBUG_UART=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index d7f5f0dbb2c7..c7bb3b4488d8 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -1,6 +1,9 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=8 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_GOOGLE=y CONFIG_TARGET_CHROMEBOX_PANTHER=y CONFIG_HAVE_MRC=y diff --git a/configs/ci20_mmc_defconfig b/configs/ci20_mmc_defconfig index fadebee80823..3b3ec10995e1 100644 --- a/configs/ci20_mmc_defconfig +++ b/configs/ci20_mmc_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SPL_MMC_SUPPORT=y +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_OFFSET=0x83800 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_ARCH_JZ47XX=y diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index 1062ba5b5990..497d6f9bdb5e 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -7,8 +7,11 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_CL_SOM_IMX7=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 9f75e391f219..c5fbe3186632 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -11,6 +11,8 @@ CONFIG_TARGET_CLEARFOG=y CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0xF0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 diff --git a/configs/clearfog_gt_8k_defconfig b/configs/clearfog_gt_8k_defconfig index 8e654e4cb2b3..0c842c800741 100644 --- a/configs/clearfog_gt_8k_defconfig +++ b/configs/clearfog_gt_8k_defconfig @@ -4,9 +4,12 @@ CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_MVEBU_ARMADA_8K=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DEBUG_UART_BASE=0xf0512000 CONFIG_DEBUG_UART_CLOCK=200000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_DEBUG_UART=y CONFIG_AHCI=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 3f14c67ea3ff..218d3d6d0976 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -7,8 +7,11 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_CM_FX6=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y # CONFIG_CMD_BMODE is not set diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 597f30d9742b..478c17e0e725 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_CM_T43=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_ENV_SIZE=0x4000 -CONFIG_ENV_OFFSET=0xc0000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_SPL=y CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_FS_FAT=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index f857c04b0270..11b34d9046a2 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -4,7 +4,7 @@ CONFIG_OMAP54XX=y CONFIG_TARGET_CM_T54=y CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC=16296 CONFIG_ENV_SIZE=0x4000 -CONFIG_ENV_OFFSET=0xc0000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x40300000 CONFIG_DISTRO_DEFAULTS=y @@ -33,6 +33,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xC4000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SCSI_AHCI=y diff --git a/configs/cobra5272_defconfig b/configs/cobra5272_defconfig index e43f373d2d20..3bc76ac69cfc 100644 --- a/configs/cobra5272_defconfig +++ b/configs/cobra5272_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFFE00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TARGET_COBRA5272=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set @@ -12,6 +14,7 @@ CONFIG_CMD_IMLS=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_DEFAULT_DEVICE_TREE="cobra5272" +CONFIG_ENV_ADDR=0xFFE04000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MTD_NOR_FLASH=y CONFIG_MII=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index bc25a3d71961..044a642b8c14 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_COLIBRI_IMX6ULL=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x380000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/colibri-imx8qxp_defconfig b/configs/colibri-imx8qxp_defconfig index 575f07f80cb6..5eb8a1856670 100644 --- a/configs/colibri-imx8qxp_defconfig +++ b/configs/colibri-imx8qxp_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_IMX8=y CONFIG_SYS_TEXT_BASE=0x80020000 CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_COLIBRI_IMX8X=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 CONFIG_NR_DRAM_BANKS=3 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 2931b86beb37..534873b28ab7 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_COLIBRI_IMX6=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_CMD_HDMIDETECT=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index c3a381cdf4dc..ae0f1953b6a9 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_MX7=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_COLIBRI_IMX7=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x380000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index ba5e23aa3960..6ba2647c424c 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_MX7=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_COLIBRI_IMX7=y CONFIG_TARGET_COLIBRI_IMX7_EMMC=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y diff --git a/configs/colibri_pxa270_defconfig b/configs/colibri_pxa270_defconfig index ab2d1851c66f..8ddad7e9571a 100644 --- a/configs/colibri_pxa270_defconfig +++ b/configs/colibri_pxa270_defconfig @@ -4,7 +4,9 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_COLIBRI_PXA270=y CONFIG_SYS_TEXT_BASE=0x0 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=tty0 console=ttyS0,115200" @@ -27,6 +29,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x80000 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index abebf15a3ec2..0d18de020ef8 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x200000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA20=y CONFIG_TARGET_COLIBRI_T20=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 628ed2570ff8..009cf6c23ed5 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA30=y CONFIG_TARGET_COLIBRI_T30=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 53d5a8fbef9e..dfebd4291d38 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_COLIBRI_VF=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/comtrend_ar5315u_ram_defconfig b/configs/comtrend_ar5315u_ram_defconfig index 90ff4c8c2e5e..578b21b1b88a 100644 --- a/configs/comtrend_ar5315u_ram_defconfig +++ b/configs/comtrend_ar5315u_ram_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6318=y diff --git a/configs/comtrend_ar5387un_ram_defconfig b/configs/comtrend_ar5387un_ram_defconfig index 73bec553d356..bfefb7c87850 100644 --- a/configs/comtrend_ar5387un_ram_defconfig +++ b/configs/comtrend_ar5387un_ram_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6328=y diff --git a/configs/comtrend_ct5361_ram_defconfig b/configs/comtrend_ct5361_ram_defconfig index fae85de4933d..46b4f0dd8594 100644 --- a/configs/comtrend_ct5361_ram_defconfig +++ b/configs/comtrend_ct5361_ram_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6348=y diff --git a/configs/comtrend_vr3032u_ram_defconfig b/configs/comtrend_vr3032u_ram_defconfig index 7273234c782b..bb84091fed48 100644 --- a/configs/comtrend_vr3032u_ram_defconfig +++ b/configs/comtrend_vr3032u_ram_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM63268=y diff --git a/configs/comtrend_wap5813n_ram_defconfig b/configs/comtrend_wap5813n_ram_defconfig index cc278f61e828..21edb3e016a7 100644 --- a/configs/comtrend_wap5813n_ram_defconfig +++ b/configs/comtrend_wap5813n_ram_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6368=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 033129e0ca24..36a1fc33aa45 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -1,8 +1,11 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x6EF000 CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_CONGATEC=y CONFIG_TARGET_CONGA_QEVAL20_QA3_E3845=y CONFIG_INTERNAL_UART=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 8597a3fd2271..4233e248eb9a 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -1,6 +1,9 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x6EF000 CONFIG_NR_DRAM_BANKS=8 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_CONGATEC=y CONFIG_TARGET_CONGA_QEVAL20_QA3_E3845=y CONFIG_SMP=y diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index e5473ff2c941..9c89ebd6979e 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_IDENT_STRING=" controlcenterd 0.01" CONFIG_MPC85xx=y CONFIG_TARGET_CONTROLCENTERD=y diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index 475534e00a7e..d9a2a790c0f3 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_IDENT_STRING=" controlcenterd 0.01" CONFIG_MPC85xx=y CONFIG_TARGET_CONTROLCENTERD=y diff --git a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig index d91b94a032ce..be213bf8c1bc 100644 --- a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xf8fc0000 +CONFIG_ENV_SIZE=0x2000 CONFIG_IDENT_STRING=" controlcenterd trailblazer 0.01" CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/controlcenterd_TRAILBLAZER_defconfig b/configs/controlcenterd_TRAILBLAZER_defconfig index 9093c73c10ee..65052ddc5db2 100644 --- a/configs/controlcenterd_TRAILBLAZER_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xf8fc0000 +CONFIG_ENV_SIZE=0x2000 CONFIG_IDENT_STRING=" controlcenterd trailblazer 0.01" CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index 1fbb577861a3..39fc57417e72 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -6,10 +6,13 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CONTROLCENTERDC=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y diff --git a/configs/coreboot_defconfig b/configs/coreboot_defconfig index 7f979fb4b827..3d40a2c4aa91 100644 --- a/configs/coreboot_defconfig +++ b/configs/coreboot_defconfig @@ -1,5 +1,6 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0x1110000 +CONFIG_ENV_SIZE=0x1000 CONFIG_NR_DRAM_BANKS=8 CONFIG_PRE_CON_BUF_ADDR=0x100000 CONFIG_VENDOR_COREBOOT=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index e7df353ab613..2608e19898ad 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -42,6 +42,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g45-corvus" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BLK=y CONFIG_CLK=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 1eeecc17d0c9..d6e062d809fe 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -1,6 +1,9 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFE00000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x5FF000 CONFIG_NR_DRAM_BANKS=8 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_INTEL=y CONFIG_TARGET_COUGARCANYON2=y # CONFIG_HAVE_INTEL_ME is not set diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index e67622743ccd..32dd79bed065 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -1,7 +1,10 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 CONFIG_MAX_CPUS=2 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x0 CONFIG_NR_DRAM_BANKS=8 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_INTEL=y CONFIG_TARGET_CROWNBAY=y CONFIG_SMP=y diff --git a/configs/crs305-1g-4s_defconfig b/configs/crs305-1g-4s_defconfig index a04618177558..81f3d0accf44 100644 --- a/configs/crs305-1g-4s_defconfig +++ b/configs/crs305-1g-4s_defconfig @@ -4,6 +4,9 @@ CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CRS305_1G_4S=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_BUILD_TARGET="u-boot.kwb" CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index b4cf22c4d756..3c090a495f36 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NET2BIG_V2=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x70000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" D2 v2" CONFIG_SYS_EXTRA_OPTIONS="D2NET_V2" CONFIG_BOOTDELAY=3 @@ -36,6 +39,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-d2net" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 +CONFIG_ENV_ADDR=0x70000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 7c69d3b02485..1a9bf5253206 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -8,8 +8,11 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0x80000000 diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 26b12bfbb600..c8cdb2bd1736 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -6,7 +6,9 @@ CONFIG_TARGET_DA850EVM=y CONFIG_DA850_LOWLEVEL=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SYS_MALLOC_F_LEN=0x800 +CONFIG_ENV_SIZE=0x2800 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_EXTRA_OPTIONS="USE_NOR,DIRECT_NOR_BOOT" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -38,6 +40,7 @@ CONFIG_CMD_DIAG=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60100000 CONFIG_DM=y CONFIG_BLK=y CONFIG_DM_GPIO=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 54594b9bebdc..ae67a895c79c 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -8,6 +8,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 6952a06fecc0..7390c76b194e 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA114=y CONFIG_TARGET_DALMORE=y diff --git a/configs/db-88f6281-bp-nand_defconfig b/configs/db-88f6281-bp-nand_defconfig index e0c7deb6d3ef..aa5f512ae0d7 100644 --- a/configs/db-88f6281-bp-nand_defconfig +++ b/configs/db-88f6281-bp-nand_defconfig @@ -5,7 +5,10 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DB_88F6281_BP=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_IDENT_STRING="\nMarvell DB-88F6281-BP" # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 diff --git a/configs/db-88f6281-bp-spi_defconfig b/configs/db-88f6281-bp-spi_defconfig index 9ccf0a93d487..8fabea48f268 100644 --- a/configs/db-88f6281-bp-spi_defconfig +++ b/configs/db-88f6281-bp-spi_defconfig @@ -5,7 +5,10 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DB_88F6281_BP=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_IDENT_STRING="\nMarvell DB-88F6281-BP" # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index 8945777defcb..4a77535a1e9a 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -7,10 +7,13 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_DB_88F6720=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 29016b878ad5..acb46f802351 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -7,10 +7,13 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_DB_88F6820_AMC=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=200000000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index 65580497b747..586a2c213d97 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -7,10 +7,13 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_DB_88F6820_GP=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index f5e6244a9a87..ee2cc8ce0efc 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -7,10 +7,13 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_DB_MV784MP_GP=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y diff --git a/configs/db-xc3-24g4xg_defconfig b/configs/db-xc3-24g4xg_defconfig index 6da6ee04cd54..2c2cbd306ee9 100644 --- a/configs/db-xc3-24g4xg_defconfig +++ b/configs/db-xc3-24g4xg_defconfig @@ -4,6 +4,9 @@ CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_DB_XC3_24G4XG=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_BUILD_TARGET="u-boot.kwb" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index bca9d0efdee9..458bf37bd69b 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -7,6 +7,8 @@ CONFIG_SYS_TEXT_BASE=0x83F00000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xA0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00000000 diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index e7db1af630bd..fce877faa9cb 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -1,6 +1,9 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x6EF000 CONFIG_NR_DRAM_BANKS=8 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_DFI=y CONFIG_SMP=y CONFIG_HAVE_VGA_BIOS=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index f72bbe4afb15..90be467c0ddf 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -8,9 +8,12 @@ CONFIG_MX6_DDRCAL=y CONFIG_TARGET_DHCOMIMX6=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_ADDR=0x00900000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_AHCI=y @@ -46,6 +49,7 @@ CONFIG_OF_LIST="imx6q-dhcom-pdk2 imx6dl-dhcom-pdk2" CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x110000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DWC_AHSATA=y CONFIG_BOOTCOUNT_LIMIT=y diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 8fc864c6c138..af94dd503d70 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -9,11 +9,14 @@ CONFIG_MX6_DDRCAL=y CONFIG_TARGET_DISPLAY5=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x120000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_SYS_BOOTCOUNT_ADDR=0x020CC068 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0x00908000 @@ -69,6 +72,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-display5" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x130000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 5324b2a2c700..65214bb5204e 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -9,9 +9,12 @@ CONFIG_MX6_DDRCAL=y CONFIG_TARGET_DISPLAY5=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x120000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0x00908000 @@ -72,6 +75,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-display5" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x130000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index d66db090efb2..8971ee755143 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -3,7 +3,10 @@ CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_ADVANTECH_DMS_BA16=y CONFIG_SYS_DDR_1G=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index dcfa8fade18e..b9c4a8c282b0 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_ADVANTECH_DMS_BA16=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 6e95fb265e93..58993fd5ecb9 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DNS325=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nD-Link DNS-325" # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 18df663b7b63..5251264deba8 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DOCKSTAR=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nSeagate FreeAgent DockStar" CONFIG_BOOTDELAY=3 diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 759be2710212..713dcc1eab42 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -47,6 +47,7 @@ CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x280000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 07e66a590445..b0cdf41c27c5 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -50,6 +50,7 @@ CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x280000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 3154d61f75ff..6604953ea451 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -49,6 +49,7 @@ CONFIG_SPL_MULTI_DTB_FIT_UNCOMPRESS_SZ=0x9000 CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x280000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 08ba45d66f0a..46d4f41e6062 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -60,6 +60,7 @@ CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x2E0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index f6cedb47107f..d4a276ce1461 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_SNAPDRAGON=y CONFIG_SYS_TEXT_BASE=0x80080000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="\nQualcomm-DragonBoard 410C" CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/dragonboard820c_defconfig b/configs/dragonboard820c_defconfig index 00c154cbdd9a..a6b0495e742e 100644 --- a/configs/dragonboard820c_defconfig +++ b/configs/dragonboard820c_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SNAPDRAGON=y CONFIG_SYS_TEXT_BASE=0x80080000 +CONFIG_ENV_SIZE=0x4000 CONFIG_TARGET_DRAGONBOARD820C=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nQualcomm-DragonBoard 820C" diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index c421eacbe8ff..fa956f2df6f0 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DREAMPLUG=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="\nMarvell-DreamPlug" # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 @@ -27,6 +30,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dreamplug" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 +CONFIG_ENV_ADDR=0x100000 CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 3e69aaa7c459..24179906f376 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DS109=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x3D0000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 # CONFIG_SYS_MALLOC_F is not set CONFIG_USE_PREBOOT=y CONFIG_HUSH_PARSER=y @@ -22,6 +25,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ds109" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 +CONFIG_ENV_ADDR=0x3D0000 CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index bc0446d36de9..45fe489397b9 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -7,10 +7,13 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_DS414=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x7E0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y diff --git a/configs/durian_defconfig b/configs/durian_defconfig index 71e0e5165901..6da300b2176c 100644 --- a/configs/durian_defconfig +++ b/configs/durian_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARM_SMCCC=y CONFIG_TARGET_DURIAN=y CONFIG_SYS_TEXT_BASE=0x500000 +CONFIG_ENV_SIZE=0x1000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_PSCI_RESET is not set CONFIG_AHCI=y diff --git a/configs/e2220-1170_defconfig b/configs/e2220-1170_defconfig index c50598ace116..21edeed1569d 100644 --- a/configs/e2220-1170_defconfig +++ b/configs/e2220-1170_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA210=y CONFIG_OF_SYSTEM_SETUP=y diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index daaf83a94e81..2d9caec5f2f8 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xFF000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_EB_CPU5282=y CONFIG_SYS_EXTRA_OPTIONS="SYS_MONITOR_BASE=0xFF000400" CONFIG_BOOTDELAY=5 @@ -16,6 +18,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="eb_cpu5282" +CONFIG_ENV_ADDR=0xFF040000 CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=8 diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index 7bd0d30fb606..411cbc935e29 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -1,5 +1,7 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_EB_CPU5282=y CONFIG_SYS_EXTRA_OPTIONS="SYS_MONITOR_BASE=0xF0000418" CONFIG_BOOTDELAY=5 @@ -15,6 +17,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="eb_cpu5282_internal" +CONFIG_ENV_ADDR=0xFF040000 CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=8 diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index 3c506fdcdb2e..04dfcd4ac53b 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_EDB93XX=y CONFIG_SYS_TEXT_BASE=0x60000000 +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=8 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_EXTRA_OPTIONS="MK_edb9315a" CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs console=ttyAM0,115200 ip=dhcp" @@ -25,6 +27,8 @@ CONFIG_CMD_JFFS2=y # CONFIG_DOS_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0x60040000 +CONFIG_ENV_ADDR_REDUND=0x60060000 CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=0 diff --git a/configs/edison_defconfig b/configs/edison_defconfig index 510e640823c5..29bc96aa60ca 100644 --- a/configs/edison_defconfig +++ b/configs/edison_defconfig @@ -1,5 +1,7 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0x1101000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=3 CONFIG_VENDOR_INTEL=y CONFIG_TARGET_EDISON=y @@ -29,6 +31,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="edison" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x600000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_CPU=y CONFIG_DFU_MMC=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index 9630d15cb470..84d8bd0a41b4 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -6,8 +6,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_EDMINIV2=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_IDENT_STRING=" EDMiniV2" CONFIG_SPL_TEXT_BASE=0xffff0000 CONFIG_BOOTDELAY=3 @@ -26,6 +28,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_EXT2=y CONFIG_ISO_PARTITION=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFF84000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/efi-x86_app_defconfig b/configs/efi-x86_app_defconfig index cc1df1ff849c..790268a1ff9c 100644 --- a/configs/efi-x86_app_defconfig +++ b/configs/efi-x86_app_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_ENV_SIZE=0x1000 CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BASE=0 CONFIG_DEBUG_UART_CLOCK=0 diff --git a/configs/efi-x86_payload32_defconfig b/configs/efi-x86_payload32_defconfig index e8a517b0340a..cd6f39b5dbdf 100644 --- a/configs/efi-x86_payload32_defconfig +++ b/configs/efi-x86_payload32_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_ENV_SIZE=0x1000 CONFIG_NR_DRAM_BANKS=8 CONFIG_PRE_CON_BUF_ADDR=0x100000 CONFIG_VENDOR_EFI=y diff --git a/configs/efi-x86_payload64_defconfig b/configs/efi-x86_payload64_defconfig index 2b2e5de9a870..b86c9210a510 100644 --- a/configs/efi-x86_payload64_defconfig +++ b/configs/efi-x86_payload64_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_ENV_SIZE=0x1000 CONFIG_NR_DRAM_BANKS=8 CONFIG_PRE_CON_BUF_ADDR=0x100000 CONFIG_VENDOR_EFI=y diff --git a/configs/elgin-rv1108_defconfig b/configs/elgin-rv1108_defconfig index e539d87c9206..628ab19421d8 100644 --- a/configs/elgin-rv1108_defconfig +++ b/configs/elgin-rv1108_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x60000000 CONFIG_ROCKCHIP_RV1108=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_TARGET_ELGIN_RV1108=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0x10210000 diff --git a/configs/espresso7420_defconfig b/configs/espresso7420_defconfig index 1d2b023c1246..79d9e749f59b 100644 --- a/configs/espresso7420_defconfig +++ b/configs/espresso7420_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS7=y CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=8 CONFIG_IDENT_STRING=" for ESPRESSO7420" CONFIG_SILENT_CONSOLE=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index cd218a1017fd..8a669e113af3 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -61,6 +61,7 @@ CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xB80000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y diff --git a/configs/evb-ast2500_defconfig b/configs/evb-ast2500_defconfig index 06bf607eca46..b572f946c5fe 100644 --- a/configs/evb-ast2500_defconfig +++ b/configs/evb-ast2500_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x0 CONFIG_ASPEED_AST2500=y CONFIG_TARGET_EVB_AST2500=y CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_PRE_CON_BUF_ADDR=0x1e720000 CONFIG_USE_BOOTARGS=y diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index a8c708438cde..59125c0f812e 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -7,6 +7,7 @@ CONFIG_TPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_TPL_LDSCRIPT="arch/arm/mach-rockchip/u-boot-tpl-v8.lds" CONFIG_TARGET_EVB_PX5=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y diff --git a/configs/evb-rk3128_defconfig b/configs/evb-rk3128_defconfig index 21ecffc1607d..69167a5411ce 100644 --- a/configs/evb-rk3128_defconfig +++ b/configs/evb-rk3128_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x60000000 CONFIG_ROCKCHIP_RK3128=y +CONFIG_ENV_OFFSET=0x0 CONFIG_NR_DRAM_BANKS=2 CONFIG_DEBUG_UART_BASE=0x20068000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 5291ebd0c6c6..82cdc40008be 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -5,6 +5,7 @@ CONFIG_ROCKCHIP_RK322X=y CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x0 CONFIG_TARGET_EVB_RK3229=y CONFIG_TPL_LDSCRIPT="arch/arm/mach-rockchip/u-boot-tpl.lds" +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x60600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DEBUG_UART_BASE=0x11030000 diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index a5a60bce27a6..0711d2f0db92 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ROCKCHIP_RK3288=y CONFIG_TARGET_EVB_RK3288=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL_SIZE_LIMIT=0x4b000 diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index d051637020a1..4a06d33789a4 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -6,6 +6,7 @@ CONFIG_TPL_ROCKCHIP_COMMON_BOARD=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF130000 diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index caf83be19363..82e5d8196c63 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig index 69e3e0a0bc0f..6bb030acc161 100644 --- a/configs/ficus-rk3399_defconfig +++ b/configs/ficus-rk3399_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_TARGET_ROCK960_RK3399=y CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 62a8dcb7f85d..2a1689d263a1 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ROCKCHIP_RK3288=y CONFIG_TARGET_FIREFLY_RK3288=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL_SIZE_LIMIT=262144 diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index b531d212ddc0..b84d7b9ff0a5 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index 81c29714bd3b..1e1600851c4d 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_TARGET_FLEA3=y CONFIG_SYS_TEXT_BASE=0xA0000000 +CONFIG_ENV_SIZE=0x10000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 @@ -23,6 +25,8 @@ CONFIG_MTDIDS_DEFAULT="nand0=mxc_nand,nor0=physmap-flash.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand:50m(root1),32m(rootfb),64m(pcache),64m(app1),10m(app2),-(spool);physmap-flash.0:512k(u-boot),64k(env1),64k(env2),3776k(kernel1),3776k(kernel2)" CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xA0080000 +CONFIG_ENV_ADDR_REDUND=0xA0090000 CONFIG_MXC_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index ff243f72165e..bb1a01d70698 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -1,6 +1,9 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF10000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x0 CONFIG_NR_DRAM_BANKS=8 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_INTEL=y CONFIG_TARGET_GALILEO=y CONFIG_GENERATE_PIRQ_TABLE=y diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index cf20f4af6d1e..9a149a54b505 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -1,8 +1,11 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0xA0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ARCH_MTMIPS=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y @@ -41,6 +44,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="gardena-smart-gateway-mt7688" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xB0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 7c6b6572e0b3..45407d8387ac 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -1,8 +1,11 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9c000000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0xA0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ARCH_MTMIPS=y CONFIG_BOOT_ROM=y CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y @@ -44,6 +47,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="gardena-smart-gateway-mt7688" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xB0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/gazerbeam_defconfig b/configs/gazerbeam_defconfig index f7a6b1153b6c..1c71666d3579 100644 --- a/configs/gazerbeam_defconfig +++ b/configs/gazerbeam_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 CONFIG_SYS_MALLOC_F_LEN=0x600 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" gazerbeam 0.01" CONFIG_SYS_CLK_FREQ=33333333 CONFIG_MPC83xx=y @@ -141,6 +143,8 @@ CONFIG_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="gazerbeam" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE080000 +CONFIG_ENV_ADDR_REDUND=0xFE090000 CONFIG_DM=y CONFIG_REGMAP=y CONFIG_AXI=y diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index 13ab3a1980bd..68abf46d7afb 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -5,8 +5,11 @@ CONFIG_SYS_VPD_EEPROM_I2C_ADDR=0x50 CONFIG_SYS_VPD_EEPROM_I2C_BUS=4 CONFIG_SYS_VPD_EEPROM_SIZE=1024 CONFIG_TARGET_GE_BX50V3=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_BOOTCOUNT_ADDR=0x7000A000 +CONFIG_ENV_SECT_SIZE=0x10000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 5fa8b4d1f539..c7e116920405 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_GOFLEXHOME=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nSeagate GoFlex Home" # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 15a9c5c8f193..5983e4088e32 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -12,9 +12,12 @@ CONFIG_ARCH_RMOBILE_BOARD_STRING="Gose" CONFIG_R8A7793=y CONFIG_TARGET_GOSE=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0xe6300000 @@ -55,6 +58,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7793-gose-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xC0000 CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/gplugd_defconfig b/configs/gplugd_defconfig index b27c109c9dfd..d03f4143ea63 100644 --- a/configs/gplugd_defconfig +++ b/configs/gplugd_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_GPLUGD=y CONFIG_SYS_TEXT_BASE=0x00f00000 +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nMarvell-gplugD" CONFIG_BOOTDELAY=3 diff --git a/configs/grpeach_defconfig b/configs/grpeach_defconfig index 94b207b82636..b71fe9d9359a 100644 --- a/configs/grpeach_defconfig +++ b/configs/grpeach_defconfig @@ -3,7 +3,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_RMOBILE=y CONFIG_SYS_TEXT_BASE=0x18000000 CONFIG_RZA1=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_HUSH_PARSER=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index f94eeb42abe3..fa7e5ab149cf 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_GURUPLUG=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nMarvell-GuruPlug" # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index f659e892592f..b9876c87a493 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -9,6 +9,8 @@ CONFIG_CMD_EECONFIG=y CONFIG_CMD_GSC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xB1400 CONFIG_SPL_STACK_R_ADDR=0x18000000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y @@ -60,6 +62,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xD1400 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_DWC_AHSATA=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 1b2ee06be04a..eb1c125ae3e3 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -9,6 +9,8 @@ CONFIG_CMD_EECONFIG=y CONFIG_CMD_GSC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xB1400 CONFIG_SPL_STACK_R_ADDR=0x18000000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y @@ -60,6 +62,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xD1400 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_DWC_AHSATA=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 545d71bf2906..f4827b46c4ed 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -9,6 +9,8 @@ CONFIG_CMD_EECONFIG=y CONFIG_CMD_GSC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x1000000 CONFIG_SPL_STACK_R_ADDR=0x18000000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y @@ -63,6 +65,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x1080000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_DWC_AHSATA=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 412b070937ae..0ff1f2c7ea74 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x1FFE0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA20=y CONFIG_TARGET_HARMONY=y diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index b8c239b04cae..e38292e9d839 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -8,6 +8,8 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_HELIOS4=y CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index 68738107891c..02db8ca085b2 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_DCACHE_OFF=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_HIGHBANK=y CONFIG_SYS_TEXT_BASE=0x00008000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=0 CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_SYS_BOOTCOUNT_ADDR=0xfff3cf0c @@ -19,6 +20,7 @@ CONFIG_AUTOBOOT_KEYED_CTRLC=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_ENV_IS_IN_NVRAM=y +CONFIG_ENV_ADDR=0xFFF88000 CONFIG_SCSI_AHCI=y CONFIG_BOOTCOUNT_LIMIT=y # CONFIG_MMC is not set diff --git a/configs/hikey960_defconfig b/configs/hikey960_defconfig index 8a13aba8cc74..536201d6a0e1 100644 --- a/configs/hikey960_defconfig +++ b/configs/hikey960_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_HIKEY960=y CONFIG_SYS_TEXT_BASE=0x1ac98000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x1000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="\nHikey960" CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/hikey_defconfig b/configs/hikey_defconfig index 8c2b438ae6f0..b58829468b1d 100644 --- a/configs/hikey_defconfig +++ b/configs/hikey_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_SYS_TEXT_BASE=0x35000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x0 CONFIG_NR_DRAM_BANKS=6 CONFIG_IDENT_STRING="hikey" CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index bfbe37262505..dca59972cb1d 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" hrcon 0.01" CONFIG_SYS_CLK_FREQ=33333333 CONFIG_MPC83xx=y @@ -120,6 +122,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE060000 +CONFIG_ENV_ADDR_REDUND=0xFE070000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig index fdf8af9015e4..40de2f95f354 100644 --- a/configs/hrcon_dh_defconfig +++ b/configs/hrcon_dh_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" hrcon dh 0.01" CONFIG_SYS_CLK_FREQ=33333333 CONFIG_MPC83xx=y @@ -118,6 +120,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE060000 +CONFIG_ENV_ADDR_REDUND=0xFE070000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/huawei_hg556a_ram_defconfig b/configs/huawei_hg556a_ram_defconfig index 6e024e75cc4f..73f2f432776f 100644 --- a/configs/huawei_hg556a_ram_defconfig +++ b/configs/huawei_hg556a_ram_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6358=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 31498f662dc9..86c98fc08c39 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_IB62X0=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" RaidSonic ICY BOX IB-NAS62x0" CONFIG_BOOTDELAY=3 diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index dfd7955ade41..670a565c0cbf 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_ICONNECT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" Iomega iConnect" CONFIG_BOOTDELAY=3 diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 241763d1ca78..d34e1136bb13 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x20000 CONFIG_SYS_BOOTCOUNT_ADDR=0x9 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -148,6 +150,8 @@ CONFIG_MTDIDS_DEFAULT="nor0=ff800000.flash,nand0=e1000000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:7m(dum),768k(BOOT-BIN),128k(BOOT-ENV),128k(BOOT-REDENV);e1000000.flash:-(ubi)" CONFIG_CMD_UBI=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFFFC0000 +CONFIG_ENV_ADDR_REDUND=0xFFFE0000 CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_I2C=y # CONFIG_MMC is not set diff --git a/configs/imgtec_xilfpga_defconfig b/configs/imgtec_xilfpga_defconfig index c6228675dea0..61173e577f4f 100644 --- a/configs/imgtec_xilfpga_defconfig +++ b/configs/imgtec_xilfpga_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_MALLOC_F_LEN=0x600 +CONFIG_ENV_SIZE=0x4000 CONFIG_TARGET_XILFPGA=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index f919dd40272e..ba5333c8116a 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6Q_ENGICAM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y # CONFIG_CMD_BMODE is not set diff --git a/configs/imx6dl_mamoj_defconfig b/configs/imx6dl_mamoj_defconfig index bc896ede6b66..479922212435 100644 --- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_MX6DL_MAMOJ=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IMX_HAB=y # CONFIG_CMD_BMODE is not set diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index 223f9ded964e..c7bbae673915 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6Q_ENGICAM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y # CONFIG_CMD_BMODE is not set diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 8010eabe0757..a1e1e39ba4b4 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -8,6 +8,8 @@ CONFIG_MX6_OCRAM_256KB=y CONFIG_TARGET_MX6LOGICPD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x100000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 1d9c1fa9a91e..9f95edf6be76 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6Q_ENGICAM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0x021f0000 diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index e0ec3415dd28..f7dbbf76bb82 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6Q_ENGICAM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index 223f9ded964e..c7bbae673915 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6Q_ENGICAM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y # CONFIG_CMD_BMODE is not set diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index 788546fabf18..4538ffae0f05 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6Q_ENGICAM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 6fd1f1fad3bf..d3f72f0bbf97 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6UL_ENGICAM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index 1ee337858c96..056987eaffc0 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6UL_ENGICAM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y # CONFIG_CMD_BMODE is not set diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index 9a8904e42014..b8accfb49018 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6UL_ENGICAM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 264d28903282..3115a59752a1 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6UL_ENGICAM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y # CONFIG_CMD_BMODE is not set diff --git a/configs/imx8mm_evk_defconfig b/configs/imx8mm_evk_defconfig index 6161e341c350..87560ef989c8 100644 --- a/configs/imx8mm_evk_defconfig +++ b/configs/imx8mm_evk_defconfig @@ -11,6 +11,8 @@ CONFIG_TARGET_IMX8MM_EVK=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_FIT=y diff --git a/configs/imx8mn_ddr4_evk_defconfig b/configs/imx8mn_ddr4_evk_defconfig index d460ed9ba046..50b03d0763f5 100644 --- a/configs/imx8mn_ddr4_evk_defconfig +++ b/configs/imx8mn_ddr4_evk_defconfig @@ -11,6 +11,8 @@ CONFIG_TARGET_IMX8MN_EVK=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_SPL=y CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 CONFIG_SPL_TEXT_BASE=0x912000 diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index b1d51d538419..b5560d5ad1f9 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -5,6 +5,8 @@ CONFIG_ARCH_IMX8M=y CONFIG_SYS_TEXT_BASE=0x40200000 CONFIG_TARGET_IMX8MQ_EVK=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_SPL=y CONFIG_CSF_SIZE=0x2000 CONFIG_SPL_TEXT_BASE=0x7E1000 diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index 39cc507e9b95..2f7fe256357b 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -13,6 +13,8 @@ CONFIG_TARGET_IMX8QM_MEK=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_NR_DRAM_BANKS=3 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x100000 diff --git a/configs/imx8qm_rom7720_a1_4G_defconfig b/configs/imx8qm_rom7720_a1_4G_defconfig index 6646d16a5a14..ea019024ba46 100644 --- a/configs/imx8qm_rom7720_a1_4G_defconfig +++ b/configs/imx8qm_rom7720_a1_4G_defconfig @@ -11,6 +11,8 @@ CONFIG_TARGET_IMX8QM_ROM7720_A1=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_SPL=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index 6aff5b7405de..35699316de86 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -13,6 +13,8 @@ CONFIG_TARGET_IMX8QXP_MEK=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 CONFIG_NR_DRAM_BANKS=3 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x100000 diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 95dfa9c571e7..b05387c18b6d 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x70000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" IS v2" CONFIG_SYS_EXTRA_OPTIONS="INETSPACE_V2" CONFIG_BOOTDELAY=3 @@ -36,6 +39,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-is2" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 +CONFIG_ENV_ADDR=0x70000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index f0bf27b997a4..f5f9cb28b38c 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM720T=y +CONFIG_ENV_SIZE=0x8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAM0 console=tty" diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index 1759351bf232..8a0ad1f94813 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM920T=y +CONFIG_ENV_SIZE=0x8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAM0 console=tty" diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index 4a8b44b4b5bd..ab61bf2ef465 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM926EJ_S=y +CONFIG_ENV_SIZE=0x8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAM0 console=tty" diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index f02059fbf6d7..7af54331610a 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM946ES=y +CONFIG_ENV_SIZE=0x8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAM0 console=tty" diff --git a/configs/integratorcp_cm1136_defconfig b/configs/integratorcp_cm1136_defconfig index 1b3d067ce6a0..f2d7f9df6ef2 100644 --- a/configs/integratorcp_cm1136_defconfig +++ b/configs/integratorcp_cm1136_defconfig @@ -3,7 +3,9 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM1136=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAMA0 console=tty ip=dhcp netdev=27,0,0xfc800000,0xfc800010,eth0 video=clcdfb:0" CONFIG_MISC_INIT_R=y @@ -16,6 +18,7 @@ CONFIG_SYS_PROMPT="Integrator-CP # " CONFIG_CMD_IMLS=y CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_ADDR=0x24F00000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/integratorcp_cm920t_defconfig b/configs/integratorcp_cm920t_defconfig index 847196e1cf51..e133ab1361b9 100644 --- a/configs/integratorcp_cm920t_defconfig +++ b/configs/integratorcp_cm920t_defconfig @@ -3,7 +3,9 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM920T=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAMA0 console=tty ip=dhcp netdev=27,0,0xfc800000,0xfc800010,eth0 video=clcdfb:0" CONFIG_MISC_INIT_R=y @@ -16,6 +18,7 @@ CONFIG_SYS_PROMPT="Integrator-CP # " CONFIG_CMD_IMLS=y CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_ADDR=0x24F00000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/integratorcp_cm926ejs_defconfig b/configs/integratorcp_cm926ejs_defconfig index b3a1bcba3cae..f5a840d09c23 100644 --- a/configs/integratorcp_cm926ejs_defconfig +++ b/configs/integratorcp_cm926ejs_defconfig @@ -3,7 +3,9 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM926EJ_S=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAMA0 console=tty ip=dhcp netdev=27,0,0xfc800000,0xfc800010,eth0 video=clcdfb:0" CONFIG_MISC_INIT_R=y @@ -16,6 +18,7 @@ CONFIG_SYS_PROMPT="Integrator-CP # " CONFIG_CMD_IMLS=y CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_ADDR=0x24F00000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/integratorcp_cm946es_defconfig b/configs/integratorcp_cm946es_defconfig index cadf5e8915c2..b3a33d9b6255 100644 --- a/configs/integratorcp_cm946es_defconfig +++ b/configs/integratorcp_cm946es_defconfig @@ -3,7 +3,9 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM946ES=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAMA0 console=tty ip=dhcp netdev=27,0,0xfc800000,0xfc800010,eth0 video=clcdfb:0" CONFIG_MISC_INIT_R=y @@ -16,6 +18,7 @@ CONFIG_SYS_PROMPT="Integrator-CP # " CONFIG_CMD_IMLS=y CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_ADDR=0x24F00000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 3e3e924bc3b2..2112ce813be9 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -8,6 +8,7 @@ CONFIG_TARGET_J721E_A72_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL_FS_FAT=y diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index b92a850c598e..62b959461def 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -9,6 +9,7 @@ CONFIG_TARGET_J721E_R5_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index 8b6d9c94402e..874e90e8479b 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA124=y CONFIG_TARGET_JETSON_TK1=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 4565899cb7ef..bb0acc6cdda5 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_K2E_EVM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index b20427e53500..d660a68b16e0 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -7,6 +7,8 @@ CONFIG_ISW_ENTRY_ADDR=0xC100000 CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_TARGET_K2E_EVM=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 58274e8e7467..159d772c1fac 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_K2G_EVM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 27cb905938c2..c30058fb61dc 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -7,6 +7,7 @@ CONFIG_ISW_ENTRY_ADDR=0xC0A0000 CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_TARGET_K2G_EVM=y +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index fbb1a9ed3ee0..cab702ef35b6 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_K2HK_EVM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index dd826ba36549..48e400708787 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -7,6 +7,8 @@ CONFIG_ISW_ENTRY_ADDR=0xC200000 CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_TARGET_K2HK_EVM=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index c74897f5d320..8054f514d7aa 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_K2L_EVM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index f12a7b7885c3..b80d7e737dea 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -7,6 +7,8 @@ CONFIG_ISW_ENTRY_ADDR=0xC100000 CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_TARGET_K2L_EVM=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/khadas-edge-captain-rk3399_defconfig b/configs/khadas-edge-captain-rk3399_defconfig index 7f016da37741..c408a1a59b30 100644 --- a/configs/khadas-edge-captain-rk3399_defconfig +++ b/configs/khadas-edge-captain-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/khadas-edge-rk3399_defconfig b/configs/khadas-edge-rk3399_defconfig index 9d32183d2a1c..796f94f8d721 100644 --- a/configs/khadas-edge-rk3399_defconfig +++ b/configs/khadas-edge-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/khadas-edge-v-rk3399_defconfig b/configs/khadas-edge-v-rk3399_defconfig index 3433573e7cd5..e70e1ec2e685 100644 --- a/configs/khadas-edge-v-rk3399_defconfig +++ b/configs/khadas-edge-v-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/khadas-vim2_defconfig b/configs/khadas-vim2_defconfig index a7f106a13420..cc9935d03882 100644 --- a/configs/khadas-vim2_defconfig +++ b/configs/khadas-vim2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_MESON_GXM=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xc81004c0 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/khadas-vim3_defconfig b/configs/khadas-vim3_defconfig index d2e09e8f73c0..17d5a900fc7b 100644 --- a/configs/khadas-vim3_defconfig +++ b/configs/khadas-vim3_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_BOARD="w400" CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_MESON_G12A=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff803000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/khadas-vim_defconfig b/configs/khadas-vim_defconfig index dda47c79370b..9b0ac8fad88a 100644 --- a/configs/khadas-vim_defconfig +++ b/configs/khadas-vim_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_MESON_GXL=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xc81004c0 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index 39e6f8d1718d..73b4054dcc83 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_IDENT_STRING="\nKeymile Kirkwood 128M16" CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_128M16" CONFIG_MISC_INIT_R=y @@ -32,6 +34,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_EEPROM=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x2000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index 8100243e5839..ea8af60fa56f 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_IDENT_STRING="\nKeymile Kirkwood" CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD" CONFIG_MISC_INIT_R=y @@ -32,6 +34,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_EEPROM=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x2000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index f01cb3cdb4aa..1927fb47f231 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -5,6 +5,8 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_IDENT_STRING="\nKeymile Kirkwood PCI" CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_PCI" CONFIG_MISC_INIT_R=y @@ -33,6 +35,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_EEPROM=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x2000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index 587d761620ca..ad2de2cd62c0 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -1,6 +1,9 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff40000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SYS_BOOTCOUNT_ADDR=0xFB000020 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MPC85xx=y CONFIG_TARGET_KMP204X=y CONFIG_FIT=y @@ -37,6 +40,7 @@ CONFIG_CMD_UBI=y CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x110000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index edd9af9adbb7..0d41396c250b 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE011BFF8 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -178,6 +180,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xF00C0000 +CONFIG_ENV_ADDR_REDUND=0xF00E0000 CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index d0071fb6c56d..ff23af3060be 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -7,6 +7,9 @@ CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_PIGGY_MAC_ADRESS_OFFSET=3 CONFIG_KM_ENV_IS_IN_SPI_NOR=y CONFIG_KM_PIGGY4_88E6352=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="\nKeymile COGE5UN" CONFIG_SYS_EXTRA_OPTIONS="KM_COGE5UN" CONFIG_MISC_INIT_R=y @@ -35,6 +38,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xD0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index eb598b8ccca1..4d9f41202085 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE011BFF8 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -141,6 +143,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xF00C0000 +CONFIG_ENV_ADDR_REDUND=0xF00E0000 CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index b62869c6bda1..0b5a0e4e2249 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -7,6 +7,9 @@ CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y CONFIG_KM_ENV_IS_IN_SPI_NOR=y CONFIG_KM_PIGGY4_88E6352=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="\nKeymile NUSA" CONFIG_SYS_EXTRA_OPTIONS="KM_NUSA" CONFIG_MISC_INIT_R=y @@ -35,6 +38,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xD0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index c33b25660813..80af10558485 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -161,6 +163,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xF00C0000 +CONFIG_ENV_ADDR_REDUND=0xF00E0000 CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index a72fd9cac107..3afde51f8dd9 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -7,6 +7,9 @@ CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y CONFIG_KM_ENV_IS_IN_SPI_NOR=y CONFIG_KM_PIGGY4_88E6352=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="\nKeymile SUGP1" CONFIG_SYS_EXTRA_OPTIONS="KM_SUGP1" CONFIG_MISC_INIT_R=y @@ -35,6 +38,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xD0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index 2f7cca59527f..4e58aed96ab9 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -141,6 +143,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xF00C0000 +CONFIG_ENV_ADDR_REDUND=0xF00E0000 CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index 633cf83c919d..632e5dfa822b 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -6,6 +6,9 @@ CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y CONFIG_KM_ENV_IS_IN_SPI_NOR=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="\nKeymile SUV31" CONFIG_SYS_EXTRA_OPTIONS="KM_SUV31" CONFIG_MISC_INIT_R=y @@ -34,6 +37,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xD0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index d8a84658dc92..9cf0cde923ac 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -142,6 +144,8 @@ CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xF0100000 +CONFIG_ENV_ADDR_REDUND=0xF0120000 CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index 8e838eac0944..d84da2d34b01 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -161,6 +163,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xF00C0000 +CONFIG_ENV_ADDR_REDUND=0xF00E0000 CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 393a1c680aad..34ef807adf23 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -12,9 +12,12 @@ CONFIG_ARCH_RMOBILE_BOARD_STRING="Koelsch" CONFIG_R8A7791=y CONFIG_TARGET_KOELSCH=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0xe6300000 @@ -55,6 +58,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7791-koelsch-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xC0000 CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/kp_imx53_defconfig b/configs/kp_imx53_defconfig index 3171c3022eb4..931726b34b93 100644 --- a/configs/kp_imx53_defconfig +++ b/configs/kp_imx53_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX5=y CONFIG_SYS_TEXT_BASE=0x77800000 CONFIG_TARGET_KP_IMX53=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_FIT=y @@ -30,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx53-kp" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x102000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0x1 diff --git a/configs/kp_imx6q_tpc_defconfig b/configs/kp_imx6q_tpc_defconfig index b956a1903f27..ed047f26c401 100644 --- a/configs/kp_imx6q_tpc_defconfig +++ b/configs/kp_imx6q_tpc_defconfig @@ -9,6 +9,8 @@ CONFIG_MX6_DDRCAL=y CONFIG_TARGET_KP_IMX6Q_TPC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00908000 @@ -43,6 +45,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-kp" CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents interrupts dmas dma-names" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x102000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_BLOCK_CACHE is not set CONFIG_SPL_CLK_IMX6Q=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index b16d38938fae..d05906ed2d30 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x60000000 CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ROCKCHIP_RK3036=y CONFIG_TARGET_KYLIN_RK3036=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x0 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index 94f77cf733bf..32f23fa843f2 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -5,7 +5,9 @@ CONFIG_ARCH_RMOBILE=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_ARCH_RMOBILE_BOARD_STRING="KMC KZM-A9-GT" CONFIG_TARGET_KZM9G=y +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/null console=ttySC4,115200" @@ -21,6 +23,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x40000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index c3a96471f4b3..1be6df22e924 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -12,9 +12,12 @@ CONFIG_ARCH_RMOBILE_BOARD_STRING="Lager" CONFIG_R8A7790=y CONFIG_TARGET_LAGER=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0xe6300000 @@ -55,6 +58,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7790-lager-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xC0000 CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/leez-rk3399_defconfig b/configs/leez-rk3399_defconfig index 616c74495b91..3758d79a1e68 100644 --- a/configs/leez-rk3399_defconfig +++ b/configs/leez-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 5e3c42f9ebfb..4349ad6afeec 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_SYS_TEXT_BASE=0xc1080000 CONFIG_TARGET_LEGOEV3=y +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTDELAY=0 CONFIG_VERSION_VARIABLE=y diff --git a/configs/libretech-ac_defconfig b/configs/libretech-ac_defconfig index cef07e021117..7e9f02aaa1bc 100644 --- a/configs/libretech-ac_defconfig +++ b/configs/libretech-ac_defconfig @@ -3,9 +3,12 @@ CONFIG_SYS_CONFIG_NAME="libretech-ac" CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_MESON_GXL=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFF0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xc81004c0 CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" libretech-ac" CONFIG_DEBUG_UART=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/libretech-cc_defconfig b/configs/libretech-cc_defconfig index 36d65d9f94e6..8976d7f1f4a8 100644 --- a/configs/libretech-cc_defconfig +++ b/configs/libretech-cc_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_MESON_GXL=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xc81004c0 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig index 43c916f1e965..4aff34faed15 100644 --- a/configs/linkit-smart-7688-ram_defconfig +++ b/configs/linkit-smart-7688-ram_defconfig @@ -1,6 +1,9 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_LINKIT_SMART_7688=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index fca86f9c25ff..1ecd4dfb5f03 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -1,6 +1,9 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9c000000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_LINKIT_SMART_7688=y CONFIG_BOOT_ROM=y diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index deb71032e341..ec5c576ce035 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -6,6 +6,7 @@ CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x0 CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y diff --git a/configs/liteboard_defconfig b/configs/liteboard_defconfig index 6f891c7e92f2..4d2e491f6b1d 100644 --- a/configs/liteboard_defconfig +++ b/configs/liteboard_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_LITEBOARD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00908000 diff --git a/configs/ls1012a2g5rdb_qspi_defconfig b/configs/ls1012a2g5rdb_qspi_defconfig index 463f48cf8d1f..710df14c74f9 100644 --- a/configs/ls1012a2g5rdb_qspi_defconfig +++ b/configs/ls1012a2g5rdb_qspi_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1012A2G5RDB=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/ls1012a2g5rdb_tfa_defconfig b/configs/ls1012a2g5rdb_tfa_defconfig index eeffa9a07612..cafd942d998d 100644 --- a/configs/ls1012a2g5rdb_tfa_defconfig +++ b/configs/ls1012a2g5rdb_tfa_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1012A2G5RDB=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y diff --git a/configs/ls1012afrdm_qspi_defconfig b/configs/ls1012afrdm_qspi_defconfig index ef167642866c..541d7b9e89ad 100644 --- a/configs/ls1012afrdm_qspi_defconfig +++ b/configs/ls1012afrdm_qspi_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1012AFRDM=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012afrdm_tfa_defconfig b/configs/ls1012afrdm_tfa_defconfig index e6d724547add..90ad5aaf2a5e 100644 --- a/configs/ls1012afrdm_tfa_defconfig +++ b/configs/ls1012afrdm_tfa_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1012AFRDM=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig index 8eb25434be2d..131b3a00e3a8 100644 --- a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1012AFRWY=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_NXP_ESBC=y CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x10000 CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012afrwy_qspi_defconfig b/configs/ls1012afrwy_qspi_defconfig index 312c655569db..5cd45156cd50 100644 --- a/configs/ls1012afrwy_qspi_defconfig +++ b/configs/ls1012afrwy_qspi_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AFRWY=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x1D0000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set @@ -27,6 +30,7 @@ CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x401D0000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig index ff8758434a39..e64214052e7f 100644 --- a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1012AFRWY=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x10000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/ls1012afrwy_tfa_defconfig b/configs/ls1012afrwy_tfa_defconfig index 0a6d5c6d9f95..aae6fcac8cfe 100644 --- a/configs/ls1012afrwy_tfa_defconfig +++ b/configs/ls1012afrwy_tfa_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AFRWY=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x1D0000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -27,6 +30,7 @@ CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x401D0000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 29cb61163b53..c73878af0a2d 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1012AQDS=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig index b032289ac6e2..e5500e1ecb46 100644 --- a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_NXP_ESBC=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/ls1012aqds_tfa_defconfig b/configs/ls1012aqds_tfa_defconfig index 8bf7c2c1b9e4..99e3b65f51c5 100644 --- a/configs/ls1012aqds_tfa_defconfig +++ b/configs/ls1012aqds_tfa_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1012AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y diff --git a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig index c7f2780bf591..3cb4e9585f07 100644 --- a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_NXP_ESBC=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index b755a29c29b8..0b98d9ec38cb 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1012ARDB=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set @@ -29,6 +32,7 @@ CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-rdb" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x40300000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig index 6001e193f0cb..ca855a1494de 100644 --- a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_NXP_ESBC=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/ls1012ardb_tfa_defconfig b/configs/ls1012ardb_tfa_defconfig index ce10c736e707..4c57430c0a94 100644 --- a/configs/ls1012ardb_tfa_defconfig +++ b/configs/ls1012ardb_tfa_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1012ARDB=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -29,6 +32,7 @@ CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-rdb" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x40500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index f3be6c7bdf7a..842087661e33 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -1,7 +1,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AIOT=y CONFIG_SYS_TEXT_BASE=0x40010000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_AHCI=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_MISC_INIT_R=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index 073e20f2d08e..55a17f080d64 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AIOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 61855e9b7c81..ec67e9d86858 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -33,6 +35,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 213f2dfb5bf9..51aada33c7da 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -34,6 +36,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index e761a7d8a168..a7f3fd15f0c4 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x140000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 8dcd414c153f..3e28fc11d61c 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 7f42e51263a5..7483b7121056 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -33,6 +35,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index b67c24cf6460..09aba6e3a188 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -34,6 +36,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index c50f6488788c..6dfde1ad3ce9 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -1,7 +1,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x40100000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 417519b9c9a1..b005affa14a9 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 0de4a3a8ef04..811694f5cd2e 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1021atsn_qspi_defconfig b/configs/ls1021atsn_qspi_defconfig index 129a2927e919..add2c8b390a3 100644 --- a/configs/ls1021atsn_qspi_defconfig +++ b/configs/ls1021atsn_qspi_defconfig @@ -1,7 +1,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATSN=y CONFIG_SYS_TEXT_BASE=0x40100000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/ls1021atsn_sdcard_defconfig b/configs/ls1021atsn_sdcard_defconfig index df9eac2e1113..75b9af9ee175 100644 --- a/configs/ls1021atsn_sdcard_defconfig +++ b/configs/ls1021atsn_sdcard_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 07708362080b..beb5ad9eed9a 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index a5aaa9a35088..1032f15bb7cf 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y @@ -28,6 +30,7 @@ CONFIG_CMD_BMP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index fe0f6c40525d..ed77989e7713 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y @@ -30,6 +32,7 @@ CONFIG_CMD_BMP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-lpuart" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index f36f0a2698b0..77a144b34b83 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -1,7 +1,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x40100000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 44713a2968de..2098a7fbfd52 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_NXP_ESBC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x10000000 diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 2ddc40e7613b..18ff9fac3526 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 1b8cb3eb0d4b..74ab1225de15 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig index e2fed911b106..b14dc5990a10 100644 --- a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TFABOOT=y CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_NXP_ESBC=y CONFIG_SYS_FSL_SDHC_CLK_DIV=1 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/ls1028aqds_tfa_defconfig b/configs/ls1028aqds_tfa_defconfig index 67c9a82bcd6a..1875c0a3ebf3 100644 --- a/configs/ls1028aqds_tfa_defconfig +++ b/configs/ls1028aqds_tfa_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1028AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_SYS_FSL_SDHC_CLK_DIV=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -27,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1028a-qds" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y diff --git a/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig index 6b87c57ec332..a8e878f3566b 100644 --- a/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TFABOOT=y CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_NXP_ESBC=y CONFIG_SYS_FSL_SDHC_CLK_DIV=1 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index 1fd38ca3d482..e01bf2e1252e 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1028ARDB=y CONFIG_TFABOOT=y CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_SYS_FSL_SDHC_CLK_DIV=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -27,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1028a-rdb" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 65b2dd18f94f..d0d384d7cee3 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y @@ -29,6 +31,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 51fc761f459c..ec1712be9470 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y @@ -30,6 +32,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-lpuart" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index c3baaf5cc95d..6b3bd428877e 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 65734f5cda7a..6a4fc87e0788 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y @@ -29,6 +31,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index c4d7c45a1cbb..36e6f4cce48e 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043AQDS=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index c4a7932e4d7d..03cae8ab2027 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -7,6 +7,8 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index a7de15c8c6c7..3ee00a87eb27 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -7,6 +7,8 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index 9883d1683d7e..b3102ab6c18f 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1043AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index b49ac2cb5d0c..e0e35e77af40 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -36,6 +39,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_BUS=y CONFIG_ENV_SPI_BUS=0 +CONFIG_ENV_ADDR=0x60500000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 0d9d2dd490af..99599a82deba 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1043ARDB=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NXP_ESBC=y CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 49d498ae80e2..0ca215f57d82 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043ARDB=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -23,6 +25,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 07e29df443a5..b14f538d8d7e 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_NXP_ESBC=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x10000000 diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 423080605c3b..fd4208216e06 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x10000000 diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 5d54b03bcfba..3ab6c9eab380 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x10000000 diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index c201513858b7..a0ffcbd73496 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -7,6 +7,8 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x10000000 diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index 187d493336dd..af6a40b2a505 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1043ARDB=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index 75bb52ad4ad8..d64f40586324 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043ARDB=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_DISTRO_DEFAULTS=y @@ -27,6 +30,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_ENV_ADDR=0x60500000 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig index 3cabb52ef012..0a7ff78f2404 100644 --- a/configs/ls1046afrwy_tfa_defconfig +++ b/configs/ls1046afrwy_tfa_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1046AFRWY=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -27,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-frwy" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x40500000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index c39b880456a2..146457a60853 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1046AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NXP_ESBC=y CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index d82d786be28f..5f962804eaa1 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1046AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y @@ -29,6 +31,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index d3fb8077ef8e..2b212b401442 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1046AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y @@ -30,6 +32,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-lpuart" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index ee0b8fd99737..02ebb7f51be5 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -3,6 +3,8 @@ CONFIG_TARGET_LS1046AQDS=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_FSL_LS_PPA=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index 602c31612cc6..7339aba903ea 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1046AQDS=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 6d5220850370..b1dad99ba29b 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -7,6 +7,8 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index 3a169d35cf60..88ed9b2aff9c 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -7,6 +7,8 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index a8a260fb0b58..d4c6b549c0b4 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1046AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 9033f424f9c9..3b6e561aa4a1 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1046AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -36,6 +39,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_BUS=y CONFIG_ENV_SPI_BUS=0 +CONFIG_ENV_ADDR=0x60500000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 2f921f744584..7df296833ab1 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -7,6 +7,8 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index 0afd2821a055..92a4d506f6cf 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_NXP_ESBC=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index 89217320f7f0..391b2d06dbea 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1046ARDB=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index ba851b37a13b..62edfb111a3e 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -8,8 +8,11 @@ CONFIG_SPL_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index da683c230b17..b10094530228 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x10000000 diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 5a647f29b99e..4d0b04afc75a 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -7,6 +7,8 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig index b6d22fa75a3a..534b0f6ac545 100644 --- a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_NXP_ESBC=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index d183cf74acb5..265e1a0a7a2e 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1046ARDB=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -27,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x40500000 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index 56af5261e384..2cd10b80f7c4 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1088AQDS=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -26,6 +28,7 @@ CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x80300000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index 40163a4af1e2..e34f215c3d1d 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_NXP_ESBC=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 8051e89796ba..087d2cb2232c 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1088AQDS=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set @@ -26,6 +29,7 @@ CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20300000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index ccbdafa06253..8f13526fbf41 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -7,6 +7,8 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index d6990b799579..25503aa236e1 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -7,6 +7,8 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 22bf8b849eee..dd25f6c200ca 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -4,7 +4,10 @@ CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -31,6 +34,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x80500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y diff --git a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig index 0658b4f1ebd6..0f668aed83b5 100644 --- a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_NXP_ESBC=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index b3582e33a73e..33bec3042aef 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS1088ARDB=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set @@ -27,6 +30,7 @@ CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20300000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index 267dad3c5d23..f41158a3f0e8 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x1800a000 diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 0d3668c74b7e..73196d2aa922 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -7,6 +7,8 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig index e4c61dc82e0d..c5b803e6f2f1 100644 --- a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_NXP_ESBC=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig index 53882dd331d3..9c8a719c29b2 100644 --- a/configs/ls1088ardb_tfa_defconfig +++ b/configs/ls1088ardb_tfa_defconfig @@ -4,7 +4,10 @@ CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -30,6 +33,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x80500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig index f5835e9aca88..7927e3838fd5 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2080a_emu_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080A_EMU=y CONFIG_SYS_TEXT_BASE=0x30100000 +CONFIG_ENV_SIZE=0x1000 CONFIG_NR_DRAM_BANKS=3 CONFIG_IDENT_STRING=" LS2080A-EMU" CONFIG_FIT=y diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index c4ee87e62e5b..1845236cc33f 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080A_SIMU=y CONFIG_SYS_TEXT_BASE=0x30100000 +CONFIG_ENV_SIZE=0x1000 CONFIG_NR_DRAM_BANKS=3 CONFIG_IDENT_STRING=" LS2080A-SIMU" CONFIG_FIT=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 81169bf20fe9..197c796377fe 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080AQDS=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_NXP_ESBC=y CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=3 CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index d2b545f0dee2..de0c3d1d778b 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080AQDS=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=3 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -29,6 +31,7 @@ CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x80300000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 21a087eb3209..17777543872f 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_NR_DRAM_BANKS=3 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 47d0e7b7ca58..ac0a18da1ab5 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -1,7 +1,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080AQDS=y CONFIG_SYS_TEXT_BASE=0x20100000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=3 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index 0280705075b7..dca47b5daad3 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -7,6 +7,8 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=3 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 99f3dd2bf3ad..d231c235f023 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_NXP_ESBC=y CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=3 CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index 7943d91e6c54..484030495506 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_FSL_LS_PPA=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=3 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -29,6 +31,7 @@ CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x80300000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 5dd652269131..49bdd587ac84 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -5,6 +5,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x200000 CONFIG_NR_DRAM_BANKS=3 CONFIG_SPL=y CONFIG_AHCI=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index 35fcedf4c0d3..01288a7be7f3 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS2081ARDB=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=3 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index 2c8f08cf4c7f..f0ef704309ee 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=3 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -32,6 +35,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x80500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig index d8059ef0357f..8894df5d31b0 100644 --- a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_NXP_ESBC=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=3 CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index 1063ef0f69ae..d230000e1925 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -3,7 +3,10 @@ CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=3 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index 88f2ce14e387..db253d1ce957 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_NXP_ESBC=y CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 9fed7935bfd4..1730c9a5eab1 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -4,7 +4,10 @@ CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_QSPI_AHB_INIT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=3 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -33,6 +36,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x80500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index afd64288ac1e..35190cf632fa 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_LSXL=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x70000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" LS-CHLv2" CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index f3f368d99dea..74004fb29514 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_LSXL=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x70000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" LS-XHL" CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="LSXHL" diff --git a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig index 5c6a0b5af017..4ab7582fc7b9 100644 --- a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/lx2160aqds_tfa_defconfig b/configs/lx2160aqds_tfa_defconfig index f50bc027cb3b..a35f1cc38d5e 100644 --- a/configs/lx2160aqds_tfa_defconfig +++ b/configs/lx2160aqds_tfa_defconfig @@ -3,6 +3,8 @@ CONFIG_TARGET_LX2160AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig index 2e2d888009d7..87c54b00f670 100644 --- a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_NXP_ESBC=y CONFIG_EMC2305=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index 632b52e548bd..18057b20b19a 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -4,6 +4,8 @@ CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_EMC2305=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 0a2cb4eb3550..5401cc945492 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_TARGET_M53MENLO=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y @@ -57,6 +59,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx53-m53menlo" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index 10d2e55f5acf..e5a19a6e546e 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xFFFFFFFFBE000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_MALTA=y CONFIG_CPU_MIPS64_R2=y CONFIG_MISC_INIT_R=y @@ -20,6 +22,7 @@ CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFFFFFFBE3E0000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index 6759d1817642..e9de5bea6e1f 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xFFFFFFFFBE000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_MALTA=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_CPU_MIPS64_R2=y @@ -21,6 +23,7 @@ CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFFFFFFBE3E0000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/malta_defconfig b/configs/malta_defconfig index 6b6869dce6d1..2b43818c81ff 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xBE000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_MALTA=y CONFIG_MISC_INIT_R=y CONFIG_BOARD_EARLY_INIT_F=y @@ -19,6 +21,7 @@ CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xBE3E0000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index 8dca7ff32f76..ec984b5a356e 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xBE000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_MALTA=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_MISC_INIT_R=y @@ -20,6 +22,7 @@ CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xBE3E0000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index e80af16a56d7..25e52b487e51 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_EMBESTMX6BOARDS=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" CONFIG_BOOTCOMMAND="run finduuid; run distro_bootcmd" diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index c3f690563f38..a75c4b3f6bf9 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -7,10 +7,13 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_MAXBCM=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index d46c996709d9..c92d50ff21d2 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -5,8 +5,10 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MCCMON6=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x20000 # CONFIG_CMD_BMODE is not set CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_DISTRO_DEFAULTS=y @@ -40,6 +42,8 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-mccmon6" CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0x8040000 +CONFIG_ENV_ADDR_REDUND=0x8060000 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_SYS_I2C_MXC=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 196c7b3f99c7..dc159942fc4c 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -6,8 +6,10 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MCCMON6=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x20000 # CONFIG_CMD_BMODE is not set CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_DISTRO_DEFAULTS=y @@ -38,6 +40,8 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-mccmon6" CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0x8040000 +CONFIG_ENV_ADDR_REDUND=0x8060000 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_SYS_I2C_MXC=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index 74d4377f88e3..0117f87dd5be 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x1FFE0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA20=y CONFIG_TARGET_MEDCOM_WIDE=y diff --git a/configs/meerkat96_defconfig b/configs/meerkat96_defconfig index fab1b41be092..537edb1f41a4 100644 --- a/configs/meerkat96_defconfig +++ b/configs/meerkat96_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_MX7=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_MEERKAT96=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARMV7_BOOT_SEC_DEFAULT=y # CONFIG_ARMV7_VIRT is not set diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index 944180631c82..cae6645832e6 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -6,6 +6,8 @@ CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_PIGGY_MAC_ADRESS_OFFSET=3 CONFIG_KM_PIGGY4_88E6061=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_IDENT_STRING="\nKeymile COGE3UN" CONFIG_SYS_EXTRA_OPTIONS="KM_MGCOGE3UN" CONFIG_MISC_INIT_R=y @@ -34,6 +36,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_EEPROM=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x2000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 7d2859c5c376..3e6698682208 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_TEXT_BASE=0x29000000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_TARGET_MICROBLAZE_GENERIC=y diff --git a/configs/microchip_mpfs_icicle_defconfig b/configs/microchip_mpfs_icicle_defconfig index 3c54877fa4f7..0bc1cc2de023 100644 --- a/configs/microchip_mpfs_icicle_defconfig +++ b/configs/microchip_mpfs_icicle_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_ENV_SIZE=0x2000 CONFIG_TARGET_MICROCHIP_ICICLE=y CONFIG_ARCH_RV64I=y CONFIG_NR_CPUS=5 diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 724240f7e87f..4280fb96458e 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -1,8 +1,11 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x6EF000 CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_INTEL=y CONFIG_TARGET_MINNOWMAX=y CONFIG_INTERNAL_UART=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index b4d213d70c5d..76622a8bb904 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_ROCKCHIP_RK3288=y CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_MIQI_RK3288=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff690000 diff --git a/configs/mpc8308_p1m_defconfig b/configs/mpc8308_p1m_defconfig index 68d20b1f55f5..7dd8808b41ee 100644 --- a/configs/mpc8308_p1m_defconfig +++ b/configs/mpc8308_p1m_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFC000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=33333333 CONFIG_MPC83xx=y CONFIG_TARGET_MPC8308_P1M=y @@ -108,6 +110,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFC060000 +CONFIG_ENV_ADDR_REDUND=0xFC080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/mscc_jr2_defconfig b/configs/mscc_jr2_defconfig index 42331eafb2e7..04d5256f5dbe 100644 --- a/configs/mscc_jr2_defconfig +++ b/configs/mscc_jr2_defconfig @@ -1,9 +1,12 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x40000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x70100000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARCH_MSCC=y CONFIG_SOC_JR2=y CONFIG_SYS_LITTLE_ENDIAN=y @@ -41,6 +44,7 @@ CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x140000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y diff --git a/configs/mscc_luton_defconfig b/configs/mscc_luton_defconfig index 7705ddc16835..1348548e43c6 100644 --- a/configs/mscc_luton_defconfig +++ b/configs/mscc_luton_defconfig @@ -1,9 +1,12 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x40000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x70100000 CONFIG_DEBUG_UART_CLOCK=208333333 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARCH_MSCC=y CONFIG_SOC_LUTON=y CONFIG_DDRTYPE_MT47H128M8HQ=y @@ -44,6 +47,7 @@ CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x140000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index bcc77d1fc584..e68ff0eb294f 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -1,9 +1,12 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x40000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x70100000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARCH_MSCC=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_DEBUG_UART=y @@ -43,6 +46,7 @@ CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x140000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y diff --git a/configs/mscc_serval_defconfig b/configs/mscc_serval_defconfig index e4368081d3c3..54d89d3dcd8c 100644 --- a/configs/mscc_serval_defconfig +++ b/configs/mscc_serval_defconfig @@ -1,6 +1,9 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x40000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARCH_MSCC=y CONFIG_SOC_SERVAL=y CONFIG_DDRTYPE_H5TQ1G63BFA=y @@ -38,6 +41,7 @@ CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x140000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y diff --git a/configs/mscc_servalt_defconfig b/configs/mscc_servalt_defconfig index e672bf4be708..26cfb5e56297 100644 --- a/configs/mscc_servalt_defconfig +++ b/configs/mscc_servalt_defconfig @@ -1,6 +1,9 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x40000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ARCH_MSCC=y CONFIG_SOC_SERVALT=y CONFIG_SYS_LITTLE_ENDIAN=y @@ -36,6 +39,7 @@ CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x140000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y diff --git a/configs/mt7623n_bpir2_defconfig b/configs/mt7623n_bpir2_defconfig index 18c3a2bc5924..384822db1f46 100644 --- a/configs/mt7623n_bpir2_defconfig +++ b/configs/mt7623n_bpir2_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_MEDIATEK=y CONFIG_SYS_TEXT_BASE=0x81e00000 CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/mt7629_rfb_defconfig b/configs/mt7629_rfb_defconfig index 5eb2c0dd481a..6bb090e941e2 100644 --- a/configs/mt7629_rfb_defconfig +++ b/configs/mt7629_rfb_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_MT7629=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL_TEXT_BASE=0x201000 CONFIG_FIT=y diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index 8c782d9b20e6..fe50ce941638 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -4,9 +4,12 @@ CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_MVEBU_ARMADA_37XX=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=25804800 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DEBUG_UART=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/mvebu_db_armada8k_defconfig b/configs/mvebu_db_armada8k_defconfig index 5583ff6763bb..bf50a1c2f265 100644 --- a/configs/mvebu_db_armada8k_defconfig +++ b/configs/mvebu_db_armada8k_defconfig @@ -4,9 +4,12 @@ CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_MVEBU_ARMADA_8K=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DEBUG_UART_BASE=0xf0512000 CONFIG_DEBUG_UART_CLOCK=200000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_DEBUG_UART=y CONFIG_AHCI=y diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index 2c456860f396..f2a5fb3f6557 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -4,9 +4,12 @@ CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_MVEBU_ARMADA_37XX=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=25804800 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DEBUG_UART=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/mvebu_mcbin-88f8040_defconfig b/configs/mvebu_mcbin-88f8040_defconfig index 41107ca5441e..3e914f1266fd 100644 --- a/configs/mvebu_mcbin-88f8040_defconfig +++ b/configs/mvebu_mcbin-88f8040_defconfig @@ -4,9 +4,12 @@ CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_MVEBU_ARMADA_8K=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DEBUG_UART_BASE=0xf0512000 CONFIG_DEBUG_UART_CLOCK=200000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DEBUG_UART=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index c14f9ad87fd7..b286c5dcfa8a 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX23_OLINUXINO=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index bfafa50f1620..1a7473bc7c75 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX23EVK=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 diff --git a/configs/mx25pdk_defconfig b/configs/mx25pdk_defconfig index cf7d8b918aea..dbe5d4895dbf 100644 --- a/configs/mx25pdk_defconfig +++ b/configs/mx25pdk_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX25=y CONFIG_SYS_TEXT_BASE=0x81200000 CONFIG_TARGET_MX25PDK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx25pdk/imximage.cfg" CONFIG_DEFAULT_FDT_FILE="imx25-pdk.dtb" diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index 6c63969bbdf3..a0860304b686 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX28EVK=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index fbf5b0c94955..430a3bdcbb68 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX28EVK=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index ff77b810a82d..ed60dc66b9ee 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX28EVK=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x300000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 @@ -38,6 +40,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),5 CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x380000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 5d64408d0d25..9bbc7d6774e9 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX28EVK=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index c5da01c6e4ca..684afd59767b 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -6,6 +6,8 @@ CONFIG_SYS_TEXT_BASE=0x87e00000 CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX31PDK=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x87dc0000 @@ -23,6 +25,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x60000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_MXC_GPIO=y # CONFIG_MMC is not set diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index 59457e35c842..eac080a366ba 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_MX35PDK=y CONFIG_SYS_TEXT_BASE=0xA0000000 +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x20000 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y @@ -26,6 +28,8 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xA0080000 +CONFIG_ENV_ADDR_REDUND=0xA00A0000 CONFIG_MXC_GPIO=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index dc7b4ec818d5..dd782b3e7194 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX5=y CONFIG_SYS_TEXT_BASE=0x97800000 CONFIG_TARGET_MX51EVK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx51evk/imximage.cfg" diff --git a/configs/mx53ard_defconfig b/configs/mx53ard_defconfig index 7bec5d1a17a9..06f6d1585bd8 100644 --- a/configs/mx53ard_defconfig +++ b/configs/mx53ard_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX5=y CONFIG_SYS_TEXT_BASE=0x77800000 CONFIG_TARGET_MX53ARD=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=2 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53ard/imximage_dd3.cfg" diff --git a/configs/mx53cx9020_defconfig b/configs/mx53cx9020_defconfig index c16a591dd229..3e16f4519d5f 100644 --- a/configs/mx53cx9020_defconfig +++ b/configs/mx53cx9020_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX5=y CONFIG_SYS_TEXT_BASE=0x77800000 CONFIG_TARGET_MX53CX9020=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=2 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/beckhoff/mx53cx9020/imximage.cfg" diff --git a/configs/mx53evk_defconfig b/configs/mx53evk_defconfig index 5e0a9e4730e9..68915c366b86 100644 --- a/configs/mx53evk_defconfig +++ b/configs/mx53evk_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX5=y CONFIG_SYS_TEXT_BASE=0x77800000 CONFIG_TARGET_MX53EVK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53evk/imximage.cfg" CONFIG_HUSH_PARSER=y diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index 626ac2270205..28f48bfa9a30 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX5=y CONFIG_SYS_TEXT_BASE=0x77800000 CONFIG_TARGET_MX53LOCO=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=2 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53loco/imximage.cfg" diff --git a/configs/mx53ppd_defconfig b/configs/mx53ppd_defconfig index c2bee460ef6a..a21cbd8ab53c 100644 --- a/configs/mx53ppd_defconfig +++ b/configs/mx53ppd_defconfig @@ -5,6 +5,8 @@ CONFIG_TARGET_MX53PPD=y CONFIG_SYS_VPD_EEPROM_I2C_ADDR=0x50 CONFIG_SYS_VPD_EEPROM_I2C_BUS=2 CONFIG_SYS_VPD_EEPROM_SIZE=1024 +CONFIG_ENV_SIZE=0x2800 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SYS_BOOTCOUNT_ADDR=0x7000A000 CONFIG_FIT=y diff --git a/configs/mx53smd_defconfig b/configs/mx53smd_defconfig index 3c70136a5fc5..39ecb50eb009 100644 --- a/configs/mx53smd_defconfig +++ b/configs/mx53smd_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX5=y CONFIG_SYS_TEXT_BASE=0x77800000 CONFIG_TARGET_MX53SMD=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=2 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53smd/imximage.cfg" diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 94d6a0fb4468..1eba5e5cfab7 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6CUBOXI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFE000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/mx6dlarm2_defconfig b/configs/mx6dlarm2_defconfig index 76b9428d0aa9..75236a603382 100644 --- a/configs/mx6dlarm2_defconfig +++ b/configs/mx6dlarm2_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_MX6QARM2=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg,MX6DL,DDR_MB=2048" diff --git a/configs/mx6dlarm2_lpddr2_defconfig b/configs/mx6dlarm2_lpddr2_defconfig index 63b2a90b4bf7..8b4e3d74bc61 100644 --- a/configs/mx6dlarm2_lpddr2_defconfig +++ b/configs/mx6dlarm2_lpddr2_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_MX6QARM2=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg,MX6DL,MX6DL_LPDDR2,DDR_MB=512" diff --git a/configs/mx6memcal_defconfig b/configs/mx6memcal_defconfig index 0ded54cbf224..0ee35132d2ee 100644 --- a/configs/mx6memcal_defconfig +++ b/configs/mx6memcal_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_MX6_DDRCAL=y CONFIG_TARGET_MX6MEMCAL=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00908000 diff --git a/configs/mx6qarm2_defconfig b/configs/mx6qarm2_defconfig index cd41115a8772..49e254f29ec4 100644 --- a/configs/mx6qarm2_defconfig +++ b/configs/mx6qarm2_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_MX6QARM2=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q,DDR_MB=2048" diff --git a/configs/mx6qarm2_lpddr2_defconfig b/configs/mx6qarm2_lpddr2_defconfig index 71c24e1e3cb2..6163259d2f6c 100644 --- a/configs/mx6qarm2_lpddr2_defconfig +++ b/configs/mx6qarm2_lpddr2_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_MX6QARM2=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q,MX6DQ_LPDDR2,DDR_MB=512" diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 38c93ac5f963..9eccb7814d9e 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_NITROGEN6X=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index c62c98cedf5a..ba20198919c1 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -8,6 +8,8 @@ CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_MX6SABREAUTO=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index f46b16342b10..d0177af0e5a4 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -8,6 +8,8 @@ CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_MX6SABRESD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index 3e3038dc1fc4..5aea1484e5f7 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_MX6SLEVK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg" diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 9ac5b9b20b68..a681684a574c 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_MX6SLEVK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg" CONFIG_SPI_BOOT=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index a8606bfe8904..bec90e89263e 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6SLEVK=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/mx6sllevk_defconfig b/configs/mx6sllevk_defconfig index 79e04695e169..b43648dc6f68 100644 --- a/configs/mx6sllevk_defconfig +++ b/configs/mx6sllevk_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_MX6SLLEVK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sllevk/imximage.cfg" diff --git a/configs/mx6sllevk_plugin_defconfig b/configs/mx6sllevk_plugin_defconfig index 33fcfbb13c57..fffcfb346731 100644 --- a/configs/mx6sllevk_plugin_defconfig +++ b/configs/mx6sllevk_plugin_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_MX6SLLEVK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_USE_IMXIMG_PLUGIN=y # CONFIG_CMD_BMODE is not set diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index 7e1e11b0cf7d..d3e3b2fb022f 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_MX6SXSABREAUTO=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabreauto/imximage.cfg" diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index eab38178239a..543678e93b81 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_MX6SXSABRESD=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_NXP_BOARD_REVISION=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 514e58e0b475..668284eee9ae 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6SXSABRESD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index d8663dab43fe..313e918a9c04 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6UL_14X14_EVK=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 3c367e8f1d59..2e8af707c686 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX6UL_9X9_EVK=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/mx6ull_14x14_evk_defconfig b/configs/mx6ull_14x14_evk_defconfig index dc2f4b5c3e59..d969a98fb4c2 100644 --- a/configs/mx6ull_14x14_evk_defconfig +++ b/configs/mx6ull_14x14_evk_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_MX6ULL_14X14_EVK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6ullevk/imximage.cfg" CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/mx6ull_14x14_evk_plugin_defconfig b/configs/mx6ull_14x14_evk_plugin_defconfig index 8acb0e565e70..3394b41fae32 100644 --- a/configs/mx6ull_14x14_evk_plugin_defconfig +++ b/configs/mx6ull_14x14_evk_plugin_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_MX6ULL_14X14_EVK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_USE_IMXIMG_PLUGIN=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6ullevk/imximage.cfg" diff --git a/configs/mx6ulz_14x14_evk_defconfig b/configs/mx6ulz_14x14_evk_defconfig index b8e54199d81c..ab06628a2a59 100644 --- a/configs/mx6ulz_14x14_evk_defconfig +++ b/configs/mx6ulz_14x14_evk_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_MX6ULL_14X14_EVK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6ullevk/imximage.cfg" CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index 223003b3fb04..9befbb70c2d4 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX7=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_MX7DSABRESD=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARMV7_BOOT_SEC_DEFAULT=y # CONFIG_ARMV7_VIRT is not set diff --git a/configs/mx7dsabresd_qspi_defconfig b/configs/mx7dsabresd_qspi_defconfig index 619b29e5dc54..c317453349f3 100644 --- a/configs/mx7dsabresd_qspi_defconfig +++ b/configs/mx7dsabresd_qspi_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX7=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_MX7DSABRESD=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_ARMV7_BOOT_SEC_DEFAULT=y # CONFIG_ARMV7_VIRT is not set CONFIG_IMX_RDC=y diff --git a/configs/mx7ulp_evk_defconfig b/configs/mx7ulp_evk_defconfig index e4fc5c436efb..bd75a99be666 100644 --- a/configs/mx7ulp_evk_defconfig +++ b/configs/mx7ulp_evk_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX7ULP=y CONFIG_SYS_TEXT_BASE=0x67800000 CONFIG_TARGET_MX7ULP_EVK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7ulp_evk/imximage.cfg" diff --git a/configs/mx7ulp_evk_plugin_defconfig b/configs/mx7ulp_evk_plugin_defconfig index 5227eb78e9a3..0b07962dc9a5 100644 --- a/configs/mx7ulp_evk_plugin_defconfig +++ b/configs/mx7ulp_evk_plugin_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX7ULP=y CONFIG_SYS_TEXT_BASE=0x67800000 CONFIG_TARGET_MX7ULP_EVK=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7ulp_evk/imximage.cfg" CONFIG_BOUNCE_BUFFER=y diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig index 2e710cbef4ea..504346eb996a 100644 --- a/configs/nanopc-t4-rk3399_defconfig +++ b/configs/nanopc-t4-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/nanopi-k2_defconfig b/configs/nanopi-k2_defconfig index e5bd4622c1a6..7bdeb7906a7f 100644 --- a/configs/nanopi-k2_defconfig +++ b/configs/nanopi-k2_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xc81004c0 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/nanopi-m4-rk3399_defconfig b/configs/nanopi-m4-rk3399_defconfig index d9ebf3f1e9c1..24c8aa401b43 100644 --- a/configs/nanopi-m4-rk3399_defconfig +++ b/configs/nanopi-m4-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/nanopi-neo4-rk3399_defconfig b/configs/nanopi-neo4-rk3399_defconfig index 7fe68061780c..986739f16eef 100644 --- a/configs/nanopi-neo4-rk3399_defconfig +++ b/configs/nanopi-neo4-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index a4b6a16b12e0..1bd754234d39 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NAS220=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0xA0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nNAS 220" # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 2a309f54417c..98d02d68b433 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NET2BIG_V2=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x70000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" 2Big v2" CONFIG_SYS_EXTRA_OPTIONS="NET2BIG_V2" CONFIG_BOOTDELAY=3 @@ -36,6 +39,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-net2big" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 +CONFIG_ENV_ADDR=0x70000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/netgear_cg3100d_ram_defconfig b/configs/netgear_cg3100d_ram_defconfig index 48f00b7dc0e0..6c280748efcc 100644 --- a/configs/netgear_cg3100d_ram_defconfig +++ b/configs/netgear_cg3100d_ram_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_BMIPS=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/netgear_dgnd3700v2_ram_defconfig b/configs/netgear_dgnd3700v2_ram_defconfig index aa8af0b386d2..3452e0d5615b 100644 --- a/configs/netgear_dgnd3700v2_ram_defconfig +++ b/configs/netgear_dgnd3700v2_ram_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6362=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index ee58114b949c..e310f2ebd976 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x70000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" NS v2 Lite" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_LITE_V2" CONFIG_BOOTDELAY=3 @@ -36,6 +39,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2lite" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 +CONFIG_ENV_ADDR=0x70000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 2a95a55752e4..3feeaf94116b 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x70000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" NS Max v2" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MAX_V2" CONFIG_BOOTDELAY=3 @@ -36,6 +39,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2max" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 +CONFIG_ENV_ADDR=0x70000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 6933a9ba86ed..bd7ec1cbec08 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x70000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" NS v2 Mini" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MINI_V2" CONFIG_BOOTDELAY=3 @@ -34,6 +37,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2mini" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 +CONFIG_ENV_ADDR=0x70000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index fc806e445e71..a24848cbafb5 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x70000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" NS v2" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_V2" CONFIG_BOOTDELAY=3 @@ -36,6 +39,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 +CONFIG_ENV_ADDR=0x70000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index c738633a9192..7038c03e9d9c 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_NITROGEN6X=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 65bf98b706c4..91dc551a5cb7 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_NITROGEN6X=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 4452a5daa787..1c0f3596b362 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_NITROGEN6X=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 0be2461be2e6..f67de86b4437 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_NITROGEN6X=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index c20ce33228d4..b39cf3d4ee1a 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_NITROGEN6X=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 164f635447c2..1bb29a631e15 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_NITROGEN6X=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 85c6be2d1f20..96ff80e92a23 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -8,6 +8,8 @@ CONFIG_MX6_DDRCAL=y CONFIG_TARGET_KOSAGI_NOVENA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y @@ -46,6 +48,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-novena" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x84000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_DWC_AHSATA=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index cc238f01c4c3..404e7ccf1b6f 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NSA310S=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index a6e73bd2b78e..c9b82d30216c 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x81000100 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTSTAGE_STASH_ADDR=0x83000000 CONFIG_DEBUG_UART_BASE=0x70006000 diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 091c6331c18b..1f5a52c57cf3 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xc81004c0 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/odroid-n2_defconfig b/configs/odroid-n2_defconfig index 4ba54b6fc287..dccf3f1e7db7 100644 --- a/configs/odroid-n2_defconfig +++ b/configs/odroid-n2_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_BOARD="w400" CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_MESON_G12A=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff803000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 5b8988aa7cb3..24d21139209e 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS5=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x310000 CONFIG_NR_DRAM_BANKS=8 CONFIG_IDENT_STRING=" for ODROID-XU3/XU4/HC1/HC2" CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index f94e096ad0db..4a5e56671b9e 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43e00000 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_ODROID=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x140000 CONFIG_NR_DRAM_BANKS=8 CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index e595fa16ee63..a54ce9f2b015 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x280000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SCSI_AHCI=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 898e9514123e..add152eb5173 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x0 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x80000000 diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index e933b2df8be2..92f9b8a7c461 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_OPENRD=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nOpenRD-Base" CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_BASE" diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index caa05c5bdeb5..1eb794527453 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_OPENRD=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nOpenRD-Client" CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_CLIENT" diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index 748a5895d40c..2c7af6a921ad 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_OPENRD=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nOpenRD-Ultimate" CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_ULTIMATE" diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index e2d2dcd36a7e..74f07695b115 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_OPOS6ULDEV=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2800 +CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y @@ -63,6 +65,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-opos6uldev" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig index 54bcdd684928..bed634b699a0 100644 --- a/configs/orangepi-rk3399_defconfig +++ b/configs/orangepi-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/origen_defconfig b/configs/origen_defconfig index a975fdddaafb..32fb1902eb1f 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -5,6 +5,8 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_ORIGEN=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x4200 CONFIG_SPL=y CONFIG_IDENT_STRING=" for ORIGEN" CONFIG_SPL_TEXT_BASE=0x02021410 diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index 15f052d0d2b6..7e8489634869 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -2,7 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_OT1200=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/bachmann/ot1200/mx6q_4x_mt41j128.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 0cc129dc0466..fbc8feaaf8b2 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -6,8 +6,11 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_OT1200=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0x00908000 diff --git a/configs/p200_defconfig b/configs/p200_defconfig index b9dc5971dae9..bd65f50c17b7 100644 --- a/configs/p200_defconfig +++ b/configs/p200_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xc81004c0 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/p201_defconfig b/configs/p201_defconfig index 0ebf726a9f9f..ff6f279d6957 100644 --- a/configs/p201_defconfig +++ b/configs/p201_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_BOARD="p201" CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xc81004c0 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/p212_defconfig b/configs/p212_defconfig index 1590cc68003a..2f72db99e502 100644 --- a/configs/p212_defconfig +++ b/configs/p212_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_MESON_GXL=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xc81004c0 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index de8802f05bb4..ae80e62cddbc 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA210=y CONFIG_TARGET_P2371_0000=y diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index d4c307606fbf..2bdc2e67aa7a 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA210=y CONFIG_TARGET_P2371_2180=y diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index 5b43bb5be64c..2525cbf9a6b8 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA210=y CONFIG_TARGET_P2571=y diff --git a/configs/p2771-0000-000_defconfig b/configs/p2771-0000-000_defconfig index 8ddc8c5d3d30..9a3330a876b4 100644 --- a/configs/p2771-0000-000_defconfig +++ b/configs/p2771-0000-000_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=1026 CONFIG_TEGRA186=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/p2771-0000-500_defconfig b/configs/p2771-0000-500_defconfig index 7a8be9f29edf..920919c364b5 100644 --- a/configs/p2771-0000-500_defconfig +++ b/configs/p2771-0000-500_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=1026 CONFIG_TEGRA186=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index 4fe0b161d418..dd61088211c4 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA20=y CONFIG_TARGET_PAZ00=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index 3f0fc3a82ed2..71a51079b740 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xA0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_PCM052=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg" @@ -25,6 +27,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="vf610-pcm052" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xC0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_DM_GPIO=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 30644a449aff..06c0f3c75583 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -7,8 +7,11 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PCM058=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y @@ -44,6 +47,7 @@ CONFIG_CMD_UBI=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x110000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_FSL_USDHC=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 9f7f55dde37e..5272f1dd9f69 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -4,8 +4,11 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x23E00000 CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_PEACH_PI=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x3FC000 CONFIG_NR_DRAM_BANKS=7 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x4000 CONFIG_IDENT_STRING=" for Peach-Pi" CONFIG_SPL_TEXT_BASE=0x02024410 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index c820c1fc1bcf..4ad71c19e132 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -4,7 +4,10 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x23E00000 CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_PEACH_PIT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x3FC000 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x4000 CONFIG_IDENT_STRING=" for Peach-Pit" CONFIG_SPL_TEXT_BASE=0x02024410 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index 0cf456e03516..56bd8f137bfa 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -7,8 +7,11 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PFLA02=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y @@ -45,6 +48,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x110000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_FSL_USDHC=y diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index 072c95fa8c8b..e9990efa4c77 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -9,7 +9,7 @@ CONFIG_SYS_MPUCLK=1000 CONFIG_TARGET_PHYCORE_AM335X_R2=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_ENV_OFFSET=0x000a0000 +CONFIG_ENV_OFFSET=0xA0000 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index e240ce6a3831..782b2adb57cb 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_ROCKCHIP_RK3288=y CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_PHYCORE_RK3288=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff690000 diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig index e7d9332cd97e..6b234e572127 100644 --- a/configs/phycore_pcl063_defconfig +++ b/configs/phycore_pcl063_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PCL063=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=8 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00909000 diff --git a/configs/phycore_pcl063_ull_defconfig b/configs/phycore_pcl063_ull_defconfig index 0dc4d312dc99..814e76b11641 100644 --- a/configs/phycore_pcl063_ull_defconfig +++ b/configs/phycore_pcl063_ull_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PCL063_ULL=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=8 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x908000 diff --git a/configs/pic32mzdask_defconfig b/configs/pic32mzdask_defconfig index f20a55d6b648..6801ebd22c8d 100644 --- a/configs/pic32mzdask_defconfig +++ b/configs/pic32mzdask_defconfig @@ -1,6 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9D004000 CONFIG_SYS_MALLOC_F_LEN=0x600 +CONFIG_ENV_SIZE=0x4000 CONFIG_MACH_PIC32=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/pico-dwarf-imx6ul_defconfig b/configs/pico-dwarf-imx6ul_defconfig index e742aca6ae0e..26fd36574871 100644 --- a/configs/pico-dwarf-imx6ul_defconfig +++ b/configs/pico-dwarf-imx6ul_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX6UL=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/pico-dwarf-imx7d_defconfig b/configs/pico-dwarf-imx7d_defconfig index e51ff7812a75..533f569e1e19 100644 --- a/configs/pico-dwarf-imx7d_defconfig +++ b/configs/pico-dwarf-imx7d_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX7D=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y diff --git a/configs/pico-hobbit-imx6ul_defconfig b/configs/pico-hobbit-imx6ul_defconfig index 42605fe1b7d9..c2281b1c6304 100644 --- a/configs/pico-hobbit-imx6ul_defconfig +++ b/configs/pico-hobbit-imx6ul_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX6UL=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index 1af12ad3beea..3dd4f9a3a9ef 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX7D=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y diff --git a/configs/pico-imx6_defconfig b/configs/pico-imx6_defconfig index 388e157093af..0c8c74762cc7 100644 --- a/configs/pico-imx6_defconfig +++ b/configs/pico-imx6_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX6=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index e5e2abf3da86..c50f4fdf0908 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX6UL=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/pico-imx7d_bl33_defconfig b/configs/pico-imx7d_bl33_defconfig index 3297cc27f5b9..6633115487ad 100644 --- a/configs/pico-imx7d_bl33_defconfig +++ b/configs/pico-imx7d_bl33_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX7D=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_SPL=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_FIT=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 8ee1ee4c53a3..3b3108875700 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX7D=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y diff --git a/configs/pico-nymph-imx7d_defconfig b/configs/pico-nymph-imx7d_defconfig index e51ff7812a75..533f569e1e19 100644 --- a/configs/pico-nymph-imx7d_defconfig +++ b/configs/pico-nymph-imx7d_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX7D=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y diff --git a/configs/pico-pi-imx6ul_defconfig b/configs/pico-pi-imx6ul_defconfig index 47a5c30534eb..5db7a1b56f2f 100644 --- a/configs/pico-pi-imx6ul_defconfig +++ b/configs/pico-pi-imx6ul_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX6UL=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index 48afb39efd0d..d8e3c54aab44 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX7D=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index 1683e9d14480..58edba04e80c 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PLATINUM_PICON=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x1000000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y @@ -49,6 +51,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(e CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x1080000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_FSL_USDHC=y CONFIG_NAND=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 8c67a92c6575..dca2037ae106 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PLATINUM_TITANIUM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x1000000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y @@ -49,6 +51,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(e CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x1080000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_FSL_USDHC=y CONFIG_NAND=y diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 7475130ef7f7..9bd314a94fba 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x1FFE0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA20=y CONFIG_TARGET_PLUTUX=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index 604e83dd3a2e..b833ecc85cd3 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_TEXT_BASE=0 CONFIG_TARGET_PM9261=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261" @@ -32,6 +31,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=physmap-flash.0:256k(u-boot)ro,64k(u-boot-env) CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x10040000 CONFIG_DM=y CONFIG_BLK=y CONFIG_CLK=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index a1d22af2a3fc..37825a34db02 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_TEXT_BASE=0 CONFIG_TARGET_PM9263=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263" @@ -32,6 +31,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=physmap-flash.0:256k(u-boot)ro,64k(u-boot-env) CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x10040000 CONFIG_DM=y CONFIG_BLK=y CONFIG_CLK=y diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index e2ee1c8707aa..8a554a72f5ba 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9m10g45ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index 026a556fa011..d31a13de220e 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_POGO_E02=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nPogo E02" CONFIG_BOOTDELAY=3 diff --git a/configs/poplar_defconfig b/configs/poplar_defconfig index 1e068acb63cf..c71aa4dae4a9 100644 --- a/configs/poplar_defconfig +++ b/configs/poplar_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_TARGET_POPLAR=y CONFIG_SYS_TEXT_BASE=0x37000000 CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x1F0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="poplar" CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index a692c2c6dc34..1f0431415762 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_ROCKCHIP_RK3288=y CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_POPMETAL_RK3288=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff690000 diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 581f2812ad10..d496a26369d5 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -12,9 +12,12 @@ CONFIG_ARCH_RMOBILE_BOARD_STRING="Porter" CONFIG_R8A7791=y CONFIG_TARGET_PORTER=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0xe6300000 @@ -54,6 +57,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7791-porter-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xC0000 CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 6a5e89dc585c..4d97ad8683ae 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_BOOT_MODE_REG=0x0 +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_TARGET_PUMA_RK3399=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF180000 diff --git a/configs/pumpkin_defconfig b/configs/pumpkin_defconfig index 1bb6fb2c28f7..7ca42d09e471 100644 --- a/configs/pumpkin_defconfig +++ b/configs/pumpkin_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_MEDIATEK=y CONFIG_SYS_TEXT_BASE=0x4C000000 CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_MT8516=y +CONFIG_ENV_SIZE=0x1000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0x11005000 CONFIG_DEBUG_UART_CLOCK=26000000 diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index 8b2ad8b028db..4f50142ad6be 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xf01000 +CONFIG_ENV_SIZE=0x2000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_QEMU_PPCE500=y diff --git a/configs/qemu-riscv32_defconfig b/configs/qemu-riscv32_defconfig index d21f18575a1b..d3f8fed58c1b 100644 --- a/configs/qemu-riscv32_defconfig +++ b/configs/qemu-riscv32_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_QEMU_VIRT=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/qemu-riscv32_smode_defconfig b/configs/qemu-riscv32_smode_defconfig index e60eaa974935..20fc8f34725c 100644 --- a/configs/qemu-riscv32_smode_defconfig +++ b/configs/qemu-riscv32_smode_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_QEMU_VIRT=y CONFIG_RISCV_SMODE=y diff --git a/configs/qemu-riscv32_spl_defconfig b/configs/qemu-riscv32_spl_defconfig index eb0dd2ee94b1..fcaf0d5f6716 100644 --- a/configs/qemu-riscv32_spl_defconfig +++ b/configs/qemu-riscv32_spl_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_TARGET_QEMU_VIRT=y diff --git a/configs/qemu-riscv64_defconfig b/configs/qemu-riscv64_defconfig index e41bcc134801..7cda5e5a59d7 100644 --- a/configs/qemu-riscv64_defconfig +++ b/configs/qemu-riscv64_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_QEMU_VIRT=y CONFIG_ARCH_RV64I=y diff --git a/configs/qemu-riscv64_smode_defconfig b/configs/qemu-riscv64_smode_defconfig index 20f1def3dad5..33776f039094 100644 --- a/configs/qemu-riscv64_smode_defconfig +++ b/configs/qemu-riscv64_smode_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_QEMU_VIRT=y CONFIG_ARCH_RV64I=y diff --git a/configs/qemu-riscv64_spl_defconfig b/configs/qemu-riscv64_spl_defconfig index 70cd66e4e43a..6da9dd754de5 100644 --- a/configs/qemu-riscv64_spl_defconfig +++ b/configs/qemu-riscv64_spl_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_TARGET_QEMU_VIRT=y diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index 1f0bd6aa0e37..099062800787 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -2,6 +2,7 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0x1110000 CONFIG_SYS_MALLOC_F_LEN=0x1000 CONFIG_MAX_CPUS=2 +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 30a55f013c24..dc69aa5f7a5b 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -1,6 +1,7 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 CONFIG_MAX_CPUS=2 +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=8 CONFIG_SMP=y CONFIG_GENERATE_PIRQ_TABLE=y diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index 533195bc05ee..d2d7c38271d6 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_ARCH_QEMU=y CONFIG_TARGET_QEMU_ARM_64BIT=y +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_USE_PREBOOT=y @@ -14,6 +16,7 @@ CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_OF_BOARD=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x4000000 CONFIG_SCSI_AHCI=y CONFIG_AHCI_PCI=y CONFIG_BLK=y diff --git a/configs/qemu_arm_defconfig b/configs/qemu_arm_defconfig index 6491a5e29e36..ed6d591f9360 100644 --- a/configs/qemu_arm_defconfig +++ b/configs/qemu_arm_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARM_SMCCC=y CONFIG_ARCH_QEMU=y CONFIG_TARGET_QEMU_ARM_32BIT=y +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_USE_PREBOOT=y @@ -15,6 +17,7 @@ CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_OF_BOARD=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x4000000 CONFIG_SCSI_AHCI=y CONFIG_AHCI_PCI=y CONFIG_BLK=y diff --git a/configs/qemu_mips64_defconfig b/configs/qemu_mips64_defconfig index aff109512e33..eae64add37be 100644 --- a/configs/qemu_mips64_defconfig +++ b/configs/qemu_mips64_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xFFFFFFFFBFC00000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_SECT_SIZE=0x8000 CONFIG_TARGET_QEMU_MIPS=y CONFIG_CPU_MIPS64_R1=y CONFIG_BOOTDELAY=10 @@ -17,6 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFFFFFFBFFF8000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/qemu_mips64el_defconfig b/configs/qemu_mips64el_defconfig index 63cbd44c0d21..bdbe48b6768e 100644 --- a/configs/qemu_mips64el_defconfig +++ b/configs/qemu_mips64el_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xFFFFFFFFBFC00000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_SECT_SIZE=0x8000 CONFIG_TARGET_QEMU_MIPS=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_CPU_MIPS64_R1=y @@ -18,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFFFFFFFBFFF8000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/qemu_mips_defconfig b/configs/qemu_mips_defconfig index 37bf69f9e8e6..f12fddc15ceb 100644 --- a/configs/qemu_mips_defconfig +++ b/configs/qemu_mips_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xBFC00000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_SECT_SIZE=0x8000 CONFIG_TARGET_QEMU_MIPS=y CONFIG_BOOTDELAY=10 CONFIG_MISC_INIT_R=y @@ -15,6 +17,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xBFFF8000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/qemu_mipsel_defconfig b/configs/qemu_mipsel_defconfig index 82091b97df43..29df92c4c99b 100644 --- a/configs/qemu_mipsel_defconfig +++ b/configs/qemu_mipsel_defconfig @@ -1,5 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xBFC00000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_SECT_SIZE=0x8000 CONFIG_TARGET_QEMU_MIPS=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_BOOTDELAY=10 @@ -16,6 +18,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xBFFF8000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index e10ac939c5b9..8ae4ba1a1c8d 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -1,5 +1,7 @@ CONFIG_SH=y CONFIG_SYS_TEXT_BASE=0x8FE00000 +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_TARGET_R2DPLUS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=-1 @@ -20,6 +22,7 @@ CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="sh7751-r2dplus" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xA0040000 CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/r7780mp_defconfig b/configs/r7780mp_defconfig index 7862312d23cf..daacd43ba336 100644 --- a/configs/r7780mp_defconfig +++ b/configs/r7780mp_defconfig @@ -1,5 +1,7 @@ CONFIG_SH=y CONFIG_SYS_TEXT_BASE=0x0FFC0000 +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_TARGET_R7780MP=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -28,6 +30,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xA0040000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index 708bbe4aa9ab..497b1483db42 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_RMOBILE=y CONFIG_SYS_TEXT_BASE=0x50000000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_SALVATOR_X=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xFFFE0000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y diff --git a/configs/r8a7795_ulcb_defconfig b/configs/r8a7795_ulcb_defconfig index 314397396506..5df54dc6610c 100644 --- a/configs/r8a7795_ulcb_defconfig +++ b/configs/r8a7795_ulcb_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_TEXT_BASE=0x50000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_ULCB=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xFFFE0000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y diff --git a/configs/r8a77965_salvator-x_defconfig b/configs/r8a77965_salvator-x_defconfig index a759fee9f595..fa0b5a44592d 100644 --- a/configs/r8a77965_salvator-x_defconfig +++ b/configs/r8a77965_salvator-x_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_TEXT_BASE=0x50000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_SALVATOR_X=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xFFFE0000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y diff --git a/configs/r8a77965_ulcb_defconfig b/configs/r8a77965_ulcb_defconfig index db46f0348bd3..2e8c3f2b1ab3 100644 --- a/configs/r8a77965_ulcb_defconfig +++ b/configs/r8a77965_ulcb_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_TEXT_BASE=0x50000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_ULCB=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xFFFE0000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index a3cecb65f290..2c78df0bfeef 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_TEXT_BASE=0x50000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_SALVATOR_X=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xFFFE0000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y diff --git a/configs/r8a7796_ulcb_defconfig b/configs/r8a7796_ulcb_defconfig index f6d3ef5146b7..a8f3c8a5a676 100644 --- a/configs/r8a7796_ulcb_defconfig +++ b/configs/r8a7796_ulcb_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_TEXT_BASE=0x50000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_ULCB=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xFFFE0000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y diff --git a/configs/r8a77970_eagle_defconfig b/configs/r8a77970_eagle_defconfig index c348b912e7b2..eca37d72cdb2 100644 --- a/configs/r8a77970_eagle_defconfig +++ b/configs/r8a77970_eagle_defconfig @@ -5,6 +5,9 @@ CONFIG_SYS_TEXT_BASE=0x50000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_EAGLE=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x700000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_FIT=y diff --git a/configs/r8a77980_condor_defconfig b/configs/r8a77980_condor_defconfig index 190b4d8195fc..9169a9e06d11 100644 --- a/configs/r8a77980_condor_defconfig +++ b/configs/r8a77980_condor_defconfig @@ -5,6 +5,9 @@ CONFIG_SYS_TEXT_BASE=0x50000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_CONDOR=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x700000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_FIT=y diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index 79a1e9a92582..f968be678733 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_TEXT_BASE=0x50000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_EBISU=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xFFFE0000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_FIT=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index 75b11d65d690..9fc9b393c13b 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_TEXT_BASE=0x50000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_DRAAK=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xFFFE0000 CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_FIT=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index b676d4e041dd..4cbf6d4ae132 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -60,6 +60,7 @@ CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x2E0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 735542031419..a234dd123ab4 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_EMBESTMX6BOARDS=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" diff --git a/configs/riotboard_spl_defconfig b/configs/riotboard_spl_defconfig index 4174322f27cd..79c3570185c3 100644 --- a/configs/riotboard_spl_defconfig +++ b/configs/riotboard_spl_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/roc-rk3399-pc_defconfig b/configs/roc-rk3399-pc_defconfig index 11d8bcd2e31b..305baa712cd0 100644 --- a/configs/roc-rk3399-pc_defconfig +++ b/configs/roc-rk3399-pc_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 5faecb3f3fac..2c01bf1f8751 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 75546faa46bb..a28b3f14942a 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_ROCKCHIP_RK3288=y CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_ROCK2=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff690000 diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index bdcd8fe7ede3..ec6dcf80f901 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -6,6 +6,7 @@ CONFIG_TPL_ROCKCHIP_COMMON_BOARD=y CONFIG_TPL_LIBCOMMON_SUPPORT=y CONFIG_TPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF130000 diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index 609f17ac66d8..0d3c3a0bf386 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_TARGET_ROCK960_RK3399=y CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/rock_defconfig b/configs/rock_defconfig index 11174faa7a4b..3ce9aa10670a 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x60000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3188=y CONFIG_TARGET_ROCK=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x60080000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0x20064000 diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 67030c852e5d..abba6b98f693 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/rpi_0_w_defconfig b/configs/rpi_0_w_defconfig index ecfd3efc4014..52f15ce3e4a2 100644 --- a/configs/rpi_0_w_defconfig +++ b/configs/rpi_0_w_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_BCM283X=y CONFIG_SYS_TEXT_BASE=0x00008000 CONFIG_TARGET_RPI_0_W=y +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index 4cec41a8fe20..8c3335c5ed3c 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_BCM283X=y CONFIG_SYS_TEXT_BASE=0x00008000 CONFIG_TARGET_RPI_2=y +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index 366eba564c23..571d2cd23c02 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_BCM283X=y CONFIG_SYS_TEXT_BASE=0x00008000 CONFIG_TARGET_RPI_3_32B=y CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/rpi_3_b_plus_defconfig b/configs/rpi_3_b_plus_defconfig index 35c5951c91f9..169c6fdb9d89 100644 --- a/configs/rpi_3_b_plus_defconfig +++ b/configs/rpi_3_b_plus_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_BCM283X=y CONFIG_SYS_TEXT_BASE=0x00080000 CONFIG_TARGET_RPI_3=y CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index ecfae610b23d..3fb2c3f09062 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_BCM283X=y CONFIG_SYS_TEXT_BASE=0x00080000 CONFIG_TARGET_RPI_3=y CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index 899c1cc78213..7ff390cd24af 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_BCM283X=y CONFIG_SYS_TEXT_BASE=0x00008000 CONFIG_TARGET_RPI_4_32B=y CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index 98d185a5ed10..c5089eb9c8d4 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_BCM283X=y CONFIG_SYS_TEXT_BASE=0x00080000 CONFIG_TARGET_RPI_4=y CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 83a36143006b..a7ccab17102b 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_BCM283X=y CONFIG_SYS_TEXT_BASE=0x00008000 CONFIG_TARGET_RPI=y +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/s32v234evb_defconfig b/configs/s32v234evb_defconfig index 52f6dd99a356..1fb25ee2ba1f 100644 --- a/configs/s32v234evb_defconfig +++ b/configs/s32v234evb_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TARGET_S32V234EVB=y CONFIG_SYS_TEXT_BASE=0x3E800000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/s32v234evb/s32v234evb.cfg" diff --git a/configs/s400_defconfig b/configs/s400_defconfig index f61bd53c5dcf..6b9e790973df 100644 --- a/configs/s400_defconfig +++ b/configs/s400_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_MESON_AXG=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff803000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index d1f3f9aa2afb..a33ae3c5f088 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_S5PC1XX=y CONFIG_SYS_TEXT_BASE=0x34800000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x7000 CONFIG_TARGET_S5P_GONI=y CONFIG_NR_DRAM_BANKS=3 CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index 7e6237a70481..db764e82bed3 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x44800000 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_S5PC210_UNIVERSAL=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x7000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DISTRO_DEFAULTS=y CONFIG_USE_BOOTARGS=y diff --git a/configs/sagem_f@st1704_ram_defconfig b/configs/sagem_f@st1704_ram_defconfig index d25a7e1c653c..423360e38712 100644 --- a/configs/sagem_f@st1704_ram_defconfig +++ b/configs/sagem_f@st1704_ram_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6338=y diff --git a/configs/sam9x60ek_nandflash_defconfig b/configs/sam9x60ek_nandflash_defconfig index c9b821a02e87..f270b6828a80 100644 --- a/configs/sam9x60ek_nandflash_defconfig +++ b/configs/sam9x60ek_nandflash_defconfig @@ -35,6 +35,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="sam9x60ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/sama5d2_ptc_ek_nandflash_defconfig b/configs/sama5d2_ptc_ek_nandflash_defconfig index fb27cbb6e809..33ec13ff16a8 100644 --- a/configs/sama5d2_ptc_ek_nandflash_defconfig +++ b/configs/sama5d2_ptc_ek_nandflash_defconfig @@ -35,6 +35,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d2_ptc_ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index 4275f27fc3b8..cd2b75c3b4bc 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="sama5d36ek_cmp" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 90c83ada4b3f..b7e8dd93446d 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -46,6 +46,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d3_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 41c38b492d85..6104a9f829d5 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -45,6 +45,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sama5d36ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index 8d7380c3a555..9373f9ddb443 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -41,6 +41,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d4_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index df8502482ea0..c9df00c41673 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -43,6 +43,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d4ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 10355ce319a7..716096abc543 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -1,4 +1,5 @@ CONFIG_SYS_TEXT_BASE=0 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_PRE_CON_BUF_ADDR=0x100000 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 9b11a9e1e2f5..a8144436ebdc 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -1,4 +1,5 @@ CONFIG_SYS_TEXT_BASE=0 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_PRE_CON_BUF_ADDR=0xf0000 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index 4cdc17f9724c..774c278bce82 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -1,4 +1,5 @@ CONFIG_SYS_TEXT_BASE=0 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 3399ec1aae65..02702fa7a557 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -3,6 +3,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_BOOTSTAGE_STASH_ADDR=0x0 diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 5e6a05ea8cdc..5ee5ef0c1697 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_SANSA_FUZE_PLUS=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 diff --git a/configs/sbc8349_PCI_33_defconfig b/configs/sbc8349_PCI_33_defconfig index c0e513dc2733..a042b1e886ee 100644 --- a/configs/sbc8349_PCI_33_defconfig +++ b/configs/sbc8349_PCI_33_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=33000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -100,6 +102,8 @@ CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFF840000 +CONFIG_ENV_ADDR_REDUND=0xFF860000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sbc8349_PCI_66_defconfig b/configs/sbc8349_PCI_66_defconfig index f35973f94ce1..6d09d61fd388 100644 --- a/configs/sbc8349_PCI_66_defconfig +++ b/configs/sbc8349_PCI_66_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -100,6 +102,8 @@ CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFF840000 +CONFIG_ENV_ADDR_REDUND=0xFF860000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sbc8349_defconfig b/configs/sbc8349_defconfig index 0c90e576a4bc..efcaae90c1b1 100644 --- a/configs/sbc8349_defconfig +++ b/configs/sbc8349_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFF800000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -77,6 +79,8 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFF840000 +CONFIG_ENV_ADDR_REDUND=0xFF860000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sbc8548_PCI_33_PCIE_defconfig b/configs/sbc8548_PCI_33_PCIE_defconfig index 5a04646a7ecd..e3eca06cd026 100644 --- a/configs/sbc8548_PCI_33_PCIE_defconfig +++ b/configs/sbc8548_PCI_33_PCIE_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFFA0000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_SBC8548=y @@ -19,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set # CONFIG_CMD_IRQ is not set +CONFIG_ENV_ADDR=0xFFFE0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sbc8548_PCI_33_defconfig b/configs/sbc8548_PCI_33_defconfig index 36291e0e7a98..9583402ebfb1 100644 --- a/configs/sbc8548_PCI_33_defconfig +++ b/configs/sbc8548_PCI_33_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFFA0000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_SBC8548=y @@ -19,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set # CONFIG_CMD_IRQ is not set +CONFIG_ENV_ADDR=0xFFFE0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sbc8548_PCI_66_PCIE_defconfig b/configs/sbc8548_PCI_66_PCIE_defconfig index cfe0f3a340ef..3d8033f6b4dd 100644 --- a/configs/sbc8548_PCI_66_PCIE_defconfig +++ b/configs/sbc8548_PCI_66_PCIE_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFFA0000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_SBC8548=y @@ -19,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set # CONFIG_CMD_IRQ is not set +CONFIG_ENV_ADDR=0xFFFE0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sbc8548_PCI_66_defconfig b/configs/sbc8548_PCI_66_defconfig index e4b3c63def03..0eb0cc542ac1 100644 --- a/configs/sbc8548_PCI_66_defconfig +++ b/configs/sbc8548_PCI_66_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFFA0000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_SBC8548=y @@ -19,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set # CONFIG_CMD_IRQ is not set +CONFIG_ENV_ADDR=0xFFFE0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sbc8548_defconfig b/configs/sbc8548_defconfig index 33be2b90df74..4e090770a80a 100644 --- a/configs/sbc8548_defconfig +++ b/configs/sbc8548_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFFA0000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_SBC8548=y @@ -17,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set # CONFIG_CMD_IRQ is not set +CONFIG_ENV_ADDR=0xFFFE0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sbc8641d_defconfig b/configs/sbc8641d_defconfig index 47cec18a95ec..767428a04d96 100644 --- a/configs/sbc8641d_defconfig +++ b/configs/sbc8641d_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC86xx=y CONFIG_HIGH_BATS=y CONFIG_TARGET_SBC8641D=y @@ -16,6 +18,7 @@ CONFIG_CMD_PCI=y CONFIG_CMD_PING=y CONFIG_MP=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_ADDR=0xFFF60000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index 596c628baada..679d10a8345c 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_SC_SPS_1=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 3b3f5c330433..a6402483df59 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA20=y CONFIG_TARGET_SEABOARD=y diff --git a/configs/secomx6quq7_defconfig b/configs/secomx6quq7_defconfig index 48fb20bb8e32..2ef64b7fe125 100644 --- a/configs/secomx6quq7_defconfig +++ b/configs/secomx6quq7_defconfig @@ -5,6 +5,8 @@ CONFIG_TARGET_SECOMX6=y CONFIG_SECOMX6_UQ7=y CONFIG_SECOMX6Q=y CONFIG_SECOMX6_2GB=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/sei510_defconfig b/configs/sei510_defconfig index 4bb75a02f4fd..9914e286c716 100644 --- a/configs/sei510_defconfig +++ b/configs/sei510_defconfig @@ -4,6 +4,8 @@ CONFIG_SYS_CONFIG_NAME="sei510" CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_MESON_G12A=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0xFFFF0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff803000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/sei610_defconfig b/configs/sei610_defconfig index 83c5834b2527..37934fb9886d 100644 --- a/configs/sei610_defconfig +++ b/configs/sei610_defconfig @@ -4,6 +4,8 @@ CONFIG_SYS_CONFIG_NAME="sei610" CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_MESON_G12A=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0xFFFF0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff803000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/sfr_nb4-ser_ram_defconfig b/configs/sfr_nb4-ser_ram_defconfig index eea1409d6f29..325893aad9e9 100644 --- a/configs/sfr_nb4-ser_ram_defconfig +++ b/configs/sfr_nb4-ser_ram_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6358=y diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index d9fa1ca57fc9..12651028c59d 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -1,5 +1,6 @@ CONFIG_SH=y CONFIG_SYS_TEXT_BASE=0x5ff80000 +CONFIG_ENV_SIZE=0x10000 CONFIG_SH_32BIT=y CONFIG_TARGET_SH7752EVB=y CONFIG_BOOTDELAY=3 diff --git a/configs/sh7753evb_defconfig b/configs/sh7753evb_defconfig index e5698d802f78..bcece6f5328e 100644 --- a/configs/sh7753evb_defconfig +++ b/configs/sh7753evb_defconfig @@ -1,5 +1,6 @@ CONFIG_SH=y CONFIG_SYS_TEXT_BASE=0x5ff80000 +CONFIG_ENV_SIZE=0x10000 CONFIG_TARGET_SH7753EVB=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sh7757lcr_defconfig b/configs/sh7757lcr_defconfig index f9b7379cee75..91579b83ea2e 100644 --- a/configs/sh7757lcr_defconfig +++ b/configs/sh7757lcr_defconfig @@ -1,5 +1,6 @@ CONFIG_SH=y CONFIG_SYS_TEXT_BASE=0x8ef80000 +CONFIG_ENV_SIZE=0x10000 CONFIG_SH_32BIT=y CONFIG_TARGET_SH7757LCR=y CONFIG_BOOTDELAY=3 diff --git a/configs/sh7763rdp_defconfig b/configs/sh7763rdp_defconfig index 74c174b27b91..2ec6939caabd 100644 --- a/configs/sh7763rdp_defconfig +++ b/configs/sh7763rdp_defconfig @@ -1,5 +1,7 @@ CONFIG_SH=y CONFIG_SYS_TEXT_BASE=0x8FFC0000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_TARGET_SH7763RDP=y CONFIG_BOOTDELAY=-1 CONFIG_USE_BOOTARGS=y @@ -28,6 +30,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xA0020000 +CONFIG_ENV_ADDR_REDUND=0xA0040000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index cc485364153a..7bcfdadffe31 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_SHEEVAPLUG=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nMarvell-Sheevaplug" # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/sifive_fu540_defconfig b/configs/sifive_fu540_defconfig index 5f6d1c765f10..790da97667f8 100644 --- a/configs/sifive_fu540_defconfig +++ b/configs/sifive_fu540_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_SIFIVE_FU540=y CONFIG_ARCH_RV64I=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index b24f51c4d104..3043e17eb16a 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -12,9 +12,12 @@ CONFIG_ARCH_RMOBILE_BOARD_STRING="Silk" CONFIG_R8A7794=y CONFIG_TARGET_SILK=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0xe6300000 @@ -54,6 +57,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7794-silk-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xC0000 CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/sksimx6_defconfig b/configs/sksimx6_defconfig index d5897e940c96..cc4f0abc921d 100644 --- a/configs/sksimx6_defconfig +++ b/configs/sksimx6_defconfig @@ -8,6 +8,8 @@ CONFIG_MX6_DDRCAL=y CONFIG_TARGET_SKSIMX6=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y @@ -32,6 +34,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x64000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_FSL_USDHC=y diff --git a/configs/slimbootloader_defconfig b/configs/slimbootloader_defconfig index 5171cf59526c..4a4fb1100d40 100644 --- a/configs/slimbootloader_defconfig +++ b/configs/slimbootloader_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_ENV_SIZE=0x1000 CONFIG_VENDOR_INTEL=y CONFIG_TARGET_SLIMBOOTLOADER=y # CONFIG_USE_CAR is not set diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 5d2837d8e2a7..1a7437b7e149 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -44,6 +44,7 @@ CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260-smartweb" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index 4456e51f3b3d..b3e58281a359 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -6,8 +6,11 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_SMDK5250=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x3FC000 CONFIG_NR_DRAM_BANKS=8 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x4000 CONFIG_IDENT_STRING=" for SMDK5250" CONFIG_SPL_TEXT_BASE=0x02023400 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index 00460c487e74..968f3a1afefb 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -4,8 +4,11 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x23E00000 CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_SMDK5420=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x3FC000 CONFIG_NR_DRAM_BANKS=7 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x4000 CONFIG_IDENT_STRING=" for SMDK5420" CONFIG_SPL_TEXT_BASE=0x02024410 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/smdkc100_defconfig b/configs/smdkc100_defconfig index 88b56cbb814e..76bb74df8523 100644 --- a/configs/smdkc100_defconfig +++ b/configs/smdkc100_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_S5PC1XX=y CONFIG_SYS_TEXT_BASE=0x34800000 +CONFIG_ENV_SIZE=0x20000 CONFIG_TARGET_SMDKC100=y CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING=" for SMDKC100" @@ -21,6 +22,7 @@ CONFIG_MTDIDS_DEFAULT="onenand0=s3c-onenand" CONFIG_MTDPARTS_DEFAULT="mtdparts=s3c-onenand:256k(bootloader),128k@0x40000(params),3m@0x60000(kernel),16m@0x360000(test),-(UBI)" CONFIG_DEFAULT_DEVICE_TREE="s5pc1xx-smdkc100" CONFIG_ENV_IS_IN_ONENAND=y +CONFIG_ENV_ADDR=0x40000 # CONFIG_MMC is not set CONFIG_MTD_DEVICE=y CONFIG_SMC911X=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index 981010bd9b48..95d83cff04f3 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS4=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x4200 CONFIG_SPL=y CONFIG_IDENT_STRING=" for SMDKC210/V310" CONFIG_SPL_TEXT_BASE=0x02021410 diff --git a/configs/snow_defconfig b/configs/snow_defconfig index b10d8ed5bf18..c0d43e68d6b7 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -6,10 +6,13 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_SNOW=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x3FC000 CONFIG_NR_DRAM_BANKS=8 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0x12c30000 CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_ENV_SECT_SIZE=0x4000 CONFIG_IDENT_STRING=" for snow" CONFIG_DEBUG_UART=y CONFIG_SPL_TEXT_BASE=0x02023400 diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index 016379967fad..e822cdcc4ee4 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x4400 CONFIG_TARGET_SOCFPGA_ARRIA10_SOCDK=y CONFIG_IDENT_STRING="socfpga_arria10" CONFIG_SPL_FS_FAT=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index c4c71177b953..94dbe566b0c8 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x4400 CONFIG_TARGET_SOCFPGA_ARRIA5_SOCDK=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 6bf7172c2c0f..290e9697571b 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x4400 CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index 298b66c2eb08..3b4a1f54127b 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x4400 CONFIG_TARGET_SOCFPGA_DEVBOARDS_DBM_SOC1=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_FIT=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index ebb34f5b7311..ddf17ada963e 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x4400 CONFIG_TARGET_SOCFPGA_TERASIC_DE0_NANO=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index 7a0e1c75242f..98ec7b32de29 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x4400 CONFIG_TARGET_SOCFPGA_TERASIC_DE10_NANO=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index c14be93621b9..c70ff1ff7b34 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x4400 CONFIG_TARGET_SOCFPGA_TERASIC_DE1_SOC=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 30d3b2a2a261..f86a955b9c57 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -1,7 +1,10 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_TARGET_SOCFPGA_IS1=y CONFIG_SYS_BOOTCOUNT_ADDR=0xfffffff8 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 1eb57a60d309..600acfd9f1ad 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x4400 CONFIG_TARGET_SOCFPGA_ARIES_MCVEVK=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index f9b5ee2d00b5..20535719ef29 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x4400 CONFIG_TARGET_SOCFPGA_TERASIC_SOCKIT=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index e24723673c10..ffead58383c5 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x4400 CONFIG_TARGET_SOCFPGA_EBV_SOCRATES=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 08b829ddb8f5..78cb072abf7a 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -1,7 +1,10 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0xE0000 CONFIG_TARGET_SOCFPGA_SR1500=y CONFIG_SYS_BOOTCOUNT_ADDR=0xfffffff8 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y @@ -36,6 +39,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xF0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BOOTCOUNT_LIMIT=y diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index c7e8bf6aca23..de3a2cb25277 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y CONFIG_SYS_TEXT_BASE=0x1000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x200 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_SOCFPGA_STRATIX10_SOCDK=y CONFIG_IDENT_STRING="socfpga_stratix10" diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 5175c6493d69..130282c5af82 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_TARGET_SOCFPGA_SOFTING_VINING_FPGA=y +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y @@ -41,6 +44,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_vining_fpga" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x110000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 99e65f495dfe..ae99637d47a5 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff80000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_SOCRATES=y @@ -37,6 +39,8 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="socrates" CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFFF40000 +CONFIG_ENV_ADDR_REDUND=0xFFF20000 CONFIG_DM=y CONFIG_BLK=y CONFIG_DM_I2C=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 692b75a2c163..4c0ba53b0436 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -1,8 +1,11 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x6EF000 CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_ADVANTECH=y CONFIG_TARGET_SOM_DB5800_SOM_6867=y CONFIG_DEBUG_UART=y diff --git a/configs/spear300_defconfig b/configs/spear300_defconfig index 8e22c1e9d1f0..f020249aa443 100644 --- a/configs/spear300_defconfig +++ b/configs/spear300_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR300" CONFIG_BOOTDELAY=1 @@ -20,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xF8040000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear300_nand_defconfig b/configs/spear300_nand_defconfig index acd2d8b08bba..3bd39c37bb05 100644 --- a/configs/spear300_nand_defconfig +++ b/configs/spear300_nand_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR300" diff --git a/configs/spear300_usbtty_defconfig b/configs/spear300_usbtty_defconfig index fbdd4a31afee..11b62c4ce952 100644 --- a/configs/spear300_usbtty_defconfig +++ b/configs/spear300_usbtty_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR300,USBTTY" CONFIG_BOOTDELAY=-1 @@ -20,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xF8040000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear300_usbtty_nand_defconfig b/configs/spear300_usbtty_nand_defconfig index 3136f482b7c7..fd0c66d2eead 100644 --- a/configs/spear300_usbtty_nand_defconfig +++ b/configs/spear300_usbtty_nand_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR300,USBTTY" diff --git a/configs/spear310_defconfig b/configs/spear310_defconfig index 423e1ff00937..e210ea79d4bf 100644 --- a/configs/spear310_defconfig +++ b/configs/spear310_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310" CONFIG_BOOTDELAY=1 @@ -20,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xF8040000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear310_nand_defconfig b/configs/spear310_nand_defconfig index cd29bb7e75c3..669bb79033ca 100644 --- a/configs/spear310_nand_defconfig +++ b/configs/spear310_nand_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310" diff --git a/configs/spear310_pnor_defconfig b/configs/spear310_pnor_defconfig index dea51b9efe82..27cdb6bdb9e4 100644 --- a/configs/spear310_pnor_defconfig +++ b/configs/spear310_pnor_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,FLASH_PNOR" CONFIG_BOOTDELAY=1 @@ -20,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x50060000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear310_usbtty_defconfig b/configs/spear310_usbtty_defconfig index 722c84804d25..33fd690b3750 100644 --- a/configs/spear310_usbtty_defconfig +++ b/configs/spear310_usbtty_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,USBTTY" CONFIG_BOOTDELAY=-1 @@ -20,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xF8040000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear310_usbtty_nand_defconfig b/configs/spear310_usbtty_nand_defconfig index dc78280c18ff..badcae64a49c 100644 --- a/configs/spear310_usbtty_nand_defconfig +++ b/configs/spear310_usbtty_nand_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,USBTTY" diff --git a/configs/spear310_usbtty_pnor_defconfig b/configs/spear310_usbtty_pnor_defconfig index 7fd7dda43114..79686cbb2dcd 100644 --- a/configs/spear310_usbtty_pnor_defconfig +++ b/configs/spear310_usbtty_pnor_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,USBTTY,FLASH_PNOR" CONFIG_BOOTDELAY=-1 @@ -20,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x50060000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear320_defconfig b/configs/spear320_defconfig index 979bf04121fd..0864acd6b389 100644 --- a/configs/spear320_defconfig +++ b/configs/spear320_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320" CONFIG_BOOTDELAY=1 @@ -20,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xF8040000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear320_nand_defconfig b/configs/spear320_nand_defconfig index 13aeff87c605..4286d94ce9cf 100644 --- a/configs/spear320_nand_defconfig +++ b/configs/spear320_nand_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320" diff --git a/configs/spear320_pnor_defconfig b/configs/spear320_pnor_defconfig index f7dd48711500..958be6b90f54 100644 --- a/configs/spear320_pnor_defconfig +++ b/configs/spear320_pnor_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,FLASH_PNOR" CONFIG_BOOTDELAY=1 @@ -20,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x44060000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear320_usbtty_defconfig b/configs/spear320_usbtty_defconfig index 9fab406f13a4..954d325e983e 100644 --- a/configs/spear320_usbtty_defconfig +++ b/configs/spear320_usbtty_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,USBTTY" CONFIG_BOOTDELAY=-1 @@ -20,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xF8040000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear320_usbtty_nand_defconfig b/configs/spear320_usbtty_nand_defconfig index c38e75475847..d9e4e0539e7c 100644 --- a/configs/spear320_usbtty_nand_defconfig +++ b/configs/spear320_usbtty_nand_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,USBTTY" diff --git a/configs/spear320_usbtty_pnor_defconfig b/configs/spear320_usbtty_pnor_defconfig index 1dfac113d35c..0c2468715eaf 100644 --- a/configs/spear320_usbtty_pnor_defconfig +++ b/configs/spear320_usbtty_pnor_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,USBTTY,FLASH_PNOR" CONFIG_BOOTDELAY=-1 @@ -20,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x44060000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear600_defconfig b/configs/spear600_defconfig index eeb2746a9e76..d1369a9e88d4 100644 --- a/configs/spear600_defconfig +++ b/configs/spear600_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR600=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR600" CONFIG_BOOTDELAY=1 @@ -23,6 +25,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xF8040000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear600_nand_defconfig b/configs/spear600_nand_defconfig index b1202f601a66..0bc5fa935afe 100644 --- a/configs/spear600_nand_defconfig +++ b/configs/spear600_nand_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR600=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR600" diff --git a/configs/spear600_usbtty_defconfig b/configs/spear600_usbtty_defconfig index 2e6f3f159cf9..2affcfe8e0de 100644 --- a/configs/spear600_usbtty_defconfig +++ b/configs/spear600_usbtty_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR600=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR600,USBTTY" CONFIG_BOOTDELAY=-1 @@ -20,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xF8040000 CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear600_usbtty_nand_defconfig b/configs/spear600_usbtty_nand_defconfig index 8265eb49e064..207068da71eb 100644 --- a/configs/spear600_usbtty_nand_defconfig +++ b/configs/spear600_usbtty_nand_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_SPEAR600=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR600,USBTTY" diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 4ccef7fff492..ce9899136156 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -6,10 +6,13 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_SPRING=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x3FC000 CONFIG_NR_DRAM_BANKS=8 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0x12c30000 CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_ENV_SECT_SIZE=0x4000 CONFIG_IDENT_STRING=" for spring" CONFIG_DEBUG_UART=y CONFIG_SPL_TEXT_BASE=0x02023400 diff --git a/configs/stih410-b2260_defconfig b/configs/stih410-b2260_defconfig index 7b5fafe5bf6a..3c159ce39dd0 100644 --- a/configs/stih410-b2260_defconfig +++ b/configs/stih410-b2260_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_STI=y CONFIG_SYS_TEXT_BASE=0x7D600000 +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="STMicroelectronics STiH410-B2260" CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index 45fdb9d2ad7f..54cc51782467 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -2,9 +2,11 @@ CONFIG_ARM=y CONFIG_STM32=y CONFIG_SYS_TEXT_BASE=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0xF00 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_STM32F4=y CONFIG_TARGET_STM32F429_DISCOVERY=y +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -21,6 +23,7 @@ CONFIG_CMD_TIMER=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="stm32f429-disco" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x8040000 # CONFIG_NET is not set # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/stm32f429-evaluation_defconfig b/configs/stm32f429-evaluation_defconfig index a9c27959ebb1..24f79b51bf4d 100644 --- a/configs/stm32f429-evaluation_defconfig +++ b/configs/stm32f429-evaluation_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_STM32=y CONFIG_SYS_TEXT_BASE=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0xF00 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_STM32F4=y CONFIG_TARGET_STM32F429_EVALUATION=y diff --git a/configs/stm32f469-discovery_defconfig b/configs/stm32f469-discovery_defconfig index 5cf46aeecbd3..61ae8dc539df 100644 --- a/configs/stm32f469-discovery_defconfig +++ b/configs/stm32f469-discovery_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_STM32=y CONFIG_SYS_TEXT_BASE=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0xF00 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_STM32F4=y CONFIG_TARGET_STM32F469_DISCOVERY=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 2a018c7dc96e..bd03a5322cba 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_STM32=y CONFIG_SYS_TEXT_BASE=0x08008000 CONFIG_SYS_MALLOC_F_LEN=0xE00 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_STM32F7=y CONFIG_TARGET_STM32F746_DISCO=y diff --git a/configs/stm32f769-disco_defconfig b/configs/stm32f769-disco_defconfig index 3517a16aac38..44affcce33aa 100644 --- a/configs/stm32f769-disco_defconfig +++ b/configs/stm32f769-disco_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_STM32=y CONFIG_SYS_TEXT_BASE=0x08008000 CONFIG_SYS_MALLOC_F_LEN=0xE00 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_STM32F7=y CONFIG_TARGET_STM32F746_DISCO=y diff --git a/configs/stm32h743-disco_defconfig b/configs/stm32h743-disco_defconfig index ac001f844b03..3b7e152d44f6 100644 --- a/configs/stm32h743-disco_defconfig +++ b/configs/stm32h743-disco_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_STM32=y CONFIG_SYS_TEXT_BASE=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0xF00 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_STM32H7=y CONFIG_TARGET_STM32H743_DISCO=y diff --git a/configs/stm32h743-eval_defconfig b/configs/stm32h743-eval_defconfig index 3823ec9a86c7..24e250abf8a8 100644 --- a/configs/stm32h743-eval_defconfig +++ b/configs/stm32h743-eval_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_STM32=y CONFIG_SYS_TEXT_BASE=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0xF00 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_STM32H7=y CONFIG_TARGET_STM32H743_EVAL=y diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 8f1ce400b729..db653daac015 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -58,6 +58,7 @@ CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_EXT4_INTERFACE="mmc" CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" CONFIG_ENV_EXT4_FILE="/uboot.env" +CONFIG_ENV_OFFSET_REDUND=0x2C0000 CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="uboot_config" CONFIG_ENV_UBI_VOLUME_REDUND="uboot_config_r" diff --git a/configs/stm32mp15_optee_defconfig b/configs/stm32mp15_optee_defconfig index e156aaf31b2c..8f4199d24d6c 100644 --- a/configs/stm32mp15_optee_defconfig +++ b/configs/stm32mp15_optee_defconfig @@ -45,6 +45,7 @@ CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_EXT4_INTERFACE="mmc" CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" CONFIG_ENV_EXT4_FILE="/uboot.env" +CONFIG_ENV_OFFSET_REDUND=0x2C0000 CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="uboot_config" CONFIG_ENV_UBI_VOLUME_REDUND="uboot_config_r" diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 439370b6c805..5e5528f37bc3 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -44,6 +44,7 @@ CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_EXT4_INTERFACE="mmc" CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" CONFIG_ENV_EXT4_FILE="/uboot.env" +CONFIG_ENV_OFFSET_REDUND=0x2C0000 CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="uboot_config" CONFIG_ENV_UBI_VOLUME_REDUND="uboot_config_r" diff --git a/configs/stmark2_defconfig b/configs/stmark2_defconfig index eb130857aef3..4c5de0833bca 100644 --- a/configs/stmark2_defconfig +++ b/configs/stmark2_defconfig @@ -1,5 +1,8 @@ CONFIG_M68K=y CONFIG_SYS_TEXT_BASE=0x47E00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x40000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_STMARK2=y CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_SERIAL_BOOT,SYS_INPUT_CLKSRC=30000000" # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/stout_defconfig b/configs/stout_defconfig index a06098a8efff..69a914bbda05 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -12,9 +12,12 @@ CONFIG_ARCH_RMOBILE_BOARD_STRING="Stout" CONFIG_R8A7790=y CONFIG_TARGET_STOUT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0xe6300000 @@ -54,6 +57,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7790-stout-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0xC0000 CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/strider_con_defconfig b/configs/strider_con_defconfig index 8fb955c6f478..1c3146ed1800 100644 --- a/configs/strider_con_defconfig +++ b/configs/strider_con_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" strider con 0.01" CONFIG_SYS_CLK_FREQ=33333333 CONFIG_MPC83xx=y @@ -117,6 +119,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE060000 +CONFIG_ENV_ADDR_REDUND=0xFE070000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/strider_con_dp_defconfig b/configs/strider_con_dp_defconfig index 05272bd26679..0cea69d0c0a0 100644 --- a/configs/strider_con_dp_defconfig +++ b/configs/strider_con_dp_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" strider con dp 0.01" CONFIG_SYS_CLK_FREQ=33333333 CONFIG_MPC83xx=y @@ -117,6 +119,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE060000 +CONFIG_ENV_ADDR_REDUND=0xFE070000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/strider_cpu_defconfig b/configs/strider_cpu_defconfig index f6bb254319a9..3a5db81a598e 100644 --- a/configs/strider_cpu_defconfig +++ b/configs/strider_cpu_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" strider cpu 0.01" CONFIG_SYS_CLK_FREQ=33333333 CONFIG_MPC83xx=y @@ -117,6 +119,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE060000 +CONFIG_ENV_ADDR_REDUND=0xFE070000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/strider_cpu_dp_defconfig b/configs/strider_cpu_dp_defconfig index 0b1f16134f71..3897d864f9ba 100644 --- a/configs/strider_cpu_dp_defconfig +++ b/configs/strider_cpu_dp_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" strider cpu dp 0.01" CONFIG_SYS_CLK_FREQ=33333333 CONFIG_MPC83xx=y @@ -117,6 +119,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE060000 +CONFIG_ENV_ADDR_REDUND=0xFE070000 CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/stv0991_defconfig b/configs/stv0991_defconfig index eca2f2df6ba9..55fdf4b8f783 100644 --- a/configs/stv0991_defconfig +++ b/configs/stv0991_defconfig @@ -3,7 +3,10 @@ CONFIG_SYS_DCACHE_OFF=y CONFIG_TARGET_STV0991=y CONFIG_SYS_TEXT_BASE=0x00010000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x30000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_EXTRA_OPTIONS="STV0991" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set @@ -22,6 +25,7 @@ CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="stv0991" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x188000 # CONFIG_MMC is not set CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/suvd3_defconfig b/configs/suvd3_defconfig index a7782d50cd1d..659baa2bef1d 100644 --- a/configs/suvd3_defconfig +++ b/configs/suvd3_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -162,6 +164,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xF00C0000 +CONFIG_ENV_ADDR_REDUND=0xF00E0000 CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index db8804179f03..63a12f89444f 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -59,6 +59,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20-taurus" CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM=y CONFIG_BLK=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 9ab608abb072..ffe043678cdf 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_TBS2910=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_PRE_CON_BUF_ADDR=0x7c000000 CONFIG_CMD_HDMIDETECT=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index f720f3743f9d..8554e42f74a0 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA30=y CONFIG_TARGET_TEC_NG=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 48945a8fada2..b09de07291a3 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x1FFE0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA20=y CONFIG_TARGET_TEC=y diff --git a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig index ee94863ccd6f..edc201ac2541 100644 --- a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig @@ -1,6 +1,9 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x6EC000 CONFIG_NR_DRAM_BANKS=8 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_CONGATEC=y CONFIG_TARGET_THEADORABLE_X86_CONGA_QA3_E3845=y CONFIG_INTERNAL_UART=y @@ -46,6 +49,7 @@ CONFIG_AMIGA_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="conga-qeval20-qa3-e3845" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x6EE000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/theadorable-x86-conga-qa3-e3845_defconfig b/configs/theadorable-x86-conga-qa3-e3845_defconfig index 94d082b0d58f..eb96f672fb56 100644 --- a/configs/theadorable-x86-conga-qa3-e3845_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845_defconfig @@ -1,6 +1,9 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x6EC000 CONFIG_NR_DRAM_BANKS=8 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_CONGATEC=y CONFIG_TARGET_THEADORABLE_X86_CONGA_QA3_E3845=y CONFIG_INTERNAL_UART=y @@ -45,6 +48,7 @@ CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="conga-qeval20-qa3-e3845" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x6EE000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 10a9c78a5a18..8becc51de4e3 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -1,6 +1,9 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x6EC000 CONFIG_NR_DRAM_BANKS=8 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_VENDOR_DFI=y CONFIG_TARGET_THEADORABLE_X86_DFI_BT700=y CONFIG_SMP=y @@ -43,6 +46,7 @@ CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="theadorable-x86-dfi-bt700" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x6EE000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index b395ad35ab10..ef57644fafd8 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -7,10 +7,13 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_THEADORABLE=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 0e0ceb7cdab0..ee8da7b0a52d 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -60,6 +60,7 @@ CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x2E0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y diff --git a/configs/thunderx_88xx_defconfig b/configs/thunderx_88xx_defconfig index 002d2c958a97..a4ff74e07179 100644 --- a/configs/thunderx_88xx_defconfig +++ b/configs/thunderx_88xx_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_THUNDERX_88XX=y CONFIG_SYS_TEXT_BASE=0x00500000 +CONFIG_ENV_SIZE=0x1000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0x87e024000000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 13b0c89374b5..f6f58976b970 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_TI816X_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_ENV_SIZE=0x2000 -CONFIG_ENV_OFFSET=0x001c0000 +CONFIG_ENV_OFFSET=0x1C0000 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y @@ -41,6 +41,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="dm8168-evm" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x1E0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_DM_GPIO=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index a48b17f0da39..ad3fe651069f 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_ROCKCHIP_RK3288=y CONFIG_TARGET_TINKER_RK3288=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL_SIZE_LIMIT=0x4b000 diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index 624ce71a6d92..023c99ebb982 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_TITANIUM=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x1000000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/barco/titanium/imximage.cfg" CONFIG_BOOTDELAY=3 @@ -35,6 +37,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:16M(uboot),512k(env1),512k(env2),-(u CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x1080000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_FSL_USDHC=y CONFIG_NAND=y diff --git a/configs/tools-only_defconfig b/configs/tools-only_defconfig index 381b16959ddd..e36c9debf6d2 100644 --- a/configs/tools-only_defconfig +++ b/configs/tools-only_defconfig @@ -1,4 +1,5 @@ CONFIG_SYS_TEXT_BASE=0 +CONFIG_ENV_SIZE=0x2000 CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index 5be7813078e6..4c3ddc56bd3e 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_CONFIG_NAME="topic_miami" CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_ENV_SIZE=0x8000 CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0000000 diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index 15999de90b08..9ea7068ce470 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_CONFIG_NAME="topic_miami" CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_ENV_SIZE=0x8000 CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0000000 diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index af58d702d44e..c841ca45e239 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_CONFIG_NAME="topic_miami" CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_ENV_SIZE=0x8000 CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0000000 diff --git a/configs/tplink_wdr4300_defconfig b/configs/tplink_wdr4300_defconfig index ba2b76f1b8b6..3a518d062a83 100644 --- a/configs/tplink_wdr4300_defconfig +++ b/configs/tplink_wdr4300_defconfig @@ -1,6 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0xA1000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x10000 CONFIG_ARCH_ATH79=y CONFIG_BOARD_TPLINK_WDR4300=y CONFIG_BOOTDELAY=3 diff --git a/configs/tqma6dl_mba6_mmc_defconfig b/configs/tqma6dl_mba6_mmc_defconfig index 3065ee9fffab..fe8f2b53fcd0 100644 --- a/configs/tqma6dl_mba6_mmc_defconfig +++ b/configs/tqma6dl_mba6_mmc_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x4fc00000 CONFIG_TARGET_TQMA6=y CONFIG_TQMA6DL=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/tqma6dl_mba6_spi_defconfig b/configs/tqma6dl_mba6_spi_defconfig index 5d82a9866cf5..ff8bca966355 100644 --- a/configs/tqma6dl_mba6_spi_defconfig +++ b/configs/tqma6dl_mba6_spi_defconfig @@ -4,7 +4,10 @@ CONFIG_SYS_TEXT_BASE=0x4fc00000 CONFIG_TARGET_TQMA6=y CONFIG_TQMA6DL=y CONFIG_TQMA6X_SPI_BOOT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -34,6 +37,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x90000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index c4c5604ca67e..21af99938051 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x4fc00000 CONFIG_TARGET_TQMA6=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index db71e5f13429..3de61fbe2bbc 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -3,7 +3,10 @@ CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x4fc00000 CONFIG_TARGET_TQMA6=y CONFIG_TQMA6X_SPI_BOOT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -33,6 +36,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x90000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index ee2a0f91b415..3cb8cf6849f0 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x2fc00000 CONFIG_TARGET_TQMA6=y CONFIG_TQMA6S=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index d007d3277602..c0320e3b7837 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -4,7 +4,10 @@ CONFIG_SYS_TEXT_BASE=0x2fc00000 CONFIG_TARGET_TQMA6=y CONFIG_TQMA6S=y CONFIG_TQMA6X_SPI_BOOT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -34,6 +37,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x90000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/tqma6s_wru4_mmc_defconfig b/configs/tqma6s_wru4_mmc_defconfig index 47cb33b5d083..9feced743e4d 100644 --- a/configs/tqma6s_wru4_mmc_defconfig +++ b/configs/tqma6s_wru4_mmc_defconfig @@ -4,6 +4,8 @@ CONFIG_SYS_TEXT_BASE=0x2fc00000 CONFIG_TARGET_TQMA6=y CONFIG_TQMA6S=y CONFIG_WRU4=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_BOOTCOUNT_ADDR=0x00900000 CONFIG_FIT=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 3cabd16e0f40..3c247c16d43e 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43e00000 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_TRATS2=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x7000 CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index ed2129cc5aee..cdf38271a4db 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x63300000 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_TRATS=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x7000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 8e2e214f0945..6adc90a9252d 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -27,6 +27,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:128k(SPL),1m(u-boot),384k(u-boot- CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x2A0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set CONFIG_LED_STATUS=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index ee947c801d51..f4feafe5d4e4 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -1,7 +1,10 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFE000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_TEGRA20=y CONFIG_TARGET_TRIMSLICE=y CONFIG_SPL_TEXT_BASE=0x00108000 diff --git a/configs/ts4600_defconfig b/configs/ts4600_defconfig index 5a7d72b93c32..85074c7171b6 100644 --- a/configs/ts4600_defconfig +++ b/configs/ts4600_defconfig @@ -4,6 +4,8 @@ CONFIG_SYS_TEXT_BASE=0x40002000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_TS4600=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 diff --git a/configs/ts4800_defconfig b/configs/ts4800_defconfig index 58a8d9b5aae2..6a6b3e8e8bc9 100644 --- a/configs/ts4800_defconfig +++ b/configs/ts4800_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX5=y CONFIG_SYS_TEXT_BASE=0x90008000 CONFIG_TARGET_TS4800=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_BOOTDELAY=1 diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index 30a36ee03941..b8df1f57f8e4 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -141,6 +143,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xF00C0000 +CONFIG_ENV_ADDR_REDUND=0xF00E0000 CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/turris_mox_defconfig b/configs/turris_mox_defconfig index 412adbd2ded3..fafc47119369 100644 --- a/configs/turris_mox_defconfig +++ b/configs/turris_mox_defconfig @@ -4,9 +4,12 @@ CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_TURRIS_MOX=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=25804800 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 7c10b67cab8e..a1d829797145 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -9,10 +9,13 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_TURRIS_OMNIA=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0xF0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index bccc459002ca..562dcbd1ede5 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -163,6 +165,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xF00C0000 +CONFIG_ENV_ADDR_REDUND=0xF00E0000 CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/u200_defconfig b/configs/u200_defconfig index bb01718689ca..d96906f2ff4d 100644 --- a/configs/u200_defconfig +++ b/configs/u200_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_MESON_G12A=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff803000 CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/configs/uDPU_defconfig b/configs/uDPU_defconfig index 3a23a9b5c2d7..2c31d22a28fe 100644 --- a/configs/uDPU_defconfig +++ b/configs/uDPU_defconfig @@ -4,8 +4,11 @@ CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_MVEBU_ARMADA_37XX=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=25804800 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SMBIOS_PRODUCT_NAME="uDPU" CONFIG_DEBUG_UART=y CONFIG_AHCI=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index c33fe0f3dc5f..9b05ee6c9d97 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_UDOO=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index 4a91c12d5053..d85555f5fb4f 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_UDOO_NEO=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index a53b545c1841..643610c48cea 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=3 CONFIG_SPL=y CONFIG_ARCH_UNIPHIER_LD4_SLD8=y diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index af094c244564..3ee599bbd175 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=3 CONFIG_SPL=y CONFIG_MICRO_SUPPORT_CARD=y diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 39a862eba6e1..1e336ea12b50 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -5,6 +5,7 @@ CONFIG_ARM_SMCCC=y CONFIG_ARCH_UNIPHIER=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=3 CONFIG_ARCH_UNIPHIER_V8_MULTI=y CONFIG_MICRO_SUPPORT_CARD=y diff --git a/configs/usbarmory_defconfig b/configs/usbarmory_defconfig index c4fb98360bf9..f66cad7c7ffa 100644 --- a/configs/usbarmory_defconfig +++ b/configs/usbarmory_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX5=y CONFIG_SYS_TEXT_BASE=0x77800000 CONFIG_TARGET_USBARMORY=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/variscite_dart6ul_defconfig b/configs/variscite_dart6ul_defconfig index 9e2065c57e8b..7178b8ea7424 100644 --- a/configs/variscite_dart6ul_defconfig +++ b/configs/variscite_dart6ul_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_DART_6UL=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=8 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00908000 diff --git a/configs/vct_platinum_defconfig b/configs/vct_platinum_defconfig index 2dacc1c2f0d5..ecb3358c292f 100644 --- a/configs/vct_platinum_defconfig +++ b/configs/vct_platinum_defconfig @@ -1,4 +1,6 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUM=y CONFIG_BOOTDELAY=5 @@ -16,6 +18,8 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xB0040000 +CONFIG_ENV_ADDR_REDUND=0xB0050000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vct_platinum_onenand_defconfig b/configs/vct_platinum_onenand_defconfig index ded3de04993a..2788dca4ad99 100644 --- a/configs/vct_platinum_onenand_defconfig +++ b/configs/vct_platinum_onenand_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x20000 CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUM=y CONFIG_VCT_ONENAND=y @@ -23,6 +24,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=onenand:128k(u-boot),128k(env),20m(kernel),-(r CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_ENV_IS_IN_ONENAND=y +CONFIG_ENV_ADDR=0x20000 CONFIG_MTD_DEVICE=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x00000000 diff --git a/configs/vct_platinum_onenand_small_defconfig b/configs/vct_platinum_onenand_small_defconfig index 4afb03ee9eb8..56be171e7694 100644 --- a/configs/vct_platinum_onenand_small_defconfig +++ b/configs/vct_platinum_onenand_small_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x20000 CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUM=y CONFIG_VCT_ONENAND=y @@ -28,6 +29,7 @@ CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_ONENAND=y +CONFIG_ENV_ADDR=0x20000 # CONFIG_NET is not set CONFIG_MTD_DEVICE=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinum_small_defconfig b/configs/vct_platinum_small_defconfig index d53fd4fe513d..4a0d53e555bb 100644 --- a/configs/vct_platinum_small_defconfig +++ b/configs/vct_platinum_small_defconfig @@ -1,4 +1,6 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUM=y CONFIG_VCT_SMALL_IMAGE=y @@ -21,6 +23,8 @@ CONFIG_CMD_IMLS=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xB0040000 +CONFIG_ENV_ADDR_REDUND=0xB0050000 # CONFIG_NET is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/vct_platinumavc_defconfig b/configs/vct_platinumavc_defconfig index 21f04a763543..03ab55de703d 100644 --- a/configs/vct_platinumavc_defconfig +++ b/configs/vct_platinumavc_defconfig @@ -1,4 +1,6 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUMAVC=y CONFIG_BOOTDELAY=5 @@ -13,6 +15,8 @@ CONFIG_CMD_I2C=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xB0040000 +CONFIG_ENV_ADDR_REDUND=0xB0050000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vct_platinumavc_onenand_defconfig b/configs/vct_platinumavc_onenand_defconfig index e7e9c6cde1f0..8fd81dd51e27 100644 --- a/configs/vct_platinumavc_onenand_defconfig +++ b/configs/vct_platinumavc_onenand_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x20000 CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUMAVC=y CONFIG_VCT_ONENAND=y @@ -20,6 +21,7 @@ CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_ONENAND=y +CONFIG_ENV_ADDR=0x20000 CONFIG_MTD_DEVICE=y CONFIG_SYS_NS16550=y # CONFIG_REGEX is not set diff --git a/configs/vct_platinumavc_onenand_small_defconfig b/configs/vct_platinumavc_onenand_small_defconfig index 776472666c57..fa2c91f06355 100644 --- a/configs/vct_platinumavc_onenand_small_defconfig +++ b/configs/vct_platinumavc_onenand_small_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x20000 CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUMAVC=y CONFIG_VCT_ONENAND=y @@ -28,6 +29,7 @@ CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_ONENAND=y +CONFIG_ENV_ADDR=0x20000 # CONFIG_NET is not set CONFIG_MTD_DEVICE=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_small_defconfig b/configs/vct_platinumavc_small_defconfig index e7b2b1b19894..5f897a89ec9e 100644 --- a/configs/vct_platinumavc_small_defconfig +++ b/configs/vct_platinumavc_small_defconfig @@ -1,4 +1,6 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUMAVC=y CONFIG_VCT_SMALL_IMAGE=y @@ -21,6 +23,8 @@ CONFIG_CMD_IMLS=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xB0040000 +CONFIG_ENV_ADDR_REDUND=0xB0050000 # CONFIG_NET is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/vct_premium_defconfig b/configs/vct_premium_defconfig index 2b53b0904808..0762194e3332 100644 --- a/configs/vct_premium_defconfig +++ b/configs/vct_premium_defconfig @@ -1,4 +1,6 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_VCT=y CONFIG_VCT_PREMIUM=y CONFIG_BOOTDELAY=5 @@ -16,6 +18,8 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xB0040000 +CONFIG_ENV_ADDR_REDUND=0xB0050000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vct_premium_onenand_defconfig b/configs/vct_premium_onenand_defconfig index f1d01d9c90b5..a6851d9eb8f3 100644 --- a/configs/vct_premium_onenand_defconfig +++ b/configs/vct_premium_onenand_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x20000 CONFIG_TARGET_VCT=y CONFIG_VCT_PREMIUM=y CONFIG_VCT_ONENAND=y @@ -23,6 +24,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=onenand:128k(u-boot),128k(env),20m(kernel),-(r CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_ENV_IS_IN_ONENAND=y +CONFIG_ENV_ADDR=0x20000 CONFIG_MTD_DEVICE=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x00000000 diff --git a/configs/vct_premium_onenand_small_defconfig b/configs/vct_premium_onenand_small_defconfig index 751f8819426d..7dd68887d70c 100644 --- a/configs/vct_premium_onenand_small_defconfig +++ b/configs/vct_premium_onenand_small_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x20000 CONFIG_TARGET_VCT=y CONFIG_VCT_PREMIUM=y CONFIG_VCT_ONENAND=y @@ -28,6 +29,7 @@ CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_ONENAND=y +CONFIG_ENV_ADDR=0x20000 # CONFIG_NET is not set CONFIG_MTD_DEVICE=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_premium_small_defconfig b/configs/vct_premium_small_defconfig index 706799a89e5d..b19d3a607784 100644 --- a/configs/vct_premium_small_defconfig +++ b/configs/vct_premium_small_defconfig @@ -1,4 +1,6 @@ CONFIG_MIPS=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_VCT=y CONFIG_VCT_PREMIUM=y CONFIG_VCT_SMALL_IMAGE=y @@ -21,6 +23,8 @@ CONFIG_CMD_IMLS=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xB0040000 +CONFIG_ENV_ADDR_REDUND=0xB0050000 # CONFIG_NET is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/ve8313_defconfig b/configs/ve8313_defconfig index 2581d3cf2559..08597ab43420 100644 --- a/configs/ve8313_defconfig +++ b/configs/ve8313_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=32000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -135,6 +137,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFE060000 +CONFIG_ENV_ADDR_REDUND=0xFE080000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 63d03d945b28..3d81c8a354c6 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA124=y CONFIG_TARGET_VENICE2=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index d6131f71764f..726927b8b7d1 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFE000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TEGRA20=y CONFIG_TARGET_VENTANA=y diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index 0823d17c1158..d95d40f4bcfc 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS64_JUNO=y CONFIG_SYS_TEXT_BASE=0xe0000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x10000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING=" vexpress_aemv8a" CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 @@ -27,6 +29,7 @@ CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xBFC0000 CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index db5ad3dfa5a4..12302c62768a 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS64_BASE_FVP=y CONFIG_SYS_TEXT_BASE=0x88000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_IDENT_STRING=" vexpress_aemv8a" CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 @@ -27,6 +29,7 @@ CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFC0000 CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index 904c75614fd7..a1690dcc60e0 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS_CA15_TC2=y CONFIG_SYS_TEXT_BASE=0x80800000 +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run distro_bootcmd; run bootflash" @@ -20,6 +22,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_MISC is not set CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFF80000 CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/vexpress_ca5x2_defconfig b/configs/vexpress_ca5x2_defconfig index ca847a2f9a39..c95cc38be0c9 100644 --- a/configs/vexpress_ca5x2_defconfig +++ b/configs/vexpress_ca5x2_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS_CA5X2=y CONFIG_SYS_TEXT_BASE=0x80800000 +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run distro_bootcmd; run bootflash" # CONFIG_DISPLAY_CPUINFO is not set @@ -19,6 +21,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_MISC is not set CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFF80000 CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index 06fcfee1d3d7..4007c5cb3d61 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS_CA9X4=y CONFIG_SYS_TEXT_BASE=0x60800000 +CONFIG_ENV_SIZE=0x40000 CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run distro_bootcmd; run bootflash" # CONFIG_DISPLAY_CPUINFO is not set @@ -19,6 +21,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_MISC is not set CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0x47F80000 CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 54365da9853c..36a8b9028ff8 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg" CONFIG_BOOTDELAY=3 diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index 329bdccd4cbe..942ee6426662 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x180000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg" CONFIG_BOOTDELAY=3 diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index 350af3ee1cb1..32ef01b63996 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_SOFTING_VINING_2000=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/softing/vining_2000/imximage.cfg" @@ -36,6 +38,7 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6sx-softing-vining-2000" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x90000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_GPIO=y diff --git a/configs/vme8349_defconfig b/configs/vme8349_defconfig index 8533c4da94d3..536c2d1466c7 100644 --- a/configs/vme8349_defconfig +++ b/configs/vme8349_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF00000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -109,6 +111,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xFFFC0000 +CONFIG_ENV_ADDR_REDUND=0xFFFE0000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index 220e0ad7acca..cff61677cb97 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -5,6 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00100000 CONFIG_ROCKCHIP_RK3288=y CONFIG_TARGET_VYASA_RK3288=y +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff690000 diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index fc382833fb6e..eac4af95a4ad 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_WANDBOARD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index 72123d2fb994..e75afc782ef6 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX7=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_WARP7=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_HAB=y CONFIG_FIT=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 869cfe4c73d7..72cdb684a702 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX7=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_WARP7=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARMV7_BOOT_SEC_DEFAULT=y # CONFIG_ARMV7_VIRT is not set diff --git a/configs/warp_defconfig b/configs/warp_defconfig index 47d55ddae6b4..ed89615d31e1 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_WARP=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/warp/imximage.cfg" diff --git a/configs/wb45n_defconfig b/configs/wb45n_defconfig index 60c9db7f353a..672fbc7e472c 100644 --- a/configs/wb45n_defconfig +++ b/configs/wb45n_defconfig @@ -7,7 +7,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_ENV_OFFSET=0xa0000 +CONFIG_ENV_OFFSET=0xA0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x300000 @@ -29,6 +29,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xC0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set diff --git a/configs/wb50n_defconfig b/configs/wb50n_defconfig index fc08bae49b58..f3a7aee1a4f7 100644 --- a/configs/wb50n_defconfig +++ b/configs/wb50n_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0xC0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_NAND=y diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index 40cd074e3c05..81cb1796fb06 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_TARGET_WOODBURN=y CONFIG_SYS_TEXT_BASE=0xA0000000 +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y @@ -28,6 +30,8 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xA0080000 +CONFIG_ENV_ADDR_REDUND=0xA00A0000 CONFIG_MXC_GPIO=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index c4826f4f01c5..443837f92350 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -7,8 +7,10 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_TEXT_BASE=0x10002300 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/woodburn/imximage.cfg" @@ -40,6 +42,8 @@ CONFIG_EFI_PARTITION=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xA0080000 +CONFIG_ENV_ADDR_REDUND=0xA00A0000 CONFIG_MXC_GPIO=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 1196b7806c67..1f4e71fea25e 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -10,6 +10,8 @@ CONFIG_TARGET_WORK_92105=y CONFIG_CMD_HD44760=y CONFIG_CMD_MAX6957=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00000000 @@ -37,6 +39,7 @@ CONFIG_CMD_DATE=y CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_OFFSET_REDUND=0x120000 # CONFIG_MMC is not set CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 325390493466..f4013ed3cb24 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -7,10 +7,13 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_X530=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y @@ -44,6 +47,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="armada-385-atl-x530" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x100000 CONFIG_SPL_OF_TRANSLATE=y CONFIG_BLK=y CONFIG_DM_GPIO=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index c7c9dc4d2cc5..824ef6a2162e 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -8,9 +8,11 @@ CONFIG_SYS_TEXT_BASE=0x00800040 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_ADDR=0xD2801FF8 +CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SPL_TEXT_BASE=0xd2800b00 CONFIG_BOOTDELAY=3 @@ -45,6 +47,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:64M(ubi0),64M(ubi1)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_ADDR=0xF8060000 +CONFIG_ENV_ADDR_REDUND=0xF8070000 CONFIG_BOOTCOUNT_LIMIT=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 4087f6e00eca..07d22765a1ae 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_XFI3=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x00001000 diff --git a/configs/xilinx_zynqmp_r5_defconfig b/configs/xilinx_zynqmp_r5_defconfig index fa2960b5b245..512b4b9c0f85 100644 --- a/configs/xilinx_zynqmp_r5_defconfig +++ b/configs/xilinx_zynqmp_r5_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_ZYNQMP_R5=y CONFIG_SYS_TEXT_BASE=0x10000000 +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff010000 CONFIG_DEBUG_UART_CLOCK=100000000 diff --git a/configs/xpedite517x_defconfig b/configs/xpedite517x_defconfig index 86819427fa2f..8068a2f6ff9f 100644 --- a/configs/xpedite517x_defconfig +++ b/configs/xpedite517x_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff00000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC86xx=y CONFIG_HIGH_BATS=y CONFIG_TARGET_XPEDITE517X=y @@ -26,6 +28,7 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_DATE=y CONFIG_CMD_JFFS2=y CONFIG_CMD_IRQ=y +CONFIG_ENV_ADDR=0xFFF80000 CONFIG_CMD_PCA953X=y CONFIG_DS4510=y # CONFIG_MMC is not set diff --git a/configs/xpedite520x_defconfig b/configs/xpedite520x_defconfig index 81689a44d5f5..b2c0cb00cd3c 100644 --- a/configs/xpedite520x_defconfig +++ b/configs/xpedite520x_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_XPEDITE520X=y @@ -27,6 +29,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_JFFS2=y # CONFIG_CMD_IRQ is not set +CONFIG_ENV_ADDR=0xFFF40000 CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/xpedite537x_defconfig b/configs/xpedite537x_defconfig index 72a2a424e286..5a5bc3019e98 100644 --- a/configs/xpedite537x_defconfig +++ b/configs/xpedite537x_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_XPEDITE537X=y @@ -28,6 +30,7 @@ CONFIG_MP=y # CONFIG_CMD_HASH is not set CONFIG_CMD_JFFS2=y # CONFIG_CMD_IRQ is not set +CONFIG_ENV_ADDR=0xFFF40000 CONFIG_SYS_FSL_DDR2=y CONFIG_CMD_PCA953X=y CONFIG_DS4510=y diff --git a/configs/xpedite550x_defconfig b/configs/xpedite550x_defconfig index f86d1bdc2d14..daa356771f0e 100644 --- a/configs/xpedite550x_defconfig +++ b/configs/xpedite550x_defconfig @@ -1,5 +1,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_XPEDITE550X=y @@ -28,6 +30,7 @@ CONFIG_MP=y CONFIG_CMD_JFFS2=y # CONFIG_CMD_IRQ is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xFFF40000 CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/xpress_defconfig b/configs/xpress_defconfig index 852a53478e64..5e3e3b8d848f 100644 --- a/configs/xpress_defconfig +++ b/configs/xpress_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_XPRESS=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/ccv/xpress/imximage.cfg" CONFIG_BOOTDELAY=3 diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig index e8e54109c3f3..a7bb6e9a534a 100644 --- a/configs/xpress_spl_defconfig +++ b/configs/xpress_spl_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_XPRESS=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/xtfpga_defconfig b/configs/xtfpga_defconfig index 051bba0ceb7f..1911cdadaf20 100644 --- a/configs/xtfpga_defconfig +++ b/configs/xtfpga_defconfig @@ -1,5 +1,7 @@ CONFIG_XTENSA=y CONFIG_SYS_CPU="dc233c" +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_XTFPGA_KC705=y CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_BOOTDELAY=10 @@ -19,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_DIAG=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xF7FE0000 CONFIG_DM=y # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index 1d8484ff26a8..57553611a3e7 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_ZC5202=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig index 6eac854d07d5..49d5f4a84035 100644 --- a/configs/zc5601_defconfig +++ b/configs/zc5601_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_ZC5601=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x0 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/zmx25_defconfig b/configs/zmx25_defconfig index 3bba1ec74aa5..2513feff51b0 100644 --- a/configs/zmx25_defconfig +++ b/configs/zmx25_defconfig @@ -2,7 +2,9 @@ CONFIG_ARM=y CONFIG_ARCH_MX25=y CONFIG_SYS_TEXT_BASE=0xA0000000 CONFIG_TARGET_ZMX25=y +CONFIG_ENV_SIZE=0x20000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_BOOTDELAY=5 CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set @@ -22,6 +24,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xA0040000 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 997836ca38df..55ac82352851 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_CACHE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm012" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_ADDR=0xE20E0000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BLK=y diff --git a/env/Kconfig b/env/Kconfig index 0b97af42b1c8..bc88c59cd54d 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -467,11 +467,25 @@ config ENV_EXT4_FILE It's a string of the EXT4 file name. This file use to store the environment (explicit path to the file)
-if ARCH_ROCKCHIP || ARCH_SUNXI || ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_VERSAL || ARC || ARCH_STM32MP || ARCH_OMAP2PLUS || ARCH_AT91 +config ENV_ADDR + hex "Environment address" + depends on ENV_IS_IN_FLASH || ENV_IS_IN_NVRAM || ENV_IS_IN_ONENAND || \ + ENV_IS_IN_REMOTE || ENV_IS_IN_SPI_FLASH + default 0x0 if ENV_IS_IN_SPI_FLASH + help + Offset from the start of the device (or partition) + +config ENV_ADDR_REDUND + hex "Redundant environment address" + depends on ENV_IS_IN_FLASH && SYS_REDUNDAND_ENVIRONMENT + help + Offset from the start of the device (or partition) of the redundant + environment location.
config ENV_OFFSET - hex "Environment Offset" - depends on (!ENV_IS_IN_UBI && !ENV_IS_NOWHERE) || ARCH_STM32MP + hex "Environment offset" + depends on ENV_IS_IN_EEPROM || ENV_IS_IN_MMC || ENV_IS_IN_NAND || \ + ENV_IS_IN_SPI_FLASH default 0x3f8000 if ARCH_ROCKCHIP default 0x88000 if ARCH_SUNXI default 0xE0000 if ARCH_ZYNQ @@ -483,6 +497,14 @@ config ENV_OFFSET help Offset from the start of the device (or partition)
+config ENV_OFFSET_REDUND + hex "Redundant environment offset" + depends on (ENV_IS_IN_EEPROM || ENV_IS_IN_MMC || ENV_IS_IN_NAND || \ + ENV_IS_IN_SPI_FLASH) && SYS_REDUNDAND_ENVIRONMENT + help + Offset from the start of the device (or partition) of the redundant + environment location. + config ENV_SIZE hex "Environment Size" default 0x40000 if ENV_IS_IN_SPI_FLASH && ARCH_ZYNQMP @@ -495,7 +517,7 @@ config ENV_SIZE
config ENV_SECT_SIZE hex "Environment Sector-Size" - depends on (!ENV_IS_NOWHERE && (ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_VERSAL || ARCH_OMAP2PLUS || ARCH_AT91) )|| ARCH_STM32MP + depends on ENV_IS_IN_FLASH || ENV_IS_IN_SPI_FLASH default 0x40000 if ARCH_ZYNQMP || ARCH_VERSAL default 0x20000 if ARCH_ZYNQ || ARCH_OMAP2PLUS || ARCH_AT91 help @@ -526,8 +548,6 @@ config ENV_UBI_VID_OFFSET help UBI VID offset for environment. If 0, no custom VID offset is used.
-endif - config SYS_RELOC_GD_ENV_ADDR bool "Relocate gd->en_addr" help diff --git a/env/embedded.c b/env/embedded.c index a38e169fe0b4..208553e6af17 100644 --- a/env/embedded.c +++ b/env/embedded.c @@ -91,6 +91,6 @@ unsigned long env_size __UBOOT_ENV_SECTION__(env_size) = sizeof(env_t); /* * Add in absolutes. */ -GEN_ABS(env_offset, CONFIG_ENV_OFFSET); +GEN_ABS(env_offset, (CONFIG_ENV_ADDR - CONFIG_SYS_FLASH_BASE));
#endif /* ENV_IS_EMBEDDED */ diff --git a/env/mmc.c b/env/mmc.c index fee9f0674edc..b24c35cec94e 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -24,10 +24,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#if !defined(CONFIG_ENV_OFFSET) -#define CONFIG_ENV_OFFSET 0 -#endif - #if CONFIG_IS_ENABLED(OF_CONTROL) static inline int mmc_offset_try_partition(const char *str, s64 *val) { diff --git a/env/remote.c b/env/remote.c index 02531f427ba8..55faa1e5d0e8 100644 --- a/env/remote.c +++ b/env/remote.c @@ -18,10 +18,6 @@ env_t *env_ptr = (env_t *)CONFIG_ENV_ADDR;
-#if !defined(CONFIG_ENV_OFFSET) -#define CONFIG_ENV_OFFSET 0 -#endif - static int env_remote_init(void) { if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { diff --git a/env/sf.c b/env/sf.c index 590d0cedd852..16dba1157835 100644 --- a/env/sf.c +++ b/env/sf.c @@ -284,14 +284,14 @@ out: } #endif
-#ifdef CONFIG_ENV_ADDR +#if CONFIG_ENV_ADDR != 0x0 __weak void *env_sf_get_env_addr(void) { return (void *)CONFIG_ENV_ADDR; } #endif
-#if defined(INITENV) && defined(CONFIG_ENV_ADDR) +#if defined(INITENV) && (CONFIG_ENV_ADDR != 0x0) static int env_sf_init(void) { env_t *env_ptr = (env_t *)env_sf_get_env_addr(); @@ -315,7 +315,7 @@ U_BOOT_ENV_LOCATION(sf) = { #ifdef CMD_SAVEENV .save = env_save_ptr(env_sf_save), #endif -#if defined(INITENV) && defined(CONFIG_ENV_ADDR) +#if defined(INITENV) && (CONFIG_ENV_ADDR != 0x0) .init = env_sf_init, #endif }; diff --git a/include/configs/10m50_devboard.h b/include/configs/10m50_devboard.h index 4843a27cbf2f..3948d68014a1 100644 --- a/include/configs/10m50_devboard.h +++ b/include/configs/10m50_devboard.h @@ -62,9 +62,7 @@ * (which is common practice). */
-#define CONFIG_ENV_SIZE 0x10000 /* 64k, 1 sector */ #define CONFIG_ENV_OVERWRITE /* Serial change Ok */ -#define CONFIG_ENV_ADDR (0xf4000000 + CONFIG_SYS_MONITOR_LEN)
/* * MISC diff --git a/include/configs/3c120_devboard.h b/include/configs/3c120_devboard.h index f6ce4303a445..97bce43ce438 100644 --- a/include/configs/3c120_devboard.h +++ b/include/configs/3c120_devboard.h @@ -62,9 +62,7 @@ * (which is common practice). */
-#define CONFIG_ENV_SIZE 0x20000 /* 128k, 1 sector */ #define CONFIG_ENV_OVERWRITE /* Serial change Ok */ -#define CONFIG_ENV_ADDR (0xe2800000 + CONFIG_SYS_MONITOR_LEN)
/* * MISC diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 3ccd0925e2a5..d2133751287a 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -96,25 +96,8 @@ #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 1097) -#elif defined(CONFIG_NAND) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_ADDR 0xffe20000 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_ENV_IS_NOWHERE) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#ifndef __ASSEMBLY__ @@ -154,9 +137,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 #define CONFIG_SYS_L3_SIZE 256 << 10 #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_ADDR + 32 * 1024) -#ifdef CONFIG_NAND -#define CONFIG_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) -#endif +#define SPL_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SPL_GD_ADDR + 12 * 1024) #define CONFIG_SPL_RELOC_MALLOC_SIZE (30 << 10) #define CONFIG_SPL_RELOC_STACK (CONFIG_SPL_GD_ADDR + 64 * 1024) diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index b5d759ce025d..cd8589f0c9be 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -250,16 +250,8 @@ extern unsigned long get_sdram_size(void); * Environment */ #if defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_NAND) -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET ((768 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) -#elif defined(CONFIG_SYS_RAMBOOT) -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -#define CONFIG_ENV_SIZE 0x2000 #endif
#define CONFIG_LOADS_ECHO /* echo on for serial download */ diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 1c615acb3b3b..58841d5a92e1 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -448,22 +448,8 @@ combinations. this should be removed later #if defined(CONFIG_RAMBOOT_SDCARD) #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_NAND) || defined(CONFIG_NAND_SECBOOT) -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET ((768 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) -#elif defined(CONFIG_SYS_RAMBOOT) -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 #endif
#define CONFIG_LOADS_ECHO /* echo on for serial download */ diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 5a1a29bd9ead..dea196dd17ef 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -375,24 +375,12 @@ * Environment */ #if defined(CONFIG_SYS_RAMBOOT) -#if defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_SIZE 0x2000 -#endif #elif defined(CONFIG_NAND) #ifdef CONFIG_TPL_BUILD -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) +#define SPL_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) #else -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_RANGE CONFIG_ENV_SIZE #endif -#define CONFIG_ENV_OFFSET CONFIG_SYS_NAND_BLOCK_SIZE -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 #endif
#define CONFIG_LOADS_ECHO diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index 0a356f483ee7..867ae8be6de9 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -141,9 +141,6 @@ * Configuration for environment * Environment is embedded in u-boot in the second sector of the flash */ -#define CONFIG_ENV_OFFSET 0x2000 -#define CONFIG_ENV_SIZE 0x1000 -#define CONFIG_ENV_SECT_SIZE 0x2000
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index a9c260d5cfcf..a5a1c38f6e7d 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -174,16 +174,10 @@ #ifdef CONFIG_SYS_STMICRO_BOOT # define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE # define CONFIG_SYS_FLASH0_BASE CONFIG_SYS_CS0_BASE -# define CONFIG_ENV_OFFSET 0x30000 -# define CONFIG_ENV_SIZE 0x1000 -# define CONFIG_ENV_SECT_SIZE 0x10000 #endif #ifdef CONFIG_SYS_SPANSION_BOOT # define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE # define CONFIG_SYS_FLASH0_BASE CONFIG_SYS_CS0_BASE -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000) -# define CONFIG_ENV_SIZE 0x1000 -# define CONFIG_ENV_SECT_SIZE 0x8000 #endif
#ifdef CONFIG_SYS_FLASH_CFI diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index a197c3a853c5..3c56cec425c4 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -160,16 +160,6 @@ . = DEFINED(env_offset) ? env_offset : .; \ env/embedded.o(.text);
-#ifdef NORFLASH_PS32BIT -# define CONFIG_ENV_OFFSET (0x8000) -# define CONFIG_ENV_SIZE 0x4000 -# define CONFIG_ENV_SECT_SIZE 0x4000 -#else -# define CONFIG_ENV_OFFSET (0x4000) -# define CONFIG_ENV_SIZE 0x2000 -# define CONFIG_ENV_SECT_SIZE 0x2000 -#endif - /*----------------------------------------------------------------------- * Cache Configuration */ diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index f214dc90bc72..97c09f94c7b7 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -71,10 +71,6 @@ . = DEFINED(env_offset) ? env_offset : .; \ env/embedded.o(.text);
-#define CONFIG_ENV_OFFSET 0x4000 /* Address of Environment Sector*/ -#define CONFIG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ -#define CONFIG_ENV_SECT_SIZE 0x2000 /* see README - env sector total size */ - /*----------------------------------------------------------------------- * Start addresses for the final memory configuration * (Set up by the startup code) diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 1199fa3151cd..9fc0f5f4d19b 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -17,13 +17,6 @@ /* Configuration for environment * Environment is embedded in u-boot in the second sector of the flash */ -#ifdef CONFIG_MONITOR_IS_IN_RAM -# define CONFIG_ENV_OFFSET 0x4000 -# define CONFIG_ENV_SECT_SIZE 0x1000 -#else -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x4000) -# define CONFIG_ENV_SECT_SIZE 0x1000 -#endif
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index 9d3bf42974d4..bd9ae53d20f1 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -29,13 +29,6 @@ /* Configuration for environment * Environment is embedded in u-boot in the second sector of the flash */ -#ifndef CONFIG_MONITOR_IS_IN_RAM -#define CONFIG_ENV_OFFSET 0x4000 -#define CONFIG_ENV_SECT_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR 0xffe04000 -#define CONFIG_ENV_SECT_SIZE 0x2000 -#endif
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 682e2e397912..e9fcb5dfbc4e 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -29,13 +29,6 @@ /* Configuration for environment * Environment is embedded in u-boot in the second sector of the flash */ -#ifndef CONFIG_MONITOR_IS_IN_RAM -#define CONFIG_ENV_OFFSET 0x4000 -#define CONFIG_ENV_SECT_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR 0xffe04000 -#define CONFIG_ENV_SECT_SIZE 0x2000 -#endif
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index a06872668199..dfaa847af3fd 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -26,8 +26,6 @@ /* Configuration for environment * Environment is embedded in u-boot in the second sector of the flash */ -#define CONFIG_ENV_ADDR 0xffe04000 -#define CONFIG_ENV_SIZE 0x2000
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index 39e2748373bd..24eb36159b30 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -161,9 +161,6 @@ /* Configuration for environment * Environment is embedded in u-boot in the second sector of the flash */ -#define CONFIG_ENV_OFFSET (CONFIG_SYS_FLASH_BASE + 0x40000) -#define CONFIG_ENV_SIZE 0x1000 -#define CONFIG_ENV_SECT_SIZE 0x8000
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index 7a96dd1b7129..2cff0d6cf602 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -166,8 +166,6 @@ /* Configuration for environment * Environment is embedded in u-boot in the second sector of the flash */ -#define CONFIG_ENV_OFFSET 0x4000 -#define CONFIG_ENV_SECT_SIZE 0x2000
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index f62fb5ac63ff..576c075a174c 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -166,8 +166,6 @@ /* Configuration for environment * Environment is embedded in u-boot in the second sector of the flash */ -#define CONFIG_ENV_OFFSET 0x4000 -#define CONFIG_ENV_SECT_SIZE 0x2000
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index e07684d82034..72cc13ab79fc 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -220,21 +220,7 @@ /* Configuration for environment * Environment is embedded in u-boot in the second sector of the flash */ -#if !defined(CONFIG_SERIAL_BOOT) /*MRAM boot*/ -#define CONFIG_ENV_ADDR (0x40000 - 0x1000) /*MRAM size 40000*/ -#define CONFIG_ENV_SIZE 0x1000 -#endif
-#if defined(CONFIG_CF_SBF) -#define CONFIG_ENV_OFFSET 0x40000 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x10000 -#endif -#if defined(CONFIG_SYS_NAND_BOOT) -#define CONFIG_ENV_OFFSET 0x80000 -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_SECT_SIZE 0x20000 -#endif #undef CONFIG_ENV_OVERWRITE
/* FLASH organization */ diff --git a/include/configs/M54451EVB.h b/include/configs/M54451EVB.h index 2bd0e6223172..5482edeb2d91 100644 --- a/include/configs/M54451EVB.h +++ b/include/configs/M54451EVB.h @@ -185,15 +185,6 @@ * Environment is not embedded in u-boot. First time runing may have env * crc error warning if there is no correct environment on the flash. */ -#if defined(CONFIG_SYS_STMICRO_BOOT) -# define CONFIG_ENV_OFFSET 0x20000 -# define CONFIG_ENV_SIZE 0x2000 -# define CONFIG_ENV_SECT_SIZE 0x10000 -#else -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000) -# define CONFIG_ENV_SIZE 0x2000 -# define CONFIG_ENV_SECT_SIZE 0x20000 -#endif #undef CONFIG_ENV_OVERWRITE
/* FLASH organization */ diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index d73101f96c5e..9434cc278e2c 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -246,25 +246,16 @@ #ifdef CONFIG_SYS_STMICRO_BOOT # define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE # define CONFIG_SYS_FLASH0_BASE CONFIG_SYS_CS1_BASE -# define CONFIG_ENV_OFFSET 0x30000 -# define CONFIG_ENV_SIZE 0x2000 -# define CONFIG_ENV_SECT_SIZE 0x10000 #endif #ifdef CONFIG_SYS_ATMEL_BOOT # define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE # define CONFIG_SYS_FLASH0_BASE CONFIG_SYS_CS0_BASE # define CONFIG_SYS_FLASH1_BASE CONFIG_SYS_CS1_BASE -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000) -# define CONFIG_ENV_SIZE 0x2000 -# define CONFIG_ENV_SECT_SIZE 0x10000 #endif #ifdef CONFIG_SYS_INTEL_BOOT # define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE # define CONFIG_SYS_FLASH0_BASE CONFIG_SYS_CS0_BASE # define CONFIG_SYS_FLASH1_BASE CONFIG_SYS_CS1_BASE -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000) -# define CONFIG_ENV_SIZE 0x2000 -# define CONFIG_ENV_SECT_SIZE 0x20000 #endif
#ifdef CONFIG_SYS_FLASH_CFI diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index 7cc09ab7cc9a..721592350713 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -208,8 +208,6 @@ * First time runing may have env crc error warning if there is * no correct environment on the flash. */ -#define CONFIG_ENV_OFFSET 0x40000 -#define CONFIG_ENV_SECT_SIZE 0x10000
/*----------------------------------------------------------------------- * Cache Configuration diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index 3f5ced28ec8b..49d5d9cf1106 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -195,8 +195,6 @@ * Environment is not embedded in u-boot. First time runing may have env * crc error warning if there is no correct environment on the flash. */ -#define CONFIG_ENV_OFFSET 0x40000 -#define CONFIG_ENV_SECT_SIZE 0x10000
/*----------------------------------------------------------------------- * Cache Configuration diff --git a/include/configs/MCR3000.h b/include/configs/MCR3000.h index 3c46ae039626..72533bc80723 100644 --- a/include/configs/MCR3000.h +++ b/include/configs/MCR3000.h @@ -94,8 +94,6 @@ /* Environment Configuration */
/* environment is in FLASH */ -#define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_OFFSET 0x4000 #define CONFIG_ENV_OVERWRITE 1
/* Ethernet configuration part */ diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index e4a51d2d27e2..29561c41016c 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -248,11 +248,6 @@ /* * Environment */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ - CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE)
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8313ERDB_NAND.h b/include/configs/MPC8313ERDB_NAND.h index fb09c2630f9c..4389d66dc0cb 100644 --- a/include/configs/MPC8313ERDB_NAND.h +++ b/include/configs/MPC8313ERDB_NAND.h @@ -297,11 +297,7 @@ /* * Environment */ -#define CONFIG_ENV_OFFSET (512 * 1024) -#define CONFIG_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_RANGE (CONFIG_ENV_SECT_SIZE * 4) -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) +#define CONFIG_ENV_RANGE (CONFIG_SYS_NAND_BLOCK_SIZE * 4)
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8313ERDB_NOR.h b/include/configs/MPC8313ERDB_NOR.h index ff8dedf03e46..20aaa83f460b 100644 --- a/include/configs/MPC8313ERDB_NOR.h +++ b/include/configs/MPC8313ERDB_NOR.h @@ -266,15 +266,7 @@ * Environment */ #if !defined(CONFIG_SYS_RAMBOOT) - #define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 - /* Address and size of Redundant Environment Sector */ -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 #endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 521c5ca6eec5..169d747af9b5 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -299,15 +299,6 @@ /* * Environment */ -#if !defined(CONFIG_SYS_RAMBOOT) - #define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 94c2a6170f61..d39ba8f5d95c 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -211,15 +211,6 @@ /* * Environment */ -#ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - #define CONFIG_ENV_SECT_SIZE 0x20000 - #define CONFIG_ENV_SIZE 0x2000 -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 26a44071efd5..f410763a7ec8 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -237,15 +237,6 @@ /* * Environment */ -#ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - #define CONFIG_ENV_SECT_SIZE 0x20000 - #define CONFIG_ENV_SIZE 0x2000 -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 10293bd5f1b5..295cb169903d 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -269,17 +269,7 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 - /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) - -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 #endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ diff --git a/include/configs/MPC8349EMDS_SDRAM.h b/include/configs/MPC8349EMDS_SDRAM.h index 0193a6bfb736..79f2e38e952b 100644 --- a/include/configs/MPC8349EMDS_SDRAM.h +++ b/include/configs/MPC8349EMDS_SDRAM.h @@ -324,17 +324,7 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 - /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) - -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 #endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index c395d6237903..d0ae923ec3e7 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -340,16 +340,6 @@ boards, we say we have two, but don't display a message if we find only one. */ */ #define CONFIG_ENV_OVERWRITE
-#ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K (one sector) for environment */ - #define CONFIG_ENV_SIZE 0x2000 -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 -#endif - #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 724f8afb76d1..f6420da21deb 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -299,15 +299,6 @@ extern int board_pci_host_broken(void); /* * Environment */ -#ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 37f51ba743bc..1ba6f07e9296 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -315,15 +315,6 @@ /* * Environment */ -#ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE+CONFIG_SYS_MONITOR_LEN) - #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K (one sector) for env */ - #define CONFIG_ENV_SIZE 0x4000 -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE-0x1000) - #define CONFIG_ENV_SIZE 0x2000 -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 7697e8d3e061..8fc8dfd2b2f1 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -523,21 +523,10 @@
#if defined(CONFIG_SYS_RAMBOOT) #if defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0xF0000 -#define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_RAMBOOT_SDCARD) #define CONFIG_FSL_FIXED_MMC_LOCATION -#define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 #endif -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) - #define CONFIG_ENV_SIZE 0x2000 - #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 13ca2c395df3..a5483dabaf82 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -282,14 +282,6 @@ /* * Environment */ -#ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) - #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index e00a56e2fd9f..f81f4b0e6468 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -314,9 +314,6 @@ extern unsigned long get_clock_freq(void); /* * Environment */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) -#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ -#define CONFIG_ENV_SIZE 0x2000
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 2cbe8552358a..4eb2888caeae 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -307,13 +307,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Environment */ -#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K (one sector) */ -#if CONFIG_SYS_MONITOR_BASE > 0xfff80000 -#define CONFIG_ENV_ADDR 0xfff80000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#endif -#define CONFIG_ENV_SIZE 0x2000
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 3a8c074dc55e..a68d190f6ab5 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -429,13 +429,6 @@ extern unsigned long get_clock_freq(void); /* * Environment */ -#if CONFIG_SYS_MONITOR_BASE > 0xfff80000 -#define CONFIG_ENV_ADDR 0xfff80000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#endif -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K for env */ -#define CONFIG_ENV_SIZE 0x2000
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 5b3933412c23..d53e156f3089 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -312,9 +312,6 @@ extern unsigned long get_clock_freq(void); /* * Environment */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) -#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ -#define CONFIG_ENV_SIZE 0x2000
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 5ba2b6d64348..20684dc6f3d3 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -315,14 +315,6 @@ /* * Environment */ -#ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) - #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 01ee69c0131b..3a078a363c36 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -325,9 +325,6 @@ extern unsigned long get_clock_freq(void); /* * Environment */ -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE)
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index de187bf9a4f5..da86f94e544f 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -409,12 +409,6 @@ extern unsigned long get_clock_freq(void); /* * Environment */ -#if defined(CONFIG_SYS_RAMBOOT) -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ -#define CONFIG_ENV_SIZE 0x2000 -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index e3952f423bfb..0f4c7e6f4885 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -506,18 +506,6 @@ * Environment */
-#if defined(CONFIG_SYS_RAMBOOT) - -#else - #if CONFIG_SYS_MONITOR_BASE > 0xfff80000 - #define CONFIG_ENV_ADDR 0xfff80000 - #else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) - #endif - #define CONFIG_ENV_SIZE 0x2000 - #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif - #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 04f55e399041..8b10a6cfef94 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -383,14 +383,6 @@ /* * Environment */ -#ifndef CONFIG_SYS_RAMBOOT -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 126k (one sector) for env */ -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -#define CONFIG_ENV_SIZE 0x2000 -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 8c01891e263a..db05a6cb077a 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -545,14 +545,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Environment */ -#ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -#endif -#define CONFIG_ENV_SIZE 0x2000
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index fab355e1f2a4..c58b7814ba94 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -78,11 +78,7 @@
/* ENV setting */ #define CONFIG_ENV_OVERWRITE 1 -#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) /* Offset of env Flash sector relative to CONFIG_SYS_FLASH_BASE */ -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR - CONFIG_SYS_FLASH_BASE)
/* Board Clock */ #define CONFIG_SYS_CLK_FREQ 33333333 diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 344e19d2c55c..9244feea8bdf 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -629,32 +629,16 @@ extern unsigned long get_sdram_size(void); #if defined(CONFIG_SDCARD) #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_NAND) #ifdef CONFIG_TPL_BUILD -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) +#define SPL_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) #else #if defined(CONFIG_TARGET_P1010RDB_PA) -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) /* 3*16=48K for env */ #elif defined(CONFIG_TARGET_P1010RDB_PB) -#define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_RANGE (32 * CONFIG_ENV_SIZE) /* new block size 512K */ #endif #endif -#define CONFIG_ENV_OFFSET (1024 * 1024) -#elif defined(CONFIG_SYS_RAMBOOT) -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#define CONFIG_LOADS_ECHO /* echo on for serial download */ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 4b2eb6525bde..db4b94ec1ecb 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -492,30 +492,16 @@ /* * Environment */ -#ifdef CONFIG_SPIFLASH -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#elif defined(CONFIG_SDCARD) +#if defined(CONFIG_SDCARD) #define CONFIG_FSL_FIXED_MMC_LOCATION -#define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 #elif defined(CONFIG_NAND) +#define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) #ifdef CONFIG_TPL_BUILD -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) -#else -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define SPL_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) #endif -#define CONFIG_ENV_OFFSET (1024 * 1024) -#define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) #elif defined(CONFIG_SYS_RAMBOOT) -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#define SPL_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #endif
#define CONFIG_LOADS_ECHO diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 9535a7bbb2fa..1818b4b70d7c 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -214,10 +214,6 @@ extern unsigned long get_clock_freq(void); */ #define CONFIG_ENV_OVERWRITE
-#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ - #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index f8cfef7b2d75..d0a935c41124 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -48,27 +48,9 @@ #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SPIFLASH) - #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ - #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ - #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_SYS_MMC_ENV_DEV 0 - #define CONFIG_ENV_SIZE 0x2000 - #define CONFIG_ENV_OFFSET (512 * 1658) -#elif defined(CONFIG_NAND) -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_ADDR 0xffe20000 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_ENV_IS_NOWHERE) -#define CONFIG_ENV_SIZE 0x2000 -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE \ - - CONFIG_ENV_SECT_SIZE) - #define CONFIG_ENV_SIZE 0x2000 - #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#ifndef __ASSEMBLY__ diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index f24cd23af223..b17113ab9a82 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -56,9 +56,6 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ -#define CONFIG_ENV_SIZE 0x02000 -#define CONFIG_ENV_OFFSET 0xc0000 /* env starts here - 768K */
/* * U-Boot bootcode configuration diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index b60232326271..462e62c7c204 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -56,9 +56,6 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ -#define CONFIG_ENV_SIZE 0x02000 -#define CONFIG_ENV_OFFSET 0xc0000 /* env starts here - 768K */
/* * U-Boot bootcode configuration diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index fe9a9097ce9a..c6b88c16545c 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -122,25 +122,8 @@ #endif
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 0x800) -#elif defined(CONFIG_NAND) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_ADDR 0xffe20000 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_ENV_IS_NOWHERE) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#ifndef __ASSEMBLY__ @@ -173,9 +156,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 #define CONFIG_SYS_L3_SIZE (256 << 10) #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_ADDR + 32 * 1024) -#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) -#endif +#define SPL_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SPL_GD_ADDR + 12 * 1024) #define CONFIG_SPL_RELOC_MALLOC_SIZE (30 << 10) #define CONFIG_SPL_RELOC_STACK (CONFIG_SPL_GD_ADDR + 64 * 1024) diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 8c1434fb10e0..88a6f0361a65 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -137,33 +137,8 @@ #endif
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#if defined(CONFIG_TARGET_T1024RDB) -#define CONFIG_ENV_SECT_SIZE 0x10000 -#elif defined(CONFIG_TARGET_T1023RDB) -#define CONFIG_ENV_SECT_SIZE 0x40000 -#endif #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 0x800) -#elif defined(CONFIG_NAND) -#define CONFIG_ENV_SIZE 0x2000 -#if defined(CONFIG_TARGET_T1024RDB) -#define CONFIG_ENV_OFFSET (2 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_TARGET_T1023RDB) -#define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) -#endif -#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_ADDR 0xffe20000 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_ENV_IS_NOWHERE) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#ifndef __ASSEMBLY__ @@ -196,9 +171,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 #define CONFIG_SYS_L3_SIZE (256 << 10) #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_ADDR + 32 * 1024) -#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) -#endif +#define SPL_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SPL_GD_ADDR + 12 * 1024) #define CONFIG_SPL_RELOC_MALLOC_SIZE (30 << 10) #define CONFIG_SPL_RELOC_STACK (CONFIG_SPL_GD_ADDR + 64 * 1024) diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index d8b65e699c93..2881ee9e1841 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -59,24 +59,9 @@
#ifdef CONFIG_MTD_NOR_FLASH #if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 1658) -#elif defined(CONFIG_NAND) -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif -#else /* CONFIG_MTD_NOR_FLASH */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#ifndef __ASSEMBLY__ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 7cc3db943e50..a8e51e72c639 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -155,24 +155,13 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 0x800) #elif defined(CONFIG_NAND) #ifdef CONFIG_NXP_ESBC #define CONFIG_RAMBOOT_NAND #define CONFIG_BOOTSCRIPT_COPY_RAM #endif -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (3 * CONFIG_SYS_NAND_BLOCK_SIZE) -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#define CONFIG_SYS_CLK_FREQ 100000000 @@ -211,9 +200,7 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_SYS_INIT_L3_VADDR 0xFFFC0000 #define CONFIG_SYS_L3_SIZE 256 << 10 #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_VADDR + 32 * 1024) -#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) -#endif +#define SPL_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SPL_GD_ADDR + 12 * 1024) #define CONFIG_SPL_RELOC_MALLOC_SIZE (30 << 10) #define CONFIG_SPL_RELOC_STACK (CONFIG_SPL_GD_ADDR + 64 * 1024) diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 54ec1abd66a2..f485e4e6da6d 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -118,25 +118,8 @@ #endif
#ifndef __ASSEMBLY__ @@ -153,9 +136,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 #define CONFIG_SYS_L3_SIZE (512 << 10) #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_ADDR + 32 * 1024) -#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) -#endif +#define SPL_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SPL_GD_ADDR + 12 * 1024) #define CONFIG_SPL_RELOC_MALLOC_SIZE (50 << 10) #define CONFIG_SPL_RELOC_STACK (CONFIG_SPL_GD_ADDR + 64 * 1024) diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 3d95c4afa262..b64bafdb330e 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -103,25 +103,8 @@ #define CONFIG_SYS_MEMTEST_END 0x00400000
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 0x800) -#elif defined(CONFIG_NAND) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (2 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_ADDR 0xffe20000 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_ENV_IS_NOWHERE) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#ifndef __ASSEMBLY__ @@ -138,9 +121,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 #define CONFIG_SYS_L3_SIZE (512 << 10) #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_ADDR + 32 * 1024) -#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) -#endif +#define SPL_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SPL_GD_ADDR + 12 * 1024) #define CONFIG_SPL_RELOC_MALLOC_SIZE (50 << 10) #define CONFIG_SPL_RELOC_STACK (CONFIG_SPL_GD_ADDR + 64 * 1024) diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index f17625365e14..a7ef469375e0 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -69,25 +69,8 @@ #include "t4qds.h"
#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 57d8d171a7db..fc2aed335688 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -89,9 +89,7 @@ #define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 #define CONFIG_SYS_L3_SIZE (512 << 10) #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_ADDR + 32 * 1024) -#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) -#endif +#define SPL_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SPL_GD_ADDR + 12 * 1024) #define CONFIG_SPL_RELOC_MALLOC_SIZE (50 << 10) #define CONFIG_SPL_RELOC_STACK (CONFIG_SPL_GD_ADDR + 64 * 1024) @@ -280,22 +278,8 @@ "bootm 0x01000000 - 0x00f00000"
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 0x800) -#elif defined(CONFIG_NAND) -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_ENV_IS_NOWHERE) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#define CONFIG_SYS_CLK_FREQ 66666666 diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index c8537e03139e..f557a3c93624 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -186,11 +186,6 @@ /* * Environment */ -#define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) for env */ -#define CONFIG_ENV_SIZE 0x8000 /* 32K max size */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE)
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index b2778a93c984..68276a15a748 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -370,49 +370,11 @@ /* * Environment */ -#ifdef CONFIG_ENV_FIT_UCBOOT - -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x20000) -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ - -#else - - -#ifdef CONFIG_RAMBOOT_SPIFLASH - -#define CONFIG_ENV_SIZE 0x3000 /* 12KB */ -#define CONFIG_ENV_OFFSET 0x2000 /* 8KB */ -#define CONFIG_ENV_SECT_SIZE 0x1000 - -#if defined(CONFIG_SYS_REDUNDAND_ENVIRONMENT) -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#endif - -#elif defined(CONFIG_RAMBOOT_SDCARD) +#if !defined(CONFIG_ENV_FIT_UCBOOT) && defined(CONFIG_RAMBOOT_SDCARD) #define CONFIG_FSL_FIXED_MMC_LOCATION -#define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 - -#elif defined(CONFIG_SYS_RAMBOOT) -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -#define CONFIG_ENV_SIZE 0x2000 - -#else -#define CONFIG_ENV_BASE (CONFIG_SYS_FLASH_BASE) -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_ADDR (CONFIG_ENV_BASE + 0xC0000) -#if defined(CONFIG_SYS_REDUNDAND_ENVIRONMENT) -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SIZE) #endif
-#endif - -#endif /* CONFIG_ENV_FIT_UCBOOT */ - #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index 1fe33917d01f..5b035c7ec5a3 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -201,9 +201,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 512
/* environments */ -#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OFFSET 0x140000 -#define CONFIG_ENV_SIZE 8192 #define CONFIG_ENV_OVERWRITE
diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 6cf494e73f5b..71c7fe929d3d 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -316,12 +316,9 @@
/* max number of sectors on one chip */ #define CONFIG_FLASH_SECTOR_SIZE (0x10000*2) -#define CONFIG_ENV_SECT_SIZE CONFIG_FLASH_SECTOR_SIZE #define CONFIG_SYS_MAX_FLASH_SECT 512
/* environments */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x140000) -#define CONFIG_ENV_SIZE 8192 #define CONFIG_ENV_OVERWRITE
/* diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 129885981217..a115676d4cf1 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -204,10 +204,6 @@
/* FLASH and environment organization */
-#define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_OFFSET (768 * 1024) -#define CONFIG_ENV_SECT_SIZE (64 * 1024) - #define CONFIG_SYS_FSL_USDHC_NUM 3
/* Framebuffer */ diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 15cda803cc2b..085b2bcac048 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -274,23 +274,11 @@ */ #if defined(CONFIG_SPI_BOOT) /* SPL related */ - -#define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ -#define CONFIG_ENV_OFFSET (768 << 10) /* 768 KiB in */ -#define CONFIG_ENV_OFFSET_REDUND (896 << 10) /* 896 KiB in */ #elif defined(CONFIG_EMMC_BOOT) #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 0 -#define CONFIG_ENV_OFFSET 0x260000 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_MAX_DEVICE 2 -#elif defined(CONFIG_NOR_BOOT) -#define CONFIG_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_ENV_OFFSET (512 << 10) /* 512 KiB */ -#define CONFIG_ENV_OFFSET_REDUND (768 << 10) /* 768 KiB */ #elif defined(CONFIG_ENV_IS_IN_NAND) -#define CONFIG_ENV_OFFSET 0x001c0000 -#define CONFIG_ENV_OFFSET_REDUND 0x001e0000 #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #endif
diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index b34e48cb454e..eabf19ddebd0 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -45,13 +45,9 @@ * ENV at MMC Boot0 Partition - 0/Undefined=user, 1=boot0, 2=boot1, * 4..7=general0..3 */ -#define CONFIG_ENV_SIZE 0x1000 /* 4 KB */ -#define CONFIG_ENV_OFFSET 0x7000 /* 28 kB */
#define CONFIG_HSMMC2_8BIT
-#define CONFIG_ENV_OFFSET_REDUND 0x9000 /* 36 kB */ - #ifndef CONFIG_SHC_ICT /* * In builds other than ICT, reset to retry after timeout diff --git a/include/configs/am335x_sl50.h b/include/configs/am335x_sl50.h index 7bb2bff5d18e..0453cb2965f0 100644 --- a/include/configs/am335x_sl50.h +++ b/include/configs/am335x_sl50.h @@ -78,8 +78,6 @@ #if defined(CONFIG_EMMC_BOOT) #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET 0x0 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #endif
/* Network. */ diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 5fa393d45d5d..6087a29ef4c4 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -182,7 +182,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB sector */ -#define CONFIG_ENV_ADDR 0x260000
/*----------------------------------------------------------------------- * CFI FLASH driver setup diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 3e5f0b1992f3..05ee21b08c26 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -176,7 +176,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_ENV_ADDR 0x260000
/* Defines for SPL */
diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 9db006880b88..487083294cea 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -108,10 +108,6 @@ #define DFUARGS #endif
-#ifdef CONFIG_QSPI_BOOT -#define CONFIG_ENV_OFFSET_REDUND 0x120000 -#endif - #ifndef CONFIG_SPL_BUILD #include <environment/ti/dfu.h> #include <environment/ti/mmc.h> diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index baeca5417d22..cdab9246f2c5 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -19,7 +19,6 @@ /* MMC ENV related defines */ #define CONFIG_SYS_MMC_ENV_DEV 1 /* eMMC */ #define CONFIG_SYS_MMC_ENV_PART 0 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
#define CONFIG_SYS_BOOTM_LEN SZ_64M
diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h index 9c06f10a2f18..06be7cc8a469 100644 --- a/include/configs/am65x_evm.h +++ b/include/configs/am65x_evm.h @@ -14,8 +14,6 @@ #include <environment/ti/mmc.h> #include <environment/ti/k3_rproc.h>
-#define CONFIG_ENV_SIZE (128 << 10) - /* DDR Configuration */ #define CONFIG_SYS_SDRAM_BASE1 0x880000000
@@ -118,9 +116,6 @@ #ifdef CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 1 -#define CONFIG_ENV_SIZE (128 << 10) -#define CONFIG_ENV_OFFSET 0x680000 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #endif
#define CONFIG_SUPPORT_EMMC_BOOT diff --git a/include/configs/amcore.h b/include/configs/amcore.h index 26d6fef290bc..bc1fc8c7b015 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -64,11 +64,6 @@ #define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) #define CONFIG_SYS_BOOTPARAMS_LEN (64 * 1024)
-#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ - CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SIZE 0x1000 -#define CONFIG_ENV_SECT_SIZE 0x1000 - #define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ env/embedded.o(.text*); diff --git a/include/configs/ap121.h b/include/configs/ap121.h index 0e8c3f70d959..07ba195a126c 100644 --- a/include/configs/ap121.h +++ b/include/configs/ap121.h @@ -30,10 +30,6 @@ "mtdparts default;" \ "bootm 0x9f650000"
-#define CONFIG_ENV_OFFSET 0x40000 -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_SIZE 0x10000 - /* Miscellaneous configurable options */
/* diff --git a/include/configs/ap143.h b/include/configs/ap143.h index fa6921022d05..d6c22d54893a 100644 --- a/include/configs/ap143.h +++ b/include/configs/ap143.h @@ -34,10 +34,6 @@ "mtdparts default;" \ "bootm 0x9f680000"
/* diff --git a/include/configs/ap152.h b/include/configs/ap152.h index c948a4405412..73378b95f3f4 100644 --- a/include/configs/ap152.h +++ b/include/configs/ap152.h @@ -35,9 +35,6 @@ "bootm 0x9f060000"
#define CONFIG_ENV_SPI_MAX_HZ 25000000 -#define CONFIG_ENV_OFFSET 0x40000 -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_SIZE 0x10000
diff --git a/include/configs/apalis-imx8.h b/include/configs/apalis-imx8.h index 3a8d2d40d776..bea035c3e23b 100644 --- a/include/configs/apalis-imx8.h +++ b/include/configs/apalis-imx8.h @@ -86,9 +86,6 @@ #define CONFIG_SYS_MEMTEST_END 0x89000000
/* Environment in eMMC, before config block at the end of 1st "boot sector" */ -#define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ - CONFIG_TDX_CFG_BLOCK_OFFSET) #define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC1 eMMC */ #define CONFIG_SYS_MMC_ENV_PART 1
diff --git a/include/configs/apalis-tk1.h b/include/configs/apalis-tk1.h index fe45917b885d..4127f2d6c624 100644 --- a/include/configs/apalis-tk1.h +++ b/include/configs/apalis-tk1.h @@ -22,8 +22,6 @@ #define FDT_MODULE_V1_0 "apalis"
/* Environment in eMMC, before config block at the end of 1st "boot sector" */ -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ - CONFIG_TDX_CFG_BLOCK_OFFSET) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 1
diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index a5f9a96732fd..50a4391cd47d 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -225,12 +225,9 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* environment organization */ -#define CONFIG_ENV_SIZE (8 * 1024)
#if defined(CONFIG_ENV_IS_IN_MMC) /* Environment in eMMC, before config block at the end of 1st "boot sector" */ -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ - CONFIG_TDX_CFG_BLOCK_OFFSET) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 1 #endif diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index f6adfeb96a56..821162a2be8a 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -19,8 +19,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_APALIS_T30
diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 16a257406321..351b27094a61 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -66,11 +66,7 @@ #define ACFG_MONITOR_OFFSET 0x00000000 #define CONFIG_SYS_MONITOR_LEN 0x00100000 /* 1MiB */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_OFFSET 0x00100000 /* NAND offset */ -#define CONFIG_ENV_SIZE 0x00020000 /* 128kB */ #define CONFIG_ENV_RANGE 0X00080000 /* 512kB */ -#define CONFIG_ENV_OFFSET_REDUND \ - (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) /* +512kB */ #define CONFIG_FIRMWARE_OFFSET 0x00200000 #define CONFIG_FIRMWARE_SIZE 0x00080000 /* 512kB */ #define CONFIG_KERNEL_OFFSET 0x00300000 diff --git a/include/configs/apx4devkit.h b/include/configs/apx4devkit.h index 66b616c80bb1..b66069c81a81 100644 --- a/include/configs/apx4devkit.h +++ b/include/configs/apx4devkit.h @@ -26,19 +26,12 @@
/* Environment is in MMC */ #if defined(CONFIG_CMD_MMC) && defined(CONFIG_ENV_IS_IN_MMC) -#define CONFIG_ENV_OFFSET (256 * 1024) -#define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 #endif
/* Environment is in NAND */ #if defined(CONFIG_CMD_NAND) && defined(CONFIG_ENV_IS_IN_NAND) -#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_SIZE (128 * 1024) #define CONFIG_ENV_RANGE (384 * 1024) -#define CONFIG_ENV_OFFSET 0x120000 -#define CONFIG_ENV_OFFSET_REDUND \ - (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) #endif
/* UBI and NAND partitioning */ diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 041abb5ac1f6..1d84db509834 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -146,10 +146,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_SIZE (12 * 1024) -#define CONFIG_ENV_SECT_SIZE (0x010000) -#define CONFIG_ENV_OFFSET (0x0d0000) -#define CONFIG_ENV_OFFSET_REDUND (0x0e0000)
#define CONFIG_SYS_FSL_USDHC_NUM 2
diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index dc611da035f4..e9f1eb21426b 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -70,11 +70,6 @@
/* ENV setting */ #define CONFIG_ENV_OVERWRITE 1 -#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ - CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE)
/* SH Ether */ #define CONFIG_SH_ETHER_USE_PORT 0 diff --git a/include/configs/arndale.h b/include/configs/arndale.h index 8aa6e1d0c326..308cd30cb3d5 100644 --- a/include/configs/arndale.h +++ b/include/configs/arndale.h @@ -23,8 +23,6 @@ /* Miscellaneous configurable options */ #define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0"
-#define CONFIG_ENV_OFFSET (CONFIG_BL2_OFFSET + CONFIG_BL2_SIZE) - #define CONFIG_IRAM_STACK 0x02050000
#define CONFIG_SYS_INIT_SP_ADDR CONFIG_IRAM_STACK diff --git a/include/configs/aspenite.h b/include/configs/aspenite.h index 79bf8f26e932..717ed53d839e 100644 --- a/include/configs/aspenite.h +++ b/include/configs/aspenite.h @@ -35,6 +35,5 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_SIZE 0x20000 /* 64k */
#endif /* __CONFIG_ASPENITE_H */ diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index 2e7fbfb396ce..3d79311d625f 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -109,8 +109,6 @@ */
#ifndef CONFIG_MONITOR_IS_IN_RAM -#define CONFIG_ENV_OFFSET 0x1FF8000 -#define CONFIG_ENV_SECT_SIZE 0x8000 #else /* * environment in RAM - This is used to use a single PC-based application @@ -118,8 +116,6 @@ * to execute the commands from the environment. Feedback is done via setting * and reading memory locations. */ -#define CONFIG_ENV_ADDR 0x40060000 -#define CONFIG_ENV_SECT_SIZE 0x8000 #endif
/* here we put our FPGA configuration... */ diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index 61312773671d..d19fd3153c37 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -49,7 +49,6 @@
#ifdef CONFIG_NAND_BOOT /* u-boot env in nand flash */ -#define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_BOOTCOMMAND "nand read 0x21000000 0x180000 0x80000;" \ "nand read 0x22000000 0x200000 0x600000;" \ "bootz 0x22000000 - 0x21000000" diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 8bfba35e16a7..e52f7e440bb9 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -143,8 +143,6 @@ /* * after u-boot.bin */ -#define CONFIG_ENV_ADDR \ - (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN)
/* The following #defines are needed to get flash environment right */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index b283c9d8737f..3156118e9637 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -114,18 +114,12 @@ #ifdef CONFIG_SYS_USE_DATAFLASH_CS0
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_ENV_SECT_SIZE 0x210 #define CONFIG_BOOTCOMMAND "sf probe 0:0; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000"
#elif CONFIG_SYS_USE_DATAFLASH_CS1
-#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_ENV_SECT_SIZE 0x210 #define CONFIG_BOOTCOMMAND "sf probe 0:1; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" @@ -133,16 +127,11 @@ #elif defined(CONFIG_SYS_USE_NANDFLASH)
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_OFFSET 0x140000 -#define CONFIG_ENV_OFFSET_REDUND 0x100000 -#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ #define CONFIG_BOOTCOMMAND "nand read 0x22000000 0x200000 0x300000; bootm"
#else /* CONFIG_SYS_USE_MMC */ /* bootstrap + u-boot + env + linux in mmc */ /* For FAT system, most cases it should be in the reserved sector */ -#define CONFIG_ENV_OFFSET 0x2000 -#define CONFIG_ENV_SIZE 0x1000 #define CONFIG_SYS_MMC_ENV_DEV 0
#define CONFIG_BOOTCOMMAND \ diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 599e2627f6cc..39b879b3b1bc 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -101,9 +101,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH_CS0
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_ENV_SECT_SIZE 0x210 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" @@ -111,9 +108,6 @@ #elif CONFIG_SYS_USE_DATAFLASH_CS3
/* bootstrap + u-boot + env + linux in dataflash on CS3 */ -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_ENV_SECT_SIZE 0x210 #define CONFIG_BOOTCOMMAND "sf probe 0:3; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" @@ -121,9 +115,6 @@ #else /* CONFIG_SYS_USE_NANDFLASH */
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_OFFSET 0x140000 -#define CONFIG_ENV_OFFSET_REDUND 0x100000 -#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ #define CONFIG_BOOTCOMMAND "nand read 0x22000000 0x200000 0x300000; bootm" #endif
diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 3e7adf63f30e..c08845b3c8d3 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -66,11 +66,8 @@ #define CONFIG_SYS_MONITOR_SEC 1:0-3 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN (256 << 10) -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x007E0000) -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR - CONFIG_ENV_SIZE)
/* Address and size of Primary Environment Sector */ -#define CONFIG_ENV_SIZE 0x10000
#define CONFIG_EXTRA_ENV_SETTINGS \ "monitor_base=" __stringify(CONFIG_SYS_MONITOR_BASE) "\0" \ @@ -217,9 +214,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_ENV_SECT_SIZE 0x210 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" @@ -227,9 +221,6 @@ #elif CONFIG_SYS_USE_NANDFLASH
diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 044c428a716a..ee207cfcca2f 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -74,16 +74,12 @@
#ifdef CONFIG_NAND_BOOT /* bootstrap + u-boot + env in nandflash */ -#define CONFIG_ENV_OFFSET 0x140000 -#define CONFIG_ENV_OFFSET_REDUND 0x100000 -#define CONFIG_ENV_SIZE 0x20000
#define CONFIG_BOOTCOMMAND \ "nand read 0x70000000 0x200000 0x300000;" \ "bootm 0x70000000" #elif CONFIG_SD_BOOT /* bootstrap + u-boot + env + linux in mmc */ -#define CONFIG_ENV_SIZE 0x4000
#define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x71000000 dtb; " \ "fatload mmc 0:1 0x72000000 zImage; " \ diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index bc79e1739ba9..caa487b038b8 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -85,9 +85,6 @@ #ifdef CONFIG_SPI_BOOT
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_OFFSET 0x5000 -#define CONFIG_ENV_SIZE 0x3000 -#define CONFIG_ENV_SECT_SIZE 0x1000 #define CONFIG_BOOTCOMMAND \ "setenv bootargs ${console} ${mtdparts} ${bootargs_nand};" \ "sf probe 0; sf read 0x22000000 0x100000 0x300000; " \ @@ -96,9 +93,6 @@ #elif defined(CONFIG_NAND_BOOT)
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_OFFSET 0x140000 -#define CONFIG_ENV_OFFSET_REDUND 0x100000 -#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ #define CONFIG_BOOTCOMMAND \ "setenv bootargs ${console} ${mtdparts} ${bootargs_nand};" \ "nand read 0x21000000 0x180000 0x080000;" \ @@ -111,12 +105,9 @@
#ifdef CONFIG_ENV_IS_IN_MMC /* Use raw reserved sectors to save environment */ -#define CONFIG_ENV_OFFSET 0x2000 -#define CONFIG_ENV_SIZE 0x1000 #define CONFIG_SYS_MMC_ENV_DEV 0 #else /* Use file in FAT file to save environment */ -#define CONFIG_ENV_SIZE 0x4000 #endif
#define CONFIG_BOOTCOMMAND \ diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 1c67be56b02b..1da26049fd9a 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -72,9 +72,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_ENV_SECT_SIZE 0x210 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" @@ -82,9 +79,6 @@ #elif CONFIG_SYS_USE_NANDFLASH
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_OFFSET 0x140000 -#define CONFIG_ENV_OFFSET_REDUND 0x100000 -#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ #define CONFIG_BOOTCOMMAND "nand read 0x22000000 0x200000 0x600000; " \ "nand read 0x21000000 0x180000 0x80000; " \ "bootz 0x22000000 - 0x21000000" @@ -92,7 +86,6 @@ #else /* CONFIG_SYS_USE_MMC */
/* bootstrap + u-boot + env + linux in mmc */ -#define CONFIG_ENV_SIZE 0x4000 #define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x21000000 at91sam9rlek.dtb; " \ "fatload mmc 0:1 0x22000000 zImage; " \ "bootz 0x22000000 - 0x21000000" diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index f9a100ba2462..d85a4867648a 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -72,7 +72,6 @@
#ifdef CONFIG_NAND_BOOT /* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_BOOTCOMMAND "nand read " \ "0x22000000 0x200000 0x600000; " \ "nand read 0x21000000 0x180000 0x20000; " \ diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index a4037f33dd25..5fd7a6043f51 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -113,7 +113,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 512
/* environments */ -#define CONFIG_ENV_SECT_SIZE 0x1000 #define CONFIG_ENV_OVERWRITE
/* SPI FLASH */ @@ -130,7 +129,6 @@ #define CONFIG_SYS_BOOTM_LEN (64 << 20)
/* When we use RAM as ENV */ -#define CONFIG_ENV_SIZE 0x2000
/* Enable distro boot */ #define BOOT_TARGET_DEVICES(func) \ diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 4ecf8de33344..a31b71ea98dd 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -360,8 +360,6 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 -#define CONFIG_ENV_OFFSET 0x001c0000 -#define CONFIG_ENV_OFFSET_REDUND 0x001e0000 #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE /* NAND: SPL related configs */ #ifdef CONFIG_SPL_OS_BOOT @@ -443,15 +441,9 @@ DEFAULT_LINUX_BOOT_ENV \ */ #if defined(CONFIG_SPI_BOOT) /* SPL related */ - -#define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ -#define CONFIG_ENV_OFFSET (768 << 10) /* 768 KiB in */ -#define CONFIG_ENV_OFFSET_REDUND (896 << 10) /* 896 KiB in */ #elif defined(CONFIG_EMMC_BOOT) #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET 0x0 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #endif
/* SPI flash. */ @@ -479,11 +471,6 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_SYS_FLASH_SIZE 0x01000000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Reduce SPL size by removing unlikey targets */ -#ifdef CONFIG_NOR_BOOT -#define CONFIG_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_ENV_OFFSET (512 << 10) /* 512 KiB */ -#define CONFIG_ENV_OFFSET_REDUND (768 << 10) /* 768 KiB */ -#endif #endif /* NOR support */
#endif /* ! __CONFIG_AM335X_EVM_H */ diff --git a/include/configs/bayleybay.h b/include/configs/bayleybay.h index 288bb8e425d3..0198051bcf26 100644 --- a/include/configs/bayleybay.h +++ b/include/configs/bayleybay.h @@ -19,7 +19,5 @@ "stderr=serial,vidconsole\0"
/* Environment configuration */ -#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OFFSET 0x006ff000
#endif /* __CONFIG_H */ diff --git a/include/configs/bcm23550_w1d.h b/include/configs/bcm23550_w1d.h index f59cd75d6898..e771548aa670 100644 --- a/include/configs/bcm23550_w1d.h +++ b/include/configs/bcm23550_w1d.h @@ -77,8 +77,6 @@
/* must fit into GPT:u-boot-env partition */ #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_OFFSET (0x00011a00 * 512) -#define CONFIG_ENV_SIZE (8 * 512)
/* console configuration */ #define CONFIG_SYS_CBSIZE 1024 /* Console buffer size */ diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index 111858ffb043..d807997277ae 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -76,8 +76,6 @@
/* console configuration */ #define CONFIG_SYS_CBSIZE 1024 /* Console buffer size */ diff --git a/include/configs/bcm7260.h b/include/configs/bcm7260.h index 967bde54c866..3bd85ffe281b 100644 --- a/include/configs/bcm7260.h +++ b/include/configs/bcm7260.h @@ -30,7 +30,6 @@ /* * Environment configuration for eMMC. */ -#define CONFIG_ENV_OFFSET (0x000040a4 * 512) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 0
diff --git a/include/configs/bcm7445.h b/include/configs/bcm7445.h index 3ff4677f0af1..ce865cb4564e 100644 --- a/include/configs/bcm7445.h +++ b/include/configs/bcm7445.h @@ -30,8 +30,6 @@ /* * Environment configuration for SPI flash. */ -#define CONFIG_ENV_OFFSET 0x1e0000 -#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE
#define CONFIG_SYS_MAX_FLASH_BANKS 1
diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index b67100aa3aa4..273f08e5e15d 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -42,8 +42,6 @@ /* Serial Info */ #define CONFIG_SYS_NS16550_SERIAL
-#define CONFIG_ENV_SIZE 0x2000 - /* console configuration */ #define CONFIG_SYS_CBSIZE 1024 /* Console buffer size */ #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/bcm_northstar2.h b/include/configs/bcm_northstar2.h index 754bf2e0dbef..45dc7b29c9e4 100644 --- a/include/configs/bcm_northstar2.h +++ b/include/configs/bcm_northstar2.h @@ -33,8 +33,6 @@ #define CONFIG_SYS_NS16550_COM4 0x66130000 #define CONFIG_BAUDRATE 115200
-#define CONFIG_ENV_SIZE SZ_8K - /* console configuration */ #define CONFIG_SYS_CBSIZE SZ_1K #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/bcmstb.h b/include/configs/bcmstb.h index 2feabdd6c6df..ba5eb7a4a8aa 100644 --- a/include/configs/bcmstb.h +++ b/include/configs/bcmstb.h @@ -149,8 +149,6 @@ extern phys_addr_t prior_stage_fdt_address; /* * Environment configuration. */ -#define CONFIG_ENV_SIZE (64 << 10) /* 64 KiB */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_ENV_OVERWRITE
/* diff --git a/include/configs/beaver.h b/include/configs/beaver.h index 4c5826cd983d..1b6ba8c85d24 100644 --- a/include/configs/beaver.h +++ b/include/configs/beaver.h @@ -23,7 +23,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_BEAVER
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2
diff --git a/include/configs/bg0900.h b/include/configs/bg0900.h index c05b06a417bb..5a17a2a1c1dc 100644 --- a/include/configs/bg0900.h +++ b/include/configs/bg0900.h @@ -11,7 +11,6 @@ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
/* Environment */ -#define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OVERWRITE
/* FEC Ethernet on SoC */ diff --git a/include/configs/bk4r1.h b/include/configs/bk4r1.h index 2575a0de3f93..0566892e157a 100644 --- a/include/configs/bk4r1.h +++ b/include/configs/bk4r1.h @@ -259,11 +259,4 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
-#ifdef CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SECT_SIZE (SZ_128K) -#define CONFIG_ENV_SIZE (SZ_8K) -#define CONFIG_ENV_OFFSET 0x200000 -#define CONFIG_ENV_OFFSET_REDUND 0x220000 -#endif - #endif /* __CONFIG_H */ diff --git a/include/configs/blanche.h b/include/configs/blanche.h index 7f4a204a3959..7ee38a7ef9bc 100644 --- a/include/configs/blanche.h +++ b/include/configs/blanche.h @@ -52,13 +52,5 @@ #define CONFIG_SYS_CLK_FREQ RMOBILE_XTAL_CLK
/* ENV setting */ -#if !defined(CONFIG_MTD_NOR_FLASH) -#else -#undef CONFIG_ENV_ADDR -#define CONFIG_ENV_SECT_SIZE (256 * 1024) -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#endif
#endif /* __BLANCHE_H */ diff --git a/include/configs/boston.h b/include/configs/boston.h index 61aaa26989de..e5dc0c8e3286 100644 --- a/include/configs/boston.h +++ b/include/configs/boston.h @@ -53,14 +53,5 @@ /* * Environment */ -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#ifdef CONFIG_64BIT -# define CONFIG_ENV_ADDR \ - (0xffffffffb8000000 + (128 << 20) - CONFIG_ENV_SIZE) -#else -# define CONFIG_ENV_ADDR \ - (0xb8000000 + (128 << 20) - CONFIG_ENV_SIZE) -#endif
#endif /* __CONFIGS_BOSTON_H__ */ diff --git a/include/configs/broadcom_bcm963158.h b/include/configs/broadcom_bcm963158.h index a0f7ead4c749..f73ee2508abf 100644 --- a/include/configs/broadcom_bcm963158.h +++ b/include/configs/broadcom_bcm963158.h @@ -40,4 +40,3 @@ * bcm963158 */
-#define CONFIG_ENV_SIZE (8 * 1024) diff --git a/include/configs/broadcom_bcm968380gerg.h b/include/configs/broadcom_bcm968380gerg.h index b0e93376fe37..a1c54cf615b1 100644 --- a/include/configs/broadcom_bcm968380gerg.h +++ b/include/configs/broadcom_bcm968380gerg.h @@ -6,8 +6,6 @@ #include <configs/bmips_common.h> #include <configs/bmips_bcm6838.h>
-#define CONFIG_ENV_SIZE SZ_8K - #ifdef CONFIG_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT diff --git a/include/configs/broadcom_bcm968580xref.h b/include/configs/broadcom_bcm968580xref.h index fdb620341dc7..95615180311e 100644 --- a/include/configs/broadcom_bcm968580xref.h +++ b/include/configs/broadcom_bcm968580xref.h @@ -39,4 +39,3 @@ * 968580xref */
-#define CONFIG_ENV_SIZE (8 * 1024) diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index c9c28bef0421..ccdaebdf06b2 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -182,17 +182,12 @@ NANDTGTS \ #if defined(CONFIG_SPI) /* SPI Flash */ /* Environment */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ - CONFIG_ENV_SECT_SIZE) #elif defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET 0x40000 /* TODO: Adresse definieren */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
#elif defined(CONFIG_ENV_IS_IN_NAND) /* No NAND env support in SPL */ -#define CONFIG_ENV_OFFSET 0x60000 #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_ENV_SIZE #else #error "no storage for Environment defined!" diff --git a/include/configs/brppt2.h b/include/configs/brppt2.h index d36931509084..6c073ab383d2 100644 --- a/include/configs/brppt2.h +++ b/include/configs/brppt2.h @@ -37,9 +37,6 @@
/* Environment */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_OFFSET 0x20000
#define CONFIG_EXTRA_ENV_SETTINGS \ BUR_COMMON_ENV \ diff --git a/include/configs/brsmarc1.h b/include/configs/brsmarc1.h index 47d7a8772899..4bff349a0328 100644 --- a/include/configs/brsmarc1.h +++ b/include/configs/brsmarc1.h @@ -69,8 +69,6 @@ BUR_COMMON_ENV \ /* SPI Flash */
#define CONFIG_CONS_INDEX 1 #endif /* __CONFIG_BRSMARC1_H__ */ diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index 30bd8cb3837b..ea15912c900e 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -66,8 +66,5 @@ BUR_COMMON_ENV \ /* Environment */ #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_OFFSET 0x40000 /* TODO: Adresse definieren */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
#endif /* __CONFIG_BRXRE1_H__ */ diff --git a/include/configs/bubblegum_96.h b/include/configs/bubblegum_96.h index e1dc37b68722..c739d665f662 100644 --- a/include/configs/bubblegum_96.h +++ b/include/configs/bubblegum_96.h @@ -32,8 +32,6 @@ /* UART Definitions */ #define CONFIG_BAUDRATE 115200
-#define CONFIG_ENV_SIZE 0x2000 - /* Console configuration */ #define CONFIG_SYS_CBSIZE 1024 /* Console buffer size */ #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/caddy2.h b/include/configs/caddy2.h index 2c4f2c5b730b..63a7581d6821 100644 --- a/include/configs/caddy2.h +++ b/include/configs/caddy2.h @@ -199,16 +199,7 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0xc0000) - #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 - /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) - -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 #endif
#define CONFIG_LOADS_ECHO /* echo on for serial download */ diff --git a/include/configs/cardhu.h b/include/configs/cardhu.h index 8d541a18ee8b..7eeadfc9c3d2 100644 --- a/include/configs/cardhu.h +++ b/include/configs/cardhu.h @@ -27,7 +27,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_CARDHU
diff --git a/include/configs/cei-tk1-som.h b/include/configs/cei-tk1-som.h index e6abfe2eb3d3..dbebef34e386 100644 --- a/include/configs/cei-tk1-som.h +++ b/include/configs/cei-tk1-som.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE
diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index f109b22fdace..befa06faaae3 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -206,15 +206,7 @@
/* Environment organization */ #if defined (CONFIG_ENV_IS_IN_MMC) -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 #endif
-#define CONFIG_ENV_SIZE (8 * 1024) - -#if defined(CONFIG_ENV_IS_IN_SPI_FLASH) -#define CONFIG_ENV_OFFSET (768 * 1024) -#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#endif - #endif /* __CONFIG_CGTQMX6EVAL_H */ diff --git a/include/configs/cherryhill.h b/include/configs/cherryhill.h index 77ace93b96c3..6c7f9ea83bae 100644 --- a/include/configs/cherryhill.h +++ b/include/configs/cherryhill.h @@ -15,7 +15,5 @@ "stderr=vidconsole,serial\0"
/* Environment configuration */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_OFFSET 0x005f0000
#endif /* __CONFIG_H */ diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 8141aece410d..ca7ce31e1a3f 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -161,11 +161,9 @@ #endif
#if defined(CONFIG_ENV_IS_IN_NAND) -#define CONFIG_ENV_OFFSET_REDUND 0x001e0000 #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #else #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #endif
/* Network. */ diff --git a/include/configs/chromebook_link.h b/include/configs/chromebook_link.h index f26e463fe53b..96d5cf1a3389 100644 --- a/include/configs/chromebook_link.h +++ b/include/configs/chromebook_link.h @@ -15,9 +15,6 @@ #include <configs/x86-common.h> #include <configs/x86-chromebook.h>
-#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OFFSET 0x003f8000 - #define CONFIG_SPL_BOARD_LOAD_IMAGE
#endif /* __CONFIG_H */ diff --git a/include/configs/chromebook_samus.h b/include/configs/chromebook_samus.h index 2f7dd69fb82d..dfeede7e91a4 100644 --- a/include/configs/chromebook_samus.h +++ b/include/configs/chromebook_samus.h @@ -20,9 +20,6 @@ "stdout=vidconsole,serial\0" \ "stderr=vidconsole,serial\0"
-#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OFFSET 0x003f8000 - #define CONFIG_TPL_TEXT_BASE 0xfffd8000
#endif /* __CONFIG_H */ diff --git a/include/configs/ci20.h b/include/configs/ci20.h index 21a86323c267..0f9c2ac53a34 100644 --- a/include/configs/ci20.h +++ b/include/configs/ci20.h @@ -42,8 +42,6 @@
/* Environment */ #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE (32 << 10) -#define CONFIG_ENV_OFFSET ((14 + 512) << 10) #define CONFIG_ENV_OVERWRITE
/* Command line configuration. */ diff --git a/include/configs/cl-som-imx7.h b/include/configs/cl-som-imx7.h index d0a60c25f7a2..f9ffb4de8066 100644 --- a/include/configs/cl-som-imx7.h +++ b/include/configs/cl-som-imx7.h @@ -134,9 +134,6 @@ /* SPI Flash support */
/* FLASH and environment organization */ -#define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_OFFSET (768 * 1024) -#define CONFIG_ENV_SECT_SIZE (64 * 1024)
/* MMC Config*/ #ifdef CONFIG_FSL_USDHC diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 9d20a5e88c1d..633187d86fe0 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -33,16 +33,12 @@
/* Environment in MMC */ #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SECT_SIZE 0x200 -#define CONFIG_ENV_SIZE 0x10000 /* * For SD - reserve 1 LBA for MBR + 1M for u-boot image. The MMC/eMMC * boot image starts @ LBA-0. * As result in MMC/eMMC case it will be a 1 sector gap between u-boot * image and environment */ -#define CONFIG_ENV_OFFSET 0xf0000 -#define CONFIG_ENV_ADDR CONFIG_ENV_OFFSET
#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index c1a6625fcb10..eb29f07032b2 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -39,9 +39,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200}
/* Environment */ -#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_OFFSET (768 * 1024)
#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 54f2cea864b9..e0fc7fc3b125 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -116,7 +116,6 @@ #undef CONFIG_SYS_NAND_U_BOOT_OFFS #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000
-#define CONFIG_ENV_OFFSET 0x300000 /* environment starts here */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ #define CONFIG_SYS_NAND_ONFI_DETECTION #ifdef CONFIG_SPL_OS_BOOT diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index f9a6444d1d52..5bd9a49f4d01 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -178,8 +178,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
-#define CONFIG_ENV_ADDR 0x260000 - /* additions for new relocation code, must be added to all boards */ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 diff --git a/include/configs/cm_t54.h b/include/configs/cm_t54.h index 7368fd85bb0a..50308fb28f2a 100644 --- a/include/configs/cm_t54.h +++ b/include/configs/cm_t54.h @@ -29,14 +29,9 @@ #define CONFIG_SYS_NS16550_COM4 UART4_BASE
/* MMC ENV related defines */ -#undef CONFIG_ENV_OFFSET -#undef CONFIG_ENV_SIZE
#define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ #define CONFIG_SYS_MMC_ENV_PART 0 -#define CONFIG_ENV_OFFSET 0xc0000 /* (in bytes) 768 KB */ -#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
/* Enhance our eMMC support / experience. */ #define CONFIG_HSMMC2_8BIT diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index 337c875655cc..b6c3cd88ba3e 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -92,14 +92,6 @@ * --- */
-#ifndef CONFIG_MONITOR_IS_IN_RAM -#define CONFIG_ENV_OFFSET 0x4000 -#define CONFIG_ENV_SECT_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR 0xffe04000 -#define CONFIG_ENV_SECT_SIZE 0x2000 -#endif - #define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ env/embedded.o(.text); diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index de94eb95fe96..0c36a57a0e07 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -125,12 +125,6 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
-#if defined(CONFIG_ENV_IS_IN_NAND) -#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_OFFSET (28 * CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#endif - /* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* used to initialize CONFIG_SYS_NAND_BASE_LIST which is unused */ diff --git a/include/configs/colibri-imx8x.h b/include/configs/colibri-imx8x.h index ab98da6da397..311ed439f61b 100644 --- a/include/configs/colibri-imx8x.h +++ b/include/configs/colibri-imx8x.h @@ -118,9 +118,6 @@ #define CONFIG_SYS_MEMTEST_END 0x89000000
diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 1f2b89e72257..95b5a14b595c 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -206,12 +206,9 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
#if defined(CONFIG_ENV_IS_IN_MMC) /* Environment in eMMC, before config block at the end of 1st "boot sector" */ -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ - CONFIG_TDX_CFG_BLOCK_OFFSET) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 1 #endif diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index c2d98291b0cd..d92db7192ee3 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -212,15 +212,8 @@
#if defined(CONFIG_ENV_IS_IN_MMC) /* Environment in eMMC, before config block at the end of 1st "boot sector" */ -#define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ - CONFIG_TDX_CFG_BLOCK_OFFSET) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 1 -#elif defined(CONFIG_ENV_IS_IN_NAND) -#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_OFFSET (28 * CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #endif
#ifdef CONFIG_TARGET_COLIBRI_IMX7_NAND diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index bc3d40e667ce..111bb27126ae 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -116,10 +116,6 @@ #define CONFIG_SYS_MONITOR_LEN 0x40000
/* Skip factory configuration block */ -#define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN + 0x40000) -#define CONFIG_ENV_SIZE 0x40000 -#define CONFIG_ENV_SECT_SIZE 0x40000
/* * GPIO settings diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index cd7e1687812c..122294de6fc3 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -28,9 +28,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* Environment in NAND, 64K is a bit excessive but erase block is 512K anyway */ -#define CONFIG_ENV_OFFSET (SZ_2M) -#undef CONFIG_ENV_SIZE /* undef size from tegra20-common.h */ -#define CONFIG_ENV_SIZE (SZ_64K)
#define BOARD_EXTRA_ENV_SETTINGS \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index 8ff6433f45d2..5aecf14393ad 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -21,8 +21,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_COLIBRI_T30
diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index da9a8426ecdd..40c050a27e7a 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -156,9 +156,7 @@
/* Environment organization */ #ifdef CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SIZE (64 * 2048) #define CONFIG_ENV_RANGE (4 * 64 * 2048) -#define CONFIG_ENV_OFFSET (12 * 64 * 2048) #endif
/* USB Host Support */ diff --git a/include/configs/comtrend_ar5315u.h b/include/configs/comtrend_ar5315u.h index 1da96c163a16..71a1af1cddce 100644 --- a/include/configs/comtrend_ar5315u.h +++ b/include/configs/comtrend_ar5315u.h @@ -8,4 +8,3 @@
#define CONFIG_REMAKE_ELF
-#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/comtrend_ar5387un.h b/include/configs/comtrend_ar5387un.h index 73e6a5dac79b..7b195749ac4c 100644 --- a/include/configs/comtrend_ar5387un.h +++ b/include/configs/comtrend_ar5387un.h @@ -8,4 +8,3 @@
-#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/comtrend_ct5361.h b/include/configs/comtrend_ct5361.h index 72f9ecbb06f3..2a28e6c624dc 100644 --- a/include/configs/comtrend_ct5361.h +++ b/include/configs/comtrend_ct5361.h @@ -8,4 +8,3 @@
-#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/comtrend_vr3032u.h b/include/configs/comtrend_vr3032u.h index cb888056bcfb..3c3c4df01533 100644 --- a/include/configs/comtrend_vr3032u.h +++ b/include/configs/comtrend_vr3032u.h @@ -8,8 +8,6 @@
-#define CONFIG_ENV_SIZE SZ_8K - #ifdef CONFIG_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT diff --git a/include/configs/comtrend_wap5813n.h b/include/configs/comtrend_wap5813n.h index b67f6548e682..c8cddaf126e0 100644 --- a/include/configs/comtrend_wap5813n.h +++ b/include/configs/comtrend_wap5813n.h @@ -8,4 +8,3 @@
-#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/condor.h b/include/configs/condor.h index c84d127f49f6..c286dbb40663 100644 --- a/include/configs/condor.h +++ b/include/configs/condor.h @@ -16,9 +16,6 @@ #define CONFIG_BITBANGMII_MULTI
/* Environment compatibility */ -#undef CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_SECT_SIZE (256 * 1024) -#define CONFIG_ENV_OFFSET 0x700000
/* SH Ether */ #define CONFIG_SH_ETHER_USE_PORT 0 diff --git a/include/configs/conga-qeval20-qa3-e3845.h b/include/configs/conga-qeval20-qa3-e3845.h index 93dcad4b6652..01b67f7e2d8b 100644 --- a/include/configs/conga-qeval20-qa3-e3845.h +++ b/include/configs/conga-qeval20-qa3-e3845.h @@ -21,9 +21,6 @@ #define VIDEO_IO_OFFSET 0 #define CONFIG_X86EMU_RAW_IO
-#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OFFSET 0x006ef000 - #undef CONFIG_BOOTCOMMAND #define CONFIG_BOOTCOMMAND \ "load scsi 0:2 03000000 /boot/vmlinuz-${kernel-ver}-generic;" \ diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 19223e29472c..d62c784e5b79 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -272,14 +272,8 @@ * Environment */ #if defined(CONFIG_TRAILBLAZER) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#elif defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_RAMBOOT_SDCARD) #define CONFIG_FSL_FIXED_MMC_LOCATION -#define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 #endif
diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index f6d53284d7d5..1f6d0c533c90 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -43,9 +43,6 @@ #define CONFIG_EHCI_IS_TDI
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ -#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ -#define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */
diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index df602f696461..48746873bf17 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -59,26 +59,9 @@ #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 1658) -#elif defined(CONFIG_NAND) -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_ADDR 0xffe20000 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_ENV_IS_NOWHERE) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() /* sysclk for MPC85xx */ diff --git a/include/configs/corvus.h b/include/configs/corvus.h index f2df66eaa36f..e9064a200d32 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -88,7 +88,6 @@ #define CONFIG_SYS_LOAD_ADDR ATMEL_BASE_CS6
/* bootstrap + u-boot + env in nandflash */ -#define CONFIG_ENV_OFFSET_REDUND 0x180000
#define CONFIG_BOOTCOMMAND \ "nand read 0x70000000 0x200000 0x300000;" \ diff --git a/include/configs/cougarcanyon2.h b/include/configs/cougarcanyon2.h index 8070af780a96..353756193eee 100644 --- a/include/configs/cougarcanyon2.h +++ b/include/configs/cougarcanyon2.h @@ -17,7 +17,5 @@ "stderr=serial,vga\0"
/* Environment configuration */ -#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OFFSET 0x5ff000
#endif /* __CONFIG_H */ diff --git a/include/configs/crownbay.h b/include/configs/crownbay.h index 75f677fe6da2..4c118080cb5c 100644 --- a/include/configs/crownbay.h +++ b/include/configs/crownbay.h @@ -21,7 +21,5 @@ "stderr=serial,vidconsole\0"
#endif /* __CONFIG_H */ diff --git a/include/configs/crs305-1g-4s.h b/include/configs/crs305-1g-4s.h index a2df69adc779..617c8af83a0d 100644 --- a/include/configs/crs305-1g-4s.h +++ b/include/configs/crs305-1g-4s.h @@ -18,9 +18,6 @@ #define CONFIG_EHCI_IS_TDI
/* Keep device tree and initrd in lower memory so the kernel can access them */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index d152f23e7c28..49fee9249bf9 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -51,8 +51,6 @@ #if defined(CONFIG_SDCARD) #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 1658) #endif
/* diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 6876134a00cb..e4c8dc3e01bf 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -124,11 +124,6 @@ * Flash & Environment */ #ifdef CONFIG_NAND -#ifdef CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ -#define CONFIG_ENV_SIZE (128 << 10) -#define CONFIG_ENV_SECT_SIZE (128 << 10) -#endif #define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST #define CONFIG_SYS_NAND_PAGE_2K #define CONFIG_SYS_NAND_CS 3 @@ -181,19 +176,10 @@ #ifdef CONFIG_USE_NOR #define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of flash banks */ #define CONFIG_SYS_FLASH_SECT_SZ (128 << 10) /* 128KB */ -#define CONFIG_ENV_OFFSET (SZ_1M) -#define CONFIG_ENV_SIZE (10 << 10) /* 10KB */ #define CONFIG_SYS_FLASH_BASE DAVINCI_ASYNC_EMIF_DATA_CE2_BASE #define PHYS_FLASH_SIZE (8 << 20) /* Flash size 8MB */ #define CONFIG_SYS_MAX_FLASH_SECT ((PHYS_FLASH_SIZE/CONFIG_SYS_FLASH_SECT_SZ)\ + 3) -#define CONFIG_ENV_SECT_SIZE CONFIG_SYS_FLASH_SECT_SZ -#endif - -#if defined(CONFIG_USE_SPIFLASH) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) -#define CONFIG_ENV_SIZE (64 << 10) -#define CONFIG_ENV_OFFSET (512 << 10) -#define CONFIG_ENV_SECT_SIZE (64 << 10) #endif
/* @@ -243,7 +229,6 @@ #if !defined(CONFIG_NAND) && \ !defined(CONFIG_USE_NOR) && \ !defined(CONFIG_USE_SPIFLASH) -#define CONFIG_ENV_SIZE (16 << 10) #endif
/* USB Configs */ diff --git a/include/configs/dalmore.h b/include/configs/dalmore.h index e8a4e3c1f4f6..0cfc197142e5 100644 --- a/include/configs/dalmore.h +++ b/include/configs/dalmore.h @@ -22,7 +22,6 @@ /* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* SPI */ #define CONFIG_SPI_FLASH_SIZE (4 << 20) diff --git a/include/configs/dart_6ul.h b/include/configs/dart_6ul.h index 801011cf7799..894a8d7973fc 100644 --- a/include/configs/dart_6ul.h +++ b/include/configs/dart_6ul.h @@ -39,10 +39,6 @@ #define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M)
/* Environment settings */ -#define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_OFFSET (14 * SZ_64K) -#define CONFIG_ENV_OFFSET_REDUND \ - (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
/* Environment in SD */ #define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/db-88f6281-bp.h b/include/configs/db-88f6281-bp.h index 1b5541e49e38..749adb29075b 100644 --- a/include/configs/db-88f6281-bp.h +++ b/include/configs/db-88f6281-bp.h @@ -45,9 +45,6 @@ #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 20000000 /* 20Mhz */ #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ -#define CONFIG_ENV_SIZE 0x01000 -#define CONFIG_ENV_OFFSET 0xC0000
/* * U-Boot bootcode configuration diff --git a/include/configs/db-88f6720.h b/include/configs/db-88f6720.h index 79b9ccfaa0bd..0735ab221576 100644 --- a/include/configs/db-88f6720.h +++ b/include/configs/db-88f6720.h @@ -33,9 +33,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 3
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ -#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ -#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */
diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 61b91dd91f0f..f06853b74efe 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -20,9 +20,6 @@ #define CONFIG_EHCI_IS_TDI
diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 900c96267901..26c2240dbec1 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -41,9 +41,6 @@ #define CONFIG_EHCI_IS_TDI
diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 907bd0d032f7..3e20516e94b3 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -30,9 +30,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 3
diff --git a/include/configs/db-xc3-24g4xg.h b/include/configs/db-xc3-24g4xg.h index 86d11e40b1de..0e9ccd9b4419 100644 --- a/include/configs/db-xc3-24g4xg.h +++ b/include/configs/db-xc3-24g4xg.h @@ -17,9 +17,6 @@ #define CONFIG_EHCI_IS_TDI
/* NAND */ #define CONFIG_SYS_NAND_ONFI_DETECTION diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 16031c1da6b3..911ab9aa4ed8 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -118,8 +118,6 @@ /* * Environment */ -#define CONFIG_ENV_SIZE SZ_128K -#define CONFIG_ENV_OFFSET 0x000A0000
#define CONFIG_BOOTCOMMAND \ "dhcp; " \ diff --git a/include/configs/dfi-bt700.h b/include/configs/dfi-bt700.h index a8e1850f2b38..6d0e68e5df1f 100644 --- a/include/configs/dfi-bt700.h +++ b/include/configs/dfi-bt700.h @@ -26,9 +26,6 @@ #define VIDEO_IO_OFFSET 0 #define CONFIG_X86EMU_RAW_IO
-#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OFFSET 0x006ef000 - #undef CONFIG_BOOTCOMMAND #define CONFIG_BOOTCOMMAND \ "load scsi 0:1 03000000 /boot/vmlinuz-${kernel-ver}-generic;" \ diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 66a1b980eee9..d762d2cb19b5 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -137,13 +137,5 @@ #define CONFIG_SYS_MEMTEST_SCRATCH 0x10800000
/* Environment */ -#define CONFIG_ENV_SIZE (16 * 1024) - -#if defined(CONFIG_ENV_IS_IN_SPI_FLASH) -#define CONFIG_ENV_OFFSET (1024 * 1024) -#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_OFFSET_REDUND \ - (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE) -#endif
#endif /* __DH_IMX6_CONFIG_H */ diff --git a/include/configs/display5.h b/include/configs/display5.h index b353cffbfcc2..6600b94ac3a7 100644 --- a/include/configs/display5.h +++ b/include/configs/display5.h @@ -348,12 +348,7 @@
/* ENV config */ #ifdef CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SIZE (SZ_64K) /* The 0x120000 value corresponds to above SPI-NOR memory MAP */ -#define CONFIG_ENV_OFFSET (0x120000) -#define CONFIG_ENV_SECT_SIZE (SZ_64K) -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ - CONFIG_ENV_SECT_SIZE) #endif
#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) diff --git a/include/configs/dns325.h b/include/configs/dns325.h index f72ee90ab57e..41079e834549 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -60,13 +60,6 @@ /* * Environment variables configurations */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128KB */ -#endif - -#define CONFIG_ENV_SIZE 0x20000 /* 128KB */ -#define CONFIG_ENV_ADDR 0xe0000 -#define CONFIG_ENV_OFFSET 0xe0000 /* env starts here */
/* * Default environment variables diff --git a/include/configs/dockstar.h b/include/configs/dockstar.h index f33978829d6c..04dd0f68c370 100644 --- a/include/configs/dockstar.h +++ b/include/configs/dockstar.h @@ -27,16 +27,10 @@ /* * Environment variables configurations */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#endif /* * max 4k env size is enough, but in case of nand * it has to be rounded to sector size */ -#define CONFIG_ENV_SIZE 0x20000 /* 128k */ -#define CONFIG_ENV_ADDR 0x80000 -#define CONFIG_ENV_OFFSET 0x80000 /* env starts here */
/* * Default environment variables diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 0ad23ce4b943..1255999de60c 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -21,7 +21,6 @@ #ifndef CONFIG_QSPI_BOOT /* MMC ENV related defines */ #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #endif
#if (CONFIG_CONS_INDEX == 1) @@ -82,12 +81,6 @@ #define CONFIG_SYS_SPI_KERNEL_OFFS 0x1E0000 #define CONFIG_SYS_SPI_ARGS_OFFS 0x140000 #define CONFIG_SYS_SPI_ARGS_SIZE 0x80000 -#if defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_SIZE (64 << 10) -#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64 KB sectors */ -#define CONFIG_ENV_OFFSET 0x1C0000 -#define CONFIG_ENV_OFFSET_REDUND 0x1D0000 -#endif
/* SPI SPL */
@@ -140,11 +133,6 @@ #define CONFIG_SYS_FLASH_BASE (0x08000000) #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Reduce SPL size by removing unlikey targets */ -#ifdef CONFIG_NOR_BOOT -#define CONFIG_ENV_SECT_SIZE (128 * 1024) /* 128 KiB */ -#define CONFIG_ENV_OFFSET 0x001c0000 -#define CONFIG_ENV_OFFSET_REDUND 0x001e0000 -#endif #endif /* NOR support */
#endif /* __CONFIG_DRA7XX_EVM_H */ diff --git a/include/configs/draak.h b/include/configs/draak.h index 9a8d6a4e79ab..78ec444af544 100644 --- a/include/configs/draak.h +++ b/include/configs/draak.h @@ -19,7 +19,6 @@ #define COUNTER_FREQUENCY 0xFE502A /* 16.66MHz from CPclk */
diff --git a/include/configs/draco.h b/include/configs/draco.h index e566ccef2a19..016532f3363b 100644 --- a/include/configs/draco.h +++ b/include/configs/draco.h @@ -41,7 +41,6 @@ #define CONFIG_FACTORYSET
/* Define own nand partitions */ -#define CONFIG_ENV_OFFSET_REDUND 0x2E0000 #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index bf0e0315c26d..65149ad44149 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -80,7 +80,6 @@ REFLASH(dragonboard/u-boot.img, 8)\ "pxefile_addr_r=0x90100000\0"\ BOOTENV
-#define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 /* mmc0 = emmc, mmc1 = sd */ #define CONFIG_SYS_MMC_ENV_PART 2 /* Set env partition to BOOT2 partition */
diff --git a/include/configs/dragonboard820c.h b/include/configs/dragonboard820c.h index a41df22273e6..4256e6f06077 100644 --- a/include/configs/dragonboard820c.h +++ b/include/configs/dragonboard820c.h @@ -50,8 +50,6 @@ "pxefile_addr_r=0x90100000\0"\ BOOTENV
-#define CONFIG_ENV_SIZE 0x4000 - /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_8M)
diff --git a/include/configs/dreamplug.h b/include/configs/dreamplug.h index f7f9141dd0e1..3e3f4c17f8b3 100644 --- a/include/configs/dreamplug.h +++ b/include/configs/dreamplug.h @@ -30,17 +30,11 @@ /* * Environment variables configurations */ -#ifdef CONFIG_SPI_FLASH -#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64k */ -#endif
/* * max 4k env size is enough, but in case of nand * it has to be rounded to sector size */ -#define CONFIG_ENV_SIZE 0x1000 /* 4k */ -#define CONFIG_ENV_ADDR 0x100000 -#define CONFIG_ENV_OFFSET 0x100000 /* env starts here */
/* * Default environment variables diff --git a/include/configs/ds109.h b/include/configs/ds109.h index 31abb4bc85f1..594cc82234bc 100644 --- a/include/configs/ds109.h +++ b/include/configs/ds109.h @@ -33,17 +33,11 @@ /* * Environment variables configurations */ -#ifdef CONFIG_SPI_FLASH -#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64k */ -#endif
/* * max 4k env size is enough, but in case of nand * it has to be rounded to sector size */ -#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_ADDR 0x3d0000 -#define CONFIG_ENV_OFFSET 0x3d0000 /* env starts here */
/* * Default environment variables diff --git a/include/configs/ds414.h b/include/configs/ds414.h index 552c7449d59c..e3693767b66d 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -29,9 +29,6 @@ #define CONFIG_SYS_I2C_SPEED 100000
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_OFFSET 0x7E0000 /* RedBoot config partition in DTS */ -#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ -#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */
#define CONFIG_SYS_NETA_INTERFACE_TYPE PHY_INTERFACE_MODE_RGMII
diff --git a/include/configs/durian.h b/include/configs/durian.h index c42a98b9a094..fa48e5c02400 100644 --- a/include/configs/durian.h +++ b/include/configs/durian.h @@ -16,7 +16,6 @@ #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x10000000)
/* Size of Malloc Pool */ -#define CONFIG_ENV_SIZE 4096 #define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024 + CONFIG_ENV_SIZE)
#define CONFIG_SYS_INIT_SP_ADDR (0x88000000 - 0x100000) diff --git a/include/configs/e2220-1170.h b/include/configs/e2220-1170.h index c636bf945792..c4349bda4592 100644 --- a/include/configs/e2220-1170.h +++ b/include/configs/e2220-1170.h @@ -20,7 +20,6 @@ /* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* SPI */ #define CONFIG_SPI_FLASH_SIZE (4 << 20) diff --git a/include/configs/eagle.h b/include/configs/eagle.h index 5f2fe42d2eb0..b567caa17485 100644 --- a/include/configs/eagle.h +++ b/include/configs/eagle.h @@ -16,9 +16,6 @@ #define CONFIG_BITBANGMII_MULTI
/* Board Clock */ /* XTAL_CLK : 33.33MHz */ diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index e266e1f5428c..f8de8d3467ba 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -38,9 +38,6 @@ * Environment is in the second sector of the first 256k of flash * *----------------------------------------------------------------------*/
-#define CONFIG_ENV_ADDR 0xFF040000 -#define CONFIG_ENV_SECT_SIZE 0x00020000 - /* * BOOTP options */ diff --git a/include/configs/ebisu.h b/include/configs/ebisu.h index 2e4974acb2f1..0e246629bc0b 100644 --- a/include/configs/ebisu.h +++ b/include/configs/ebisu.h @@ -22,7 +22,6 @@ #define COUNTER_FREQUENCY 0xFE502A /* 16.66MHz from CPclk */
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 2 #define CONFIG_SYS_MMC_ENV_PART 2
diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index 6526a83141f1..d801c6605084 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -33,35 +33,27 @@
#ifdef CONFIG_EDB9301 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9301 -#define CONFIG_ENV_SECT_SIZE 0x00020000 #elif defined(CONFIG_EDB9302) #define CONFIG_EP9302 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9302 -#define CONFIG_ENV_SECT_SIZE 0x00020000 #elif defined(CONFIG_EDB9302A) #define CONFIG_EP9302 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9302A -#define CONFIG_ENV_SECT_SIZE 0x00020000 #elif defined(CONFIG_EDB9307) #define CONFIG_EP9307 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9307 -#define CONFIG_ENV_SECT_SIZE 0x00040000 #elif defined(CONFIG_EDB9307A) #define CONFIG_EP9307 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9307A -#define CONFIG_ENV_SECT_SIZE 0x00020000 #elif defined(CONFIG_EDB9312) #define CONFIG_EP9312 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9312 -#define CONFIG_ENV_SECT_SIZE 0x00040000 #elif defined(CONFIG_EDB9315) #define CONFIG_EP9315 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9315 -#define CONFIG_ENV_SECT_SIZE 0x00040000 #elif defined(CONFIG_EDB9315A) #define CONFIG_EP9315 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9315A -#define CONFIG_ENV_SECT_SIZE 0x00020000 #else #error "no board defined" #endif @@ -179,11 +171,6 @@
#define CONFIG_ENV_OVERWRITE /* Vendor params unprotected */
-#define CONFIG_ENV_ADDR 0x60040000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) - -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE - #define CONFIG_USB_OHCI_NEW #define CONFIG_USB_OHCI_EP93XX #define CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/include/configs/edison.h b/include/configs/edison.h index 218b50a1d9bb..3e174e9aa535 100644 --- a/include/configs/edison.h +++ b/include/configs/edison.h @@ -31,9 +31,6 @@ /* Environment */ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 0 -#define CONFIG_ENV_SIZE (64 * 1024) -#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) -#define CONFIG_ENV_OFFSET_REDUND (6 * 1024 * 1024)
/* RTC */ #define CONFIG_SYS_ISA_IO_BASE_ADDRESS 0 diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index f07171894462..60dfee81b71b 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -171,9 +171,6 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_SECT_SIZE 0x2000 /* 16K */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET 0x4000 /* env starts here */
/* * Size of malloc() pool diff --git a/include/configs/el6x_common.h b/include/configs/el6x_common.h index fe28154dc19d..95c04c379706 100644 --- a/include/configs/el6x_common.h +++ b/include/configs/el6x_common.h @@ -92,12 +92,9 @@
-#define CONFIG_ENV_SIZE (8 * 1024) - #if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET 0x0 #endif
#endif /* __EL6Q_COMMON_CONFIG_H */ diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 8bc7a3ad2e13..481066b71e96 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -68,20 +68,16 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_SIZE (8 * 1024)
#if defined(CONFIG_ENV_IS_IN_MMC) /* RiOTboard */ #define CONFIG_FDTFILE "imx6dl-riotboard.dtb" #define CONFIG_SYS_FSL_USDHC_NUM 3 #define CONFIG_SYS_MMC_ENV_DEV 2 /* SDHC4 */ -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) #elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) /* MarSBoard */ #define CONFIG_FDTFILE "imx6q-marsboard.dtb" #define CONFIG_SYS_FSL_USDHC_NUM 2 -#define CONFIG_ENV_OFFSET (768 * 1024) -#define CONFIG_ENV_SECT_SIZE (8 * 1024) #endif
/* Framebuffer */ diff --git a/include/configs/etamin.h b/include/configs/etamin.h index 8e09f73a887f..4ce8f93103c2 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -20,11 +20,9 @@ #undef CONFIG_SYS_NAND_ECCPOS #undef CONFIG_SYS_NAND_U_BOOT_OFFS #undef CONFIG_SYS_ENV_SECT_SIZE -#undef CONFIG_ENV_OFFSET #undef CONFIG_NAND_OMAP_ECCSCHEME #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW
-#define CONFIG_ENV_OFFSET 0x980000 #define CONFIG_SYS_ENV_SECT_SIZE (512 << 10) /* 512 KiB */ #define CONFIG_SYS_NAND_PAGE_SIZE 4096 #define CONFIG_SYS_NAND_OOBSIZE 224 @@ -111,7 +109,6 @@ #endif
/* Define own nand partitions */ -#define CONFIG_ENV_OFFSET_REDUND 0xB80000 #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index c9e7c8c0e2b6..39a4a066ad04 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -50,7 +50,6 @@
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_OFFSET 0x3DE000
/* NAND flash */ #ifdef CONFIG_CMD_NAND diff --git a/include/configs/evb_ast2500.h b/include/configs/evb_ast2500.h index e4b07e3bd686..7a0ea753be03 100644 --- a/include/configs/evb_ast2500.h +++ b/include/configs/evb_ast2500.h @@ -19,6 +19,4 @@ /* Memory Info */ #define CONFIG_SYS_LOAD_ADDR 0x83000000
-#define CONFIG_ENV_SIZE 0x20000 - #endif /* __CONFIG_H */ diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index e0a4d76d5380..5911a8a63992 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -89,7 +89,6 @@ #define CONFIG_RES_BLOCK_SIZE (512) #define CONFIG_BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ #define CONFIG_BL2_SIZE (512UL << 10UL) /* 512 KB */ -#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */
#define CONFIG_BL1_OFFSET (CONFIG_RES_BLOCK_SIZE + CONFIG_SEC_FW_SIZE) #define CONFIG_BL2_OFFSET (CONFIG_BL1_OFFSET + CONFIG_BL1_SIZE) @@ -108,10 +107,6 @@
/* SPI */
-#ifdef CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -#endif - /* Ethernet Controllor Driver */ #ifdef CONFIG_CMD_NET #define CONFIG_ENV_SROM_BANK 1 diff --git a/include/configs/exynos5-dt-common.h b/include/configs/exynos5-dt-common.h index a87182ae8481..cc9ffda669ee 100644 --- a/include/configs/exynos5-dt-common.h +++ b/include/configs/exynos5-dt-common.h @@ -19,7 +19,6 @@
#define CONFIG_SYS_SPI_BASE 0x12D30000 #define FLASH_SIZE (4 << 20) -#define CONFIG_ENV_OFFSET (FLASH_SIZE - CONFIG_ENV_SECT_SIZE) #define CONFIG_SPI_BOOTING
#define CONFIG_BOARD_COMMON diff --git a/include/configs/exynos7420-common.h b/include/configs/exynos7420-common.h index 157260ca03b8..6c0aa9bcd4a6 100644 --- a/include/configs/exynos7420-common.h +++ b/include/configs/exynos7420-common.h @@ -62,7 +62,6 @@ #define PHYS_SDRAM_8_SIZE SDRAM_BANK_SIZE
/* Configuration of ENV Blocks */ -#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */
#define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 4b8b2dc4ad65..fded5a11dac7 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -112,14 +112,7 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN (512 * 1024)
-#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE - /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) - -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ - CONFIG_SYS_MONITOR_LEN)
/* * CFI FLASH driver setup diff --git a/include/configs/galileo.h b/include/configs/galileo.h index 507d08cb1107..57483a2af960 100644 --- a/include/configs/galileo.h +++ b/include/configs/galileo.h @@ -26,7 +26,5 @@ #define CONFIG_DW_ALTDESCRIPTOR
#endif /* __CONFIG_H */ diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index cfa7d1c674a0..59c60743d24c 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -38,11 +38,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
/* Environment settings */ -#define CONFIG_ENV_OFFSET 0xa0000 -#define CONFIG_ENV_SIZE (64 << 10) -#define CONFIG_ENV_SECT_SIZE (64 << 10) -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ - CONFIG_ENV_SECT_SIZE)
/* * Environment is right behind U-Boot in flash. Make sure U-Boot diff --git a/include/configs/gazerbeam.h b/include/configs/gazerbeam.h index 8c01097245ed..6a7a93144bf2 100644 --- a/include/configs/gazerbeam.h +++ b/include/configs/gazerbeam.h @@ -55,11 +55,6 @@ /* * Environment */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ - CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE)
#define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 6de5119d7fbe..73cdc5b489fb 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -184,9 +184,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* environment organization */ -#define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_OFFSET (768 * 1024) -#define CONFIG_ENV_SECT_SIZE (64 * 1024)
diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index 1d69a4e51802..afd48d5ad046 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -50,16 +50,10 @@ /* * Environment variables configurations */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#endif /* * max 4k env size is enough, but in case of nand * it has to be rounded to sector size */ -#define CONFIG_ENV_SIZE 0x20000 /* 128k */ -#define CONFIG_ENV_ADDR 0xC0000 -#define CONFIG_ENV_OFFSET 0xC0000 /* env starts here */
/* * Default environment variables diff --git a/include/configs/gplugd.h b/include/configs/gplugd.h index 7da8739a1960..2f66af344725 100644 --- a/include/configs/gplugd.h +++ b/include/configs/gplugd.h @@ -70,7 +70,6 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_SIZE 0x4000
#ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI_ARMADA100 diff --git a/include/configs/grpeach.h b/include/configs/grpeach.h index 26ca6943b12a..b875f9b132ef 100644 --- a/include/configs/grpeach.h +++ b/include/configs/grpeach.h @@ -28,9 +28,6 @@ (CONFIG_SYS_SDRAM_BASE + 4 * 1024 * 1024)
#define CONFIG_ENV_OVERWRITE 1 -#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_OFFSET 0x80000
/* Malloc */ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) diff --git a/include/configs/guruplug.h b/include/configs/guruplug.h index 739ab320f637..768f4ebcbb8d 100644 --- a/include/configs/guruplug.h +++ b/include/configs/guruplug.h @@ -28,15 +28,10 @@ /* * Environment variables configurations */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#endif /* * max 4k env size is enough, but in case of nand * it has to be rounded to sector size */ -#define CONFIG_ENV_SIZE 0x20000 /* 128k */ -#define CONFIG_ENV_OFFSET 0xE0000 /* env starts here */ /* * Environment is right behind U-Boot in flash. Make sure U-Boot * doesn't grow into the environment area. diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 8b0f4d4d9019..894f8b11142b 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -155,18 +155,6 @@ #if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 1 - #define CONFIG_ENV_OFFSET (709 * SZ_1K) - #define CONFIG_ENV_SIZE (128 * SZ_1K) - #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + (128 * SZ_1K)) -#elif defined(CONFIG_ENV_IS_IN_NAND) - #define CONFIG_ENV_OFFSET (16 * SZ_1M) - #define CONFIG_ENV_SECT_SIZE (128 * SZ_1K) - #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE - #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + (512 * SZ_1K)) -#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) - #define CONFIG_ENV_OFFSET (512 * SZ_1K) - #define CONFIG_ENV_SECT_SIZE (64 * SZ_1K) - #define CONFIG_ENV_SIZE (8 * SZ_1K) #endif
/* Environment */ diff --git a/include/configs/harmony.h b/include/configs/harmony.h index f873cea26533..b2464f90dea2 100644 --- a/include/configs/harmony.h +++ b/include/configs/harmony.h @@ -30,7 +30,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* Environment in NAND (which is 512M), aligned to start of last sector */ -#define CONFIG_ENV_OFFSET (SZ_512M - SZ_128K) /* 128K sector size */
#include "tegra-common-post.h"
diff --git a/include/configs/helios4.h b/include/configs/helios4.h index 4df32002e094..5a4c9ae066eb 100644 --- a/include/configs/helios4.h +++ b/include/configs/helios4.h @@ -44,19 +44,12 @@
#ifdef CONFIG_MVEBU_SPL_BOOT_DEVICE_SPI /* Environment in SPI NOR flash */ -#define CONFIG_ENV_SECT_SIZE SZ_64K -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_OFFSET SZ_1M #endif
#ifdef CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC /* Environment in MMC */ #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SECT_SIZE 0x200 -#define CONFIG_ENV_SIZE 0x2000 /* stay within first 1M */ -#define CONFIG_ENV_OFFSET (SZ_1M - CONFIG_ENV_SIZE) -#define CONFIG_ENV_ADDR CONFIG_ENV_OFFSET #endif
#define CONFIG_PHY_MARVELL /* there is a marvell phy */ diff --git a/include/configs/highbank.h b/include/configs/highbank.h index c0e295b6b745..8d16e18d8b6e 100644 --- a/include/configs/highbank.h +++ b/include/configs/highbank.h @@ -58,8 +58,6 @@ */ #define CONFIG_SYS_NVRAM_BASE_ADDR 0xfff88000 /* NVRAM base address */ #define CONFIG_SYS_NVRAM_SIZE 0x8000 /* NVRAM size */ -#define CONFIG_ENV_SIZE 0x2000 /* Size of Environ */ -#define CONFIG_ENV_ADDR CONFIG_SYS_NVRAM_BASE_ADDR
#define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_INIT_SP_ADDR 0x01000000 diff --git a/include/configs/hikey.h b/include/configs/hikey.h index 60c6bde16ea9..2732c019c426 100644 --- a/include/configs/hikey.h +++ b/include/configs/hikey.h @@ -82,7 +82,6 @@ BOOTENV
/* Preserve environment on eMMC */ -#define CONFIG_ENV_SIZE 0x1000 #define CONFIG_SYS_MMC_ENV_DEV 0 /* Use eMMC */ #define CONFIG_SYS_MMC_ENV_PART 2 /* Use Boot1 partition */
diff --git a/include/configs/hikey960.h b/include/configs/hikey960.h index f6f9c8d85a2d..04d458798a17 100644 --- a/include/configs/hikey960.h +++ b/include/configs/hikey960.h @@ -36,8 +36,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_8M)
-#define CONFIG_ENV_SIZE 0x1000 - #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) #include <config_distro_bootcmd.h> @@ -52,8 +50,6 @@ "initrd_high=0xffffffffffffffff\0" \ BOOTENV
-#define CONFIG_ENV_SIZE 0x1000 - /* TODO: Remove this once the SD clock is fixed */ #define CONFIG_SYS_MMC_MAX_BLK_COUNT 1024
diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index cd59b840e9f9..43c31e6a2c2a 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -351,15 +351,6 @@ void fpga_control_clear(unsigned int bus, int pin); /* * Environment */ -#if 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ - CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#else -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/huawei_hg556a.h b/include/configs/huawei_hg556a.h index 2aa5c6664325..529fc9495ef4 100644 --- a/include/configs/huawei_hg556a.h +++ b/include/configs/huawei_hg556a.h @@ -8,4 +8,3 @@
-#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h index 5e54441c73d1..71738bfb7d8e 100644 --- a/include/configs/ib62x0.h +++ b/include/configs/ib62x0.h @@ -33,11 +33,6 @@ /* * Environment variables configuration */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_SECT_SIZE 0x20000 -#endif -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_OFFSET 0xe0000
/* * Default environment variables diff --git a/include/configs/iconnect.h b/include/configs/iconnect.h index 87113d7805c1..a694b2e92be9 100644 --- a/include/configs/iconnect.h +++ b/include/configs/iconnect.h @@ -38,11 +38,6 @@ /* * Environment variables configuration */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_SECT_SIZE 0x20000 -#endif -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_OFFSET 0x80000
/* * Default environment variables diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index 71063653fadc..d37a5b7a4f50 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -223,10 +223,6 @@ /* * Environment Configuration */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE \ - + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SIZE)
#define CONFIG_NETDEV eth1 #define CONFIG_HOSTNAME "ids8313" diff --git a/include/configs/imgtec_xilfpga.h b/include/configs/imgtec_xilfpga.h index 8e2d72323d62..fcf1b7f990e1 100644 --- a/include/configs/imgtec_xilfpga.h +++ b/include/configs/imgtec_xilfpga.h @@ -45,7 +45,6 @@ /* ------------------------------------------------- * Environment */ -#define CONFIG_ENV_SIZE 0x4000
/* --------------------------------------------------------------------- * Board boot configuration diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index a2d0ade0151f..82ac4242bbf3 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -95,9 +95,7 @@ CONFIG_SYS_FLASH_SECT_SZ) #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN 0x40000 /* Reserve 256KiB */ -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
/* * Ethernet diff --git a/include/configs/imx6-engicam.h b/include/configs/imx6-engicam.h index 0826195f4838..46529a61da3c 100644 --- a/include/configs/imx6-engicam.h +++ b/include/configs/imx6-engicam.h @@ -16,7 +16,6 @@ #define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M)
/* Total Size of Environment Sector */ -#define CONFIG_ENV_SIZE SZ_128K
/* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE @@ -25,11 +24,7 @@ #ifndef CONFIG_ENV_IS_NOWHERE /* Environment in MMC */ # if defined(CONFIG_ENV_IS_IN_MMC) -# define CONFIG_ENV_OFFSET 0x100000 /* Environment in NAND */ -# elif defined(CONFIG_ENV_IS_IN_NAND) -# define CONFIG_ENV_OFFSET 0x400000 -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE # endif #endif
diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index d6b7477ee912..2274db0e2295 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -132,9 +132,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_SIZE (1024 * 1024) -#define CONFIG_ENV_OFFSET 0x400000 -#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE
/* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/imx6dl-mamoj.h b/include/configs/imx6dl-mamoj.h index 7605e145c2f3..b6e336a33d99 100644 --- a/include/configs/imx6dl-mamoj.h +++ b/include/configs/imx6dl-mamoj.h @@ -17,7 +17,6 @@ #define CONFIG_SYS_MALLOC_LEN (35 * SZ_1M)
/* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE @@ -25,9 +24,6 @@ /* Environment */ #ifndef CONFIG_ENV_IS_NOWHERE /* Environment in MMC */ -# if defined(CONFIG_ENV_IS_IN_MMC) -# define CONFIG_ENV_OFFSET 0x100000 -# endif #endif
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index e0c5f5a62651..acbab05ae93a 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -113,10 +113,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
#define CONFIG_ENV_OVERWRITE -#if defined(CONFIG_ENV_IS_IN_MMC) -#define CONFIG_ENV_OFFSET (64 * SZ_64K) -#endif -#define CONFIG_ENV_SIZE SZ_4K #define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC2 */ #define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */
diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index 8d4a88b332e2..62037c7387af 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -116,10 +116,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index 84fae3477702..b29989db8f92 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -177,8 +177,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
#define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_OFFSET (64 * SZ_64K) -#define CONFIG_ENV_SIZE 0x1000 #define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ #define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */
diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index 37ef595e4ead..97170dc94949 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -162,8 +162,6 @@ #define CONFIG_SYS_INIT_SP_ADDR 0x80200000
/* Default environment is in SD */ -#define CONFIG_ENV_SIZE 0x1000 -#define CONFIG_ENV_OFFSET (64 * SZ_64K) #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */
#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 diff --git a/include/configs/imx8qm_rom7720.h b/include/configs/imx8qm_rom7720.h index fb31dc4627f7..865863eb7cb0 100644 --- a/include/configs/imx8qm_rom7720.h +++ b/include/configs/imx8qm_rom7720.h @@ -130,17 +130,13 @@ #define CONFIG_SYS_INIT_SP_ADDR 0x80200000
/* Default environment is in SD */ -#define CONFIG_ENV_SIZE 0x2000
#ifdef CONFIG_QSPI_BOOT -#define CONFIG_ENV_OFFSET (4 * 1024 * 1024) -#define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS #define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #else -#define CONFIG_ENV_OFFSET (64 * SZ_64K) #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ #endif
diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index 59f88bd2033b..cb39bcdebf5d 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -161,8 +161,6 @@ #define CONFIG_SYS_INIT_SP_ADDR 0x80200000
#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index 4a9c60d758a9..f15e08f39763 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -32,7 +32,6 @@ /* Flash settings */ #define CONFIG_SYS_FLASH_SIZE 0x02000000 /* 32 MiB */ #define CONFIG_SYS_MAX_FLASH_SECT 128 -#define CONFIG_ENV_SIZE 32768
/*----------------------------------------------------------------------- * PCI definitions diff --git a/include/configs/integratorcp.h b/include/configs/integratorcp.h index 56931b78a621..d8a474db2e5b 100644 --- a/include/configs/integratorcp.h +++ b/include/configs/integratorcp.h @@ -52,22 +52,16 @@ */ #if ( PHYS_FLASH_SIZE == 0x04000000 )
-#define CONFIG_ENV_ADDR 0x27F00000 #define CONFIG_SYS_MONITOR_BASE 0x27F40000
#elif (PHYS_FLASH_SIZE == 0x02000000 )
-#define CONFIG_ENV_ADDR 0x25F00000 #define CONFIG_SYS_MONITOR_BASE 0x25F40000
#else
-#define CONFIG_ENV_ADDR 0x24F00000 #define CONFIG_SYS_MONITOR_BASE 0x27F40000
#endif
-#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ -#define CONFIG_ENV_SIZE 8192 /* 8KB */ - #endif /* __CONFIG_H */ diff --git a/include/configs/j721e_evm.h b/include/configs/j721e_evm.h index 639d87a4e578..84518786c747 100644 --- a/include/configs/j721e_evm.h +++ b/include/configs/j721e_evm.h @@ -15,8 +15,6 @@ #include <environment/ti/k3_rproc.h> #include <environment/ti/ufs.h>
-#define CONFIG_ENV_SIZE (128 << 10) - /* DDR Configuration */ #define CONFIG_SYS_SDRAM_BASE1 0x880000000
diff --git a/include/configs/jetson-tk1.h b/include/configs/jetson-tk1.h index 65044690d64a..98248876e8eb 100644 --- a/include/configs/jetson-tk1.h +++ b/include/configs/jetson-tk1.h @@ -19,7 +19,6 @@ #define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2
diff --git a/include/configs/k2e_evm.h b/include/configs/k2e_evm.h index 547127490c92..716ae3b0d4aa 100644 --- a/include/configs/k2e_evm.h +++ b/include/configs/k2e_evm.h @@ -35,9 +35,6 @@ "name_uboot=u-boot-spi-k2e-evm.gph\0" \ "name_fs=arago-console-image-k2e-evm.cpio.gz\0"
-#define CONFIG_ENV_SIZE (256 << 10) /* 256 KiB */ -#define CONFIG_ENV_OFFSET 0x100000 - #include <configs/ti_armv7_keystone2.h>
#define SPI_MTD_PARTS KEYSTONE_SPI0_MTD_PARTS diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index b39e956defd6..25f3959533c6 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -81,8 +81,6 @@ #define CONFIG_KSNET_MDIO_PHY_CONFIG_ENABLE #define PHY_ANEG_TIMEOUT 10000 /* PHY needs longer aneg time */
-#define CONFIG_ENV_SIZE (256 << 10) /* 256 KiB */ - #ifndef CONFIG_SPL_BUILD #define CONFIG_CADENCE_QSPI #define CONFIG_CQSPI_REF_CLK 384000000 diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index d4f2e96bab08..d90b2648185a 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -35,9 +35,6 @@ "name_uboot=u-boot-spi-k2hk-evm.gph\0" \ "name_fs=arago-console-image-k2hk-evm.cpio.gz\0"
#define SPI_MTD_PARTS KEYSTONE_SPI0_MTD_PARTS diff --git a/include/configs/k2l_evm.h b/include/configs/k2l_evm.h index cfdb36e2d7ff..152cea01b55b 100644 --- a/include/configs/k2l_evm.h +++ b/include/configs/k2l_evm.h @@ -35,9 +35,6 @@ "name_uboot=u-boot-spi-k2l-evm.gph\0" \ "name_fs=arago-console-image-k2l-evm.cpio.gz\0"
#define SPI_MTD_PARTS KEYSTONE_SPI0_MTD_PARTS diff --git a/include/configs/km/km-mpc83xx.h b/include/configs/km/km-mpc83xx.h index a9899fe4591e..dfb78c50f4b1 100644 --- a/include/configs/km/km-mpc83xx.h +++ b/include/configs/km/km-mpc83xx.h @@ -105,22 +105,7 @@ */
#ifndef CONFIG_SYS_RAMBOOT -#ifndef CONFIG_ENV_ADDR -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ - CONFIG_SYS_MONITOR_LEN) -#endif -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ -#ifndef CONFIG_ENV_OFFSET -#define CONFIG_ENV_OFFSET (CONFIG_SYS_MONITOR_LEN) -#endif - /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ - CONFIG_ENV_SECT_SIZE) - -#else /* CFG_SYS_RAMBOOT */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -#define CONFIG_ENV_SIZE 0x2000 #endif /* CFG_SYS_RAMBOOT */
/* diff --git a/include/configs/km/km-powerpc.h b/include/configs/km/km-powerpc.h index 20b596f54140..84594874b88e 100644 --- a/include/configs/km/km-powerpc.h +++ b/include/configs/km/km-powerpc.h @@ -16,8 +16,6 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 /* 8 Byte write page */ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10
-#define CONFIG_ENV_SIZE 0x04000 /* Size of Environment */ - #define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */
#define CONFIG_SYS_MEMTEST_END 0x00f00000 /* 1 ... 15 MB in DRAM */ diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 63fa6675ff92..156edfba2269 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -141,20 +141,12 @@ int get_scl(void); * Environment variables configurations */ #if defined CONFIG_KM_ENV_IS_IN_SPI_NOR -#define CONFIG_ENV_OFFSET 0xc0000 /* no bracets! */ -#define CONFIG_ENV_SIZE 0x02000 /* Size of Environment */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_TOTAL_SIZE 0x20000 /* no bracets! */ #else #define CONFIG_SYS_DEF_EEPROM_ADDR 0x50 #define CONFIG_ENV_EEPROM_IS_ON_I2C #define CONFIG_SYS_EEPROM_WREN -#define CONFIG_ENV_OFFSET 0x0 /* no bracets! */ -#define CONFIG_ENV_SIZE (0x2000 - CONFIG_ENV_OFFSET) #define CONFIG_I2C_ENV_EEPROM_BUS 5 /* I2C2 (Mux-Port 5) */ -#define CONFIG_ENV_OFFSET_REDUND 0x2000 /* no bracets! */ #endif
#define KM_FLASH_GPIO_PIN 16 diff --git a/include/configs/kmp204x.h b/include/configs/kmp204x.h index f83b98c879b6..771d0248f791 100644 --- a/include/configs/kmp204x.h +++ b/include/configs/kmp204x.h @@ -50,10 +50,6 @@ #define CONFIG_SYS_DPAA_RMAN /* RMan */
/* Environment in SPI Flash */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB for u-boot */ -#define CONFIG_ENV_SIZE 0x004000 /* 16K env */ -#define CONFIG_ENV_SECT_SIZE 0x010000 -#define CONFIG_ENV_OFFSET_REDUND 0x110000 #define CONFIG_ENV_TOTAL_SIZE 0x020000
#ifndef __ASSEMBLY__ diff --git a/include/configs/kmtegr1.h b/include/configs/kmtegr1.h index 701eb53f631d..e62760622285 100644 --- a/include/configs/kmtegr1.h +++ b/include/configs/kmtegr1.h @@ -25,9 +25,6 @@ #define CONFIG_KM_UBI_PARTITION_NAME_BOOT "ubi0" #define CONFIG_KM_UBI_PARTITION_NAME_APP "ubi1"
-#define CONFIG_ENV_ADDR 0xF0100000 -#define CONFIG_ENV_OFFSET 0x100000 - #define CONFIG_NAND_ECC_BCH #define CONFIG_NAND_KMETER1 #define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/kp_imx53.h b/include/configs/kp_imx53.h index 85224c3f46ae..5e2af76c6e4b 100644 --- a/include/configs/kp_imx53.h +++ b/include/configs/kp_imx53.h @@ -97,9 +97,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* environment organization */ -#define CONFIG_ENV_OFFSET (SZ_1M) -#define CONFIG_ENV_SIZE (SZ_8K) -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0
#endif /* __CONFIG_H_ */ diff --git a/include/configs/kp_imx6q_tpc.h b/include/configs/kp_imx6q_tpc.h index fc3896e7d10f..0f0fe63f4fbf 100644 --- a/include/configs/kp_imx6q_tpc.h +++ b/include/configs/kp_imx6q_tpc.h @@ -126,8 +126,5 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment */ -#define CONFIG_ENV_SIZE (SZ_8K) -#define CONFIG_ENV_OFFSET 0x100000 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
#endif /* __KP_IMX6Q_TPC_IMX6_CONFIG_H_ */ diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 5a2b040225bb..cceabdf66363 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -62,9 +62,6 @@ #undef CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_SYS_FLASH_EMPTY_INFO #define FLASH_SECTOR_SIZE (256 * 1024) /* 256 KB sectors */ -#define CONFIG_ENV_SIZE FLASH_SECTOR_SIZE -#define CONFIG_ENV_OFFSET FLASH_SECTOR_SIZE -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET)
/* Timeout for Flash erase operations (in ms) */ #define CONFIG_SYS_FLASH_ERASE_TOUT (3 * 1000) diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 1ba28b501f58..5bb0255a74d5 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -125,10 +125,6 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64KB */ -#define CONFIG_ENV_SIZE 0x1000 /* 4KB */ -#define CONFIG_ENV_ADDR 0x70000 -#define CONFIG_ENV_OFFSET 0x70000 /* env starts here */
/* * Default environment variables diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index c1eeca0c60bb..0bfa67a7c09c 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -135,8 +135,6 @@ #define CONFIG_CLOCKS #endif
-#define CONFIG_ENV_SIZE (16 << 10) - /* additions for new relocation code, must added to all boards */ #define CONFIG_SYS_SDRAM_BASE 0xc0000000
diff --git a/include/configs/libretech-ac.h b/include/configs/libretech-ac.h index 419dc615874d..bf20d3154302 100644 --- a/include/configs/libretech-ac.h +++ b/include/configs/libretech-ac.h @@ -9,9 +9,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_OFFSET (-0x10000) - #define BOOT_TARGET_DEVICES(func) \ func(ROMUSB, romusb, na) \ func(MMC, mmc, 0) \ diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h index 4d30d98abfae..ca5b693e4ccb 100644 --- a/include/configs/linkit-smart-7688.h +++ b/include/configs/linkit-smart-7688.h @@ -38,9 +38,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
/* Environment settings */ -#define CONFIG_ENV_OFFSET 0x80000 -#define CONFIG_ENV_SIZE (16 << 10) -#define CONFIG_ENV_SECT_SIZE (64 << 10)
/* * Environment is right behind U-Boot in flash. Make sure U-Boot diff --git a/include/configs/liteboard.h b/include/configs/liteboard.h index 975f32474c4a..14008fec3613 100644 --- a/include/configs/liteboard.h +++ b/include/configs/liteboard.h @@ -123,8 +123,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* FLASH and environment organization */ -#define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 0 #define CONFIG_MMCROOT "/dev/mmcblk0p2" diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index dd2a679b799a..2579e2fb37ee 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -53,14 +53,6 @@ * Environment */ #define CONFIG_ENV_OVERWRITE - -#define CONFIG_ENV_SIZE 0x40000 /* 256KB */ -#ifdef CONFIG_TFABOOT -#define CONFIG_ENV_OFFSET 0x500000 /* 5MB */ -#else -#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ -#endif -#define CONFIG_ENV_SECT_SIZE 0x40000 #endif
/* SATA */ diff --git a/include/configs/ls1012afrwy.h b/include/configs/ls1012afrwy.h index 1b0f1566d3eb..44b37c5475b6 100644 --- a/include/configs/ls1012afrwy.h +++ b/include/configs/ls1012afrwy.h @@ -25,8 +25,6 @@
/* ENV */ #define CONFIG_SYS_FSL_QSPI_BASE 0x40000000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FSL_QSPI_BASE + \ - CONFIG_ENV_OFFSET)
#ifndef CONFIG_SPL_BUILD #undef BOOT_TARGET_DEVICES @@ -35,14 +33,8 @@ func(USB, usb, 0) #endif
-#undef CONFIG_ENV_OFFSET -#define CONFIG_ENV_OFFSET 0x1D0000 #undef FSL_QSPI_FLASH_SIZE #define FSL_QSPI_FLASH_SIZE SZ_16M -#undef CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_SECT_SIZE 0x10000 /*64 KB*/ -#undef CONFIG_ENV_SIZE -#define CONFIG_ENV_SIZE 0x10000 /*64 KB*/
/* MMC */ #ifdef CONFIG_MMC diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index a5e27404f86a..3cd7baf21dad 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -19,8 +19,6 @@
/* ENV */ #define CONFIG_SYS_FSL_QSPI_BASE 0x40000000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FSL_QSPI_BASE + \ - CONFIG_ENV_OFFSET) /* * I2C IO expander */ diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index ee570bc1a9cf..0b2d331b9b9c 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -234,13 +234,7 @@ #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET 0x100000 #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET 0x100000 -#define CONFIG_ENV_SECT_SIZE 0x10000 #endif
#define CONFIG_OF_BOARD_SETUP diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 66771e279beb..8427be5adc18 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -493,20 +493,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET 0x300000 #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#elif defined(CONFIG_NAND_BOOT) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#include <asm/fsl_secure_boot.h> diff --git a/include/configs/ls1021atsn.h b/include/configs/ls1021atsn.h index b011cb2a8414..bdb4273cf5c6 100644 --- a/include/configs/ls1021atsn.h +++ b/include/configs/ls1021atsn.h @@ -236,13 +236,7 @@ #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET 0x300000 #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x20000 -#elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET 0x300000 -#define CONFIG_ENV_SECT_SIZE 0x40000 #endif
#define CONFIG_SYS_BOOTM_LEN 0x8000000 /* 128 MB */ diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 1363d3084d44..1919d1e14f9e 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -458,17 +458,7 @@ #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET 0x300000 #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x20000 -#elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET 0x300000 -#define CONFIG_ENV_SECT_SIZE 0x10000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#include <asm/fsl_secure_boot.h> diff --git a/include/configs/ls1028a_common.h b/include/configs/ls1028a_common.h index 39f931800709..09fc33381064 100644 --- a/include/configs/ls1028a_common.h +++ b/include/configs/ls1028a_common.h @@ -171,11 +171,7 @@
#define CONFIG_SYS_MMC_ENV_DEV 0 #define OCRAM_NONSECURE_SIZE 0x00010000 -#define CONFIG_ENV_OFFSET 0x500000 /* 5MB */ #define CONFIG_SYS_FSL_QSPI_BASE 0x20000000 -#define CONFIG_ENV_ADDR CONFIG_SYS_FSL_QSPI_BASE + CONFIG_ENV_OFFSET -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_SECT_SIZE 0x40000
diff --git a/include/configs/ls1028aqds.h b/include/configs/ls1028aqds.h index b0e9441a48bd..982df07bb013 100644 --- a/include/configs/ls1028aqds.h +++ b/include/configs/ls1028aqds.h @@ -59,7 +59,6 @@ #define I2C_MUX_CH_RTC 0xB
/* Store environment at top of flash */ -#define CONFIG_ENV_SIZE 0x2000
#ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_MONITOR_BASE CONFIG_SPL_TEXT_BASE diff --git a/include/configs/ls1028ardb.h b/include/configs/ls1028ardb.h index b77c36d2798e..a4c3d73d2a13 100644 --- a/include/configs/ls1028ardb.h +++ b/include/configs/ls1028ardb.h @@ -15,7 +15,6 @@ #define CONFIG_SYS_RTC_BUS_NUM 0
#define CONFIG_DIMM_SLOTS_PER_CTLR 1
diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 0ea3ca033244..37080629a13f 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -414,27 +414,10 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_TFABOOT #define CONFIG_SYS_MMC_ENV_DEV 0 - -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET 0x500000 /* 5MB */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x500000) -#define CONFIG_ENV_SECT_SIZE 0x20000 #else #ifdef CONFIG_NAND_BOOT -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (24 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE 0x20000 #endif #endif
diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index d2979efcdf95..f7b110cffcf8 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -247,23 +247,10 @@
#ifdef CONFIG_TFABOOT #define CONFIG_SYS_MMC_ENV_DEV 0 - -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET 0x500000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x500000) -#define CONFIG_ENV_SECT_SIZE 0x20000 #else #if defined(CONFIG_NAND_BOOT) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (24 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE 0x20000 #endif #endif
diff --git a/include/configs/ls1046afrwy.h b/include/configs/ls1046afrwy.h index 8609ebfecc14..4ccd3b05609e 100644 --- a/include/configs/ls1046afrwy.h +++ b/include/configs/ls1046afrwy.h @@ -100,12 +100,7 @@
-#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x500000 /* 5MB */ -#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ #define CONFIG_SYS_FSL_QSPI_BASE 0x40000000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FSL_QSPI_BASE + \ - CONFIG_ENV_OFFSET)
/* FMan */ #ifdef CONFIG_SYS_DPAA_FMAN diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index eea738e6021f..0b17b1e99432 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -429,27 +429,10 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_TFABOOT #define CONFIG_SYS_MMC_ENV_DEV 0 - -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET 0x500000 /* 5MB */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x500000) -#define CONFIG_ENV_SECT_SIZE 0x20000 #else #ifdef CONFIG_NAND_BOOT -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (12 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE 0x20000 #endif #endif
diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 2d20f156835a..efedfd59236c 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -160,20 +160,10 @@ #ifdef CONFIG_TFABOOT #define CONFIG_SYS_MMC_ENV_DEV 0
-#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x500000 /* 5MB */ -#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ #define CONFIG_SYS_FSL_QSPI_BASE 0x40000000 -#define CONFIG_ENV_ADDR CONFIG_SYS_FSL_QSPI_BASE + CONFIG_ENV_OFFSET #else #if defined(CONFIG_SD_BOOT) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ -#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ #endif #endif
diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 73c56296ff48..ab5b396e1a59 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -40,9 +40,6 @@ #else #ifdef CONFIG_QSPI_BOOT #define CONFIG_SYS_FSL_QSPI_BASE 0x20000000 -#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FSL_QSPI_BASE + \ - CONFIG_ENV_OFFSET) #endif #endif
diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index c9c517f93ec9..a5125c8f37fc 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -18,24 +18,10 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MMC_ENV_DEV 0
#define CONFIG_MISC_INIT_R - -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_OFFSET 0x500000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ - CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SECT_SIZE 0x40000 #else #if defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_SECT_SIZE 0x40000 #elif defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE 0x20000 #endif #endif
diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index b71f70426cff..b082d8549ab0 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -10,25 +10,12 @@
#ifdef CONFIG_TFABOOT #define CONFIG_SYS_MMC_ENV_DEV 0 - -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x500000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ - CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SECT_SIZE 0x40000 #else #if defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_SECT_SIZE 0x40000 #elif defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 #else #define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE 0x20000 #endif #endif /* CONFIG_TFABOOT */
diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 6be581a229ca..b58776a788b1 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -23,14 +23,6 @@ /* We need architecture specific misc initializations */
/* Link Definitions */ -#ifndef CONFIG_TFABOOT -#ifndef CONFIG_QSPI_BOOT -#else -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ -#define CONFIG_ENV_SECT_SIZE 0x40000 -#endif -#endif
#define CONFIG_SKIP_LOWLEVEL_INIT
diff --git a/include/configs/ls2080a_emu.h b/include/configs/ls2080a_emu.h index d5cb3e4df972..3e0ad48ddacc 100644 --- a/include/configs/ls2080a_emu.h +++ b/include/configs/ls2080a_emu.h @@ -76,6 +76,5 @@ #define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 200000
/* Store environment at top of flash */ -#define CONFIG_ENV_SIZE 0x1000
#endif /* __LS2_EMU_H */ diff --git a/include/configs/ls2080a_simu.h b/include/configs/ls2080a_simu.h index a52665884056..ab46df76007f 100644 --- a/include/configs/ls2080a_simu.h +++ b/include/configs/ls2080a_simu.h @@ -143,6 +143,5 @@ #define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 200000
#endif /* __LS2_SIMU_H */ diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 08696fa9a3af..9539e2a8db27 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -58,11 +58,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_TFABOOT #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_OFFSET 0x500000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ - CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SECT_SIZE 0x20000 #endif
#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) @@ -229,16 +224,11 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3
-#define CONFIG_ENV_OFFSET (896 * 1024) -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SYS_NAND_U_BOOT_OFFS (256 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 * 1024) #elif defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET 0x300000 #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x20000 #endif #else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT @@ -268,12 +258,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 #define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 - -#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_TFABOOT) -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE 0x2000 -#endif #endif
/* Debug Server firmware */ diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 2bf821768588..c5d57cfdd43b 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -72,12 +72,6 @@ unsigned long get_board_sys_clk(void); CONFIG_SYS_SCSI_MAX_LUN) #ifdef CONFIG_TFABOOT #define CONFIG_SYS_MMC_ENV_DEV 0 - -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET 0x500000 /* 5MB */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ - CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SECT_SIZE 0x40000 #endif
#if !defined(CONFIG_FSL_QSPI) || defined(CONFIG_TFABOOT) @@ -221,11 +215,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3
-#ifndef CONFIG_TFABOOT -#define CONFIG_ENV_OFFSET (2048 * 1024) -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE 0x2000 -#endif #define CONFIG_SPL_PAD_TO 0x80000 #define CONFIG_SYS_NAND_U_BOOT_OFFS (1024 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (512 * 1024) @@ -247,12 +236,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 #define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 - -#ifndef CONFIG_TFABOOT -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE 0x2000 -#endif #endif
/* Debug Server firmware */ diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 3ba5548f25ac..faa74c613fbd 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -50,12 +50,8 @@ #ifdef CONFIG_SPI_FLASH #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 8 -#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K */ #endif
-#define CONFIG_ENV_SIZE 0x10000 /* 64k */ -#define CONFIG_ENV_OFFSET 0x70000 /* env starts here */ - /* * Default environment variables */ diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 110d49726693..cfb20d3fb035 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -173,11 +173,6 @@ unsigned long get_board_ddr_clk(void); #define HWCONFIG_BUFFER_SIZE 128
#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_OFFSET 0x500000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ - CONFIG_ENV_OFFSET)
/* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 701bf2a597ba..af6fc3ae7aec 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -62,7 +62,6 @@ /* * NAND */ -#define CONFIG_ENV_SIZE (16 * 1024) #ifdef CONFIG_CMD_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE NFC_BASE_ADDR_AXI @@ -72,11 +71,7 @@ #define CONFIG_MXC_NAND_HWECC
/* Environment is in NAND */ -#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_RANGE (4 * CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_OFFSET (8 * CONFIG_ENV_SECT_SIZE) /* 1 MiB */ -#define CONFIG_ENV_OFFSET_REDUND \ - (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) +#define CONFIG_ENV_RANGE (0x00080000) /* 512 KiB */ #endif
/* diff --git a/include/configs/malta.h b/include/configs/malta.h index f536234f4890..bb8a44433eba 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -68,10 +68,6 @@ /* * Environment */ -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_ADDR \ - (CONFIG_SYS_FLASH_BASE + (4 << 20) - CONFIG_ENV_SIZE)
/* * IDE/ATA diff --git a/include/configs/maxbcm.h b/include/configs/maxbcm.h index 9d5fbcd516ee..9cc13052cc75 100644 --- a/include/configs/maxbcm.h +++ b/include/configs/maxbcm.h @@ -31,9 +31,6 @@ /* SPI NOR flash default params, used by sf commands */
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ -#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ -#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */
#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index 50afc7c60808..045a9f7bdf9d 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -245,12 +245,7 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_SIZE (SZ_128K)
/* Envs are stored in NOR flash */ -#define CONFIG_ENV_SECT_SIZE (SZ_128K) -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000) - -#define CONFIG_ENV_ADDR_REDUND (CONFIG_SYS_FLASH_BASE + 0x60000)
#endif /* __CONFIG_H * */ diff --git a/include/configs/medcom-wide.h b/include/configs/medcom-wide.h index d212a7f680fe..84b998e23af8 100644 --- a/include/configs/medcom-wide.h +++ b/include/configs/medcom-wide.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* Environment in NAND, aligned to start of last sector */ -#define CONFIG_ENV_OFFSET (SZ_512M - SZ_128K) /* 128K sectors */
diff --git a/include/configs/meerkat96.h b/include/configs/meerkat96.h index d0450af9542f..2dc3156b266d 100644 --- a/include/configs/meerkat96.h +++ b/include/configs/meerkat96.h @@ -38,8 +38,6 @@ /* Environment configs */ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 0 -#define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_OFFSET (8 * SZ_64K)
/* USB configs */ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 3a173a2665a3..9d6c3b83006e 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -93,15 +93,10 @@ #ifdef CONFIG_SYS_USE_DATAFLASH
/* bootstrap + u-boot + env in dataflash on CS0 */ -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_ENV_SECT_SIZE 0x210
#elif CONFIG_SYS_USE_NANDFLASH
/* bootstrap + u-boot + env + linux in nandflash */ -# define CONFIG_ENV_OFFSET 0xC0000 -# define CONFIG_ENV_SIZE 0x20000
#endif
diff --git a/include/configs/meson64.h b/include/configs/meson64.h index f8d3eee29222..736081277d41 100644 --- a/include/configs/meson64.h +++ b/include/configs/meson64.h @@ -37,9 +37,6 @@
#define CONFIG_CPU_ARMV8 #define CONFIG_REMAKE_ELF -#ifndef CONFIG_ENV_SIZE -#define CONFIG_ENV_SIZE 0x2000 -#endif #define CONFIG_SYS_MAXARGS 32 #define CONFIG_SYS_MALLOC_LEN (32 << 20) #define CONFIG_SYS_CBSIZE 1024 diff --git a/include/configs/meson64_android.h b/include/configs/meson64_android.h index 055fb44e9364..a4d9779667f4 100644 --- a/include/configs/meson64_android.h +++ b/include/configs/meson64_android.h @@ -11,8 +11,6 @@
#define CONFIG_SYS_MMC_ENV_DEV 2 #define CONFIG_SYS_MMC_ENV_PART 1 -#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_OFFSET (-0x10000)
#define BOOTENV_DEV_FASTBOOT(devtypeu, devtypel, instance) \ diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index f1d0def3c163..385b30c99b75 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -70,35 +70,20 @@ /* hardware flash protection */ /* use buffered writes (20x faster) */ # ifdef RAMENV -# define CONFIG_ENV_SIZE 0x1000 -# define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE) - # else /* FLASH && !RAMENV */ /* 128K(one sector) for env */ -# define CONFIG_ENV_SECT_SIZE 0x20000 -# define CONFIG_ENV_ADDR \ - (CONFIG_SYS_FLASH_BASE + (2 * CONFIG_ENV_SECT_SIZE)) -# define CONFIG_ENV_SIZE 0x20000 # endif /* FLASH && !RAMBOOT */ #else /* !FLASH */
#ifdef SPIFLASH # ifdef RAMENV -# define CONFIG_ENV_SIZE 0x1000 -# define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE) - # else /* SPIFLASH && !RAMENV */ /* 128K(two sectors) for env */ -# define CONFIG_ENV_SECT_SIZE 0x10000 -# define CONFIG_ENV_SIZE (2 * CONFIG_ENV_SECT_SIZE) /* Warning: adjust the offset in respect of other flash content and size */ -# define CONFIG_ENV_OFFSET (128 * CONFIG_ENV_SECT_SIZE) /* at 8MB */ # endif /* SPIFLASH && !RAMBOOT */ #else /* !SPIFLASH */
/* ENV in RAM */ -# define CONFIG_ENV_SIZE 0x1000 -# define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE) #endif /* !SPIFLASH */ #endif /* !FLASH */
diff --git a/include/configs/microchip_mpfs_icicle.h b/include/configs/microchip_mpfs_icicle.h index 82c7fbbdf22f..2f90ab317571 100644 --- a/include/configs/microchip_mpfs_icicle.h +++ b/include/configs/microchip_mpfs_icicle.h @@ -58,6 +58,5 @@ #define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_0 + PHYS_SDRAM_0_SIZE)
/* When we use RAM as ENV */ -#define CONFIG_ENV_SIZE 0x2000
#endif /* __CONFIG_H */ diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h index d0fe582c9094..6bcae31cb61b 100644 --- a/include/configs/minnowmax.h +++ b/include/configs/minnowmax.h @@ -22,7 +22,4 @@ #define VIDEO_IO_OFFSET 0 #define CONFIG_X86EMU_RAW_IO
-#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OFFSET 0x006ef000 - #endif /* __CONFIG_H */ diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index 5a8546838fe3..cc58e806defc 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -227,11 +227,6 @@ /* * Environment */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ - CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE)
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/mt7623.h b/include/configs/mt7623.h index 5f67893f3127..e5182aeea872 100644 --- a/include/configs/mt7623.h +++ b/include/configs/mt7623.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_NONCACHED_MEMORY SZ_1M
/* Environment */ -#define CONFIG_ENV_SIZE SZ_4K /* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
@@ -58,6 +57,5 @@ #define CONFIG_SERVERIP 192.168.1.2
#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_OFFSET 0x100000
#endif diff --git a/include/configs/mt7629.h b/include/configs/mt7629.h index 741b6fbc1b18..4aef894c6ebe 100644 --- a/include/configs/mt7629.h +++ b/include/configs/mt7629.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_NONCACHED_MEMORY SZ_1M
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index bc249039c8e2..172bfc88b64b 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -60,9 +60,6 @@ #define CONFIG_MTD_PARTITIONS /* required for UBI partition support */
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_OFFSET 0x180000 /* as Marvell U-Boot version */ -#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ -#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */
/* * Ethernet Driver configuration diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index 3be36833de05..b72a0a5b9ed7 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -47,10 +47,6 @@ /* End of 16M scrubbed by training in bootrom */ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + 0xFF0000)
-#define CONFIG_ENV_OFFSET 0x180000 /* as Marvell U-Boot version */ -#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ -#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */ - /* When runtime detection fails this is the default */ #define CONFIG_SYS_MMC_ENV_DEV 0
diff --git a/include/configs/mx23_olinuxino.h b/include/configs/mx23_olinuxino.h index 330f020f7896..1f55e9209191 100644 --- a/include/configs/mx23_olinuxino.h +++ b/include/configs/mx23_olinuxino.h @@ -20,8 +20,6 @@
/* Environment is in MMC */ #if defined(CONFIG_CMD_MMC) && defined(CONFIG_ENV_IS_IN_MMC) -#define CONFIG_ENV_OFFSET (256 * 1024) -#define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 #endif
diff --git a/include/configs/mx23evk.h b/include/configs/mx23evk.h index da1d53c883d9..595727aa3071 100644 --- a/include/configs/mx23evk.h +++ b/include/configs/mx23evk.h @@ -23,8 +23,6 @@
diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index 6537e3a20445..174f038be8eb 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -49,8 +49,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
/* No NOR flash present */ -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) -#define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
/* U-Boot general configuration */ diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 7e7637ebecd8..15b64ee03eca 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -19,34 +19,19 @@ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
/* Environment */ -#ifndef CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SIZE (16 * 1024) -#else -#define CONFIG_ENV_SIZE (4 * 1024) -#endif #define CONFIG_ENV_OVERWRITE
/* Environment is in MMC */ #if defined(CONFIG_CMD_MMC) && defined(CONFIG_ENV_IS_IN_MMC) -#define CONFIG_ENV_OFFSET (256 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 #endif
/* Environment is in NAND */ #if defined(CONFIG_CMD_NAND) && defined(CONFIG_ENV_IS_IN_NAND) -#define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_RANGE (512 * 1024) -#define CONFIG_ENV_OFFSET 0x300000 -#define CONFIG_ENV_OFFSET_REDUND \ - (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) #endif
/* Environment is in SPI flash */ -#if defined(CONFIG_CMD_SF) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) -#define CONFIG_ENV_OFFSET 0x40000 /* 256K */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_ENV_SECT_SIZE 0x1000 -#endif
/* UBI and NAND partitioning */
diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 04e3b8ff28ce..4082a0bd6424 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -94,9 +94,6 @@ /* * environment organization */ -#define CONFIG_ENV_OFFSET 0x40000 -#define CONFIG_ENV_OFFSET_REDUND 0x60000 -#define CONFIG_ENV_SIZE (128 * 1024)
/* * NAND driver diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 4ec36193c0b2..222d13eb1fdd 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -128,18 +128,7 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN (512 * 1024)
-#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE - /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) - -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ - CONFIG_SYS_MONITOR_LEN) - -#if defined(CONFIG_FSL_ENV_IN_NAND) - #define CONFIG_ENV_OFFSET (1024 * 1024) -#endif
/* * CFI FLASH driver setup diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index fc498b2481e1..71ff7893810f 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -182,8 +182,6 @@ /*----------------------------------------------------------------------- * environment organization */ -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) -#define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
#endif diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index d25629f41553..ff71435776a4 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -168,8 +168,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* environment organization */ -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) -#define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
#define MX53ARD_CS1GCR1 (CSEN | DSZ(2)) diff --git a/include/configs/mx53cx9020.h b/include/configs/mx53cx9020.h index bbe057403300..af23762396f4 100644 --- a/include/configs/mx53cx9020.h +++ b/include/configs/mx53cx9020.h @@ -154,8 +154,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Framebuffer and LCD */ diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index 17ff13df3e42..2e687b9bdc0b 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -119,8 +119,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
#endif /* __CONFIG_H */ diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 65a5993f6147..1798a92efc53 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -164,7 +164,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment starts at 768k = 768 * 1024 = 786432 */ -#define CONFIG_ENV_OFFSET 786432 /* * Detect overlap between U-Boot image and environment area in build-time * @@ -175,7 +174,6 @@ * write the direct value here */ #define CONFIG_BOARD_SIZE_LIMIT 785408 -#define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
#ifdef CONFIG_CMD_SATA diff --git a/include/configs/mx53ppd.h b/include/configs/mx53ppd.h index 59988efc9b32..f7667eca7c09 100644 --- a/include/configs/mx53ppd.h +++ b/include/configs/mx53ppd.h @@ -183,8 +183,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* FLASH and environment organization */ -#define CONFIG_ENV_OFFSET (12 * 64 * 1024) -#define CONFIG_ENV_SIZE (10 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
#define CONFIG_CMD_FUSE diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index e606ee81b5f8..610e6e8a11fb 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -114,8 +114,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
#endif /* __CONFIG_H */ diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 3cf2f1ce28a0..c8d91dcfa05d 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -131,7 +131,5 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_OFFSET (SZ_1M - CONFIG_ENV_SIZE)
#endif /* __MX6CUBOXI_CONFIG_H */ diff --git a/include/configs/mx6memcal.h b/include/configs/mx6memcal.h index 58d5ebf56473..6fd87c2abcd4 100644 --- a/include/configs/mx6memcal.h +++ b/include/configs/mx6memcal.h @@ -50,8 +50,6 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
-#define CONFIG_ENV_SIZE (8 * 1024) - #define CONFIG_MXC_USB_PORTSC PORT_PTS_UTMI
#endif /* __CONFIG_H */ diff --git a/include/configs/mx6qarm2.h b/include/configs/mx6qarm2.h index 6e4e7519356c..7e6917b9670e 100644 --- a/include/configs/mx6qarm2.h +++ b/include/configs/mx6qarm2.h @@ -118,8 +118,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) -#define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 1
/* USB Configs */ diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 56b10d8eb294..9309e0320f2a 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -179,11 +179,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_SIZE (8 * 1024) - -#if defined(CONFIG_ENV_IS_IN_MMC) -#define CONFIG_ENV_OFFSET (768 * 1024) -#endif
/* Framebuffer */ #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 5d649f6e2f08..6b2a174e7a46 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -131,14 +131,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_SIZE SZ_8K - -#if defined CONFIG_SPI_BOOT -#define CONFIG_ENV_OFFSET (768 * 1024) -#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#else -#define CONFIG_ENV_OFFSET (8 * SZ_64K) -#endif
/* USB Configs */ #ifdef CONFIG_CMD_USB diff --git a/include/configs/mx6sllevk.h b/include/configs/mx6sllevk.h index b96e63198d11..8ae1e0a2e636 100644 --- a/include/configs/mx6sllevk.h +++ b/include/configs/mx6sllevk.h @@ -120,12 +120,9 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_SIZE SZ_8K #define CONFIG_SYS_MMC_ENV_PART 0 /* user partition */ #define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC1 */
-#define CONFIG_ENV_OFFSET (12 * SZ_64K) - /* MMC Configs */ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC1_BASE_ADDR #define CONFIG_SYS_FSL_USDHC_NUM 3 diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index c4d8a8939cf9..0bcf031953f7 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -151,9 +151,6 @@ #define FSL_QSPI_FLASH_NUM 2 #endif
-#define CONFIG_ENV_OFFSET (8 * SZ_64K) -#define CONFIG_ENV_SIZE SZ_8K - #define CONFIG_SYS_FSL_USDHC_NUM 2 #if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 0 /*USDHC3*/ diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index dc4181dbf839..704d9f3dcb89 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -199,9 +199,6 @@ #endif #endif
-#define CONFIG_ENV_OFFSET (14 * SZ_64K) -#define CONFIG_ENV_SIZE SZ_8K - #define CONFIG_SYS_FSL_USDHC_NUM 3 #if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 2 /*USDHC4*/ diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 87f88693c5aa..c21d633ca069 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -157,8 +157,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* environment organization */ -#define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ #define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */ diff --git a/include/configs/mx6ullevk.h b/include/configs/mx6ullevk.h index 3bcd0d3ee345..7cce911314b3 100644 --- a/include/configs/mx6ullevk.h +++ b/include/configs/mx6ullevk.h @@ -154,9 +154,6 @@ #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ #define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */
-#define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_OFFSET (12 * SZ_64K) - #define CONFIG_IMX_THERMAL
#define CONFIG_IOMUX_LPSR diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index e1f92da48ca6..745507571dde 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -174,7 +174,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* * If want to use nand, define CONFIG_NAND_MXS and rework board @@ -190,7 +189,6 @@ /* DMA stuff, needed for GPMI/MXS NAND support */ #endif
-#define CONFIG_ENV_OFFSET (12 * SZ_64K) #ifdef CONFIG_NAND_MXS #define CONFIG_SYS_FSL_USDHC_NUM 1 #else diff --git a/include/configs/mx7ulp_evk.h b/include/configs/mx7ulp_evk.h index 3b023624984d..cdc1a487c494 100644 --- a/include/configs/mx7ulp_evk.h +++ b/include/configs/mx7ulp_evk.h @@ -26,9 +26,6 @@ #define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC1 */ #define CONFIG_SYS_MMC_IMG_LOAD_PART 1
-#define CONFIG_ENV_OFFSET (12 * SZ_64K) -#define CONFIG_ENV_SIZE SZ_8K - /* Using ULP WDOG for reset */ #define WDOG_BASE_ADDR WDG1_RBASE
diff --git a/include/configs/nas220.h b/include/configs/nas220.h index bdfa42fd30c2..5251db9389cc 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -50,12 +50,6 @@ /* * Environment variables configurations */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_SECT_SIZE 0x10000 -#endif - -#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_OFFSET 0xa0000
/* * Default environment variables diff --git a/include/configs/netgear_cg3100d.h b/include/configs/netgear_cg3100d.h index e5a96015197b..8d2b3e73a048 100644 --- a/include/configs/netgear_cg3100d.h +++ b/include/configs/netgear_cg3100d.h @@ -6,4 +6,3 @@ #include <configs/bmips_common.h> #include <configs/bmips_bcm3380.h>
-#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/netgear_dgnd3700v2.h b/include/configs/netgear_dgnd3700v2.h index 3baa17ae6183..779c20700a9a 100644 --- a/include/configs/netgear_dgnd3700v2.h +++ b/include/configs/netgear_dgnd3700v2.h @@ -8,4 +8,3 @@
-#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 23c370b07c39..9ef6ea90a3f6 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -147,14 +147,9 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
#if defined(CONFIG_ENV_IS_IN_MMC) -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 -#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) -#define CONFIG_ENV_OFFSET (768 * 1024) -#define CONFIG_ENV_SECT_SIZE (8 * 1024) #endif
/* diff --git a/include/configs/novena.h b/include/configs/novena.h index fff2396e98f2..c03b8db2bad9 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -18,7 +18,6 @@ /* U-Boot general configurations */
/* U-Boot environment */ -#define CONFIG_ENV_SIZE (16 * 1024) /* * Environment is on MMC, starting at offset 512KiB from start of the card. * Please place first partition at offset 1MiB from the start of the card @@ -27,9 +26,6 @@ */ #ifdef CONFIG_CMD_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_OFFSET (512 * 1024) -#define CONFIG_ENV_OFFSET_REDUND \ - (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #endif
/* Booting Linux */ diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index eb465e069054..e59ef11e66a7 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -27,11 +27,6 @@ #include "mv-common.h"
/* environment variables configuration */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_SECT_SIZE 0x20000 -#endif -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_OFFSET 0xe0000
/* default environment variables */ #define CONFIG_BOOTCOMMAND \ diff --git a/include/configs/nyan-big.h b/include/configs/nyan-big.h index fca4eb59a4ad..97dd168b0180 100644 --- a/include/configs/nyan-big.h +++ b/include/configs/nyan-big.h @@ -21,7 +21,6 @@ /* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* Align LCD to 1MB boundary */ #define CONFIG_LCD_ALIGNMENT MMU_SECTION_SIZE diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 9f2d43e3fa38..77fca32fcaf6 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -48,8 +48,6 @@ #define CONFIG_SYS_MONITOR_BASE 0x00000000
#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV -#define CONFIG_ENV_SIZE SZ_16K -#define CONFIG_ENV_OFFSET (SZ_1K * 1280) /* 1.25 MiB offset */ #define CONFIG_ENV_OVERWRITE
/* Partitions name */ diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index af6004eaf511..47c30543f8f0 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -23,11 +23,6 @@ #define CONFIG_SYS_MEM_TOP_HIDE (22UL << 20UL) #define CONFIG_TZSW_RESERVED_DRAM_SIZE CONFIG_SYS_MEM_TOP_HIDE
-#undef CONFIG_ENV_SIZE -#undef CONFIG_ENV_OFFSET -#define CONFIG_ENV_SIZE (SZ_1K * 16) -#define CONFIG_ENV_OFFSET (SZ_1K * 3136) /* ~3 MiB offset */ - #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000)
#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index e8c60838b72b..800e22b486ed 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -40,7 +40,6 @@ #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 #define CONFIG_SYS_ENV_SECT_SIZE SZ_128K -#define CONFIG_ENV_ADDR 0x260000 #define CONFIG_ENV_OVERWRITE /* NAND: SPL falcon mode configs */ #if defined(CONFIG_SPL_OS_BOOT) diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index 9e2b7523e5d1..1b1a56d7cd42 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -161,7 +161,6 @@ #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_ENV_ADDR 0x260000
/* Defines for SPL */
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 8e98977de8e8..a04499ec10cc 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -44,7 +44,6 @@ #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW #define CONFIG_SYS_ENV_SECT_SIZE SZ_128K -#define CONFIG_ENV_ADDR 0x260000 #define CONFIG_ENV_OVERWRITE /* NAND: SPL falcon mode configs */ #if defined(CONFIG_SPL_OS_BOOT) diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 90292ae31211..207cd9399e50 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -198,7 +198,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 38a10e23d917..da67cbbf1ea5 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -155,8 +155,6 @@
#define ONENAND_ENV_OFFSET 0x240000 /* environment starts here */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_ENV_OFFSET 0x240000 -#define CONFIG_ENV_ADDR 0x240000
/* Initial RAM setup */ #define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 98f243f4ddde..9e6a8684589b 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -61,6 +61,5 @@
#endif /* __CONFIG_H */ diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 4dc22a7a1994..a4ba7dbcc56b 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -130,6 +130,5 @@ #define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */
#endif /* __CONFIG_H */ diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 1a0f9cace07b..884f45df2256 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -21,6 +21,5 @@
/* ENV related config options */ #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ -#define CONFIG_ENV_OFFSET 0xE0000
#endif /* __CONFIG_SDP4430_H */ diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index ff811569b99c..53589c03ead8 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -32,7 +32,6 @@
/* MMC ENV related defines */ #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
/* Enhance our eMMC support / experience. */ #define CONFIG_HSMMC2_8BIT diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 1c41e7e97adc..fc5c87cc9ae3 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -117,8 +117,6 @@ * Flash & Environment */ #ifdef CONFIG_NAND -#define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ -#define CONFIG_ENV_SIZE (128 << 9) #define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST #define CONFIG_SYS_NAND_PAGE_2K #define CONFIG_SYS_NAND_CS 3 @@ -215,13 +213,6 @@
/* SD/MMC */
-#ifdef CONFIG_ENV_IS_IN_MMC -#undef CONFIG_ENV_SIZE -#undef CONFIG_ENV_OFFSET -#define CONFIG_ENV_SIZE (16 << 10) /* 16 KiB */ -#define CONFIG_ENV_OFFSET (51 << 9) /* Sector 51 */ -#endif - /* defines for SPL */ #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE - \ CONFIG_SYS_MALLOC_LEN) diff --git a/include/configs/openrd.h b/include/configs/openrd.h index 62d8862cc755..5c59cabc0885 100644 --- a/include/configs/openrd.h +++ b/include/configs/openrd.h @@ -33,15 +33,10 @@ /* * Environment variables configurations */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#endif /* * max 4k env size is enough, but in case of nand * it has to be rounded to sector size */ -#define CONFIG_ENV_SIZE 0x20000 /* 128k */ -#define CONFIG_ENV_OFFSET 0x80000 /* env starts here */ /* * Environment is right behind U-Boot in flash. Make sure U-Boot * doesn't grow into the environment area. diff --git a/include/configs/opos6uldev.h b/include/configs/opos6uldev.h index f80e34729a69..3ef5ebbac793 100644 --- a/include/configs/opos6uldev.h +++ b/include/configs/opos6uldev.h @@ -61,9 +61,6 @@ /* Environment is stored in the eMMC boot partition */ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 1 -#define CONFIG_ENV_SIZE (10 * 1024) -#define CONFIG_ENV_OFFSET (1024 * 1024) /* 1 MB */ -#define CONFIG_ENV_OFFSET_REDUND (1536 * 1024) /* 512KB from CONFIG_ENV_OFFSET */
#define CONFIG_ENV_VERSION 100 #define CONFIG_BOARD_NAME opos6ul diff --git a/include/configs/origen.h b/include/configs/origen.h index 44561acbf4a6..ff9318a81b8f 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -80,10 +80,8 @@ #define CONFIG_MIU_2BIT_21_7_INTERLEAVED
#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ #define RESERVE_BLOCK_SIZE (512) #define BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ -#define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE)
#define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024)
diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 4efef892a840..c8ebe3e390d9 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -92,10 +92,7 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_SIZE (64 * 1024) /* 64 kb */ -#define CONFIG_ENV_OFFSET (1024 * 1024) /* M25P16 has an erase size of 64 KiB */ -#define CONFIG_ENV_SECT_SIZE (64 * 1024)
#define CONFIG_BOOTP_SERVERIP #define CONFIG_BOOTP_BOOTFILE diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 1481d683e5c3..39cec354d899 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -696,30 +696,16 @@ /* * Environment */ -#ifdef CONFIG_SPIFLASH -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#elif defined(CONFIG_SDCARD) +#if defined(CONFIG_SDCARD) #define CONFIG_FSL_FIXED_MMC_LOCATION -#define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 #elif defined(CONFIG_NAND) +#define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) #ifdef CONFIG_TPL_BUILD -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) -#else -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define SPL_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) #endif -#define CONFIG_ENV_OFFSET (1024 * 1024) -#define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) #elif defined(CONFIG_SYS_RAMBOOT) -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#define SPL_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #endif
#define CONFIG_LOADS_ECHO /* echo on for serial download */ diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index 1e0708a71bda..3ff75663ea16 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -322,16 +322,8 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); */ #ifdef CONFIG_SYS_RAMBOOT #ifdef CONFIG_RAMBOOT_SDCARD -#define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -#define CONFIG_ENV_SIZE 0x2000 #endif -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
#define CONFIG_LOADS_ECHO /* echo on for serial download */ diff --git a/include/configs/p2371-0000.h b/include/configs/p2371-0000.h index 177e8d8dfea8..8e3e1a77f5ae 100644 --- a/include/configs/p2371-0000.h +++ b/include/configs/p2371-0000.h @@ -20,7 +20,6 @@ /* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* SPI */ #define CONFIG_SPI_FLASH_SIZE (4 << 20) diff --git a/include/configs/p2371-2180.h b/include/configs/p2371-2180.h index 7205a17e5d8d..7998eabd30cb 100644 --- a/include/configs/p2371-2180.h +++ b/include/configs/p2371-2180.h @@ -20,7 +20,6 @@ /* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* SPI */ #define CONFIG_SPI_FLASH_SIZE (4 << 20) diff --git a/include/configs/p2571.h b/include/configs/p2571.h index 02db6bb79fb3..e7b860a30ec4 100644 --- a/include/configs/p2571.h +++ b/include/configs/p2571.h @@ -21,7 +21,6 @@ /* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* SPI */ #define CONFIG_SPI_FLASH_SIZE (4 << 20) diff --git a/include/configs/p2771-0000.h b/include/configs/p2771-0000.h index e546c1d73fd2..7c6d68a4f11a 100644 --- a/include/configs/p2771-0000.h +++ b/include/configs/p2771-0000.h @@ -16,7 +16,6 @@ /* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
#define BOARD_EXTRA_ENV_SETTINGS \ "calculated_vars=kernel_addr_r fdt_addr_r scriptaddr pxefile_addr_r " \ diff --git a/include/configs/paz00.h b/include/configs/paz00.h index b76958c36d80..ae8e0dee2cd1 100644 --- a/include/configs/paz00.h +++ b/include/configs/paz00.h @@ -22,7 +22,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_PAZ00
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2
diff --git a/include/configs/pcl063.h b/include/configs/pcl063.h index 943fca937764..238b03f600eb 100644 --- a/include/configs/pcl063.h +++ b/include/configs/pcl063.h @@ -54,9 +54,6 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
-#define CONFIG_ENV_SIZE (16 << 10) -#define CONFIG_ENV_OFFSET (512 << 10) - /* NAND */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 diff --git a/include/configs/pcl063_ull.h b/include/configs/pcl063_ull.h index 23e491236cb4..d2459874706a 100644 --- a/include/configs/pcl063_ull.h +++ b/include/configs/pcl063_ull.h @@ -21,10 +21,6 @@ #define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M)
/* Environment settings */ -#define CONFIG_ENV_SIZE (0x4000) -#define CONFIG_ENV_OFFSET (0x80000) -#define CONFIG_ENV_OFFSET_REDUND \ - (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
/* Environment in SD */ #define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index b68d205bfb3a..72f8d08a665c 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -168,17 +168,7 @@
/* environment organization */ #ifdef CONFIG_ENV_IS_IN_MMC -#define CONFIG_ENV_SIZE (SZ_8K) - -#define CONFIG_ENV_OFFSET (12 * SZ_64K) #define CONFIG_SYS_MMC_ENV_DEV 0 #endif
-#ifdef CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SECT_SIZE (SZ_128K) -#define CONFIG_ENV_SIZE (SZ_8K) -#define CONFIG_ENV_OFFSET 0xA0000 -#define CONFIG_ENV_OFFSET_REDUND 0xC0000 -#endif - #endif diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index 6c4a619433b6..7c27ebb811da 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -73,15 +73,5 @@ #define CONFIG_SYS_FSL_USDHC_NUM 1
/* Environment organization */ -#define CONFIG_ENV_SIZE (16 * 1024) -#define CONFIG_ENV_OFFSET (1024 * SZ_1K) -#define CONFIG_ENV_SECT_SIZE (64 * SZ_1K) -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ - CONFIG_ENV_SECT_SIZE) - -#ifdef CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_OFFSET (0x1E0000) -#define CONFIG_ENV_SECT_SIZE (128 * SZ_1K) -#endif
#endif diff --git a/include/configs/pdu001.h b/include/configs/pdu001.h index e4c2872fe955..78a1a86431ce 100644 --- a/include/configs/pdu001.h +++ b/include/configs/pdu001.h @@ -13,7 +13,6 @@ #include <configs/ti_am335x_common.h>
/* Using 32K of volatile storage for environment */ -#define CONFIG_ENV_SIZE 0x4000
#define MACH_TYPE_PDU001 5075 #define CONFIG_MACH_TYPE MACH_TYPE_PDU001 diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index a535d0c2f2d0..8a0506911d27 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -18,7 +18,6 @@ #define V_SCLK V_OSCK
/* set env size */ -#define CONFIG_ENV_SIZE 0x4000
#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ @@ -144,7 +143,6 @@ #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000
/* Size must be a multiple of Nand erase size (524288 b) */ -#define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT diff --git a/include/configs/pfla02.h b/include/configs/pfla02.h index a4d0e4898a48..d4a7de7df6a2 100644 --- a/include/configs/pfla02.h +++ b/include/configs/pfla02.h @@ -74,16 +74,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 2
/* Default environment */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/pic32mzdask.h b/include/configs/pic32mzdask.h index d3ab5575ee70..2f641d3831de 100644 --- a/include/configs/pic32mzdask.h +++ b/include/configs/pic32mzdask.h @@ -74,7 +74,6 @@ /* ------------------------------------------------- * Environment */ -#define CONFIG_ENV_SIZE 0x4000
/* --------------------------------------------------------------------- * Board boot configuration diff --git a/include/configs/pico-imx6.h b/include/configs/pico-imx6.h index 5bbb9ea8f701..376370b07de2 100644 --- a/include/configs/pico-imx6.h +++ b/include/configs/pico-imx6.h @@ -125,10 +125,8 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment starts at 768k = 768 * 1024 = 786432 */ -#define CONFIG_ENV_OFFSET 786432 /* * Detect overlap between U-Boot image and environment area in build-time * diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 22dfac7fec05..27e83b47cd63 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -135,9 +135,7 @@ #define CONFIG_SYS_I2C_SPEED 100000
/* environment organization */ -#define CONFIG_ENV_SIZE SZ_8K /* Environment starts at 768k = 768 * 1024 = 786432 */ -#define CONFIG_ENV_OFFSET 786432 /* * Detect overlap between U-Boot image and environment area in build-time * diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index 607784e42363..1d0df9dd447f 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -164,10 +164,8 @@ #endif
/* Environment starts at 768k = 768 * 1024 = 786432 */ -#define CONFIG_ENV_OFFSET 786432 /* * Detect overlap between U-Boot image and environment area in build-time * diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index ad41d161493a..cb8338f38477 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -91,7 +91,6 @@
#ifdef CONFIG_SYS_USE_MMC /* bootstrap + u-boot + env + linux in mmc */ -#define CONFIG_ENV_SIZE 0x4000
#define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x21000000 dtb; " \ "fatload mmc 0:1 0x22000000 zImage; " \ diff --git a/include/configs/platinum.h b/include/configs/platinum.h index 58e590a1fd3b..210927f4de00 100644 --- a/include/configs/platinum.h +++ b/include/configs/platinum.h @@ -74,16 +74,10 @@ /* DMA config, needed for GPMI/MXS NAND support */
/* Environment in NAND */ -#define CONFIG_ENV_OFFSET (16 << 20) -#define CONFIG_ENV_SECT_SIZE (128 << 10) -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + (512 << 10))
#else /* CONFIG_CMD_NAND */
/* Environment in MMC */ -#define CONFIG_ENV_SIZE (8 << 10) -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
#endif /* CONFIG_CMD_NAND */ diff --git a/include/configs/plutux.h b/include/configs/plutux.h index 43856bad2c1a..7fc06e8326bb 100644 --- a/include/configs/plutux.h +++ b/include/configs/plutux.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1
#include "tegra-common-post.h"
diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 99ca1f730e60..f958ceb30531 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -203,9 +203,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH_CS0
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_ENV_SECT_SIZE 0x210 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x84000 0x210000; " \ "bootm 0x22000000" @@ -213,16 +210,10 @@ #elif defined(CONFIG_SYS_USE_NANDFLASH) /* CONFIG_SYS_USE_NANDFLASH */
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_OFFSET 0x60000 -#define CONFIG_ENV_OFFSET_REDUND 0x80000 -#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ #define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm"
#elif defined (CONFIG_SYS_USE_FLASH)
-#define CONFIG_ENV_OFFSET 0x40000 -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_SIZE 0x10000 #define CONFIG_ENV_OVERWRITE 1
/* JFFS Partition offset set */ diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 595acf1b9434..50d953a8e891 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -232,9 +232,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_ENV_SECT_SIZE 0x210 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" @@ -242,16 +239,10 @@ #elif defined(CONFIG_SYS_USE_NANDFLASH) /* CFG_USE_NANDFLASH */
#elif defined(CONFIG_SYS_USE_FLASH) /* CFG_USE_FLASH */
/* JFFS Partition offset set */ diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index ae87f9be7920..8c181e64afdb 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -64,16 +64,12 @@
#ifdef CONFIG_NAND_BOOT /* bootstrap + u-boot + env in nandflash */ -#define CONFIG_ENV_OFFSET 0x140000 -#define CONFIG_ENV_OFFSET_REDUND 0x100000 -#define CONFIG_ENV_SIZE 0x20000
#define CONFIG_BOOTCOMMAND \ "nand read 0x70000000 0x200000 0x300000;" \ "bootm 0x70000000" #elif CONFIG_SD_BOOT /* bootstrap + u-boot + env + linux in mmc */ -#define CONFIG_ENV_SIZE 0x4000
#define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x71000000 dtb; " \ "fatload mmc 0:1 0x72000000 zImage; " \ diff --git a/include/configs/pogo_e02.h b/include/configs/pogo_e02.h index 68d726835ca8..bb24739a9083 100644 --- a/include/configs/pogo_e02.h +++ b/include/configs/pogo_e02.h @@ -37,12 +37,6 @@ /* * Environment variables configurations */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#endif - -#define CONFIG_ENV_SIZE 0x20000 /* 128k */ -#define CONFIG_ENV_OFFSET 0x60000 /* env starts here */
/* * Default environment variables diff --git a/include/configs/poplar.h b/include/configs/poplar.h index be9a0b51a96f..81c7f251bcca 100644 --- a/include/configs/poplar.h +++ b/include/configs/poplar.h @@ -54,8 +54,6 @@
/* Command line configuration */ #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_OFFSET (0xf80 * 512) /* env_mmc_blknum bytes */ -#define CONFIG_ENV_SIZE (0x80 * 512) /* env_mmc_nblks bytes */
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 diff --git a/include/configs/puma_rk3399.h b/include/configs/puma_rk3399.h index 4d6085d2dd83..27a8a7d9c3af 100644 --- a/include/configs/puma_rk3399.h +++ b/include/configs/puma_rk3399.h @@ -10,8 +10,6 @@
#if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 1 -#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) -#define CONFIG_ENV_SECT_SIZE (8 * 1024) #endif
#define SDRAM_BANK_SIZE (2UL << 30) diff --git a/include/configs/pumpkin.h b/include/configs/pumpkin.h index b2dda642ccb9..35e28be950ca 100644 --- a/include/configs/pumpkin.h +++ b/include/configs/pumpkin.h @@ -11,7 +11,6 @@
#include <linux/sizes.h>
-#define CONFIG_ENV_SIZE SZ_4K #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MALLOC_LEN SZ_4M
diff --git a/include/configs/qemu-arm.h b/include/configs/qemu-arm.h index c7aaafaad468..fb599c951022 100644 --- a/include/configs/qemu-arm.h +++ b/include/configs/qemu-arm.h @@ -21,8 +21,6 @@ #define CONFIG_SYS_HZ 1000
/* Environment options */ -#define CONFIG_ENV_ADDR 0x4000000 -#define CONFIG_ENV_SIZE SZ_256K
#define BOOT_TARGET_DEVICES(func) \ func(USB, usb, 0) \ diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index 193782939481..42a25623c37b 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -90,8 +90,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 128
/* Address and size of Primary Environment Sector */ -#define CONFIG_ENV_SIZE 0x8000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + (4 << 20) - CONFIG_ENV_SIZE)
diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h index fe384ec84e78..e4a78fbddadd 100644 --- a/include/configs/qemu-mips64.h +++ b/include/configs/qemu-mips64.h @@ -90,8 +90,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 128
diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 424235e7774a..47fb18169324 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -107,7 +107,6 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void); /* * Environment */ -#define CONFIG_ENV_SIZE 0x2000
diff --git a/include/configs/qemu-riscv.h b/include/configs/qemu-riscv.h index fa9b9af93461..5fe9dcfc58f8 100644 --- a/include/configs/qemu-riscv.h +++ b/include/configs/qemu-riscv.h @@ -32,7 +32,6 @@ #define CONFIG_STANDALONE_LOAD_ADDR 0x80200000
/* Environment options */ -#define CONFIG_ENV_SIZE SZ_128K
#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ diff --git a/include/configs/qemu-x86.h b/include/configs/qemu-x86.h index c5574201dd68..49e307b43006 100644 --- a/include/configs/qemu-x86.h +++ b/include/configs/qemu-x86.h @@ -22,9 +22,6 @@ #include <config_distro_bootcmd.h> #include <configs/x86-common.h>
-#undef CONFIG_ENV_SIZE -#define CONFIG_ENV_SIZE SZ_256K - #define CONFIG_PREBOOT "pci enum"
#define CONFIG_SYS_MONITOR_LEN (1 << 20) diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index 0b16fb0f64ec..afa446f53a4b 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -36,10 +36,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE }
-#define CONFIG_ENV_SECT_SIZE 0x40000 -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - /* * SuperH Clock setting */ diff --git a/include/configs/r7780mp.h b/include/configs/r7780mp.h index 6ea7f38a176d..b562308db8bf 100644 --- a/include/configs/r7780mp.h +++ b/include/configs/r7780mp.h @@ -61,9 +61,6 @@ /* print 'E' for empty sector on flinfo */ #define CONFIG_SYS_FLASH_EMPTY_INFO
-#define CONFIG_ENV_SECT_SIZE (256 * 1024) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_SYS_FLASH_ERASE_TOUT 120000 #define CONFIG_SYS_FLASH_WRITE_TOUT 500
diff --git a/include/configs/rastaban.h b/include/configs/rastaban.h index c34b68a374f7..bd5e00e10cdf 100644 --- a/include/configs/rastaban.h +++ b/include/configs/rastaban.h @@ -46,7 +46,6 @@ #define CONFIG_FACTORYSET
/* Define own nand partitions */ -#define CONFIG_ENV_OFFSET_REDUND 0x2E0000 #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 3a763336ed17..b6c5cad43384 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -36,13 +36,9 @@ #define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024)
/* ENV setting */ -#define CONFIG_ENV_ADDR 0xC0000
/* Common ENV setting */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_SECT_SIZE (256 * 1024) -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE)
/* SF MTD */ #ifdef CONFIG_SPL_BUILD diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index 0f7a00f95782..520da5027ef2 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -52,8 +52,6 @@
/* ENV setting */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE)
#define CONFIG_EXTRA_ENV_SETTINGS \ "bootm_size=0x10000000\0" diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 77d2d5458a1f..c03bad811ba9 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -74,7 +74,6 @@ #define CONFIG_SYS_CBSIZE 1024
/* Environment */ -#define CONFIG_ENV_SIZE SZ_16K #define CONFIG_SYS_LOAD_ADDR 0x1000000
/* Shell */ diff --git a/include/configs/s32v234evb.h b/include/configs/s32v234evb.h index cc6d9206373c..53c94ed70e6f 100644 --- a/include/configs/s32v234evb.h +++ b/include/configs/s32v234evb.h @@ -178,9 +178,7 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* environment organization */ -#define CONFIG_ENV_SIZE (8 * 1024)
-#define CONFIG_ENV_OFFSET (12 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index be6f011ab058..20538df0252b 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -165,8 +165,6 @@ /* FLASH and environment organization */ #define CONFIG_MMC_DEFAULT_DEV 0 #define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ #define CONFIG_ENV_OVERWRITE
#define CONFIG_USE_ONENAND_BOARD_INIT diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 832032da1853..ec9abaf584ed 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -56,8 +56,6 @@ #define CONFIG_UBIBLOCK "9"
#define CONFIG_ENV_UBIFS_OPTION " rootflags=bulk_read,no_chk_data_crc " #define CONFIG_ENV_FLASHBOOT CONFIG_ENV_UBI_MTD CONFIG_ENV_UBIFS_OPTION \ diff --git a/include/configs/sagem_f@st1704.h b/include/configs/sagem_f@st1704.h index 5a526d9d8b32..e5bb4e50d123 100644 --- a/include/configs/sagem_f@st1704.h +++ b/include/configs/sagem_f@st1704.h @@ -6,4 +6,3 @@ #include <configs/bmips_common.h> #include <configs/bmips_bcm6338.h>
-#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/salvator-x.h b/include/configs/salvator-x.h index 1bf223491882..669602eb60eb 100644 --- a/include/configs/salvator-x.h +++ b/include/configs/salvator-x.h @@ -19,7 +19,6 @@ #define COUNTER_FREQUENCY 0xFE502A /* 16.66MHz from CPclk */
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2
diff --git a/include/configs/sam9x60ek.h b/include/configs/sam9x60ek.h index 5f89ae4a511a..3dda8696e4f7 100644 --- a/include/configs/sam9x60ek.h +++ b/include/configs/sam9x60ek.h @@ -73,7 +73,6 @@
#elif defined(CONFIG_NAND_BOOT) /* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_BOOTCOMMAND "nand read " \ "0x22000000 0x200000 0x600000; " \ "nand read 0x21000000 0x180000 0x20000; " \ diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 5d75021ed6b7..1c13055cdc05 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -37,8 +37,6 @@
/* turn on command-line edit/c/auto */
-#define CONFIG_ENV_SIZE 8192 - /* SPI - enable all SPI flash types for testing purposes */
#define CONFIG_I2C_EDID diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h index 1beff234db17..555b5ce68681 100644 --- a/include/configs/sansa_fuze_plus.h +++ b/include/configs/sansa_fuze_plus.h @@ -13,7 +13,6 @@ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
/* Environment */ -#define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OVERWRITE
/* Booting Linux */ diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index 01d480288578..9d6558483882 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -223,16 +223,7 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) - #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 - /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) - -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 #endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 6aa40caa7c3d..f4113e03c464 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -462,20 +462,6 @@ #define CONFIG_ETHPRIME "eTSEC0" #endif /* CONFIG_TSEC_ENET */
-/* - * Environment - */ -#define CONFIG_ENV_SIZE 0x2000 -#if CONFIG_SYS_TEXT_BASE == 0xfff00000 /* Boot from 64MB SODIMM */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x80000) -#define CONFIG_ENV_SECT_SIZE 0x80000 /* 512K(one sector) for env */ -#elif CONFIG_SYS_TEXT_BASE == 0xfffa0000 /* Boot from 8MB soldered flash */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ -#else -#warning undefined environment size/location. -#endif - #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index d1535b6facc7..011e5736e272 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -426,9 +426,6 @@ /* * Environment */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128k(one sector) for env */ -#define CONFIG_ENV_SIZE 0x2000
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/sc_sps_1.h b/include/configs/sc_sps_1.h index cc108920dc6a..8db2772d7580 100644 --- a/include/configs/sc_sps_1.h +++ b/include/configs/sc_sps_1.h @@ -19,11 +19,9 @@ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index 5df013b0b321..857e2e349e2b 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -27,7 +27,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_SEABOARD
diff --git a/include/configs/secomx6quq7.h b/include/configs/secomx6quq7.h index 2d219b2b5fe1..20acc4036348 100644 --- a/include/configs/secomx6quq7.h +++ b/include/configs/secomx6quq7.h @@ -77,10 +77,8 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
#if defined(CONFIG_ENV_IS_IN_MMC) - #define CONFIG_ENV_OFFSET (6 * 128 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_DYNAMIC_MMC_DEVNO #endif diff --git a/include/configs/sfr_nb4_ser.h b/include/configs/sfr_nb4_ser.h index 2aa5c6664325..529fc9495ef4 100644 --- a/include/configs/sfr_nb4_ser.h +++ b/include/configs/sfr_nb4_ser.h @@ -8,4 +8,3 @@
-#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index 02c5143491a6..3a1f1ac288c1 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -62,11 +62,7 @@ #define CONFIG_SH_MMCIF_CLK 48000000
/* ENV setting */ -#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_ADDR (0x00080000) -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) #define CONFIG_ENV_OVERWRITE 1 -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) #define CONFIG_EXTRA_ENV_SETTINGS \ "netboot=bootp; bootm\0"
diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index ae76254589b3..5253a5be3221 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -62,11 +62,7 @@ #define CONFIG_SH_MMCIF_CLK 48000000
diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index 04b6879644b7..d46aaad44107 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -74,11 +74,7 @@ #define SH7757LCR_PCIEBRG_SIZE (96 * 1024)
diff --git a/include/configs/sh7763rdp.h b/include/configs/sh7763rdp.h index 620cf5af5009..2e79fea053a8 100644 --- a/include/configs/sh7763rdp.h +++ b/include/configs/sh7763rdp.h @@ -55,12 +55,7 @@ #define CONFIG_SYS_FLASH_UNLOCK_TOUT (3 * 1000) /* Use hardware flash sectors protection instead of U-Boot software protection */ #undef CONFIG_SYS_DIRECT_FLASH_TFTP -#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + (1 * CONFIG_ENV_SECT_SIZE)) /* Offset of env Flash sector relative to CONFIG_SYS_FLASH_BASE */ -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR - CONFIG_SYS_FLASH_BASE) -#define CONFIG_ENV_ADDR_REDUND (CONFIG_SYS_FLASH_BASE + (2 * CONFIG_ENV_SECT_SIZE))
/* Clock */ #define CONFIG_SYS_CLK_FREQ 66666666 diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index deec71734dc7..ed5e284077db 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -32,16 +32,10 @@ /* * Environment variables configurations */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#endif /* * max 4k env size is enough, but in case of nand * it has to be rounded to sector size */ -#define CONFIG_ENV_SIZE 0x20000 /* 128k */ -#define CONFIG_ENV_ADDR 0x80000 -#define CONFIG_ENV_OFFSET 0x80000 /* env starts here */ /* * Environment is right behind U-Boot in flash. Make sure U-Boot * doesn't grow into the environment area. diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index ea6cc38fc139..09e4836316ad 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -172,10 +172,6 @@ * 0xE0000 - 0x442000 : Linux Kernel * 0x442000 - 0x800000 : Userland */ -#if defined(CONFIG_SPI_BOOT) -# define CONFIG_ENV_OFFSET (892 << 10) /* 892 KiB in */ -# define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ -#endif /* SPI support */
#define CONFIG_BOOTP_DEFAULT #define CONFIG_BOOTP_DNS2 diff --git a/include/configs/sifive-fu540.h b/include/configs/sifive-fu540.h index 736ceb1f4855..2756ed5a77f3 100644 --- a/include/configs/sifive-fu540.h +++ b/include/configs/sifive-fu540.h @@ -23,7 +23,6 @@ #define CONFIG_STANDALONE_LOAD_ADDR 0x80200000
#define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ diff --git a/include/configs/sksimx6.h b/include/configs/sksimx6.h index b2ca7b1a7257..63c168ccdd19 100644 --- a/include/configs/sksimx6.h +++ b/include/configs/sksimx6.h @@ -53,11 +53,7 @@ #define CONFIG_SYS_FSL_USDHC_NUM 1
/* Environment organization */ -#define CONFIG_ENV_SIZE (16 * 1024) -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ - CONFIG_ENV_SIZE)
/* Default environment */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index c1a43a5e550a..624ad3b7688e 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -144,7 +144,6 @@ /* * The NAND Flash partitions: */ -#define CONFIG_ENV_OFFSET_REDUND (0x180000) #define CONFIG_ENV_RANGE (SZ_512K)
/* diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index 1d09792ce996..dbdb9a4a07a5 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -139,9 +139,6 @@ /*----------------------------------------------------------------------- * Boot configuration */ -#define CONFIG_ENV_SIZE (128 << 10) /* 128KiB, 0x20000 */ -#define CONFIG_ENV_ADDR (256 << 10) /* 256KiB, 0x40000 */ -#define CONFIG_ENV_OFFSET (256 << 10) /* 256KiB, 0x40000 */
#define CONFIG_USE_ONENAND_BOARD_INIT #define CONFIG_SAMSUNG_ONENAND 1 diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 68af0ef450fc..13e81ee2ffed 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -65,10 +65,8 @@ #define CONFIG_MIU_2BIT_INTERLEAVED
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index baa214399ff9..05bfef75c0df 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -157,21 +157,13 @@ unsigned int cm_get_qspi_controller_clk_hz(void); /* * U-Boot environment */ -#if !defined(CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE (8 * 1024) -#endif
/* Environment for SDMMC boot */ -#if defined(CONFIG_ENV_IS_IN_MMC) && !defined(CONFIG_ENV_OFFSET) +#if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 0 /* device 0 */ -#define CONFIG_ENV_OFFSET (34 * 512) /* just after the GPT */ #endif
/* Environment for QSPI boot */ -#if defined(CONFIG_ENV_IS_IN_SPI_FLASH) && !defined(CONFIG_ENV_OFFSET) -#define CONFIG_ENV_OFFSET 0x00100000 -#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#endif
/* * SPL diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index e1a48715fb0d..ccaa050ae597 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -28,10 +28,6 @@ #define CONFIG_SYS_BOOTCOUNT_BE
/* Environment setting for SPI flash */ -#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_SIZE (16 * 1024) -#define CONFIG_ENV_OFFSET 0x000e0000 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE)
/* The rest of the configuration is shared */ #include <configs/socfpga_common.h> diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h index 8e6ecf4bed34..e8e66fa4ae67 100644 --- a/include/configs/socfpga_stratix10_socdk.h +++ b/include/configs/socfpga_stratix10_socdk.h @@ -48,9 +48,7 @@ /* * U-Boot environment configurations */ -#define CONFIG_ENV_SIZE 0x1000 #define CONFIG_SYS_MMC_ENV_DEV 0 /* device 0 */ -#define CONFIG_ENV_OFFSET 512 /* just after the MBR */
/* * QSPI support @@ -62,13 +60,6 @@ /* Flash device info */
/*#define CONFIG_ENV_IS_IN_SPI_FLASH*/ -#ifdef CONFIG_ENV_IS_IN_SPI_FLASH -#undef CONFIG_ENV_OFFSET -#undef CONFIG_ENV_SIZE -#define CONFIG_ENV_OFFSET 0x710000 -#define CONFIG_ENV_SIZE (4 * 1024) -#define CONFIG_ENV_SECT_SIZE (4 * 1024) -#endif /* CONFIG_ENV_IS_IN_SPI_FLASH */
#ifndef CONFIG_SPL_BUILD #define CONFIG_MTD_DEVICE diff --git a/include/configs/socfpga_vining_fpga.h b/include/configs/socfpga_vining_fpga.h index 5cc12419a692..8b97cd93a78a 100644 --- a/include/configs/socfpga_vining_fpga.h +++ b/include/configs/socfpga_vining_fpga.h @@ -195,11 +195,6 @@ "fi\0" \ "socfpga_legacy_reset_compat=1\0"
-#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_OFFSET 0x100000 -#define CONFIG_ENV_OFFSET_REDUND \ - (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE) - /* Support changing the prompt string */ #define CONFIG_CMDLINE_PS_SUPPORT
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index f5f3316b9030..4fe67dced850 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -187,11 +187,6 @@ /* * Environment */ -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - \ - CONFIG_ENV_SECT_SIZE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x4000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR - CONFIG_ENV_SECT_SIZE)
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/som-db5800-som-6867.h b/include/configs/som-db5800-som-6867.h index cfcc9c866d63..201f2c2ece57 100644 --- a/include/configs/som-db5800-som-6867.h +++ b/include/configs/som-db5800-som-6867.h @@ -21,7 +21,4 @@ #define VIDEO_IO_OFFSET 0 #define CONFIG_X86EMU_RAW_IO
-#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OFFSET 0x006ef000 - #endif /* __CONFIG_H */ diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index d21ff9771693..85e498dc6687 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -99,7 +99,6 @@ * Environment is in serial NOR flash */ #define CONFIG_SYS_MONITOR_LEN 0x00040000 -#define CONFIG_ENV_SECT_SIZE 0x00010000 #define CONFIG_FSMTDBLK "/dev/mtdblock3 "
#define CONFIG_BOOTCOMMAND "bootm 0xf8050000" @@ -109,21 +108,16 @@ * Environment is in parallel NOR flash */ #define CONFIG_SYS_MONITOR_LEN 0x00060000 -#define CONFIG_ENV_SECT_SIZE 0x00020000 #define CONFIG_FSMTDBLK "/dev/mtdblock3 "
#define CONFIG_BOOTCOMMAND "cp.b 0x50080000 0x1600000 " \ "0x4C0000; bootm 0x1600000" #endif - -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ - CONFIG_SYS_MONITOR_LEN) #elif defined(CONFIG_ENV_IS_IN_NAND) /* * Environment is in NAND */
-#define CONFIG_ENV_OFFSET 0x60000 #define CONFIG_ENV_RANGE 0x10000 #define CONFIG_FSMTDBLK "/dev/mtdblock7 "
@@ -146,7 +140,6 @@ "console=ttyAMA0,115200 $(othbootargs);" \ CONFIG_BOOTCOMMAND
-#define CONFIG_ENV_SIZE 0x02000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
/* Miscellaneous configurable options */ diff --git a/include/configs/stih410-b2260.h b/include/configs/stih410-b2260.h index b67efbb16830..a8a58f395068 100644 --- a/include/configs/stih410-b2260.h +++ b/include/configs/stih410-b2260.h @@ -39,9 +39,6 @@ "ramdisk_addr_r=0x48000000\0" \ BOOTENV
- -#define CONFIG_ENV_SIZE 0x4000 - /* Extra Commands */ #define CONFIG_CMD_ASKENV
diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index 31c17d081867..a8b3a173096f 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -20,10 +20,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 12 #define CONFIG_SYS_MAX_FLASH_BANKS 2
-#define CONFIG_ENV_OFFSET (256 << 10) -#define CONFIG_ENV_SECT_SIZE (128 << 10) -#define CONFIG_ENV_SIZE (8 << 10) - #define CONFIG_RED_LED 110 #define CONFIG_GREEN_LED 109
diff --git a/include/configs/stm32f429-evaluation.h b/include/configs/stm32f429-evaluation.h index a5390f874284..7a17222d7b81 100644 --- a/include/configs/stm32f429-evaluation.h +++ b/include/configs/stm32f429-evaluation.h @@ -20,10 +20,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 12 #define CONFIG_SYS_MAX_FLASH_BANKS 2
-#define CONFIG_ENV_OFFSET (256 << 10) -#define CONFIG_ENV_SECT_SIZE (128 << 10) -#define CONFIG_ENV_SIZE (8 << 10) - #define CONFIG_STM32_FLASH
#define CONFIG_SYS_HZ_CLOCK 1000000 /* Timer is clocked at 1MHz */ diff --git a/include/configs/stm32f469-discovery.h b/include/configs/stm32f469-discovery.h index 1c7efd13b835..463f1c4396d0 100644 --- a/include/configs/stm32f469-discovery.h +++ b/include/configs/stm32f469-discovery.h @@ -20,10 +20,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 12 #define CONFIG_SYS_MAX_FLASH_BANKS 2
#define CONFIG_SYS_HZ_CLOCK 1000000 /* Timer is clocked at 1MHz */ diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index cc26f83e7462..337b99977b80 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -24,8 +24,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 8 #define CONFIG_SYS_MAX_FLASH_BANKS 1
#define CONFIG_DW_GMAC_DEFAULT_DMA_PBL (8) diff --git a/include/configs/stm32h743-disco.h b/include/configs/stm32h743-disco.h index f110e2994c71..74c69eba39d3 100644 --- a/include/configs/stm32h743-disco.h +++ b/include/configs/stm32h743-disco.h @@ -18,8 +18,6 @@ #define CONFIG_SYS_LOAD_ADDR 0xD0400000 #define CONFIG_LOADADDR 0xD0400000
-#define CONFIG_ENV_SIZE (8 << 10) - #define CONFIG_SYS_HZ_CLOCK 1000000
#define CONFIG_CMDLINE_TAG diff --git a/include/configs/stm32h743-eval.h b/include/configs/stm32h743-eval.h index e3bf5b27e859..b7c84922ab84 100644 --- a/include/configs/stm32h743-eval.h +++ b/include/configs/stm32h743-eval.h @@ -18,8 +18,6 @@ #define CONFIG_SYS_LOAD_ADDR 0xD0400000 #define CONFIG_LOADADDR 0xD0400000
#define CONFIG_CMDLINE_TAG diff --git a/include/configs/stmark2.h b/include/configs/stmark2.h index 35966580a918..a08d9950bd87 100644 --- a/include/configs/stmark2.h +++ b/include/configs/stmark2.h @@ -139,9 +139,6 @@
#if defined(CONFIG_CF_SBF) #define CONFIG_ENV_IS_IN_SPI_FLASH 1 -#define CONFIG_ENV_OFFSET 0x40000 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x10000 #endif
#undef CONFIG_ENV_OVERWRITE diff --git a/include/configs/strider.h b/include/configs/strider.h index d270d8a2dd4f..ac9fce80cec3 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -384,15 +384,6 @@ void fpga_control_clear(unsigned int bus, int pin); /* * Environment */ -#if 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ - CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#else -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/stv0991.h b/include/configs/stv0991.h index e5262085fc75..81e1e49c928a 100644 --- a/include/configs/stv0991.h +++ b/include/configs/stv0991.h @@ -13,11 +13,6 @@ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define PHYS_SDRAM_1_SIZE 0x00198000
-#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -#define CONFIG_ENV_OFFSET 0x30000 -#define CONFIG_ENV_ADDR \ - (PHYS_SDRAM_1_SIZE - CONFIG_ENV_SIZE) #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 16 * 1024)
/* user interface */ diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index bf3750191281..5d087caf31e4 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -54,9 +54,7 @@ #define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 #define CONFIG_SYS_L3_SIZE (512 << 10) #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_ADDR + 32 * 1024) -#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) -#endif +#define SPL_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SPL_GD_ADDR + 12 * 1024) #define CONFIG_SPL_RELOC_MALLOC_SIZE (50 << 10) #define CONFIG_SPL_RELOC_STACK (CONFIG_SPL_GD_ADDR + 64 * 1024) diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 69819da492fd..a2bb1b55eb12 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -110,10 +110,6 @@
/* Redundant Environment */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_ENV_OFFSET 0x180000 -#define CONFIG_ENV_ADDR 0x180000 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ - 2 * CONFIG_SYS_ENV_SECT_SIZE)
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 7a54fe3e1e37..e95cd0087d3f 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -169,7 +169,6 @@ #define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) -#define CONFIG_ENV_ADDR CONFIG_ENV_OFFSET
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 diff --git a/include/configs/taurus.h b/include/configs/taurus.h index fdd1c5224b78..9990c9340a3d 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -108,7 +108,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x22000000
/* bootstrap in spi flash , u-boot + env + linux in nandflash */ -#define CONFIG_ENV_OFFSET_REDUND 0x180000
#ifndef CONFIG_SPL_BUILD #if defined(CONFIG_BOARD_AXM) diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 46d67a7fcfd0..b598fca1ecb3 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -75,8 +75,6 @@ /* Environment organization */ #define CONFIG_SYS_MMC_ENV_DEV 2 /* overwritten on SD boot */ #define CONFIG_SYS_MMC_ENV_PART 1 /* overwritten on SD boot */ -#define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_OFFSET (384 * 1024) #define CONFIG_ENV_OVERWRITE
#define CONFIG_BOARD_SIZE_LIMIT 392192 /* (CONFIG_ENV_OFFSET - 1024) */ diff --git a/include/configs/tec-ng.h b/include/configs/tec-ng.h index b637832a5ee7..1047372105e2 100644 --- a/include/configs/tec-ng.h +++ b/include/configs/tec-ng.h @@ -17,7 +17,6 @@ #define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE
diff --git a/include/configs/tec.h b/include/configs/tec.h index 907c8d5e2301..aa9665eab59a 100644 --- a/include/configs/tec.h +++ b/include/configs/tec.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* Environment in NAND, aligned to start of last sector */ -#define CONFIG_ENV_OFFSET (SZ_512M - SZ_128K) /* 128K sectors */
diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 84f671d00c37..b4da1f8428ca 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -25,7 +25,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */
/* Environment */ -#define CONFIG_ENV_SIZE 0x2000 /* Total Size Environment */
/* * NS16550 Configuration diff --git a/include/configs/theadorable-x86-common.h b/include/configs/theadorable-x86-common.h index 2d7be7d5b96e..0a1261fa2017 100644 --- a/include/configs/theadorable-x86-common.h +++ b/include/configs/theadorable-x86-common.h @@ -23,12 +23,6 @@ #define CONFIG_BMP_16BPP
/* Environment settings */ -#undef CONFIG_ENV_SIZE -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OFFSET 0x006ec000 -#define CONFIG_ENV_OFFSET_REDUND \ - (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
#undef CONFIG_BOOTCOMMAND #undef CONFIG_EXTRA_ENV_SETTINGS diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 45cd7e2b83ac..6d42ec1aa194 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -40,9 +40,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 3
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ -#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ -#define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */ #define CONFIG_ENV_OVERWRITE
#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */ diff --git a/include/configs/thuban.h b/include/configs/thuban.h index 954b063e293a..d909be9b019c 100644 --- a/include/configs/thuban.h +++ b/include/configs/thuban.h @@ -39,7 +39,6 @@ #define CONFIG_FACTORYSET
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/thunderx_88xx.h b/include/configs/thunderx_88xx.h index 619571d45ba6..dac7e4ad9594 100644 --- a/include/configs/thunderx_88xx.h +++ b/include/configs/thunderx_88xx.h @@ -61,7 +61,6 @@ "fdt_high=0x9fffffff\0"
/* Do not preserve environment */ -#define CONFIG_ENV_SIZE 0x1000
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index fc5608b3fd47..1d3b2a392237 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -12,7 +12,6 @@ #include <configs/ti_armv7_omap.h> #include <asm/arch/omap.h>
-#define CONFIG_ENV_SIZE 0x2000 #define CONFIG_MACH_TYPE MACH_TYPE_TI8168EVM
#define CONFIG_EXTRA_ENV_SETTINGS \ @@ -84,8 +83,6 @@ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 -#define CONFIG_ENV_OFFSET 0x001c0000 -#define CONFIG_ENV_OFFSET_REDUND 0x001e0000 #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE
/* SPL */ diff --git a/include/configs/titanium.h b/include/configs/titanium.h index 64ec06da8599..d6ab5e4393ee 100644 --- a/include/configs/titanium.h +++ b/include/configs/titanium.h @@ -145,16 +145,10 @@ /* DMA stuff, needed for GPMI/MXS NAND support */
#endif /* CONFIG_CMD_NAND */ diff --git a/include/configs/topic_miami.h b/include/configs/topic_miami.h index b98656dd4c17..73fdfae4610c 100644 --- a/include/configs/topic_miami.h +++ b/include/configs/topic_miami.h @@ -15,10 +15,6 @@ #include "zynq-common.h"
/* Fixup settings */ -#undef CONFIG_ENV_SIZE -#define CONFIG_ENV_SIZE 0x8000 -#undef CONFIG_ENV_OFFSET -#define CONFIG_ENV_OFFSET 0x80000
/* SPL settings */ #undef CONFIG_SPL_ETH_SUPPORT diff --git a/include/configs/tplink_wdr4300.h b/include/configs/tplink_wdr4300.h index 436715824b23..8f13744c322f 100644 --- a/include/configs/tplink_wdr4300.h +++ b/include/configs/tplink_wdr4300.h @@ -34,8 +34,6 @@ #define CONFIG_BOOTCOMMAND \ "dhcp 192.168.1.1:wdr4300.fit && bootm $loadaddr"
-#define CONFIG_ENV_SIZE 0x10000 - /* * Command */ diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 3c1d629d251f..1ea6332878fe 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -68,7 +68,6 @@
#define CONFIG_ARP_TIMEOUT 200UL
-#define CONFIG_ENV_SIZE (SZ_8K) /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * SZ_1M)
@@ -78,7 +77,6 @@ #define TQMA6_UBOOT_SECTOR_START 0x2 #define TQMA6_UBOOT_SECTOR_COUNT 0x7fe
-#define CONFIG_ENV_OFFSET SZ_1M #define CONFIG_SYS_MMC_ENV_DEV 0
#define TQMA6_FDT_OFFSET (2 * SZ_1M) @@ -148,11 +146,6 @@ #define TQMA6_UBOOT_SIZE (TQMA6_UBOOT_SECTOR_SIZE * \ TQMA6_UBOOT_SECTOR_COUNT)
-#define CONFIG_ENV_OFFSET (TQMA6_UBOOT_SIZE) -#define CONFIG_ENV_SECT_SIZE TQMA6_SPI_FLASH_SECTOR_SIZE -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ - CONFIG_ENV_SECT_SIZE) - #define TQMA6_FDT_OFFSET (CONFIG_ENV_OFFSET_REDUND + \ CONFIG_ENV_SECT_SIZE) #define TQMA6_FDT_SECT_SIZE (TQMA6_SPI_FLASH_SECTOR_SIZE) diff --git a/include/configs/trats.h b/include/configs/trats.h index af8e8ce3b6cc..37fadc52102a 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -49,8 +49,6 @@ #define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 9c6b2bbc8d60..8b71c2575735 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -44,8 +44,6 @@ #define CONFIG_SYS_MONITOR_BASE 0x00000000
diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 2106f4e5b043..1e4459747d54 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -78,7 +78,6 @@
/* environment placement (for NAND), is different for FLASHCARD but does not * harm there */ -#define CONFIG_ENV_OFFSET_REDUND 0x2A0000 /* redundant env start */ #define CONFIG_ENV_RANGE (384 << 10) /* allow badblocks in env */
/* the loadaddr is the same as CONFIG_SYS_LOAD_ADDR, unfortunately the defiend diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h index 93db175288c1..b914e444b6e7 100644 --- a/include/configs/trimslice.h +++ b/include/configs/trimslice.h @@ -23,9 +23,7 @@ /* SPI */
/* Environment in SPI */ -#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE /* 1MiB flash, environment located as high as possible */ -#define CONFIG_ENV_OFFSET (SZ_1M - CONFIG_ENV_SIZE)
diff --git a/include/configs/ts4600.h b/include/configs/ts4600.h index a107e96530ec..6aab8a06a963 100644 --- a/include/configs/ts4600.h +++ b/include/configs/ts4600.h @@ -21,11 +21,9 @@ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
/* Environment */ -#define CONFIG_ENV_SIZE (8 * 1024)
/* Environment is in MMC */ #if defined(CONFIG_CMD_MMC) && defined(CONFIG_ENV_IS_IN_MMC) -#define CONFIG_ENV_OFFSET (256 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 #endif
diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index 4e274bd4141d..bd50d3b19c32 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -135,8 +135,6 @@ * Environment organization */
-#define CONFIG_ENV_OFFSET (6 * 64 * 1024) -#define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
#endif diff --git a/include/configs/turris_mox.h b/include/configs/turris_mox.h index 16a49c766f28..9409344338e1 100644 --- a/include/configs/turris_mox.h +++ b/include/configs/turris_mox.h @@ -62,9 +62,6 @@ #define CONFIG_SYS_I2C_SLAVE 0x0
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_OFFSET 0x180000 /* as Marvell U-Boot version */ -#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ -#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */
/* * Ethernet Driver configuration diff --git a/include/configs/turris_omnia.h b/include/configs/turris_omnia.h index abe1e99acda5..0b55c14d8bff 100644 --- a/include/configs/turris_omnia.h +++ b/include/configs/turris_omnia.h @@ -22,9 +22,6 @@ #define CONFIG_EHCI_IS_TDI
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ -#define CONFIG_ENV_OFFSET ((1 << 20) - CONFIG_ENV_SIZE) -#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB */
diff --git a/include/configs/udoo.h b/include/configs/udoo.h index 3378b4a601c4..bf9106e239fe 100644 --- a/include/configs/udoo.h +++ b/include/configs/udoo.h @@ -87,9 +87,7 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_SIZE (8 * 1024)
#endif /* __CONFIG_H * */ diff --git a/include/configs/udoo_neo.h b/include/configs/udoo_neo.h index 6ba4270b72db..f4a2837b3913 100644 --- a/include/configs/udoo_neo.h +++ b/include/configs/udoo_neo.h @@ -75,8 +75,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_OFFSET (8 * SZ_64K) -#define CONFIG_ENV_SIZE SZ_8K
#define CONFIG_IMX_THERMAL
diff --git a/include/configs/ulcb.h b/include/configs/ulcb.h index 6f2a0cc56dce..1d99dcaba666 100644 --- a/include/configs/ulcb.h +++ b/include/configs/ulcb.h @@ -19,7 +19,6 @@ #define COUNTER_FREQUENCY 0xFE502A /* 16.66MHz from CPclk */
diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 68568f412245..29866668c491 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -72,10 +72,6 @@ /* Boot Argument Buffer Size */ #define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE)
-#define CONFIG_ENV_OFFSET 0x100000 -#define CONFIG_ENV_SIZE 0x2000 -/* #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) */ - #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 1
diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index 128f02db66fa..91c8b478b3af 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -15,8 +15,6 @@ #include <asm/arch/imx-regs.h>
/* U-Boot environment */ -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) -#define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
/* U-Boot general configurations */ diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h index 6ff68cd6a085..e69456ef7ce2 100644 --- a/include/configs/vcoreiii.h +++ b/include/configs/vcoreiii.h @@ -25,15 +25,6 @@
#define CONFIG_BOARD_TYPES
-#if defined(CONFIG_ENV_IS_IN_SPI_FLASH) && !defined(CONFIG_ENV_OFFSET) -#define CONFIG_ENV_OFFSET (1024 * 1024) -#define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_SECT_SIZE (256 * 1024) - -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE) - -#endif - #define CONFIG_SYS_SDRAM_BASE 0x80000000 #if defined(CONFIG_DDRTYPE_H5TQ1G63BFA) || defined(CONFIG_DDRTYPE_MT47H128M8HQ) #define CONFIG_SYS_SDRAM_SIZE (128 * SZ_1M) diff --git a/include/configs/vct.h b/include/configs/vct.h index 890f347b4395..284d2682593d 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -128,12 +128,7 @@ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */
#ifdef CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_SECT_SIZE 0x10000 /* size of one complete sector */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ - /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) #endif /* CONFIG_ENV_IS_IN_FLASH */ #endif /* CONFIG_VCT_NOR */
@@ -141,8 +136,6 @@ #define CONFIG_USE_ONENAND_BOARD_INIT #define CONFIG_SYS_ONENAND_BASE 0x00000000 /* this is not real address */ #define CONFIG_SYS_FLASH_BASE 0x00000000 -#define CONFIG_ENV_ADDR (128 << 10) /* after compr. U-Boot image */ -#define CONFIG_ENV_SIZE (128 << 10) /* erase size */ #endif /* CONFIG_VCT_ONENAND */
/* diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 2608b2b23220..a31e6f4abe35 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -195,13 +195,7 @@ /* * Environment */ -#define CONFIG_ENV_ADDR \ - (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ -#define CONFIG_ENV_SIZE 0x4000 /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND \ - (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE)
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/include/configs/venice2.h b/include/configs/venice2.h index 8ad872d94f37..b62a43054a21 100644 --- a/include/configs/venice2.h +++ b/include/configs/venice2.h @@ -21,7 +21,6 @@ /* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* SPI */ #define CONFIG_SPI_FLASH_SIZE (4 << 20) diff --git a/include/configs/ventana.h b/include/configs/ventana.h index 09f90db1f515..2c2d66cdc099 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -20,7 +20,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_VENTANA
diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index b2c14f9e10f6..9a9cec414c87 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -201,15 +201,11 @@ #define CONFIG_SYS_MAX_FLASH_SECT 259 /* Store environment at top of flash in the same location as blank.img */ /* in the Juno firmware. */ -#define CONFIG_ENV_ADDR 0x0BFC0000 -#define CONFIG_ENV_SECT_SIZE 0x00010000 #else #define CONFIG_SYS_FLASH_BASE 0x0C000000 /* 256 x 256KiB sectors */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* Store environment at top of flash */ -#define CONFIG_ENV_ADDR 0x0FFC0000 -#define CONFIG_ENV_SECT_SIZE 0x00040000 #endif
#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT @@ -217,6 +213,5 @@
#define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */ #define FLASH_MAX_SECTOR_SIZE 0x00040000 -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE
#endif /* __VEXPRESS_AEMV8A_H */ diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index 47ea89df6607..7f215a670771 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -226,21 +226,15 @@ #define FLASH_MAX_SECTOR_SIZE 0x00040000 /* 256 KB sectors */
/* Room required on the stack for the environment data */ -#define CONFIG_ENV_SIZE FLASH_MAX_SECTOR_SIZE
/* * Amount of flash used for environment: * We don't know which end has the small erase blocks so we use the penultimate * sector location for the environment */ -#define CONFIG_ENV_SECT_SIZE FLASH_MAX_SECTOR_SIZE #define CONFIG_ENV_OVERWRITE 1
/* Store environment at top of flash */ -#define CONFIG_ENV_OFFSET (PHYS_FLASH_SIZE - \ - (2 * CONFIG_ENV_SECT_SIZE)) -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE1 + \ - CONFIG_ENV_OFFSET) #define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */ #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE0, \ CONFIG_SYS_FLASH_BASE1 } diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index ba85bc91e74d..3ab323194387 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -187,17 +187,11 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
#ifdef CONFIG_ENV_IS_IN_MMC -#define CONFIG_ENV_SIZE (8 * 1024) - -#define CONFIG_ENV_OFFSET (12 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 #endif
#ifdef CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SIZE (64 * 2048) -#define CONFIG_ENV_SECT_SIZE (64 * 2048) #define CONFIG_ENV_RANGE (512 * 1024) -#define CONFIG_ENV_OFFSET 0x180000 #endif
#endif diff --git a/include/configs/vinco.h b/include/configs/vinco.h index eebb3f7ca789..a709502d4373 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -63,11 +63,6 @@ #ifdef CONFIG_SPI_BOOT /* bootstrap + u-boot + env + linux in serial flash */ /* Use our own mapping for the VInCo platform */ -#undef CONFIG_ENV_OFFSET -#undef CONFIG_ENV_SIZE - -#define CONFIG_ENV_OFFSET 0x10000 -#define CONFIG_ENV_SIZE 0x10000
/* Update the bootcommand according to our mapping for the VInCo platform */ #undef CONFIG_BOOTCOMMAND diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index 6672930fb39c..54c8c2f62efc 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -85,10 +85,6 @@
#define CONFIG_IMX6_PWM_PER_CLK 66000000
-#define CONFIG_ENV_OFFSET (8 * SZ_64K) -#define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_OFFSET_REDUND (9 * SZ_64K) - #ifdef CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC4 eMMC */ /* 0=user, 1=boot0, 2=boot1, * 4..7=general0..3. */ diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 74e8d3925bf2..f40c9002e590 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -199,16 +199,7 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0xc0000) - #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 - /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) - -#else - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 #endif
#define CONFIG_LOADS_ECHO /* echo on for serial download */ diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index a0a78eab27bf..a65d23bbe80a 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -124,9 +124,7 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
-#define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
#endif /* __CONFIG_H * */ diff --git a/include/configs/warp.h b/include/configs/warp.h index 41fd6c759eba..68361a6199ee 100644 --- a/include/configs/warp.h +++ b/include/configs/warp.h @@ -41,8 +41,6 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
-#define CONFIG_ENV_OFFSET (6 * SZ_64K) -#define CONFIG_ENV_SIZE SZ_8K #define CONFIG_SYS_MMC_ENV_DEV 0
/* VDD voltage 1.65 - 1.95 */ diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 73541fe17608..9a82581c5f3a 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -130,9 +130,7 @@ #define CONFIG_SYS_I2C_SPEED 100000
-#define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_SYS_FSL_USDHC_NUM 1
#define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/wb45n.h b/include/configs/wb45n.h index 43de2e111933..36060975c10e 100644 --- a/include/configs/wb45n.h +++ b/include/configs/wb45n.h @@ -66,9 +66,6 @@
#ifdef CONFIG_SYS_USE_NANDFLASH /* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_OFFSET 0xa0000 -#define CONFIG_ENV_OFFSET_REDUND 0xc0000 -#define CONFIG_ENV_SIZE 0x20000 /* 1 block = 128 kB */
#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xe0000 0x280000; " \ "run _mtd; bootm" diff --git a/include/configs/wb50n.h b/include/configs/wb50n.h index 6e471f62e6be..ca1619f25116 100644 --- a/include/configs/wb50n.h +++ b/include/configs/wb50n.h @@ -72,7 +72,6 @@ "autostart=no\0"
/* bootstrap + u-boot + env in nandflash */ -#define CONFIG_ENV_OFFSET_REDUND 0xC0000 #define CONFIG_BOOTCOMMAND \ "nand read 0x22000000 0x000e0000 0x500000; " \ "bootm" diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index d7c4a6f1f4d8..194e43ecc612 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -119,14 +119,7 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN (512 * 1024)
-#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE - /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) - -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ - CONFIG_SYS_MONITOR_LEN)
/* * CFI FLASH driver setup diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index e260a637d6fd..f73946b935a4 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -116,11 +116,6 @@ * Environment */
-#define CONFIG_ENV_SIZE 0x00020000 -#define CONFIG_ENV_OFFSET 0x00100000 -#define CONFIG_ENV_OFFSET_REDUND 0x00120000 -#define CONFIG_ENV_ADDR 0x80000100 - /* * Boot Linux */ diff --git a/include/configs/x530.h b/include/configs/x530.h index 2269d1ed8cd0..b4e986ebccdf 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -59,10 +59,6 @@ #define CONFIG_EHCI_IS_TDI
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ -#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ -#define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */ -#define CONFIG_ENV_ADDR CONFIG_ENV_OFFSET
#define CONFIG_PHY_MARVELL /* there is a marvell phy */ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */ diff --git a/include/configs/x600.h b/include/configs/x600.h index f6779213a896..63092b24a53a 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -87,12 +87,6 @@ /* * U-Boot Environment placing definitions. */ -#define CONFIG_ENV_SECT_SIZE 0x00010000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ - CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SIZE 0x02000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + \ - CONFIG_ENV_SECT_SIZE)
/* Miscellaneous configurable options */ #define CONFIG_BOOT_PARAMS_ADDR 0x00000100 diff --git a/include/configs/x86-chromebook.h b/include/configs/x86-chromebook.h index 5a33223b7ddf..0efc7156a6dd 100644 --- a/include/configs/x86-chromebook.h +++ b/include/configs/x86-chromebook.h @@ -28,11 +28,6 @@ #define VIDEO_IO_OFFSET 0 #define CONFIG_X86EMU_RAW_IO
-#undef CONFIG_ENV_SIZE -#define CONFIG_ENV_SIZE 0x1000 -#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OFFSET 0x003f8000 - #define CONFIG_STD_DEVICES_SETTINGS "stdin=usbkbd,i8042-kbd,serial\0" \ "stdout=vidconsole,serial\0" \ "stderr=vidconsole,serial\0" diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 54214f99e9a6..329b270467e2 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -79,7 +79,6 @@ /*----------------------------------------------------------------------- * Environment configuration */ -#define CONFIG_ENV_SIZE 0x01000
/*----------------------------------------------------------------------- * PCI configuration diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h index afc4b82fd80f..51efab1d2c1a 100644 --- a/include/configs/xfi3.h +++ b/include/configs/xfi3.h @@ -13,7 +13,6 @@ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
/* Booting Linux */ diff --git a/include/configs/xilinx_zynqmp_r5.h b/include/configs/xilinx_zynqmp_r5.h index 4eb3312e2d2b..38d952d0c0cc 100644 --- a/include/configs/xilinx_zynqmp_r5.h +++ b/include/configs/xilinx_zynqmp_r5.h @@ -16,8 +16,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400}
-# define CONFIG_ENV_SIZE (128 << 10) - /* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index 23f038961574..634ee4240993 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -485,9 +485,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Environment Configuration */ -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128k (one sector) for env */ -#define CONFIG_ENV_SIZE 0x8000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN)
/* * Flash memory map: diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index 21e91ee1a4dd..0186aaa10277 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -285,9 +285,6 @@ /* * Environment Configuration */ -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128k (one sector) for env */ -#define CONFIG_ENV_SIZE 0x8000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - (256 * 1024))
/* * Flash memory map: diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index 73e1fa313f88..5e027bebcabe 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -335,9 +335,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Environment Configuration */ -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128k (one sector) for env */ -#define CONFIG_ENV_SIZE 0x8000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - (256 * 1024))
/* * Flash memory map: diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index e5a41abd4b52..611089cbb935 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -333,9 +333,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Environment Configuration */ -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128k (one sector) for env */ -#define CONFIG_ENV_SIZE 0x8000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - (256 * 1024))
/* * Flash memory map: diff --git a/include/configs/xpress.h b/include/configs/xpress.h index 4cbf8aa5261d..dbdd812506b5 100644 --- a/include/configs/xpress.h +++ b/include/configs/xpress.h @@ -51,8 +51,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment is in stored in the eMMC boot partition */ -#define CONFIG_ENV_SIZE (16 << 10) -#define CONFIG_ENV_OFFSET (512 << 10) #define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC2 */ #define CONFIG_SYS_MMC_ENV_PART 1 /* boot parition */ #define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC2 */ diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index 2f20273572d2..8b73900130d7 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -220,8 +220,6 @@ * Put environment in top block (64kB) * Another option would be to put env. in 2nd param block offs 8KB, size 8KB */ -#define CONFIG_ENV_OFFSET (CONFIG_SYS_FLASH_SIZE - CONFIG_SYS_FLASH_SECT_SZ) -#define CONFIG_ENV_SIZE CONFIG_SYS_FLASH_SECT_SZ
/* print 'E' for empty sector on flinfo */ #define CONFIG_SYS_FLASH_EMPTY_INFO diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index 9d683768f4cf..a8c6f0be10d4 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -85,10 +85,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 256
-#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x00040000) -#define CONFIG_ENV_SECT_SIZE (128 * 1024) -#define CONFIG_ENV_SIZE (128 * 1024) - /* * CFI FLASH driver setup */ diff --git a/include/env_internal.h b/include/env_internal.h index b8158c0e0bc5..90a4df8a7273 100644 --- a/include/env_internal.h +++ b/include/env_internal.h @@ -30,26 +30,6 @@ *************************************************************************/
#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_OFFSET -# define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR - CONFIG_SYS_FLASH_BASE) -# endif -# if !defined(CONFIG_ENV_ADDR_REDUND) && defined(CONFIG_ENV_OFFSET_REDUND) -# define CONFIG_ENV_ADDR_REDUND \ - (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET_REDUND) -# endif -# if defined(CONFIG_ENV_SECT_SIZE) || defined(CONFIG_ENV_SIZE) -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# else -# error "Both CONFIG_ENV_SECT_SIZE and CONFIG_ENV_SIZE undefined" -# endif # if defined(CONFIG_ENV_ADDR_REDUND) && \ ((CONFIG_ENV_ADDR >= CONFIG_SYS_MONITOR_BASE) && \ (CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SIZE) <= \ @@ -75,41 +55,9 @@ # endif extern unsigned long nand_env_oob_offset; # define CONFIG_ENV_OFFSET nand_env_oob_offset -# else -# ifndef CONFIG_ENV_OFFSET -# error "Need to define CONFIG_ENV_OFFSET when using CONFIG_ENV_IS_IN_NAND" -# endif # endif /* CONFIG_ENV_OFFSET_OOB */ -# ifndef CONFIG_ENV_SIZE -# error "Need to define CONFIG_ENV_SIZE when using CONFIG_ENV_IS_IN_NAND" -# endif #endif /* CONFIG_ENV_IS_IN_NAND */
-#if defined(CONFIG_ENV_IS_IN_UBI) -# ifndef CONFIG_ENV_UBI_PART -# error "Need to define CONFIG_ENV_UBI_PART when using CONFIG_ENV_IS_IN_UBI" -# endif -# ifndef CONFIG_ENV_UBI_VOLUME -# error "Need to define CONFIG_ENV_UBI_VOLUME when using CONFIG_ENV_IS_IN_UBI" -# endif -# ifndef CONFIG_ENV_SIZE -# error "Need to define CONFIG_ENV_SIZE when using CONFIG_ENV_IS_IN_UBI" -# endif -# ifndef CONFIG_CMD_UBI -# error "Need to define CONFIG_CMD_UBI when using CONFIG_ENV_IS_IN_UBI" -# endif -#endif /* CONFIG_ENV_IS_IN_UBI */ - -/* Embedded env is only supported for some flash types */ -#ifdef CONFIG_ENV_IS_EMBEDDED -# if !defined(CONFIG_ENV_IS_IN_FLASH) && \ - !defined(CONFIG_ENV_IS_IN_NAND) && \ - !defined(CONFIG_ENV_IS_IN_ONENAND) && \ - !defined(CONFIG_ENV_IS_IN_SPI_FLASH) -# error "CONFIG_ENV_IS_EMBEDDED not supported for your flash type" -# endif -#endif - /* * For the flash types where embedded env is supported, but it cannot be * calculated automatically (i.e. NAND), take the board opt-in. diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d73e433cffb1..284fb62e54c1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -426,9 +426,7 @@ CONFIG_ENABLE_MMU CONFIG_ENABLE_MUST_CHECK CONFIG_ENABLE_WARN_DEPRECATED CONFIG_ENV_ACCESS_IGNORE_FORCE -CONFIG_ENV_ADDR CONFIG_ENV_ADDR_FLEX -CONFIG_ENV_ADDR_REDUND CONFIG_ENV_BASE CONFIG_ENV_CALLBACK_LIST_DEFAULT CONFIG_ENV_CALLBACK_LIST_STATIC @@ -443,7 +441,6 @@ CONFIG_ENV_IS_IN_ CONFIG_ENV_MAX_ENTRIES CONFIG_ENV_MIN_ENTRIES CONFIG_ENV_OFFSET_OOB -CONFIG_ENV_OFFSET_REDUND CONFIG_ENV_OVERWRITE CONFIG_ENV_RANGE CONFIG_ENV_RDADDR
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: Monday, November 18, 2019 7:02 PM To: u-boot@lists.denx.de Cc: Wolfgang Denk wd@denx.de; Joseph Hershberger joseph.hershberger@ni.com; Patrick Delaunay patrick.delaunay@st.com; uboot-stm32@st-md-mailman.stormreply.com Subject: [EXTERNAL] [PATCHv2 5/5] env: Finish migration of common ENV options
- In ARMv8 NXP Layerscape platforms we also need to make use of CONFIG_SYS_RELOC_GD_ENV_ADDR now, do so.
- On ENV_IS_IN_REMOTE, CONFIG_ENV_OFFSET is never used, drop the
define to 0.
- Add Kconfig entry for ENV_ADDR.
- Make ENV_ADDR / ENV_OFFSET depend on the env locations that use it.
- Add ENV_xxx_REDUND options that depend on their primary option and SYS_REDUNDAND_ENVIRONMENT
- On a number of PowerPC platforms, use SPL_ENV_ADDR not
CONFIG_ENV_ADDR for the pre-main-U-Boot environment location.
- On ENV_IS_IN_SPI_FLASH, check not for CONFIG_ENV_ADDR being set but rather it being non-zero, as it will now be zero by default.
- Rework the env_offset absolute in env/embedded.o to not use CONFIG_ENV_OFFSET as it was the only use of ENV_OFFSET within ENV_IS_IN_FLASH.
- Migrate all platforms.
Cc: Wolfgang Denk wd@denx.de Cc: Joe Hershberger joe.hershberger@ni.com Cc: Patrick Delaunay patrick.delaunay@st.com Cc: uboot-stm32@st-md-mailman.stormreply.com Signed-off-by: Tom Rini trini@konsulko.com
Wow! That was a big one!
Am 19.11.2019 um 02:02 schrieb Tom Rini:> - In ARMv8 NXP Layerscape platforms we also need to make use of
- On ENV_IS_IN_REMOTE, CONFIG_ENV_OFFSET is never used, drop the define to 0.
- On a number of PowerPC platforms, use SPL_ENV_ADDR not CONFIG_ENV_ADDR for the pre-main-U-Boot environment location.
<snip>
- U-Boot environment
Removing paragraphs like this one will break configs that haven't made it to a mainline defconfig. E.g. for socfpga_socrates_defconfig, you can chose for the ENV to be saved in SPI instead of MMC as the config supports booting from all sources.
How do we proceed with such things? I know that might be non-mainline, but I think throwing this info away is a step-back, not an improvement.
[And don't get me wrong: this doesn't affect my downstream boards, they don't save/load env due to secure boot reasons anyway.]
- SPL
- U-Boot environment configurations
- QSPI support
- Environment
- Environment is in serial NOR flash
- Environment is in parallel NOR flash
#elif defined(CONFIG_ENV_IS_IN_NAND) /*CONFIG_SYS_MONITOR_LEN)
- Environment is in NAND
- Environment
1024) */
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2
#include "tegra-common-post.h"
- NS16550 Configuration
/* Environment in NAND */ -#define CONFIG_ENV_OFFSET (16 << 20) -#define CONFIG_ENV_SECT_SIZE (128 << 10) -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + (512 << 10))
#else /* CONFIG_CMD_NAND */
/* Environment in MMC */ -#define CONFIG_ENV_SIZE (8 << 10) -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
- Command
does not
- harm there */
the defiend
- Environment organization
- Ethernet Driver configuration
CONFIG_ENV_SIZE) */
-#endif
(in ms) */
address */
- Environment
blank.img */
- Amount of flash used for environment:
- We don't know which end has the small erase blocks so we use the
penultimate
- sector location for the environment
#define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */ #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE0, \ CONFIG_SYS_FLASH_BASE1 }CONFIG_ENV_OFFSET)
platform */
- Environment
-#else
/* environment organization */ -#define CONFIG_ENV_SIZE SZ_8K
- CFI FLASH driver setup
- Environment
- Boot Linux
- U-Boot Environment placing definitions.
- Environment configuration
- PCI configuration
230400}
long dummy);
- Environment Configuration
- Flash memory map:
- Flash memory map:
long dummy);
- Flash memory map:
long dummy);
- Flash memory map:
- Put environment in top block (64kB)
- Another option would be to put env. in 2nd param block offs 8KB,
size 8KB
- For the flash types where embedded env is supported, but it
cannot be
- calculated automatically (i.e. NAND), take the board opt-in.
<snip>
So, I would be happy to see follow up series that add default values for locations for various SoCs. That would address the type of problem you're talking about, I believe.
I'd be even happier if someone looked at how Zephyr takes a dts file and generates a header and adapt that to a way for us to have some values be read from a dts* file and turned into a define we can use at build time (not just the OF_PLAT data). That would be a real nice step forward :)
Am 19.11.2019 um 22:52 schrieb Tom Rini:
<snip>
You mean adding lines like this to env/Kconfig at config ENV_OFFSET default 0x00100000 if ARCH_SOCFPGA && ENV_IS_IN_SPI_FLASH
Does that even work? And how well does it scale? I know it's a more fundamental problem, but in my opinion, scattering those defaults for every arch or board throughout all Kconfig files is not the best solution. Although I have to admit I don't have an idea of how to solve it better right now...
If we have that ENV information in the devicetree, we could just use it and dump the defines. No need to convert dts to defines beforehand. Only if dts cannot be used, we need something different. But in that case (mostly real small SPL, I guess), do we really enable the ENV loading code?
Anyway, thinking this over, I don't see a way out to keep the SPI env locations for socfpga when moving to Kconfig, so for socfpga:
Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
BTW: From looking at the include/configs/* changes, CONFIG_SYS_MMC_ENV_DEV could be moved to Kconfig, too...
<snip>
That does work, it's about what we do for other platforms today, it's not the best and doesn't scale well.
I mention the above mainly because there's a lot of other examples of this type of problem where yes, we can put a value in Kconfig and have a default but it's really not the best way forward.
Thanks!
Yes, there's a bunch of other changes that could/should be moved as well. I'm going down this particular rabbit hole so that I can take the MTD Makefile/Kconfig clean-up and verify that those changes are still size neutral. I want to circle back to the env stuff to change a few things soon including seeing about getting the rest of the easy migrations done.
Cc: Wolfgang Denk wd@denx.de Cc: Joe Hershberger joe.hershberger@ni.com Cc: Patrick Delaunay patrick.delaunay@st.com Cc: uboot-stm32@st-md-mailman.stormreply.com Signed-off-by: Tom Rini trini@konsulko.com Acked-by: Joe Hershberger joe.hershberger@ni.com Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
On 19.11.19 02:02, Tom Rini wrote:
The board file has a build time check to ensure that we do not have the redundant environment overwriting the factory data. However, using the symbol CONFIG_ENV_SIZE_REDUND isn't strictly needed as that is always the same as CONFIG_ENV_SIZE. Use CONFIG_ENV_SIZE instead so that we can later drop CONFIG_ENV_SIZE_REDUND.
Cc: Stefan Roese sr@denx.de Signed-off-by: Tom Rini trini@konsulko.com
Changes in v2:
- As pointed out by Stefan's review, I should address the usage of ENV_SIZE_REDUND here first and remove it second.
board/gardena/smart-gateway-mt7688/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/gardena/smart-gateway-mt7688/board.c b/board/gardena/smart-gateway-mt7688/board.c index bd494c84fc80..e9ffd42a8a68 100644 --- a/board/gardena/smart-gateway-mt7688/board.c +++ b/board/gardena/smart-gateway-mt7688/board.c @@ -18,7 +18,7 @@
#define FACTORY_DATA_OFFS 0xc0000 #define FACTORY_DATA_SECT_SIZE 0x10000 -#if ((CONFIG_ENV_OFFSET_REDUND + CONFIG_ENV_SIZE_REDUND) > FACTORY_DATA_OFFS) +#if ((CONFIG_ENV_OFFSET_REDUND + CONFIG_ENV_SIZE) > FACTORY_DATA_OFFS) #error "U-Boot image with environment too big (overlapping with factory-data)!" #endif #define FACTORY_DATA_USER_OFFS 0x140
Thanks, Stefan
Cc: Stefan Roese sr@denx.de Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Stefan Roese sr@denx.de
participants (7)
Joe Hershberger
Joseph Hershberger
Priyanka Jain
Simon Goldschmidt
Stefan Roese
