[PATCH] phy: usbphyc: use regulator_set_enable_if_allowed for disabling vbus supply
Use regulator_set_enable_if_allowed() api instead of regulator_set_enable() while disabling vbus supply. This way the driver doesn't see an error when it disable an always-on regulator for VBUS.
This patch is needed for STM32MP157C-DK2 board when the regulator v3v3: buck4 used as the phy vbus supply in kernel device tree is always on with the next hack for low power use-case:
&usbphyc_port0 { ... /* * Hack to keep hub active until all connected devices are suspended * otherwise the hub will be powered off as soon as the v3v3 is disabled * and it can disturb connected devices. */ connector { compatible = "usb-a-connector"; vbus-supply = <&v3v3>; }; };
Without this patch and the previous update in DT the command "usb stop" failed and the next command "usb start" cause a crash.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
drivers/phy/phy-stm32-usbphyc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/phy/phy-stm32-usbphyc.c b/drivers/phy/phy-stm32-usbphyc.c index 9f0b7d71187..dcf2194e9a7 100644 --- a/drivers/phy/phy-stm32-usbphyc.c +++ b/drivers/phy/phy-stm32-usbphyc.c @@ -375,7 +375,7 @@ static int stm32_usbphyc_phy_power_off(struct phy *phy) return 0;
if (usbphyc_phy->vbus) { - ret = regulator_set_enable(usbphyc_phy->vbus, false); + ret = regulator_set_enable_if_allowed(usbphyc_phy->vbus, false); if (ret) return ret; }
Hi Patrick
if (ret) return ret; }ret = regulator_set_enable_if_allowed(usbphyc_phy->vbus, false);
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Hi Patrick
On 9/26/22 09:07, Patrice CHOTARD wrote:
Hi Patrick
Thanks Patrice _______________________________________________ Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Applied to u-boot-stm/master
Thanks Patrice
Hi Marek,
Can you reviewed this minor patch for v2023.01-rc1 ?
Thanks.
Patrick
On 10/26/22 15:09, Patrick DELAUNAY wrote:
Hi Marek,
diff --git a/drivers/phy/phy-stm32-usbphyc.c b/drivers/phy/phy-stm32-usbphyc.c index 9f0b7d71187..dcf2194e9a7 100644 --- a/drivers/phy/phy-stm32-usbphyc.c +++ b/drivers/phy/phy-stm32-usbphyc.c @@ -375,7 +375,7 @@ static int stm32_usbphyc_phy_power_off(struct phy *phy) return 0; if (usbphyc_phy->vbus) { - ret = regulator_set_enable(usbphyc_phy->vbus, false); + ret = regulator_set_enable_if_allowed(usbphyc_phy->vbus, false); if (ret) return ret; }
Seems OK to me:
Thanks
Patrice CHOTARD
Patrick DELAUNAY
Patrick Delaunay
