[PATCH v2] bootcount_ext: Add flag to enable/disable bootcount
After a successful upgrade, multiple problem during boot sequence may trigger the altbootcmd process. This patch adds a version and an upgrade_available entries to the bootcount file to enable/disable the bootcount check. When failing to read the bootcount file it will consider that bootcount is enabled, acting as previously, and update the file accordingly.
The bootcount file is only saved when `upgrade_available` is true, this allows to save writes to the filesystem.
Signed-off-by: Frédéric Danis frederic.danis@collabora.com --- doc/README.bootcount | 51 +++++++++++++++++++++++++++++++ drivers/bootcount/bootcount_ext.c | 46 ++++++++++++++++++++-------- 2 files changed, 85 insertions(+), 12 deletions(-) create mode 100644 doc/README.bootcount
diff --git a/doc/README.bootcount b/doc/README.bootcount new file mode 100644 index 0000000000..b1c22905c6 --- /dev/null +++ b/doc/README.bootcount @@ -0,0 +1,51 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Boot Count Limit +================ + +This allows to detect multiple failed attempts to boot Linux. + +After a power-on reset, "bootcount" variable will be initialized with 1, and +each reboot will increment the value by 1. + +If, after a reboot, the new value of "bootcount" exceeds the value of +"bootlimit", then instead of the standard boot action (executing the contents of +"bootcmd") an alternate boot action will be performed, and the contents of +"altbootcmd" will be executed. + +If the variable "bootlimit" is not defined in the environment, the Boot Count +Limit feature is disabled. If it is enabled, but "altbootcmd" is not defined, +then U-Boot will drop into interactive mode and remain there. + +It is the responsibility of some application code (typically a Linux +application) to reset the variable "bootcount", thus allowing for more boot +cycles. + +BOOTCOUNT_EXT +------------- + +This adds support for maintaining boot count in a file on an EXT filesystem. +The file to use is define by: + +SYS_BOOTCOUNT_EXT_INTERFACE +SYS_BOOTCOUNT_EXT_DEVPART +SYS_BOOTCOUNT_EXT_NAME + +The format of the file is: + +==== ================= +type entry +==== ================= +u8 magic +u8 version +u8 bootcount +u8 upgrade_available +==== ================= + +To prevent unattended usage of "altbootcmd" the "upgrade_available" variable is +used. +If "upgrade_available" is 0, "bootcount" is not saved, if "upgrade_available" is +1 "bootcount" is save. +So the Userspace Application must set the "upgrade_available" and "bootcount" +variables to 0, if a boot was successfully. +This also prevents writes on all reboots. diff --git a/drivers/bootcount/bootcount_ext.c b/drivers/bootcount/bootcount_ext.c index 075e590896..9639e638e9 100644 --- a/drivers/bootcount/bootcount_ext.c +++ b/drivers/bootcount/bootcount_ext.c @@ -7,11 +7,21 @@ #include <fs.h> #include <mapmem.h>
-#define BC_MAGIC 0xbc +#define BC_MAGIC 0xbd +#define BC_VERSION 1 + +typedef struct { + u8 magic; + u8 version; + u8 bootcount; + u8 upgrade_available; +} bootcount_ext_t; + +static u8 upgrade_available = 1;
void bootcount_store(ulong a) { - u8 *buf; + bootcount_ext_t *buf; loff_t len; int ret;
@@ -21,20 +31,27 @@ void bootcount_store(ulong a) return; }
- buf = map_sysmem(CONFIG_SYS_BOOTCOUNT_ADDR, 2); - buf[0] = BC_MAGIC; - buf[1] = (a & 0xff); + /* Only update bootcount during upgrade process */ + if (!upgrade_available) + return; + + buf = map_sysmem(CONFIG_SYS_BOOTCOUNT_ADDR, sizeof(bootcount_ext_t)); + buf->magic = BC_MAGIC; + buf->version = BC_VERSION; + buf->bootcount = (a & 0xff); + buf->upgrade_available = upgrade_available; unmap_sysmem(buf);
ret = fs_write(CONFIG_SYS_BOOTCOUNT_EXT_NAME, - CONFIG_SYS_BOOTCOUNT_ADDR, 0, 2, &len); + CONFIG_SYS_BOOTCOUNT_ADDR, 0, sizeof(bootcount_ext_t), + &len); if (ret != 0) puts("Error storing bootcount\n"); }
ulong bootcount_load(void) { - u8 *buf; + bootcount_ext_t *buf; loff_t len_read; int ret;
@@ -45,15 +62,20 @@ ulong bootcount_load(void) }
ret = fs_read(CONFIG_SYS_BOOTCOUNT_EXT_NAME, CONFIG_SYS_BOOTCOUNT_ADDR, - 0, 2, &len_read); - if (ret != 0 || len_read != 2) { + 0, sizeof(bootcount_ext_t), &len_read); + if (ret != 0 || len_read != sizeof(bootcount_ext_t)) { puts("Error loading bootcount\n"); return 0; }
- buf = map_sysmem(CONFIG_SYS_BOOTCOUNT_ADDR, 2); - if (buf[0] == BC_MAGIC) - ret = buf[1]; + buf = map_sysmem(CONFIG_SYS_BOOTCOUNT_ADDR, sizeof(bootcount_ext_t)); + if (buf->magic == BC_MAGIC && buf->version == BC_VERSION) { + upgrade_available = buf->upgrade_available; + if (upgrade_available) + ret = buf->bootcount; + } else { + puts("Incorrect bootcount file\n"); + }
unmap_sysmem(buf);
Hi Frédéric,
On Tue, 17 Mar 2020 at 10:59, Frédéric Danis frederic.danis@collabora.com wrote:
Is there a change log? I see that this is v2.
Hi Simon,
Sorry I missed to add the change log.
Since v1: - Add doc/README.bootcount - Add version number in bootcount_ext file and change Magic byte
Regards, Fred
On 18/03/2020 03:17, Simon Glass wrote:
Hi Frédéric,
On Wed, 18 Mar 2020 at 02:17, Frédéric Danis frederic.danis@collabora.com wrote:
Hi Simon,
Since v1:
Regards, Fred
Hi Frédéric,
Hi Simon,
Hi Simon,
Since v1:
Thanks for the review. What should be the next steps to get this commit merged? Should I need to send a new version with your Reviewed-By, or should it need to be reviewed by someone else?
Fred
Hi Fred,
On Mon, 23 Mar 2020 at 10:20, Frédéric Danis frederic.danis@collabora.com wrote:
Hi Simon,
Hi Simon,
Since v1:
I'm not sure if anyone else will review it. Tom may pull it into his next branch, or otherwise it will be merged when the merge window opens.
Hi Tom,
On 23/03/2020 19:42, Simon Glass wrote:
Hi Fred,
Hi Simon,
Hi Simon,
Since v1:
Can I hope this is merged in next version?
Frédéric Danis
Signed-off-by: Frédéric Danis frederic.danis@collabora.com Reviewed-by: Simon Glass sjg@chromium.org
Frédéric Danis
