[PATCH v2 0/3] Broadcom bcmbca dts updates
Updates for Broadcom bcmbca devices, make use of OF_UPSTREAM which uses Linux dts, update bcmbca dts to current nand node naming convention, enable basic nand functionality for bcmbca devices.
Changes in v2: - Removed addition of nand-on-flash-bbt parameter - Moved enabling of nand functionality to a new patch added to the series
david regan (3): arm: dts: Use upstream dts for additional bcmbca devices arm: dts: Update nand node for bcmbca board dts arm: dts: Enable basic nand functionality for bcmbca devices
arch/arm/dts/bcm4908.dtsi | 127 ---------------------- arch/arm/dts/bcm63138.dtsi | 149 -------------------------- arch/arm/dts/bcm63148.dtsi | 103 ------------------ arch/arm/dts/bcm94908.dts | 30 ------ arch/arm/dts/bcm963138.dts | 30 ------ arch/arm/dts/bcm963148.dts | 30 ------ arch/arm/dts/bcm96753ref.dts | 18 ++-- arch/arm/dts/bcm968360bg.dts | 18 ++-- arch/arm/dts/bcm968580xref.dts | 18 ++-- arch/arm/mach-bcmbca/bcm4908/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63138/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63148/Kconfig | 1 + configs/bcm94908_defconfig | 11 +- configs/bcm963138_defconfig | 11 +- configs/bcm963148_defconfig | 11 +- 15 files changed, 54 insertions(+), 505 deletions(-) delete mode 100644 arch/arm/dts/bcm4908.dtsi delete mode 100644 arch/arm/dts/bcm63138.dtsi delete mode 100644 arch/arm/dts/bcm63148.dtsi delete mode 100644 arch/arm/dts/bcm94908.dts delete mode 100644 arch/arm/dts/bcm963138.dts delete mode 100644 arch/arm/dts/bcm963148.dts
Make use of OF_UPSTREAM which uses Linux dts.
Changes in v2: - Removed enabling of nand functionality
Signed-off-by: david degan dregan@broadcom.com Reviewed-by: William Zhang william.zhang@broadcom.com Reviewed-by: Anand Gore anand.gore@broadcom.com --- arch/arm/dts/bcm4908.dtsi | 127 ---------------------- arch/arm/dts/bcm63138.dtsi | 149 -------------------------- arch/arm/dts/bcm63148.dtsi | 103 ------------------ arch/arm/dts/bcm94908.dts | 30 ------ arch/arm/dts/bcm963138.dts | 30 ------ arch/arm/dts/bcm963148.dts | 30 ------ arch/arm/mach-bcmbca/bcm4908/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63138/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63148/Kconfig | 1 + configs/bcm94908_defconfig | 3 +- configs/bcm963138_defconfig | 3 +- configs/bcm963148_defconfig | 3 +- 12 files changed, 9 insertions(+), 472 deletions(-) delete mode 100644 arch/arm/dts/bcm4908.dtsi delete mode 100644 arch/arm/dts/bcm63138.dtsi delete mode 100644 arch/arm/dts/bcm63148.dtsi delete mode 100644 arch/arm/dts/bcm94908.dts delete mode 100644 arch/arm/dts/bcm963138.dts delete mode 100644 arch/arm/dts/bcm963148.dts
diff --git a/arch/arm/dts/bcm4908.dtsi b/arch/arm/dts/bcm4908.dtsi deleted file mode 100644 index 0be5cfeeffa9..000000000000 --- a/arch/arm/dts/bcm4908.dtsi +++ /dev/null @@ -1,127 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> - -/dts-v1/; - -/ { - compatible = "brcm,bcm4908", "brcm,bcmbca"; - - interrupt-parent = <&gic>; - - #address-cells = <2>; - #size-cells = <2>; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "brcm,brahma-b53"; - reg = <0x0>; - enable-method = "spin-table"; - cpu-release-addr = <0x0 0xfff8>; - next-level-cache = <&l2>; - }; - - cpu1: cpu@1 { - device_type = "cpu"; - compatible = "brcm,brahma-b53"; - reg = <0x1>; - enable-method = "spin-table"; - cpu-release-addr = <0x0 0xfff8>; - next-level-cache = <&l2>; - }; - - cpu2: cpu@2 { - device_type = "cpu"; - compatible = "brcm,brahma-b53"; - reg = <0x2>; - enable-method = "spin-table"; - cpu-release-addr = <0x0 0xfff8>; - next-level-cache = <&l2>; - }; - - cpu3: cpu@3 { - device_type = "cpu"; - compatible = "brcm,brahma-b53"; - reg = <0x3>; - enable-method = "spin-table"; - cpu-release-addr = <0x0 0xfff8>; - next-level-cache = <&l2>; - }; - - l2: l2-cache0 { - compatible = "cache"; - }; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x00 0x00 0x81000000 0x4000>; - - gic: interrupt-controller@1000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x1000 0x1000>, - <0x2000 0x2000>; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - }; - - pmu { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; - }; - - clocks { - periph_clk: periph_clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <50000000>; - clock-output-names = "periph"; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x00 0x00 0xff800000 0x3000>; - - uart0: serial@640 { - compatible = "brcm,bcm6345-uart"; - reg = <0x640 0x18>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&periph_clk>; - clock-names = "refclk"; - status = "disabled"; - }; - - }; -}; diff --git a/arch/arm/dts/bcm63138.dtsi b/arch/arm/dts/bcm63138.dtsi deleted file mode 100644 index 42b442aec9f4..000000000000 --- a/arch/arm/dts/bcm63138.dtsi +++ /dev/null @@ -1,149 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Broadcom BCM63138 DSL SoCs Device Tree - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> - -/ { - compatible = "brcm,bcm63138", "brcm,bcmbca"; - #address-cells = <1>; - #size-cells = <1>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a9"; - next-level-cache = <&L2>; - reg = <0>; - enable-method = "brcm,bcm63138"; - }; - - cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a9"; - next-level-cache = <&L2>; - reg = <1>; - enable-method = "brcm,bcm63138"; - }; - }; - - clocks { - /* UBUS peripheral clock */ - periph_clk: periph_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <50000000>; - clock-output-names = "periph"; - }; - - /* peripheral clock for system timer */ - axi_clk: axi_clk { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&armpll>; - clock-div = <2>; - clock-mult = <1>; - }; - - /* APB bus clock */ - apb_clk: apb_clk { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&armpll>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - /* ARM bus */ - axi@80000000 { - compatible = "simple-bus"; - ranges = <0 0x80000000 0x784000>; - #address-cells = <1>; - #size-cells = <1>; - - L2: cache-controller@1d000 { - compatible = "arm,pl310-cache"; - reg = <0x1d000 0x1000>; - cache-unified; - cache-level = <2>; - cache-size = <524288>; - cache-sets = <1024>; - cache-line-size = <32>; - interrupts = <GIC_PPI 0 IRQ_TYPE_LEVEL_HIGH>; - }; - - scu: scu@1e000 { - compatible = "arm,cortex-a9-scu"; - reg = <0x1e000 0x100>; - }; - - gic: interrupt-controller@1f000 { - compatible = "arm,cortex-a9-gic"; - reg = <0x1f000 0x1000 - 0x1e100 0x100>; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - }; - - global_timer: timer@1e200 { - compatible = "arm,cortex-a9-global-timer"; - reg = <0x1e200 0x20>; - interrupts = <GIC_PPI 11 IRQ_TYPE_EDGE_RISING>; - clocks = <&axi_clk>; - }; - - local_timer: local-timer@1e600 { - compatible = "arm,cortex-a9-twd-timer"; - reg = <0x1e600 0x20>; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | - IRQ_TYPE_EDGE_RISING)>; - clocks = <&axi_clk>; - }; - - twd_watchdog: watchdog@1e620 { - compatible = "arm,cortex-a9-twd-wdt"; - reg = <0x1e620 0x20>; - interrupts = <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | - IRQ_TYPE_LEVEL_HIGH)>; - }; - - armpll: armpll@20000 { - #clock-cells = <0>; - compatible = "brcm,bcm63138-armpll"; - clocks = <&periph_clk>; - reg = <0x20000 0xf00>; - }; - }; - - /* Legacy UBUS base */ - bus@fffe8000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0xfffe8000 0x8000>; - - timer0: timer@80 { - compatible = "brcm,bcmbca-periph-timer"; - reg = <0x80 0x28>; - clocks = <&periph_clk>; - }; - - uart0: serial@600 { - compatible = "brcm,bcm6345-uart"; - reg = <0x600 0x20>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&periph_clk>; - clock-names = "refclk"; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm63148.dtsi b/arch/arm/dts/bcm63148.dtsi deleted file mode 100644 index df5307b6b3af..000000000000 --- a/arch/arm/dts/bcm63148.dtsi +++ /dev/null @@ -1,103 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> - -/ { - compatible = "brcm,bcm63148", "brcm,bcmbca"; - #address-cells = <1>; - #size-cells = <1>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - B15_0: cpu@0 { - device_type = "cpu"; - compatible = "brcm,brahma-b15"; - reg = <0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B15_1: cpu@1 { - device_type = "cpu"; - compatible = "brcm,brahma-b15"; - reg = <0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; - - pmu: pmu { - compatible = "arm,cortex-a15-pmu"; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&B15_0>, <&B15_1>; - }; - - clocks: clocks { - periph_clk: periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <50000000>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@80030000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x80030000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,cortex-a15-gic"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x1000 0x1000>, - <0x2000 0x2000>, - <0x4000 0x2000>, - <0x6000 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | - IRQ_TYPE_LEVEL_HIGH)>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0xfffe8000 0x8000>; - - uart0: serial@600 { - compatible = "brcm,bcm6345-uart"; - reg = <0x600 0x20>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&periph_clk>; - clock-names = "refclk"; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm94908.dts b/arch/arm/dts/bcm94908.dts deleted file mode 100644 index fcbd3c430ace..000000000000 --- a/arch/arm/dts/bcm94908.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm4908.dtsi" - -/ { - model = "Broadcom BCM94908 Reference Board"; - compatible = "brcm,bcm94908", "brcm,bcm4908", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm963138.dts b/arch/arm/dts/bcm963138.dts deleted file mode 100644 index 6158a8733554..000000000000 --- a/arch/arm/dts/bcm963138.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm63138.dtsi" - -/ { - model = "Broadcom BCM963138 Reference Board"; - compatible = "brcm,bcm963138", "brcm,bcm63138", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm963148.dts b/arch/arm/dts/bcm963148.dts deleted file mode 100644 index 98f6a6d09f50..000000000000 --- a/arch/arm/dts/bcm963148.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2019 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm63148.dtsi" - -/ { - model = "Broadcom BCM963148 Reference Board"; - compatible = "brcm,bcm963148", "brcm,bcm63148", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/mach-bcmbca/bcm4908/Kconfig b/arch/arm/mach-bcmbca/bcm4908/Kconfig index 564bc8d2d664..9131505fa7c8 100644 --- a/arch/arm/mach-bcmbca/bcm4908/Kconfig +++ b/arch/arm/mach-bcmbca/bcm4908/Kconfig @@ -8,6 +8,7 @@ if BCM4908 config TARGET_BCM94908 bool "Broadcom 4908 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm4908" diff --git a/arch/arm/mach-bcmbca/bcm63138/Kconfig b/arch/arm/mach-bcmbca/bcm63138/Kconfig index a34888d231d3..9b7db352f84d 100644 --- a/arch/arm/mach-bcmbca/bcm63138/Kconfig +++ b/arch/arm/mach-bcmbca/bcm63138/Kconfig @@ -8,6 +8,7 @@ if BCM63138 config TARGET_BCM963138 bool "Broadcom 63138 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm63138" diff --git a/arch/arm/mach-bcmbca/bcm63148/Kconfig b/arch/arm/mach-bcmbca/bcm63148/Kconfig index f81504c25cbb..a3c7b5bf8e45 100644 --- a/arch/arm/mach-bcmbca/bcm63148/Kconfig +++ b/arch/arm/mach-bcmbca/bcm63148/Kconfig @@ -8,6 +8,7 @@ if BCM63148 config TARGET_BCM963148 bool "Broadcom 63148 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm63148" diff --git a/configs/bcm94908_defconfig b/configs/bcm94908_defconfig index 3979c29e9323..0b6db9aa52e9 100644 --- a/configs/bcm94908_defconfig +++ b/configs/bcm94908_defconfig @@ -9,7 +9,7 @@ CONFIG_TARGET_BCM94908=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm94908" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcmbca/bcm94908" CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM4908" CONFIG_ENV_VARS_UBOOT_CONFIG=y @@ -17,5 +17,6 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CACHE=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y CONFIG_CLK=y diff --git a/configs/bcm963138_defconfig b/configs/bcm963138_defconfig index cc2ffe5fcd29..9459a232560d 100644 --- a/configs/bcm963138_defconfig +++ b/configs/bcm963138_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_BCM963138=y CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm963138" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcm963138" CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM63138" @@ -17,5 +17,6 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CACHE=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y CONFIG_CLK=y diff --git a/configs/bcm963148_defconfig b/configs/bcm963148_defconfig index a0dd06ba505a..d6fbc34927cb 100644 --- a/configs/bcm963148_defconfig +++ b/configs/bcm963148_defconfig @@ -9,7 +9,7 @@ CONFIG_TARGET_BCM963148=y CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm963148" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcm963148" CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM63148" @@ -18,5 +18,6 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CACHE=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y CONFIG_CLK=y
Update bcmbca dts to current nand node naming convention.
Signed-off-by: david regan dregan@broadcom.com Reviewed-by: William Zhang william.zhang@broadcom.com Reviewed-by: Anand Gore anand.gore@broadcom.com --- arch/arm/dts/bcm96753ref.dts | 18 +++++++----------- arch/arm/dts/bcm968360bg.dts | 18 +++++++----------- arch/arm/dts/bcm968580xref.dts | 18 +++++++----------- 3 files changed, 21 insertions(+), 33 deletions(-)
diff --git a/arch/arm/dts/bcm96753ref.dts b/arch/arm/dts/bcm96753ref.dts index ebc8c8e4ce77..c763358514fc 100644 --- a/arch/arm/dts/bcm96753ref.dts +++ b/arch/arm/dts/bcm96753ref.dts @@ -64,19 +64,15 @@ status = "okay"; };
-&nand { +&nand_controller { + brcm,wp-not-connected; status = "okay"; - write-protect = <0>; - #address-cells = <1>; - #size-cells = <0>; +};
- nandcs@0 { - compatible = "brcm,nandcs"; - reg = <0>; - nand-ecc-strength = <4>; - nand-ecc-step-size = <512>; - brcm,nand-oob-sector-size = <16>; - }; +&nandcs { + nand-ecc-strength = <4>; + nand-ecc-step-size = <512>; + brcm,nand-oob-sector-size = <16>; };
&leds { diff --git a/arch/arm/dts/bcm968360bg.dts b/arch/arm/dts/bcm968360bg.dts index 1335f484ee6c..a5b30f4e4a6b 100644 --- a/arch/arm/dts/bcm968360bg.dts +++ b/arch/arm/dts/bcm968360bg.dts @@ -62,19 +62,15 @@ status = "okay"; };
&leds { diff --git a/arch/arm/dts/bcm968580xref.dts b/arch/arm/dts/bcm968580xref.dts index 9aa45877b543..77616023010e 100644 --- a/arch/arm/dts/bcm968580xref.dts +++ b/arch/arm/dts/bcm968580xref.dts @@ -62,19 +62,15 @@ status = "okay"; };
&leds {
Enable rudimentary nand read/write capability.
Changes in v2: - New patch in series added enabling of nand functionality
Signed-off-by: david regan dregan@broadcom.com Reviewed-by: William Zhang william.zhang@broadcom.com Reviewed-by: Anand Gore anand.gore@broadcom.com --- configs/bcm94908_defconfig | 8 ++++++++ configs/bcm963138_defconfig | 8 ++++++++ configs/bcm963148_defconfig | 8 ++++++++ 3 files changed, 24 insertions(+)
diff --git a/configs/bcm94908_defconfig b/configs/bcm94908_defconfig index 0b6db9aa52e9..e651212d6853 100644 --- a/configs/bcm94908_defconfig +++ b/configs/bcm94908_defconfig @@ -16,7 +16,15 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm963138_defconfig b/configs/bcm963138_defconfig index 9459a232560d..f1f83dc2f1be 100644 --- a/configs/bcm963138_defconfig +++ b/configs/bcm963138_defconfig @@ -16,7 +16,15 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm963148_defconfig b/configs/bcm963148_defconfig index d6fbc34927cb..579fdd5d22c3 100644 --- a/configs/bcm963148_defconfig +++ b/configs/bcm963148_defconfig @@ -17,7 +17,15 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y
Changes in v2:
david regan
